C:\Windows\system32\rstrui.exe, zwart scherm, geen iconen op me bureaublad
Scan saved at 13:58:33, on 18-6-2011
MSIE: Internet Explorer v8.00 (8.00.6001.19088)
C:\Windows\system32\Dwm.exe
C:\Windows\Explorer.EXE
C:\Program Files\ASUS\Ai Suite\AiNap\AiNap.exe
C:\Program Files\Adobe\Reader 8.0\Reader\reader_sl.exe
C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe
C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe
D:\Program Files\iTunes\iTunesHelper.exe
D:\Program Files\DAP\DAP.exe
D:\Program Files\BitLord\BitLord.exe
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\Program Files\Microsoft Office\Office12\GrooveShellExtensions.dll
O2 - BHO: URLRedirectionBHO - {B4F3A835-0E21-4959-BA22-42B3008E02FF} - C:\PROGRA~1\MICROS~2\Office14\URLREDIR.DLL
O4 - HKLM\..\Run: [Ai Nap] "C:\Program Files\ASUS\Ai Suite\AiNap\AiNap.exe"
O4 - HKLM\..\Run: [QFan Help] "C:\Program Files\ASUS\Ai Suite\QFan3\QFanHelp.exe"
O4 - HKLM\..\Run: [Cpu Level Up help] C:\Program Files\ASUS\Ai Suite\CpuLevelUpHelp.exe
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [AppleSyncNotifier] C:\Program Files\Common Files\Apple\Mobile Device Support\AppleSyncNotifier.exe
O4 - HKLM\..\Run: [GrooveMonitor] "C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe"
O4 - HKLM\..\Run: [iTunesHelper] "D:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [Malwarebytes' Anti-Malware (reboot)] "C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe" /runcleanupscript
O4 - HKCU\..\Run: [DownloadAccelerator] "D:\Program Files\DAP\DAP.EXE" /STARTUP
O4 - HKCU\..\Run: [bitComet] "D:\Program Files\BitLord\BitLord.exe"
O4 - HKUS\S-1-5-18\..\RunOnce: [FlashPlayerUpdate] C:\Windows\system32\Macromed\Flash\FlashUtil10k_ActiveX.exe -update activex (User 'SYSTEEM')
O4 - HKUS\.DEFAULT\..\RunOnce: [FlashPlayerUpdate] C:\Windows\system32\Macromed\Flash\FlashUtil10k_ActiveX.exe -update activex (User 'Default user')
O4 - Startup: LimeWire On Startup.lnk = D:\Program Files\LimeWire\LimeWire.exe
O8 - Extra context menu item: &Clean Traces - D:\Program Files\DAP\Privacy Package\dapcleanerie.htm
O8 - Extra context menu item: &Download with &DAP - D:\Program Files\DAP\dapextie.htm
O8 - Extra context menu item: &Verzenden naar OneNote - res://C:\PROGRA~1\MICROS~2\Office14\ONBttnIE.dll/105
O8 - Extra context menu item: Download &all with DAP - D:\Program Files\DAP\dapextie2.htm
O8 - Extra context menu item: E&xporteren naar Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office14\EXCEL.EXE/3000
O9 - Extra button: Verzenden naar OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office\Office14\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: &Verzenden naar OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office\Office14\ONBttnIE.dll
O9 - Extra button: &Gekoppelde notities van OneNote - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files\Microsoft Office\Office14\ONBttnIELinkedNotes.dll
O9 - Extra 'Tools' menuitem: &Gekoppelde notities van OneNote - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files\Microsoft Office\Office14\ONBttnIELinkedNotes.dll
O16 - DPF: {7530BFB8-7293-4D34-9923-61A11451AFC5} (OnlineScanner Control) - http://download.eset.com/special/eos-beta/OnlineScanner.cab
O18 - Protocol: grooveLocalGWS - {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\Program Files\Microsoft Office\Office12\GrooveSystemServices.dll
O18 - Filter hijack: text/xml - {807573E5-5146-11D5-A672-00B0D022E945} - C:\Program Files\Common Files\Microsoft Shared\OFFICE14\MSOXMLMF.DLL
O23 - Service: Mobiel Apple apparaat (Apple Mobile Device) - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service: ProtexisLicensing - Unknown owner - C:\Windows\system32\PSIService.exe
End of file - 6472 bytes
  • Reacties 46
@Kape, Jaume, Kweezie Wabbit: Ik heb deze Saga opgevolgd en zéér interessant gevonden. Hopelijk is het einde in zicht. Alle respect voor de helpers, maar ook voor 'het slachtoffer' die toch blijkt door te zetten. De aanhouder wint. Als alles voorbij is dan met een zucht een paar checkups doen (kan wel wat voorstellen) en verder werken dat computeren weer plezierig wordt...
MVG | WW
Als eerste wil ik graag Kweezie, Wawa en Kape bedanken voor alles! Volgens mij werkt alles zoals het hoort. Ben zeer tevreden over jullie steun en advies. Zoals Wawa al zei enorm veel respect!!!
Zijn er nog wat dingen opgevallen in mijn logs? Wat anders kan of moet? En hoe kan ik dit verkomen in de toekomst?
Misschien een betere virusscan? Of een combinatie van? Oja Kan mijn prullenbak nergens vinden!?
Als je de problemen van de baan zijn, gaan we de restjes opruimen.
Verwijder Combofix: Start -> Uitvoeren en typ: ComboFix /Uninstall (met spatie voor de /)
Let op bij de installatie.
Haal beide vinkjes weg bij de vraag over de Chrome browser.
Installeer het en start CCleaner op.
Klik in de linkse kolom op “Cleaner”. Klik achtereenvolgens op ‘Analyseren’ en 'Schoonmaken'. Bevestigen met JA of OK
Wil je dit uitgebreid in beeld bekijken, lees dan deze handleiding.
Het is aangewezen om de bestaande herstelpunten te verwijderen (daar kunnen besmette herstelpunten tussen zitten die je zou kunnen terugzetten) door systeemherstel tijdelijk uit te schakelen. Doe dit via Configuratiescherm -> Systeem en Onderhoud -> Systeem -> tabblad "Systeembeveiliging" -> vinkje weghalen bij de schijf waarvan je de herstelpunten wil verwijderen -> klikken op "toepassen".
Dan krijg je de schermmelding “Weet u zeker dat u systeemherstel wil uitschakelen”. Klik hier op “Systeemherstel uitschakelen”. Dan zijn alle herstelpunten verwijderd op de aangeduide schijf.
Zet daarna opnieuw een vinkje bij de harde schijf. Maak meteen ook een nieuw herstelpunt, zodat je niet hoeft te wachten op een automatisch herstelpunt van het systeem.
Ik geloof dat je momenteel Windows Defender gebruikt als virusscanner.
Als je daarbij wekelijks een scan doet met malwarebytes ben je al goed beveiligd.
Als je toch een andere virusscanner wil proberen/gebruiken, kan je in deze discussie vast wel wat vinden.
Wat kan je doen om besmettingen te vermijden?
Lees altijd de meldingen die gegeven worden bij downloads en/of installaties en gebruik je gezond verstand voor je op ja of ok klikt.
Als je software of gadgets installeert, vink dan alrijd de meegeleverde toolbars uit. Die hebben meestal veiligheidslekken of ze zijn zelf de malware en kunnnen achteraf voor heel wat problemen zorgen. De enige toolbar die (volgens mij) de moeite is om te gebruiken is de google toolbar.
Combifix en Hijackthis zijn verwijderd. AVG en CCleaner gedownload en gelijk laten scannen samen met Malware.
aangepast door jaume
