Hopelijk heb ik het goed gedaan??zip bestandje?
RogueKiller V8.1.0 [09/28/2012] by Tigzy
mail: tigzyRK<at>gmail<dot>com
Feedback: RogueKiller - Geeks to Go Forums
Website: RogueKiller
Blog: tigzy-RK
Operating System: Windows 7 (6.1.7601 Service Pack 1) 64 bits version
Started in : Normal mode
User : flokke [Admin rights]
Mode : Scan -- Date : 09/29/2012 22:56:09
¤¤¤ Bad processes : 0 ¤¤¤
¤¤¤ Registry Entries : 7 ¤¤¤
[RUN][sUSP PATH] HKLM\[...]\Run : JAVA (C:\Windows\java.vbs) -> FOUND
[TASK][ROGUE ST] 0 : c:\program files (x86)\internet explorer\iexplore.exe -> FOUND
[TASK][ROGUE ST] 4817 : wscript.exe C:\Users\flokke\AppData\Local\Temp\launchie.vbs //B -> FOUND
[TASK][bLPATH] HPCustParticipation HP Photosmart 6510 series : "C:\Program Files\HP\HP Photosmart 6510 series\Bin\HPCustPartic.exe" /UA 9.5 /DDV 0x1000 -> FOUND
[sTARTUP][bLACKLIST DLL] Inktwaarschuwingen controleren - HP Photosmart 6510 series (netwerk).lnk @flokke : C:\Windows\system32\RunDll32.exe|"C:\Program Files\HP\HP Photosmart 6510 series\bin\HPStatusBL.dll",RunDLLEntry SERIALNUMBER=CN1C2411DT05QB;CONNECTION=NW;MONITOR=1; -> FOUND
[HJ SMENU] HKLM\[...]\Advanced : Start_ShowMyGames (0) -> FOUND
[HJ SMENU] HKLM\[...]\Advanced : Start_ShowRun (0) -> FOUND
¤¤¤ Particular Files / Folders: ¤¤¤
¤¤¤ Driver : [NOT LOADED] ¤¤¤
¤¤¤ HOSTS File: ¤¤¤
--> C:\Windows\system32\drivers\etc\hosts
¤¤¤ MBR Check: ¤¤¤
+++++ PhysicalDrive0: ST32000542AS +++++
--- User ---
[MBR] e9d343d5216d5be0a9eea973bb51622f
[bSP] 301bf6bd99be89b946b8bb0f63e5d29e : Windows Vista/7 MBR Code
Partition table:
0 - [ACTIVE] NTFS (0x07) [VISIBLE] Offset (sectors): 2048 | Size: 100 Mo
1 - [XXXXXX] NTFS (0x07) [VISIBLE] Offset (sectors): 206848 | Size: 1875883 Mo
2 - [XXXXXX] NTFS (0x07) [VISIBLE] Offset (sectors): 3842015232 | Size: 30720 Mo
3 - [XXXXXX] COMPAQ (0x12) [VISIBLE] Offset (sectors): 3904929792 | Size: 1024 Mo
User = LL1 ... OK!
User = LL2 ... OK!
Finished : << RKreport[1].txt >>
RKreport[1].txt
  • Reacties 29
Heb ik het goed gedaan? Zip bestandje??nie gevonden...Merciekes!
Blog: tigzy-RK
¤¤¤ HOSTS File: ¤¤¤
¤¤¤ MBR Check: ¤¤¤
--- User ---
Partition table:
User = LL1 ... OK!
User = LL2 ... OK!
RKreport[1].txt
Link 1
Link 2
Klik hier
Hierbij het logje, bedankt !
