  • Reacties 23
  [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Windows];r64
 "AppInit_DLLs"=-;r64
 C:\Windows\tasks\AutoKMS.job;f
 C:\Windows\tasks\AutoKMSDaily.job;f
 C:\Windows\SysNative\tasks\AutoKMS;fs
 C:\Windows\SysNative\tasks\AutoKMSDaily;fs
  • Post het geopende logje in het volgende bericht.
Zoek.exe Version 4.0.0.5 Updated 09-November-2013
Tool run by Jan on do 14/11/2013 at 12:45:59,35.
Microsoft Windows 7 Home Premium 6.1.7601 Service Pack 1 x64
Launched: C:\Users\Jan\Desktop\zoek.exe [script inserted]
==== Older Logs ======================
C:\zoek-results2013-11-04-184047.log 41247 bytes
==== Registry Fix Code x64 ======================
Windows Registry Editor Version 5.00
"AppInit_DLLs"=-
C:\Windows\SysNative\tasks\AutoKMS deleted
C:\Windows\SysNative\tasks\AutoKMSDaily deleted
"C:\Windows\tasks\AutoKMS.job" deleted
"C:\Windows\tasks\AutoKMSDaily.job" deleted
==== EOF on do 14/11/2013 at 12:46:54,42 ======================
    • Adware: Verplaats
    • Dialers: Verplaats
    • Jokes: Rapportage
    • Riskware: Rapportage
    • Hacktools: Verplaats
    [*]Gevonden bestanden worden naar '%USERPROFILE%\\DocterWeb\\Quarantine' -map verplaatst indien het herstellen niet mogelijk is.
Als ik op F9 druk gebeurt er niets??
Dit is de log van de express scan (vage links zijn er nog):
Dr.Web Scanner SE for Windows v8.2.0.07100
(c) Doctor Web, Ltd., 1992-2013
Scan session started 2013/11/18 11:35:55
Module location : C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\
OPTION [Automatic Apply Actions] NO
OPTION [Turn Off Computer After Scan] NO
OPTION [Use Sound Alerts] NO
OPTION [Block Network] NO
OPTION [Protect Process] NO
OPTION [Protect Raw Disk] NO
Using language: "English"
Available instances: 12
Instances used: 12
Platform: Windows 7 Premium x64/WOW (Build 7601), Service Pack 1
API Version: 2.2
Scanning Engine version: 8.1.0.7100
Virus Finding Engine version: 7.0.5.6250
Total 147 virus bases are loaded from C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8
v4j5eze1 7.0 868ea1ad2980c4cf10131b42bc1554dfd699d347 2013/11/18 08:50:41 526 records - OK
ygux6bbh 7.0 d07fc5cc240588c772457e7df580f3cec20d9222 2011/07/25 16:20:03 2 records - OK
oqwg4a9e 7.0 955b0c6f1bf687c6db51378f2044bf9d2837c0e1 2013/11/18 04:11:33 1 record - OK
2bt1qxns 7.0 8e677cc8b19dc0ad82c4b71202c0acd9e2e25827 2013/11/18 04:08:42 32245 records - OK
uu5jqjkc 7.0 bc2662842e39ed5dc010a39140fd82d7ad1b6006 2013/11/11 04:09:43 33084 records - OK
ozaf29oh 7.0 8900859cec3affe1e5bbb086bdb2299d125acf7c 2013/11/04 04:09:28 30356 records - OK
m6dg9zlu 7.0 0e9ca4f15f289ae826d213e6a1d672470a127b51 2013/10/28 04:09:43 18457 records - OK
kfxb9b1h 7.0 eba0efa3e9d70063908fb5e41a704579c255ea33 2013/10/21 05:09:49 19594 records - OK
47mj5ezr 7.0 0f5e49d3e5b4c931d1f2de5e7b3551b3290cae26 2013/10/14 05:07:20 22924 records - OK
59bqq06a 7.0 11c09a3ae7c80058711dd699aeb1ca4f5ba0f5a5 2013/10/07 05:07:56 24694 records - OK
eud3g03p 7.0 27f46d939a14e1a0605b9762db1de5a2aca20a58 2013/09/30 05:08:23 24253 records - OK
gia9f7yc 7.0 e679853ff1af1082b1982cf226785128a26e1099 2013/09/23 05:07:56 18453 records - OK
9bew6ay2 7.0 690d8b937e4edb8176c3d466585662a6014e3d0e 2013/09/16 05:08:41 19662 records - OK
r7f48618 7.0 cf5d32d1091e0c33523e8c6f9697c32ef2bf4f29 2013/09/09 05:07:53 11289 records - OK
6o2dodve 7.0 8f8258337f82d1dd4434e9b71f2e481f06baf7c2 2013/09/02 05:08:50 16486 records - OK
t1vi7kde 7.0 f806ed4628669b46da54d1f2eb12aa9bcef603a6 2013/08/26 05:08:46 18051 records - OK
fouy57ig 7.0 b453f2d6f8659d9dd5b9aa92f2a4cfa16cbfa1db 2013/08/19 05:07:38 30970 records - OK
vujqj4y2 7.0 99da1df207839fb44ae24c23590c827a78b79624 2013/08/12 05:07:21 36983 records - OK
1mlq3a6m 7.0 f00c8b50a0012e8c42c6739e1326d23df1894610 2013/08/05 05:06:47 34115 records - OK
vjkowfvd 7.0 896fcf8d5d0cd958da3891b65648d2dc1592338b 2013/07/29 05:07:44 19463 records - OK
17497lq5 7.0 d690513befab3ea86af2fe671a7f24cc05c9feaa 2013/07/22 05:08:15 35067 records - OK
jlvu2vjd 7.0 5d7d11b0edc97be077b0771339ba3dc0c75de9e0 2013/07/15 05:08:05 29822 records - OK
0lch1w3x 7.0 67683402b8212ef4da87f649878865c52e5dc113 2013/07/08 05:08:35 39172 records - OK
znt3e8ol 7.0 613a3e4bae38b4e00a7432c24a9cd916fb1c654f 2013/07/01 05:06:34 24654 records - OK
8mn8obww 7.0 b81132c4abffd4d2949531a1219b6bb1c3bad6f7 2013/06/24 05:06:30 14062 records - OK
wnwknlqw 7.0 9aab251475626c658b193cfa2b5f91da471bf8f2 2013/06/17 05:05:57 13350 records - OK
mmkypvyt 7.0 e1f8aca88745fcdd49dc7ae75e142c41e1faf178 2013/06/10 05:08:13 26371 records - OK
hxrwx872 7.0 4e8627555a073f6bad5218bad3e69ebc4b93069f 2013/06/03 05:07:47 25525 records - OK
kme42i93 7.0 f562371c5115143824efde38c9567c34ccbe5d1a 2013/05/27 05:16:19 33200 records - OK
khvl4vct 7.0 eccb30ec8ed44456f9b88fe96d9fe0de40e4fa51 2013/05/20 05:11:05 46384 records - OK
ws6um9bf 7.0 9b481fbfbe1f564a84f21552da1d30d24e7b01db 2013/05/13 05:07:01 34270 records - OK
tm4wdx0m 7.0 1bf754dd720727b5d6803e081c16ff7f4ba7b40b 2013/05/06 05:08:46 41611 records - OK
19geal5i 7.0 4e883c92513c2d991968fb3e4f27910a63d9a2df 2013/04/29 05:06:36 36105 records - OK
j81x2b97 7.0 b047d178295ecde53c3cf1c34e4361004569fa33 2013/04/22 05:07:26 31319 records - OK
gkqhcic9 7.0 9207e55a924e4aa989dfde4d8d219cf5cc200ce2 2013/04/15 05:07:56 28216 records - OK
g398s016 7.0 78855cfb9fbc063889c5405a577fe73188f08789 2013/04/08 05:05:35 23589 records - OK
85pp2jme 7.0 cec6d34c79d50608520e81b90a23d91f39df0b27 2013/04/01 05:07:37 26946 records - OK
es39ot1j 7.0 fd3c78d78ea4dae4e252a7f7d76db22e1a679be9 2013/03/25 04:05:37 34778 records - OK
lvmq4vjx 7.0 268e71b1123ab5e60fd2f38d269fe5f3d22b3697 2013/03/18 04:06:19 11271 records - OK
4nxhsepv 7.0 d196879775b0dc0ee8286f2e4def9adedb5b88df 2013/03/11 04:05:36 12046 records - OK
5eumhj1i 7.0 0db61d4e3235481da8493523538ced712db362c2 2013/03/04 04:05:18 21747 records - OK
7hlsbs2r 7.0 65f99faf227b51883c9f1c854a3f76806b60affb 2013/02/25 04:06:28 11540 records - OK
8gwa3lss 7.0 17bd7383b9c4b214c5c9029171db8ae1455984a0 2013/02/18 04:06:38 15568 records - OK
vcsqb3g1 7.0 cbe8774953ae403e49370d552b522a5839aa9fdb 2013/02/11 04:06:00 18805 records - OK
rnbla4fw 7.0 fb6865c02a3680338e4ee0603579107227313b2b 2013/02/04 04:06:01 32488 records - OK
psk1w021 7.0 95fcd2e24cd9b2ec2610656ffa70b8bf46e86a8b 2013/01/28 04:04:52 15470 records - OK
p3uy74tu 7.0 3d710b3dd4580a7eca8c74d2c886d48f5b8b5172 2013/01/21 04:06:27 30093 records - OK
i7mis6nw 7.0 bddde0b5426b7e5bebd61e1239ca529c87ae6e36 2013/01/14 04:04:41 16158 records - OK
h94i1x1z 7.0 bc40bd9330301e8d7796f489d03357fb711b3121 2013/01/07 04:04:45 19597 records - OK
of9w67qd 7.0 805b6089c867549c75f843eac96b759c3f8d101f 2012/12/31 04:05:41 18184 records - OK
z0v86t1d 7.0 c680da06ac6ec011d130e7ac765e33da89e2820a 2012/12/24 04:05:33 29945 records - OK
2u9e0uv5 7.0 33def496782eb5b7b1cc93fdb036a1b62fa6a2fd 2012/12/17 04:06:21 25519 records - OK
xrhqvwnc 7.0 422abae03c588822f412aa9aae50578a1d61737e 2012/12/10 04:05:04 20358 records - OK
q8ghzxp8 7.0 a4f0d0ecad4fb6e0afdb1925f4e0b7863b9d03fa 2012/12/03 04:06:19 20133 records - OK
jn3eu9b9 7.0 86daa918ee3de1e4c1e5dea6f9b5f63544cf8814 2012/11/26 04:05:22 27311 records - OK
mgqv6uvk 7.0 6556881c748e1f894eb9c7943ebae67017e1aec2 2012/11/19 04:06:09 29434 records - OK
6e2qbftp 7.0 559141ef34f9e6226bb58560e9b52e4cc5165150 2012/11/12 04:06:22 26900 records - OK
kf8758hl 7.0 cc55013e63ff89319ec772e34d77056c7108cd3b 2012/11/05 04:05:22 25164 records - OK
3swz6dzf 7.0 f477dc247d9b562bb64fd4f46a7dcbdf7124eb60 2012/10/29 04:06:37 30226 records - OK
y7xw1ra8 7.0 abaf5f7fda7308fcf7573b193bbf2116723e9802 2012/10/22 05:04:37 16441 records - OK
ccbz0qxq 7.0 5adc85528fb49e201d4bc61eca580d6839cc4a4c 2012/10/15 05:05:04 26289 records - OK
78qfaurd 7.0 da8cf3fbd81206bb3d8103347a439f920a74bbe2 2012/10/08 05:05:51 27278 records - OK
nod71e50 7.0 5988744d3cb357f1a013427d466e2d79ab5f8907 2012/10/01 05:05:11 17444 records - OK
weptlclg 7.0 d4a0dabf4a4df0f79805c6ccdc025f796765e786 2012/09/24 05:06:30 21205 records - OK
sty3t19f 7.0 82ed005784d9e258213070a0cd8bfceff345018d 2012/09/17 05:05:43 11686 records - OK
ic3pjl29 7.0 a95ae63004b8d857c2db055f4e47c15bfc97f626 2012/09/10 05:04:34 12677 records - OK
unc9f11j 7.0 c39bf233d25242ae9ed8cf204b9b788c8f45ab79 2012/09/03 05:05:28 10118 records - OK
4mtz3rb6 7.0 d37b5484b009947b7cdd3837dafe8148615401c2 2012/08/27 05:05:26 12602 records - OK
wzhuti7z 7.0 41bf1347794ab7060dec7aaecc1d1d95cf6fecb5 2012/08/20 05:04:05 18298 records - OK
bqmvflwd 7.0 1a997511e5892aaeb69b3db70e06676af36382e3 2012/08/13 05:05:19 17126 records - OK
3vklbjkz 7.0 f7226c59914e3683e538e668c3b664af3232654d 2012/08/06 05:03:53 20539 records - OK
j55rzecm 7.0 4035c8d3b617bf935a317a8c57efaa8e835a61f4 2012/07/30 05:05:26 19330 records - OK
yr4auuxs 7.0 09b55bc000f184ed426f1d8b9665669346fe5e71 2012/07/23 05:05:34 19692 records - OK
xnqdyc58 7.0 f746c097f298e94faa9db94e6f64ef9fd4a7b010 2012/07/16 05:05:43 14727 records - OK
rhrbiv6y 7.0 792a6a25a17e764390440cd4c2c6ca5a97ab162f 2012/07/09 05:04:33 19485 records - OK
bs9qh98d 7.0 ca9905c39e3d93428a4db65a192debe9fbd7acf7 2012/07/02 05:04:55 22898 records - OK
r1ehovtp 7.0 dc29c610b866c66ba5327e7830452b2460149a35 2012/06/25 05:05:17 20551 records - OK
g3n3yxqo 7.0 c28739bea153508d12942ac9a61abd475d0a0404 2012/06/18 05:03:35 9661 records - OK
yr5surx8 7.0 e5b5835a7c512120c5348e31483a4caa2a845d28 2012/06/11 05:04:32 23632 records - OK
1m2ssboz 7.0 61853ce89026ef0ebbd80174f1b7dd5d25bbc63a 2012/06/04 05:04:41 12423 records - OK
r2fnnj0c 7.0 4e6c9897e153b47ca97b7da48ceed23e555a7761 2012/05/28 05:04:26 15493 records - OK
4wt8e2u2 7.0 35f4c105cecd8ec1fd01714abebf30f8f3efb96e 2012/05/21 05:03:29 13065 records - OK
2htclfyx 7.0 3522aa84677411aa7d67796bb05ea3ab62f02a71 2012/05/14 05:04:24 16238 records - OK
aj7hnyq4 7.0 7597333540eda537bd42c0a17d4a6526ad247a2e 2012/05/07 05:04:33 11570 records - OK
t9e3aeb2 7.0 867814380363bc6ad605acf4b96e02c54dbd60f7 2012/04/30 05:03:28 15478 records - OK
au9qthrd 7.0 3c04f402d91a19039cb9c223c435dc4ea1bb3da4 2012/04/23 05:05:05 11881 records - OK
j8jfzfff 7.0 8d0220a2a50b367e61a51d3b29c2659cde41bb7f 2012/04/16 05:03:29 13578 records - OK
96yohfv6 7.0 b79dc6f5832ad390108d1880694ec538e8b34bb0 2012/04/09 05:05:02 14292 records - OK
f15bfkpf 7.0 8ff7cc095c43c2154275b7a54a89bf365e8daf4a 2012/04/02 05:03:24 14084 records - OK
b5rnrgrf 7.0 9502a428b32be4ad08556134e271c9ba03195398 2012/03/26 05:04:43 19126 records - OK
t06l261g 7.0 28c2fabbc645aff41baac12b911a8499ea163536 2012/03/19 04:03:23 14920 records - OK
o0ji0p0n 7.0 86de597ff06e58206f94263f2eef33cb41b2530c 2012/03/12 04:03:25 19017 records - OK
2ls4jox3 7.0 5bd1d666e7c9ca70c34e591dc6c55314ce4b11af 2012/03/05 04:04:32 19691 records - OK
79lxjcki 7.0 15a9d10c451d2fcf124700f29f557d9bf338e671 2012/02/27 04:03:21 23605 records - OK
wp2c33bo 7.0 5647d941e5358105ca6558dce78873f06c48d5dc 2012/02/20 04:03:45 19067 records - OK
7devl6to 7.0 c9b2600cb665ce34e0ccd0f19e0a88cd44437f51 2012/02/13 04:04:49 19019 records - OK
kozaxv8o 7.0 9df2e129e78a9d9ab491186da1329c1dd1190e17 2012/02/06 04:05:25 28028 records - OK
ft2kft7r 7.0 b69b9504a51b8777b8e95a4680dc8ac1d8d8c25d 2012/01/30 04:08:41 29444 records - OK
xtpeoy13 7.0 3d7431bdee1a22d6329e017f348db7760f2645ac 2012/01/23 09:22:13 19353 records - OK
ulf5ou8d 7.0 e04570f78fb00d758abdf77c534a460980e102c0 2012/01/16 04:12:31 20747 records - OK
dwq2uamx 7.0 2de2479b112c4416e2375343f57ca789b042aecc 2012/01/09 04:04:30 28052 records - OK
alht7v5t 7.0 c4bd9612ff1f71d8bd23b4f1bc114eed1ae2ee6b 2012/01/02 04:04:40 12183 records - OK
nsx85e16 7.0 28b1d218ade8f05fdc8550c7456ac3b74f705208 2011/12/26 04:03:33 19984 records - OK
g93rg8jc 7.0 539e41e8f3d97a6f347600c7cef903d9f34e0518 2011/12/19 04:08:45 22627 records - OK
89bp5ogl 7.0 f8e81968965f555bce0d02fc9933fee840b97aaf 2011/12/12 21:20:22 49580 records - OK
31hd3u9y 7.0 14751e0f442bba3efc08ee12d82a2815c61cfeb6 2011/12/04 09:00:00 45195 records - OK
e7c499cx 7.0 1a1e6cb9b3096a2cbba2c31d05e11914c0357d52 2011/12/04 08:00:00 165532 records - OK
tr5kqyd3 7.0 0f948a7d416c556bfc8a8be2c2c39f998fee6d9e 2011/12/04 07:00:00 170820 records - OK
jqhhpyyw 7.0 9357c3cc73a4a374346a678f197daa22496c7ae5 2011/12/04 06:00:00 171279 records - OK
l3xs27l0 7.0 ae56b06b3d6f1e13c5f10cce4ed68f2cccbf3298 2011/12/04 05:00:00 170253 records - OK
t56r391k 7.0 fdaab5c1079d02c94f20d07c39d638cad79d8771 2011/12/04 04:00:00 170291 records - OK
551w7aah 7.0 b59d8841e65d7670b2aae7f2b65734269f6c4fe3 2011/12/04 03:00:00 170501 records - OK
pjbog3x9 7.0 3946b1d195434cf7a70d144da71c87559475c58f 2011/12/04 02:00:00 353582 records - OK
lkmbhsep 7.0 8df4695f74ea5949551df6044720694e204b13d7 2011/12/04 01:00:00 852776 records - OK
u2ui1xpe 7.0 d06d362724b2e97b0179dcb20fac64ab050d93a4 2013/11/18 08:51:11 1576 records - OK
ahl84mdx 7.0 6ede5b37423910c2f3ffff6d90fef6a16e565e5e 2013/09/02 05:14:42 1327 records - OK
skpuw5v3 7.0 c1d53c2aef72dfab36a8045897938e7a31f279ac 2013/07/15 05:15:07 1590 records - OK
k4bzbsif 7.0 0cb77ee7a3e6545553585eb6df267a86d4fecbe4 2013/04/22 05:14:29 1680 records - OK
n8jji65i 7.0 6cb68b8fab821702ef054f864ff44917414e50fa 2013/02/04 04:13:43 2078 records - OK
10alna6x 7.0 cfbe9cf43615f7856e4c35f0fc02e2baf12e39e7 2012/12/17 04:14:14 1725 records - OK
du2sdowj 7.0 047694e79b1a8d295f27ea9c6565062404f84a57 2012/11/12 04:12:52 2050 records - OK
2pbls1lh 7.0 f3413603f4ee1c88018a78c1f6faf2abeb8fa8c1 2012/09/24 05:13:14 1456 records - OK
18r9txnt 7.0 8871f579eeb7e5e7b70c6dd898afd27391d7daf4 2012/06/25 05:12:36 1421 records - OK
v221tfhj 7.0 3ee43130fe7fec4b367a791892a444d0a791b29b 2012/03/26 05:12:30 1385 records - OK
5401f5b2 7.0 fddc5d687537580c7166dbf117d591593bc62261 2012/01/23 05:56:09 1653 records - OK
au16j9z2 7.0 b154106e75b9f9edbb6f88bdbcd054f97cc07760 2013/11/18 08:51:03 1271 records - OK
h3w8p2k1 7.0 4ed4e052d8cc2df4eb5f1916da50e16da9e4e3da 2013/10/21 05:25:47 2062 records - OK
48jhiui3 7.0 cc2fc58477a41d340f63e6d3d228133c927a9810 2013/09/16 05:25:22 3440 records - OK
3hab60y9 7.0 63ff62f7b5aa956912f6c29e7ad7be26569416ff 2013/08/19 05:25:05 1485 records - OK
okhukz8m 7.0 d95d1ab4adf9a869001802f64960356e903dd478 2013/07/22 05:24:06 2214 records - OK
n1eyhu7o 7.0 45cdfad530697916adbfea43a8763a4ab0c95beb 2013/05/20 05:24:48 1426 records - OK
6zqxovs3 7.0 bd9fd948b79e07c8676018e17a43ee81f5335e36 2013/04/22 05:24:10 1641 records - OK
wfmiwzyh 7.0 c7f70566b9bae9fd3f5a8d0b56d961f890a55508 2013/03/18 04:23:44 1742 records - OK
r0ixweti 7.0 8893c0d254eb40c78b5c78ea17fbc3be60ea6304 2013/01/21 04:24:33 2016 records - OK
ogde4qqc 7.0 cdf3a9d2dcab57f90c378d9eefacbfd358a42699 2012/12/10 04:23:23 1620 records - OK
f4geycli 7.0 c0726ba000e840272f0810b89051e6daa8799084 2012/11/05 04:23:16 1658 records - OK
44advobu 7.0 216611859de0125bf130d6324d43c9115cb05def 2012/10/08 05:23:20 1465 records - OK
1itlhcio 7.0 264c14ad60c4423ec292f5f8b182e4448504dfa9 2012/09/10 05:23:14 1588 records - OK
dyf5y1xk 7.0 33197bfe9efefa9db33725d240757103c625b601 2012/07/23 05:22:36 1702 records - OK
euknowxg 7.0 74d8e114edb84b95bc09d5a2a36191d15a61e2cb 2012/06/11 05:22:36 1659 records - OK
nkwsmg0n 7.0 79ca8239f310688d2b9c314fa3d738a34985cce3 2012/04/30 05:22:34 1670 records - OK
2rsa25qx 7.0 aac27e986e3731e5260cb76f5b14558e36660dec 2012/03/12 04:22:28 1729 records - OK
3aq9o98s 7.0 fa5c96b8be693a20c2a295e3545419e6f117fdc4 2012/01/30 04:23:00 1523 records - OK
kzd896ys 7.0 e9b21e0a3578ef2e2067f4876309671ddc78f65f 2011/12/19 04:22:29 1805 records - OK
gmzmdfka 7.0 8f7a8f6f55130f6becc5331ab38dc2108746b8aa 2011/12/04 00:00:00 26456 records - OK
3xgsw7rr 7.0 e6d52b11d2f7d405ccd31347da3b6fde69825168 2011/12/03 23:00:00 74279 records - OK
iwppk6g1 7.0 e20ffde4bbc58e0585b0b3b2f324bc91272c2360 2011/12/03 22:00:00 1 record - OK
Total records count: 4700852
Anti-rootkit module version ( ver: 8.6.201308190, api: 5.01/5.01 )
Using C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\zarjs90i.key as Dr.Web (R) Key file
This Dr.Web (R) Key is for 1 computer (A User)
Start scanning
Command line used:-rpcep:\pipe\427846D43 -rpcpr:np
Object(s) to scan:
- Scan processes in memory
- Scan boot sectors
- Scanning for rootkits
- C:\autoexec.bat
- C:\bootmgr
- C:\hiberfil.sys
- C:\pagefile.sys
- C:\Recovery (D) - Snelkoppeling.lnk
- C:\settings.ini
- C:\zoek-results.log
- C:\zoek-results2013-11-04-184047.log
- C:\Windows\system32\
- C:\Windows\SysWOW64\
- C:\Users\Jan\Documents\
- C:\Windows\TEMP\
- C:\Users\Jan\AppData\Local\Temp\
Computer\Motherboard\SYSTEM BIOS - Ok
c:\windows\system32\ntoskrnl.exe - Ok
c:\windows\system32\hal.dll - Ok
c:\windows\system32\kdcom.dll - Ok
c:\windows\system32\mcupdate_genuineintel.dll - Ok
c:\windows\system32\pshed.dll - Ok
c:\windows\system32\clfs.sys - Ok
c:\windows\system32\ci.dll - Ok
c:\windows\system32\drivers\wdf01000.sys - Ok
c:\windows\system32\drivers\wdfldr.sys - Ok
c:\windows\system32\drivers\acpi.sys - Ok
c:\windows\system32\drivers\wmilib.sys - Ok
c:\windows\system32\drivers\msisadrv.sys - Ok
c:\windows\system32\drivers\pci.sys - Ok
c:\windows\system32\drivers\vdrvroot.sys - Ok
c:\windows\system32\drivers\partmgr.sys - Ok
c:\windows\system32\drivers\compbatt.sys - Ok
c:\windows\system32\drivers\battc.sys - Ok
c:\windows\system32\drivers\volmgr.sys - Ok
c:\windows\system32\drivers\volmgrx.sys - Ok
c:\windows\system32\drivers\mountmgr.sys - Ok
c:\windows\system32\drivers\iastor.sys - Ok
c:\windows\system32\drivers\atapi.sys - Ok
c:\windows\system32\drivers\ataport.sys - Ok
c:\windows\system32\drivers\msahci.sys - Ok
c:\windows\system32\drivers\pciidex.sys - Ok
c:\windows\system32\drivers\amdxata.sys - Ok
c:\windows\system32\drivers\fltmgr.sys - Ok
c:\windows\system32\drivers\fileinfo.sys - Ok
c:\windows\system32\drivers\pxhlpa64.sys - Ok
c:\windows\system32\drivers\ntfs.sys - Ok
c:\windows\system32\drivers\msrpc.sys - Ok
c:\windows\system32\drivers\ksecdd.sys - Ok
c:\windows\system32\drivers\cng.sys - Ok
c:\windows\system32\drivers\pcw.sys - Ok
c:\windows\system32\drivers\fs_rec.sys - Ok
c:\windows\system32\drivers\ndis.sys - Ok
c:\windows\system32\drivers\netio.sys - Ok
c:\windows\system32\drivers\ksecpkg.sys - Ok
c:\windows\system32\drivers\tcpip.sys - Ok
c:\windows\system32\drivers\fwpkclnt.sys - Ok
c:\windows\system32\drivers\epfwwfp.sys - Ok
c:\windows\system32\drivers\volsnap.sys - Ok
c:\windows\system32\drivers\spldr.sys - Ok
c:\windows\system32\drivers\rdyboost.sys - Ok
c:\windows\system32\drivers\mup.sys - Ok
c:\windows\system32\drivers\hwpolicy.sys - Ok
c:\windows\system32\drivers\hpdskflt.sys - Ok
c:\windows\system32\drivers\fvevol.sys - Ok
c:\windows\system32\drivers\disk.sys - Ok
c:\windows\system32\drivers\classpnp.sys - Ok
c:\windows\system32\drivers\cdrom.sys - Ok
c:\windows\system32\drivers\null.sys - Ok
c:\windows\system32\drivers\beep.sys - Ok
c:\windows\system32\drivers\ehdrv.sys - Ok
c:\program files\eset\eset smart security\em006_64.dat - Ok
c:\program files\eset\eset smart security\em018_64.dat - Ok
c:\windows\system32\drivers\vga.sys - Ok
c:\windows\system32\drivers\videoprt.sys - Ok
c:\windows\system32\drivers\watchdog.sys - Ok
c:\windows\system32\drivers\rdpcdd.sys - Ok
c:\windows\system32\drivers\rdpencdd.sys - Ok
c:\windows\system32\drivers\rdprefmp.sys - Ok
c:\windows\system32\drivers\msfs.sys - Ok
c:\windows\system32\drivers\npfs.sys - Ok
c:\windows\system32\drivers\tdx.sys - Ok
c:\windows\system32\drivers\tdi.sys - Ok
c:\windows\system32\drivers\afd.sys - Ok
c:\windows\system32\drivers\netbt.sys - Ok
c:\windows\system32\drivers\wfplwf.sys - Ok
c:\windows\system32\drivers\pacer.sys - Ok
c:\windows\system32\drivers\vwififlt.sys - Ok
c:\windows\system32\drivers\epfwlwf.sys - Ok
c:\windows\system32\drivers\netbios.sys - Ok
c:\windows\system32\drivers\wanarp.sys - Ok
c:\windows\system32\drivers\termdd.sys - Ok
c:\windows\system32\drivers\rdbss.sys - Ok
c:\windows\system32\drivers\nsiproxy.sys - Ok
c:\windows\system32\drivers\mssmbios.sys - Ok
c:\windows\system32\drivers\discache.sys - Ok
c:\windows\system32\drivers\dfsc.sys - Ok
c:\windows\system32\drivers\blbdrive.sys - Ok
c:\windows\system32\drivers\tunnel.sys - Ok
c:\windows\system32\drivers\atikmpag.sys - Ok
c:\windows\system32\drivers\atikmdag.sys - Ok
c:\windows\system32\drivers\igdpmd64.sys - Ok
c:\windows\system32\drivers\dxgkrnl.sys - Ok
c:\windows\system32\drivers\dxgmms1.sys - Ok
c:\windows\system32\drivers\fastfat.sys - Ok
c:\windows\system32\drivers\hecix64.sys - Ok
c:\windows\system32\drivers\usbehci.sys - Ok
c:\windows\system32\drivers\usbport.sys - Ok
c:\windows\system32\drivers\hdaudbus.sys - Ok
c:\windows\system32\drivers\rt64win7.sys - Ok
c:\windows\system32\drivers\netwsw00.sys - Ok
c:\windows\system32\drivers\vwifibus.sys - Ok
c:\windows\system32\drivers\rtspstor.sys - Ok
c:\windows\system32\drivers\sdbus.sys - Ok
c:\windows\system32\drivers\nusb3xhc.sys - Ok
c:\windows\system32\drivers\usbd.sys - Ok
c:\windows\system32\drivers\i8042prt.sys - Ok
c:\windows\system32\drivers\kbdclass.sys - Ok
c:\windows\system32\drivers\syntp.sys - Ok
c:\windows\system32\drivers\mouclass.sys - Ok
c:\windows\system32\drivers\gearaspiwdm.sys - Ok
c:\windows\system32\drivers\cmbatt.sys - Ok
c:\windows\system32\drivers\accelerometer.sys - Ok
c:\windows\system32\drivers\wmiacpi.sys - Ok
c:\windows\system32\drivers\intelppm.sys - Ok
c:\windows\system32\drivers\amppal.sys - Ok
c:\windows\system32\drivers\compositebus.sys - Ok
c:\windows\system32\drivers\clwvd.sys - Ok
c:\windows\system32\drivers\ks.sys - Ok
c:\windows\system32\drivers\ksthunk.sys - Ok
c:\windows\system32\drivers\agilevpn.sys - Ok
c:\windows\system32\drivers\rasl2tp.sys - Ok
c:\windows\system32\drivers\ndistapi.sys - Ok
c:\windows\system32\drivers\ndiswan.sys - Ok
c:\windows\system32\drivers\raspppoe.sys - Ok
c:\windows\system32\drivers\raspptp.sys - Ok
c:\windows\system32\drivers\rassstp.sys - Ok
c:\windows\system32\drivers\swenum.sys - Ok
c:\windows\system32\drivers\iwdbus.sys - Ok
c:\windows\system32\drivers\umbus.sys - Ok
c:\windows\system32\drivers\usbhub.sys - Ok
c:\windows\system32\drivers\ndproxy.sys - Ok
c:\windows\system32\drivers\stwrt64.sys - Ok
c:\windows\system32\drivers\portcls.sys - Ok
c:\windows\system32\drivers\drmk.sys - Ok
c:\windows\system32\drivers\intcdaud.sys - Ok
c:\windows\system32\drivers\nusb3hub.sys - Ok
c:\windows\system32\win32k.sys - Ok
c:\windows\system32\drivers\dxapi.sys - Ok
c:\windows\system32\drivers\crashdmp.sys - Ok
c:\windows\system32\drivers\dump_iastor.sys - file not found
c:\windows\system32\drivers\dump_dumpfve.sys - file not found
c:\windows\system32\drivers\usbccgp.sys - Ok
c:\windows\system32\drivers\usbvideo.sys - Ok
c:\windows\system32\drivers\ibtfltcoex.sys - Ok
c:\windows\system32\drivers\btmhsf.sys - Ok
c:\windows\system32\drivers\bthusb.sys - Ok
c:\windows\system32\drivers\bthport.sys - Ok
c:\windows\system32\drivers\hidusb.sys - Ok
c:\windows\system32\drivers\hidclass.sys - Ok
c:\windows\system32\drivers\hidparse.sys - Ok
c:\windows\system32\drivers\kbdhid.sys - Ok
c:\windows\system32\drivers\mouhid.sys - Ok
c:\windows\system32\drivers\rfcomm.sys - Ok
c:\windows\system32\drivers\bthenum.sys - Ok
c:\windows\system32\drivers\bthpan.sys - Ok
c:\windows\system32\drivers\btmaux.sys - Ok
c:\windows\system32\drivers\monitor.sys - Ok
c:\windows\system32\tsddd.dll - Ok
c:\windows\system32\cdd.dll - Ok
c:\windows\system32\atmfd.dll - Ok
c:\windows\system32\drivers\luafv.sys - Ok
c:\windows\system32\drivers\eamonm.sys - Ok
c:\windows\system32\drivers\mbam.sys - Ok
c:\windows\system32\drivers\wudfpf.sys - Ok
c:\windows\system32\drivers\epfw.sys - Ok
c:\windows\system32\drivers\winusb.sys - Ok
c:\windows\system32\drivers\wudfrd.sys - Ok
c:\windows\system32\drivers\lltdio.sys - Ok
c:\windows\system32\drivers\nwifi.sys - Ok
c:\windows\system32\drivers\ndisuio.sys - Ok
c:\windows\system32\drivers\rspndr.sys - Ok
>c:\windows\system32\drivers\http.sys is BINARYRES container
c:\windows\system32\drivers\http.sys - container
c:\windows\system32\drivers\bowser.sys - Ok
c:\windows\system32\drivers\mpsdrv.sys - Ok
c:\windows\system32\drivers\mrxsmb.sys - Ok
c:\windows\system32\drivers\mrxsmb10.sys - Ok
c:\windows\system32\drivers\mrxsmb20.sys - Ok
c:\windows\system32\drivers\vwifimp.sys - Ok
c:\windows\system32\drivers\peauth.sys - Ok
c:\windows\system32\drivers\secdrv.sys - Ok
c:\windows\system32\drivers\srvnet.sys - Ok
c:\windows\system32\drivers\tcpipreg.sys - Ok
c:\windows\system32\drivers\srv2.sys - Ok
c:\windows\system32\drivers\srv.sys - Ok
c:\windows\system32\drivers\asyncmac.sys - Ok
c:\users\jan\appdata\local\temp\42799f4d1.sys - file not found
c:\users\jan\appdata\local\temp\42a293c9e.sys - file not found
c:\windows\system32\ntdll.dll - Ok
c:\windows\system32\smss.exe - Ok
c:\windows\system32\apisetschema.dll - Ok
c:\windows\system32\autochk.exe - Ok
System Idle Process - file not found
System Process - file not found
c:\windows\system32\csrss.exe - Ok
c:\windows\system32\wininit.exe - Ok
c:\windows\system32\services.exe - Ok
c:\windows\system32\lsass.exe - Ok
c:\windows\system32\lsm.exe - Ok
c:\windows\system32\svchost.exe - Ok
c:\windows\system32\winlogon.exe - Ok
c:\program files (x86)\hp simplepass 2012\truesuiteservice.exe - Ok
c:\windows\system32\atiesrxx.exe - Ok
c:\program files\idt\wdm\stacsv64.exe - Ok
c:\windows\system32\hpservice.exe - Ok
c:\windows\system32\wudfhost.exe - Ok
c:\windows\system32\atieclxx.exe - Ok
c:\windows\system32\dwm.exe - Ok
c:\windows\explorer.exe - Ok
c:\windows\system32\wlanext.exe - Ok
c:\windows\system32\conhost.exe - Ok
c:\windows\system32\spoolsv.exe - Ok
c:\windows\system32\taskhost.exe - Ok
c:\program files (x86)\common files\adobe\arm\1.0\armsvc.exe - Ok
c:\program files\idt\wdm\aestsr64.exe - Ok
c:\program files (x86)\common files\apple\mobile device support\applemobiledeviceservice.exe - Ok
>c:\program files (x86)\intel\bluetooth\devmonsrv.exe - packed by FLY-CODE
c:\program files (x86)\intel\bluetooth\devmonsrv.exe - Ok
c:\program files\bonjour\mdnsresponder.exe - Ok
c:\program files\eset\eset smart security\x86\ekrn.exe - Ok
c:\program files\intel\wifi\bin\evteng.exe - Ok
c:\windows\syswow64\ezsharedsvchost.exe - Ok
c:\program files\hewlett-packard\hp client services\hpclientservices.exe - Ok
c:\program files (x86)\hewlett-packard\shared\hpdrvmntsvc.exe - Ok
c:\program files (x86)\hewlett-packard\hp quick launch\hpwmisvc.exe - Ok
c:\program files (x86)\realtek\realtek pcie card reader\riconman.exe - Ok
c:\program files (x86)\intel\services\ipt\jhi_service.exe - Ok
c:\program files (x86)\malwarebytes' anti-malware\mbamscheduler.exe - Ok
c:\program files (x86)\malwarebytes' anti-malware\mbamservice.exe - Ok
c:\program files\common files\intel\wirelesscommon\regsrvc.exe - Ok
c:\program files (x86)\malwarebytes' anti-malware\mbamgui.exe - Ok
>c:\program files (x86)\teamviewer\version7\teamviewer_service.exe is BINARYRES container
c:\program files (x86)\teamviewer\version7\teamviewer_service.exe - container
c:\program files\common files\microsoft shared\windows live\wlidsvc.exe - Ok
c:\program files\intel\wifi\bin\zeroconfigservice.exe - Ok
>c:\program files (x86)\intel\bluetooth\obexsrv.exe - packed by FLY-CODE
c:\program files (x86)\intel\bluetooth\obexsrv.exe - Ok
c:\program files\common files\microsoft shared\windows live\wlidsvcm.exe - Ok
c:\windows\system32\wbem\unsecapp.exe - Ok
c:\windows\system32\wbem\wmiprvse.exe - Ok
c:\windows\system32\rundll32.exe - Ok
c:\windows\system32\igfxtray.exe - Ok
c:\windows\system32\hkcmd.exe - Ok
c:\windows\system32\igfxpers.exe - Ok
c:\program files\synaptics\syntp\syntpenh.exe - Ok
>c:\program files\eset\eset smart security\egui.exe is ZLIB container
c:\program files\eset\eset smart security\egui.exe - container
c:\program files\hewlett-packard\hp launchbox\hptaskbar1.exe - Ok
c:\program files\hewlett-packard\hp launchbox\hptaskbar2.exe - Ok
c:\program files\idt\wdm\sttray64.exe - Ok
>c:\program files (x86)\intel\bluetooth\mediasrv.exe - packed by FLY-CODE
c:\program files (x86)\intel\bluetooth\mediasrv.exe - Ok
c:\program files\synaptics\syntp\syntphelper.exe - Ok
c:\users\jan\appdata\roaming\spotify\data\spotifywebhelper.exe - Ok
>c:\program files (x86)\intel\bluetooth\btplayerctrl.exe - packed by FLY-CODE
c:\program files (x86)\intel\bluetooth\btplayerctrl.exe - Ok
c:\program files (x86)\intel\intel(r) rapid storage technology\iastoricon.exe - Ok
c:\program files (x86)\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.exe - Ok
c:\program files (x86)\hewlett-packard\hp quickweb\hpqwutils.exe - Ok
c:\program files (x86)\common files\adobe\arm\1.0\adobearm.exe - Ok
>c:\program files (x86)\hewlett-packard\hp on screen display\hposd.exe is ZLIB container
c:\program files (x86)\hewlett-packard\hp on screen display\hposd.exe - container
>c:\program files (x86)\hewlett-packard\hp coolsense\coolsense.exe is ZLIB container
c:\program files (x86)\hewlett-packard\hp coolsense\coolsense.exe - container
c:\program files (x86)\hewlett-packard\shared\hpqwmiex.exe - Ok
c:\windows\system32\taskeng.exe - Ok
c:\program files (x86)\cyberlink\youcam\ycmmirage.exe - Ok
c:\program files (x86)\adobe\acrobat 10.0\acrobat\acrotray.exe - Ok
c:\program files (x86)\itunes\ituneshelper.exe - Ok
c:\program files (x86)\hewlett-packard\hp quick launch\hpmsgsvc.exe - Ok
c:\program files (x86)\common files\java\java update\jusched.exe - Ok
c:\windows\system32\searchindexer.exe - Ok
c:\program files\ipod\bin\ipodservice.exe - Ok
c:\program files\windows media player\wmpnetwk.exe - Ok
c:\program files\microsoft office\office14\outlook.exe - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\mom.exe - Ok
c:\windows\system32\dllhost.exe - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\ccc.exe - Ok
c:\program files\intel\bluetoothhs\bthsamppalservice.exe - Ok
c:\program files\intel\bluetoothhs\bthssecuritymgr.exe - Ok
c:\program files (x86)\hewlett-packard\hp support framework\hpsa_service.exe - Ok
c:\program files (x86)\intel\intel(r) rapid storage technology\iastordatamgrsvc.exe - Ok
c:\program files (x86)\intel\intel(r) management engine components\lms\lms.exe - Ok
c:\program files\common files\microsoft shared\officesoftwareprotectionplatform\osppsvc.exe - Ok
c:\windows\microsoft.net\framework64\v3.0\wpf\presentationfontcache.exe - Ok
c:\program files (x86)\intel\intel(r) management engine components\uns\uns.exe - Ok
c:\program files (x86)\internet explorer\ielowutil.exe - Ok
c:\program files (x86)\common files\adobe\oobe\pdapp\uwa\aam updates notifier.exe - Ok
c:\program files (x86)\hp simplepass 2012\touchcontrol.exe - Ok
c:\program files (x86)\hp simplepass 2012\biomonitor.exe - Ok
c:\windows\system32\audiodg.exe - Ok
c:\program files (x86)\mozilla firefox\firefox.exe - Ok
c:\program files (x86)\mozilla firefox\plugin-container.exe - Ok
c:\windows\syswow64\macromed\flash\flashplayerplugin_11_9_900_117.exe - Ok
>c:\users\jan\desktop\launch.exe is BINARYRES container
>>c:\users\jan\desktop\launch.exe\data001 - packed by BINARYRES
>>c:\users\jan\desktop\launch.exe\data002 - packed by BINARYRES
c:\users\jan\desktop\launch.exe - container
c:\users\jan\desktop\launch.exe:Zone.Identifier - Ok
c:\users\jan\appdata\local\temp\29a853e8-ed91999a-ef968fba-f9fe4db8\m01cbbgb.exe - Ok
>c:\users\jan\appdata\local\temp\29a853e8-ed91999a-ef968fba-f9fe4db8\i4yqhvm6.exe is BINARYRES container
c:\users\jan\appdata\local\temp\29a853e8-ed91999a-ef968fba-f9fe4db8\i4yqhvm6.exe - container
c:\windows\system32\searchprotocolhost.exe - Ok
c:\users\jan\appdata\local\temp\29a853e8-ed91999a-ef968fba-f9fe4db8\mpchg1uj.exe - Ok
c:\windows\system32\searchfilterhost.exe - Ok
c:\windows\system32\user32.dll - Ok
c:\windows\system32\kernel32.dll - Ok
c:\windows\system32\cryptbase.dll - Ok
c:\windows\system32\sxs.dll - Ok
c:\windows\system32\sxssrv.dll - Ok
c:\windows\system32\winsrv.dll - Ok
c:\windows\system32\basesrv.dll - Ok
c:\windows\system32\csrsrv.dll - Ok
c:\windows\system32\kernelbase.dll - Ok
c:\windows\system32\lpk.dll - Ok
c:\windows\system32\gdi32.dll - Ok
c:\windows\system32\msvcrt.dll - Ok
c:\windows\system32\sechost.dll - Ok
c:\windows\system32\usp10.dll - Ok
c:\windows\system32\advapi32.dll - Ok
c:\windows\system32\rpcrt4.dll - Ok
c:\windows\system32\wshtcpip.dll - Ok
c:\windows\system32\credssp.dll - Ok
c:\windows\system32\wship6.dll - Ok
c:\windows\system32\mswsock.dll - Ok
c:\windows\system32\secur32.dll - Ok
c:\windows\system32\sspicli.dll - Ok
c:\windows\system32\apphelp.dll - Ok
c:\windows\system32\rpcrtremote.dll - Ok
c:\windows\system32\profapi.dll - Ok
c:\windows\system32\ws2_32.dll - Ok
c:\windows\system32\imm32.dll - Ok
c:\windows\system32\msctf.dll - Ok
c:\windows\system32\nsi.dll - Ok
c:\windows\system32\wtsapi32.dll - Ok
c:\windows\system32\winsta.dll - Ok
c:\windows\system32\ubpm.dll - Ok
c:\windows\system32\authz.dll - Ok
c:\windows\system32\srvcli.dll - Ok
c:\windows\system32\scesrv.dll - Ok
c:\windows\system32\scext.dll - Ok
c:\windows\system32\msprivs.dll - Ok
c:\windows\system32\psapi.dll - Ok
c:\windows\system32\psbase.dll - Ok
c:\windows\system32\pstorsvc.dll - Ok
c:\windows\system32\dssenh.dll - Ok
c:\windows\system32\efsutil.dll - Ok
c:\windows\system32\cryptnet.dll - Ok
c:\windows\system32\efscore.dll - Ok
c:\windows\system32\efssvc.dll - Ok
c:\windows\system32\vaultsvc.dll - Ok
c:\windows\system32\ktmw32.dll - Ok
c:\windows\system32\keyiso.dll - Ok
c:\windows\system32\winnsi.dll - Ok
c:\windows\system32\iphlpapi.dll - Ok
c:\windows\system32\netutils.dll - Ok
c:\windows\system32\slc.dll - Ok
c:\windows\system32\gpapi.dll - Ok
c:\windows\system32\userenv.dll - Ok
c:\windows\system32\scecli.dll - Ok
c:\windows\system32\efslsaext.dll - Ok
c:\windows\system32\bcryptprimitives.dll - Ok
c:\windows\system32\livessp.dll - Ok
c:\windows\system32\pku2u.dll - Ok
c:\windows\system32\tspkg.dll - Ok
c:\windows\system32\rsaenh.dll - Ok
c:\windows\system32\wdigest.dll - Ok
c:\windows\system32\schannel.dll - Ok
c:\windows\system32\logoncli.dll - Ok
c:\windows\system32\dnsapi.dll - Ok
c:\windows\system32\netlogon.dll - Ok
c:\windows\system32\msv1_0.dll - Ok
c:\windows\system32\cryptsp.dll - Ok
c:\windows\system32\kerberos.dll - Ok
c:\windows\system32\negoexts.dll - Ok
c:\windows\system32\netjoin.dll - Ok
c:\windows\system32\bcrypt.dll - Ok
c:\windows\system32\ncrypt.dll - Ok
c:\windows\system32\cngaudit.dll - Ok
c:\windows\system32\wevtapi.dll - Ok
c:\windows\system32\cryptdll.dll - Ok
c:\windows\system32\samsrv.dll - Ok
c:\windows\system32\lsasrv.dll - Ok
c:\windows\system32\sspisrv.dll - Ok
c:\windows\system32\msasn1.dll - Ok
c:\windows\system32\cfgmgr32.dll - Ok
c:\windows\system32\crypt32.dll - Ok
c:\windows\system32\shlwapi.dll - Ok
c:\windows\system32\wldap32.dll - Ok
c:\windows\system32\pcwum.dll - Ok
c:\windows\system32\wmsgapi.dll - Ok
c:\windows\system32\sysntfy.dll - Ok
c:\windows\system32\wbem\wmiutils.dll - Ok
c:\windows\system32\wbem\wbemsvc.dll - Ok
c:\windows\system32\ntdsapi.dll - Ok
c:\windows\system32\wbem\fastprox.dll - Ok
c:\windows\system32\wbem\wmidcprv.dll - Ok
c:\windows\system32\wbemcomn.dll - Ok
c:\windows\system32\wbem\wbemprox.dll - Ok
c:\windows\system32\ntmarta.dll - Ok
c:\windows\system32\rpcss.dll - Ok
c:\windows\system32\umpo.dll - Ok
c:\windows\system32\devrtl.dll - Ok
c:\windows\system32\spinf.dll - Ok
c:\windows\system32\umpnpmgr.dll - Ok
c:\windows\system32\devobj.dll - Ok
c:\windows\system32\wintrust.dll - Ok
c:\windows\system32\oleaut32.dll - Ok
>c:\windows\system32\setupapi.dll - packed by BINARYRES
>>c:\windows\system32\setupapi.dll - packed by MS COMPRESS
c:\windows\system32\setupapi.dll - Ok
>c:\windows\system32\ole32.dll is BINARYRES container
c:\windows\system32\ole32.dll - container
c:\windows\system32\clbcatq.dll - Ok
c:\windows\system32\mpr.dll - Ok
c:\windows\system32\uxinit.dll - Ok
c:\windows\system32\wkscli.dll - Ok
c:\windows\system32\windowscodecs.dll - Ok
c:\windows\system32\uxtheme.dll - Ok
c:\windows\syswow64\apphelp.dll - Ok
c:\windows\syswow64\winsta.dll - Ok
c:\windows\syswow64\ntmarta.dll - Ok
c:\windows\syswow64\oleacc.dll - Ok
c:\windows\syswow64\winspool.drv - Ok
c:\program files (x86)\hp simplepass 2012\tslog.dll - Ok
c:\windows\syswow64\profapi.dll - Ok
c:\windows\syswow64\userenv.dll - Ok
c:\windows\syswow64\wtsapi32.dll - Ok
c:\windows\system32\wow64cpu.dll - Ok
c:\windows\system32\wow64win.dll - Ok
c:\windows\system32\wow64.dll - Ok
c:\windows\syswow64\cryptbase.dll - Ok
c:\windows\syswow64\sspicli.dll - Ok
c:\windows\syswow64\gdi32.dll - Ok
c:\windows\syswow64\sechost.dll - Ok
c:\windows\syswow64\shlwapi.dll - Ok
c:\windows\syswow64\kernelbase.dll - Ok
c:\windows\syswow64\shell32.dll - Ok
c:\windows\syswow64\imm32.dll - Ok
c:\windows\syswow64\oleaut32.dll - Ok
c:\windows\syswow64\rpcrt4.dll - Ok
c:\windows\syswow64\wldap32.dll - Ok
c:\windows\syswow64\advapi32.dll - Ok
c:\windows\syswow64\lpk.dll - Ok
c:\windows\syswow64\msvcrt.dll - Ok
c:\windows\syswow64\usp10.dll - Ok
c:\windows\syswow64\user32.dll - Ok
c:\windows\syswow64\msctf.dll - Ok
>c:\windows\syswow64\ole32.dll is BINARYRES container
c:\windows\syswow64\ole32.dll - container
c:\windows\syswow64\kernel32.dll - Ok
c:\windows\syswow64\ntdll.dll - Ok
c:\windows\system32\sfc.dll - Ok
c:\windows\system32\msi.dll - Ok
c:\windows\system32\sfc_os.dll - Ok
c:\windows\system32\msiltcfg.dll - Ok
c:\windows\system32\fwpuclnt.dll - Ok
c:\windows\system32\version.dll - Ok
c:\windows\system32\firewallapi.dll - Ok
c:\windows\system32\rpcepmap.dll - Ok
c:\windows\system32\powrprof.dll - Ok
c:\windows\system32\wbem\winmgmtr.dll - Ok
c:\windows\system32\srslabs\{176f4e15-8f7c-4833-aded-81fae8ccd186}\sluapo64.dll - Ok
c:\windows\system32\stapo64.dll - Ok
c:\windows\system32\wuapi.dll - Ok
c:\windows\system32\wscsvc.dll - Ok
c:\program files\internet explorer\ieproxy.dll - Ok
c:\windows\system32\p2pcollab.dll - Ok
c:\windows\system32\p2p.dll - Ok
c:\windows\system32\fdproxy.dll - Ok
c:\windows\system32\provsvc.dll - Ok
c:\windows\system32\tquery.dll - Ok
c:\windows\system32\dbghelp.dll - Ok
c:\windows\system32\pnrpnsp.dll - Ok
c:\windows\system32\actxprxy.dll - Ok
c:\windows\system32\npmproxy.dll - Ok
c:\windows\system32\rasadhlp.dll - Ok
c:\windows\system32\fundisc.dll - Ok
c:\windows\system32\cabinet.dll - Ok
c:\windows\system32\msxml6.dll - Ok
c:\windows\system32\dhcpcsvc6.dll - Ok
c:\windows\system32\dhcpcsvc.dll - Ok
c:\windows\system32\dhcpcore6.dll - Ok
c:\windows\system32\dhcpcore.dll - Ok
c:\windows\system32\nrpsrv.dll - Ok
c:\windows\system32\lmhsvc.dll - Ok
c:\windows\system32\xmllite.dll - Ok
c:\windows\system32\mfplat.dll - Ok
c:\windows\system32\wmalfxgfxdsp.dll - Ok
c:\windows\system32\audioeng.dll - Ok
c:\windows\system32\audioses.dll - Ok
c:\windows\system32\atl.dll - Ok
c:\windows\system32\propsys.dll - Ok
c:\windows\system32\mmdevapi.dll - Ok
c:\windows\system32\msdmo.dll - Ok
c:\windows\system32\avrt.dll - Ok
c:\windows\system32\audiosrv.dll - Ok
c:\windows\system32\wevtsvc.dll - Ok
c:\windows\system32\api-ms-win-downlevel-advapi32-l1-1-0.dll - Ok
c:\windows\system32\api-ms-win-downlevel-shlwapi-l1-1-0.dll - Ok
>c:\windows\system32\shell32.dll is BINARYRES container
c:\windows\system32\shell32.dll - container
c:\windows\system32\imagehlp.dll - Ok
c:\windows\system32\hgprint.dll - Ok
c:\windows\system32\idlisten.dll - Ok
c:\windows\system32\listsvc.dll - Ok
c:\windows\system32\rasapi32.dll - Ok
c:\windows\system32\rasdlg.dll - Ok
c:\windows\system32\netman.dll - Ok
c:\windows\system32\rasman.dll - Ok
c:\windows\system32\portabledeviceconnectapi.dll - Ok
c:\windows\system32\portabledeviceapi.dll - Ok
c:\windows\system32\hidserv.dll - Ok
c:\windows\system32\hnetcfg.dll - Ok
c:\windows\system32\trkwks.dll - Ok
c:\windows\system32\netshell.dll - Ok
c:\windows\system32\sysmain.dll - Ok
c:\windows\system32\aepic.dll - Ok
c:\windows\system32\pcasvc.dll - Ok
c:\windows\system32\netcfgx.dll - Ok
c:\windows\system32\winspool.drv - Ok
c:\windows\system32\mprapi.dll - Ok
c:\windows\system32\tabsvc.dll - Ok
c:\windows\system32\winscard.dll - Ok
c:\windows\system32\wlanutil.dll - Ok
c:\windows\system32\l2gpstore.dll - Ok
c:\windows\system32\wlgpclnt.dll - Ok
c:\windows\system32\eappcfg.dll - Ok
c:\windows\system32\eappprxy.dll - Ok
c:\windows\system32\onex.dll - Ok
c:\windows\system32\wlansec.dll - Ok
c:\windows\system32\wlanmsm.dll - Ok
c:\windows\system32\wlansvc.dll - Ok
c:\windows\system32\cscapi.dll - Ok
c:\windows\winsxs\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7601.18201_none_a4d3b9377117c3df\comctl32.dll - Ok
c:\windows\system32\rtutils.dll - Ok
c:\windows\system32\samcli.dll - Ok
c:\windows\system32\netapi32.dll - Ok
c:\windows\system32\wudfplatform.dll - Ok
c:\windows\system32\wudfsvc.dll - Ok
c:\windows\system32\uxsms.dll - Ok
c:\windows\system32\hid.dll - Ok
c:\windows\system32\dsrole.dll - Ok
c:\windows\system32\samlib.dll - Ok
c:\windows\system32\shacct.dll - Ok
c:\windows\winsxs\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_fa396087175ac9ac\comctl32.dll - Ok
c:\windows\system32\nlaapi.dll - Ok
c:\program files\bonjour\mdnsnsp.dll - Ok
c:\windows\system32\fdssdp.dll - Ok
c:\windows\system32\mlang.dll - Ok
c:\windows\system32\fdwsd.dll - Ok
c:\windows\system32\fdphost.dll - Ok
c:\windows\system32\wshbth.dll - Ok
c:\windows\system32\winrnr.dll - Ok
c:\windows\system32\napinsp.dll - Ok
c:\windows\system32\perftrack.dll - Ok
c:\windows\system32\wdi.dll - Ok
c:\program files\common files\microsoft shared\windows live\wlidnsp.dll - Ok
c:\windows\system32\netprofm.dll - Ok
c:\windows\system32\wer.dll - Ok
c:\windows\system32\ssdpapi.dll - Ok
c:\windows\system32\webio.dll - Ok
c:\windows\system32\winhttp.dll - Ok
c:\windows\system32\webservices.dll - Ok
c:\windows\system32\wsdapi.dll - Ok
c:\windows\system32\nsisvc.dll - Ok
c:\windows\system32\dwmapi.dll - Ok
c:\windows\system32\es.dll - Ok
c:\windows\system32\fntcache.dll - Ok
c:\windows\system32\advpack.dll - Ok
c:\windows\system32\wuaueng.dll - Ok
c:\windows\system32\qmgr.dll - Ok
c:\windows\system32\upnp.dll - Ok
c:\windows\system32\bitsigd.dll - Ok
c:\windows\system32\mmcss.dll - Ok
c:\windows\system32\bitsperf.dll - Ok
c:\windows\system32\mspatcha.dll - Ok
c:\windows\system32\api-ms-win-downlevel-shlwapi-l2-1-0.dll - Ok
c:\windows\system32\appinfo.dll - Ok
c:\windows\system32\resutils.dll - Ok
c:\windows\system32\clusapi.dll - Ok
c:\windows\system32\browser.dll - Ok
c:\windows\system32\srvsvc.dll - Ok
c:\windows\system32\nci.dll - Ok
c:\windows\system32\wdscore.dll - Ok
c:\windows\system32\sqmapi.dll - Ok
c:\windows\system32\iphlpsvc.dll - Ok
c:\windows\system32\wbem\ncprov.dll - Ok
c:\windows\system32\wbem\wbemess.dll - Ok
c:\windows\system32\wbem\wmiprvsd.dll - Ok
c:\windows\system32\msxml3.dll - Ok
c:\windows\system32\wbem\repdrvfs.dll - Ok
c:\windows\system32\sscore.dll - Ok
c:\windows\system32\ncobjapi.dll - Ok
c:\windows\system32\wbem\esscli.dll - Ok
c:\windows\system32\wbem\wbemcore.dll - Ok
c:\windows\system32\wbem\wmisvc.dll - Ok
c:\windows\system32\aelupsvc.dll - Ok
c:\windows\system32\ikeext.dll - Ok
c:\windows\system32\vsstrace.dll - Ok
c:\windows\system32\vssapi.dll - Ok
>c:\windows\system32\spfileq.dll - packed by BINARYRES
>>c:\windows\system32\spfileq.dll - packed by MS COMPRESS
c:\windows\system32\spfileq.dll - Ok
c:\windows\system32\esent.dll - Ok
c:\windows\system32\tschannel.dll - Ok
c:\windows\system32\wiarpc.dll - Ok
c:\windows\system32\taskcomp.dll - Ok
c:\windows\system32\fvecerts.dll - Ok
c:\windows\system32\tbs.dll - Ok
c:\windows\system32\fveapi.dll - Ok
c:\windows\system32\schedsvc.dll - Ok
c:\windows\system32\shsvcs.dll - Ok
c:\windows\system32\umb.dll - Ok
c:\windows\system32\eapphost.dll - Ok
c:\windows\system32\eapsvc.dll - Ok
c:\windows\system32\sens.dll - Ok
c:\windows\system32\profsvc.dll - Ok
c:\windows\system32\themeservice.dll - Ok
c:\windows\system32\gpsvc.dll - Ok
c:\windows\system32\aestar64.dll - Ok
c:\windows\system32\stapi64.dll - Ok
c:\windows\system32\winmm.dll - Ok
c:\windows\system32\dsound.dll - Ok
c:\windows\system32\odbcint.dll - Ok
c:\windows\system32\accelerometerdll.dll - Ok
c:\windows\system32\odbc32.dll - Ok
c:\windows\system32\mfc42u.dll - Ok
c:\windows\system32\drivers\umdf\wbf_vfs_0018.dll - Ok
c:\windows\system32\wudfx.dll - Ok
c:\windows\system32\winusb.dll - Ok
c:\windows\system32\atiadlxx.dll - Ok
c:\windows\system32\atidxx64.dll - Ok
c:\windows\system32\aticfx64.dll - Ok
c:\windows\system32\igd10umd64.dll - Ok
c:\windows\system32\udwm.dll - Ok
c:\windows\system32\atiuxp64.dll - Ok
c:\windows\system32\d3d11.dll - Ok
c:\windows\system32\dxgi.dll - Ok
c:\windows\system32\d3d10_1core.dll - Ok
c:\windows\system32\d3d10_1.dll - Ok
c:\windows\system32\dwmcore.dll - Ok
c:\windows\system32\dwmredir.dll - Ok
c:\program files (x86)\adobe\acrobat 10.0\acrobat\locale\nl_nl\acrobat elements\contextmenu64.nld - Ok
c:\program files (x86)\intel\bluetooth\resources\nld.dll - Ok
c:\program files (x86)\intel\bluetooth\btmshell.dll - Ok
c:\windows\system32\fxsresm.dll - Ok
c:\program files\eset\eset smart security\shellext.dll - Ok
c:\windows\winsxs\amd64_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_0a1fd3a3a768b895\atl90.dll - Ok
c:\windows\winsxs\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\msvcp90.dll - Ok
c:\windows\winsxs\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251\msvcr90.dll - Ok
c:\windows\system32\ksuser.dll - Ok
c:\windows\system32\normaliz.dll - Ok
c:\program files (x86)\filezilla ftp client\fzshellext_64.dll - Ok
c:\program files (x86)\adobe\acrobat 10.0\acrobat elements\contextmenu64.dll - Ok
c:\windows\system32\ieframe.dll - Ok
c:\windows\system32\wercplsupport.dll - Ok
c:\windows\system32\framedynos.dll - Ok
c:\windows\system32\werconcpl.dll - Ok
>c:\windows\system32\wscui.cpl is ZLIB container
c:\windows\system32\wscui.cpl - container
c:\windows\system32\wscapi.dll - Ok
c:\windows\system32\wscinterop.dll - Ok
c:\windows\system32\api-ms-win-downlevel-shell32-l1-1-0.dll - Ok
c:\windows\system32\msftedit.dll - Ok
c:\windows\system32\fxsapi.dll - Ok
c:\windows\system32\hcproviders.dll - Ok
c:\windows\system32\hgcpl.dll - Ok
c:\windows\system32\synccenter.dll - Ok
c:\windows\system32\wlanmm.dll - Ok
c:\windows\system32\wwanmm.dll - Ok
c:\windows\system32\rasmm.dll - Ok
c:\windows\system32\imapi2.dll - Ok
c:\windows\system32\structuredquery.dll - Ok
c:\windows\system32\fxsst.dll - Ok
c:\windows\system32\wlanhlp.dll - Ok
c:\windows\system32\qagent.dll - Ok
c:\windows\system32\wwanapi.dll - Ok
c:\windows\system32\mssprxy.dll - Ok
c:\windows\system32\srchadmin.dll - Ok
c:\windows\system32\portabledevicetypes.dll - Ok
c:\windows\system32\actioncenter.dll - Ok
c:\windows\system32\pnidui.dll - Ok
c:\windows\system32\uianimation.dll - Ok
c:\windows\system32\wdmaud.drv - Ok
c:\windows\system32\networkexplorer.dll - Ok
c:\windows\system32\bthprops.cpl - Ok
c:\windows\system32\msls31.dll - Ok
c:\windows\system32\gameux.dll - Ok
c:\windows\system32\zipfldr.dll - Ok
c:\windows\system32\aclui.dll - Ok
c:\windows\system32\riched20.dll - Ok
c:\windows\system32\syncui.dll - Ok
c:\windows\system32\midimap.dll - Ok
c:\windows\system32\acppage.dll - Ok
c:\windows\system32\synceng.dll - Ok
c:\program files\winrar\rarext.dll - Ok
c:\program files (x86)\malwarebytes' anti-malware\mbamext.dll - Ok
c:\windows\system32\twext.dll - Ok
c:\windows\system32\ehstorapi.dll - Ok
c:\windows\system32\msacm32.dll - Ok
c:\windows\system32\van.dll - Ok
c:\windows\system32\shdocvw.dll - Ok
c:\windows\system32\msacm32.drv - Ok
c:\windows\system32\ntshrui.dll - Ok
c:\program files\microsoft office\office14\1043\grooveintlresource.dll - Ok
c:\program files\common files\microsoft shared\office14\cultures\office.odf - Ok
>c:\windows\system32\timedate.cpl is ZLIB container
c:\windows\system32\timedate.cpl - container
c:\windows\system32\linkinfo.dll - Ok
c:\program files\microsoft office\office14\grooveex.dll - Ok
c:\windows\system32\api-ms-win-downlevel-advapi32-l2-1-0.dll - Ok
c:\windows\system32\msutb.dll - Ok
c:\windows\system32\wlanapi.dll - Ok
c:\windows\system32\ehstorshell.dll - Ok
c:\windows\system32\explorerframe.dll - Ok
c:\windows\system32\iconcodecservice.dll - Ok
c:\windows\system32\msimg32.dll - Ok
c:\windows\system32\wwapi.dll - Ok
c:\windows\system32\wpdshserviceobj.dll - Ok
c:\windows\system32\dxp.dll - Ok
c:\windows\system32\oleacc.dll - Ok
c:\windows\system32\qutil.dll - Ok
c:\windows\system32\prnfldr.dll - Ok
c:\windows\system32\batmeter.dll - Ok
c:\windows\system32\stobject.dll - Ok
c:\windows\system32\sndvolsso.dll - Ok
c:\windows\system32\syncreg.dll - Ok
c:\windows\ehome\ehsso.dll - Ok
c:\windows\system32\alttab.dll - Ok
c:\windows\system32\riched32.dll - Ok
c:\windows\system32\duser.dll - Ok
c:\windows\system32\dui70.dll - Ok
c:\windows\winsxs\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18120_none_2b25b14c71ebf230\gdiplus.dll - Ok
c:\windows\system32\cryptui.dll - Ok
>c:\windows\system32\authui.dll is ZLIB container
c:\windows\system32\authui.dll - container
c:\windows\system32\api-ms-win-downlevel-version-l1-1-0.dll - Ok
c:\windows\system32\api-ms-win-downlevel-ole32-l1-1-0.dll - Ok
c:\windows\system32\api-ms-win-downlevel-user32-l1-1-0.dll - Ok
c:\windows\system32\api-ms-win-downlevel-normaliz-l1-1-0.dll - Ok
>c:\windows\system32\urlmon.dll is BINARYRES container
c:\windows\system32\urlmon.dll - container
c:\windows\system32\comdlg32.dll - Ok
c:\windows\system32\iertutil.dll - Ok
c:\windows\system32\wininet.dll - Ok
c:\windows\system32\sensapi.dll - Ok
c:\windows\system32\ncsi.dll - Ok
c:\windows\system32\nlasvc.dll - Ok
c:\windows\system32\cryptsvc.dll - Ok
c:\windows\system32\wkssvc.dll - Ok
c:\windows\system32\dnsext.dll - Ok
c:\windows\system32\dnsrslvr.dll - Ok
c:\program files\intel\wifi\bin\p2psupplicant.dll - Ok
c:\program files\common files\intel\wirelesscommon\libeay32.dll - Ok
c:\windows\system32\msvcp100.dll - Ok
c:\windows\system32\msvcr100.dll - Ok
>c:\windows\system32\mfc100.dll is ZLIB container
c:\windows\system32\mfc100.dll - container
c:\program files\intel\wifi\bin\iwmsprov.dll - Ok
c:\program files\intel\wifi\bin\intstngs.dll - Ok
c:\program files\intel\wifi\bin\kmmdlplugins\panauthenticator.dll - Ok
c:\program files\intel\wifi\bin\kmmdlplugins\p2psupplicantplugin.dll - Ok
c:\program files\intel\wifi\bin\kmmdlplugins\ihvwpsplugin.dll - Ok
c:\program files\intel\wifi\bin\kmmdlplugins\ccxplugin.dll - Ok
c:\program files\common files\intel\wirelesscommon\traceapi.dll - Ok
c:\program files\common files\intel\wirelesscommon\psregapi.dll - Ok
c:\windows\system32\iwmssvc.dll - Ok
>c:\windows\system32\cnbjmon2.dll - packed by PESTUB
c:\windows\system32\cnbjmon2.dll - Ok
c:\windows\system32\mgmtapi.dll - Ok
c:\windows\system32\tcpmib.dll - Ok
c:\windows\system32\inetpp.dll - Ok
c:\windows\system32\win32spl.dll - Ok
c:\windows\system32\spool\prtprocs\x64\hpzppwn7.dll - Ok
c:\windows\system32\spool\prtprocs\x64\winprint.dll - Ok
c:\windows\system32\fdpnp.dll - Ok
c:\windows\system32\wsdmon.dll - Ok
c:\windows\system32\wls0wndh.dll - Ok
c:\windows\system32\usbmon.dll - Ok
c:\windows\system32\wsnmp32.dll - Ok
c:\windows\system32\snmpapi.dll - Ok
c:\windows\system32\tcpmon.dll - Ok
c:\windows\system32\fxsmon.dll - Ok
c:\windows\system32\adobepdf.dll - Ok
c:\windows\system32\printisolationproxy.dll - Ok
c:\windows\system32\spoolss.dll - Ok
c:\windows\system32\localspl.dll - Ok
c:\windows\system32\browcli.dll - Ok
c:\program files\internet explorer\sqmapi.dll - Ok
c:\windows\system32\dimsjob.dll - Ok
c:\windows\system32\taskschd.dll - Ok
c:\windows\system32\hotstartuseragent.dll - Ok
c:\windows\system32\msctfmonitor.dll - Ok
c:\windows\system32\playsndsrv.dll - Ok
c:\windows\winsxs\amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.6195_none_88e41e092fab0294\msvcr80.dll - Ok
c:\windows\winsxs\amd64_microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_8448b2bd328df189\mfc80u.dll - Ok
c:\windows\system32\winbioplugins\vcswbfengineadapter.dll - Ok
c:\windows\system32\winbioplugins\winbiostorageadapter.dll - Ok
c:\windows\system32\wbiosrvc.dll - Ok
c:\windows\system32\winbioplugins\winbiosensoradapter.dll - Ok
c:\windows\system32\vaultcli.dll - Ok
c:\windows\system32\credui.dll - Ok
c:\windows\system32\wdiasqmmodule.dll - Ok
c:\windows\system32\radardt.dll - Ok
c:\windows\system32\dps.dll - Ok
c:\windows\system32\mpssvc.dll - Ok
c:\windows\system32\bfe.dll - Ok
c:\windows\system32\wfapigp.dll - Ok
c:\windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\msvcr90.dll - Ok
>c:\windows\syswow64\wintrust.dll - packed by FLY-CODE
c:\windows\syswow64\wintrust.dll - Ok
c:\windows\syswow64\crypt32.dll - Ok
c:\windows\syswow64\msasn1.dll - Ok
c:\program files (x86)\common files\apple\apple application support\icudt46.dll - Ok
c:\program files (x86)\common files\apple\apple application support\libxml2.dll - Ok
c:\program files (x86)\common files\apple\apple application support\sqlite3.dll - Ok
>c:\windows\syswow64\winnsi.dll - packed by FLY-CODE
c:\windows\syswow64\winnsi.dll - Ok
c:\windows\syswow64\iphlpapi.dll - Ok
c:\program files (x86)\common files\apple\apple application support\cfnetwork.dll - Ok
c:\program files (x86)\common files\apple\apple application support\zlib1.dll - Ok
c:\program files (x86)\common files\apple\mobile device support\mobiledevice.dll - Ok
c:\windows\syswow64\wshtcpip.dll - Ok
c:\windows\syswow64\mswsock.dll - Ok
c:\windows\syswow64\dnssd.dll - Ok
c:\program files (x86)\common files\apple\mobile device support\applemobiledeviceservice_main.dll - Ok
c:\program files (x86)\common files\apple\apple application support\asl.dll - Ok
c:\program files (x86)\common files\apple\apple application support\libicuuc.dll - Ok
c:\program files (x86)\common files\apple\apple application support\libicuin.dll - Ok
c:\windows\syswow64\winmm.dll - Ok
c:\program files (x86)\common files\apple\apple application support\libdispatch.dll - Ok
c:\program files (x86)\common files\apple\apple application support\objc.dll - Ok
c:\windows\syswow64\wsock32.dll - Ok
c:\program files (x86)\common files\apple\apple application support\pthreadvc2.dll - Ok
c:\program files (x86)\common files\apple\apple application support\corefoundation.dll - Ok
c:\program files (x86)\common files\apple\apple application support\yscrashdump.dll - Ok
c:\program files (x86)\common files\apple\apple application support\appleversions.dll - Ok
c:\windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.6195_none_d09154e044272b9a\msvcr80.dll - Ok
c:\windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.6195_none_d09154e044272b9a\msvcp80.dll - Ok
c:\windows\syswow64\version.dll - Ok
c:\windows\syswow64\cfgmgr32.dll - Ok
c:\windows\syswow64\api-ms-win-downlevel-version-l1-1-0.dll - Ok
c:\windows\syswow64\ws2_32.dll - Ok
c:\windows\syswow64\iertutil.dll - Ok
c:\windows\syswow64\devobj.dll - Ok
c:\windows\syswow64\api-ms-win-downlevel-normaliz-l1-1-0.dll - Ok
c:\windows\syswow64\normaliz.dll - Ok
c:\windows\syswow64\api-ms-win-downlevel-shlwapi-l1-1-0.dll - Ok
c:\windows\syswow64\setupapi.dll - Ok
c:\windows\syswow64\api-ms-win-downlevel-user32-l1-1-0.dll - Ok
c:\windows\syswow64\api-ms-win-downlevel-advapi32-l1-1-0.dll - Ok
c:\windows\syswow64\wininet.dll - Ok
>c:\windows\syswow64\nsi.dll - packed by FLY-CODE
c:\windows\syswow64\nsi.dll - Ok
c:\windows\syswow64\bthprops.cpl - Ok
c:\windows\syswow64\sxs.dll - Ok
c:\windows\syswow64\rpcrtremote.dll - Ok
c:\windows\syswow64\rsaenh.dll - Ok
c:\windows\syswow64\cryptsp.dll - Ok
c:\windows\winsxs\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2\comctl32.dll - Ok
c:\windows\syswow64\clbcatq.dll - Ok
c:\windows\system32\shfolder.dll - Ok
c:\windows\system32\bthserv.dll - Ok
c:\program files\eset\eset smart security\x86\ekrnparental.dll - Ok
c:\windows\syswow64\mlang.dll - Ok
c:\program files\eset\eset smart security\x86\ekrnsmonengine.dll - Ok
c:\windows\syswow64\rtutils.dll - Ok
c:\windows\syswow64\wship6.dll - Ok
c:\windows\syswow64\rasadhlp.dll - Ok
c:\windows\syswow64\fwpuclnt.dll - Ok
c:\program files (x86)\bonjour\mdnsnsp.dll - Ok
c:\program files (x86)\common files\microsoft shared\windows live\wlidnsp.dll - Ok
c:\windows\syswow64\dnsapi.dll - Ok
c:\windows\syswow64\dhcpcsvc6.dll - Ok
c:\windows\syswow64\dhcpcsvc.dll - Ok
c:\windows\syswow64\wscapi.dll - Ok
c:\windows\syswow64\wscisvif.dll - Ok
c:\windows\syswow64\ntdsapi.dll - Ok
c:\windows\syswow64\slc.dll - Ok
c:\windows\syswow64\atl.dll - Ok
c:\windows\syswow64\hnetcfg.dll - Ok
c:\windows\syswow64\wlanutil.dll - Ok
c:\windows\syswow64\wlanapi.dll - Ok
c:\windows\syswow64\wbem\fastprox.dll - Ok
c:\windows\syswow64\wbem\wbemsvc.dll - Ok
c:\program files\eset\eset smart security\x86\ekrnmailplugins.dll - Ok
c:\program files\eset\eset smart security\x86\updater.dll - Ok
c:\program files\eset\eset smart security\x86\ekrnupdate.dll - Ok
c:\program files\eset\eset smart security\x86\ekrnsmon.dll - Ok
c:\program files\eset\eset smart security\x86\ekrnepfw.dll - Ok
c:\program files\eset\eset smart security\x86\ekrndmon.dll - Ok
c:\program files\eset\eset smart security\x86\ekrnemon.dll - Ok
c:\program files\eset\eset smart security\x86\ekrnamon.dll - Ok
c:\program files\eset\eset smart security\x86\ekrnscan.dll - Ok
c:\program files\eset\eset smart security\x86\ekrnhips.dll - Ok
c:\windows\syswow64\sfc_os.dll - Ok
c:\windows\syswow64\sfc.dll - Ok
c:\windows\syswow64\schedcli.dll - Ok
c:\windows\syswow64\faultrep.dll - Ok
c:\windows\syswow64\msi.dll - Ok
c:\windows\syswow64\rasman.dll - Ok
c:\windows\syswow64\rasapi32.dll - Ok
c:\windows\syswow64\wkscli.dll - Ok
c:\windows\syswow64\srvcli.dll - Ok
>c:\windows\syswow64\netutils.dll - packed by FLY-CODE
c:\windows\syswow64\netutils.dll - Ok
c:\windows\syswow64\netapi32.dll - Ok
c:\windows\syswow64\wer.dll - Ok
c:\windows\syswow64\wbemcomn.dll - Ok
c:\windows\syswow64\wbem\wbemprox.dll - Ok
>c:\windows\syswow64\cryptui.dll - packed by FLY-CODE
c:\windows\syswow64\cryptui.dll - Ok
c:\windows\syswow64\api-ms-win-downlevel-shell32-l1-1-0.dll - Ok
c:\windows\syswow64\api-ms-win-downlevel-advapi32-l2-1-0.dll - Ok
c:\windows\syswow64\api-ms-win-downlevel-shlwapi-l2-1-0.dll - Ok
c:\windows\syswow64\ieframe.dll - Ok
c:\windows\syswow64\mpr.dll - Ok
c:\windows\syswow64\schannel.dll - Ok
c:\windows\syswow64\credssp.dll - Ok
c:\windows\syswow64\gpapi.dll - Ok
>c:\windows\syswow64\secur32.dll - packed by FLY-CODE
c:\windows\syswow64\secur32.dll - Ok
c:\windows\syswow64\webio.dll - Ok
c:\windows\syswow64\winhttp.dll - Ok
c:\windows\syswow64\psapi.dll - Ok
c:\windows\syswow64\urlmon.dll - Ok
c:\windows\syswow64\api-ms-win-downlevel-ole32-l1-1-0.dll - Ok
c:\program files\intel\wifi\bin\s24mudll.dll - Ok
c:\windows\system32\wsock32.dll - Ok
c:\program files\intel\wifi\bin\amtwsman.dll - Ok
c:\program files\intel\wifi\bin\murocapi.dll - Ok
c:\windows\syswow64\ezsvc7x.dll - Ok
c:\windows\winsxs\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7601.18201_none_ec80f00e8593ece5\comctl32.dll - Ok
c:\windows\system32\upnphost.dll - Ok
c:\windows\system32\ssdpsrv.dll - Ok
c:\windows\system32\httpapi.dll - Ok
c:\windows\system32\fdrespub.dll - Ok
>c:\windows\winsxs\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_044aad0bab1eb146\mfc90u.dll is ZLIB container
c:\windows\winsxs\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_044aad0bab1eb146\mfc90u.dll - container
c:\program files (x86)\hewlett-packard\hp quick launch\msvcr100.dll - Ok
c:\program files (x86)\realtek\realtek pcie card reader\rscrlib.dll - Ok
c:\program files (x86)\malwarebytes' anti-malware\mbamnet.dll - Ok
c:\program files (x86)\malwarebytes' anti-malware\mbam.dll - Ok
>c:\program files (x86)\malwarebytes' anti-malware\mbamcore.dll is BINARYRES container
c:\program files (x86)\malwarebytes' anti-malware\mbamcore.dll - container
c:\windows\syswow64\dwmapi.dll - Ok
c:\windows\syswow64\uxtheme.dll - Ok
c:\windows\system32\wiatrace.dll - Ok
c:\windows\system32\wiaservc.dll - Ok
>c:\windows\syswow64\wshbth.dll - packed by FLY-CODE
c:\windows\syswow64\wshbth.dll - Ok
c:\windows\syswow64\winrnr.dll - Ok
c:\windows\syswow64\pnrpnsp.dll - Ok
c:\windows\syswow64\napinsp.dll - Ok
c:\windows\syswow64\nlaapi.dll - Ok
c:\windows\syswow64\propsys.dll - Ok
c:\windows\syswow64\browcli.dll - Ok
c:\windows\syswow64\samcli.dll - Ok
c:\windows\syswow64\d3d8thk.dll - Ok
c:\windows\syswow64\d3d9.dll - Ok
c:\windows\syswow64\magnification.dll - Ok
c:\windows\syswow64\shfolder.dll - Ok
c:\windows\syswow64\sensapi.dll - Ok
c:\windows\syswow64\bcryptprimitives.dll - Ok
c:\windows\syswow64\bcrypt.dll - Ok
c:\windows\syswow64\ncrypt.dll - Ok
>c:\windows\syswow64\msimg32.dll - packed by FLY-CODE
c:\windows\syswow64\msimg32.dll - Ok
c:\windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18120_none_72d2e82386681b36\gdiplus.dll - Ok
c:\windows\syswow64\imagehlp.dll - Ok
c:\program files\common files\microsoft shared\windows live\sqmapi.dll - Ok
c:\program files\intel\wifi\bin\panihvint.dll - Ok
c:\program files\intel\wifi\bin\dbengine.dll - Ok
c:\program files\intel\wifi\bin\pfmgrapi.dll - Ok
c:\program files\intel\wifi\bin\ps7zcfgs.dll - Ok
c:\windows\system32\wbem\wmiprov.dll - Ok
c:\windows\system32\fwremotesvr.dll - Ok
c:\windows\system32\ipsecsvc.dll - Ok
c:\windows\system32\igfxsrvc.dll - Ok
c:\windows\system32\igfxrnld.lrc - Ok
c:\windows\system32\igfxress.dll - Ok
c:\windows\system32\hccutils.dll - Ok
c:\windows\system32\icclibdll_x64.dll - Ok
c:\program files\synaptics\syntp\syntpres.dll - Ok
c:\windows\system32\syncom.dll - Ok
c:\windows\system32\syntpapi.dll - Ok
c:\program files\eset\eset smart security\eguismon.dll - Ok
c:\program files\eset\eset smart security\eguiepfw.dll - Ok
c:\program files\eset\eset smart security\eguihips.dll - Ok
c:\program files\eset\eset smart security\eguiamon.dll - Ok
c:\program files\eset\eset smart security\eguidmon.dll - Ok
c:\program files\eset\eset smart security\eguiemon.dll - Ok
c:\program files\eset\eset smart security\eguiscan.dll - Ok
c:\windows\winsxs\amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.6195_none_88e41e092fab0294\msvcp80.dll - Ok
c:\program files\eset\eset smart security\eguiparental.dll - Ok
c:\program files\eset\eset smart security\eguimailplugins.dll - Ok
c:\program files\eset\eset smart security\eguiupdate.dll - Ok
c:\windows\system32\thumbcache.dll - Ok
c:\program files\idt\wdm\stlang64.dll - Ok
c:\windows\syswow64\dsound.dll - Ok
c:\windows\syswow64\powrprof.dll - Ok
c:\program files (x86)\intel\intel(r) rapid storage technology\iastorcommon.dll - Ok
c:\program files (x86)\intel\intel(r) rapid storage technology\iastorutil.dll - Ok
c:\program files (x86)\intel\intel(r) rapid storage technology\nl-nl\iastoricon.resources.dll - Ok
c:\program files (x86)\intel\intel(r) rapid storage technology\iastoruihelper.dll - Ok
c:\windows\assembly\gac_msil\mscorlib.resources\2.0.0.0_nl_b77a5c561934e089\mscorlib.resources.dll - Ok
c:\program files (x86)\intel\intel(r) rapid storage technology\nl-nl\intelvisualdesign.resources.dll - Ok
c:\windows\assembly\gac_msil\system.runtime.remoting.resources\2.0.0.0_nl_b77a5c561934e089\system.runtime.remoting.resources.dll - Ok
c:\program files (x86)\intel\intel(r) rapid storage technology\intelvisualdesign.dll - Ok
c:\windows\microsoft.net\framework\v2.0.50727\diasymreader.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_32\windowsbase\4eef5a3a4d0ed6d6fd882947a70df530\windowsbase.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_32\system.web\6ebbfafc5521934f7e1c154937a2788b\system.web.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_32\system.runtime.remo#\d473c19e69818875b9c739cad8f386a5\system.runtime.remoting.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_32\iastorcommon\22d36f517c7545fdb65ccddae680a3eb\iastorcommon.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_32\system.xml\439eb22c3f6967beb8a3364626883423\system.xml.ni.dll - Ok
c:\windows\syswow64\windowscodecs.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_32\system.configuration\29f3ae8d313e62b4daed1107ccd29f9f\system.configuration.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_32\system.windows.forms\ef0a534be135cd8f0d99d938d8b1814a\system.windows.forms.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_32\system.drawing\5aa44bce7933e4de09d935848f868a4b\system.drawing.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_32\iastorutil\97ce162bb354fcf9c8d9eae8252ee216\iastorutil.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_32\system\5d22a30e587e2cac106b81fb351e7c08\system.ni.dll - Ok
c:\windows\microsoft.net\framework\v2.0.50727\mscorjit.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_32\mscorlib\9a6c1b7af18b4d5a91dc7f8d6617522f\mscorlib.ni.dll - Ok
c:\windows\microsoft.net\framework\v2.0.50727\mscorwks.dll - Ok
c:\windows\microsoft.net\framework\v4.0.30319\mscoreei.dll - Ok
c:\windows\syswow64\mscoree.dll - Ok
c:\program files (x86)\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.dll - Ok
c:\program files (x86)\hewlett-packard\hp quickweb\hpswmanageddll.dll - Ok
c:\program files (x86)\hewlett-packard\hp quickweb\hp.mobile.shared.dll - Ok
c:\windows\microsoft.net\framework\v2.0.50727\mscorsec.dll - Ok
c:\windows\syswow64\samlib.dll - Ok
c:\windows\syswow64\cryptnet.dll - Ok
c:\windows\syswow64\comdlg32.dll - Ok
c:\windows\syswow64\d3d10warp.dll - Ok
c:\windows\syswow64\mmdevapi.dll - Ok
c:\windows\syswow64\msvcr100.dll - Ok
c:\windows\syswow64\d3d11.dll - Ok
c:\windows\syswow64\dxgi.dll - Ok
c:\windows\syswow64\d2d1.dll - Ok
c:\windows\system32\taskschdps.dll - Ok
c:\windows\syswow64\devenum.dll - Ok
c:\windows\syswow64\msdmo.dll - Ok
c:\program files (x86)\adobe\acrobat 10.0\acrobat\locale\nl_nl\acrotray.nld - Ok
c:\program files (x86)\itunes\ituneshelper.resources\ituneshelper.dll - Ok
c:\program files (x86)\itunes\ituneshelper.resources\nl.lproj\ituneshelperlocalized.dll - Ok
c:\program files (x86)\itunes\ituneshelper.dll - Ok
c:\program files (x86)\common files\apple\mobile device support\itunesmobiledevice.dll - Ok
c:\windows\syswow64\ezupbhook.dll - Ok
c:\program files (x86)\hewlett-packard\shared\hputils.dll - Ok
c:\program files (x86)\microsoft office\office14\grooveex.dll - Ok
c:\windows\syswow64\msxml3.dll - Ok
c:\windows\winsxs\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_51cd0a7abbe4e19b\atl90.dll - Ok
c:\windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\msvcp90.dll - Ok
c:\windows\system32\nlslexicons0013.dll - Ok
c:\windows\system32\nlslexicons0009.dll - Ok
c:\windows\system32\nlslexicons0003.dll - Ok
c:\windows\system32\chtbrkr.dll - Ok
c:\windows\system32\query.dll - Ok
c:\windows\system32\nlsdata0003.dll - Ok
c:\windows\system32\nlsdata0009.dll - Ok
c:\windows\system32\nlsdata0013.dll - Ok
c:\windows\system32\elslad.dll - Ok
c:\windows\system32\nlsdata0000.dll - Ok
c:\windows\system32\naturallanguage6.dll - Ok
c:\windows\system32\chsbrkr.dll - Ok
c:\windows\system32\elscore.dll - Ok
c:\windows\system32\korwbrkr.dll - Ok
c:\windows\system32\mssrch.dll - Ok
c:\windows\system32\msidle.dll - Ok
c:\program files\ipod\bin\ipodservice.resources\ipodservice.dll - Ok
c:\program files\ipod\bin\ipodservice.resources\nl.lproj\ipodservicelocalized.dll - Ok
c:\windows\system32\wmploc.dll - Ok
c:\windows\system32\ntlanman.dll - Ok
c:\windows\system32\msmpeg2enc.dll - Ok
>c:\windows\system32\winsatapi.dll is ZLIB container
c:\windows\system32\winsatapi.dll - container
c:\windows\system32\blackbox.dll - Ok
>c:\windows\system32\wmpmde.dll - packed by PESTUB
c:\windows\system32\wmpmde.dll - Ok
c:\windows\system32\wmpps.dll - Ok
c:\windows\system32\wmp.dll - Ok
c:\windows\system32\devenum.dll - Ok
>c:\windows\system32\drmv2clt.dll is BINARYRES container
>>c:\windows\system32\drmv2clt.dll\data001 is JS-HTML container
c:\windows\system32\drmv2clt.dll - container
c:\windows\system32\davhlpr.dll - Ok
c:\windows\system32\davclnt.dll - Ok
c:\windows\system32\wmdrmdev.dll - Ok
c:\windows\system32\drprov.dll - Ok
c:\program files\common files\microsoft shared\office14\usp10.dll - Ok
c:\program files\common files\microsoft shared\officesoftwareprotectionplatform\osppc.dll - Ok
c:\windows\system32\security.dll - Ok
c:\program files\eset\eset smart security\eplgoutlooksmon.dll - Ok
c:\program files\eset\eset smart security\eplgoutlookemon.dll - Ok
c:\program files\eset\eset smart security\eplgoutlook.dll - Ok
>c:\program files (x86)\intel\bluetooth\btmofficea.dll is ZLIB container
c:\program files (x86)\intel\bluetooth\btmofficea.dll - container
c:\windows\system32\hlink.dll - Ok
c:\program files\microsoft office\office14\proof\mssp7nl.dll - Ok
c:\program files\common files\microsoft shared\proof\mslid.dll - Ok
c:\program files\common files\microsoft shared\office14\msptls.dll - Ok
c:\program files\microsoft office\office14\1043\wwintl.dll - Ok
c:\program files\microsoft office\office14\exsec32.dll - Ok
c:\program files\microsoft office\office14\outlfltr.dll - Ok
>c:\program files\microsoft office\office14\rtfhtml.dll is BINARYRES container
>>c:\program files\microsoft office\office14\rtfhtml.dll\data001 is JS-HTML container
c:\program files\microsoft office\office14\rtfhtml.dll - container
c:\program files\microsoft office\office14\msproof7.dll - Ok
c:\program files\microsoft office\office14\outlmime.dll - Ok
c:\program files\microsoft office\office14\outlph.dll - Ok
c:\program files\microsoft office\office14\omsmain.dll - Ok
c:\windows\system32\idndl.dll - Ok
c:\windows\system32\d3d10warp.dll - Ok
c:\windows\system32\dwrite.dll - Ok
c:\windows\system32\d2d1.dll - Ok
c:\windows\system32\jscript9.dll - Ok
c:\windows\system32\mshtml.dll - Ok
c:\windows\system32\jscript.dll - Ok
>c:\program files\microsoft office\office14\sharepointprovider.dll is ZLIB container
c:\program files\microsoft office\office14\sharepointprovider.dll - container
c:\windows\system32\mscms.dll - Ok
c:\windows\system32\jsproxy.dll - Ok
>c:\program files\microsoft office\office14\1043\umoutlookstrings.dll is ZLIB container
c:\program files\microsoft office\office14\1043\umoutlookstrings.dll - container
>c:\program files\microsoft office\office14\addins\umoutlookaddin.dll is BINARYRES container
c:\program files\microsoft office\office14\addins\umoutlookaddin.dll - container
c:\program files\common files\apple\mobile device support\outlookchangenotifieraddin.dll - Ok
c:\program files\microsoft office\office14\socialconnector.dll - Ok
c:\program files\microsoft office\office14\onbttnol.dll - Ok
c:\program files\microsoft office\office14\1043\omsintl.dll - Ok
c:\program files\common files\system\msmapi\1043\msmapi32.dll - Ok
c:\program files\microsoft office\office14\addins\colleagueimport.dll - Ok
c:\windows\system32\windowscodecsext.dll - Ok
c:\windows\system32\icm32.dll - Ok
c:\program files\microsoft office\office14\msohev.dll - Ok
c:\program files\microsoft office\office14\addins\bcsaddin.dll - Ok
c:\program files\microsoft office\office14\oart.dll - Ok
c:\program files\microsoft office\office14\wwlib.dll - Ok
c:\program files\common files\microsoft shared\office14\msores.dll - Ok
c:\program files\common files\microsoft shared\office14\mso.dll - Ok
c:\program files\microsoft office\office14\gfx.dll - Ok
c:\program files\microsoft office\office14\1043\mapir.dll - Ok
c:\program files\microsoft office\office14\olmapi32.dll - Ok
c:\program files\common files\microsoft shared\office14\riched20.dll - Ok
c:\program files\microsoft office\office14\1043\outllibr.dll - Ok
c:\program files\common files\microsoft shared\office14\1043\msointl.dll - Ok
c:\windows\microsoft.net\framework64\v4.0.30319\mscoreei.dll - Ok
c:\windows\system32\mscoree.dll - Ok
c:\program files\microsoft office\office14\mspst32.dll - Ok
c:\program files\microsoft office\office14\omsxp32.dll - Ok
c:\windows\system32\mapi32.dll - Ok
c:\windows\system32\msimtf.dll - Ok
c:\program files\microsoft office\office14\outlrpc.dll - Ok
>c:\program files\microsoft office\office14\bcsruntime.dll is ZLIB container
c:\program files\microsoft office\office14\bcsruntime.dll - container
c:\program files\microsoft office\office14\1043\bcsruntimeres.dll - Ok
c:\program files\microsoft office\office14\intldate.dll - Ok
c:\program files\microsoft office\office14\contab32.dll - Ok
c:\program files\microsoft office\office14\bcsproxy.dll - Ok
c:\windows\system32\l3codeca.acm - Ok
c:\windows\system32\msadp32.acm - Ok
c:\windows\system32\msgsm32.acm - Ok
c:\windows\system32\msg711.acm - Ok
c:\windows\system32\imaadp32.acm - Ok
c:\windows\system32\p2pgraph.dll - Ok
c:\windows\system32\p2psvc.dll - Ok
c:\windows\system32\pnrpsvc.dll - Ok
c:\windows\system32\drt.dll - Ok
c:\windows\system32\drttransport.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\mom.foundation.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\log.foundation.private.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\log.foundation.implementation.private.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\log.foundation.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\mom.implementation.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\log.foundation.implementation.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\newaem.foundation.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\ccc.implementation.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_64\system.web\ffcb92605ae455c5763d0cf2afa82ed2\system.web.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_64\system.windows.forms\994b9a807cc6fa0c8d1a9ae90ab685ac\system.windows.forms.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_64\system\af0a0b96a02f9925eb84392ee65a5cfa\system.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_64\mscorlib\88744044294787b99dd4a8704ab75a79\mscorlib.ni.dll - Ok
c:\windows\microsoft.net\framework64\v2.0.50727\mscorwks.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_64\system.drawing\868d117286ad259249f31d3fe813d39a\system.drawing.ni.dll - Ok
c:\windows\microsoft.net\framework64\v2.0.50727\mscorjit.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_64\system.runtime.remo#\c3e08d83feb430f44496c4adb55ef007\system.runtime.remoting.ni.dll - Ok
c:\program files\common files\microsoft shared\windows live\wlidcli.dll - Ok
c:\program files\common files\microsoft shared\windows live\wlidprov.dll - Ok
c:\windows\system32\idstore.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.displaysoptions.graphics.runtime.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\aem.plugin.gd.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\aem.plugin.dppe.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.component.runtime.shared.private.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.foundation.xmanifest.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.foundation.private.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.foundation.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\aem.server.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.component.runtime.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\aem.server.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\aem.plugin.reg.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.component.runtime.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\aticccom.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\adl.foundation.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\dem.graphics.i0601.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\dem.graphics.i1010.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\dem.graphics.i0906.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\aem.plugin.source.kit.server.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\aem.plugin.hotkeys.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\aem.plugin.winmessages.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.hotkeyshandling.graphics.runtime.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.caste.fuel.dashboard.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.amdhome.graphics.dashboard.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.powerplaydppe.graphics.dashboard.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.caste.graphics.dashboard.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.caste.platform.dashboard.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\branding\branding.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.crossfirex.graphics.dashboard.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.updatenotification.graphics.dashboard.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\dem.foundation.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\dem.graphics.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\dem.graphics.i0709.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\aem.actions.ccaa.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\resourcemanagement.foundation.private.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\atixclib.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.caste.graphics.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.caste.graphics.dashboard.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.displaysoptions.graphics.dashboard.dll - Ok
c:\windows\system32\atidemgx.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\dem.graphics.i0804.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\coreaudioapi.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.transcode.graphics.runtime.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.hotkeyshandling.graphics.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.amdhome.graphics.runtime.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\dem.graphics.i0702.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.powerplaydppe.graphics.runtime.dll - Ok
c:\windows\system32\atipdl64.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\localization.foundation.private.dll - Ok
>c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.displaysmanager.graphics.dashboard.dll is ZLIB container
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.displaysmanager.graphics.dashboard.dll - container
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.transcode.graphics.dashboard.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.caste.graphics.runtime.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.mmvideo.graphics.runtime.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\dem.graphics.i0712.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.powerxpress.graphics.runtime.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.amdoverdrive.platform.dashboard.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.radeon3d.graphics.runtime.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.updatenotification.graphics.runtime.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.caste.graphics.runtime.shared.private.dll - Ok
c:\windows\assembly\gac_msil\system.windows.forms.resources\2.0.0.0_nl_b77a5c561934e089\system.windows.forms.resources.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.caste.hydravision.dashboard.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.component.client.shared.private.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\aem.plugin.eeu.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.component.client.shared.dll - Ok
c:\windows\assembly\gac_msil\presentationframework.resources\3.0.0.0_nl_31bf3856ad364e35\presentationframework.resources.dll - Ok
c:\windows\assembly\gac_msil\system.resources\2.0.0.0_nl_b77a5c561934e089\system.resources.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.component.dashboard.profilemanager2.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.component.runtime.extension.eeu.dll - Ok
>c:\program files (x86)\ati technologies\ati.ace\core-static\cli.component.dashboard.dll is ZLIB container
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.component.dashboard.dll - container
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.component.dashboard.shared.dll - Ok
>c:\program files (x86)\ati technologies\ati.ace\core-static\cli.component.dashboard.shared.private.dll is ZLIB container
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.component.dashboard.shared.private.dll - container
>c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.powerxpress.graphics.dashboard.dll is ZLIB container
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.powerxpress.graphics.dashboard.dll - container
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.component.eeu.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.mmvideo.graphics.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.displaysoptions.graphics.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.powerplaydppe.graphics.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.powerxpress.graphics.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.updatenotification.graphics.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.radeon3d.graphics.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\dem.graphics.i1011.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.amdhome.graphics.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\dem.graphics.i0710.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.transcode.graphics.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\dem.graphics.i0901.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.caste.fuel.runtime.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.caste.fuel.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.caste.hydravision.runtime.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.caste.hydravision.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\fuel.foundation.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.caste.platform.runtime.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.caste.platform.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.amdoverdrive.platform.runtime.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.amdoverdrive.platform.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.cpuoverdrive.fuel.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.overdrive5.graphics.shared.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\apm.server.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\apm.foundation.dll - Ok
>c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.crossdisplay.graphics.dashboard.dll is ZLIB container
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.crossdisplay.graphics.dashboard.dll - container
>c:\program files (x86)\ati technologies\ati.ace\core-static\resourcemanagement.foundation.implementation.dll is ZLIB container
c:\program files (x86)\ati technologies\ati.ace\core-static\resourcemanagement.foundation.implementation.dll - container
c:\program files (x86)\ati technologies\ati.ace\core-static\localization.foundation.implementation.nl_localization.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.foundation.client.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.aspect.mmvideo.graphics.dashboard.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\cli.combined.graphics.aspects1.dashboard.dll - Ok
c:\windows\system32\igdumd64.dll - Ok
c:\windows\system32\atiumd64.dll - Ok
c:\windows\system32\presentationnative_v0300.dll - Ok
c:\windows\microsoft.net\framework64\v3.0\wpf\wpfgfx_v0300.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_64\system.core\7140611b14c038e25f80544af4f1ab61\system.core.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_64\presentationframewo#\56d7206478a1eb28089a8efbdf921bf2\presentationframework.aero.ni.dll - Ok
c:\windows\system32\d3d9.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_64\windowsformsintegra#\fffa833a307c3ad981d98b81311f2ad3\windowsformsintegration.ni.dll - Ok
c:\windows\system32\msctfui.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_64\presentationframewo#\3f0016119cbaccffc68806e1c91da0fc\presentationframework.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_64\presentationcore\4ea564f9fd06e0fb40a42acf7693b81a\presentationcore.ni.dll - Ok
c:\windows\system32\atiu9p64.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_64\windowsbase\fd08d5ddc926ae51bf653620202e8d19\windowsbase.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_64\system.xml\3975acf49313ceea1280da91f0383480\system.xml.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_64\system.configuration\fed86e49fe95761085bf287f901f5b53\system.configuration.ni.dll - Ok
c:\windows\system32\d3d8thk.dll - Ok
c:\program files\intel\bluetoothhs\usr3ioport.dll - Ok
c:\program files\intel\bluetoothhs\kmmdlplugins\panauthenticator.dll - Ok
c:\program files\intel\bluetoothhs\bthssupplicant.dll - Ok
c:\program files\intel\bluetoothhs\kmmdlplugins\btsupplicantplugin.dll - Ok
c:\windows\assembly\gac_msil\hp.supportframework.servicemanager\7.0.0.1__afd7346f05a57c11\hp.supportframework.servicemanager.dll - Ok
c:\windows\assembly\gac_msil\hp.supportframework.common\7.0.0.1__41bdec5abf54f6dc\hp.supportframework.common.dll - Ok
c:\windows\assembly\gac_msil\system.serviceprocess.resources\2.0.0.0_nl_b03f5f7f11d50a3a\system.serviceprocess.resources.dll - Ok
c:\program files (x86)\hewlett-packard\hp support framework\interop.scheduler.dll - Ok
c:\windows\microsoft.net\framework64\v2.0.50727\mscorsec.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_64\system.runtime.seri#\845e04461d3d879b24c5b0d30947050a\system.runtime.serialization.formatters.soap.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_64\system.serviceproce#\bcdc7d59f3f8ed743115a7e706e6232a\system.serviceprocess.ni.dll - Ok
c:\program files (x86)\intel\intel(r) rapid storage technology\iastordatamgr.dll - Ok
c:\program files (x86)\intel\intel(r) rapid storage technology\isdiinterop.dll - Ok
c:\program files (x86)\intel\intel(r) rapid storage technology\nl-nl\iastordatamgr.resources.dll - Ok
c:\program files (x86)\intel\intel(r) rapid storage technology\isdi.dll - Ok
c:\windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\msvcm90.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_32\isdiinterop\1beb84c27c2edeb38839916524b9df4d\isdiinterop.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_32\iastordatamgr\ce7b44cbfc389c03dcaab2ccfd9b3a93\iastordatamgr.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_32\system.serviceproce#\c664f44617c6a89edcc171fa8596c89d\system.serviceprocess.ni.dll - Ok
c:\windows\assembly\nativeimages_v2.0.50727_32\iastordatamgrsvc\ba8384a1c68e5ac00a24df20c8b0ebde\iastordatamgrsvc.ni.exe - Ok
c:\program files\common files\microsoft shared\officesoftwareprotectionplatform\osppobjs.dll - Ok
>c:\programdata\microsoft\windows defender\definition updates\{38efc0bb-8061-4008-ae6b-0f7cc96d267e}\mpengine.dll is BINARYRES container
c:\programdata\microsoft\windows defender\definition updates\{38efc0bb-8061-4008-ae6b-0f7cc96d267e}\mpengine.dll - container
c:\windows\system32\tdh.dll - Ok
c:\program files\windows defender\mpclient.dll - Ok
c:\program files\windows defender\mpsvc.dll - Ok
c:\program files\windows defender\mprtp.dll - Ok
c:\program files (x86)\intel\intel(r) management engine components\uns\statusstrings.dll - Ok
c:\program files (x86)\intel\intel(r) management engine components\uns\xerces-c_2_7.dll - Ok
c:\program files (x86)\common files\adobe\oobe\pdapp\uwa\logsession.dll - Ok
c:\windows\syswow64\jscript.dll - Ok
c:\program files (x86)\common files\adobe\oobe\pdapp\uwa\updatercore.dll - Ok
c:\windows\syswow64\netprofm.dll - Ok
c:\windows\syswow64\taskschd.dll - Ok
c:\windows\syswow64\jsproxy.dll - Ok
c:\windows\syswow64\npmproxy.dll - Ok
c:\program files (x86)\common files\authentec\trueapi.dll - Ok
c:\program files (x86)\hp simplepass 2012\datamanager.dll - Ok
c:\program files (x86)\hp simplepass 2012\truesuite.autosoftwareupdate.dll - Ok
c:\program files (x86)\common files\authentec\trueotpvalidity.dll - Ok
c:\program files (x86)\hp simplepass 2012\biolayer.dll - Ok
c:\windows\syswow64\credui.dll - Ok
c:\program files (x86)\hp simplepass 2012\tokenmachine.dll - Ok
c:\windows\syswow64\oledlg.dll - Ok
c:\windows\syswow64\winbio.dll - Ok
c:\windows\syswow64\igdumd32.dll - Ok
>c:\program files (x86)\mozilla firefox\xul.dll is BINARYRES container
c:\program files (x86)\mozilla firefox\xul.dll - container
c:\windows\syswow64\mf.dll - Ok
>c:\windows\syswow64\mfplat.dll - packed by FLY-CODE
c:\windows\syswow64\mfplat.dll - Ok
c:\program files (x86)\microsoft office\office14\1043\grooveintlresource.dll - Ok
c:\program files (x86)\common files\microsoft shared\office14\cultures\office.odf - Ok
c:\windows\syswow64\atiumdag.dll - Ok
c:\windows\syswow64\aticfx32.dll - Ok
c:\windows\syswow64\dwrite.dll - Ok
c:\program files (x86)\mozilla firefox\gkmedias.dll - Ok
c:\windows\syswow64\msls31.dll - Ok
c:\windows\syswow64\xmllite.dll - Ok
c:\windows\syswow64\networkexplorer.dll - Ok
c:\program files (x86)\internet explorer\ieproxy.dll - Ok
c:\windows\syswow64\zipfldr.dll - Ok
c:\windows\syswow64\ehstorapi.dll - Ok
c:\windows\syswow64\portabledeviceapi.dll - Ok
c:\windows\syswow64\icm32.dll - Ok
c:\windows\syswow64\searchfolder.dll - Ok
c:\windows\syswow64\wevtapi.dll - Ok
c:\windows\syswow64\wpc.dll - Ok
c:\windows\syswow64\dui70.dll - Ok
c:\program files (x86)\mozilla firefox\mozjs.dll - Ok
c:\windows\syswow64\mscms.dll - Ok
c:\windows\syswow64\structuredquery.dll - Ok
c:\windows\syswow64\audioses.dll - Ok
c:\windows\syswow64\davclnt.dll - Ok
c:\windows\syswow64\ntshrui.dll - Ok
c:\program files (x86)\windows defender\mpoav.dll - Ok
c:\windows\syswow64\ntlanman.dll - Ok
c:\windows\syswow64\mfreadwrite.dll - Ok
c:\windows\syswow64\explorerframe.dll - Ok
c:\windows\syswow64\iconcodecservice.dll - Ok
c:\windows\syswow64\thumbcache.dll - Ok
c:\windows\syswow64\ksuser.dll - Ok
c:\windows\syswow64\davhlpr.dll - Ok
c:\windows\syswow64\ehstorshell.dll - Ok
c:\windows\syswow64\shdocvw.dll - Ok
c:\windows\syswow64\dxva2.dll - Ok
c:\windows\syswow64\linkinfo.dll - Ok
c:\windows\syswow64\duser.dll - Ok
c:\program files (x86)\mozilla firefox\nssckbi.dll - Ok
c:\program files (x86)\mozilla firefox\freebl3.dll - Ok
c:\program files (x86)\mozilla firefox\nssdbm3.dll - Ok
c:\program files (x86)\mozilla firefox\softokn3.dll - Ok
c:\program files (x86)\mozilla firefox\browser\components\browsercomps.dll - Ok
c:\windows\syswow64\dbghelp.dll - Ok
c:\program files (x86)\mozilla firefox\nss3.dll - Ok
c:\program files (x86)\mozilla firefox\msvcp100.dll - Ok
c:\program files (x86)\mozilla firefox\msvcr100.dll - Ok
c:\windows\syswow64\avrt.dll - Ok
c:\program files (x86)\mozilla firefox\mozglue.dll - Ok
c:\windows\syswow64\actxprxy.dll - Ok
c:\windows\syswow64\atiu9pag.dll - Ok
c:\windows\syswow64\drprov.dll - Ok
c:\program files (x86)\mozilla firefox\mozalloc.dll - Ok
c:\windows\syswow64\cscapi.dll - Ok
>c:\windows\syswow64\macromed\flash\npswf32_11_9_900_117.dll - packed by BINARYRES
>>c:\windows\syswow64\macromed\flash\npswf32_11_9_900_117.dll is WISE container
c:\windows\syswow64\macromed\flash\npswf32_11_9_900_117.dll - container
c:\windows\syswow64\dinput8.dll - Ok
c:\windows\apppatch\aclayers.dll - Ok
c:\windows\syswow64\msv1_0.dll - Ok
c:\windows\syswow64\cryptdll.dll - Ok
>c:\users\jan\appdata\local\temp\29a853e8-ed91999a-ef968fba-f9fe4db8\9ucvgoxp.dll is BINARYRES container
>>c:\users\jan\appdata\local\temp\29a853e8-ed91999a-ef968fba-f9fe4db8\9ucvgoxp.dll\data003 - packed by BINARYRES
>>c:\users\jan\appdata\local\temp\29a853e8-ed91999a-ef968fba-f9fe4db8\9ucvgoxp.dll\data004 - packed by BINARYRES
c:\users\jan\appdata\local\temp\29a853e8-ed91999a-ef968fba-f9fe4db8\9ucvgoxp.dll - container
c:\windows\syswow64\pdh.dll - Ok
c:\windows\syswow64\cabinet.dll - Ok
c:\program files\windows defender\mpcmdrun.exe - Ok
c:\windows\system32\wermgr.exe - Ok
c:\windows\system32\sc.exe - Ok
c:\windows\system32\raserver.exe - Ok
c:\windows\system32\powercfg.exe - Ok
c:\windows\system32\gathernetworkinfo.vbs - Ok
c:\windows\ehome\ehprivjob.exe - Ok
c:\windows\system32\defrag.exe - Ok
c:\windows\system32\bthudtask.exe - Ok
c:\windows\system32\aitagent.exe - Ok
c:\windows\system32\appidpolicyconverter.exe - Ok
c:\program files (x86)\hewlett-packard\hp support framework\hpsf.exe - Ok
c:\program files (x86)\apple software update\softwareupdate.exe - Ok
c:\users\jan\appdata\roaming\microsoft\windows\start menu\programs\startup\desktop.ini - Ok
c:\programdata\microsoft\windows\start menu\programs\startup\desktop.ini - Ok
c:\:uxag2ifgyzsucmvt5nkyauhfdt - Ok
c:\:uxag2ifgyzsucmvt5nkyauhfdt:50WjYNYRxNFIztfi8sM - file not found
c:\:uxag2ifgyzsucmvt5nkyauhfdt:UxAG2iFGyZsUCMVt5nkyauhfDt - file not found
c:\:50wjynyrxnfiztfi8sm - Ok
c:\:50wjynyrxnfiztfi8sm:50WjYNYRxNFIztfi8sM - file not found
c:\:50wjynyrxnfiztfi8sm:UxAG2iFGyZsUCMVt5nkyauhfDt - file not found
c:\windows\system32\dshowrdpfilter.dll - Ok
c:\windows\system32\wwanadvui.dll - Ok
c:\windows\system32\dfdwiz.exe - Ok
c:\windows\system32\wabsyncprovider.dll - Ok
c:\windows\system32\shwebsvc.dll - Ok
c:\windows\system32\oobefldr.dll - Ok
c:\windows\system32\stikynot.exe - Ok
c:\windows\system32\sdiageng.dll - Ok
>c:\windows\system32\oobe\msoobeui.dll is ZLIB container
c:\windows\system32\oobe\msoobeui.dll - container
c:\windows\system32\deviceuxres.dll - Ok
c:\windows\system32\apds.dll - Ok
c:\windows\system32\wlanpref.dll - Ok
c:\windows\system32\documentperformanceevents.dll - Ok
c:\windows\system32\magnification.dll - Ok
c:\windows\system32\intl.cpl - Ok
c:\windows\system32\drivers\storport.sys - Ok
c:\windows\system32\connect.dll - Ok
c:\windows\system32\wmphoto.dll - Ok
c:\windows\system32\apilogen.dll - Ok
c:\windows\system32\mfplay.dll - Ok
c:\windows\system32\wisptis.exe - Ok
c:\windows\system32\powercpl.dll - Ok
c:\windows\system32\mssha.dll - Ok
c:\windows\system32\taskmgr.exe - Ok
c:\windows\system32\certpoleng.dll - Ok
c:\windows\system32\msmpeg2vdec.dll - Ok
c:\windows\system32\werfault.exe - Ok
c:\windows\system32\ocsetup.exe - Ok
c:\windows\system32\wsmres.dll - Ok
c:\windows\system32\setupetw.dll - Ok
c:\windows\system32\msdt.exe - Ok
c:\windows\system32\wsqmcons.exe - Ok
c:\program files (x86)\cisco\cisco peap module\ciscoeappeap.dll - Ok
c:\windows\system32\windowspowershell\v1.0\psevents.dll - Ok
c:\windows\system32\powercfg.cpl - Ok
c:\windows\system32\d3d10core.dll - Ok
c:\windows\system32\actioncentercpl.dll - Ok
c:\windows\system32\sdiagprv.dll - Ok
c:\windows\system32\mblctr.exe - Ok
c:\windows\system32\portabledevicestatus.dll - Ok
c:\program files (x86)\cisco\cisco eap-fast module\ciscoeapfast.dll - Ok
c:\windows\system32\uiribbon.dll - Ok
c:\windows\system32\l2nacp.dll - Ok
c:\windows\system32\uiautomationcore.dll - Ok
c:\windows\system32\napipsec.dll - Ok
c:\windows\system32\p2phost.exe - Ok
c:\windows\system32\mp4sdecd.dll - Ok
c:\windows\system32\d3d10level9.dll - Ok
c:\program files (x86)\internet explorer\iedvtool.dll - Ok
c:\program files (x86)\windows media player\wmpnssui.dll - Ok
c:\windows\system32\mcxdriv.dll - Ok
c:\windows\system32\setupcl.exe - Ok
c:\windows\system32\oobe\windeploy.exe - Ok
c:\windows\system32\oobe\oobeldr.exe - Ok
c:\windows\system32\sysprep\sysprep.exe - Ok
c:\windows\system32\oobe\cmisetup.dll - Ok
c:\windows\system32\oobe\audit.exe - Ok
c:\windows\system32\setupugc.exe - Ok
c:\windows\system32\dxpserver.exe - Ok
c:\windows\system32\adsldpc.dll - Ok
c:\windows\system32\display.dll - Ok
c:\windows\system32\netcenter.dll - Ok
c:\windows\system32\wevtfwd.dll - Ok
c:\program files\windows media player\wmpdmccore.dll - Ok
c:\windows\system32\sud.dll - Ok
c:\windows\system32\eqossnap.dll - Ok
c:\windows\system32\themecpl.dll - Ok
c:\program files (x86)\windows media player\wmpmediasharing.dll - Ok
c:\windows\system32\osbaseln.dll - Ok
c:\program files (x86)\cisco\cisco leap module\ciscoeapleap.dll - Ok
c:\windows\system32\rdrleakdiag.exe - Ok
c:\program files (x86)\windows nt\accessories\wordpad.exe - Ok
c:\windows\system32\firewallcontrolpanel.dll - Ok
c:\windows\system32\elshyph.dll - Ok
c:\windows\system32\pcaevts.dll - Ok
c:\windows\system32\racengn.dll - Ok
c:\windows\system32\mfreadwrite.dll - Ok
c:\windows\system32\sdiagschd.dll - Ok
>c:\program files\windows media player\wmpdmc.exe is ZLIB container
c:\program files\windows media player\wmpdmc.exe - container
c:\windows\system32\tsmf.dll - Ok
c:\windows\system32\dxptaskringtone.dll - Ok
c:\windows\system32\appidapi.dll - Ok
c:\windows\system32\wbem\ntevt.dll - Ok
c:\windows\system32\dccw.exe - Ok
c:\windows\system32\usercpl.dll - Ok
c:\program files (x86)\common files\microsoft shared\ink\rtscom.dll - Ok
c:\windows\system32\tzutil.exe - Ok
c:\windows\system32\rpchttp.dll - Ok
c:\windows\system32\dxptasksync.dll - Ok
c:\windows\system32\wlanconn.dll - Ok
c:\windows\system32\mspaint.exe - Ok
c:\windows\system32\oleres.dll - Ok
c:\windows\system32\energy.dll - Ok
c:\windows\system32\wdfres.dll - Ok
c:\windows\system32\diagcpl.dll - Ok
c:\windows\system32\oleaccrc.dll - Ok
c:\windows\system32\displayswitch.exe - Ok
c:\windows\system32\portabledevicesyncprovider.dll - Ok
c:\windows\system32\msdtcvsp1res.dll - Ok
c:\windows\system32\prflbmsg.dll - Ok
>c:\windows\system32\speech\speechux\speechux.dll is ZLIB container
c:\windows\system32\speech\speechux\speechux.dll - container
c:\windows\system32\comres.dll - Ok
c:\windows\system32\actionqueue.dll - Ok
c:\program files (x86)\windows media player\setup_wm.exe - Ok
c:\windows\system32\cttune.exe - Ok
c:\windows\system32\syncinfrastructure.dll - Ok
c:\windows\system32\wusa.exe - Ok
c:\windows\system32\taskbarcpl.dll - Ok
c:\windows\system32\wdc.dll - Ok
c:\windows\system32\pdh.dll - Ok
c:\windows\system32\wpd_ci.dll - Ok
c:\windows\system32\sharemediacpl.dll - Ok
c:\windows\system32\wpc.dll - Ok
c:\windows\syswow64\p2pcollab.dll - Ok
c:\windows\syswow64\netlogon.dll - Ok
c:\windows\syswow64\logoncli.dll - Ok
c:\windows\system32\wlancfg.dll - Ok
c:\windows\system32\wwancfg.dll - Ok
c:\windows\system32\p2pnetsh.dll - Ok
c:\windows\system32\wcnnetsh.dll - Ok
c:\windows\system32\nettrace.dll - Ok
c:\windows\system32\nshipsec.dll - Ok
c:\windows\system32\napmontr.dll - Ok
c:\windows\system32\dot3cfg.dll - Ok
c:\windows\system32\rpcnsh.dll - Ok
c:\windows\system32\hnetmon.dll - Ok
c:\windows\system32\whhelper.dll - Ok
c:\windows\system32\netiohlp.dll - Ok
c:\windows\system32\ifmon.dll - Ok
c:\windows\system32\authfwcfg.dll - Ok
c:\windows\system32\fwcfg.dll - Ok
c:\windows\system32\nshhttp.dll - Ok
c:\windows\system32\wshelper.dll - Ok
c:\windows\system32\dhcpcmonitor.dll - Ok
c:\windows\system32\nshwfp.dll - Ok
c:\windows\system32\rasmontr.dll - Ok
c:\windows\syswow64\wlancfg.dll - Ok
c:\windows\syswow64\p2pnetsh.dll - Ok
c:\windows\syswow64\nshipsec.dll - Ok
c:\windows\syswow64\napmontr.dll - Ok
c:\windows\syswow64\dot3cfg.dll - Ok
c:\windows\syswow64\rpcnsh.dll - Ok
>c:\windows\syswow64\hnetmon.dll - packed by FLY-CODE
c:\windows\syswow64\hnetmon.dll - Ok
c:\windows\syswow64\whhelper.dll - Ok
c:\windows\syswow64\netiohlp.dll - Ok
c:\windows\syswow64\ifmon.dll - Ok
c:\windows\syswow64\authfwcfg.dll - Ok
c:\windows\syswow64\fwcfg.dll - Ok
c:\windows\syswow64\nshhttp.dll - Ok
c:\windows\syswow64\wshelper.dll - Ok
>c:\windows\syswow64\dhcpcmonitor.dll - packed by FLY-CODE
c:\windows\syswow64\dhcpcmonitor.dll - Ok
c:\windows\syswow64\nshwfp.dll - Ok
c:\windows\syswow64\rasmontr.dll - Ok
c:\windows\system32\rasplap.dll - Ok
c:\windows\syswow64\rasplap.dll - Ok
c:\program files\common files\microsoft shared\windows live\wlidcredprov.dll - Ok
c:\program files (x86)\common files\microsoft shared\windows live\wlidcredprov.dll - Ok
c:\windows\system32\certcredprovider.dll - Ok
c:\windows\syswow64\certcredprovider.dll - Ok
c:\windows\system32\biocredprov.dll - Ok
c:\windows\syswow64\biocredprov.dll - Ok
c:\windows\system32\smartcardcredentialprovider.dll - Ok
c:\windows\syswow64\smartcardcredentialprovider.dll - Ok
c:\windows\system32\vaultcredprovider.dll - Ok
>c:\windows\syswow64\authui.dll is ZLIB container
c:\windows\syswow64\authui.dll - container
c:\windows\system32\chkwudrv.dll - Ok
>c:\windows\system32\dfrgui.exe is ZLIB container
c:\windows\system32\dfrgui.exe - container
c:\windows\system32\cleanmgr.exe - Ok
c:\windows\system32\sdclt.exe - Ok
>c:\windows\syswow64\dfrgui.exe is ZLIB container
c:\windows\syswow64\dfrgui.exe - container
c:\windows\syswow64\cleanmgr.exe - Ok
>c:\windows\system32\calc.exe is ZLIB container
c:\windows\system32\calc.exe - container
>c:\windows\syswow64\calc.exe is ZLIB container
c:\windows\syswow64\calc.exe - container
c:\windows\system32\rdpwsx.dll - Ok
c:\windows\system32\rdpcfgex.dll - Ok
c:\windows\system32\osk.exe - Ok
c:\program files (x86)\java\jre7\bin\jabswitch.exe - Ok
c:\windows\system32\narrator.exe - Ok
>c:\windows\system32\magnify.exe is ZLIB container
c:\windows\system32\magnify.exe - container
c:\windows\syswow64\osk.exe - Ok
>c:\windows\syswow64\magnify.exe is ZLIB container
c:\windows\syswow64\magnify.exe - container
c:\windows\system32\wfs.exe - Ok
c:\windows\system32\msicofire.dll - Ok
c:\windows\system32\pnpts.dll - Ok
c:\windows\system32\apphlpdm.dll - Ok
c:\windows\system32\radarrs.dll - Ok
c:\windows\system32\pcadm.dll - Ok
c:\windows\system32\diagperf.dll - Ok
c:\windows\system32\ncryptui.dll - Ok
c:\windows\system32\msobjs.dll - Ok
c:\windows\system32\adtschema.dll - Ok
c:\windows\system32\msaudite.dll - Ok
c:\windows\system32\iassvcs.dll - Ok
c:\windows\system32\vdsvd.dll - Ok
c:\windows\system32\vdsdyn.dll - Ok
c:\windows\system32\vdsbas.dll - Ok
c:\windows\system32\ntprint.dll - Ok
c:\windows\system32\netmsg.dll - Ok
c:\windows\microsoft.net\framework64\v2.0.50727\eventlogmessages.dll - Ok
c:\windows\system32\whealogr.dll - Ok
c:\windows\system32\wbem\win32_tpm.dll - Ok
c:\windows\system32\reagent.dll - Ok
c:\windows\system32\oobe\winsetup.dll - Ok
c:\windows\servicing\cbsmsg.dll - Ok
c:\windows\system32\recovery.dll - Ok
c:\windows\system32\pots.dll - Ok
c:\windows\system32\mdsched.exe - Ok
c:\windows\system32\relpost.exe - Ok
c:\windows\system32\lpksetup.exe - Ok
c:\windows\system32\microsoft-windows-kernel-processor-power-events.dll - Ok
c:\windows\system32\microsoft-windows-kernel-power-events.dll - Ok
c:\windows\system32\microsoft-windows-hal-events.dll - Ok
c:\windows\system32\fms.dll - Ok
c:\windows\system32\fthsvc.dll - Ok
c:\windows\system32\ehstorauthn.exe - Ok
c:\windows\system32\dfdts.dll - Ok
c:\windows\system32\netdiagfx.dll - Ok
c:\windows\system32\cofiredm.dll - Ok
c:\windows\system32\iscsilog.dll - Ok
c:\windows\system32\rtm.dll - Ok
c:\windows\system32\dispci.dll - Ok
c:\windows\system32\dhcpqec.dll - Ok
c:\windows\system32\netevent.dll - Ok
c:\windows\system32\iologmsg.dll - Ok
c:\windows\system32\wshext.dll - Ok
c:\windows\system32\ntvdm64.dll - Ok
c:\windows\microsoft.net\framework64\v4.0.30319\eventlogmessages.dll - Ok
c:\windows\system32\wsepno.dll - Ok
c:\windows\system32\sdengin2.dll - Ok
c:\windows\system32\wat\watux.exe - Ok
c:\program files\common files\microsoft shared\vsto\10.0\vstomessageprovider.dll - Ok
c:\windows\syswow64\msvbvm60.dll - Ok
c:\windows\system32\usbperf.dll - Ok
c:\windows\system32\srcore.dll - Ok
c:\windows\system32\sxproxy.dll - Ok
c:\windows\system32\mprmsg.dll - Ok
c:\windows\system32\msimsg.dll - Ok
c:\windows\system32\xwizards.dll - Ok
c:\windows\system32\winsat.exe - Ok
c:\windows\system32\mciavi32.dll - Ok
c:\windows\system32\mstscax.dll - Ok
c:\windows\system32\rstrtmgr.dll - Ok
c:\windows\system32\msra.exe - Ok
c:\windows\system32\tsworkspace.dll - Ok
c:\windows\system32\perfctrs.dll - Ok
c:\windows\system32\loadperf.dll - Ok
c:\windows\system32\ksproxy.ax - Ok
c:\windows\system32\quartz.dll - Ok
c:\windows\system32\certcli.dll - Ok
c:\windows\system32\dimsroam.dll - Ok
c:\windows\system32\certenroll.dll - Ok
c:\windows\system32\pautoenr.dll - Ok
c:\windows\system32\blbevents.dll - Ok
c:\windows\system32\aeevts.dll - Ok
c:\program files\microsoft office\office14\bcsclient.msg.dll - Ok
c:\windows\system32\locationnotifications.exe - Ok
c:\windows\system32\ulib.dll - Ok
c:\windows\microsoft.net\framework\v2.0.50727\eventlogmessages.dll - Ok
c:\program files\common files\microsoft shared\office14\mssoap30.dll - Ok
c:\windows\microsoft.net\framework64\v4.0.30319\servicemodelevents.dll - Ok
c:\windows\microsoft.net\framework64\v3.0\windows communication foundation\servicemodelevents.dll - Ok
c:\windows\system32\fxsevent.dll - Ok
c:\windows\system32\icardres.dll - Ok
c:\windows\system32\drivers\ati2erec.dll - Ok
c:\windows\microsoft.net\framework64\v2.0.50727\aspnet_rc.dll - Ok
>c:\program files (x86)\hewlett-packard\hp support framework\resources\hpnetworkcheck\hpnetworkcheckpluginx64.dll is BINARYRES container
>>c:\program files (x86)\hewlett-packard\hp support framework\resources\hpnetworkcheck\hpnetworkcheckpluginx64.dll\data037 is ZLIB container
c:\program files (x86)\hewlett-packard\hp support framework\resources\hpnetworkcheck\hpnetworkcheckpluginx64.dll - container
>c:\program files (x86)\hewlett-packard\hp support framework\resources\hpnetworkcheck\hpnetworkcheckplugin.dll is BINARYRES container
>>c:\program files (x86)\hewlett-packard\hp support framework\resources\hpnetworkcheck\hpnetworkcheckplugin.dll\data037 is ZLIB container
c:\program files (x86)\hewlett-packard\hp support framework\resources\hpnetworkcheck\hpnetworkcheckplugin.dll - container
c:\program files (x86)\java\jre7\bin\jp2ssv.dll - Ok
c:\program files\microsoft office\office14\urlredir.dll - Ok
c:\program files (x86)\microsoft office\office14\urlredir.dll - Ok
c:\program files\common files\microsoft shared\windows live\windowslivelogin.dll - Ok
c:\program files (x86)\common files\microsoft shared\windows live\windowslivelogin.dll - Ok
c:\program files (x86)\hp simplepass 2012\x64\iebho.dll - Ok
c:\program files (x86)\hp simplepass 2012\iebho.dll - Ok
c:\program files (x86)\java\jre7\bin\ssv.dll - Ok
c:\program files (x86)\common files\adobe\acrobat\activex\pdfshell.dll - Ok
>c:\program files (x86)\common files\adobe\acrobat\activex\acroiefavclient.dll is BINARYRES container
>>c:\program files (x86)\common files\adobe\acrobat\activex\acroiefavclient.dll\data001 is JS-HTML container
>>c:\program files (x86)\common files\adobe\acrobat\activex\acroiefavclient.dll\data002 is JS-HTML container
>>c:\program files (x86)\common files\adobe\acrobat\activex\acroiefavclient.dll\data003 is JS-HTML container
>>c:\program files (x86)\common files\adobe\acrobat\activex\acroiefavclient.dll\data004 is JS-HTML container
c:\program files (x86)\common files\adobe\acrobat\activex\acroiefavclient.dll - container
c:\program files (x86)\adobe\adobe contribute cs5\plugins\ieplugin\contributeieplugin.dll - Ok
c:\program files\itunes\itunesminiplayer.dll - Ok
c:\program files\winrar\rarext32.dll - Ok
c:\program files\microsoft office\office14\mlshext.dll - Ok
c:\program files\microsoft office\office14\visshe.dll - Ok
c:\program files\microsoft office\office14\onfilter.dll - Ok
c:\program files\microsoft office\office14\msohevi.dll - Ok
>c:\system.sav\util\hprpguard.dll is ZLIB container
c:\system.sav\util\hprpguard.dll - container
c:\program files (x86)\ati technologies\ati.ace\core-static\atiama64.dll - Ok
c:\program files (x86)\windows live\photo gallery\photoviewershimx64.dll - Ok
c:\program files (x86)\windows live\photo gallery\photoviewershim.dll - Ok
c:\program files\common files\microsoft shared\office14\msoshext.dll - Ok
c:\program files (x86)\common files\microsoft shared\office14\msoshext.dll - Ok
c:\program files (x86)\adobe\acrobat 10.0\acrobat\..\acrobat elements\contextmenu64.dll - Ok
c:\program files (x86)\adobe\acrobat 10.0\acrobat elements\contextmenu.dll - Ok
c:\program files\eset\eset smart security\x86\shellext.dll - Ok
c:\program files\microsoft office\office14\olkfstub.dll - Ok
c:\program files (x86)\microsoft office\office14\olkfstub.dll - Ok
c:\program files (x86)\microsoft office\office14\nameext.dll - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\atiacm64.dll - Ok
c:\windows\system32\webcheck.dll - Ok
c:\windows\syswow64\webcheck.dll - Ok
c:\windows\system32\mf.dll - Ok
c:\program files (x86)\windows live\photo gallery\albumdownloadprotocolhandler.dll - Ok
c:\program files (x86)\windows live\mail\mailcomm.dll - Ok
c:\program files (x86)\common files\skype\skype4com.dll - Ok
c:\program files\common files\microsoft shared\help\hxds.dll - Ok
c:\windows\system32\inetcomm.dll - Ok
c:\windows\syswow64\inetcomm.dll - Ok
c:\program files (x86)\windows live\messenger\msgrapp.dll - Ok
c:\windows\system32\itss.dll - Ok
c:\windows\syswow64\itss.dll - Ok
c:\windows\system32\msvidctl.dll - Ok
c:\windows\syswow64\msvidctl.dll - Ok
c:\windows\syswow64\mshtml.dll - Ok
c:\program files\common files\microsoft shared\office14\msoxmlmf.dll - Ok
c:\program files (x86)\common files\microsoft shared\office14\msoxmlmf.dll - Ok
c:\windows\system32\igfxdev.dll - Ok
c:\windows\system32\tasklist.exe - Ok
c:\windows\syswow64\tasklist.exe - Ok
c:\windows\system32\wwansvc.dll - Ok
c:\windows\system32\drivers\wsdprint.sys - Ok
c:\windows\system32\drivers\ws2ifsl.sys - Ok
c:\windows\system32\wpdbusenum.dll - Ok
c:\windows\system32\wpcsvc.dll - Ok
c:\windows\system32\wbem\wmiapsrv.exe - Ok
c:\windows\system32\wbem\wmiaprpl.dll - Ok
c:\program files\windows live\mesh\wlcrasvc.exe - Ok
c:\windows\system32\wsmsvc.dll - Ok
>c:\windows\syswow64\drivers\wimmount.sys - packed by FLY-CODE
c:\windows\syswow64\drivers\wimmount.sys - Ok
c:\windows\system32\wersvc.dll - Ok
c:\windows\system32\wecsvc.dll - Ok
c:\windows\system32\webclnt.dll - Ok
c:\windows\system32\drivers\wd.sys - Ok
c:\windows\system32\wcspluginservice.dll - Ok
c:\windows\system32\wcncsvc.dll - Ok
c:\windows\system32\wbengine.exe - Ok
c:\windows\system32\wat\watadminsvc.exe - Ok
c:\windows\system32\drivers\wacompen.sys - Ok
c:\windows\system32\w32time.dll - Ok
c:\windows\system32\vssvc.exe - Ok
c:\windows\system32\drivers\vsmraid.sys - Ok
c:\windows\system32\drivers\viaide.sys - Ok
c:\windows\system32\drivers\vhdmp.sys - Ok
c:\windows\system32\drivers\vgapnp.sys - Ok
c:\windows\system32\vds.exe - Ok
c:\windows\system32\drivers\usbuhci.sys - Ok
c:\windows\system32\drivers\usbstor.sys - Ok
c:\windows\system32\drivers\usbprint.sys - Ok
c:\windows\system32\drivers\usbohci.sys - Ok
c:\windows\system32\drivers\usbcir.sys - Ok
c:\windows\system32\drivers\usbaapl64.sys - Ok
c:\windows\system32\drivers\umpass.sys - Ok
c:\windows\system32\drivers\uliagpkx.sys - Ok
c:\windows\system32\ui0detect.exe - Ok
c:\windows\system32\drivers\udfs.sys - Ok
c:\windows\system32\drivers\uagp35.sys - Ok
c:\windows\system32\drivers\tsusbgd.sys - Ok
c:\windows\system32\drivers\tsusbflt.sys - Ok
c:\windows\system32\drivers\tssecsrv.sys - Ok
c:\windows\servicing\trustedinstaller.exe - Ok
c:\windows\system32\termsrv.dll - Ok
c:\windows\system32\drivers\tdtcp.sys - Ok
c:\windows\system32\drivers\tdpipe.sys - Ok
c:\windows\system32\tbssvc.dll - Ok
c:\windows\system32\tapisrv.dll - Ok
c:\windows\system32\swprv.dll - Ok
c:\windows\system32\drivers\stexstor.sys - Ok
c:\windows\system32\sstpsvc.dll - Ok
c:\windows\system32\drivers\vstcnxt6.sys - Ok
c:\windows\system32\drivers\vstdpv6.sys - Ok
c:\windows\system32\drivers\vstazl6.sys - Ok
c:\windows\system32\sppuinotify.dll - Ok
c:\windows\system32\sppsvc.exe - Ok
c:\windows\system32\snmptrap.exe - Ok
c:\windows\system32\drivers\smb.sys - Ok
>c:\program files (x86)\skype\updater\updater.exe - packed by UPX
c:\program files (x86)\skype\updater\updater.exe - Ok
c:\windows\system32\drivers\sisraid4.sys - Ok
c:\windows\system32\drivers\sisraid2.sys - Ok
c:\windows\system32\ipnathlp.dll - Ok
c:\windows\system32\drivers\sfloppy.sys - Ok
c:\windows\system32\drivers\sffp_sd.sys - Ok
c:\windows\system32\drivers\sffp_mmc.sys - Ok
c:\windows\system32\drivers\sffdisk.sys - Ok
c:\windows\system32\sessenv.dll - Ok
c:\windows\system32\drivers\sermouse.sys - Ok
c:\windows\system32\drivers\serial.sys - Ok
c:\windows\system32\drivers\serenum.sys - Ok
c:\windows\system32\sensrsvc.dll - Ok
c:\windows\system32\seclogon.dll - Ok
c:\windows\system32\sdrsvc.dll - Ok
c:\windows\system32\drivers\scfilter.sys - Ok
c:\windows\system32\scardsvr.dll - Ok
c:\windows\system32\drivers\sbp2port.sys - Ok
c:\windows\system32\locator.exe - Ok
c:\windows\system32\regsvc.dll - Ok
c:\windows\system32\mprdim.dll - Ok
c:\windows\system32\drivers\rdpwd.sys - Ok
c:\windows\system32\rdpdd.dll - Ok
c:\windows\system32\drivers\rdpbus.sys - Ok
c:\windows\system32\rasmans.dll - Ok
c:\windows\system32\rasauto.dll - Ok
c:\windows\system32\drivers\rasacd.sys - Ok
c:\windows\system32\drivers\qwavedrv.sys - Ok
c:\windows\system32\qwave.dll - Ok
c:\windows\system32\drivers\ql40xx.sys - Ok
c:\windows\system32\drivers\ql2300.sys - Ok
c:\windows\system32\drivers\processr.sys - Ok
c:\windows\system32\pnrpauto.dll - Ok
c:\windows\system32\hpzipm12.dll - Ok
c:\windows\system32\pla.dll - Ok
c:\windows\system32\perfproc.dll - Ok
c:\windows\system32\perfos.dll - Ok
c:\windows\system32\perfnet.dll - Ok
c:\windows\syswow64\perfhost.exe - Ok
c:\windows\system32\perfdisk.dll - Ok
c:\windows\system32\drivers\pcmcia.sys - Ok
c:\windows\system32\drivers\pciide.sys - Ok
c:\windows\system32\drivers\parport.sys - Ok
c:\program files\common files\microsoft shared\source engine\ose.exe - Ok
c:\windows\system32\drivers\ohci1394.sys - Ok
c:\windows\system32\drivers\nv_agp.sys - Ok
c:\windows\system32\drivers\nvstor.sys - Ok
c:\windows\system32\drivers\nvraid.sys - Ok
c:\windows\system32\drivers\nvm62x64.sys - Ok
c:\windows\system32\drivers\nfrd960.sys - Ok
c:\windows\microsoft.net\framework64\v3.0\windows communication foundation\smsvchost.exe - Ok
c:\windows\system32\drivers\ndiscap.sys - Ok
c:\windows\system32\qagentrt.dll - Ok
c:\program files\intel\wifi\bin\pandhcpdns.exe - Ok
c:\windows\system32\drivers\mtconfig.sys - Ok
c:\windows\system32\drivers\mstee.sys - Ok
c:\windows\system32\msscntrs.dll - Ok
c:\windows\system32\drivers\mspqm.sys - Ok
c:\windows\system32\drivers\mspclock.sys - Ok
c:\windows\system32\drivers\mskssrv.sys - Ok
c:\windows\system32\msiexec.exe - Ok
c:\windows\system32\iscsiexe.dll - Ok
c:\windows\system32\drivers\mshidkmdf.sys - Ok
c:\windows\system32\drivers\bridge.sys - Ok
c:\windows\system32\msdtc.exe - Ok
c:\windows\system32\drivers\msdsm.sys - Ok
c:\windows\system32\drivers\mrxdav.sys - Ok
c:\windows\system32\drivers\mpio.sys - Ok
c:\windows\system32\drivers\modem.sys - Ok
c:\program files\microsoft office\office14\groove.exe - Ok
c:\windows\system32\drivers\megasr.sys - Ok
c:\windows\system32\drivers\megasas.sys - Ok
c:\windows\system32\mcx2svc.dll - Ok
c:\windows\system32\drivers\lsi_scsi.sys - Ok
c:\windows\system32\drivers\lsi_sas2.sys - Ok
c:\windows\system32\drivers\lsi_sas.sys - Ok
c:\windows\system32\drivers\lsi_fc.sys - Ok
c:\windows\system32\lltdsvc.dll - Ok
c:\windows\system32\msdtckrm.dll - Ok
c:\windows\system32\drivers\msiscsi.sys - Ok
c:\windows\system32\drivers\isapnp.sys - Ok
c:\windows\system32\drivers\irenum.sys - Ok
c:\windows\system32\drivers\ipnat.sys - Ok
c:\windows\system32\drivers\ipmidrv.sys - Ok
c:\windows\system32\drivers\ipfltdrv.sys - Ok
c:\windows\system32\ipbusenum.dll - Ok
c:\windows\system32\drivers\intelide.sys - Ok
c:\windows\system32\drivers\intelaud.sys - Ok
c:\windows\system32\drivers\iirsp.sys - Ok
c:\windows\microsoft.net\framework64\v3.0\windows communication foundation\infocard.exe - Ok
c:\windows\system32\drivers\iastorv.sys - Ok
c:\windows\system32\drivers\hpsamd.sys - Ok
c:\windows\system32\kmsvc.dll - Ok
c:\windows\system32\drivers\hidir.sys - Ok
c:\windows\system32\drivers\hidbth.sys - Ok
c:\windows\system32\drivers\hidbatt.sys - Ok
c:\windows\system32\drivers\hdaudio.sys - Ok
c:\windows\system32\drivers\hcw85cir.sys - Ok
c:\program files (x86)\wildtangent games\app\gamesappservice.exe - Ok
c:\windows\system32\drivers\gagp30kx.sys - Ok
c:\windows\system32\drivers\fsdepends.sys - Ok
c:\windows\system32\drivers\flpydisk.sys - Ok
c:\windows\system32\drivers\filetrace.sys - Ok
c:\windows\system32\drivers\fdc.sys - Ok
c:\windows\system32\fxssvc.exe - Ok
c:\windows\system32\drivers\exfat.sys - Ok
c:\windows\system32\drivers\errdev.sys - Ok
c:\windows\system32\drivers\elxstor.sys - Ok
c:\windows\ehome\ehsched.exe - Ok
c:\windows\ehome\ehrecvr.exe - Ok
c:\windows\system32\drivers\evbda.sys - Ok
c:\windows\system32\drivers\drmkaud.sys - Ok
c:\windows\system32\dot3svc.dll - Ok
c:\windows\system32\defragsvc.dll - Ok
c:\windows\system32\drivers\crcdisk.sys - Ok
c:\windows\system32\drivers\cmdide.sys - Ok
c:\windows\microsoft.net\framework64\v4.0.30319\mscorsvw.exe - Ok
c:\windows\microsoft.net\framework\v4.0.30319\mscorsvw.exe - Ok
c:\windows\microsoft.net\framework64\v2.0.50727\mscorsvw.exe - Ok
c:\windows\microsoft.net\framework\v2.0.50727\mscorsvw.exe - Ok
c:\windows\system32\drivers\circlass.sys - Ok
c:\windows\system32\certprop.dll - Ok
c:\windows\system32\drivers\cdfs.sys - Ok
c:\windows\system32\drivers\bthmodem.sys - Ok
c:\windows\system32\drivers\brusbser.sys - Ok
c:\windows\system32\drivers\brusbmdm.sys - Ok
c:\windows\system32\drivers\brserwdm.sys - Ok
c:\windows\system32\drivers\brserid.sys - Ok
c:\windows\system32\drivers\brfiltup.sys - Ok
c:\windows\system32\drivers\brfiltlo.sys - Ok
c:\windows\system32\bdesvc.dll - Ok
c:\windows\system32\drivers\bcmwl664.sys - Ok
c:\windows\system32\drivers\b57nd60a.sys - Ok
c:\windows\system32\drivers\bxvbda.sys - Ok
c:\windows\system32\axinstsv.dll - Ok
c:\windows\system32\drivers\arcsas.sys - Ok
c:\windows\system32\drivers\arc.sys - Ok
c:\windows\system32\appidsvc.dll - Ok
c:\windows\system32\drivers\appid.sys - Ok
c:\windows\system32\drivers\amdsbs.sys - Ok
c:\windows\system32\drivers\amdsata.sys - Ok
c:\windows\system32\drivers\amdppm.sys - Ok
c:\windows\system32\drivers\amdk8.sys - Ok
c:\windows\system32\drivers\amdide.sys - Ok
c:\windows\system32\drivers\aliide.sys - Ok
c:\windows\system32\alg.exe - Ok
c:\windows\system32\drivers\agp440.sys - Ok
c:\windows\system32\drivers\adpu320.sys - Ok
c:\windows\system32\drivers\adpahci.sys - Ok
c:\windows\system32\drivers\adp94xx.sys - Ok
c:\windows\syswow64\macromed\flash\flashplayerupdateservice.exe - Ok
c:\windows\system32\drivers\acpipmi.sys - Ok
c:\windows\system32\drivers\1394ohci.sys - Ok
c:\windows\system32\mscories.dll - Ok
c:\windows\system32\ie4uinit.exe - Ok
c:\windows\system32\cmd.exe - Ok
c:\windows\system32\themeui.dll - Ok
c:\windows\system32\regsvr32.exe - Ok
c:\windows\system32\unregmp2.exe - Ok
c:\windows\syswow64\msiexec.exe - Ok
c:\windows\syswow64\mscories.dll - Ok
c:\windows\syswow64\rundll32.exe - Ok
c:\program files (x86)\windows mail\winmail.exe - Ok
c:\windows\syswow64\cmd.exe - Ok
c:\windows\syswow64\themeui.dll - Ok
>c:\windows\syswow64\regsvr32.exe - packed by FLY-CODE
c:\windows\syswow64\regsvr32.exe - Ok
c:\windows\syswow64\unregmp2.exe - Ok
c:\windows\system32\difxapi.dll - Ok
c:\windows\system32\mctadmin.exe - Ok
c:\program files (x86)\hewlett-packard\hp health check\activecheck\product_line\ncpluginupdater.exe - Ok
>c:\users\jan\appdata\roaming\spotify\spotify.exe - packed by FLY-CODE
c:\users\jan\appdata\roaming\spotify\spotify.exe - Ok
c:\program files (x86)\adobe\acrobat 10.0\acrobat\adobecollabsync.exe - Ok
c:\users\jan\appdata\local\google\update\googleupdate.exe - Ok
c:\users\jan\appdata\local\facebook\update\facebookupdate.exe - Ok
c:\program files (x86)\windows live\messenger\msnmsgr.exe - Ok
c:\program files (x86)\windows sidebar\sidebar.exe - Ok
>c:\windows\system32\logilda.dll is BINARYRES container
>>c:\windows\system32\logilda.dll\data001 is JS-HTML container
>>c:\windows\system32\logilda.dll\data002 is JS-HTML container
c:\windows\system32\logilda.dll - container
c:\program files (x86)\common files\adobe\oobe\pdapp\uwa\updaterstartuputility.exe - Ok
c:\program files\microsoft office\office14\bcssync.exe - Ok
c:\program files\hewlett-packard\hp launchbox\setdefault.exe - Ok
c:\program files (x86)\common files\apple\apple application support\apsdaemon.exe - Ok
c:\program files (x86)\adobe\acrobat 10.0\acrobat\acrobat_sl.exe - Ok
c:\program files (x86)\common files\adobe\switchboard\switchboard.exe - Ok
c:\program files (x86)\common files\adobe\cs5servicemanager\cs5servicemanager.exe - Ok
c:\program files (x86)\easybits for kids\ezrecover.exe - Ok
c:\program files (x86)\ati technologies\ati.ace\core-static\clistart.exe - Ok
c:\windows\system32\auditcse.dll - Ok
c:\windows\system32\polstore.dll - Ok
c:\windows\system32\dot3gpclnt.dll - Ok
c:\windows\system32\gpprnext.dll - Ok
c:\windows\system32\iedkcs32.dll - Ok
c:\windows\system32\tsusbredirectiongrouppolicyextension.dll - Ok
c:\windows\system32\gptext.dll - Ok
c:\windows\system32\dskquota.dll - Ok
c:\windows\system32\fdeploy.dll - Ok
c:\windows\syswow64\polstore.dll - Ok
c:\windows\syswow64\dot3gpclnt.dll - Ok
c:\windows\syswow64\gpprnext.dll - Ok
c:\windows\syswow64\scecli.dll - Ok
c:\windows\syswow64\srchadmin.dll - Ok
c:\windows\syswow64\iedkcs32.dll - Ok
c:\windows\syswow64\gptext.dll - Ok
c:\windows\syswow64\dskquota.dll - Ok
c:\windows\syswow64\fdeploy.dll - Ok
c:\windows\syswow64\wlgpclnt.dll - Ok
>c:\windows\system32\macromed\flash\flash64_11_9_900_117.ocx - packed by BINARYRES
>>c:\windows\system32\macromed\flash\flash64_11_9_900_117.ocx is WISE container
c:\windows\system32\macromed\flash\flash64_11_9_900_117.ocx - container
>c:\windows\syswow64\macromed\flash\flash32_11_9_900_117.ocx - packed by BINARYRES
>>c:\windows\syswow64\macromed\flash\flash32_11_9_900_117.ocx is WISE container
c:\windows\syswow64\macromed\flash\flash32_11_9_900_117.ocx - container
c:\program files (x86)\oracle\javafx 2.1 runtime\bin\jp2iexp.dll - Ok
c:\program files (x86)\java\jre7\bin\jp2iexp.dll - Ok
>c:\program files (x86)\quicktime\qtplugin.ocx - packed by BINARYRES
c:\program files (x86)\quicktime\qtplugin.ocx - Ok
c:\program files (x86)\hewlett-packard\hp support framework\resources\hpnetworkcheck\nclauncherfromie.exe - Ok
c:\program files\microsoft office\office14\onbttnielinkednotes.dll - Ok
c:\program files (x86)\microsoft office\office14\onbttnielinkednotes.dll - Ok
>c:\program files\microsoft office\office14\onbttnie.dll is BINARYRES container
>>c:\program files\microsoft office\office14\onbttnie.dll\data001 is JS-HTML container
c:\program files\microsoft office\office14\onbttnie.dll - container
>c:\program files (x86)\microsoft office\office14\onbttnie.dll is BINARYRES container
>>c:\program files (x86)\microsoft office\office14\onbttnie.dll\data001 is JS-HTML container
c:\program files (x86)\microsoft office\office14\onbttnie.dll - container
c:\program files (x86)\windows live\writer\writerbrowserextension.dll - Ok
c:\program files\microsoft office\office14\mlcfg32.cpl - Ok
c:\windows\syswow64\explorer.exe - Ok
c:\windows\system32\userinit.exe - Ok
c:\windows\syswow64\userinit.exe - Ok
c:\windows\system32\vfwwdm32.dll - Ok
c:\windows\system32\tsbyuv.dll - Ok
c:\windows\system32\iyuv_32.dll - Ok
c:\windows\system32\msyuv.dll - Ok
c:\windows\system32\msvidc32.dll - Ok
c:\windows\system32\msrle32.dll - Ok
c:\windows\syswow64\sirenacm.dll - Ok
c:\windows\syswow64\wdmaud.drv - Ok
c:\windows\syswow64\iccvid.dll - Ok
c:\windows\syswow64\l3codeca.acm - Ok
c:\windows\syswow64\tsbyuv.dll - Ok
>c:\windows\syswow64\iyuv_32.dll - packed by FLY-CODE
c:\windows\syswow64\iyuv_32.dll - Ok
c:\windows\syswow64\msyuv.dll - Ok
c:\windows\syswow64\msacm32.drv - Ok
c:\windows\syswow64\midimap.dll - Ok
c:\windows\syswow64\msadp32.acm - Ok
c:\windows\syswow64\msgsm32.acm - Ok
c:\windows\syswow64\msg711.acm - Ok
>c:\windows\syswow64\imaadp32.acm - packed by FLY-CODE
c:\windows\syswow64\imaadp32.acm - Ok
c:\windows\syswow64\msvidc32.dll - Ok
c:\windows\syswow64\msrle32.dll - Ok
C:\Windows\system32\drivers\etc\hosts - probably infected with DFH:HOSTS.corrupted
C:\Windows\system32\drivers\etc\hosts - infected
Process :0 - read error
Process System:4 - read error
Process C:\Windows\System32\smss.exe:364 - Ok
Process C:\Windows\System32\csrss.exe:532 - Ok
Process C:\Windows\System32\wininit.exe:668 - Ok
Process C:\Windows\System32\csrss.exe:692 - Ok
Process C:\Windows\System32\services.exe:752 - Ok
Process C:\Windows\System32\lsass.exe:768 - Ok
Process C:\Windows\System32\lsm.exe:776 - Ok
Process C:\Windows\System32\svchost.exe:880 - Ok
Process C:\Windows\System32\winlogon.exe:932 - Ok
Process C:\Program Files (x86)\HP SimplePass 2012\TrueSuiteService.exe:972 - Ok
Process C:\Windows\System32\svchost.exe:148 - Ok
Process C:\Windows\System32\atiesrxx.exe:548 - Ok
Process C:\Windows\System32\svchost.exe:632 - Ok
Process C:\Windows\System32\svchost.exe:472 - Ok
Process C:\Windows\System32\svchost.exe:696 - Ok
Process C:\Windows\System32\svchost.exe:1028 - Ok
Process C:\Program Files\IDT\WDM\stacsv64.exe:1084 - Ok
Process C:\Windows\System32\hpservice.exe:1336 - Ok
Process C:\Windows\System32\WUDFHost.exe:1400 - Ok
Process C:\Windows\System32\atieclxx.exe:1480 - Ok
Process C:\Windows\System32\dwm.exe:1748 - Ok
Process C:\Windows\explorer.exe:1772 - Ok
Process C:\Windows\System32\svchost.exe:1904 - Ok
Process C:\Windows\System32\wlanext.exe:1988 - Ok
Process C:\Windows\System32\conhost.exe:2008 - Ok
Process C:\Windows\System32\spoolsv.exe:1136 - Ok
Process C:\Windows\System32\taskhost.exe:1316 - Ok
Process C:\Windows\System32\svchost.exe:1600 - Ok
Process C:\Windows\System32\svchost.exe:1728 - Ok
Process C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe:2000 - Ok
Process C:\Program Files\IDT\WDM\AESTSr64.exe:2108 - Ok
Process C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe:2136 - Ok
Process C:\Program Files (x86)\Intel\Bluetooth\devmonsrv.exe:2264 - Ok
Process C:\Program Files\Bonjour\mDNSResponder.exe:2332 - Ok
Process C:\Windows\System32\svchost.exe:2352 - Ok
Process C:\Program Files\ESET\ESET Smart Security\x86\ekrn.exe:2388 - Ok
Process C:\Program Files\Intel\WiFi\bin\EvtEng.exe:2456 - Ok
Process C:\Windows\SysWOW64\ezSharedSvcHost.exe:2480 - Ok
Process C:\Windows\System32\svchost.exe:2528 - Ok
Process C:\Program Files\Hewlett-Packard\HP Client Services\HPClientServices.exe:2628 - Ok
Process C:\Program Files (x86)\Hewlett-Packard\Shared\HPDrvMntSvc.exe:2676 - Ok
Process C:\Program Files (x86)\Hewlett-Packard\HP Quick Launch\HPWMISVC.exe:2700 - Ok
Process C:\Program Files (x86)\Realtek\Realtek PCIE Card Reader\RIconMan.exe:2856 - Ok
Process C:\Program Files (x86)\Intel\Services\IPT\jhi_service.exe:2912 - Ok
Process C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbamscheduler.exe:2936 - Ok
Process C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbamservice.exe:2960 - Ok
Process C:\Program Files\Common Files\Intel\WirelessCommon\RegSrvc.exe:3016 - Ok
Process C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbamgui.exe:1052 - Ok
Process C:\Windows\System32\svchost.exe:1644 - Ok
Process C:\Program Files (x86)\TeamViewer\Version7\TeamViewer_Service.exe:2560 - Ok
Process C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE:2804 - Ok
Process C:\Program Files\Intel\WiFi\bin\ZeroConfigService.exe:3136 - Ok
Process C:\Program Files (x86)\Intel\Bluetooth\obexsrv.exe:3188 - Ok
Process C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVCM.EXE:3232 - Ok
Process C:\Windows\System32\wbem\unsecapp.exe:3328 - Ok
Process C:\Windows\System32\wbem\WmiPrvSE.exe:3348 - Ok
Process C:\Windows\System32\wbem\unsecapp.exe:3624 - Ok
Process C:\Windows\System32\svchost.exe:3808 - Ok
Process C:\Windows\System32\rundll32.exe:4320 - Ok
Process C:\Windows\System32\igfxtray.exe:4564 - Ok
Process C:\Windows\System32\hkcmd.exe:4584 - Ok
Process C:\Windows\System32\igfxpers.exe:4600 - Ok
Process C:\Program Files\Synaptics\SynTP\SynTPEnh.exe:4660 - Ok
Process C:\Windows\System32\rundll32.exe:4692 - Ok
Process C:\Program Files\ESET\ESET Smart Security\egui.exe:4768 - Ok
Process C:\Program Files\Hewlett-Packard\HP LaunchBox\HPTaskBar1.exe:4816 - Ok
Process C:\Program Files\Hewlett-Packard\HP LaunchBox\HPTaskBar2.exe:4848 - Ok
Process C:\Program Files\IDT\WDM\sttray64.exe:4976 - Ok
Process C:\Program Files (x86)\Intel\Bluetooth\mediasrv.exe:4984 - Ok
Process C:\Program Files\Synaptics\SynTP\SynTPHelper.exe:4432 - Ok
Process C:\Users\Jan\AppData\Roaming\Spotify\Data\SpotifyWebHelper.exe:4532 - Ok
Process C:\Program Files (x86)\Intel\Bluetooth\btplayerctrl.exe:5100 - Ok
Process C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe:4444 - Ok
Process C:\Program Files (x86)\Renesas Electronics\USB 3.0 Host Controller Driver\Application\nusb3mon.exe:4008 - Ok
Process C:\Program Files (x86)\Hewlett-Packard\HP QuickWeb\hpqwutils.exe:4740 - Ok
Process C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe:4500 - Ok
Process C:\Program Files (x86)\Hewlett-Packard\HP On Screen Display\HPOSD.exe:1416 - Ok
Process C:\Program Files (x86)\Hewlett-Packard\HP CoolSense\CoolSense.exe:5148 - Ok
Process C:\Program Files (x86)\Hewlett-Packard\Shared\hpqWmiEx.exe:5200 - Ok
Process C:\Windows\System32\taskeng.exe:5468 - Ok
Process C:\Program Files (x86)\CyberLink\YouCam\YCMMirage.exe:5504 - Ok
Process C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\acrotray.exe:5520 - Ok
Process C:\Program Files (x86)\iTunes\iTunesHelper.exe:5544 - Ok
Process C:\Program Files (x86)\Hewlett-Packard\HP Quick Launch\HPMSGSVC.exe:5816 - Ok
Process C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe:5824 - Ok
Process C:\Windows\System32\SearchIndexer.exe:6032 - Ok
Process C:\Program Files\iPod\bin\iPodService.exe:6092 - Ok
Process C:\Program Files\Windows Media Player\wmpnetwk.exe:2448 - Ok
Process C:\Program Files\Microsoft Office\Office14\OUTLOOK.EXE:6444 - Ok
Process C:\Windows\System32\svchost.exe:6700 - Ok
Process C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\MOM.exe:6828 - Ok
Process C:\Windows\System32\dllhost.exe:4024 - Ok
Process C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CCC.exe:3756 - Ok
Process C:\Program Files\Intel\BluetoothHS\BTHSAmpPalService.exe:3028 - Ok
Process C:\Program Files\Intel\BluetoothHS\BTHSSecurityMgr.exe:7128 - Ok
Process C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\HPSA_Service.exe:5880 - Ok
Process C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe:2844 - Ok
Process C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe:6764 - Ok
Process C:\Program Files\Common Files\Microsoft Shared\OfficeSoftwareProtectionPlatform\OSPPSVC.EXE:5904 - Ok
Process C:\Windows\System32\svchost.exe:6540 - Ok
Process C:\Windows\Microsoft.NET\Framework64\v3.0\WPF\PresentationFontCache.exe:5700 - Ok
Process C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\UNS\UNS.exe:3396 - Ok
Process C:\Program Files (x86)\Internet Explorer\ielowutil.exe:4420 - Ok
Process C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\AAM Updates Notifier.exe:544 - Ok
Process C:\Program Files (x86)\HP SimplePass 2012\TouchControl.exe:7252 - Ok
Process C:\Program Files (x86)\HP SimplePass 2012\BioMonitor.exe:7316 - Ok
Process audiodg.exe:4952 - read error
Process C:\Program Files (x86)\Mozilla Firefox\firefox.exe:8220 - Ok
Process C:\Program Files (x86)\Mozilla Firefox\plugin-container.exe:9092 - Ok
Process C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_9_900_117.exe:8968 - Ok
Process C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_9_900_117.exe:8808 - Ok
Process C:\Users\Jan\Desktop\launch.exe:7688 - Ok
Process C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\m01cbbgb.exe:7936 - Ok
Process C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\i4yqhvm6.exe:6484 - Ok
Process C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\mpchg1uj.exe:5868 - Ok
Process C:\Windows\System32\taskeng.exe:4088 - Ok
HDD0 MBR - Ok
HDD0 Partition 1: Active NTFS\exFAT - Ok
HDD0 Partition 2: NTFS\exFAT - Ok
HDD0 Partition 3: NTFS\exFAT - Ok
HDD0 Partition 4: FAT32 LBA - Ok
C:\autoexec.bat - Ok
C:\hiberfil.sys - read error
C:\pagefile.sys - read error
C:\zoek-results.log - Ok
C:\Recovery (D) - Snelkoppeling.lnk - Ok
>C:\settings.ini is JS-HTML container
C:\zoek-results2013-11-04-184047.log - Ok
C:\settings.ini - container
C:\Windows\system32\7B296FB0-376B-497e-B012-9C450E1B7327-5P-1.C7483456-A289-439d-8115-601632D005A0 - Ok
C:\Windows\system32\7B296FB0-376B-497e-B012-9C450E1B7327-5P-0.C7483456-A289-439d-8115-601632D005A0 - Ok
C:\Windows\system32\ACCTRES.dll - Ok
C:\Windows\system32\accelerometerdll.DLL - Ok
C:\bootmgr - Ok
C:\Windows\system32\acproxy.dll - Ok
C:\Windows\system32\acppage.dll - Ok
C:\Windows\system32\aclui.dll - Ok
C:\Windows\system32\ActionQueue.dll - Ok
C:\Windows\system32\acledit.dll - Ok
C:\Windows\system32\ActionCenter.dll - Ok
C:\Windows\system32\ActionCenterCPL.dll - Ok
C:\Windows\system32\AdobePDF.dll - Ok
C:\Windows\system32\activeds.tlb - Ok
C:\Windows\system32\activeds.dll - Ok
C:\Windows\system32\AdapterTroubleshooter.exe - Ok
C:\Windows\system32\adsldpc.dll - Ok
C:\Windows\system32\adprovider.dll - Ok
C:\Windows\system32\adsmsext.dll - Ok
C:\Windows\system32\AdobePDFUI.dll - Ok
C:\Windows\system32\aeevts.dll - Ok
C:\Windows\system32\advpack.dll - Ok
C:\Windows\system32\adsldp.dll - Ok
C:\Windows\system32\aelupsvc.dll - Ok
C:\Windows\system32\adtschema.dll - Ok
