Raeltek HD Audio, geen geluid meer
System Information
Time of this report: 2/15/2012, 12:24:10
Machine name: PRIV-5C7FC2E704
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.111025-1629)
Language: Dutch (Regional Setting: Dutch)
System Manufacturer: INTEL_
System Model: DG33BU__
BIOS: Default System BIOS
Processor: Intel® Core2 CPU 6420 @ 2.13GHz (2 CPUs)
Memory: 1006MB RAM
Page File: 842MB used, 1579MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: DirectSound test results: Failure at step 19 (User verification of software): HRESULT = 0x00000000 (error code)
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 8600 GTS
Manufacturer: NVIDIA
Chip type: GeForce 8600 GTS
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0400&SUBSYS_34481458&REV_A1
Display Memory: 256.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Standaardbeeldscherm
Monitor Max Res:
Driver Name: nv4_disp.dll
Driver Version: 6.14.0012.8558 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/8/2011 05:50:00, 4226688 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n.v.t.
Mini VDD: nv4_mini.sys
Mini VDD Date: 10/8/2011 05:50:00, 12791488 bytes
Device Identifier: {D7B71E3E-4740-11CF-8656-441400C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0400
SubSys ID: 0x34481458
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_80860001&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.6526 (English)
WHQL Logo'd: Yes
Date and Size: 12/13/2011 18:27:30, 7069288 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: No
EAX 2.0 Listen/Src: Yes, Yes
I3DL2 Listen/Src: Yes, Yes
Sensaura ZoomFX: No
Registry: OK
Sound Test Result: Failure at step 19 (User verification of software): HRESULT = 0x00000000 (error code)
Sound Capture Devices
Description: Realtek HD Audio Input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
Description: Pinnacle PCTV 713x Tuner BDA Analog Audio Capture
Default Sound Capture: No
Default Voice Capture: No
Driver Name: 3xHybrid.sys
Driver Version: 1.03.0003.0005 (English)
Date and Size: 11/22/2006 08:53:02, 1121536 bytes
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Microsoft MIDI-mapper (emulatie), Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable-software (emulatie), Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Muis
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Toetsenbord
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: EP2 Interrupt
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x04FC, 0x05D8
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB-hoofdhub
| Vendor/Product ID: 0x8086, 0x2936
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/13/2008 19:45:37, 59520 bytes
| Driver: usbd.sys, 8/2/2007 13:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ HID-toetsenbordapparaat
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 4/14/2008 17:39:03, 14720 bytes
| Driver: kbdclass.sys, 4/14/2008 17:39:02, 25088 bytes
+ Toestenbordstuurprogramma voor Terminal Server
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 18:03:44, 40840 bytes
+ HID-compliant muis
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 4/14/2008 17:30:53, 23552 bytes
| Driver: mouhid.sys, 8/2/2007 13:00:00, 12288 bytes
+ Stuurprogramma voor muis van Terminal Server
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Passed, Half Duplex: Passed, Mic: Failed gracefully
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: LAN-verbinding - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 15.5 GB
Total Space: 32.6 GB
File System: NTFS
Model: WDC WD2500JS-60MHB1
Drive: D:
Free Space: 72.1 GB
Total Space: 205.9 GB
File System: NTFS
Drive: J:
Free Space: 212.8 GB
Total Space: 305.2 GB
File System: FAT32
Model: ST332082 0AS USB Device
Drive: K:
Free Space: 879.2 GB
Total Space: 1430.4 GB
File System: FAT32
Model: WDC WD15 EARS-00Z5B1 USB Device
Drive: I:
Model: Optiarc DVD RW AD-7173A
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (Dutch), 4/13/2008 19:40:46, 62976 bytes
System Devices
Name: Intel® Management Engine Interface
Device ID: PCI\VEN_8086&DEV_29C4&SUBSYS_50448086&REV_02\3&61AAA01&0&18
Driver: C:\WINDOWS\system32\DRIVERS\HECI.sys, 3.00.0030.1086 (English), 5/11/2007 18:00:14, 45056 bytes
Name: Intel® G33/G31/P35/P31 Express Chipset PCI Express Root Port - 29C1
Device ID: PCI\VEN_8086&DEV_29C1&SUBSYS_00000000&REV_02\3&61AAA01&0&08
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (Dutch), 4/14/2008 17:43:22, 68224 bytes
Name: Intel® G33/G31/P35/P31 Express Chipset Processor to I/O Controller - 29C0
Device ID: PCI\VEN_8086&DEV_29C0&SUBSYS_00000000&REV_02\3&61AAA01&0&00
Driver: n/a
Name: Intel® 82566DC-2 Gigabit Network Connection
Device ID: PCI\VEN_8086&DEV_294C&SUBSYS_00018086&REV_02\3&61AAA01&0&C8
Driver: C:\WINDOWS\system32\DRIVERS\e1e5132.sys, 9.15.0011.0000 (Dutch), 10/14/2011 10:40:24, 253656 bytes
Driver: C:\WINDOWS\system32\e1e5132.din, 5/17/2011 16:46:18, 2885 bytes
Driver: C:\WINDOWS\system32\NicCo2.dll, 1.02.0000.0000 (English), 8/6/2007 23:28:34, 28272 bytes
Driver: C:\WINDOWS\system32\NicInstE.dll, 9.10.0069.0000 (English), 6/16/2011 00:04:28, 81600 bytes
Driver: C:\WINDOWS\system32\e1000msg.dll, 9.08.0000.0000 (English), 12/14/2007 12:06:04, 121440 bytes
Name: Intel® ICH9 Family PCI Express Root Port 5 - 2948
Device ID: PCI\VEN_8086&DEV_2948&SUBSYS_00000000&REV_02\3&61AAA01&0&E4
Name: Intel® ICH9 Family PCI Express Root Port 4 - 2946
Device ID: PCI\VEN_8086&DEV_2946&SUBSYS_00000000&REV_02\3&61AAA01&0&E3
Name: Intel® ICH9 Family PCI Express Root Port 3 - 2944
