Random Freezes - Geen spoor van virus of malware - Netwerkprobleem - W7 - 64-bit
Ik heb nu de fix gedraaid, en ben nu in Veilige modus om het Hijack-rapport te posten. In normale modus kan ik met Hijack nog steeds weinig doen.
Hierbij het nieuwe rapport :
Scan saved at 21:12:06, on 11/05/2011
Boot mode: Safe mode with network support
O2 - BHO: LastPass Browser Helper Object - {95D9ECF5-2A4D-4550-BE49-70D42F71296E} - C:\Program Files (x86)\LastPass\LPBar.dll
O2 - BHO: URLRedirectionBHO - {B4F3A835-0E21-4959-BA22-42B3008E02FF} - C:\PROGRA~2\MICROS~1\Office14\URLREDIR.DLL
O3 - Toolbar: LastPass Toolbar - {9f6b5cc3-5c7b-4b5c-97af-19dec1e380e5} - C:\Program Files (x86)\LastPass\LPBar.dll
O8 - Extra context menu item: &Verzenden naar OneNote - res://C:\PROGRA~2\MICROS~1\Office14\ONBttnIE.dll/105
O8 - Extra context menu item: E&xporteren naar Microsoft Excel - res://C:\PROGRA~2\MICROS~1\Office14\EXCEL.EXE/3000
O8 - Extra context menu item: Google Sidewiki... - res://C:\Program Files (x86)\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_D183CA64F05FDD98.dll/cmsidewiki.html
O8 - Extra context menu item: LastPass - file://C:\Program Files (x86)\LastPass\context.html?cmd=lastpass
O8 - Extra context menu item: LastPass Fill Forms - file://C:\Program Files (x86)\LastPass\context.html?cmd=fillforms
O9 - Extra button: Verzenden naar OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office14\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: &Verzenden naar OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office14\ONBttnIE.dll
O9 - Extra button: LastPass - {43699cd0-e34f-11de-8a39-0800200c9a66} - C:\Program Files (x86)\LastPass\LPBar.dll
O9 - Extra button: &Gekoppelde notities van OneNote - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files (x86)\Microsoft Office\Office14\ONBttnIELinkedNotes.dll
O9 - Extra 'Tools' menuitem: &Gekoppelde notities van OneNote - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files (x86)\Microsoft Office\Office14\ONBttnIELinkedNotes.dll
O16 - DPF: Garmin Communicator Plug-In - https://static.garmincdn.com/gcp/ie/2.9.3.0/GarminAxControl.CAB
O16 - DPF: {0D41B8C5-2599-4893-8183-00195EC8D5F9} (asusTek_sysctrl Class) - http://support.asus.com/select/asusTek_sys_ctrl3.cab
O16 - DPF: {1E54D648-B804-468d-BC78-4AFFED8E262F} (System Requirements Lab) - http://www.nvidia.com/content/DriverDownload/srl/3.0.0.4/srl_bin/sysreqlab_nvd.cab
O16 - DPF: {3D3B42C2-11BF-4732-A304-A01384B70D68} (UploadListView Class) - http://picasaweb.google.com/s/v/66.25/uploader2.cab
O16 - DPF: {4B54A9DE-EF1C-4EBE-A328-7C28EA3B433A} (BitDefender QuickScan Control) - http://quickscan.bitdefender.com/qsax/qsax.cab
O16 - DPF: {74DBCB52-F298-4110-951D-AD2FF67BC8AB} (NVIDIA Smart Scan) - http://www.nvidia.com/content/DriverDownload/nforce/NvidiaSmartScan.cab
O16 - DPF: {8100D56A-5661-482C-BEE8-AFECE305D968} (Facebook Photo Uploader 5 Control) - http://upload.facebook.com/controls/2009.07.28_v5.5.8.1/FacebookPhotoUploader55.cab
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files (x86)\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: NVIDIA Stereoscopic 3D Driver Service (Stereo Service) - NVIDIA Corporation - C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvSCPAPISvr.exe
End of file - 7431 bytes
Nu draai ik terug MBAM, ook in veilige modus met netwerkverbinding. Hierbij het rapport.