C:\Windows\system32\aepic.dll - Ok
C:\Windows\system32\aecache.dll - Ok
C:\Windows\system32\AESTAR64.dll - Ok
C:\Windows\system32\advapi32.dll - Ok
C:\Windows\system32\aepdu.dll - Ok
C:\Windows\system32\adsnt.dll - Ok
C:\Windows\system32\actxprxy.dll - Ok
C:\Windows\system32\aaclient.dll - Ok
C:\Windows\system32\AltTab.dll - Ok
C:\Windows\system32\alg.exe - Ok
C:\Windows\system32\aitagent.exe - Ok
C:\Windows\system32\AESTCo64.dll - Ok
C:\Windows\system32\aeinv.dll - Ok
C:\Windows\system32\amdpcom64.dll - Ok
C:\Windows\system32\accessibilitycpl.dll - Ok
C:\Windows\system32\amstream.dll - Ok
C:\Windows\system32\api-ms-win-core-datetime-l1-1-0.dll - Ok
C:\Windows\system32\AESTAC64.dll - Ok
C:\Windows\system32\amxread.dll - Ok
C:\Windows\system32\api-ms-win-core-debug-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-errorhandling-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-fibers-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-delayload-l1-1-0.dll - Ok
C:\Windows\system32\amcompat.tlb - Ok
C:\Windows\system32\api-ms-win-core-libraryloader-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-io-l1-1-0.dll - Ok
C:\Windows\system32\AESTEC64.dll - Ok
C:\Windows\system32\api-ms-win-core-file-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-handle-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-localization-l1-1-0.dll - Ok
C:\Windows\system32\apds.dll - Ok
C:\Windows\system32\api-ms-win-core-memory-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-processthreads-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-interlocked-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-localregistry-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-profile-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-rtlsupport-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-misc-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-namedpipe-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-processenvironment-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-console-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-util-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-threadpool-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-downlevel-advapi32-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-downlevel-advapi32-l2-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-xstate-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-downlevel-normaliz-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-sysinfo-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-synch-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-downlevel-ole32-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-downlevel-shell32-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-string-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-downlevel-user32-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-downlevel-shlwapi-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-downlevel-shlwapi-l2-1-0.dll - Ok
C:\Windows\system32\api-ms-win-security-base-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-ums-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-core-heap-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-downlevel-version-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-service-core-l1-1-0.dll - Ok
C:\Windows\system32\apisetschema.dll - Ok
C:\Windows\system32\apilogen.dll - Ok
C:\Windows\system32\api-ms-win-security-lsalookup-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-security-sddl-l1-1-0.dll - Ok
C:\Windows\system32\Apphlpdm.dll - Ok
C:\Windows\system32\api-ms-win-service-management-l2-1-0.dll - Ok
C:\Windows\system32\api-ms-win-service-management-l1-1-0.dll - Ok
C:\Windows\system32\api-ms-win-service-winsvc-l1-1-0.dll - Ok
C:\Windows\system32\appidapi.dll - Ok
C:\Windows\system32\appidsvc.dll - Ok
C:\Windows\system32\appidcertstorecheck.exe - Ok
C:\Windows\system32\appinfo.dll - Ok
C:\Windows\system32\asferror.dll - Ok
C:\Windows\system32\appidpolicyconverter.exe - Ok
C:\Windows\system32\ARP.EXE - Ok
C:\Windows\system32\apphelp.dll - Ok
C:\Windows\system32\at.exe - Ok
C:\Windows\system32\asycfilt.dll - Ok
C:\Windows\system32\atiapfxx.blb - Ok
C:\Windows\system32\AtBroker.exe - Ok
C:\Windows\system32\atiadlxx.dll - Ok
C:\Windows\system32\aticalcl64.dll - Ok
C:\Windows\system32\aticalrt64.dll - Ok
C:\Windows\system32\atieclxx.exe - Ok
C:\Windows\system32\aticfx64.dll - Ok
C:\Windows\system32\apss.dll - Ok
C:\Windows\system32\ATIDEMGX.dll - Ok
C:\Windows\system32\atiedu64.dll - Ok
C:\Windows\system32\apircl.dll - Ok
C:\Windows\system32\atig6pxx.dll - Ok
C:\Windows\system32\atidxx64.dll - Ok
C:\Windows\system32\atig6txx.dll - Ok
C:\Windows\system32\atiicdxx.dat - Ok
C:\Windows\system32\atiesrxx.exe - Ok
C:\Windows\system32\atimpc64.dll - Ok
C:\Windows\system32\atipblup.dat - Ok
C:\Windows\system32\atipblag.dat - Ok
C:\Windows\system32\atiu9p64.dll - Ok
C:\Windows\system32\atipdl64.dll - Ok
C:\Windows\system32\atibtmon.exe - Ok
C:\Windows\system32\atiuxp64.dll - Ok
C:\Windows\system32\atimuixx.dll - Ok
C:\Windows\system32\atl.dll - Ok
C:\Windows\system32\atiumd64.dll - Ok
C:\Windows\system32\atiumd6a.cap - Ok
>C:\Windows\system32\atitmm64.dll - packed by PESTUB
C:\Windows\system32\appwiz.cpl - Ok
C:\Windows\system32\atmfd.dll - Ok
C:\Windows\system32\attrib.exe - Ok
C:\Windows\system32\atiapfxx.exe - Ok
C:\Windows\system32\audiodg.exe - Ok
C:\Windows\system32\atmlib.dll - Ok
C:\Windows\system32\atitmm64.dll - Ok
C:\Windows\system32\auditcse.dll - Ok
C:\Windows\system32\AudioEng.dll - Ok
C:\Windows\system32\authfwcfg.dll - Ok
C:\Windows\system32\AudioSes.dll - Ok
C:\Windows\system32\auditpol.exe - Ok
C:\Windows\system32\audiosrv.dll - Ok
C:\Windows\system32\authz.dll - Ok
>C:\Windows\system32\authui.dll is ZLIB container
C:\Windows\system32\autochk.exe - Ok
C:\Windows\system32\authui.dll - container
C:\Windows\system32\atl100.dll - Ok
C:\Windows\system32\amdocl64.dll - Ok
C:\Windows\system32\AuthFWWizFwk.dll - Ok
C:\Windows\system32\AuxiliaryDisplayApi.dll - Ok
C:\Windows\system32\autoplay.dll - Ok
C:\Windows\system32\AuxiliaryDisplayDriverLib.dll - Ok
C:\Windows\system32\AuthFWGP.dll - Ok
C:\Windows\system32\AUDIOKSE.dll - Ok
C:\Windows\system32\AuxiliaryDisplayClassInstaller.dll - Ok
C:\Windows\system32\avicap32.dll - Ok
C:\Windows\system32\avrt.dll - Ok
C:\Windows\system32\atiumd6a.dll - Ok
C:\Windows\system32\avifil32.dll - Ok
C:\Windows\system32\AxInstSv.dll - Ok
C:\Windows\system32\AuxiliaryDisplayServices.dll - Ok
C:\Windows\system32\atiumd6v.dll - Ok
C:\Windows\system32\AzSqlExt.dll - Ok
C:\Windows\system32\basesrv.dll - Ok
C:\Windows\system32\AxInstUI.exe - Ok
C:\Windows\system32\batmeter.dll - Ok
C:\Windows\system32\azman.msc - Ok
C:\Windows\system32\basecsp.dll - Ok
C:\Windows\system32\azroleui.dll - Ok
C:\Windows\system32\batt.dll - Ok
C:\Windows\system32\bcdprov.dll - Ok
C:\Windows\system32\bcrypt.dll - Ok
C:\Windows\system32\bcdboot.exe - Ok
C:\Windows\system32\autoconv.exe - Ok
C:\Windows\system32\azroles.dll - Ok
C:\Windows\system32\aticaldd64.dll - Ok
C:\Windows\system32\bdesvc.dll - Ok
C:\Windows\system32\bcryptprimitives.dll - Ok
C:\Windows\system32\autofmt.exe - Ok
C:\Windows\system32\bderepair.dll - Ok
C:\Windows\system32\AuxiliaryDisplayCpl.dll - Ok
C:\Windows\system32\bidispl.dll - Ok
C:\Windows\system32\bcdsrv.dll - Ok
C:\Windows\system32\bdeui.dll - Ok
C:\Windows\system32\bitsigd.dll - Ok
C:\Windows\system32\bdaplgin.ax - Ok
C:\Windows\system32\BdeUnlockWizard.exe - Ok
C:\Windows\system32\bitsperf.dll - Ok
C:\Windows\system32\BioCredProv.dll - Ok
C:\Windows\system32\BFE.DLL - Ok
C:\Windows\system32\BdeUISrv.exe - Ok
C:\Windows\system32\bitsadmin.exe - Ok
C:\Windows\system32\bitsprx3.dll - Ok
C:\Windows\system32\bcdedit.exe - Ok
C:\Windows\system32\bitsprx6.dll - Ok
C:\Windows\system32\BlbEvents.dll - Ok
C:\Windows\system32\bltinmic.ico - Ok
C:\Windows\system32\bitsprx5.dll - Ok
C:\Windows\system32\blbres.dll - Ok
C:\Windows\system32\blb_ps.dll - Ok
C:\Windows\system32\biocpl.dll - Ok
C:\Windows\system32\bopomofo.uce - Ok
C:\Windows\system32\bootstr.dll - Ok
C:\Windows\system32\BOOTVID.DLL - Ok
C:\Windows\system32\blackbox.dll - Ok
C:\Windows\system32\bitsprx2.dll - Ok
C:\Windows\system32\bootcfg.exe - Ok
>C:\Windows\system32\brcoinst.dll - packed by PESTUB
C:\Windows\system32\browcli.dll - Ok
C:\Windows\system32\boot.sdi - Ok
C:\Windows\system32\bridgeunattend.exe - Ok
C:\Windows\system32\brcoinst.dll - Ok
C:\Windows\system32\browser.dll - Ok
C:\Windows\system32\BthMtpContextHandler.dll - Ok
C:\Windows\system32\bridgeres.dll - Ok
C:\Windows\system32\bthci.dll - Ok
C:\Windows\system32\bthserv.dll - Ok
C:\Windows\system32\brdgcfg.dll - Ok
C:\Windows\system32\bitsprx4.dll - Ok
C:\Windows\system32\bthudtask.exe - Ok
C:\Windows\system32\browseui.dll - Ok
C:\Windows\system32\bthprops.cpl - Ok
C:\Windows\system32\btpanui.dll - Ok
C:\Windows\system32\cabinet.dll - Ok
>C:\Windows\system32\browserchoice.exe is BINARYRES container
C:\Windows\system32\BthpanContextHandler.dll - Ok
>>C:\Windows\system32\browserchoice.exe\data001 is JS-HTML container
C:\Windows\system32\atio6axx.dll - Ok
C:\Windows\system32\bthpanapi.dll - Ok
>>C:\Windows\system32\browserchoice.exe\data002 is JS-HTML container
C:\Windows\system32\cabview.dll - Ok
>C:\Windows\system32\calc.exe is ZLIB container
>>C:\Windows\system32\browserchoice.exe\data003 is JS-HTML container
C:\Windows\system32\BWUnpairElevated.dll - Ok
C:\Windows\system32\Bubbles.scr - Ok
>>C:\Windows\system32\browserchoice.exe\data004 is JS-HTML container
C:\Windows\system32\cacls.exe - Ok
>>C:\Windows\system32\browserchoice.exe\data005 is JS-HTML container
C:\Windows\system32\catsrvps.dll - Ok
C:\Windows\system32\BWContextHandler.dll - Ok
C:\Windows\system32\browserchoice.exe - container
C:\Windows\system32\catsrv.dll - Ok
C:\Windows\system32\capisp.dll - Ok
C:\Windows\system32\cdd.dll - Ok
C:\Windows\system32\capiprovider.dll - Ok
C:\Windows\system32\catsrvut.dll - Ok
C:\Windows\system32\calc.exe - container
>C:\Windows\system32\cero.rs is ZLIB container
C:\Windows\system32\cca.dll - Ok
C:\Windows\system32\certCredProvider.dll - Ok
C:\Windows\system32\cero.rs - container
C:\Windows\system32\CertEnrollCtrl.exe - Ok
C:\Windows\system32\certcli.dll - Ok
C:\Windows\system32\certmgr.msc - Ok
C:\Windows\system32\CertPolEng.dll - Ok
C:\Windows\system32\CertEnrollUI.dll - Ok
C:\Windows\system32\certprop.dll - Ok
C:\Windows\system32\certenc.dll - Ok
C:\Windows\system32\cfgbkend.dll - Ok
C:\Windows\system32\bootres.dll - Ok
C:\Windows\system32\cfgmgr32.dll - Ok
C:\Windows\system32\cewmdm.dll - Ok
C:\Windows\system32\chcp.com - Ok
C:\Windows\system32\chajei.ime - Ok
C:\Windows\system32\CertEnroll.dll - Ok
C:\Windows\system32\chkntfs.exe - Ok
C:\Windows\system32\certreq.exe - Ok
C:\Windows\system32\chkdsk.exe - Ok
C:\Windows\system32\chkwudrv.dll - Ok
C:\Windows\system32\choice.exe - Ok
C:\Windows\system32\charmap.exe - Ok
C:\Windows\system32\chsbrkr.dll - Ok
C:\Windows\system32\CHxReadingStringIME.dll - Ok
C:\Windows\system32\cic.dll - Ok
C:\Windows\system32\chtbrkr.dll - Ok
C:\Windows\system32\certmgr.dll - Ok
C:\Windows\system32\cipher.exe - Ok
C:\Windows\system32\cintlgnt.ime - Ok
C:\Windows\system32\ci.dll - Ok
C:\Windows\system32\CIRCoInst.dll - Ok
C:\Windows\system32\clfsw32.dll - Ok
C:\Windows\system32\cliconfg.exe - Ok
C:\Windows\system32\clfs.sys - Ok
C:\Windows\system32\cliconfg.dll - Ok
C:\Windows\system32\cleanmgr.exe - Ok
C:\Windows\system32\cliconfg.rll - Ok
C:\Windows\system32\clb.dll - Ok
C:\Windows\system32\clbcatq.dll - Ok
C:\Windows\system32\cmdkey.exe - Ok
C:\Windows\system32\clip.exe - Ok
C:\Windows\system32\clusapi.dll - Ok
C:\Windows\system32\cmcfg32.dll - Ok
C:\Windows\system32\cmdl32.exe - Ok
C:\Windows\system32\cmicryptinstall.dll - Ok
C:\Windows\system32\cmd.exe - Ok
C:\Windows\system32\cmifw.dll - Ok
C:\Windows\system32\cmmon32.exe - Ok
C:\Windows\system32\cmlua.dll - Ok
C:\Windows\system32\cmpbk32.dll - Ok
C:\Windows\system32\cmipnpinstall.dll - Ok
C:\Windows\system32\certutil.exe - Ok
>C:\Windows\system32\CNBJMON2.DLL - packed by PESTUB
C:\Windows\system32\cmstplua.dll - Ok
C:\Windows\system32\cngaudit.dll - Ok
C:\Windows\system32\cmutil.dll - Ok
C:\Windows\system32\cmstp.exe - Ok
C:\Windows\system32\cmdial32.dll - Ok
C:\Windows\system32\cnvfat.dll - Ok
C:\Windows\system32\cngprovider.dll - Ok
C:\Windows\system32\cofiredm.dll - Ok
C:\Windows\system32\cofire.exe - Ok
C:\Windows\system32\CNBJMON2.DLL - Ok
C:\Windows\system32\AuthFWSnapin.dll - Ok
C:\Windows\system32\cob-au.rs - Ok
C:\Windows\system32\collab.cpl - Ok
C:\Windows\system32\colbact.dll - Ok
C:\Windows\system32\comcat.dll - Ok
C:\Windows\system32\COLORCNV.DLL - Ok
C:\Windows\system32\coinst.dll - Ok
C:\Windows\system32\comp.exe - Ok
C:\Windows\system32\compact.exe - Ok
C:\Windows\system32\comdlg32.dll - Ok
C:\Windows\system32\colorcpl.exe - Ok
C:\Windows\system32\comres.dll - Ok
C:\Windows\system32\ComputerDefaults.exe - Ok
C:\Windows\system32\comexp.msc - Ok
C:\Windows\system32\comrepl.dll - Ok
C:\Windows\system32\CompMgmtLauncher.exe - Ok
C:\Windows\system32\comsnap.dll - Ok
C:\Windows\system32\conhost.exe - Ok
C:\Windows\system32\connect.dll - Ok
C:\Windows\system32\colorui.dll - Ok
C:\Windows\system32\console.dll - Ok
C:\Windows\system32\convert.exe - Ok
>C:\Windows\system32\cdosys.dll is BINARYRES container
C:\Windows\system32\cdosys.dll - container
C:\Windows\system32\credssp.dll - Ok
C:\Windows\system32\consent.exe - Ok
C:\Windows\system32\compmgmt.msc - Ok
C:\Windows\system32\credui.dll - Ok
C:\Windows\system32\credwiz.exe - Ok
C:\Windows\system32\cryptbase.dll - Ok
C:\Windows\system32\comuid.dll - Ok
C:\Windows\system32\cryptdll.dll - Ok
C:\Windows\system32\control.exe - Ok
C:\Windows\system32\crypt32.dll - Ok
C:\Windows\system32\cryptnet.dll - Ok
C:\Windows\system32\cryptdlg.dll - Ok
C:\Windows\system32\cryptsp.dll - Ok
C:\Windows\system32\correngine.dll - Ok
C:\Windows\system32\cscapi.dll - Ok
C:\Windows\system32\cryptsvc.dll - Ok
C:\Windows\system32\compstui.dll - Ok
C:\Windows\system32\cryptui.dll - Ok
C:\Windows\system32\csrsrv.dll - Ok
C:\Windows\system32\csrss.exe - Ok
C:\Windows\system32\cryptxml.dll - Ok
C:\Windows\system32\cryptext.dll - Ok
C:\Windows\system32\cscript.exe - Ok
C:\Windows\system32\ctfmon.exe - Ok
C:\Windows\system32\C_037.NLS - Ok
C:\Windows\system32\csrr.rs - Ok
C:\Windows\system32\cttune.exe - Ok
C:\Windows\system32\C_10004.NLS - Ok
C:\Windows\system32\cttunesvr.exe - Ok
C:\Windows\system32\C_10000.NLS - Ok
C:\Windows\system32\C_10006.NLS - Ok
C:\Windows\system32\C_10005.NLS - Ok
C:\Windows\system32\C_10007.NLS - Ok
C:\Windows\system32\C_10003.NLS - Ok
C:\Windows\system32\cmncliM.dll - Ok
C:\Windows\system32\C_10010.NLS - Ok
C:\Windows\system32\C_10017.NLS - Ok
C:\Windows\system32\C_10021.NLS - Ok
C:\Windows\system32\C_10029.NLS - Ok
C:\Windows\system32\C_10079.NLS - Ok
C:\Windows\system32\C_10081.NLS - Ok
C:\Windows\system32\C_10082.NLS - Ok
C:\Windows\system32\C_1026.NLS - Ok
C:\Windows\system32\C_1047.NLS - Ok
C:\Windows\system32\C_1140.NLS - Ok
C:\Windows\system32\C_10008.NLS - Ok
C:\Windows\system32\C_1141.NLS - Ok
C:\Windows\system32\C_1142.NLS - Ok
C:\Windows\system32\C_1143.NLS - Ok
C:\Windows\system32\C_1145.NLS - Ok
C:\Windows\system32\C_10001.NLS - Ok
C:\Windows\system32\C_1147.NLS - Ok
C:\Windows\system32\C_1148.NLS - Ok
C:\Windows\system32\C_1149.NLS - Ok
C:\Windows\system32\C_1250.NLS - Ok
C:\Windows\system32\C_1251.NLS - Ok
C:\Windows\system32\C_1252.NLS - Ok
C:\Windows\system32\C_1253.NLS - Ok
C:\Windows\system32\C_1255.NLS - Ok
C:\Windows\system32\C_1144.NLS - Ok
C:\Windows\system32\C_1256.NLS - Ok
C:\Windows\system32\C_1254.NLS - Ok
C:\Windows\system32\C_1146.NLS - Ok
C:\Windows\system32\C_10002.NLS - Ok
C:\Windows\system32\C_1257.NLS - Ok
C:\Windows\system32\C_1258.NLS - Ok
C:\Windows\system32\C_20000.NLS - Ok
C:\Windows\system32\C_20105.NLS - Ok
C:\Windows\system32\C_20001.NLS - Ok
C:\Windows\system32\C_20003.NLS - Ok
C:\Windows\system32\C_20106.NLS - Ok
C:\Windows\system32\C_20107.NLS - Ok
C:\Windows\system32\C_20005.NLS - Ok
C:\Windows\system32\C_20108.NLS - Ok
C:\Windows\system32\C_20127.NLS - Ok
C:\Windows\system32\C_20269.NLS - Ok
C:\Windows\system32\C_20004.NLS - Ok
C:\Windows\system32\C_20273.NLS - Ok
C:\Windows\system32\C_20261.NLS - Ok
C:\Windows\system32\C_20277.NLS - Ok
C:\Windows\system32\C_20278.NLS - Ok
C:\Windows\system32\C_20280.NLS - Ok
C:\Windows\system32\C_20284.NLS - Ok
C:\Windows\system32\C_20285.NLS - Ok
C:\Windows\system32\C_20290.NLS - Ok
C:\Windows\system32\C_20297.NLS - Ok
C:\Windows\system32\C_20420.NLS - Ok
C:\Windows\system32\C_20423.NLS - Ok
C:\Windows\system32\C_20424.NLS - Ok
C:\Windows\system32\C_20833.NLS - Ok
C:\Windows\system32\C_20838.NLS - Ok
C:\Windows\system32\C_20866.NLS - Ok
C:\Windows\system32\C_20871.NLS - Ok
C:\Windows\system32\C_20880.NLS - Ok
C:\Windows\system32\C_20905.NLS - Ok
C:\Windows\system32\C_20924.NLS - Ok
C:\Windows\system32\cscdll.dll - Ok
C:\Windows\system32\C_21025.NLS - Ok
C:\Windows\system32\C_21027.NLS - Ok
C:\Windows\system32\C_20002.NLS - Ok
C:\Windows\system32\C_21866.NLS - Ok
C:\Windows\system32\C_28591.NLS - Ok
C:\Windows\system32\C_1361.NLS - Ok
C:\Windows\system32\C_28592.NLS - Ok
C:\Windows\system32\C_28593.NLS - Ok
C:\Windows\system32\C_20936.NLS - Ok
C:\Windows\system32\C_28594.NLS - Ok
C:\Windows\system32\C_28597.NLS - Ok
C:\Windows\system32\C_28595.NLS - Ok
C:\Windows\system32\C_28596.NLS - Ok
C:\Windows\system32\C_28598.NLS - Ok
C:\Windows\system32\c_28603.nls - Ok
C:\Windows\system32\C_28599.NLS - Ok
C:\Windows\system32\C_500.NLS - Ok
C:\Windows\system32\C_437.NLS - Ok
C:\Windows\system32\C_20949.NLS - Ok
C:\Windows\system32\C_708.NLS - Ok
C:\Windows\system32\C_737.NLS - Ok
C:\Windows\system32\C_720.NLS - Ok
C:\Windows\system32\C_775.NLS - Ok
C:\Windows\system32\C_850.NLS - Ok
C:\Windows\system32\C_855.NLS - Ok
C:\Windows\system32\C_852.NLS - Ok
C:\Windows\system32\C_857.NLS - Ok
C:\Windows\system32\C_20932.NLS - Ok
C:\Windows\system32\C_860.NLS - Ok
C:\Windows\system32\C_858.NLS - Ok
C:\Windows\system32\C_861.NLS - Ok
C:\Windows\system32\C_864.NLS - Ok
C:\Windows\system32\C_862.NLS - Ok
C:\Windows\system32\C_866.NLS - Ok
C:\Windows\system32\C_870.NLS - Ok
C:\Windows\system32\C_863.NLS - Ok
C:\Windows\system32\C_874.NLS - Ok
C:\Windows\system32\C_869.NLS - Ok
C:\Windows\system32\C_28605.NLS - Ok
C:\Windows\system32\C_875.NLS - Ok
C:\Windows\system32\C_932.NLS - Ok
C:\Windows\system32\C_936.NLS - Ok
C:\Windows\system32\C_865.NLS - Ok
C:\Windows\system32\C_950.NLS - Ok
C:\Windows\system32\CPFilters.dll - Ok
C:\Windows\system32\C_IS2022.DLL - Ok
C:\Windows\system32\C_949.NLS - Ok
C:\Windows\system32\d3d10core.dll - Ok
C:\Windows\system32\d2d1.dll - Ok
C:\Windows\system32\C_ISCII.DLL - Ok
C:\Windows\system32\d3d10_1.dll - Ok
C:\Windows\system32\d3d10warp.dll - Ok
C:\Windows\system32\d3d10level9.dll - Ok
C:\Windows\system32\d3d10_1core.dll - Ok
C:\Windows\system32\d3d8thk.dll - Ok
C:\Windows\system32\d3d10.dll - Ok
C:\Windows\system32\davhlpr.dll - Ok
C:\Windows\system32\davclnt.dll - Ok
C:\Windows\system32\dataclen.dll - Ok
C:\Windows\system32\C_G18030.DLL - Ok
C:\Windows\system32\dbnmpntw.dll - Ok
C:\Windows\system32\d3d11.dll - Ok
C:\Windows\system32\comsvcs.dll - Ok
C:\Windows\system32\dbnetlib.dll - Ok
C:\Windows\system32\dbghelp.dll - Ok
C:\Windows\system32\dciman32.dll - Ok
C:\Windows\system32\d3dx10_42.dll - Ok
C:\Windows\system32\dccw.exe - Ok
C:\Windows\system32\DDACLSys.dll - Ok
C:\Windows\system32\d3d9.dll - Ok
C:\Windows\system32\dcomcnfg.exe - Ok
C:\Windows\system32\ddodiag.exe - Ok
C:\Windows\system32\DDOIProxy.dll - Ok
C:\Windows\system32\ddrawex.dll - Ok
C:\Windows\system32\Defrag.exe - Ok
C:\Windows\system32\defragsvc.dll - Ok
C:\Windows\system32\defaultlocationcpl.dll - Ok
C:\Windows\system32\desktop.ini - Ok
C:\Windows\system32\defragproxy.dll - Ok
C:\Windows\system32\devenum.dll - Ok
C:\Windows\system32\dbgeng.dll - Ok
C:\Windows\system32\ddraw.dll - Ok
C:\Windows\system32\DeviceDisplayObjectProvider.exe - Ok
C:\Windows\system32\DeviceEject.exe - Ok
C:\Windows\system32\DeviceDisplayStatusManager.dll - Ok
C:\Windows\system32\DeviceMetadataParsers.dll - Ok
C:\Windows\system32\DeviceCenter.dll - Ok
C:\Windows\system32\deskmon.dll - Ok
C:\Windows\system32\deskadp.dll - Ok
C:\Windows\system32\DevicePairing.dll - Ok
C:\Windows\system32\deskperf.dll - Ok
C:\Windows\system32\DevicePairingProxy.dll - Ok
C:\Windows\system32\DeviceUxRes.dll - Ok
C:\Windows\system32\DevicePairingHandler.dll - Ok
C:\Windows\system32\DevicePairingWizard.exe - Ok
C:\Windows\system32\devrtl.dll - Ok
C:\Windows\system32\DevicePairingFolder.dll - Ok
C:\Windows\system32\desk.cpl - Ok
C:\Windows\system32\comctl32.dll - Ok
C:\Windows\system32\dfdts.dll - Ok
C:\Windows\system32\devobj.dll - Ok
C:\Windows\system32\dhcpcmonitor.dll - Ok
C:\Windows\system32\DFDWiz.exe - Ok
>C:\Windows\system32\dfrgui.exe is ZLIB container
C:\Windows\system32\DfsShlEx.dll - Ok
C:\Windows\system32\dfscli.dll - Ok
C:\Windows\system32\devmgmt.msc - Ok
C:\Windows\system32\dhcpcore.dll - Ok
C:\Windows\system32\d3dx9_32.dll - Ok
C:\Windows\system32\dhcpcsvc.dll - Ok
C:\Windows\system32\dhcpcore6.dll - Ok
C:\Windows\system32\dfrgui.exe - container
C:\Windows\system32\DeviceProperties.exe - Ok
C:\Windows\system32\CardGames.dll - Ok
C:\Windows\system32\dhcpcsvc6.dll - Ok
C:\Windows\system32\DHCPQEC.DLL - Ok
C:\Windows\system32\dhcpsapi.dll - Ok
C:\Windows\system32\dimsjob.dll - Ok
C:\Windows\system32\dialer.exe - Ok
C:\Windows\system32\dimsroam.dll - Ok
C:\Windows\system32\difxapi.dll - Ok
C:\Windows\system32\DiagCpl.dll - Ok
C:\Windows\system32\devmgr.dll - Ok
C:\Windows\system32\dinotify.exe - Ok
C:\Windows\system32\difx64.exe - Ok
C:\Windows\system32\diskcopy.com - Ok
C:\Windows\system32\dinput.dll - Ok
C:\Windows\system32\diantz.exe - Ok
C:\Windows\system32\diskmgmt.msc - Ok
C:\Windows\system32\diagperf.dll - Ok
C:\Windows\system32\dispci.dll - Ok
C:\Windows\system32\diskpart.exe - Ok
C:\Windows\system32\diskcomp.com - Ok
C:\Windows\system32\dispex.dll - Ok
C:\Windows\system32\dinput8.dll - Ok
C:\Windows\system32\dllhost.exe - Ok
C:\Windows\system32\djctq.rs - Ok
C:\Windows\system32\dispdiag.exe - Ok
C:\Windows\system32\DisplaySwitch.exe - Ok
C:\Windows\system32\diskperf.exe - Ok
C:\Windows\system32\Display.dll - Ok
C:\Windows\system32\DDORes.dll - Ok
C:\Windows\system32\dllhst3g.exe - Ok
C:\Windows\system32\dmdskres2.dll - Ok
C:\Windows\system32\djoin.exe - Ok
C:\Windows\system32\Dism.exe - Ok
C:\Windows\system32\dmintf.dll - Ok
C:\Windows\system32\dmloader.dll - Ok
C:\Windows\system32\dmutil.dll - Ok
C:\Windows\system32\dmocx.dll - Ok
C:\Windows\system32\dmdskmgr.dll - Ok
C:\Windows\system32\diskraid.exe - Ok
C:\Windows\system32\dmsynth.dll - Ok
C:\Windows\system32\diskcopy.dll - Ok
C:\Windows\system32\dmusic.dll - Ok
C:\Windows\system32\dmvdsitf.dll - Ok
C:\Windows\system32\dnsext.dll - Ok
C:\Windows\system32\dnscacheugc.exe - Ok
C:\Windows\system32\dns-sd.exe - Ok
C:\Windows\system32\dnsapi.dll - Ok
C:\Windows\system32\dmview.ocx - Ok
C:\Windows\system32\dmdskres.dll - Ok
C:\Windows\system32\DocumentPerformanceEvents.dll - Ok
C:\Windows\system32\dmrc.dll - Ok
C:\Windows\system32\doskey.exe - Ok
C:\Windows\system32\dnscmmc.dll - Ok
C:\Windows\system32\dnsrslvr.dll - Ok
C:\Windows\system32\dot3cfg.dll - Ok
C:\Windows\system32\docprop.dll - Ok
C:\Windows\system32\dot3api.dll - Ok
C:\Windows\system32\dot3dlg.dll - Ok
C:\Windows\system32\dot3gpclnt.dll - Ok
C:\Windows\system32\dnshc.dll - Ok
C:\Windows\system32\dnssd.dll - Ok
C:\Windows\system32\dot3hc.dll - Ok
C:\Windows\system32\dmdlgs.dll - Ok
C:\Windows\system32\dot3svc.dll - Ok
C:\Windows\system32\dpnaddr.dll - Ok
C:\Windows\system32\dpapiprovider.dll - Ok
C:\Windows\system32\dfshim.dll - Ok
C:\Windows\system32\DpiScaling.exe - Ok
C:\Windows\system32\dot3msm.dll - Ok
C:\Windows\system32\dnssdX.dll - Ok
C:\Windows\system32\dpnathlp.dll - Ok
C:\Windows\system32\dpapimig.exe - Ok
C:\Windows\system32\dpnsvr.exe - Ok
C:\Windows\system32\dpnlobby.dll - Ok
C:\Windows\system32\dot3gpui.dll - Ok
C:\Windows\system32\dpnhpast.dll - Ok
C:\Windows\system32\dps.dll - Ok
C:\Windows\system32\dpnhupnp.dll - Ok
C:\Windows\system32\driverquery.exe - Ok
C:\Windows\system32\drprov.dll - Ok
C:\Windows\system32\drttransport.dll - Ok
C:\Windows\system32\dpnet.dll - Ok
C:\Windows\system32\drt.dll - Ok
>C:\Windows\system32\drmv2clt.dll is BINARYRES container
>>C:\Windows\system32\drmv2clt.dll\data001 is JS-HTML container
C:\Windows\system32\drmv2clt.dll - container
C:\Windows\system32\dpx.dll - Ok
C:\Windows\system32\dot3ui.dll - Ok
C:\Windows\system32\dsauth.dll - Ok
C:\Windows\system32\ds32gt.dll - Ok
C:\Windows\system32\drtprov.dll - Ok
C:\Windows\system32\dskquota.dll - Ok
C:\Windows\system32\DShowRdpFilter.dll - Ok
C:\Windows\system32\drvinst.exe - Ok
C:\Windows\system32\dsrole.dll - Ok
C:\Windows\system32\dsdmo.dll - Ok
C:\Windows\system32\dskquoui.dll - Ok
C:\Windows\system32\dssec.dll - Ok
C:\Windows\system32\dswave.dll - Ok
C:\Windows\system32\dssenh.dll - Ok
C:\Windows\system32\dsprop.dll - Ok
C:\Windows\system32\dvdplay.exe - Ok
C:\Windows\system32\dsound.dll - Ok
C:\Windows\system32\dsquery.dll - Ok
>C:\Windows\system32\drvstore.dll - packed by BINARYRES
>>C:\Windows\system32\drvstore.dll - packed by MS COMPRESS
C:\Windows\system32\drmmgrtn.dll - Ok
C:\Windows\system32\drvstore.dll - Ok
C:\Windows\system32\dui70.dll - Ok
C:\Windows\system32\dwm.exe - Ok
C:\Windows\system32\dwmapi.dll - Ok
C:\Windows\system32\dwmredir.dll - Ok
C:\Windows\system32\dsuiext.dll - Ok
C:\Windows\system32\dtsh.dll - Ok
C:\Windows\system32\dvdupgrd.exe - Ok
C:\Windows\system32\duser.dll - Ok
C:\Windows\system32\dxmasf.dll - Ok
C:\Windows\system32\dwmcore.dll - Ok
C:\Windows\system32\dxpps.dll - Ok
C:\Windows\system32\DWrite.dll - Ok
C:\Windows\system32\dxgi.dll - Ok
C:\Windows\system32\DXP.dll - Ok
C:\Windows\system32\DWWIN.EXE - Ok
C:\Windows\system32\Dxpserver.exe - Ok
C:\Windows\system32\DxpTaskSync.dll - Ok
C:\Windows\system32\DXPTaskRingtone.dll - Ok
C:\Windows\system32\dxdiag.exe - Ok
C:\Windows\system32\eappcfg.dll - Ok
C:\Windows\system32\Eap3Host.exe - Ok
C:\Windows\system32\dxva2.dll - Ok
C:\Windows\system32\eappprxy.dll - Ok
C:\Windows\system32\eapphost.dll - Ok
C:\Windows\system32\dxdiagn.dll - Ok
C:\Windows\system32\eapsvc.dll - Ok
C:\Windows\system32\efslsaext.dll - Ok
C:\Windows\system32\dxtrans.dll - Ok
C:\Windows\system32\efssvc.dll - Ok
C:\Windows\system32\efsui.exe - Ok
C:\Windows\system32\eappgnui.dll - Ok
C:\Windows\system32\efsutil.dll - Ok
C:\Windows\system32\efscore.dll - Ok
C:\Windows\system32\EhStorAPI.dll - Ok
C:\Windows\system32\ELSCore.dll - Ok
C:\Windows\system32\efsadu.dll - Ok
C:\Windows\system32\EhStorAuthn.exe - Ok
C:\Windows\system32\elsTrans.dll - Ok
C:\Windows\system32\elshyph.dll - Ok
C:\Windows\system32\EhStorShell.dll - Ok
C:\Windows\system32\elslad.dll - Ok
C:\Windows\system32\dxtmsft.dll - Ok
C:\Windows\system32\EhStorPwdMgr.dll - Ok
C:\Windows\system32\eapp3hst.dll - Ok
C:\Windows\system32\encapi.dll - Ok
C:\Windows\system32\EAPQEC.DLL - Ok
C:\Windows\system32\eqossnap.dll - Ok
C:\Windows\system32\dssec.dat - Ok
C:\Windows\system32\energy.dll - Ok
C:\Windows\system32\EncDump.dll - Ok
>C:\Windows\system32\EventViewer_EventDetails.xsl is JS-HTML container
C:\Windows\system32\esentprf.dll - Ok
C:\Windows\system32\esentutl.exe - Ok
C:\Windows\system32\eventcreate.exe - Ok
C:\Windows\system32\EventViewer_EventDetails.xsl - container
C:\Windows\system32\EncDec.dll - Ok
>C:\Windows\system32\esrb.rs is ZLIB container
C:\Windows\system32\es.dll - Ok
C:\Windows\system32\eventvwr.exe - Ok
C:\Windows\system32\esrb.rs - container
C:\Windows\system32\eudcedit.exe - Ok
C:\Windows\system32\extrac32.exe - Ok
C:\Windows\system32\els.dll - Ok
C:\Windows\system32\f3ahvoas.dll - Ok
C:\Windows\system32\esent.dll - Ok
C:\Windows\system32\fdPHost.dll - Ok
C:\Windows\system32\fdeploy.dll - Ok
C:\Windows\system32\fdBthProxy.dll - Ok
C:\Windows\system32\fdPnp.dll - Ok
>C:\Windows\system32\expand.exe - packed by BINARYRES
C:\Windows\system32\eventvwr.msc - Ok
>>C:\Windows\system32\expand.exe - packed by MS COMPRESS
C:\Windows\system32\fdProxy.dll - Ok
C:\Windows\system32\expand.exe - Ok
C:\Windows\system32\FDResPub.dll - Ok
C:\Windows\system32\ExplorerFrame.dll - Ok
C:\Windows\system32\fdSSDP.dll - Ok
C:\Windows\system32\Faultrep.dll - Ok
C:\Windows\system32\fdWNet.dll - Ok
C:\Windows\system32\eventcls.dll - Ok
C:\Windows\system32\fde.dll - Ok
C:\Windows\system32\fdWSD.dll - Ok
C:\Windows\system32\find.exe - Ok
C:\Windows\system32\evr.dll - Ok
C:\Windows\system32\feclient.dll - Ok
C:\Windows\system32\fdWCN.dll - Ok
C:\Windows\system32\finger.exe - Ok
C:\Windows\system32\findstr.exe - Ok
C:\Windows\system32\fdBth.dll - Ok
C:\Windows\system32\fixmapi.exe - Ok
C:\Windows\system32\findnetprinters.dll - Ok
C:\Windows\system32\Firewall.cpl - Ok
C:\Windows\system32\FM20ENU.DLL - Ok
C:\Windows\system32\fdprint.dll - Ok
C:\Windows\system32\fltMC.exe - Ok
C:\Windows\system32\FirewallControlPanel.dll - Ok
C:\Windows\system32\fc.exe - Ok
C:\Windows\system32\fmifs.dll - Ok
C:\Windows\system32\FM20NLD.DLL - Ok
C:\Windows\system32\fms.dll - Ok
C:\Windows\system32\fltLib.dll - Ok
C:\Windows\system32\FirewallAPI.dll - Ok
C:\Windows\system32\fpb.rs - Ok
C:\Windows\system32\framebuf.dll - Ok
C:\Windows\system32\FntCache.dll - Ok
C:\Windows\system32\forfiles.exe - Ok
C:\Windows\system32\format.com - Ok
C:\Windows\system32\framedyn.dll - Ok
C:\Windows\system32\fphc.dll - Ok
C:\Windows\system32\framedynos.dll - Ok
C:\Windows\system32\FNTCACHE.DAT - Ok
C:\Windows\system32\fthsvc.dll - Ok
C:\Windows\system32\fsmgmt.msc - Ok
>C:\Windows\system32\fontext.dll - packed by BINARYRES
C:\Windows\system32\fundisc.dll - Ok
>>C:\Windows\system32\fontext.dll - packed by MS COMPRESS
C:\Windows\system32\fvecerts.dll - Ok
C:\Windows\system32\fontext.dll - Ok
C:\Windows\system32\fveapi.dll - Ok
C:\Windows\system32\fsutil.exe - Ok
C:\Windows\system32\fveapibase.dll - Ok
C:\Windows\system32\ftp.exe - Ok
C:\Windows\system32\FwRemoteSvr.dll - Ok
C:\Windows\system32\fwcfg.dll - Ok
C:\Windows\system32\fontview.exe - Ok
C:\Windows\system32\fvenotify.exe - Ok
C:\Windows\system32\fsquirt.exe - Ok
C:\Windows\system32\fveprompt.exe - Ok
C:\Windows\system32\fveRecover.dll - Ok
C:\Windows\system32\FXSAPI.dll - Ok
C:\Windows\system32\FXSEVENT.dll - Ok
C:\Windows\system32\fveui.dll - Ok
C:\Windows\system32\FWPUCLNT.DLL - Ok
C:\Windows\system32\FXSCOMPOSERES.dll - Ok
C:\Windows\system32\FXSMON.dll - Ok
C:\Windows\system32\FXSCOM.dll - Ok
C:\Windows\system32\FXSCOVER.exe - Ok
C:\Windows\system32\FXSSVC.exe - Ok
C:\Windows\system32\fontsub.dll - Ok
C:\Windows\system32\FXSST.dll - Ok
C:\Windows\system32\FXSROUTE.dll - Ok
C:\Windows\system32\FXSUNATD.exe - Ok
C:\Windows\system32\FXSCOMEX.dll - Ok
C:\Windows\system32\FXSRESM.dll - Ok
C:\Windows\system32\FXSCOMPOSE.dll - Ok
C:\Windows\system32\g711codc.ax - Ok
C:\Windows\system32\gacinstall.dll - Ok
C:\Windows\system32\FXST30.dll - Ok
C:\Windows\system32\gb2312.uce - Ok
C:\Windows\system32\FXSUTILITY.dll - Ok
C:\Windows\system32\filemgmt.dll - Ok
C:\Windows\system32\FXSTIFF.dll - Ok
C:\Windows\system32\gcdef.dll - Ok
C:\Windows\system32\gdi32.dll - Ok
C:\Windows\system32\GettingStarted.exe - Ok
C:\Windows\system32\Gfxres.ar-SA.resources - Ok
C:\Windows\system32\Gfxres.da-DK.resources - Ok
C:\Windows\system32\getuname.dll - Ok
C:\Windows\system32\getmac.exe - Ok
C:\Windows\system32\FM20.DLL - Ok
C:\Windows\system32\Gfxres.es-ES.resources - Ok
C:\Windows\system32\Gfxres.en-US.resources - Ok
C:\Windows\system32\Gfxres.fr-FR.resources - Ok
C:\Windows\system32\Gfxres.he-IL.resources - Ok
C:\Windows\system32\Gfxres.hr-HR.resources - Ok
C:\Windows\system32\Gfxres.hu-HU.resources - Ok
C:\Windows\system32\Gfxres.fi-FI.resources - Ok
C:\Windows\system32\Gfxres.it-IT.resources - Ok
C:\Windows\system32\Gfxres.ja-JP.resources - Ok
C:\Windows\system32\GEARAspi64.dll - Ok
C:\Windows\system32\Gfxres.nb-NO.resources - Ok
C:\Windows\system32\Gfxres.el-GR.resources - Ok
C:\Windows\system32\Gfxres.cs-CZ.resources - Ok
C:\Windows\system32\Gfxres.nl-NL.resources - Ok
C:\Windows\system32\Gfxres.pt-BR.resources - Ok
C:\Windows\system32\Gfxres.ro-RO.resources - Ok
C:\Windows\system32\Gfxres.pl-PL.resources - Ok
C:\Windows\system32\Gfxres.pt-PT.resources - Ok
C:\Windows\system32\Gfxres.ko-KR.resources - Ok
C:\Windows\system32\Gfxres.sl-SI.resources - Ok
C:\Windows\system32\Gfxres.de-DE.resources - Ok
C:\Windows\system32\Gfxres.zh-CN.resources - Ok
C:\Windows\system32\Gfxres.ru-RU.resources - Ok
C:\Windows\system32\Gfxres.zh-TW.resources - Ok
C:\Windows\system32\gameux.dll - Ok
C:\Windows\system32\GfxUI.exe.config - Ok
C:\Windows\system32\Gfxres.sv-SE.resources - Ok
C:\Windows\system32\Gfxres.th-TH.resources - Ok
C:\Windows\system32\Gfxres.sk-SK.resources - Ok
C:\Windows\system32\Gfxres.tr-TR.resources - Ok
C:\Windows\system32\gptext.dll - Ok
C:\Windows\system32\gpprnext.dll - Ok
C:\Windows\system32\gpapi.dll - Ok
C:\Windows\system32\gfxSrvc.dll - Ok
C:\Windows\system32\gpupdate.exe - Ok
C:\Windows\system32\grpconv.exe - Ok
C:\Windows\system32\grb.rs - Ok
C:\Windows\system32\gatherNetworkInfo.vbs - Ok
C:\Windows\system32\gpresult.exe - Ok
C:\Windows\system32\glmf32.dll - Ok
C:\Windows\system32\Groupinghc.dll - Ok
C:\Windows\system32\hcproviders.dll - Ok
C:\Windows\system32\hccutils.dll - Ok
C:\Windows\system32\gpsvc.dll - Ok
C:\Windows\system32\hbaapi.dll - Ok
C:\Windows\system32\hal.dll - Ok
C:\Windows\system32\hdwwiz.exe - Ok
C:\Windows\system32\help.exe - Ok
C:\Windows\system32\glu32.dll - Ok
C:\Windows\system32\hid.dll - Ok
C:\Windows\system32\hgprint.dll - Ok
C:\Windows\system32\hhsetup.dll - Ok
C:\Windows\system32\hidserv.dll - Ok
C:\Windows\system32\hdwwiz.cpl - Ok
C:\Windows\system32\hnetmon.dll - Ok
C:\Windows\system32\hgcpl.dll - Ok
C:\Windows\system32\hlink.dll - Ok
C:\Windows\system32\HelpPaneProxy.dll - Ok
C:\Windows\system32\hpbeats.ico - Ok
C:\Windows\system32\HOSTNAME.EXE - Ok
C:\Windows\system32\hkcmd.exe - Ok
C:\Windows\system32\hnetcfg.dll - Ok
C:\Windows\system32\HotStartUserAgent.dll - Ok
C:\Windows\system32\gpedit.dll - Ok
C:\Windows\system32\hidphone.tsp - Ok
C:\Windows\system32\HPBMINI.DLL - Ok
C:\Windows\system32\HPEACLHN.HPI - Ok
C:\Windows\system32\hhctrl.ocx - Ok
C:\Windows\system32\HPBOIDPS.DLL - Ok
C:\Windows\system32\hotplug.dll - Ok
C:\Windows\system32\HPBPRO.DLL - Ok
C:\Windows\system32\HPBOID.DLL - Ok
C:\Windows\system32\hpservice.exe - Ok
C:\Windows\system32\HPMDPCoInst12.dll - Ok
C:\Windows\system32\HPBPROPS.DLL - Ok
C:\Windows\system32\HP_ActiveX_Patch_NOT_DETECTED.txt - Ok
C:\Windows\system32\HPZIPM12.DLL - Ok
C:\Windows\system32\HPBMIAPI.DLL - Ok
C:\Windows\system32\HPZIPR12.DLL - Ok
C:\Windows\system32\HPZISN12.DLL - Ok
C:\Windows\system32\httpapi.dll - Ok
C:\Windows\system32\htui.dll - Ok
C:\Windows\system32\HPZIPT12.DLL - Ok
C:\Windows\system32\ias.dll - Ok
C:\Windows\system32\iasacct.dll - Ok
C:\Windows\system32\HPMUIDir.exe - Ok
C:\Windows\system32\iasads.dll - Ok
C:\Windows\system32\html.iec - Ok
C:\Windows\system32\iaspolcy.dll - Ok
C:\Windows\system32\iasdatastore.dll - Ok
C:\Windows\system32\iashlpr.dll - Ok
C:\Windows\system32\HPZIDR12.DLL - Ok
C:\Windows\system32\HPZINW12.DLL - Ok
C:\Windows\system32\iasnap.dll - Ok
C:\Windows\system32\iassvcs.dll - Ok
C:\Windows\system32\icaapi.dll - Ok
C:\Windows\system32\iasrad.dll - Ok
C:\Windows\system32\icardres.dll - Ok
C:\Windows\system32\icardie.dll - Ok
C:\Windows\system32\iasrecst.dll - Ok
C:\Windows\system32\iassam.dll - Ok
C:\Windows\system32\icacls.exe - Ok
>C:\Windows\system32\IasMigPlugin.dll is BINARYRES container
C:\Windows\system32\IconCodecService.dll - Ok
C:\Windows\system32\IccLibDll_x64.dll - Ok
C:\Windows\system32\HPToneCtrls64.dll - Ok
C:\Windows\system32\icm32.dll - Ok
C:\Windows\system32\icmui.dll - Ok
C:\Windows\system32\iassdo.dll - Ok
C:\Windows\system32\IasMigPlugin.dll - container
C:\Windows\system32\ideograf.uce - Ok
C:\Windows\system32\icsunattend.exe - Ok
C:\Windows\system32\icfupgd.dll - Ok
C:\Windows\system32\idndl.dll - Ok
C:\Windows\system32\icmp.dll - Ok
C:\Windows\system32\icsigd.dll - Ok
C:\Windows\system32\IDStore.dll - Ok
C:\Windows\system32\IdListen.dll - Ok
C:\Windows\system32\ie4uinit.exe - Ok
C:\Windows\system32\icrav03.rat - Ok
C:\Windows\system32\iedkcs32.dll - Ok
C:\Windows\system32\IDTNJ.exe - Ok
C:\Windows\system32\ieframe.dll - Ok
C:\Windows\system32\ieapfltr.dll - Ok
C:\Windows\system32\iernonce.dll - Ok
C:\Windows\system32\iepeers.dll - Ok
C:\Windows\system32\iesetup.dll - Ok
C:\Windows\system32\IEAdvpack.dll - Ok
C:\Windows\system32\iertutil.dll - Ok
C:\Windows\system32\icardagt.exe - Ok
C:\Windows\system32\ieuinit.inf - Ok
C:\Windows\system32\ifmon.dll - Ok
C:\Windows\system32\iexpress.exe - Ok
C:\Windows\system32\ifsutil.dll - Ok
C:\Windows\system32\iesysprep.dll - Ok
C:\Windows\system32\ifsutilx.dll - Ok
C:\Windows\system32\igd10umd64.dll - Ok
C:\Windows\system32\ieapfltr.dat - Ok
C:\Windows\system32\IDTNX.dll - Ok
C:\Windows\system32\igdumd64.dll - Ok
C:\Windows\system32\igcompkrng600.bin - Ok
C:\Windows\system32\igfcg600m.bin - Ok
C:\Windows\system32\ieui.dll - Ok
C:\Windows\system32\igdDiag.dll - Ok
C:\Windows\system32\igfxdev.dll - Ok
C:\Windows\system32\igfxcmrt64.dll - Ok
C:\Windows\system32\IDTNC64.cpl - Ok
C:\Windows\system32\igdde64.dll - Ok
C:\Windows\system32\IGFXDEVLib.dll - Ok
C:\Windows\system32\igfxpers.exe - Ok
C:\Windows\system32\igfxext.exe - Ok
C:\Windows\system32\igfxcpl.cpl - Ok
C:\Windows\system32\igfxexps.dll - Ok
C:\Windows\system32\igfxrara.lrc - Ok
C:\Windows\system32\igfxpph.dll - Ok
C:\Windows\system32\igfxrcht.lrc - Ok
C:\Windows\system32\ieUnatt.exe - Ok
C:\Windows\system32\igfxrcsy.lrc - Ok
C:\Windows\system32\igfxrdeu.lrc - Ok
C:\Windows\system32\igfxrdan.lrc - Ok
C:\Windows\system32\igfxrchs.lrc - Ok
C:\Windows\system32\igfxress.dll - Ok
C:\Windows\system32\igfxrfra.lrc - Ok
C:\Windows\system32\igfxrheb.lrc - Ok
C:\Windows\system32\igfxrell.lrc - Ok
C:\Windows\system32\igfxresn.lrc - Ok
C:\Windows\system32\igfxrfin.lrc - Ok
C:\Windows\system32\igfxrenu.lrc - Ok
C:\Windows\system32\igfxdo.dll - Ok
C:\Windows\system32\igfxrnld.lrc - Ok
C:\Windows\system32\igfxrhun.lrc - Ok
C:\Windows\system32\igfxrptb.lrc - Ok
C:\Windows\system32\igfxrhrv.lrc - Ok
C:\Windows\system32\igfxrita.lrc - Ok
C:\Windows\system32\igfxrnor.lrc - Ok
C:\Windows\system32\igfxrplk.lrc - Ok
C:\Windows\system32\igfxrjpn.lrc - Ok
C:\Windows\system32\igfxrptg.lrc - Ok
C:\Windows\system32\igfxrsve.lrc - Ok
C:\Windows\system32\igfxrrom.lrc - Ok
C:\Windows\system32\igfxrtrk.lrc - Ok
C:\Windows\system32\igfxsrvc.dll - Ok
C:\Windows\system32\igfxrrus.lrc - Ok
C:\Windows\system32\igfxrsky.lrc - Ok
C:\Windows\system32\igfxrslv.lrc - Ok
C:\Windows\system32\igfxrtha.lrc - Ok
C:\Windows\system32\igfxtray.exe - Ok
C:\Windows\system32\igfxrkor.lrc - Ok
C:\Windows\system32\iglhxa64.vp - Ok
C:\Windows\system32\igfxsrvc.exe - Ok
C:\Windows\system32\iglhxc64.vp - Ok
C:\Windows\system32\iglhxg64.vp - Ok
C:\Windows\system32\iglhxo64.vp - Ok
C:\Windows\system32\iglhxs64.vp - Ok
C:\Windows\system32\imaadp32.acm - Ok
C:\Windows\system32\igkrng600.bin - Ok
C:\Windows\system32\iglhsip64.dll - Ok
C:\Windows\system32\igfxTMM.dll - Ok
C:\Windows\system32\GameUXLegacyGDFs.dll - Ok
C:\Windows\system32\iglhcp64.dll - Ok
C:\Windows\system32\IKEEXT.DLL - Ok
C:\Windows\system32\imagehlp.dll - Ok
C:\Windows\system32\imapi2.dll - Ok
C:\Windows\system32\imgutil.dll - Ok
C:\Windows\system32\iglhxa64.cpa - Ok
C:\Windows\system32\imm32.dll - Ok
C:\Windows\system32\imapi.dll - Ok
C:\Windows\system32\imkr80.ime - Ok
C:\Windows\system32\inetcomm.dll - Ok
C:\Windows\system32\imagesp1.dll - Ok
C:\Windows\system32\IMJP10K.DLL - Ok
C:\Windows\system32\IMJP10.IME - Ok
C:\Windows\system32\inetmib1.dll - Ok
C:\Windows\system32\inetpp.dll - Ok
C:\Windows\system32\ig4icd64.dll - Ok
C:\Windows\system32\infocardcpl.cpl - Ok
C:\Windows\system32\InfDefaultInstall.exe - Ok
C:\Windows\system32\INETRES.dll - Ok
C:\Windows\system32\InstallPackage_ETW.Log - Ok
C:\Windows\system32\input.dll - Ok
C:\Windows\system32\IntcDAuC.dll - Ok
C:\Windows\system32\inetppui.dll - Ok
C:\Windows\system32\InkEd.dll - Ok
C:\Windows\system32\iologmsg.dll - Ok
C:\Windows\system32\IPBusEnum.dll - Ok
C:\Windows\system32\imapi2fs.dll - Ok
C:\Windows\system32\intl.cpl - Ok
C:\Windows\system32\IPHLPAPI.DLL - Ok
C:\Windows\system32\inseng.dll - Ok
C:\Windows\system32\infocardapi.dll - Ok
C:\Windows\system32\iphlpsvc.dll - Ok
C:\Windows\system32\ipnathlp.dll - Ok
C:\Windows\system32\iprtprio.dll - Ok
C:\Windows\system32\iprtrmgr.dll - Ok
C:\Windows\system32\ipconfig.exe - Ok
C:\Windows\system32\IPBusEnumProxy.dll - Ok
C:\Windows\system32\IPSECSVC.DLL - Ok
C:\Windows\system32\irclass.dll - Ok
C:\Windows\system32\GfxUI.exe - Ok
C:\Windows\system32\irmon.dll - Ok
C:\Windows\system32\ipsmsnap.dll - Ok
C:\Windows\system32\irftp.exe - Ok
C:\Windows\system32\iscsicpl.exe - Ok
C:\Windows\system32\iscsiexe.dll - Ok
C:\Windows\system32\iscsidsc.dll - Ok
C:\Windows\system32\iscsilog.dll - Ok
C:\Windows\system32\iscsium.dll - Ok
C:\Windows\system32\iscsied.dll - Ok
C:\Windows\system32\isoburn.exe - Ok
C:\Windows\system32\itss.dll - Ok
C:\Windows\system32\ipsecsnp.dll - Ok
C:\Windows\system32\itircl.dll - Ok
C:\Windows\system32\iscsiwmi.dll - Ok
C:\Windows\system32\iyuv_32.dll - Ok
C:\Windows\system32\jdns_sd.dll - Ok
C:\Windows\system32\iscsicli.exe - Ok
C:\Windows\system32\iscsicpl.dll - Ok
C:\Windows\system32\iwmssvc.dll - Ok
C:\Windows\system32\jsproxy.dll - Ok
C:\Windows\system32\inetcpl.cpl - Ok
C:\Windows\system32\irprops.cpl - Ok
C:\Windows\system32\kanji_2.uce - Ok
C:\Windows\system32\kanji_1.uce - Ok
C:\Windows\system32\iTVData.dll - Ok
C:\Windows\system32\kbd101a.dll - Ok
C:\Windows\system32\kbd101c.dll - Ok
C:\Windows\system32\kbd101b.dll - Ok
C:\Windows\system32\joy.cpl - Ok
C:\Windows\system32\kbd103.dll - Ok
C:\Windows\system32\kbd106n.dll - Ok
C:\Windows\system32\kbd106.dll - Ok
C:\Windows\system32\imageres.dll - Ok
C:\Windows\system32\KBDA2.DLL - Ok
C:\Windows\system32\KBDA1.DLL - Ok
C:\Windows\system32\kbd101.dll - Ok
C:\Windows\system32\jscript.dll - Ok
C:\Windows\system32\KBDAL.DLL - Ok
C:\Windows\system32\KBDA3.DLL - Ok
C:\Windows\system32\jscript9.dll - Ok
C:\Windows\system32\KBDBENE.DLL - Ok
C:\Windows\system32\KBDARME.DLL - Ok
C:\Windows\system32\KBDAZEL.DLL - Ok
C:\Windows\system32\kbdax2.dll - Ok
C:\Windows\system32\KBDBGPH1.DLL - Ok
C:\Windows\system32\KBDBASH.DLL - Ok
C:\Windows\system32\KBDARMW.DLL - Ok
C:\Windows\system32\KBDAZE.DLL - Ok
C:\Windows\system32\KBDBHC.DLL - Ok
C:\Windows\system32\KBDBGPH.DLL - Ok
C:\Windows\system32\KBDBULG.DLL - Ok
C:\Windows\system32\KBDCA.DLL - Ok
C:\Windows\system32\KBDBU.DLL - Ok
C:\Windows\system32\KBDCR.DLL - Ok
C:\Windows\system32\KBDBE.DLL - Ok
C:\Windows\system32\KBDCZ2.DLL - Ok
C:\Windows\system32\KBDDA.DLL - Ok
C:\Windows\system32\KBDDIV2.DLL - Ok
C:\Windows\system32\KBDDV.DLL - Ok
C:\Windows\system32\KBDDIV1.DLL - Ok
C:\Windows\system32\KBDES.DLL - Ok
C:\Windows\system32\KBDBR.DLL - Ok
C:\Windows\system32\KBDBLR.DLL - Ok
C:\Windows\system32\KBDFA.DLL - Ok
C:\Windows\system32\KBDFI.DLL - Ok
C:\Windows\system32\KBDFC.DLL - Ok
C:\Windows\system32\KBDCZ1.DLL - Ok
C:\Windows\system32\KBDCZ.DLL - Ok
C:\Windows\system32\KBDGAE.DLL - Ok
C:\Windows\system32\KBDFR.DLL - Ok
C:\Windows\system32\KBDFO.DLL - Ok
C:\Windows\system32\KBDGEO.DLL - Ok
C:\Windows\system32\kbdgeoqw.dll - Ok
C:\Windows\system32\kbdgeoer.dll - Ok
C:\Windows\system32\KBDFI1.DLL - Ok
C:\Windows\system32\KBDGKL.DLL - Ok
C:\Windows\system32\KBDGRLND.DLL - Ok
C:\Windows\system32\KBDHAU.DLL - Ok
C:\Windows\system32\KBDGR1.DLL - Ok
C:\Windows\system32\KBDGR.DLL - Ok
C:\Windows\system32\KBDHE.DLL - Ok
C:\Windows\system32\KBDHELA3.DLL - Ok
C:\Windows\system32\KBDHE319.DLL - Ok
C:\Windows\system32\KBDHELA2.DLL - Ok
C:\Windows\system32\KBDHEB.DLL - Ok
C:\Windows\system32\KBDHEPT.DLL - Ok
C:\Windows\system32\KBDCAN.DLL - Ok
C:\Windows\system32\KBDHE220.DLL - Ok
C:\Windows\system32\kbdibm02.dll - Ok
C:\Windows\system32\KBDIBO.DLL - Ok
C:\Windows\system32\KBDEST.DLL - Ok
C:\Windows\system32\KBDINBE1.DLL - Ok
C:\Windows\system32\KBDINBE2.DLL - Ok
C:\Windows\system32\KBDINASA.DLL - Ok
C:\Windows\system32\KBDIC.DLL - Ok
C:\Windows\system32\KBDHU1.DLL - Ok
C:\Windows\system32\KBDINBEN.DLL - Ok
C:\Windows\system32\KBDINMAL.DLL - Ok
C:\Windows\system32\KBDINGUJ.DLL - Ok
C:\Windows\system32\KBDINDEV.DLL - Ok
C:\Windows\system32\KBDINORI.DLL - Ok
C:\Windows\system32\KBDINEN.DLL - Ok
C:\Windows\system32\KBDHU.DLL - Ok
C:\Windows\system32\KBDINMAR.DLL - Ok
C:\Windows\system32\KBDIR.DLL - Ok
C:\Windows\system32\KBDINUK2.DLL - Ok
C:\Windows\system32\KBDIT142.DLL - Ok
C:\Windows\system32\KBDINKAN.DLL - Ok
C:\Windows\system32\KBDINTEL.DLL - Ok
C:\Windows\system32\KBDKAZ.DLL - Ok
C:\Windows\system32\KBDIULAT.DLL - Ok
C:\Windows\system32\KBDINPUN.DLL - Ok
C:\Windows\system32\KBDIT.DLL - Ok
C:\Windows\system32\KBDINHIN.DLL - Ok
C:\Windows\system32\KBDKOR.DLL - Ok
C:\Windows\system32\KBDKHMR.DLL - Ok
C:\Windows\system32\KBDINTAM.DLL - Ok
C:\Windows\system32\KBDLT.DLL - Ok
C:\Windows\system32\KBDLAO.DLL - Ok
C:\Windows\system32\KBDKYR.DLL - Ok
C:\Windows\system32\KBDLA.DLL - Ok
C:\Windows\system32\KBDLV.DLL - Ok
C:\Windows\system32\KBDLT1.DLL - Ok
C:\Windows\system32\KBDMACST.DLL - Ok
C:\Windows\system32\KBDLV1.DLL - Ok
C:\Windows\system32\KBDMAC.DLL - Ok
C:\Windows\system32\KBDMAORI.DLL - Ok
C:\Windows\system32\KBDMLT47.DLL - Ok
C:\Windows\system32\KBDMLT48.DLL - Ok
C:\Windows\system32\KBDMON.DLL - Ok
C:\Windows\system32\kbdlk41a.dll - Ok
C:\Windows\system32\KBDJPN.DLL - Ok
C:\Windows\system32\kbdnec.dll - Ok
C:\Windows\system32\KBDLT2.DLL - Ok
C:\Windows\system32\kbdnec95.dll - Ok
C:\Windows\system32\KBDNEPR.DLL - Ok
C:\Windows\system32\KBDNO1.DLL - Ok
C:\Windows\system32\KBDNO.DLL - Ok
C:\Windows\system32\kbdnecnt.dll - Ok
C:\Windows\system32\kbdnecat.dll - Ok
C:\Windows\system32\KBDMONMO.DLL - Ok
C:\Windows\system32\KBDPL.DLL - Ok
C:\Windows\system32\KBDNSO.DLL - Ok
C:\Windows\system32\KBDROPR.DLL - Ok
C:\Windows\system32\KBDRU.DLL - Ok
C:\Windows\system32\KBDRU1.DLL - Ok
C:\Windows\system32\KBDPASH.DLL - Ok
C:\Windows\system32\KBDSL1.DLL - Ok
C:\Windows\system32\KBDSL.DLL - Ok
C:\Windows\system32\KBDSF.DLL - Ok
C:\Windows\system32\KBDSG.DLL - Ok
C:\Windows\system32\KBDPL1.DLL - Ok
C:\Windows\system32\KBDSMSNO.DLL - Ok
C:\Windows\system32\KBDROST.DLL - Ok
C:\Windows\system32\KBDSMSFI.DLL - Ok
C:\Windows\system32\KBDRO.DLL - Ok
C:\Windows\system32\KBDPO.DLL - Ok
C:\Windows\system32\KBDSW.DLL - Ok
C:\Windows\system32\KBDSOREX.DLL - Ok
C:\Windows\system32\KBDSW09.DLL - Ok
C:\Windows\system32\KBDSORS1.DLL - Ok
C:\Windows\system32\KBDNE.DLL - Ok
C:\Windows\system32\KBDTAJIK.DLL - Ok
C:\Windows\system32\KBDSN1.DLL - Ok
C:\Windows\system32\KBDTAT.DLL - Ok
C:\Windows\system32\KBDTH1.DLL - Ok
C:\Windows\system32\KBDSYR1.DLL - Ok
C:\Windows\system32\KBDSYR2.DLL - Ok
C:\Windows\system32\KBDTH2.DLL - Ok
C:\Windows\system32\KBDTH0.DLL - Ok
C:\Windows\system32\KBDUK.DLL - Ok
C:\Windows\system32\KBDUGHR1.DLL - Ok
C:\Windows\system32\KBDUGHR.DLL - Ok
C:\Windows\system32\KBDTH3.DLL - Ok
C:\Windows\system32\KBDSP.DLL - Ok
C:\Windows\system32\KBDTURME.DLL - Ok
C:\Windows\system32\KBDTUF.DLL - Ok
C:\Windows\system32\KBDTUQ.DLL - Ok
C:\Windows\system32\KBDURDU.DLL - Ok
C:\Windows\system32\KBDUR.DLL - Ok
C:\Windows\system32\KBDUR1.DLL - Ok
C:\Windows\system32\KBDUSL.DLL - Ok
C:\Windows\system32\KBDUSR.DLL - Ok
C:\Windows\system32\KBDUSA.DLL - Ok
C:\Windows\system32\KBDUZB.DLL - Ok
C:\Windows\system32\KBDSORST.DLL - Ok
C:\Windows\system32\KBDYCC.DLL - Ok
C:\Windows\system32\KBDYBA.DLL - Ok
C:\Windows\system32\kdcom.dll - Ok
C:\Windows\system32\KBDVNTC.DLL - Ok
C:\Windows\system32\KBDTIPRC.DLL - Ok
C:\Windows\system32\KBDYAK.DLL - Ok
C:\Windows\system32\KBDUSX.DLL - Ok
C:\Windows\system32\kerberos.dll - Ok
C:\Windows\system32\kernel32.dll - Ok
C:\Windows\system32\keyiso.dll - Ok
C:\Windows\system32\KBDUKX.DLL - Ok
C:\Windows\system32\kernelceip.dll - Ok
C:\Windows\system32\KBDUS.DLL - Ok
C:\Windows\system32\KernelBase.dll - Ok
C:\Windows\system32\korean.uce - Ok
C:\Windows\system32\KBDWOL.DLL - Ok
C:\Windows\system32\korwbrkr.lex - Ok
C:\Windows\system32\KMSVC.DLL - Ok
C:\Windows\system32\KBDYCL.DLL - Ok
C:\Windows\system32\korwbrkr.dll - Ok
C:\Windows\system32\ksuser.dll - Ok
C:\Windows\system32\ksproxy.ax - Ok
C:\Windows\system32\kmddsp.tsp - Ok
C:\Windows\system32\ktmw32.dll - Ok
C:\Windows\system32\ktmutil.exe - Ok
C:\Windows\system32\ksetup.exe - Ok
C:\Windows\system32\ksxbar.ax - Ok
C:\Windows\system32\klist.exe - Ok
C:\Windows\system32\l2gpstore.dll - Ok
C:\Windows\system32\kstvtune.ax - Ok
C:\Windows\system32\keymgr.dll - Ok
C:\Windows\system32\l2nacp.dll - Ok
C:\Windows\system32\kd1394.dll - Ok
C:\Windows\system32\kdusb.dll - Ok
C:\Windows\system32\Kswdmcap.ax - Ok
C:\Windows\system32\l3codeca.acm - Ok
C:\Windows\system32\lcptr.tbl - Ok
C:\Windows\system32\label.exe - Ok
C:\Windows\system32\linkinfo.dll - Ok
C:\Windows\system32\lcphrase.tbl - Ok
C:\Windows\system32\LangCleanupSysprepAction.dll - Ok
C:\Windows\system32\LIVESSP.DLL - Ok
C:\Windows\system32\licmgr10.dll - Ok
C:\Windows\system32\ListSvc.dll - Ok
C:\Windows\system32\l3codecp.acm - Ok
C:\Windows\system32\L2SecHC.dll - Ok
C:\Windows\system32\LAPRXY.DLL - Ok
C:\Windows\system32\LocalGroupAdminAdd.log - Ok
C:\Windows\system32\locale.nls - Ok
C:\Windows\system32\lmhsvc.dll - Ok
C:\Windows\system32\Local_LLU.log - Ok
C:\Windows\system32\lltdapi.dll - Ok
C:\Windows\system32\lltdsvc.dll - Ok
C:\Windows\system32\lltdres.dll - Ok
C:\Windows\system32\loadperf.dll - Ok
C:\Windows\system32\Locator.exe - Ok
C:\Windows\system32\LocationNotifications.exe - Ok
C:\Windows\system32\localui.dll - Ok
C:\Windows\system32\locationnotificationsview.xml - Ok
C:\Windows\system32\localspl.dll - Ok
C:\Windows\system32\logagent.exe - Ok
C:\Windows\system32\loghours.dll - Ok
C:\Windows\system32\logoncli.dll - Ok
C:\Windows\system32\LocationApi.dll - Ok
C:\Windows\system32\lodctr.exe - Ok
C:\Windows\system32\lpk.dll - Ok
C:\Windows\system32\LogonUI.exe - Ok
C:\Windows\system32\lpksetupproxyserv.dll - Ok
C:\Windows\system32\localsec.dll - Ok
C:\Windows\system32\lsass.exe - Ok
>C:\Windows\system32\LogiLDA.DLL is BINARYRES container
>>C:\Windows\system32\LogiLDA.DLL\data001 is JS-HTML container
C:\Windows\system32\lpksetup.exe - Ok
C:\Windows\system32\lpremove.exe - Ok
C:\Windows\system32\logman.exe - Ok
>>C:\Windows\system32\LogiLDA.DLL\data002 is JS-HTML container
C:\Windows\system32\LogiLDA.DLL - container
C:\Windows\system32\lsmproxy.dll - Ok
C:\Windows\system32\Magnification.dll - Ok
C:\Windows\system32\luainstall.dll - Ok
C:\Windows\system32\l_intl.nls - Ok
C:\Windows\system32\lz32.dll - Ok
C:\Windows\system32\lsm.exe - Ok
>C:\Windows\system32\manage-bde.wsf is JS-HTML container
C:\Windows\system32\manage-bde.wsf - container
C:\Windows\system32\mapi32.dll - Ok
C:\Windows\system32\lusrmgr.msc - Ok
>C:\Windows\system32\Magnify.exe is ZLIB container
C:\Windows\system32\lsasrv.dll - Ok
C:\Windows\system32\manage-bde.exe - Ok
C:\Windows\system32\mapistub.dll - Ok
C:\Windows\system32\main.cpl - Ok
C:\Windows\system32\makecab.exe - Ok
C:\Windows\system32\mblctr.exe - Ok
C:\Windows\system32\Magnify.exe - container
C:\Windows\system32\mciavi32.dll - Ok
C:\Windows\system32\mciseq.dll - Ok
C:\Windows\system32\mcicda.dll - Ok
C:\Windows\system32\mciwave.dll - Ok
C:\Windows\system32\mcbuilder.exe - Ok
C:\Windows\system32\mciqtz32.dll - Ok
C:\Windows\system32\MCEWMDRMNDBootstrap.dll - Ok
C:\Windows\system32\Mcx2Svc.dll - Ok
C:\Windows\system32\mctadmin.exe - Ok
C:\Windows\system32\mcupdate_GenuineIntel.dll - Ok
>C:\Windows\system32\mcmde.dll - packed by PESTUB
C:\Windows\system32\mcupdate_AuthenticAMD.dll - Ok
C:\Windows\system32\mctres.dll - Ok
C:\Windows\system32\McxDriv.dll - Ok
C:\Windows\system32\memdiag.dll - Ok
C:\Windows\system32\MdSched.exe - Ok
C:\Windows\system32\license.rtf - Ok
C:\Windows\system32\mcsrchPH.dll - Ok
C:\Windows\system32\mdminst.dll - Ok
C:\Windows\system32\MdRes.exe - Ok
C:\Windows\system32\IDTNHP.dll - Ok
C:\Windows\system32\mf3216.dll - Ok
C:\Windows\system32\mfc100chs.dll - Ok
C:\Windows\system32\mfAACEnc.dll - Ok
C:\Windows\system32\mfc100fra.dll - Ok
C:\Windows\system32\mfc100deu.dll - Ok
C:\Windows\system32\mf.dll - Ok
C:\Windows\system32\mfc100enu.dll - Ok
C:\Windows\system32\MediaMetadataHandler.dll - Ok
C:\Windows\system32\mfc100jpn.dll - Ok
C:\Windows\system32\mfc100esn.dll - Ok
C:\Windows\system32\mfc100cht.dll - Ok
C:\Windows\system32\mfc100ita.dll - Ok
C:\Windows\system32\mcmde.dll - Ok
C:\Windows\system32\mfc100rus.dll - Ok
C:\Windows\system32\mfc100kor.dll - Ok
C:\Windows\system32\mfcm100.dll - Ok
>C:\Windows\system32\mfc100.dll is ZLIB container
C:\Windows\system32\mfcm100u.dll - Ok
C:\Windows\system32\mfdvdec.dll - Ok
C:\Windows\system32\mfcsubs.dll - Ok
C:\Windows\system32\mfc42u.dll - Ok
C:\Windows\system32\mfc100.dll - container
C:\Windows\system32\mfh264enc.dll - Ok
C:\Windows\system32\mferror.dll - Ok
C:\Windows\system32\mfpmp.exe - Ok
C:\Windows\system32\mfmjpegdec.dll - Ok
C:\Windows\system32\MFPlay.dll - Ok
C:\Windows\system32\mgmtapi.dll - Ok
C:\Windows\system32\mfplat.dll - Ok
C:\Windows\system32\microsoft-windows-hal-events.dll - Ok
C:\Windows\system32\mfreadwrite.dll - Ok
C:\Windows\system32\microsoft-windows-kernel-processor-power-events.dll - Ok
C:\Windows\system32\midimap.dll - Ok
C:\Windows\system32\microsoft-windows-kernel-power-events.dll - Ok
C:\Windows\system32\migwiz.lnk - Ok
C:\Windows\system32\mfds.dll - Ok
C:\Windows\system32\mfvdsp.dll - Ok
C:\Windows\system32\MigAutoPlay.exe - Ok
C:\Windows\system32\mfps.dll - Ok
C:\Windows\system32\migisol.dll - Ok
C:\Windows\system32\MFWMAAEC.DLL - Ok
C:\Windows\system32\mlang.dll - Ok
C:\Windows\system32\mfc42.dll - Ok
C:\Windows\system32\mmcss.dll - Ok
C:\Windows\system32\mmcshext.dll - Ok
C:\Windows\system32\mlang.dat - Ok
C:\Windows\system32\MMDevAPI.dll - Ok
C:\Windows\system32\mimefilt.dll - Ok
C:\Windows\system32\mmci.dll - Ok
C:\Windows\system32\miguiresource.dll - Ok
C:\Windows\system32\montr_ci.dll - Ok
C:\Windows\system32\mobsync.exe - Ok
>C:\Windows\system32\mfc100u.dll is ZLIB container
C:\Windows\system32\more.com - Ok
C:\Windows\system32\mode.com - Ok
C:\Windows\system32\mfc100u.dll - container
C:\Windows\system32\moricons.dll - Ok
C:\Windows\system32\modemui.dll - Ok
C:\Windows\system32\MP4SDECD.DLL - Ok
C:\Windows\system32\mountvol.exe - Ok
C:\Windows\system32\mmsys.cpl - Ok
C:\Windows\system32\mmcico.dll - Ok
C:\Windows\system32\Mpeg2Data.ax - Ok
C:\Windows\system32\mmcbase.dll - Ok
C:\Windows\system32\MPG4DECD.DLL - Ok
C:\Windows\system32\mpnotify.exe - Ok
C:\Windows\system32\mpr.dll - Ok
C:\Windows\system32\mprdim.dll - Ok
C:\Windows\system32\MP3DMOD.DLL - Ok
C:\Windows\system32\mprapi.dll - Ok
C:\Windows\system32\mprddm.dll - Ok
C:\Windows\system32\mprmsg.dll - Ok
C:\Windows\system32\MRINFO.EXE - Ok
C:\Windows\system32\MpSigStub.exe - Ok
C:\Windows\system32\msacm32.dll - Ok
C:\Windows\system32\mpg2splt.ax - Ok
C:\Windows\system32\MPSSVC.dll - Ok
C:\Windows\system32\msacm32.drv - Ok
C:\Windows\system32\msaatext.dll - Ok
C:\Windows\system32\msadp32.acm - Ok
C:\Windows\system32\msasn1.dll - Ok
C:\Windows\system32\MP43DECD.DLL - Ok
C:\Windows\system32\msaudite.dll - Ok
C:\Windows\system32\msafd.dll - Ok
C:\Windows\system32\mscms.dll - Ok
C:\Windows\system32\msclmd.dll - Ok
C:\Windows\system32\MSAC3ENC.DLL - Ok
C:\Windows\system32\mscoree.dll - Ok
C:\Windows\system32\mscandui.dll - Ok
C:\Windows\system32\mscories.dll - Ok
C:\Windows\system32\MsCtfMonitor.dll - Ok
C:\Windows\system32\mscorier.dll - Ok
C:\Windows\system32\msctfui.dll - Ok
C:\Windows\system32\msctf.dll - Ok
C:\Windows\system32\msctfp.dll - Ok
C:\Windows\system32\mscat32.dll - Ok
C:\Windows\system32\msdmo.dll - Ok
C:\Windows\system32\msdelta.dll - Ok
C:\Windows\system32\msdadiag.dll - Ok
C:\Windows\system32\msctfime.ime - Ok
C:\Windows\system32\msconfig.exe - Ok
C:\Windows\system32\msdtc.exe - Ok
C:\Windows\system32\msdt.exe - Ok
C:\Windows\system32\msdart.dll - Ok
C:\Windows\system32\msdri.dll - Ok
C:\Windows\system32\msdatsrc.tlb - Ok
C:\Windows\system32\msdtckrm.dll - Ok
C:\Windows\system32\msdtcVSp1res.dll - Ok
C:\Windows\system32\mmcndmgr.dll - Ok
C:\Windows\system32\mmc.exe - Ok
C:\Windows\system32\msdtclog.dll - Ok
C:\Windows\system32\msdrm.dll - Ok
C:\Windows\system32\msfeedssync.exe - Ok
C:\Windows\system32\MSDvbNP.ax - Ok
C:\Windows\system32\msg711.acm - Ok
C:\Windows\system32\msgsm32.acm - Ok
C:\Windows\system32\msftedit.dll - Ok
C:\Windows\system32\msdxm.tlb - Ok
C:\Windows\system32\msdtcprx.dll - Ok
C:\Windows\system32\mshta.exe - Ok
C:\Windows\system32\msdxm.ocx - Ok
C:\Windows\system32\msdtctm.dll - Ok
C:\Windows\system32\mshtmled.dll - Ok
C:\Windows\system32\msfeeds.dll - Ok
C:\Windows\system32\MsiCofire.dll - Ok
C:\Windows\system32\mshtml.tlb - Ok
C:\Windows\system32\mshtmlmedia.dll - Ok
C:\Windows\system32\msidle.dll - Ok
C:\Windows\system32\msfeedsbs.dll - Ok
C:\Windows\system32\msidcrl30.dll - Ok
C:\Windows\system32\mshtml.dll - Ok
C:\Windows\system32\msidntld.dll - Ok
C:\Windows\system32\mshtmler.dll - Ok
C:\Windows\system32\msiltcfg.dll - Ok
C:\Windows\system32\msimsg.dll - Ok
C:\Windows\system32\msiexec.exe - Ok
C:\Windows\system32\msimg32.dll - Ok
C:\Windows\system32\msimtf.dll - Ok
C:\Windows\system32\msi.dll - Ok
C:\Windows\system32\msident.dll - Ok
C:\Windows\system32\msisip.dll - Ok
C:\Windows\system32\msieftp.dll - Ok
C:\Windows\system32\msmmsp.dll - Ok
C:\Windows\system32\msls31.dll - Ok
C:\Windows\system32\msnetobj.dll - Ok
C:\Windows\system32\MSMPEG2ENC.DLL - Ok
C:\Windows\system32\msobjs.dll - Ok
C:\Windows\system32\msdtcuiu.dll - Ok
C:\Windows\system32\msmpeg2vdec.dll - Ok
C:\Windows\system32\mspatcha.dll - Ok
C:\Windows\system32\MSNP.ax - Ok
C:\Windows\system32\MsPbdaCoInst.dll - Ok
C:\Windows\system32\msports.dll - Ok
C:\Windows\system32\msihnd.dll - Ok
C:\Windows\system32\msprivs.dll - Ok
C:\Windows\system32\mspaint.exe - Ok
C:\Windows\system32\msinfo32.exe - Ok
C:\Windows\system32\MsraLegacy.tlb - Ok
C:\Windows\system32\msra.exe - Ok
C:\Windows\system32\msoeacct.dll - Ok
C:\Windows\system32\msrle32.dll - Ok
C:\Windows\system32\MsRdpWebAccess.dll - Ok
C:\Windows\system32\mspbda.dll - Ok
C:\Windows\system32\msrdc.dll - Ok
C:\Windows\system32\msscntrs.dll - Ok
C:\Windows\system32\msrahc.dll - Ok
C:\Windows\system32\mssha.dll - Ok
C:\Windows\system32\msshooks.dll - Ok
C:\Windows\system32\msoert2.dll - Ok
C:\Windows\system32\mssip32.dll - Ok
C:\Windows\system32\mssign32.dll - Ok
C:\Windows\system32\mssitlb.dll - Ok
C:\Windows\system32\msmpeg2adec.dll - Ok
C:\Windows\system32\msshavmsg.dll - Ok
C:\Windows\system32\msrating.dll - Ok
C:\Windows\system32\msswch.dll - Ok
C:\Windows\system32\mssprxy.dll - Ok
C:\Windows\system32\mstscax.dll - Ok
C:\Windows\system32\msscp.dll - Ok
C:\Windows\system32\mssrch.dll - Ok
C:\Windows\system32\mstask.dll - Ok
C:\Windows\system32\mssphtb.dll - Ok
C:\Windows\system32\msv1_0.dll - Ok
C:\Windows\system32\msutb.dll - Ok
C:\Windows\system32\msvcp100.dll - Ok
C:\Windows\system32\mssph.dll - Ok
C:\Windows\system32\msvcirt.dll - Ok
C:\Windows\system32\msvidc32.dll - Ok
C:\Windows\system32\msvcr100.dll - Ok
C:\Windows\system32\msvcrt.dll - Ok
C:\Windows\system32\mswmdm.dll - Ok
C:\Windows\system32\mswsock.dll - Ok
C:\Windows\system32\msxml3r.dll - Ok
C:\Windows\system32\mssvp.dll - Ok
C:\Windows\system32\MsSpellCheckingFacility.exe - Ok
C:\Windows\system32\msxml6r.dll - Ok
C:\Windows\system32\MSVidCtl.dll - Ok
C:\Windows\system32\msyuv.dll - Ok
C:\Windows\system32\msxml3.dll - Ok
C:\Windows\system32\mtstocom.exe - Ok
C:\Windows\system32\mtxdm.dll - Ok
C:\Windows\system32\msvfw32.dll - Ok
C:\Windows\system32\msxml6.dll - Ok
C:\Windows\system32\IDTNGUI.exe - Ok
C:\Windows\system32\msvcp60.dll - Ok
C:\Windows\system32\muifontsetup.dll - Ok
C:\Windows\system32\mtxex.dll - Ok
C:\Windows\system32\MUILanguageCleanup.dll - Ok
C:\Windows\system32\NAPCLCFG.MSC - Ok
C:\Windows\system32\mydocs.dll - Ok
C:\Windows\system32\Mystify.scr - Ok
C:\Windows\system32\MultiDigiMon.exe - Ok
C:\Windows\system32\mtxoci.dll - Ok
C:\Windows\system32\NapiNSP.dll - Ok
C:\Windows\system32\napdsnap.dll - Ok
C:\Windows\system32\napipsec.dll - Ok
C:\Windows\system32\mtxclu.dll - Ok
C:\Windows\system32\NAPHLPR.DLL - Ok
C:\Windows\system32\mycomput.dll - Ok
C:\Windows\system32\MuiUnattend.exe - Ok
C:\Windows\system32\nbspkrsbeats.ico - Ok
C:\Windows\system32\NAPMONTR.DLL - Ok
C:\Windows\system32\NativeHooks.dll - Ok
C:\Windows\system32\mstsc.exe - Ok
C:\Windows\system32\nci.dll - Ok
C:\Windows\system32\NAPCRYPT.DLL - Ok
C:\Windows\system32\ncobjapi.dll - Ok
C:\Windows\system32\ncryptui.dll - Ok
C:\Windows\system32\msvcr100_clr0400.dll - Ok
C:\Windows\system32\nbtstat.exe - Ok
C:\Windows\system32\ncpa.cpl - Ok
C:\Windows\system32\ndCPrepLog - Ok
C:\Windows\system32\NcdProp.dll - Ok
C:\Windows\system32\ncsi.dll - Ok
C:\Windows\system32\NaturalLanguage6.dll - Ok
C:\Windows\system32\NdfEventView.xml - Ok
C:\Windows\system32\ncrypt.dll - Ok
C:\Windows\system32\nddeapi.dll - Ok
C:\Windows\system32\ndiscapCfg.dll - Ok
C:\Windows\system32\NAPSTAT.EXE - Ok
C:\Windows\system32\ndptsp.tsp - Ok
C:\Windows\system32\ndproxystub.dll - Ok
C:\Windows\system32\negoexts.dll - Ok
C:\Windows\system32\ndadmin.exe - Ok
C:\Windows\system32\Narrator.exe - Ok
C:\Windows\system32\netapi32.dll - Ok
C:\Windows\system32\netbtugc.exe - Ok
C:\Windows\system32\ndfhcdiscovery.dll - Ok
C:\Windows\system32\ndishc.dll - Ok
C:\Windows\system32\ndfetw.dll - Ok
C:\Windows\system32\ndfapi.dll - Ok
C:\Windows\system32\netevent.dll - Ok
C:\Windows\system32\netcfgx.dll - Ok
C:\Windows\system32\netcenter.dll - Ok
C:\Windows\system32\netcfg.exe - Ok
C:\Windows\system32\net1.exe - Ok
C:\Windows\system32\netdiagfx.dll - Ok
C:\Windows\system32\netfxperf.dll - Ok
C:\Windows\system32\netcorehc.dll - Ok
C:\Windows\system32\neth.dll - Ok
C:\Windows\system32\netiougc.exe - Ok
C:\Windows\system32\netiohlp.dll - Ok
C:\Windows\system32\netmsg.dll - Ok
C:\Windows\system32\netbios.dll - Ok
C:\Windows\system32\net.exe - Ok
C:\Windows\system32\netjoin.dll - Ok
C:\Windows\system32\Netplwiz.exe - Ok
C:\Windows\system32\netman.dll - Ok
C:\Windows\system32\netplwiz.dll - Ok
C:\Windows\system32\NETSTAT.EXE - Ok
C:\Windows\system32\netid.dll - Ok
C:\Windows\system32\NetTrace.PLA.Diagnostics.xml - Ok
C:\Windows\system32\netprofm.dll - Ok
C:\Windows\system32\netutils.dll - Ok
C:\Windows\system32\netsh.exe - Ok
C:\Windows\system32\netlogon.dll - Ok
C:\Windows\system32\Network_LLU.log - Ok
C:\Windows\system32\nettrace.dll - Ok
C:\Windows\system32\netshell.dll - Ok
C:\Windows\system32\networkexplorer.dll - Ok
C:\Windows\system32\networkitemfactory.dll - Ok
C:\Windows\system32\nlaapi.dll - Ok
C:\Windows\system32\newdev.exe - Ok
C:\Windows\system32\nlasvc.dll - Ok
C:\Windows\system32\netprof.dll - Ok
C:\Windows\system32\nlmgp.dll - Ok
C:\Windows\system32\nlahc.dll - Ok
C:\Windows\system32\nlmsprep.dll - Ok
C:\Windows\system32\nlsbres.dll - Ok
C:\Windows\system32\NlsData0000.dll - Ok
C:\Windows\system32\NlsData0003.dll - Ok
C:\Windows\system32\Netwcw00.dll - Ok
C:\Windows\system32\nlhtml.dll - Ok
C:\Windows\system32\NlsData0009.dll - Ok
C:\Windows\system32\NlsData0001.dll - Ok
C:\Windows\system32\newdev.dll - Ok
C:\Windows\system32\NlsData0002.dll - Ok
C:\Windows\system32\mmres.dll - Ok
C:\Windows\system32\NlsData000d.dll - Ok
C:\Windows\system32\NlsData000f.dll - Ok
C:\Windows\system32\NETwNc64.dll - Ok
C:\Windows\system32\NlsData0013.dll - Ok
C:\Windows\system32\NlsData0019.dll - Ok
C:\Windows\system32\NlsData0007.dll - Ok
C:\Windows\system32\NlsData0018.dll - Ok
C:\Windows\system32\NlsData001b.dll - Ok
C:\Windows\system32\NlsData001a.dll - Ok
C:\Windows\system32\NlsData001d.dll - Ok
C:\Windows\system32\NlsData0010.dll - Ok
C:\Windows\system32\NlsData0022.dll - Ok
C:\Windows\system32\networkmap.dll - Ok
C:\Windows\system32\NlsData0011.dll - Ok
C:\Windows\system32\NETwNr64.dll - Ok
C:\Windows\system32\NlsData0020.dll - Ok
C:\Windows\system32\NlsData0021.dll - Ok
C:\Windows\system32\NlsData0027.dll - Ok
C:\Windows\system32\NlsData0047.dll - Ok
C:\Windows\system32\NlsData0046.dll - Ok
C:\Windows\system32\NlsData0045.dll - Ok
C:\Windows\system32\NlsData0024.dll - Ok
C:\Windows\system32\NlsData0039.dll - Ok
C:\Windows\system32\NlsData002a.dll - Ok
C:\Windows\system32\NlsData0049.dll - Ok
C:\Windows\system32\NlsData004e.dll - Ok
C:\Windows\system32\NlsData004c.dll - Ok
C:\Windows\system32\Netwrw00.dll - Ok
C:\Windows\system32\NlsData0c1a.dll - Ok
C:\Windows\system32\NlsData081a.dll - Ok
C:\Windows\system32\NlsData000c.dll - Ok
C:\Windows\system32\NlsData004a.dll - Ok
C:\Windows\system32\Nlsdl.dll - Ok
C:\Windows\system32\NlsData004b.dll - Ok
C:\Windows\system32\NlsData0026.dll - Ok
C:\Windows\system32\NlsLexicons0003.dll - Ok
C:\Windows\system32\NlsData003e.dll - Ok
C:\Windows\system32\NlsLexicons0009.dll - Ok
C:\Windows\system32\NlsData0816.dll - Ok
C:\Windows\system32\NlsLexicons000d.dll - Ok
C:\Windows\system32\NlsData0414.dll - Ok
C:\Windows\system32\NlsLexicons0013.dll - Ok
C:\Windows\system32\NlsLexicons0002.dll - Ok
C:\Windows\system32\NlsData000a.dll - Ok
>C:\Windows\system32\MRT.exe is BINARYRES container
C:\Windows\system32\NlsData0416.dll - Ok
C:\Windows\system32\NlsLexicons0011.dll - Ok
>>C:\Windows\system32\MRT.exe\data001 is BINARYRES container
C:\Windows\system32\NlsLexicons000f.dll - Ok
C:\Windows\system32\NlsLexicons0018.dll - Ok
C:\Windows\system32\NlsLexicons0020.dll - Ok
C:\Windows\system32\NlsLexicons0010.dll - Ok
C:\Windows\system32\NlsLexicons000c.dll - Ok
C:\Windows\system32\NlsLexicons001b.dll - Ok
C:\Windows\system32\NlsLexicons0019.dll - Ok
C:\Windows\system32\NlsLexicons0021.dll - Ok
C:\Windows\system32\NlsLexicons001d.dll - Ok
C:\Windows\system32\NlsLexicons002a.dll - Ok
C:\Windows\system32\NlsLexicons0026.dll - Ok
C:\Windows\system32\NlsLexicons0001.dll - Ok
C:\Windows\system32\NlsLexicons0045.dll - Ok
C:\Windows\system32\NlsLexicons0039.dll - Ok
C:\Windows\system32\NlsLexicons0046.dll - Ok
C:\Windows\system32\NlsLexicons001a.dll - Ok
C:\Windows\system32\NlsLexicons0047.dll - Ok
C:\Windows\system32\NlsLexicons0049.dll - Ok
C:\Windows\system32\NlsLexicons0022.dll - Ok
C:\Windows\system32\NlsLexicons004b.dll - Ok
C:\Windows\system32\NlsLexicons004a.dll - Ok
C:\Windows\system32\NlsLexicons0007.dll - Ok
C:\Windows\system32\NlsLexicons004c.dll - Ok
C:\Windows\system32\NlsLexicons003e.dll - Ok
C:\Windows\system32\NlsLexicons004e.dll - Ok
C:\Windows\system32\NOISE.CHS - Ok
C:\Windows\system32\NOISE.CHT - Ok
C:\Windows\system32\NOISE.DAT - Ok
C:\Windows\system32\noise.jpn - Ok
C:\Windows\system32\noise.kor - Ok
C:\Windows\system32\NOISE.THA - Ok
C:\Windows\system32\normaliz.dll - Ok
C:\Windows\system32\normidna.nls - Ok
C:\Windows\system32\normnfc.nls - Ok
C:\Windows\system32\normnfd.nls - Ok
C:\Windows\system32\normnfkc.nls - Ok
C:\Windows\system32\nltest.exe - Ok
C:\Windows\system32\normnfkd.nls - Ok
C:\Windows\system32\npmproxy.dll - Ok
C:\Windows\system32\nrpsrv.dll - Ok
C:\Windows\system32\nshhttp.dll - Ok
C:\Windows\system32\notepad.exe - Ok
C:\Windows\system32\nshipsec.dll - Ok
C:\Windows\system32\nsi.dll - Ok
C:\Windows\system32\nshwfp.dll - Ok
C:\Windows\system32\nsisvc.dll - Ok
C:\Windows\system32\nslookup.exe - Ok
C:\Windows\system32\ntdll.dll - Ok
C:\Windows\system32\ntdsapi.dll - Ok
C:\Windows\system32\ntlanman.dll - Ok
C:\Windows\system32\ntmarta.dll - Ok
C:\Windows\system32\ntoskrnl.exe - Ok
C:\Windows\system32\ntprint.dll - Ok
C:\Windows\system32\ntlanui2.dll - Ok
C:\Windows\system32\ntprint.exe - Ok
C:\Windows\system32\ntvdm64.dll - Ok
C:\Windows\system32\ntshrui.dll - Ok
C:\Windows\system32\NlsLexicons0024.dll - Ok
C:\Windows\system32\NlsLexicons081a.dll - Ok
C:\Windows\system32\objsel.dll - Ok
C:\Windows\system32\occache.dll - Ok
C:\Windows\system32\ocsetapi.dll - Ok
C:\Windows\system32\ocsetup.exe - Ok
C:\Windows\system32\odbc32gt.dll - Ok
C:\Windows\system32\odbc32.dll - Ok
C:\Windows\system32\NlsLexicons0416.dll - Ok
C:\Windows\system32\odbcconf.exe - Ok
C:\Windows\system32\odbcbcp.dll - Ok
C:\Windows\system32\odbcconf.rsp - Ok
C:\Windows\system32\odbcad32.exe - Ok
C:\Windows\system32\odbcconf.dll - Ok
C:\Windows\system32\odbccp32.dll - Ok
C:\Windows\system32\odbccu32.dll - Ok
C:\Windows\system32\odbcint.dll - Ok
C:\Windows\system32\odbccr32.dll - Ok
>C:\Windows\system32\oflc.rs is ZLIB container
C:\Windows\system32\NlsLexicons0c1a.dll - Ok
C:\Windows\system32\offfilt.dll - Ok
C:\Windows\system32\odbctrac.dll - Ok
C:\Windows\system32\oflc.rs - container
C:\Windows\system32\NlsLexicons000a.dll - Ok
C:\Windows\system32\oleaccrc.dll - Ok
C:\Windows\system32\oleacc.dll - Ok
C:\Windows\system32\oleacchooks.dll - Ok
>C:\Windows\system32\ole32.dll is BINARYRES container
C:\Windows\system32\ole32.dll - container
C:\Windows\system32\oleprn.dll - Ok
C:\Windows\system32\oleres.dll - Ok
C:\Windows\system32\nusb3co2.dll - Ok
C:\Windows\system32\oleaut32.dll - Ok
C:\Windows\system32\onlinesetup.cmd - Ok
C:\Windows\system32\oledlg.dll - Ok
C:\Windows\system32\onex.dll - Ok
C:\Windows\system32\OobeFldr.dll - Ok
C:\Windows\system32\openfiles.exe - Ok
C:\Windows\system32\ogldrv.dll - Ok
C:\Windows\system32\OnLineIDCpl.dll - Ok
C:\Windows\system32\osbaseln.dll - Ok
C:\Windows\system32\osk.exe - Ok
C:\Windows\system32\OptionalFeatures.exe - Ok
C:\Windows\system32\oflc-nz.rs - Ok
C:\Windows\system32\osuninst.dll - Ok
C:\Windows\system32\P2P.dll - Ok
C:\Windows\system32\onexui.dll - Ok
C:\Windows\system32\p2pcollab.dll - Ok
C:\Windows\system32\OpcServices.dll - Ok
C:\Windows\system32\P2PGraph.dll - Ok
C:\Windows\system32\NlsLexicons0414.dll - Ok
C:\Windows\system32\p2phost.exe - Ok
C:\Windows\system32\p2pnetsh.dll - Ok
C:\Windows\system32\p2psvc.dll - Ok
C:\Windows\system32\NlsLexicons0027.dll - Ok
C:\Windows\system32\pautoenr.dll - Ok
C:\Windows\system32\pcadm.dll - Ok
C:\Windows\system32\pcaevts.dll - Ok
C:\Windows\system32\OpenCL.dll - Ok
C:\Windows\system32\panmap.dll - Ok
C:\Windows\system32\pcasvc.dll - Ok
C:\Windows\system32\PATHPING.EXE - Ok
C:\Windows\system32\pcl.sep - Ok
C:\Windows\system32\OVDecode64.dll - Ok
C:\Windows\system32\pcaui.exe - Ok
C:\Windows\system32\pcaui.dll - Ok
C:\Windows\system32\pcwum.dll - Ok
C:\Windows\system32\pcwutl.dll - Ok
C:\Windows\system32\pcwrun.exe - Ok
C:\Windows\system32\pcawrk.exe - Ok
C:\Windows\system32\packager.dll - Ok
>C:\Windows\system32\pegi-fi.rs is ZLIB container
C:\Windows\system32\pdh.dll - Ok
C:\Windows\system32\perfc009.dat - Ok
C:\Windows\system32\opengl32.dll - Ok
>C:\Windows\system32\pegibbfc.rs is ZLIB container
>C:\Windows\system32\pegi.rs is ZLIB container
C:\Windows\system32\pegi.rs - container
>C:\Windows\system32\pegi-pt.rs is ZLIB container
C:\Windows\system32\pegibbfc.rs - container
C:\Windows\system32\pegi-pt.rs - container
C:\Windows\system32\pcalua.exe - Ok
C:\Windows\system32\pegi-fi.rs - container
C:\Windows\system32\PerfCenterCpl.ico - Ok
C:\Windows\system32\perfd009.dat - Ok
C:\Windows\system32\perfd013.dat - Ok
C:\Windows\system32\perfctrs.dll - Ok
C:\Windows\system32\perfdisk.dll - Ok
C:\Windows\system32\perfi013.dat - Ok
C:\Windows\system32\perfh013.dat - Ok
C:\Windows\system32\pdhui.dll - Ok
C:\Windows\system32\perfh009.dat - Ok
C:\Windows\system32\perfc013.dat - Ok
C:\Windows\system32\perfnet.dll - Ok
C:\Windows\system32\perfos.dll - Ok
C:\Windows\system32\perfproc.dll - Ok
C:\Windows\system32\perftrack.dll - Ok
C:\Windows\system32\perfi009.dat - Ok
C:\Windows\system32\OxpsConverter.exe - Ok
C:\Windows\system32\PerfStringBackup.INI - Ok
C:\Windows\system32\phon.ime - Ok
C:\Windows\system32\pid.dll - Ok
>C:\Windows\system32\PhotoScreensaver.scr is ZLIB container
C:\Windows\system32\perfmon.exe - Ok
C:\Windows\system32\perfts.dll - Ok
C:\Windows\system32\pifmgr.dll - Ok
C:\Windows\system32\PING.EXE - Ok
C:\Windows\system32\perfmon.msc - Ok
C:\Windows\system32\pku2u.dll - Ok
C:\Windows\system32\pintlgnt.ime - Ok
C:\Windows\system32\PlaySndSrv.dll - Ok
C:\Windows\system32\pla.dll - Ok
C:\Windows\system32\pngfilt.dll - Ok
C:\Windows\system32\plasrv.exe - Ok
C:\Windows\system32\PkgMgr.exe - Ok
C:\Windows\system32\NlsLexicons0816.dll - Ok
C:\Windows\system32\pnpts.dll - Ok
C:\Windows\system32\pnidui.dll - Ok
C:\Windows\system32\PnPutil.exe - Ok
C:\Windows\system32\pnpui.dll - Ok
C:\Windows\system32\PhotoMetadataHandler.dll - Ok
C:\Windows\system32\pnrpauto.dll - Ok
C:\Windows\system32\pnpsetup.dll - Ok
C:\Windows\system32\PhotoScreensaver.scr - container
C:\Windows\system32\PNPXAssoc.dll - Ok
C:\Windows\system32\pnrpnsp.dll - Ok
C:\Windows\system32\pnrpsvc.dll - Ok
C:\Windows\system32\polstore.dll - Ok
C:\Windows\system32\PerfCenterCPL.dll - Ok
C:\Windows\system32\PortableDeviceConnectApi.dll - Ok
C:\Windows\system32\PNPXAssocPrx.dll - Ok
C:\Windows\system32\PortableDeviceClassExtension.dll - Ok
C:\Windows\system32\PortableDeviceSyncProvider.dll - Ok
C:\Windows\system32\poqexec.exe - Ok
C:\Windows\system32\PortableDeviceStatus.dll - Ok
C:\Windows\system32\PortableDeviceApi.dll - Ok
C:\Windows\system32\pots.dll - Ok
C:\Windows\system32\PnPUnattend.exe - Ok
C:\Windows\system32\PortableDeviceTypes.dll - Ok
C:\Windows\system32\photowiz.dll - Ok
C:\Windows\system32\powercfg.exe - Ok
C:\Windows\system32\powercfg.cpl - Ok
C:\Windows\system32\powrprof.dll - Ok
C:\Windows\system32\powercpl.dll - Ok
C:\Windows\system32\PortableDeviceWMDRM.dll - Ok
C:\Windows\system32\PresentationHostProxy.dll - Ok
C:\Windows\system32\prflbmsg.dll - Ok
C:\Windows\system32\PortableDeviceWiaCompat.dll - Ok
C:\Windows\system32\PresentationNative_v0300.dll - Ok
C:\Windows\system32\print.exe - Ok
C:\Windows\system32\PresentationHost.exe - Ok
C:\Windows\system32\printfilterpipelineprxy.dll - Ok
C:\Windows\system32\PrintIsolationProxy.dll - Ok
C:\Windows\system32\Pnrphc.dll - Ok
C:\Windows\system32\PrintIsolationHost.exe - Ok
C:\Windows\system32\prnfldr.dll - Ok
C:\Windows\system32\prncache.dll - Ok
C:\Windows\system32\printui.exe - Ok
C:\Windows\system32\procinst.dll - Ok
C:\Windows\system32\profapi.dll - Ok
C:\Windows\system32\prevhost.exe - Ok
C:\Windows\system32\profprov.dll - Ok
C:\Windows\system32\profsvc.dll - Ok
C:\Windows\system32\proquota.exe - Ok
C:\Windows\system32\provsvc.dll - Ok
C:\Windows\system32\psapi.dll - Ok
C:\Windows\system32\pscript.sep - Ok
C:\Windows\system32\psbase.dll - Ok
C:\Windows\system32\prntvpt.dll - Ok
C:\Windows\system32\PSHED.DLL - Ok
C:\Windows\system32\propsys.dll - Ok
C:\Windows\system32\prnntfy.dll - Ok
C:\Windows\system32\PresentationCFFRasterizerNative_v0300.dll - Ok
C:\Windows\system32\pstorsvc.dll - Ok
C:\Windows\system32\NlsModels0011.dll - Ok
C:\Windows\system32\puiapi.dll - Ok
C:\Windows\system32\pidgenx.dll - Ok
C:\Windows\system32\pwrshplugin.dll - Ok
C:\Windows\system32\psisrndr.ax - Ok
C:\Windows\system32\puiobj.dll - Ok
C:\Windows\system32\pstorec.dll - Ok
C:\Windows\system32\psisdecd.dll - Ok
C:\Windows\system32\QCLIPROV.DLL - Ok
C:\Windows\system32\qcap.dll - Ok
C:\Windows\system32\qasf.dll - Ok
C:\Windows\system32\QAGENTRT.DLL - Ok
C:\Windows\system32\QAGENT.DLL - Ok
C:\Windows\system32\printfilterpipelinesvc.exe - Ok
C:\Windows\system32\qintlgnt.ime - Ok
C:\Windows\system32\qmgr.dll - Ok
C:\Windows\system32\QSVRMGMT.DLL - Ok
C:\Windows\system32\QSHVHOST.DLL - Ok
C:\Windows\system32\psr.exe - Ok
C:\Windows\system32\quartz.dll - Ok
C:\Windows\system32\qdv.dll - Ok
C:\Windows\system32\provthrd.dll - Ok
C:\Windows\system32\qmgrprxy.dll - Ok
C:\Windows\system32\QUTIL.DLL - Ok
C:\Windows\system32\qwave.dll - Ok
C:\Windows\system32\RacRules.xml - Ok
C:\Windows\system32\radardt.dll - Ok
C:\Windows\system32\radarrs.dll - Ok
C:\Windows\system32\qedit.dll - Ok
C:\Windows\system32\rasadhlp.dll - Ok
C:\Windows\system32\rasauto.dll - Ok
C:\Windows\system32\Query.dll - Ok
C:\Windows\system32\quick.ime - Ok
>C:\Windows\system32\racpldlg.dll is ZLIB container
C:\Windows\system32\rasctrnm.h - Ok
C:\Windows\system32\RacEngn.dll - Ok
C:\Windows\system32\rasautou.exe - Ok
C:\Windows\system32\rasapi32.dll - Ok
C:\Windows\system32\rascfg.dll - Ok
C:\Windows\system32\rasctrs.dll - Ok
C:\Windows\system32\rasdial.exe - Ok
C:\Windows\system32\racpldlg.dll - container
C:\Windows\system32\qedwipes.dll - Ok
C:\Windows\system32\rasdiag.dll - Ok
C:\Windows\system32\qdvd.dll - Ok
C:\Windows\system32\raserver.exe - Ok
C:\Windows\system32\rasman.dll - Ok
C:\Windows\system32\rasmbmgr.dll - Ok
C:\Windows\system32\rasdlg.dll - Ok
C:\Windows\system32\printui.dll - Ok
C:\Windows\system32\rasmans.dll - Ok
C:\Windows\system32\raschap.dll - Ok
C:\Windows\system32\rasphone.exe - Ok
C:\Windows\system32\rasmontr.dll - Ok
C:\Windows\system32\rasser.dll - Ok
C:\Windows\system32\rdpcfgex.dll - Ok
C:\Windows\system32\rasmxs.dll - Ok
C:\Windows\system32\RASMM.dll - Ok
C:\Windows\system32\rasplap.dll - Ok
C:\Windows\system32\rasgcw.dll - Ok
C:\Windows\system32\rdpcorekmts.dll - Ok
C:\Windows\system32\rdpdd.dll - Ok
C:\Windows\system32\rdrleakdiag.exe - Ok
C:\Windows\system32\rasppp.dll - Ok
C:\Windows\system32\RDPREFDD.dll - Ok
C:\Windows\system32\rdpwsx.dll - Ok
C:\Windows\system32\rdpd3d.dll - Ok
C:\Windows\system32\rdprefdrvapi.dll - Ok
C:\Windows\system32\ReAgentc.exe - Ok
C:\Windows\system32\RDPENCDD.dll - Ok
C:\Windows\system32\ReAgent.dll - Ok
C:\Windows\system32\rdpencom.dll - Ok
C:\Windows\system32\recovery.dll - Ok
C:\Windows\system32\RegCtrl.dll - Ok
C:\Windows\system32\rdrmemptylst.exe - Ok
C:\Windows\system32\rastapi.dll - Ok
C:\Windows\system32\regidle.dll - Ok
C:\Windows\system32\regsvr32.exe - Ok
C:\Windows\system32\rdpcore.dll - Ok
C:\Windows\system32\regsvc.dll - Ok
C:\Windows\system32\regini.exe - Ok
C:\Windows\system32\RegisterIEPKEYs.exe - Ok
C:\Windows\system32\RelPost.exe - Ok
C:\Windows\system32\regapi.dll - Ok
C:\Windows\system32\rekeywiz.exe - Ok
C:\Windows\system32\replace.exe - Ok
C:\Windows\system32\remotepg.dll - Ok
C:\Windows\system32\repair-bde.exe - Ok
C:\Windows\system32\reg.exe - Ok
C:\Windows\system32\RestartManagerUninstall.mof - Ok
C:\Windows\system32\relog.exe - Ok
C:\Windows\system32\resutils.dll - Ok
C:\Windows\system32\regedt32.exe - Ok
C:\Windows\system32\RestartManager.mof - Ok
C:\Windows\system32\rastls.dll - Ok
C:\Windows\system32\riched32.dll - Ok
C:\Windows\system32\rgb9rast.dll - Ok
C:\Windows\system32\riched20.dll - Ok
C:\Windows\system32\Ribbons.scr - Ok
C:\Windows\system32\remotesp.tsp - Ok
C:\Windows\system32\RESAMPLEDMO.DLL - Ok
C:\Windows\system32\resmon.exe - Ok
C:\Windows\system32\RMActivate.exe - Ok
C:\Windows\system32\RMActivate_ssp_isv.exe - Ok
C:\Windows\system32\rendezvousSession.tlb - Ok
C:\Windows\system32\recover.exe - Ok
C:\Windows\system32\RpcEpMap.dll - Ok
C:\Windows\system32\RmClient.exe - Ok
C:\Windows\system32\rpchttp.dll - Ok
C:\Windows\system32\ROUTE.EXE - Ok
C:\Windows\system32\rpcnsh.dll - Ok
C:\Windows\system32\RPCNDFP.dll - Ok
C:\Windows\system32\RMActivate_isv.exe - Ok
C:\Windows\system32\RpcRtRemote.dll - Ok
C:\Windows\system32\Robocopy.exe - Ok
C:\Windows\system32\RpcPing.exe - Ok
C:\Windows\system32\RpcNs4.dll - Ok
C:\Windows\system32\rnr20.dll - Ok
>C:\Windows\system32\RMActivate_ssp.exe is BINARYRES container
>>C:\Windows\system32\RMActivate_ssp.exe\data001 is ZLIB container
C:\Windows\system32\RstrtMgr.dll - Ok
C:\Windows\system32\rpcss.dll - Ok
C:\Windows\system32\rshx32.dll - Ok
C:\Windows\system32\rsaenh.dll - Ok
C:\Windows\system32\rrinstaller.exe - Ok
C:\Windows\system32\rpcrt4.dll - Ok
C:\Windows\system32\rtm.dll - Ok
C:\Windows\system32\rundll32.exe - Ok
C:\Windows\system32\rtutils.dll - Ok
C:\Windows\system32\RtNicProp64.dll - Ok
C:\Windows\system32\RpcDiag.dll - Ok
C:\Windows\system32\samcli.dll - Ok
C:\Windows\system32\samlib.dll - Ok
C:\Windows\system32\recdisc.exe - Ok
C:\Windows\system32\SampleRes.dll - Ok
C:\Windows\system32\RTNUninst64.dll - Ok
C:\Windows\system32\rtffilt.dll - Ok
C:\Windows\system32\rstrui.exe - Ok
C:\Windows\system32\runonce.exe - Ok
C:\Windows\system32\sbunattend.exe - Ok
C:\Windows\system32\sberes.dll - Ok
C:\Windows\system32\sas.dll - Ok
C:\Windows\system32\samsrv.dll - Ok
C:\Windows\system32\ScavengeSpace.xml - Ok
C:\Windows\system32\sc.exe - Ok
C:\Windows\system32\runas.exe - Ok
C:\Windows\system32\RunLegacyCPLElevated.exe - Ok
C:\Windows\system32\SCardSvr.dll - Ok
C:\Windows\system32\sccls.dll - Ok
C:\Windows\system32\scext.dll - Ok
C:\Windows\system32\scecli.dll - Ok
C:\Windows\system32\SCardDlg.dll - Ok
C:\Windows\system32\scesrv.dll - Ok
C:\Windows\system32\sbeio.dll - Ok
C:\Windows\system32\schedcli.dll - Ok
C:\Windows\system32\schannel.dll - Ok
C:\Windows\system32\scansetting.dll - Ok
C:\Windows\system32\scrnsave.scr - Ok
C:\Windows\system32\RMActivate_ssp.exe - container
C:\Windows\system32\scrrun.dll - Ok
C:\Windows\system32\scksp.dll - Ok
C:\Windows\system32\sdautoplay.dll - Ok
C:\Windows\system32\sdchange.exe - Ok
C:\Windows\system32\sbe.dll - Ok
C:\Windows\system32\schedsvc.dll - Ok
C:\Windows\system32\sdbinst.exe - Ok
C:\Windows\system32\scrobj.dll - Ok
C:\Windows\system32\sdiagnhost.exe - Ok
C:\Windows\system32\sdclt.exe - Ok
>C:\Windows\system32\scripto.dll is BINARYRES container
C:\Windows\system32\scripto.dll - container
C:\Windows\system32\sdhcinst.dll - Ok
C:\Windows\system32\sdengin2.dll - Ok
C:\Windows\system32\sdiageng.dll - Ok
C:\Windows\system32\sdiagschd.dll - Ok
C:\Windows\system32\sdiagprv.dll - Ok
C:\Windows\system32\schtasks.exe - Ok
C:\Windows\system32\SearchFilterHost.exe - Ok
C:\Windows\system32\sdrsvc.dll - Ok
C:\Windows\system32\sechost.dll - Ok
C:\Windows\system32\SearchProtocolHost.exe - Ok
C:\Windows\system32\sdcpl.dll - Ok
C:\Windows\system32\seclogon.dll - Ok
C:\Windows\system32\secinit.exe - Ok
C:\Windows\system32\SecEdit.exe - Ok
C:\Windows\system32\SearchIndexer.exe - Ok
C:\Windows\system32\scavengeui.dll - Ok
C:\Windows\system32\secur32.dll - Ok
C:\Windows\system32\security.dll - Ok
C:\Windows\system32\sdohlp.dll - Ok
C:\Windows\system32\sdshext.dll - Ok
C:\Windows\system32\SensApi.dll - Ok
C:\Windows\system32\Sens.dll - Ok
C:\Windows\system32\sendmail.dll - Ok
C:\Windows\system32\secproc_ssp.dll - Ok
C:\Windows\system32\secproc.dll - Ok
C:\Windows\system32\sensrsvc.dll - Ok
C:\Windows\system32\serialui.dll - Ok
C:\Windows\system32\serwvdrv.dll - Ok
C:\Windows\system32\SensorsClassExtension.dll - Ok
C:\Windows\system32\secproc_ssp_isv.dll - Ok
C:\Windows\system32\SensorsApi.dll - Ok
C:\Windows\system32\secproc_isv.dll - Ok
C:\Windows\system32\SessEnv.dll - Ok
C:\Windows\system32\services.exe - Ok
C:\Windows\system32\setspn.exe - Ok
C:\Windows\system32\setupetw.dll - Ok
C:\Windows\system32\setupcl.exe - Ok
C:\Windows\system32\services.msc - Ok
C:\Windows\system32\sfc.dll - Ok
C:\Windows\system32\setupugc.exe - Ok
C:\Windows\system32\sethc.exe - Ok
C:\Windows\system32\SetIEInstalledDate.exe - Ok
C:\Windows\system32\setbcdlocale.dll - Ok
>C:\Windows\system32\setupapi.dll - packed by BINARYRES
C:\Windows\system32\sfc_os.dll - Ok
>>C:\Windows\system32\setupapi.dll - packed by MS COMPRESS
C:\Windows\system32\setupapi.dll - Ok
C:\Windows\system32\shacct.dll - Ok
C:\Windows\system32\sharemediacpl.dll - Ok
C:\Windows\system32\shdocvw.dll - Ok
C:\Windows\system32\ShiftJIS.uce - Ok
C:\Windows\system32\sfc.exe - Ok
C:\Windows\system32\shfolder.dll - Ok
C:\Windows\system32\setupcln.dll - Ok
C:\Windows\system32\setx.exe - Ok
C:\Windows\system32\SearchFolder.dll - Ok
C:\Windows\system32\shgina.dll - Ok
C:\Windows\system32\shimgvw.dll - Ok
C:\Windows\system32\shimeng.dll - Ok
C:\Windows\system32\shpafact.dll - Ok
C:\Windows\system32\shlwapi.dll - Ok
C:\Windows\system32\shsvcs.dll - Ok
C:\Windows\system32\shunimpl.dll - Ok
C:\Windows\system32\shellstyle.dll - Ok
C:\Windows\system32\shsetup.dll - Ok
C:\Windows\system32\shutdown.exe - Ok
C:\Windows\system32\SensorsCpl.dll - Ok
C:\Windows\system32\slc.dll - Ok
C:\Windows\system32\sisbkup.dll - Ok
C:\Windows\system32\shrpubw.exe - Ok
C:\Windows\system32\shwebsvc.dll - Ok
C:\Windows\system32\simpdata.tlb - Ok
C:\Windows\system32\sigverif.exe - Ok
C:\Windows\system32\signdrv.dll - Ok
C:\Windows\system32\slwga.dll - Ok
C:\Windows\system32\SmartcardCredentialProvider.dll - Ok
C:\Windows\system32\SMBHelperClass.dll - Ok
C:\Windows\system32\smss.exe - Ok
>C:\Windows\system32\shell32.dll is BINARYRES container
C:\Windows\system32\shell32.dll - container
C:\Windows\system32\SndVolSSO.dll - Ok
C:\Windows\system32\snmpapi.dll - Ok
C:\Windows\system32\snmptrap.exe - Ok
C:\Windows\system32\SndVol.exe - Ok
C:\Windows\system32\softpub.dll - Ok
C:\Windows\system32\slcext.dll - Ok
C:\Windows\system32\SNTSearch.dll - Ok
C:\Windows\system32\SortWindows6Compat.dll - Ok
C:\Windows\system32\SortServer2003Compat.dll - Ok
C:\Windows\system32\softkbd.dll - Ok
C:\Windows\system32\spcinstrumentation.man - Ok
C:\Windows\system32\spbcd.dll - Ok
C:\Windows\system32\SlotMaximizerAg.dll - Ok
>C:\Windows\system32\spfileq.dll - packed by BINARYRES
>>C:\Windows\system32\spfileq.dll - packed by MS COMPRESS
C:\Windows\system32\SPInf.dll - Ok
C:\Windows\system32\spfileq.dll - Ok
C:\Windows\system32\spnet.dll - Ok
C:\Windows\system32\slmgr.vbs - Ok
C:\Windows\system32\sort.exe - Ok
C:\Windows\system32\spcmsg.dll - Ok
C:\Windows\system32\spoolss.dll - Ok
C:\Windows\system32\spopk.dll - Ok
C:\Windows\system32\sperror.dll - Ok
C:\Windows\system32\spoolsv.exe - Ok
C:\Windows\system32\SnippingTool.exe - Ok
C:\Windows\system32\SlotMaximizerBe.dll - Ok
C:\Windows\system32\SoundRecorder.exe - Ok
C:\Windows\system32\sppc.dll - Ok
C:\Windows\system32\spp.dll - Ok
C:\Windows\system32\sppnp.dll - Ok
C:\Windows\system32\slui.exe - Ok
C:\Windows\system32\sppsvc.exe - Ok
C:\Windows\system32\sppcc.dll - Ok
C:\Windows\system32\sppuinotify.dll - Ok
C:\Windows\system32\sppinst.dll - Ok
C:\Windows\system32\sppcomapi.dll - Ok
C:\Windows\system32\spwinsat.dll - Ok
C:\Windows\system32\spreview.exe - Ok
C:\Windows\system32\sppwmi.dll - Ok
C:\Windows\system32\spwizeng.dll - Ok
C:\Windows\system32\spwizres.dll - Ok
C:\Windows\system32\spwmp.dll - Ok
C:\Windows\system32\spinstall.exe - Ok
C:\Windows\system32\sppcommdlg.dll - Ok
C:\Windows\system32\sqlceoledb30.dll - Ok
C:\Windows\system32\sqmapi.dll - Ok
C:\Windows\system32\sqlcese30.dll - Ok
C:\Windows\system32\srchadmin.dll - Ok
C:\Windows\system32\srcore.dll - Ok
C:\Windows\system32\sqlsrv32.rll - Ok
C:\Windows\system32\srdelayed.exe - Ok
C:\Windows\system32\spwizui.dll - Ok
C:\Windows\system32\sqlsrv32.dll - Ok
C:\Windows\system32\srvcli.dll - Ok
C:\Windows\system32\srvsvc.dll - Ok
C:\Windows\system32\sppwinob.dll - Ok
C:\Windows\system32\sscore.dll - Ok
C:\Windows\system32\sppcext.dll - Ok
C:\Windows\system32\ssdpapi.dll - Ok
C:\Windows\system32\sspisrv.dll - Ok
C:\Windows\system32\srwmi.dll - Ok
C:\Windows\system32\ssdpsrv.dll - Ok
C:\Windows\system32\sspicli.dll - Ok
C:\Windows\system32\sstpsvc.dll - Ok
C:\Windows\system32\SSShim.dll - Ok
C:\Windows\system32\sqlceqp30.dll - Ok
C:\Windows\system32\stclient.dll - Ok
C:\Windows\system32\stapi64.dll - Ok
C:\Windows\system32\stapo64.dll - Ok
C:\Windows\system32\SmiEngine.dll - Ok
C:\Windows\system32\staco64.dll - Ok
C:\Windows\system32\StikyNot.exe - Ok
C:\Windows\system32\srhelper.dll - Ok
C:\Windows\system32\srclient.dll - Ok
C:\Windows\system32\stobject.dll - Ok
C:\Windows\system32\stdole2.tlb - Ok
C:\Windows\system32\StorageContextHandler.dll - Ok
C:\Windows\system32\stdole32.tlb - Ok
C:\Windows\system32\StructuredQuery.dll - Ok
C:\Windows\system32\SubRange.uce - Ok
C:\Windows\system32\Storprop.dll - Ok
C:\Windows\system32\stcplx64.dll - Ok
C:\Windows\system32\svchost.exe - Ok
C:\Windows\system32\srrstr.dll - Ok
C:\Windows\system32\sud.dll - Ok
C:\Windows\system32\swprv.dll - Ok
C:\Windows\system32\sxproxy.dll - Ok
C:\Windows\system32\sxssrv.dll - Ok
C:\Windows\system32\sxshared.dll - Ok
C:\Windows\system32\sxs.dll - Ok
C:\Windows\system32\sxsstore.dll - Ok
C:\Windows\system32\streamci.dll - Ok
C:\Windows\system32\synceng.dll - Ok
C:\Windows\system32\SyncCenter.dll - Ok
C:\Windows\system32\subst.exe - Ok
C:\Windows\system32\sxstrace.exe - Ok
C:\Windows\system32\ssText3d.scr - Ok
C:\Windows\system32\SyncHost.exe - Ok
C:\Windows\system32\SyncInfrastructureps.dll - Ok
C:\Windows\system32\Syncreg.dll - Ok
C:\Windows\system32\SyncInfrastructure.dll - Ok
C:\Windows\system32\SynCOM.dll - Ok
C:\Windows\system32\syncui.dll - Ok
C:\Windows\system32\sti_ci.dll - Ok
C:\Windows\system32\SynTPAPI.dll - Ok
C:\Windows\system32\SynCtrl.dll - Ok
C:\Windows\system32\SynTPCo9.dll - Ok
C:\Windows\system32\sysdm.cpl - Ok
C:\Windows\system32\syskey.exe - Ok
C:\Windows\system32\sysmain.dll - Ok
C:\Windows\system32\sysntfy.dll - Ok
C:\Windows\system32\sysprint.sep - Ok
C:\Windows\system32\sysprtj.sep - Ok
C:\Windows\system32\sysmon.ocx - Ok
C:\Windows\system32\SysFxUI.dll - Ok
C:\Windows\system32\sysprepMCE.dll - Ok
C:\Windows\system32\syssetup.dll - Ok
C:\Windows\system32\systeminfo.exe - Ok
C:\Windows\system32\SystemPropertiesComputerName.exe - Ok
C:\Windows\system32\SystemPropertiesAdvanced.exe - Ok
C:\Windows\system32\SyncHostps.dll - Ok
C:\Windows\system32\sti.dll - Ok
C:\Windows\system32\systemsf.ebd - Ok
C:\Windows\system32\sysclass.dll - Ok
C:\Windows\system32\t2embed.dll - Ok
C:\Windows\system32\systemcpl.dll - Ok
C:\Windows\system32\systray.exe - Ok
C:\Windows\system32\SystemPropertiesPerformance.exe - Ok
C:\Windows\system32\SystemPropertiesDataExecutionPrevention.exe - Ok
C:\Windows\system32\SystemPropertiesHardware.exe - Ok
C:\Windows\system32\SystemPropertiesProtection.exe - Ok
C:\Windows\system32\TabbtnEx.dll - Ok
C:\Windows\system32\Tabbtn.dll - Ok
C:\Windows\system32\tabcal.exe - Ok
C:\Windows\system32\SystemPropertiesRemote.exe - Ok
C:\Windows\system32\TabSvc.dll - Ok
C:\Windows\system32\tapilua.dll - Ok
C:\Windows\system32\tapiperf.dll - Ok
C:\Windows\system32\TapiMigPlugin.dll - Ok
C:\Windows\system32\tapisrv.dll - Ok
C:\Windows\system32\takeown.exe - Ok
C:\Windows\system32\tapi3.dll - Ok
C:\Windows\system32\taskbarcpl.dll - Ok
C:\Windows\system32\tapi32.dll - Ok
C:\Windows\system32\taskhost.exe - Ok
C:\Windows\system32\taskeng.exe - Ok
C:\Windows\system32\taskcomp.dll - Ok
C:\Windows\system32\taskkill.exe - Ok
C:\Windows\system32\tapiui.dll - Ok
C:\Windows\system32\TapiSysprep.dll - Ok
C:\Windows\system32\tasklist.exe - Ok
C:\Windows\system32\TapiUnattend.exe - Ok
C:\Windows\system32\tbs.dll - Ok
C:\Windows\system32\TaskSchdPS.dll - Ok
C:\Windows\system32\taskmgr.exe - Ok
C:\Windows\system32\tcpbidi.xml - Ok
C:\Windows\system32\tbssvc.dll - Ok
C:\Windows\system32\tcpmib.dll - Ok
C:\Windows\system32\taskschd.msc - Ok
C:\Windows\system32\tcpmon.dll - Ok
C:\Windows\system32\tcmsetup.exe - Ok
C:\Windows\system32\tdc.ocx - Ok
C:\Windows\system32\taskschd.dll - Ok
C:\Windows\system32\tcpmonui.dll - Ok
C:\Windows\system32\TCPSVCS.EXE - Ok
C:\Windows\system32\TabletPC.cpl - Ok
C:\Windows\system32\telephon.cpl - Ok
C:\Windows\system32\sppobjs.dll - Ok
C:\Windows\system32\themeservice.dll - Ok
C:\Windows\system32\termsrv.dll - Ok
C:\Windows\system32\termmgr.dll - Ok
C:\Windows\system32\tcpipcfg.dll - Ok
C:\Windows\system32\tdh.dll - Ok
C:\Windows\system32\stlang64.dll - Ok
C:\Windows\system32\themecpl.dll - Ok
C:\Windows\system32\ticrf.rat - Ok
C:\Windows\system32\themeui.dll - Ok
C:\Windows\system32\tlscsp.dll - Ok
>C:\Windows\system32\timedate.cpl is ZLIB container
C:\Windows\system32\thumbcache.dll - Ok
C:\Windows\system32\timeout.exe - Ok
C:\Windows\system32\TimeDateMUICallback.dll - Ok
C:\Windows\system32\tpmcompc.dll - Ok
C:\Windows\system32\tintlgnt.ime - Ok
C:\Windows\system32\tpm.msc - Ok
C:\Windows\system32\thawbrkr.dll - Ok
C:\Windows\system32\timedate.cpl - container
C:\Windows\system32\TpmInit.exe - Ok
C:\Windows\system32\tree.com - Ok
C:\Windows\system32\TRAPI.dll - Ok
C:\Windows\system32\trkwks.dll - Ok
C:\Windows\system32\TRACERT.EXE - Ok
C:\Windows\system32\TSChannel.dll - Ok
C:\Windows\system32\tsbyuv.dll - Ok
C:\Windows\system32\tsddd.dll - Ok
C:\Windows\system32\traffic.dll - Ok
C:\Windows\system32\tracerpt.exe - Ok
C:\Windows\system32\TsUsbRedirectionGroupPolicyExtension.dll - Ok
C:\Windows\system32\TsUsbGDCoInstaller.dll - Ok
C:\Windows\system32\TSpkg.dll - Ok
C:\Windows\system32\tsgqec.dll - Ok
C:\Windows\system32\TSTheme.exe - Ok
C:\Windows\system32\TsUsbRedirectionGroupPolicyControl.exe - Ok
C:\Windows\system32\tsmf.dll - Ok
C:\Windows\system32\TSWbPrxy.exe - Ok
C:\Windows\system32\txfw32.dll - Ok
C:\Windows\system32\tzres.dll - Ok
C:\Windows\system32\tcpmon.ini - Ok
C:\Windows\system32\tvratings.dll - Ok
C:\Windows\system32\typeperf.exe - Ok
C:\Windows\system32\TSWorkspace.dll - Ok
C:\Windows\system32\tquery.dll - Ok
C:\Windows\system32\twext.dll - Ok
C:\Windows\system32\tzutil.exe - Ok
C:\Windows\system32\TsWpfWrp.exe - Ok
C:\Windows\system32\ubpm.dll - Ok
C:\Windows\system32\udhisapi.dll - Ok
C:\Windows\system32\UI0Detect.exe - Ok
C:\Windows\system32\ucsvc.exe - Ok
C:\Windows\system32\txflog.dll - Ok
C:\Windows\system32\uDWM.dll - Ok
C:\Windows\system32\ucmhc.dll - Ok
C:\Windows\system32\ufat.dll - Ok
C:\Windows\system32\UIAnimation.dll - Ok
C:\Windows\system32\umdmxfrm.dll - Ok
C:\Windows\system32\umb.dll - Ok
C:\Windows\system32\ulib.dll - Ok
C:\Windows\system32\umstartup.etl - Ok
C:\Windows\system32\uexfat.dll - Ok
C:\Windows\system32\umstartup000.etl - Ok
C:\Windows\system32\uicom.dll - Ok
C:\Windows\system32\UIAutomationCore.dll - Ok
C:\Windows\system32\umpnpmgr.dll - Ok
C:\Windows\system32\unimdmat.dll - Ok
C:\Windows\system32\umpo.dll - Ok
C:\Windows\system32\uniplat.dll - Ok
C:\Windows\system32\unlodctr.exe - Ok
C:\Windows\system32\unregmp2.exe - Ok
C:\Windows\system32\upnpcont.exe - Ok
C:\Windows\system32\upnp.dll - Ok
C:\Windows\system32\untfs.dll - Ok
C:\Windows\system32\unimdm.tsp - Ok
C:\Windows\system32\upnphost.dll - Ok
C:\Windows\system32\unattend.dll - Ok
C:\Windows\system32\UIRibbon.dll - Ok
C:\Windows\system32\usbmon.dll - Ok
C:\Windows\system32\usbperf.dll - Ok
C:\Windows\system32\UIHub.dll - Ok
C:\Windows\system32\ureg.dll - Ok
C:\Windows\system32\url.dll - Ok
C:\Windows\system32\usbui.dll - Ok
C:\Windows\system32\UserAccountControlSettings.dll - Ok
C:\Windows\system32\userenv.dll - Ok
C:\Windows\system32\user32.dll - Ok
C:\Windows\system32\UIRibbonRes.dll - Ok
C:\Windows\system32\usercpl.dll - Ok
C:\Windows\system32\userinit.exe - Ok
>C:\Windows\system32\urlmon.dll is BINARYRES container
C:\Windows\system32\urlmon.dll - container
C:\Windows\system32\utildll.dll - Ok
C:\Windows\system32\usbceip.dll - Ok
C:\Windows\system32\UserAccountControlSettings.exe - Ok
C:\Windows\system32\UXInit.dll - Ok
C:\Windows\system32\usk.rs - Ok
C:\Windows\system32\uxlibres.dll - Ok
C:\Windows\system32\uxsms.dll - Ok
C:\Windows\system32\usp10.dll - Ok
C:\Windows\system32\uudf.dll - Ok
C:\Windows\system32\vaultcli.dll - Ok
C:\Windows\system32\uxlib.dll - Ok
C:\Windows\system32\VaultCmd.exe - Ok
C:\Windows\system32\uxtheme.dll - Ok
C:\Windows\system32\VaultCredProvider.dll - Ok
C:\Windows\system32\vaultsvc.dll - Ok
C:\Windows\system32\VBAME.DLL - Ok
C:\Windows\system32\VAN.dll - Ok
C:\Windows\system32\vdsbas.dll - Ok
C:\Windows\system32\vds.exe - Ok
C:\Windows\system32\Utilman.exe - Ok
C:\Windows\system32\VaultSysUi.exe - Ok
C:\Windows\system32\vbisurf.ax - Ok
C:\Windows\system32\vdsdyn.dll - Ok
C:\Windows\system32\vdsldr.exe - Ok
C:\Windows\system32\VBICodec.ax - Ok
C:\Windows\system32\vdsvd.dll - Ok
C:\Windows\system32\vdsutil.dll - Ok
C:\Windows\system32\vbscript.dll - Ok
C:\Windows\system32\version.dll - Ok
C:\Windows\system32\VEN2232.OLB - Ok
C:\Windows\system32\vfwwdm32.dll - Ok
C:\Windows\system32\vcomp100.dll - Ok
C:\Windows\system32\verifier.dll - Ok
C:\Windows\system32\verclsid.exe - Ok
C:\Windows\system32\vga.dll - Ok
C:\Windows\system32\vidcap.ax - Ok
C:\Windows\system32\virtdisk.dll - Ok
C:\Windows\system32\verifier.exe - Ok
C:\Windows\system32\vds_ps.dll - Ok
C:\Windows\system32\vsstrace.dll - Ok
C:\Windows\system32\vpnike.dll - Ok
C:\Windows\system32\vpnikeapi.dll - Ok
C:\Windows\system32\VSSVC.exe - Ok
C:\Windows\system32\vss_ps.dll - Ok
C:\Windows\system32\WABSyncProvider.dll - Ok
C:\Windows\system32\w32tm.exe - Ok
C:\Windows\system32\Vault.dll - Ok
C:\Windows\system32\w32topl.dll - Ok
C:\Windows\system32\waitfor.exe - Ok
C:\Windows\system32\WavDest.dll - Ok
C:\Windows\system32\w32time.dll - Ok
C:\Windows\system32\wbengine.exe - Ok
C:\Windows\system32\wavemsp.dll - Ok
C:\Windows\system32\VIDRESZR.DLL - Ok
C:\Windows\system32\wbadmin.exe - Ok
C:\Windows\system32\vssadmin.exe - Ok
C:\Windows\system32\vssapi.dll - Ok
C:\Windows\system32\wbiosrvc.dll - Ok
C:\Windows\system32\wbemcomn.dll - Ok
C:\Windows\system32\WcnNetsh.dll - Ok
C:\Windows\system32\WcsPlugInService.dll - Ok
C:\Windows\system32\WcnEapPeerProxy.dll - Ok
C:\Windows\system32\wcncsvc.dll - Ok
C:\Windows\system32\Wdfres.dll - Ok
C:\Windows\system32\wdiasqmmodule.dll - Ok
C:\Windows\system32\wdi.dll - Ok
C:\Windows\system32\WdsUnattendTemplate.xml - Ok
C:\Windows\system32\wdmaud.drv - Ok
C:\Windows\system32\wdigest.dll - Ok
C:\Windows\system32\WcnEapAuthProxy.dll - Ok
C:\Windows\system32\WcnApi.dll - Ok
C:\Windows\system32\wdscore.dll - Ok
C:\Windows\system32\WEB.rs - Ok
C:\Windows\system32\wdc.dll - Ok
C:\Windows\system32\webcheck.dll - Ok
C:\Windows\system32\wecapi.dll - Ok
C:\Windows\system32\WebClnt.dll - Ok
C:\Windows\system32\webio.dll - Ok
C:\Windows\system32\wecsvc.dll - Ok
C:\Windows\system32\wercplsupport.dll - Ok
C:\Windows\system32\wecutil.exe - Ok
C:\Windows\system32\werdiagcontroller.dll - Ok
C:\Windows\system32\wer.dll - Ok
C:\Windows\system32\webservices.dll - Ok
C:\Windows\system32\wermgr.exe - Ok
C:\Windows\system32\WerFaultSecure.exe - Ok
C:\Windows\system32\wersvc.dll - Ok
C:\Windows\system32\WerFault.exe - Ok
C:\Windows\system32\spwizimg.dll - Ok
C:\Windows\system32\wevtfwd.dll - Ok
C:\Windows\system32\wevtapi.dll - Ok
C:\Windows\system32\werconcpl.dll - Ok
C:\Windows\system32\wcnwiz.dll - Ok
C:\Windows\system32\wfapigp.dll - Ok
C:\Windows\system32\wevtutil.exe - Ok
C:\Windows\system32\whealogr.dll - Ok
C:\Windows\system32\WF.msc - Ok
C:\Windows\system32\WfHC.dll - Ok
C:\Windows\system32\where.exe - Ok
C:\Windows\system32\whhelper.dll - Ok
C:\Windows\system32\WFS.exe - Ok
C:\Windows\system32\whoami.exe - Ok
C:\Windows\system32\wiaacmgr.exe - Ok
C:\Windows\system32\werui.dll - Ok
C:\Windows\system32\wiarpc.dll - Ok
C:\Windows\system32\wiadss.dll - Ok
C:\Windows\system32\WiaExtensionHost64.dll - Ok
C:\Windows\system32\wevtsvc.dll - Ok
C:\Windows\system32\wiadefui.dll - Ok
C:\Windows\system32\wiascanprofiles.dll - Ok
C:\Windows\system32\wiatrace.dll - Ok
C:\Windows\system32\wextract.exe - Ok
C:\Windows\system32\wiaservc.dll - Ok
C:\Windows\system32\wiavideo.dll - Ok
C:\Windows\system32\wiawow64.exe - Ok
C:\Windows\system32\wiashext.dll - Ok
C:\Windows\system32\usbaaplrc.dll - Ok
C:\Windows\system32\win32k.sys - Ok
C:\Windows\system32\win32spl.dll - Ok
C:\Windows\system32\wincredprovider.dll - Ok
C:\Windows\system32\winbio.dll - Ok
C:\Windows\system32\winbrand.dll - Ok
C:\Windows\system32\WindowsAnytimeUpgrade.exe - Ok
C:\Windows\system32\WindowsCodecsExt.dll - Ok
C:\Windows\system32\wimgapi.dll - Ok
C:\Windows\system32\WindowsCodecs.dll - Ok
C:\Windows\system32\wiaaut.dll - Ok
>C:\Windows\system32\WdfCoInstaller01009.dll is CAB archive
C:\Windows\system32\WdfCoInstaller01009.dll - Ok
C:\Windows\system32\WdfCoInstaller01009.dll - archive
C:\Windows\system32\winethc.dll - Ok
C:\Windows\system32\WindowsAnytimeUpgradeui.exe - Ok
C:\Windows\system32\wininit.exe - Ok
C:\Windows\system32\WinFax.dll - Ok
C:\Windows\system32\winipsec.dll - Ok
C:\Windows\system32\wimserv.exe - Ok
C:\Windows\system32\winhttp.dll - Ok
C:\Windows\system32\winnsi.dll - Ok
C:\Windows\system32\winrm.cmd - Ok
C:\Windows\system32\WindowsAnytimeUpgradeResults.exe - Ok
C:\Windows\system32\winrnr.dll - Ok
C:\Windows\system32\winmm.dll - Ok
C:\Windows\system32\winlogon.exe - Ok
C:\Windows\system32\WFSR.dll - Ok
C:\Windows\system32\winrsmgr.dll - Ok
C:\Windows\system32\winrs.exe - Ok
C:\Windows\system32\winrshost.exe - Ok
C:\Windows\system32\winload.efi - Ok
C:\Windows\system32\winrssrv.dll - Ok
C:\Windows\system32\wininet.dll - Ok
C:\Windows\system32\winrscmd.dll - Ok
C:\Windows\system32\winresume.exe - Ok
C:\Windows\system32\winload.exe - Ok
>C:\Windows\system32\WinSATAPI.dll is ZLIB container
C:\Windows\system32\winresume.efi - Ok
C:\Windows\system32\WINSRPC.DLL - Ok
C:\Windows\system32\WinSAT.exe - Ok
C:\Windows\system32\winspool.drv - Ok
C:\Windows\system32\WinSATAPI.dll - container
C:\Windows\system32\WinSCard.dll - Ok
C:\Windows\system32\winshfhc.dll - Ok
C:\Windows\system32\winsockhc.dll - Ok
C:\Windows\system32\winsrv.dll - Ok
C:\Windows\system32\winusb.dll - Ok
C:\Windows\system32\winsta.dll - Ok
C:\Windows\system32\wintrust.dll - Ok
C:\Windows\system32\WinSyncMetastore.dll - Ok
C:\Windows\system32\WinSyncProviders.dll - Ok
C:\Windows\system32\wkscli.dll - Ok
C:\Windows\system32\wisptis.exe - Ok
C:\Windows\system32\wkssvc.dll - Ok
C:\Windows\system32\wlanapi.dll - Ok
C:\Windows\system32\wlancfg.dll - Ok
C:\Windows\system32\wksprtPS.dll - Ok
C:\Windows\system32\wlanext.exe - Ok
C:\Windows\system32\WLanConn.dll - Ok
C:\Windows\system32\winver.exe - Ok
C:\Windows\system32\wlanhlp.dll - Ok
C:\Windows\system32\wlaninst.dll - Ok
C:\Windows\system32\wlanmsm.dll - Ok
C:\Windows\system32\wksprt.exe - Ok
C:\Windows\system32\WinSync.dll - Ok
C:\Windows\system32\WLanHC.dll - Ok
C:\Windows\system32\WlanMM.dll - Ok
C:\Windows\system32\wlansec.dll - Ok
C:\Windows\system32\wlangpui.dll - Ok
C:\Windows\system32\wlandlg.dll - Ok
C:\Windows\system32\winrm.vbs - Ok
C:\Windows\system32\wlanutil.dll - Ok
C:\Windows\system32\wlansvc.dll - Ok
C:\Windows\system32\WlS0WndH.dll - Ok
C:\Windows\system32\wlgpclnt.dll - Ok
C:\Windows\system32\wlanpref.dll - Ok
C:\Windows\system32\wlrmdr.exe - Ok
C:\Windows\system32\wmcodecdspps.dll - Ok
C:\Windows\system32\wmdmlog.dll - Ok
C:\Windows\system32\Wldap32.dll - Ok
C:\Windows\system32\WMALFXGFXDSP.dll - Ok
C:\Windows\system32\wmerror.dll - Ok
C:\Windows\system32\wmdrmdev.dll - Ok
C:\Windows\system32\wlanui.dll - Ok
C:\Windows\system32\wmdmps.dll - Ok
C:\Windows\system32\wmi.dll - Ok
C:\Windows\system32\wmdrmnet.dll - Ok
C:\Windows\system32\wmiprop.dll - Ok
C:\Windows\system32\WMASF.DLL - Ok
C:\Windows\system32\wmidx.dll - Ok
C:\Windows\system32\WmiMgmt.msc - Ok
C:\Windows\system32\wmpcm.dll - Ok
C:\Windows\system32\WmpDui.dll - Ok
C:\Windows\system32\wmpdxm.dll - Ok
C:\Windows\system32\WMPhoto.dll - Ok
C:\Windows\system32\WMADMOD.DLL - Ok
>C:\Windows\system32\wmpmde.dll - packed by PESTUB
C:\Windows\system32\WMADMOE.DLL - Ok
C:\Windows\system32\wmdrmsdk.dll - Ok
C:\Windows\system32\wmp.dll - Ok
C:\Windows\system32\wmpps.dll - Ok
C:\Windows\system32\wmsgapi.dll - Ok
C:\Windows\system32\wmpmde.dll - Ok
C:\Windows\system32\wmpshell.dll - Ok
C:\Windows\system32\wmpsrcwp.dll - Ok
C:\Windows\system32\WMNetMgr.dll - Ok
C:\Windows\system32\wmpeffects.dll - Ok
C:\Windows\system32\WMPEncEn.dll - Ok
C:\Windows\system32\wmvdspa.dll - Ok
C:\Windows\system32\WMVSENCD.DLL - Ok
C:\Windows\system32\wow64.dll - Ok
C:\Windows\system32\WMVXENCD.DLL - Ok
C:\Windows\system32\wow64cpu.dll - Ok
C:\Windows\system32\WMVSDECD.DLL - Ok
C:\Windows\system32\wow64win.dll - Ok
C:\Windows\system32\WMSPDMOD.DLL - Ok
C:\Windows\system32\wowreg32.exe - Ok
C:\Windows\system32\wpcao.dll - Ok
C:\Windows\system32\Wpc.dll - Ok
C:\Windows\system32\wpcsvc.dll - Ok
C:\Windows\system32\wpcmig.dll - Ok
C:\Windows\system32\wpdbusenum.dll - Ok
C:\Windows\system32\wpcumi.dll - Ok
C:\Windows\system32\WMSPDMOE.DLL - Ok
C:\Windows\system32\wmicmiplugin.dll - Ok
C:\Windows\system32\WMVENCOD.DLL - Ok
C:\Windows\system32\WPDShServiceObj.dll - Ok
C:\Windows\system32\wpccpl.dll - Ok
C:\Windows\system32\WpdMtpUS.dll - Ok
C:\Windows\system32\wmploc.DLL - Ok
C:\Windows\system32\WpdMtp.dll - Ok
C:\Windows\system32\wpnpinst.exe - Ok
C:\Windows\system32\WPDShextAutoplay.exe - Ok
C:\Windows\system32\write.exe - Ok
C:\Windows\system32\wpd_ci.dll - Ok
C:\Windows\system32\wscapi.dll - Ok
C:\Windows\system32\wscinterop.dll - Ok
C:\Windows\system32\wlihvui.dll - Ok
C:\Windows\system32\WPDSp.dll - Ok
C:\Windows\system32\ws2_32.dll - Ok
C:\Windows\system32\wscproxystub.dll - Ok
C:\Windows\system32\wscsvc.dll - Ok
>C:\Windows\system32\wscui.cpl is ZLIB container
C:\Windows\system32\ws2help.dll - Ok
C:\Windows\system32\wscisvif.dll - Ok
C:\Windows\system32\wsdchngr.dll - Ok
C:\Windows\system32\WSDMon.dll - Ok
C:\Windows\system32\WSDApi.dll - Ok
C:\Windows\system32\wpdwcn.dll - Ok
C:\Windows\system32\wsepno.dll - Ok
C:\Windows\system32\WSDScanProxy.dll - Ok
C:\Windows\system32\wscmisetup.dll - Ok
C:\Windows\system32\wshbth.dll - Ok
C:\Windows\system32\wshelper.dll - Ok
C:\Windows\system32\wship6.dll - Ok
C:\Windows\system32\WSDPrintProxy.DLL - Ok
C:\Windows\system32\wshext.dll - Ok
C:\Windows\system32\wscui.cpl - container
C:\Windows\system32\wshirda.dll - Ok
C:\Windows\system32\WSHTCPIP.DLL - Ok
C:\Windows\system32\wshrm.dll - Ok
C:\Windows\system32\wshcon.dll - Ok
C:\Windows\system32\wshqos.dll - Ok
C:\Windows\system32\wsmanconfig_schema.xml - Ok
C:\Windows\system32\wscript.exe - Ok
C:\Windows\system32\wsmprovhost.exe - Ok
C:\Windows\system32\wsmplpxy.dll - Ok
C:\Windows\system32\wshnetbs.dll - Ok
C:\Windows\system32\WsmPty.xsl - Ok
C:\Windows\system32\WsmAuto.dll - Ok
C:\Windows\system32\WsmTxt.xsl - Ok
C:\Windows\system32\WsmRes.dll - Ok
C:\Windows\system32\wsnmp32.dll - Ok
C:\Windows\system32\wsock32.dll - Ok
C:\Windows\system32\WsmSvc.dll - Ok
C:\Windows\system32\wshom.ocx - Ok
C:\Windows\system32\wtsapi32.dll - Ok
C:\Windows\system32\wsqmcons.exe - Ok
C:\Windows\system32\WSManMigrationPlugin.dll - Ok
C:\Windows\system32\WSTPager.ax - Ok
C:\Windows\system32\wsecedit.dll - Ok
C:\Windows\system32\wuauclt.exe - Ok
C:\Windows\system32\wuapi.dll - Ok
C:\Windows\system32\wuaueng.dll - Ok
C:\Windows\system32\WUDFHost.exe - Ok
C:\Windows\system32\wuapp.exe - Ok
C:\Windows\system32\WUDFPlatform.dll - Ok
C:\Windows\system32\WUDFSvc.dll - Ok
C:\Windows\system32\WUDFx.dll - Ok
C:\Windows\system32\wups2.dll - Ok
C:\Windows\system32\wups.dll - Ok
C:\Windows\system32\WUDFCoinstaller.dll - Ok
C:\Windows\system32\wudriver.dll - Ok
C:\Windows\system32\WMVDECOD.DLL - Ok
C:\Windows\system32\wusa.exe - Ok
C:\Windows\system32\Wwanadvui.dll - Ok
C:\Windows\system32\wwancfg.dll - Ok
C:\Windows\system32\WSManHTTPConfig.exe - Ok
C:\Windows\system32\WsmWmiPl.dll - Ok
C:\Windows\system32\WWanAPI.dll - Ok
C:\Windows\system32\wwaninst.dll - Ok
C:\Windows\system32\wuwebv.dll - Ok
C:\Windows\system32\wpdshext.dll - Ok
C:\Windows\system32\WWanHC.dll - Ok
C:\Windows\system32\wwanmm.dll - Ok
C:\Windows\system32\wwapi.dll - Ok
C:\Windows\system32\Wwanpref.dll - Ok
C:\Windows\system32\wwanprotdim.dll - Ok
C:\Windows\system32\wwansvc.dll - Ok
C:\Windows\system32\wwanconn.dll - Ok
C:\Windows\system32\xcopy.exe - Ok
C:\Windows\system32\xolehlp.dll - Ok
C:\Windows\system32\xmllite.dll - Ok
C:\Windows\system32\XInput9_1_0.dll - Ok
C:\Windows\system32\wvc.dll - Ok
C:\Windows\system32\xmlfilter.dll - Ok
C:\Windows\system32\xmlprovi.dll - Ok
C:\Windows\system32\XpsRasterService.dll - Ok
C:\Windows\system32\xpsrchvw.xml - Ok
C:\Windows\system32\xwizard.dtd - Ok
C:\Windows\system32\xwizard.exe - Ok
C:\Windows\system32\XPSSHHDR.dll - Ok
C:\Windows\system32\xwizards.dll - Ok
C:\Windows\system32\wzcdlg.dll - Ok
C:\Windows\system32\xwreg.dll - Ok
C:\Windows\system32\xwtpw32.dll - Ok
C:\Windows\system32\XpsFilt.dll - Ok
C:\Windows\system32\0401\nusb3co.dll.mui - Ok
C:\Windows\system32\zgmprxy.dll - Ok
C:\Windows\system32\0404\nusb3co.dll.mui - Ok
C:\Windows\system32\0405\nusb3co.dll.mui - Ok
C:\Windows\system32\0406\nusb3co.dll.mui - Ok
C:\Windows\system32\0407\nusb3co.dll.mui - Ok
C:\Windows\system32\0408\nusb3co.dll.mui - Ok
C:\Windows\system32\zipfldr.dll - Ok
C:\Windows\system32\0409\nusb3co.dll.mui - Ok
C:\Windows\system32\040A\nusb3co.dll.mui - Ok
C:\Windows\system32\040B\nusb3co.dll.mui - Ok
C:\Windows\system32\040D\nusb3co.dll.mui - Ok
C:\Windows\system32\040C\nusb3co.dll.mui - Ok
C:\Windows\system32\040E\nusb3co.dll.mui - Ok
C:\Windows\system32\xwtpdui.dll - Ok
C:\Windows\system32\0410\nusb3co.dll.mui - Ok
C:\Windows\system32\0411\nusb3co.dll.mui - Ok
C:\Windows\system32\0412\nusb3co.dll.mui - Ok
C:\Windows\system32\0413\nusb3co.dll.mui - Ok
C:\Windows\system32\0414\nusb3co.dll.mui - Ok
C:\Windows\system32\0416\nusb3co.dll.mui - Ok
C:\Windows\system32\0415\nusb3co.dll.mui - Ok
C:\Windows\system32\0419\nusb3co.dll.mui - Ok
C:\Windows\system32\041B\nusb3co.dll.mui - Ok
C:\Windows\system32\041D\nusb3co.dll.mui - Ok
C:\Windows\system32\041E\nusb3co.dll.mui - Ok
C:\Windows\system32\041F\nusb3co.dll.mui - Ok
C:\Windows\system32\0424\nusb3co.dll.mui - Ok
C:\Windows\system32\0816\nusb3co.dll.mui - Ok
C:\Windows\system32\0804\nusb3co.dll.mui - Ok
C:\Windows\system32\0C04\nusb3co.dll.mui - Ok
C:\Windows\system32\0C0A\nusb3co.dll.mui - Ok
C:\Windows\system32\2C0A\nusb3co.dll.mui - Ok
C:\Windows\system32\xpsservices.dll - Ok
C:\Windows\system32\xpssvcs.dll - Ok
C:\Windows\system32\AdvancedInstallers\cmiadapter.dll - Ok
C:\Windows\system32\AdvancedInstallers\OEMHelpIns.dll - Ok
C:\Windows\system32\AdvancedInstallers\cmitrust.dll - Ok
C:\Windows\system32\WMVCORE.DLL - Ok
C:\Windows\system32\AdvancedInstallers\locdrv.dll - Ok
C:\Windows\system32\Boot\nl-NL\winload.efi.mui - Ok
C:\Windows\system32\XpsGdiConverter.dll - Ok
C:\Windows\system32\Boot\nl-NL\winload.exe.mui - Ok
C:\Windows\system32\Boot\winresume.efi - Ok
C:\Windows\system32\Boot\nl-NL\winresume.efi.mui - Ok
C:\Windows\system32\Boot\nl-NL\winresume.exe.mui - Ok
C:\Windows\system32\DRVSTORE\GEARAspiWD_53DFBC3344EBC2614851E0BF38F60B616DF86778\GEARAspiWDM.inf - Ok
C:\Windows\system32\DRVSTORE\GEARAspiWD_53DFBC3344EBC2614851E0BF38F60B616DF86778\GEARAspiWDMx64.cat - Ok
C:\Windows\system32\Boot\winresume.exe - Ok
C:\Windows\system32\DRVSTORE\GEARAspiWD_B60A2DA9F47E0A7F3329B57AA751F1789961A8BE\GEARAspiWDM.inf - Ok
C:\Windows\system32\DRVSTORE\GEARAspiWD_B60A2DA9F47E0A7F3329B57AA751F1789961A8BE\GEARAspiWDMx64.cat - Ok
C:\Windows\system32\CodeIntegrity\driver.stl - Ok
C:\Windows\system32\AdvancedInstallers\CntrtextInstaller.DLL - Ok
C:\Windows\system32\Boot\winload.exe - Ok
C:\Windows\system32\Boot\winload.efi - Ok
C:\Windows\system32\DRVSTORE\GEARAspiWD_B60A2DA9F47E0A7F3329B57AA751F1789961A8BE\x64\GEARAspi64.dll - Ok
C:\Windows\system32\DRVSTORE\GEARAspiWD_53DFBC3344EBC2614851E0BF38F60B616DF86778\x64\GEARAspiWDM.sys - Ok
C:\Windows\system32\DRVSTORE\GEARAspiWD_B60A2DA9F47E0A7F3329B57AA751F1789961A8BE\x64\GEARAspiWDM.sys - Ok
C:\Windows\system32\Dism\DismCorePS.dll - Ok
C:\Windows\system32\DRVSTORE\GEARAspiWD_B60A2DA9F47E0A7F3329B57AA751F1789961A8BE\x64\GEARAspi.dll - Ok
C:\Windows\system32\Dism\DismCore.dll - Ok
C:\Windows\system32\Dism\CompatProvider.dll - Ok
C:\Windows\system32\Dism\DismHost.exe - Ok
C:\Windows\system32\Dism\DismProv.dll - Ok
C:\Windows\system32\xpsrchvw.exe - Ok
C:\Windows\system32\Dism\LogProvider.dll - Ok
C:\Windows\system32\Dism\DmiProvider.dll - Ok
C:\Windows\system32\Dism\FolderProvider.dll - Ok
C:\Windows\system32\Dism\IntlProvider.dll - Ok
C:\Windows\system32\Dism\CbsProvider.dll - Ok
C:\Windows\system32\Dism\OSProvider.dll - Ok
C:\Windows\system32\Dism\MsiProvider.dll - Ok
C:\Windows\system32\Dism\nl-NL\CbsProvider.dll.mui - Ok
C:\Windows\system32\Dism\nl-NL\CompatProvider.dll.mui - Ok
C:\Windows\system32\Dism\nl-NL\DismProv.dll.mui - Ok
C:\Windows\system32\Dism\nl-NL\DmiProvider.dll.mui - Ok
C:\Windows\system32\Dism\nl-NL\FolderProvider.dll.mui - Ok
C:\Windows\system32\Dism\SmiProvider.dll - Ok
C:\Windows\system32\Dism\UnattendProvider.dll - Ok
C:\Windows\system32\CodeIntegrity\bootcat.cache - Ok
C:\Windows\system32\Dism\TransmogProvider.dll - Ok
C:\Windows\system32\Dism\nl-NL\IntlProvider.dll.mui - Ok
C:\Windows\system32\Dism\nl-NL\MsiProvider.dll.mui - Ok
C:\Windows\system32\Dism\nl-NL\SmiProvider.dll.mui - Ok
C:\Windows\system32\Dism\nl-NL\OSProvider.dll.mui - Ok
C:\Windows\system32\DriverStore\drvindex.dat - Ok
C:\Windows\system32\Dism\nl-NL\LogProvider.dll.mui - Ok
C:\Windows\system32\Dism\WimProvider.dll - Ok
C:\Windows\system32\DriverStore\INFCACHE.1 - Ok
C:\Windows\system32\DriverStore\infpub.dat - Ok
C:\Windows\system32\DriverStore\FileRepository\1394.inf_amd64_neutral_0b11366838152a76\1394.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\1394.inf_amd64_neutral_0b11366838152a76\1394.PNF - Ok
C:\Windows\system32\Dism\nl-NL\WimProvider.dll.mui - Ok
C:\Windows\system32\AdvancedInstallers\cmiv2.dll - Ok
C:\Windows\system32\Dism\nl-NL\TransmogProvider.dll.mui - Ok
C:\Windows\system32\DriverStore\FileRepository\61883.inf_amd64_neutral_a64d66bac757464c\61883.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\61883.inf_amd64_neutral_a64d66bac757464c\61883.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\accelerometer.inf_amd64_neutral_c8b1e093c46a3e18\accelerometer.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\accelerometer.inf_amd64_neutral_c8b1e093c46a3e18\accelerometer.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\1394.inf_amd64_neutral_0b11366838152a76\1394bus.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\61883.inf_amd64_neutral_a64d66bac757464c\61883.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\1394.inf_amd64_neutral_0b11366838152a76\ohci1394.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\1394.inf_amd64_neutral_0b11366838152a76\1394ohci.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\accelerometer.inf_amd64_neutral_c8b1e093c46a3e18\hpqaccamd64.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\accelerometer.inf_amd64_neutral_c8b1e093c46a3e18\amd64\HPMDPCoInst12.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\accelerometer.inf_amd64_neutral_c8b1e093c46a3e18\amd64\accelerometerdll.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\accelerometer.inf_amd64_neutral_c8b1e093c46a3e18\amd64\Accelerometer.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\acpi.inf_amd64_neutral_aed2e7a487803437\acpi.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\accelerometer.inf_amd64_neutral_c8b1e093c46a3e18\amd64\hpdskflt.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\acpi.inf_amd64_neutral_aed2e7a487803437\acpi.inf - Ok
C:\Windows\system32\Dism\nl-NL\UnattendProvider.dll.mui - Ok
C:\Windows\system32\DriverStore\FileRepository\accelerometer.inf_amd64_neutral_c8b1e093c46a3e18\amd64\hpservice.exe - Ok
C:\Windows\system32\DriverStore\infstor.dat - Ok
C:\Windows\system32\DriverStore\FileRepository\acpipmi.inf_amd64_neutral_256ad642985694b3\acpipmi.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\acpipmi.inf_amd64_neutral_256ad642985694b3\acpipmi.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\adobepdf.inf_amd64_neutral_70cb20a3417216e2\AdobePDF.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\adobepdf.inf_amd64_neutral_70cb20a3417216e2\adobepdf.PNF - Ok
C:\Windows\system32\XpsPrint.dll - Ok
C:\Windows\system32\Dism\nl-NL\DismCore.dll.mui - Ok
C:\Windows\system32\DriverStore\infstrng.dat - Ok
C:\Windows\system32\DriverStore\FileRepository\adobepdf.inf_amd64_neutral_70cb20a3417216e2\Amd64\ADGELP.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\adobepdf.inf_amd64_neutral_70cb20a3417216e2\adobepdf.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\adobepdf.inf_amd64_neutral_70cb20a3417216e2\Amd64\ADPDF9.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\adp94xx.inf_amd64_neutral_4928c8870f6a1577\adp94xx.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\adobepdf.inf_amd64_neutral_70cb20a3417216e2\Amd64\ADREGP.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\adp94xx.inf_amd64_neutral_4928c8870f6a1577\adp94xx.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\adpahci.inf_amd64_neutral_b082e95ec9f8c3f9\adpahci.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\adpahci.inf_amd64_neutral_b082e95ec9f8c3f9\adpahci.PNF - Ok
C:\Windows\system32\wucltux.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\adpu320.inf_amd64_neutral_4ea3d42a9839982a\adpu320.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\adobepdf.inf_amd64_neutral_70cb20a3417216e2\Amd64\ADUIGP.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\adpu320.inf_amd64_neutral_4ea3d42a9839982a\adpu320.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\af9035bda.inf_amd64_neutral_aa11aa34552d1d4d\af9035bda.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\acpi.inf_amd64_neutral_aed2e7a487803437\errdev.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\af9035bda.inf_amd64_neutral_aa11aa34552d1d4d\af9035bda.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\adobepdf.inf_amd64_neutral_70cb20a3417216e2\Amd64Vista\AdobePDFUI.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\adp94xx.inf_amd64_neutral_4928c8870f6a1577\adp94xx.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\acpi.inf_amd64_neutral_aed2e7a487803437\wmiacpi.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\agp.inf_amd64_neutral_22cdceb61fbafb43\agp.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\acpipmi.inf_amd64_neutral_256ad642985694b3\acpipmi.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\adobepdf.inf_amd64_neutral_70cb20a3417216e2\Amd64\PSCRPTFE.NTF - Ok
C:\Windows\system32\DriverStore\FileRepository\agp.inf_amd64_neutral_22cdceb61fbafb43\agp.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\amdsata.inf_amd64_neutral_5c3d0d1e97e99e10\amdsata.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\amdsata.inf_amd64_neutral_5c3d0d1e97e99e10\amdsata.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\amdsata.inf_amd64_neutral_67db50590108ebd9\amdsata.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\amdsata.inf_amd64_neutral_67db50590108ebd9\amdsata.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\adobepdf.inf_amd64_neutral_70cb20a3417216e2\Amd64Vista\AdobePdf.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\agp.inf_amd64_neutral_22cdceb61fbafb43\GAGP30KX.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\amdsbs.inf_amd64_neutral_5cae6933bef20aa8\amdsbs.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\amdsbs.inf_amd64_neutral_5cae6933bef20aa8\amdsbs.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal.inf_amd64_neutral_5766c10b882c919d\amppal.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal.inf_amd64_neutral_5766c10b882c919d\amppal.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\af9035bda.inf_amd64_neutral_aa11aa34552d1d4d\AF9035BDA.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\amdsata.inf_amd64_neutral_5c3d0d1e97e99e10\amdxata.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\amdsata.inf_amd64_neutral_67db50590108ebd9\amdxata.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\acpi.inf_amd64_neutral_aed2e7a487803437\acpi.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal.inf_amd64_neutral_fe05a6f6d455de12\amppal.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\amdsata.inf_amd64_neutral_5c3d0d1e97e99e10\amdsata.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\amdsata.inf_amd64_neutral_67db50590108ebd9\amdsata.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\adpahci.inf_amd64_neutral_b082e95ec9f8c3f9\adpahci.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal.inf_amd64_neutral_fe05a6f6d455de12\amppal.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\amdsbs.inf_amd64_neutral_5cae6933bef20aa8\amdsbs.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\adpu320.inf_amd64_neutral_4ea3d42a9839982a\adpu320.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal.inf_amd64_neutral_fe05a6f6d455de12\amppal.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\agp.inf_amd64_neutral_22cdceb61fbafb43\UAGP35.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal.inf_amd64_neutral_5766c10b882c919d\amppal.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal_p.inf_amd64_neutral_0c6622f2e8d3a928\amppal.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal_p.inf_amd64_neutral_0c6622f2e8d3a928\amppal_p.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal_p.inf_amd64_neutral_0c6622f2e8d3a928\amppal_p.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal_p.inf_amd64_neutral_d802c470f066e93b\amppal.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal_p.inf_amd64_neutral_d802c470f066e93b\amppal_p.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal_p.inf_amd64_neutral_d802c470f066e93b\amppal_p.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\angel264.inf_amd64_neutral_04b54b6322607cce\Angel264.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\angel264.inf_amd64_neutral_04b54b6322607cce\angel264.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\angel64.inf_amd64_neutral_6bed16c93db1ccf3\Angel64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal.inf_amd64_neutral_5766c10b882c919d\AmpPal.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\angel64.inf_amd64_neutral_6bed16c93db1ccf3\angel64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\angelu64.inf_amd64_neutral_3d6079dd78127f5e\AngelU64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\angelu64.inf_amd64_neutral_3d6079dd78127f5e\angelu64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal.inf_amd64_neutral_fe05a6f6d455de12\AmpPal.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\arc.inf_amd64_neutral_11b52dec8e94d9aa\arc.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\arc.inf_amd64_neutral_11b52dec8e94d9aa\arc.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal_p.inf_amd64_neutral_0c6622f2e8d3a928\amppal.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\arcsas.inf_amd64_neutral_c763887719bed95d\arcsas.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\arcsas.inf_amd64_neutral_c763887719bed95d\arcsas.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal_p.inf_amd64_neutral_d802c470f066e93b\amppal.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\arc.inf_amd64_neutral_11b52dec8e94d9aa\arc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\amdpcom64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\arcsas.inf_amd64_neutral_c763887719bed95d\arcsas.sys - Ok
>C:\Windows\system32\DriverStore\FileRepository\amppal.inf_amd64_neutral_fe05a6f6d455de12\WdfCoInstaller01009.dll is CAB archive
C:\Windows\system32\DriverStore\FileRepository\amppal.inf_amd64_neutral_fe05a6f6d455de12\WdfCoInstaller01009.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal.inf_amd64_neutral_fe05a6f6d455de12\WdfCoInstaller01009.dll - archive
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\atiilhag.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\atiumd6a.cap - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\amdpcom32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\atiilhag.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\atiumdva.cap - Ok
C:\Windows\system32\DriverStore\FileRepository\angel264.inf_amd64_neutral_04b54b6322607cce\Angel2.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\angel64.inf_amd64_neutral_6bed16c93db1ccf3\Angel.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\ativcaxx.vp - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\ativcaxx.cpa - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\ativdkxx.vp - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\ativpkxx.vp - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\ativokxx.vp - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\ativvpxx.vp - Ok
C:\Windows\system32\DriverStore\FileRepository\atiriol6.inf_amd64_neutral_bde34ad5722cca75\atiriol6.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\atiriol6.inf_amd64_neutral_bde34ad5722cca75\atiriol6.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\angelu64.inf_amd64_neutral_3d6079dd78127f5e\AngelUsb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\avc.inf_amd64_neutral_3ef33c750e6308ce\avc.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\avc.inf_amd64_neutral_3ef33c750e6308ce\avc.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\atiriol6.inf_amd64_neutral_bde34ad5722cca75\atinavrr.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\avc.inf_amd64_neutral_3ef33c750e6308ce\avcstrm.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\avc.inf_amd64_neutral_3ef33c750e6308ce\avc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\averfx2hbh826d_noaverir_x64.inf_amd64_neutral_da2ba9e8a30dad14\averfx2hbh826d_noaverir_x64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\averfx2hbh826d_noaverir_x64.inf_amd64_neutral_da2ba9e8a30dad14\averfx2hbh826d_noaverir_x64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\atidxx64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\averfx2hbtv_x64.inf_amd64_neutral_7216b6fb23536c40\averfx2hbtv_x64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\averfx2hbtv_x64.inf_amd64_neutral_7216b6fb23536c40\averfx2hbtv_x64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\atiumd6a.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\atikmdag.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\averfx2hbtv_x64.inf_amd64_neutral_7216b6fb23536c40\MVDetection64.ax - Ok
C:\Windows\system32\DriverStore\FileRepository\averfx2swtv_noavin_x64.inf_amd64_neutral_86943dd17860e449\averfx2swtv_noavin_x64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\averfx2swtv_noavin_x64.inf_amd64_neutral_86943dd17860e449\averfx2swtv_noavin_x64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\averfx2swtv_noavin_x64.inf_amd64_neutral_86943dd17860e449\MVDetection64.ax - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\atiumd64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\averfx2swtv_x64.inf_amd64_neutral_24a71cdaabc7f783\averfx2swtv_x64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\averfx2swtv_x64.inf_amd64_neutral_24a71cdaabc7f783\averfx2swtv_x64.PNF - Ok
>C:\Windows\system32\DriverStore\FileRepository\amppal.inf_amd64_neutral_5766c10b882c919d\WdfCoInstaller01009.dll is CAB archive
C:\Windows\system32\DriverStore\FileRepository\amppal.inf_amd64_neutral_5766c10b882c919d\WdfCoInstaller01009.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\amppal.inf_amd64_neutral_5766c10b882c919d\WdfCoInstaller01009.dll - archive
C:\Windows\system32\DriverStore\FileRepository\averhbh826_noaverir_x64.inf_amd64_neutral_2fe3b14136d6e46d\averhbh826_noaverir_x64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\averfx2swtv_x64.inf_amd64_neutral_24a71cdaabc7f783\MVDetection64.ax - Ok
C:\Windows\system32\DriverStore\FileRepository\averfx2swtv_noavin_x64.inf_amd64_neutral_86943dd17860e449\AVerFx2hbtv64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\averfx2swtv_x64.inf_amd64_neutral_24a71cdaabc7f783\AVerFx2hbtv64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\averfx2hbtv_x64.inf_amd64_neutral_7216b6fb23536c40\AVerFx2hbtv64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\averfx2hbh826d_noaverir_x64.inf_amd64_neutral_da2ba9e8a30dad14\AVerFx2hbtv64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\averhbh826_noaverir_x64.inf_amd64_neutral_2fe3b14136d6e46d\averhbh826_noaverir_x64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\averhbh826_noaverir_x64.inf_amd64_neutral_2fe3b14136d6e46d\MVDetection64.ax - Ok
C:\Windows\system32\DriverStore\FileRepository\averhbh826_noaverir_x64.inf_amd64_neutral_2fe3b14136d6e46d\AVerFx2hbtv64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\avmx64c.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\avmx64c.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\avmc2064.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\avmc2032.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\avmcowan.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\c2.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\avmcoxp.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\avmenum.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\fus2base.frm - Ok
C:\Windows\system32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\fus3base.frm - Ok
C:\Windows\system32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\b1.t4 - Ok
C:\Windows\system32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\c4.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\battery.inf_amd64_neutral_cb8fa151a7b7cb80\battery.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\battery.inf_amd64_neutral_cb8fa151a7b7cb80\battery.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\battery.inf_amd64_neutral_cb8fa151a7b7cb80\battc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\battery.inf_amd64_neutral_cb8fa151a7b7cb80\CmBatt.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\battery.inf_amd64_neutral_cb8fa151a7b7cb80\compbatt.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\bda.inf_amd64_neutral_41c6262952846788\bda.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\battery.inf_amd64_neutral_cb8fa151a7b7cb80\hidbatt.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\bda.inf_amd64_neutral_41c6262952846788\bda.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\b1cbase.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\blbdrive.inf_amd64_neutral_1aa816fe7dc98c3f\blbdrive.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\blbdrive.inf_amd64_neutral_1aa816fe7dc98c3f\blbdrive.PNF - Ok
>C:\Windows\system32\DriverStore\FileRepository\brmfcmdm.inf_amd64_neutral_af49d2f3ffa12116\brcoinst.dll - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\blbdrive.inf_amd64_neutral_1aa816fe7dc98c3f\blbdrive.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\fxusbase.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcmdm.inf_amd64_neutral_af49d2f3ffa12116\brmfcmdm.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\bda.inf_amd64_neutral_41c6262952846788\BdaSup.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcmdm.inf_amd64_neutral_af49d2f3ffa12116\brcoinst.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcmdm.inf_amd64_neutral_af49d2f3ffa12116\brmfcmdm.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\fus2base.sys - Ok
>C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\brcoinst.dll - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\fpcibase.sys - Ok
>C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrEvIF.dll - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\brcoinst.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcmdm.inf_amd64_neutral_af49d2f3ffa12116\BrUsbSer.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcmdm.inf_amd64_neutral_af49d2f3ffa12116\BrSerId.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\avmx64c.inf_amd64_neutral_8ebb15bf548db022\fpcmbase.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrmfBidi.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrEvIF.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrFilt.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\brmfcmf.PNF - Ok
>C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrBidiIf.dll - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\brmfcmf.inf - Ok
>C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrmfBidi.dll - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrBidiIf.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrmfBidi.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrParwdm.sys - Ok
>C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrmfLpt.dll - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrmfUSB.dll - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrSerIf.dll - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrSerWdm.sys - Ok
>C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrScnRsm.dll - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrmfLpt.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrmfUSB.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrmfRsmg.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrSerIf.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrScnRsm.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcsto.inf_amd64_neutral_2d7208355536945e\brmfcsto.inf - Ok
>C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\RSMGRSTR.dll - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\brmfcsto.inf_amd64_neutral_2d7208355536945e\BrFiltLo.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcumd.inf_amd64_neutral_db43b26810939b3e\brmfcumd.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcumd.inf_amd64_neutral_db43b26810939b3e\brmfcumd.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcsto.inf_amd64_neutral_2d7208355536945e\BrFiltUp.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcsto.inf_amd64_neutral_2d7208355536945e\brmfcsto.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\BrUsbMdm.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcumd.inf_amd64_neutral_db43b26810939b3e\BrUsbMdm.sys - Ok