Device ID: PCI\VEN_8086&DEV_2944&SUBSYS_00000000&REV_02\3&61AAA01&0&E2
Name: Intel® ICH9 Family PCI Express Root Port 2 - 2942
Device ID: PCI\VEN_8086&DEV_2942&SUBSYS_00000000&REV_02\3&61AAA01&0&E1
Name: Intel® ICH9 Family PCI Express Root Port 1 - 2940
Device ID: PCI\VEN_8086&DEV_2940&SUBSYS_00000000&REV_02\3&61AAA01&0&E0
Name: Microsoft UAA-busstuurprogramma voor High Definition Audio
Device ID: PCI\VEN_8086&DEV_293E&SUBSYS_00018086&REV_02\3&61AAA01&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 4/13/2008 17:36:05, 144384 bytes
Name: Intel® ICH9 Family USB2 Enhanced Host Controller - 293C
Device ID: PCI\VEN_8086&DEV_293C&SUBSYS_50448086&REV_02\3&61AAA01&0&D7
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:35, 30208 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:36, 143872 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (Dutch), 4/14/2008 18:02:44, 76288 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:37, 59520 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 18:02:27, 7168 bytes
Name: Intel® ICH9 Family USB2 Enhanced Host Controller - 293A
Device ID: PCI\VEN_8086&DEV_293A&SUBSYS_50448086&REV_02\3&61AAA01&0&EF
Name: Intel® ICH9 Family USB Universal Host Controller - 2939
Device ID: PCI\VEN_8086&DEV_2939&SUBSYS_50448086&REV_02\3&61AAA01&0&D2
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:35, 20608 bytes
Name: Intel® ICH9 Family USB Universal Host Controller - 2938
Device ID: PCI\VEN_8086&DEV_2938&SUBSYS_50448086&REV_02\3&61AAA01&0&D1
Name: Intel® ICH9 Family USB Universal Host Controller - 2937
Device ID: PCI\VEN_8086&DEV_2937&SUBSYS_50448086&REV_02\3&61AAA01&0&D0
Name: Intel® ICH9 Family USB Universal Host Controller - 2936
Device ID: PCI\VEN_8086&DEV_2936&SUBSYS_50448086&REV_02\3&61AAA01&0&EA
Name: Intel® ICH9 Family USB Universal Host Controller - 2935
Device ID: PCI\VEN_8086&DEV_2935&SUBSYS_50448086&REV_02\3&61AAA01&0&E9
Name: Intel® ICH9 Family USB Universal Host Controller - 2934
Device ID: PCI\VEN_8086&DEV_2934&SUBSYS_50448086&REV_02\3&61AAA01&0&E8
Name: Intel® 82801GB SMBus Controller - 2930 (Intel® SMBus 2.0 Driver)
Device ID: PCI\VEN_8086&DEV_2930&SUBSYS_50448086&REV_02\3&61AAA01&0&FB
Driver: C:\WINDOWS\system32\drivers\intelsmb.sys, 6.04.0000.0001 (English), 12/28/2006 07:27:00, 45184 bytes
Name: Intel® ICH9 Family 2 port Serial ATA Storage Controller 2 - 2926
Device ID: PCI\VEN_8086&DEV_2926&SUBSYS_50448086&REV_02\3&61AAA01&0&FD
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (Dutch), 8/2/2007 13:00:00, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (Dutch), 4/13/2008 19:40:29, 24960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/13/2008 19:40:30, 96512 bytes
Name: Intel® ICH9R/DO/DH 4 port Serial ATA Storage Controller 1 - 2920
Device ID: PCI\VEN_8086&DEV_2920&SUBSYS_50448086&REV_02\3&61AAA01&0&FA
Name: Intel® ICH9DH LPC Interface Controller - 2912
Device ID: PCI\VEN_8086&DEV_2912&SUBSYS_00000000&REV_02\3&61AAA01&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (Dutch), 4/14/2008 17:38:30, 37760 bytes
Name: Intel® 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_92\3&61AAA01&0&F0
Name: Standaard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_11AB&DEV_6101&SUBSYS_610111AB&REV_B1\4&84CCC20&0&00E1
Name: Pinnacle PCTV 310i PAL Stereo DVB-T Capture Device
Device ID: PCI\VEN_1131&DEV_7133&SUBSYS_002F11BD&REV_D1\4&2C3BA146&0&08F0
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:14, 60160 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.5512 (English), 4/13/2008 20:19:42, 146048 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.5512 (Dutch), 4/13/2008 19:45:16, 49408 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.5512 (English), 4/14/2008 18:03:22, 23552 bytes
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.5512 (Dutch), 4/14/2008 18:02:30, 4096 bytes
Driver: C:\WINDOWS\system32\kstvtune.ax, 5.03.2600.5512 (Dutch), 4/14/2008 18:03:21, 61952 bytes
Driver: C:\WINDOWS\system32\ksxbar.ax, 5.03.2600.5512 (English), 4/14/2008 18:03:21, 43008 bytes
Driver: C:\WINDOWS\system32\kswdmcap.ax, 5.03.2600.5512 (Dutch), 4/14/2008 18:03:21, 91648 bytes
Driver: C:\WINDOWS\system32\vidcap.ax, 5.01.2600.5512 (English), 4/14/2008 18:03:21, 28672 bytes
Driver: C:\WINDOWS\system32\vfwwdm32.dll, 5.01.2600.5512 (Dutch), 4/14/2008 18:02:44, 54272 bytes
Driver: C:\WINDOWS\system32\iyuv_32.dll, 5.01.2600.5908 (Dutch), 11/27/2009 17:10:19, 48128 bytes
Driver: C:\WINDOWS\system32\msh263.drv, 5.01.2600.5512 (Dutch), 4/14/2008 18:03:22, 299008 bytes
Driver: C:\WINDOWS\system32\msyuv.dll, 5.03.2600.5908 (English), 11/27/2009 18:14:12, 17920 bytes
Driver: C:\WINDOWS\system32\BdaPlgIn.ax, 5.03.2600.5512 (Dutch), 4/14/2008 18:03:21, 18432 bytes
Driver: C:\WINDOWS\system32\MSDvbNP.ax, 6.05.2600.5512 (English), 4/14/2008 18:03:21, 56832 bytes
Driver: C:\WINDOWS\system32\PsisRndr.ax, 6.05.2600.5512 (English), 4/14/2008 18:03:21, 33280 bytes
Driver: C:\WINDOWS\system32\PsisDecd.dll, 6.05.2600.5512 (English), 4/14/2008 18:02:38, 363520 bytes
Driver: C:\WINDOWS\system32\drivers\BdaSup.sys, 5.03.2600.5512 (English), 4/13/2008 19:46:21, 11776 bytes
Driver: C:\WINDOWS\system32\tsbyuv.dll, 5.01.2600.5908 (English), 11/27/2009 17:10:19, 8704 bytes
Driver: C:\WINDOWS\system32\drivers\3xHybrid.sys, 1.03.0003.0005 (English), 11/22/2006 08:53:02, 1121536 bytes
Driver: C:\WINDOWS\system32\34CoInstaller.dll, 2/27/2003 09:07:20, 3072 bytes
Name: NVIDIA GeForce 8600 GTS
Device ID: PCI\VEN_10DE&DEV_0400&SUBSYS_34481458&REV_A1\4&1E683DFA&0&0008
