bij deze de logbestanden:
Malwarebytes' Anti-Malware 1.45
www.malwarebytes.org
Databaseversie: 4041
Internet Explorer 8.0.6001.18702
27-4-2010 15:17:44
mbam-log-2010-04-27 (15-17-44).txt
Scantype: Snelle scan
Objecten gescand: 124600
Verstreken tijd: 9 minuut/minuten, 0 seconde(n)
Registerdata geïnfecteerd: 0
Mappen geïnfecteerd: 0
Bestanden geïnfecteerd: 0
Geheugenmodulen geïnfecteerd:
Registerwaarden geïnfecteerd:
Scan saved at 15:37:28, on 27-4-2010
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Common Files\Ahead\lib\NMBgMonitor.exe
C:\WINDOWS\system32\rundll32.exe
C:\Program Files\MSN Messenger\msnmsgr.exe
C:\WINDOWS\system32\wscntfy.exe
C:\WINDOWS\system32\wuauclt.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = Hyves.nl: always in touch with your friends
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Windows Internet Explorer provided by Hyves
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [AdobeCS4ServiceManager] "C:\Program Files\Common Files\Adobe\CS4ServiceManager\CS4ServiceManager.exe" -launchedbylogin
O4 - HKCU\..\Run: [bgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] "C:\Program Files\Common Files\Ahead\lib\NMBgMonitor.exe"
O4 - HKCU\..\Run: [updateMgr] "C:\Program Files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe" AcRdB7_0_9 -reboot 1
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\MSN Messenger\msnmsgr.exe" /background
O8 - Extra context menu item: E&xporteren naar Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O16 - DPF: {D3166EE4-3E00-46CA-8F62-8E01D2314A7F} - http://www.cig.canon-europe.com/ph/nl_NL/st/download/ddup/CNIMGUP_01_210102E.cab
O16 - DPF: {EDFCB7CB-942C-4822-AF14-F0B687409848} (Image Uploader Control) - http://cache.hyves-static.net/statics/Aurigma/ImageUploader4.cab
O23 - Service: FLEXnet Licensing Service - Acresso Software Inc. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
End of file - 4894 bytes
Dit zier prima uit. Nog even dit als extraatje :
Download Combofix naar je Bureaublad.
Lees hier meer over correct gebruik van Combofix.
OPMERKING: indien je, tijdens of na het downloaden van Combofix of tijdens het gebruik van Combofix een melding krijgt van je Antivirus- of een andere realtime scanner, schakel dan deze scanner uit en download Combofix opnieuw.
Sommige scanners zien bepaalde componenten die Combofix gebruikt als verdacht en gaan deze blokkeren of verwijderen!
  • Dubbelklik op Combofix.exe om het te starten.
    Indien je Combofix al eerder hebt gebruikt, kan je een waarschuwing krijgen dat een update beschikbaar is. Sta toe dat ComboFix wordt geupdate.
    Volg de instructies, aanvaard de disclaimer door op Ja te klikken.
    Indien de Recovery Console niet geïnstalleerd is, wordt je gevraagd om dit alsnog te doen door op JA te klikken in het "Query - Recovery Console" venster (enkel voor XP, niet voor VISTA).
    Klik op OK en Ja om automatisch de Recovery Console te laten installeren.
    Klik na afloop terug op Ja om het scannen op malware te starten.
    Tijdens het runnen van de fix, NIET in het venster klikken, want dit zal je pc doen vasthangen.
Wanneer de fix voltooid is en na herstart, zal de log Combofix.txt openen.
Post dit logje in je volgende antwoord.
bij deze weer het logje :)
ComboFix 10-04-26.04 - MSuser 27-04-2010 17:37:58.1.1 - x86 NETWORK
Microsoft Windows XP Home Edition 5.1.2600.3.1252.31.1043.18.1023.800 [GMT 2:00]
Gestart vanuit: c:\documents and settings\nielzie\Bureaublad\ComboFix.exe
ADS - WINDOWS: deleted 0 bytes in 1 streams.