>C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brcoinst.dll - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrEvIF.dll - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrBidiIf.dll - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrmfBidi.dll - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\brmfcmf.inf_amd64_neutral_67b5984f8e8ff717\RSMGRSTR.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brcoinst.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\atidxx32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrEvIF.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrmfBidi.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrBidiIf.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsi01.bin - Ok
>C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrmfUSB.dll - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\atiriol6.inf_amd64_neutral_bde34ad5722cca75\CTRL.s3 - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrmfRsmg.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmfcwia.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmfcwia.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsi02.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsi02f.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrmfUSB.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsi03.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsi04.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsi01.icm - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsi04f.bin - Ok
>C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrmfLpt.dll - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsi06.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsi05f.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrmfcWia.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsi03f.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsi02.icm - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsl01.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsi06f.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsl03.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsl02.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsl01f.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsl04.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsl06.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsl05.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsl05f.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsl06f.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrmfLpt.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsl01f.icm - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsl07.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsl05f.icm - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\Brmf2wia.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsl07f.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsl06f.icm - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsl07f.icm - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsl09f.icm - Ok
>C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrScnRsm.dll - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrSerIf.dll - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\RSMGRSTR.dll - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrParImg.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\brmsl08f.icm - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfport.inf_amd64_neutral_f41f35e5c21bc350\brmfport.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrUsbScn.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrScnRsm.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrSerIf.dll - Ok
>C:\Windows\system32\DriverStore\FileRepository\brmfport.inf_amd64_neutral_f41f35e5c21bc350\brcoinst.dll - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_ca26c6da62d71ca8\bth.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfport.inf_amd64_neutral_f41f35e5c21bc350\BrUsbSer.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\RSMGRSTR.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_ca26c6da62d71ca8\bth.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfport.inf_amd64_neutral_f41f35e5c21bc350\BrSerWdm.sys - Ok
>C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrUsbSti.dll - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\brmfport.inf_amd64_neutral_f41f35e5c21bc350\brmfport.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_de0494b6391d872c\bth.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfport.inf_amd64_neutral_f41f35e5c21bc350\brcoinst.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_ca26c6da62d71ca8\bthenum.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_de0494b6391d872c\bth.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfport.inf_amd64_neutral_f41f35e5c21bc350\BrSerId.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_de0494b6391d872c\bthenum.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_e54666f6a3e5af91\bth.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_e54666f6a3e5af91\bth.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_de0494b6391d872c\BTHUSB.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_ca26c6da62d71ca8\BTHUSB.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\brmfcwia.inf_amd64_neutral_817b8835aed3d6b7\BrUsbSti.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_e54666f6a3e5af91\bthenum.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\bthmtpenum.inf_amd64_neutral_c70e85b87ee4ece9\bthmtpenum.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_de0494b6391d872c\fsquirt.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_ca26c6da62d71ca8\fsquirt.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\bthpan.inf_amd64_neutral_024281c0e4e954e2\bthpan.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_e54666f6a3e5af91\BTHUSB.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\bthpan.inf_amd64_neutral_024281c0e4e954e2\bthpan.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\bthmtpenum.inf_amd64_neutral_c70e85b87ee4ece9\bthmtpenum.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\bthmtpenum.inf_amd64_neutral_c70e85b87ee4ece9\BthMtpEnum.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_e54666f6a3e5af91\fsquirt.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\bthprint.inf_amd64_neutral_3c11362fa327f5a4\bthprint.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\bthprint.inf_amd64_neutral_3c11362fa327f5a4\bthprint.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\bthspp.inf_amd64_neutral_1b15060bdfbd09e1\bthspp.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\btmaud.inf_amd64_neutral_c544777ed34e4c5c\btmaud.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\btmaud.inf_amd64_neutral_c544777ed34e4c5c\btmaud.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\bthspp.inf_amd64_neutral_1b15060bdfbd09e1\bthspp.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\btmaud.inf_amd64_neutral_c544777ed34e4c5c\btmaud.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\btmaux.inf_amd64_neutral_eb7929dbe82bb0ac\btmaux.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_de0494b6391d872c\bthport.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\btmaux.inf_amd64_neutral_eb7929dbe82bb0ac\btmaux.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\bthpan.inf_amd64_neutral_024281c0e4e954e2\bthpan.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\btmaux.inf_amd64_neutral_eb7929dbe82bb0ac\btmaux.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\C7126477.INF - Ok
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_ca26c6da62d71ca8\bthport.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\btmaud.inf_amd64_neutral_c544777ed34e4c5c\Win64\btmaud.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\bthprint.inf_amd64_neutral_3c11362fa327f5a4\BTHPRINT.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\btmaux.inf_amd64_neutral_eb7929dbe82bb0ac\Win64\btmaux.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\bth.inf_amd64_neutral_e54666f6a3e5af91\bthport.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\C7126477.CAT - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\atiumdva.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiapfxx.blb - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\c7126477.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\ati2edxx.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\ati2erec.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\aticalcl.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiadlxy.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\aticalrt.dll - Ok
>C:\Windows\system32\DriverStore\FileRepository\btmaux.inf_amd64_neutral_eb7929dbe82bb0ac\Win64\WdfCoInstaller01009.dll is CAB archive
C:\Windows\system32\DriverStore\FileRepository\btmaux.inf_amd64_neutral_eb7929dbe82bb0ac\Win64\WdfCoInstaller01009.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\btmaux.inf_amd64_neutral_eb7929dbe82bb0ac\Win64\WdfCoInstaller01009.dll - archive
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\aticalcl64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\aticalrt64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiapfxx.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atibtmon.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiadlxx.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiedu64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\ATIDEMGX.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\atiilhag.inf_amd64_neutral_0a660e899f5038a2\atiumdag.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\aticfx64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atig6pxx.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atieclxx.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiicdxx.dat - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atig6txx.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atigktxx.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiglpxx.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiesrxx.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atimuixx.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atimpc64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atikmpag.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\aticfx32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atimpc32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atipblag.dat - Ok
>C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atitmm64.dll - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atipdl64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiogl.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atitmm64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiu9p64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiumd6a.cap - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiu9pag.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atipdlxx.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atidxx64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiumd64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiumdva.cap - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiumd6a.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atikmdag.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiuxp64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atio6axx.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiuxpag.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\coinst.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.ar-SA.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.cs-CZ.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.da-DK.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\difx64.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.el-GR.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.en-US.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.de-DE.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\Oemdspif.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.es-ES.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.he-IL.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.fi-FI.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.fr-FR.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.hr-HR.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.it-IT.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.hu-HU.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.ja-JP.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.nb-NO.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.nl-NL.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.ko-KR.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.pl-PL.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.pt-PT.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.ru-RU.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\aticaldd64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiumd6v.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.ro-RO.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\aticaldd.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.sl-SI.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.zh-CN.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.pt-BR.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.th-TH.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.zh-TW.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.sk-SK.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.sv-SE.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\GfxUI.exe.config - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\Gfxres.tr-TR.resources - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\gfxSrvc.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\IccLibDll_x64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igcompkrng575.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\hkcmd.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\hccutils.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igcompkrng600.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igdde32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igdde64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiumdmv.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atidxx32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiumdva.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igdkmd64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfcg575m.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfcg600m.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxcmrt32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\ig4icd64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxcpl.cpl - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxcmrt64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igdumdx32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxdo.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\IGFXDEVLib.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atiumdag.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxdv32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxdev.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxexps32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxexps.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxext.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxpph.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrara.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxpers.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrchs.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrcht.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrdan.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrdeu.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igdumd64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrcsy.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igd10umd64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrenu.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxresn.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\GfxUI.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrfin.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrheb.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrhun.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrfra.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrita.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrjpn.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrell.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrnld.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxress.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrnor.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrhrv.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrsky.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrptg.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrkor.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrsve.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrptb.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrslv.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrplk.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrtrk.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrtha.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrrus.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxrrom.lrc - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igkrng600.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxsrvc.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\iglhcp64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igkrng575.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\iglhcp32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\iglhxa64.vp - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxTMM.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\iglhxa64.cpa - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\iglhxg64.vp - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\iglhxc64.vp - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\iglhxo64.vp - Ok
>C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\iglhsip32.dll - packed by FLY-CODE
C:\Windows\system32\DriverStore\FileRepository\cdrom.inf_amd64_neutral_0b3d0d1942ab684b\cdrom.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\iglhxs64.vp - Ok
C:\Windows\system32\DriverStore\FileRepository\cdrom.inf_amd64_neutral_0b3d0d1942ab684b\cdrom.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxsrvc.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\circlass.inf_amd64_neutral_cf52485bed804e02\circlass.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\circlass.inf_amd64_neutral_cf52485bed804e02\circlass.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\clwvd.inf_amd64_neutral_49da4b19183afad3\clwvd.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\clwvd.inf_amd64_neutral_49da4b19183afad3\clwvd.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\clwvd.inf_amd64_neutral_49da4b19183afad3\clwvd.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\circlass.inf_amd64_neutral_cf52485bed804e02\circlass.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\cnql20.inf_amd64_neutral_47472730a82b7b65\CNQL20.INF - Ok
C:\Windows\system32\DriverStore\FileRepository\cnql20.inf_amd64_neutral_47472730a82b7b65\cnql20.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igfxtray.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\cnql30.inf_amd64_neutral_a112d0446d62d8cd\CNQL30.INF - Ok
C:\Windows\system32\DriverStore\FileRepository\cnql30.inf_amd64_neutral_a112d0446d62d8cd\cnql30.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\iglhsip64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\compositebus.inf_amd64_neutral_b9280780a8000d4b\CompositeBus.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igdumd32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\compositebus.inf_amd64_neutral_b9280780a8000d4b\compositebus.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\cougcore.inf_amd64_neutral_7389ba687c766ea9\cougcore.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\cougcore.inf_amd64_neutral_7389ba687c766ea9\cougcore.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\cdrom.inf_amd64_neutral_0b3d0d1942ab684b\cdrom.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\cougsmb.inf_amd64_neutral_aa127b372b0f77c8\cougsmb.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\cougsmb.inf_amd64_neutral_aa127b372b0f77c8\cougsmb.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\cougcore.inf_amd64_neutral_7389ba687c766ea9\cougcore.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\cougsmb.inf_amd64_neutral_aa127b372b0f77c8\cougsmb.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\cougusb.inf_amd64_neutral_df69f6287c46af9b\cougusb.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\compositebus.inf_amd64_neutral_b9280780a8000d4b\CompositeBus.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\cougusb.inf_amd64_neutral_df69f6287c46af9b\cougusb.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\cougusb.inf_amd64_neutral_df69f6287c46af9b\cougusb.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\cpu.inf_amd64_neutral_ae5de2e1bf2793c3\cpu.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\cpu.inf_amd64_neutral_ae5de2e1bf2793c3\cpu.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\crcdisk.inf_amd64_neutral_d10626d1f8b423c3\crcdisk.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\crcdisk.inf_amd64_neutral_d10626d1f8b423c3\crcdisk.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\clwvd.inf_amd64_neutral_49da4b19183afad3\clwvd.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\cpu.inf_amd64_neutral_ae5de2e1bf2793c3\processr.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\cpu.inf_amd64_neutral_ae5de2e1bf2793c3\amdppm.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\crcdisk.inf_amd64_neutral_d10626d1f8b423c3\crcdisk.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\cxfalcon_ibv64.inf_amd64_neutral_d065aec3fcf4ec4e\cxfalcon_IBV64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\cpu.inf_amd64_neutral_ae5de2e1bf2793c3\amdk8.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\cxfalcon_ibv64.inf_amd64_neutral_d065aec3fcf4ec4e\cpnotify_IBV64.ax - Ok
C:\Windows\system32\DriverStore\FileRepository\cxfalcon_ibv64.inf_amd64_neutral_d065aec3fcf4ec4e\cxfalcon_ibv64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\cxfalcon_ibv64.inf_amd64_neutral_d065aec3fcf4ec4e\colorcvt_IBV64.ax - Ok
C:\Windows\system32\DriverStore\FileRepository\cxfalcon_ibv64.inf_amd64_neutral_d065aec3fcf4ec4e\merlinb.rom - Ok
C:\Windows\system32\DriverStore\FileRepository\cxfalcon_ibv64.inf_amd64_neutral_d065aec3fcf4ec4e\merlinc.rom - Ok
C:\Windows\system32\DriverStore\FileRepository\cxfalpal_ibv64.inf_amd64_neutral_4c42ac5f00413365\cpnotify_IBV64.ax - Ok
C:\Windows\system32\DriverStore\FileRepository\cxfalpal_ibv64.inf_amd64_neutral_4c42ac5f00413365\colorcvt_IBV64.ax - Ok
C:\Windows\system32\DriverStore\FileRepository\cxfalpal_ibv64.inf_amd64_neutral_4c42ac5f00413365\cxfalpal_ibv64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\cxfalpal_ibv64.inf_amd64_neutral_4c42ac5f00413365\cxFalPal_IBV64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\cpu.inf_amd64_neutral_ae5de2e1bf2793c3\intelppm.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\cxfalpal_ibv64.inf_amd64_neutral_4c42ac5f00413365\merlinb.rom - Ok
C:\Windows\system32\DriverStore\FileRepository\cxfalpal_ibv64.inf_amd64_neutral_4c42ac5f00413365\merlinc.rom - Ok
C:\Windows\system32\DriverStore\FileRepository\cxfalcon_ibv64.inf_amd64_neutral_d065aec3fcf4ec4e\cxfalcon.rom - Ok
C:\Windows\system32\DriverStore\FileRepository\cxfalpal_ibv64.inf_amd64_neutral_4c42ac5f00413365\cxfalcon.rom - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_fm1216mk5_ibv64.inf_amd64_neutral_3eaae75b591bd148\apu.rom - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_fm1216mk5_ibv64.inf_amd64_neutral_3eaae75b591bd148\cpnotify_raptor_IBV64.ax - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_fm1216mk5_ibv64.inf_amd64_neutral_3eaae75b591bd148\cxraptor_fm1216mk5_ibv64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_fm1216mk5_ibv64.inf_amd64_neutral_3eaae75b591bd148\cxraptor_FM1216MK5_IBV64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_fm1216mk5_ibv64.inf_amd64_neutral_3eaae75b591bd148\cxraptor.rom - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_fm1216mk5_ibv64.inf_amd64_neutral_3eaae75b591bd148\cxraptor_merlinc.rom - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_fm1236mk5_ibv64.inf_amd64_neutral_b81bec917adfaea5\apu.rom - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_fm1236mk5_ibv64.inf_amd64_neutral_b81bec917adfaea5\colorcvt_raptor_IBV64.ax - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_fm1236mk5_ibv64.inf_amd64_neutral_b81bec917adfaea5\cxraptor.rom - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_fm1236mk5_ibv64.inf_amd64_neutral_b81bec917adfaea5\cpnotify_raptor_IBV64.ax - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_fm1236mk5_ibv64.inf_amd64_neutral_b81bec917adfaea5\cxraptor_FM1236MK5_IBV64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_fm1236mk5_ibv64.inf_amd64_neutral_b81bec917adfaea5\cxraptor_merlinc.rom - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_fm1236mk5_ibv64.inf_amd64_neutral_b81bec917adfaea5\cxraptor_fm1236mk5_ibv64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_fm1216mk5_ibv64.inf_amd64_neutral_3eaae75b591bd148\colorcvt_raptor_IBV64.ax - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_fm1216mk5_ibv64.inf_amd64_neutral_3eaae75b591bd148\cxraptor_IBV64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_fm1236mk5_ibv64.inf_amd64_neutral_b81bec917adfaea5\cxraptor_IBV64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_philipstuv1236d_ibv64.inf_amd64_neutral_b6a3e57df5bad299\colorcvt_raphd_IBV64.ax - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_philipstuv1236d_ibv64.inf_amd64_neutral_b6a3e57df5bad299\cxraphd_apu.rom - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_philipstuv1236d_ibv64.inf_amd64_neutral_b6a3e57df5bad299\cxraphd_merlinc.rom - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_philipstuv1236d_ibv64.inf_amd64_neutral_b6a3e57df5bad299\cxraptor_philipstuv1236d_ibv64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_philipstuv1236d_ibv64.inf_amd64_neutral_b6a3e57df5bad299\cxraptor_PhilipsTUV1236D_IBV64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\dc21x4vm.inf_amd64_neutral_8887242a56ee027e\dc21x4vm.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_philipstuv1236d_ibv64.inf_amd64_neutral_b6a3e57df5bad299\cxraphd.rom - Ok
C:\Windows\system32\DriverStore\FileRepository\digitalmediadevice.inf_amd64_neutral_6fd673519d66ab20\digitalmediadevice.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_philipstuv1236d_ibv64.inf_amd64_neutral_b6a3e57df5bad299\cpnotify_raphd_IBV64.ax - Ok
C:\Windows\system32\DriverStore\FileRepository\dc21x4vm.inf_amd64_neutral_8887242a56ee027e\dc21x4vm.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\cxraptor_philipstuv1236d_ibv64.inf_amd64_neutral_b6a3e57df5bad299\cxraphd_IBV64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\digitalmediadevice.inf_amd64_neutral_6fd673519d66ab20\digitalmediadevice.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\disk.inf_amd64_neutral_10ce25bbc5a9cc43\disk.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\disk.inf_amd64_neutral_10ce25bbc5a9cc43\disk.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\display.inf_amd64_neutral_ea1c8215e52777a6\display.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\display.inf_amd64_neutral_ea1c8215e52777a6\display.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\cxfalpal_ibv64.inf_amd64_neutral_4c42ac5f00413365\cxfalcon_IBV64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\cxfalcon_ibv64.inf_amd64_neutral_d065aec3fcf4ec4e\cxfalcon_IBV64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\dc21x4vm.inf_amd64_neutral_8887242a56ee027e\dc21x4vm.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\display.inf_amd64_neutral_ea1c8215e52777a6\vgapnp.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\disk.inf_amd64_neutral_10ce25bbc5a9cc43\disk.sys - Ok
>C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\disrvci.dll - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\disrvci.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\diapi264.dll - Ok
>C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\disrvpp.dll - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\disrvsu.dll - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\dicapi.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\disrvpp.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\dimaint.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\disrvsu.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\diapi232.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\divacx64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\usbdldv2.hex - Ok
C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\usbdload.hex - Ok
C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\divacx64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\dspcli.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\iglhsip32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\dot4.inf_amd64_neutral_b89cfac15ccb2fba\dot4.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\ditrace.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\dot4.inf_amd64_neutral_b89cfac15ccb2fba\dot4.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\dot4prt.inf_amd64_neutral_e7d3f62d0d4411db\dot4prt.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\dot4prt.inf_amd64_neutral_e7d3f62d0d4411db\dot4prt.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\eamonm.inf_amd64_neutral_06c20b27fbc1c443\eamonm.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\eamonm.inf_amd64_neutral_06c20b27fbc1c443\eamonm.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\dot4.inf_amd64_neutral_b89cfac15ccb2fba\Dot4Scan.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\dot4prt.inf_amd64_neutral_e7d3f62d0d4411db\Dot4Prt.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\eaphost.inf_amd64_neutral_4506dea11740c089\eaphost.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\eamonm.inf_amd64_neutral_06c20b27fbc1c443\eamonm.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\eaphost.inf_amd64_neutral_4506dea11740c089\eaphost.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ehdrv.inf_amd64_neutral_3fce481915c9149d\ehdrv.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\dot4.inf_amd64_neutral_b89cfac15ccb2fba\Dot4usb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ehdrv.inf_amd64_neutral_3fce481915c9149d\ehdrv.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\ehdrv.inf_amd64_neutral_3fce481915c9149d\ehdrv.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\xlog.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\ehstorcertdrv.inf_amd64_neutral_2e1cecffae9c899a\ehstorcertdrv.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ehstorcertdrv.inf_amd64_neutral_2e1cecffae9c899a\ehstorcertdrv.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ehstorpwddrv.inf_amd64_neutral_ecd233d7cabbdebf\ehstorpwddrv.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ehstorpwddrv.inf_amd64_neutral_ecd233d7cabbdebf\ehstorpwddrv.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\elxstor.inf_amd64_neutral_4263942b9dfe9077\elxstor.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\epfw.inf_amd64_neutral_5945c81829d31cba\epfw.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\elxstor.inf_amd64_neutral_4263942b9dfe9077\elxstor.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\epfw.inf_amd64_neutral_5945c81829d31cba\epfw.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\epfwlwf.inf_amd64_neutral_97e5bc8a9df262cc\EpfwLwf.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\epfw.inf_amd64_neutral_5945c81829d31cba\epfw.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\epfwlwf.inf_amd64_neutral_97e5bc8a9df262cc\EpfwLwf.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\epfwlwf.inf_amd64_neutral_97e5bc8a9df262cc\epfwlwf.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ehstorpwddrv.inf_amd64_neutral_ecd233d7cabbdebf\EhStorPwdDrv.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\epfwwfp.inf_amd64_neutral_4574602addc98017\epfwwfp.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\divacx64.inf_amd64_neutral_fa0f82f024789743\dicowan.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\epfwwfp.inf_amd64_neutral_4574602addc98017\EpfwWfp.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\epfwwfp.inf_amd64_neutral_4574602addc98017\epfwwfp.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\dot4.inf_amd64_neutral_b89cfac15ccb2fba\Dot4.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\faxca003.inf_amd64_neutral_5b8c7c1dda79bef4\CNHF1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\faxca003.inf_amd64_neutral_5b8c7c1dda79bef4\CNHF1CMN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\elxstor.inf_amd64_neutral_4263942b9dfe9077\elxstor.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ehstorcertdrv.inf_amd64_neutral_2e1cecffae9c899a\EhStorCertDrv.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\faxca003.inf_amd64_neutral_5b8c7c1dda79bef4\CNHF_323.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\faxca003.inf_amd64_neutral_5b8c7c1dda79bef4\CNHF_279.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\faxca003.inf_amd64_neutral_5b8c7c1dda79bef4\CNHF_309.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\epfwlwf.inf_amd64_neutral_97e5bc8a9df262cc\EpfwLWF.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\faxca003.inf_amd64_neutral_5b8c7c1dda79bef4\CNHF1DR.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\faxca003.inf_amd64_neutral_5b8c7c1dda79bef4\CNHF_329.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\faxca003.inf_amd64_neutral_5b8c7c1dda79bef4\CNHF_324.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\faxca003.inf_amd64_neutral_5b8c7c1dda79bef4\CNHF_332.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\faxca003.inf_amd64_neutral_5b8c7c1dda79bef4\CNHF1UI.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\faxca003.inf_amd64_neutral_5b8c7c1dda79bef4\faxca003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\faxca003.inf_amd64_neutral_5b8c7c1dda79bef4\CNHF1LM.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\faxca003.inf_amd64_neutral_5b8c7c1dda79bef4\faxca003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\faxcn001.inf_amd64_neutral_d23021a1eb548156\faxcn001.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\faxcn002.inf_amd64_neutral_3d392ccc357e04db\faxcn002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\faxcn001.inf_amd64_neutral_d23021a1eb548156\faxcn001.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\fdc.inf_amd64_neutral_bbcfca39fdc02275\fdc.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\flpydisk.inf_amd64_neutral_f54222cc59267e1e\flpydisk.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\flpydisk.inf_amd64_neutral_f54222cc59267e1e\flpydisk.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\fdc.inf_amd64_neutral_bbcfca39fdc02275\fdc.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\gameport.inf_amd64_neutral_fe5c4f29488f121e\gameport.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\gameport.inf_amd64_neutral_fe5c4f29488f121e\gameport.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\hal.inf_amd64_neutral_232b95977cf6d84c\hal.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hal.inf_amd64_neutral_232b95977cf6d84c\hal.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\fdc.inf_amd64_neutral_bbcfca39fdc02275\fdc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\flpydisk.inf_amd64_neutral_f54222cc59267e1e\flpydisk.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\hcw72b64.inf_amd64_neutral_023772237d3a4ade\hcw72b64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\flpydisk.inf_amd64_neutral_f54222cc59267e1e\sfloppy.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\hcw72b64.inf_amd64_neutral_023772237d3a4ade\hcw72b64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\faxcn002.inf_amd64_neutral_3d392ccc357e04db\faxcn002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\hcw85b64.inf_amd64_neutral_22b436d5d06ab017\hcw85b64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\faxca003.inf_amd64_neutral_5b8c7c1dda79bef4\CNHF1UR.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\hcw85b64.inf_amd64_neutral_22b436d5d06ab017\hcw85b64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hcw85b64.inf_amd64_neutral_22b436d5d06ab017\hcw85mlD.rom - Ok
C:\Windows\system32\DriverStore\FileRepository\hcw72b64.inf_amd64_neutral_023772237d3a4ade\hcwmsCP72.ax - Ok
C:\Windows\system32\DriverStore\FileRepository\hcw72b64.inf_amd64_neutral_023772237d3a4ade\hcw72ADFilter.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\hcw85b64.inf_amd64_neutral_22b436d5d06ab017\hcw85enc.rom - Ok
C:\Windows\system32\DriverStore\FileRepository\hcw85c64.inf_amd64_neutral_96b71557b416d04a\hcw85c64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\hcw72b64.inf_amd64_neutral_023772237d3a4ade\hcw72Co.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\hcw85c64.inf_amd64_neutral_96b71557b416d04a\hcw85c64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hdaudbus.inf_amd64_neutral_4b99fffee061ff26\hdaudbus.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hdaudbus.inf_amd64_neutral_4b99fffee061ff26\hdaudbus.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\hdaudio.inf_amd64_neutral_ce7bc199c85ae0a0\hdaudio.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hcw85c64.inf_amd64_neutral_96b71557b416d04a\hcw85cir.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\hcw85b64.inf_amd64_neutral_22b436d5d06ab017\hcwmsCP885.ax - Ok
C:\Windows\system32\DriverStore\FileRepository\hdaudss.inf_amd64_neutral_330a593eb888237c\hdaudss.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hdaudio.inf_amd64_neutral_ce7bc199c85ae0a0\hdaudio.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\hdaudss.inf_amd64_neutral_330a593eb888237c\hdaudss.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\heci.inf_amd64_neutral_8ac1feb3337b1441\HECI.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\heci.inf_amd64_neutral_8ac1feb3337b1441\heci.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\heci.inf_amd64_neutral_8ac1feb3337b1441\heci.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hdaudbus.inf_amd64_neutral_4b99fffee061ff26\hdaudbus.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\hidbth.inf_amd64_neutral_8a1323fc68ad84af\hidbth.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hidbth.inf_amd64_neutral_8a1323fc68ad84af\hidbth.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\hiddigi.inf_amd64_neutral_12aaf5742a9969da\hiddigi.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\hiddigi.inf_amd64_neutral_12aaf5742a9969da\hiddigi.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hiddigi.inf_amd64_neutral_12aaf5742a9969da\wacompen.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\hidir.inf_amd64_neutral_5b48c4b1b49ca54a\hidir.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hdaudio.inf_amd64_neutral_ce7bc199c85ae0a0\HdAudio.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\hidbth.inf_amd64_neutral_8a1323fc68ad84af\hidbth.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\hidir.inf_amd64_neutral_5b48c4b1b49ca54a\hidir.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\hidirkbd.inf_amd64_neutral_2b561a02e977e2e3\hidirkbd.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hidirkbd.inf_amd64_neutral_2b561a02e977e2e3\hidirkbd.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\hidserv.inf_amd64_neutral_f2223e39f37c69f3\hidserv.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hidserv.inf_amd64_neutral_f2223e39f37c69f3\hidserv.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\heci.inf_amd64_neutral_8ac1feb3337b1441\HECIx64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\hpoa1nd.inf_amd64_neutral_cf39c48277e038de\hpoa1nd.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hpoa1nd.inf_amd64_neutral_cf39c48277e038de\hpoa1nd.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\hpoa1sd.inf_amd64_neutral_caaa16c52c48f8ac\hpoa1sd.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\hpoa1sd.inf_amd64_neutral_caaa16c52c48f8ac\hpoa1sd.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hidir.inf_amd64_neutral_5b48c4b1b49ca54a\hidir.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\hpoa1so.inf_amd64_neutral_4f1a3f1015001339\hpoa1so.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hpoa1so.inf_amd64_neutral_4f1a3f1015001339\hpoa1so.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\hpoa1ss.inf_amd64_neutral_8cae09a2238d64e0\hpoa1ss.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hpoa1ss.inf_amd64_neutral_8cae09a2238d64e0\hpoa1ss.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\hcw72b64.inf_amd64_neutral_023772237d3a4ade\hcw72DTV.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\hcw85b64.inf_amd64_neutral_22b436d5d06ab017\HCW85BDA.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\hpoa1sd.inf_amd64_neutral_caaa16c52c48f8ac\hpotscld.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\hpsamd.inf_amd64_neutral_84ae149ecc9f8033\hpsamd.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hpsamd.inf_amd64_neutral_84ae149ecc9f8033\hpsamd.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\iaahci.inf_amd64_neutral_e6913aab23ea9a9c\iaAHCI.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\iaahci.inf_amd64_neutral_e6913aab23ea9a9c\iaahci.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\iaahci.inf_amd64_neutral_e6913aab23ea9a9c\iaahci.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\ig4icd32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\hcw72b64.inf_amd64_neutral_023772237d3a4ade\hcw72ATV.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\iastorv.inf_amd64_neutral_0bcee2057afcc090\iastorv.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\iastorv.inf_amd64_neutral_0bcee2057afcc090\iastorv.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\hpsamd.inf_amd64_neutral_84ae149ecc9f8033\HpSAMD.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\iastorv.inf_amd64_neutral_668286aa35d55928\iastorv.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\iastorv.inf_amd64_neutral_668286aa35d55928\iastorv.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ibtfltcoexhs.inf_amd64_neutral_8319d50bcac7c826\iBtFltCoex.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\hpoa1sd.inf_amd64_neutral_caaa16c52c48f8ac\hpowiad1.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\hpoa1ss.inf_amd64_neutral_8cae09a2238d64e0\hpotscl1.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\hpoa1so.inf_amd64_neutral_4f1a3f1015001339\hpotiop1.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ibtfltcoexhs.inf_amd64_neutral_8319d50bcac7c826\ibtfltcoexhs.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ibtfltcoexhs.inf_amd64_neutral_8319d50bcac7c826\ibtfltcoexhs.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\iastorv.inf_amd64_neutral_0bcee2057afcc090\iaStorV.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\iastorv.inf_amd64_neutral_668286aa35d55928\iaStorV.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ibtfltcoexhs.inf_amd64_neutral_8319d50bcac7c826\Win64\iBtFltCoex.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ibtfltcoexhs.inf_amd64_neutral_8319d50bcac7c826\Win64\btmhsf.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\igcompkrng500.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\hpoa1so.inf_amd64_neutral_4f1a3f1015001339\hpowiav1.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\hpoa1ss.inf_amd64_neutral_8cae09a2238d64e0\hpowiav1.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\igdlh.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\igdlh.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\igfcg500m.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\igkrng400.bin - Ok
>C:\Windows\system32\DriverStore\FileRepository\ibtfltcoexhs.inf_amd64_neutral_8319d50bcac7c826\Win64\WdfCoInstaller01009.dll is CAB archive
C:\Windows\system32\DriverStore\FileRepository\ibtfltcoexhs.inf_amd64_neutral_8319d50bcac7c826\Win64\WdfCoInstaller01009.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ibtfltcoexhs.inf_amd64_neutral_8319d50bcac7c826\Win64\WdfCoInstaller01009.dll - archive
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\igkrng500.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\iglhxa64.vp - Ok
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\igfcg500.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\iglhxa64.cpa - Ok
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\iglhxc64.vp - Ok
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\iglhxg64.vp - Ok
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\iglhxo64.vp - Ok
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\iglhxs64.vp - Ok
C:\Windows\system32\DriverStore\FileRepository\iirsp.inf_amd64_neutral_25c14d33af7f54f1\iirsp.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\iirsp.inf_amd64_neutral_25c14d33af7f54f1\iirsp.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\iirsp2.inf_amd64_neutral_9ed65fe0bab06b1b\iirsp2.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\iirsp2.inf_amd64_neutral_9ed65fe0bab06b1b\iirsp2.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\image.inf_amd64_neutral_4a983035eaabe2f4\image.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\image.inf_amd64_neutral_4a983035eaabe2f4\image.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\iirsp.inf_amd64_neutral_25c14d33af7f54f1\iirsp.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\image.inf_amd64_neutral_4a983035eaabe2f4\sonydcam.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\input.inf_amd64_neutral_8693053514b10ee9\hidparse.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\input.inf_amd64_neutral_8693053514b10ee9\hidclass.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\input.inf_amd64_neutral_8693053514b10ee9\input.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\input.inf_amd64_neutral_8693053514b10ee9\input.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\input.inf_amd64_neutral_8693053514b10ee9\hidusb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\input.inf_amd64_neutral_fccb715ac7d8c66d\hidusb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\input.inf_amd64_neutral_fccb715ac7d8c66d\input.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\input.inf_amd64_neutral_fccb715ac7d8c66d\input.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\iaahci.inf_amd64_neutral_e6913aab23ea9a9c\iaStor.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\input.inf_amd64_neutral_fccb715ac7d8c66d\hidparse.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\intcdaud.inf_amd64_neutral_9131d44a507f3b6e\intcdaud.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\intcdaud.inf_amd64_neutral_9131d44a507f3b6e\IntcDAud.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\intcdaud.inf_amd64_neutral_9131d44a507f3b6e\IntcDAud.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\intelaud.inf_amd64_neutral_0b460c7faec7c3f0\intelaud.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\intelaud.inf_amd64_neutral_0b460c7faec7c3f0\intelaud.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\intcdaud.inf_amd64_neutral_9131d44a507f3b6e\intcdaud.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\intelaud.inf_amd64_neutral_0b460c7faec7c3f0\intelaudx64.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\ipmidrv.inf_amd64_neutral_1cb648411f252d13\ipmidrv.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ipmidrv.inf_amd64_neutral_1cb648411f252d13\ipmidrv.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\igdkmd64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\iscsi.inf_amd64_neutral_2ef24e9270d8b2a9\iscsi.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ipmidrv.inf_amd64_neutral_1cb648411f252d13\IPMIDrv.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\iscsi.inf_amd64_neutral_2ef24e9270d8b2a9\iscsi.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\intcdaud.inf_amd64_neutral_9131d44a507f3b6e\IntcDAuC.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\iwdbus.inf_amd64_neutral_1884300cc99f7afa\iwdbus.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\iwdbus.inf_amd64_neutral_1884300cc99f7afa\iwdbus.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\igd10umd64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\iwdbus.inf_amd64_neutral_1884300cc99f7afa\iwdbusx64.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\iscsi.inf_amd64_neutral_2ef24e9270d8b2a9\msiscsi.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\keyboard.inf_amd64_neutral_0684fdc43059f486\i8042prt.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\Intel\igd10umd32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\iwdbus.inf_amd64_neutral_1884300cc99f7afa\iwdbus.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\intelaud.inf_amd64_neutral_0b460c7faec7c3f0\intelaud.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\keyboard.inf_amd64_neutral_0684fdc43059f486\keyboard.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\keyboard.inf_amd64_neutral_0684fdc43059f486\kbdhid.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ks.inf_amd64_neutral_2b583ce4a6a029a1\ks.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\kscaptur.inf_amd64_neutral_6cb3fb6811a3f83d\kscaptur.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\kscaptur.inf_amd64_neutral_6cb3fb6811a3f83d\kscaptur.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ksfilter.inf_amd64_neutral_86311fdf78a07678\ksfilter.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ksfilter.inf_amd64_neutral_86311fdf78a07678\ksfilter.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\lsi_fc.inf_amd64_neutral_a7088f3644ca646a\lsi_fc.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\lsi_fc.inf_amd64_neutral_a7088f3644ca646a\lsi_fc.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\input.inf_amd64_neutral_fccb715ac7d8c66d\hidclass.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\lsi_sas.inf_amd64_neutral_a4d6780f72cbd5b4\lsi_sas.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\lsi_sas.inf_amd64_neutral_a4d6780f72cbd5b4\lsi_sas.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\keyboard.inf_amd64_neutral_0684fdc43059f486\keyboard.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\lsi_sas2.inf_amd64_neutral_e12a5c4cfbe49204\lsi_sas2.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\lsi_sas2.inf_amd64_neutral_e12a5c4cfbe49204\lsi_sas2.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\lsi_sas2.inf_amd64_neutral_e12a5c4cfbe49204\lsi_sas2.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\lsi_sas.inf_amd64_neutral_a4d6780f72cbd5b4\lsi_sas.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\lsi_scsi.inf_amd64_neutral_cfbbf0b0b66ba280\lsi_scsi.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\lsi_fc.inf_amd64_neutral_a7088f3644ca646a\lsi_fc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\lsi_scsi.inf_amd64_neutral_cfbbf0b0b66ba280\lsi_scsi.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\machine.inf_amd64_neutral_a2f120466549d68b\isapnp.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\machine.inf_amd64_neutral_a2f120466549d68b\AGP440.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\iscsi.inf_amd64_neutral_2ef24e9270d8b2a9\iscsilog.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\lsi_scsi.inf_amd64_neutral_cfbbf0b0b66ba280\lsi_scsi.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\machine.inf_amd64_neutral_a2f120466549d68b\machine.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\machine.inf_amd64_neutral_a2f120466549d68b\mssmbios.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ks.inf_amd64_neutral_2b583ce4a6a029a1\ks.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\machine.inf_amd64_neutral_a2f120466549d68b\machine.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\machine.inf_amd64_neutral_a2f120466549d68b\streamci.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\machine.inf_amd64_neutral_a2f120466549d68b\NV_AGP.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\machine.inf_amd64_neutral_a2f120466549d68b\termdd.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\machine.inf_amd64_neutral_a2f120466549d68b\vdrvroot.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\machine.inf_amd64_neutral_a2f120466549d68b\msisadrv.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\machine.inf_amd64_neutral_a2f120466549d68b\swenum.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\machine.inf_amd64_neutral_a2f120466549d68b\ULIAGPKX.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\adicvls.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\atlmc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\keyboard.inf_amd64_neutral_0684fdc43059f486\kbdclass.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\ddsmc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\examc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\adicsc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\igdumd64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\breecemc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\jvcmc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\m4mc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\elmsmc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\igd10umd32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\mchgr.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\mchgr.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\libxprmc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\powerfil.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\plasmc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\pnrmc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\qlstrmc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\hpmc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\nsmmc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mcx2.inf_amd64_neutral_8cf9cade8f7bba56\Mcx2.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mcx2.inf_amd64_neutral_8cf9cade8f7bba56\mcx2.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdm3com.inf_amd64_neutral_11abcf129a29fb9f\mdm3com.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\qntmmc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdm5674a.inf_amd64_neutral_46f893a4f998bb46\mdm5674a.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdm5674a.inf_amd64_neutral_46f893a4f998bb46\mdm5674a.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmadc.inf_amd64_neutral_62d6e6995428f9d0\mdmadc.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmadc.inf_amd64_neutral_62d6e6995428f9d0\mdmadc.PNF - Ok
>C:\Windows\system32\DriverStore\FileRepository\iwdbus.inf_amd64_neutral_1884300cc99f7afa\WdfCoInstaller01009.dll is CAB archive
C:\Windows\system32\DriverStore\FileRepository\iwdbus.inf_amd64_neutral_1884300cc99f7afa\WdfCoInstaller01009.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\iwdbus.inf_amd64_neutral_1884300cc99f7afa\WdfCoInstaller01009.dll - archive
C:\Windows\system32\DriverStore\FileRepository\machine.inf_amd64_neutral_a2f120466549d68b\volmgr.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmagm64.inf_amd64_neutral_ef322a8cc2738a9b\mdmagm64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdm3com.inf_amd64_neutral_11abcf129a29fb9f\mdm3com.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmagm64.inf_amd64_neutral_ef322a8cc2738a9b\mdmagm64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\spctramc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmairte.inf_amd64_neutral_0feacd08cb9c7fe3\mdmairte.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmags64.inf_amd64_neutral_e68956e24e287714\mdmags64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\sonymc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmairte.inf_amd64_neutral_0feacd08cb9c7fe3\mdmairte.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\seaddsmc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmaiwa.inf_amd64_neutral_560c956da9bcd8f5\mdmaiwa.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmaiwa.inf_amd64_neutral_560c956da9bcd8f5\mdmaiwa.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmaiwa3.inf_amd64_neutral_77e515342bd572cc\mdmaiwa3.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmaiwa3.inf_amd64_neutral_77e515342bd572cc\mdmaiwa3.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmags64.inf_amd64_neutral_e68956e24e287714\mdmags64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmaiwa5.inf_amd64_neutral_ea8128ac5da37eb9\mdmaiwa5.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmaiwa5.inf_amd64_neutral_ea8128ac5da37eb9\mdmaiwa5.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmaiwa4.inf_amd64_neutral_6e97842bb8d9e6a8\mdmaiwa4.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmaiwat.inf_amd64_neutral_213e93b5ced8b0fe\mdmaiwat.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmaiwat.inf_amd64_neutral_213e93b5ced8b0fe\mdmaiwat.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmar1.inf_amd64_neutral_b8ebf59556c3dbf0\mdmar1.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmar1.inf_amd64_neutral_b8ebf59556c3dbf0\mdmar1.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmarch.inf_amd64_neutral_4261401e3170ebfb\mdmarch.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmarch.inf_amd64_neutral_4261401e3170ebfb\mdmarch.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmarn.inf_amd64_neutral_fa693d8797766f49\mdmarn.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\machine.inf_amd64_neutral_a2f120466549d68b\pci.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmarn.inf_amd64_neutral_fa693d8797766f49\mdmarn.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmati.inf_amd64_neutral_ded8f26cdee953c3\mdmati.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmatm2k.inf_amd64_neutral_64a8fb018ead55a7\mdmatm2k.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmatm2k.inf_amd64_neutral_64a8fb018ead55a7\mdmatm2k.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmaus.inf_amd64_neutral_5fa4270b9924b918\Mdmaus.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmaiwa4.inf_amd64_neutral_6e97842bb8d9e6a8\mdmaiwa4.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmati.inf_amd64_neutral_ded8f26cdee953c3\mdmati.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmaus.inf_amd64_neutral_5fa4270b9924b918\mdmaus.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmboca.inf_amd64_neutral_cc532ed7b3b5b5a9\mdmboca.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmboca.inf_amd64_neutral_cc532ed7b3b5b5a9\mdmboca.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr002.inf_amd64_neutral_ce2134188ab21f59\mdmbr002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr002.inf_amd64_neutral_ce2134188ab21f59\mdmbr002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr004.inf_amd64_neutral_ccf1bc353e588fe1\mdmbr004.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr004.inf_amd64_neutral_ccf1bc353e588fe1\mdmbr004.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mchgr.inf_amd64_neutral_407146dba80d1566\snyaitmc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr005.inf_amd64_neutral_d140721f97061bba\mdmbr005.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr005.inf_amd64_neutral_d140721f97061bba\mdmbr005.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmagm64.inf_amd64_neutral_ef322a8cc2738a9b\ltmdm64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr004.inf_amd64_neutral_ccf1bc353e588fe1\BrUsbSIb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr005.inf_amd64_neutral_d140721f97061bba\BrUsbSIb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr002.inf_amd64_neutral_ce2134188ab21f59\BrUsbSIb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr006.inf_amd64_neutral_40c76453575b1208\mdmbr006.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr006.inf_amd64_neutral_40c76453575b1208\mdmbr006.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr006.inf_amd64_neutral_40c76453575b1208\BrUsbSIb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr007.inf_amd64_neutral_91d259640bad7d26\mdmbr007.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr007.inf_amd64_neutral_91d259640bad7d26\mdmbr007.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr007.inf_amd64_neutral_91d259640bad7d26\BrUsbSIb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr008.inf_amd64_neutral_2cedaac353c381da\mdmbr008.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr008.inf_amd64_neutral_2cedaac353c381da\BrUsbSIb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr008.inf_amd64_neutral_2cedaac353c381da\mdmbr008.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr00a.inf_amd64_neutral_aa4f0850ff03674e\BrUsbSIb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmags64.inf_amd64_neutral_e68956e24e287714\agrsm64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr00a.inf_amd64_neutral_aa4f0850ff03674e\mdmbr00a.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr00a.inf_amd64_neutral_aa4f0850ff03674e\mdmbr00a.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbsb.inf_amd64_neutral_56a9f6bceeec7f72\mdmbsb.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbsb.inf_amd64_neutral_56a9f6bceeec7f72\mdmbsb.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbtmdm.inf_amd64_neutral_2e4da8629fc5904e\mdmbtmdm.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbtmdm.inf_amd64_neutral_2e4da8629fc5904e\mdmbtmdm.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbug3.inf_amd64_neutral_7617862a9cc286da\mdmbug3.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbug3.inf_amd64_neutral_7617862a9cc286da\mdmbug3.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbw561.inf_amd64_neutral_fe42c0ff14d5562b\MDMBW561.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbw561.inf_amd64_neutral_fe42c0ff14d5562b\mdmbw561.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbtmdm.inf_amd64_neutral_2e4da8629fc5904e\bthmodem.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmc26a.inf_amd64_neutral_547edd894d7c19d9\mdmc26a.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr008.inf_amd64_neutral_2cedaac353c381da\BrSerIb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr002.inf_amd64_neutral_ce2134188ab21f59\BrSerIb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr004.inf_amd64_neutral_ccf1bc353e588fe1\BrSerIb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr005.inf_amd64_neutral_d140721f97061bba\BrSerIb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmc26a.inf_amd64_neutral_547edd894d7c19d9\mdmc26a.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr006.inf_amd64_neutral_40c76453575b1208\BrSerIb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcdp.inf_amd64_neutral_170c11f3a6d3f0a8\mdmcdp.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcdp.inf_amd64_neutral_170c11f3a6d3f0a8\mdmcdp.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcodex.inf_amd64_neutral_9bb71004e7b8f7ae\mdmcodex.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcodex.inf_amd64_neutral_9bb71004e7b8f7ae\mdmcodex.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcommu.inf_amd64_neutral_83cc415156be45c8\mdmcommu.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcom1.inf_amd64_neutral_96c22c683482d8bd\mdmcom1.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr00a.inf_amd64_neutral_aa4f0850ff03674e\BrSerIb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcommu.inf_amd64_neutral_83cc415156be45c8\mdmcommu.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcom1.inf_amd64_neutral_96c22c683482d8bd\mdmcom1.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcm28.inf_amd64_neutral_d3fa0f62d3d7cea1\mdmcm28.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcomp.inf_amd64_neutral_e5ca2f01ca47bddb\mdmcomp.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcomp.inf_amd64_neutral_e5ca2f01ca47bddb\mdmcomp.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcpq.inf_amd64_neutral_b53453733bd795bc\mdmcpq.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcm28.inf_amd64_neutral_d3fa0f62d3d7cea1\mdmcm28.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmbr007.inf_amd64_neutral_91d259640bad7d26\BrSerIb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcpq2.inf_amd64_neutral_e9784021af1f5e24\mdmcpq2.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcpq2.inf_amd64_neutral_e9784021af1f5e24\mdmcpq2.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcpv.inf_amd64_neutral_5667cca434e3a6b7\mdmcpv.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcpv.inf_amd64_neutral_5667cca434e3a6b7\mdmcpv.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcpq.inf_amd64_neutral_fbc4a14a6a13d0c8\mdmcpq.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcrtix.inf_amd64_neutral_e91a5dc0655e200a\mdmcrtix.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcrtix.inf_amd64_neutral_e91a5dc0655e200a\mdmcrtix.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcpq.inf_amd64_neutral_fbc4a14a6a13d0c8\mdmcpq.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcpq.inf_amd64_neutral_fbc4a14a6a13d0c8\usbser.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcxhv6.inf_amd64_neutral_81ba64c5b6150dd3\mdmcxhv6.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcxhv6.inf_amd64_neutral_81ba64c5b6150dd3\mdmcxhv6.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcxhv6.inf_amd64_neutral_81ba64c5b6150dd3\VSTProf.cty - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcxpv6.inf_amd64_neutral_f62ac4bd04e653d0\mdmcxpv6.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcxpv6.inf_amd64_neutral_f62ac4bd04e653d0\mdmcxpv6.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcxhv6.inf_amd64_neutral_81ba64c5b6150dd3\VSTAZL6.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcxhv6.inf_amd64_neutral_81ba64c5b6150dd3\VSTBS26.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcpq.inf_amd64_neutral_b53453733bd795bc\mdmcpq.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcxpv6.inf_amd64_neutral_f62ac4bd04e653d0\VSTProf.cty - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcxhv6.inf_amd64_neutral_81ba64c5b6150dd3\VSTBS36.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcxpv6.inf_amd64_neutral_f62ac4bd04e653d0\VSTBS26.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcpq.inf_amd64_neutral_b53453733bd795bc\usbser.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmdcm5.inf_amd64_neutral_0bb09f3e5a59f3a8\mdmdcm5.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmdcm5.inf_amd64_neutral_0bb09f3e5a59f3a8\mdmdcm5.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmdcm6.inf_amd64_neutral_b1db427ce3d2a1b4\mdmdcm6.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmdcm6.inf_amd64_neutral_b1db427ce3d2a1b4\mdmdcm6.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmdf56f.inf_amd64_neutral_26a79521b746fc31\mdmdf56f.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmdf56f.inf_amd64_neutral_26a79521b746fc31\mdmdf56F.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmdgitn.inf_amd64_neutral_09132735f1063a47\mdmdgitn.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmdp2.inf_amd64_neutral_ab710894455d7b9a\mdmdp2.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmdgitn.inf_amd64_neutral_09132735f1063a47\mdmdgitn.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmdyna.inf_amd64_neutral_7e4d690d07ee94c1\mdmdyna.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmdsi.inf_amd64_neutral_e77f438012239042\mdmdsi.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmeiger.inf_amd64_neutral_492d4e047d14bde9\mdmeiger.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmeiger.inf_amd64_neutral_492d4e047d14bde9\mdmeiger.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmdsi.inf_amd64_neutral_e77f438012239042\mdmdsi.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmelsa.inf_amd64_neutral_374f9d31af832d6b\mdmelsa.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmdp2.inf_amd64_neutral_ab710894455d7b9a\mdmdp2.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcxpv6.inf_amd64_neutral_f62ac4bd04e653d0\VSTCNXT6.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmeric.inf_amd64_neutral_27c5b45728cc9ed0\mdmeric.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmeric.inf_amd64_neutral_27c5b45728cc9ed0\mdmeric.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmelsa.inf_amd64_neutral_374f9d31af832d6b\mdmelsa.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmdyna.inf_amd64_neutral_7e4d690d07ee94c1\mdmdyna.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmetech.inf_amd64_neutral_230358eeb58f0b3b\mdmetech.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmeric2.inf_amd64_neutral_a0575ec9ce5c7de9\mdmeric2.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcxhv6.inf_amd64_neutral_81ba64c5b6150dd3\VSTCNXT6.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmfj2.inf_amd64_neutral_9c9eb67d406a1632\mdmfj2.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmetech.inf_amd64_neutral_230358eeb58f0b3b\mdmetech.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgatew.inf_amd64_neutral_84eee4cc19fd00dc\mdmgatew.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmeric2.inf_amd64_neutral_a0575ec9ce5c7de9\mdmeric2.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgcs.inf_amd64_neutral_aafcd45e4e890862\mdmgcs.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgen.inf_amd64_neutral_083b7cd856bd912c\mdmgen.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgatew.inf_amd64_neutral_84eee4cc19fd00dc\mdmgatew.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgen.inf_amd64_neutral_083b7cd856bd912c\mdmgen.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmfj2.inf_amd64_neutral_9c9eb67d406a1632\mdmfj2.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgen.inf_amd64_neutral_7a967d06d569b1e4\mdmgen.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgcs.inf_amd64_neutral_aafcd45e4e890862\mdmgcs.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl001.inf_amd64_neutral_9209e816461a1a73\mdmgl001.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl001.inf_amd64_neutral_9209e816461a1a73\mdmgl001.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgen.inf_amd64_neutral_7a967d06d569b1e4\mdmgen.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl002.inf_amd64_neutral_e204d4267d752eb7\mdmgl002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl002.inf_amd64_neutral_e204d4267d752eb7\mdmgl002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl003.inf_amd64_neutral_4c78da9e48068043\mdmgl003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl003.inf_amd64_neutral_4c78da9e48068043\mdmgl003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl005.inf_amd64_neutral_8b56291bfd2a4061\mdmgl005.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl005.inf_amd64_neutral_8b56291bfd2a4061\mdmgl005.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl004.inf_amd64_neutral_1874f16002601f78\mdmgl004.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl004.inf_amd64_neutral_1874f16002601f78\mdmgl004.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl006.inf_amd64_neutral_e5693eb731048022\mdmgl006.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl008.inf_amd64_neutral_d225e15af1a594cd\mdmgl008.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl006.inf_amd64_neutral_e5693eb731048022\mdmgl006.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl007.inf_amd64_neutral_935cd017fcb965ee\mdmgl007.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl007.inf_amd64_neutral_935cd017fcb965ee\mdmgl007.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgsm.inf_amd64_neutral_dd3fbd8c64c7c87d\mdmgsm.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgsm.inf_amd64_neutral_dd3fbd8c64c7c87d\mdmgsm.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmhaeu.inf_amd64_neutral_6611a858035bf482\mdmhaeu.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmhaeu.inf_amd64_neutral_6611a858035bf482\mdmhaeu.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl010.inf_amd64_neutral_46f466c9e68abb4a\mdmgl010.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl009.inf_amd64_neutral_bed6224f27f5c478\mdmgl009.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl008.inf_amd64_neutral_d225e15af1a594cd\mdmgl008.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl009.inf_amd64_neutral_bed6224f27f5c478\mdmgl009.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmgl010.inf_amd64_neutral_46f466c9e68abb4a\mdmgl010.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmhandy.inf_amd64_neutral_386661b46df6da3f\mdmhandy.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmhandy.inf_amd64_neutral_386661b46df6da3f\mdmhandy.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmhay2.inf_amd64_neutral_ff250f861d941dd8\mdmhay2.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmhayes.inf_amd64_neutral_507db5d34d7acddc\mdmhayes.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmhay2.inf_amd64_neutral_ff250f861d941dd8\mdmhay2.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdminfot.inf_amd64_neutral_fc6bcd80e9e6a3c3\mdminfot.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdminfot.inf_amd64_neutral_fc6bcd80e9e6a3c3\mdminfot.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcxpv6.inf_amd64_neutral_f62ac4bd04e653d0\VSTDPV6.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmcxhv6.inf_amd64_neutral_81ba64c5b6150dd3\VSTDPV6.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmhayes.inf_amd64_neutral_507db5d34d7acddc\mdmhayes.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmiodat.inf_amd64_neutral_839e9ee1a8736613\mdmiodat.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmiodat.inf_amd64_neutral_839e9ee1a8736613\mdmiodat.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmjf56e.inf_amd64_neutral_328dabbf0aeed9bc\mdmjf56e.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmirmdm.inf_amd64_neutral_fadec14b0a37b637\mdmirmdm.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmirmdm.inf_amd64_neutral_fadec14b0a37b637\mdmirmdm.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmisdn.inf_amd64_neutral_061c61abd3904560\mdmisdn.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmke.inf_amd64_neutral_3e4daa83122b1559\mdmke.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmjf56e.inf_amd64_neutral_328dabbf0aeed9bc\mdmjf56e.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmisdn.inf_amd64_neutral_061c61abd3904560\mdmisdn.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmke.inf_amd64_neutral_3e4daa83122b1559\mdmke.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmkortx.inf_amd64_neutral_1975687236603184\mdmkortx.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmkortx.inf_amd64_neutral_1975687236603184\mdmkortx.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmlasat.inf_amd64_neutral_bc1469ba40fe2114\mdmlasat.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmlasno.inf_amd64_neutral_c86d5b5e5fa8b48a\mdmlasno.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmlasno.inf_amd64_neutral_c86d5b5e5fa8b48a\mdmlasno.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmc288.inf_amd64_neutral_c4a901dab689ad79\mdmmc288.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmcd.inf_amd64_neutral_49212f5920298e45\mdmmcd.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmlucnt.inf_amd64_neutral_642a5ab3f2a1ae20\mdmlucnt.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmlucnt.inf_amd64_neutral_642a5ab3f2a1ae20\mdmlucnt.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmirmdm.inf_amd64_neutral_fadec14b0a37b637\MSIRCOMM.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmcom.inf_amd64_neutral_716a306ec3899e04\mdmmcom.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmcd.inf_amd64_neutral_49212f5920298e45\Mdmmcd.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmct.inf_amd64_neutral_15bb3ed734fbbeb3\mdmmct.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmcom.inf_amd64_neutral_716a306ec3899e04\mdmmcom.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmega.inf_amd64_neutral_f9c441ed24f00358\mdmmega.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmega.inf_amd64_neutral_f9c441ed24f00358\mdmmega.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmct.inf_amd64_neutral_15bb3ed734fbbeb3\Mdmmct.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmlasat.inf_amd64_neutral_bc1469ba40fe2114\mdmlasat.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmhrtz.inf_amd64_neutral_10affee00545fb45\mdmmhrtz.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmetri.inf_amd64_neutral_f89b8a357327f615\mdmmetri.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmhrtz.inf_amd64_neutral_10affee00545fb45\mdmmhrtz.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmc288.inf_amd64_neutral_c4a901dab689ad79\mdmmc288.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmminij.inf_amd64_neutral_7c300346e830b2dc\mdmminij.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmminij.inf_amd64_neutral_7c300346e830b2dc\mdmminij.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmod.inf_amd64_neutral_5766736c47b90fff\mdmmod.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmetri.inf_amd64_neutral_f89b8a357327f615\mdmmetri.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmod.inf_amd64_neutral_5766736c47b90fff\mdmmod.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmhzel.inf_amd64_neutral_1292ec506cfc26db\mdmmhzel.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmotou.inf_amd64_neutral_eb1d978f38f35bca\mdmmotou.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmhzel.inf_amd64_neutral_1292ec506cfc26db\mdmmhzel.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmot64.inf_amd64_neutral_1abbad2f29c8fa08\mdmmot64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmoto1.inf_amd64_neutral_bf4b404852955eb4\mdmmoto1.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmoto1.inf_amd64_neutral_bf4b404852955eb4\mdmmoto1.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnis1u.inf_amd64_neutral_131acacf005e4310\mdmnis1u.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmotou.inf_amd64_neutral_eb1d978f38f35bca\mdmmotou.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmts.inf_amd64_neutral_b7f0a8d5f67c19e8\mdmmts.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmneuhs.inf_amd64_neutral_d1563e8412461eea\mdmneuhs.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnis1u.inf_amd64_neutral_131acacf005e4310\mdmnis1u.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmneuhs.inf_amd64_neutral_d1563e8412461eea\mdmneuhs.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnis1u.inf_amd64_neutral_15011483bd8465c4\mdmnis1u.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnis2u.inf_amd64_neutral_2cf31c7acd8eee58\mdmnis2u.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnis2u.inf_amd64_neutral_2cf31c7acd8eee58\mdmnis2u.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnis1u.inf_amd64_neutral_15011483bd8465c4\mdmnis1u.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnis2u.inf_amd64_neutral_de46607a02fe2552\mdmnis2u.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnis2u.inf_amd64_neutral_de46607a02fe2552\mdmnis2u.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnis5t.inf_amd64_neutral_6c50ee5cb1ea2780\mdmnis5t.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnis5t.inf_amd64_neutral_6c50ee5cb1ea2780\mdmnis5t.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnis3t.inf_amd64_neutral_857ff0fa9c73850a\mdmnis3t.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmot64.inf_amd64_neutral_1abbad2f29c8fa08\mdmmot64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnis3t.inf_amd64_neutral_857ff0fa9c73850a\mdmnis3t.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnova.inf_amd64_neutral_b52d8db82d8c3be9\mdmnova.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnokia.inf_amd64_neutral_a8e9a41983d33a0b\mdmnokia.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmntt1.inf_amd64_neutral_ecf5cff2236b273a\mdmntt1.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmts.inf_amd64_neutral_b7f0a8d5f67c19e8\mdmmts.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmntt1.inf_amd64_neutral_ecf5cff2236b273a\mdmntt1.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnttd2.inf_amd64_neutral_9dcd97ab7a913b7a\MDMNTTD2.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnttd2.inf_amd64_neutral_9dcd97ab7a913b7a\mdmnttd2.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnokia.inf_amd64_neutral_a8e9a41983d33a0b\MSIRCOMM.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnttd6.inf_amd64_neutral_ce587aa61510da51\MDMNTTD6.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnttd6.inf_amd64_neutral_ce587aa61510da51\mdmnttd6.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnttme.inf_amd64_neutral_ece4b1cc5aee6a38\mdmnttme.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnova.inf_amd64_neutral_b52d8db82d8c3be9\mdmnova.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnttme.inf_amd64_neutral_ece4b1cc5aee6a38\mdmnttme.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnttp.inf_amd64_neutral_18b899bdc8a755fa\mdmnttp.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnttp.inf_amd64_neutral_18b899bdc8a755fa\mdmnttp.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnttp2.inf_amd64_neutral_d218c42ac8635704\mdmnttp2.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnttp2.inf_amd64_neutral_d218c42ac8635704\mdmnttp2.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnttte.inf_amd64_neutral_16d100fb6ba2e40f\mdmnttte.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnttte.inf_amd64_neutral_16d100fb6ba2e40f\mdmnttte.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmolic.inf_amd64_neutral_a53ac1a125d227fc\mdmolic.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmnokia.inf_amd64_neutral_a8e9a41983d33a0b\mdmnokia.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmoptn.inf_amd64_neutral_be2f30f68f2a5567\mdmoptn.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmoptn.inf_amd64_neutral_be2f30f68f2a5567\mdmoptn.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmolic.inf_amd64_neutral_a53ac1a125d227fc\mdmolic.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmomrn3.inf_amd64_neutral_a87289088ec2cdf1\mdmomrn3.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmosi.inf_amd64_neutral_932d048a735b47c2\mdmosi.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmosi.inf_amd64_neutral_932d048a735b47c2\mdmosi.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmpace.inf_amd64_neutral_f5caca1789a3c28b\mdmpace.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmomrn3.inf_amd64_neutral_a87289088ec2cdf1\mdmomrn3.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmpin.inf_amd64_neutral_2415474b9db0a888\MDMPIN.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmpace.inf_amd64_neutral_f5caca1789a3c28b\mdmpace.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmpenr.inf_amd64_neutral_34624840c3163a38\mdmpenr.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmpn1.inf_amd64_neutral_e44cc033b67e7d04\mdmpn1.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmpin.inf_amd64_neutral_2415474b9db0a888\mdmpin.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmmot64.inf_amd64_neutral_1abbad2f29c8fa08\SmSerl64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmpp.inf_amd64_neutral_a9cb77fe1985cd2c\mdmpp.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmpn1.inf_amd64_neutral_e44cc033b67e7d04\mdmpn1.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmpenr.inf_amd64_neutral_34624840c3163a38\mdmpenr.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmpp.inf_amd64_neutral_a9cb77fe1985cd2c\mdmpp.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmracal.inf_amd64_neutral_857b8ff74e5a7073\mdmracal.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmrock.inf_amd64_neutral_2ec26aaad7a9d419\mdmrock.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmracal.inf_amd64_neutral_857b8ff74e5a7073\mdmracal.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmrock.inf_amd64_neutral_2ec26aaad7a9d419\mdmrock.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmrock3.inf_amd64_neutral_9fdc5d710dd63e80\mdmrock3.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmrock4.inf_amd64_neutral_e45293c539584293\mdmrock4.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmrock3.inf_amd64_neutral_9fdc5d710dd63e80\mdmrock3.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmpsion.inf_amd64_neutral_6e65ea91a16f922a\mdmpsion.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmpsion.inf_amd64_neutral_6e65ea91a16f922a\mdmpsion.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmrock4.inf_amd64_neutral_e45293c539584293\mdmrock4.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmrock5.inf_amd64_neutral_cadd97421d121ebb\mdmrock5.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsii64.inf_amd64_neutral_d7409fccc5ef4078\mdmsii64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsier.inf_amd64_neutral_622ad8125bbeeda8\mdmsier.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmrock5.inf_amd64_neutral_cadd97421d121ebb\mdmrock5.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsier.inf_amd64_neutral_622ad8125bbeeda8\mdmsier.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsii64.inf_amd64_neutral_d7409fccc5ef4078\mdmsii64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsonyu.inf_amd64_neutral_45152a8a9362fb82\mdmsonyu.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsun1.inf_amd64_neutral_6184912bd8e5b438\mdmsun1.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsun1.inf_amd64_neutral_6184912bd8e5b438\mdmsun1.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsonyu.inf_amd64_neutral_45152a8a9362fb82\mdmsonyu.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsun2.inf_amd64_neutral_242c76ad2e288fb4\mdmsun2.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsun2.inf_amd64_neutral_242c76ad2e288fb4\mdmsun2.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsupr3.inf_amd64_neutral_8416bd6e64a8e858\mdmsupr3.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsmart.inf_amd64_neutral_829e8c7d1c8d5207\mdmsmart.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsmart.inf_amd64_neutral_829e8c7d1c8d5207\mdmsmart.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsuprv.inf_amd64_neutral_31d10a1a73b4feaa\mdmsuprv.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsupr3.inf_amd64_neutral_8416bd6e64a8e858\mdmsupr3.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsuprv.inf_amd64_neutral_31d10a1a73b4feaa\mdmsuprv.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtdk.inf_amd64_neutral_e567adb271831b5d\mdmtdk.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsupra.inf_amd64_neutral_c4fe81ea47c6df87\mdmsupra.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtdk.inf_amd64_neutral_e567adb271831b5d\mdmtdk.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmsupra.inf_amd64_neutral_c4fe81ea47c6df87\mdmsupra.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtdkj3.inf_amd64_neutral_7e1053ab483310f6\mdmtdkj3.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtdkj2.inf_amd64_neutral_0cf7696e2236ca4e\mdmtdkj2.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtdkj3.inf_amd64_neutral_7e1053ab483310f6\mdmtdkj3.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtdkj4.inf_amd64_neutral_c150a510c4b85ce7\mdmtdkj4.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtdkj4.inf_amd64_neutral_c150a510c4b85ce7\mdmtdkj4.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtdkj5.inf_amd64_neutral_15940559c66fe8d9\mdmtdkj5.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtdkj6.inf_amd64_neutral_8087946c82068597\mdmtdkj6.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtdkj7.inf_amd64_neutral_7c21481229e1e66c\mdmtdkj7.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtdkj6.inf_amd64_neutral_8087946c82068597\mdmtdkj6.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtdkj5.inf_amd64_neutral_15940559c66fe8d9\mdmtdkj5.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtexas.inf_amd64_neutral_7572473d88d69307\mdmtexas.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtexas.inf_amd64_neutral_7572473d88d69307\mdmtexas.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmti.inf_amd64_neutral_4443b423d18c3ffc\mdmti.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtkr.inf_amd64_neutral_8e3809aa77440c37\mdmtkr.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmti.inf_amd64_neutral_4443b423d18c3ffc\mdmti.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtkr.inf_amd64_neutral_8e3809aa77440c37\mdmtkr.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtdkj7.inf_amd64_neutral_7c21481229e1e66c\mdmtdkj7.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmusrf.inf_amd64_neutral_439e7d1dcac00aca\mdmusrf.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtron.inf_amd64_neutral_1121c7f92e9e3001\mdmtron.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtron.inf_amd64_neutral_1121c7f92e9e3001\mdmtron.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmusrf.inf_amd64_neutral_439e7d1dcac00aca\mdmusrf.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmusrgl.inf_amd64_neutral_d42522943de68905\mdmusrgl.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmusrsp.inf_amd64_neutral_a44611db70783ded\mdmusrsp.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmtdkj2.inf_amd64_neutral_0cf7696e2236ca4e\mdmtdkj2.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmusrgl.inf_amd64_neutral_d42522943de68905\mdmusrgl.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmusrg.inf_amd64_neutral_814744dd97ccf09f\mdmusrg.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmusrg.inf_amd64_neutral_814744dd97ccf09f\mdmusrg.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmusrsp.inf_amd64_neutral_a44611db70783ded\mdmusrsp.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmusrk1.inf_amd64_neutral_19cdebd3e1182874\mdmusrk1.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmvdot.inf_amd64_neutral_714bc6a3a28b9f0f\mdmvdot.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmusrk1.inf_amd64_neutral_19cdebd3e1182874\mdmusrk1.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmvv.inf_amd64_neutral_14cb440c800fe9fe\mdmvv.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmvdot.inf_amd64_neutral_714bc6a3a28b9f0f\mdmvdot.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmvv.inf_amd64_neutral_14cb440c800fe9fe\mdmvv.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmx5560.inf_amd64_neutral_e853cea0022c059a\mdmx5560.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmx5560.inf_amd64_neutral_e853cea0022c059a\mdmx5560.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmwhql0.inf_amd64_neutral_23613e3dd9401f10\mdmwhql0.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmzyp.inf_amd64_neutral_b64bd08009e7444f\mdmzyp.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmzyp.inf_amd64_neutral_b64bd08009e7444f\mdmzyp.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmzoom.inf_amd64_neutral_dd07287cee791f3c\mdmzoom.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\megasas.inf_amd64_neutral_395276dd9b7a7448\megasas.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmwhql0.inf_amd64_neutral_23613e3dd9401f10\mdmwhql0.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmzyxel.inf_amd64_neutral_ed1f16b3d0cae908\mdmzyxel.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmzoom.inf_amd64_neutral_dd07287cee791f3c\mdmzoom.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmzyxlg.inf_amd64_neutral_14f9249844f1cf17\mdmzyxlg.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\megasas2.inf_amd64_neutral_599d713507780ed4\megasas2.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmzyxlg.inf_amd64_neutral_14f9249844f1cf17\mdmzyxlg.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\megasas2.inf_amd64_neutral_599d713507780ed4\megasas2.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\igdlh.inf_amd64_neutral_54a12b57f547d08e\igdumd32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\memory.inf_amd64_neutral_c2d2c213c3138487\memory.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\memory.inf_amd64_neutral_c2d2c213c3138487\memory.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\megasr.inf_amd64_neutral_30b367f92ca46598\megasr.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\megasr.inf_amd64_neutral_30b367f92ca46598\megasr.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\megasas.inf_amd64_neutral_395276dd9b7a7448\megasas.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\megasas.inf_amd64_neutral_395276dd9b7a7448\megasas.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mdmzyxel.inf_amd64_neutral_ed1f16b3d0cae908\mdmzyxel.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mf.inf_amd64_neutral_b263d46928b97a9b\mf.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mf.inf_amd64_neutral_b263d46928b97a9b\mf.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\modemcsa.inf_amd64_neutral_b64a610f1f09f267\modemcsa.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\modemcsa.inf_amd64_neutral_b64a610f1f09f267\modemcsa.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\memory.inf_amd64_neutral_c2d2c213c3138487\pnpmem.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mpio.inf_amd64_neutral_0c74c0f95001b61c\mpio.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mpio.inf_amd64_neutral_0c74c0f95001b61c\mpio.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\monitor.inf_amd64_neutral_ab477c4d805d044f\monitor.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\msclmd.inf_amd64_neutral_413d17c790177eef\msclmd.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\msdri.inf_amd64_neutral_86bb50f34c49ae71\msdri.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\msclmd.inf_amd64_neutral_413d17c790177eef\msclmd.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\modemcsa.inf_amd64_neutral_b64a610f1f09f267\MODEMCSA.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mf.inf_amd64_neutral_b263d46928b97a9b\mf.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\msdri.inf_amd64_neutral_86bb50f34c49ae71\msdri.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\msdsm.inf_amd64_neutral_be2b348981b2ef17\msdsm.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\megasr.inf_amd64_neutral_30b367f92ca46598\MegaSR.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\msdsm.inf_amd64_neutral_be2b348981b2ef17\msdsm.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\msdv.inf_amd64_neutral_571f87a277565224\msdv.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\monitor.inf_amd64_neutral_ab477c4d805d044f\monitor.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\modemcsa.inf_amd64_neutral_b64a610f1f09f267\csamsp.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_552ea5111ec825a6\atapi.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\msdv.inf_amd64_neutral_571f87a277565224\msdv.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mpio.inf_amd64_neutral_0c74c0f95001b61c\mpio.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_552ea5111ec825a6\amdide.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_552ea5111ec825a6\aliide.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\msdv.inf_amd64_neutral_571f87a277565224\msdv.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_552ea5111ec825a6\mshdc.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_552ea5111ec825a6\mshdc.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\monitor.inf_amd64_neutral_ab477c4d805d044f\monitor.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\msdsm.inf_amd64_neutral_be2b348981b2ef17\msdsm.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_aad30bdeec04ea5e\atapi.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_aad30bdeec04ea5e\aliide.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_aad30bdeec04ea5e\amdide.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_552ea5111ec825a6\pciide.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_552ea5111ec825a6\ataport.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_aad30bdeec04ea5e\mshdc.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_aad30bdeec04ea5e\intelide.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_552ea5111ec825a6\intelide.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_aad30bdeec04ea5e\mshdc.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_552ea5111ec825a6\viaide.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_552ea5111ec825a6\cmdide.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_aad30bdeec04ea5e\cmdide.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_aad30bdeec04ea5e\pciide.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_552ea5111ec825a6\msahci.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_aad30bdeec04ea5e\viaide.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_552ea5111ec825a6\pciidex.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_aad30bdeec04ea5e\msahci.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_aad30bdeec04ea5e\pciidex.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\msmouse.inf_amd64_neutral_7a5f47d3150cc0eb\msmouse.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\msports.inf_amd64_neutral_fdcfb86ce78678d1\msports.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mshdc.inf_amd64_neutral_aad30bdeec04ea5e\ataport.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\msmouse.inf_amd64_neutral_7a5f47d3150cc0eb\mouhid.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\msmouse.inf_amd64_neutral_7a5f47d3150cc0eb\i8042prt.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\msports.inf_amd64_neutral_fdcfb86ce78678d1\msports.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\msmouse.inf_amd64_neutral_7a5f47d3150cc0eb\msmouse.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mstape.inf_amd64_neutral_c2bb3ef1c45cd5a1\mstape.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\mstape.inf_amd64_neutral_c2bb3ef1c45cd5a1\mstape.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mtconfig.inf_amd64_neutral_4de24f49b5e60c45\mtconfig.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mtconfig.inf_amd64_neutral_4de24f49b5e60c45\mtconfig.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\msmouse.inf_amd64_neutral_7a5f47d3150cc0eb\mouclass.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\multiprt.inf_amd64_neutral_988a34fc912eab54\multiprt.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\multiprt.inf_amd64_neutral_988a34fc912eab54\multiprt.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\net1kx64.inf_amd64_neutral_1f62482fbb9e52a5\net1kx64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\msmouse.inf_amd64_neutral_7a5f47d3150cc0eb\sermouse.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\msports.inf_amd64_neutral_fdcfb86ce78678d1\serenum.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\net1kx64.inf_amd64_neutral_1f62482fbb9e52a5\net1kx64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\mtconfig.inf_amd64_neutral_4de24f49b5e60c45\MTConfig.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\mstape.inf_amd64_neutral_c2bb3ef1c45cd5a1\mstape.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\net1qx64.inf_amd64_neutral_85d10fa4c777b7be\net1qx64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\msports.inf_amd64_neutral_fdcfb86ce78678d1\serial.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\net1yx64.inf_amd64_neutral_ed16756f950857e8\net1yx64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\net1qx64.inf_amd64_neutral_85d10fa4c777b7be\net1qx64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\msports.inf_amd64_neutral_fdcfb86ce78678d1\parport.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\net1yx64.inf_amd64_neutral_ed16756f950857e8\net1yx64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\net44amd.inf_amd64_neutral_db76873d4261eb11\net44amd.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\net8185.inf_amd64_neutral_4ab014d645098f5f\net8185.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\net8185.inf_amd64_neutral_4ab014d645098f5f\net8185.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\net44amd.inf_amd64_neutral_db76873d4261eb11\net44amd.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\net8187bv64.inf_amd64_neutral_d9eee378245b3b8b\net8187bv64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\net8187bv64.inf_amd64_neutral_d9eee378245b3b8b\net8187bv64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\net8187se64.inf_amd64_neutral_c239ab5d36a3b3e9\net8187se64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\net8187se64.inf_amd64_neutral_c239ab5d36a3b3e9\net8187se64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netaapl64.inf_amd64_neutral_bf785db627c6d127\netaapl64.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\netaapl64.inf_amd64_neutral_bf785db627c6d127\netaapl64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netaapl64.inf_amd64_neutral_bf785db627c6d127\netaapl64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\net1kx64.inf_amd64_neutral_1f62482fbb9e52a5\e1k60x64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\net1qx64.inf_amd64_neutral_85d10fa4c777b7be\e1q60x64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\net44amd.inf_amd64_neutral_db76873d4261eb11\b44amd64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netaapl64.inf_amd64_neutral_bf785db627c6d127\netaapl64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\net1yx64.inf_amd64_neutral_ed16756f950857e8\e1y60x64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netathrx.inf_amd64_neutral_905772087ff288af\netathrx.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netathrx.inf_amd64_neutral_905772087ff288af\netathrx.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\net8187bv64.inf_amd64_neutral_d9eee378245b3b8b\RTL8187B.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\net8185.inf_amd64_neutral_4ab014d645098f5f\RTL85n64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\net8187se64.inf_amd64_neutral_c239ab5d36a3b3e9\RTL8187Se.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netbc664.inf_amd64_neutral_673d3dfb961e9b17\netbc664.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netbvbda.inf_amd64_neutral_2bfa4ea57bd5d74a\netbvbda.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netbc664.inf_amd64_neutral_673d3dfb961e9b17\netbc664.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netb57va.inf_amd64_neutral_6264e97d4fc12211\netb57va.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netbvbda.inf_amd64_neutral_2bfa4ea57bd5d74a\netbvbda.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netbxnda.inf_amd64_neutral_c81780c5dcabd0a0\netbxnda.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netb57va.inf_amd64_neutral_6264e97d4fc12211\b57nd60a.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netbxnda.inf_amd64_neutral_c81780c5dcabd0a0\netbxnda.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\nete1e3e.inf_amd64_neutral_f77725472d91b1d1\nete1e3e.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\nete1e3e.inf_amd64_neutral_f77725472d91b1d1\nete1e3e.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\nete1g3e.inf_amd64_neutral_7f08406e40c6ede2\nete1g3e.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netb57va.inf_amd64_neutral_6264e97d4fc12211\netb57va.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\nete1g3e.inf_amd64_neutral_7f08406e40c6ede2\nete1g3e.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netefe3e.inf_amd64_neutral_b71dd3dadc5c3e27\netefe3e.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netefe3e.inf_amd64_neutral_b71dd3dadc5c3e27\neteFE3e.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netevbda.inf_amd64_neutral_bab421df9c31cc81\netevbda.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netevbda.inf_amd64_neutral_bab421df9c31cc81\netevbda.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netg664.inf_amd64_neutral_b4e8ccc6ba210e97\netg664.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netbxnda.inf_amd64_neutral_c81780c5dcabd0a0\bxnd60a.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netg664.inf_amd64_neutral_b4e8ccc6ba210e97\netg664.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netimm.inf_amd64_neutral_9b64397618841a19\netimm.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\nete1g3e.inf_amd64_neutral_7f08406e40c6ede2\E1G6032E.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netimm.inf_amd64_neutral_9b64397618841a19\netimm.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netefe3e.inf_amd64_neutral_b71dd3dadc5c3e27\eFE5b32e.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netirda.inf_amd64_neutral_93a886f96cea2847\netirda.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netg664.inf_amd64_neutral_b4e8ccc6ba210e97\SiSG664.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\nete1e3e.inf_amd64_neutral_f77725472d91b1d1\e1e6032e.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netk57a.inf_amd64_neutral_8b26ad5d0cc037a9\netk57a.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netirda.inf_amd64_neutral_93a886f96cea2847\netirda.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netbvbda.inf_amd64_neutral_2bfa4ea57bd5d74a\bxvbda.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netl160a.inf_amd64_neutral_f8bdd2cbac28a8fd\netl160a.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netk57a.inf_amd64_neutral_8b26ad5d0cc037a9\netk57a.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netl160a.inf_amd64_neutral_f8bdd2cbac28a8fd\netl160a.inf - Ok
>C:\Windows\system32\DriverStore\FileRepository\netaapl64.inf_amd64_neutral_bf785db627c6d127\wdfcoinstaller01009.dll is CAB archive
C:\Windows\system32\DriverStore\FileRepository\netaapl64.inf_amd64_neutral_bf785db627c6d127\wdfcoinstaller01009.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\netaapl64.inf_amd64_neutral_bf785db627c6d127\wdfcoinstaller01009.dll - archive
C:\Windows\system32\DriverStore\FileRepository\netl1c64.inf_amd64_neutral_30b0b06f47cab8cf\netl1c64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netl1e64.inf_amd64_neutral_22118b1072f57433\netl1e64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netl1c64.inf_amd64_neutral_30b0b06f47cab8cf\netl1c64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netl1e64.inf_amd64_neutral_22118b1072f57433\netl1e64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netl260a.inf_amd64_neutral_085226e1dfe76c55\netl260a.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netl260a.inf_amd64_neutral_085226e1dfe76c55\netl260a.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netloop.inf_amd64_neutral_856142fd87f1c21a\netloop.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netbc664.inf_amd64_neutral_673d3dfb961e9b17\BCMWL664.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\netl260a.inf_amd64_neutral_085226e1dfe76c55\l260x64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netl1c64.inf_amd64_neutral_30b0b06f47cab8cf\L1C62x64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netloop.inf_amd64_neutral_856142fd87f1c21a\netloop.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netl160a.inf_amd64_neutral_f8bdd2cbac28a8fd\l160x64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netl1e64.inf_amd64_neutral_22118b1072f57433\L1E62x64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netnvm64.inf_amd64_neutral_59c2a018fe2cf0b4\netnvm64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netmyk00.inf_amd64_neutral_9c0c35afdddc16d2\netmyk00.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netloop.inf_amd64_neutral_856142fd87f1c21a\loop.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netnvm64.inf_amd64_neutral_59c2a018fe2cf0b4\netnvm64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netnvma.inf_amd64_neutral_99bb33c9a5bedaea\netnvma.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netk57a.inf_amd64_neutral_8b26ad5d0cc037a9\k57nd60a.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netmyk00.inf_amd64_neutral_9c0c35afdddc16d2\netmyk00.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netnvma.inf_amd64_neutral_99bb33c9a5bedaea\netnvma.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netr28ux.inf_amd64_neutral_54f2470c084714e1\netr28ux.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netr28ux.inf_amd64_neutral_54f2470c084714e1\netr28ux.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netr28x.inf_amd64_neutral_c86d6d5c3810fc04\netr28x.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netr28x.inf_amd64_neutral_c86d6d5c3810fc04\netr28x.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netr7364.inf_amd64_neutral_68988e550e69a417\netr7364.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_0b46e86f0f566f5a\netrndis.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netr7364.inf_amd64_neutral_68988e550e69a417\netr7364.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netathrx.inf_amd64_neutral_905772087ff288af\athrx.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_0b46e86f0f566f5a\netrndis.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netnvm64.inf_amd64_neutral_59c2a018fe2cf0b4\nvm62x64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netevbda.inf_amd64_neutral_bab421df9c31cc81\evbda.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netmyk00.inf_amd64_neutral_9c0c35afdddc16d2\yk62x64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_1c5becb2deac08f0\netrndis.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_1c5becb2deac08f0\netrndis.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_0b46e86f0f566f5a\rndismp6.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_1c5becb2deac08f0\rndismp6.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_0b46e86f0f566f5a\usb8023x.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netr28ux.inf_amd64_neutral_54f2470c084714e1\netr28ux.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_4c56d83f6e4d75b0\netrndis.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_4c56d83f6e4d75b0\netrndis.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netnvma.inf_amd64_neutral_99bb33c9a5bedaea\nvm60x64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_0b46e86f0f566f5a\rndismpx.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_1c5becb2deac08f0\rndismpx.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netrtl64.inf_amd64_neutral_0383c5de75359695\netrtl64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_4c56d83f6e4d75b0\usb8023x.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netrtl64.inf_amd64_neutral_0383c5de75359695\netrtl64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_1c5becb2deac08f0\usb80236.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netrtx64.inf_amd64_neutral_410e89ed86071c9b\netrtx64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netrtx64.inf_amd64_neutral_410e89ed86071c9b\netrtx64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_4c56d83f6e4d75b0\rndismp6.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_4c56d83f6e4d75b0\rndismpx.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\nettun.inf_amd64_neutral_bd24fb174fabec97\nettun.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\nettun.inf_amd64_neutral_bd24fb174fabec97\nettun.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_4c56d83f6e4d75b0\usb80236.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_0b46e86f0f566f5a\usb80236.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netvfx64.inf_amd64_neutral_194cb6d2ea3a486e\netvfx64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netvg62a.inf_amd64_neutral_5817ae5135655364\netvg62a.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netvfx64.inf_amd64_neutral_194cb6d2ea3a486e\netvfx64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netvg62a.inf_amd64_neutral_5817ae5135655364\netvg62a.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netvwifibus.inf_amd64_neutral_9d0740f32ce81d24\netvwifibus.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netvwifibus.inf_amd64_neutral_9d0740f32ce81d24\netvwifibus.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netrndis.inf_amd64_neutral_1c5becb2deac08f0\usb8023x.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netw5v64.inf_amd64_neutral_a6b778ba802632cc\netw5v64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netvwifibus.inf_amd64_neutral_9d0740f32ce81d24\vwifibus.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netw5v64.inf_amd64_neutral_a6b778ba802632cc\netw5v64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netwlv64.inf_amd64_neutral_37d73903829cd3b4\NETwLv64.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\netwlv64.inf_amd64_neutral_37d73903829cd3b4\netwlv64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netrtl64.inf_amd64_neutral_0383c5de75359695\Rtnic64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netvfx64.inf_amd64_neutral_194cb6d2ea3a486e\fet6x64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netrtx64.inf_amd64_neutral_410e89ed86071c9b\Rt64win7.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netr28x.inf_amd64_neutral_c86d6d5c3810fc04\netr28x.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netvg62a.inf_amd64_neutral_5817ae5135655364\getn62a.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netwns64.inf_amd64_neutral_172aee87bb6725e8\NETwNs64.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\netwns64.inf_amd64_neutral_172aee87bb6725e8\netwns64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netwlv64.inf_amd64_neutral_37d73903829cd3b4\netwlv64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netwns64.inf_amd64_neutral_172aee87bb6725e8\netwns64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netwns64.inf_amd64_neutral_61d284fa8d9f4db1\NETwNc64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\netwns64.inf_amd64_neutral_61d284fa8d9f4db1\NETwNs64.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\netwns64.inf_amd64_neutral_61d284fa8d9f4db1\netwns64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\c7126477.inf_amd64_neutral_854d8ba5493e7ece\B126239\atioglxx.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\netwlv64.inf_amd64_neutral_37d73903829cd3b4\NETwLc64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\netwns64.inf_amd64_neutral_61d284fa8d9f4db1\netwns64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netr7364.inf_amd64_neutral_68988e550e69a417\netr7364.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netwsw00.inf_amd64_neutral_670af40e75cac748\Netwsw00.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\netwsw00.inf_amd64_neutral_670af40e75cac748\netwsw00.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netwsw00.inf_amd64_neutral_670af40e75cac748\netwsw00.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netwns64.inf_amd64_neutral_172aee87bb6725e8\NETwNc64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\netwns64.inf_amd64_neutral_61d284fa8d9f4db1\NETwNs64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netxex64.inf_amd64_neutral_77b02fd738dca150\netxex64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netxex64.inf_amd64_neutral_77b02fd738dca150\netxex64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netxex64.inf_amd64_neutral_77b02fd738dca150\ixe60x64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netwns64.inf_amd64_neutral_172aee87bb6725e8\NETwNs64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netxfx64.inf_amd64_neutral_3336ecb2950fdc45\netxfx64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\netxfx64.inf_amd64_neutral_3336ecb2950fdc45\netxfx64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\nfrd960.inf_amd64_neutral_cfc8c0013e9ede68\nfrd960.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\nfrd960.inf_amd64_neutral_cfc8c0013e9ede68\nfrd960.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\ntprint.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\ntprint.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\ntprint.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\nfrd960.inf_amd64_neutral_cfc8c0013e9ede68\nfrd960.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\netxfx64.inf_amd64_neutral_3336ecb2950fdc45\xfrmx64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\MSXPSINC.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\LOCALE.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\MSXPSINC.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\P6FONT.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\netwsw00.inf_amd64_neutral_670af40e75cac748\Netwcw00.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\netw5v64.inf_amd64_neutral_a6b778ba802632cc\netw5v64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\PCL4RES.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\P6DISP.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\PCLXL.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\PCLXL.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\PJLMON.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\PJL.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\PSCRIPT.HLP - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\MXDWDRV.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\PSCRIPT.NTF - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\PCL5ERES.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\PS_SCHM.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\STDDTYPE.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\PSCRPTFE.NTF - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\STDSCHEM.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\STDSCHMX.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\PS5UI.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\TTFSUB.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\UNIDRV.HLP - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\UNIDRV.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\netwns64.inf_amd64_neutral_61d284fa8d9f4db1\NETwNr64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\netwsw00.inf_amd64_neutral_670af40e75cac748\Netwsw00.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\PSCRIPT5.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\netwlv64.inf_amd64_neutral_37d73903829cd3b4\NETwLv64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\nulhpopr.inf_amd64_neutral_e078ec466987bb3b\nulhpopr.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\nulhpopr.inf_amd64_neutral_e078ec466987bb3b\nulhpopr.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\nusb3hub.inf_amd64_neutral_d6bd1fbeba322908\nusb3hub.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\nusb3hub.inf_amd64_neutral_d6bd1fbeba322908\nusb3hub.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\nusb3hub.inf_amd64_neutral_d6bd1fbeba322908\nusb3hub.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\nusb3xhc.inf_amd64_neutral_0bef1a22bb2463ef\nusb3xhc.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\nusb3xhc.inf_amd64_neutral_0bef1a22bb2463ef\nusb3xhc.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\nusb3xhc.inf_amd64_neutral_0bef1a22bb2463ef\nusb3xhc.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\PCL5URES.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\STDNAMES.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\netwlv64.inf_amd64_neutral_37d73903829cd3b4\NETwLr64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\UNIDRVUI.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\nusb3xhc.inf_amd64_neutral_0bef1a22bb2463ef\nusb3co.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\nusb3hub.inf_amd64_neutral_d6bd1fbeba322908\nusb3hub.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\nv_lh.inf_amd64_neutral_bc69f20e3115af59\nv_LH.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\nusb3xhc.inf_amd64_neutral_0bef1a22bb2463ef\nusb3xhc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\nv_lh.inf_amd64_neutral_bc69f20e3115af59\nv_lh.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\nvraid.inf_amd64_neutral_0276fc3b3ea60d41\nvraid.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\netwns64.inf_amd64_neutral_172aee87bb6725e8\NETwNr64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\nvraid.inf_amd64_neutral_0276fc3b3ea60d41\nvraid.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\nvraid.inf_amd64_neutral_dd659ed032d28a14\nvraid.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\nvraid.inf_amd64_neutral_dd659ed032d28a14\nvraid.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\nvraid.inf_amd64_neutral_dd659ed032d28a14\nvraid.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\nvraid.inf_amd64_neutral_0276fc3b3ea60d41\nvraid.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\pcmcia.inf_amd64_neutral_1678e66e0cbb04b2\pcmcia.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\pcmcia.inf_amd64_neutral_1678e66e0cbb04b2\pcmcia.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\pcmcia.inf_amd64_neutral_1678e66e0cbb04b2\pcmcia.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\nvraid.inf_amd64_neutral_dd659ed032d28a14\nvstor.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\nvraid.inf_amd64_neutral_0276fc3b3ea60d41\nvstor.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc0.inf_amd64_neutral_c24bcc939e6dfc23\Ph3xIBC0.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc0.inf_amd64_neutral_c24bcc939e6dfc23\ph3xibc0.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\nv_lh.inf_amd64_neutral_bc69f20e3115af59\nvlddmkm.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\UNIRES.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\nv_lh.inf_amd64_neutral_bc69f20e3115af59\nvd3dumx.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc1.inf_amd64_neutral_662220c3016bb4d0\ph3xibc1.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc1.inf_amd64_neutral_662220c3016bb4d0\Ph3xIBC1.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ntprint.inf_amd64_neutral_4616c3de1949be6d\Amd64\XPSSVCS.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc10.inf_amd64_neutral_2c5d0c618dbfaf2a\Ph3xIBC10.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc10.inf_amd64_neutral_2c5d0c618dbfaf2a\ph3xibc10.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc10.inf_amd64_neutral_2c5d0c618dbfaf2a\Ph3xIB64MV.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc1.inf_amd64_neutral_662220c3016bb4d0\Ph3xIB64MV.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc0.inf_amd64_neutral_c24bcc939e6dfc23\Ph3xIB64MV.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc11.inf_amd64_neutral_bb18e5f134c40c68\ph3xibc11.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc11.inf_amd64_neutral_bb18e5f134c40c68\Ph3xIBC11.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc11.inf_amd64_neutral_bb18e5f134c40c68\Ph3xIB64MV.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc12.inf_amd64_neutral_ff7295ba5a46d63f\Ph3xIBC12.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc12.inf_amd64_neutral_ff7295ba5a46d63f\Ph3xIB64MV.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc12.inf_amd64_neutral_ff7295ba5a46d63f\ph3xibc12.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc2.inf_amd64_neutral_7621f5d62d77f42e\Ph3xIB64MV.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc2.inf_amd64_neutral_7621f5d62d77f42e\Ph3xIBC2.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc2.inf_amd64_neutral_7621f5d62d77f42e\ph3xibc2.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\nv_lh.inf_amd64_neutral_bc69f20e3115af59\nvwgf2umx.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc3.inf_amd64_neutral_1da6abc36a79974f\Ph3xIB64MV.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc3.inf_amd64_neutral_1da6abc36a79974f\Ph3xIBC3.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc3.inf_amd64_neutral_1da6abc36a79974f\ph3xibc3.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc0.inf_amd64_neutral_c24bcc939e6dfc23\Ph3xIB64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc3.inf_amd64_neutral_1da6abc36a79974f\Ph3xIB64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc1.inf_amd64_neutral_662220c3016bb4d0\Ph3xIB64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc2.inf_amd64_neutral_7621f5d62d77f42e\Ph3xIB64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc11.inf_amd64_neutral_bb18e5f134c40c68\Ph3xIB64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc4.inf_amd64_neutral_310871d800afa82a\Ph3xIB64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc10.inf_amd64_neutral_2c5d0c618dbfaf2a\Ph3xIB64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc4.inf_amd64_neutral_310871d800afa82a\Ph3xIBC4.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc4.inf_amd64_neutral_310871d800afa82a\Ph3xIB64MV.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc5.inf_amd64_neutral_2270382453de2dbb\ph3xibc5.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc12.inf_amd64_neutral_ff7295ba5a46d63f\Ph3xIB64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc5.inf_amd64_neutral_2270382453de2dbb\Ph3xIB64MV.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc4.inf_amd64_neutral_310871d800afa82a\ph3xibc4.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc6.inf_amd64_neutral_2818f7b3b62bdd39\Ph3xIBC6.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc6.inf_amd64_neutral_2818f7b3b62bdd39\Ph3xIB64MV.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc5.inf_amd64_neutral_2270382453de2dbb\Ph3xIBC5.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc7.inf_amd64_neutral_348f512722c79525\Ph3xIBC7.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc7.inf_amd64_neutral_348f512722c79525\ph3xibc7.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc6.inf_amd64_neutral_2818f7b3b62bdd39\ph3xibc6.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc8.inf_amd64_neutral_c93e7023ef90e637\Ph3xIBC8.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc8.inf_amd64_neutral_c93e7023ef90e637\Ph3xIB64MV.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc7.inf_amd64_neutral_348f512722c79525\Ph3xIB64MV.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc5.inf_amd64_neutral_2270382453de2dbb\Ph3xIB64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc9.inf_amd64_neutral_ff3a566e4b6ba035\Ph3xIBC9.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc8.inf_amd64_neutral_c93e7023ef90e637\ph3xibc8.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc9.inf_amd64_neutral_ff3a566e4b6ba035\Ph3xIB64MV.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc9.inf_amd64_neutral_ff3a566e4b6ba035\ph3xibc9.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ph6xib64c0.inf_amd64_neutral_a43df8f7441e1c61\ph6xib64c0.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc6.inf_amd64_neutral_2818f7b3b62bdd39\Ph3xIB64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ph6xib64c0.inf_amd64_neutral_a43df8f7441e1c61\ph6xib64c0.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ph6xib64c1.inf_amd64_neutral_68c99681343e9b68\ph6xib64c1.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ph6xib64c1.inf_amd64_neutral_68c99681343e9b68\ph6xib64c1.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc7.inf_amd64_neutral_348f512722c79525\Ph3xIB64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\prnbr002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\prnbr002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\prnbr002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ph6xib64c0.inf_amd64_neutral_a43df8f7441e1c61\Ph6xIB64MV.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc8.inf_amd64_neutral_c93e7023ef90e637\Ph3xIB64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ph6xib64c1.inf_amd64_neutral_68c99681343e9b68\Ph6xIB64MV.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRCI06A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\ph3xibc9.inf_amd64_neutral_ff3a566e4b6ba035\Ph3xIB64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRCI06A.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRCI06UI.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRCI06A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD128C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD129C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD131C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD135C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD130C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD150C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD153C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD155C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD330C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\ph6xib64c0.inf_amd64_neutral_a43df8f7441e1c61\Ph6xIB64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ph6xib64c1.inf_amd64_neutral_68c99681343e9b68\Ph6xIB64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD331C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD157C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD329C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD350C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD353C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\netwsw00.inf_amd64_neutral_670af40e75cac748\Netwrw00.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD750CN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\nv_lh.inf_amd64_neutral_bc69f20e3115af59\nvwgf2um.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD770CN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD357C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD540CN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRF1960C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRF1860C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD770CW.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\brio06af.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\brio06ab.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\brio06ac.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\brio06ag.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD750CW.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRF2580C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRD560CN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\brio06aa.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRF2480C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM230C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM240C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM260C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM235C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM460CN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM440CN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM239C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM465CN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM265C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM3360C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM5460C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM480CN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM5860C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM650CD.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM665CW.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM680CN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM845CW.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\prnbr003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM660CN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM860CD.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\prnbr003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\Amd64\BRMW2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\Amd64\BRPT123.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM850CD.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\Amd64\BRMW260.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM885CW.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\prnbr003.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\Amd64\BRPT21.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM685CW.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM630CD.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\Amd64\BRMWUNI2.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\Amd64\BRPT2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\Amd64\BRPTUNI2.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\Amd64\BRPT24A.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM880CD.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\Amd64\BRPT27.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\Amd64\BRPT243.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr002.inf_amd64_neutral_db1d8c9efda9b3c0\Amd64\BRM870CD.