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 6.14.0012.8558 (English), 10/8/2011 05:50:00, 175104 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 10/8/2011 05:50:00, 285176 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 10/8/2011 05:50:00, 15511 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0012.8558 (English), 10/8/2011 05:50:00, 12791488 bytes
Driver: C:\WINDOWS\system32\OpenCL.dll, 1.00.0000.0000 (English), 10/8/2011 05:50:00, 65536 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0012.8558 (English), 10/8/2011 05:50:00, 4226688 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0012.8558 (English), 10/8/2011 05:50:00, 2449408 bytes
Driver: C:\WINDOWS\system32\nvcompiler.dll, 6.14.0012.8558 (English), 10/8/2011 05:50:00, 17240064 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0012.8558 (English), 10/8/2011 05:50:00, 5595136 bytes
Driver: C:\WINDOWS\system32\nvcuvenc.dll, 6.14.0012.8558 (English), 10/8/2011 05:50:00, 2099520 bytes
Driver: C:\WINDOWS\system32\nvcuvid.dll, 6.14.0012.8558 (English), 10/8/2011 05:50:00, 2398016 bytes
Driver: C:\WINDOWS\system32\nvdata.data, 10/8/2011 05:50:00, 2130002 bytes
Driver: C:\WINDOWS\system32\nvinfo.pb, 10/8/2011 05:50:00, 3250 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0012.8558 (English), 10/8/2011 05:50:00, 17956864 bytes
Driver: C:\WINDOWS\system32\nvdispco32.dll, 2.00.0018.0000 (English), 10/8/2011 05:50:00, 919872 bytes
Driver: C:\WINDOWS\system32\nvgenco32.dll, 2.00.0013.0000 (English), 10/8/2011 05:50:00, 877376 bytes
Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_50448086&REV_00\4&2C3BA146&0&18F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 4/13/2008 19:46:18, 61696 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 4/13/2008 19:46:18, 53376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 4/13/2008 19:51:25, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 4/13/2008 19:51:25, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 22:46:40, 6400 bytes
DirectX Components
ddraw.dll: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:24 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:24 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/2/2007 13:00:00 10496 bytes
d3d8.dll: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:23 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:23 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:23 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/2/2007 13:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:23 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/2/2007 13:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/2/2007 13:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/2/2007 13:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/2/2007 13:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 Dutch Final Retail 8/2/2007 13:00:00 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:24 229888 bytes
dpmodemx.dll: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:24 24064 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/2/2007 13:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:24 57856 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:55 29696 bytes
dpnsvr.exe: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:55 18432 bytes
dpnet.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:24 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:00:38 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:00:38 3072 bytes
dpvoice.dll: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:24 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:55 83456 bytes
dpvvox.dll: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:24 116736 bytes
dpvacm.dll: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:24 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:24 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:24 60928 bytes
dpserial.dll: 5.00.2134.0001 Dutch Final Retail 8/2/2007 13:00:00 53520 bytes
dinput.dll: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:24 163840 bytes
dinput8.dll: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:24 186880 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/2/2007 13:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 Dutch Final Retail 8/2/2007 13:00:00 395264 bytes
joy.cpl: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:03:20 69632 bytes
gcdef.dll: 5.01.2600.0000 Dutch Final Retail 8/2/2007 13:00:00 77312 bytes
pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:38 35328 bytes
dsound.dll: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:24 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:24 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:24 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:24 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:24 72192 bytes
dmusic.dll: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:24 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:24 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:24 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:24 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:24 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:24 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:24 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:24 82432 bytes