ComboFix 12-09-30.01 - flokke 30/09/2012 20:28:01.1.4 - x64
Microsoft Windows 7 Home Premium 6.1.7601.1.1252.32.1043.18.4078.2564 [GMT 2:00]
Gestart vanuit: c:\users\flokke\Downloads\ComboFix.exe
AV: AVG Internet Security Business Edition 2012 *Disabled/Updated* {5A2746B1-DEE9-F85A-FBCD-ADB11639C5F0}
FW: AVG Internet Security Business Edition 2012 *Enabled* {621CC794-9486-F902-D092-0484E8EA828B}
SP: AVG Internet Security Business Edition 2012 *Disabled/Updated* {E146A755-F8D3-F7D4-C17D-96C36DBE8F4D}
SP: Windows Defender *Disabled/Outdated* {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
c:\program files (x86)\DealPly
c:\program files (x86)\DealPly\DealPlyTune.dll
c:\program files (x86)\DealPly\sqlite3.dll
c:\programdata\dsgsdgdsgdsgw.pad
(((((((((((((((((((( Bestanden Gemaakt van 2012-08-28 to 2012-09-30 ))))))))))))))))))))))))))))))
2013-04-28 15:58 . 2013-04-28 15:58 -------- d--h--w- c:\programdata\Common Files
2013-04-28 15:57 . 2013-04-28 15:57 -------- d-----w- c:\program files (x86)\AVG
2013-04-28 15:54 . 2012-09-30 14:10 -------- d-----w- c:\programdata\MFAData
2012-09-30 18:31 . 2012-09-30 18:31 -------- d-----w- c:\users\Default\AppData\Local\temp
2012-09-29 16:29 . 2012-09-29 20:48 -------- d-----w- C:\sh4ldr
2012-09-29 16:29 . 2012-09-29 16:29 -------- d-----w- c:\program files\Enigma Software Group
2012-09-29 16:28 . 2012-09-29 20:48 -------- d-----w- c:\windows\8C5C34C7BC6B48318B2C6535FE63E502.TMP
2012-09-29 16:28 . 2012-09-29 16:28 -------- d-----w- c:\program files (x86)\Common Files\Wise Installation Wizard
2012-09-26 13:55 . 2012-09-28 19:30 -------- d-----w- c:\users\flokke\AppData\Roaming\Systweak
2012-09-26 13:55 . 2012-09-21 10:05 17080 ----a-w- c:\windows\system32\roboot64.exe
2012-09-26 13:11 . 2012-08-21 21:01 245760 ----a-w- c:\windows\system32\OxpsConverter.exe
2012-09-25 16:13 . 2012-09-25 16:13 -------- d-----w- c:\program files (x86)\Online Games Manager
2012-09-24 15:21 . 2011-09-16 09:24 778088 ------w- c:\windows\system32\HPDiscoPMA511.dll
2012-09-20 17:01 . 2012-09-20 17:01 388096 ----a-r- c:\users\flokke\AppData\Roaming\Microsoft\Installer\{45A66726-69BC-466B-A7A4-12FCBA4883D7}\HiJackThis.exe
2012-09-20 17:01 . 2012-09-20 17:01 -------- d-----w- c:\program files (x86)\Trend Micro
2012-09-19 20:47 . 2012-09-19 20:47 -------- d-----w- c:\users\flokke\AppData\Roaming\Malwarebytes
2012-09-19 20:47 . 2012-09-19 20:47 -------- d-----w- c:\programdata\Malwarebytes
2012-09-19 20:43 . 2012-09-29 21:20 -------- d-----w- c:\program files\CCleaner
2012-09-19 19:39 . 2012-08-22 18:12 950128 ----a-w- c:\windows\system32\drivers\ndis.sys
2012-09-19 19:39 . 2012-07-04 20:26 41472 ----a-w- c:\windows\system32\drivers\RNDISMP.sys
2012-09-19 19:39 . 2012-08-22 18:12 1913200 ----a-w- c:\windows\system32\drivers\tcpip.sys
2012-09-19 19:39 . 2012-08-22 18:12 376688 ----a-w- c:\windows\system32\drivers\netio.sys
2012-09-19 19:39 . 2012-08-22 18:12 288624 ----a-w- c:\windows\system32\drivers\FWPKCLNT.SYS
2012-09-19 19:39 . 2012-08-02 17:58 574464 ----a-w- c:\windows\system32\d3d10level9.dll
2012-09-19 19:39 . 2012-08-02 16:57 490496 ----a-w- c:\windows\SysWow64\d3d10level9.dll
2012-09-17 17:32 . 2012-09-19 07:44 -------- d-----w- c:\program files (x86)\Microsoft
2012-09-17 17:32 . 2012-09-24 15:22 -------- d-----w- c:\program files (x86)\HP Photo Creations
2012-09-17 17:32 . 2012-09-24 15:22 -------- d-----w- c:\programdata\HP Photo Creations
2012-09-17 17:31 . 2012-09-17 17:31 -------- d-----w- c:\users\flokke\AppData\Roaming\HpUpdate
2012-09-17 17:30 . 2012-09-17 17:30 -------- d-----w- c:\programdata\HP
2012-09-17 17:30 . 2012-09-24 15:21 -------- d-----w- c:\program files (x86)\HP