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\prnbr004.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\prnbr004.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\prnbr004.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\Amd64\brci08a.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\Amd64\BRCI08A.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\Amd64\BRPTUI2.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\Amd64\brio08aa.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\Amd64\BRQL105.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\Amd64\BRQL106N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\Amd64\BRDP669W.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\Amd64\BRQL57.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\Amd64\BRQL58N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\Amd64\BRRL70S.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\Amd64\brio08ab.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\Amd64\brio08af.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\Amd64\brio08ak.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\Amd64\brci08ui.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\Amd64\brio08ac.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\Amd64\brio08ah.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\Amd64\brio08ae.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\Amd64\brio08ag.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr003.inf_amd64_neutral_dff45d1d0df04caf\Amd64\BRQL56.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\prnbr005.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\prnbr005.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\Amd64\BRMF589C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\prnbr005.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\Amd64\BRMF649N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRCI08B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRDP163C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\Amd64\brci08a.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\brci08ui.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRDP167C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRDP165C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRDP185C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRDP145C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRDP383C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRDP385C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr004.inf_amd64_neutral_a78e168d6944619a\Amd64\BRMF649W.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\brci08b.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRDP535N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRDP387C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\brio08ba.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\brio08bk.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\brio08bb.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRDP585W.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\brio08bc.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\brio08bf.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\brio08be.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\brio08bg.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRMF250C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRMF490N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRMF290C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRMF549C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\brci08b.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRMF297C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRMF67CD.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\prnbr006.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRMF790W.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\prnbr006.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\prnbr006.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRMF490W.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRMF990W.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr005.inf_amd64_neutral_9e4cc05e0d4bcb33\Amd64\BRMF93CD.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRD7040U.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRH2045U.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRH2075U.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRH2150U.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRD7030U.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRH5340D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\nv_lh.inf_amd64_neutral_bc69f20e3115af59\nvd3dum.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRH2170W.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRD7045N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRH2140U.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRM7320U.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRM7345N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRUNI23A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRH535DN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRH538DN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRM7440N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRH537DW.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr007.inf_amd64_neutral_add2acf1d573aef0\prnbr007.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr007.inf_amd64_neutral_add2acf1d573aef0\prnbr007.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr007.inf_amd64_neutral_add2acf1d573aef0\Amd64\BRCL06.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr007.inf_amd64_neutral_add2acf1d573aef0\prnbr007.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRURD23A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRM7450U.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRM7340U.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr007.inf_amd64_neutral_add2acf1d573aef0\Amd64\BRCLUI06.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRUUI23A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr007.inf_amd64_neutral_add2acf1d573aef0\Amd64\BRD9040N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr007.inf_amd64_neutral_add2acf1d573aef0\Amd64\BRD904DN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRM7840W.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRM7840N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr007.inf_amd64_neutral_add2acf1d573aef0\Amd64\BRH4040N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr006.inf_amd64_neutral_f156853def526447\Amd64\BRM867DN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr008.inf_amd64_neutral_0540370b0b1e348e\prnbr008.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr008.inf_amd64_neutral_0540370b0b1e348e\prnbr008.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr008.inf_amd64_neutral_0540370b0b1e348e\prnbr008.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr008.inf_amd64_neutral_0540370b0b1e348e\Amd64\BRCL05.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr007.inf_amd64_neutral_add2acf1d573aef0\Amd64\BRD9045D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr007.inf_amd64_neutral_add2acf1d573aef0\Amd64\BRH405DN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\prnbr009.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr007.inf_amd64_neutral_add2acf1d573aef0\Amd64\BRM9440N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr007.inf_amd64_neutral_add2acf1d573aef0\Amd64\BRM9640W.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\prnbr009.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr007.inf_amd64_neutral_add2acf1d573aef0\Amd64\BRH407DW.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr008.inf_amd64_neutral_0540370b0b1e348e\Amd64\BRCLUI05.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\prnbr009.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\brci14a.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr007.inf_amd64_neutral_add2acf1d573aef0\Amd64\BRM945DN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\brio14aa.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\BRCI14A.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\brio14ac.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr008.inf_amd64_neutral_0540370b0b1e348e\Amd64\BRM942CN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\brio14ab.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr008.inf_amd64_neutral_0540370b0b1e348e\Amd64\BRCLRD05.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\brio14ad.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\brio14af.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\brio14ag.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\brio14ah.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\brio14ak.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\brio14am.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr00a.inf_amd64_neutral_e7f3f91e6832ef5c\prnbr00a.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\BRD117C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\brio14ai.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\brio14an.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\brci14ui.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr00a.inf_amd64_neutral_e7f3f91e6832ef5c\prnbr00a.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\BRD116C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr00a.inf_amd64_neutral_e7f3f91e6832ef5c\prnbr00a.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\brio14al.bcm - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr00a.inf_amd64_neutral_e7f3f91e6832ef5c\Amd64\BRMZ13.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr007.inf_amd64_neutral_add2acf1d573aef0\Amd64\BRM984DW.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca003.inf_amd64_neutral_8e91d4aa9330d2f8\prnca003.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca003.inf_amd64_neutral_8e91d4aa9330d2f8\prnca003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca003.inf_amd64_neutral_8e91d4aa9330d2f8\prnca003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca003.inf_amd64_neutral_8e91d4aa9330d2f8\Amd64\CNN0B007.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr007.inf_amd64_neutral_add2acf1d573aef0\Amd64\BRCLRD06.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr00a.inf_amd64_neutral_e7f3f91e6832ef5c\Amd64\brmzrd13.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr00a.inf_amd64_neutral_e7f3f91e6832ef5c\Amd64\brmzui13.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr00a.inf_amd64_neutral_e7f3f91e6832ef5c\Amd64\BRHBP13.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca003.inf_amd64_neutral_8e91d4aa9330d2f8\Amd64\CNN0B007.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr009.inf_amd64_neutral_fd2ac5b9c40bd465\Amd64\brci14a.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\prnca005.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\prnca005.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca003.inf_amd64_neutral_8e91d4aa9330d2f8\Amd64\CNN0BMC1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca003.inf_amd64_neutral_8e91d4aa9330d2f8\Amd64\CNN0BME1.GPD - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB1000.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca003.inf_amd64_neutral_8e91d4aa9330d2f8\Amd64\CNN0BSB1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnbr00a.inf_amd64_neutral_e7f3f91e6832ef5c\Amd64\BRM8640D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca003.inf_amd64_neutral_8e91d4aa9330d2f8\Amd64\CNN0BSB2.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB1000.DLL - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB1000S.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\prnca005.cat - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB2000.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB1000S.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB1000S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB2000.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB1000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca003.inf_amd64_neutral_8e91d4aa9330d2f8\Amd64\CNN0BSC2.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB2000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB2000S.GPD - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB2000S.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB2100.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB2000S.DLL - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB2100S.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca003.inf_amd64_neutral_8e91d4aa9330d2f8\Amd64\CNN0B007.GPD - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB240.DLL - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB2100.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB240.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB2100S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB25GE3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB2100.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca003.inf_amd64_neutral_8e91d4aa9330d2f8\Amd64\CNN0BSC1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB2100S.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB25HE3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB25FE3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB25HP3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB265SP.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca003.inf_amd64_neutral_8e91d4aa9330d2f8\Amd64\CNN0BMB1.GPD - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB265SP.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB25HF3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB240.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB3000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB265SP.DLL - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB4300.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB25PE3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB25PF3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB4300.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43BEA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43BE3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43FE3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB25FF3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43FF3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43FD3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43GD3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43GE3.ICM - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB3000.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB25GF3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43GF3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB25GP3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB3000.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43HEA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43FEA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43FFA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43HE3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43GEA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43HD3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43HS3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43GP3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43GFA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43GS3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43PF3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43PE3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB4300.GPD - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB4400.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43PS3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB4400.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43PP3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43HFA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43PFA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43HP3.ICM - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB4650.DLL - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB50.DLL - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB55.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB4650.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43PD3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB50.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB55.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB55.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43PEA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB6000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB4400.GPD - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB6000.DLL - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB6100.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB6000.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB6100.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB6100.DLL - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB6500.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB6500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB6200.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB6500.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB7100.GPD - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB80.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB43HF3.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB4650.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB8000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB80.DLL - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB6200.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJ.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB5500.GPD - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB85.DLL - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB7100.DLL - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB8000.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB6200.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB85.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJ0650.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJ2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB8000.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB7100.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJ0670.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJ0690.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB85.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB80.GPD - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB5500.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJGRC2.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB5500.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNB50.GPD - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJMON.DLL - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJDRV.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJPR18.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJPR14.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJDRV.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJDRC.DLL - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJDRV2.DLL - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBO59.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBO59.DLL - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBO64.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJDRV2.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJGRC.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBO64.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBPGR02.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBPGR01.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJ0760.TBL - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJUI2.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBS400.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJ0600.TBL - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJMON2.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBPGR08.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBS400S.GPD - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBS450.DLL - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBS400.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBS450.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBPGR05.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBS400.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBSTD.ICM - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBS4500.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBVM.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBS4500.DLL - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBOSTD.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\prnca00a.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBOSTD.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\prnca00a.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBS4500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\prnca00a.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBS450.GPD - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJUI.DLL - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBS400S.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNBBR319.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNBBR325.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBS400S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNBBR326.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBPGR03.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNBBR327.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNBBR328.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNBJ3260.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNBJ3250.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNBJ3190.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNBJOP8V.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNBJOP91.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNBJOP92.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJMON.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNBP_327.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNB_0319.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNB_0325.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNB_0319.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNB_0325.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNBP_326.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNB_0326.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNB_0327.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNB_0326.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNB_0327.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNB_0328.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNB_0329.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\prnca00b.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\prnca00b.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\prnca00b.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNB_0328.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNB_0329.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB9BCAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB9BCBA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB9BCCA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB9BDBA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNBP_328.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB9BHBA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB9BJBA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB9BMBA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNBP_319.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBBR303.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJUI.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB9BMCA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB9BNBA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNBP_329.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB9BNCA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBJ3090.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBJ3030.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBBR331.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBBR332.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBBR309.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBJ3310.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBJ3420.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBJ3460.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBJ3320.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00a.inf_amd64_neutral_d64d696193e69d7b\Amd64\CNBP_325.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBBR342.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJUI2.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBJOP8L.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBBR335.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBJOP9B.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBBR346.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBJOP8F.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBJOP9I.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBJ3350.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBJOP98.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca005.inf_amd64_neutral_179dd80b276be15d\Amd64\CNBJMON2.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBJOP97.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBJOP9M.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB_0303.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB_0309.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB_0309.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB_0303.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBP_335.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB_0331.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBP_331.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB_0332.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB_0335.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB_0331.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB_0332.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB_0335.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\prnca00c.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB_0342.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB_0346.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBP_303.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\prnca00c.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\prnca00c.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBP_346.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB_0342.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNB_0346.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBBR315.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBP_342.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBBR318.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBBR316.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBBR320.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBJ3200.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBBR323.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBP_332.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBJ3180.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBMR284.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBJOP8W.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBJ3150.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBJ3160.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBP_317.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBP_324.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNB_0315.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNB_0315.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBP_318.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBP_316.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNB_0316.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNB_0317.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBP_321.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNB_0317.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNB_0316.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNB_0318.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBJOP8S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBJOP7I.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNB_0318.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00b.inf_amd64_neutral_4412894f52d39895\Amd64\CNBP_309.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNB_0320.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNB_0321.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNB_0320.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBP_320.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\prnca00d.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\prnca00d.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\prnca00d.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNB_0323.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBP_315.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNB_0321.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNB_0323.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNB_0324.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBBR285.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBBR311.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBBR289.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBBR284.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBJ2840.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBBR310.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBBR312.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBBR290.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBJOP7I.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNBP_323.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBJ3120.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBJ2910.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00c.inf_amd64_neutral_510c36849918ce92\Amd64\CNB_0324.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBJ2850.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBJ3100.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBJOP7W.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBJOP8M.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBJOP8N.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBMR284.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBP_289.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNB_0284.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBP_311.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNB_0284.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBP_312.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBP_290.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNB_0285.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNB_0285.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBP_291.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNB_0289.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNB_0290.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBP_284.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNB_0291.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNB_0310.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNB_0289.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNB_0311.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBP_310.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\prnca00e.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNB_0310.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\prnca00e.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNB_0290.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNB_0291.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\prnca00e.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBP_285.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNB_0312.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNB_0311.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNBJ2970.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNB_0312.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNBJ3000.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNBBR294.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNBJOP89.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNBJOP86.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNBJ2940.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNBBR297.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNBBR300.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNBJOP8B.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNB_0294.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNB_0295.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNB_0296.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNB_0294.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNB_0295.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNB_0296.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNB_0297.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNB_0298.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBMR310.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNB_0297.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNB_0298.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\prnca00f.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNB_0300.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\prnca00f.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\prnca00f.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00d.inf_amd64_neutral_0600b2ba575729f4\Amd64\CNBMR285.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNB_0300.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNBP_294.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBBR280.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBBR276.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBBR283.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBJ2600.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNBP_295.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBBR274.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBJ2610.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNBP_298.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBBR292.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNBP_300.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBJ2760.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBJ2920.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBBR293.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBJOP79.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBJOP7E.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBJOP78.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBJOP84.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBJ2800.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBJOP7S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBBR273.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBP_274.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNB_0274.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBP_276.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNB_0275.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBP_283.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBP_280.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNB_0276.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNB_0279.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNB_0275.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNB_0276.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNB_0274.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNB_0280.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00e.inf_amd64_neutral_651eeed98428be5e\Amd64\CNBP_297.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNB_0280.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNB_0292.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNB_0283.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNB_0279.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\prnca00g.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNB_0293.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\prnca00g.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBP_279.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7TDAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\prnca00g.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNB_0292.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNB_0283.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNB_0293.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7TKCA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7TECA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7THAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7TJAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7TIAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7TLAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBP_292.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7TEAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7TKAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00f.inf_amd64_neutral_777b6911d18869b7\Amd64\CNBP_293.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7TMAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7TMCA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7TNAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7UCBA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7UCAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7UDAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7UHAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7UECA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7UEAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7UEDA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7UIAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7UJAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7UCCA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7ULAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7UNAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7UMAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7UKAA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7UMCA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7UKCA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNBJ2810.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB7UNBA.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNBBR282.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNBBR281.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNBX4.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNBJ2820.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNBX4PIPELINECONFIG.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNBX0281.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNBX0281.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNBX0282.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNBJOP7T.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNBX0282.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB_0281.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNBJOP7U.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\prnca00h.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\prnca00h.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\prnca00h.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB_0281.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB_0282.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNBJ2860.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNB_0282.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNBBR286.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNBBR301.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNBBR288.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNBJ3020.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNBBR302.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNBP_282.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNBXLF4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNBJ3010.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNBJ2880.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNBJOP7D.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNBJOP7B.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNBJOP7F.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNBJOP8E.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNB_0286.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNBP_281.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNB_0287.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNB_0286.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNB_0288.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNBXRF4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNB_0287.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNB_0288.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNB_0301.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNBP_301.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\prnca00i.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNB_0302.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNB_0302.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNB_0301.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\prnca00i.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\prnca00i.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNBP_286.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNBJ3340.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNBJ3410.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00g.inf_amd64_neutral_6f76b14b2912fa55\Amd64\CNBXUI4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNBJOP99.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNBJ3330.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNBJOP9A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNBP_302.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNBP_287.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00h.inf_amd64_neutral_96a8e38189e54d71\Amd64\CNBP_288.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNBP_336.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNBBR333.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNBBR334.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNBBR339.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNBP_338.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNB_0333.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNBP_339.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNB_0334.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNBP_337.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNB_0333.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNB_0334.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNB_0336.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNB_0337.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNB_0338.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNB_0339.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNB_0336.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNB_0337.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNB_0338.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNB_0340.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNB_0339.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\prnca00x.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\prnca00x.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNB_0341.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNB_0340.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\prnca00x.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBBLP1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBBLP2.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBCMN1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBBLP3.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBCOL1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNBP_333.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNBP_334.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNB_0341.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNBJOP9F.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBDUP3.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBDUP4.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBDUP1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBEFF1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBDUP2.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBCOL2.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBCOL3.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBEFF2.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBEFF4.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBJ3.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBEFF3.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBGRC1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBP0.DAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBFUS.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBP1.DAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNBP_340.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBP2.DAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBLH.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00i.inf_amd64_neutral_09ff5ee0a0cf0233\Amd64\CNBP_341.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBLM3_2.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBLM3_1.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBLM3_3.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBSD3.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBPP3.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBSQ3.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBDR3_5.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBPV3.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBSTP1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00y.inf_amd64_neutral_64560c72e81f6ad7\prnca00y.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBSM3.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBSS3.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00y.inf_amd64_neutral_64560c72e81f6ad7\prnca00y.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBPCOMM.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00y.inf_amd64_neutral_64560c72e81f6ad7\prnca00y.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00y.inf_amd64_neutral_64560c72e81f6ad7\Amd64\CNBJPR14.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00y.inf_amd64_neutral_64560c72e81f6ad7\Amd64\CNBJPR18.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00y.inf_amd64_neutral_64560c72e81f6ad7\Amd64\CNBJPR22.ICM - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\prnca00z.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\prnca00z.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBCMN41.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBBLP41.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\prnca00z.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBDUP41.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBDUP42.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBDUP43.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBE4_0.DAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBEFF42.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBDUP44.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBGRC41.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBEI4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBIC4_1.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBIC4_2.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBUI3.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBDR4_5.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBWI3.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBIC4_3.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBIC4_4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBJ4.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBIC4_5.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBFUS4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBLR.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBIC4_8.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBIC4_6.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBLH4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBP40.DAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBIC4_7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBP41.DAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBLM4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBP42.DAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBPRT2.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBPRT1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBLH4_2.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBSD4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBPP4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBPC4_1.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBSQ4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBPV4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep002.inf_amd64_neutral_efc4a7485b172c07\PRNEP002.CAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep002.inf_amd64_neutral_efc4a7485b172c07\prnep002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep002.inf_amd64_neutral_efc4a7485b172c07\prnep002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBSS4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBSR.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep002.inf_amd64_neutral_efc4a7485b172c07\Amd64\EP0SBT00.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep002.inf_amd64_neutral_efc4a7485b172c07\Amd64\EP0SBW00.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\PRNEP003.CAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBSM4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\prnep003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\prnep003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep002.inf_amd64_neutral_efc4a7485b172c07\Amd64\EP0SLM01.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep002.inf_amd64_neutral_efc4a7485b172c07\Amd64\EP0SLP01.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0LB010.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0LB01A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0LB020.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0LB02A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0LB01B.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0LB030.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0LB030.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBWI4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0LB020.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0LB010.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBUI4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0LB040.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0LB040.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0LB03F.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB010.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0LB03A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0LB04A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB01B.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB01A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB030.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB03A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0LB03B.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB040.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBPC4_2.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB050.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB04A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0LB03E.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB070.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBSR4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB05A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB070.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB050.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB040.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB07A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\PRNEP004.CAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\prnep004.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\prnep004.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB020.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB010.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL00.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL02.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB090.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL01.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL03.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep003.inf_amd64_neutral_92ed2d842e0dd4ea\Amd64\EP0NB080.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL04.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL05.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL02.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL0K.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL0L.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBLR4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL00.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL01.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL0M.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL0N.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL0O.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL03.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL04.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL05.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL0P.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL0L.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL0K.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL0M.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL0Y.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL0N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL0X.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL0O.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL13.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL15.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL0P.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL11.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL16.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL10.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL12.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7PII00.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep005.inf_amd64_neutral_f2fbc5759618d8fb\PRNEP005.CAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep005.inf_amd64_neutral_f2fbc5759618d8fb\prnep005.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep005.inf_amd64_neutral_f2fbc5759618d8fb\prnep005.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL14.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\prnep00a.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7RES00.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL0Z.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\prnep00a.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NCAUM.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NDC66.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NDC67.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\prnep00A.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL18.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7MDL17.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NAR00.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep005.inf_amd64_neutral_f2fbc5759618d8fb\Amd64\EP7RDP00.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NGX00.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7RES01.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep004.inf_amd64_neutral_63b22bfb6b93eaba\Amd64\EP7UIP00.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NGWUM.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NH431.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NH43R.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NDW00.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NH433.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NHF34.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00x.inf_amd64_neutral_eb0842aa932d01ee\Amd64\CNBUR.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NIP46.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NGXUM.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NIP47.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NLMUI.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NM400.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NM4RE.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NPP01.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NO000.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NS411.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NS421.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NOE03.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NOE04.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NH44L.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\prnep00B.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NCA8G.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\prnep00b.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\prnep00b.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NSF11.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NCA8L.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NCA9A.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NCA9C.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NCA8M.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NCAUC.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NCAUK.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NCJ7F.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NGN00.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NRA8G.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NREUJ.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGE9C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGE8M.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGA9A.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGE8G.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGE8L.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGE6C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGE9B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGE8K.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGE9E.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGP8G.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGEUK.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGEUC.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGEUM.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGJ7J.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGEUH.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGE9H.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NGR00.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGP8K.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGPUL.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGPUD.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGP9H.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGP9E.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGP8L.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGP9A.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGP9B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGP9C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGPUT.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnca00z.inf_amd64_neutral_27f402ce616c3ebc\Amd64\CNBUR4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGWUC.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGN7F.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00a.inf_amd64_neutral_92a4c727cdf4c2f7\Amd64\EP0NUI60.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGX7C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGX7F.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGW9C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGW9A.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGW8G.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGW8M.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGW8L.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGW7C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGX8G.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGX8L.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NM4RI.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGX8M.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NM40J.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGX9A.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NM46A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGXUC.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOE6C.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NH434.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOE8K.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOE8L.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOE8G.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOE8M.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOEUC.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOE9H.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOE9E.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NGX9C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NMF6C.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOEUK.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOE9C.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOEUH.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOEUM.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOP8G.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOJ7J.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOP8K.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOP8L.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOP9E.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOE9B.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOA9A.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOP9A.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOP9H.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOP9B.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOP9C.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOPUD.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOPUL.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOPUT.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\prnep00C.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NCA8T.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\prnep00c.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NCJ8T.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\prnep00c.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NGE6A.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOE14.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NGE8T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NGE6V.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NGEUY.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NGE6F.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NGE6B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NGEZZ.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NRE9C.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NGP8T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NGP8W.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NGP6W.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NGP7Z.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NGJ7E.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NGJ6A.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NOE6A.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NOE6B.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NOE6F.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NOE6V.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NOE8T.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NOEUY.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NOEZZ.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NOJ6A.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NOJ7E.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NOP6W.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NOE18.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NOP7Z.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NOP8T.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NM4R0.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NOP8W.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NGN8T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\prnep00d.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\prnep00D.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NRE8L.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NCJ8H.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\prnep00d.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NRE9A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NCA8H.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NGW8T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00b.inf_amd64_neutral_2e6b718b2b177506\Amd64\EP0NRE8M.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NGX8T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NGJ9G.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NGE8F.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NGE8H.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NGJ9F.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NGA9F.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NGJ8H.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NGJ8F.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NGP8H.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NGP8F.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NOA9F.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NOE8F.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NOE8H.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NRE8T.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NOJ8F.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NOJ8H.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NOJ9F.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NOJ9G.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NOP8F.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NOP8H.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NM40F.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\prnep00e.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\prnep00E.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\prnep00e.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NCAAB.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NCJAB.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NCAAA.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NGAAB.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NGAAA.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NGEAA.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NGEAB.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NGN8H.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NOE17.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NOE12.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NRE8H.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NGPAB.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NGX8H.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NGJAB.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NGPAA.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NOAAA.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00c.inf_amd64_neutral_f0d9ddf52f04765c\Amd64\EP0NOE02.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NGWAA.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NGXAA.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NGXAB.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NOAAB.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NOEAB.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NGWAB.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NOJAB.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NOPAB.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NOPAA.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NOEAA.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NMF7A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NMF7B.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\prnep00f.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NO001.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\prnep00F.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\prnep00f.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NCA8C.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NCJ8C.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NGE8S.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NGP8S.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NGJ8C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NGP8C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NGE8C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NOE8C.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NREAA.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NOE8S.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NOJ8C.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NGNAB.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NOP8C.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NOP8S.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NOE20.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\prnep00G.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\prnep00g.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00e.inf_amd64_neutral_edc631ff41a34218\Amd64\EP0NREAB.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\prnep00g.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NM4RB.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NCA8D.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NCJ8D.CMB - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NGJ8D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NGL8R.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NGE8R.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NGE8D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NGP8D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NOE09.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NOE8D.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NOE8R.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NOJ8D.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NM4RC.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00d.inf_amd64_neutral_dd61103f3a2743d4\Amd64\EP0NGW8H.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NOL8R.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NOP8D.DXT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NGX8C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NGW8D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\prnep00l.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NGX8D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\prnep00l.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\prnep00L.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NGW8C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NGN8D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NGN8C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00f.inf_amd64_neutral_a5f6001b957bd7e0\Amd64\EP0NRE8C.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LIMM1.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVF00.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LLP00.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LPP00.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LPP01.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP12.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LIMC0.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP13.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP14.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LIMM2.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP11.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP17.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NOE10.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP18.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP16.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP15.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1A.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1E.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LUZ00.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1F.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP10.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1J.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1G.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1L.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1H.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1Q.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1I.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1M.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1P.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00g.inf_amd64_neutral_2926840e245f88f6\Amd64\EP0NRE8D.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1R.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1O.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1S.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1K.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1V.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1Y.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1X.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1U.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPA0.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LGX00.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPA1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPA3.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPA2.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVP1W.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPA4.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPA5.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPA6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPA7.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPA8.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPA9.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPAD.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPAE.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPAF.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPZ0.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LGR00.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPAH.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPAG.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPZ1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPZA.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPAB.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPAC.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPAA.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPAK.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR10.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR14.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR13.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR11.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR12.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR15.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR17.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR16.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1B.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1D.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR18.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1F.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1E.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1G.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPZA.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1L.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1J.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1C.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1K.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1O.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1N.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1I.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1M.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1H.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1Q.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1P.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVPZ0.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1V.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1U.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1T.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1R.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRA0.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRA1.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1W.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRA2.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1X.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRA3.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRAA.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRA4.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRA5.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRA7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRAB.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRA8.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRAD.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRA9.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRAF.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnfx002.inf_amd64_neutral_b6dd354531184f64\prnfx002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRAE.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRAG.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVR1Y.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRAH.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnfx002.inf_amd64_neutral_b6dd354531184f64\prnfx002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRAC.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnfx002.inf_amd64_neutral_b6dd354531184f64\PRNFx002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnfx002.inf_amd64_neutral_b6dd354531184f64\Amd64\FXUCCM01.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnfx002.inf_amd64_neutral_b6dd354531184f64\Amd64\FXUCSR01.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnfx002.inf_amd64_neutral_b6dd354531184f64\Amd64\FXUCSR04.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnfx002.inf_amd64_neutral_b6dd354531184f64\Amd64\FXUCSR05.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnfx002.inf_amd64_neutral_b6dd354531184f64\Amd64\FXUCSR02.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnfx002.inf_amd64_neutral_b6dd354531184f64\Amd64\FXUCSR06.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnfx002.inf_amd64_neutral_b6dd354531184f64\Amd64\FXUCCM01.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnfx002.inf_amd64_neutral_b6dd354531184f64\Amd64\FXUCSR03.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnge001.inf_amd64_neutral_cfffa4143b3c4592\prnge001.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnge001.inf_amd64_neutral_cfffa4143b3c4592\prnge001.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnge001.inf_amd64_neutral_cfffa4143b3c4592\prnge001.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRAK.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnfx002.inf_amd64_neutral_b6dd354531184f64\Amd64\FXUCYP04.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnfx002.inf_amd64_neutral_b6dd354531184f64\Amd64\FXUCYP03.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnfx002.inf_amd64_neutral_b6dd354531184f64\Amd64\FXUCYP01.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnfx002.inf_amd64_neutral_b6dd354531184f64\Amd64\FXUCYP05.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnge001.inf_amd64_neutral_cfffa4143b3c4592\Amd64\MSGENCOL.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnge001.inf_amd64_neutral_cfffa4143b3c4592\Amd64\TTY.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnge001.inf_amd64_neutral_cfffa4143b3c4592\Amd64\GENIBM9.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnge001.inf_amd64_neutral_cfffa4143b3c4592\Amd64\MSGENBW.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnfx002.inf_amd64_neutral_b6dd354531184f64\Amd64\FXUCYP02.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnep00l.inf_amd64_neutral_f1fa021d2221e2c7\Amd64\EP0LVRA6.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnge001.inf_amd64_neutral_cfffa4143b3c4592\Amd64\TTYUI.HLP - Ok
C:\Windows\system32\DriverStore\FileRepository\prnfx002.inf_amd64_neutral_b6dd354531184f64\Amd64\FXUCU001.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\prngt002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnge001.inf_amd64_neutral_cfffa4143b3c4592\Amd64\TTY.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnge001.inf_amd64_neutral_cfffa4143b3c4592\Amd64\TTY.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\prngt002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS1100.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS1350.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS2000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS161.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\prngt002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS1600.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS2510.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnge001.inf_amd64_neutral_cfffa4143b3c4592\Amd64\GENIBM9W.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS2500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS2550.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS3350.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS2550B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS3010.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS4000B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS4000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS3350B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS4500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS5000B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS5500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS5000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS3500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS6000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS7031NL.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS6500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS7035N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS7031N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnge001.inf_amd64_neutral_cfffa4143b3c4592\Amd64\TTYRES.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnge001.inf_amd64_neutral_cfffa4143b3c4592\Amd64\OK9IBRES.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS8200.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS7500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS8000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS7675.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GSC1500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS9000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GSC2000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GSC2500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GSC3000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GSC3500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GSC420D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GSC6000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GSC7500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GSC7531D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GSC7526D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GSC4500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GSC7640D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\prngt003.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnge001.inf_amd64_neutral_cfffa4143b3c4592\Amd64\TTYUI.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS11006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS13506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS20006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\prngt003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS7000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS16006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\prngt003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS25106.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS1616.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS25006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt002.inf_amd64_neutral_df2060d80de9ff13\Amd64\GS7245.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS30106.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS2550B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS25506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS33506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS35006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS3350B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS4000B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS40006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS45006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS50006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS60006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS65006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS55006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS5000B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS70006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS7035N6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS7031N6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS82006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS703NL6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS80006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS90006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS75006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS76756.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GS72456.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GSC20006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GSC420D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GSC15006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GSC25006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GSC45006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GSC35006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GSC30006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GSC60006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GSC75266.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GSC75316.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GSC764D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt003.inf_amd64_neutral_8c9aae54a5673a35\Amd64\GSC75006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\prngt004.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\prngt004.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GE1312E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GED71103.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\prngt004.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GE1311E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GED71353.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1321E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GEDS7903.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GEMPC203.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1332E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GEMPC253.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1303E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GEMPC303.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1341E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1371E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1331E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1301E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1391E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1342E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1302E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1392E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1402E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1403E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1393E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1401E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1404E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1431E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1394E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS2171E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS2193E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS2191E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1432E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS2192E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS3172E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS2221E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS2161E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS3191E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS3202E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS3201E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS4171E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS1433E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS4172E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\PRNHP002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS4181E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\prnhp002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS3171E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\prnhp002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC1RWSL.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPBMINI.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC1RXSL.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPBOID.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPBPROPS.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC3050F.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPBMIAPI.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC3052F.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC1RWSL.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC3055F.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC3050F.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC3390F.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prngt004.inf_amd64_neutral_f5bf8a7ba9dfff55\Amd64\GS4221E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC5200F.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC5201F.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC3055F.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC1RXSL.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC3052F.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC3390F.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC5201F.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPBPRO.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPEACLHN.HPI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPBOIDPS.DLL - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC9500S.GPD is MAIL container
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC9500S.GPD - mail
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC520XF.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPF0450T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpf69000.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPDJ5550.CFG - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPF4A63L.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpf69001.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC5200F.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPF4BK3L.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPC9500S.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpf69002.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpf69005.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpf69003.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPF6940T.XML - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPCDMCLH.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPF6980T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPIJ2280.CFG - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPFRES50.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPLJ9500.CFG - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpf69004.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPMCPAP6.CFG - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPFIME50.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpmcpap6.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPMCPBP6.CFG - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpmcpap6.gpd is MAIL container
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpmcpap6.gpd - mail
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpmcpbp6.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPLJ2300.CFG - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpmcpbp6.gpd is MAIL container
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpmcpbp6.gpd - mail
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpmcpcp6.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPMCPCP6.CFG - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPMCPDP5.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPMCPD25.CFG - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPCDMCLH.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPMCPD25.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpmcpdp6.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPMCPDPS.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPMCPDP6.CFG - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpmcpcp6.gpd is MAIL container
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpmcpcp6.gpd - mail
>C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpmcpdp6.gpd is MAIL container
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpmcpdp6.gpd - mail
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO0410T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPF0450T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPF4A63L.GPD - Ok
>C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPMCPM25.GPD is MAIL container
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPMCPM25.GPD - mail
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO1500T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO1600T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPF4BK3L.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO2600T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO2700T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO3100T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO2700T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO3200T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO2600T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPFIGLHN.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO3100T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO3300T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO1600T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO3200T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPF6940T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO4300T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO3300T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO4PG3L.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO5600T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPF6980T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO5H83L.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpo63001.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpo63000.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpo63003.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpo63002.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpo63004.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO6200T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\hpo63005.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO6200T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO6300T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO7200T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO7300T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO7200T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO5600T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO4300T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO7400T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO7300T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO4PG3L.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO0410T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPOGDS3L.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO7400T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO5H83L.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPOF300T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO3X00T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPOJ1600.CFG - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPOJ6200.CFG - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPOJ7300.CFG - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO6300T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPOJ7200.CFG - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPOJ2700.CFG - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPP8100T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPOJ2600.CFG - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPP8100T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPP8200T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPP8400T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPOJ7400.CFG - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO6X00T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPP8700T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPPH1500.EXP - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPP8700T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPPH3100.EXP - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPPH3200.EXP - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPPH8100.EXP - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPPH8400.EXP - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPP8400T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPPH3300.EXP - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPW0460T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPW0460T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPPH8200.EXP - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPW1000T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPOF300T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPW1200T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO1500T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPOGDS3L.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPW1B83L.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPW1QI3L.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPW1RC3L.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPW1200T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPW9800T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPWH0460.CFG - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPO7X00T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPW9800T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPWK550T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPWH9800.CFG - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZ3Cwn7.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPWK850T.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPP8X00T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZ3LWN7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPP8200T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZ5CWN7.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZ6CWN7.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZ3Mwn7.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZ6MWN7.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPW1B83L.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPW1QI3L.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZ3Awn7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZFNWN7.NTF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZ5RWN7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZINW12.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZIPM12.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZIDR12.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZIPT12.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZISN12.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPWK550T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZEVWN7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZIPR12.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZ3Rwn7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPW1000T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZSCWN7.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZSCWN7.DTD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZLLWN7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZ6RWN7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPWK850T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZSMWN7.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\prnhp003.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZPPWN7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPW1RC3L.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZPRwn7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpadbrgb.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\prnhp003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZSRWN7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpah470t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\prnhp003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZLEwn7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpb8300t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpah470t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZLAwn7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpb8300t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpbselio.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZLSWN7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZUIWN7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZSSWN7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc3100t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc3100t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpah470t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpbsbasi.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpbscarr.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc3100t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc4200t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc4100t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpbscham.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc4100t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc4300t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc4200t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc4200t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc4100t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc4300t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc4340t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpbsodys.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc4400t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc5100t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc4340t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc4400t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpbsdash.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc5100t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc5200t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc5100t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpbsnewm.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc6100t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc4340t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc6200t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc4400t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc6100t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpb8300t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc6100t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc5200t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc7100t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc6200t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc7100t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc7200t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc6200t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc7200t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc8100t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd1360t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc7100t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc7200t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc4300t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd1400t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc8100t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc8100t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd1360t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd1500t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpcdmc71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd1500t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd2360t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd1400t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd1500t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd1360t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd2360t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd2400t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpbserho.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd2360t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpc5200t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd2500t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd2500t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd4100t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd2400t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd2400t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd4200t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd2500t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd4200t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd4300t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd4300t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd5060t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd1400t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd4100t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd4100t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd4200t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd5100t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd5300t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd4300t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd6100t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd5060t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd6100t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd7100t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd6100t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd5300t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd7200t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd7100t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpCommon.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd7100t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd7200t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd7300t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd5100t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd7400t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd7300t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpf2100t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd5060t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd7400t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd7200t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd7400t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd7300t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpf2100t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd5100t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpf4100t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpf4200t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpf2100t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpf4100t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpf2200t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpf2200t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpf2200t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpfclw71.rpo - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpf4200t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpfcnw71.rpo - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpf4100t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpd5300t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hphp910t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpf4200t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpfrsw71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpfspw71.rpo - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hphp915t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj3500t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpfstw71.rpo - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hphp910t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj3600t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hphp910t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hphp915t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpfigw71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hphp915t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj3600t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj4500t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpfiew71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj4660t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj4660t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj3600t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj4500t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj4680t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj5500t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj4500t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj5500t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj5700t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj4660t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj4680t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj4680t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj3500t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj5500t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj6400t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpk5300t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj5700t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpk5400t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpk5300t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpk5400t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj6400t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpk8600t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpk7100t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpl7300t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpk5300t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj5700t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpl7400t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpl7300t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpk5400t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj6400t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpk8600t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpl7500t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpl7600t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpl7400t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpl7600t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpl7300t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpl7500t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpl7700t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24\Amd64\HPZSTWN7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpl7400t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpl7500t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpl7600t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpn5150t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa310t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpl7700t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa320t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpk8600t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa310t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa430t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa320t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpk7100t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpn5150t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa440t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpl7700t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa430t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa510t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa440t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa510t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa520t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa610t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpj3500t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa430t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa310t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa620t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa510t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa620t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa520t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa710t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa710t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa820t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa610t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpQ307w7.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa610t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa820t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpsd730t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpk7100t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa710t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hptf735t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpsd730t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hptf735t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa320t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hptf735t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpz3lw71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpsd730t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpz3mw71.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa520t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpn5150t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpzc3w71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa620t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpzllw71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\HPZEVW71.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpzppw71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpzscw71.dtd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpz3cw71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpzsmw71.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpzlew71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa440t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\PRNHP004.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\prnhp004.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\prnhp004.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpz3rw71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\HPadbrgb.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpoa820t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpb8500t.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpzlaw71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpb8500t.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpb8500t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpzprw71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpzsew71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc4500t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpb8500t.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc4500t.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc4500t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc4500t.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpzssw71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc5300t.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc4500t.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc5300t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc5300t.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc4500t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc5300t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc5500t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc5500t.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpb8500t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc5500t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc5300t.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc6300t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpb8500t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc5500t.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc6300t.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc6300t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc6300t.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpD5400t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpD5400t.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\HPZUIW71.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc5300t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc5500t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc6300t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpD5400t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpD5400t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpD5400t.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpd7500t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpd7500t.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc5500t.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpd7500t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpd7500t.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpfrsw71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpfst071.rpo - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpfigw71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpz3mw72.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpfiew71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpz3lw72.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpzpaw72.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\hpzurw71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpzscw72.dtd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpd7500t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpzsmw72.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpd7500t.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpzppw72.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpzpaw72.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpc6300t.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\PRNHP005.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\prnhp005.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\prnhp005.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpD5400t.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpzevw72.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp309apm.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpzprw72.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp309ppm.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp309ppb.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp309ppp.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpzvuw72.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6000aa.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6000at.cfg - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp309apb.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6000at.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6000na.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6000nt.cfg - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6000nt.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpzuiw72.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6000nt.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6500aa.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6500at.cfg - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6000at.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6000at.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6500at.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6500at.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6500na.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6500nt.cfg - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpz3rw72.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6500nt.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6500nt.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8000aa.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8000at.cfg - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6000nt.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6000at.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8000at.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8000at.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6500at.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500aa.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500at.cfg - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpzstw72.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6500nt.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6500nt.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500at.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500at.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500ga.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500gt.cfg - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8000at.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8000at.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500gt.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500na.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500nt.cfg - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6000nt.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp6500at.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500gt.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpadbrgb.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500nt.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpc309aa.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500nt.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500at.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpc309at.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpc309at.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpc309at.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpc4600a.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpc4600t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500nt.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500gt.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpc309at.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpc4600t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpc4600t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500gt.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpd2600a.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpd2600t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpc309at.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpc4600t.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpd2600t.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500nt.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpd2600t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\HPCDMC71.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpf4400a.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpf3lw73.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpf3mw73.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpf4400t.exp - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpf4400t.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpf4400t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpd2600t.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpf4400t.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hp8500at.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpc4600t.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpfpaw73.vdf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpfiew73.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpfllw73.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpfevw73.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpfigw73.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpd2600t.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpfscw73.dtd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpfpaw73.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpfsmw73.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpfppw73.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpfrsw73.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\prnin002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpfprw73.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\prnin002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpfvp6en.rpo - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\prnin002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpf4400t.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF2255.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp004.inf_amd64_neutral_53f688945cfc24cc\Amd64\hpzurw72.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF2316.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF2320.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF2265.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF2275.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF2416.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF2325.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF2425.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF2430.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF2550.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF2445.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF2435.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF2550B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF3090.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpfvuw73.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF3350.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF3110.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF4000B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF5000B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF3135.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF5000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF3350B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF6000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF8000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF7000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IF4000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IFC2020.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IFC3030.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IFC4040D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IFC6000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IFC615G.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IFC7500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IFCP2525.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IFCS2525.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IFCP3030.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IFCS3535.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin002.inf_amd64_neutral_977d40799168c216\Amd64\IFCS4045.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\prnin003.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF22556.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF22656.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\prnin003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\prnin003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF22756.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpfvew73.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF23206.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF23166.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF23256.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF24166.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF24306.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF24256.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF24356.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF25506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF2550B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF31106.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF30906.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpf3rw73.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF33506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF3350B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF40006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF31356.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF4000B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF60006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF5000B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF50006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF70006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IFC30306.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF80006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IFC404D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IFC615G6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IFC60006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IF24456.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IFC75006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IFCP2526.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IFCP3036.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IFCS2526.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IFCS3536.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IFCS4046.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\prnin004.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin003.inf_amd64_neutral_3a3c6293d0cda862\Amd64\IFC20206.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\prnin004.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\prnin004.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1321E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1301E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1302E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1303E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1341E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1332E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1392E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1371E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1393E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1391E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1331E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1342E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1394E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1401E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1402E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1403E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1404E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1432E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1431E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp003.inf_amd64_neutral_4480210763997eb4\Amd64\HPZSTW71.