je moet eens ccleaner opstarten en op gereedschap en daarna opstarten klikken,en van die opstartlijst een log maken rechtsonder als opslaan als textbestand en het posten aub?
is kijken wat er dan allemaal opstart ......;-)
  • Reacties 34
Bedankt maar ben er vrij zeker van dat het aan dat niet ligt.
Ja HKCU:Run Pando Media Booster C:\Program Files (x86)\Pando Networks\Media Booster\PMB.exe
Ja HKCU:Run msnmsgr "C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe" /background
Nee HKCU:Run EADM "C:\Program Files (x86)\Origin\Origin.exe" -AutoStart
Nee HKCU:Run msnmsgr "C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe" /background
Nee HKCU:Run Nero MediaHome 4 "C:\Program Files (x86)\Nero\Nero MediaHome 4\NeroMediaHome.exe" /AUTORUN
Nee HKCU:Run Steam "C:\Program Files (x86)\Steam\steam.exe" -silent
Ja HKLM:Run NUSB3MON "C:\Program Files (x86)\Renesas Electronics\USB 3.0 Host Controller Driver\Application\nusb3mon.exe"
Ja HKLM:Run IAStorIcon C:\Program Files (x86)\Intel\Intel® Rapid Storage Technology\IAStorIcon.exe
Ja HKLM:Run BCU "C:\Program Files (x86)\DeviceVM\Browser Configuration Utility\BCU.exe"
Ja HKLM:Run Adobe ARM "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
Ja HKLM:Run SunJavaUpdateSched "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
Ja HKLM:Run QuickTime Task "C:\Program Files (x86)\QuickTime\QTTask.exe" -atboottime
Ja HKLM:Run ASUS Ai Charger C:\Program Files (x86)\ASUS\ASUS Ai Charger\AiChargerAP.exe
Ja HKLM:Run ASUS ShellProcess Execute C:\Program Files (x86)\ASUS\AI Suite II\ASUS Mobilink\Simulator\AsShellProcess.exe
Ja HKLM:Run APSDaemon "C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe"
Ja HKLM:Run RtHDVCpl C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe -s
Ja HKLM:Run AtherosBtStack "C:\Program Files (x86)\Bluetooth Suite\BtvStack.exe"
Ja HKLM:Run AthBtTray "C:\Program Files (x86)\Bluetooth Suite\AthBtTray.exe"
Ja HKLM:Run Kernel and Hardware Abstraction Layer KHALMNPR.EXE
Ja HKLM:Run Bluetooth Connection Assistant LBTWIZ.EXE -silent
Nee HKLM:Run iTunesHelper "C:\Program Files (x86)\iTunes\iTunesHelper.exe"
Nee HKLM:Run LogitechVideoRepair C:\Program Files (x86)\Logitech\Video\ISStart.exe
Nee HKLM:Run LogitechVideoTray C:\Program Files (x86)\Logitech\Video\LogiTray.exe
Nee HKLM:Run tvncontrol "C:\Program Files (x86)\TightVNC\tvnserver.exe" -controlservice -slave
Ja Startup Common Logitech Desktop Messenger.lnk C:\Program Files (x86)\Logitech\Desktop Messenger\8876480\Program\LDMConf.exe
Ja Startup Common Logitech SetPoint.lnk C:\Program Files\Logitech\SetPoint\SetPoint.exe
Ja Startup User GIGABYTE Gamer HUD Lite.lnk C:\Program Files (x86)\GIGABYTE\Gamer HUD Lite\HUD.exe
Nee Startup User CurseClientStartup.ccip C:\Users\User\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\CurseClientStartup.ccip
Nee Startup User Xfire.lnk C:\PROGRA~2\Xfire\Xfire.exe
Ik probeerde net een herstel te doen met mijn Windows cd omdat ik denk dat het een probleem van windows is, en er kwam op:
Deze versie van opties voor systeemherstel is niet compatibel met de versie van windows die u probeert te herstellen.
Gebruik een herstelschijf die met deze versie van windows compatibel is.
Het probleem ! Heb er een foto van kunnen nemen en geupload ! (Heb dit al bij firefox,mijn computer,paint,mijn documenten gehad)
aangepast door control143
welke versie van windows staat nu op je pc of laptop,de 32 bit of de 64 bit en welke taal is het?
als je een van beide niet juist overeenkomt heb je een probleem natuurlijk ;-)
