Vrijwel alle hardware vervangen, nog steeds errors.
Twocats
  • Reacties 26
Hier een nieuwe batch errors. Hopelijk zijn ze nuttig.
System Information (local)
computer name: HALEWIJN-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: AuthenticAMD AMD Phenom II X4 980 Processor AMD586, level: 16
4 logical processors, active mask: 15
RAM: 4294103040 total
VM: 2147352576, free: 1969283072
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sat 3-11-2012 18:33:48 GMT your computer crashed
crash dump file: C:\Windows\Minidump\110312-15834-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7EFC0)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF8000317AC2C, 0xFFFFF88004632F60, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Sat 3-11-2012 18:30:05 GMT your computer crashed
crash dump file: C:\Windows\Minidump\110312-17908-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80002E8E284, 0xFFFFF88008861F20, 0x0)
On Thu 1-11-2012 23:27:56 GMT your computer crashed
crash dump file: C:\Windows\Minidump\110212-25318-01.dmp
This was probably caused by the following module: unknown_module_00000000`00000001.sys (Unloaded_Unknown_Module_00000000`00000001+0x9)
Bugcheck code: 0xA (0xFFFFF88002FD2130, 0x2, 0x1, 0xFFFFF80002EE5733)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: unknown_module_00000000`00000001.sys .
Google query: unknown_module_00000000`00000001.sys IRQL_NOT_LESS_OR_EQUAL