2012-09-17 17:30 . 2012-09-17 17:30 -------- d-----w- c:\program files\HP
2012-09-17 17:29 . 2012-09-24 15:24 -------- d-----w- c:\users\flokke\AppData\Local\HP
2012-09-15 20:04 . 2012-09-15 20:04 -------- d-----w- c:\users\flokke\AppData\Roaming\Oberon Media
2012-09-15 20:04 . 2012-09-19 19:33 -------- d-----w- c:\program files (x86)\Yahoo! Games
2012-09-15 09:08 . 2012-09-15 09:08 -------- d-----w- c:\program files (x86)\MSECache
2012-09-14 17:07 . 2012-09-27 15:52 -------- d-----w- C:\Zylom Games
2012-09-14 17:07 . 2012-09-27 15:52 -------- d-----w- c:\program files (x86)\RealArcade
2012-09-12 17:05 . 2012-09-14 16:19 -------- d-----w- c:\programdata\FarmFrenzy3_Madagascar
2012-09-12 17:00 . 2012-09-12 17:00 -------- d-----w- c:\programdata\Zylom
2012-09-12 16:59 . 2012-09-14 16:02 -------- d-----w- c:\programdata\Trymedia
2012-09-21 16:10 . 2012-04-19 22:07 73136 ----a-w- c:\windows\SysWow64\FlashPlayerCPLApp.cpl
2012-09-21 16:10 . 2012-04-19 22:07 696240 ----a-w- c:\windows\SysWow64\FlashPlayerApp.exe
2012-09-19 20:02 . 2010-07-07 15:49 64462936 ----a-w- c:\windows\system32\MRT.exe
2012-08-24 13:43 . 2012-08-24 13:43 384352 ----a-w- c:\windows\system32\drivers\avgtdia.sys
2012-07-26 01:21 . 2012-07-26 01:21 291680 ----a-w- c:\windows\system32\drivers\avgldx64.sys
2012-07-18 18:15 . 2012-08-27 22:52 3148800 ----a-w- c:\windows\system32\win32k.sys
2012-07-04 22:16 . 2012-08-27 22:52 73216 ----a-w- c:\windows\system32\netapi32.dll
2012-07-04 22:13 . 2012-08-27 22:52 59392 ----a-w- c:\windows\system32\browcli.dll
2012-07-04 22:13 . 2012-08-27 22:52 136704 ----a-w- c:\windows\system32\browser.dll
2012-07-04 21:14 . 2012-08-27 22:52 41984 ----a-w- c:\windows\SysWow64\browcli.dll
REGEDIT4
"swg"="c:\program files (x86)\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2012-04-18 39408]
"HP Photosmart 6510 series (NET)"="c:\program files\HP\HP Photosmart 6510 series\Bin\ScanToPCActivationApp.exe" [2011-09-16 2676584]
"CLMLServer"="c:\program files (x86)\CyberLink\Power2Go\CLMLSvc.exe" [2009-11-02 103720]
"NUSB3MON"="c:\program files (x86)\Renesas Electronics\USB 3.0 Host Controller Driver\Application\nusb3mon.exe" [2010-11-17 113288]
"IAStorIcon"="c:\program files (x86)\Intel\Intel® Rapid Storage Technology\IAStorIcon.exe" [2010-11-06 283160]
"Adobe ARM"="c:\program files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2012-01-03 843712]
"AVG_TRAY"="c:\program files (x86)\AVG\AVG2012\avgtray.exe" [2012-07-31 2596984]
"HP Software Update"="c:\program files (x86)\Hp\HP Software Update\HPWuSchd2.exe" [2011-03-24 49208]
c:\users\flokke\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\
Inktwaarschuwingen controleren - HP Photosmart 6510 series (netwerk).lnk - c:\windows\system32\RunDll32.exe [2009-7-14 45568]
"ConsentPromptBehaviorAdmin"= 5 (0x5)
[HKEY_LOCAL_MACHINE\software\wow6432node\microsoft\windows nt\currentversion\windows]
"LoadAppInit_DLLs"=1 (0x1)
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\session manager]
BootExecute REG_MULTI_SZ autocheck autochk *\0c:\progra~2\AVG\AVG2012\avgrsa.exe /sync /restart
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa]
Security Packages REG_MULTI_SZ kerberos msv1_0 schannel wdigest tspkg pku2u livessp
R1 A2DDA;A2 Direct Disk Access Support Driver;c:\users\flokke\AppData\Local\Temp\Rar$EXa0.736\Run\a2ddax64.sys [x]
R2 AVGIDSAgent;AVGIDSAgent;c:\program files (x86)\AVG\AVG2012\AVGIDSAgent.exe [2012-08-13 5167736]
R2 clr_optimization_v4.0.30319_64;Microsoft .NET Framework NGEN v4.0.30319_X64;c:\windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe [2010-03-18 138576]
R2 gupdate;Google Updateservice (gupdate);c:\program files (x86)\Google\Update\GoogleUpdate.exe [2012-04-18 136176]
