  • Reacties 48
voor nieuwjaar heb ik wel een domme fout gedaan :embarassed: heb IE10 willen installeren hehe, ik had het er terug afgehaald maar speccy vind er toch nog iets van:
17/12/2012 Cumulative Security Update for Internet Explorer 10 Release Preview for Windows 7 for x64-based Systems (KB2761465)
Security issues have been identified that could allow an attacker
to compromise a system that is running Microsoft Internet Explorer
and gain control over it. You can help protect your system by
installing this update from Microsoft. After you install this
item, you may have to restart your computer.
lijkt me dat vanaf dan ongeveer de problemen zijn begonnen... kan het er iets mee te maken hebben?
Dat is een beveiliging update voor alle browser.
Ik zou dit eens doen:
Tip!
Scan saved at 9:18:38, on 15/01/2013
MSIE: Internet Explorer v9.00 (9.00.8112.16457)
C:\Program Files (x86)\ASUS\ASUS Instant On\AsInstantOn.exe
C:\Program Files (x86)\ASUS\AI Suite II\AsRoutineController.exe
C:\Program Files (x86)\ASUS\AI Suite II\EPU\EPUHelp.exe
C:\Program Files\BullGuard Ltd\BullGuard\files32\spamfilter\LittleHook.exe
C:\Program Files (x86)\Nokia\Nokia Suite\NokiaSuite.exe
C:\Program Files (x86)\ASUS\AI Manager\AsShellApplication.exe
C:\Program Files (x86)\InstallShield Installation Information\{E6931688-DA2B-4E16-8539-3D323D69C677}\AiChargerPlus.exe
C:\Program Files (x86)\ASUS\ASUS Easy Update\ALU.exe
C:\Program Files (x86)\HP\HP Software Update\hpwuschd2.exe
C:\Program Files (x86)\HP\Digital Imaging\bin\hpqtra08.exe
C:\Program Files (x86)\Bamboo Dock\BambooCore.exe
C:\Program Files (x86)\Gizmo\gizmo.exe
C:\Program Files (x86)\Bamboo Dock\Bamboo Dock\Bamboo Dock.exe
C:\Program Files (x86)\HP\Digital Imaging\bin\hpqSTE08.exe
C:\Program Files (x86)\HP\Digital Imaging\bin\hpqbam08.exe
C:\Program Files (x86)\HP\Digital Imaging\bin\hpqgpc01.exe
C:\Program Files (x86)\Common Files\HP\Digital Imaging\Bin\hpqPhotoCrm.exe
C:\Program Files (x86)\PC Connectivity Solution\Transports\NclMSBTSrvEx.exe
C:\windows\SysWOW64\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.exe
O2 - BHO: HP Print Enhancer - {0347C33E-8762-4905-BF09-768834316C61} - C:\Program Files (x86)\HP\Digital Imaging\Smart Web Printing\hpswp_printenhancer.dll
O2 - BHO: BitComet ClickCapture - {39F7E362-828A-4B5A-BCAF-5B79BFDFEA60} - C:\Program Files (x86)\BitComet\tools\BitCometBHO_1.5.4.11.dll
O2 - BHO: Windows Live ID Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Logitech Flow Scroll - {E11DB59D-5008-42ff-9069-535843BC0BE1} - C:\Program Files\Logitech\FlowScroll\32-bit\LogiSmooth.dll
O2 - BHO: HP Smart BHO Class - {FFFFFFFF-CF4E-4F2B-BDC2-0E72E116A856} - C:\Program Files (x86)\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll
O4 - HKLM\..\Run: [RunAIShell] C:\Program Files (x86)\ASUS\AI Manager\AsShellApplication.exe
O4 - HKLM\..\Run: [ASUS AiChargerPlus Execute] C:\Program Files (x86)\InstallShield Installation Information\{E6931688-DA2B-4E16-8539-3D323D69C677}\AiChargerPlus.exe
O4 - HKLM\..\Run: [ASUS Easy Update] C:\Program Files (x86)\ASUS\ASUS Easy Update\ALU.exe
O4 - HKLM\..\Run: [ASUSWebStorage] C:\Program Files (x86)\ASUS\ASUS WebStorage\3.0.104.216\AsusWSPanel.exe /S
O4 - HKLM\..\Run: [hpqSRMon] C:\Program Files (x86)\HP\Digital Imaging\bin\hpqSRMon.exe
O4 - HKLM\..\Run: [HP Software Update] C:\Program Files (x86)\HP\HP Software Update\HPWuSchd2.exe
O4 - HKLM\..\Run: [bambooCore] C:\Program Files (x86)\Bamboo Dock\BambooCore.exe
O4 - HKCU\..\Run: [NokiaSuite.exe] C:\Program Files (x86)\Nokia\Nokia Suite\NokiaSuite.exe -tray
