IE is traag, ADDICT-THING Class
Doe nogmaals een scan met malwarebytes en herstart de pc na verwijdering van de gevonden items.
    • Adware: Verplaats
    • Dialers: Verplaats
    • Jokes: Rapportage
    • Riskware: Rapportage
    • Hacktools: Verplaats
  • Reacties 20
Gast peter-ramona
[TABLE=width: 256]
[TR]
[TD]adobe fotoshop cs6.exe[/TD]
[TD]E:\Data\Documents[/TD]
[TD]Adware.Downware.418[/TD]
[TD]Verwijderd.[/TD]
[/TR]
[TR]
[TD]DownloadSetup.exe[/TD]
[/TR]
[TR]
[TD]nmindexingservice.exe[/TD]
[TD]c:\program files\common files\ahead\lib[/TD]
[TD]Trojan.Click2.36316[/TD]
[/TR]
[TR]
[TD]rbmonitor.exe[/TD]
[TD]c:\program files\uniblue\registrybooster[/TD]
[TD]Program.Uniblue.4[/TD]
[/TR]
[TR]
[TD]background.html[/TD]
[TD]C:\Documents and Settings\All Users\ADDICT-THING[/TD]
[TD]Adware.Bho.3865[/TD]
[TD]Verplaatst.[/TD]
[/TR]
[TR]
[TD]runtime.dll[/TD]
[TD]C:\Documents and Settings\All Users\Application Data\TheBflixUpdater[/TD]
[TD=colspan: 2]Program.Unwanted.6[/TD]
[/TR]
[TR]
[TD]C:\Documents and Settings\All Users\TheBflixUpdater[/TD]
[/TR]
[TR]
[TD]background.html\JSTAG_1[81][1634][/TD]
[TD]C:\Documents and Settings\van Amerongen\AppData\Local\Application Data\Google\Chrome\User Data\Default\Extensions\dpgkoeinjnkgc[/TD]
[TD=colspan: 2]Adware.Siggen.24131[/TD]
[/TR]
[TR]
[TD]Container contains infected objects[/TD]
[/TR]
[TR]
[TD]background.js[/TD]
[TD]C:\Documents and Settings\van Amerongen\AppData\Local\Application Data\Google\Chrome\User Data\Default\Extensions\pmlghpafmmnmm[/TD]
[TD]Adware.Downware.430[/TD]
[/TR]
[TR]
[TD]ex.js[/TD]
[/TR]
[TR]
[TD]00DC1BF6.exe[/TD]
[TD]C:\Documents and Settings\van Amerongen\AppData\LocalLow\SoccerInfernoEI\Installr\Cache[/TD]
[TD]Tool.InstallToolbar.5[/TD]
[/TR]
[TR]
[TD]2e002d9c-5b747bf7\com/bitcoinplus/applet/MiningApplet.class[/TD]
[TD]C:\Documents and Settings\van Amerongen\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\28\2e002d9c-5b747bf7[/TD]
[TD=colspan: 2]Java.BitCoinMiner.1[/TD]
[/TR]
[TR]
[TD]2e002d9c-5b747bf7[/TD]
[TD]C:\Documents and Settings\van Amerongen\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\28[/TD]
[/TR]
[TR]
[TD]main.js[/TD]
[TD]C:\Documents and Settings\van Amerongen\AppData\Roaming\Mozilla\Firefox\Profiles\extensions\OneClickDownload@OneClickDownload.c[/TD]
[/TR]
[TR]
[TD]ub.exe[/TD]
[TD]C:\Documents and Settings\van Amerongen\AppData\Roaming\Uniblue\RegistryBooster\_temp[/TD]
[TD=colspan: 2]Program.Uniblue.7[/TD]
[/TR]
[TR]
[TD]ub.exe[/TD]
[TD]C:\Documents and Settings\van Amerongen\Application Data\Uniblue\RegistryBooster\_temp[/TD]
[/TR]
[TR]
[TD]C:\Documents and Settings\van Amerongen\DoctorWeb\Quarantine[/TD]
[/TR]
[TR]
[TD]C:\Documents and Settings\van Amerongen\DoctorWeb\Quarantine\2e002d9c-5b747bf7[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]backgroun0.html\JSTAG_1[81][1634][/TD]
[TD]C:\Documents and Settings\van Amerongen\DoctorWeb\Quarantine\backgroun0.html[/TD]
[/TR]
[TR]
[TD]backgroun0.html[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD]ex.js[/TD]
[/TR]
[TR]
