Bij het opzoeken via google wordt ik telkens doorverwezen naar andere sites dan de aangeklikte link !
Hierbij een logje als hier iemand bereid is dit even na te kijken .
Dank bijvoorbaat ;-)
mvg,
MDG4X4.
Scan saved at 17:27:10, on 22/11/2011
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\csrss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\System32\SCardSvr.exe
C:\Program Files\Common Files\Acronis\Schedule2\schedul2.exe
D:\Program Files\PC Tools\Spyware Doctor\Spyware Doctor\sdhelp.exe
C:\WINDOWS\SOUNDMAN.EXE
C:\WINDOWS\System32\alg.exe
D:\Utilitys\AVG 2012\AVGIDSAgent.exe
D:\Utilitys\AVG 2012\avgwdsvc.exe
D:\Utilitys\AVG 2012\avgnsx.exe
D:\Utilitys\AVG 2012\avgemcx.exe
D:\Utilitys\AVG 2012\avgrsx.exe
D:\Utilitys\AVG 2012\avgcsrvx.exe
D:\Utilitys\AVG 2012\avgtray.exe
D:\Program Files\HijackThis\HijackThis.exe
C:\WINDOWS\system32\wbem\wmiprvse.exe
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = Acer.com Worldwide - Select your local country or region
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - D:\Utilitys\AVG 2012\avgssie.dll
O2 - BHO: PCTools Site Guard - {5C8B2A36-3DB1-42A4-A3CB-D426709BBFEB} - D:\PROGRA~1\PCTOOL~1\SPYWAR~1\SPYWAR~1\tools\iesdsg.dll
O2 - BHO: PCTools Browser Monitor - {B56A7D7D-6927-48C8-A975-17DF180C71AC} - D:\PROGRA~1\PCTOOL~1\SPYWAR~1\SPYWAR~1\tools\iesdpb.dll
O4 - HKLM\..\Run: [AVG_TRAY] "D:\Utilitys\AVG 2012\avgtray.exe"
O4 - HKLM\..\Run: [soundMan] SOUNDMAN.EXE
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'Lokale service')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'Netwerkservice')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'Default user')
O8 - Extra context menu item: E&xporteren naar Microsoft Excel - res://D:\Suite\office\Office10\EXCEL.EXE/3000
O8 - Extra context menu item: Google Sidewiki... - res://C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_7461B1589E8B4FB7.dll/cmsidewiki.html
O9 - Extra button: Spyware Doctor - {2D663D1A-8670-49D9-A1A5-4C56B4E14E84} - D:\PROGRA~1\PCTOOL~1\SPYWAR~1\SPYWAR~1\tools\iesdpb.dll
O14 - IERESET.INF: START_PAGE_URL=http://GLOBAL.ACER.COM/
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} (get_atlcom Class) - http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - D:\Utilitys\AVG 2012\avgpp.dll
O23 - Service: Acronis Scheduler2 Service (AcrSch2Svc) - Acronis - C:\Program Files\Common Files\Acronis\Schedule2\schedul2.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: AVGIDSAgent - AVG Technologies CZ, s.r.o. - D:\Utilitys\AVG 2012\AVGIDSAgent.exe
O23 - Service: AVG WatchDog (avgwd) - AVG Technologies CZ, s.r.o. - D:\Utilitys\AVG 2012\avgwdsvc.exe
O23 - Service: PC Tools Spyware Doctor (SDhelper) - PC Tools Research Pty Ltd - D:\Program Files\PC Tools\Spyware Doctor\Spyware Doctor\sdhelp.exe
End of file - 5777 bytes
  • Reacties 50
Download MVPS Hosts.
Unzip het programma naar een door u bepaalde locatie.
Windows XP
Klik op mvps.bat en kies voor “uitvoeren” om mvps.bat op te starten (*).
Druk op toets om door te gaan.
Van het bestaande bestand HOSTS op de standaardlocatie C:\windows\system32\drivers\etc wordt een backup gemaakt met de naam HOSTS.MVP
Dan wordt het bestand vervangen door de actuele MVPS Hosts-versie.