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF1433E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF3171E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF3191E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpfuiw73.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF3201E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF3172E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF4172E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IN1312E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IN1311E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\INI30903.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\INI31103.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\INI31353.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\INISC203.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF4181E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF4171E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\prnkm002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\prnkm002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\prnkm002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\IF3202E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnhp005.inf_amd64_neutral_914d6c300207814f\Amd64\hpfstw73.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KO25509P.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KO4650PU.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\INISC253.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KO40PPU.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KO501U.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnin004.inf_amd64_neutral_c8902ae660ab1360\Amd64\INISC303.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KO360U.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KO5650PU.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KO5550PU.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KO8650U.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KO5570PU.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KO5670PU.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\prnkm003.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\prnkm003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\prnkm003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\KOC353X.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KOC10PNP.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KOC252U.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KOC20PPU.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KOC31PPU.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KOC30PPU.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\KOC451X.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\KOC650X.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\koc650X.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\koc451X.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\KOM4650X.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\kom4650X.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\KOC451X.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KOC451U.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\KOP4650X.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\KOP5650X.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\KOM4650X.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\KOC353X.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\kop4650X.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\KOC650X.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\kop5650X.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm004.inf_amd64_neutral_d2aee42dc9c393ea\prnkm004.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm004.inf_amd64_neutral_d2aee42dc9c393ea\prnkm004.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\koc353X.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\KOP4650X.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm005.inf_amd64_neutral_c03c9e328608873e\prnkm005.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm004.inf_amd64_neutral_d2aee42dc9c393ea\Amd64\KOC200U.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm004.inf_amd64_neutral_d2aee42dc9c393ea\prnkm004.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm005.inf_amd64_neutral_c03c9e328608873e\prnkm005.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KOC353U.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\KOP5650X.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm003.inf_amd64_neutral_48652cda3bb15180\Amd64\KO0C0001.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm004.inf_amd64_neutral_d2aee42dc9c393ea\Amd64\KOM4695U.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm005.inf_amd64_neutral_c03c9e328608873e\prnkm005.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\PRNKY002.CAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm004.inf_amd64_neutral_d2aee42dc9c393ea\Amd64\KOC20PU.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm002.inf_amd64_neutral_7c42808e24ebff99\Amd64\KOC650U.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\prnky002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\prnky002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm005.inf_amd64_neutral_c03c9e328608873e\Amd64\KOM1650U.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm005.inf_amd64_neutral_c03c9e328608873e\Amd64\KOP5650U.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm005.inf_amd64_neutral_c03c9e328608873e\Amd64\KOP4650U.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm005.inf_amd64_neutral_c03c9e328608873e\Amd64\KOM8460K.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm005.inf_amd64_neutral_c03c9e328608873e\Amd64\KO751U.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnkm005.inf_amd64_neutral_c03c9e328608873e\Amd64\KOM7460K.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYC2525E.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYCS3232.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYC3225E.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYC4035E.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYCS3225.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYC3232E.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYCS2520.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYEPC170.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYKC1100.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYEPC270.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYKC1030.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYEPC220.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYK2525E.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYK3232E.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYK4035E.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYK3225E.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYKC8100.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYKC5015.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYPS2525.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYPS5010.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYPS4000.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYPS8100.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYKC5025.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYEPC320.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\PRNKY003.CAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\prnky003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\prnky003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYKM2520.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYKM3225.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYW7AUTO.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYKM3232.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYKC5030.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYFS1118.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYFS37EP.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYFS2000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYFS4000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYFS3900.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYFS47EP.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYFS9130.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYKM2560.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky002.inf_amd64_neutral_525d9740c77e325f\Amd64\KYW7QURY.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYFS9530.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYKM3040.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYKM3050.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYKM3060.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYUD1118.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYUD1100.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYKM2540.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYUD2000.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYFS51EP.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYUD2560.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYKM5050.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYKM4050.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYUD37EP.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYUD3050.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYUD51EP.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\PRNKY004.CAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYUD9130.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\kyw7aut2.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYFS6950.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\prnky004.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\prnky004.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\KYFS1030.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYW7FRES.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\KYFS820.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYW7SRES.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\KYKM2050.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\KYFS920.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\KYKM1650.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\KYKM6030.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\KYKM2550.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\kyw7qur2.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\KYUD6030.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\KYKM8030.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\KYW7AUT4.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYFS1100.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\KYUD1030.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\KYUD5100.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky005.inf_amd64_neutral_8836be987024e6a9\PRNKY005.CAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky005.inf_amd64_neutral_8836be987024e6a9\prnky005.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky003.inf_amd64_neutral_fe7ea176f20ab839\Amd64\KYFS1300.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\kyw7fr03.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky005.inf_amd64_neutral_8836be987024e6a9\prnky005.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky005.inf_amd64_neutral_8836be987024e6a9\Amd64\KYPS4008.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky005.inf_amd64_neutral_8836be987024e6a9\Amd64\KYC5020N.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky005.inf_amd64_neutral_8836be987024e6a9\Amd64\KYW7AUT3.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\KYW7QUR4.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky005.inf_amd64_neutral_8836be987024e6a9\Amd64\KYPS5020.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\PRNKY006.CAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\kyw7sr02.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky005.inf_amd64_neutral_8836be987024e6a9\Amd64\KYK4008.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\prnky006.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\KYW7FR02.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\prnky006.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\Amd64\KYEP470D.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\Amd64\KYEP370D.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\Amd64\KYKC1300.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\Amd64\KYKC2000.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\Amd64\KYKC4000.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\Amd64\KYEP510D.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky005.inf_amd64_neutral_8836be987024e6a9\Amd64\KYW7QUR3.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\Amd64\KYKC5100.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\Amd64\KYKC5200.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\Amd64\KYKC3900.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky005.inf_amd64_neutral_8836be987024e6a9\Amd64\KYC4008.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\Amd64\KYKC5300.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\Amd64\KYPS1300.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\Amd64\KYPS400B.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\Amd64\KYPS9130.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\Amd64\KYPS5100.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\prnky007.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\PRNKY007.CAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\Amd64\KYW7AUT5.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\prnky007.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\Amd64\KYKC6950.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\Amd64\KYEPC170.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\Amd64\KYEPC220.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\Amd64\KYEPC270.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\Amd64\KYEPC320.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\KYFS5100.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\Amd64\KYFS5030.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\Amd64\KYUD5015.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\Amd64\KYFS8100.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\Amd64\KYUD8100.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\Amd64\KYUDC170.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\Amd64\KYFS5025.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\Amd64\KYFS5020.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\Amd64\KYW7AUT6.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\Amd64\KYUDC320.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\prnky008.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\PRNKY008.CAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\prnky008.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\Amd64\KYFS5015.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\KYFS5200.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYCS250c.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\Amd64\kyw7fr04.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYCS300c.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYCS400c.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky006.inf_amd64_neutral_522043c34551b0c0\Amd64\KYW7QUR5.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\Amd64\kyw7sr03.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYKC3920.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYKC1350.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYKC4020.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYCS500c.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky007.inf_amd64_neutral_e637699044f367f3\Amd64\KYW7QUR6.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYPS250.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYKC5400.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYPS51DN.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYPS4020.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYPS130B.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYW7AUT7.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYKC6970.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYKC2020.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\PRNKY009.CAT - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky004.inf_amd64_neutral_5db759db19acd3ae\Amd64\KYFS5300.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYTS250c.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\prnky009.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\prnky009.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYTS500c.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYTS400c.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYTS300c.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky008.inf_amd64_neutral_9f6abc54cbf095f2\Amd64\KYW7QUR7.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\KYUD1350.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\KYUD2020.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\KYUD250.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\KYFS1350.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\kyw7aut8.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\KYUD5400.GDL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\KYW7FRES.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\KYFS2020.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\prnle002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\KYFS3920.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\prnle002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR1100.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR131N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\KYW7SRES.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\prnle002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR131NL.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR1350.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR145N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\KYTAS400.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR150.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR136N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR161.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\KYFS6970.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\KYTAS300.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR2000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR2500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR2510.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR2550.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR2550B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR3010.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\kyw7qur8.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR3350.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR3350B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR3500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR4000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR4000B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR4110N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR1600.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR4500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR4100N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR5000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR5000B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR6500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR6000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR5500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR7000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR8000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR9000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\KYTAS500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR9100.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LR7500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LRC1500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LRC226C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LRC2000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LRC231C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LRC2500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LRC331CN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LRC3000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LRC3500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LRC400D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LRC440C.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LRC6000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LRC4500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle002.inf_amd64_neutral_c7564163ba063094\Amd64\LRC7500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\prnle003.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR131NL6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR131N6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR11006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\prnle003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\prnle003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR136N6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR145N6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR13506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR1506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR1616.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR16006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR20006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR25506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR25106.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR25006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR2550B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR30106.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR35006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR33506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR4000B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR3350B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR40006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR4100N6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR50006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR45006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR4110N6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR55006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR60006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR5000B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR65006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR90006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR70006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LRC15006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR80006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR75006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LR91006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LRC20006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LRC226C6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LRC25006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LRC231C6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LRC33CN6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LRC30006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LRC45006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LRC400D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LRC75006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LRC35006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LRC440C6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle003.inf_amd64_neutral_c61883abf66ddb39\Amd64\LRC60006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\prnle004.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\prnle004.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\prnle004.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LA1311E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LA1312E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LALD1903.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LAMPC303.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LAMPC203.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LAL11353.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1301E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LAMPC253.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1302E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1321E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1341E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1331E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1342E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1303E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1371E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LAL11003.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1391E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1392E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1393E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1332E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1402E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1401E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1404E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1431E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1432E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1433E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1403E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN2161E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN2192E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN2191E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\KYFS4020.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN1394E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN2193E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN3171E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN2221E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN3172E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN2171E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN2195E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN2194E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN4171E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN4172E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN3202E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx002.inf_amd64_neutral_12563574abbc36eb\prnlx002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN3191E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx002.inf_amd64_neutral_12563574abbc36eb\prnlx002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx002.inf_amd64_neutral_12563574abbc36eb\prnlx002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN3201E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx002.inf_amd64_neutral_12563574abbc36eb\Amd64\LEXC520.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN4181E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN4231E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnle004.inf_amd64_neutral_beb9bf23b7202bff\Amd64\LN4221E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx002.inf_amd64_neutral_12563574abbc36eb\Amd64\LEXC522.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx002.inf_amd64_neutral_12563574abbc36eb\Amd64\LEXC510.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx002.inf_amd64_neutral_12563574abbc36eb\Amd64\LEXC760.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx002.inf_amd64_neutral_12563574abbc36eb\Amd64\LEXC530.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx002.inf_amd64_neutral_12563574abbc36eb\Amd64\LEXC532.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx002.inf_amd64_neutral_12563574abbc36eb\Amd64\LEXC534.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx002.inf_amd64_neutral_12563574abbc36eb\Amd64\LEXC770.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx002.inf_amd64_neutral_12563574abbc36eb\Amd64\LEXC762.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\prnlx003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx002.inf_amd64_neutral_12563574abbc36eb\Amd64\LEXC524.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\prnlx003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\prnlx003.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx002.inf_amd64_neutral_12563574abbc36eb\Amd64\LEXC782.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx002.inf_amd64_neutral_12563574abbc36eb\Amd64\LEXC780.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\KYFS5400.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx002.inf_amd64_neutral_12563574abbc36eb\Amd64\LEXC772.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\Amd64\LME234.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\Amd64\LME232.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\Amd64\LME234N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\Amd64\LME332N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnky009.inf_amd64_neutral_8e54c9ff272b72f1\Amd64\KYTAS250.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\Amd64\LME330.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\Amd64\LME323.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\Amd64\LME238.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\Amd64\LME240N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\Amd64\LME250DN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx004.inf_amd64_neutral_2cf95f307381e481\prnlx004.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx004.inf_amd64_neutral_2cf95f307381e481\prnlx004.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\Amd64\LME340.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\Amd64\LME120N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\Amd64\LME450DN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx004.inf_amd64_neutral_2cf95f307381e481\prnlx004.PNF - Ok
C:\Windows\system32\MRT.exe - container
C:\Windows\system32\DriverStore\FileRepository\prnlx005.inf_amd64_neutral_f65eeb9bff6bd8f3\prnlx005.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx004.inf_amd64_neutral_2cf95f307381e481\Amd64\LM2590.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx005.inf_amd64_neutral_f65eeb9bff6bd8f3\prnlx005.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx004.inf_amd64_neutral_2cf95f307381e481\Amd64\LM2591.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\Amd64\LME250D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx005.inf_amd64_neutral_f65eeb9bff6bd8f3\prnlx005.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx005.inf_amd64_neutral_f65eeb9bff6bd8f3\Amd64\LMT430.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx005.inf_amd64_neutral_f65eeb9bff6bd8f3\Amd64\LMT632.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx005.inf_amd64_neutral_f65eeb9bff6bd8f3\Amd64\LMT630.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\Amd64\LME350D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\Amd64\LME240.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx005.inf_amd64_neutral_f65eeb9bff6bd8f3\Amd64\LMT634.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx006.inf_amd64_neutral_cc725426972d1293\prnlx006.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx006.inf_amd64_neutral_cc725426972d1293\prnlx006.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx004.inf_amd64_neutral_2cf95f307381e481\Amd64\LM2580.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx006.inf_amd64_neutral_cc725426972d1293\prnlx006.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx006.inf_amd64_neutral_cc725426972d1293\Amd64\LEXC920.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx005.inf_amd64_neutral_f65eeb9bff6bd8f3\Amd64\LMT640.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx005.inf_amd64_neutral_f65eeb9bff6bd8f3\Amd64\LMT644.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx005.inf_amd64_neutral_f65eeb9bff6bd8f3\Amd64\LMW812.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx007.inf_amd64_neutral_0b796ee4978458e2\prnlx007.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx004.inf_amd64_neutral_2cf95f307381e481\Amd64\LM2581.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx007.inf_amd64_neutral_0b796ee4978458e2\prnlx007.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx005.inf_amd64_neutral_f65eeb9bff6bd8f3\Amd64\LMW840.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx007.inf_amd64_neutral_0b796ee4978458e2\prnlx007.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx006.inf_amd64_neutral_cc725426972d1293\Amd64\LEXC935.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx007.inf_amd64_neutral_0b796ee4978458e2\Amd64\LME230.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx007.inf_amd64_neutral_0b796ee4978458e2\Amd64\LME220.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx007.inf_amd64_neutral_0b796ee4978458e2\Amd64\LME321.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx005.inf_amd64_neutral_f65eeb9bff6bd8f3\Amd64\LMX646e.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx008.inf_amd64_neutral_75545721835fd863\prnlx008.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\Amd64\LME352DN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx003.inf_amd64_neutral_d1510a8315a2ea0d\Amd64\LXE342N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx008.inf_amd64_neutral_75545721835fd863\prnlx008.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx005.inf_amd64_neutral_f65eeb9bff6bd8f3\Amd64\LMX644e.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx008.inf_amd64_neutral_75545721835fd863\prnlx008.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx007.inf_amd64_neutral_0b796ee4978458e2\Amd64\LME320.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx008.inf_amd64_neutral_75545721835fd863\Amd64\LXX832e.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx009.inf_amd64_neutral_d4b76afd08f308fb\prnlx009.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx007.inf_amd64_neutral_0b796ee4978458e2\Amd64\LMT522.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx009.inf_amd64_neutral_d4b76afd08f308fb\prnlx009.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx009.inf_amd64_neutral_d4b76afd08f308fb\prnlx009.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx005.inf_amd64_neutral_f65eeb9bff6bd8f3\Amd64\LMT642.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx009.inf_amd64_neutral_d4b76afd08f308fb\Amd64\LXX422.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx007.inf_amd64_neutral_0b796ee4978458e2\Amd64\LMT622.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx007.inf_amd64_neutral_0b796ee4978458e2\Amd64\LXT520.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00a.inf_amd64_neutral_a89d2c01c0f43dfd\prnlx00a.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00a.inf_amd64_neutral_a89d2c01c0f43dfd\prnlx00a.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00a.inf_amd64_neutral_a89d2c01c0f43dfd\prnlx00a.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx008.inf_amd64_neutral_75545721835fd863\Amd64\LXX830e.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00b.inf_amd64_neutral_89b555703683b583\prnlx00b.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00a.inf_amd64_neutral_a89d2c01c0f43dfd\Amd64\LXX945.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00b.inf_amd64_neutral_89b555703683b583\prnlx00b.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx007.inf_amd64_neutral_0b796ee4978458e2\Amd64\LXT520S.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00a.inf_amd64_neutral_a89d2c01c0f43dfd\Amd64\LXX940.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx007.inf_amd64_neutral_0b796ee4978458e2\Amd64\LMT620.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00b.inf_amd64_neutral_89b555703683b583\prnlx00b.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx007.inf_amd64_neutral_0b796ee4978458e2\Amd64\LME322.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx008.inf_amd64_neutral_75545721835fd863\Amd64\LXX850e.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx009.inf_amd64_neutral_d4b76afd08f308fb\Amd64\LXX642e.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00b.inf_amd64_neutral_89b555703683b583\Amd64\LXE260.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00b.inf_amd64_neutral_89b555703683b583\Amd64\LXE360D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00b.inf_amd64_neutral_89b555703683b583\Amd64\LXE360DN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00c.inf_amd64_neutral_79ebe29715d2fa47\prnlx00c.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00c.inf_amd64_neutral_79ebe29715d2fa47\prnlx00c.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00c.inf_amd64_neutral_79ebe29715d2fa47\prnlx00c.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00c.inf_amd64_neutral_79ebe29715d2fa47\Amd64\LXC540.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00c.inf_amd64_neutral_79ebe29715d2fa47\Amd64\LXC544.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00d.inf_amd64_neutral_ce7a0b4e23e432ad\prnlx00d.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx008.inf_amd64_neutral_75545721835fd863\Amd64\LXX852e.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00d.inf_amd64_neutral_ce7a0b4e23e432ad\prnlx00d.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00d.inf_amd64_neutral_ce7a0b4e23e432ad\prnlx00d.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx008.inf_amd64_neutral_75545721835fd863\Amd64\LXX854e.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00c.inf_amd64_neutral_79ebe29715d2fa47\Amd64\LXC543.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00b.inf_amd64_neutral_89b555703683b583\Amd64\LXE260D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00b.inf_amd64_neutral_89b555703683b583\Amd64\LXE260DN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00e.inf_amd64_neutral_0a4797d9b127d3a7\prnlx00e.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00e.inf_amd64_neutral_0a4797d9b127d3a7\prnlx00e.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00e.inf_amd64_neutral_0a4797d9b127d3a7\prnlx00e.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00b.inf_amd64_neutral_89b555703683b583\Amd64\LXE460DW.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00e.inf_amd64_neutral_0a4797d9b127d3a7\Amd64\LXX544.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00e.inf_amd64_neutral_0a4797d9b127d3a7\Amd64\LXX543.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00v.inf_amd64_neutral_86ff307c66080d00\prnlx00v.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00b.inf_amd64_neutral_89b555703683b583\Amd64\LXT650.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00b.inf_amd64_neutral_89b555703683b583\Amd64\LXE460DN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00v.inf_amd64_neutral_86ff307c66080d00\Amd64\lxkpcl.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00v.inf_amd64_neutral_86ff307c66080d00\prnlx00v.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00w.inf_amd64_neutral_d4c93bb2fbf75723\prnlx00w.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00b.inf_amd64_neutral_89b555703683b583\Amd64\LXT652.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00w.inf_amd64_neutral_d4c93bb2fbf75723\prnlx00w.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00w.inf_amd64_neutral_d4c93bb2fbf75723\prnlx00w.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00v.inf_amd64_neutral_86ff307c66080d00\Amd64\lxkpclrd.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00x.inf_amd64_neutral_808baf4e08594a59\prnlx00x.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00x.inf_amd64_neutral_808baf4e08594a59\prnlx00x.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00x.inf_amd64_neutral_808baf4e08594a59\Amd64\lxkps.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00x.inf_amd64_neutral_808baf4e08594a59\prnlx00x.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00y.inf_amd64_neutral_977318f2317f5ddd\prnlx00y.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00b.inf_amd64_neutral_89b555703683b583\Amd64\LXT654.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00y.inf_amd64_neutral_977318f2317f5ddd\prnlx00y.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00y.inf_amd64_neutral_977318f2317f5ddd\prnlx00y.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00x.inf_amd64_neutral_808baf4e08594a59\Amd64\lxkpsrd.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00d.inf_amd64_neutral_ce7a0b4e23e432ad\Amd64\LXX654DE.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00y.inf_amd64_neutral_977318f2317f5ddd\Amd64\LXKXL.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00d.inf_amd64_neutral_ce7a0b4e23e432ad\Amd64\LXX652DE.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00y.inf_amd64_neutral_977318f2317f5ddd\Amd64\LXKXLRD.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00v.inf_amd64_neutral_86ff307c66080d00\Amd64\lxkpclui.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00z.inf_amd64_neutral_aea50acf04a2db1d\prnlx00z.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00w.inf_amd64_neutral_d4c93bb2fbf75723\Amd64\lxkpclrs.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00z.inf_amd64_neutral_aea50acf04a2db1d\prnlx00z.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00v.inf_amd64_neutral_86ff307c66080d00\prnlx00v.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00x.inf_amd64_neutral_808baf4e08594a59\Amd64\lxkpsui.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms001.inf_amd64_neutral_9b214cd9b78760aa\mxdwdui.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms001.inf_amd64_neutral_9b214cd9b78760aa\prnms001.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00y.inf_amd64_neutral_977318f2317f5ddd\Amd64\LXKXLMAC.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms001.inf_amd64_neutral_9b214cd9b78760aa\prnms001.Inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms001.inf_amd64_neutral_9b214cd9b78760aa\prnms001.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00z.inf_amd64_neutral_aea50acf04a2db1d\Amd64\LXKPTPRC.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00y.inf_amd64_neutral_977318f2317f5ddd\Amd64\LXKXLRES.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms001.inf_amd64_neutral_9b214cd9b78760aa\mxdwdui.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00z.inf_amd64_neutral_aea50acf04a2db1d\prnlx00z.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms001.inf_amd64_neutral_9fe8503f82ce60fa\mxdwdui.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms001.inf_amd64_neutral_9fe8503f82ce60fa\prnms001.Inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms001.inf_amd64_neutral_9fe8503f82ce60fa\prnms001.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00y.inf_amd64_neutral_977318f2317f5ddd\Amd64\LXKXLUI.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00d.inf_amd64_neutral_ce7a0b4e23e432ad\Amd64\LXX658DE.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms002.inf_amd64_neutral_d834e48846616289\prnms002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms002.inf_amd64_neutral_d834e48846616289\prnms002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms002.inf_amd64_neutral_d834e48846616289\prnms002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms001.inf_amd64_neutral_9fe8503f82ce60fa\mxdwdui.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms001.inf_amd64_neutral_9fe8503f82ce60fa\prnms001.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\prnnr002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\prnnr002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms001.inf_amd64_neutral_9b214cd9b78760aa\mxdwdui.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR1100.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\prnnr002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR1350.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR1600.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR161.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms001.inf_amd64_neutral_9fe8503f82ce60fa\mxdwdui.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR2000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR2500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR2550.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR2510.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR2550B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR3010.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR3350.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR4000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR4000B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR3350B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR4100N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms002.inf_amd64_neutral_d834e48846616289\Amd64\FXSUI.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR4110N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR3500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR4500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms002.inf_amd64_neutral_d834e48846616289\Amd64\FXSTIFF.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms002.inf_amd64_neutral_d834e48846616289\Amd64\FXSWZRD.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR5000B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR5000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms002.inf_amd64_neutral_d834e48846616289\Amd64\FXSDRV.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR6000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR6500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR7000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR8000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR9000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR5500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR8200.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR8100D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms002.inf_amd64_neutral_d834e48846616289\Amd64\FXSAPI.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR9100D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NRC150SP.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NRC2000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NRC3000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NRC411D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NRC3500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NRC420D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NRC410D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NRC4500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR4100NL.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NRC6000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NRC7500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NRC811DN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NRC2500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\prnnr003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\prnnr003.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR13506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR16006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR1616.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR11006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR25006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR25106.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR25506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR2550B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR30106.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR33506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR35006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR40006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR3350B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR4100N6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR50006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR4000B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR45006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00d.inf_amd64_neutral_ce7a0b4e23e432ad\Amd64\LXX656DE.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR4110N6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR5000B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\prnnr003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr002.inf_amd64_neutral_37896c5e81c8d488\Amd64\NR7500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR55006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR70006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR65006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR410NL6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR60006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR75006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR8100D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnlx00d.inf_amd64_neutral_ce7a0b4e23e432ad\Amd64\LXX651DE.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NRC15SP6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR20006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR80006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR9100D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NRC25006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR82006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NRC411D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NRC35006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NRC45006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NRC60006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NRC420D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NRC75006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NR90006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NRC30006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NRC811D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NRC20006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\prnnr004.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\prnnr004.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr003.inf_amd64_neutral_c07c33bfb5764bdb\Amd64\NRC410D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1321E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1311E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1312E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1301E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1332E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1331E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1341E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\prnnr004.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1303E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1302E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1371E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1392E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1403E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1404E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1401E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1391E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1394E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1393E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1342E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1402E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR2171E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR2161E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1433E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR2193E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR3191E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR2221E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1432E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR1431E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR3201E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR3172E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR2192E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR2191E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR3202E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR3171E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR4171E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NRG11003.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NRG13503.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnod002.inf_amd64_neutral_a10c656b6c7c053c\prnod002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NRMPC203.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NRG90003.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR4181E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR4172E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnod002.inf_amd64_neutral_a10c656b6c7c053c\prnod002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnod002.inf_amd64_neutral_a10c656b6c7c053c\prnod002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnod002.inf_amd64_neutral_a10c656b6c7c053c\Amd64\OKDTEVER.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NR4221E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NRMPC253.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnnr004.inf_amd64_neutral_3319ff2548f89fd8\Amd64\NRMPC303.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnod002.inf_amd64_neutral_a10c656b6c7c053c\Amd64\OKMLIVU.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\prnok002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\prnok002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnod002.inf_amd64_neutral_a10c656b6c7c053c\Amd64\OKML421.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnod002.inf_amd64_neutral_a10c656b6c7c053c\Amd64\OKML186.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnod002.inf_amd64_neutral_a10c656b6c7c053c\Amd64\OKML491.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\prnok002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\ML3321.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnod002.inf_amd64_neutral_a10c656b6c7c053c\Amd64\OKPM4410.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnod002.inf_amd64_neutral_a10c656b6c7c053c\Amd64\OD63FSC.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\ML3320.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\ML4410.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnod002.inf_amd64_neutral_a10c656b6c7c053c\Amd64\ODML1120.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OK4350U5.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnod002.inf_amd64_neutral_a10c656b6c7c053c\Amd64\OKML490.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OK5400U5.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnod002.inf_amd64_neutral_a10c656b6c7c053c\Amd64\OKML420.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OK4300U5.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OK7350U5.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OK5300U5.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OK540NU5.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OK7500U5.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OK7100U5.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OK7300U5.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKDTUVER.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OK7550U5.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnod002.inf_amd64_neutral_a10c656b6c7c053c\Amd64\OKML8810.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OK8800U5.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OK9500U5.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OK9300U5.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML3390.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML3391.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKDOT9.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKDOT24.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML320T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML184T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML339X.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKDTURES.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML321T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML1190.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnod002.inf_amd64_neutral_a10c656b6c7c053c\Amd64\OKDTERES.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML4410.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML390T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKDTERES.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML5591.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML280E.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKMLIVU.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc002.inf_amd64_neutral_fdb6f2e252435905\prnrc002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML5590.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML720.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc002.inf_amd64_neutral_fdb6f2e252435905\prnrc002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc002.inf_amd64_neutral_fdb6f2e252435905\Amd64\RIC2500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc002.inf_amd64_neutral_fdb6f2e252435905\Amd64\RICM3000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc002.inf_amd64_neutral_fdb6f2e252435905\prnrc002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc003.inf_amd64_neutral_47e09b7cc0d9e993\prnrc003.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc003.inf_amd64_neutral_47e09b7cc0d9e993\prnrc003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc003.inf_amd64_neutral_47e09b7cc0d9e993\prnrc003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc003.inf_amd64_neutral_47e09b7cc0d9e993\Amd64\RIC25006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc003.inf_amd64_neutral_47e09b7cc0d9e993\Amd64\RICM3006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc004.inf_amd64_neutral_bbd3435eeaf576ee\prnrc004.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc004.inf_amd64_neutral_bbd3435eeaf576ee\prnrc004.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc004.inf_amd64_neutral_bbd3435eeaf576ee\prnrc004.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKSIDM9.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc004.inf_amd64_neutral_bbd3435eeaf576ee\Amd64\RAF42253.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\prnrc005.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc004.inf_amd64_neutral_bbd3435eeaf576ee\Amd64\RAF42303.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML791.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA1100.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\prnrc005.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML5520.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA1350.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA161.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA1600.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA2000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA2510.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA2550B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA2500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA3010.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA2550.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA3350B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA3500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA4000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA4500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA5000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA4000B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA5000B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\prnrc005.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA6500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA5500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA6000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA7000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML721.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML790.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA8000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA8100D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA7500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA9000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA3350.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA8200.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML391T.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIA9100D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIAS411N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIAS41NL.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIC3500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIC1500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIC411D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIC420D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIC811DN.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIC6000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIC7500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RICM2000.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIC400D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIAS410N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\prnrc006.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\prnrc006.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA11006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIC4500.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA13506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\prnrc006.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA16006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA25106.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA25506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA20006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc005.inf_amd64_neutral_31e08a1c2f933124\Amd64\RIC410D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA25006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA335B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA255B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA35006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA30106.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA1616.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA40006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA400B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA45006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA33506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA55006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA500B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA75006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA60006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA70006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA50006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA82006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA80006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA910D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIAS4106.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIAS4116.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA90006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA65006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIC35006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIC400D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIC410D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIC15006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIA810D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIC60006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIC411D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIC420D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIC75006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RICM2006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIAS41L6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\prnrc007.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\prnrc007.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\prnrc007.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIC45006.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc006.inf_amd64_neutral_7e12a60cc98d3f89\Amd64\RIC811D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML630F.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RAF21653.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RAF42153.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RAF21553.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1311E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RAF21753.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RAF31103.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RAF31353.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RAF42353.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RAF42203.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1312E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RAF42453.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1331E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1332E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1341E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1342E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1371E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RAF30903.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1391E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1401E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1403E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1321E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1402E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1404E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI2161E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1433E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI2192E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1431E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1432E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI2171E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnok002.inf_amd64_neutral_616c1e9b7df7d5a9\Amd64\OKML5521.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1393E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1392E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI1394E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI2191E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI3201E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI4172E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI4171E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI2221E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI2193E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00a.inf_amd64_neutral_565c5d04cc520c48\prnrc00a.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00a.inf_amd64_neutral_565c5d04cc520c48\prnrc00a.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00a.inf_amd64_neutral_565c5d04cc520c48\prnrc00a.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00a.inf_amd64_neutral_565c5d04cc520c48\Amd64\RIARES17.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00a.inf_amd64_neutral_565c5d04cc520c48\Amd64\RIARES27.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI4231E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00a.inf_amd64_neutral_565c5d04cc520c48\Amd64\RIA6MAC7.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI3202E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\prnrc00b.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\prnrc00b.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\prnrc00b.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI4181E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00a.inf_amd64_neutral_565c5d04cc520c48\Amd64\RICFG7.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIAAPC1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIAADC45.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIAADP4.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIAALC1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc007.inf_amd64_neutral_2df575afa0f7d35f\Amd64\RI4221E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIAGAP2.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIAGAP3.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00a.inf_amd64_neutral_565c5d04cc520c48\Amd64\RIARES7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIAAPP1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIAATC1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00a.inf_amd64_neutral_565c5d04cc520c48\Amd64\RIACMAC7.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIAALP1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIAMTP2.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIAPRC1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIARUC45.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIARUC5.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIABLC3.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIAMTC35.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00c.inf_amd64_neutral_53a58f4fd7d88575\prnrc00c.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIAMTC3.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIAPGC1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00c.inf_amd64_neutral_53a58f4fd7d88575\prnrc00c.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00c.inf_amd64_neutral_53a58f4fd7d88575\prnrc00c.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00c.inf_amd64_neutral_53a58f4fd7d88575\Amd64\RICOHPS7.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIASNP1.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIAVEC2.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIAKRC3.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\prnsa002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\prnsa002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\prnsa002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00c.inf_amd64_neutral_53a58f4fd7d88575\Amd64\RICFG7.XML - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\saacps.gdl - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\SM6X22.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\saacuni.gdl - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smc350u.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smc350.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smc350.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smc610u.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnms002.inf_amd64_neutral_d834e48846616289\Amd64\FXSRES.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smc660u.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\SMC610.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smc660.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smc660.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smc770u.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00b.inf_amd64_neutral_3338d41663aad5fa\Amd64\RIASTC3.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\SM6X22.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smc770.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smc770.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smf4x6.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smf4x4.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smf4x8.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smf472.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smf4x8.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smf583u.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smf563.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00c.inf_amd64_neutral_53a58f4fd7d88575\Amd64\RIPSRES7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smf472.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smf6x4u.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smf563.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smf583.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smf6x5.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smcomu1.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smf6x5.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smf6x4.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smf6x4.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\sml257.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\sml257.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smf6x5u.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\sml285.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smf583.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00a.inf_amd64_neutral_565c5d04cc520c48\Amd64\RIAUI27.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\sml285.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\sml405u.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\sml28p.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\sml28p.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\SML347.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\sml455u.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\sml405.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smpicfg2.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\SML347.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\sml8x0.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\sml8x0.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\sml405.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smpclrd1.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\sml455.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\sml455.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smpicfg3.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smx620u.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smx620.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smpclrc1.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smx624.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smx620.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smx624.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smx624u.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smpsrd1.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smx8x3u.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\prnsh002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\prnsh002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\prnsh002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHC23N01.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHC23N03.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\smpclrc1.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHC23N02.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHH51N03.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHC23N04.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHH52N02.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHH51N04.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHH52N04.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00a.inf_amd64_neutral_565c5d04cc520c48\Amd64\RIAUI17.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHH52N06.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHH52N01.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHH52N05.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHC2N003.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHH52N03.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHH5N002.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHJ11N02.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHJ11N03.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHJ11N04.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHJ11N05.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHJ12N02.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHJ11N01.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHJ11N06.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHJ12N03.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHH5N001.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHK11N04.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHK11N02.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHJ12N01.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHJ1N002.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\SMX8X3.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHK11N05.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHK11N03.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsa002.inf_amd64_neutral_d9df1d04d8cbe336\Amd64\SMX8X3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHJ1N001.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHK11N06.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHK12N01.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHK11N01.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnrc00c.inf_amd64_neutral_53a58f4fd7d88575\Amd64\RIPSUI7.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnso002.inf_amd64_neutral_c3b7ce4e6f71641f\prnso002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHK12N04.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnso002.inf_amd64_neutral_c3b7ce4e6f71641f\prnso002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHK12N02.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnso002.inf_amd64_neutral_c3b7ce4e6f71641f\prnso002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHK12N03.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnso002.inf_amd64_neutral_c3b7ce4e6f71641f\Amd64\SODPP2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHK1N001.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SHK1N002.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnso002.inf_amd64_neutral_c3b7ce4e6f71641f\Amd64\SODPPRC2.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\prnsv002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnso002.inf_amd64_neutral_c3b7ce4e6f71641f\Amd64\SODPFP95.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\prnsv002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnso002.inf_amd64_neutral_c3b7ce4e6f71641f\Amd64\SODPPLM2.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnso002.inf_amd64_neutral_c3b7ce4e6f71641f\Amd64\SODPFP85.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnso002.inf_amd64_neutral_c3b7ce4e6f71641f\Amd64\SODPFP75.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnso002.inf_amd64_neutral_c3b7ce4e6f71641f\Amd64\SODPPUI2.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnso002.inf_amd64_neutral_c3b7ce4e6f71641f\Amd64\SODPFP65.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnso002.inf_amd64_neutral_c3b7ce4e6f71641f\Amd64\SODPPUN2.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV31N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV150.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\prnsv002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV175N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnso002.inf_amd64_neutral_c3b7ce4e6f71641f\Amd64\SODPFP60.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV145.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnso002.inf_amd64_neutral_c3b7ce4e6f71641f\Amd64\SODPFP90.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV7025.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnso002.inf_amd64_neutral_c3b7ce4e6f71641f\Amd64\SODPFP70.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV36N.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV31NL.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV8025E.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV8045E.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV8035E.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV8055.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV8060.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV8070.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV8065.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV8080.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV8110.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV9016.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV816.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV9025.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV8135.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV9025b.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV9040.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV9021D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV9033b.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV9050.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SVC1506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV8075.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV9040B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SVC2020.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV9050B.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SVC131D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsh002.inf_amd64_neutral_42b7a64f45c7554c\Amd64\SH_1_RES.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SVC240D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV9033.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SVC2525.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV8090.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SVC27D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SV8030E.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SVC31D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SVC6055.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SVC400D.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SVC3030.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SVC3535.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\prnsv003.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SVC7570.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv002.inf_amd64_neutral_6ca80563d6148ee5\Amd64\SVC4540.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\prnsv003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV175N6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\prnsv003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV1456.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV31NL6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV31N6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV36N6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV1506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV8045E6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV8030E6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV70256.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV8025E6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV80556.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV8035E6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV80656.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV80606.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV80756.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV80706.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV81106.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV8166.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV80906.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV81356.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV80806.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV90166.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV9025b6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV90336.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV9021D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV9033b6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV90256.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV90406.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV9040B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV90506.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SVC15066.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SVC20206.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SVC131D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SVC27D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SVC240D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SVC30306.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SVC400D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SVC45406.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SVC35356.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\prnsv004.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SVC31D6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SVC75706.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SV9050B6.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\prnsv004.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\prnsv004.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SVC60556.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv003.inf_amd64_neutral_1e0c4fbb9b11b015\Amd64\SVC25256.GPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SA1312E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SA1311E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SA381353.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SA1342E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SA380903.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SA381103.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SA1341E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SAC30303.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1301E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1303E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SAC20203.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1302E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1321E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1371E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SAC25253.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1332E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1391E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1331E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1392E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV2161E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV2171E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV2193E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV2192E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1393E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1403E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1402E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1401E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1431E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1404E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1432E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1394E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV2191E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV1433E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV3172E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV2221E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV3191E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV3202E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV4171E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV3171E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts002.inf_amd64_neutral_ad2aa922aa11af2c\prnts002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV4172E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV4221E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts002.inf_amd64_neutral_ad2aa922aa11af2c\prnts002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV3201E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV4181E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts002.inf_amd64_neutral_ad2aa922aa11af2c\Amd64\tsmpu002.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts002.inf_amd64_neutral_ad2aa922aa11af2c\prnts002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts002.inf_amd64_neutral_ad2aa922aa11af2c\Amd64\tsmpu002.gdl - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts003.inf_amd64_neutral_33a68664c7e7ae4b\prnts003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts003.inf_amd64_neutral_33a68664c7e7ae4b\prnts003.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts003.inf_amd64_neutral_33a68664c7e7ae4b\prnts003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts002.inf_amd64_neutral_ad2aa922aa11af2c\Amd64\tsmpc002.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts002.inf_amd64_neutral_ad2aa922aa11af2c\Amd64\tsmpd002.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts003.inf_amd64_neutral_33a68664c7e7ae4b\Amd64\tsmxu003.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts003.inf_amd64_neutral_33a68664c7e7ae4b\Amd64\tsmxuPipelineConfig.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts002.inf_amd64_neutral_ad2aa922aa11af2c\Amd64\tsmpb002.ppd - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts003.inf_amd64_neutral_33a68664c7e7ae4b\Amd64\tsmxu003.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnxx002.inf_amd64_neutral_560fdd891b24f384\prnxx002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts003.inf_amd64_neutral_33a68664c7e7ae4b\Amd64\tsmxu003.gdl - Ok
C:\Windows\system32\DriverStore\FileRepository\prnxx002.inf_amd64_neutral_560fdd891b24f384\prnxx002.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnsv004.inf_amd64_neutral_fc4526bbfbd5feb1\Amd64\SV4231E3.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnxx002.inf_amd64_neutral_560fdd891b24f384\prnxx002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnxx002.inf_amd64_neutral_560fdd891b24f384\Amd64\XR6120PU.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\qd3x64.inf_amd64_neutral_e8903726d63a3f07\qd3x64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\qd3x64.inf_amd64_neutral_e8903726d63a3f07\qd3x64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts002.inf_amd64_neutral_ad2aa922aa11af2c\Amd64\tsmpu002.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\prnxx002.inf_amd64_neutral_560fdd891b24f384\Amd64\XR6180DN.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnxx002.inf_amd64_neutral_560fdd891b24f384\Amd64\XR6180MN.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnxx002.inf_amd64_neutral_560fdd891b24f384\Amd64\XRX6180N.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\prnxx002.inf_amd64_neutral_560fdd891b24f384\Amd64\XR6180MD.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\ql2300.inf_amd64_neutral_ca8487daf77ff7cb\ql2300.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ql40xx2.inf_amd64_neutral_b95932400326817e\ql40xx2.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ql40xx.inf_amd64_neutral_77a826e5c0a07842\ql40xx.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ql40xx2.inf_amd64_neutral_b95932400326817e\ql40xx2.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ql2300.inf_amd64_neutral_ca8487daf77ff7cb\ql2300.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ramdisk.inf_amd64_neutral_798b5d4dd3f22a07\ramdisk.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ramdisk.inf_amd64_neutral_798b5d4dd3f22a07\ramdisk.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnxx002.inf_amd64_neutral_560fdd891b24f384\Amd64\XRX6130N.PPD - Ok
C:\Windows\system32\DriverStore\FileRepository\rawsilo.inf_amd64_neutral_8eb7e6403ddbb7a8\rawsilo.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\rawsilo.inf_amd64_neutral_8eb7e6403ddbb7a8\rawsilo.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\rdpbus.inf_amd64_neutral_3b741ca76444b9c3\rdpbus.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\rdpbus.inf_amd64_neutral_3b741ca76444b9c3\rdpbus.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ricoh.inf_amd64_neutral_66b4504d1fb1c857\ricoh.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ramdisk.inf_amd64_neutral_798b5d4dd3f22a07\ramdisk.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ricoh.inf_amd64_neutral_66b4504d1fb1c857\ricoh.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ql40xx.inf_amd64_neutral_77a826e5c0a07842\ql40xx.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ql40xx.inf_amd64_neutral_77a826e5c0a07842\ql40xx.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\rdpbus.inf_amd64_neutral_3b741ca76444b9c3\rdpbus.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ricoh.inf_amd64_neutral_66b4504d1fb1c857\RW430Ext.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ricoh.inf_amd64_neutral_66b4504d1fb1c857\IS330.icm - Ok
C:\Windows\system32\DriverStore\FileRepository\ricoh.inf_amd64_neutral_66b4504d1fb1c857\RW001Ext.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ricoh.inf_amd64_neutral_66b4504d1fb1c857\RW450Ext.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\rndiscmp.inf_amd64_neutral_4ca64d28e1be8fa9\rndiscmp.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\rndiscmp.inf_amd64_neutral_4ca64d28e1be8fa9\rndiscmp.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\rt64win7.inf_amd64_neutral_bd3a21c37713fd5b\rt64win7.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ricoh.inf_amd64_neutral_66b4504d1fb1c857\RW330Ext.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\rt64win7.inf_amd64_neutral_bd3a21c37713fd5b\rt64win7.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts003.inf_amd64_neutral_33a68664c7e7ae4b\Amd64\tsmxuui3.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ricoh.inf_amd64_neutral_66b4504d1fb1c857\RWia330.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\ricoh.inf_amd64_neutral_66b4504d1fb1c857\RWia450.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\rtspstord3offmsieh.inf_amd64_neutral_fa41de1d70d8602e\RtsPStor.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\rtspstord3offmsieh.inf_amd64_neutral_fa41de1d70d8602e\RtsPStorD3OffMSIEH.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\rtspstord3offmsieh.inf_amd64_neutral_fa41de1d70d8602e\rtspstord3offmsieh.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts003.inf_amd64_neutral_33a68664c7e7ae4b\Amd64\tsmxbman.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\ricoh.inf_amd64_neutral_66b4504d1fb1c857\RWia430.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\sbp2.inf_amd64_neutral_332943647e950ada\sbp2.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\sbp2.inf_amd64_neutral_332943647e950ada\sbp2.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\prnts003.inf_amd64_neutral_33a68664c7e7ae4b\Amd64\tsmxcman.gpd - Ok
C:\Windows\system32\DriverStore\FileRepository\scrawpdo.inf_amd64_neutral_4c228493af8567bb\scrawpdo.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\scrawpdo.inf_amd64_neutral_4c228493af8567bb\scrawpdo.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\scsidev.inf_amd64_neutral_a7f5d9f34b621dca\scsidev.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\scsidev.inf_amd64_neutral_a7f5d9f34b621dca\scsidev.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\rt64win7.inf_amd64_neutral_bd3a21c37713fd5b\rt64win7.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\rt64win7.inf_amd64_neutral_bd3a21c37713fd5b\RtNicProp64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\sdbus.inf_amd64_neutral_735aa3b5ee832f62\sdbus.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\sdbus.inf_amd64_neutral_735aa3b5ee832f62\sdbus.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ql2300.inf_amd64_neutral_ca8487daf77ff7cb\ql2300.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\rt64win7.inf_amd64_neutral_bd3a21c37713fd5b\RTNUninst64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\sffdisk.inf_amd64_neutral_d2425e60845d17d3\sffdisk.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\sffdisk.inf_amd64_neutral_d2425e60845d17d3\sffdisk.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\sensorsalsdriver.inf_amd64_neutral_1c5bc8e71eb90127\sensorsalsdriver.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ricoh.inf_amd64_neutral_66b4504d1fb1c857\RWia001.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\sensorsalsdriver.inf_amd64_neutral_1c5bc8e71eb90127\acpials.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\sbp2.inf_amd64_neutral_332943647e950ada\sbp2port.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\sensorsalsdriver.inf_amd64_neutral_1c5bc8e71eb90127\SensorsAlsDriver.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\sisraid2.inf_amd64_neutral_845e008c32615283\sisraid2.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\sisraid4.inf_amd64_neutral_65ab84e9830f6f4b\sisraid4.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\sisraid4.inf_amd64_neutral_65ab84e9830f6f4b\sisraid4.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\sisraid2.inf_amd64_neutral_845e008c32615283\sisraid2.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\sdbus.inf_amd64_neutral_735aa3b5ee832f62\sdbus.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\sffdisk.inf_amd64_neutral_d2425e60845d17d3\sffp_sd.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\rtspstord3offmsieh.inf_amd64_neutral_fa41de1d70d8602e\RtsPStor.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\rt64win7.inf_amd64_neutral_bd3a21c37713fd5b\Rt64win7.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\sffdisk.inf_amd64_neutral_d2425e60845d17d3\sffdisk.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\sffdisk.inf_amd64_neutral_d2425e60845d17d3\sffp_mmc.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\smartcrd.inf_amd64_neutral_6fb75ea318f84fe5\smartcrd.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\smartcrd.inf_amd64_neutral_6fb75ea318f84fe5\smartcrd.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\smartcrd.inf_amd64_neutral_6fb75ea318f84fe5\cmbp0wdm.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\sisraid2.inf_amd64_neutral_845e008c32615283\sisraid2.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\smartcrd.inf_amd64_neutral_6fb75ea318f84fe5\scmstcs.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\smartcrd.inf_amd64_neutral_6fb75ea318f84fe5\SCR111.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\smartcrd.inf_amd64_neutral_6fb75ea318f84fe5\pscr.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\snb2009.inf_amd64_neutral_3569c3492796a454\snb2009.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\snb2009.inf_amd64_neutral_3569c3492796a454\snb2009.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\smartcrd.inf_amd64_neutral_6fb75ea318f84fe5\stcusb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\snb2009.inf_amd64_neutral_3569c3492796a454\SNB2009.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\stexstor.inf_amd64_neutral_80ee226e29362f51\stexstor.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\stexstor.inf_amd64_neutral_80ee226e29362f51\stexstor.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\sti.inf_amd64_neutral_972872c0e59df52d\sti.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\sti.inf_amd64_neutral_972872c0e59df52d\sti.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\smartcrd.inf_amd64_neutral_6fb75ea318f84fe5\grserial.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\smartcrd.inf_amd64_neutral_6fb75ea318f84fe5\cxbp0wdm.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\sti.inf_amd64_neutral_972872c0e59df52d\scsiscan.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\sti.inf_amd64_neutral_9d9a7113099a28a2\scsiscan.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\stexstor.inf_amd64_neutral_80ee226e29362f51\stexstor.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\sti.inf_amd64_neutral_972872c0e59df52d\WSDScan.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\sti.inf_amd64_neutral_972872c0e59df52d\usbscan.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\sti.inf_amd64_neutral_9d9a7113099a28a2\sti.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\2hps.ico - Ok
C:\Windows\system32\DriverStore\FileRepository\sti.inf_amd64_neutral_9d9a7113099a28a2\usbscan.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\sti.inf_amd64_neutral_9d9a7113099a28a2\WSDScan.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\sisraid4.inf_amd64_neutral_65ab84e9830f6f4b\sisraid4.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\sti.inf_amd64_neutral_972872c0e59df52d\wiafbdrv.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\sti.inf_amd64_neutral_9d9a7113099a28a2\sti.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\sti.inf_amd64_neutral_9d9a7113099a28a2\wiafbdrv.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\bltinmic.ico - Ok
C:\Windows\system32\DriverStore\FileRepository\sti.inf_amd64_neutral_972872c0e59df52d\serscan.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\sti.inf_amd64_neutral_9d9a7113099a28a2\serscan.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\Balen&Yeats.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\Copley.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\AESTCo64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\Gable2.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\AESTAC64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\EEA64A.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\hpbeats.ico - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\Goya&Kroyer.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\AESTAR64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\EEG64A.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\AESTEC64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\idt64mp1.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\HPToneCtrls64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\EED64A.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\Lauren2.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\nbspkrs.ico - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\AESTSr64.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\nbspkrsbeats.ico - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\EEL64A.dll - Ok
>C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\Presets.bin is ZIP archive
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\Presets.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\Presets.bin - archive
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\IDTPMA64.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\slcsii64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\slcc3d64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\IDTNJ.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\slgeq64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\slh36064.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\slcshp64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\slhlim64.dll - Ok
>C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\idtcpl64.cpl is ZLIB container
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\slmaxv64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\slInit64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\EEP64A.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\idtcpl64.cpl - container
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\slvipp64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\slviq64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\slapoi64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\slprop64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\sluapo64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\SRS_NETGUI_LineOut_L.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\SRS_NETGUI_LineOut_S.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\sltshd64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\IDTNC64.cpl - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\SRS_Speaker1_S.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\staco64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\SRS_Speaker1_L.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\SRS_NETGUI_Speaker_S.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\stacsv64.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\SRS_Speaker_S.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\SRS_Speaker_L.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\StellaEQ2.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\IDTNX.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\stwrt64.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\stwrt64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\stcplx64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\stwrt64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\VuittonEq5.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\stwrt64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\stwrt64.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\suhlp64.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\stapi64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\stlang64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-2A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\stapo64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-0.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-1A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-3B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-1C.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-5.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-3A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-5A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-4.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-4A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\sttray64.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-6.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-4C.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-6B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-6D.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-6F.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-7.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-7A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-6C.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-4B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-6E.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M12-0.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M11-6A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M12-0A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M12-0B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M12-0C.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M12-0D.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M12-1A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M12-1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M12-1C.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M12-1B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M12-2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M12-2A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M12-1D.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M12-3.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M12-2C.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M12-4.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M12-2B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M12-4A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M4-2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M4-3.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M4-5.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M4-4.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M4-7.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M4-9.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M4-1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M4-A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M4-B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M4-E.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M4-6.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M4-C.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M4-F.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M5-1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M5-3.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M5-7.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M5-2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M5-6.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-3.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M5-9.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M5-D.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-0.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-4.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-8A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-5.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-7.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-6.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-8.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-D.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-C.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-E.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-F.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-F1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-9.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-F2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\IDTNHP.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-F3.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-4B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M6-G.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-3.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-4.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-5.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-9B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-8A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-6.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-9D.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-7.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-9.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-9C.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\rtspstord3offmsieh.inf_amd64_neutral_fa41de1d70d8602e\RtsPStorIcon.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-D.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\2hps.ico - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-A1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-9A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M8-1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-A4.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\bltinmic.ico - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M8-2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-C.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\AESTCo64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\AESTAR64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\AESTAC64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\hpbeats.ico - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\EEL64A.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-A2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\AESTSr64.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\EEA64A.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\EEG64A.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-E.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\AESTEC64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\HPToneCtrls64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\WRT_M7-A3.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\nbspkrs.ico - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\nbspkrsbeats.ico - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\idt64mp1.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\IDTPMA64.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\IDTNJ.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\slh36064.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\slcshp64.dll - Ok
>C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\idtcpl64.cpl is ZLIB container
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\sltshd64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\sluapo64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\SRS_NETGUI_LineOut_L.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\EED64A.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\SRS_NETGUI_LineOut_S.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\SRS_NETGUI_Speaker_S.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\idtcpl64.cpl - container
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\EEP64A.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\SRS_Speaker1_L.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\IDTNX.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\staco64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\SRS_Speaker1_S.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\SRS_Speaker_S.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\SRS_Speaker_L.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\stcplx64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\stwrt64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\stwrt64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\IDTNC64.cpl - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\stlang64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\stapi64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\stwrt64.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\stacsv64.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\stwrt64.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\suhlp64.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\stwrt64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\stapo64.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-2A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-0.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-1C.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-1A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-3B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-2B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-2C.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-5.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\sttray64.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-5A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-4B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-4A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-6.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-3A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-4.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-4C.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-6B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-6D.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-6A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-6F.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-6C.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-7.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-6E.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M4-3.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M4-2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M11-7A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M4-1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M4-4.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M4-5.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M4-6.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M4-A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\IDTNHP.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M4-9.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M4-E.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M4-7.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M4-B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M4-C.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M4-F.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M5-1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M5-2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M5-9.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M5-3.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M5-7.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M5-6.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M5-D.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-0.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-3.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-4.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-5.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-6.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-8A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-8.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-9.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-E.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-7.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-D.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-F1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-C.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_29fbc89de71e4db1\IDTNGUI.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-F.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-F3.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-F2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-4B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M6-G.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-3.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-4.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-5.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-7.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-8A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-9B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-9D.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-6.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-9.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-9A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-A1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-9C.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-A4.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-A2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Ckp2FingerScrolling.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-A.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-D.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Ckp3FingerDown.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\CkpClickDrag.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Ckp3FingerFlick.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\CkpLinearScroll.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M8-1.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\CkpLRClick.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M8-2.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\CkpMomentum.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\CkpChiralMotion.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\CkpPivotRotate.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\CkpPivotRotate2.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-B.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\StaticImg.png - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn1FingerClickNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\CkpPinch.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\CkpTouchpadDisable.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn2FingerClickDrag.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn1FingerClickDrag.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\StaticImg.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\StaticImg.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn2FingerFlickNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn2FingerMomentumVHScrollingNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn2FingerHScrollingNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn2FingerHScrolling.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn2FingerFlickLRNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\InstNT.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn2FingerRightClickNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn2FingerMomentumVHScrolling.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-C.INI - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn2FingerFlick.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn2FingerVHCoasting.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn2FingerScrolling.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-A3.INI - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn2FingerVHCoastingNB.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn3FingerFlick.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn3FingerPress.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn3FingerFlickNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn3FingerPressNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn2FingerFlick.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn2FingerScrollingNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\WRT_M7-E.INI - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn3FingerPress.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn3FingerFlick.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn4FingerFlick.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn4FingerFlickLeftRight.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn2FingerScrolling.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn3FingerFlick.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn4FFlickVNB.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn4FingerFlick.html is JS-HTML container
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn4FingerFlickLeftRight.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn4FingerFlickNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn3FingerPress.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn4FingerFlickUpDownNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn4FingerFlickUpDown.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynButtons.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn2FingerScrolling.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn4FingerFlickLeftRightNB.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn4FingerFlickUpDown.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynButtonsNB.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynAccessibility.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn4FingerFlickLeftRight.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynChiralRotate.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn4FingerFlick.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynChiralScrolling.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynButtons.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynChiralScrollingNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynChiralRotateNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynChiralTwistRotate.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Syn4FingerFlickUpDown.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynChiralRotate.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynAccessibility.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynCoastingScrollingNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynChiralVHScroll.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynCoastingScrolling.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynClicking.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynConstrainedMotion.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynButtons.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynCoverGesture.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynCoverGestureNB.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynCoverGesture.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynEdgeMotionDragging.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynEdgeMotion.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynClicking.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynEdgeMotionDraggingNB.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynEdgeMotion.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynEdgeMotionFixedSpeed.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynEdgeMotionFixedSpeedNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynEdgeMotionPointing.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynEdgeMotionPointingNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynEdgeMotionPressure.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynEdgeMotionPressureNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynCoverGesture.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynConstrainedMotionNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynFlick.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynEdgeMotionNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynEdgeMotion.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynLinearHScrolling.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynLinearHScrollingNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynLinearScrolling.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynLinearVHScroll.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynLinearScrollingNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynCOM.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynCOM32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynMomentum.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynLinearVScroll.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynMomentumNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynMomentumVHScrolling.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynMomentum.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynMomentumScrollingNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynNoButtons.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynCtrl.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynMomentumScrolling.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynMomentum.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynPalmCheck.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynMomentumVHScrollingNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynPalmCheckNB.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynMultiFingerGestures.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynMomentum.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\synpd.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\synpd.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynISDLL.dll - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynPalmCheck.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynPinchZoomNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynPinchZoom.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynCtrl32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynPivotRotate.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynMultiFingerGestures.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynPointing.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynPinchZoom.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynPinch.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynPointingNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynPivotRotateNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynPalmCheck.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynPivotRotate_ChiralRotate.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynReverseScrolling.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynPointing.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynReverseScrollingNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynPinchZoom.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynSensitivity.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynSensitivityNB.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynRotating.html is JS-HTML container
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynSensitivity.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynSlowMotionNB.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynScrolling.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynSmartSenseNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynPointing.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTapHoldToDrag.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynSlowMotion.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynSysDetect.js is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTapHoldToDragNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTapping.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynSmartSense.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynSensitivity.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTappingNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynScrolling.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynSysDetect.js - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynPivotRotate.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTapZones.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTapZonesNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynThreeFingerFlick.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTouchStykSelect.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynRotating.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTouchStykButton.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynSmartSense.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynThreeFingersDown.mpg - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTapping.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTP.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTouchStykSensitivity.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTouchStykSelect.html is JS-HTML container
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTouchStykButton.html is JS-HTML container
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTouchStykSensitivity.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTapping.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynMood.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTouchStykSelect.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTouchStykButton.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTouchStykSensitivity.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTPCOM.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTPEnhPS.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTPCo9.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTPAPI.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTwistRotate.mpg - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTwistRotate.html is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTPCOM32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTwistRotateNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynUnst.ini - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTPEnhPS32.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTwoFingerVHScroll.mpg - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTwistRotate.html - container
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTP.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynVHCoastingNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTPHelper.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynWindowConstrainedNB.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynVHCoasting.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTPCpl.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTPRes.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTwistRotate.wmv - Ok
>C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\WdfCoInstaller01009.dll is CAB archive
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\WdfCoInstaller01009.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\WdfCoInstaller01009.dll - archive
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynWindowConstrained.wmv - Ok