system.dll: 1.01.4322.2494 English Final Retail 1/3/2012 21:57:30 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 2/3/2012 16:54:43 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 2/3/2012 16:54:25 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 2/3/2012 16:54:27 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 2/3/2012 16:54:28 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 2/3/2012 16:54:28 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 2/3/2012 16:54:29 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 2/3/2012 16:54:30 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 2/3/2012 16:54:31 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 2/3/2012 16:54:32 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 2/3/2012 16:54:32 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 2/3/2012 16:54:44 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 2/3/2012 16:54:44 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 2/3/2012 16:54:44 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 2/3/2012 16:54:45 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 2/3/2012 16:54:45 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 2/3/2012 16:54:43 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 2/3/2012 16:54:43 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 2/3/2012 16:54:43 223232 bytes
dx7vb.dll: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:24 619008 bytes
dx8vb.dll: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:25 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:25 2113536 bytes
mfc40.dll: 4.01.0000.6151 English Beta Retail 9/18/2010 07:53:44 954368 bytes
mfc42.dll: 6.02.8081.0000 English Final Retail 2/8/2011 14:33:59 978944 bytes
wsock32.dll: 5.01.2600.5512 Dutch Final Retail 4/14/2008 18:02:45 24576 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 18:02:22 70656 bytes
devenum.dll: 6.05.2600.5512 Dutch Final Retail 4/14/2008 18:02:24 59904 bytes
dxmasf.dll: 6.04.0009.1133 Dutch Final Retail 4/14/2008 18:02:25 499254 bytes
mciqtz32.dll: 6.05.2600.5512 Dutch Final Retail 4/14/2008 18:02:29 35328 bytes
mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/14/2008 18:03:21 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 18:02:30 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:02:25 20480 bytes
qasf.dll: 9.00.0000.4503 Dutch Final Retail 4/14/2008 18:02:38 237568 bytes
qcap.dll: 6.05.2600.5512 Dutch Final Retail 4/14/2008 18:02:38 192512 bytes
qdv.dll: 6.05.2600.5512 Dutch Final Retail 4/14/2008 18:02:38 279040 bytes
qdvd.dll: 6.05.2600.6169 Dutch Final Retail 11/3/2011 16:29:18 386560 bytes
qedit.dll: 6.05.2600.5512 Dutch Final Retail 4/14/2008 18:02:38 562688 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 18:21:32 733696 bytes
quartz.dll: 6.05.2600.6169 Dutch Final Retail 11/3/2011 16:29:18 1296384 bytes
strmdll.dll: 4.01.0000.3938 Dutch Final Retail 8/26/2009 09:16:40 247326 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 18:03:21 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 18:03:21 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 18:02:28 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 18:02:28 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 18:02:28 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 18:02:28 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 18:02:28 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 18:03:21 154624 bytes
mswebdvd.dll: 6.05.2600.5857 Dutch Final Retail 8/5/2009 10:01:48 205312 bytes
ks.sys: 5.03.2600.5512 Dutch Final Retail 4/13/2008 20:16:36 141056 bytes
ksproxy.ax: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:03:22 129536 bytes
ksuser.dll: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:30 4096 bytes
stream.sys: 5.03.2600.5512 Dutch Final Retail 4/13/2008 19:45:16 49408 bytes
mspclock.sys: 5.03.2600.5512 Dutch Final Retail 4/13/2008 19:39:50 5376 bytes
mspqm.sys: 5.01.2600.5512 Dutch Final Retail 4/13/2008 19:39:51 4992 bytes
mskssrv.sys: 5.03.2600.5512 Dutch Final Retail 4/13/2008 19:39:52 7552 bytes
swenum.sys: 5.03.2600.5512 Dutch Final Retail 4/13/2008 19:39:53 4352 bytes
mstee.sys: 5.03.2600.5512 Dutch Final Retail 4/13/2008 19:39:50 5504 bytes
bdaplgin.ax: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:03:21 18432 bytes
bdasup.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:46:21 11776 bytes
msdvbnp.ax: 6.05.2600.5512 English Final Retail 4/14/2008 18:03:21 56832 bytes
psisdecd.dll: 6.05.2600.5512 English Final Retail 4/14/2008 18:02:38 363520 bytes
psisrndr.ax: 6.05.2600.5512 English Final Retail 4/14/2008 18:03:21 33280 bytes
ipsink.ax: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:03:21 16384 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 18:03:21 118272 bytes
ndisip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:46:22 10880 bytes
mpe.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:46:22 15232 bytes
streamip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:46:21 15232 bytes
msvidctl.dll: 6.05.2600.5512 Dutch Final Retail 4/14/2008 18:02:33 1433088 bytes
slip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:46:23 11136 bytes
nabtsfec.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:46:25 85248 bytes
ccdecode.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:46:23 17024 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 18:03:21 30208 bytes
msyuv.dll: 5.03.2600.5908 English Final Retail 11/27/2009 18:14:12 17920 bytes
kstvtune.ax: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:03:21 61952 bytes
ksxbar.ax: 5.03.2600.5512 English Final Retail 4/14/2008 18:03:21 43008 bytes
kswdmcap.ax: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:03:21 91648 bytes
vfwwdm32.dll: 5.01.2600.5512 Dutch Final Retail 4/14/2008 18:02:44 54272 bytes