(*) Windows Vista en Windows 7 gebruikers moeten rechtsklikken op mvps.bat en kiezen voor ”uitvoeren als administrator” om mvps.bat op te starten.
Start daarna de PC opnieuw op en laat even weten of Google nu nog steeds de verkeerde richting uitgaat ?
Heb je raad opgevolgd!
Ondertussen even via google een paar sites ingetikt en bij het aanklikken van de link flitst nog wel in de browserbalk even een andere site maar gaat niemeer open op dit moment.De juiste link opent dan wel...
Dat is al iets ... nog even dieper kijken dan.
Link 1
Link 2
Klik hier
2. Dubbelklik op ComboFix.exe en volg de meldingen op het scherm.
3. ComboFix zal controleren of dat de Microsoft Windows Recovery Console reeds is geïnstalleerd.
4. Volg de meldingen op het scherm om ComboFix de Microsoft Windows Recovery Console te laten downloaden en installeren.
5. Wanneer ComboFix klaar is, zal het een logbestand voor je maken. Post de inhoud van dit logbestand (te vinden als C:\ComboFix.txt) in je volgende bericht.
Ik denk er sterk aan om de grote middelen aan te wenden.Ik zit namelijk nog met een ander probleem ivm het geluid en ook dat
geraakt niet opgelost! Dus misschien toch beter opnieuw vanaf een schone lei beginnen.@ Kape,ik waardeer ten sterkste de hulp die ik hier op zo'n korte tijd kreeg aangeboden.:top:
thx voor de moeite;-)
Indien er nog meer problemen zijn, kan ik je beslissing alleen maar begrijpen. Succes ermee !
En dan kunnen we dit topic als "afgesloten" beschouwen.
  • 4 weken later...
Hier zijn we terug ! Computer is terug gedraaid door m'n broer omdat er nog andere problemen waren ook.Deze laatste zijn hiermee opgelost,maar het google probleem dus niet:hmmmm: Heb ondertussen combofix laten draaien en hierbij dus het logbestand:
ComboFix 11-12-19.01 - Michel 19/12/2011 17:59:08.1.1 - x86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.31.1043.18.1023.488 [GMT 1:00]
Gestart vanuit: c:\documents and settings\Michel\Bureaublad\ComboFix.exe
AV: AVG Anti-Virus Free Edition 2012 *Disabled/Updated* {17DDD097-36FF-435F-9E1B-52D74245D6BF}
c:\documents and settings\Administrator\WINDOWS
c:\documents and settings\All Users\Application Data\TEMP
c:\documents and settings\All Users\Application Data\TEMP\5C321E34.TMP
c:\documents and settings\Default User\WINDOWS
c:\documents and settings\Michel\WINDOWS
c:\windows\alcrmv.exe
c:\windows\help\wmplayer.bak
c:\windows\IsUn0413.exe
c:\windows\iun6002.exe
c:\windows\system32\config\systemprofile\WINDOWS
c:\windows\system32\ctfmon(2).exe
c:\windows\system32\CTFMON(3).EXE
c:\windows\system32\CTFMON(4).EXE
(((((((((((((((((((( Bestanden Gemaakt van 2011-11-19 to 2011-12-19 ))))))))))))))))))))))))))))))
2011-12-18 21:01 . 2011-12-18 21:01 -------- d-----w- C:\Quarantine
2011-12-18 13:29 . 2011-12-19 16:05 2984 ----a-w- C:\user.js
2011-12-18 13:29 . 2011-12-18 13:29 -------- d-----w- c:\documents and settings\All Users\Application Data\Babylon
2011-12-18 13:29 . 2011-12-19 16:05 -------- d-----w- c:\program files\BrowserCompanion