C:\Windows\system32\DriverStore\FileRepository\tape.inf_amd64_neutral_c6a6811d3d827dba\4mmdat.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\tape.inf_amd64_neutral_c6a6811d3d827dba\hpt4qic.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\tape.inf_amd64_neutral_c6a6811d3d827dba\mammoth.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\tape.inf_amd64_neutral_c6a6811d3d827dba\miniqic.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\tape.inf_amd64_neutral_c6a6811d3d827dba\exabyte2.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\tape.inf_amd64_neutral_c6a6811d3d827dba\ltotape.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\tape.inf_amd64_neutral_c6a6811d3d827dba\tape.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\tape.inf_amd64_neutral_c6a6811d3d827dba\qic157.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\tape.inf_amd64_neutral_c6a6811d3d827dba\tape.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\tape.inf_amd64_neutral_c6a6811d3d827dba\dlttape.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\tdibth.inf_amd64_neutral_6ad685957123daf1\tdibth.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\tdibth.inf_amd64_neutral_6ad685957123daf1\tdibth.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\tape.inf_amd64_neutral_c6a6811d3d827dba\sonyait.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\tpm.inf_amd64_neutral_d5bb6575cf91cd73\tpm.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\tpm.inf_amd64_neutral_d5bb6575cf91cd73\tpm.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\tape.inf_amd64_neutral_c6a6811d3d827dba\tandqic.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\transfercable.inf_amd64_neutral_82f4c743c8996d67\TransferCable.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\ts_generic.inf_amd64_neutral_1a5c861fdb3aab0e\ts_generic.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\tpm.inf_amd64_neutral_d5bb6575cf91cd73\tpm.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\transfercable.inf_amd64_neutral_82f4c743c8996d67\transfercable.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ts_wpdmtp.inf_amd64_neutral_daa64ca27846aa23\ts_wpdmtp.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\tsgenericusbdriver.inf_amd64_neutral_24c807694f614911\tsgenericusbdriver.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\ts_generic.inf_amd64_neutral_1a5c861fdb3aab0e\ts_generic.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\tdibth.inf_amd64_neutral_6ad685957123daf1\rfcomm.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\ts_wpdmtp.inf_amd64_neutral_daa64ca27846aa23\ts_wpdmtp.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\tsprint.inf_amd64_neutral_c48d421ad2c1e3e3\tsprint-datafile.dat - Ok
C:\Windows\system32\DriverStore\FileRepository\tsprint.inf_amd64_neutral_c48d421ad2c1e3e3\tsprint-PipelineConfig.xml - Ok
C:\Windows\system32\DriverStore\FileRepository\tsgenericusbdriver.inf_amd64_neutral_24c807694f614911\tsgenericusbdriver.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\tsprint.inf_amd64_neutral_c48d421ad2c1e3e3\tsprint.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\tsprint.inf_amd64_neutral_c48d421ad2c1e3e3\tsprint.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\tsusbhubfilter.inf_amd64_neutral_d0615d6fd67bad03\tsusbhubfilter.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\umbus.inf_amd64_neutral_2d4257afa2e35253\umbus.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\tsusbhubfilter.inf_amd64_neutral_d0615d6fd67bad03\tsusbhubfilter.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\umbus.inf_amd64_neutral_2d4257afa2e35253\umbus.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\umpass.inf_amd64_neutral_e3be362bfab667d2\umpass.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\umpass.inf_amd64_neutral_e3be362bfab667d2\umpass.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\tsgenericusbdriver.inf_amd64_neutral_24c807694f614911\TsUsbGD.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\unifhid.inf_amd64_neutral_03cbb0739029076a\unifhid.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\unifhid.inf_amd64_neutral_03cbb0739029076a\unifhid.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\unifhid.inf_amd64_neutral_03cbb0739029076a\unifhidx64.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynZMetr.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\transfercable.inf_amd64_neutral_82f4c743c8996d67\amd64\winusb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\unknown.inf_amd64_neutral_5eb6ac70dd1a3ad0\unknown.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\unknown.inf_amd64_neutral_5eb6ac70dd1a3ad0\unknown.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\usb.inf_amd64_neutral_153b489118ee37b8\usb.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\tsprint.inf_amd64_neutral_c48d421ad2c1e3e3\amd64\tsprint.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\usb.inf_amd64_neutral_153b489118ee37b8\usb.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\umbus.inf_amd64_neutral_2d4257afa2e35253\umbus.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usb.inf_amd64_neutral_269d7150439b3372\usb.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\usb.inf_amd64_neutral_269d7150439b3372\usb.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\usbaapl64.inf_amd64_neutral_319001e62f792f3e\USBAAPL64.CAT - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\Tutorial.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\umpass.inf_amd64_neutral_e3be362bfab667d2\umpass.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usbaapl64.inf_amd64_neutral_319001e62f792f3e\usbaapl64.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\usbaapl64.inf_amd64_neutral_319001e62f792f3e\usbaapl64.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\usb.inf_amd64_neutral_153b489118ee37b8\usbccgp.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usbcir.inf_amd64_neutral_379fb0c62496be6e\usbcir.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\usbcir.inf_amd64_neutral_379fb0c62496be6e\usbcir.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\usbcir.inf_amd64_neutral_379fb0c62496be6e\CIRCoInst.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\usb.inf_amd64_neutral_269d7150439b3372\usbccgp.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usbcir.inf_amd64_neutral_4ea21d8f037020da\CIRCoInst.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\usbcir.inf_amd64_neutral_4ea21d8f037020da\usbcir.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\usbcir.inf_amd64_neutral_4ea21d8f037020da\usbcir.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynTPEnh.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\usbaapl64.inf_amd64_neutral_319001e62f792f3e\usbaapl64.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usb.inf_amd64_neutral_153b489118ee37b8\usbhub.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usbcir.inf_amd64_neutral_379fb0c62496be6e\usbcir.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usbport.inf_amd64_neutral_189259810882aaea\usbport.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\usbport.inf_amd64_neutral_189259810882aaea\usbport.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\usbport.inf_amd64_neutral_189259810882aaea\usbohci.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usbport.inf_amd64_neutral_189259810882aaea\usbehci.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usbport.inf_amd64_neutral_189259810882aaea\usbhub.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usbport.inf_amd64_neutral_f935002f367d5bb0\usbd.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usbport.inf_amd64_neutral_189259810882aaea\usbd.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usbport.inf_amd64_neutral_f935002f367d5bb0\usbport.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\usbport.inf_amd64_neutral_f935002f367d5bb0\usbohci.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usbport.inf_amd64_neutral_f935002f367d5bb0\usbport.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\usbport.inf_amd64_neutral_f935002f367d5bb0\usbehci.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usbprint.inf_amd64_neutral_54948be2bc4bcdd1\usbprint.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\usb.inf_amd64_neutral_269d7150439b3372\usbhub.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usbprint.inf_amd64_neutral_54948be2bc4bcdd1\usbprint.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\usbstor.inf_amd64_neutral_0725c2806a159a9d\usbstor.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\usbport.inf_amd64_neutral_189259810882aaea\usbport.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usbport.inf_amd64_neutral_f935002f367d5bb0\usbhub.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usbstor.inf_amd64_neutral_0725c2806a159a9d\usbstor.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\usbstor.inf_amd64_neutral_26b33263a639795d\usbstor.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\usbstor.inf_amd64_neutral_26b33263a639795d\usbstor.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\usbcir.inf_amd64_neutral_4ea21d8f037020da\usbcir.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usbprint.inf_amd64_neutral_54948be2bc4bcdd1\usbprint.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\usbvideo.inf_amd64_neutral_836a6716cd56c692\usbvideo.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\usbvideo.inf_amd64_neutral_836a6716cd56c692\usbvideo.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\usbvideo.inf_amd64_neutral_eac3887e52f72113\usbvideo.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\usbvideo.inf_amd64_neutral_eac3887e52f72113\usbvideo.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\usbport.inf_amd64_neutral_189259810882aaea\usbuhci.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\v_mscdsc.inf_amd64_neutral_8b1e6b55729c3283\V_MSCDSC.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\usbport.inf_amd64_neutral_f935002f367d5bb0\usbuhci.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\stwrt64.inf_amd64_neutral_7b038477904cedb2\IDTNGUI.exe - Ok
C:\Windows\system32\DriverStore\FileRepository\v_mscdsc.inf_amd64_neutral_8b1e6b55729c3283\v_mscdsc.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\vhdmp.inf_amd64_neutral_c3910bbf4fbccf97\vhdmp.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\usbport.inf_amd64_neutral_f935002f367d5bb0\usbport.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\vhdmp.inf_amd64_neutral_c3910bbf4fbccf97\vhdmp.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\volsnap.inf_amd64_neutral_7499a4fac85b39fc\volsnap.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\volume.inf_amd64_neutral_df8bea40ac96ca21\volume.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\volsnap.inf_amd64_neutral_7499a4fac85b39fc\volsnap.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\volume.inf_amd64_neutral_df8bea40ac96ca21\volume.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\usbstor.inf_amd64_neutral_0725c2806a159a9d\USBSTOR.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\volume.inf_amd64_neutral_e7c4cd5b40e03494\volume.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\volume.inf_amd64_neutral_e7c4cd5b40e03494\volume.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\vsmraid.inf_amd64_neutral_be11b7aaa746e92d\vsmraid.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\usbvideo.inf_amd64_neutral_836a6716cd56c692\usbvideo.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\vsmraid.inf_amd64_neutral_be11b7aaa746e92d\vsmraid.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\usbstor.inf_amd64_neutral_26b33263a639795d\USBSTOR.SYS - Ok
C:\Windows\system32\DriverStore\FileRepository\wave.inf_amd64_neutral_7a0a0b166f55e1aa\wave.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wave.inf_amd64_neutral_7a0a0b166f55e1aa\wave.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wbf_vfs_0018.inf_amd64_neutral_49317f3bc51fe689\wbf_vfs_0018.cat - Ok
C:\Windows\system32\DriverStore\FileRepository\wbf_vfs_0018.inf_amd64_neutral_49317f3bc51fe689\wbf_vfs_0018.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wbf_vfs_0018.inf_amd64_neutral_49317f3bc51fe689\wbf_vfs_0018.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wceisvista.inf_amd64_neutral_3500779911f7f3ca\WceISVista.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wceisvista.inf_amd64_neutral_3500779911f7f3ca\wceisvista.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wd.inf_amd64_neutral_759109899b486d47\wd.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wd.inf_amd64_neutral_759109899b486d47\wd.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\vsmraid.inf_amd64_neutral_be11b7aaa746e92d\vsmraid.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\wdma_usb.inf_amd64_neutral_7bb325bca8ea1218\wdma_usb.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wdma_usb.inf_amd64_neutral_7bb325bca8ea1218\wdma_usb.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\vhdmp.inf_amd64_neutral_c3910bbf4fbccf97\vhdmp.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\wdma_usb.inf_amd64_neutral_d9e9f15c971c38d4\wdma_usb.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wdma_usb.inf_amd64_neutral_d9e9f15c971c38d4\wdma_usb.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wd.inf_amd64_neutral_759109899b486d47\wd.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\wdmaudio.inf_amd64_neutral_423894ded0ba8fdf\drmk.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\wdma_usb.inf_amd64_neutral_7bb325bca8ea1218\USBAUDIO.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\wdmaudio.inf_amd64_neutral_423894ded0ba8fdf\wdmaudio.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wdmaudio.inf_amd64_neutral_423894ded0ba8fdf\drmkaud.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\volume.inf_amd64_neutral_e7c4cd5b40e03494\volsnap.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\wdmaudio.inf_amd64_neutral_423894ded0ba8fdf\wdmaudio.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\volume.inf_amd64_neutral_df8bea40ac96ca21\volsnap.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr002.inf_amd64_neutral_b4ea26a49ad66560\wiabr002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr002.inf_amd64_neutral_b4ea26a49ad66560\wiabr002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wdmaudio.inf_amd64_neutral_423894ded0ba8fdf\portcls.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr002.inf_amd64_neutral_b4ea26a49ad66560\BrUs2Sti.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr004.inf_amd64_neutral_b1d90b3749c5e6a6\wiabr004.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr004.inf_amd64_neutral_b1d90b3749c5e6a6\BrUs2Sti.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr004.inf_amd64_neutral_b1d90b3749c5e6a6\wiabr004.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wdmaudio.inf_amd64_neutral_423894ded0ba8fdf\SysFxUI.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr005.inf_amd64_neutral_e14a0514f37611d8\wiabr005.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr005.inf_amd64_neutral_e14a0514f37611d8\BrUs2Sti.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr005.inf_amd64_neutral_e14a0514f37611d8\wiabr005.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr005.inf_amd64_neutral_e14a0514f37611d8\Brmf3wia.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr004.inf_amd64_neutral_b1d90b3749c5e6a6\Brmf3wia.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr002.inf_amd64_neutral_b4ea26a49ad66560\Brmf3wia.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr006.inf_amd64_neutral_0232ca4f23224d01\wiabr006.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr006.inf_amd64_neutral_0232ca4f23224d01\Brmf3wia.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr006.inf_amd64_neutral_0232ca4f23224d01\wiabr006.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr006.inf_amd64_neutral_0232ca4f23224d01\BrUs2Sti.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr006.inf_amd64_neutral_0232ca4f23224d01\brmsl09a.icm - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr007.inf_amd64_neutral_442d902f3f3dd5b7\wiabr007.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr007.inf_amd64_neutral_442d902f3f3dd5b7\wiabr007.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr007.inf_amd64_neutral_442d902f3f3dd5b7\BrUs2Sti.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr008.inf_amd64_neutral_27d1c9a28eac4eed\wiabr008.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr008.inf_amd64_neutral_27d1c9a28eac4eed\BrUs2Sti.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr008.inf_amd64_neutral_27d1c9a28eac4eed\wiabr008.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr007.inf_amd64_neutral_442d902f3f3dd5b7\Brmf3wia.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr009.inf_amd64_neutral_2d7b3edfda95df40\wiabr009.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr009.inf_amd64_neutral_2d7b3edfda95df40\wiabr009.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr008.inf_amd64_neutral_27d1c9a28eac4eed\Brmf3wia.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr009.inf_amd64_neutral_2d7b3edfda95df40\BrUs2Sti.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr00a.inf_amd64_neutral_6033065925bcc882\brmsl07a.bin - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr00a.inf_amd64_neutral_6033065925bcc882\wiabr00a.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr009.inf_amd64_neutral_2d7b3edfda95df40\Brmf3wia.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr00a.inf_amd64_neutral_6033065925bcc882\wiabr00a.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr00a.inf_amd64_neutral_6033065925bcc882\BrUs2Sti.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00a.inf_amd64_neutral_163313056d8f34ab\CNC970W.DAT - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr00a.inf_amd64_neutral_6033065925bcc882\Brmf3wia.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiabr00a.inf_amd64_neutral_6033065925bcc882\brmsl07a.icm - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00a.inf_amd64_neutral_163313056d8f34ab\CNFRAE.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\usbvideo.inf_amd64_neutral_eac3887e52f72113\usbvideo.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00a.inf_amd64_neutral_163313056d8f34ab\CNFRAC.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00a.inf_amd64_neutral_163313056d8f34ab\CNFRAH.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00a.inf_amd64_neutral_163313056d8f34ab\CNFRAD.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wdmaudio.inf_amd64_neutral_423894ded0ba8fdf\WMALFXGFXDSP.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00a.inf_amd64_neutral_163313056d8f34ab\CNHL520.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00a.inf_amd64_neutral_163313056d8f34ab\CNHL970.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00a.inf_amd64_neutral_163313056d8f34ab\CNHL610.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00a.inf_amd64_neutral_163313056d8f34ab\CNHLX700.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00a.inf_amd64_neutral_163313056d8f34ab\CNHMWL.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00a.inf_amd64_neutral_163313056d8f34ab\wiaca00a.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00a.inf_amd64_neutral_163313056d8f34ab\CNHMWL6.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00a.inf_amd64_neutral_163313056d8f34ab\wiaca00a.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNC172DD.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNC980W.DAT - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNFRAR.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNC980N.DAT - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNFRAI.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNFRAJ.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNFRAK.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00a.inf_amd64_neutral_163313056d8f34ab\CNHI07A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNHI07A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00a.inf_amd64_neutral_163313056d8f34ab\CNHW07A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNHL190.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNHI08S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNHI08A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNHL08A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNHW07A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNHMCA.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNHMCA6.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\wiaca00b.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\wiaca00b.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNHL7600.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNHLX850.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\CNFRAA.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNHW08A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00b.inf_amd64_neutral_1aaa057d3d52ea43\CNHW08S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\CNFRA8.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\CNFRA9.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\CNHI06A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\CNHI07A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\CNFRAB.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\CNFRAF.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\CNHL220.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\CNFRAG.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\CNHLX310.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\wiaca00c.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\CNHLX300.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\CNHL470.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\wiaca00c.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00d.inf_amd64_neutral_2c3623fa97b0c28e\CNFRA0.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00d.inf_amd64_neutral_2c3623fa97b0c28e\CNFRA1.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\CNHL140.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\CNHW07A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\CNHL210.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00d.inf_amd64_neutral_2c3623fa97b0c28e\CNHI06A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00d.inf_amd64_neutral_2c3623fa97b0c28e\CNFRA2.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00d.inf_amd64_neutral_2c3623fa97b0c28e\wiaca00d.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00d.inf_amd64_neutral_2c3623fa97b0c28e\wiaca00d.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00d.inf_amd64_neutral_2c3623fa97b0c28e\CNHL460.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00d.inf_amd64_neutral_2c3623fa97b0c28e\CNHL180.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00c.inf_amd64_neutral_27f4ad26fea72eb1\CNHW06A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00d.inf_amd64_neutral_2c3623fa97b0c28e\CNHW06A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00d.inf_amd64_neutral_2c3623fa97b0c28e\CNHL160.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wdma_usb.inf_amd64_neutral_d9e9f15c971c38d4\USBAUDIO.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00e.inf_amd64_neutral_5a376e6a7cb007d5\CNHI06A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00e.inf_amd64_neutral_5a376e6a7cb007d5\CNFRA5.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00e.inf_amd64_neutral_5a376e6a7cb007d5\CNFRA4.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00e.inf_amd64_neutral_5a376e6a7cb007d5\CNHL600.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00e.inf_amd64_neutral_5a376e6a7cb007d5\wiaca00e.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00e.inf_amd64_neutral_5a376e6a7cb007d5\CNHL600R.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00e.inf_amd64_neutral_5a376e6a7cb007d5\wiaca00e.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00e.inf_amd64_neutral_5a376e6a7cb007d5\CNFRA6.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00e.inf_amd64_neutral_5a376e6a7cb007d5\CNFRA7.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\CNFMP53R.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00e.inf_amd64_neutral_5a376e6a7cb007d5\CNHW06A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00e.inf_amd64_neutral_5a376e6a7cb007d5\CNHL960.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\CNFMP95R.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00e.inf_amd64_neutral_5a376e6a7cb007d5\CNHL810.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wbf_vfs_0018.inf_amd64_neutral_49317f3bc51fe689\X64\wbf_vfs_0018.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\CNHI06S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\CNFMP8RR.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\CNHL530.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\CNHL800.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\CNHL510.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\CNFRA3.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\CNHI05A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\CNHI06A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\CNC172ED.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\wiaca00f.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\CNFMP80R.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\wiaca00f.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\CNC1730D.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\CNC1731D.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\CNC172FD.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\CNC1733D.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\CNHW06A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\CNC1732D.TBL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\CNHW05A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\CNHW06S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\CNHL950.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\CNFRAO.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\CNHI08A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\CNFRAN.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\CNHMCA.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\CNHMCA6.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\CNHL08A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\CNFRAQ.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\CNFRAM.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\wiaca00i.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\CNHW08A.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\wiaca00i.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\CNFRAL.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00i.inf_amd64_neutral_de104aaa48ee4b00\CNFRAP.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaca00f.inf_amd64_neutral_f7f7e179d99acc58\CNHL800R.DLL - Ok
>C:\Windows\system32\DriverStore\FileRepository\unifhid.inf_amd64_neutral_03cbb0739029076a\x64\LogiLDA.DLL is BINARYRES container
>C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHC750S.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHIPRO.DLL - Ok
>C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHL500.DLL - packed by PESTUB
>>C:\Windows\system32\DriverStore\FileRepository\unifhid.inf_amd64_neutral_03cbb0739029076a\x64\LogiLDA.DLL\data001 is JS-HTML container
>C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHL730S.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\synpd.inf_amd64_neutral_93ccef322b34258a\SynCntxt.rtf - Ok
>C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHL750S.DLL - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHC370S.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHC750S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHP170S.ICC - Ok
>>C:\Windows\system32\DriverStore\FileRepository\unifhid.inf_amd64_neutral_03cbb0739029076a\x64\LogiLDA.DLL\data002 is JS-HTML container
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHL500.DLL - Ok
>C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHL170S.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\unifhid.inf_amd64_neutral_03cbb0739029076a\x64\LogiLDA.DLL - container
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHP500.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\usbaapl64.inf_amd64_neutral_319001e62f792f3e\usbaaplrc.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHL750S.DLL - Ok
>C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHL370S.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHC370S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHP750S.ICC - Ok
>C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHC730S.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHL170S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHP830.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHP370S.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHP760S.ICC - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHL370S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHL730S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHL830.DLL - Ok
>C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHW500.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHC730S.DLL - Ok
>C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHW370S.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHP730S.ICC - Ok
>C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHW750S.DLL - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHW170S.DLL - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHW760S.DLL - packed by PESTUB
>C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHW730S.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHP900.ICC - Ok
>C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHW900.DLL - packed by PESTUB
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHW500.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHW370S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaep002.inf_amd64_neutral_0a982dec66379cb0\wiaep002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHW750S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHW760S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\wiacn001.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaep002.inf_amd64_neutral_0a982dec66379cb0\wiaep002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHW170S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\wiacn001.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHW730S.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHW900.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaep003.inf_amd64_neutral_c2a98813147bf34e\wiaep003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiahp001.inf_amd64_neutral_aee49cdf3b352e58\wiahp001.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiacn001.inf_amd64_neutral_b7a0b2f53d745b5a\CNHW830.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiahp001.inf_amd64_neutral_aee49cdf3b352e58\wiahp001.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaep003.inf_amd64_neutral_c2a98813147bf34e\wiaep003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaep003.inf_amd64_neutral_c2a98813147bf34e\ep0icn1.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaep003.inf_amd64_neutral_c2a98813147bf34e\ep0icd1.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaky002.inf_amd64_neutral_b898f5982403f3cb\wiaky002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaep003.inf_amd64_neutral_c2a98813147bf34e\ep0icb1.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaky002.inf_amd64_neutral_b898f5982403f3cb\kyweds10.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaep003.inf_amd64_neutral_c2a98813147bf34e\ep0icn2.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaky002.inf_amd64_neutral_b898f5982403f3cb\kywdds10.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx002.inf_amd64_neutral_71f4aacee1aa9f06\wialx002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaky002.inf_amd64_neutral_b898f5982403f3cb\wiaky002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaep002.inf_amd64_neutral_0a982dec66379cb0\ep0icd0.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx002.inf_amd64_neutral_71f4aacee1aa9f06\wialx002.PNF - Ok
>C:\Windows\system32\DriverStore\FileRepository\wiaky002.inf_amd64_neutral_b898f5982403f3cb\kywuds10.dll is ZLIB container
C:\Windows\system32\DriverStore\FileRepository\wiaep003.inf_amd64_neutral_c2a98813147bf34e\ep0icn3.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx003.inf_amd64_neutral_db618863f9347f9a\wialx003.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx003.inf_amd64_neutral_db618863f9347f9a\wialx003.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx002.inf_amd64_neutral_71f4aacee1aa9f06\lxa1WIA.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiahp001.inf_amd64_neutral_aee49cdf3b352e58\hpljbfig.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx004.inf_amd64_neutral_0a3a62ae6ed43127\wialx004.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx004.inf_amd64_neutral_0a3a62ae6ed43127\wialx004.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx002.inf_amd64_neutral_71f4aacee1aa9f06\lxa1comc.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx004.inf_amd64_neutral_0a3a62ae6ed43127\lxa3WIA.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx005.inf_amd64_neutral_5304c93e2193f237\wialx005.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx003.inf_amd64_neutral_db618863f9347f9a\lxa2iobj.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx003.inf_amd64_neutral_db618863f9347f9a\lxa2WIA.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx005.inf_amd64_neutral_5304c93e2193f237\wialx005.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx006.inf_amd64_neutral_ae607a72b46f9cfc\wialx006.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx005.inf_amd64_neutral_5304c93e2193f237\lxa4WIA.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx006.inf_amd64_neutral_ae607a72b46f9cfc\wialx006.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx003.inf_amd64_neutral_db618863f9347f9a\lxa2usb1.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SA4300.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx005.inf_amd64_neutral_5304c93e2193f237\lxa4drs.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SA4500.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx006.inf_amd64_neutral_ae607a72b46f9cfc\lxa5drs.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SA216x.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SA4725.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SA4500W.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SA4x24.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaky002.inf_amd64_neutral_b898f5982403f3cb\kywuds10.dll - container
C:\Windows\system32\DriverStore\FileRepository\wialx006.inf_amd64_neutral_ae607a72b46f9cfc\lxa5WIA.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SA4x26.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx004.inf_amd64_neutral_0a3a62ae6ed43127\lxa3usb1.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SA6x45.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SA6x22.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SA4x28.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SA6240.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SA5635.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SA5935.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SA6200.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\wiasa002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx003.inf_amd64_neutral_db618863f9347f9a\lxa2comc.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SA8380.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\wiasa002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaxx002.inf_amd64_neutral_fbe080a7dd77c4a3\wiaxx002.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaxx002.inf_amd64_neutral_fbe080a7dd77c4a3\wiaxx002.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx004.inf_amd64_neutral_0a3a62ae6ed43127\lxa3iobj.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SaImgFlt.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SaErHdlr.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SA3170.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaxx002.inf_amd64_neutral_fbe080a7dd77c4a3\xrWPdeft.xst - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaxx002.inf_amd64_neutral_fbe080a7dd77c4a3\xrWCbgnd.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SA6x55.icc - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaxx002.inf_amd64_neutral_fbe080a7dd77c4a3\xrWCdev.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaxx002.inf_amd64_neutral_fbe080a7dd77c4a3\xrWPpb4.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaxx002.inf_amd64_neutral_fbe080a7dd77c4a3\xrWCtmg2.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\windowssideshowenhanceddriver.inf_amd64_neutral_184a2ef2a8f57c33\windowssideshowenhanceddriver.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\windowssideshowenhanceddriver.inf_amd64_neutral_184a2ef2a8f57c33\WindowsSideShowEnhancedDriver.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaxx002.inf_amd64_neutral_fbe080a7dd77c4a3\xrWPcpst.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\windowssideshowenhanceddriver.inf_amd64_neutral_184a2ef2a8f57c33\AuxiliaryDisplayEnhancedDriver.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaxx002.inf_amd64_neutral_fbe080a7dd77c4a3\xrWPpb3.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\winusb.inf_amd64_neutral_6cb50ae9f480775b\winusb.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\winusb.inf_amd64_neutral_6cb50ae9f480775b\winusb.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wpdcomp.inf_amd64_neutral_11bbf54c8508434e\wpdcomp.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx004.inf_amd64_neutral_0a3a62ae6ed43127\lxa3comc.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SaSegFlt.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wpdcomp.inf_amd64_neutral_11bbf54c8508434e\wpdcomp.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wpdfs.inf_amd64_neutral_fc4ebadff3a40ae4\WpdFs.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wpdfs.inf_amd64_neutral_fc4ebadff3a40ae4\wpdfs.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wialx002.inf_amd64_neutral_71f4aacee1aa9f06\lxa1usb1.DLL - Ok
C:\Windows\system32\DriverStore\FileRepository\wpdmtp.inf_amd64_neutral_28f06ca2e38e8979\wpdmtp.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaxx002.inf_amd64_neutral_fbe080a7dd77c4a3\xrWPcoin.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wpdcomp.inf_amd64_neutral_11bbf54c8508434e\Wpdcomp.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wpdmtp.inf_amd64_neutral_28f06ca2e38e8979\wpdmtp.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\winusb.inf_amd64_neutral_6cb50ae9f480775b\winusb.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\wiasa002.inf_amd64_neutral_6429a42f1243419a\SaMinDrv.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wpdmtphw.inf_amd64_neutral_a7a22bb0bb81abb0\wpdmtphw.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wpdmtphw.inf_amd64_neutral_a7a22bb0bb81abb0\wpdmtphw.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wsdprint.inf_amd64_neutral_f91980f20f3112ed\WSDPrint.Inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wsdprint.inf_amd64_neutral_f91980f20f3112ed\wsdprint.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wsdscdrv.inf_amd64_neutral_47406488f9e8d5b8\WSDScDrv.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wsdscdrv.inf_amd64_neutral_47406488f9e8d5b8\wsdscdrv.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wpdmtp.inf_amd64_neutral_28f06ca2e38e8979\WpdMtpbt.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wsdprint.inf_amd64_neutral_f91980f20f3112ed\WSDPrint.sys - Ok
C:\Windows\system32\DriverStore\FileRepository\wpdmtp.inf_amd64_neutral_28f06ca2e38e8979\WpdMtpUS.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wudfusbcciddriver.inf_amd64_neutral_adc3e4acb1046b4b\wudfusbcciddriver.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wpdmtp.inf_amd64_neutral_28f06ca2e38e8979\WpdMtpIP.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaxx002.inf_amd64_neutral_fbe080a7dd77c4a3\xrWPusd.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wudfusbcciddriver.inf_amd64_neutral_adc3e4acb1046b4b\WUDFUsbccidDriver.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\wpdmtp.inf_amd64_neutral_28f06ca2e38e8979\WpdMtp.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wpdfs.inf_amd64_neutral_fc4ebadff3a40ae4\WpdFs.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\xcbdav.inf_amd64_neutral_cf80e4da1c95e6e2\xcbdav.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\xcbdav.inf_amd64_neutral_cf80e4da1c95e6e2\xcbdav.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\xnacc.inf_amd64_neutral_13c4e272a96185a1\xnacc.inf - Ok
C:\Windows\system32\DriverStore\FileRepository\xnacc.inf_amd64_neutral_13c4e272a96185a1\xnacc.PNF - Ok
C:\Windows\system32\DriverStore\FileRepository\wiaxx002.inf_amd64_neutral_fbe080a7dd77c4a3\xrWPcpl.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\xcbdav.inf_amd64_neutral_cf80e4da1c95e6e2\xccpx64.ax - Ok
C:\Windows\system32\DriverStore\FileRepository\wsdscdrv.inf_amd64_neutral_47406488f9e8d5b8\WSDScDrv.dll - Ok
C:\Windows\system32\DriverStore\FileRepository\wudfusbcciddriver.inf_amd64_neutral_adc3e4acb1046b4b\WUDFUsbccidDriver.dll - Ok
C:\Windows\system32\DriverStore\Temp\{522f6bf6-ae20-0f66-d982-a746d010852a}\prnms001.cat - Ok
C:\Windows\system32\DriverStore\nl-NL\61883.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\acpipmi.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\1394.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\adp94xx.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\adpahci.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\acpi.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\agp.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\AMDSBS.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\amdsata.inf_loc - Ok
C:\Windows\system32\DriverStore\FileRepository\xcbdav.inf_amd64_neutral_cf80e4da1c95e6e2\xcmemVx64.sys - Ok
C:\Windows\system32\DriverStore\nl-NL\adpu320.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\arc.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\avc.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\atiilhag.inf_loc - Ok
C:\Windows\system32\DriverStore\FileRepository\xcbdav.inf_amd64_neutral_cf80e4da1c95e6e2\xcbdaVx64.sys - Ok
C:\Windows\system32\DriverStore\nl-NL\avmx64c.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\blbdrive.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\bda.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\brmfcsto.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\brmfcmf.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\brmfport.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\brmfcwia.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\arcsas.inf_loc - Ok
C:\Windows\system32\DriverStore\FileRepository\wpdmtp.inf_amd64_neutral_28f06ca2e38e8979\WpdMtpDr.dll - Ok
C:\Windows\system32\DriverStore\nl-NL\bthpan.inf_loc - Ok
C:\Windows\system32\DriverStore\FileRepository\xnacc.inf_amd64_neutral_13c4e272a96185a1\xnacc.sys - Ok
C:\Windows\system32\DriverStore\nl-NL\circlass.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\cdrom.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\brmfcumd.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\bthmtpenum.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\cpu.inf_loc - Ok
C:\Windows\system32\DriverStore\FileRepository\xcbdav.inf_amd64_neutral_cf80e4da1c95e6e2\xchalVx64.sys - Ok
C:\Windows\system32\DriverStore\nl-NL\brmfcmdm.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\crcdisk.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\DigitalMediaDevice.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\dc21x4vm.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\EAPHost.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\display.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\EhStorCertDrv.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\divacx64.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\faxca003.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\bth.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\battery.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\CompositeBus.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\faxcn002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\fdc.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\faxcn001.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\dot4prt.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\bthspp.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\bthprint.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\hdaudbus.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\hal.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\hiddigi.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\disk.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\hdaudss.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\hidserv.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\flpydisk.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\EhStorPwdDrv.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\hidbth.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\gameport.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\dot4.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\elxstor.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\hidirkbd.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\hidir.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\hdaudio.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\hpoa1ss.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\hpoa1sd.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\iirsp2.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\hpsamd.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\iastorv.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\iirsp.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\hpoa1nd.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\hpoa1so.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\ipmidrv.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\image.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\lltdio.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\input.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\igdlh.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\ksfilter.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\iscsi.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\ks.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\keyboard.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mdmbr004.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mdmbr002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\kscaptur.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mchgr.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mdmbr005.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\Mcx2.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mdmbr008.inf_loc - Ok
C:\Windows\system32\DriverStore\FileRepository\xcbdav.inf_amd64_neutral_cf80e4da1c95e6e2\xcfeVx64.sys - Ok
C:\Windows\system32\DriverStore\nl-NL\mdmcxpv6.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mdmbr00a.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\lsi_sas2.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\lsi_scsi.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\lsi_fc.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\lsi_sas.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mdmbtmdm.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mdmbr007.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mdmbr006.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mdmirmdm.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mdmgen.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mdmhayes.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\machine.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mdmmoto1.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\megasas2.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mdmusrk1.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mdmvv.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\memory.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mf.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mdmcxhv6.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\modemcsa.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\megasas.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\megasr.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\MTConfig.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\multiprt.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\monitor.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\ndiscap.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\ndisuio.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\msclmd.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\net1kx64.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mpio.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\msdsm.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\NET8185.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\msports.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\net8187bv64.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netb57va.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mshdc.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netbvbda.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\msdri.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\nete1g3e.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\msmouse.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\net44amd.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netevbda.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\msdv.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\mstape.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\net8187se64.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netbc664.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netg664.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netimm.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netirda.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netathrx.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netl160a.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\nete1e3e.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netk57a.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netl260a.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netloop.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netmscli.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netip6.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netmyk00.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netl1c64.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netnwifi.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netpacer.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netpgm.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\net1qx64.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netnvma.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netr28x.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netr28ux.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netrass.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netl1e64.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netr7364.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netserv.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netrndis.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netsstpa.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\neteFE3e.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netsstpt.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netrasa.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netvwififlt.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netrast.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\nettcpip.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\nettun.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netrtx64.INF_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netw5v64.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\ntprint.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\net1yx64.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netbxnda.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netxfx64.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netrtl64.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\nulhpopr.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnbr002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\nvraid.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netvg62a.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\pcmcia.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\nfrd960.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnbr003.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\nv_LH.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnbr004.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnbr005.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnbr006.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnbr008.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netvfx64.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnbr009.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnbr00a.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnbr007.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnca003.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netvwifimp.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnca00d.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnca00c.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnca00e.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnca00b.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnca00a.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnca00h.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnca00f.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnca00x.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netvwifibus.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnca00i.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnca00y.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netnvm64.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnep002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnep003.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnca00z.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnep004.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnep00d.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnep00e.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnep00a.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnep005.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnca00g.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnep00c.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnep00b.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\netxex64.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnep00g.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnep00l.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnfx002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnep00f.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prngt002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnge001.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prngt003.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnhp004.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prngt004.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnhp003.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnin002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnhp005.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnkm002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnin004.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnkm003.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnkm004.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnkm005.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnky004.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnky002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnky003.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnky009.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnky008.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnle002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnky007.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnle004.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnky006.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnky005.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnle003.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx006.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx004.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnin003.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnhp002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx005.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx00b.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx008.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx003.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx009.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx00c.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx007.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx00w.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx00d.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx00z.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx00e.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx00a.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx00y.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnnr003.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx00v.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnnr002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnrc002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnlx00x.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnms002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnrc003.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnod002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnrc005.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnnr004.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnrc006.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnrc00b.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnok002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnrc004.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnrc007.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnsa002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnrc00c.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnrc00a.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnsh002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnsv003.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnsv002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnso002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnsv004.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnts002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnts003.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\prnxx002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\ql40xx2.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\sbp2.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\rawsilo.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\SCRAWPDO.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\rspndr.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\rndiscmp.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\ql40xx.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\ql2300.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\qd3x64.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\ramdisk.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\ricoh.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\scsidev.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\sdbus.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\tsprint.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\tape.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\umbus.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\umpass.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\unknown.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\sffdisk.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\TransferCable.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\sisraid2.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\STEXSTOR.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\sti.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\sisraid4.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\smartcrd.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\SensorsAlsDriver.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\tpm.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\tdibth.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\ts_wpdmtp.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\usbcir.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\usb.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\vhdmp.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\volsnap.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\vsmraid.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\volume.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\V_MSCDSC.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\usbprint.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\WceISVista.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\usbport.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wave.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiabr005.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiabr006.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiabr004.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wdmaudio.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiabr002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiabr007.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wd.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\usbvideo.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiabr009.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiabr008.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiaca00b.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiabr00a.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiaca00a.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\usbstor.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiaca00d.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiaky002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wdma_usb.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiaep003.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiahp001.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiaca00i.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wialx002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiaca00c.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiaca00e.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wialx005.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wialx006.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wialx004.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wialx003.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiaxx002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\winusb.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiaca00f.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiaep002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wpdmtphw.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wpdmtp.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\WindowsSideShowEnhancedDriver.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiasa002.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\WSDScDrv.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wpdcomp.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\xnacc.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\WUDFUsbccidDriver.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wpdfs.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\wiacn001.inf_loc - Ok
C:\Windows\system32\DriverStore\nl-NL\WSDPrint.inf_loc - Ok
C:\Windows\system32\IME\IMEJP10\IMJPDADM.EXE - Ok
C:\Windows\system32\IME\IMEJP10\IMJPDCTP.DLL - Ok
C:\Windows\system32\IME\IMEJP10\IMJPUEX.EXE - Ok
C:\Windows\system32\IME\IMEJP10\IMJPDSVR.EXE - Ok
C:\Windows\system32\IME\IMEJP10\IMJPMGR.EXE - Ok
C:\Windows\system32\IME\IMEJP10\imjpuexc.exe - Ok
C:\Windows\system32\IME\IMEJP10\imjppdmg.exe - Ok
C:\Windows\system32\IME\IMEJP10\APPLETS\IMJPCLST.XML - Ok
C:\Windows\system32\IME\IMEJP10\IMJPCD.DLL - Ok
C:\Windows\system32\IME\IMEJP10\IMJPAPI.DLL - Ok
C:\Windows\system32\IME\IMEJP10\imjputyc.dll - Ok
C:\Windows\system32\IME\IMEJP10\APPLETS\IMJPKDIC.DLL - Ok
C:\Windows\system32\IME\IMEJP10\APPLETS\IMJPCAC.DLL - Ok
C:\Windows\system32\IME\IMESC5\IMSCPROP.exe - Ok
C:\Windows\system32\IME\IMESC5\ImSCCfg.DLL - Ok
C:\Windows\system32\IME\IMEJP10\APPLETS\IMJPSKF.DLL - Ok
C:\Windows\system32\IME\IMEJP10\IMJPDCT.EXE - Ok
C:\Windows\system32\IME\IMESC5\PMIGRATE.dll - Ok
C:\Windows\system32\IME\IMEJP10\imjpcus.dll - Ok
C:\Windows\system32\IME\IMESC5\ImSCCore.dll - Ok
C:\Windows\system32\IME\IMETC10\IMTCCFG.DLL - Ok
C:\Windows\system32\IME\IMETC10\IMTCPROP.exe - Ok
>C:\Windows\system32\IME\IMESC5\IMSCTIP.dll - packed by BINARYRES
C:\Windows\system32\IME\IMEJP10\IMJPTIP.DLL - Ok
>C:\Windows\system32\IME\IMETC10\imtcui.DLL - packed by BINARYRES
>C:\Windows\system32\IME\IMESC5\imscui.DLL - packed by BINARYRES
C:\Windows\system32\IME\IMEJP10\APPLETS\IMJPCLST.DLL - Ok
C:\Windows\system32\IME\IMETC10\applets\IMTCDIC.dll - Ok
C:\Windows\system32\IME\IMESC5\applets\PINTLCSA.dll - Ok
>C:\Windows\system32\IME\IMETC10\IMTCTIP.dll - packed by BINARYRES
C:\Windows\system32\IME\IMESC5\IMSCTIP.dll - Ok
C:\Windows\system32\IME\IMESC5\imscui.DLL - Ok
C:\Windows\system32\IME\IMETC10\imtcui.DLL - Ok
C:\Windows\system32\IME\imekr8\imkrapi.dll - Ok
C:\Windows\system32\IME\IMETC10\IMTCTIP.dll - Ok
C:\Windows\system32\IME\imekr8\applets\imkrskf.dll - Ok
C:\Windows\system32\IME\imekr8\applets\imkrcac.dll - Ok
C:\Windows\system32\IME\imekr8\dicts\imkrhjd.dll - Ok
C:\Windows\system32\IME\shared\imecfm.dll - Ok
C:\Windows\system32\IME\IMETC10\IMTCCORE.DLL - Ok
C:\Windows\system32\IME\shared\IMEAPIS.DLL - Ok
C:\Windows\system32\IME\imekr8\imkrtip.dll - Ok
C:\Windows\system32\IME\imekr8\imkrudt.dll - Ok
C:\Windows\system32\IME\shared\IMEPADSM.DLL - Ok
C:\Windows\system32\IME\shared\imever.dll - Ok
C:\Windows\system32\IME\shared\IMCCPHR.exe - Ok
C:\Windows\system32\IME\shared\res\padrs404.dll - Ok
C:\Windows\system32\IME\shared\IMJKAPI.DLL - Ok
C:\Windows\system32\LogFiles\AIT\AitEventLog.etl.001 - Ok
C:\Windows\system32\IME\shared\IMEPADSV.EXE - Ok
C:\Windows\system32\IME\shared\IMETIP.DLL - Ok
C:\Windows\system32\LogFiles\AIT\AitEventLog.etl.002 - Ok
C:\Windows\system32\LogFiles\AIT\AitEventLog.etl.003 - Ok
C:\Windows\system32\LogFiles\AIT\AitEventLog.etl.004 - Ok
C:\Windows\system32\LogFiles\AIT\AitEventLog.etl.005 - Ok
C:\Windows\system32\IME\shared\res\padrs412.dll - Ok
C:\Windows\system32\IME\shared\res\padrs411.dll - Ok
C:\Windows\system32\LogFiles\Scm\044a6734-e90e-4f8f-b357-b2dc8ab3b5ec - Ok
C:\Windows\system32\LogFiles\Scm\00a1c74f-524c-413a-b98c-95ac9a064968 - Ok
C:\Windows\system32\IME\shared\MSCAND20.DLL - Ok
C:\Windows\system32\LogFiles\Scm\097f621f-7968-47b2-a4cb-eb99a37b323a - Ok
C:\Windows\system32\LogFiles\Scm\088482fa-65b8-4e17-9abf-1dcd48e8d373 - Ok
C:\Windows\system32\LogFiles\Scm\12f82f95-de40-4cbd-b2ec-9020f694dd3d - Ok
C:\Windows\system32\LogFiles\Scm\1985d33f-a34d-4097-9958-c173b29779c9 - Ok
C:\Windows\system32\LogFiles\Scm\18605e92-696e-49fc-9682-a335219ec350 - Ok
C:\Windows\system32\LogFiles\Scm\1f7b7221-ae8f-44f3-ba82-f7d260f51964 - Ok
C:\Windows\system32\LogFiles\Scm\23bcc3b4-46f8-4d11-a2ec-a0bddc83e9b0 - Ok
C:\Windows\system32\LogFiles\Scm\28011108-68df-4c73-b91b-57427d501bba - Ok
C:\Windows\system32\LogFiles\Scm\2470470f-2634-478e-b181-571e98a789bb - Ok
C:\Windows\system32\LogFiles\HTTPERR\httperr1.log - Ok
C:\Windows\system32\LogFiles\Scm\2f57269b-1e09-4e2d-ab1e-b0fdac7d279c - Ok
C:\Windows\system32\LogFiles\Scm\33fea13a-f438-4d48-ba14-da3dda27818a - Ok
C:\Windows\system32\LogFiles\Scm\1eab1079-2e3e-4b99-927d-d99860fc1470 - Ok
C:\Windows\system32\LogFiles\Scm\37aab2e9-1325-49d8-821f-23413413ecc5 - Ok
C:\Windows\system32\LogFiles\Scm\47536d45-eeec-4bdc-8183-a4dc1f8da9e4 - Ok
C:\Windows\system32\LogFiles\Scm\4bd182b7-f219-4760-b4d0-469db306ad2f - Ok
C:\Windows\system32\LogFiles\Scm\48310d68-5674-4ff7-bda3-2624ad47f05a - Ok
C:\Windows\system32\LogFiles\Scm\486d715e-6aa2-44cf-bc48-b6990cbb53c6 - Ok
C:\Windows\system32\LogFiles\Scm\09f06bfe-a3c8-40e3-846a-6e6f4000c238 - Ok
C:\Windows\system32\LogFiles\Scm\5528f22c-2470-4715-acae-e274ef6898c7 - Ok
C:\Windows\system32\LogFiles\Scm\5cba9b68-7b85-450d-b152-0d4c48633106 - Ok
C:\Windows\system32\LogFiles\Scm\5b42dd9c-5a26-4f27-bb95-34603f0997e5 - Ok
C:\Windows\system32\IME\IMETC10\applets\IMTCCAC.dll - Ok
C:\Windows\system32\LogFiles\Scm\5f5a18eb-dc73-4e45-a11c-b59043598412 - Ok
C:\Windows\system32\LogFiles\Scm\4c8b01a2-11ff-4c41-848f-508ef4f00cf7 - Ok
C:\Windows\system32\LogFiles\Scm\5c0aeeea-c154-45be-8499-bea5f11baff6 - Ok
C:\Windows\system32\LogFiles\Scm\6738ba6e-ea75-4b6b-b8b8-71f0336dd8ef - Ok
C:\Windows\system32\LogFiles\Scm\72db7465-bc54-491b-a92a-4637a28c9bbf - Ok
C:\Windows\system32\LogFiles\Scm\613612ba-897d-44ce-8dc1-8fc283f9fd51 - Ok
C:\Windows\system32\LogFiles\Scm\5a40e926-9e86-4b89-9cfd-b12311724371 - Ok
C:\Windows\system32\LogFiles\Scm\753c47ae-ec5e-44b3-95a9-2c8e553f0e39 - Ok
C:\Windows\system32\LogFiles\Scm\7b924de2-f82c-4842-ad2c-4413f2b2bb3f - Ok
C:\Windows\system32\IME\shared\res\padrs804.dll - Ok
C:\Windows\system32\LogFiles\Scm\793e7149-32b1-4a5a-bee0-4141831feed2 - Ok
C:\Windows\system32\LogFiles\Scm\7afcc0ca-7121-422a-ab45-b0e8d599ff08 - Ok
C:\Windows\system32\LogFiles\Scm\7faa463b-6128-4b01-8695-9d591e33cfda - Ok
C:\Windows\system32\LogFiles\Scm\82a1ac7f-7ea7-4f0f-96af-ddb4a88fa05a - Ok
C:\Windows\system32\IME\IMETC10\applets\IMTCSKF.dll - Ok
C:\Windows\system32\LogFiles\Scm\81540b9f-b5bf-47eb-9c95-be195bf2c664 - Ok
C:\Windows\system32\LogFiles\Scm\8879ccfd-0abe-4699-a33a-0ddcd50c0843 - Ok
C:\Windows\system32\LogFiles\Scm\8af38eaa-c119-4c34-b31f-648e0269f211 - Ok
C:\Windows\system32\LogFiles\Scm\9435f817-fed2-454e-88cd-7f78fda62c48 - Ok
C:\Windows\system32\LogFiles\Scm\810a7adc-e0a0-478a-b368-a8d128707165 - Ok
C:\Windows\system32\LogFiles\Scm\8f18ad72-1394-40a9-ac9e-874ff62bc826 - Ok
C:\Windows\system32\LogFiles\Scm\994c86ad-a929-4b2c-88a0-4e25a107a029 - Ok
C:\Windows\system32\LogFiles\Scm\9979cb83-103a-4105-9e5d-c74b0af6d198 - Ok
C:\Windows\system32\LogFiles\Scm\a1586ad7-c16c-46b8-b212-8bda367c7b6d - Ok
C:\Windows\system32\LogFiles\Scm\a35bb7a6-5f0c-4c9f-8450-2b3bed532d51 - Ok
C:\Windows\system32\LogFiles\Scm\a48cabbf-24c8-4b87-b00f-9261807c3b43 - Ok
C:\Windows\system32\LogFiles\Scm\a7b233f7-ed55-4ce3-83bf-e93340ab3de2 - Ok
C:\Windows\system32\LogFiles\Scm\a6af9377-77ce-47ab-ad7d-ec32cad0c82d - Ok
C:\Windows\system32\LogFiles\Scm\ac668097-4d6b-4093-ac14-014c09dbf820 - Ok
C:\Windows\system32\LogFiles\Scm\a7c73732-9f11-4281-8d19-764d4ec9d94d - Ok
C:\Windows\system32\LogFiles\Scm\aec88454-6336-4b94-9bd3-f446eb31d9a9 - Ok
C:\Windows\system32\LogFiles\Scm\af01ab36-ce74-4a29-9b51-7c16b4b76b50 - Ok
C:\Windows\system32\LogFiles\Scm\ba21033f-b8f8-4fc0-a4bf-42a011010d5b - Ok
C:\Windows\system32\LogFiles\Scm\be669c13-8165-4536-96d0-6d6c39292aae - Ok
C:\Windows\system32\LogFiles\Scm\ac4e5acf-89f7-4220-ba21-81ee183975e2 - Ok
C:\Windows\system32\LogFiles\Scm\c25974c6-dc24-4b2e-84bc-c68602b824c1 - Ok
C:\Windows\system32\LogFiles\Scm\c18183e0-d6c4-46c4-9df7-7379998ccd88 - Ok
C:\Windows\system32\LogFiles\Scm\ca4b8ff2-a4d2-4d88-a52e-3a5bdaf7f56e - Ok
C:\Windows\system32\LogFiles\Scm\c6bd7943-067d-4283-af3f-f22efa4ed01a - Ok
C:\Windows\system32\LogFiles\Scm\cee64558-e1a7-4d9d-80a7-2001912be5b5 - Ok
C:\Windows\system32\LogFiles\Scm\cb3d64bf-c0c9-45ff-bfb0-ff1a8f680186 - Ok
C:\Windows\system32\LogFiles\Scm\d7b6e81d-3cf4-432c-84d2-24213f4316e6 - Ok
C:\Windows\system32\LogFiles\Scm\b0cbab43-44fc-469b-a4ce-87426761fdce - Ok
C:\Windows\system32\LogFiles\Scm\c016366b-7126-46ca-b36b-592a3d95a60b - Ok
C:\Windows\system32\LogFiles\Scm\da41de71-8431-42fb-9db0-eb64a961dead - Ok
C:\Windows\system32\LogFiles\Scm\e22a8667-f75b-4ba9-ba46-067ed4429de8 - Ok
C:\Windows\system32\LogFiles\Scm\dd9f510c-95f4-499a-90c8-bac5bc372ff4 - Ok
C:\Windows\system32\LogFiles\Scm\e994088e-f177-4a81-b8e6-3370762668d4 - Ok
C:\Windows\system32\LogFiles\Scm\d0250f3f-6480-484f-b719-42f659ac64d5 - Ok
C:\Windows\system32\LogFiles\Scm\e3163c33-301d-4730-a266-5518c5ed3967 - Ok
C:\Windows\system32\LogFiles\Scm\f150c477-baa5-4314-a476-ddf217a1a49b - Ok
C:\Windows\system32\LogFiles\Scm\f1fd67a1-3b3a-4c09-9946-e990ed4ec055 - Ok
C:\Windows\system32\LogFiles\Scm\ea585df0-56c6-4716-bc13-9c0708441b45 - Ok
C:\Windows\system32\LogFiles\Scm\ebcffb66-8af5-42ec-8299-7ff7146c04e6 - Ok
C:\Windows\system32\LogFiles\Scm\eaca24ff-236c-401d-a1e7-b3d5267b8a50 - Ok
C:\Windows\system32\LogFiles\Scm\f896c6ec-85dc-45d3-be6b-9c79ed808705 - Ok
C:\Windows\system32\LogFiles\Scm\fb3c354d-297a-4eb2-9b58-090f6361906b - Ok
C:\Windows\system32\LogFiles\Scm\fdd56c73-f0d5-41b6-b767-6effd7966428 - Ok
C:\Windows\system32\LogFiles\Scm\fa2bc0a6-8d4b-458a-85c8-2b8c72487513 - Ok
C:\Windows\system32\LogFiles\Scm\eb02381f-d652-4b1c-894a-712498c62c51 - Ok
C:\Windows\system32\LogFiles\WMI\Terminal-Services-Core.etl - Ok
C:\Windows\system32\LogFiles\WMI\Terminal-Services-IP-Virtualization.etl - Ok
C:\Windows\system32\LogFiles\WMI\Terminal-Services-RPC-Client.etl - Ok
C:\Windows\system32\LogFiles\WMI\Terminal-Services-SessionEnv.etl - Ok
C:\Windows\system32\LogFiles\WMI\RtBackup\EtwRTDiagLog.etl - Ok
C:\Windows\system32\LogFiles\WMI\Terminal-Services-Unified-APIs.etl - Ok
C:\Windows\system32\LogFiles\WMI\RtBackup\EtwRTMsMpPsSession7.etl - Ok
C:\Windows\system32\LogFiles\WMI\RtBackup\EtwRTMuroc System Trace.etl - Ok
C:\Windows\system32\LogFiles\WMI\RtBackup\EtwRTEventLog-Application.etl - Ok
C:\Windows\system32\LogFiles\Scm\SCM.EVM.2 - Ok
C:\Windows\system32\LogFiles\WMI\RtBackup\EtwRTEventlog-Security.etl - Ok
C:\Windows\system32\LogFiles\WUDF\WudfHost_ext__10268.dmp - Ok
C:\Windows\system32\LogFiles\WMI\RtBackup\EtwRTEventLog-System.etl - Ok
C:\Windows\system32\LogFiles\WMI\RtBackup\EtwRTUBPM.etl - Ok
C:\Windows\system32\LogFiles\Scm\SCM.EVM - Ok
C:\Windows\system32\LogFiles\Scm\SCM.EVM.4 - Ok
C:\Windows\system32\LogFiles\Scm\SCM.EVM.1 - Ok
C:\Windows\system32\LogFiles\WUDF\WudfHost_ext__1500.dmp - Ok
C:\Windows\system32\LogFiles\WUDF\WUDFTrace.etl - Ok
C:\Windows\system32\MUI\0413\mscorees.dll - Ok
C:\Windows\system32\MUI\0409\mscorees.dll - Ok
C:\Windows\system32\LogFiles\Scm\SCM.EVM.3 - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\0aa29889-1960-47af-9f4e-cea289fa3b42 - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\0abca3bd-678c-4cf4-9073-976b0ab70506 - Ok
C:\Windows\system32\Macromed\Flash\FlashInstall.log - Ok
>C:\Windows\system32\Macromed\Flash\Flash64_11_9_900_117.ocx - packed by BINARYRES
>>C:\Windows\system32\Macromed\Flash\Flash64_11_9_900_117.ocx is WISE container
C:\Windows\system32\Microsoft\Protect\S-1-5-18\232b56db-d65a-4713-a703-5b71ea4af830 - Ok
C:\Windows\system32\Macromed\Flash\Flash64_11_9_900_117.ocx - container
C:\Windows\system32\Microsoft\Protect\S-1-5-18\6aee2035-9c58-4497-afe4-e97c1a8b1395 - Ok
C:\Windows\system32\Macromed\Flash\plugin.vch - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\7189b5ec-e652-4b98-9ccc-2b3af887a5ff - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\85f59655-58dd-4dfd-8d3a-451b8a03853f - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\e40191f8-deb9-43d0-8372-b51ff20d4ef9 - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\b889ab5d-f7d2-47ff-92a1-3ec877b7e01c - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\e6dee871-c1e0-4167-bbff-ac67e035b8cb - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\f640571f-82cc-4cfd-8a3d-9496d2e1be41 - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\Preferred - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\User\0625fbb2-f3d1-413d-8b9c-5b7bceca685e - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\User\1e582198-061f-43f1-abdf-d4e9b606b035 - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\User\201ce1ae-5bb8-44bf-8b08-b75dfef6dffc - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\aaf367c8-e8a5-438c-a89a-8ac43d48bd4b - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\User\77de69a6-88de-4f59-93cd-77e908e18c33 - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\User\467fd2db-7d39-48b5-9d26-9e2d522025dd - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\User\7cbd90a1-240d-44db-9a91-6e7b59e5cea4 - Ok
C:\Windows\system32\Macromed\Flash\activex.vch - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\User\a6e6224a-7e67-4a6a-a547-9471bbbac0c3 - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\User\81fa1fdb-8699-40a3-865d-cce77a3c1dbe - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\User\d691abb3-8555-43b2-8b16-6674f3812c77 - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\User\f22e410f-f947-4e08-8f2a-8f65df603f8d - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-19\0805440c-5598-440c-940e-a314cacd8ff5 - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\User\Preferred - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\User\d1b8c998-b420-47c3-ac55-5ab1ab22818e - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-19\3ff5a31c-603d-4eea-9448-376702a19030 - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-19\306956f3-124c-4e93-a00e-db5671ad0cf2 - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-19\bfe130d1-19ab-4da7-b272-b36eda4a7036 - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-19\86ddab3d-e96b-4a76-a902-4c76159d16a4 - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-19\8121820f-9236-40e8-b22a-5075bcf0243f - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-19\de29c067-7275-4675-98d1-cc1e0b4f122f - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-19\Preferred - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-19\df3fc6d1-57d6-4526-821d-e1c9889514dd - Ok
C:\Windows\system32\Msdtc\MSDTC.LOG - Ok
C:\Windows\system32\NetworkList\Icons\{19F2D63F-25CA-45E7-AC60-025A18EEE828}_16.bin - Ok
C:\Windows\system32\Microsoft\Protect\S-1-5-18\User\6168ed3a-3fe6-4d7a-932a-05ded934a499 - Ok
C:\Windows\system32\NetworkList\Icons\{19F2D63F-25CA-45E7-AC60-025A18EEE828}_32.bin - Ok
C:\Windows\system32\NetworkList\Icons\{19F2D63F-25CA-45E7-AC60-025A18EEE828}_24.bin - Ok
C:\Windows\system32\NetworkList\Icons\{19F2D63F-25CA-45E7-AC60-025A18EEE828}_48.bin - Ok
C:\Windows\system32\NDF\eventlog.etl - Ok
C:\Windows\system32\NetworkList\Icons\{3B245407-4FDB-4E97-B147-7609234288AB}_16.bin - Ok
C:\Windows\system32\NetworkList\Icons\{3B245407-4FDB-4E97-B147-7609234288AB}_24.bin - Ok
C:\Windows\system32\NetworkList\Icons\{3B245407-4FDB-4E97-B147-7609234288AB}_32.bin - Ok
C:\Windows\system32\NetworkList\Icons\{3B245407-4FDB-4E97-B147-7609234288AB}_48.bin - Ok
C:\Windows\system32\NetworkList\Icons\{48EC6415-E04B-4DC8-99CF-97CF5AD23C58}_16.bin - Ok
C:\Windows\system32\NetworkList\Icons\{48EC6415-E04B-4DC8-99CF-97CF5AD23C58}_24.bin - Ok
C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_117_ActiveX.exe - Ok
C:\Windows\system32\NetworkList\Icons\{85D26362-7648-40CE-A86D-35465CBB0591}_16.bin - Ok
C:\Windows\system32\NetworkList\Icons\{85D26362-7648-40CE-A86D-35465CBB0591}_24.bin - Ok
C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_117_ActiveX.dll - Ok
C:\Windows\system32\Msdtc\Trace\msdtcvtr.bat - Ok
C:\Windows\system32\NetworkList\Icons\{87C851C9-7640-4EA2-A4EE-796D87A7D10F}_16.bin - Ok
C:\Windows\system32\NetworkList\Icons\{87C851C9-7640-4EA2-A4EE-796D87A7D10F}_24.bin - Ok
C:\Windows\system32\NetworkList\Icons\{48EC6415-E04B-4DC8-99CF-97CF5AD23C58}_48.bin - Ok
C:\Windows\system32\NetworkList\Icons\{48EC6415-E04B-4DC8-99CF-97CF5AD23C58}_32.bin - Ok
C:\Windows\system32\NetworkList\Icons\{A56AB16F-41B0-484A-A4FA-730B423222CF}_16.bin - Ok
C:\Windows\system32\NetworkList\Icons\{A56AB16F-41B0-484A-A4FA-730B423222CF}_24.bin - Ok
C:\Windows\system32\NetworkList\Icons\{85D26362-7648-40CE-A86D-35465CBB0591}_32.bin - Ok
C:\Windows\system32\NetworkList\Icons\{A90F749D-C18E-4938-9C9E-5F1E03F852D5}_16.bin - Ok
C:\Windows\system32\NetworkList\Icons\{85D26362-7648-40CE-A86D-35465CBB0591}_48.bin - Ok
C:\Windows\system32\Msdtc\Trace\msdtctr.mof - Ok
C:\Windows\system32\NetworkList\Icons\{A90F749D-C18E-4938-9C9E-5F1E03F852D5}_24.bin - Ok
C:\Windows\system32\NetworkList\Icons\{87C851C9-7640-4EA2-A4EE-796D87A7D10F}_32.bin - Ok
C:\Windows\system32\NetworkList\Icons\{87C851C9-7640-4EA2-A4EE-796D87A7D10F}_48.bin - Ok
C:\Windows\system32\NetworkList\Icons\{B42586C4-8210-4BB7-8ED0-6D9344BC885D}_16.bin - Ok
C:\Windows\system32\NetworkList\Icons\{B42586C4-8210-4BB7-8ED0-6D9344BC885D}_24.bin - Ok
C:\Windows\system32\NetworkList\Icons\{B8A86F80-EFA6-4E96-8CB2-584EF3305B7A}_16.bin - Ok
C:\Windows\system32\NetworkList\Icons\{B8A86F80-EFA6-4E96-8CB2-584EF3305B7A}_24.bin - Ok
C:\Windows\system32\NetworkList\Icons\{A56AB16F-41B0-484A-A4FA-730B423222CF}_32.bin - Ok
C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_117_Plugin.exe - Ok
C:\Windows\system32\NetworkList\Icons\{A56AB16F-41B0-484A-A4FA-730B423222CF}_48.bin - Ok
C:\Windows\system32\NetworkList\Icons\{DE203B8E-AA7C-4EF3-AFC7-57DB4B8EE88E}_16.bin - Ok
C:\Windows\system32\NetworkList\Icons\{A90F749D-C18E-4938-9C9E-5F1E03F852D5}_32.bin - Ok
C:\Windows\system32\NetworkList\Icons\{DE203B8E-AA7C-4EF3-AFC7-57DB4B8EE88E}_24.bin - Ok
C:\Windows\system32\NetworkList\Icons\{A90F749D-C18E-4938-9C9E-5F1E03F852D5}_48.bin - Ok
C:\Windows\system32\NetworkList\Icons\{DE203B8E-AA7C-4EF3-AFC7-57DB4B8EE88E}_32.bin - Ok
C:\Windows\system32\NetworkList\Icons\{B42586C4-8210-4BB7-8ED0-6D9344BC885D}_48.bin - Ok
C:\Windows\system32\NetworkList\Icons\{DE203B8E-AA7C-4EF3-AFC7-57DB4B8EE88E}_48.bin - Ok
C:\Windows\system32\NetworkList\Icons\{DF1B1DCA-F83D-4ECB-8134-0C35E3AB6380}_16.bin - Ok
C:\Windows\system32\NetworkList\Icons\{DF1B1DCA-F83D-4ECB-8134-0C35E3AB6380}_24.bin - Ok
C:\Windows\system32\NetworkList\Icons\{DF1B1DCA-F83D-4ECB-8134-0C35E3AB6380}_32.bin - Ok
C:\Windows\system32\NetworkList\Icons\{B42586C4-8210-4BB7-8ED0-6D9344BC885D}_32.bin - Ok
C:\Windows\system32\NetworkList\Icons\{E847AED0-BEBB-4F57-90F6-F715476CDDE4}_16.bin - Ok
C:\Windows\system32\NetworkList\Icons\{E847AED0-BEBB-4F57-90F6-F715476CDDE4}_24.bin - Ok
C:\Windows\system32\NetworkList\Icons\{E847AED0-BEBB-4F57-90F6-F715476CDDE4}_32.bin - Ok
C:\Windows\system32\NetworkList\Icons\{E847AED0-BEBB-4F57-90F6-F715476CDDE4}_48.bin - Ok
C:\Windows\system32\NetworkList\Icons\{FA3F30E0-3722-418B-9CA0-83545B3A44B9}_16.bin - Ok
C:\Windows\system32\NetworkList\Icons\{FA3F30E0-3722-418B-9CA0-83545B3A44B9}_24.bin - Ok
C:\Windows\system32\NetworkList\Icons\StockIcons\bench_24.bin - Ok
C:\Windows\system32\NetworkList\Icons\StockIcons\bench_32.bin - Ok
C:\Windows\system32\NetworkList\Icons\StockIcons\house_16.bin - Ok
C:\Windows\system32\NetworkList\Icons\StockIcons\bench_16.bin - Ok
C:\Windows\system32\NetworkList\Icons\{DF1B1DCA-F83D-4ECB-8134-0C35E3AB6380}_48.bin - Ok
C:\Windows\system32\NetworkList\Icons\StockIcons\house_24.bin - Ok
C:\Windows\system32\NetworkList\Icons\{B8A86F80-EFA6-4E96-8CB2-584EF3305B7A}_32.bin - Ok
C:\Windows\system32\NetworkList\Icons\StockIcons\office_16.bin - Ok
C:\Windows\system32\NetworkList\Icons\StockIcons\office_24.bin - Ok
C:\Windows\system32\NetworkList\Icons\StockIcons\bench_48.bin - Ok
C:\Windows\system32\NetworkList\Icons\StockIcons\office_32.bin - Ok
C:\Windows\system32\NetworkList\Icons\{B8A86F80-EFA6-4E96-8CB2-584EF3305B7A}_48.bin - Ok
C:\Windows\system32\NetworkList\Icons\StockIcons\office_48.bin - Ok
>C:\Windows\system32\Macromed\Flash\NPSWF64_11_9_900_117.dll - packed by BINARYRES
>>C:\Windows\system32\Macromed\Flash\NPSWF64_11_9_900_117.dll is WISE container
C:\Windows\system32\Macromed\Flash\NPSWF64_11_9_900_117.dll - container
C:\Windows\system32\NetworkList\Icons\{FA3F30E0-3722-418B-9CA0-83545B3A44B9}_32.bin - Ok
C:\Windows\system32\NetworkList\Icons\StockIcons\house_48.bin - Ok
C:\Windows\system32\NetworkList\Icons\{FA3F30E0-3722-418B-9CA0-83545B3A44B9}_48.bin - Ok
C:\Windows\system32\Recovery\ReAgent.xml - Ok
C:\Windows\system32\NetworkList\Icons\StockIcons\house_32.bin - Ok
C:\Windows\system32\Printing_Admin_Scripts\nl-NL\pubprn.vbs - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT - Ok
C:\Windows\system32\SMI\Schema\WcmTypes.xsd - Ok
C:\Windows\system32\SMI\Store\Machine\schema.dat.LOG - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT.LOG2 - Ok
C:\Windows\system32\Recovery\Winre.wim - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{2d50ad80-b952-11e1-9e70-4c809397a0b2}.TM.blf - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{2d50ad80-b952-11e1-9e70-4c809397a0b2}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\IME\IMEJP10\APPLETS\mshwjpnrIME.dll - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{846ee3d3-7039-11de-9d20-001d09fa5a1c}.TM.blf - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{2d50ad80-b952-11e1-9e70-4c809397a0b2}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{8ed11da2-62ea-11e1-b7e4-4c809397a0b2}.TM.blf - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT.LOG1 - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{846ee3d3-7039-11de-9d20-001d09fa5a1c}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{8ed11da2-62ea-11e1-b7e4-4c809397a0b2}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{8f5fe555-6247-11e1-b2f6-4c809397a0b2}.TM.blf - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{846ee3d3-7039-11de-9d20-001d09fa5a1c}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{d2ff5daf-6242-11e1-a69c-4c809397a0b2}.TM.blf - Ok
C:\Windows\system32\Printing_Admin_Scripts\nl-NL\prndrvr.vbs - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{8f5fe555-6247-11e1-b2f6-4c809397a0b2}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{8ed11da2-62ea-11e1-b7e4-4c809397a0b2}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\Printing_Admin_Scripts\nl-NL\prnqctl.vbs - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{f539843e-e3e9-11e2-a1e0-4c809397a0b2}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\Printing_Admin_Scripts\nl-NL\prncnfg.vbs - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{8f5fe555-6247-11e1-b2f6-4c809397a0b2}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\Printing_Admin_Scripts\nl-NL\prnport.vbs - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{d2ff5daf-6242-11e1-a69c-4c809397a0b2}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\Printing_Admin_Scripts\nl-NL\prnjobs.vbs - Ok
C:\Windows\system32\Printing_Admin_Scripts\nl-NL\prnmngr.vbs - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{f539843e-e3e9-11e2-a1e0-4c809397a0b2}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\SRSLabs\{176F4E15-8F7C-4833-ADED-81FAE8CCD186}\slcsii64.dll - Ok
C:\Windows\system32\SRSLabs\{176F4E15-8F7C-4833-ADED-81FAE8CCD186}\slh36064.dll - Ok
C:\Windows\system32\SRSLabs\{176F4E15-8F7C-4833-ADED-81FAE8CCD186}\slhlim64.dll - Ok
C:\Windows\system32\SRSLabs\{176F4E15-8F7C-4833-ADED-81FAE8CCD186}\slinit64.dll - Ok
C:\Windows\system32\SRSLabs\{176F4E15-8F7C-4833-ADED-81FAE8CCD186}\sltshd64.dll - Ok
C:\Windows\system32\SRSLabs\{176F4E15-8F7C-4833-ADED-81FAE8CCD186}\slgeq64.dll - Ok
C:\Windows\system32\SRSLabs\{176F4E15-8F7C-4833-ADED-81FAE8CCD186}\slmaxv64.dll - Ok
C:\Windows\system32\SRSLabs\{176F4E15-8F7C-4833-ADED-81FAE8CCD186}\sluapo64.dll - Ok
C:\Windows\system32\SRSLabs\{176F4E15-8F7C-4833-ADED-81FAE8CCD186}\slcc3d64.dll - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{d2ff5daf-6242-11e1-a69c-4c809397a0b2}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\SRSLabs\{176F4E15-8F7C-4833-ADED-81FAE8CCD186}\slvipp64.dll - Ok
C:\Windows\system32\SRSLabs\{176F4E15-8F7C-4833-ADED-81FAE8CCD186}\slviq64.dll - Ok
C:\Windows\system32\Setup\FXSOCM.dll - Ok
C:\Windows\system32\Setup\pbkmigr.dll - Ok
C:\Windows\system32\Setup\msdtcstp.dll - Ok
C:\Windows\system32\SRSLabs\{176F4E15-8F7C-4833-ADED-81FAE8CCD186}\slapoi64.dll - Ok
C:\Windows\system32\Setup\RasMigPlugin.dll - Ok
C:\Windows\system32\Setup\cmmigr.dll - Ok
C:\Windows\system32\Setup\tssysprep.dll - Ok
C:\Windows\system32\SMI\Store\Machine\SCHEMA.DAT{f539843e-e3e9-11e2-a1e0-4c809397a0b2}.TM.blf - Ok
C:\Windows\system32\Setup\comsetup.dll - Ok
C:\Windows\system32\Speech\Engines\SR\spsrx.dll - Ok
>C:\Windows\system32\Speech\SpeechUX\SpeechUX.dll is ZLIB container
C:\Windows\system32\SRSLabs\{176F4E15-8F7C-4833-ADED-81FAE8CCD186}\slcshp64.dll - Ok
C:\Windows\system32\Speech\Engines\SR\spsreng.dll - Ok
C:\Windows\system32\Speech\Engines\SR\nl-NL\srloc.dll.mui - Ok
C:\Windows\system32\Speech\SpeechUX\SpeechUXPS.DLL - Ok
C:\Windows\system32\Speech\SpeechUX\SPTIP.DLL - Ok
C:\Windows\system32\IME\IMETC10\applets\MSHWCHTRIME.dll - Ok
C:\Windows\system32\IME\imekr8\applets\mshwkorrIME.dll - Ok
C:\Windows\system32\Speech\SpeechUX\nl-NL\sapi.cpl.mui - Ok
C:\Windows\system32\Speech\Engines\SR\srloc.dll - Ok
C:\Windows\system32\Tasks\Adobe Flash Player Updater - Ok
C:\Windows\system32\Tasks\AdobeAAMUpdater-1.0-Jan-HP-Jan - Ok
C:\Windows\system32\Tasks\FacebookUpdateTaskUserS-1-5-21-3541089858-1470975645-1250053556-1000Core - Ok
C:\Windows\system32\Tasks\FacebookUpdateTaskUserS-1-5-21-3541089858-1470975645-1250053556-1000UA - Ok
C:\Windows\system32\Speech\SpeechUX\nl-NL\SpeechUXWiz.exe.mui - Ok
C:\Windows\system32\Speech\SpeechUX\nl-NL\SpeechUXTutorial.exe.mui - Ok
C:\Windows\system32\Speech\SpeechUX\nl-NL\SpeechUX.dll.mui - Ok
C:\Windows\system32\Tasks\GoogleUpdateTaskUserS-1-5-21-3541089858-1470975645-1250053556-1000UA - Ok
C:\Windows\system32\Tasks\GoogleUpdateTaskUserS-1-5-21-3541089858-1470975645-1250053556-1000Core - Ok
C:\Windows\system32\Tasks\MirageAgent - Ok
C:\Windows\system32\Tasks\HPCeeScheduleForJan - Ok
C:\Windows\system32\Tasks\{D7CB4D03-2047-4A42-82B8-BB8F1ADC9930} - Ok
C:\Windows\system32\Tasks\SpyHunter4Startup - Ok
C:\Windows\system32\Tasks\User_Feed_Synchronization-{8789CA09-5A41-493B-95F7-CB27813D40E9} - Ok
C:\Windows\system32\Tasks\Apple\AppleSoftwareUpdate - Ok
C:\Windows\system32\Tasks\Hewlett-Packard\HP Support Assistant\PC Health Analysis - Ok
C:\Windows\system32\Tasks\Hewlett-Packard\HP Support Assistant\HP Support Assistant Quick Start - Ok
C:\Windows\system32\Tasks\Hewlett-Packard\HP Support Assistant\Update Check - Ok
C:\Windows\system32\Tasks\Hewlett-Packard\HP Support Assistant\WarrantyChecker_DeviceScan - Ok
C:\Windows\system32\Tasks\Microsoft\Windows Defender\MP Scheduled Scan - Ok
C:\Windows\system32\Tasks\Microsoft\Windows Live\SOXE\Extractor Definitions Update Task - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Active Directory Rights Management Services Client\AD RMS Rights Policy Template Management (Automated) - Ok
>C:\Windows\system32\Speech\SpeechUX\SpeechUXWiz.exe is ZLIB container
C:\Windows\system32\Tasks\Microsoft\Windows\Active Directory Rights Management Services Client\AD RMS Rights Policy Template Management (Manual) - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\AppID\PolicyConverter - Ok
C:\Windows\system32\Speech\SpeechUX\nl-NL\speechuxcpl.dll.mui - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\AppID\VerifiedPublisherCertStoreCheck - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Application Experience\AitAgent - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Application Experience\ProgramDataUpdater - Ok
C:\Windows\system32\Speech\Common\sapi.dll - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\CertificateServicesClient\SystemTask - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\CertificateServicesClient\UserTask - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Autochk\Proxy - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\CertificateServicesClient\UserTask-Roam - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Customer Experience Improvement Program\UsbCeip - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Customer Experience Improvement Program\Consolidator - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Customer Experience Improvement Program\KernelCeipTask - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Diagnosis\Scheduled - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Defrag\ScheduledDefrag - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Location\Notifications - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\DiskDiagnostic\Microsoft-Windows-DiskDiagnosticDataCollector - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\MUI\Lpksetup - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\DiskDiagnostic\Microsoft-Windows-DiskDiagnosticResolver - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Bluetooth\UninstallDeviceTask - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\MUI\LPRemove - Ok
C:\Windows\system32\SRSLabs\{176F4E15-8F7C-4833-ADED-81FAE8CCD186}\slprop64.dll - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\MUI\Mcbuilder - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\ActivateWindowsSearch - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Maintenance\WinSAT - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\ConfigureInternetTimeService - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\DispatchRecoveryTasks - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\MediaCenterRecoveryTask - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\InstallPlayReady - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\ehDRMInit - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\ObjectStoreRecoveryTask - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\OCURDiscovery - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\mcupdate - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\PBDADiscoveryW1 - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\PBDADiscoveryW2 - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\PeriodicScanRetry - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\PBDADiscovery - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\PvrRecoveryTask - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\PvrScheduleTask - Ok
C:\Windows\system32\Speech\SpeechUX\SpeechUXTutorial.exe - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\OCURActivate - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\ReindexSearchRoot - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\SqlLiteRecoveryTask - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\RegisterSearch - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\RecordingRestart - Ok
C:\Windows\system32\Speech\SpeechUX\sapi.cpl - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\MemoryDiagnostic\CorruptionDetector - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\MemoryDiagnostic\DecompressionFailureDetector - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\NetTrace\GatherNetworkInfo - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Multimedia\SystemSoundsService - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\MobilePC\HotStart - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\RAC\RacTask - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Power Efficiency Diagnostics\AnalyzeSystem - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Registry\RegIdleBackup - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\RemoteAssistance\RemoteAssistanceTask - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Media Center\UpdateRecordPath - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Shell\WindowsParentalControlsMigration - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\PerfTrack\BackgroundConfigSurveyor - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Ras\MobilityManager - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Shell\WindowsParentalControls - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\SideShow\AutoWake - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\SideShow\GadgetManager - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\SoftwareProtectionPlatform\SvcRestartTask - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\SideShow\SystemDataProviders - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\TextServicesFramework\MsCtfMonitor - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\SystemRestore\SR - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Time Synchronization\SynchronizeTime - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\SideShow\SessionAgent - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\UPnP\UPnPHostConfig - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\User Profile Service\HiveUploadTask - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Task Manager\Interactive - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Windows Error Reporting\QueueReporting - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Tcpip\IpAddressConflict1 - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Tcpip\IpAddressConflict2 - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\WDI\ResolutionHost - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Windows Activation Technologies\ValidationTask - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Windows Filtering Platform\BfeOnServiceStartTypeChange - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Windows Media Sharing\UpdateLibrary - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Wininet\CacheTask - Ok
C:\Windows\system32\Tasks\OfficeSoftwareProtectionPlatform\SvcRestartTask - Ok
C:\Windows\system32\WLANProfiles\Profiles.enc - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\WindowsColorSystem\Calibration Loader - Ok
C:\Windows\system32\Tasks\WPD\SqmUpload_S-1-5-21-3541089858-1470975645-1250053556-1000 - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\Windows Activation Technologies\ValidationTaskDeadline - Ok
C:\Windows\system32\Tasks\Microsoft\Windows\WindowsBackup\ConfigNotification - Ok
C:\Windows\system32\WinBioDatabase\1000F3B5-9412-490E-97BA-4AA5A1A171AE.DAT - Ok
C:\Windows\system32\Speech\SpeechUX\SpeechUX.dll - container
C:\Windows\system32\WinBioPlugIns\nl-NL\winbiosensoradapter.dll.mui - Ok
C:\Windows\system32\WinBioPlugIns\vcsWBFEngineAdapter.dll - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\Certificate.format.ps1xml - Ok
C:\Windows\system32\WinBioPlugIns\nl-NL\winbioStorageadapter.dll.mui - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\Diagnostics.Format.ps1xml - Ok
C:\Windows\system32\Wat\WatAdminSvc.exe - Ok
C:\Windows\system32\Wat\WatUX.exe - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\DotNetTypes.format.ps1xml - Ok
C:\Windows\system32\WinBioPlugIns\winbiosensoradapter.dll - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\FileSystem.format.ps1xml - Ok
C:\Windows\system32\Wat\npWatWeb.dll - Ok
C:\Windows\system32\WinBioPlugIns\winbiostorageadapter.dll - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\getevent.types.ps1xml - Ok
C:\Windows\system32\Speech\SpeechUX\SpeechUXWiz.exe - container
C:\Windows\system32\WindowsPowerShell\v1.0\Help.format.ps1xml - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\PowerShellCore.format.ps1xml - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\PowerShellTrace.format.ps1xml - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\pwrshmsg.dll - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\Registry.format.ps1xml - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\types.ps1xml - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\PSEvents.dll - Ok
C:\Windows\system32\Speech\SpeechUX\speechuxcpl.dll - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\WSMan.Format.ps1xml - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\Examples\profile.ps1 - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\Modules\BitsTransfer\BitsTransfer.psd1 - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\Modules\BitsTransfer\BitsTransfer.Format.ps1xml - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\Modules\PSDiagnostics\PSDiagnostics.psd1 - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\Modules\BitsTransfer\nl-NL\about_BITS_Cmdlets.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\pwrshsip.dll - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\Modules\PSDiagnostics\PSDiagnostics.psm1 - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\Modules\TroubleshootingPack\TroubleshootingPack.psd1 - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\Modules\BitsTransfer\nl-NL\Microsoft.BackgroundIntelligentTransfer.Management.dll-Help.xml - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\Modules\TroubleshootingPack\nl-NL\Microsoft.Windows.Diagnosis.TroubleshootingPack.dll-Help.xml - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\pspluginwkr.dll - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Arithmetic_Operators.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_arrays.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Break.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\powershell_ise.exe - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Command_Syntax.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Assignment_Operators.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_aliases.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_command_precedence.help.txt - Ok
C:\Windows\system32\Wat\WatWeb.dll - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Continue.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\CompiledComposition.Microsoft.PowerShell.GPowerShell.dll - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Comment_Based_Help.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_debuggers.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_environment_variables.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_data_sections.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Automatic_Variables.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Core_Commands.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_do.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Comparison_Operators.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_For.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Foreach.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_eventlogs.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_format.ps1xml.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_CommonParameters.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_functions_advanced.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_functions_cmdletbindingattribute.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_execution_policies.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_escape_characters.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_History.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\Modules\BitsTransfer\Microsoft.BackgroundIntelligentTransfer.Management.Interop.dll - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_functions_advanced_parameters.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_jobs.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\Modules\TroubleshootingPack\TroubleshootingPack.format.ps1xml - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_hash_tables.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_join.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Language_Keywords.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_locations.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_functions.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_If.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_methods.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_modules.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_functions_advanced_methods.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_job_details.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Line_Editing.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Parsing.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_logical_operators.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_operators.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Path_Syntax.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_prompts.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_pipelines.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_objects.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\powershell.exe - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_preference_variables.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Quoting_Rules.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Ref.help.txt - Ok
C:\Windows\system32\WCN\nl-NL\Add_a_device_or_computer_to_a_network_usb.rtf - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_regular_expressions.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_remote.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_profiles.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_remote_jobs.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_properties.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_remote_FAQ.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_providers.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Reserved_Words.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_PSSnapins.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_remote_troubleshooting.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_remote_output.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_parameters.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_scopes.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_scripts.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Return.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_requires.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Signing.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Special_Characters.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_script_blocks.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_split.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Switch.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_trap.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_transactions.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Throw.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_try_catch_finally.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_pssession_details.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Variables.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Session_Configurations.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_remote_requirements.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_While.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_wildcards.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Redirection.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_script_internationalization.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Windows_PowerShell_ISE.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_Windows_PowerShell_2.0.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_WMI_Cmdlets.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\ImportAllModules.psd1 - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\default.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\Microsoft.PowerShell.ConsoleHost.dll-Help.xml - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_pssessions.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\powershell.exe.mui - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_type_operators.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_WS-Management_Cmdlets.help.txt - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\Microsoft.PowerShell.Commands.Management.dll-Help.xml - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\pspluginwkr.dll.mui - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\pwrshmsg.dll.mui - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\PSEvents.dll.mui - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\System.Management.Automation.dll-Help.xml - Ok
>C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_types.ps1xml.help.txt is JS-HTML container
C:\Windows\system32\ar-SA\comctl32.dll.mui - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\Microsoft.PowerShell.Commands.Diagnostics.dll-Help.xml - Ok
C:\Windows\system32\ar-SA\msprivs.dll.mui - Ok
C:\Windows\system32\ar-SA\fms.dll.mui - Ok
C:\Windows\system32\ar-SA\mlang.dll.mui - Ok
C:\Windows\system32\bg-BG\comctl32.dll.mui - Ok
C:\Windows\system32\bg-BG\fms.dll.mui - Ok
C:\Windows\system32\catroot2\dberr.txt - Ok
C:\Windows\system32\ar-SA\cdosys.dll.mui - Ok
C:\Windows\system32\catroot2\edb.chk - Ok
C:\Windows\system32\catroot2\edb.log - read error
C:\Windows\system32\ar-SA\comdlg32.dll.mui - Ok
C:\Windows\system32\catroot2\edb00869.log - Ok
C:\Windows\system32\catroot2\edb0086A.log - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\Microsoft.Wsman.Management.dll-Help.xml - Ok
C:\Windows\system32\catroot2\{127D0A1D-4EF2-11D1-8608-00C04FC295EE}\catdb - read error
C:\Windows\system32\bg-BG\mlang.dll.mui - Ok
C:\Windows\system32\catroot2\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\catdb - read error
C:\Windows\system32\bg-BG\msimsg.dll.mui - Ok
C:\Windows\system32\catroot\cdr4x64.cat - Ok
C:\Windows\system32\catroot\cdralx64.cat - Ok
C:\Windows\system32\catroot2\edbres00002.jrs - Ok
C:\Windows\system32\catroot\pxhlpa64.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\1.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\3.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\2.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\4.CAT - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\powershell_ise.resources.dll - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\6.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\5.CAT - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\Microsoft.PowerShell.Security.dll-Help.xml - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\GEARAspiWDMx64.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Hyper-V-Common-Drivers-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Anytime-Upgrade-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot2\edbres00001.jrs - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\Microsoft.PowerShell.Commands.Utility.dll-Help.xml - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Anytime-Upgrade-Results-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Backup-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Media-Foundation-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Backup-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-BLB-Client-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Anytime-Upgrade-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\WindowsPowerShell\v1.0\nl-NL\about_types.ps1xml.help.txt - container
C:\Windows\system32\ar-SA\msimsg.dll.mui - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Anytime-Upgrade-Results-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-BLB-Client-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Branding-HomePremium-Client-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-BusinessScanning-Feature-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Branding-Professional-Client-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Branding-HomePremium-Client-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\bg-BG\comdlg32.dll.mui - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-BusinessScanning-Feature-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Client-LanguagePack-Package-wrapper~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Branding-Ultimate-Client-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Media-Foundation-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Branding-Professional-Client-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Branding-Ultimate-Client-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Client-Drivers-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Client-Refresh-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Hyper-V-Guest-Integration-Drivers-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-ClipsInTheLibrary-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Client-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-CodecPack-Basic-Package-wrapper~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-CodecPack-Basic-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Client-Drivers-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-CodecPack-Basic-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Client-Wired-Network-Drivers-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-ClipsInTheLibrary-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-CodecPack-Basic-Encoder-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-DesktopWindowManager-uDWM-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Common-Modem-Drivers-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Disk-Diagnosis-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Editions-Client-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Disk-Diagnosis-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-EnterpriseEdition-wrapper~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-GroupPolicy-ClientExtensions-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-GroupPolicy-ClientExtensions-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-GPUPipeline-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-GroupPolicy-ClientTools-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-GroupPolicy-ClientTools-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Help-CoreClientUAHP-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Help-CoreClientUAHP-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Help-CoreClientUAUE-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Gadget-Platform-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Help-CoreClientUAUE-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Help-CoreClientUAPS-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-HomeBasicEdition-wrapper~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-HomePremiumEdition~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Help-Customization-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-ICM-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IE-Hyphenation-Package-English~31bf3856ad364e35~amd64~~6.2.9200.16437.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IE-Hyphenation-Parent-Package-English~31bf3856ad364e35~~~10.2.9200.16437.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IE-Spelling-Package-English~31bf3856ad364e35~amd64~~6.2.9200.16437.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IE-Hyphenation-Package-Dutch~31bf3856ad364e35~amd64~~6.2.9200.16437.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Gadget-Platform-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-HomePremiumEdition-wrapper~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Help-CoreClientUAPS-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IE-Hyphenation-Parent-Package-Dutch~31bf3856ad364e35~~~10.2.9200.16437.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IE-Spelling-Parent-Package-English~31bf3856ad364e35~~~10.2.9200.16437.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Help-Customization-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IE-Spelling-Package-Dutch~31bf3856ad364e35~amd64~~6.2.9200.16437.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IE-Troubleshooters-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Common-Modem-Drivers-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IE-Spelling-Parent-Package-Dutch~31bf3856ad364e35~~~10.2.9200.16437.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IE-Troubleshooters-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IE-Troubleshooters-Package-wrapper~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-ImageBasedSetup-IE-Package-Base-Downlevel~31bf3856ad364e35~amd64~en-US~6.2.9200.16521.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IIS-WebServer-AddOn-2-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IIS-WebServer-AddOn-2-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IIS-WebServer-AddOn-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IE-Troubleshooters-Package-wrapper~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IE-Troubleshooters-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-ICM-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-GPUPipeline-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-LanguagePack~31bf3856ad364e35~amd64~de-DE~9.4.8112.16421.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-LanguagePack~31bf3856ad364e35~amd64~nl-NL~9.4.8112.16421.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-LanguagePack~31bf3856ad364e35~amd64~nl-NL~10.2.9200.16521.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~de-DE~9.4.8112.16421.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Optional-Package-wrapper~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~en-US~9.4.8112.16421.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-ImageBasedSetup-IE-Package-Base-Downlevel~31bf3856ad364e35~amd64~~6.2.9200.16521.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~en-US~8.0.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~fr-FR~9.4.8112.16421.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~nl-NL~10.2.9200.16521.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~nl-NL~9.4.8112.16421.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~en-US~10.2.9200.16521.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IIS-WebServer-AddOn-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~nl-NL~8.0.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~~8.0.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~~9.4.8112.16421.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Package-TopLevel~31bf3856ad364e35~amd64~~10.2.9200.16521.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Package-TopLevel~31bf3856ad364e35~amd64~~9.4.8112.16421.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Optional-Package-wrapper~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~en-US~9.4.8112.16421.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~~10.2.9200.16521.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-IIS-WebServer-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~en-US~10.2.9200.16521.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Killbits-Package~31bf3856ad364e35~amd64~~8.0.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Links-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~~9.4.8112.16421.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Package-MiniLP~31bf3856ad364e35~amd64~en-US~9.4.8112.16421.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Optional-Package~31bf3856ad364e35~amd64~~10.2.9200.16521.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Links-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Package-MiniLP~31bf3856ad364e35~amd64~en-US~10.2.9200.16521.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-LocalPack-US-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-VistaPlus-Update~31bf3856ad364e35~amd64~~9.4.8112.16421.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-LocalPack-GB-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Media-Format-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Indexing-Service-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-LocalPack-CA-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~~8.0.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-LanguagePack~31bf3856ad364e35~amd64~fr-FR~9.4.8112.16421.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-MediaCenter-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-LocalPack-ZA-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-MediaPlayback-OC-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Media-Format-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-MediaPlayer-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-LocalPack-AU-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-Package~31bf3856ad364e35~amd64~nl-NL~8.0.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-InternetExplorer-VistaPlus-Update~31bf3856ad364e35~amd64~~10.2.9200.16521.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-MobilePC-Client-Premium-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-MediaPlayer-DVDRegistration-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-MediaCenter-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-MobilePC-Client-SideShow-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-MobilePC-Client-Basic-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-MediaPlayer-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-MSMQ-Client-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Indexing-Service-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-MSMQ-Client-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-MobilePC-Client-Premium-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-MobilePC-Client-Sensors-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-MobilePC-Client-Sensors-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-NetFx3-OC-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-MobilePC-Client-SideShow-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-OfflineFiles-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-NFS-ClientSKU-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-MobilePC-Client-Basic-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-NFS-ClientSKU-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-OfflineFiles-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PeerDist-Client-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-MediaPlayback-OC-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-ParentalControls-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-OpticalMediaDisc-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PeerToPeer-Full-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PhotoBasicPackage~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-NetFx3-OC-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PhotoBasicPackage~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PhotoPremiumPackage~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-OpticalMediaDisc-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Personalization-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-NetworkDiagnostics-DirectAccessEntry-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~cs-CZ~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PeerDist-Client-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PhotoPremiumPackage~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-ParentalControls-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~de-DE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~da-DK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~es-ES~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~ar-SA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~fi-FI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~el-GR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~en-GB~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~bg-BG~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~fr-FR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~et-EE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~hu-HU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~en-US~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~it-IT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~he-IL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~hi-IN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PeerToPeer-Full-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~nb-NO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~ko-KR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~nl-NL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~hr-HR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~ja-JP~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~lt-LT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~ro-RO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~pt-BR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~ru-RU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~sv-SE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~th-TH~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~lv-LV~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~tr-TR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~sk-SK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~zh-HK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~zh-CN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~sl-SI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-TopLevel~31bf3856ad364e35~amd64~~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~zh-TW~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~cs-CZ~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~da-DK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~bg-BG~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~de-DE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~ar-SA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~en-GB~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~el-GR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~pt-PT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~fr-FR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~pl-PL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~fi-FI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~sr-LATN-CS~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~it-IT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package-MiniLP~31bf3856ad364e35~amd64~uk-UA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~et-EE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~hi-IN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~ja-JP~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~hu-HU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~lv-LV~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~lt-LT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~he-IL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~ko-KR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~nl-NL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~en-US~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~pl-PL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~es-ES~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~pt-PT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~pt-BR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~nb-NO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~ru-RU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~sl-SI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~sk-SK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~sv-SE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~uk-UA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~sr-LATN-CS~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~zh-HK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~th-TH~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~zh-TW~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~ro-RO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~zh-CN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Printing-Foundation-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Printing-XPSServices-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~tr-TR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-PlatformUpdate-Win7-SRV08R2-Package~31bf3856ad364e35~amd64~hr-HR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Printing-PremiumTools-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Printing-LocalPrinting-Home-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-ProfessionalEdition~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Printing-PremiumTools-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-RasRip-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-RDC-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Printer-Drivers-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-RecDisc-SDP-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-RDC-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-RecDisc-SDP-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Printing-Foundation-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Printer-Drivers-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-RemoteFX-RemoteClient-Setup-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-RemoteFX-VM-Setup-LanguagePack~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-RemoteAssistance-Package-Client~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-RemoteFX-RemoteClient-Setup-LanguagePack~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Printing-XPSServices-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SampleContent-Music-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SampleContent-Ringtones-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-RemoteFX-VM-Setup-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-ProfessionalEdition-wrapper~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SecureStartup-Basic-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SecureStartup-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Security-SPP-Component-SKU-Professional-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Security-SPP-Component-SKU-Ultimate-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-RasRip-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SearchEngine-Client-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-ShareMedia-ControlPanel-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SecureStartup-Basic-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-ServicingBaseline-Ultimate-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SecureStartup-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Shell-HomeGroup-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SearchEngine-Client-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Shell-PremiumInboxGames-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Security-SPP-Component-SKU-HomePremium-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-RemoteAssistance-Package-Client~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Shell-HomeGroup-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-ShareMedia-ControlPanel-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SimpleTCP-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SimpleTCP-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Shell-SoundThemes-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SNMP-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SnippingTool-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Shell-InboxGames-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Shell-InboxGames-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-StickyNotes-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-StorageService-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Security-WindowsActivationTechnologies-Package~31bf3856ad364e35~amd64~~7.1.7600.16395.