F:\install.exe
(((((((((((((((((((( Bestanden Gemaakt van 2010-03-27 to 2010-04-27 ))))))))))))))))))))))))))))))
2010-04-27 12:00 . 2010-04-27 12:00 -------- d-----w- c:\documents and settings\MSuser\Application Data\Malwarebytes
2010-04-27 12:00 . 2010-03-29 22:46 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2010-04-27 12:00 . 2010-04-27 12:00 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2010-04-27 12:00 . 2010-04-27 12:00 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2010-04-27 12:00 . 2010-03-29 22:45 20824 ----a-w- c:\windows\system32\drivers\mbam.sys
2010-04-26 15:29 . 2008-04-14 20:32 4255 ------w- c:\windows\system32\drivers\adv01nt5.dll
2010-04-26 15:24 . 2010-04-26 15:24 -------- d-----w- c:\windows\EHome
2010-04-26 13:35 . 2010-04-27 13:38 -------- d-----w- c:\program files\AVI DivX to DVD SVCD VCD Converter
2010-04-26 13:30 . 2010-04-26 13:30 -------- d-----w- c:\documents and settings\MSuser\Local Settings\Application Data\Badger I.T
2010-04-26 12:10 . 2010-04-26 12:10 -------- d-----w- c:\windows\~nsu.tmp
2010-04-26 07:04 . 2010-04-26 07:04 388096 ----a-r- c:\documents and settings\MSuser\Application Data\Microsoft\Installer\{45A66726-69BC-466B-A7A4-12FCBA4883D7}\HiJackThis.exe
2010-04-26 07:04 . 2010-04-26 07:04 -------- d-----w- c:\program files\Trend Micro
2010-04-26 06:27 . 2010-04-26 06:27 -------- d-----w- c:\documents and settings\MSuser\Local Settings\Application Data\Xenocode
2010-04-26 06:26 . 2010-04-26 06:26 -------- d-----w- c:\program files\BadgerIT
2010-04-25 14:39 . 2010-04-25 14:39 -------- d-----w- c:\program files\microsoft frontpage
2010-04-25 13:12 . 2010-04-25 13:12 -------- d-----w- c:\documents and settings\All Users\Application Data\Azureus
2010-04-25 13:12 . 2010-04-27 13:38 -------- d-----w- c:\documents and settings\MSuser\Application Data\Azureus
2010-04-25 13:11 . 2010-04-25 13:12 -------- d-----w- c:\program files\Vuze
2010-04-25 13:11 . 2010-04-25 14:44 -------- d-----w- c:\documents and settings\MSuser\Local Settings\Application Data\Vuze_Remote
2010-04-25 13:11 . 2010-04-25 13:11 -------- d-----w- c:\program files\Vuze_Remote
2010-04-25 13:11 . 2010-04-25 13:11 -------- d-----w- c:\documents and settings\MSuser\Local Settings\Application Data\Conduit
2010-04-22 19:13 . 2010-04-22 19:13 -------- d-----w- c:\documents and settings\All Users\Application Data\AVS4YOU
2010-04-22 19:12 . 2010-04-25 13:06 -------- d-----w- c:\program files\Common Files\AVSMedia
2010-04-21 17:05 . 2010-04-21 17:05 -------- d-----w- c:\documents and settings\MSuser\Local Settings\Application Data\LooksBuilder
2010-04-03 10:24 . 2010-02-12 10:03 293376 ------w- c:\windows\system32\browserchoice.exe
2010-04-27 15:37 . 2004-08-04 12:00 91632 ----a-w- c:\windows\system32\perfc013.dat
2010-04-27 15:37 . 2004-08-04 12:00 511866 ----a-w- c:\windows\system32\perfh013.dat
2010-04-26 15:54 . 2009-11-09 12:28 -------- d-----w- c:\program files\MSN Messenger
2010-04-26 15:35 . 2006-04-03 11:38 76487 ----a-w- c:\windows\pchealth\helpctr\OfflineCache\index.dat
2010-04-21 08:50 . 2006-04-09 10:09 37472 -c-ha-w- c:\windows\Fonts\infoview.fon
2010-04-13 21:24 . 2009-11-23 17:51 79488 ----a-w- c:\documents and settings\MSuser\Application Data\Sun\Java\jre1.6.0_17\gtapi.dll