2011-12-18 13:29 . 2011-12-18 13:29 -------- d-----w- c:\documents and settings\Michel\AppData
2011-12-16 17:36 . 2011-12-16 17:36 -------- d-----w- c:\windows\Sun
2011-12-16 08:16 . 2011-12-16 08:50 -------- d-----w- c:\documents and settings\All Users\Application Data\Spybot - Search & Destroy
2011-12-16 06:06 . 2011-12-16 06:06 414368 ----a-w- c:\windows\system32\FlashPlayerCPLApp.cpl
2011-12-16 05:49 . 2003-06-25 15:05 266360 ----a-w- c:\windows\system32\TweakUI.exe
2011-12-16 05:42 . 2011-12-16 05:42 -------- d-----w- c:\documents and settings\Michel\Local Settings\Application Data\Temp
2011-12-16 04:46 . 2011-12-16 04:46 -------- d-----w- c:\program files\Common Files\Java
2011-12-16 04:46 . 2011-12-16 04:46 472808 ----a-w- c:\windows\system32\deployJava1.dll
2011-12-16 04:01 . 2011-11-04 19:13 743424 ------w- c:\windows\system32\dllcache\iedvtool.dll
2011-12-16 04:00 . 2011-07-08 14:02 10496 ------w- c:\windows\system32\dllcache\ndistapi.sys
2011-12-16 03:13 . 2010-09-18 06:53 953856 ------w- c:\windows\system32\dllcache\mfc40u.dll
2011-12-16 03:12 . 2010-08-23 16:13 617472 ------w- c:\windows\system32\dllcache\comctl32.dll
2011-12-16 03:11 . 2010-06-14 14:31 744448 ------w- c:\windows\system32\dllcache\helpsvc.exe
2011-12-16 03:11 . 2010-11-02 15:17 40960 ------w- c:\windows\system32\dllcache\ndproxy.sys
2011-12-16 03:10 . 2011-08-31 16:00 22216 ----a-w- c:\windows\system32\drivers\mbam.sys
2011-12-16 03:09 . 2011-06-24 14:10 139656 ------w- c:\windows\system32\dllcache\rdpwd.sys
2011-12-16 03:09 . 2011-04-21 13:37 105472 ------w- c:\windows\system32\dllcache\mup.sys
2011-12-16 03:02 . 2010-10-11 14:59 45568 ------w- c:\windows\system32\dllcache\wab.exe
2011-12-16 01:34 . 2011-12-16 01:34 -------- d-----w- c:\documents and settings\Michel\Application Data\AVG2012
2011-12-16 01:32 . 2011-12-19 15:08 -------- d-----w- c:\windows\system32\drivers\AVG
2011-12-16 01:32 . 2011-12-16 01:56 -------- d-----w- c:\documents and settings\All Users\Application Data\AVG2012
2011-12-16 01:13 . 2011-12-16 01:13 -------- d--h--w- c:\documents and settings\All Users\Application Data\Common Files
2011-12-16 01:13 . 2011-12-19 15:08 -------- d-----w- c:\documents and settings\All Users\Application Data\MFAData
2011-12-16 04:46 . 2010-03-09 01:14 73728 ----a-w- c:\windows\system32\javacpl.cpl
2011-11-23 14:40 . 1979-12-31 23:00 1859712 ----a-w- c:\windows\system32\win32k.sys
2011-11-04 19:13 . 1979-12-31 23:00 916992 ----a-w- c:\windows\system32\wininet.dll
2011-11-04 19:13 . 1979-12-31 23:00 43520 ----a-w- c:\windows\system32\licmgr10.dll
2011-11-04 19:13 . 1979-12-31 23:00 1469440 ------w- c:\windows\system32\inetcpl.cpl
2011-11-04 11:25 . 2010-02-04 18:29 385024 ----a-w- c:\windows\system32\html.iec
2011-11-01 16:07 . 2010-01-31 15:53 1288192 ----a-w- c:\windows\system32\ole32.dll
2011-10-28 05:32 . 1979-12-31 23:00 33280 ----a-w- c:\windows\system32\csrsrv.dll
2011-10-18 11:13 . 1979-12-31 23:00 186880 ----a-w- c:\windows\system32\encdec.dll