[TD]main.js[/TD]
[/TR]
[TR]
[TD]Helper.dll[/TD]
[TD]C:\Program Files\iLivid[/TD]
[TD]Adware.Bandoo.5[/TD]
[/TR]
[TR]
[TD]BadPlugin.exe[/TD]
[TD]C:\Program Files\TuneUpMedia\xre[/TD]
[TD]Trojan.Click2.25892[/TD]
[/TR]
[TR]
[TD]Launcher.exe[/TD]
[TD]C:\Program Files\Uniblue\RegistryBooster[/TD]
[TD=colspan: 2]Program.Uniblue.5[/TD]
[/TR]
[TR]
[TD]rbnotifier.exe[/TD]
[TD=colspan: 2]Program.Uniblue.4[/TD]
[/TR]
[TR]
[TD]rb_move_serial.exe[/TD]
[/TR]
[TR]
[TD]rb_ubm.exe[/TD]
[/TR]
[TR]
[TD]registrybooster.exe[/TD]
[/TR]
[TR]
[TD]uninstall.exe[/TD]
[TD]C:\Program Files\Uninstall Information\ib_uninst_518[/TD]
[TD]Adware.Downware.428[/TD]
[/TR]
[TR]
[TD]C:\Program Files\Uninstall Information\ib_uninst_519[/TD]
[/TR]
[TR]
[TD]C:\Program Files\Uninstall Information\ib_uninst_532[/TD]
[/TR]
[TR]
[TD]C:\Program Files\Uninstall Information\ib_uninst_567[/TD]
[/TR]
[TR]
[TD]C:\ProgramData\TheBflixUpdater[/TD]
[/TR]
[TR]
[TD]C:\Users\All Users\TheBflixUpdater[/TD]
[/TR]
[TR]
[TD]ub.exe[/TD]
[TD]C:\Users\van Amerongen\AppData\Roaming\Uniblue\RegistryBooster\_temp[/TD]
[/TR]
[TR]
[TD]backup-20120930-194915-304.dll[/TD]
[TD]E:\Data\Downloads\backups[/TD]
[/TR]
[/TABLE]
Gast peter-ramona
Nee, de ADDICT THING, staat niet meer tussen de invoegtoepassingen.
Blijkbaar is er meer aan de hand, want IE is nog steeds heel traag.
Gast peter-ramona
Zonder invoegtoepassingen werkt IE wel....!
Gast peter-ramona
Het gekke is dat wanneer ik IE opstart vanuit Bureau-accessoires, Systeemwerkset, IE (zonder invoegtoepassingen); draait het goed. Doe ik handmatig in Invoegtoepassingen beheren alles uitschakelen, en ik IE normaal opstart is hij heel traag.
Kan dus ook niet zien waar de schoen wringt.
Download de Emsisoft Emergency Kit naar het bureaublad en pak het ZIP bestand uit.
  • Open de map "EmsisoftEmergencyKit" en dubbelklik op "Start.exe"
  • Klik nu op "Emergency Kit Scanner" u krijg nu een melding dat het is aanbevolen om eerst te updaten sta dit toe door te klikken op "Ja"
  • Als de update gereed is en de melding "Update process is succesvol afgerond" verschijnt klikt u op "menu" en dan op "Scan PC"
  • Selecteer de optie "Diep" als deze niet standaard al zo is ingesteld.
  • Klik Nu op de knop "Scan" en doe verder niets op de computer tijdens het scannen, deze scan kan een geruime tijd in beslag nemen dus wacht dit geduldig af.
  • Het venster met de waarschuwing over een verhoogd risico kunt u sluiten als de scan gereed is.
  • Zorg ervoor dat alle gevonden items zijn aangevinkt en druk dan op de knop "verwijder geselecteerde" u zal nu de volgende melding krijgen maar klik hier op "Ja"
  • Als het verwijderen gereed is klikt u op de knop "View report" en selecteert u het tekstbestand van deze scan met de naam zoals: a2scan_110730-111615.txt
  • Plaats de inhoud van dit LOG bestand straks in uw volgende bericht.
  • Herstart nu de computer.
Gast peter-ramona
Beste kape,
sinds gister werkt IE weer!!
is het nog verstandig om Emsisoft Emergency Kit zijn werk te laten doen, of zal ik het zo laten?
groeten,
Peter
