Dat is inderdaad schijfopties. Hier had ik al gekeken, maar niets kunnen vinden. Volgens mij blijft hij lopen bij het controleren van de schijf:
[b]Volume 'FILMS' controleren[/b][font=Lucida Grande]Bestandssysteem controlerenntfsck 3011.12.9-mac[/font]
[font=Lucida Grande]Checking NTFS Superblock ...[/font]
[font=Lucida Grande]Device name        : /dev/disk1s1[/font]
[font=Lucida Grande]NTFS volume version: 3.1[/font]
[font=Lucida Grande]Cluster size       : 4096 bytes[/font]
[font=Lucida Grande]Current volume size: 80026358272 bytes (80027 MB)[/font]
[font=Lucida Grande]Syncing device ...[/font]
[font=Helvetica]
Bij schijf herstel kwam dit naar voren:
[/font]
[font=Lucida Grande][b]Volume 'FILMS' controleren en herstellen[/b][/font]
[font=Lucida Grande]Current device size: 80026360832 bytes (80027 MB)[/font]
[font=Lucida Grande]Checking for bad sectors ...[/font]
[font=Lucida Grande]Scanning $MFT ...[/font]
[font=Lucida Grande]ntfs_attr_pread_i: ntfs_pread failed: Input/output error[/font]
[font=Lucida Grande]read_mft_data: couldn't read file: Input/output error[/font]
[font=Lucida Grande]Failed to read of MFT, mft=103 count=1 br=-1: Input/output error[/font]
[font=Lucida Grande]Could not read "COMAPP~1.DON".[/font]
[font=Lucida Grande]Checking directory structure ...[/font]
[font=Lucida Grande]Corrupt directory found, inode=5 (0x5)[/font]
[font=Lucida Grande]Repairing corrupt directories started.[/font]
[font=Lucida Grande]  0.00 percent completed[/font]
[font=Lucida Grande] 33.67 percent completed[/font]
[font=Lucida Grande]Failed to read of MFT, mft=100 count=1 br=-1: Input/output error[/font]
[font=Lucida Grande]Failed to read of MFT, mft=101 count=1 br=-1: Input/output error[/font]
[font=Lucida Grande]Failed to read of MFT, mft=102 count=1 br=-1: Input/output error[/font]
[font=Lucida Grande] 67.34 percent completed[/font]
[font=Lucida Grande]100.00 percent completed[/font]
[font=Lucida Grande]Could not read "Store-V1".[/font]
[font=Lucida Grande]Repairing corrupt directories completed.[/font]
[font=Lucida Grande]Corrupt directory found, inode=23 (0x17)[/font]
[font=Lucida Grande]Checking for orphaned files ...[/font]
[font=Lucida Grande]Deleting orphaned inode 100 (0x64)[/font]
[font=Lucida Grande]Could not delete orphaned inode 100 (0x64)[/font]
[font=Lucida Grande]Deleting orphaned inode 101 (0x65)[/font]
[font=Lucida Grande]Could not delete orphaned inode 101 (0x65)[/font]
[font=Lucida Grande]Deleting orphaned inode 102 (0x66)[/font]
[font=Lucida Grande]Could not delete orphaned inode 102 (0x66)[/font]
[font=Lucida Grande]Deleting orphaned inode 103 (0x67)[/font]
[font=Lucida Grande]Could not delete orphaned inode 103 (0x67)[/font]
[font=Lucida Grande]Adding inode 179 (0xb3) to directory 289 (0x121)[/font]
[font=Lucida Grande]Scanning orphaned files completed.[/font]
[font=Lucida Grande]Checking cluster allocation ...[/font]
[font=Lucida Grande]Checking cluster allocation bitmap ...[/font]
[font=Lucida Grande]Cluster accounting failed at 5865472 - 7927178 (0x598000 - 0x78f58a): missing cluster in $Bitmap[/font]
[font=Lucida Grande]Totally 2061707 cluster accounting mismatches.[/font]
[font=Lucida Grande]Checking $MFT bitmap ...[/font]
[font=Lucida Grande]Fixing $MFT bitmap[/font]
[font=Lucida Grande]Fixed $MFT bitmap[/font]
[font=Lucida Grande]Space in use       : 66401 MB (83.0%)[/font]
[font=Lucida Grande]Done NTFS checking and repair on device '/dev/disk1s1'.[/font]
[font=Helvetica][font=Lucida Grande]Herstel volume voltooid.Opstartondersteuningspartities voor het volume waar nodig bijwerken.[/font]
[/font]
  • Reacties 21
Oeps.
Daar komt nogal wat boven water.
De reparatie lijkt geslaagd, althans hij geeft geen foutmeldingen weer bij het repareren. Zijn de problemen nu opgelost?