2011-10-10 14:22 . 2010-01-31 15:48 692736 ----a-w- c:\windows\system32\inetcomm.dll
2011-10-07 05:23 . 2011-10-07 05:23 230608 ----a-w- c:\windows\system32\drivers\avgldx86.sys
2011-10-04 05:21 . 2011-10-04 05:21 16720 ----a-w- c:\windows\system32\drivers\AVGIDSShim.sys
2011-09-28 07:06 . 1979-12-31 23:00 602624 ----a-w- c:\windows\system32\crypt32.dll
2011-09-26 10:41 . 2008-07-29 18:59 614912 ----a-w- c:\windows\system32\uiautomationcore.dll
2011-09-26 10:41 . 1979-12-31 23:00 23040 ----a-w- c:\windows\system32\oleaccrc.dll
2011-09-26 10:41 . 1979-12-31 23:00 220160 ----a-w- c:\windows\system32\oleacc.dll
REGEDIT4
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{00cbb66b-1d3b-46d3-9577-323a336acb50}]
2011-10-27 09:24 225584 ----a-w- c:\program files\BrowserCompanion\jsloader.dll
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{963B125B-8B21-49A2-A3A8-E37092276531}]
2011-10-27 09:24 141104 ----a-w- c:\program files\BrowserCompanion\updatebhoWin32.dll
"AVG_TRAY"="d:\utilitys\AVG 2012\avgtray.exe" [2011-12-03 2415456]
"Adobe ARM"="c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2011-06-06 937920]
"Browser companion helper"="c:\program files\BrowserCompanion\BCHelper.exe" [2011-11-29 182576]
"CTFMON.EXE"="c:\windows\System32\CTFMON.EXE" [2008-04-14 15360]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\session manager]
BootExecute REG_MULTI_SZ autocheck autochk *\0d:\utilitys\AVG201~1\avgrsx.exe /sync /restart
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Menu Start^Programma's^Opstarten^Adobe Gamma Loader.lnk]
backup=c:\windows\pss\Adobe Gamma Loader.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Menu Start^Programma's^Opstarten^Microsoft Office.lnk]
backup=c:\windows\pss\Microsoft Office.lnkCommon Startup
HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Adobe Reader Speed Launcher
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Adobe ARM]
2011-06-06 11:55 937920 ----a-w- c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Disk Monitor]
2003-06-18 10:57 466944 ----a-w- c:\program files\Generic\USB Card Reader Driver v1.9e3\Disk_Monitor.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SoundMan]
2003-09-23 08:09 57344 ----a-w- c:\windows\SOUNDMAN.EXE
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SunJavaUpdateSched]
2011-06-09 12:06 254696 ----a-w- c:\program files\Common Files\Java\Java Update\jusched.exe
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
"EnableFirewall"= 0 (0x0)
"%windir%\\Network Diagnostic\\xpnetdiag.exe"=
"c:\\Program Files\\Windows Live\\Messenger\\wlcsdk.exe"=
"c:\\Program Files\\Windows Live\\Messenger\\msnmsgr.exe"=
"c:\\Program Files\\Windows Live\\Sync\\WindowsLiveSync.exe"=
"d:\\Utilitys\\AVG 2012\\avgnsx.exe"=
"d:\\Utilitys\\AVG 2012\\avgdiagex.exe"=
"d:\\Utilitys\\AVG 2012\\avgmfapx.exe"=
"d:\\Utilitys\\AVG 2012\\avgemcx.exe"=
R0 AVGIDSEH;AVGIDSEH;c:\windows\system32\drivers\AVGIDSEH.sys [11/07/2011 1:14 23120]