R3 AdobeFlashPlayerUpdateSvc;Adobe Flash Player Update Service;c:\windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [2012-09-21 250288]
R3 e1cexpress;Intel® PRO/1000 PCI Express Network Connection Driver C;c:\windows\system32\DRIVERS\e1c62x64.sys [2010-12-17 315568]
R3 esgiguard;esgiguard;c:\program files\Enigma Software Group\SpyHunter\esgiguard.sys [x]
R3 gupdatem;Google Update-service (gupdatem);c:\program files (x86)\Google\Update\GoogleUpdate.exe [2012-04-18 136176]
R3 IAMTVE;Driver for Intel® Active Management Technology - KCS;c:\windows\system32\DRIVERS\IAMTVE.sys [2010-12-17 43416]
R3 IAMTXPE;Driver for Intel® Active Management Technology - KCS;c:\windows\system32\DRIVERS\IAMTXPE.sys [2010-12-17 51096]
R3 ioatdma1;ioatdma1;c:\windows\System32\Drivers\qd162x64.sys [2010-12-17 40144]
R3 ioatdma2;Intel® QuickData Technology device ver.2;c:\windows\System32\Drivers\qd262x64.sys [2010-12-17 42192]
R3 osppsvc;Office Software Protection Platform;c:\program files\Common Files\Microsoft Shared\OfficeSoftwareProtectionPlatform\OSPPSVC.EXE [2010-01-09 4925184]
R3 RTL8167;Realtek 8167 NT Driver;c:\windows\system32\DRIVERS\Rt64win7.sys [2010-05-31 333928]
R3 TsUsbFlt;TsUsbFlt;c:\windows\system32\drivers\tsusbflt.sys [2010-11-20 59392]
R3 WatAdminSvc;Windows Activation Technologies-service;c:\windows\system32\Wat\WatAdminSvc.exe [2010-11-10 1255736]
R3 WSDPrintDevice;WSD-ondersteuning voor afdrukken via UMB;c:\windows\system32\DRIVERS\WSDPrint.sys [2009-07-14 23040]
R4 wlcrasvc;Windows Live Mesh remote connections service;c:\program files\Windows Live\Mesh\wlcrasvc.exe [2010-09-23 57184]
S0 AVGIDSHA;AVGIDSHA;c:\windows\system32\DRIVERS\avgidsha.sys [2012-04-19 28480]
S0 Avgrkx64;AVG Anti-Rootkit Driver;c:\windows\system32\DRIVERS\avgrkx64.sys [2012-01-31 36944]
S1 Avgfwfd;AVG network filter service;c:\windows\system32\DRIVERS\avgfwd6a.sys [2011-05-22 48992]
S1 Avgldx64;AVG AVI Loader Driver;c:\windows\system32\DRIVERS\avgldx64.sys [2012-07-26 291680]
S1 Avgmfx64;AVG Mini-Filter Resident Anti-Virus Shield;c:\windows\system32\DRIVERS\avgmfx64.sys [2011-12-23 47696]
S1 Avgtdia;AVG TDI Driver;c:\windows\system32\DRIVERS\avgtdia.sys [2012-08-24 384352]
S1 vwififlt;Virtual WiFi Filter Driver;c:\windows\system32\DRIVERS\vwififlt.sys [2009-07-14 59904]
S2 AdobeARMservice;Adobe Acrobat Update Service;c:\program files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe [2012-04-03 63928]
S2 avgfws;AVG Firewall;c:\program files (x86)\AVG\AVG2012\avgfws.exe [2012-06-13 2321560]
S2 avgwd;AVG WatchDog;c:\program files (x86)\AVG\AVG2012\avgwdsvc.exe [2012-02-14 193288]
S2 cvhsvc;Client Virtualization Handler;c:\program files (x86)\Common Files\Microsoft Shared\Virtualization Handler\CVHSVC.EXE [2012-01-04 822624]
S2 IAStorDataMgrSvc;Intel® Rapid Storage Technology;c:\program files (x86)\Intel\Intel® Rapid Storage Technology\IAStorDataMgrSvc.exe [2010-11-06 13336]
S2 Intel® PROSet Monitoring Service;Intel® PROSet Monitoring Service;c:\windows\system32\IProsetMonitor.exe [2010-10-25 164008]
S2 NAUpdate;Nero Update;c:\program files (x86)\Nero\Update\NASvc.exe [2011-11-25 687400]
S2 ogmservice;Online Games Manager;c:\program files (x86)\Online Games Manager\ogmservice.exe [2012-06-08 521344]
S2 sftlist;Application Virtualization Client;c:\program files (x86)\Microsoft Application Virtualization Client\sftlist.exe [2011-10-01 508776]
S3 AVGIDSDriver;AVGIDSDriver;c:\windows\system32\DRIVERS\avgidsdrivera.sys [2011-12-23 124496]
S3 AVGIDSFilter;AVGIDSFilter;c:\windows\system32\DRIVERS\avgidsfiltera.sys [2011-12-23 29776]
