Ik kan geen Engels maar google vertaling heeft dit vertaald:
Go to Control Panel / Network Center
Click Advanced Settings to change parts.
Network Detection
Network Autodiscovery
File and Printer Sharing
Public Folder Sharing
Enable sharing etc ... ..
Link for file sharing
Select 128 bits but unless you have appliances that use 40 or 56 bit encryption.
With password protected sharing
Password protected sharing off.
Connection with home group
Connecting with Windows to manage group home (recommended)
Now click Save Changes
Now click on wireless network management.
Click on the router and possibly start.
Click to view full list (top right in network center)
There you select the wireless router.
This should you do if you want to switch between wireless and LAN
Note: If Windows 7 has difficulty with Wireless LAN and you do so even in network center
Click Change Setting Adapter
Depending on your wireless LAN, or one of the two off.
Would you share a folder in Windows 7 would do so:
Note: This only applies if your password is disabled.
Right at home to share with group (read and write)
Again, right-click properties
Click the Security tab and then click Edit.
Click Add and enter in the box and click OK everyone
Now you can see in the box duties allow.
Can anyone here come from your network gives you full control and then click Apply and OK and OK again
  • Reacties 22
Populaire dagen