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-StorageService-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Shell-MultiplayerInboxGames-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SUA-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SNMP-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Sidebar-Killbits-SDP-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SnippingTool-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Shell-MultiplayerInboxGames-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SUA-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-StarterEdition-wrapper~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SystemRestore-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-StickyNotes-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Telnet-Server-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Telnet-Client-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-TabletPC-OC-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Telnet-Server-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-TerminalServices-CommandLineTools-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-SystemRestore-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-TerminalServices-CommandLineTools-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-TerminalServices-MiscRedirection-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-TerminalServices-RemoteApplications-Client-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-TerminalServices-RemoteApplications-Client-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-TerminalServices-Publishing-WMIProvider-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-TerminalServices-UsbRedirector-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-TerminalServices-WMIProvider-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-TerminalServices-Publishing-WMIProvider-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-TerminalServices-WMIProvider-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~bg-BG~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-TerminalServices-UsbRedirector-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-TFTP-Client-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Telnet-Client-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~el-GR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~da-DK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~de-DE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~cs-CZ~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-TabletPC-OC-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~en-GB~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~fi-FI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~es-ES~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~en-US~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~hu-HU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~fr-FR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~he-IL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~it-IT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~et-EE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Tuner-Drivers-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-TFTP-Client-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~hi-IN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~lt-LT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~ko-KR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~nl-NL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~hr-HR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~ar-SA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~ja-JP~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~pt-PT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~lv-LV~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~ro-RO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~nb-NO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~sl-SI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~sr-LATN-CS~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~sv-SE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~th-TH~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~pl-PL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~zh-CN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~sk-SK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~pt-BR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~zh-HK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~ru-RU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~uk-UA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~tr-TR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UltimateEdition-wrapper~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-VirtualPC-Licensing-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-VirtualPC-USB-RPM-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~zh-TW~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-VirtualPC-USB-RPM-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-WindowsMediaPlayer-Troubleshooters-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-WindowsMediaPlayer-Troubleshooters-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-WinOcr-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-WMI-SNMP-Provider-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Shell-PremiumInboxGames-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-WMI-SNMP-Provider-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-WMPNetworkSharingService-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-WMPNetworkSharingService-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Xps-Foundation-Client-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Networking-MPSSVC-Rules-HomePremiumEdition-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Networking-MPSSVC-Rules-BusinessEdition-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-TerminalServices-MiscRedirection-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-WinOcr-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UltimateEdition~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-VirtualXP-Licensing-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Networking-MPSSVC-Rules-UltimateEdition-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\ntprint.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem13.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem14.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem11.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-UIAnimation-WinIP-Package~31bf3856ad364e35~amd64~~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem15.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem16.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem17.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem18.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem19.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem2.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem20.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem22.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem21.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem24.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem25.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem26.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem27.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem28.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem29.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-Xps-Foundation-Client-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem30.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem3.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem31.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem34.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem36.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem35.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem37.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem38.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem23.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem40.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem41.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem42.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem43.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem44.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem5.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem6.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem7.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem8.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem33.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_102_for_KB2750841~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_10_for_KB2496898~31bf3856ad364e35~amd64~~6.1.3.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_110_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_110_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_110_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_110_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_111_for_KB2661254~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_111_for_KB2862966~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_112_for_KB2661254~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_111_for_KB2868626~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem9.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_112_for_KB2862966~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_112_for_KB2808679~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_112_for_KB2868626~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_113_for_KB2661254~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_113_for_KB2798162~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_113_for_KB2808679~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_113_for_KB2813430~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_113_for_KB2862966~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_114_for_KB2661254~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_114_for_KB2798162~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\ntph.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_113_for_KB2868626~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_114_for_KB2808679~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem4.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_114_for_KB2813430~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_114_for_KB2862966~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_114_for_KB2868626~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_115_for_KB2798162~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\ntexe.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_115_for_KB2813430~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_116_for_KB2798162~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_116_for_KB2813430~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_115_for_KB2808679~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_117_for_KB2798162~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_117_for_KB2813430~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem12.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_11_for_KB2676562~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_118_for_KB2798162~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem39.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_118_for_KB2813430~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_13_for_KB2813170~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_11_for_KB2729094~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_11_for_KB2729094~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_146_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\nt5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_146_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_147_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_146_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_147_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_147_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\ntpe.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\oem10.CAT - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_148_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_148_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_148_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_149_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_148_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_150_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_150_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_146_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_150_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_150_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_149_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_151_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_151_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_149_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_147_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_151_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_152_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_149_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_151_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_153_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_152_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_152_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_153_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_154_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_154_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_155_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_153_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_155_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_155_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_154_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_155_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_156_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_153_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_156_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_156_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_152_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_156_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_157_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_159_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_158_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_157_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_158_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_158_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_159_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_157_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_159_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_159_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_160_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_160_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_160_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_157_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_161_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_162_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_162_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_160_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_161_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_154_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_158_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_161_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_162_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_162_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_163_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_164_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_161_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_163_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_164_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_165_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_163_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_165_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_166_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_165_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_164_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_163_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_166_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_165_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_167_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_164_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_166_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_166_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_167_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_167_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_168_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_167_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_168_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_168_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_169_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_169_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_169_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_170_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_16_for_KB2756921~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_170_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_169_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_171_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_172_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_172_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_171_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_170_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_170_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_172_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_171_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_173_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_173_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_174_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_171_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_174_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_172_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_175_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_175_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_175_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_173_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_174_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_175_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_176_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_173_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_176_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_176_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_177_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_176_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_177_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_177_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_168_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_179_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_174_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_179_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_178_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_177_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_17_for_KB2685811~31bf3856ad364e35~amd64~~6.1.1.11.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_179_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_17_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_179_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_178_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_17_for_KB2545698~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_180_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_18_for_KB2572077~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_178_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_180_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_18_for_KB2656373~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_180_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_18_for_KB2656373~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_18_for_KB2633873~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_178_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_18_for_KB2686831~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_18_for_KB2844286~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_18_for_KB2804579~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_18_for_KB2791765~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_18_for_KB2762895~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_180_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_18_for_KB982018~31bf3856ad364e35~amd64~~6.1.3.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_19_for_KB2518869~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_18_for_KB2833946~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_19_for_KB2492386~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_18_for_KB2789645~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_18_for_KB2844286~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_18_for_KB2836943~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_18_for_KB2863240~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2479943~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_19_for_KB2742599~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2488113~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2484033~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2505454~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2505438~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2508429~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2515325~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2492386~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2511250~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2519740~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2518869~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2524840~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2529073~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2491683~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2522422~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2532531~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2536275~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2541014~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2547666~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_19_for_KB2836943~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2530548~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2551127~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2544521~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2570947~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2506928~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2562937~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2572077~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2508272~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2584146~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2559049~31bf3856ad364e35~amd64~~9.4.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2618451~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2586448~31bf3856ad364e35~amd64~~9.4.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2603229~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2631813~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2619339~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_19_for_KB2698365~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2633873~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2647518~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2656373~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2647753~31bf3856ad364e35~amd64~~6.1.4.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2647753~31bf3856ad364e35~amd64~~6.1.3.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2656356~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2604115~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2647516~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2665364~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2667402~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2667402~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2685811~31bf3856ad364e35~amd64~~6.1.1.11.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_17_for_KB982018~31bf3856ad364e35~amd64~~6.1.3.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2685813~31bf3856ad364e35~amd64~~6.1.1.11.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2685939~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2579686~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2656373~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2686831~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2656411~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2658846~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2699988~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2695962~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2699779~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2675157~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2729452~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2727528~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2660075~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2719177~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2709630~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2736233~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2741355~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2722913~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2761217~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2744842~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2732487~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2762895~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2660649~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2770660~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2732487~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2736422~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2742599~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2620704~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2761451~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2712808~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2769369~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2761465~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2797052~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2786081~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2773072~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2813347~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2809289~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2804579~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2791765~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2803821~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2820331~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2803821~31bf3856ad364e35~amd64~~6.1.2.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2817183~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2830290~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2792100~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2835364~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2832414~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2789645~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2813956~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2833946~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2835361~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2820197~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2829530~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2836942~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2834140~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2836943~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2840631~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2845187~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2847927~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2836502~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2844286~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2844286~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2846960~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2839894~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2861698~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2846071~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2847204~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2853952~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2861855~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2859903~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2862772~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2876284~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2861191~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2884256~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2888505~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2868038~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2870699~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2862335~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB942914~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2836943~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_20_for_KB2496898~31bf3856ad364e35~amd64~~6.1.3.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_21_for_KB2496898~31bf3856ad364e35~amd64~~6.1.3.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB976902~31bf3856ad364e35~amd64~~6.1.1.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB976002~31bf3856ad364e35~amd64~~6.1.1.14.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2879017~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_21_for_KB2656356~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_21_for_KB2729452~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_21_for_KB2732059~31bf3856ad364e35~amd64~~6.1.5.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2838727~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_21_for_KB2750841~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_22_for_KB2685813~31bf3856ad364e35~amd64~~6.1.1.11.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2900986~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB2863240~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_23_for_KB2868116~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_23_for_KB2604115~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_22_for_KB2813347~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_22_for_KB2773072~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_26_for_KB2763523~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_20_for_KB2750841~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_25_for_KB2756921~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_1_for_KB982018~31bf3856ad364e35~amd64~~6.1.3.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_27_for_KB2762895~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2479628~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_26_for_KB2756921~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2479943~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2475792~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_27_for_KB2791765~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_27_for_KB982018~31bf3856ad364e35~amd64~~6.1.3.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2487426~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2476490~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_28_for_KB2492386~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2492386~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2503665~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2485376~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2502789~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2482017~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2505454~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_23_for_KB2773072~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2506223~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2488113~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2509553~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2507938~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_27_for_KB2756921~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2503658~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2506014~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2518869~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2511455~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2524375~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2528507~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2482122~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2522422~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2529073~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2533552~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2534366~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2536276~31bf3856ad364e35~amd64~~6.1.2.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2519736~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2533623~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2545698~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2544893~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2552343~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2563227~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2555917~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2556532~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2506212~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2507618~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2511250~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2567053~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2579686~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2563894~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2484033~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2567680~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2572077~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2588516~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2570947~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2585542~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2631813~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2633873~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2621440~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2564958~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2616676~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2604115~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2639308~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2641690~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2647753~31bf3856ad364e35~amd64~~6.1.4.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2653956~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2645640~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2644615~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2655992~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2620712~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2647753~31bf3856ad364e35~amd64~~6.1.3.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2641653~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2656373~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2654428~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2640148~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2676562~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2656356~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2686831~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2659262~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2690533~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2660465~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2660649~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2705219~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2685939~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2656373~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2709162~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2718704~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2691442~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2718523~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2705219~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2510531~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2719985~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2729094~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2688338~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2729094~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2731847~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2732500~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2729452~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2732500~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2731847~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2735855~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2699988~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2736422~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2739159~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2724197~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2709715~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2742599~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2750841~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2749655~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2741355~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2722913~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2753842~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2757638~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2753842~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2769369~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2761226~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2719177~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2778344~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2778930~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2762895~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2744842~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2743555~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2779030~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2785220~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2789645~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2790655~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2786400~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2761465~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2799494~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2807986~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2799926~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2813170~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2790113~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2792100~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2804579~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2761451~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2829361~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2820331~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2808735~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2833946~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2834140~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2834886~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2835364~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2836943~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2836942~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2679255~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2836943~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2839894~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2835361~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2840149~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2829530~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2840631~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2845690~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2844286~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2809289~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2823324~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2844286~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2847311~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2849470~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2817183~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2859537~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2850851~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2838727~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2862152~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2861855~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2861698~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2863240~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2846071~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2868038~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2862335~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2864058~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2864202~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2875783~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2846960~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2868623~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2876315~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2876331~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2872339~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2862772~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2888049~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2882822~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2791765~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB942914~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2870699~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_36_for_KB2732059~31bf3856ad364e35~amd64~~6.1.5.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_37_for_KB2731771~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2879017~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2883150~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_38_for_KB2813347~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_30_for_KB2868725~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_39_for_KB2773072~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_37_for_KB2758857~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_31_for_KB2868725~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_38_for_KB2868116~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2425227~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_39_for_KB2813347~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2476490~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2475792~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2479628~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2487426~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2496898~31bf3856ad364e35~amd64~~6.1.3.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_38_for_KB2726535~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2492386~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2506212~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2506223~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2507618~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2485376~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2868116~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_38_for_KB2773072~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2497640~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_2_for_KB2888505~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2528507~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2518869~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2547666~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2530548~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2507938~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2534366~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2502789~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2552343~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2545698~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2555917~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2556532~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2533623~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2563227~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2579686~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2560656~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2564958~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2567053~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2510531~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2621440~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2559049~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2567680~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2639308~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2603229~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2654428~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2655992~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2585542~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2586448~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2641653~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2620712~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2660465~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2656356~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2660649~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2667402~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2676562~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2604115~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2667402~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2705219~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2679255~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2705219~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2709162~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2698365~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2718523~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2653956~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2644615~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2724197~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2729452~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2709715~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2659262~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2731847~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2731847~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2749655~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2761226~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2778344~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2736422~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2753842~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2750841~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2778930~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2753842~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2735855~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2785220~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2790113~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2790655~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2786400~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2719857~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2807986~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2813170~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2829361~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2808735~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2836943~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2836942~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2840631~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2846960~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2779030~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2850851~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2859537~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2849470~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2862335~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2861698~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2868623~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2864058~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2876331~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2872339~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2882822~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2883150~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_40_for_KB2798162~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_40_for_KB2773072~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2876315~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_40_for_KB2813347~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2888049~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_40_for_KB2868116~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_40_for_KB2893519~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2847311~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2845690~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_41_for_KB2773072~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB982018~31bf3856ad364e35~amd64~~6.1.3.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2834886~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_41_for_KB2813347~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_41_for_KB982018~31bf3856ad364e35~amd64~~6.1.3.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_43_for_KB2750841~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_41_for_KB2893519~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2799494~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_47_for_KB2868725~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_42_for_KB2763523~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2530548~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2496898~31bf3856ad364e35~amd64~~6.1.3.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2559049~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_41_for_KB2798162~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2560656~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2586448~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2533623~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2604115~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2507938~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2497640~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2742599~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2579686~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2676562~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2719857~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2656356~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2685939~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2567680~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2621440~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2750841~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2698365~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2872339~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2761217~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2882822~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_53_for_KB2762895~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2813170~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_57_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_53_for_KB2791765~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_54_for_KB2492386~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_57_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2790113~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_56_for_KB2868725~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_57_for_KB2863058~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_58_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_57_for_KB2868725~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_58_for_KB2677070~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_57_for_KB2677070~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_57_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_57_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_58_for_KB2758857~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_58_for_KB2731771~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_58_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_59_for_KB2550648~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_58_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_3_for_KB2853952~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_58_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_59_for_KB2726535~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_59_for_KB2731771~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_58_for_KB2863058~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_59_for_KB2868626~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_58_for_KB2868725~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_59_for_KB2862966~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_59_for_KB2868725~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_4_for_KB2859537~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_59_for_KB2661254~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_59_for_KB2808679~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_59_for_KB2758857~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_5_for_KB2496898~31bf3856ad364e35~amd64~~6.1.3.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_5_for_KB2604115~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_5_for_KB2698365~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_5_for_KB2719857~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_59_for_KB2813430~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_5_for_KB2859537~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_5_for_KB2872339~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_5_for_KB2729094~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_5_for_KB2729094~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_60_for_KB2808679~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_60_for_KB2813430~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_5_for_KB2586448~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_60_for_KB2862966~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_5_for_KB2559049~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_60_for_KB2550648~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_5_for_KB2807986~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_5_for_KB2882822~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_5_for_KB2530548~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_62_for_KB2798162~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_6_for_KB2393802~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_6_for_KB2604115~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_6_for_KB2621440~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_73_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_62_for_KB2893519~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_73_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_60_for_KB2726535~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_73_for_KB2863058~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_60_for_KB2661254~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_6_for_KB2698365~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_60_for_KB2868626~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_75_for_KB2661254~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_74_for_KB2758857~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_73_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_75_for_KB2726535~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_75_for_KB2808679~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_75_for_KB2813430~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_73_for_KB2677070~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_75_for_KB2862966~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_76_for_KB2550648~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_78_for_KB2893519~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_75_for_KB2868626~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_73_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_76_for_KB2808679~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_81_for_KB2893519~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_74_for_KB2731771~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_80_for_KB2893519~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_7_for_KB2667402~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_7_for_KB2667402~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_94_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_7_for_KB2604115~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_94_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_8_for_KB2545698~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_79_for_KB2893519~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_8_for_KB2698365~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_94_for_KB2677070~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_5_for_KB2656356~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_94_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_7_for_KB2698365~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_96_for_KB2862966~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_94_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_94_for_KB2863058~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_96_for_KB2661254~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_96_for_KB2868626~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_97_for_KB2550648~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_7_for_KB2547666~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_98_for_KB2798162~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_98_for_KB2813430~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_9_for_KB2496898~31bf3856ad364e35~amd64~~6.1.3.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_9_for_KB2639308~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_95_for_KB2758857~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_9_for_KB2709715~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_9_for_KB2556532~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_96_for_KB2726535~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_9_for_KB2761217~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2393802_RTM~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2393802~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_9_for_KB2799494~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_95_for_KB2731771~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_9_for_KB2679255~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2425227_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_9_for_KB2644615~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2425227~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_9_for_KB2724197~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2475792_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2479628_SP1~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2479628~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_97_for_KB2808679~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2475792~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2479943_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2479943~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2476490_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2484033_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2482122~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2482017~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2476490~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2485376_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2482122_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2488113~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2487426_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2485376~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2484033~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2488113_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2491683~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2491683_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2496898_SP1~31bf3856ad364e35~amd64~~6.1.3.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2496898_RTM~31bf3856ad364e35~amd64~~6.1.3.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2492386_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2492386~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2487426~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2497640_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2482017_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2496898~31bf3856ad364e35~amd64~~6.1.3.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2502789_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2503665_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2497640~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2503658_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2503658~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2505438_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2505454_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2505438~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2505454~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2506014_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2506212~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2506212_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2505454_RTM~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2506223~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2507618_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2502789~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2507618~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2506928_SP1~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2506223_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2506928~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2507938_SP1~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2503665~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2508429~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2508272~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2508429_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2506014~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2508272_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2509553~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2510531~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2509553_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2510531_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2511250_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2511250~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2519736_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2515325_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2519736~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2511455~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2511455_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2519740~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2515325~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2507938~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2519740_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2518869~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2524375_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_9_for_KB2534366~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2524840~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2528507~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2524840_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2524375~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2529073_RTM~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2528507_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2522422_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2530548_RTM~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2522422~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2529073~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2530548~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2529073_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2532531~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2533623~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2530548~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2534366_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2536275_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2534366~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2533623_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2530548_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2533552~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2536275~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2536276~31bf3856ad364e35~amd64~~6.1.2.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2544521_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2541014_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2536276_SP1~31bf3856ad364e35~amd64~~6.1.2.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2544893_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2544521~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2544893~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2545698_RTM~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2547666_RTM~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2545698_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2547666_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2533552_RTM~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2532531_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2550648~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2518869_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2550648_SP1~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2534366_RTM~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2552343_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2547666~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2552343~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2555917_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2545698~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2541014~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2551127~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2556532_RTM~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2555917~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2551127_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2559049_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2556532~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2560656_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2559049_RTM~31bf3856ad364e35~amd64~~9.4.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2556532_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2559049~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2562937_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2560656~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2563227_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2563894~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2559049~31bf3856ad364e35~amd64~~9.4.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2567053~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2567680_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2562937~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2563227~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2563894_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2564958~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2570791_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2567680~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2570791~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2567053_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2564958_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2572077_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2572077~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2579686~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2584146_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2570947~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2586448_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2585542_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2586448~31bf3856ad364e35~amd64~~9.4.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2586448~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2588516_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2585542~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2603229~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2588516~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2603229_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2604115_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2616676~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2579686_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2584146~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2616676_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2619339_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2618451_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2586448_RTM~31bf3856ad364e35~amd64~~9.4.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2618451~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2604115~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2620712_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2621440~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2603229_RTM~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2620712~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2619339~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2620704~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2631813~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2620704_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2633952_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2633873_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2639308_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2621440_SP1~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2639308~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2633873~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2640148_SP1~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2640148~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2641653_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2641690~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2644615_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2645640_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2641690_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2645640~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2647516_RTM~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2647518~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2639308_RTM~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2641653~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2644615~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2631813_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2647753_SP1~31bf3856ad364e35~amd64~~6.1.3.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2647516~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2647753_SP1~31bf3856ad364e35~amd64~~6.1.4.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2653956_SP1~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2653956~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2654428~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2647753~31bf3856ad364e35~amd64~~6.1.4.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2655992_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2654428_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2655992~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2656373_SP1~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2656356~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2656373_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2633952~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2656411_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2647753~31bf3856ad364e35~amd64~~6.1.3.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2570947_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2647518_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2656356_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2656373~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2656373~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2659262~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2659262_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2656411~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2658846_SP1~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2660075_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2660465~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2660465_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2660075~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2658846~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2660649_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2660649~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2661254_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2665364~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2667402_SP1~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2661254~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2667402_RTM~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2675157~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2676562~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2675157_RTM~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2667402_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2676562_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2667402~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2667402_RTM~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2676562_RTM~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2679255_SP1~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2667402~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2685811_SP1~31bf3856ad364e35~amd64~~6.1.1.11.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2679255_RTM~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2679255~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2685813~31bf3856ad364e35~amd64~~6.1.1.11.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2686831_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2644615_RTM~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2677070_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2685811~31bf3856ad364e35~amd64~~6.1.1.11.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2685813_SP1~31bf3856ad364e35~amd64~~6.1.1.11.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2685939_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2688338_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2690533~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2690533_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2688338~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2691442_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2685939~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2695962_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2695962~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2686831~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2698365~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2698365_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2699988~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2691442~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2698365_RTM~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2699779~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2699988_RTM~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2705219_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2709162~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2709630_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2699779_SP1~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2705219_SP1~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2705219~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2677070~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2705219~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2709630~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2709715_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2709715_RTM~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2712808~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2712808_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2718704_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2718523~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2709715~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2718523_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2719857~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2718704~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2719177_RTM~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2719857_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2709162_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2722913_RTM~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2722913~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2719985~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2726535_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2665364_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2724197~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2727528~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2729094_RTM~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2726535~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2727528_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2729094~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2724197_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2729094_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2729094~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2729452~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2731771~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2719177~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2731847_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2719985_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2729452_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2731771_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2731847_SP1~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2731847~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2732059~31bf3856ad364e35~amd64~~6.1.5.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2731847~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2729094_RTM~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2732487_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2732059_SP1~31bf3856ad364e35~amd64~~6.1.5.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2729094_SP1~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2732487~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2724197_RTM~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2732487~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2732487_SP1~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2732500_SP1~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2732500_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2735855_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2732500~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2735855~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2736422_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2736233~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2732500~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2741355_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2742599_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2742599~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2736233_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2744842~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2739159_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2741355~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2736422~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2743555_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2739159~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2749655_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2749655~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2750841_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2753842_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2753842_SP1~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2753842~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2750841~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2744842_RTM~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2756921_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2756921~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2743555~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2756822_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2756822~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2758857~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2753842~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2757638_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2761226~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2761217~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2761217_RTM~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2761226_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2758857_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2757638~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2761451~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2761465~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2761451_RTM~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2761465_RTM~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2761217_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2770660_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2763523_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2770660~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2773072~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2762895~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2762895_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2778344_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2769369_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2769369~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2779030_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2773072_SP1~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2778344~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2763523~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2785220_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2779562~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2786081~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2785220~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2786400_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2779562_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2778930_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2779030~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2778930~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2790113_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2789645_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2786400~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2791765~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2790113~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2792100_RTM~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2789645~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2786081_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2790655_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2790655~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2798162_SP1~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2799494_RTM~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2799494_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2797052_RTM~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2799926~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2791765_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2797052~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2799926_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2798162~31bf3856ad364e35~amd64~~6.1.1.5.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2803821_SP1~31bf3856ad364e35~amd64~~6.1.2.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2807986_RTM~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2803821~31bf3856ad364e35~amd64~~6.1.2.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2804579_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2807986~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2808679_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2803821~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2792100~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2808735_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2809289_RTM~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2808679~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2813170_RTM~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2808735~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2813170_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2803821_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2813347_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2813347~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2799494~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2809289~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2813956_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2813170~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2813956~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2807986_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2813430~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2820197~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2813430_SP1~31bf3856ad364e35~amd64~~6.1.1.4.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2817183~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2804579~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2823324_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2820331_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2829530_RTM~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2829361_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2817183_RTM~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2829361~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2823324~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2830290~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2820197_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2829530~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2834140_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2820331~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2834140~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2832414_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2833946_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2833946~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2836502_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2832414~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2835361_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2836502~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2835364_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2830290_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2836943_SP1~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2836942_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2836942~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2839894_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2839894~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2834886_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2840149_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2838727_RTM~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2834886~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2836943_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2840149~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2840631~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2844286~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2844286_SP1~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2838727~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2835364~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2845187_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2845690_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2836943~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2836943~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2844286_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2845187~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2844286~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2846960~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2847311~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2845690~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2847311_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2846960_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2847204_RTM~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2849470~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2847927_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2849470_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2850851_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2850851~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2835361~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2853952_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2847927~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2846071~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2859537_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2847204~31bf3856ad364e35~amd64~~9.4.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2853952~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2852386_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2859903~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2859903_RTM~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2859537~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2861191~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2861191_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2861855~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2852386~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2862152~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2862335_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2862152_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2861698_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2853952_RTM~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2846071_RTM~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2862335_RTM~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2862966_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2862772_RTM~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2862966~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2863058~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2862335~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2862772~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2863240_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2863240~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2861855_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2863058_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2864058~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2861698~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2864202_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2868038_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2868116_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2868116~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2868623_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2868725~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2870699_RTM~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2868623~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2872339_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2868038~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2875783~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2864202~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2875783_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2864058_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2868725_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2876315~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2876284~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2868626_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2876315_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2872339~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2876284_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2876331~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2882822~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2868626~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2876331_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2882822_SP1~31bf3856ad364e35~amd64~~6.1.1.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2883150_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2840631_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2879017~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2888505~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2888049~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2883150~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2879017_RTM~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2893519~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2893519_SP1~31bf3856ad364e35~amd64~~6.1.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB942914_SP1~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2888505_RTM~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2870699~31bf3856ad364e35~amd64~~10.2.1.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2900986_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB976002~31bf3856ad364e35~amd64~~6.1.1.14.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2884256~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB942914~31bf3856ad364e35~amd64~~6.1.2.0.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB976902_RTM~31bf3856ad364e35~amd64~~6.1.1.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB976932~31bf3856ad364e35~amd64~~6.1.0.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB976902~31bf3856ad364e35~amd64~~6.1.1.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB976002_RTM~31bf3856ad364e35~amd64~~6.1.1.14.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB976933~31bf3856ad364e35~amd64~de-DE~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB976933~31bf3856ad364e35~amd64~es-ES~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB976933~31bf3856ad364e35~amd64~fr-FR~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB976933~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB976933~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB976933~31bf3856ad364e35~amd64~ja-JP~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB982018_RTM~31bf3856ad364e35~amd64~~6.1.3.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB982018_SP1~31bf3856ad364e35~amd64~~6.1.3.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnbr004.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnbr005.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnbr008.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnbr002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnbr009.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnbr006.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB982018~31bf3856ad364e35~amd64~~6.1.3.2.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnbr00a.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2888049_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnbr007.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2900986~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnca00b.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnca00d.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnca00c.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnca003.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnca00g.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnca00f.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnca00i.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnca00h.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Package_for_KB2884256_SP1~31bf3856ad364e35~amd64~~6.1.1.1.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnca00e.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnca00y.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnep002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnep005.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnep004.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnep00c.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnep00e.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnep00g.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnca00x.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnep00d.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnca00a.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnep00l.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prngt002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnep00b.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnep003.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prngt004.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnfx002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnca00z.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnge001.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnep00f.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prngt003.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnbr003.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnhp003.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnhp004.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnhp002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnhp005.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnin004.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnkm003.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnkm005.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnep00a.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnky003.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnky002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnkm002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnky005.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnky007.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnin002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnin003.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnkm004.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnle002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnle004.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnky008.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnky006.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnle003.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnky009.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnky004.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx006.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx004.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx007.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx005.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx00a.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx003.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx009.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx00b.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx00d.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx00e.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx00y.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx00w.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnnr002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnnr003.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnms002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnod002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnrc002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx00v.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnrc003.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnok002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx00c.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx008.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnrc006.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnrc00a.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnrc00b.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnrc007.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx00x.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnrc00c.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnsv002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnrc004.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnsh002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnts003.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnsv003.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnsv004.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnnr004.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnts002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnso002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnsa002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnxx002.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Server-Help-Package.ClientUltimate~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Server-Help-Package.ClientHomePremium~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~cs-CZ~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~ar-SA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Server-Help-Package.ClientProfessional~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Server-Help-Package.ClientProfessional~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~de-DE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Server-Help-Package.ClientHomePremium~31bf3856ad364e35~amd64~nl-NL~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~el-GR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~es-ES~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Server-Help-Package.ClientUltimate~31bf3856ad364e35~amd64~~6.1.7601.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~fr-FR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~et-EE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~da-DK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~he-IL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~en-GB~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~hu-HU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~hr-HR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~fi-FI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~bg-BG~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~lt-LT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnlx00z.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~it-IT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~hi-IN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~lv-LV~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~pl-PL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~pt-BR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~nl-NL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~pt-PT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~nb-NO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~sk-SK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~ro-RO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\prnrc005.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~ru-RU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~ja-JP~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~sr-LATN-CS~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~sl-SI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~zh-CN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~uk-UA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~sv-SE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~zh-TW~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~th-TH~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~zh-HK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~tr-TR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~ar-SA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~ko-KR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~cs-CZ~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~da-DK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~de-DE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~bg-BG~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~en-US~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~fr-FR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~hr-HR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~fi-FI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~el-GR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~es-ES~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~et-EE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~he-IL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~hi-IN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~lt-LT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~en-GB~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~ko-KR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~hu-HU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~nb-NO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~nl-NL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~ja-JP~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~lv-LV~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~ru-RU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~pl-PL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~pt-PT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~it-IT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~pt-BR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~sr-LATN-CS~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~sk-SK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~th-TH~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~ro-RO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~zh-HK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~sv-SE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~zh-CN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~uk-UA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~tr-TR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~sl-SI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~de-DE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~en-US~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~bg-BG~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~cs-CZ~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~zh-TW~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~ar-SA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~el-GR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~en-US~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~et-EE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~da-DK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~es-ES~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~hi-IN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~en-GB~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~hr-HR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~he-IL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~fi-FI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~ko-KR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~fr-FR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~nb-NO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~lv-LV~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~pl-PL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~pt-PT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~it-IT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~hu-HU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~sk-SK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~nl-NL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~ro-RO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~sl-SI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~pt-BR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~sr-LATN-CS~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~ru-RU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~zh-TW~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~uk-UA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~sv-SE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~zh-CN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~ar-SA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~th-TH~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~zh-HK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~de-DE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~en-GB~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~da-DK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~bg-BG~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~en-US~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~cs-CZ~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~lt-LT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~ja-JP~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~el-GR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~et-EE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~es-ES~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~he-IL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~hr-HR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~hu-HU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~fr-FR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~hi-IN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~ja-JP~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Shell-WinIP-Package~31bf3856ad364e35~amd64~tr-TR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~lt-LT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~lv-LV~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~pl-PL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~nb-NO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~pt-BR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~ro-RO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~sk-SK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~ko-KR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~sv-SE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~sl-SI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~fi-FI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~nl-NL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~sr-LATN-CS~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~th-TH~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~zh-HK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~uk-UA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~tr-TR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~ru-RU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~ar-SA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~cs-CZ~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~da-DK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~bg-BG~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~pt-PT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~en-GB~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~es-ES~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~de-DE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~fr-FR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~fi-FI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~hi-IN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~hu-HU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~hr-HR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~he-IL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~zh-TW~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~ja-JP~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~et-EE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~lv-LV~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~lt-LT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~el-GR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~nl-NL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~ko-KR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~pl-PL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~en-US~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~it-IT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~ro-RO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~zh-CN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~pt-BR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~sr-LATN-CS~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~nb-NO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~ru-RU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~sk-SK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~sl-SI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~uk-UA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~tr-TR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~zh-CN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~zh-HK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~pt-PT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~zh-TW~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~ar-SA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~th-TH~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~bg-BG~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~en-US~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~cs-CZ~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~da-DK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~he-IL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~et-EE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~el-GR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~it-IT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~hi-IN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~de-DE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~ja-JP~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~hr-HR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~fr-FR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~hu-HU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~es-ES~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Package~31bf3856ad364e35~amd64~it-IT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~sv-SE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~en-GB~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~nb-NO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~nl-NL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~lt-LT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~pt-BR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~ro-RO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~pt-PT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~ko-KR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~sr-LATN-CS~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~pl-PL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~lv-LV~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~ru-RU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~sv-SE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~th-TH~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~uk-UA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~sk-SK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~zh-TW~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~zh-HK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~ar-SA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~cs-CZ~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~da-DK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~el-GR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~bg-BG~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~tr-TR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~fi-FI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~es-ES~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~sl-SI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~fr-FR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~he-IL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~hi-IN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~hu-HU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~hr-HR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~it-IT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~de-DE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~lt-LT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~lv-LV~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~nl-NL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~nb-NO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~en-GB~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~pl-PL~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~ru-RU~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~zh-CN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~ko-KR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~pt-BR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~et-EE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~sk-SK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Graphics-Package~31bf3856ad364e35~amd64~fi-FI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~sr-LATN-CS~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~uk-UA~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~sv-SE~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~pt-PT~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~en-US~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~ro-RO~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~zh-CN~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Windows7SP1-KB976933~31bf3856ad364e35~amd64~~6.1.0.17514.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~sl-SI~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Printing-Package~31bf3856ad364e35~amd64~~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~th-TH~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WUClient-SelfUpdate-Aux-AuxComp~31bf3856ad364e35~amd64~~7.6.7600.256.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~tr-TR~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WUClient-SelfUpdate-Aux-TopLevel~31bf3856ad364e35~amd64~~7.6.7600.256.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WUClient-SelfUpdate-Aux~31bf3856ad364e35~amd64~~7.6.7600.256.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WUClient-SelfUpdate-Core-AdmComp~31bf3856ad364e35~amd64~nl-NL~7.6.7600.256.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~zh-HK~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~zh-TW~7.1.7601.16492.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WUClient-SelfUpdate-Aux~31bf3856ad364e35~amd64~nl-NL~7.6.7600.256.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WUClient-SelfUpdate-Aux-AuxComp~31bf3856ad364e35~amd64~nl-NL~7.6.7600.256.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WUClient-SelfUpdate-Core-CoreComp~31bf3856ad364e35~amd64~~7.6.7600.256.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\windows-legacy-whql.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WUClient-SelfUpdate-Core-AdmComp~31bf3856ad364e35~amd64~~7.6.7600.256.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WUClient-SelfUpdate-Aux-MiniLP~31bf3856ad364e35~amd64~nl-NL~7.6.7600.256.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WUClient-SelfUpdate-Core-MiniLP~31bf3856ad364e35~amd64~nl-NL~7.6.7600.256.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WUClient-SelfUpdate-Core-TopLevel~31bf3856ad364e35~amd64~~7.6.7600.256.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WUClient-SelfUpdate-Core-UIComp~31bf3856ad364e35~amd64~~7.6.7600.256.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WUClient-SelfUpdate-Core~31bf3856ad364e35~amd64~~7.6.7600.256.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WUClient-SelfUpdate-ActiveX~31bf3856ad364e35~amd64~~7.6.7600.256.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WUClient-SelfUpdate-Core~31bf3856ad364e35~amd64~nl-NL~7.6.7600.256.cat - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WUClient-SelfUpdate-Core-CoreComp~31bf3856ad364e35~amd64~nl-NL~7.6.7600.256.cat - Ok
C:\Windows\system32\config\BCD-Template - Ok
C:\Windows\system32\config\BCD-Template.LOG - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Win8IP-Microsoft-Windows-Multimedia-Package~31bf3856ad364e35~amd64~ja-JP~7.1.7601.16492.cat - Ok
C:\Windows\system32\config\COMPONENTS.LOG - Ok
C:\Windows\system32\config\COMPONENTS.LOG2 - Ok
C:\Windows\system32\com\MigRegDB.exe - Ok
C:\Windows\system32\config\COMPONENTS{016888b9-6c6f-11de-8d1d-001e0bcde3ec}.TM.blf - Ok
C:\Windows\system32\com\comrepl.exe - Ok
C:\Windows\system32\com\comempty.dat - Ok
C:\Windows\system32\com\nl-NL\MigRegDB.exe.mui - Ok
C:\Windows\system32\com\nl-NL\comrepl.exe.mui - Ok
C:\Windows\system32\config\COMPONENTS{19bdf00b-19e8-11e3-9968-4c809397a0b2}.TM.blf - Ok
C:\Windows\system32\com\mtsadmin.tlb - Ok
C:\Windows\system32\config\COMPONENTS{016888b9-6c6f-11de-8d1d-001e0bcde3ec}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{3920b4eb-8be2-11e1-a187-4c809397a0b2}.TM.blf - Ok
C:\Windows\system32\config\COMPONENTS{4454d5a9-77e5-11e1-bc8e-4c809397a0b2}.TM.blf - Ok
C:\Windows\system32\config\COMPONENTS{016888b9-6c6f-11de-8d1d-001e0bcde3ec}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{3920b4eb-8be2-11e1-a187-4c809397a0b2}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{7b7a424b-5903-11e2-84f0-4c809397a0b2}.TM.blf - Ok
C:\Windows\system32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\WUClient-SelfUpdate-Core-UIComp~31bf3856ad364e35~amd64~nl-NL~7.6.7600.256.cat - Ok
C:\Windows\system32\config\COMPONENTS{4454d5a9-77e5-11e1-bc8e-4c809397a0b2}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{942d6863-62e8-11e1-96a7-4c809397a0b2}.TM.blf - Ok
C:\Windows\system32\com\comadmin.dll - Ok
C:\Windows\system32\config\COMPONENTS{99c56b47-f0e3-11e1-b261-4c809397a0b2}.TM.blf - Ok
C:\Windows\system32\config\COMPONENTS{7b7a424b-5903-11e2-84f0-4c809397a0b2}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{9a02c22b-8575-11e2-b1a0-4c809397a0b2}.TM.blf - Ok
C:\Windows\system32\config\COMPONENTS{7b7a424b-5903-11e2-84f0-4c809397a0b2}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{19bdf00b-19e8-11e3-9968-4c809397a0b2}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{19bdf00b-19e8-11e3-9968-4c809397a0b2}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{e045a8cb-647c-11e2-90c9-4c809397a0b2}.TM.blf - Ok
C:\Windows\system32\config\COMPONENTS{99c56b47-f0e3-11e1-b261-4c809397a0b2}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{9a02c22b-8575-11e2-b1a0-4c809397a0b2}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{f12a0f72-6251-11e1-9018-4c809397a0b2}.TM.blf - Ok
C:\Windows\system32\config\COMPONENTS{99c56b47-f0e3-11e1-b261-4c809397a0b2}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{f4630972-903f-11e1-9ff1-4c809397a0b2}.TM.blf - Ok
C:\Windows\system32\config\COMPONENTS{9a02c22b-8575-11e2-b1a0-4c809397a0b2}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{f12a0f72-6251-11e1-9018-4c809397a0b2}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{f12a0f72-6251-11e1-9018-4c809397a0b2}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{4454d5a9-77e5-11e1-bc8e-4c809397a0b2}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{e045a8cb-647c-11e2-90c9-4c809397a0b2}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\config\DEFAULT - read error
C:\Windows\system32\config\COMPONENTS{e045a8cb-647c-11e2-90c9-4c809397a0b2}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\config\DEFAULT.LOG - Ok
C:\Windows\system32\config\DEFAULT.LOG1 - read error
C:\Windows\system32\config\DEFAULT.LOG2 - read error
C:\Windows\system32\config\SAM - read error
C:\Windows\system32\config\SAM.LOG1 - read error
C:\Windows\system32\config\SAM.LOG2 - read error
C:\Windows\system32\config\SAM.LOG - Ok
C:\Windows\system32\config\COMPONENTS{3920b4eb-8be2-11e1-a187-4c809397a0b2}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\config\SECURITY - read error
C:\Windows\system32\config\SECURITY.LOG2 - read error
C:\Windows\system32\config\SECURITY.LOG1 - read error
C:\Windows\system32\config\SOFTWARE - read error
C:\Windows\system32\config\SOFTWARE.LOG1 - read error
C:\Windows\system32\config\SOFTWARE.LOG2 - read error
C:\Windows\system32\config\SOFTWARE.LOG - Ok
C:\Windows\system32\config\SYSTEM - read error
C:\Windows\system32\config\SYSTEM.LOG1 - read error
C:\Windows\system32\config\SECURITY.LOG - Ok
C:\Windows\system32\config\SYSTEM.LOG2 - read error
C:\Windows\system32\config\RegBack\DEFAULT - read error
C:\Windows\system32\config\RegBack\DEFAULT.LOG2 - Ok
C:\Windows\system32\config\SYSTEM.LOG - Ok
C:\Windows\system32\config\RegBack\DEFAULT.LOG1 - Ok
C:\Windows\system32\config\RegBack\SAM.LOG1 - Ok
C:\Windows\system32\config\COMPONENTS{f4630972-903f-11e1-9ff1-4c809397a0b2}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\config\RegBack\SAM.LOG2 - Ok
C:\Windows\system32\config\RegBack\SECURITY.LOG1 - Ok
C:\Windows\system32\config\RegBack\SECURITY.LOG2 - Ok
C:\Windows\system32\config\RegBack\SAM - read error
C:\Windows\system32\config\RegBack\SOFTWARE.LOG2 - Ok
C:\Windows\system32\config\RegBack\SOFTWARE.LOG1 - Ok
C:\Windows\system32\config\RegBack\SYSTEM.LOG1 - Ok
C:\Windows\system32\config\RegBack\SECURITY - read error
C:\Windows\system32\config\RegBack\SOFTWARE - read error
C:\Windows\system32\config\RegBack\SYSTEM.LOG2 - Ok
C:\Windows\system32\config\RegBack\SYSTEM - read error
C:\Windows\system32\config\COMPONENTS.LOG1 - Ok
C:\Windows\system32\config\COMPONENTS{942d6863-62e8-11e1-96a7-4c809397a0b2}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{942d6863-62e8-11e1-96a7-4c809397a0b2}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{f4630972-903f-11e1-9ff1-4c809397a0b2}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\config\TxR\{016888cd-6c6f-11de-8d1d-001e0bcde3ec}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\config\TxR\{016888cd-6c6f-11de-8d1d-001e0bcde3ec}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\config\systemprofile\ntuser.dat.LOG - Ok
C:\Windows\system32\config\systemprofile\ntuser.dat.LOG2 - Ok
C:\Windows\system32\config\TxR\{016888cd-6c6f-11de-8d1d-001e0bcde3ec}.TM.blf - Ok
C:\Windows\system32\config\systemprofile\ntuser.dat{d5e30002-f518-11df-a5c1-806e6f6e6963}.TM.blf - Ok
C:\Windows\system32\config\systemprofile\ntuser.dat - Ok
C:\Windows\system32\config\systemprofile\ntuser.dat{d5e30002-f518-11df-a5c1-806e6f6e6963}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\config\systemprofile\ntuser.dat{d5e30002-f518-11df-a5c1-806e6f6e6963}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\3C3948BE6E525B8A8CEE9FAC91C9E392_5BEB6C6453DB87D996BDBC5D90D34AE1 - Ok
>C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\57C8EDB95DF3F0AD4EE2DC2B8CFD4157 is CAB archive
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\57C8EDB95DF3F0AD4EE2DC2B8CFD4157 - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\57C8EDB95DF3F0AD4EE2DC2B8CFD4157 - archive
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\60E31627FDA0A46932B0E5948949F2A5 - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\696F3DE637E6DE85B458996D49D759AD - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\7396C420A8E1BC1DA97F1AF0D10BAD21 - Ok
C:\Windows\system32\config\TxR\{016888cc-6c6f-11de-8d1d-001e0bcde3ec}.TxR.1.regtrans-ms - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\77EC63BDA74BD0D0E0426DC8F8008506 - Ok
C:\Windows\system32\config\COMPONENTS{fa87410f-2fef-11e3-8b22-4c809397a0b2}.TMContainer00000000000000000001.regtrans-ms - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\7B8944BA8AD0EFDF0E01A43EF62BECD0_8102C2D9BECD09FCBB2BC1857DCCAD50 - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\8DFDF057024880D7A081AFBF6D26B92F - Ok
>C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\94308059B57B3142E455B38A6EB92015 is CAB archive
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\94308059B57B3142E455B38A6EB92015 - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\94308059B57B3142E455B38A6EB92015 - archive
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\3C3948BE6E525B8A8CEE9FAC91C9E392_5BEB6C6453DB87D996BDBC5D90D34AE1 - Ok
C:\Windows\system32\config\COMPONENTS{fa87410f-2fef-11e3-8b22-4c809397a0b2}.TMContainer00000000000000000002.regtrans-ms - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\57C8EDB95DF3F0AD4EE2DC2B8CFD4157 - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\60E31627FDA0A46932B0E5948949F2A5 - Ok
C:\Windows\system32\config\COMPONENTS - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\62B5AF9BE9ADC1085C3C56EC07A82BF6 - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\696F3DE637E6DE85B458996D49D759AD - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\77EC63BDA74BD0D0E0426DC8F8008506 - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\7396C420A8E1BC1DA97F1AF0D10BAD21 - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\7B2238AACCEDC3F1FFE8E7EB5F575EC9 - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\7B8944BA8AD0EFDF0E01A43EF62BECD0_355DF12EAABE3F04A4C1AF592920E175 - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\7B8944BA8AD0EFDF0E01A43EF62BECD0_8102C2D9BECD09FCBB2BC1857DCCAD50 - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\8DFDF057024880D7A081AFBF6D26B92F - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\94308059B57B3142E455B38A6EB92015 - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\A8FABA189DB7D25FBA7CAC806625FD30 - Ok
C:\Windows\system32\config\systemprofile\AppData\Local\CrashDumps\ZeroConfigService.exe.3384.dmp - Ok
C:\Windows\system32\config\TxR\{016888cc-6c6f-11de-8d1d-001e0bcde3ec}.TxR.2.regtrans-ms - Ok
C:\Windows\system32\config\COMPONENTS{fa87410f-2fef-11e3-8b22-4c809397a0b2}.TM.blf - Ok
C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\Portable Devices\wpdlog00.sqm - Ok
C:\Windows\system32\config\TxR\{016888cc-6c6f-11de-8d1d-001e0bcde3ec}.TxR.blf - Ok
C:\Windows\system32\config\systemprofile\ntuser.dat.LOG1 - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\62B5AF9BE9ADC1085C3C56EC07A82BF6 - Ok
C:\Windows\system32\config\systemprofile\AppData\Local\CrashDumps\ZeroConfigService.exe.5972.dmp - Ok
C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\Portable Devices\wpdlog01.sqm - Ok
C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\History\desktop.ini - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\7B8944BA8AD0EFDF0E01A43EF62BECD0_355DF12EAABE3F04A4C1AF592920E175 - Ok
C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\Portable Devices\wpdlog02.sqm - Ok
C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\desktop.ini - Ok
C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\counters.dat - Ok
C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\desktop.ini - Ok
C:\Windows\system32\config\systemprofile\AppData\Local\CrashDumps\ZeroConfigService.exe.5040.dmp - Ok
C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\CLR Security Config\v2.0.50727.312\64bit\security.config.cch - Ok
>C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\23841LBH.txt is BASE64 container
C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\23841LBH.txt - mail
C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat - Ok
C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat - Ok
C:\Windows\system32\config\systemprofile\AppData\Roaming\Intel\Wireless\Settings\Settings.ini - Ok
C:\Windows\system32\config\systemprofile\Contacts\desktop.ini - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\7B2238AACCEDC3F1FFE8E7EB5F575EC9 - Ok
C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Speech\Files\UserLexicons\SP_13E5201D6096482EBE8B7AFD3311009B.dat - Ok
C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\SNJHAZW3.txt - Ok
C:\Windows\system32\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\A8FABA189DB7D25FBA7CAC806625FD30 - Ok
C:\Windows\system32\config\TxR\{016888cc-6c6f-11de-8d1d-001e0bcde3ec}.TxR.0.regtrans-ms - Ok
C:\Windows\system32\config\systemprofile\AppData\Local\CrashDumps\ZeroConfigService.exe.1588.dmp - Ok
C:\Windows\system32\config\systemprofile\AppData\Local\CrashDumps\ZeroConfigService.exe.4680.dmp - Ok
C:\Windows\system32\cs-CZ\fms.dll.mui - Ok