S3 MEIx64;Intel® Management Engine Interface ;c:\windows\system32\DRIVERS\HECIx64.sys [2010-10-19 56344]
S3 nusb3hub;Renesas Electronics USB 3.0 Hub Driver;c:\windows\system32\DRIVERS\nusb3hub.sys [2010-11-19 80384]
S3 nusb3xhc;Renesas Electronics USB 3.0 Host Controller Driver;c:\windows\system32\DRIVERS\nusb3xhc.sys [2010-11-19 181248]
S3 NVHDA;Service for NVIDIA High Definition Audio Driver;c:\windows\system32\drivers\nvhda64v.sys [2010-09-07 155752]
S3 RTL8192su;Realtek RTL8192SU Wireless LAN 802.11n USB 2.0 Network Adapter;c:\windows\system32\DRIVERS\RTL8192su.sys [2010-11-25 694888]
S3 Sftfs;Sftfs;c:\windows\system32\DRIVERS\Sftfslh.sys [2011-10-01 764264]
S3 Sftplay;Sftplay;c:\windows\system32\DRIVERS\Sftplaylh.sys [2011-10-01 268648]
S3 Sftredir;Sftredir;c:\windows\system32\DRIVERS\Sftredirlh.sys [2011-10-01 25960]
S3 Sftvol;Sftvol;c:\windows\system32\DRIVERS\Sftvollh.sys [2011-10-01 22376]
S3 sftvsa;Application Virtualization Service Agent;c:\program files (x86)\Microsoft Application Virtualization Client\sftvsa.exe [2011-10-01 219496]
2012-09-30 c:\windows\Tasks\Adobe Flash Player Updater.job
- c:\windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [2012-04-19 16:10]
2012-09-30 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files (x86)\Google\Update\GoogleUpdate.exe [2012-04-18 19:02]
2012-09-30 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2012-09-30 c:\windows\Tasks\HP Photo Creations Messager.job
- c:\programdata\HP Photo Creations\MessageCheck.exe [2011-02-15 10:11]
--------- X64 Entries -----------
"RtHDVCpl"="c:\program files\Realtek\Audio\HDA\RAVCpl64.exe" [2010-12-09 11613288]
uStart Page = hxxp://www.google.be/
mLocal Page = c:\windows\SysWOW64\blank.htm
mSearch Page = hxxp://search.toggle.com/?lang=nl&q={searchTerms}
IE: Download with &Media Finder - c:\program files (x86)\Media Finder\hook.html
TCP: DhcpNameServer = 195.130.131.133 195.130.130.5
DPF: {BFF1950D-B1B4-4AE8-B842-B2CCF06D9A1B} - hxxp://game.zylom.com/activex/zylomgamesplayer.cab
Toolbar-10 - (no file)
Wow6432Node-HKLM-Run-<NO NAME> - (no file)
SafeBoot-BsScanner
AddRemove-Media Player - c:\program files (x86)\FLVPlayer\Uninstall\Uninstall.exe
[HKEY_USERS\.Default\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.htm\UserChoice]
@Denied: (2) (LocalSystem)
"Progid"="ChromeHTML"
[HKEY_USERS\.Default\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.html\UserChoice]
[HKEY_USERS\.Default\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.shtml\UserChoice]
[HKEY_USERS\.Default\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.xht\UserChoice]
[HKEY_USERS\.Default\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.xhtml\UserChoice]
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}]
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\Windows\\system32\\Macromed\\Flash\\FlashUtil64_11_4_402_278_ActiveX.exe,-101"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\Elevation]
"Enabled"=dword:00000001
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\LocalServer32]
@="c:\\Windows\\system32\\Macromed\\Flash\\FlashUtil64_11_4_402_278_ActiveX.exe"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\TypeLib]
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}]
@="IFlashBroker5"
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}\ProxyStubClsid32]
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}\TypeLib]
"Version"="1.0"
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}]
@="FlashBroker"
"LocalizedString"="@c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil32_11_4_402_278_ActiveX.exe,-101"
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\Elevation]