wstcodec.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:46:24 19200 bytes
wstdecod.dll: 5.03.2600.5512 Dutch Final Retail 4/14/2008 18:02:45 51200 bytes
DirectShow Filters
WDM Streaming VBI-codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.5512
CC-decoder,0x00200000,2,1,,5.03.2600.5512
WST-codec,0x00200000,1,1,,5.03.2600.5512
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,6.05.0001.0000
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Multiple VOB-MPEG2 Source,0x00200000,0,0,vobsrc.ax,1.00.0000.0016
Pinnacle RAW Buffer Source,0x00200000,0,2,RawBuffer.ax,1.01.0340.0000
Pinnacle Real Media Renderer 2,0x00200000,2,0,PCLERMRenderer2.ax,1.00.0000.0007
DVC150 Muxer,0x00200000,2,1,DVC150Muxer.ax,4.00.0001.0000
Pinnacle MPEG TS Splitter,0x00200000,1,1,pcleTSBox.ax,3.00.0625.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.6169
Pinnacle Stream Mapper Filter,0x00200000,1,1,StreamMapperFilter.ax,1.00.0930.0000
Pinnacle VariSpeed Filter,0x00200000,0,0,DWVariSpeed.ax,15.00.0000.0004
Pinnacle MPEG TS Splitter (Rec),0x00200000,1,1,pcleTSBox.ax,3.00.0625.0000
PushSink,0x00200000,1,0,pushSink.ax,8.00.0000.0000
ESink,0x00200000,1,0,ESink.ax,2.00.0000.0001
Pinnacle MPADecoder,0x00400000,1,1,MPADecoder.ax,2.01.0000.0006
Pinnacle Video Renderer,0x00200000,1,0,pcle_ovr.ax,6.00.0297.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Pinnacle DVB Network,0x00200000,0,1,DvbTNetwork.ax,2.00.0323.0000
Pinnacle Float2PCM,0x00200000,0,0,Float2PCM.ax,1.00.0000.0009
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.6169
Pinnacle MPEG Layer-1/2 Audio Decoder,0x00400000,1,1,pcleMPEGBox.ax,5.00.0627.0000
Pinnacle ASF Audio Source,0x00200000,0,0,PCLEASFMediaSource.ax,1.00.0002.0023
Pinnacle Cutlist Audio Source 3,0x00200000,0,0,PCLECutlistSource3.ax,3.00.0000.0045
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.4503
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
VOB Stream Splitter,0x00200000,1,0,vobsplit2.ax,1.00.0000.0060
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.6169
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.6169
Pinnacle Infinite Pin Tee,0x00200000,1,1,pinftee.ax,9.00.0464.0000
Pinnacle LPCM PCM Transform Filter,0x00200000,0,0,PCLELPCMTransform.ax,1.00.0002.0003
Cirrus Logic USB-DVR2 Sink,0x00200000,1,0,usbdvr2snk.ax,4.01.0001.0000
MediaSampleGrab,0x00200000,1,1,FrameGrab.ax,2.00.0000.0000
Pinnacle(dicas) MPEG-4 Multiplexer,0x00200000,1,1,pclempeg4mux.ax,1.05.0170.0000
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Pinnacle MPEG Encoder,0x00200000,1,1,PcleMpegEnc.AX,4.00.0000.0012
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
RealVideo Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0001
Cirrus Logic USB-DVR2 Splitter,0x00200000,1,2,usbdvr2splt.ax,5.04.0001.0000
Emuzed Flow Control,0x00200000,1,1,FlowCtrl.ax,2.00.0000.0001
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
Pinnacle DVD Data Streamer Filter,0x00200000,1,1,DVDDataStreamerFilter.ax,2.01.0118.0000
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.6076
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Pinnacle Audio Scene Analyzer,0x00200000,1,0,DWAudioSceneAnalyzer.ax,1.01.0002.0030
HP Frame Grabber Filter,0x00200000,1,1,hpqdsftr.ax,53.00.0013.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6169
ESinkAudio,0x00200000,1,0,ESinkAudio.ax,1.00.0000.0000
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
Pinnacle(dicas) MPEG-4 Audio Decoder,0x00200001,1,1,pclempeg4auddec.ax,1.06.0170.0000
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DVC 150 XFormDEADCAFE,0x00200000,2,0,DVC150XFormDeadCafe.ax,4.00.0001.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
Pinnacle MPEG Layer 1-3 Audio Decoder,0x00400000,1,1,PCLEMPADecoder.ax,1.00.0000.0029
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.6169
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169
Pinnacle Audio Codec,0x00600000,1,1,PcleAudioCodec.ax,1.00.0285.0000
Pinnacle AC3 Audio Source,0x00200000,0,0,PCLEAC3MediaSource.ax,1.00.0002.0010
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.06.0000.0052
Pinnacle(dicas) MPEG-4 Video Encoder,0x00200000,1,1,pclempeg4videnc.ax,3.09.0170.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
Pinnacle Image Scaler,0x00200000,1,1,pcleCSC.ax,2.04.0298.0000
Pinnacle AC3 Encoder (5.1 Channels),0x00200000,1,1,PcleAC3Enc5_1Ch.ax,1.00.0284.0000
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Pinnacle Cutlist Video Source 3,0x00200000,0,0,PCLECutlistSource3.ax,3.00.0000.0045
Pinnacle MPEG4 Video Source,0x00200000,0,0,PCLEMPEG4MediaSource.ax,1.00.0002.0071
HP MPEG-1 Encoder,0x00200000,3,3,hpqdsftr.ax,53.00.0013.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6169
Pinnacle Windows Media Renderer2,0x00200000,0,0,WMRenderer2.ax,1.01.0000.0000
DVC150 Source,0x00200000,1,1,usbdvr2src.ax,5.04.0006.0003
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.6169
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.4503
Pinnacle Single Audio Source,0x00200000,0,0,PCLESingleSource.ax,1.00.0002.0031
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Pinnacle MPEG Video Decoder,0x00400000,1,1,PCLEMPEGVideoDecoder2.ax,1.07.0000.0022
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Pinnacle Video AntiJitter,0x00200000,1,1,pcleCSC.ax,2.04.0298.0000
Pinnacle Scene Detect Filter,0x00200000,0,0,DWSceneDetect2.ax,15.00.0002.0015
Pinnacle Single Video Source,0x00200000,0,0,PCLESingleSource.ax,1.00.0002.0031
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Pinnacle(dicas) MPEG-4 File Reader,0x00200000,0,1,pclemp4filereader.ax,1.05.0170.0000