O4 - HKCU\..\Run: [GizmoDriveDelegate] "C:\Program Files (x86)\Gizmo\gizmo.exe" /RemountStartupImages
O4 - Startup: Gizmo.lnk = C:\Program Files (x86)\Gizmo\gizmo.exe
O4 - Global Startup: AsusVibeLauncher.lnk = C:\Program Files (x86)\ASUS\AsusVibe\AsusVibeLauncher.exe
O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files (x86)\HP\Digital Imaging\bin\hpqtra08.exe
O8 - Extra context menu item: &D&ownload &met BitComet - res://C:\Program Files (x86)\BitComet\BitComet.exe/AddLink.htm
O8 - Extra context menu item: &D&ownload alles met BitComet - res://C:\Program Files (x86)\BitComet\BitComet.exe/AddAllLink.htm
O8 - Extra context menu item: Free YouTube Download - C:\Users\Mindy\AppData\Roaming\DVDVideoSoftIEHelpers\freeytvdownloader.htm
O9 - Extra button: Report to BullGuard - {27FD17FB-CF63-486b-B2BE-8D8781CBEA01} - c:\program files\bullguard ltd\bullguard\Files32\Antiphishing\IE\BGAntiphishingIE.dll
O9 - Extra button: Toon of verberg HP Smart Web Printing - {DDE87865-83C5-48c4-8357-2F5B1AA84522} - C:\Program Files (x86)\HP\Digital Imaging\Smart Web Printing\hpswp_BHO.dll
O16 - DPF: {0D41B8C5-2599-4893-8183-00195EC8D5F9} (asusTek_sysctrl Class) - http://support.asus.com/select/asusTek_sys_ctrl3.cab
O20 - AppInit_DLLs: c:\PROGRA~1\BULLGU~1\BULLGU~1\Files32\BgAgent.dll BgGamingMonitor.dll
O23 - Service: Adobe Flash Player Update Service (AdobeFlashPlayerUpdateSvc) - Adobe Systems Incorporated - C:\windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\windows\System32\alg.exe (file missing)
O23 - Service: ASUS Com Service (asComSvc) - Unknown owner - C:\Program Files (x86)\ASUS\AXSP\1.00.18\atkexComSvc.exe
O23 - Service: ASUS HM Com Service (asHmComSvc) - ASUSTeK Computer Inc. - C:\Program Files (x86)\ASUS\AAHM\1.00.16\aaHMSvc.exe
O23 - Service: ASUS System Control Service (AsSysCtrlService) - Unknown owner - C:\Program Files (x86)\ASUS\AsSysCtrlService\1.00.11\AsSysCtrlService.exe
O23 - Service: AsusFanControlService - ASUSTeK Computer Inc. - C:\Program Files (x86)\ASUS\AsusFanControlService\1.00.06\AsusFanControlService.exe
O23 - Service: BitComet Disk Boost Service (BITCOMET_HELPER_SERVICE) - www.BitComet.com - C:\Program Files (x86)\BitComet\tools\BitCometService.exe
O23 - Service: BullGuard Behavioural Detection (BsBhvScan) - BullGuard Ltd. - C:\Program Files\BullGuard Ltd\BullGuard\BullGuardBhvScanner.exe
O23 - Service: BullGuard scanning service (BsScanner) - BullGuard Ltd. - C:\Program Files\BullGuard Ltd\BullGuard\BullGuardScanner.exe
O23 - Service: BullGuard update service (BsUpdate) - BullGuard Ltd. - C:\Program Files\BullGuard Ltd\BullGuard\BullGuardUpdate.exe
O23 - Service: Device Handle Service - ASUSTeK Computer Inc. - C:\Windows\SysWOW64\AsHookDevice.exe
O23 - Service: @%SystemRoot%\system32\efssvc.dll,-100 (EFS) - Unknown owner - C:\windows\System32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\fxsresm.dll,-118 (Fax) - Unknown owner - C:\windows\system32\fxssvc.exe (file missing)
O23 - Service: Gizmo Central - Arainia Solutions - C:\Program Files (x86)\Gizmo\gservice.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files (x86)\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: Intel® Capability Licensing Service Interface - Intel® Corporation - C:\Program Files\Intel\iCLS Client\HeciServer.exe
O23 - Service: Intel® Dynamic Application Loader Host Interface Service (jhi_service) - Intel Corporation - C:\Program Files (x86)\Intel\Intel® Management Engine Components\DAL\jhi_service.exe
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\windows\system32\lsass.exe (file missing)