R0 Avgrkx86;AVG Anti-Rootkit Driver;c:\windows\system32\drivers\avgrkx86.sys [13/09/2011 6:30 32592]
R1 Avgldx86;AVG AVI Loader Driver;c:\windows\system32\drivers\avgldx86.sys [7/10/2011 6:23 230608]
R1 Avgtdix;AVG TDI Driver;c:\windows\system32\drivers\avgtdix.sys [11/07/2011 1:14 295248]
R2 AVGIDSAgent;AVGIDSAgent;d:\utilitys\AVG 2012\AVGIDSAgent.exe [12/10/2011 6:25 4433248]
R2 avgwd;AVG WatchDog;d:\utilitys\AVG 2012\avgwdsvc.exe [2/08/2011 6:09 192776]
R3 AVGIDSDriver;AVGIDSDriver;c:\windows\system32\drivers\AVGIDSDriver.sys [11/07/2011 1:14 134608]
R3 AVGIDSFilter;AVGIDSFilter;c:\windows\system32\drivers\AVGIDSFilter.sys [11/07/2011 1:14 24272]
R3 AVGIDSShim;AVGIDSShim;c:\windows\system32\drivers\AVGIDSShim.sys [4/10/2011 6:21 16720]
S3 esgiguard;esgiguard;\??\c:\program files\Enigma Software Group\SpyHunter\esgiguard.sys --> c:\program files\Enigma Software Group\SpyHunter\esgiguard.sys [?]
--- Andere Services/Drivers In Geheugen ---
*Deregistered* - mchInjDrv
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\svchost]
getPlusHelper REG_MULTI_SZ getPlusHelper
uStart Page = hxxp://www.google.be/
uInternet Connection Wizard,ShellNext = hxxp://global.acer.com/
IE: E&xporteren naar Microsoft Excel - d:\suite\office\Office10\EXCEL.EXE/3000
TCP: DhcpNameServer = 195.130.131.1 195.130.130.129
Handler: base64 - {5ACE96C0-C70A-4A4D-AF14-2E7B869345E1} - c:\program files\BrowserCompanion\tdataprotocol.dll
Handler: chrome - {5ACE96C0-C70A-4A4D-AF14-2E7B869345E1} - c:\program files\BrowserCompanion\tdataprotocol.dll
Handler: prox - {5ACE96C0-C70A-4A4D-AF14-2E7B869345E1} - c:\program files\BrowserCompanion\tdataprotocol.dll
HKU-Default-Run-Spyware Doctor - (no file)
Notify-avgrsstarter - avgrsstx.dll
AddRemove-Adobe Photoshop 7.0 - c:\windows\ISUN0413.EXE
AddRemove-Generic USB Card Reader Driver - c:\windows\iun6002.exe
AddRemove-v1.9e3 - c:\windows\iun6002.exe
catchme 0.3.1398 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, GMER - Rootkit Detector and Remover
Rootkit scan 2011-12-19 18:34
Windows 5.1.2600 Service Pack 3 NTFS
Scan succesvol afgerond
verborgen bestanden: 0
[HKEY_LOCAL_MACHINE\System\ControlSet001\Services\mchInjDrv]
"ImagePath"="\??\c:\windows\TEMP\mc21.tmp"
--------------------- DLLs Geladen Onder Lopende Processen ---------------------
- - - - - - - > 'winlogon.exe'(948)
c:\windows\system32\Ati2evxx.dll
- - - - - - - > 'lsass.exe'(1012)
c:\windows\system32\relog_ap.dll
Voltooingstijd: 2011-12-19 18:50:51
ComboFix-quarantined-files.txt 2011-12-19 17:50
Pre-Run: 32.188.481.536 bytes beschikbaar
Post-Run: 32.267.956.224 bytes beschikbaar
WindowsXP-KB310994-SP2-Home-BootDisk-NLD.exe
[boot loader]
timeout=2
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
c:\cmdcons\BOOTSECT.DAT="Microsoft Windows Recovery Console" /cmdcons
UnsupportedDebug="do not select this" /debug
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition" /fastdetect /NoExecute=OptIn
- - End Of File - - B55F2AAFA4A0A01AAFE8C1E84ED1A8AA