PICVideo M-JPEG 3 DirectShow Decompressor,0x00800001,1,1,pvmjpg30.dll,3.00.0000.0012
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Pinnacle MPEG4 Audio Source,0x00200000,0,0,PCLEMPEG4MediaSource.ax,1.00.0002.0071
Pinnacle MPEG2 Demux II (MovieBox USB version),0x00200000,1,2,PcleDemux2MBox.ax,2.00.0001.0004
Pinnacle MCE Multiplexer,0x00200000,2,1,pcleMPEGBox.ax,5.00.0627.0000
Pinnacle Quality Controller,0x00200000,1,1,DWQualityControl.ax,1.00.0000.0000
Audio Adaptor,0x00200000,1,1,AudioAdaptor.ax,1.01.0285.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.4503
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
Pinnacle Video Block Filter,0x00200000,1,1,pcleCSC.ax,2.04.0298.0000
Pinnacle Stream Source Filter,0x00200000,0,1,StreamSource.ax,1.00.0000.0004
Pinnacle MPEG Layer-2 Audio Encoder,0x00200000,1,1,PCLEMPAEncoder.ax,2.00.0000.0014
Pinnacle MPEG Source 2,0x00200000,0,3,PCLEMPEGSource2.ax,2.00.0002.0055
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.6169
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.4503
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6169
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.6076
MPEG Timeshift File Reader,0x00200000,0,1,TimeshiftFileBox.ax,4.00.0340.0000
Pinnacle Field Reverser Filter,0x00200000,0,0,DWFieldReverser.ax,3.02.0000.0005
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.6169
Pinnacle Time Fixer Filter,0x00200000,0,0,TimeFixer2.ax,1.00.0000.0002
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.6169
Pinnacle Image Converter,0x00200000,1,1,pcleCSC.ax,2.04.0298.0000
Pinnacle VideoInfo Changer Filter,0x00200000,0,0,VideoInfoChanger2.ax,1.00.0000.0003
SmartSound Soundtrack,0x00400000,0,1,DirectQX.dll,3.00.0002.0007
SmartSound SDS Reader,0x00400000,0,1,SDSReader.dll,3.00.0002.0007
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.6169
Pinnacle AC3 Encoder (2 Channels),0x00200000,1,1,PcleAC3Enc2Ch.ax,1.00.0284.0000
RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.0001.0001
Pinnacle AVI Video Source,0x00200000,0,0,PCLEAVIMediaSource.ax,1.00.0002.0049
TS_AsyncPuller,0x00400000,0,0,TS_AsynPull.ax,2.00.0464.0000
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.05.0001.0000
LEAD MCMP/MJPEG Codec,0x00000000,0,0,,
LEAD MCMP/MJPEG Decoder,0x00000000,0,0,,
Pinnacle File Writer,0x00200000,1,0,mpegrender.ax,1.00.0000.0014
Pinnacle Bender AudioPrefilter2,0x00200000,1,0,PCLEBenderAudioPrefilter2.ax,1.01.0000.0002
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.4503
Pinnacle Error Handler,0x00200000,1,1,PCLEErrorHandler.ax,1.00.0000.0000
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4504
DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0028
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
MPEG Timeshift File Writer,0x00200000,1,0,TimeshiftFileBox.ax,4.00.0340.0000
Pinnacle MPEG Layer-2 Audio Encoder,0x00200000,1,1,pcleMPEGBox.ax,5.00.0627.0000
Audio Source Adaptor,0x00200000,1,1,AudioAdaptor.ax,1.01.0285.0000
Pinnacle MP3 Audio Source,0x00200000,0,0,PCLEMP3MediaSource.ax,1.00.0002.0021
Pinnacle MPEG Adjust,0x00200000,1,1,pcleMPEGBox.ax,5.00.0627.0000
Pinnacle MPEG Audio Source,0x00200000,0,0,PCLEMPEGMediaSource.ax,1.00.0002.0050
Pinnacle AVI Audio Source,0x00200000,0,0,PCLEAVIMediaSource.ax,1.00.0002.0049
Pinnacle(dicas) MPEG-4 File Writer,0x00200000,1,0,pclemp4filewriter.ax,1.05.0170.0000
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
RealAudio Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0001
Pinnacle OSD Engine,0x00200000,1,0,VRManager.dll,1.00.0297.0000
Pinnacle Video Deinterlacer,0x00200000,1,1,pcleCSC.ax,2.04.0298.0000
Pinnacle WAV Audio Source,0x00200000,0,0,PCLEWAVMediaSource.ax,1.00.0002.0010
Pinnacle H.264 Encoder,0x00400000,1,1,H264Codec.ax,1.02.0463.0000
Pinnacle MP3 Encoder,0x00200000,1,1,PcleMP3Encoder.ax,9.03.0000.0005
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.6169
PICVideo M-JPEG 3 DirectShow Compressor,0x00100000,1,1,pvmjpg30.dll,3.00.0000.0012
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.6169
Pinnacle Silencer,0x00200000,0,0,PCLESilencer.ax,1.00.0002.0003
Pinnacle H.264 Decoder,0x00400000,1,1,H264Codec.ax,1.02.0463.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.6169
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.4503
Pinnacle MPEG Video Source,0x00200000,0,0,PCLEMPEGMediaSource.ax,1.00.0002.0050
AudioResampler,0x00200000,1,1,audioresampler.ax,2.01.0285.0000
Pinnacle ASF Video Source,0x00200000,0,0,PCLEASFMediaSource.ax,1.00.0002.0023
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Pinnacle DV Decoder,0x00200000,1,1,pcleDVBox.ax,2.02.0085.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
Pinnacle Teletext EPG Slicer,0x00200000,1,0,EpgTeletextSlicer.ax,2.00.0323.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Pinnacle Sample Sink,0x00200000,0,0,PCLESampleSink.ax,1.00.0002.0020
Pinnacle Stream Buffer Sink,0x00200000,1,0,StreamBuffer.ax,1.03.0340.0000
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.4503
Pinnacle TS EPG Slicer,0x00200000,1,0,EpgTransportStreamSlicer.ax,2.00.0323.0000
Pinnacle MPEG TS FileSource,0x00200000,0,0,pcleTSBox.ax,3.00.0625.0000
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
Pinnacle Audio / Video synchronisation filter,0x00200000,2,2,PCLESync.ax,1.01.0000.0005
DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0028
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Pinnacle wave source,0x00200000,0,1,DWWaveCapture.ax,5.00.0000.0000