BTW, ik zie een NTFS-partitie. Op een Mac?
Nee... Nog steeds werkt hij niet. En ik weet niet wat een NTFS-partities is... De externe harde schijf heb ik wel uit een windows laptop gehaald.
@ Mmaarten,
De externe harde schijf heb ik uit een laptop gehaald en zo laten maken dat ik hem op mijn mac kon gebruiken. Hij heeft het dan ook een paar maanden gewoon gedaan.
Hoe is die externe harde schijf geschikt gemaakt?
Externe harde schijf formatteren voor Mac & Windows:
Mac leest en schrijft HFS+ & Windows leest en schrijft NTFS.
ExFat [geschikt voor grote bestanden > 4GB] is het nieuwste FAT [< 4GB] formaat, formatteer je een externe harde schijf in Fat of ExFat dan kan je met Mac en met Windows de externe harde schijf lezen en bewerken.
Een externe harde schijf geformatteerd met NTFS formaat, dan kan je die externe harde schijf bewerken en lezen in Windows, en Mac kan die alleen maar lezen.
Op de harde schijf staan alleen films en series.
Is het mogelijk om die films en series ergens te kopiëren, dan kan je de externe harde schijf op nieuw formateren in ExFat formaat.
Dank je voor je toelichting, iEscape, je was me net voor.
xD
Ik wilde je ook aanraden om de schijf opnieuw te formateren, maar dan naar HFS+ omdat dit het 'native'-Mac-bestandssysteem is.
En ook omdat dit bestandsysteem dezelfde 'features' heeft als Unix 's ext*;
M.a.w. het is in staat om van zichzelf beschadigde sectoren/bestanden te repareren.
Maar misschien is het formateren naar ExFat wel verstandiger, zoals iEscape al vertelde.
Meer info over Mac 's bestandssysteem:
Mac OS X File Systems
aangepast door Chato
Bedankt beide!! Ik heb alles op mijn Windows PC gezet en de externe harde schijf geformatteerd op mijn mac naar ExFat. En alles lijkt het hier weer te doen! Alleen niet op mijn Windows PC... Daar geeft hij aan: "Schijf is niet geformatteerd, wil je hem formatteren?" Als ik op ja druk, en alle gegevens goed invul komt er uiteindelijk de fout: "kan formatteren niet voltooien". Op mijn mac werkt hij dus, maar op mijn windows niet.
Wat heb ik fout gedaan?
Windows kan alleen bestandssystemen lezen die van Windows zelf zijn (NTFS bijvoorbeeld).
Andere besturingssystemen dan Windows zijn niet zo strikt en kunnen ook bestandssystemen van anderen lezen.
Linux (en, AFAIK) Mac kunnen dus wel overweg met Windows' NTFS.
Jij hebt niets fout gedaan, maar Windows is niet zo flexibel.
Je zal bestandsformaat bedoelen. Windows herkent ook het ExFat formaat, maar dan enkel USB sticks en geheugenkaarten die in Exfat geformateerd zijn. (externe) harde schijven die in Exfat geformateerd zijn, worden door Windows niet herkend.
@ Mmaarten,
Ik heb een externe harde schijf geformatteerd in ExFat formaat.
Windows en Mac herkennen die externe harde schijf.
De enige melding van Windows is: er is geen stuurprogramma geïnstalleerd.
Gewoon negeren.
En van Windows en van Mac kan ik bestanden, documenten, video's etc. bewerken en lezen en bestanden opzetten / verwijderen.
Wat gebeurt er als je op NEE druk?
Wat ik me afvraag is: hoe die ex-laptop-schijf geschikt is gemaakt?
In een behuizing gelaatst met usb aansluiting en voorzien van een eigen voeding?
Shit. Dit is nou juist precies wat ik wil (En hoe mijne xterne harde schijf ook werkte)
Als ik op Nee druk, kan ik die harde schijf alsnog niet openen. Als ik dat dan weer probeer geeft hij dezeflde melding.
Ik heb die ex-laptop harde schijf idd uit mijn laptop gehaald en in een behuizing gestopt met een USB aansluiting. That's it.
!!OPGELOST!!
Wat ik nu gedaan heb, is die externe harde schijf op mijn Mac aangeloten en via 'schijfhulpprogramma' deze harde schijf geselecteerd en voor structuur gekozen voor NTFS gekozen. Nu kan ik er zowel bestanden opzetten via mijn mac als via mijn PC. Snap niet hoe dit kan, aangezien "Mac leest en schrijft HFS+ & Windows leest en schrijft NTFS". Maar mij hoor je niet klagen.
In ieder geval allemaal enorm bedankt voor jullie hulp! Jullie hebben mij weer gelukkig gemaakt ;)!