2010-04-13 20:44 . 2006-11-04 20:41 -------- d-----w- c:\documents and settings\MSuser\Application Data\U3
2010-03-20 11:35 . 2010-03-20 11:35 -------- d-----w- c:\documents and settings\Administrator\Application Data\TweakNow RegCleaner
2010-03-20 11:19 . 2010-03-20 11:19 45792 ----a-w- c:\documents and settings\Administrator\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2010-03-10 06:17 . 2004-08-04 12:00 420352 ----a-w- c:\windows\system32\vbscript.dll
2010-02-25 06:20 . 2004-08-04 12:00 916480 ----a-w- c:\windows\system32\wininet.dll
2010-02-24 13:11 . 2004-08-04 12:00 455680 ----a-w- c:\windows\system32\drivers\mrxsmb.sys
2010-02-17 12:09 . 2004-08-04 12:00 2194304 ----a-w- c:\windows\system32\ntoskrnl.exe
2010-02-16 19:09 . 2004-08-04 00:58 2071168 ----a-w- c:\windows\system32\ntkrnlpa.exe
2010-02-12 04:35 . 2004-08-04 12:00 100864 ----a-w- c:\windows\system32\6to4svc.dll
2010-02-11 12:02 . 2004-08-04 12:00 226880 ----a-w- c:\windows\system32\drivers\tcpip6.sys
2010-02-04 16:33 . 2006-04-03 12:45 45792 -c--a-w- c:\documents and settings\MSuser\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
------- Sigcheck -------
[-] 2005-01-28 11:44 . 140EF97B64F560FD78643CAE2CDAD838 . 25088 . . [10.0.3790.3802] . . c:\windows\RegisteredPackages\{30C7234B-6482-4A55-A11D-ECD9030313F2}\MsPMSNSv.dll
[-] 2005-01-28 11:44 . 140EF97B64F560FD78643CAE2CDAD838 . 25088 . . [10.0.3790.3802] . . c:\windows\system32\MsPMSNSv.dll
[-] 2005-01-28 11:44 . 140EF97B64F560FD78643CAE2CDAD838 . 25088 . . [10.0.3790.3802] . . c:\windows\system32\dllcache\mspmsnsv.dll
[-] 2004-08-04 12:00 . 2706E00334C86DD2E5279A47600C916A . 52736 . . [9.0.1.56] . . c:\windows\RegisteredPackages\{30C7234B-6482-4A55-A11D-ECD9030313F2}$BACKUP$\System\MsPMSNSv.dll
REGEDIT4
"BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}"="c:\program files\Common Files\Ahead\lib\NMBgMonitor.exe" [2005-09-03 94208]
"updateMgr"="c:\program files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe" [2006-03-30 313472]
"msnmsgr"="c:\program files\MSN Messenger\msnmsgr.exe" [2007-09-04 6856704]
"NvMediaCenter"="c:\windows\system32\NvMcTray.dll" [2006-03-09 86016]
"AdobeCS4ServiceManager"="c:\program files\Common Files\Adobe\CS4ServiceManager\CS4ServiceManager.exe" [2008-08-14 611712]
"CTFMON.EXE"="c:\windows\system32\CTFMON.EXE" [2008-04-14 15360]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\drivers32]
"wave9"=Echo24Wrap.dll
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Menu Start^Programma's^Opstarten^Adobe Reader Speed Launch.lnk]
path=c:\documents and settings\All Users\Menu Start\Programma's\Opstarten\Adobe Reader Speed Launch.lnk
backup=c:\windows\pss\Adobe Reader Speed Launch.lnkCommon Startup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\QuickTime Task]
2007-03-04 18:19 282624 ----a-w- c:\program files\QuickTime\qttask.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\services]
"ose"=3 (0x3)
"JavaQuickStarterService"=2 (0x2)
"idsvc"=3 (0x3)
"FLEXnet Licensing Service"=3 (0x3)
"CCALib8"=2 (0x2)
"Bonjour Service"=2 (0x2)
"astcc"=2 (0x2)
"ACDaemon"=3 (0x3)
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
"EnableFirewall"= 0 (0x0)
"c:\\Program Files\\Messenger\\msmsgs.exe"=
"c:\\Program Files\\BitTornado\\btdownloadgui.exe"=
"c:\\Program Files\\Bit Lord 1.1\\BitLord.exe"=
"c:\\Program Files\\Secway\\SimpLite-MSN 2.2\\SimpLite-MSN.exe"=
"c:\\Program Files\\Common Files\\Adobe\\CS4ServiceManager\\CS4ServiceManager.exe"=
"c:\\Program Files\\Vuze\\Azureus.exe"=
"%windir%\\Network Diagnostic\\xpnetdiag.exe"=
"c:\\Program Files\\MSN Messenger\\msnmsgr.exe"=
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]
"5353:TCP"= 5353:TCP:Adobe CSI CS4
S0 sptd;sptd;c:\windows\system32\drivers\sptd.sys [12-9-2006 13:18 682232]
S1 Scope;WDM Driver for Scope;c:\windows\system32\drivers\scope.sys [30-11-2001 16:00 103840]
S3 echo24;Gina24 Service;c:\windows\system32\drivers\echo24.sys [21-3-2003 14:07 544384]
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{CF185561-528F-E669-52CC-A7D98201A809}]
2009-02-13 17:21 102400 -c--a-w- c:\windows\system32\Sys32AoA.exe
2010-04-26 c:\windows\Tasks\Install_NSS.job
- c:\program files\Vuze\nssstub.exe [2010-04-25 13:12]
uStart Page = hxxp://www.google.nl/
uInternet Connection Wizard,ShellNext = iexplore
uInternet Settings,ProxyOverride = *.local
IE: E&xporteren naar Microsoft Excel - c:\progra~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
Trusted Zone: 0.0.0.0
Trusted Zone: ziggo.nl\thuishelp
DPF: {D3166EE4-3E00-46CA-8F62-8E01D2314A7F} - hxxp://www.cig.canon-europe.com/ph/nl_NL/st/download/ddup/CNIMGUP_01_210102E.cab
WebBrowser-{BA14329E-9550-4989-B3F2-9732E92D17CC} - (no file)
HKLM-Run-DisplayTrayIcon - (no file)
MSConfigStartUp-Adobe Photo Downloader - c:\program files\Adobe\Photoshop Album Starter Edition\3.0\Apps\apdproxy.exe
MSConfigStartUp-iTunesHelper - c:\program files\iTunes\iTunesHelper.exe
AddRemove-Titan Poker - c:\windows\Titan Poker setup.exe
AddRemove-TweakNow RegCleaner_is1 - c:\program files\TweakNow RegCleaner\unins000.exe
catchme 0.3.1398 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, GMER - Rootkit Detector and Remover
Rootkit scan 2010-04-27 17:43
Windows 5.1.2600 Service Pack 3 NTFS
Scan succesvol afgerond
verborgen bestanden: 0
[HKEY_LOCAL_MACHINE\software\Microsoft\Windows\CurrentVersion\Installer\UserData\LocalSystem\Components\Ø•€|ÿÿÿÿ•€|ù•9~*]
"3140110900063D11C8EF10054038389C"="C?\\WINDOWS\\system32\\FM20ENU.DLL"
--------------------- DLLs Geladen Onder Lopende Processen ---------------------
- - - - - - - > 'winlogon.exe'(424)
c:\program files\Common Files\Adobe\Adobe Drive CS4\AdobeDriveCS4_NP.dll
Voltooingstijd: 2010-04-27 17:46:21
ComboFix-quarantined-files.txt 2010-04-27 15:46
Pre-Run: 2.554.019.840 bytes beschikbaar
Post-Run: 3.038.035.968 bytes beschikbaar
WindowsXP-KB310994-SP2-Home-BootDisk-NLD.exe
[boot loader]
timeout=2
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
c:\cmdcons\BOOTSECT.DAT="Microsoft Windows Recovery Console" /cmdcons
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Current=2 Default=2 Failed=1 LastKnownGood=4 Sets=1,2,3,4
- - End Of File - - BE53FA15F5194975DED013D9A0765C16
Open een kladblokbestand.
File::
c:\windows\~nsu.tmp
Folder::
Registry::
[-HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{CF185561-528F-E669-52CC-A7D98201A809}]
top deze hulp zeg!
overigens heb ik geen idee of het relevant is om te zeggen maar ik voer de acties steeds in veilige modus uit omdat in normale modus het vaak niet mogelijk is de software te runnen.