Pinnacle MPEG 2 Decoder,0x00400000,2,1,pcleMPEGBox.ax,5.00.0627.0000
WaveFormatEx Detective,0x00400000,1,1,WFXDetective.ax,1.00.0000.0001
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.6076
AXWavRender,0x00200000,1,0,axwavrender.ax,4.02.0000.0001
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Pinnacle DCxx MJPEG Decompressor,0x00800000,1,1,MjpgDecompress.ax,3.01.0000.0003
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.6169
Pinnacle Slideshow Source Filter,0x00200000,0,1,PCLESlideshow.ax,1.00.1972.31897
Pinnacle MPEG 2 Splicer,0x00200000,2,3,pcleMPEGBox.ax,5.00.0627.0000
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6169
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.6169
Pinnacle MPEG Demuxer,0x00200000,1,3,PcleMPGDemux.ax,5.00.0625.0000
Pinnacle MPEG 2/AVC Multiplexer,0x00200000,2,1,pcleMPEGBox.ax,5.00.0627.0000
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.6169
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.6169
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.4503
Pinnacle DV Encoder,0x00200000,1,1,pcleDVBox.ax,2.02.0085.0000
VOB MPEG2 Video Codec,0x00600000,2,1,vobmpg2.ax,1.00.0562.0000
AVSynChronizer Filter,0x00200000,2,2,AVSynChronizer.ax,3.00.0464.0000
Pinnacle H.264 Transformer,0x00400000,1,1,H264Codec.ax,1.02.0463.0000
Pinnacle RAW Buffer Sink,0x00200000,2,0,RawBuffer.ax,1.01.0340.0000
Pinnacle(dicas) AMR Audio Decoder,0x00600000,1,1,pcleamrauddec.ax,2.03.0086.0000
Pinnacle MPEG 2 Encoder,0x00200000,1,1,pcleMPEGBox.ax,5.00.0627.0000
AVI_PASS,0x00800000,1,1,AVI_PASS.ax,2.00.0000.0000
RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00.0001.0001
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Pinnacle Generic VBI Slicer,0x00200000,3,1,VbiGenericSlicer.ax,2.00.0323.0000
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.6169
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.6169
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.6169
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Pinnacle AC3 Decoder,0x00800000,1,1,PcleAC3Decoder.ax,1.00.0284.0000
HP Rotate Filter,0x00200000,1,1,hpqdsftr.ax,53.00.0013.0000
Pinnacle Wall Clock,0x00200000,0,0,WallClock.ax,1.00.0464.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Pinnacle MPEG TS Splitter (Async),0x00200000,1,1,pcleTSBox.ax,3.00.0625.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Pinnacle(dicas) MPEG-4 Audio Encoder,0x00200000,1,1,pclempeg4audenc.ax,1.06.0170.0000
HP Resize Filter,0x00200000,1,1,hpqdsftr.ax,53.00.0013.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Pinnacle TS VBI Slicer,0x00200000,1,1,VbiTransportStreamSlicer.ax,2.00.0323.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
Pinnacle Stream Buffer Source,0x00200000,0,1,StreamBuffer.ax,1.03.0340.0000
Pinnacle file sink 2,0x00200000,0,0,DWSink2.ax,20.00.0000.0005
BDA MPEG2 Transport Information Filter,0x00200000,1,0,PsisRndr.ax,6.05.2600.5512
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6169
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.6169
AudioGrab,0x00200000,1,1,AudioGrab.ax,1.00.0000.0002
Pinnacle CSC,0x00200000,1,1,pcleCSC.ax,2.04.0298.0000
Audio Destination Adaptor,0x00200000,1,1,AudioAdaptor.ax,1.01.0285.0000
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM streaming-tee/splitter-apparatuur:
Tee/Sink-to-Sink-conversieprogramma,0x00200000,1,1,,5.03.2600.5512
Pinnacle MPEG4 Filters:
Pinnacle(dicas) AMR Audio Decoder,0x00200000,1,1,pcleamrauddec.ax,2.03.0086.0000
Pinnacle(dicas) MPEG-4 Audio Decoder,0x00200000,1,1,pclempeg4auddec.ax,1.06.0170.0000
WDM streaming-gegevenstransformaties:
Microsoft Kernel akoestische echo-opheffing,0x00000000,0,0,,
Microsoft Kernel GS Wavetable-synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DLS-synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DRM-audiodecoder,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DivX Encoder Filter,0x00200000,1,1,divxenc.ax,6.00.0000.1586
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.6169
Pinnacle DCxx MJPEG Decompressor,0x00200000,0,0,MjpgDecompress.ax,3.01.0000.0003
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
DivX® 6.5.1 Codec (2 Logical CPUs),0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV-codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
PICVideo M-JPEG 3 VfW Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Windows Media Video 9,0x00200000,1,1,qcap.dll,6.05.2600.5512
DivX® 6.5.1 YV12 Decoder,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.6169
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6169
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6169
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.6169
DSP Group TrueSpeech,0x00200000,1,1,quartz.dll,6.05.2600.6169
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.6169
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.6169
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.6169
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.6169
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.6169
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.6169
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.6169
Audio Capture Sources:
Realtek HD Audio Input,0x00200000,0,0,qcap.dll,6.05.2600.5512
Pinnacle PCTV 713x Tuner BDA An,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.6169
Microsoft GS Wavetable-software,0x00200000,1,0,quartz.dll,6.05.2600.6169
Pinnacle Auxiliary Filters:
Pinnacle AC3 Decoder,0x00200000,1,1,PcleAC3Decoder.ax,1.00.0284.0000
Pinnacle Audio Codec,0x00200000,1,1,PcleAudioCodec.ax,1.00.0285.0000