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\LocalServer32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil32_11_4_402_278_ActiveX.exe"
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\TypeLib]
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}]
@="Shockwave Flash Object"
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\InprocServer32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash32_11_4_402_278.ocx"
"ThreadingModel"="Apartment"
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\MiscStatus]
@="0"
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ProgID]
@="ShockwaveFlash.ShockwaveFlash.11"
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash32_11_4_402_278.ocx, 1"
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\TypeLib]
@="{D27CDB6B-AE6D-11cf-96B8-444553540000}"
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="ShockwaveFlash.ShockwaveFlash"
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}]
@="Macromedia Flash Factory Object"
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\InprocServer32]
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ProgID]
@="FlashFactory.FlashFactory.1"
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\TypeLib]
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="FlashFactory.FlashFactory"
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}]
@="IFlashBroker5"
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}\ProxyStubClsid32]
[HKEY_LOCAL_MACHINE\software\Classes\Wow6432Node\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}\TypeLib]
"Version"="1.0"
[HKEY_LOCAL_MACHINE\system\ControlSet002\Control\PCW\Security]
@Denied: (Full) (Everyone)
Voltooingstijd: 2012-09-30 20:32:49
ComboFix-quarantined-files.txt 2012-09-30 18:32
Pre-Run: 1.913.404.612.608 bytes beschikbaar
Post-Run: 1.913.060.720.640 bytes beschikbaar
- - End Of File - - 6517DB7A35D118EC143BAC6B5D91E226
Ik begrijp hier de 'ballen' van :cool:
aangepast door cloclo
:embarassed: Ik moet zeggen dat die de laatste twee dagen niet meer is opgedoken....volledig verdwenen dan?? Ziet het er voor de rest ok??
Mijn vraag was er inderdaad gekomen omdat ik - in alle logjes - geen enkel spoor van die RegCleanPro meer aantrof. En dat wordt nu bevestigd door je antwoord dat hij niet meer is opgedoken :-)
Voor de rest lijkt me alles inderdaad OK. Alleen moeten we dan nog wat opruimingswerken houden, zowel van de gebruikte tools als van de restjes van de besmettingen die gevonden zijn.
Verwijder Combofix: Start -> Uitvoeren/Zoekopdracht/Programma’s en bestanden zoeken en typ daar: ComboFix /Uninstall
HijackThis en RogueKiller mag je manueel verwijderen.
Download CCleaner.
Klik op “Download Latest Version” en dan start de download van CCleaner automatisch en gratis op.
Het is aangewezen om de bestaande herstelpunten te verwijderen (daar zitten besmette herstelpunten tussen die je eventueel zou kunnen terugzetten). In Windows 7
  • via Start -> Configuratiescherm -> Systeem & Beveiliging -> Systeem -> Systeembeveiliging -> schakel nu systeemherstel uit door de gewenste schijf te selecteren en op "configureren" te klikken.
  • Klik nu op "verwijderen" om alle herstelpunten te verwijderen.
  • Klik op "Toepassen" en "OK".
  • Herstart nu de PC.
Indien dit allemaal probleemloos verlopen is, mag je hieronder op "markeer als opgelost" tokkelen !
Beste,
herstelpunten gelukt denk ik, ccleaner gedaan, hijackt en roguekiller ok ,
combofix/uninstall vond ik niet terug, heb die dan via verwijderen hopelijk goed verwijderd?
C:\Qoobox vind ik terug maar krijg ik niet verwijderd, kan dit enkel als administrator maar weet nie hoe??:embarassed:
En daarna hopelijk opgelost....en nogmaals superbedankt:adore:
