Hier is de scan van HiJackThis :
Scan saved at 0:29:24, on 30/08/2010
Platform: Windows 7 (WinNT 6.00.3504)
MSIE: Internet Explorer v8.00 (8.00.7600.16385)
C:\Program Files (x86)\Spybot - Search & Destroy\TeaTimer.exe
C:\Program Files (x86)\AVG\AVG9\avgtray.exe
C:\Program Files (x86)\AVG\AVG9\Identity Protection\agent\bin\avgidsmonitor.exe
C:\Program Files (x86)\Steam\steam.exe
C:\Users\Vincent\AppData\Local\Google\Chrome\Application\chrome.exe
C:\Program Files (x86)\HiJackThis\Trend Micro\HiJackThis\HiJackThis.exe
C:\Windows\SysWOW64\DllHost.exe
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files (x86)\AVG\AVG9\avgssie.dll
O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files (x86)\Spybot - Search & Destroy\SDHelper.dll
O2 - BHO: Windows Live Aanmelden - Help - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O4 - HKLM\..\Run: [AVG9_TRAY] C:\PROGRA~2\AVG\AVG9\avgtray.exe
O4 - HKCU\..\Run: [spybotSD TeaTimer] C:\Program Files (x86)\Spybot - Search & Destroy\TeaTimer.exe
O8 - Extra context menu item: E&xporteren naar Microsoft Excel - res://C:\PROGRA~2\MICROS~4\Office12\EXCEL.EXE/3000
O9 - Extra button: Skype add-on for Internet Explorer - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
O9 - Extra 'Tools' menuitem: Skype add-on for Internet Explorer - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~2\MICROS~4\Office12\REFIEBAR.DLL
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files (x86)\Spybot - Search & Destroy\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search && Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files (x86)\Spybot - Search & Destroy\SDHelper.dll
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files (x86)\AVG\AVG9\avgpp.dll
O23 - Service: Mobiel Apple apparaat (Apple Mobile Device) - Apple Inc. - C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service: AVG E-mail Scanner (avg9emc) - AVG Technologies CZ, s.r.o. - C:\Program Files (x86)\AVG\AVG9\avgemc.exe
O23 - Service: AVG WatchDog (avg9wd) - AVG Technologies CZ, s.r.o. - C:\Program Files (x86)\AVG\AVG9\avgwdsvc.exe
O23 - Service: AVG9IDSAgent (AVGIDSAgent) - AVG Technologies CZ, s.r.o. - C:\Program Files (x86)\AVG\AVG9\Identity Protection\Agent\Bin\AVGIDSAgent.exe
O23 - Service: Bonjour-service (Bonjour Service) - Apple Inc. - C:\Program Files (x86)\Bonjour\mDNSResponder.exe
O23 - Service: NVIDIA Display Driver Service (nvsvc) - Unknown owner - C:\Windows\system32\nvvsvc.exe (file missing)
O23 - Service: Steam Client Service - Valve Corporation - C:\Program Files (x86)\Common Files\Steam\SteamService.exe
O23 - Service: NVIDIA Stereoscopic 3D Driver Service (Stereo Service) - NVIDIA Corporation - C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvSCPAPISvr.exe
O23 - Service: SwitchBoard - Adobe Systems Incorporated - C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe
O23 - Service: @C:\Program Files (x86)\TuneUp Utilities 2010\TuneUpDefragService.exe,-1 (TuneUp.Defrag) - TuneUp Software - C:\Program Files (x86)\TuneUp Utilities 2010\TuneUpDefragService.exe
O23 - Service: TuneUp Utilities Service (TuneUp.UtilitiesSvc) - TuneUp Software - C:\Program Files (x86)\TuneUp Utilities 2010\TuneUpUtilitiesService64.exe
End of file - 8407 bytes
  • Reacties 55
Geen sporen van malware in dit logje. Doe nog even dit : Download http://www.besttechie.net/tools/mbam-setup.exe
Plak de inhoud van het logje in je volgende bericht.
Hier is de inhoud van de Log van MBAM :
Malwarebytes' Anti-Malware 1.46
Malwarebytes
Databaseversie: 4505
Windows 6.1.7600
Internet Explorer 8.0.7600.16385
30/08/2010 13:23:38
mbam-log-2010-08-30 (13-23-38).txt
Scantype: Snelle scan
Objecten gescand: 162374
Verstreken tijd: 3 minuut/minuten, 4 seconde(n)
Registerdata geïnfecteerd: 0
Mappen geïnfecteerd: 0
Bestanden geïnfecteerd: 1
Geheugenmodulen geïnfecteerd:
Registerwaarden geïnfecteerd:
C:\Windows\file_2.exe (Trojan.PWS) -> Quarantined and deleted successfully.
Moeilijke vraag.
Als je vroeger bij Vista geen probleem hebt dan zou je dat overwegen.
Maar je kan ook windows 7 opnieuw installeren mits formateren en voorkomen dat windows 7 tijdens de installatie op internet zoek naar audio driver en andere drivers.
Daarna kan je het weer aanzetten zodat de rest van de drivers worden geinstalleerd. Dat gebeurd bij update.
Zoals je zelf wel gemerkt hebt is windows 7 sneller dan Vista.
Windows 7 is inderdaad een pak sneller dan Vista en heeft ook veel meer mogelijkheden. Dit is een Windows 7 Home Premium, zou een zwaardere versie erop zetten misschien iets kunnen helpen?
En ja, je zei "Maar je kan ook windows 7 opnieuw installeren mits formateren". Staat er ergens op dit forum een uitleg over hoe je correct je PC formatteert?
Hier is de handleiding
Bij deel 6 ziet je op de tekening Drive Options en daar moet je klikken en dan staat er formateren.
Bij deel 5 kies je custom en daar kan je instellen dat je windows niet moet updaten.
Windows 7 prenium is een prima windows.
Ulitamate is zwaarder maar heeft wel iets meer beveiliging tools.
Maar dat is niet echt nodig voor de pc of laptop zelf.
Zegt maar luxe.
Ik heb ultimate maar als ik opnieuw zou kopen dan kies ik voor prenium.
Wat wel verschil uitmaakt is 32 of 64 bits.
Op gebied van snelheid maakt het niks uit.
Maar op gebied van opslaan gaat dat vlugger bij 64 bits.