O23 - Service: Logitech Bluetooth Service (LBTServ) - Logitech, Inc. - C:\Program Files\Common Files\LogiShrd\Bluetooth\lbtserv.exe
O23 - Service: MBAMScheduler - Malwarebytes Corporation - C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbamscheduler.exe
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\windows\System32\msdtc.exe (file missing)
O23 - Service: Nero BackItUp Scheduler 4.0 - Nero AG - C:\Program Files (x86)\Common Files\Nero\Nero BackItUp 4\NBService.exe
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\windows\system32\lsass.exe (file missing)
O23 - Service: NVIDIA Display Driver Service (nvsvc) - Unknown owner - C:\windows\system32\nvvsvc.exe (file missing)
O23 - Service: NVIDIA Update Service Daemon (nvUpdatusService) - NVIDIA Corporation - C:\Program Files (x86)\NVIDIA Corporation\NVIDIA Update Core\daemonu.exe
O23 - Service: @%systemroot%\system32\psbase.dll,-300 (ProtectedStorage) - Unknown owner - C:\windows\system32\lsass.exe (file missing)
O23 - Service: Protexis Licensing V2 x64 (PSI_SVC_2_x64) - arvato digital services llc - c:\Program Files\Common Files\Protexis\License Service\PsiService_2.exe
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\windows\system32\locator.exe (file missing)
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\windows\system32\lsass.exe (file missing)
O23 - Service: ServiceLayer - Nokia - C:\Program Files (x86)\PC Connectivity Solution\ServiceLayer.exe
O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\windows\System32\snmptrap.exe (file missing)
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\windows\System32\spoolsv.exe (file missing)
O23 - Service: @%SystemRoot%\system32\sppsvc.exe,-101 (sppsvc) - Unknown owner - C:\windows\system32\sppsvc.exe (file missing)
O23 - Service: NVIDIA Stereoscopic 3D Driver Service (Stereo Service) - NVIDIA Corporation - C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvSCPAPISvr.exe
O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\windows\system32\UI0Detect.exe (file missing)
O23 - Service: Intel® Management and Security Application User Notification Service (UNS) - Intel Corporation - C:\Program Files (x86)\Intel\Intel® Management Engine Components\UNS\UNS.exe
O23 - Service: @%SystemRoot%\system32\vaultsvc.dll,-1003 (VaultSvc) - Unknown owner - C:\windows\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\windows\System32\vds.exe (file missing)
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\windows\system32\vssvc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\Wat\WatUX.exe,-601 (WatAdminSvc) - Unknown owner - C:\windows\system32\Wat\WatAdminSvc.exe (file missing)
O23 - Service: @%systemroot%\system32\wbengine.exe,-104 (wbengine) - Unknown owner - C:\windows\system32\wbengine.exe (file missing)
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\windows\system32\wbem\WmiApSrv.exe (file missing)
O23 - Service: Wacom Consumer Service (WTabletServiceCon) - Wacom Technology, Corp. - C:\Program Files\Tablet\Pen\WTabletServiceCon.exe
End of file - 14479 bytes
Niets abnormaal te zien in dit logje.
Bij de installatie van MBAM wordt er gevraagd of je de "evaluatieversie" wil gebruiken...
Op deze vraag dien je te antwoorden met "afwijzen".
Indien MBAM moeilijkheden heeft met het verwijderen van bepaalde bestanden zal het enkele meldingen geven waar je OK moet klikken.
Daarna zal het vragen om de computer opnieuw op te starten... Dus sta toe dat MBAM de computer opnieuw opstart.
Plak de inhoud van het logje in je volgende bericht.