Pinnacle Error Handler Filter,0x00200000,0,0,PCLEErrorHandler.ax,1.00.0000.0000
Pinnacle H.264 Decoder,0x00200000,1,1,H264Codec.ax,1.02.0463.0000
Pinnacle H.264 Encoder,0x00200000,1,1,H264Codec.ax,1.02.0463.0000
Pinnacle H.264 Transformer,0x00200000,1,1,H264Codec.ax,1.02.0463.0000
Pinnacle MPEG 2 Decoder,0x00200000,2,1,pcleMPEGBox.ax,5.00.0627.0000
Pinnacle MPEG 2 Multiplexer,0x00200000,2,1,pcleMPEGBox.ax,5.00.0627.0000
Pinnacle MPEG Layer-1/2 Audio Decoder,0x00200000,1,1,pcleMPEGBox.ax,5.00.0627.0000
Pinnacle MPEG Source 2,0x00200000,0,0,PCLEMPEGSource2.ax,2.00.0002.0055
Pinnacle Real Media Renderer 2,0x00200000,0,0,PCLERMRenderer2.ax,1.00.0000.0007
Pinnacle Stream Source Filter,0x00200000,0,0,StreamSource.ax,1.00.0000.0004
TS_AsyncPuller,0x00200000,0,0,TS_AsynPull.ax,2.00.0464.0000
WDM streaming-opnameapparaten:
Realtek HD Audio Input,0x00200000,1,1,,5.03.2600.5512
Pinnacle PCTV 713x Tuner BDA Analog Capture,0x00200000,5,0,,5.03.2600.5512
Pinnacle PCTV 713x Tuner BDA Analog Audio Capture,0x00200000,2,0,,5.03.2600.5512
WDM streaming-opbouwprincipeapparatuur:
Realtek HD Audio output,0x00200000,1,1,,5.03.2600.5512
BDA-bronfilters:
Pinnacle PCTV 713x Tuner BDA DVBT Tuner,0x00200000,2,0,,5.03.2600.5512
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.2600.5512
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.5512
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,
Microsoft DVBS Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.5512
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,
Video Capture Sources:
Cirrus Logic USB-DVR2 Source,0x00200000,0,0,usbdvr2src.ax,5.04.0006.0003
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,PsisRndr.ax,6.05.2600.5512
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
TV/tuner-apparatuur voor WDM-streaming:
Pinnacle PCTV 713x Tuner BDA Analog TV Tuner,0x00200000,2,0,,5.03.2600.5512
Crossbar-apparatuur voor WDM-streaming:
Pinnacle PCTV 713x Tuner BDA Analog Xbar,0x00200000,12,0,,5.03.2600.5512
TV/audio-apparatuur voor WDM-streaming:
Pinnacle PCTV 713x Tuner BDA Analog TV Audio,0x00200000,2,0,,5.03.2600.5512
WDM streaming-mixer-apparatuur:
Microsoft Kernel Wave-audiomixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.6161
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.6161
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.6161
Pinnacle TV Filters:
WDM streaming-communicatietransformaties:
Audio Renderers:
Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.6169
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.6169
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.6169
DirectSound: Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.6169
WDM-streaming systeemapparaten:
Realtek HD Audio Input,0x00200000,3,1,,5.03.2600.5512
Realtek HD Audio output,0x00200000,12,1,,5.03.2600.5512
Pinnacle PCTV 713x Tuner BDA Analog Audio Capture,0x00200000,1,1,,5.03.2600.5512
BDA-ontvangeronderdelen:
Pinnacle PCTV 713x Tuner BDA Digital Capture,0x00200000,2,0,,5.03.2600.5512
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.5512
BDA MPE-filter,0x00600000,1,1,,5.03.2600.5512
DirectSound-testresultaten: Fout bij stap 19 (Gebruikerscontrole van software): HRESULT = 0x00000000 (Foutcode)
  • Reacties 33
Je hebt reeds een nieuwe installatie van Windows XP uitgevoerd, in welke volgorde heb je nadien de drivers geïnstalleerd van de audio en chipset drivers?
geluidskaart er afgehaald en terug geïnstalleerd, nieuwe driver.
Hiermee bedoel je waarschijnlijk de drivers verwijderd en opnieuw geïnstalleerd, het gaat hier toch om een onboard geluidskaart en niet een losse geluidskaart?
t's een onboard realtek geluidskaart. ik heb eerst windows xp pro opnieuw geinstalleerd. die gaf al dadelijk problemen met een aantal (intel) drivers die em niet vond dus eerst die derop gezet en daarna de raeltek drivers. geeft zelfde resultaat als op de oude installatie en zelfde foutmelding in xdiag zie hieronder.
------------------System Information
Memory: 1006MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
Monitor Max Res:
WHQL Logo'd: Yes
VDD: n.v.t.
Vendor ID: 0x10DE
Device ID: 0x0400
Revision ID: 0x00A1
Revision ID: 0x00A1
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF5F
HW Memory: 0
Sensaura ZoomFX: No
Registry: OK
Cap Flags: 0x41
Format Flags: 0xFFF
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
Acceleration: n/a
Registry: OK
DirectInput Devices
Device Name: Muis
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Registry: OK
USB Devices
+ USB-hoofdhub
| Service: usbhub
Gameport Devices
PS/2 Devices
| Service: kbdhid
| Service: TermDD
| Service: mouhid
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
Free Space: 15.5 GB
File System: NTFS
Drive: D:
Free Space: 72.1 GB
File System: NTFS
Drive: J:
File System: FAT32
Drive: K:
File System: FAT32
Drive: I:
System Devices
Driver: n/a
DirectX Components
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
Midi Renderers:
BDA-bronfilters:
BDA CP/CA Filters:
Audio Renderers:
Die is (waarschijnlijk wegens krassen) helaas niet meer leesbaar
(intel express installer driver cd for the intell desktop boards DGFB AND DGBU CLASSIC SERIES)
Verwijder eens de chipset en audio drivers met behulp van Revo Uninstaller.
Een handleiding en hoe je dit programma gebruikt met de downloadlocatie vind je hier.
Herstart je pc en installeer dan eerst deze Chipset driver
Herstart je pc en installeer dan deze Audio driver
Hopelijk heb je nu meer succes
Intel® Management Engine Interface en Intel® SMBus beide verwijderen (of alleen de engine interface)?
