  • Reacties 101
Dan kunnen we rustig die verwijzingen van HP verwijderen.
Start Hijackthis op. Klik met de rechter muisknop op de icoon en kies dan voor “Run as administrator" of "Uitvoeren als administrator".
O9 - Extra button: Verbindingshelp - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\PCHEALTH\HELPCTR\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm
O9 - Extra 'Tools' menuitem: Verbindingshelp - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\PCHEALTH\HELPCTR\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm
Maak een nieuw logje met hijackthis.
Scan saved at 15:42:52, on 23/12/2011
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\Program Files\AVAST Software\Avast\AvastSvc.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Fighters\sfagent.exe
C:\Program Files\AVAST Software\Avast\avastUI.exe
C:\Program Files\CyberLink\PowerCinema\Kernel\TV\CLCapSvc.exe
C:\Program Files\CyberLink\PowerCinema\Kernel\CLML_NTService\CLMLServer.exe
C:\Program Files\Common Files\LightScribe\LSSrvc.exe
C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
C:\Program Files\Fighters\sfus.exe
C:\Program Files\Fighters\FighterSuiteService.exe
C:\Program Files\Toshiba\Bluetooth Toshiba Stack\TosBtSrv.exe
C:\Program Files\CyberLink\PowerCinema\Kernel\TV\CLSched.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = Yahoo! Zoeken - zoeken op het web
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = HP Software Update
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.6.5612.1312\swg.dll
O2 - BHO: Windows Live Toolbar Helper - {E15A8DC0-8516-42A1-81EA-DC94EC1ACF10} - C:\Program Files\Windows Live\Toolbar\wltcore.dll
O3 - Toolbar: &Windows Live Toolbar - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - C:\Program Files\Windows Live\Toolbar\wltcore.dll
O4 - HKLM\..\Run: [sfagent] C:\Program Files\Fighters\sfagent.exe
O4 - HKLM\..\Run: [Google Updater] "C:\Program Files\Google\Google Updater\GoogleUpdater.exe" -check_deprecation
O4 - .DEFAULT User Startup: Pin.lnk = C:\hp\bin\CLOAKER.EXE (User 'Default user')
O16 - DPF: {0742B9EF-8C83-41CA-BFBA-830A59E23533} (Microsoft Data Collection Control) - https://support.microsoft.com/OAS/ActiveX/MSDcode.cab
O16 - DPF: {4F1E5B1A-2A80-42CA-8532-2D05CB959537} (MSN Photo Upload Tool) - http://mary1950.spaces.live.com//PhotoUpload/MsnPUpld.cab
O16 - DPF: {7FC1B346-83E6-4774-8D20-1A6B09B0E737} (Windows Live Photo Upload Control) - http://mary1950.spaces.live.com/PhotoUpload/MsnPUpld.cab
O16 - DPF: {8E0D4DE5-3180-4024-A327-4DFAD1796A8D} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsClient.cab31267.cab
O23 - Service: Application Updater - Unknown owner - C:\Program Files\Application Updater\ApplicationUpdater.exe (file missing)
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: CyberLink Background Capture Service (CBCS) (CLCapSvc) - Unknown owner - C:\Program Files\CyberLink\PowerCinema\Kernel\TV\CLCapSvc.exe
O23 - Service: CyberLink Task Scheduler (CTS) (CLSched) - Unknown owner - C:\Program Files\CyberLink\PowerCinema\Kernel\TV\CLSched.exe
O23 - Service: CyberLink Media Library Service - Cyberlink - C:\Program Files\CyberLink\PowerCinema\Kernel\CLML_NTService\CLMLServer.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe
O23 - Service: SPAMfighter Update Service - SPAMfighter ApS - C:\Program Files\Fighters\sfus.exe
O23 - Service: Suite Service - SPAMfighter ApS - C:\Program Files\Fighters\FighterSuiteService.exe
O23 - Service: TOSHIBA Bluetooth Service - TOSHIBA CORPORATION - C:\Program Files\Toshiba\Bluetooth Toshiba Stack\TosBtSrv.exe
End of file - 7794 bytes
Tik in: sc stop "Application Updater" en druk op Enter.
Tik in: sc delete "Application Updater" en druk op Enter.
Tik in exit en druk Enter.
Als je op een van deze instructies een foutmelding krijgt, ga dan gewoon door met de volgende instructie.
Plaats na deze acties een nieuw logje van hijackthis
Krijg je nog steeds die foutmeldig?
Scan saved at 21:36:52, on 24/12/2011
---------- Post toegevoegd om 21:43 ---------- Vorige post was om 21:37 ----------
beste
ik blijf met het zelde probleem zitten zoals voorheen van FIXIT
met invoegtoepassingen
prettig kerstfeest
Het is helaas weer niet gelukt :sad
Kan je dit eens uitvoeren in veilige modus?
Scan saved at 15:48:55, on 25/12/2011
C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe
O2 - BHO: Java Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll
End of file - 8134 bytes
als ik exit intikte ging dat niet de rest wel
Het wil blijkbaar niet lukken.
Als je combofix nog hebt, mag je dat nog eens laten scannen.
Als je combofix niet meer hebt, staat hier de volledige procedure.
Link 1
Link 2
  • Schakel alle antivirus- en antispywareprogramma's uit, want anders kunnen ze misschien conflicteren met ComboFix. Hier is een handleiding over hoe je ze kan uitschakelen:
    Klik hier
  • Dubbelklik op ComboFix.exe en volg de meldingen op het scherm.
  • ComboFix zal controleren of dat de Microsoft Windows Recovery Console reeds is geïnstalleerd.
  • Volg de meldingen op het scherm om ComboFix de Microsoft Windows Recovery Console te laten downloaden en installeren.
Wanneer ComboFix klaar is, zal het het een logbestand voor je maken. Post de inhoud van dit logbestand (te vinden als C:\ComboFix.txt) in je volgende bericht.
Indien je problemen hebt bij het uitvoeren van ComboFix, gelieve dit te melden.
het wil niet lukken met comboFix
ik had die vorige verwijderd
heb nogthans virus scanner uit gezet maar melde dat op combofix virus zit