bij deze weer de logjes:
ComboFix 10-04-27.02 - MSuser 28-04-2010 12:44:10.3.1 - x86 NETWORK
gebruikte Opdracht switches :: c:\documents and settings\nielzie\Bureaublad\CFScript.txt
FILE ::
"c:\windows\~nsu.tmp"
(((((((((((((((((((( Bestanden Gemaakt van 2010-03-28 to 2010-04-28 ))))))))))))))))))))))))))))))
2010-04-25 13:12 . 2010-04-27 16:15 -------- d-----w- c:\documents and settings\MSuser\Application Data\Azureus
2010-04-28 10:45 . 2004-08-04 12:00 511866 ----a-w- c:\windows\system32\perfh013.dat
2010-04-28 10:45 . 2004-08-04 12:00 91632 ----a-w- c:\windows\system32\perfc013.dat
((((((((((((((((((((((((((((( SnapShot@2010-04-27_15.43.59 )))))))))))))))))))))))))))))))))))))))))
- 2004-08-04 12:00 . 2008-04-14 20:32 90112 c:\windows\system32\wshext.dll
+ 2004-08-04 12:00 . 2008-05-09 10:56 90112 c:\windows\system32\wshext.dll
+ 2004-08-04 12:00 . 2010-04-28 10:45 71904 c:\windows\system32\perfc009.dat
- 2004-08-04 12:00 . 2010-04-27 15:37 71904 c:\windows\system32\perfc009.dat
+ 2008-05-09 10:56 . 2008-05-09 10:56 90112 c:\windows\system32\dllcache\wshext.dll
+ 2004-08-04 12:00 . 2008-05-08 11:24 155648 c:\windows\system32\wscript.exe
- 2004-08-04 12:00 . 2008-04-14 20:33 155648 c:\windows\system32\wscript.exe
+ 2004-08-04 12:00 . 2008-05-09 10:56 172032 c:\windows\system32\scrrun.dll
- 2004-08-04 12:00 . 2008-04-14 20:32 172032 c:\windows\system32\scrrun.dll
- 2004-08-04 12:00 . 2008-04-14 20:32 180224 c:\windows\system32\scrobj.dll
+ 2004-08-04 12:00 . 2008-05-09 10:56 180224 c:\windows\system32\scrobj.dll
+ 2004-08-04 12:00 . 2010-04-28 10:45 444028 c:\windows\system32\perfh009.dat
- 2004-08-04 12:00 . 2010-04-27 15:37 444028 c:\windows\system32\perfh009.dat
+ 2008-05-08 11:24 . 2008-05-08 11:24 155648 c:\windows\system32\dllcache\wscript.exe
+ 2008-05-09 10:56 . 2008-05-09 10:56 172032 c:\windows\system32\dllcache\scrrun.dll
+ 2008-05-09 10:56 . 2008-05-09 10:56 180224 c:\windows\system32\dllcache\scrobj.dll
+ 2008-05-07 09:07 . 2008-05-07 09:07 135168 c:\windows\system32\dllcache\cscript.exe
+ 2004-08-04 12:00 . 2008-05-07 09:07 135168 c:\windows\system32\cscript.exe
+ 2006-04-03 11:35 . 2009-06-10 07:22 2066432 c:\windows\system32\mstscax.dll
+ 2006-04-03 11:35 . 2009-06-10 07:22 2066432 c:\windows\system32\dllcache\mstscax.dll
REGEDIT4
"ose"=3 (0x3)
"idsvc"=3 (0x3)
"CCALib8"=2 (0x2)
"astcc"=2 (0x2)
"ACDaemon"=3 (0x3)
Rootkit scan 2010-04-28 12:51
- - - - - - - > 'winlogon.exe'(428)
Voltooingstijd: 2010-04-28 12:54:06
ComboFix-quarantined-files.txt 2010-04-28 10:53
ComboFix2.txt 2010-04-27 16:00
ComboFix3.txt 2010-04-27 15:46
Pre-Run: 2.840.088.576 bytes beschikbaar
Post-Run: 2.949.722.112 bytes beschikbaar
- - End Of File - - CB947C4A1EC60148F83A85029A57371B
Scan saved at 12:58:59, on 28-4-2010
Boot mode: Safe mode with network support
C:\WINDOWS\explorer.exe
C:\Program Files\internet explorer\iexplore.exe
End of file - 4255 bytes
Scan saved at 16:14:53, on 28-4-2010
End of file - 4547 bytes
  • 2 maanden later...
Sorry maar ik was deze uit het oog verloren :sad
In dit logje zitten geen fouten maar we zijn ondertussen al een tijdje verder.
Heb je nog problemen, plaats dan een nieuw logje; anders mag je het onderwerp afsluiten met de knop "opgelost"