Malwarebytes' Anti-Malware 1.50.1.1100
www.malwarebytes.org
Databaseversie: 6555
Windows 6.1.7601 Service Pack 1 (Safe Mode)
11/05/2011 21:19:19
mbam-log-2011-05-11 (21-19-19).txt
Scantype: Snelle scan
Objecten gescand: 194592
Verstreken tijd: 1 minuut/minuten, 44 seconde(n)
Registerdata geïnfecteerd: 0
Mappen geïnfecteerd: 0
Bestanden geïnfecteerd: 0
Geheugenmodulen geïnfecteerd:
Registerwaarden geïnfecteerd:
Ik zal gelijk ook eerst nog eens ccleaner draaien. Veel unregistered keys betreffende "openwithprogids", en ook een entry van Wormradar hersteld.
Ik switch nu terug naar normale modus.
---------- Post toegevoegd om 21:41 ---------- Vorige post was om 21:27 ----------
Ik ben helaas al terug blijven hangen.
  • Reacties 38
Het valt te betwijfelen of malware dan de oorzaak van de freeze is, maar - voor alle zekerheid - nog een laatste test.
    • Adware: Verplaats
    • Dialers: Verplaats
    • Jokes: Rapportage
    • Riskware: Rapportage
    • Hacktools: Verplaats
Kan het zijn dat de instructies voor Dr.Web CureIt verouderd zijn ? Een en ander kwam bij mij iets anders tevoorschijn, bvb. een launch.exe ipv. drweb-cureit, en ik kon pas een PF9 doen nadat de scan al gestart werd ?
Het leek ook lang te gaan duren, en het was al laat, dus ik zal dit vanavond nog doen. Na een halfuur scannen was er alleszins nog niets gevonden.
Als het geen Malware is, wat zou dan de reden kunnen zijn dat bvb. Hijack niet toelaat om een rapport neer te zetten in de Hijack-directory ?
Ik wil je ook op de hoogte brengen van verhoogde netwerkactiviteit, met veel TCP-verbindingen en IPv4- en IPv6-loopback meldingen. Ik heb daarvoor een thread gestart in het forum over Netwerken.
Dr.Web CureIt heeft geen resultaat (dus een goed resultaat) opgeleverd. De log is blijkbaar wel te groot om hier integraal te posten.
Het form crasht bij mij wanneer ik de log probeer te plaatsen.
aangepast door Cujo
Geen reactie meer ontvangen.
Nog een paar aanvullende vraagjes in dit domein :
Hoe kan ik er zeker van zijn dat alle restanten van AVG ook echt weg zijn ?
Ik vind bvb. nog steeds een folder $AVG en ook roaming/AVG, en dit doet mij denken dat nog steeds niet alles verwijderd is en er dus nog conflicten kunnen zijn.
Is het normaal dat de Anti-malware service, als onderdeel van MS Security Ess., bijna constant draait ?
Dr. Web draait normaal erg lang en levert inderdaad een "groot" log af. Maar als er geen negatieve opmerkingen uit voortkomen, hoef je dit niet te posten. Dan is ook dat positief.
AVG verwijderen kan best met de AVG Removal Tool. Blijven er dan nog restmapjes over (zoals je die gemeld hebt), dan mag je die manueel verwijderen.
Bij MSE heb je een permanente controle op de bewegingen van de PC. Net zoals bij andere scanners wordt er dus constant gezocht naar mogelijke besmettingen. Dat lijkt me niet abnormaal te zijn.
OK, goed nieuws en slecht nieuws, want vermits het freeze-probleem nog niet weg is zal ik verder moeten zoeken ;-)
Ik heb dan nog een paar threads elders geopend.
BTW: Ik lees elders dat je meestal het advies geeft om Combofix terug te verwijderen. Doe ik dit ook best ?
Combofix hoort - na gebruik - niet thuis op de PC. Is enkel een tooltje voor probleemoplossing. Dus ja, mag/moet verwijderd worden. En best ook nog even cleanen.
Verwijder Combofix: Start -> Uitvoeren/Zoekopdracht en typ: ComboFix /Uninstall
Download CCleaner.
Klik op “Download Latest Version” en dan start de download van CCleaner automatisch en gratis op.
Combofix verwijderd.
C:\Qoobox niet teruggevonden
CCleaner (1e cyclus)
Register
Ontbrekende gedeelde DLL-bestanden
Niet gebruikte bestandsextensie's
ActiveX/COM Fouten
Verouderde softwaresleutel (swearware)
Invalid Firewall Rules (???)
CCleaner (2e cyclus)
ActiveX/COM Fouten (HKCR\Video_TVServer.CategoryTV(.1)
Opgeruimd staat netjes :-)
Nu lijkt die freeze toch eerder naar een hardwareprobleem te wijzen, dan naar een softwareprobleem.