C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\IETldCache\index.dat - Ok
C:\Windows\system32\cs-CZ\WMPhoto.dll.mui - Ok
C:\Windows\system32\cs-CZ\FntCache.dll.mui - Ok
C:\Windows\system32\cs-CZ\DWrite.dll.mui - Ok
C:\Windows\system32\cs-CZ\mlang.dll.mui - Ok
C:\Windows\system32\cs-CZ\cdosys.dll.mui - Ok
C:\Windows\system32\cs-CZ\msprivs.dll.mui - Ok
C:\Windows\system32\cs-CZ\comdlg32.dll.mui - Ok
C:\Windows\system32\cs-CZ\msimsg.dll.mui - Ok
C:\Windows\system32\da-DK\comctl32.dll.mui - Ok
C:\Windows\system32\da-DK\mlang.dll.mui - Ok
C:\Windows\system32\da-DK\cdosys.dll.mui - Ok
C:\Windows\system32\da-DK\comdlg32.dll.mui - Ok
C:\Windows\system32\da-DK\WMPhoto.dll.mui - Ok
C:\Windows\system32\da-DK\msimsg.dll.mui - Ok
C:\Windows\system32\da-DK\fms.dll.mui - Ok
C:\Windows\system32\da-DK\d2d1.dll.mui - Ok
C:\Windows\system32\de-DE\comctl32.dll.mui - Ok
C:\Windows\system32\de-DE\fms.dll.mui - Ok
C:\Windows\system32\da-DK\DWrite.dll.mui - Ok
C:\Windows\system32\da-DK\FntCache.dll.mui - Ok
C:\Windows\system32\de-DE\DWrite.dll.mui - Ok
C:\Windows\system32\cs-CZ\comctl32.dll.mui - Ok
C:\Windows\system32\drivers\103C_HP_cNB_Pavilion dv7 Notebook PC_Y5335KV_0U_Q2CE2022D7F_EFU1010059BIS-B2A_4A_I1800_SHP_V10.56_BF.12_T111026_W73-1_L413_M8140_J750_7Intel_86A7_92.20_#120117_N_(B0M73EA#UUG)_XMOBILE_CN10_Z.MRK - Ok
C:\Windows\system32\de-DE\comdlg32.dll.mui - Ok
C:\Windows\system32\cs-CZ\d2d1.dll.mui - Ok
C:\Windows\system32\de-DE\WMPhoto.dll.mui - Ok
C:\Windows\system32\de-DE\msprivs.dll.mui - Ok
C:\Windows\system32\de-DE\UIAnimation.dll.mui - Ok
C:\Windows\system32\drivers\acpipmi.sys - Ok
C:\Windows\system32\de-DE\msimsg.dll.mui - Ok
C:\Windows\system32\de-DE\FntCache.dll.mui - Ok
C:\Windows\system32\drivers\1394ohci.sys - Ok
C:\Windows\system32\de-DE\mlang.dll.mui - Ok
C:\Windows\system32\drivers\agilevpn.sys - Ok
C:\Windows\system32\drivers\adpahci.sys - Ok
C:\Windows\system32\da-DK\msprivs.dll.mui - Ok
C:\Windows\system32\drivers\adp94xx.sys - Ok
C:\Windows\system32\drivers\aliide.sys - Ok
C:\Windows\system32\drivers\amdide.sys - Ok
C:\Windows\system32\drivers\adpu320.sys - Ok
C:\Windows\system32\drivers\amdsata.sys - Ok
C:\Windows\system32\drivers\AGP440.sys - Ok
C:\Windows\system32\drivers\amdppm.sys - Ok
C:\Windows\system32\drivers\amdxata.sys - Ok
C:\Windows\system32\drivers\Accelerometer.sys - Ok
C:\Windows\system32\drivers\amppal.sys - Ok
C:\Windows\system32\drivers\amdk8.sys - Ok
C:\Windows\system32\drivers\asyncmac.sys - Ok
C:\Windows\system32\drivers\arcsas.sys - Ok
C:\Windows\system32\drivers\ataport.sys - Ok
C:\Windows\system32\drivers\ati2erec.dll - Ok
C:\Windows\system32\drivers\arc.sys - Ok
C:\Windows\system32\drivers\battc.sys - Ok
C:\Windows\system32\de-DE\d2d1.dll.mui - Ok
C:\Windows\system32\drivers\amdsbs.sys - Ok
C:\Windows\system32\drivers\appid.sys - Ok
C:\Windows\system32\drivers\blbdrive.sys - Ok
C:\Windows\system32\drivers\b57nd60a.sys - Ok
C:\Windows\system32\drivers\afd.sys - Ok
C:\Windows\system32\drivers\BrFiltUp.sys - Ok
C:\Windows\system32\de-DE\cdosys.dll.mui - Ok
C:\Windows\system32\drivers\BrFiltLo.sys - Ok
C:\Windows\system32\drivers\bowser.sys - Ok
C:\Windows\system32\drivers\atikmpag.sys - Ok
C:\Windows\system32\drivers\BrSerWdm.sys - Ok
C:\Windows\system32\drivers\BrUsbMdm.sys - Ok
C:\Windows\system32\drivers\atapi.sys - Ok
C:\Windows\system32\drivers\bthenum.sys - Ok
C:\Windows\system32\drivers\BrSerId.sys - Ok
C:\Windows\system32\drivers\bthmodem.sys - Ok
C:\Windows\system32\drivers\acpi.sys - Ok
C:\Windows\system32\drivers\BTHUSB.SYS - Ok
C:\Windows\system32\drivers\bridge.sys - Ok
C:\Windows\system32\drivers\btmaux.sys - Ok
C:\Windows\system32\drivers\cdr4_xp.sys - Ok
C:\Windows\system32\drivers\bthpan.sys - Ok
C:\Windows\system32\drivers\cdfs.sys - Ok
C:\Windows\system32\drivers\cdralw2k.sys - Ok
C:\Windows\system32\drivers\BrUsbSer.sys - Ok
C:\Windows\system32\drivers\beep.sys - Ok
C:\Windows\system32\drivers\clwvd.sys - Ok
C:\Windows\system32\drivers\circlass.sys - Ok
C:\Windows\system32\drivers\cmdide.sys - Ok
C:\Windows\system32\drivers\bthport.sys - Ok
C:\Windows\system32\drivers\CompositeBus.sys - Ok
C:\Windows\system32\drivers\cng.sys - Ok
C:\Windows\system32\drivers\CmBatt.sys - Ok
C:\Windows\system32\drivers\compbatt.sys - Ok
C:\Windows\system32\drivers\cdrom.sys - Ok
C:\Windows\system32\drivers\Classpnp.sys - Ok
C:\Windows\system32\drivers\crcdisk.sys - Ok
C:\Windows\system32\drivers\Diskdump.sys - Ok
C:\Windows\system32\drivers\discache.sys - Ok
C:\Windows\system32\drivers\crashdmp.sys - Ok
C:\Windows\system32\drivers\disk.sys - Ok
C:\Windows\system32\drivers\drmk.sys - Ok
C:\Windows\system32\drivers\dxapi.sys - Ok
C:\Windows\system32\drivers\1394bus.sys - Ok
C:\Windows\system32\drivers\drmkaud.sys - Ok
C:\Windows\system32\drivers\dfsc.sys - Ok
C:\Windows\system32\drivers\dumpfve.sys - Ok
C:\Windows\system32\drivers\eamonm.sys - Ok
C:\Windows\system32\drivers\EpfwLWF.sys - Ok
C:\Windows\system32\drivers\btmhsf.sys - Ok
C:\Windows\system32\drivers\dxg.sys - Ok
C:\Windows\system32\drivers\Dumpata.sys - Ok
C:\Windows\system32\drivers\epfwwfp.sys - Ok
C:\Windows\system32\drivers\epfw.sys - Ok
C:\Windows\system32\drivers\errdev.sys - Ok
C:\Windows\system32\drivers\fdc.sys - Ok
C:\Windows\system32\drivers\fastfat.sys - Ok
C:\Windows\system32\drivers\ehdrv.sys - Ok
C:\Windows\system32\drivers\bxvbda.sys - Ok
C:\Windows\system32\drivers\flpydisk.sys - Ok
C:\Windows\system32\drivers\fsdepends.sys - Ok
C:\Windows\system32\drivers\filetrace.sys - Ok
C:\Windows\system32\drivers\fs_rec.sys - Ok
C:\Windows\system32\drivers\fltMgr.sys - Ok
C:\Windows\system32\drivers\GEARAspiWDM.sys - Ok
C:\Windows\system32\drivers\atikmdag.sys - Ok
C:\Windows\system32\drivers\fvevol.sys - Ok
C:\Windows\system32\drivers\gmreadme.txt - Ok
C:\Windows\system32\drivers\gm.dls - Ok
C:\Windows\system32\drivers\fileinfo.sys - Ok
C:\Windows\system32\drivers\hcw85cir.sys - Ok
C:\Windows\system32\drivers\FWPKCLNT.SYS - Ok
C:\Windows\system32\drivers\hdaudbus.sys - Ok
C:\Windows\system32\drivers\HECIx64.sys - Ok
C:\Windows\system32\drivers\hidbatt.sys - Ok
C:\Windows\system32\drivers\GAGP30KX.SYS - Ok
C:\Windows\system32\drivers\hidir.sys - Ok
C:\Windows\system32\drivers\hidusb.sys - Ok
C:\Windows\system32\drivers\HdAudio.sys - Ok
C:\Windows\system32\drivers\hpdskflt.sys - Ok
C:\Windows\system32\drivers\hwpolicy.sys - Ok
C:\Windows\system32\drivers\HpSAMD.sys - Ok
C:\Windows\system32\drivers\hidclass.sys - Ok
C:\Windows\system32\drivers\iaStor.sys - Ok
C:\Windows\system32\drivers\hidparse.sys - Ok
C:\Windows\system32\drivers\i8042prt.sys - Ok
C:\Windows\system32\drivers\iBtFltCoex.sys - Ok
C:\Windows\system32\drivers\iirsp.sys - Ok
C:\Windows\system32\drivers\hidbth.sys - Ok
C:\Windows\system32\drivers\IntcDAud.sys - Ok
C:\Windows\system32\drivers\intelide.sys - Ok
C:\Windows\system32\drivers\IntelMEFWVer.dll - Ok
C:\Windows\system32\drivers\intelaud.sys - Ok
>C:\Windows\system32\drivers\http.sys is BINARYRES container
C:\Windows\system32\drivers\ipfltdrv.sys - Ok
C:\Windows\system32\drivers\exfat.sys - Ok
C:\Windows\system32\drivers\ipnat.sys - Ok
C:\Windows\system32\drivers\intelppm.sys - Ok
C:\Windows\system32\drivers\IPMIDrv.sys - Ok
C:\Windows\system32\drivers\irenum.sys - Ok
C:\Windows\system32\drivers\http.sys - container
C:\Windows\system32\drivers\iwdbus.sys - Ok
C:\Windows\system32\drivers\kbdclass.sys - Ok
C:\Windows\system32\drivers\kbdhid.sys - Ok
C:\Windows\system32\drivers\isapnp.sys - Ok
C:\Windows\system32\drivers\ks.sys - Ok
C:\Windows\system32\drivers\elxstor.sys - Ok
C:\Windows\system32\drivers\ksecpkg.sys - Ok
C:\Windows\system32\drivers\irda.sys - Ok
C:\Windows\system32\drivers\lltdio.sys - Ok
C:\Windows\system32\drivers\ksthunk.sys - Ok
C:\Windows\system32\drivers\lsi_sas.sys - Ok
C:\Windows\system32\drivers\lsi_sas2.sys - Ok
C:\Windows\system32\drivers\lsi_scsi.sys - Ok
C:\Windows\system32\drivers\ksecdd.sys - Ok
C:\Windows\system32\drivers\igdkmd64.sys - Ok
C:\Windows\system32\drivers\mbam.sys - Ok
C:\Windows\system32\drivers\luafv.sys - Ok
C:\Windows\system32\drivers\monitor.sys - Ok
C:\Windows\system32\drivers\lsi_fc.sys - Ok
C:\Windows\system32\drivers\mouclass.sys - Ok
C:\Windows\system32\drivers\mouhid.sys - Ok
C:\Windows\system32\drivers\iaStorV.sys - Ok
C:\Windows\system32\drivers\mcd.sys - Ok
C:\Windows\system32\drivers\BCMWL664.SYS - Ok
C:\Windows\system32\drivers\modem.sys - Ok
C:\Windows\system32\drivers\megasas.sys - Ok
C:\Windows\system32\drivers\mpsdrv.sys - Ok
C:\Windows\system32\drivers\igdpmd64.sys - Ok
C:\Windows\system32\drivers\mountmgr.sys - Ok
C:\Windows\system32\drivers\mrxsmb.sys - Ok
C:\Windows\system32\drivers\MsftWdf_Kernel_01011_Inbox_Critical.Wdf - Ok
C:\Windows\system32\drivers\MsftWdf_User_01_11_00_Inbox_Critical.Wdf - Ok
C:\Windows\system32\drivers\mpio.sys - Ok
C:\Windows\system32\drivers\Msft_Kernel_AMPPAL_01009.Wdf - Ok
C:\Windows\system32\drivers\Msft_Kernel_btmaux_01009.Wdf - Ok
C:\Windows\system32\drivers\Msft_Kernel_iBtFltCoex_01009.Wdf - Ok
C:\Windows\system32\drivers\Msft_Kernel_iwdbus_01009.Wdf - Ok
C:\Windows\system32\drivers\Msft_Kernel_SynTP_01009.Wdf - Ok
C:\Windows\system32\drivers\Msft_User_wbf_vfs_0018_01_09_00.Wdf - Ok
C:\Windows\system32\drivers\Msft_User_WpdFs_01_09_00.Wdf - Ok
C:\Windows\system32\drivers\Msft_User_WpdMtpDr_01_09_00.Wdf - Ok
C:\Windows\system32\drivers\msfs.sys - Ok
C:\Windows\system32\drivers\mrxsmb10.sys - Ok
C:\Windows\system32\drivers\mrxsmb20.sys - Ok
C:\Windows\system32\drivers\msahci.sys - Ok
C:\Windows\system32\drivers\mshidkmdf.sys - Ok
C:\Windows\system32\drivers\mspclock.sys - Ok
C:\Windows\system32\drivers\mspqm.sys - Ok
C:\Windows\system32\drivers\mssmbios.sys - Ok
C:\Windows\system32\drivers\mstee.sys - Ok
C:\Windows\system32\drivers\mskssrv.sys - Ok
C:\Windows\system32\drivers\msdsm.sys - Ok
C:\Windows\system32\drivers\msisadrv.sys - Ok
C:\Windows\system32\drivers\mup.sys - Ok
C:\Windows\system32\drivers\MTConfig.sys - Ok
C:\Windows\system32\drivers\ndistapi.sys - Ok
C:\Windows\system32\drivers\ndiswan.sys - Ok
C:\Windows\system32\drivers\ndisuio.sys - Ok
C:\Windows\system32\drivers\ndproxy.sys - Ok
C:\Windows\system32\drivers\netbios.sys - Ok
C:\Windows\system32\drivers\ndiscap.sys - Ok
C:\Windows\system32\drivers\netio.sys - Ok
C:\Windows\system32\drivers\MegaSR.sys - Ok
C:\Windows\system32\drivers\npfs.sys - Ok
C:\Windows\system32\drivers\nsiproxy.sys - Ok
C:\Windows\system32\drivers\msrpc.sys - Ok
C:\Windows\system32\drivers\netbt.sys - Ok
C:\Windows\system32\drivers\null.sys - Ok
C:\Windows\system32\drivers\ndis.sys - Ok
C:\Windows\system32\drivers\nfrd960.sys - Ok
C:\Windows\system32\drivers\msiscsi.sys - Ok
C:\Windows\system32\drivers\nusb3xhc.sys - Ok
C:\Windows\system32\drivers\nvraid.sys - Ok
C:\Windows\system32\drivers\mrxdav.sys - Ok
C:\Windows\system32\drivers\NV_AGP.SYS - Ok
C:\Windows\system32\drivers\nvstor.sys - Ok
C:\Windows\system32\drivers\ohci1394.sys - Ok
C:\Windows\system32\drivers\nwifi.sys - Ok
C:\Windows\system32\drivers\pacer.sys - Ok
C:\Windows\system32\drivers\parport.sys - Ok
C:\Windows\system32\drivers\partmgr.sys - Ok
C:\Windows\system32\drivers\nusb3hub.sys - Ok
C:\Windows\system32\drivers\pciide.sys - Ok
C:\Windows\system32\drivers\pcmcia.sys - Ok
C:\Windows\system32\drivers\pciidex.sys - Ok
C:\Windows\system32\drivers\nvm62x64.sys - Ok
C:\Windows\system32\drivers\pci.sys - Ok
C:\Windows\system32\drivers\portcls.sys - Ok
C:\Windows\system32\drivers\PxHlpa64.sys - Ok
C:\Windows\system32\drivers\pcw.sys - Ok
C:\Windows\system32\drivers\processr.sys - Ok
C:\Windows\system32\drivers\rasacd.sys - Ok
C:\Windows\system32\drivers\qwavedrv.sys - Ok
C:\Windows\system32\drivers\rasl2tp.sys - Ok
C:\Windows\system32\drivers\ql40xx.sys - Ok
C:\Windows\system32\drivers\rassstp.sys - Ok
C:\Windows\system32\drivers\raspptp.sys - Ok
C:\Windows\system32\drivers\RDPCDD.sys - Ok
C:\Windows\system32\drivers\RDPENCDD.sys - Ok
C:\Windows\system32\drivers\RDPREFMP.sys - Ok
C:\Windows\system32\drivers\Netwsw00.sys - Ok
C:\Windows\system32\drivers\rdbss.sys - Ok
C:\Windows\system32\drivers\rfcomm.sys - Ok
C:\Windows\system32\drivers\rdpbus.sys - Ok
C:\Windows\system32\drivers\rdyboost.sys - Ok
C:\Windows\system32\drivers\PEAuth.sys - Ok
C:\Windows\system32\drivers\rootmdm.sys - Ok
C:\Windows\system32\drivers\raspppoe.sys - Ok
C:\Windows\system32\drivers\rspndr.sys - Ok
C:\Windows\system32\drivers\Rt64win7.sys - Ok
C:\Windows\system32\drivers\sbp2port.sys - Ok
C:\Windows\system32\drivers\RtsPStor.sys - Ok
C:\Windows\system32\drivers\sdbus.sys - Ok
C:\Windows\system32\drivers\scfilter.sys - Ok
C:\Windows\system32\drivers\RNDISMP.sys - Ok
C:\Windows\system32\drivers\serenum.sys - Ok
C:\Windows\system32\drivers\sermouse.sys - Ok
C:\Windows\system32\drivers\scsiport.sys - Ok
C:\Windows\system32\drivers\sffdisk.sys - Ok
C:\Windows\system32\drivers\sffp_mmc.sys - Ok
C:\Windows\system32\drivers\rmcast.sys - Ok
C:\Windows\system32\drivers\sisraid2.sys - Ok
C:\Windows\system32\drivers\serial.sys - Ok
C:\Windows\system32\drivers\sffp_sd.sys - Ok
C:\Windows\system32\drivers\sfloppy.sys - Ok
C:\Windows\system32\drivers\secdrv.sys - Ok
C:\Windows\system32\drivers\smclib.sys - Ok
C:\Windows\system32\drivers\evbda.sys - Ok
C:\Windows\system32\drivers\smb.sys - Ok
C:\Windows\system32\drivers\sisraid4.sys - Ok
C:\Windows\system32\drivers\spldr.sys - Ok
C:\Windows\system32\drivers\stexstor.sys - Ok
C:\Windows\system32\drivers\srv.sys - Ok
C:\Windows\system32\drivers\stream.sys - Ok
C:\Windows\system32\drivers\srv2.sys - Ok
C:\Windows\system32\drivers\storport.sys - Ok
C:\Windows\system32\drivers\ql2300.sys - Ok
C:\Windows\system32\drivers\srvnet.sys - Ok
C:\Windows\system32\drivers\swenum.sys - Ok
C:\Windows\system32\drivers\tcpipreg.sys - Ok
C:\Windows\system32\drivers\rdpwd.sys - Ok
C:\Windows\system32\drivers\tdi.sys - Ok
C:\Windows\system32\drivers\stwrt64.sys - Ok
C:\Windows\system32\drivers\tape.sys - Ok
C:\Windows\system32\drivers\termdd.sys - Ok
C:\Windows\system32\drivers\tdpipe.sys - Ok
C:\Windows\system32\drivers\ntfs.sys - Ok
C:\Windows\system32\drivers\TsUsbGD.sys - Ok
C:\Windows\system32\drivers\tdtcp.sys - Ok
C:\Windows\system32\drivers\tssecsrv.sys - Ok
C:\Windows\system32\drivers\TsUsbFlt.sys - Ok
C:\Windows\system32\drivers\SynTP.sys - Ok
C:\Windows\system32\drivers\udfs.sys - Ok
C:\Windows\system32\drivers\UAGP35.SYS - Ok
C:\Windows\system32\drivers\umpass.sys - Ok
C:\Windows\system32\drivers\usb8023.sys - Ok
C:\Windows\system32\drivers\spsys.sys - Ok
C:\Windows\system32\drivers\USBCAMD2.sys - Ok
C:\Windows\system32\drivers\usbaapl64.sys - Ok
C:\Windows\system32\drivers\umbus.sys - Ok
C:\Windows\system32\drivers\usbd.sys - Ok
C:\Windows\system32\drivers\usbccgp.sys - Ok
C:\Windows\system32\drivers\tunnel.sys - Ok
C:\Windows\system32\drivers\ULIAGPKX.SYS - Ok
C:\Windows\system32\drivers\usbhub.sys - Ok
C:\Windows\system32\drivers\tdx.sys - Ok
C:\Windows\system32\drivers\usbehci.sys - Ok
C:\Windows\system32\drivers\usbport.sys - Ok
C:\Windows\system32\drivers\USBSTOR.SYS - Ok
C:\Windows\system32\drivers\usbohci.sys - Ok
C:\Windows\system32\drivers\usbuhci.sys - Ok
C:\Windows\system32\drivers\vgapnp.sys - Ok
C:\Windows\system32\drivers\vga.sys - Ok
C:\Windows\system32\drivers\vdrvroot.sys - Ok
C:\Windows\system32\drivers\vhdmp.sys - Ok
C:\Windows\system32\drivers\videoprt.sys - Ok
C:\Windows\system32\drivers\usbprint.sys - Ok
C:\Windows\system32\drivers\viaide.sys - Ok
C:\Windows\system32\drivers\usbrpm.sys - Ok
C:\Windows\system32\drivers\volmgr.sys - Ok
C:\Windows\system32\drivers\usbcir.sys - Ok
C:\Windows\system32\drivers\dxgmms1.sys - Ok
C:\Windows\system32\drivers\vwifibus.sys - Ok
C:\Windows\system32\drivers\usbvideo.sys - Ok
C:\Windows\system32\drivers\dxgkrnl.sys - Ok
C:\Windows\system32\drivers\wacompen.sys - Ok
C:\Windows\system32\drivers\vwifimp.sys - Ok
C:\Windows\system32\drivers\volmgrx.sys - Ok
C:\Windows\system32\drivers\volsnap.sys - Ok
C:\Windows\system32\drivers\watchdog.sys - Ok
C:\Windows\system32\drivers\VSTAZL6.SYS - Ok
C:\Windows\system32\drivers\vwififlt.sys - Ok
C:\Windows\system32\drivers\wd.sys - Ok
C:\Windows\system32\drivers\vsmraid.sys - Ok
C:\Windows\system32\drivers\wimmount.sys - Ok
C:\Windows\system32\drivers\wmiacpi.sys - Ok
C:\Windows\system32\drivers\winusb.sys - Ok
C:\Windows\system32\drivers\wfplwf.sys - Ok
C:\Windows\system32\drivers\wmilib.sys - Ok
C:\Windows\system32\drivers\VSTCNXT6.SYS - Ok
C:\Windows\system32\drivers\WdfLdr.sys - Ok
C:\Windows\system32\drivers\WSDPrint.sys - Ok
C:\Windows\system32\drivers\wanarp.sys - Ok
C:\Windows\system32\drivers\ws2ifsl.sys - Ok
C:\Windows\system32\drivers\WUDFPf.sys - Ok
C:\Windows\system32\drivers\etc\hosts - Ok
C:\Windows\system32\drivers\etc\lmhosts.sam - Ok
C:\Windows\system32\drivers\etc\networks - Ok
C:\Windows\system32\drivers\UMDF\nl-NL\WUDFUsbccidDriver.dll.mui - Ok
C:\Windows\system32\drivers\etc\protocol - Ok
C:\Windows\system32\drivers\nl-NL\1394ohci.sys.mui - Ok
C:\Windows\system32\drivers\UMDF\nl-NL\WpdMtpDr.dll.mui - Ok
C:\Windows\system32\drivers\UMDF\WpdFs.dll - Ok
C:\Windows\system32\drivers\VSTProf.cty - Ok
C:\Windows\system32\drivers\nl-NL\afd.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\acpi.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\amdk8.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\ataport.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\amdppm.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\amdide.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\AGP440.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\atikmdag.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\BrParwdm.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\battc.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\bfe.dll.mui - Ok
C:\Windows\system32\drivers\etc\services - Ok
C:\Windows\system32\drivers\nl-NL\bthenum.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\BTHUSB.SYS.mui - Ok
C:\Windows\system32\drivers\nl-NL\bthpan.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\cdrom.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\disk.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\Dot4usb.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\BrSerId.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\bthport.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\fvevol.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\BrSerIb.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\GAGP30KX.SYS.mui - Ok
C:\Windows\system32\drivers\nl-NL\HdAudio.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\fltmgr.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\hidbth.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\http.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\hdaudbus.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\intelppm.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\IPMIDrv.sys.mui - Ok
C:\Windows\system32\drivers\WUDFRd.sys - Ok
C:\Windows\system32\drivers\nl-NL\isapnp.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\luafv.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\kbdclass.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\mouclass.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\ipnat.sys.mui - Ok
C:\Windows\system32\drivers\UMDF\wbf_vfs_0018.dll - Ok
C:\Windows\system32\drivers\nl-NL\modem.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\kbdhid.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\mountmgr.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\i8042prt.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\MTConfig.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\mpio.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\mouhid.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\ndiscap.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\msdsm.sys.mui - Ok
C:\Windows\system32\drivers\Wdf01000.sys - Ok
C:\Windows\system32\drivers\nl-NL\ndisuio.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\nwifi.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\parport.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\mssmbios.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\ohci1394.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\pci.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\pacer.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\pcmcia.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\processr.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\portcls.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\ndis.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\NV_AGP.SYS.mui - Ok
C:\Windows\system32\drivers\nl-NL\pnpmem.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\pscr.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\rdpwd.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\RNDISMP.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\ntfs.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\rdbss.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\scsiport.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\partmgr.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\qwavedrv.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\scfilter.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\rndismp6.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\rndismpx.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\tpm.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\tsusbflt.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\serial.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\tcpip.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\tunnel.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\srv.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\serscan.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\ULIAGPKX.SYS.mui - Ok
C:\Windows\system32\drivers\nl-NL\UAGP35.SYS.mui - Ok
C:\Windows\system32\drivers\nl-NL\usbport.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\sermouse.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\usbrpm.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\vhdmp.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\usbhub.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\umbus.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\vdrvroot.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\volmgrx.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\wd.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\wacompen.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\volsnap.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\vwifibus.sys.mui - Ok
C:\Windows\system32\drivers\nl-NL\ws2ifsl.sys.mui - Ok
C:\Windows\system32\el-GR\comctl32.dll.mui - Ok
C:\Windows\system32\drivers\nl-NL\wdf01000.sys.mui - Ok
C:\Windows\system32\el-GR\DWrite.dll.mui - Ok
C:\Windows\system32\el-GR\FntCache.dll.mui - Ok
C:\Windows\system32\el-GR\cdosys.dll.mui - Ok
C:\Windows\system32\el-GR\mlang.dll.mui - Ok
C:\Windows\system32\el-GR\comdlg32.dll.mui - Ok
C:\Windows\system32\en-US\comdlg32.dll.mui - Ok
C:\Windows\system32\el-GR\fms.dll.mui - Ok
C:\Windows\system32\el-GR\msimsg.dll.mui - Ok
C:\Windows\system32\en-US\comctl32.dll.mui - Ok
C:\Windows\system32\en-US\elshyph.dll.mui - Ok
C:\Windows\system32\en-US\dfshim.dll.mui - Ok
C:\Windows\system32\el-GR\msprivs.dll.mui - Ok
C:\Windows\system32\drivers\VSTDPV6.SYS - Ok
C:\Windows\system32\en-US\DWrite.dll.mui - Ok
C:\Windows\system32\en-US\fms.dll.mui - Ok
C:\Windows\system32\en-US\d2d1.dll.mui - Ok
C:\Windows\system32\en-US\html.iec.mui - Ok
C:\Windows\system32\en-US\FntCache.dll.mui - Ok
C:\Windows\system32\el-GR\WMPhoto.dll.mui - Ok
C:\Windows\system32\en-US\IEAdvpack.dll.mui - Ok
C:\Windows\system32\en-US\iedkcs32.dll.mui - Ok
C:\Windows\system32\en-US\iepeers.dll.mui - Ok
C:\Windows\system32\en-US\ieunatt.exe.mui - Ok
C:\Windows\system32\en-US\ieui.dll.mui - Ok
>C:\Windows\system32\en-US\icardie.dll.mui is BINARYRES container
C:\Windows\system32\en-US\iexpress.exe.mui - Ok
C:\Windows\system32\en-US\icardie.dll.mui - container
C:\Windows\system32\en-US\inseng.dll.mui - Ok
C:\Windows\system32\en-US\cdosys.dll.mui - Ok
>C:\Windows\system32\en-US\iesetup.dll.mui is BINARYRES container
C:\Windows\system32\en-US\jscript.dll.mui - Ok
C:\Windows\system32\en-US\iernonce.dll.mui - Ok
C:\Windows\system32\en-US\mlang.dll.mui - Ok
C:\Windows\system32\en-US\iesetup.dll.mui - container
C:\Windows\system32\drivers\UMDF\WpdMtpDr.dll - Ok
C:\Windows\system32\en-US\ie4uinit.exe.mui - Ok
C:\Windows\system32\en-US\msfeedsbs.dll.mui - Ok
C:\Windows\system32\el-GR\d2d1.dll.mui - Ok
C:\Windows\system32\en-US\jscript9.dll.mui - Ok
C:\Windows\system32\en-US\inetcpl.cpl.mui - Ok
C:\Windows\system32\en-US\msprivs.dll.mui - Ok
C:\Windows\system32\en-US\MsSpellCheckingFacility.exe.mui - Ok
C:\Windows\system32\en-US\mshtmlmedia.dll.mui - Ok
C:\Windows\system32\en-US\licmgr10.dll.mui - Ok
C:\Windows\system32\en-US\msrating.dll.mui - Ok
C:\Windows\system32\en-US\mshtmler.dll.mui - Ok
>C:\Windows\system32\en-US\mshtml.dll.mui is BINARYRES container
C:\Windows\system32\en-US\mshta.exe.mui - Ok
C:\Windows\system32\en-US\mshtml.dll.mui - container
C:\Windows\system32\en-US\UIAnimation.dll.mui - Ok
C:\Windows\system32\en-US\occache.dll.mui - Ok
C:\Windows\system32\en-US\vbscript.dll.mui - Ok
C:\Windows\system32\en-US\wextract.exe.mui - Ok
C:\Windows\system32\en-US\WMPhoto.dll.mui - Ok
C:\Windows\system32\en-US\wininet.dll.mui - Ok
C:\Windows\system32\en-US\msimsg.dll.mui - Ok
C:\Windows\system32\es-ES\comctl32.dll.mui - Ok
C:\Windows\system32\es-ES\DWrite.dll.mui - Ok
C:\Windows\system32\es-ES\mlang.dll.mui - Ok
C:\Windows\system32\es-ES\fms.dll.mui - Ok
C:\Windows\system32\es-ES\comdlg32.dll.mui - Ok
C:\Windows\system32\es-ES\cdosys.dll.mui - Ok
C:\Windows\system32\es-ES\msimsg.dll.mui - Ok
C:\Windows\system32\en-US\urlmon.dll.mui - Ok
C:\Windows\system32\en-US\webcheck.dll.mui - Ok
C:\Windows\system32\es-ES\msprivs.dll.mui - Ok
C:\Windows\system32\es-ES\d2d1.dll.mui - Ok
C:\Windows\system32\es-ES\FntCache.dll.mui - Ok
C:\Windows\system32\es-ES\UIAnimation.dll.mui - Ok
C:\Windows\system32\et-EE\fms.dll.mui - Ok
C:\Windows\system32\et-EE\comctl32.dll.mui - Ok
C:\Windows\system32\fi-FI\comctl32.dll.mui - Ok
C:\Windows\system32\fi-FI\comdlg32.dll.mui - Ok
C:\Windows\system32\es-ES\WMPhoto.dll.mui - Ok
C:\Windows\system32\fi-FI\cdosys.dll.mui - Ok
C:\Windows\system32\fi-FI\fms.dll.mui - Ok
C:\Windows\system32\et-EE\comdlg32.dll.mui - Ok
C:\Windows\system32\et-EE\msimsg.dll.mui - Ok
C:\Windows\system32\fi-FI\FntCache.dll.mui - Ok
C:\Windows\system32\fi-FI\DWrite.dll.mui - Ok
C:\Windows\system32\fi-FI\msprivs.dll.mui - Ok
C:\Windows\system32\fi-FI\msimsg.dll.mui - Ok
C:\Windows\system32\fi-FI\mlang.dll.mui - Ok
C:\Windows\system32\fr-FR\cdosys.dll.mui - Ok
C:\Windows\system32\fi-FI\WMPhoto.dll.mui - Ok
C:\Windows\system32\fr-FR\comctl32.dll.mui - Ok
C:\Windows\system32\fr-FR\DWrite.dll.mui - Ok
C:\Windows\system32\drivers\NETwNs64.sys - Ok
C:\Windows\system32\fr-FR\UIAnimation.dll.mui - Ok
C:\Windows\system32\fr-FR\mlang.dll.mui - Ok
C:\Windows\system32\fr-FR\fms.dll.mui - Ok
C:\Windows\system32\et-EE\mlang.dll.mui - Ok
C:\Windows\system32\he-IL\cdosys.dll.mui - Ok
C:\Windows\system32\he-IL\comdlg32.dll.mui - Ok
C:\Windows\system32\fr-FR\comdlg32.dll.mui - Ok
C:\Windows\system32\fr-FR\msprivs.dll.mui - Ok
C:\Windows\system32\fr-FR\msimsg.dll.mui - Ok
C:\Windows\system32\he-IL\msprivs.dll.mui - Ok
C:\Windows\system32\en-US\ieframe.dll.mui - Ok
C:\Windows\system32\he-IL\mlang.dll.mui - Ok
C:\Windows\system32\he-IL\msimsg.dll.mui - Ok
C:\Windows\system32\hr-HR\comctl32.dll.mui - Ok
C:\Windows\system32\he-IL\comctl32.dll.mui - Ok
C:\Windows\system32\hu-HU\comctl32.dll.mui - Ok
C:\Windows\system32\hr-HR\mlang.dll.mui - Ok
C:\Windows\system32\hr-HR\comdlg32.dll.mui - Ok
C:\Windows\system32\hu-HU\cdosys.dll.mui - Ok
C:\Windows\system32\fr-FR\d2d1.dll.mui - Ok
C:\Windows\system32\hr-HR\msimsg.dll.mui - Ok
C:\Windows\system32\fr-FR\WMPhoto.dll.mui - Ok
C:\Windows\system32\hu-HU\fms.dll.mui - Ok
C:\Windows\system32\hu-HU\comdlg32.dll.mui - Ok
C:\Windows\system32\hr-HR\fms.dll.mui - Ok
C:\Windows\system32\hu-HU\mlang.dll.mui - Ok
C:\Windows\system32\ias\dnary.xsd - Ok
C:\Windows\system32\hu-HU\msimsg.dll.mui - Ok
C:\Windows\system32\icsxml\cmnicfg.xml - Ok
C:\Windows\system32\icsxml\ipcfg.xml - Ok
C:\Windows\system32\icsxml\osinfo.xml - Ok
C:\Windows\system32\hu-HU\WMPhoto.dll.mui - Ok
C:\Windows\system32\icsxml\potscfg.xml - Ok
C:\Windows\system32\icsxml\pppcfg.xml - Ok
C:\Windows\system32\hu-HU\DWrite.dll.mui - Ok
C:\Windows\system32\it-IT\comctl32.dll.mui - Ok
C:\Windows\system32\hu-HU\FntCache.dll.mui - Ok
C:\Windows\system32\fr-FR\FntCache.dll.mui - Ok
C:\Windows\system32\hu-HU\msprivs.dll.mui - Ok
C:\Windows\system32\fi-FI\d2d1.dll.mui - Ok
C:\Windows\system32\he-IL\fms.dll.mui - Ok
C:\Windows\system32\it-IT\FntCache.dll.mui - Ok
C:\Windows\system32\it-IT\DWrite.dll.mui - Ok
C:\Windows\system32\it-IT\cdosys.dll.mui - Ok
C:\Windows\system32\it-IT\comdlg32.dll.mui - Ok
C:\Windows\system32\it-IT\UIAnimation.dll.mui - Ok
C:\Windows\system32\it-IT\msimsg.dll.mui - Ok
C:\Windows\system32\it-IT\msprivs.dll.mui - Ok
C:\Windows\system32\it-IT\mlang.dll.mui - Ok
C:\Windows\system32\ja-JP\comctl32.dll.mui - Ok
C:\Windows\system32\it-IT\WMPhoto.dll.mui - Ok
C:\Windows\system32\hu-HU\d2d1.dll.mui - Ok
C:\Windows\system32\it-IT\fms.dll.mui - Ok
C:\Windows\system32\ja-JP\FntCache.dll.mui - Ok
C:\Windows\system32\ja-JP\UIAnimation.dll.mui - Ok
C:\Windows\system32\ja-JP\comdlg32.dll.mui - Ok
C:\Windows\system32\ja-JP\cdosys.dll.mui - Ok
C:\Windows\system32\ja-JP\DWrite.dll.mui - Ok
C:\Windows\system32\ja-JP\mlang.dll.mui - Ok
C:\Windows\system32\it-IT\d2d1.dll.mui - Ok
C:\Windows\system32\ja-JP\fms.dll.mui - Ok
C:\Windows\system32\ja-JP\msprivs.dll.mui - Ok
C:\Windows\system32\ja-JP\WMPhoto.dll.mui - Ok
C:\Windows\system32\ja-JP\msimsg.dll.mui - Ok
C:\Windows\system32\ko-KR\comctl32.dll.mui - Ok
C:\Windows\system32\ko-KR\msprivs.dll.mui - Ok
C:\Windows\system32\ko-KR\DWrite.dll.mui - Ok
C:\Windows\system32\ko-KR\cdosys.dll.mui - Ok
C:\Windows\system32\ko-KR\comdlg32.dll.mui - Ok
C:\Windows\system32\ko-KR\fms.dll.mui - Ok
C:\Windows\system32\ko-KR\WMPhoto.dll.mui - Ok
C:\Windows\system32\lt-LT\fms.dll.mui - Ok
C:\Windows\system32\ja-JP\d2d1.dll.mui - Ok
C:\Windows\system32\ko-KR\mlang.dll.mui - Ok
C:\Windows\system32\ko-KR\FntCache.dll.mui - Ok
C:\Windows\system32\ko-KR\msimsg.dll.mui - Ok
C:\Windows\system32\lt-LT\comdlg32.dll.mui - Ok
C:\Windows\system32\lv-LV\comdlg32.dll.mui - Ok
C:\Windows\system32\lv-LV\fms.dll.mui - Ok
C:\Windows\system32\lv-LV\msimsg.dll.mui - Ok
C:\Windows\system32\manifeststore\kernel32.amx - Ok
C:\Windows\system32\manifeststore\user32.amx - Ok
C:\Windows\system32\lt-LT\msimsg.dll.mui - Ok
C:\Windows\system32\manifeststore\kernelbase.amx - Ok
C:\Windows\system32\manifeststore\gdi32.amx - Ok
C:\Windows\system32\manifeststore\advapi32.amx - Ok
C:\Windows\system32\lt-LT\mlang.dll.mui - Ok
C:\Windows\system32\lv-LV\comctl32.dll.mui - Ok
C:\Windows\system32\ko-KR\d2d1.dll.mui - Ok
C:\Windows\system32\migration\gameuxmig.dll - Ok
C:\Windows\system32\migration\commig.dll - Ok
C:\Windows\system32\migration\imjpmig.dll - Ok
C:\Windows\system32\migration\bridgemigplugin.dll - Ok
C:\Windows\system32\migration\audmigplugin.dll - Ok
C:\Windows\system32\lt-LT\comctl32.dll.mui - Ok
C:\Windows\system32\lv-LV\mlang.dll.mui - Ok
C:\Windows\system32\migration\bthmigplugin.dll - Ok
C:\Windows\system32\migration\imkrmig.dll - Ok
C:\Windows\system32\migration\IphlpsvcMigPlugin.dll - Ok
C:\Windows\system32\migration\imtcmig.dll - Ok
C:\Windows\system32\migration\imscmig.dll - Ok
C:\Windows\system32\migration\CntrtextMig.dll - Ok
C:\Windows\system32\migration\netiomig.dll - Ok
C:\Windows\system32\migration\nlscoremig.dll - Ok
C:\Windows\system32\migration\msctfmig.dll - Ok
C:\Windows\system32\migration\modemmigplugin.dll - Ok
C:\Windows\system32\migration\ndismigplugin.dll - Ok
C:\Windows\system32\migration\PowerMigPlugin.dll - Ok
C:\Windows\system32\migration\TableTextServiceMig.dll - Ok
C:\Windows\system32\migration\SCGMigPlugin.dll - Ok
C:\Windows\system32\migration\PlaMig.dll - Ok
C:\Windows\system32\migration\shmig.dll - Ok
C:\Windows\system32\migration\WininetPlugin.dll - Ok
C:\Windows\system32\migration\SxsMigPlugin.dll - Ok
C:\Windows\system32\migration\WSMT\rras\dlmanifests\RasmanService-DL.man - Ok
C:\Windows\system32\migration\WSMT\rras\dlmanifests\RasServerOC-DL.man - Ok
C:\Windows\system32\migration\StorMigPlugin.dll - Ok
C:\Windows\system32\migration\WSMT\rras\replacementmanifests\RasBase-Rassstp-Repl.man - Ok
C:\Windows\system32\migration\WSearchMigPlugin.dll - Ok
C:\Windows\system32\migration\WSMT\rras\dlmanifests\RasServerMigPlugin-DL.man - Ok
C:\Windows\system32\migration\usbmigplugin.dll - Ok
C:\Windows\system32\migration\WSMT\rras\replacementmanifests\RasmanService-Repl.man - Ok
C:\Windows\system32\migration\WSMT\rras\replacementmanifests\RasDdm-Repl.man - Ok
C:\Windows\system32\migration\WMIMigrationPlugin.dll - Ok
C:\Windows\system32\migration\WSMT\rras\dlmanifests\RasApi-DL.man - Ok
C:\Windows\system32\migration\WsUpgrade.dll - Ok
C:\Windows\system32\migration\WSMT\rras\replacementmanifests\RasRqs-Repl.man - Ok
C:\Windows\system32\migration\WSMT\rras\dlmanifests\Microsoft-Windows-RasServer-MigPlugin\RasMigPlugin-DL-Mig.dll - Ok
>C:\Windows\system32\migration\WSMT\rras\replacementmanifests\RasServer-Repl.man is JS-HTML container
C:\Windows\system32\migration\WSMT\rras\replacementmanifests\RasServer-Repl.man - container
C:\Windows\system32\migration\WSMT\rras\replacementmanifests\Rasppp-Repl.man - Ok
C:\Windows\system32\migration\WSMT\rras\replacementmanifests\RasApi-Repl.man - Ok
C:\Windows\system32\migration\WSMT\rras\replacementmanifests\Microsoft-Windows-RasApi-MigPlugin\pbkmigr-Mig.dll - Ok
C:\Windows\system32\migwiz\migfiles.dat - Ok
C:\Windows\system32\migration\WSMT\rras\replacementmanifests\RasBase-Repl.man - Ok
C:\Windows\system32\migration\nl-NL\WsUpgrade.dll.mui - Ok
C:\Windows\system32\migration\nl-NL\SxsMigPlugin.dll.mui - Ok
C:\Windows\system32\migration\nl-NL\ShMig.dll.mui - Ok
C:\Windows\system32\migration\WSMT\rras\replacementmanifests\Microsoft-Windows-RasServer-MigPlugin\RasMigPlugin-Mig.dll - Ok
C:\Windows\system32\migwiz\mighost.exe - Ok
C:\Windows\system32\migwiz\MigSetup.exe - Ok
>C:\Windows\system32\migwiz\MigApp.xml is JS-HTML container
C:\Windows\system32\migwiz\SFCN.dat - Ok
C:\Windows\system32\migwiz\SFLCID.dat - Ok
C:\Windows\system32\migwiz\MigSys.dll - Ok
C:\Windows\system32\migwiz\cmi2migxml.dll - Ok
C:\Windows\system32\migwiz\csiagent.dll - Ok
C:\Windows\system32\migwiz\MXEAgent.dll - Ok
C:\Windows\system32\migwiz\migstore.dll - Ok
C:\Windows\system32\migwiz\migres.dll - Ok
C:\Windows\system32\migwiz\SFPATW7.inf - Ok
C:\Windows\system32\migwiz\SFPAT.inf - Ok
C:\Windows\system32\migwiz\SFPATLH.inf - Ok
C:\Windows\system32\migwiz\SFPATXP.inf - Ok
C:\Windows\system32\migwiz\PostMigRes\Web\base_images\AppInstalled.gif - Ok
C:\Windows\system32\migwiz\PostMigRes\Web\base_images\ClickDownExpanded.gif - Ok
C:\Windows\system32\migwiz\PostMigRes\Web\base_images\ClickDownNormal.gif - Ok
C:\Windows\system32\migwiz\PostMigRes\Web\base_images\Column.bmp - Ok
C:\Windows\system32\migwiz\SFLISTW7.dat - Ok
C:\Windows\system32\migwiz\PostMigRes\Web\base_images\Documents.gif - Ok
C:\Windows\system32\migwiz\PostMigRes\Web\base_images\Programs.gif - Ok
C:\Windows\system32\migwiz\PostMigRes\Web\base_images\Failure.gif - Ok
C:\Windows\system32\migwiz\PostMigRes\Web\base_images\System.gif - Ok
C:\Windows\system32\migwiz\PostMigRes\Web\base_images\Users.gif - Ok
C:\Windows\system32\migwiz\PostMigRes\Web\base_images\WindowsMovieMaker.bmp - Ok
C:\Windows\system32\migwiz\PostMigRes\Web\base_images\WindowsMail.bmp - Ok
C:\Windows\system32\migwiz\SFLISTXP.dat - Ok
C:\Windows\system32\migwiz\PostMigRes\Web\base_images\WindowsOutlookExpress.bmp - Ok
C:\Windows\system32\migwiz\PostMigRes\Web\base_images\WindowsPhotoGallery.bmp - Ok
C:\Windows\system32\migwiz\PostMigRes\data\HardwareVendors.xml - Ok
C:\Windows\system32\migwiz\SFLISTLH.dat - Ok
C:\Windows\system32\migwiz\dlmanifests\ADFS-FederationService-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\ActiveDirectory-WMIReplicationProvider-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\ActiveDirectory-WebServices-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\ADFS-FederationServiceProxy-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\ADFS-WebAgentClaims-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\ADFS-WebAgentToken-DL.man - Ok
>C:\Windows\system32\migwiz\PostMigRes\Web\reportapi.js is JS-HTML container
C:\Windows\system32\migwiz\dlmanifests\adminui-dl.man - Ok
C:\Windows\system32\migwiz\dlmanifests\ADSI-LDAP-Extensions-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\ADSI-LDAP-Provider-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\AccessibilityCpl-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\ADSI-WinNT-Provider-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\ADSI-Router-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\authui-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Application_Experience-Infrastructure-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\BITSExtensions-Server-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\CAPI2_certs-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\CommandPrompt-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\CoreOS-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\BITSExtensions-Server-Console-DL.man - Ok
C:\Windows\system32\migwiz\migcore.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\DFSClient-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Credential-Manager-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\crypto_keys-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\DirectoryServices-ADAM-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\DirectoryServices-Domain-DL.man - Ok
C:\Windows\system32\migwiz\unbcl.dll - Ok
C:\Windows\system32\migwiz\PostMigRes\Web\reportapi.js - container
C:\Windows\system32\migwiz\dlmanifests\DNS-Server-Service-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\DirectoryServices-ISM-Smtp-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\DNS-Client-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\DRM-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\ETW-core-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\eudcedit-dl.man - Ok
C:\Windows\system32\migwiz\dlmanifests\EventCollector-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\DFSN-ServerService-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\dpapi_keys-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\DHCPServerMigPlugin-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Eventlog-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\feclient-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Fonts-Type1-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\evntagnt-dl.man - Ok
C:\Windows\system32\migwiz\dlmanifests\explorer-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\GPMC-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\gpmgmt-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\GroupPolicy-Admin-Gpedit-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\frs-core-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\GroupPolicy-Admin-Gpedit-Snapin-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\ieframe-dl.man - Ok
C:\Windows\system32\migwiz\dlmanifests\HTTP-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\GroupPolicy-CSE-SoftwareInstallation-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\GPBase-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\International-TimeZones-DL.man - Ok
C:\Windows\system32\drivers\tcpip.sys - Ok
C:\Windows\system32\migwiz\dlmanifests\International-Core-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\IPSec-Svc-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Ldap-Client-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\MediaServer-ASPAdmin-Migration-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\iSNS_Service-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\MediaServer-Migration-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\IasMigPlugin-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Kerberos-Key-Distribution-Center-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-CertificateServices-CA-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-CertificateServices-CAManagement-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-CertificateServices-MSCEP-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-Bits-Client-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\MediaServer-Multicast-Migration-DL.man - Ok
C:\Windows\system32\migwiz\migwiz.exe - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-DFSR-Core-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-Dot3svc-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IE-Feeds-Platform-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-HtmlHelp-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-ICM-Profiles-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-ASP-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-CGI-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-BasicAuthentication-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-ASPNET-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IE-ESC-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-DirectoryBrowsing-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-DigestAuthentication-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-CustomLogging-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-ClientCertificateMappingAuthentication-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\MigApp.xml - container
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-HTTPLogging-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-DefaultDocument-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-HttpCompressionStatic-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-HttpCompressionDynamic-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-HttpErrors-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-FTPServer-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-HttpRedirect-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-HttpTracing-Deployment-DL.man - Ok
>C:\Windows\system32\migwiz\PostMig.exe is BINARYRES container
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-ISAPIFilter-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-IPSecurity-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-ISAPIExtensions-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-LegacyScripts-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-IISCertificateMappingAuthentication-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-LegacySnapIn-Deployment-DL.man - Ok
>>C:\Windows\system32\migwiz\PostMig.exe\data001 is JS-HTML container
C:\Windows\system32\migwiz\PostMig.exe - container
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-ManagementConsole-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-Metabase-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-NetFxExtensibility-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-ManagementScriptingTools-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-ManagementService-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-RequestFiltering-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-ODBCLogging-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-ServerSideIncludes-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-RequestMonitor-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-StaticContent-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-LoggingLibraries-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-URLAuthorization-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-WMICompatibility-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-WindowsAuthentication-Deployment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IE-ClientNetworkProtocolImplementation-DL.man - Ok
>C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-Mail-DL.man is JS-HTML container
>C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IE-InternetExplorer-DL.man is JS-HTML container
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-StorageMigration-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-Mail-DL.man - container
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IE-InternetExplorer-DL.man - container
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-SharedAccess-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-Sxs-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-TapiSetup-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-WAS-ConfigurationAPI-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-WAS-ProcessModel-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-WAS-NetFxEnvironment-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-WlanSvc-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft.Windows.COM.ComPlus.Setup.DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-NetworkBridge-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\mpr-dl.man - Ok
C:\Windows\system32\migwiz\dlmanifests\msmq-domain-ic-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\msmq-http-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-NETFXCoreComp-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-OfflineFiles-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\msmq-routing-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft.Windows.COM.DTC.Setup-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Mup-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Netlogon-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\msmq-triggers-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-WCFCoreComp-DL.man - Ok
>C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-WAB-DL.man is JS-HTML container
C:\Windows\system32\migwiz\dlmanifests\Networking-MPSSVC-Svc-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\ndis-dl.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-WAB-DL.man - container
C:\Windows\system32\migwiz\dlmanifests\NetworkLoadBalancingFullServer-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\MUISettings-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\nfs-clientcore-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\ntoskrnl-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\MigrationDisplayGroups-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\nfs-servercore-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\openrpc-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\PeerToPeerAdmin-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\openportmapper-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\partmgr-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\PeerToPeerGraphing-DL.man - Ok
>C:\Windows\system32\migwiz\dlmanifests\msmq-messagingcoreservice-DL.man is JS-HTML container
C:\Windows\system32\migwiz\dlmanifests\PeerToPeerIdManager-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\PeerToPeerBase-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\PeerToPeerGrouping-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\PerformanceCounterInfrastructure-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\PeerToPeerPNRP-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Printing-Spooler-Core-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Printing-Spooler-Networkclient-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\psync-dl.man - Ok
C:\Windows\system32\migwiz\dlmanifests\RasCMAK-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\RasConnectionManager-DL.man - Ok
>C:\Windows\system32\migwiz\dlmanifests\odbc32dll-DL.man is JS-HTML container
C:\Windows\system32\migwiz\dlmanifests\RasApi-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\RasmanService-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\RPC-HTTP-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\RPC-Local-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\RPC-HTTP_Proxy-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\RasServerOC-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\RPC-Remote-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\schannel-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\odbc32dll-DL.man - container
C:\Windows\system32\migwiz\dlmanifests\Rights-Management-Client-v1-API-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Security-NTLM-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Security-Digest-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\SimpleTCP-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\msmq-messagingcoreservice-DL.man - container
C:\Windows\system32\migwiz\dlmanifests\Security-Kerberos-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\shmig-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\SmartCardSubsystem-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Smtpsvc-Service-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\snis-dl.man - Ok
>C:\Windows\system32\migwiz\dlmanifests\SchedSvc-DL.man is JS-HTML container
C:\Windows\system32\migwiz\dlmanifests\Smtpsvc-Admin-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\snmp-dl.man - Ok
C:\Windows\system32\migwiz\dlmanifests\shell32-DL.man - Ok
>C:\Windows\system32\migwiz\wet.dll is BINARYRES container
C:\Windows\system32\migwiz\dlmanifests\RasServerMigPlugin-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\TabletPCInputPanel-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\SchedSvc-DL.man - container
C:\Windows\system32\migwiz\dlmanifests\SpeechCommon-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\TabletPC-TabBtn-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Smss-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\terminalservices-AppServer-Licensing-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Telnet-client-dl.man - Ok
C:\Windows\system32\migwiz\dlmanifests\TerminalServices-Drivers-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\TerminalServices-LocalSessionManager-DL.man - Ok
>>C:\Windows\system32\migwiz\wet.dll\data001 is JS-HTML container
C:\Windows\system32\migwiz\dlmanifests\terminalservices-licenseserver-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\TabletPCPlatformInput-core-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\TabletPCJournal-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\TerminalServices-SessionDirectory-Client-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\TerminalServices-TerminalServicesClient-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\TerminalServices-RDP-WinStationExtensions-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\TerminalServices-RemoteConnectionManager-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\TextServicesFramework-Migration-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Telnet-Server-dl.man - Ok
C:\Windows\system32\migwiz\dlmanifests\themeui-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\sua-dl.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Time-Service-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\srm-DL.man - Ok
C:\Windows\system32\migwiz\wet.dll - container
C:\Windows\system32\migwiz\dlmanifests\TCPIP-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\UPnPControlPoint-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Web-Services-for-Management-Core-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Unimodem-Config-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Vss-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\VirtualDiskService-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\UPnPDeviceHost-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\UPnPSSDP-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Video-TVVideoControl-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\WebEnroll-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\WebDAVRedir-MrxDAV-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\WMI-SNMP-Provider-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\winlogon-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\wsinfra-upgrade-dl.man - Ok
C:\Windows\system32\migwiz\dlmanifests\wds-dl.man - Ok
C:\Windows\system32\migwiz\dlmanifests\WirelessNetworking-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\WSRM-Service-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\WMI-Core-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\win32k-settings-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\WebDAVRedir-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\WindowsSearchEngine-DL.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-International-Core-DL\nlscoremig.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-COM-DTC-Setup-DL\msdtcstp.dll - Ok
>C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IasServer-MigPlugin\IasMigPlugin.dll is BINARYRES container
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-ADFS-DL\adfsmig.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\BITSExtensions-Server\bitsmig.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-Bluetooth-Config\BthMigPlugin.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IasServer-MigPlugin\IasMigPlugin.dll - container
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-COM-ComPlus-Setup-DL\commig.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-ActiveDirectory-WebServices-DL\adwsmigrate.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-IIS-DL\iismig.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-RasConnectionManager\cmmigr.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-PerformanceCounterInfrastructure-DL\CntrtextMig.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-OfflineFiles-DL\CscMigDl.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-StorageMigration\StorMigPlugin.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-NetworkLoadBalancing-Core\NlbMigPlugin.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-RasServer-MigPlugin\RasMigPlugin.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-TextServicesFramework-Migration-DL\imjpmig.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-MediaPlayer-DRM-DL\drmmgrtn.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-TextServicesFramework-Migration-DL\imscmig.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-TextServicesFramework-Migration-DL\imkrmig.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-DHCPServerMigPlugin-DL\DhcpSrvMigPlugin.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-NetworkBridge\bridgemigplugin.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-TapiSetup\TapiMigPlugin.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-Sxs\SxsMigPlugin.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-DirectoryServices-ADAM-DL\adammigrate.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-TextServicesFramework-Migration-DL\imtcmig.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-TextServicesFramework-Migration-DL\TableTextServiceMig.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-WMI-Core\WMIMigrationPlugin.dll - Ok
C:\Windows\system32\migwiz\nl-NL\migres.dll.mui - Ok
C:\Windows\system32\migwiz\nl-NL\migsetup.exe.mui - Ok
C:\Windows\system32\migwiz\nl-NL\migwiz.exe.mui - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-shmig-DL\shmig.dll - Ok
C:\Windows\system32\migwiz\replacementmanifests\activedirectory-webservices-replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\audiommecore-other-migration-replacement.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-msmq-messagingcoreservice\mqmigplugin.dll - Ok
>C:\Windows\system32\migwiz\nl-NL\PostMig.exe.mui is BINARYRES container
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-Unimodem-Config\ModemMigPlugin.dll - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-TextServicesFramework-Migration-DL\msctfmig.dll - Ok
C:\Windows\system32\migwiz\replacementmanifests\Application-Experience-Program-Compatibility-Assistant-Replacement.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Networking-MPSSVC-Svc\icfupgd.dll - Ok
C:\Windows\system32\migwiz\replacementmanifests\authui-migration-replacement.man - Ok
>>C:\Windows\system32\migwiz\nl-NL\PostMig.exe.mui\data001 is JS-HTML container
C:\Windows\system32\migwiz\nl-NL\PostMig.exe.mui - container
C:\Windows\system32\migwiz\replacementmanifests\ehome-reg-inf_repl.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\eudcedit-replacement.man - Ok
C:\Windows\system32\migwiz\dlmanifests\Microsoft-Windows-NDIS\ndismigplugin.dll - Ok
C:\Windows\system32\migwiz\replacementmanifests\FunDisc-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\capi2_certs-repl.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\dhcpclientdll-repl.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\iis-ftpextensibility-rm.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\FailoverCluster-Core-WOW64-RM.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\Fonts-Type1-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\ExtensibleAuthenticationProtocolHostService-Rep.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\iis-ftpsvc-rm.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\iis-webdav-rm.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\gameuxmig-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\iis-sharedlibraries-rm.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\IPv4IPv6CoexistenceMigration-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\iis-powershellprovider-rm.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\International-core-replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\microsoft-hyper-v-migration-replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\microsoft-hyper-v-client-migration-replacement.man - Ok
>C:\Windows\system32\migwiz\nl-NL\wet.dll.mui is BINARYRES container
C:\Windows\system32\migwiz\replacementmanifests\Microsoft-Windows-NETFX35CDFComp-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\Microsoft-Windows-NETFXCoreComp-Repl.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\Microsoft-Windows-WCFCoreComp-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\Microsoft-Windows-OfflineFiles-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\mmsys-migration-replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\nfs-admincore-repl.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\Microsoft.Windows.Servermanager-non_msil-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\microsoft-hyper-v-drivers-migration-replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\ndis-repl.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\Printing-ServerCore-WOW64-RM.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\nfs-clientcore-repl.man - Ok
>C:\Windows\system32\migwiz\replacementmanifests\dhcpservermigplugin-rep.man is JS-HTML container
C:\Windows\system32\migwiz\replacementmanifests\Microsoft-Windows-SecureStartup-FilterDriver-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\nfs-servercore-repl.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\printing-localprinting-replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\servercore-wow64-rm.man - Ok
>>C:\Windows\system32\migwiz\nl-NL\wet.dll.mui\data006 is JS-HTML container
C:\Windows\system32\migwiz\nl-NL\wet.dll.mui - container
>C:\Windows\system32\migwiz\replacementmanifests\Microsoft-Windows-Fax-Service-Replacement.man is JS-HTML container
C:\Windows\system32\migwiz\replacementmanifests\RasmanService-Repl.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\dhcpservermigplugin-rep.man - container
C:\Windows\system32\migwiz\replacementmanifests\sounds-migration-replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\ServerCore-EA-IME-WOW64-RM.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\Rasppp-Repl.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\srm-quotadriver-repl.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\Microsoft-Windows-Fax-Service-Replacement.man - container
C:\Windows\system32\migwiz\replacementmanifests\shmig-replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\srm-service-repl.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\suaCore-WOW64-RM.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\srm-ui-repl.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\sysdm-replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\srm-service-reports-repl.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\stickynotes-replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\SysMain-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\srm-datascrndriver-repl.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\tabletpcstickynotes-replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\TabletPC-UIHub-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\TerminalServices-AppServer-Licensing-replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\UsbMigPlugin-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\TerminalServices-RAPWebPart-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\virtualdiskservice-repl.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\TerminalServices-Manager-SnapIn-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\vsssystemprovider-replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\Windows-MarketTheme-MCTAdmin-Component-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\WCF-HTTP-Activation-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\TerminalServices-SBMgr-SnapIn-non_msil-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\WCF-NonHTTP-Activation-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\TCPIP-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\Rights-Management-Client-v1-API-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\WMI-Core-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\WindowsSearchEngine-replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\vssservice-repl.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\WSRM-Service-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\TabletPCPlatformInput-core-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\TerminalServices-LicenseServer-Replacement.man - Ok
C:\Windows\system32\migwiz\replacementmanifests\Microsoft-Windows-GameUXMig\gameuxmig.dll - Ok
C:\Windows\system32\migwiz\replacementmanifests\Microsoft-Windows-TerminalServices-LicenseServer\TlsRepPlugin.dll - Ok
C:\Windows\system32\migwiz\replacementmanifests\WindowsSearchEngine\WSearchMigPlugin.dll - Ok
C:\Windows\system32\migwiz\replacementmanifests\Usb\usbmigplugin.dll - Ok
C:\Windows\system32\migwiz\replacementmanifests\Microsoft-Windows-OfflineFiles-Core\CscMig.dll - Ok
C:\Windows\system32\migwiz\replacementmanifests\Microsoft-Windows-TerminalServices-AppServer-Licensing\tsmigplugin.dll - Ok
C:\Windows\system32\migwiz\replacementmanifests\microsoft-windows-audio-mmecore-other\audmigplugin.dll - Ok
C:\Windows\system32\migwiz\replacementmanifests\microsoft-international-core\nlscoremig.dll - Ok
C:\Windows\system32\nb-NO\cdosys.dll.mui - Ok
C:\Windows\system32\migwiz\replacementmanifests\microsoft-activedirectory-webservices\adwsmigrate.dll - Ok
C:\Windows\system32\migwiz\replacementmanifests\microsoft-windows-shmig\shmig.dll - Ok
C:\Windows\system32\nb-NO\DWrite.dll.mui - Ok
C:\Windows\system32\nb-NO\comctl32.dll.mui - Ok
C:\Windows\system32\migwiz\replacementmanifests\microsoft-windows-ndis\ndismigplugin.dll - Ok
C:\Windows\system32\nb-NO\fms.dll.mui - Ok
C:\Windows\system32\migwiz\replacementmanifests\microsoft-windows-iis-rm\iismig.dll - Ok
>C:\Windows\system32\migwiz\replacementmanifests\Microsoft-Windows-IE-InternetExplorer-repl.man is JS-HTML container
C:\Windows\system32\nb-NO\msprivs.dll.mui - Ok
C:\Windows\system32\nb-NO\FntCache.dll.mui - Ok
C:\Windows\system32\migwiz\replacementmanifests\Microsoft-Windows-IE-InternetExplorer-repl.man - container
C:\Windows\system32\nb-NO\mlang.dll.mui - Ok
C:\Windows\system32\nl-NL\aaclient.dll.mui - Ok
C:\Windows\system32\nl-NL\acproxy.dll.mui - Ok
C:\Windows\system32\nb-NO\comdlg32.dll.mui - Ok
C:\Windows\system32\nl-NL\accessibilitycpl.dll.mui - Ok
C:\Windows\system32\nl-NL\aclui.dll.mui - Ok
C:\Windows\system32\nl-NL\ActionCenter.dll.mui - Ok
C:\Windows\system32\nb-NO\d2d1.dll.mui - Ok
C:\Windows\system32\nb-NO\WMPhoto.dll.mui - Ok
C:\Windows\system32\nl-NL\ActionCenterCPL.dll.mui - Ok
C:\Windows\system32\nl-NL\acppage.dll.mui - Ok
C:\Windows\system32\nl-NL\activeds.dll.mui - Ok
C:\Windows\system32\nl-NL\acctres.dll.mui - Ok
C:\Windows\system32\nl-NL\adsldpc.dll.mui - Ok
C:\Windows\system32\nl-NL\acledit.dll.mui - Ok
C:\Windows\system32\nb-NO\msimsg.dll.mui - Ok
C:\Windows\system32\nl-NL\aelupsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\actionqueue.dll.mui - Ok
C:\Windows\system32\nl-NL\adsmsext.dll.mui - Ok
C:\Windows\system32\nl-NL\aeevts.dll.mui - Ok
C:\Windows\system32\nl-NL\adsnt.dll.mui - Ok
C:\Windows\system32\nl-NL\adprovider.dll.mui - Ok
C:\Windows\system32\nl-NL\aepdu.dll.mui - Ok
C:\Windows\system32\nl-NL\adsldp.dll.mui - Ok
C:\Windows\system32\nl-NL\AltTab.dll.mui - Ok
C:\Windows\system32\nl-NL\amstream.dll.mui - Ok
C:\Windows\system32\nl-NL\advpack.dll.mui - Ok
C:\Windows\system32\nl-NL\apilogen.dll.mui - Ok
C:\Windows\system32\nl-NL\AdapterTroubleshooter.exe.mui - Ok
C:\Windows\system32\nl-NL\aitagent.exe.mui - Ok
C:\Windows\system32\nl-NL\appidsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\alg.exe.mui - Ok
C:\Windows\system32\nl-NL\Apphlpdm.dll.mui - Ok
C:\Windows\system32\nl-NL\apss.dll.mui - Ok
C:\Windows\system32\nl-NL\apphelp.dll.mui - Ok
C:\Windows\system32\nl-NL\appwiz.cpl.mui - Ok
C:\Windows\system32\nl-NL\at.exe.mui - Ok
C:\Windows\system32\nl-NL\attrib.exe.mui - Ok
C:\Windows\system32\nl-NL\apds.dll.mui - Ok
C:\Windows\system32\nl-NL\apircl.dll.mui - Ok
C:\Windows\system32\nl-NL\arp.exe.mui - Ok
C:\Windows\system32\nl-NL\audiodg.exe.mui - Ok
C:\Windows\system32\nl-NL\AudioSrv.dll.mui - Ok
C:\Windows\system32\nl-NL\appinfo.dll.mui - Ok
C:\Windows\system32\nl-NL\atl.dll.mui - Ok
C:\Windows\system32\nl-NL\asferror.dll.mui - Ok
C:\Windows\system32\nl-NL\advapi32.dll.mui - Ok
C:\Windows\system32\nl-NL\auditpol.exe.mui - Ok
C:\Windows\system32\nl-NL\AudioSes.dll.mui - Ok
C:\Windows\system32\nl-NL\authui.dll.mui - Ok
C:\Windows\system32\nl-NL\appidapi.dll.mui - Ok
C:\Windows\system32\nl-NL\autoplay.dll.mui - Ok
C:\Windows\system32\nl-NL\authfwgp.dll.mui - Ok
C:\Windows\system32\nl-NL\AuxiliaryDisplayServices.dll.mui - Ok
C:\Windows\system32\nl-NL\AxInstSv.dll.mui - Ok
C:\Windows\system32\nl-NL\authfwcfg.dll.mui - Ok
C:\Windows\system32\nl-NL\AuxiliaryDisplayCpl.dll.mui - Ok
C:\Windows\system32\nl-NL\avicap32.dll.mui - Ok
C:\Windows\system32\nl-NL\AtBroker.exe.mui - Ok
C:\Windows\system32\nl-NL\autochk.exe.mui - Ok
C:\Windows\system32\nl-NL\auditcse.dll.mui - Ok
C:\Windows\system32\nl-NL\azman.msc - Ok
C:\Windows\system32\nl-NL\azsqlext.dll.mui - Ok
C:\Windows\system32\nl-NL\avifil32.dll.mui - Ok
C:\Windows\system32\nl-NL\batmeter.dll.mui - Ok
C:\Windows\system32\nl-NL\AuxiliaryDisplayClassInstaller.dll.mui - Ok
C:\Windows\system32\nl-NL\bdesvc.dll.mui - Ok
C:\Windows\system32\nl-NL\AxInstUI.exe.mui - Ok
C:\Windows\system32\nl-NL\azroleui.dll.mui - Ok
C:\Windows\system32\nl-NL\batt.dll.mui - Ok
C:\Windows\system32\nl-NL\basecsp.dll.mui - Ok
C:\Windows\system32\nl-NL\azroles.dll.mui - Ok
C:\Windows\system32\nl-NL\BdeUnlockWizard.exe.mui - Ok
C:\Windows\system32\nl-NL\bcdboot.exe.mui - Ok
C:\Windows\system32\nl-NL\bitsadmin.exe.mui - Ok
C:\Windows\system32\nl-NL\biocpl.dll.mui - Ok
C:\Windows\system32\nl-NL\bcdedit.exe.mui - Ok
C:\Windows\system32\nl-NL\bootres.dll.mui - Ok
C:\Windows\system32\nl-NL\bootstr.dll.mui - Ok
C:\Windows\system32\nl-NL\autoconv.exe.mui - Ok
C:\Windows\system32\nl-NL\BioCredProv.dll.mui - Ok
C:\Windows\system32\nl-NL\Autofmt.exe.mui - Ok
C:\Windows\system32\nl-NL\BlbEvents.dll.mui - Ok
C:\Windows\system32\nl-NL\bridgeres.dll.mui - Ok
C:\Windows\system32\nl-NL\browser.dll.mui - Ok
C:\Windows\system32\nl-NL\adtschema.dll.mui - Ok
C:\Windows\system32\nl-NL\bthci.dll.mui - Ok
C:\Windows\system32\nl-NL\BthMtpContextHandler.dll.mui - Ok
C:\Windows\system32\nl-NL\BrmfcWia.dll.mui - Ok
C:\Windows\system32\nl-NL\bthserv.dll.mui - Ok
C:\Windows\system32\nl-NL\blbres.dll.mui - Ok
C:\Windows\system32\nl-NL\bthudtask.exe.mui - Ok
C:\Windows\system32\nl-NL\btpanui.dll.mui - Ok
C:\Windows\system32\nl-NL\bfe.dll.mui - Ok
C:\Windows\system32\nl-NL\BWUnpairElevated.dll.mui - Ok
C:\Windows\system32\nl-NL\bootcfg.exe.mui - Ok
C:\Windows\system32\nl-NL\capiprovider.dll.mui - Ok
C:\Windows\system32\nl-NL\bthprops.cpl.mui - Ok
C:\Windows\system32\nl-NL\BthpanContextHandler.dll.mui - Ok
C:\Windows\system32\nl-NL\capisp.dll.mui - Ok
C:\Windows\system32\nl-NL\cabview.dll.mui - Ok
C:\Windows\system32\nl-NL\BWContextHandler.dll.mui - Ok
C:\Windows\system32\nl-NL\cero.rs.mui - Ok
C:\Windows\system32\nl-NL\certcli.dll.mui - Ok
C:\Windows\system32\nl-NL\Bubbles.scr.mui - Ok
C:\Windows\system32\nl-NL\Brmf3wia.dll.mui - Ok
C:\Windows\system32\nl-NL\certenc.dll.mui - Ok
C:\Windows\system32\nl-NL\Brmf2wia.dll.mui - Ok
C:\Windows\system32\nl-NL\certprop.dll.mui - Ok
C:\Windows\system32\nl-NL\CertEnroll.dll.mui - Ok
C:\Windows\system32\nl-NL\cdosys.dll.mui - Ok
C:\Windows\system32\nl-NL\certmgr.msc - Ok
C:\Windows\system32\nl-NL\CertEnrollCtrl.exe.mui - Ok
C:\Windows\system32\nl-NL\certcredprovider.dll.mui - Ok
C:\Windows\system32\nl-NL\cewmdm.dll.mui - Ok
C:\Windows\system32\nl-NL\cfgbkend.dll.mui - Ok
C:\Windows\system32\nl-NL\certreq.exe.mui - Ok
C:\Windows\system32\nl-NL\CertEnrollUI.dll.mui - Ok
C:\Windows\system32\nl-NL\certmgr.dll.mui - Ok
C:\Windows\system32\nl-NL\chkdsk.exe.mui - Ok
C:\Windows\system32\nl-NL\chkntfs.exe.mui - Ok
C:\Windows\system32\nl-NL\cacls.exe.mui - Ok
C:\Windows\system32\nl-NL\chkwudrv.dll.mui - Ok
C:\Windows\system32\nl-NL\cic.dll.mui - Ok
C:\Windows\system32\nl-NL\CertPolEng.dll.mui - Ok
C:\Windows\system32\nl-NL\clfs.sys.mui - Ok
C:\Windows\system32\nl-NL\cipher.exe.mui - Ok
C:\Windows\system32\nl-NL\clb.dll.mui - Ok
C:\Windows\system32\nl-NL\cleanmgr.exe.mui - Ok
C:\Windows\system32\nl-NL\clusapi.dll.mui - Ok
C:\Windows\system32\nl-NL\calc.exe.mui - Ok
C:\Windows\system32\nl-NL\cmcfg32.dll.mui - Ok
C:\Windows\system32\nl-NL\charmap.exe.mui - Ok
C:\Windows\system32\nl-NL\cmdl32.exe.mui - Ok
C:\Windows\system32\nl-NL\cmlua.dll.mui - Ok
C:\Windows\system32\nl-NL\cmdial32.dll.mui - Ok
C:\Windows\system32\nl-NL\choice.exe.mui - Ok
C:\Windows\system32\nl-NL\cliconfg.rll.mui - Ok
C:\Windows\system32\nl-NL\cmstplua.dll.mui - Ok
C:\Windows\system32\nl-NL\cmncliM.dll.mui - Ok
C:\Windows\system32\nl-NL\ci.dll.mui - Ok
C:\Windows\system32\nl-NL\CNHW170S.DLL.mui - Ok
C:\Windows\system32\nl-NL\cngprovider.dll.mui - Ok
C:\Windows\system32\nl-NL\certutil.exe.mui - Ok
C:\Windows\system32\nl-NL\cmstp.exe.mui - Ok
C:\Windows\system32\nl-NL\cmd.exe.mui - Ok
C:\Windows\system32\nl-NL\cmdkey.exe.mui - Ok
C:\Windows\system32\nl-NL\cmmon32.exe.mui - Ok
C:\Windows\system32\nl-NL\cmutil.dll.mui - Ok
C:\Windows\system32\nl-NL\CNHW370S.DLL.mui - Ok
C:\Windows\system32\nl-NL\CNHW730S.DLL.mui - Ok
C:\Windows\system32\nl-NL\CNHW500.DLL.mui - Ok
C:\Windows\system32\nl-NL\CNHW830.DLL.mui - Ok
C:\Windows\system32\nl-NL\CNHW750S.DLL.mui - Ok
C:\Windows\system32\nl-NL\CNHW760S.DLL.mui - Ok
C:\Windows\system32\nl-NL\cofire.exe.mui - Ok
C:\Windows\system32\nl-NL\clip.exe.mui - Ok
C:\Windows\system32\nl-NL\CNHW900.DLL.mui - Ok
C:\Windows\system32\nl-NL\collab.cpl.mui - Ok
C:\Windows\system32\nl-NL\cob-au.rs.mui - Ok
C:\Windows\system32\nl-NL\comp.exe.mui - Ok
C:\Windows\system32\nl-NL\ComputerDefaults.exe.mui - Ok
C:\Windows\system32\nl-NL\comctl32.dll.mui - Ok
C:\Windows\system32\nl-NL\colorui.dll.mui - Ok
C:\Windows\system32\nl-NL\comdlg32.dll.mui - Ok
C:\Windows\system32\nl-NL\compstui.dll.mui - Ok
C:\Windows\system32\nl-NL\consent.exe.mui - Ok
C:\Windows\system32\nl-NL\compmgmt.msc - Ok
C:\Windows\system32\nl-NL\compact.exe.mui - Ok
C:\Windows\system32\nl-NL\comexp.msc - Ok
C:\Windows\system32\nl-NL\colorcpl.exe.mui - Ok
C:\Windows\system32\nl-NL\credui.dll.mui - Ok
C:\Windows\system32\nl-NL\console.dll.mui - Ok
C:\Windows\system32\nl-NL\cryptsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\cofiredm.dll.mui - Ok
C:\Windows\system32\nl-NL\cryptext.dll.mui - Ok
C:\Windows\system32\nl-NL\crypt32.dll.mui - Ok
C:\Windows\system32\nl-NL\cryptdlg.dll.mui - Ok
C:\Windows\system32\nl-NL\connect.dll.mui - Ok
C:\Windows\system32\nl-NL\credwiz.exe.mui - Ok
C:\Windows\system32\nl-NL\cryptui.dll.mui - Ok
C:\Windows\system32\nl-NL\CSRR.rs.mui - Ok
C:\Windows\system32\nl-NL\conhost.exe.mui - Ok
C:\Windows\system32\nl-NL\csrss.exe.mui - Ok
C:\Windows\system32\nl-NL\cttune.exe.mui - Ok
C:\Windows\system32\nl-NL\cscript.exe.mui - Ok
C:\Windows\system32\nl-NL\cpfilters.dll.mui - Ok
C:\Windows\system32\nl-NL\csrsrv.dll.mui - Ok
C:\Windows\system32\nl-NL\cryptxml.dll.mui - Ok
C:\Windows\system32\nl-NL\corrEngine.dll.mui - Ok
C:\Windows\system32\nl-NL\dataclen.dll.mui - Ok
C:\Windows\system32\nl-NL\csamsp.dll.mui - Ok
C:\Windows\system32\nl-NL\dcomcnfg.exe.mui - Ok
C:\Windows\system32\nl-NL\ctfmon.exe.mui - Ok
C:\Windows\system32\nl-NL\cttunesvr.exe.mui - Ok
C:\Windows\system32\nl-NL\defragsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\dccw.exe.mui - Ok
C:\Windows\system32\nl-NL\DDORes.dll.mui - Ok
C:\Windows\system32\nl-NL\ddraw.dll.mui - Ok
C:\Windows\system32\nl-NL\desk.cpl.mui - Ok
C:\Windows\system32\nl-NL\deskperf.dll.mui - Ok
C:\Windows\system32\nl-NL\DeviceCenter.dll.mui - Ok
C:\Windows\system32\nl-NL\DevicePairing.dll.mui - Ok
C:\Windows\system32\nl-NL\defaultlocationcpl.dll.mui - Ok
C:\Windows\system32\nl-NL\DDACLSys.dll.mui - Ok
C:\Windows\system32\nl-NL\d2d1.dll.mui - Ok
C:\Windows\system32\nl-NL\DevicePairingProxy.dll.mui - Ok
C:\Windows\system32\nl-NL\DeviceProperties.exe.mui - Ok
C:\Windows\system32\nl-NL\deskmon.dll.mui - Ok
C:\Windows\system32\nl-NL\deskadp.dll.mui - Ok
C:\Windows\system32\nl-NL\devenum.dll.mui - Ok
C:\Windows\system32\nl-NL\DFDWiz.exe.mui - Ok
C:\Windows\system32\nl-NL\comres.dll.mui - Ok
C:\Windows\system32\nl-NL\DFDTS.dll.mui - Ok
C:\Windows\system32\nl-NL\Defrag.exe.mui - Ok
C:\Windows\system32\nl-NL\dfshim.dll.mui - Ok
C:\Windows\system32\nl-NL\DfrgUI.exe.mui - Ok
C:\Windows\system32\nl-NL\DfsShlEx.dll.mui - Ok
C:\Windows\system32\nl-NL\dhcpcmonitor.dll.mui - Ok
C:\Windows\system32\nl-NL\DevicePairingFolder.dll.mui - Ok
C:\Windows\system32\nl-NL\dhcpcore.dll.mui - Ok
C:\Windows\system32\nl-NL\DeviceUxRes.dll.mui - Ok
C:\Windows\system32\nl-NL\dhcpcore6.dll.mui - Ok
C:\Windows\system32\nl-NL\dhcpcsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\dimsjob.dll.mui - Ok
C:\Windows\system32\nl-NL\DiagCpl.dll.mui - Ok
C:\Windows\system32\nl-NL\dinotify.exe.mui - Ok
C:\Windows\system32\nl-NL\devmgr.dll.mui - Ok
C:\Windows\system32\nl-NL\dimsroam.dll.mui - Ok
C:\Windows\system32\nl-NL\DHCPQEC.DLL.MUI - Ok
C:\Windows\system32\nl-NL\dinput8.dll.mui - Ok
C:\Windows\system32\nl-NL\diskmgmt.msc - Ok
C:\Windows\system32\nl-NL\dialer.exe.mui - Ok
C:\Windows\system32\nl-NL\dhcpsapi.dll.mui - Ok
C:\Windows\system32\nl-NL\diskperf.exe.mui - Ok
C:\Windows\system32\nl-NL\diskcopy.dll.mui - Ok
C:\Windows\system32\nl-NL\dhcpcsvc6.dll.mui - Ok
C:\Windows\system32\nl-NL\ditrace.exe.mui - Ok
C:\Windows\system32\nl-NL\DisplaySwitch.exe.mui - Ok
C:\Windows\system32\nl-NL\Dism.exe.mui - Ok
C:\Windows\system32\nl-NL\dispci.dll.mui - Ok
C:\Windows\system32\nl-NL\djoin.exe.mui - Ok
C:\Windows\system32\nl-NL\disrvpp.dll.mui - Ok
C:\Windows\system32\nl-NL\Display.dll.mui - Ok
C:\Windows\system32\nl-NL\diskraid.exe.mui - Ok
C:\Windows\system32\nl-NL\djctq.rs.mui - Ok
C:\Windows\system32\nl-NL\diskpart.exe.mui - Ok
C:\Windows\system32\nl-NL\devmgmt.msc - Ok
C:\Windows\system32\nl-NL\dnsapi.dll.mui - Ok
C:\Windows\system32\nl-NL\dmdskres.dll.mui - Ok
C:\Windows\system32\nl-NL\diagperf.dll.mui - Ok
C:\Windows\system32\nl-NL\dinput.dll.mui - Ok
C:\Windows\system32\nl-NL\doskey.exe.mui - Ok
C:\Windows\system32\nl-NL\dmusic.dll.mui - Ok
C:\Windows\system32\nl-NL\dnsrslvr.dll.mui - Ok
C:\Windows\system32\nl-NL\dmdskres2.dll.mui - Ok
C:\Windows\system32\nl-NL\DocumentPerformanceEvents.dll.mui - Ok
C:\Windows\system32\nl-NL\dot3api.dll.mui - Ok
C:\Windows\system32\nl-NL\dmutil.dll.mui - Ok
C:\Windows\system32\nl-NL\dot3dlg.dll.mui - Ok
C:\Windows\system32\nl-NL\dmocx.dll.mui - Ok
C:\Windows\system32\nl-NL\dnshc.dll.mui - Ok
C:\Windows\system32\nl-NL\dot3gpclnt.dll.mui - Ok
C:\Windows\system32\nl-NL\dot3msm.dll.mui - Ok
C:\Windows\system32\nl-NL\dnscmmc.dll.mui - Ok
C:\Windows\system32\nl-NL\dpapimig.exe.mui - Ok
C:\Windows\system32\nl-NL\dpapiprovider.dll.mui - Ok
C:\Windows\system32\nl-NL\dpnsvr.exe.mui - Ok
C:\Windows\system32\nl-NL\dot3hc.dll.mui - Ok
C:\Windows\system32\nl-NL\dot3svc.dll.mui - Ok
C:\Windows\system32\nl-NL\dot3cfg.dll.mui - Ok
C:\Windows\system32\nl-NL\dpnet.dll.mui - Ok
C:\Windows\system32\nl-NL\docprop.dll.mui - Ok
C:\Windows\system32\nl-NL\dps.dll.mui - Ok
C:\Windows\system32\nl-NL\dot3ui.dll.mui - Ok
C:\Windows\system32\nl-NL\DpiScaling.exe.mui - Ok
C:\Windows\system32\nl-NL\driverquery.exe.mui - Ok
C:\Windows\system32\nl-NL\drt.dll.mui - Ok
C:\Windows\system32\nl-NL\drprov.dll.mui - Ok
C:\Windows\system32\nl-NL\dsquery.dll.mui - Ok
C:\Windows\system32\nl-NL\dskquoui.dll.mui - Ok
C:\Windows\system32\nl-NL\dssec.dll.mui - Ok
C:\Windows\system32\nl-NL\dot3gpui.dll.mui - Ok
C:\Windows\system32\nl-NL\dskquota.dll.mui - Ok
C:\Windows\system32\nl-NL\dsuiext.dll.mui - Ok
C:\Windows\system32\nl-NL\DShowRdpFilter.dll.mui - Ok
C:\Windows\system32\nl-NL\duser.dll.mui - Ok
C:\Windows\system32\nl-NL\dsprop.dll.mui - Ok
C:\Windows\system32\nl-NL\dtsh.dll.mui - Ok
C:\Windows\system32\nl-NL\dvdplay.exe.mui - Ok
C:\Windows\system32\nl-NL\dwm.exe.mui - Ok
C:\Windows\system32\nl-NL\dwmcore.dll.mui - Ok
C:\Windows\system32\nl-NL\dvdupgrd.exe.mui - Ok
C:\Windows\system32\nl-NL\dwmredir.dll.mui - Ok
C:\Windows\system32\nl-NL\dwmapi.dll.mui - Ok
C:\Windows\system32\nl-NL\DWrite.dll.mui - Ok
C:\Windows\system32\nl-NL\DXPTaskRingtone.dll.mui - Ok
C:\Windows\system32\nl-NL\dui70.dll.mui - Ok
C:\Windows\system32\nl-NL\dxdiagn.dll.mui - Ok
C:\Windows\system32\nl-NL\dxp.dll.mui - Ok
C:\Windows\system32\nl-NL\DWWIN.exe.mui - Ok
C:\Windows\system32\nl-NL\eappgnui.dll.mui - Ok
C:\Windows\system32\nl-NL\EAPQEC.DLL.MUI - Ok
C:\Windows\system32\nl-NL\dxgkrnl.sys.mui - Ok
C:\Windows\system32\nl-NL\dxdiag.exe.mui - Ok
C:\Windows\system32\nl-NL\dsound.dll.mui - Ok
C:\Windows\system32\nl-NL\DxpTaskSync.dll.mui - Ok
C:\Windows\system32\nl-NL\efssvc.dll.mui - Ok
C:\Windows\system32\nl-NL\drvinst.exe.mui - Ok
C:\Windows\system32\nl-NL\eapsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\eappcfg.dll.mui - Ok
C:\Windows\system32\nl-NL\EhStorAuthn.exe.mui - Ok
C:\Windows\system32\nl-NL\dxpserver.exe.mui - Ok
C:\Windows\system32\nl-NL\efscore.dll.mui - Ok
C:\Windows\system32\nl-NL\encdec.dll.mui - Ok
C:\Windows\system32\nl-NL\els.dll.mui - Ok
C:\Windows\system32\nl-NL\eapphost.dll.mui - Ok
C:\Windows\system32\nl-NL\erofflps.txt - Ok
C:\Windows\system32\nl-NL\EhStorPwdMgr.dll.mui - Ok
C:\Windows\system32\nl-NL\EhStorShell.dll.mui - Ok
C:\Windows\system32\nl-NL\EhStorAPI.dll.mui - Ok
C:\Windows\system32\nl-NL\elscore.dll.mui - Ok
C:\Windows\system32\nl-NL\eudcedit.exe.mui - Ok
C:\Windows\system32\nl-NL\efsadu.dll.mui - Ok
>C:\Windows\system32\nl-NL\EventViewer_EventDetails.xsl is JS-HTML container
C:\Windows\system32\nl-NL\eventvwr.exe.mui - Ok
C:\Windows\system32\nl-NL\eqossnap.dll.mui - Ok
C:\Windows\system32\nl-NL\esrb.rs.mui - Ok
C:\Windows\system32\nl-NL\expand.exe.mui - Ok
C:\Windows\system32\nl-NL\explorerframe.dll.mui - Ok
C:\Windows\system32\nl-NL\EventCreate.exe.mui - Ok
C:\Windows\system32\nl-NL\fde.dll.mui - Ok
C:\Windows\system32\nl-NL\EventViewer_EventDetails.xsl - container
C:\Windows\system32\nl-NL\fc.exe.mui - Ok
C:\Windows\system32\nl-NL\fdPHost.dll.mui - Ok
C:\Windows\system32\nl-NL\extrac32.exe.mui - Ok
C:\Windows\system32\nl-NL\fdprint.dll.mui - Ok
C:\Windows\system32\nl-NL\evr.dll.mui - Ok
>C:\Windows\system32\nl-NL\energy.dll.mui is BINARYRES container
C:\Windows\system32\nl-NL\faultrep.dll.mui - Ok
C:\Windows\system32\nl-NL\fdeploy.dll.mui - Ok
>>C:\Windows\system32\nl-NL\energy.dll.mui\data001 is JS-HTML container
C:\Windows\system32\nl-NL\energy.dll.mui - container
C:\Windows\system32\nl-NL\fdrespub.dll.mui - Ok
C:\Windows\system32\nl-NL\filemgmt.dll.mui - Ok
C:\Windows\system32\nl-NL\FirewallControlPanel.dll.mui - Ok
C:\Windows\system32\nl-NL\finger.exe.mui - Ok
C:\Windows\system32\nl-NL\FirewallAPI.dll.mui - Ok
C:\Windows\system32\nl-NL\fltlib.dll.mui - Ok
C:\Windows\system32\nl-NL\fltMC.exe.mui - Ok
C:\Windows\system32\nl-NL\findstr.exe.mui - Ok
C:\Windows\system32\nl-NL\fontext.dll.mui - Ok
C:\Windows\system32\nl-NL\fixmapi.exe.mui - Ok
C:\Windows\system32\nl-NL\fontview.exe.mui - Ok
C:\Windows\system32\nl-NL\eventvwr.msc - Ok
C:\Windows\system32\nl-NL\forfiles.exe.mui - Ok
C:\Windows\system32\nl-NL\fsquirt.exe.mui - Ok
C:\Windows\system32\nl-NL\fpb.rs.mui - Ok
C:\Windows\system32\nl-NL\FntCache.dll.mui - Ok
C:\Windows\system32\nl-NL\fms.dll.mui - Ok
C:\Windows\system32\nl-NL\ftp.exe.mui - Ok
C:\Windows\system32\nl-NL\fveapi.dll.mui - Ok
C:\Windows\system32\nl-NL\fvenotify.exe.mui - Ok
C:\Windows\system32\nl-NL\fphc.dll.mui - Ok
C:\Windows\system32\nl-NL\find.exe.mui - Ok
C:\Windows\system32\nl-NL\FunDisc.dll.mui - Ok
C:\Windows\system32\nl-NL\fveui.dll.mui - Ok
C:\Windows\system32\nl-NL\ESENT.dll.mui - Ok
C:\Windows\system32\nl-NL\fthsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\fveprompt.exe.mui - Ok
C:\Windows\system32\nl-NL\fverecover.dll.mui - Ok
C:\Windows\system32\nl-NL\fwpuclnt.dll.mui - Ok
C:\Windows\system32\nl-NL\g711codc.ax.mui - Ok
C:\Windows\system32\nl-NL\FXSEVENT.dll.mui - Ok
C:\Windows\system32\nl-NL\FXSCOMPOSERES.dll.mui - Ok
C:\Windows\system32\nl-NL\fsutil.exe.mui - Ok
C:\Windows\system32\nl-NL\FXSUTILITY.dll.mui - Ok
C:\Windows\system32\nl-NL\GCDEF.dll.mui - Ok
C:\Windows\system32\nl-NL\gpapi.dll.mui - Ok
C:\Windows\system32\nl-NL\fwcfg.dll.mui - Ok
C:\Windows\system32\nl-NL\fsmgmt.msc - Ok
C:\Windows\system32\nl-NL\gpedit.dll.mui - Ok
C:\Windows\system32\nl-NL\gptext.dll.mui - Ok
C:\Windows\system32\nl-NL\FXSRESM.dll.mui - Ok
C:\Windows\system32\nl-NL\getmac.exe.mui - Ok
C:\Windows\system32\nl-NL\gpupdate.exe.mui - Ok
C:\Windows\system32\nl-NL\gpprnext.dll.mui - Ok
C:\Windows\system32\nl-NL\grpconv.exe.mui - Ok
C:\Windows\system32\nl-NL\hdwwiz.cpl.mui - Ok
C:\Windows\system32\nl-NL\grb.rs.mui - Ok
C:\Windows\system32\nl-NL\gpresult.exe.mui - Ok
C:\Windows\system32\nl-NL\hdwwiz.exe.mui - Ok
C:\Windows\system32\nl-NL\glu32.dll.mui - Ok
C:\Windows\system32\nl-NL\help.exe.mui - Ok
C:\Windows\system32\nl-NL\Groupinghc.dll.mui - Ok
C:\Windows\system32\nl-NL\hidphone.tsp.mui - Ok
C:\Windows\system32\nl-NL\hidserv.dll.mui - Ok
C:\Windows\system32\nl-NL\gpsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\gameux.dll.mui - Ok
C:\Windows\system32\nl-NL\hid.dll.mui - Ok
C:\Windows\system32\nl-NL\hgcpl.dll.mui - Ok
C:\Windows\system32\nl-NL\hnetcfg.dll.mui - Ok
C:\Windows\system32\nl-NL\hhctrl.ocx.mui - Ok
C:\Windows\system32\nl-NL\HotStartUserAgent.dll.mui - Ok
C:\Windows\system32\nl-NL\hpotiop1.dll.mui - Ok
C:\Windows\system32\nl-NL\hpotscl1.dll.mui - Ok
C:\Windows\system32\nl-NL\hpotscld.dll.mui - Ok
C:\Windows\system32\nl-NL\hpowiad1.dll.mui - Ok
C:\Windows\system32\nl-NL\hpowiav1.dll.mui - Ok
C:\Windows\system32\nl-NL\hotplug.dll.mui - Ok
C:\Windows\system32\nl-NL\hnetmon.dll.mui - Ok
C:\Windows\system32\nl-NL\httpapi.dll.mui - Ok
C:\Windows\system32\nl-NL\hostname.exe.mui - Ok
C:\Windows\system32\nl-NL\iasacct.dll.mui - Ok
C:\Windows\system32\nl-NL\iasads.dll.mui - Ok
C:\Windows\system32\nl-NL\hcproviders.dll.mui - Ok
C:\Windows\system32\nl-NL\html.iec.mui - Ok
C:\Windows\system32\nl-NL\iashlpr.dll.mui - Ok
C:\Windows\system32\nl-NL\iasrad.dll.mui - Ok
C:\Windows\system32\nl-NL\hlink.dll.mui - Ok
C:\Windows\system32\nl-NL\iassvcs.dll.mui - Ok
C:\Windows\system32\nl-NL\iassdo.dll.mui - Ok
>C:\Windows\system32\nl-NL\icardie.dll.mui is BINARYRES container
C:\Windows\system32\nl-NL\icsigd.dll.mui - Ok
C:\Windows\system32\nl-NL\IdListen.dll.mui - Ok
C:\Windows\system32\nl-NL\ICacls.exe.mui - Ok
C:\Windows\system32\nl-NL\icardie.dll.mui - container
C:\Windows\system32\nl-NL\icm32.dll.mui - Ok
C:\Windows\system32\nl-NL\iepeers.dll.mui - Ok
C:\Windows\system32\nl-NL\icmui.dll.mui - Ok
C:\Windows\system32\nl-NL\IEAdvpack.dll.mui - Ok
C:\Windows\system32\nl-NL\ias.dll.mui - Ok
C:\Windows\system32\nl-NL\iernonce.dll.mui - Ok
C:\Windows\system32\nl-NL\iedkcs32.dll.mui - Ok
C:\Windows\system32\nl-NL\ieui.dll.mui - Ok
C:\Windows\system32\nl-NL\ikeext.dll.mui - Ok
C:\Windows\system32\nl-NL\imaadp32.acm.mui - Ok
C:\Windows\system32\nl-NL\ifmon.dll.mui - Ok
C:\Windows\system32\nl-NL\ieunatt.exe.mui - Ok
C:\Windows\system32\nl-NL\imageres.dll.mui - Ok
C:\Windows\system32\nl-NL\imagesp1.dll.mui - Ok
C:\Windows\system32\nl-NL\imapi.dll.mui - Ok
C:\Windows\system32\nl-NL\getuname.dll.mui - Ok
C:\Windows\system32\nl-NL\htui.dll.mui - Ok
C:\Windows\system32\nl-NL\iexpress.exe.mui - Ok
C:\Windows\system32\nl-NL\inetpp.dll.mui - Ok
C:\Windows\system32\nl-NL\inetppui.dll.mui - Ok
C:\Windows\system32\nl-NL\iasdatastore.dll.mui - Ok
C:\Windows\system32\nl-NL\InfDefaultInstall.exe.mui - Ok
C:\Windows\system32\nl-NL\input.dll.mui - Ok
C:\Windows\system32\nl-NL\igdDiag.dll.mui - Ok
C:\Windows\system32\nl-NL\inetcpl.cpl.mui - Ok
C:\Windows\system32\nl-NL\intl.cpl.mui - Ok
C:\Windows\system32\nl-NL\IPBusEnum.dll.mui - Ok
C:\Windows\system32\nl-NL\iphlpapi.dll.mui - Ok
>C:\Windows\system32\nl-NL\iesetup.dll.mui is BINARYRES container
C:\Windows\system32\nl-NL\imapi2.dll.mui - Ok
C:\Windows\system32\nl-NL\inetres.dll.mui - Ok
C:\Windows\system32\nl-NL\iologmsg.dll.mui - Ok
C:\Windows\system32\nl-NL\iesetup.dll.mui - container
C:\Windows\system32\nl-NL\ipconfig.exe.mui - Ok
C:\Windows\system32\nl-NL\iphlpsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\ipsecsnp.dll.mui - Ok
C:\Windows\system32\nl-NL\ipnathlp.dll.mui - Ok
C:\Windows\system32\nl-NL\irclass.dll.mui - Ok
C:\Windows\system32\nl-NL\imapi2fs.dll.mui - Ok
C:\Windows\system32\nl-NL\iprtrmgr.dll.mui - Ok
C:\Windows\system32\nl-NL\ipsecsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\irftp.exe.mui - Ok
C:\Windows\system32\nl-NL\inseng.dll.mui - Ok
C:\Windows\system32\nl-NL\iscsicpl.exe.mui - Ok
C:\Windows\system32\nl-NL\iscsicli.exe.mui - Ok
C:\Windows\system32\nl-NL\iscsilog.dll.mui - Ok
C:\Windows\system32\nl-NL\IpsmSnap.dll.mui - Ok
C:\Windows\system32\nl-NL\ie4uinit.exe.mui - Ok
C:\Windows\system32\nl-NL\joy.cpl.mui - Ok
C:\Windows\system32\nl-NL\kerberos.dll.mui - Ok
C:\Windows\system32\nl-NL\iscsicpl.dll.mui - Ok
C:\Windows\system32\nl-NL\iyuv_32.dll.mui - Ok
C:\Windows\system32\nl-NL\jscript.dll.mui - Ok
C:\Windows\system32\nl-NL\jscript9.dll.mui - Ok
C:\Windows\system32\nl-NL\iscsidsc.dll.mui - Ok
C:\Windows\system32\nl-NL\keyiso.dll.mui - Ok
C:\Windows\system32\nl-NL\irmon.dll.mui - Ok
>C:\Windows\system32\nl-NL\icardres.dll.mui is BINARYRES container
C:\Windows\system32\nl-NL\KMSVC.DLL.MUI - Ok
C:\Windows\system32\nl-NL\isoburn.exe.mui - Ok
C:\Windows\system32\nl-NL\klist.exe.mui - Ok
C:\Windows\system32\nl-NL\iscsiexe.dll.mui - Ok
C:\Windows\system32\nl-NL\KernelBase.dll.mui - Ok
C:\Windows\system32\nl-NL\irprops.cpl.mui - Ok
C:\Windows\system32\nl-NL\kstvtune.ax.mui - Ok
C:\Windows\system32\nl-NL\kmddsp.tsp.mui - Ok
C:\Windows\system32\nl-NL\kernelceip.dll.mui - Ok
C:\Windows\system32\nl-NL\ksetup.exe.mui - Ok
C:\Windows\system32\nl-NL\ksxbar.ax.mui - Ok
C:\Windows\system32\nl-NL\ksproxy.ax.mui - Ok
C:\Windows\system32\nl-NL\kywdds10.dll.mui - Ok
C:\Windows\system32\nl-NL\ktmutil.exe.mui - Ok
C:\Windows\system32\nl-NL\kswdmcap.ax.mui - Ok
C:\Windows\system32\nl-NL\l3codeca.acm.mui - Ok
C:\Windows\system32\nl-NL\keymgr.dll.mui - Ok
C:\Windows\system32\nl-NL\L2SecHC.dll.mui - Ok
C:\Windows\system32\nl-NL\kywuds10.dll.mui - Ok
C:\Windows\system32\nl-NL\label.exe.mui - Ok
C:\Windows\system32\nl-NL\listsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\licmgr10.dll.mui - Ok
C:\Windows\system32\nl-NL\lltdres.dll.mui - Ok
C:\Windows\system32\nl-NL\l2nacp.dll.mui - Ok
C:\Windows\system32\nl-NL\lmhsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\LocationNotifications.exe.mui - Ok
C:\Windows\system32\nl-NL\Locator.exe.mui - Ok
C:\Windows\system32\nl-NL\lodctr.exe.mui - Ok
C:\Windows\system32\nl-NL\localsec.dll.mui - Ok
C:\Windows\system32\nl-NL\logagent.exe.mui - Ok
C:\Windows\system32\nl-NL\localui.dll.mui - Ok
C:\Windows\system32\nl-NL\logman.exe.mui - Ok
C:\Windows\system32\nl-NL\loghours.dll.mui - Ok
C:\Windows\system32\nl-NL\lipeula.rtf - Ok
C:\Windows\system32\nl-NL\lpremove.exe.mui - Ok
C:\Windows\system32\nl-NL\Magnification.dll.mui - Ok
C:\Windows\system32\nl-NL\loadperf.dll.mui - Ok
C:\Windows\system32\nl-NL\lpksetup.exe.mui - Ok
C:\Windows\system32\nl-NL\main.cpl.mui - Ok
C:\Windows\system32\nl-NL\lsasrv.dll.mui - Ok
C:\Windows\system32\nl-NL\lpeula.rtf - Ok
C:\Windows\system32\nl-NL\localspl.dll.mui - Ok
C:\Windows\system32\nl-NL\lusrmgr.msc - Ok
C:\Windows\system32\nl-NL\icardres.dll.mui - container
C:\Windows\system32\nl-NL\mapi32.dll.mui - Ok
C:\Windows\system32\nl-NL\mciavi32.dll.mui - Ok
C:\Windows\system32\nl-NL\mblctr.exe.mui - Ok
C:\Windows\system32\nl-NL\mapistub.dll.mui - Ok
C:\Windows\system32\nl-NL\lsm.exe.mui - Ok
C:\Windows\system32\nl-NL\manage-bde.exe.mui - Ok
C:\Windows\system32\nl-NL\mctres.dll.mui - Ok
C:\Windows\system32\nl-NL\mdminst.dll.mui - Ok
C:\Windows\system32\nl-NL\Magnify.exe.mui - Ok
C:\Windows\system32\nl-NL\mctadmin.exe.mui - Ok
C:\Windows\system32\nl-NL\mcicda.dll.mui - Ok
C:\Windows\system32\nl-NL\memdiag.dll.mui - Ok
C:\Windows\system32\nl-NL\mciseq.dll.mui - Ok
C:\Windows\system32\nl-NL\mciwave.dll.mui - Ok
C:\Windows\system32\nl-NL\MdRes.exe.mui - Ok
C:\Windows\system32\nl-NL\mciqtz32.dll.mui - Ok
C:\Windows\system32\nl-NL\mf.dll.mui - Ok
C:\Windows\system32\nl-NL\McxDriv.dll.mui - Ok
C:\Windows\system32\nl-NL\MdSched.exe.mui - Ok
C:\Windows\system32\nl-NL\microsoft-windows-kernel-power-events.dll.mui - Ok
C:\Windows\system32\nl-NL\mferror.dll.mui - Ok
C:\Windows\system32\nl-NL\MFPlay.dll.mui - Ok
C:\Windows\system32\nl-NL\microsoft-windows-hal-events.dll.mui - Ok
C:\Windows\system32\nl-NL\MFC42u.dll.mui - Ok
C:\Windows\system32\nl-NL\midimap.dll.mui - Ok
C:\Windows\system32\nl-NL\MFC42.dll.mui - Ok
C:\Windows\system32\nl-NL\miguiresource.dll.mui - Ok
C:\Windows\system32\nl-NL\mlang.dll.mui - Ok
C:\Windows\system32\nl-NL\MFReadWrite.dll.mui - Ok
>C:\Windows\system32\nl-NL\mmc.exe.mui is BINARYRES container
C:\Windows\system32\nl-NL\microsoft-windows-kernel-processor-power-events.dll.mui - Ok
>>C:\Windows\system32\nl-NL\mmc.exe.mui\data001 is JS-HTML container
C:\Windows\system32\nl-NL\MigAutoPlay.exe.mui - Ok
C:\Windows\system32\nl-NL\mfpmp.exe.mui - Ok
C:\Windows\system32\nl-NL\mimefilt.dll.mui - Ok
C:\Windows\system32\nl-NL\mmcss.dll.mui - Ok
>>C:\Windows\system32\nl-NL\mmc.exe.mui\data003 is JS-HTML container
C:\Windows\system32\nl-NL\mmcshext.dll.mui - Ok
C:\Windows\system32\nl-NL\mmci.dll.mui - Ok
C:\Windows\system32\nl-NL\mfplat.dll.mui - Ok
C:\Windows\system32\nl-NL\mmcbase.dll.mui - Ok
C:\Windows\system32\nl-NL\MMDevAPI.dll.mui - Ok
>C:\Windows\system32\nl-NL\mmcndmgr.dll.mui is BINARYRES container
C:\Windows\system32\nl-NL\mmsys.cpl.mui - Ok
>>C:\Windows\system32\nl-NL\mmc.exe.mui\data004 is JS-HTML container
C:\Windows\system32\nl-NL\montr_ci.dll.mui - Ok
C:\Windows\system32\nl-NL\mp4sdecd.dll.mui - Ok
>>C:\Windows\system32\nl-NL\mmcndmgr.dll.mui\data001 is JS-HTML container
C:\Windows\system32\nl-NL\mprddm.dll.mui - Ok
C:\Windows\system32\nl-NL\modemui.dll.mui - Ok
C:\Windows\system32\nl-NL\mprdim.dll.mui - Ok
C:\Windows\system32\nl-NL\mountvol.exe.mui - Ok
C:\Windows\system32\nl-NL\mpr.dll.mui - Ok
C:\Windows\system32\nl-NL\msaatext.dll.mui - Ok
>>C:\Windows\system32\nl-NL\mmc.exe.mui\data006 is JS-HTML container
C:\Windows\system32\nl-NL\mpssvc.dll.mui - Ok
C:\Windows\system32\nl-NL\msacm32.drv.mui - Ok
C:\Windows\system32\nl-NL\kernel32.dll.mui - Ok
C:\Windows\system32\nl-NL\mrinfo.exe.mui - Ok
>>C:\Windows\system32\nl-NL\mmcndmgr.dll.mui\data002 is JS-HTML container
>>C:\Windows\system32\nl-NL\mmc.exe.mui\data007 is JS-HTML container
C:\Windows\system32\nl-NL\msadp32.acm.mui - Ok
C:\Windows\system32\nl-NL\mmcndmgr.dll.mui - container
C:\Windows\system32\nl-NL\msctf.dll.mui - Ok
C:\Windows\system32\nl-NL\mscandui.dll.mui - Ok
C:\Windows\system32\nl-NL\mprmsg.dll.mui - Ok
>>C:\Windows\system32\nl-NL\mmc.exe.mui\data008 is JS-HTML container
C:\Windows\system32\nl-NL\msctfui.dll.mui - Ok
C:\Windows\system32\nl-NL\MsCtfMonitor.dll.mui - Ok
C:\Windows\system32\nl-NL\mmc.exe.mui - container
C:\Windows\system32\nl-NL\msconfig.exe.mui - Ok
C:\Windows\system32\nl-NL\msdrm.dll.mui - Ok
C:\Windows\system32\nl-NL\msacm32.dll.mui - Ok
C:\Windows\system32\nl-NL\mmres.dll.mui - Ok
C:\Windows\system32\nl-NL\msdt.exe.mui - Ok
C:\Windows\system32\nl-NL\mshta.exe.mui - Ok
C:\Windows\system32\nl-NL\msgsm32.acm.mui - Ok
C:\Windows\system32\nl-NL\msg711.acm.mui - Ok
C:\Windows\system32\nl-NL\msaudite.dll.mui - Ok
C:\Windows\system32\nl-NL\MsiCofire.dll.mui - Ok
C:\Windows\system32\nl-NL\msdtc.exe.mui - Ok
C:\Windows\system32\nl-NL\msdtcVSp1res.dll.mui - Ok
C:\Windows\system32\nl-NL\msident.dll.mui - Ok
C:\Windows\system32\nl-NL\msidntld.dll.mui - Ok
C:\Windows\system32\nl-NL\msimtf.dll.mui - Ok
C:\Windows\system32\nl-NL\msieftp.dll.mui - Ok
C:\Windows\system32\nl-NL\mshtmlmedia.dll.mui - Ok
C:\Windows\system32\nl-NL\mscms.dll.mui - Ok
C:\Windows\system32\nl-NL\mshtmler.dll.mui - Ok
C:\Windows\system32\nl-NL\msfeedsbs.dll.mui - Ok
C:\Windows\system32\nl-NL\msoert2.dll.mui - Ok
C:\Windows\system32\nl-NL\msmpeg2enc.dll.mui - Ok
C:\Windows\system32\nl-NL\msiexec.exe.mui - Ok
C:\Windows\system32\nl-NL\msra.exe.mui - Ok
C:\Windows\system32\nl-NL\msrahc.dll.mui - Ok
C:\Windows\system32\nl-NL\mssha.dll.mui - Ok
C:\Windows\system32\nl-NL\msports.dll.mui - Ok
>C:\Windows\system32\nl-NL\mshtml.dll.mui is BINARYRES container
C:\Windows\system32\nl-NL\msobjs.dll.mui - Ok
C:\Windows\system32\nl-NL\msrle32.dll.mui - Ok
C:\Windows\system32\nl-NL\mshtml.dll.mui - container
C:\Windows\system32\nl-NL\msprivs.dll.mui - Ok
C:\Windows\system32\nl-NL\msrating.dll.mui - Ok
C:\Windows\system32\nl-NL\msimsg.dll.mui - Ok
C:\Windows\system32\nl-NL\mssvp.dll.mui - Ok
C:\Windows\system32\nl-NL\msshavmsg.dll.mui - Ok
C:\Windows\system32\nl-NL\msutb.dll.mui - Ok
C:\Windows\system32\nl-NL\mssphtb.dll.mui - Ok
C:\Windows\system32\nl-NL\msvidc32.dll.mui - Ok
C:\Windows\system32\nl-NL\mstask.dll.mui - Ok
C:\Windows\system32\nl-NL\mssph.dll.mui - Ok
C:\Windows\system32\nl-NL\msv1_0.dll.mui - Ok
C:\Windows\system32\nl-NL\mssrch.dll.mui - Ok
C:\Windows\system32\nl-NL\mssign32.dll.mui - Ok
C:\Windows\system32\nl-NL\mstsc.exe.mui - Ok
C:\Windows\system32\nl-NL\mspaint.exe.mui - Ok
C:\Windows\system32\nl-NL\mstscax.dll.mui - Ok
C:\Windows\system32\nl-NL\MSWMDM.dll.mui - Ok
C:\Windows\system32\nl-NL\msxml6r.dll.mui - Ok
C:\Windows\system32\nl-NL\MultiDigiMon.exe.mui - Ok
C:\Windows\system32\nl-NL\msinfo32.exe.mui - Ok
C:\Windows\system32\nl-NL\MSVidCtl.dll.mui - Ok
C:\Windows\system32\nl-NL\mswsock.dll.mui - Ok
C:\Windows\system32\nl-NL\mtstocom.exe.mui - Ok
C:\Windows\system32\nl-NL\msxml3r.dll.mui - Ok
C:\Windows\system32\nl-NL\msvfw32.dll.mui - Ok
C:\Windows\system32\nl-NL\mycomput.dll.mui - Ok
C:\Windows\system32\nl-NL\Mystify.scr.mui - Ok
C:\Windows\system32\nl-NL\napdsnap.dll.mui - Ok
C:\Windows\system32\nl-NL\NAPCLCFG.MSC - Ok
C:\Windows\system32\nl-NL\NAPSTAT.EXE.MUI - Ok
C:\Windows\system32\nl-NL\napipsec.dll.mui - Ok
C:\Windows\system32\nl-NL\nbtstat.exe.mui - Ok
C:\Windows\system32\nl-NL\ncrypt.dll.mui - Ok
C:\Windows\system32\nl-NL\ncpa.cpl.mui - Ok
C:\Windows\system32\nl-NL\ncsi.dll.mui - Ok
C:\Windows\system32\nl-NL\mydocs.dll.mui - Ok
C:\Windows\system32\nl-NL\ndadmin.exe.mui - Ok
C:\Windows\system32\nl-NL\ieframe.dll.mui - Ok
C:\Windows\system32\nl-NL\nddeapi.dll.mui - Ok
C:\Windows\system32\nl-NL\ndptsp.tsp.mui - Ok
C:\Windows\system32\nl-NL\ndfapi.dll.mui - Ok
C:\Windows\system32\nl-NL\NAPMONTR.DLL.MUI - Ok
C:\Windows\system32\nl-NL\netbtugc.exe.mui - Ok
C:\Windows\system32\nl-NL\netcenter.dll.mui - Ok
C:\Windows\system32\nl-NL\netcfgx.dll.mui - Ok
C:\Windows\system32\nl-NL\netid.dll.mui - Ok
C:\Windows\system32\nl-NL\neth.dll.mui - Ok
C:\Windows\system32\nl-NL\netiougc.exe.mui - Ok
C:\Windows\system32\nl-NL\NcdProp.dll.mui - Ok
C:\Windows\system32\nl-NL\ncryptui.dll.mui - Ok
C:\Windows\system32\nl-NL\netman.dll.mui - Ok
C:\Windows\system32\nl-NL\napinsp.dll.mui - Ok
C:\Windows\system32\nl-NL\nci.dll.mui - Ok
C:\Windows\system32\nl-NL\netevent.dll.mui - Ok
C:\Windows\system32\nl-NL\netprofm.dll.mui - Ok
C:\Windows\system32\nl-NL\netcorehc.dll.mui - Ok
C:\Windows\system32\nl-NL\netdiagfx.dll.mui - Ok
C:\Windows\system32\nl-NL\netiohlp.dll.mui - Ok
C:\Windows\system32\nl-NL\netprof.dll.mui - Ok
C:\Windows\system32\nl-NL\netsh.exe.mui - Ok
C:\Windows\system32\nl-NL\NetworkExplorer.dll.mui - Ok
>C:\Windows\system32\nl-NL\nettrace.dll.mui is BINARYRES container
C:\Windows\system32\nl-NL\netlogon.dll.mui - Ok
>>C:\Windows\system32\nl-NL\nettrace.dll.mui\data001 is JS-HTML container
C:\Windows\system32\nl-NL\nettrace.dll.mui - container
C:\Windows\system32\nl-NL\NetworkMap.dll.mui - Ok
C:\Windows\system32\nl-NL\netshell.dll.mui - Ok
C:\Windows\system32\nl-NL\NetworkItemFactory.dll.mui - Ok
C:\Windows\system32\nl-NL\newdev.dll.mui - Ok
C:\Windows\system32\nl-NL\Netplwiz.exe.mui - Ok
C:\Windows\system32\nl-NL\netstat.exe.mui - Ok
C:\Windows\system32\nl-NL\nlahc.dll.mui - Ok
C:\Windows\system32\nl-NL\newdev.exe.mui - Ok
C:\Windows\system32\nl-NL\nlhtml.dll.mui - Ok
C:\Windows\system32\nl-NL\netcfg.exe.mui - Ok
C:\Windows\system32\nl-NL\netplwiz.dll.mui - Ok
C:\Windows\system32\nl-NL\nlasvc.dll.mui - Ok
C:\Windows\system32\nl-NL\nltest.exe.mui - Ok
C:\Windows\system32\nl-NL\nslookup.exe.mui - Ok
C:\Windows\system32\nl-NL\nshhttp.dll.mui - Ok
C:\Windows\system32\nl-NL\nsisvc.dll.mui - Ok
C:\Windows\system32\nl-NL\nshwfp.dll.mui - Ok
C:\Windows\system32\nl-NL\nlsbres.dll.mui - Ok
C:\Windows\system32\nl-NL\notepad.exe.mui - Ok
C:\Windows\system32\nl-NL\ndishc.dll.mui - Ok
C:\Windows\system32\nl-NL\ntprint.exe.mui - Ok
C:\Windows\system32\nl-NL\nshipsec.dll.mui - Ok
C:\Windows\system32\nl-NL\ntlanui2.dll.mui - Ok
C:\Windows\system32\nl-NL\ntvdm64.dll.mui - Ok
C:\Windows\system32\nl-NL\odbcad32.exe.mui - Ok
C:\Windows\system32\nl-NL\objsel.dll.mui - Ok
C:\Windows\system32\nl-NL\nlmgp.dll.mui - Ok
C:\Windows\system32\nl-NL\ocsetup.exe.mui - Ok
C:\Windows\system32\nl-NL\offFilt.dll.mui - Ok
C:\Windows\system32\nl-NL\ntmarta.dll.mui - Ok
C:\Windows\system32\nl-NL\oflc-nz.rs.mui - Ok
C:\Windows\system32\nl-NL\ntprint.dll.mui - Ok
C:\Windows\system32\nl-NL\oleaccrc.dll.mui - Ok
C:\Windows\system32\nl-NL\ntdll.dll.mui - Ok
C:\Windows\system32\nl-NL\odbcint.dll.mui - Ok
C:\Windows\system32\nl-NL\ole32.dll.mui - Ok
C:\Windows\system32\nl-NL\ntshrui.dll.mui - Ok
C:\Windows\system32\nl-NL\oleres.dll.mui - Ok
C:\Windows\system32\nl-NL\oflc.rs.mui - Ok
C:\Windows\system32\nl-NL\oleprn.dll.mui - Ok
C:\Windows\system32\nl-NL\onexui.dll.mui - Ok
C:\Windows\system32\nl-NL\OnLineIDCPL.dll.mui - Ok
C:\Windows\system32\nl-NL\ntlanman.dll.mui - Ok
C:\Windows\system32\nl-NL\OptionalFeatures.exe.mui - Ok
C:\Windows\system32\nl-NL\osbaseln.dll.mui - Ok
C:\Windows\system32\nl-NL\osk.exe.mui - Ok
C:\Windows\system32\nl-NL\openfiles.exe.mui - Ok
C:\Windows\system32\nl-NL\p2p.dll.mui - Ok
C:\Windows\system32\nl-NL\odbcconf.exe.mui - Ok
C:\Windows\system32\nl-NL\onex.dll.mui - Ok
C:\Windows\system32\nl-NL\oobefldr.dll.mui - Ok
C:\Windows\system32\nl-NL\p2phost.exe.mui - Ok
C:\Windows\system32\nl-NL\packager.dll.mui - Ok
C:\Windows\system32\nl-NL\p2pnetsh.dll.mui - Ok
C:\Windows\system32\nl-NL\pautoenr.dll.mui - Ok
C:\Windows\system32\nl-NL\pathping.exe.mui - Ok
C:\Windows\system32\nl-NL\pcaevts.dll.mui - Ok
C:\Windows\system32\nl-NL\p2psvc.dll.mui - Ok
C:\Windows\system32\nl-NL\pcwum.dll.mui - Ok
C:\Windows\system32\nl-NL\oledlg.dll.mui - Ok
C:\Windows\system32\nl-NL\pcasvc.dll.mui - Ok
C:\Windows\system32\nl-NL\p2pcollab.dll.mui - Ok
C:\Windows\system32\nl-NL\pdh.dll.mui - Ok
C:\Windows\system32\nl-NL\pegi.rs.mui - Ok
C:\Windows\system32\nl-NL\pegibbfc.rs.mui - Ok
C:\Windows\system32\nl-NL\pegi-pt.rs.mui - Ok
C:\Windows\system32\nl-NL\perfctrs.dll.mui - Ok
C:\Windows\system32\nl-NL\pcalua.exe.mui - Ok
C:\Windows\system32\nl-NL\pcwutl.dll.mui - Ok
C:\Windows\system32\nl-NL\perfdisk.dll.mui - Ok
>C:\Windows\system32\nl-NL\perfmon.exe.mui is BINARYRES container
C:\Windows\system32\nl-NL\pdhui.dll.mui - Ok
C:\Windows\system32\nl-NL\pegi-fi.rs.mui - Ok
C:\Windows\system32\nl-NL\PerfCenterCPL.dll.mui - Ok
>>C:\Windows\system32\nl-NL\perfmon.exe.mui\data001 is JS-HTML container
C:\Windows\system32\nl-NL\perfproc.dll.mui - Ok
C:\Windows\system32\nl-NL\PhotoScreensaver.scr.mui - Ok
C:\Windows\system32\nl-NL\perfmon.exe.mui - container
C:\Windows\system32\nl-NL\perfos.dll.mui - Ok
C:\Windows\system32\nl-NL\perfnet.dll.mui - Ok
C:\Windows\system32\nl-NL\ping.exe.mui - Ok
C:\Windows\system32\nl-NL\PlaySndSrv.dll.mui - Ok
C:\Windows\system32\nl-NL\pcaui.dll.mui - Ok
C:\Windows\system32\nl-NL\pnrpauto.dll.mui - Ok
C:\Windows\system32\nl-NL\perftrack.dll.mui - Ok
C:\Windows\system32\nl-NL\PnPutil.exe.mui - Ok
C:\Windows\system32\nl-NL\PNPXAssocPrx.dll.mui - Ok
C:\Windows\system32\nl-NL\PnPUnattend.exe.mui - Ok
C:\Windows\system32\nl-NL\pnrphc.dll.mui - Ok
C:\Windows\system32\nl-NL\polstore.dll.mui - Ok
C:\Windows\system32\nl-NL\pnrpsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\PortableDeviceApi.dll.mui - Ok
C:\Windows\system32\nl-NL\perfmon.msc - Ok
C:\Windows\system32\nl-NL\pnidui.dll.mui - Ok
C:\Windows\system32\nl-NL\photowiz.dll.mui - Ok
C:\Windows\system32\nl-NL\poqexec.exe.mui - Ok
C:\Windows\system32\nl-NL\pla.dll.mui - Ok
C:\Windows\system32\nl-NL\pots.dll.mui - Ok
C:\Windows\system32\nl-NL\portabledevicestatus.dll.mui - Ok
C:\Windows\system32\nl-NL\PortableDeviceSyncProvider.dll.mui - Ok
C:\Windows\system32\nl-NL\powrprof.dll.mui - Ok
C:\Windows\system32\nl-NL\PresentationHost.exe.mui - Ok
C:\Windows\system32\nl-NL\print.exe.mui - Ok
C:\Windows\system32\nl-NL\printui.exe.mui - Ok
C:\Windows\system32\nl-NL\prflbmsg.dll.mui - Ok
C:\Windows\system32\nl-NL\procinst.dll.mui - Ok
C:\Windows\system32\nl-NL\profsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\prnntfy.dll.mui - Ok
C:\Windows\system32\nl-NL\occache.dll.mui - Ok
C:\Windows\system32\nl-NL\proquota.exe.mui - Ok
C:\Windows\system32\nl-NL\prnfldr.dll.mui - Ok
C:\Windows\system32\nl-NL\propsys.dll.mui - Ok
C:\Windows\system32\nl-NL\psbase.dll.mui - Ok
C:\Windows\system32\nl-NL\pnpui.dll.mui - Ok
C:\Windows\system32\nl-NL\netmsg.dll.mui - Ok
>C:\Windows\system32\nl-NL\psr.exe.mui is BINARYRES container
C:\Windows\system32\nl-NL\pwrshplugin.dll.mui - Ok
C:\Windows\system32\nl-NL\powercfg.exe.mui - Ok
C:\Windows\system32\nl-NL\psr.exe.mui - container
C:\Windows\system32\nl-NL\puiobj.dll.mui - Ok
C:\Windows\system32\nl-NL\pshed.dll.mui - Ok
C:\Windows\system32\nl-NL\powercfg.cpl.mui - Ok
C:\Windows\system32\nl-NL\QAgent.dll.mui - Ok
C:\Windows\system32\nl-NL\qcap.dll.mui - Ok
C:\Windows\system32\nl-NL\printui.dll.mui - Ok
C:\Windows\system32\nl-NL\qdvd.dll.mui - Ok
C:\Windows\system32\nl-NL\provsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\qedit.dll.mui - Ok
C:\Windows\system32\nl-NL\powercpl.dll.mui - Ok
C:\Windows\system32\nl-NL\qmgr.dll.mui - Ok
C:\Windows\system32\nl-NL\qasf.dll.mui - Ok
C:\Windows\system32\nl-NL\qdv.dll.mui - Ok
C:\Windows\system32\nl-NL\Qutil.dll.mui - Ok
C:\Windows\system32\nl-NL\QCLIPROV.DLL.MUI - Ok
C:\Windows\system32\nl-NL\racengn.dll.mui - Ok
C:\Windows\system32\nl-NL\QSVRMGMT.DLL.MUI - Ok
C:\Windows\system32\nl-NL\QShvHost.dll.mui - Ok
C:\Windows\system32\nl-NL\rasautou.exe.mui - Ok
C:\Windows\system32\nl-NL\rasauto.dll.mui - Ok
C:\Windows\system32\nl-NL\puiapi.dll.mui - Ok
C:\Windows\system32\nl-NL\Query.dll.mui - Ok
C:\Windows\system32\nl-NL\quartz.dll.mui - Ok
C:\Windows\system32\nl-NL\rascfg.dll.mui - Ok
C:\Windows\system32\nl-NL\radardt.dll.mui - Ok
C:\Windows\system32\nl-NL\racpldlg.dll.mui - Ok
C:\Windows\system32\nl-NL\rasctrs.dll.mui - Ok
C:\Windows\system32\nl-NL\rasdiag.dll.mui - Ok
C:\Windows\system32\nl-NL\rasapi32.dll.mui - Ok
C:\Windows\system32\nl-NL\raserver.exe.mui - Ok
C:\Windows\system32\nl-NL\qwave.dll.mui - Ok
C:\Windows\system32\nl-NL\raschap.dll.mui - Ok
C:\Windows\system32\nl-NL\rasmans.dll.mui - Ok
C:\Windows\system32\nl-NL\rasmm.dll.mui - Ok
C:\Windows\system32\nl-NL\rasmbmgr.dll.mui - Ok
C:\Windows\system32\nl-NL\radarrs.dll.mui - Ok
C:\Windows\system32\nl-NL\rasgcw.dll.mui - Ok
C:\Windows\system32\nl-NL\pnrpnsp.dll.mui - Ok
C:\Windows\system32\nl-NL\QAgentRT.dll.mui - Ok
C:\Windows\system32\nl-NL\rastls.dll.mui - Ok
C:\Windows\system32\nl-NL\rasdial.exe.mui - Ok
C:\Windows\system32\nl-NL\reagent.dll.mui - Ok
C:\Windows\system32\nl-NL\reagentc.exe.mui - Ok
C:\Windows\system32\nl-NL\regidle.dll.mui - Ok
C:\Windows\system32\nl-NL\recovery.dll.mui - Ok
C:\Windows\system32\nl-NL\recdisc.exe.mui - Ok
C:\Windows\system32\nl-NL\regsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\rdpcorekmts.dll.mui - Ok
C:\Windows\system32\nl-NL\rasphone.exe.mui - Ok
C:\Windows\system32\nl-NL\rasplap.dll.mui - Ok
C:\Windows\system32\nl-NL\recover.exe.mui - Ok
C:\Windows\system32\nl-NL\reg.exe.mui - Ok
C:\Windows\system32\nl-NL\replace.exe.mui - Ok
C:\Windows\system32\nl-NL\remotepg.dll.mui - Ok
C:\Windows\system32\nl-NL\RelPost.exe.mui - Ok
C:\Windows\system32\nl-NL\rekeywiz.exe.mui - Ok
C:\Windows\system32\nl-NL\RestartManager.mfl - Ok
C:\Windows\system32\nl-NL\repair-bde.exe.mui - Ok
C:\Windows\system32\nl-NL\rasmontr.dll.mui - Ok
C:\Windows\system32\nl-NL\RestartManagerUninstall.mfl - Ok
C:\Windows\system32\nl-NL\rdrleakdiag.exe.mui - Ok
C:\Windows\system32\nl-NL\RMActivate_isv.exe.mui - Ok
C:\Windows\system32\nl-NL\RMActivate_ssp.exe.mui - Ok
C:\Windows\system32\nl-NL\relog.exe.mui - Ok
C:\Windows\system32\nl-NL\RMActivate_ssp_isv.exe.mui - Ok
C:\Windows\system32\nl-NL\RmClient.exe.mui - Ok
C:\Windows\system32\nl-NL\RMActivate.exe.mui - Ok
C:\Windows\system32\nl-NL\regsvr32.exe.mui - Ok
C:\Windows\system32\nl-NL\rpcrt4.dll.mui - Ok
C:\Windows\system32\nl-NL\rasdlg.dll.mui - Ok
C:\Windows\system32\nl-NL\RPCNDFP.dll.mui - Ok
C:\Windows\system32\nl-NL\rdpcfgex.dll.mui - Ok
C:\Windows\system32\nl-NL\rshx32.dll.mui - Ok
C:\Windows\system32\nl-NL\rpchttp.dll.mui - Ok
C:\Windows\system32\nl-NL\RpcNs4.dll.mui - Ok
C:\Windows\system32\nl-NL\rrinstaller.exe.mui - Ok
C:\Windows\system32\nl-NL\rtffilt.dll.mui - Ok
C:\Windows\system32\nl-NL\rpcping.exe.mui - Ok
C:\Windows\system32\nl-NL\rpcnsh.dll.mui - Ok
C:\Windows\system32\nl-NL\RunLegacyCPLElevated.exe.mui - Ok
C:\Windows\system32\nl-NL\RSMGRSTR.dll.mui - Ok
C:\Windows\system32\nl-NL\RW001Ext.dll.mui - Ok
C:\Windows\system32\nl-NL\rstrui.exe.mui - Ok
C:\Windows\system32\nl-NL\rtm.dll.mui - Ok
C:\Windows\system32\nl-NL\RW430Ext.dll.mui - Ok
C:\Windows\system32\nl-NL\RW330Ext.dll.mui - Ok
C:\Windows\system32\nl-NL\RW450Ext.dll.mui - Ok
C:\Windows\system32\nl-NL\rundll32.exe.mui - Ok
C:\Windows\system32\nl-NL\rstrtmgr.dll.mui - Ok
C:\Windows\system32\nl-NL\RWia001.dll.mui - Ok
C:\Windows\system32\nl-NL\RWia450.dll.mui - Ok
C:\Windows\system32\nl-NL\SampleRes.dll.mui - Ok
C:\Windows\system32\nl-NL\SaMinDrv.dll.mui - Ok
C:\Windows\system32\nl-NL\RWia430.dll.mui - Ok
C:\Windows\system32\nl-NL\runas.exe.mui - Ok
C:\Windows\system32\nl-NL\Ribbons.scr.mui - Ok
C:\Windows\system32\nl-NL\samsrv.dll.mui - Ok
C:\Windows\system32\nl-NL\scansetting.dll.mui - Ok
C:\Windows\system32\nl-NL\SCardDlg.dll.mui - Ok
C:\Windows\system32\nl-NL\sberes.dll.mui - Ok
C:\Windows\system32\nl-NL\sccls.dll.mui - Ok
C:\Windows\system32\nl-NL\scext.dll.mui - Ok
C:\Windows\system32\nl-NL\scesrv.dll.mui - Ok
C:\Windows\system32\nl-NL\scecli.dll.mui - Ok
C:\Windows\system32\nl-NL\schtasks.exe.mui - Ok
C:\Windows\system32\nl-NL\RWia330.dll.mui - Ok
C:\Windows\system32\nl-NL\schedsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\SCardSvr.dll.mui - Ok
C:\Windows\system32\nl-NL\RpcEpMap.dll.mui - Ok
C:\Windows\system32\nl-NL\route.exe.mui - Ok
C:\Windows\system32\nl-NL\Robocopy.exe.mui - Ok
C:\Windows\system32\nl-NL\scrnsave.scr.mui - Ok
C:\Windows\system32\nl-NL\scrobj.dll.mui - Ok
C:\Windows\system32\nl-NL\scrrun.dll.mui - Ok
C:\Windows\system32\nl-NL\sdbinst.exe.mui - Ok
C:\Windows\system32\nl-NL\sdiagnhost.exe.mui - Ok
C:\Windows\system32\nl-NL\runonce.exe.mui - Ok
C:\Windows\system32\nl-NL\sdclt.exe.mui - Ok
C:\Windows\system32\nl-NL\sdiagschd.dll.mui - Ok
C:\Windows\system32\nl-NL\sdcpl.dll.mui - Ok
C:\Windows\system32\nl-NL\sdrsvc.dll.mui - Ok
>C:\Windows\system32\nl-NL\sdiageng.dll.mui is ZLIB container
C:\Windows\system32\nl-NL\scavengeui.dll.mui - Ok
C:\Windows\system32\nl-NL\sc.exe.mui - Ok
C:\Windows\system32\nl-NL\SearchIndexer.exe.mui - Ok
C:\Windows\system32\nl-NL\sdiageng.dll.mui - container
C:\Windows\system32\nl-NL\secedit.exe.mui - Ok
C:\Windows\system32\nl-NL\seclogon.dll.mui - Ok
C:\Windows\system32\nl-NL\scripto.dll.mui - Ok
C:\Windows\system32\nl-NL\sens.dll.mui - Ok
C:\Windows\system32\nl-NL\sendmail.dll.mui - Ok
C:\Windows\system32\nl-NL\sensrsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\sechost.dll.mui - Ok
C:\Windows\system32\nl-NL\SensorsCpl.dll.mui - Ok
C:\Windows\system32\nl-NL\searchfolder.dll.mui - Ok
C:\Windows\system32\nl-NL\services.exe.mui - Ok
C:\Windows\system32\nl-NL\sessenv.dll.mui - Ok
C:\Windows\system32\nl-NL\scksp.dll.mui - Ok
C:\Windows\system32\nl-NL\services.msc - Ok
C:\Windows\system32\nl-NL\sdautoplay.dll.mui - Ok
C:\Windows\system32\nl-NL\sdchange.exe.mui - Ok
C:\Windows\system32\nl-NL\sdohlp.dll.mui - Ok
C:\Windows\system32\nl-NL\secinit.exe.mui - Ok
C:\Windows\system32\nl-NL\sdengin2.dll.mui - Ok
C:\Windows\system32\nl-NL\serwvdrv.dll.mui - Ok
C:\Windows\system32\nl-NL\sdshext.dll.mui - Ok
C:\Windows\system32\nl-NL\sdiagprv.dll.mui - Ok
C:\Windows\system32\nl-NL\setupetw.dll.mui - Ok
C:\Windows\system32\nl-NL\serialui.dll.mui - Ok
C:\Windows\system32\nl-NL\sethc.exe.mui - Ok
C:\Windows\system32\nl-NL\setx.exe.mui - Ok
C:\Windows\system32\nl-NL\setupapi.dll.mui - Ok
C:\Windows\system32\nl-NL\sfc.exe.mui - Ok
C:\Windows\system32\nl-NL\setupugc.exe.mui - Ok
C:\Windows\system32\nl-NL\shimgvw.dll.mui - Ok
C:\Windows\system32\nl-NL\shgina.dll.mui - Ok
C:\Windows\system32\nl-NL\shrpubw.exe.mui - Ok
>C:\Windows\system32\nl-NL\shellstyle.dll.mui is ZLIB container
C:\Windows\system32\nl-NL\setspn.exe.mui - Ok
C:\Windows\system32\nl-NL\shlwapi.dll.mui - Ok
C:\Windows\system32\nl-NL\shdocvw.dll.mui - Ok
C:\Windows\system32\nl-NL\shell32.dll.mui - Ok
C:\Windows\system32\nl-NL\setupcl.exe.mui - Ok
C:\Windows\system32\nl-NL\setupcln.dll.mui - Ok
C:\Windows\system32\nl-NL\shutdown.exe.mui - Ok
C:\Windows\system32\nl-NL\sharemediacpl.dll.mui - Ok
C:\Windows\system32\nl-NL\slcext.dll.mui - Ok
C:\Windows\system32\nl-NL\slui.exe.mui - Ok
C:\Windows\system32\nl-NL\shsvcs.dll.mui - Ok
C:\Windows\system32\nl-NL\smss.exe.mui - Ok
C:\Windows\system32\nl-NL\sndvolsso.dll.mui - Ok
C:\Windows\system32\nl-NL\SmartcardCredentialProvider.dll.mui - Ok
>C:\Windows\system32\nl-NL\shwebsvc.dll.mui is BINARYRES container
C:\Windows\system32\nl-NL\sigverif.exe.mui - Ok
C:\Windows\system32\nl-NL\softkbd.dll.mui - Ok
C:\Windows\system32\nl-NL\sntsearch.dll.mui - Ok
C:\Windows\system32\nl-NL\SODPPLM2.DLL.mui - Ok
>>C:\Windows\system32\nl-NL\shwebsvc.dll.mui\data001 is JS-HTML container
C:\Windows\system32\nl-NL\SnippingTool.exe.mui - Ok
C:\Windows\system32\nl-NL\snmptrap.exe.mui - Ok
C:\Windows\system32\nl-NL\spcmsg.dll.mui - Ok
>>C:\Windows\system32\nl-NL\shwebsvc.dll.mui\data002 is JS-HTML container
C:\Windows\system32\nl-NL\sort.exe.mui - Ok
C:\Windows\system32\nl-NL\shwebsvc.dll.mui - container
C:\Windows\system32\nl-NL\SmiEngine.dll.mui - Ok
C:\Windows\system32\nl-NL\sppcc.dll.mui - Ok
C:\Windows\system32\nl-NL\spp.dll.mui - Ok
C:\Windows\system32\nl-NL\SMBHelperClass.dll.mui - Ok
C:\Windows\system32\nl-NL\slc.dll.mui - Ok
C:\Windows\system32\nl-NL\sppcomapi.dll.mui - Ok
C:\Windows\system32\nl-NL\sperror.dll.mui - Ok
C:\Windows\system32\nl-NL\sppuinotify.dll.mui - Ok
C:\Windows\system32\nl-NL\SoundRecorder.exe.mui - Ok
C:\Windows\system32\nl-NL\spoolsv.exe.mui - Ok
C:\Windows\system32\nl-NL\spwizres.dll.mui - Ok
C:\Windows\system32\nl-NL\sppc.dll.mui - Ok
C:\Windows\system32\nl-NL\sndvol.exe.mui - Ok
C:\Windows\system32\nl-NL\srchadmin.dll.mui - Ok
C:\Windows\system32\nl-NL\srvsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\srrstr.dll.mui - Ok
C:\Windows\system32\nl-NL\sppsvc.exe.mui - Ok
C:\Windows\system32\nl-NL\srcore.dll.mui - Ok
C:\Windows\system32\nl-NL\ssdpsrv.dll.mui - Ok
C:\Windows\system32\nl-NL\sscore.dll.mui - Ok
C:\Windows\system32\nl-NL\sppnp.dll.mui - Ok
C:\Windows\system32\nl-NL\spwizui.dll.mui - Ok
C:\Windows\system32\nl-NL\sppcommdlg.dll.mui - Ok
C:\Windows\system32\nl-NL\sppcext.dll.mui - Ok
C:\Windows\system32\nl-NL\StorageContextHandler.dll.mui - Ok
C:\Windows\system32\nl-NL\ssText3d.scr.mui - Ok
C:\Windows\system32\nl-NL\sqlsrv32.rll.mui - Ok
C:\Windows\system32\nl-NL\sstpsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\swprv.dll.mui - Ok
C:\Windows\system32\nl-NL\StikyNot.exe.mui - Ok
C:\Windows\system32\nl-NL\stobject.dll.mui - Ok
C:\Windows\system32\nl-NL\sti.dll.mui - Ok
C:\Windows\system32\nl-NL\sti_ci.dll.mui - Ok
C:\Windows\system32\nl-NL\shellstyle.dll.mui - container
C:\Windows\system32\nl-NL\svchost.exe.mui - Ok
C:\Windows\system32\nl-NL\syncui.dll.mui - Ok
C:\Windows\system32\nl-NL\sxs.dll.mui - Ok
C:\Windows\system32\nl-NL\sxstrace.exe.mui - Ok
C:\Windows\system32\nl-NL\SyncCenter.dll.mui - Ok
C:\Windows\system32\nl-NL\SyncInfrastructure.dll.mui - Ok
C:\Windows\system32\nl-NL\sysdm.cpl.mui - Ok
C:\Windows\system32\nl-NL\sysclass.dll.mui - Ok
C:\Windows\system32\nl-NL\sxproxy.dll.mui - Ok
C:\Windows\system32\nl-NL\syncreg.dll.mui - Ok
C:\Windows\system32\nl-NL\subst.exe.mui - Ok
C:\Windows\system32\nl-NL\Storprop.dll.mui - Ok
C:\Windows\system32\nl-NL\SysFxUI.dll.mui - Ok
C:\Windows\system32\nl-NL\systeminfo.exe.mui - Ok
C:\Windows\system32\nl-NL\sysmon.ocx.mui - Ok
C:\Windows\system32\nl-NL\sud.dll.mui - Ok
C:\Windows\system32\nl-NL\sysmain.dll.mui - Ok
C:\Windows\system32\nl-NL\syskey.exe.mui - Ok
C:\Windows\system32\nl-NL\SystemPropertiesComputerName.exe.mui - Ok
C:\Windows\system32\nl-NL\SystemPropertiesHardware.exe.mui - Ok
C:\Windows\system32\nl-NL\SystemPropertiesDataExecutionPrevention.exe.mui - Ok
C:\Windows\system32\nl-NL\SystemPropertiesAdvanced.exe.mui - Ok
C:\Windows\system32\nl-NL\SystemPropertiesPerformance.exe.mui - Ok
C:\Windows\system32\nl-NL\SystemPropertiesProtection.exe.mui - Ok
C:\Windows\system32\nl-NL\TabSvc.dll.mui - Ok
C:\Windows\system32\nl-NL\SystemPropertiesRemote.exe.mui - Ok
C:\Windows\system32\nl-NL\Tabbtn.dll.mui - Ok
C:\Windows\system32\nl-NL\tabcal.exe.mui - Ok
C:\Windows\system32\nl-NL\tapisrv.dll.mui - Ok
C:\Windows\system32\nl-NL\takeown.exe.mui - Ok
C:\Windows\system32\nl-NL\tapi3.dll.mui - Ok
C:\Windows\system32\nl-NL\tapi32.dll.mui - Ok
C:\Windows\system32\nl-NL\TabletPC.cpl.mui - Ok
C:\Windows\system32\nl-NL\TaskEng.exe.mui - Ok
C:\Windows\system32\nl-NL\taskbarcpl.dll.mui - Ok
C:\Windows\system32\nl-NL\taskkill.exe.mui - Ok
C:\Windows\system32\nl-NL\systemcpl.dll.mui - Ok
C:\Windows\system32\nl-NL\tbssvc.dll.mui - Ok
C:\Windows\system32\nl-NL\taskhost.exe.mui - Ok
C:\Windows\system32\nl-NL\tapiui.dll.mui - Ok
C:\Windows\system32\nl-NL\TCPMON.dll.mui - Ok
C:\Windows\system32\nl-NL\taskmgr.exe.mui - Ok
C:\Windows\system32\nl-NL\tcpipcfg.dll.mui - Ok
C:\Windows\system32\nl-NL\taskschd.dll.mui - Ok
C:\Windows\system32\nl-NL\termmgr.dll.mui - Ok
C:\Windows\system32\nl-NL\themeservice.dll.mui - Ok
C:\Windows\system32\nl-NL\tasklist.exe.mui - Ok
C:\Windows\system32\nl-NL\termsrv.dll.mui - Ok
C:\Windows\system32\nl-NL\TCPMonUI.dll.mui - Ok
C:\Windows\system32\nl-NL\thumbcache.dll.mui - Ok
C:\Windows\system32\nl-NL\tdh.dll.mui - Ok
C:\Windows\system32\nl-NL\themeui.dll.mui - Ok
C:\Windows\system32\nl-NL\tpmcompc.dll.mui - Ok
C:\Windows\system32\nl-NL\tcmsetup.exe.mui - Ok
C:\Windows\system32\nl-NL\telephon.cpl.mui - Ok
C:\Windows\system32\nl-NL\TpmInit.exe.mui - Ok
C:\Windows\system32\nl-NL\taskschd.msc - Ok
C:\Windows\system32\nl-NL\themecpl.dll.mui - Ok
C:\Windows\system32\nl-NL\trkwks.dll.mui - Ok
C:\Windows\system32\nl-NL\timedate.cpl.mui - Ok
C:\Windows\system32\nl-NL\tracert.exe.mui - Ok
C:\Windows\system32\nl-NL\tpm.msc - Ok
C:\Windows\system32\nl-NL\TSWorkspace.dll.mui - Ok
C:\Windows\system32\nl-NL\taskcomp.dll.mui - Ok
>C:\Windows\system32\nl-NL\tracerpt.exe.mui is BINARYRES container
C:\Windows\system32\nl-NL\timeout.exe.mui - Ok
C:\Windows\system32\nl-NL\typeperf.exe.mui - Ok
C:\Windows\system32\nl-NL\tquery.dll.mui - Ok
>>C:\Windows\system32\nl-NL\tracerpt.exe.mui\data001 is JS-HTML container
C:\Windows\system32\nl-NL\tzres.dll.mui - Ok
C:\Windows\system32\nl-NL\tsmf.dll.mui - Ok
C:\Windows\system32\nl-NL\tracerpt.exe.mui - container
C:\Windows\system32\nl-NL\tzutil.exe.mui - Ok
C:\Windows\system32\nl-NL\tsgqec.dll.mui - Ok
C:\Windows\system32\nl-NL\TSTheme.exe.mui - Ok
C:\Windows\system32\nl-NL\tvratings.dll.mui - Ok
C:\Windows\system32\nl-NL\ubpm.dll.mui - Ok
C:\Windows\system32\nl-NL\uDWM.dll.mui - Ok
C:\Windows\system32\nl-NL\uicom.dll.mui - Ok
C:\Windows\system32\nl-NL\TsUsbRedirectionGroupPolicyExtension.dll.mui - Ok
C:\Windows\system32\nl-NL\TsUsbGDCoInstaller.dll.mui - Ok
C:\Windows\system32\nl-NL\ucmhc.dll.mui - Ok
C:\Windows\system32\nl-NL\twext.dll.mui - Ok
C:\Windows\system32\nl-NL\UIAnimation.dll.mui - Ok
C:\Windows\system32\nl-NL\umpo.dll.mui - Ok
C:\Windows\system32\nl-NL\UIRibbon.dll.mui - Ok
C:\Windows\system32\nl-NL\ui0detect.exe.mui - Ok
C:\Windows\system32\nl-NL\UIAutomationCore.dll.mui - Ok
C:\Windows\system32\nl-NL\unimdmat.dll.mui - Ok
C:\Windows\system32\nl-NL\umpnpmgr.dll.mui - Ok
C:\Windows\system32\nl-NL\upnp.dll.mui - Ok
C:\Windows\system32\nl-NL\usbceip.dll.mui - Ok
C:\Windows\system32\nl-NL\usbmon.dll.mui - Ok
C:\Windows\system32\nl-NL\unlodctr.exe.mui - Ok
C:\Windows\system32\nl-NL\usbui.dll.mui - Ok
C:\Windows\system32\nl-NL\usercpl.dll.mui - Ok
C:\Windows\system32\nl-NL\usbperf.dll.mui - Ok
C:\Windows\system32\nl-NL\unregmp2.exe.mui - Ok
C:\Windows\system32\nl-NL\urlmon.dll.mui - Ok
C:\Windows\system32\nl-NL\user32.dll.mui - Ok
C:\Windows\system32\nl-NL\ulib.dll.mui - Ok
C:\Windows\system32\nl-NL\usk.rs.mui - Ok
C:\Windows\system32\nl-NL\userinit.exe.mui - Ok
C:\Windows\system32\nl-NL\Utilman.exe.mui - Ok
C:\Windows\system32\nl-NL\utildll.dll.mui - Ok
C:\Windows\system32\nl-NL\vaultsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\UserAccountControlSettings.dll.mui - Ok
C:\Windows\system32\nl-NL\uxtheme.dll.mui - Ok
C:\Windows\system32\nl-NL\Vault.dll.mui - Ok
C:\Windows\system32\nl-NL\unimdm.tsp.mui - Ok
C:\Windows\system32\nl-NL\VaultSysUi.exe.mui - Ok
C:\Windows\system32\nl-NL\VaultCredProvider.dll.mui - Ok
C:\Windows\system32\nl-NL\vdsbas.dll.mui - Ok
C:\Windows\system32\nl-NL\upnphost.dll.mui - Ok
C:\Windows\system32\nl-NL\vdsdyn.dll.mui - Ok
C:\Windows\system32\nl-NL\vbscript.dll.mui - Ok
C:\Windows\system32\nl-NL\vdsutil.dll.mui - Ok
C:\Windows\system32\nl-NL\vfwwdm32.dll.mui - Ok
C:\Windows\system32\nl-NL\VAN.dll.mui - Ok
C:\Windows\system32\nl-NL\VaultCmd.exe.mui - Ok
C:\Windows\system32\nl-NL\w32time.dll.mui - Ok
C:\Windows\system32\nl-NL\w32tm.exe.mui - Ok
C:\Windows\system32\nl-NL\vsstrace.dll.mui - Ok
C:\Windows\system32\nl-NL\UIHub.dll.mui - Ok
C:\Windows\system32\nl-NL\WABSyncProvider.dll.mui - Ok
C:\Windows\system32\nl-NL\waitfor.exe.mui - Ok
C:\Windows\system32\nl-NL\wbiosrvc.dll.mui - Ok
C:\Windows\system32\nl-NL\wbengine.exe.mui - Ok
C:\Windows\system32\nl-NL\wcncsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\WcsPlugInService.dll.mui - Ok
C:\Windows\system32\nl-NL\WcnNetsh.dll.mui - Ok
C:\Windows\system32\nl-NL\vdsvd.dll.mui - Ok
C:\Windows\system32\nl-NL\wdi.dll.mui - Ok
C:\Windows\system32\nl-NL\wdfres.dll.mui - Ok
C:\Windows\system32\nl-NL\VSSVC.exe.mui - Ok
C:\Windows\system32\nl-NL\verifier.exe.mui - Ok
C:\Windows\system32\nl-NL\wavemsp.dll.mui - Ok
C:\Windows\system32\nl-NL\vssadmin.exe.mui - Ok
C:\Windows\system32\nl-NL\webclnt.dll.mui - Ok
C:\Windows\system32\nl-NL\vds.exe.mui - Ok
C:\Windows\system32\nl-NL\wdmaud.drv.mui - Ok
C:\Windows\system32\nl-NL\wecsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\wer.dll.mui - Ok
>C:\Windows\system32\nl-NL\wdc.dll.mui is BINARYRES container
C:\Windows\system32\nl-NL\wbadmin.exe.mui - Ok
C:\Windows\system32\nl-NL\wcnwiz.dll.mui - Ok
C:\Windows\system32\nl-NL\wercplsupport.dll.mui - Ok
>>C:\Windows\system32\nl-NL\wdc.dll.mui\data001 is JS-HTML container
C:\Windows\system32\nl-NL\webcheck.dll.mui - Ok
C:\Windows\system32\nl-NL\wersvc.dll.mui - Ok
C:\Windows\system32\nl-NL\webio.dll.mui - Ok
>C:\Windows\system32\nl-NL\werconcpl.dll.mui is ZLIB container
C:\Windows\system32\nl-NL\WEB.rs.mui - Ok
>>C:\Windows\system32\nl-NL\wdc.dll.mui\data002 is JS-HTML container
C:\Windows\system32\nl-NL\werui.dll.mui - Ok
C:\Windows\system32\nl-NL\wevtapi.dll.mui - Ok
C:\Windows\system32\nl-NL\wdc.dll.mui - container
C:\Windows\system32\nl-NL\wecutil.exe.mui - Ok
C:\Windows\system32\nl-NL\WerFaultSecure.exe.mui - Ok
C:\Windows\system32\nl-NL\webservices.dll.mui - Ok
C:\Windows\system32\nl-NL\werconcpl.dll.mui - container
C:\Windows\system32\nl-NL\wevtsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\userenv.dll.mui - Ok
C:\Windows\system32\nl-NL\wevtfwd.dll.mui - Ok
C:\Windows\system32\nl-NL\whealogr.dll.mui - Ok
C:\Windows\system32\nl-NL\wevtutil.exe.mui - Ok
C:\Windows\system32\nl-NL\WF.msc - Ok
C:\Windows\system32\nl-NL\WerFault.exe.mui - Ok
C:\Windows\system32\nl-NL\WFSR.dll.mui - Ok
C:\Windows\system32\nl-NL\whoami.exe.mui - Ok
C:\Windows\system32\nl-NL\wiafbdrv.dll.mui - Ok
C:\Windows\system32\nl-NL\wiascanprofiles.dll.mui - Ok
C:\Windows\system32\nl-NL\wiadss.dll.mui - Ok
C:\Windows\system32\nl-NL\wextract.exe.mui - Ok
C:\Windows\system32\nl-NL\wiaservc.dll.mui - Ok
C:\Windows\system32\nl-NL\wiadefui.dll.mui - Ok
C:\Windows\system32\nl-NL\wiaaut.dll.mui - Ok
C:\Windows\system32\nl-NL\wiashext.dll.mui - Ok
C:\Windows\system32\nl-NL\where.exe.mui - Ok
C:\Windows\system32\nl-NL\wiavideo.dll.mui - Ok
C:\Windows\system32\nl-NL\whhelper.dll.mui - Ok
C:\Windows\system32\nl-NL\wiaacmgr.exe.mui - Ok
C:\Windows\system32\nl-NL\wincredprovider.dll.mui - Ok
C:\Windows\system32\nl-NL\windowsanytimeupgradeResults.exe.mui - Ok
C:\Windows\system32\nl-NL\windowsanytimeupgrade.exe.mui - Ok
C:\Windows\system32\nl-NL\winbio.dll.mui - Ok
C:\Windows\system32\nl-NL\wimgapi.dll.mui - Ok
C:\Windows\system32\nl-NL\WfHC.dll.mui - Ok
C:\Windows\system32\nl-NL\winhttp.dll.mui - Ok
C:\Windows\system32\nl-NL\winethc.dll.mui - Ok
C:\Windows\system32\nl-NL\winmm.dll.mui - Ok
C:\Windows\system32\nl-NL\winlogon.exe.mui - Ok
C:\Windows\system32\nl-NL\windowsanytimeupgradeui.exe.mui - Ok
C:\Windows\system32\nl-NL\winresume.exe.mui - Ok
C:\Windows\system32\nl-NL\Winrs.exe.mui - Ok
C:\Windows\system32\nl-NL\WinSATAPI.dll.mui - Ok
C:\Windows\system32\nl-NL\winsockhc.dll.mui - Ok
C:\Windows\system32\nl-NL\winload.efi.mui - Ok
C:\Windows\system32\nl-NL\winload.exe.mui - Ok
C:\Windows\system32\nl-NL\win32spl.dll.mui - Ok
C:\Windows\system32\nl-NL\WinSCard.dll.mui - Ok
C:\Windows\system32\nl-NL\wininet.dll.mui - Ok
C:\Windows\system32\nl-NL\winsrv.dll.mui - Ok
C:\Windows\system32\nl-NL\wininit.exe.mui - Ok
C:\Windows\system32\nl-NL\winresume.efi.mui - Ok
C:\Windows\system32\nl-NL\win32k.sys.mui - Ok
C:\Windows\system32\nl-NL\wkssvc.dll.mui - Ok
C:\Windows\system32\nl-NL\winver.exe.mui - Ok
C:\Windows\system32\nl-NL\wisptis.exe.mui - Ok
C:\Windows\system32\nl-NL\winspool.drv.mui - Ok
C:\Windows\system32\nl-NL\wksprt.exe.mui - Ok
C:\Windows\system32\nl-NL\WinSyncProviders.rll.mui - Ok
C:\Windows\system32\nl-NL\WinSyncMetastore.rll.mui - Ok
C:\Windows\system32\nl-NL\WLanConn.dll.mui - Ok
C:\Windows\system32\nl-NL\wlanext.exe.mui - Ok
C:\Windows\system32\nl-NL\wlanmm.dll.mui - Ok
C:\Windows\system32\nl-NL\WinSync.rll.mui - Ok
C:\Windows\system32\nl-NL\wlanutil.dll.mui - Ok
C:\Windows\system32\nl-NL\wlgpclnt.dll.mui - Ok
C:\Windows\system32\nl-NL\wlancfg.dll.mui - Ok
C:\Windows\system32\nl-NL\wldap32.dll.mui - Ok
C:\Windows\system32\nl-NL\wlangpui.dll.mui - Ok
C:\Windows\system32\nl-NL\WLanHC.dll.mui - Ok
C:\Windows\system32\nl-NL\WinSAT.exe.mui - Ok
C:\Windows\system32\nl-NL\wlanapi.dll.mui - Ok
C:\Windows\system32\nl-NL\wlansvc.dll.mui - Ok
C:\Windows\system32\nl-NL\wmerror.dll.mui - Ok
C:\Windows\system32\nl-NL\wlanpref.dll.mui - Ok
C:\Windows\system32\nl-NL\WMPhoto.dll.mui - Ok
C:\Windows\system32\nl-NL\wlanui.dll.mui - Ok
C:\Windows\system32\nl-NL\wlandlg.dll.mui - Ok
C:\Windows\system32\nl-NL\wpcsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\Wpc.dll.mui - Ok
C:\Windows\system32\nl-NL\wpcumi.dll.mui - Ok
C:\Windows\system32\nl-NL\WpdBusEnum.dll.mui - Ok
C:\Windows\system32\nl-NL\wmiprop.dll.mui - Ok
C:\Windows\system32\nl-NL\wmidx.dll.mui - Ok
C:\Windows\system32\nl-NL\wpccpl.dll.mui - Ok
C:\Windows\system32\nl-NL\wmpdui.dll.mui - Ok
C:\Windows\system32\nl-NL\WPDShextAutoplay.exe.mui - Ok
C:\Windows\system32\nl-NL\wpcao.dll.mui - Ok
C:\Windows\system32\nl-NL\wmpshell.dll.mui - Ok
C:\Windows\system32\nl-NL\wpcmig.dll.mui - Ok
C:\Windows\system32\nl-NL\wpdshext.dll.mui - Ok
C:\Windows\system32\nl-NL\wpnpinst.exe.mui - Ok
C:\Windows\system32\nl-NL\wsdapi.dll.mui - Ok
C:\Windows\system32\nl-NL\ws2_32.dll.mui - Ok
C:\Windows\system32\nl-NL\wpd_ci.dll.mui - Ok
C:\Windows\system32\nl-NL\WSDMon.dll.mui - Ok
C:\Windows\system32\nl-NL\WmiMgmt.msc - Ok
C:\Windows\system32\nl-NL\wpdwcn.dll.mui - Ok
C:\Windows\system32\nl-NL\WSDScDrv.dll.mui - Ok
C:\Windows\system32\nl-NL\wsepno.dll.mui - Ok
C:\Windows\system32\nl-NL\wmploc.DLL.mui - Ok
C:\Windows\system32\nl-NL\wscui.cpl.mui - Ok
C:\Windows\system32\nl-NL\wship6.dll.mui - Ok
C:\Windows\system32\nl-NL\wshqos.dll.mui - Ok
C:\Windows\system32\nl-NL\wshrm.dll.mui - Ok
C:\Windows\system32\nl-NL\wshom.ocx.mui - Ok
C:\Windows\system32\nl-NL\wshext.dll.mui - Ok
C:\Windows\system32\nl-NL\WPDSp.dll.mui - Ok
C:\Windows\system32\nl-NL\wshtcpip.dll.mui - Ok
C:\Windows\system32\nl-NL\WUDFHost.exe.mui - Ok
C:\Windows\system32\nl-NL\wscript.exe.mui - Ok
C:\Windows\system32\nl-NL\wsock32.dll.mui - Ok
C:\Windows\system32\nl-NL\wudfsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\wucltux.dll.mui - Ok
C:\Windows\system32\nl-NL\wscsvc.dll.mui - Ok
C:\Windows\system32\nl-NL\wsqmcons.exe.mui - Ok
C:\Windows\system32\nl-NL\WsmSvc.dll.mui - Ok
C:\Windows\system32\nl-NL\wuaueng.dll.mui - Ok
C:\Windows\system32\nl-NL\wvc.dll.mui - Ok
C:\Windows\system32\nl-NL\wuapi.dll.mui - Ok
C:\Windows\system32\nl-NL\WWanMM.dll.mui - Ok
C:\Windows\system32\nl-NL\wshelper.dll.mui - Ok
C:\Windows\system32\nl-NL\Wwanpref.dll.mui - Ok
C:\Windows\system32\nl-NL\wwanadvui.dll.mui - Ok
C:\Windows\system32\nl-NL\XInput9_1_0.dll.mui - Ok
C:\Windows\system32\nl-NL\WWanHC.dll.mui - Ok
C:\Windows\system32\nl-NL\wwancfg.dll.mui - Ok
C:\Windows\system32\nl-NL\xlog.exe.mui - Ok
C:\Windows\system32\nl-NL\wwanconn.dll.mui - Ok
C:\Windows\system32\nl-NL\wudfplatform.dll.mui - Ok
C:\Windows\system32\nl-NL\xmlfilter.dll.mui - Ok
C:\Windows\system32\nl-NL\wusa.exe.mui - Ok
C:\Windows\system32\nl-NL\xpsfilt.dll.mui - Ok
C:\Windows\system32\nl-NL\xpsshhdr.dll.mui - Ok
C:\Windows\system32\nl-NL\xrWCbgnd.dll.mui - Ok
C:\Windows\system32\nl-NL\xrWCtmg2.dll.mui - Ok
C:\Windows\system32\nl-NL\wzcdlg.dll.mui - Ok
C:\Windows\system32\nl-NL\xrWPcpst.dll.mui - Ok
C:\Windows\system32\nl-NL\xrWPcoin.dll.mui - Ok
C:\Windows\system32\nl-NL\xrWPcpl.dll.mui - Ok
C:\Windows\system32\nl-NL\xwizard.exe.mui - Ok
C:\Windows\system32\nl-NL\xwtpw32.dll.mui - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\Enterprise\license.rtf - Ok
C:\Windows\system32\nl-NL\xwtpdui.dll.mui - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\EnterpriseN\license.rtf - Ok
C:\Windows\system32\nl-NL\xwizards.dll.mui - Ok
C:\Windows\system32\nl-NL\xrWPusd.dll.mui - Ok
C:\Windows\system32\nl-NL\xpsrchvw.exe.mui - Ok
C:\Windows\system32\nl-NL\zipfldr.dll.mui - Ok
C:\Windows\system32\nl-NL\wwansvc.dll.mui - Ok
C:\Windows\system32\nl-NL\WsmRes.dll.mui - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\HomeBasicE\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\HomeBasicN\license.rtf - Ok
C:\Windows\system32\nl-NL\wsecedit.dll.mui - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\HomePremiumE\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\ProfessionalN\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\EnterpriseE\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\HomePremiumN\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\ProfessionalE\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\StarterE\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\HomeBasic\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\UltimateE\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\StarterN\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\EnterpriseE\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\UltimateN\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\Starter\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\EnterpriseN\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\Ultimate\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\HomeBasicN\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\HomePremiumE\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\Enterprise\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\Professional\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\HomeBasicE\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\ProfessionalE\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\HomeBasic\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\StarterE\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\HomePremium\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\OEM\HomePremium\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\Professional\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\eval\EnterpriseE\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\UltimateE\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\eval\EnterpriseN\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\StarterN\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\ProfessionalN\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\Ultimate\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\eval\Enterprise\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\eval\HomeBasicN\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\HomePremiumN\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\eval\HomeBasic\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\eval\HomePremiumN\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\eval\HomePremium\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\eval\HomeBasicE\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\eval\Professional\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\Starter\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\_Default\UltimateN\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\eval\ProfessionalE\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\eval\ProfessionalN\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\eval\HomePremiumE\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\eval\StarterN\license.rtf - Ok
C:\Windows\system32\oobe\audit.exe - Ok
C:\Windows\system32\nl-NL\Licenses\eval\Starter\license.rtf - Ok
C:\Windows\system32\oobe\background.bmp - Ok
C:\Windows\system32\oobe\cmisetup.dll - Ok
C:\Windows\system32\nl-NL\Licenses\eval\UltimateE\license.rtf - Ok
C:\Windows\system32\nl-NL\Licenses\eval\StarterE\license.rtf - Ok
C:\Windows\system32\oobe\diagER.dll - Ok
C:\Windows\system32\oobe\DU.dll - Ok
C:\Windows\system32\oobe\oobeldr.exe - Ok
C:\Windows\system32\nl\AuthFWWizFwk.Resources.dll - Ok
>C:\Windows\system32\oobe\setup.cfg is JS-HTML container
C:\Windows\system32\oobe\diagnostic.dll - Ok
>C:\Windows\system32\oobe\msoobeui.dll is ZLIB container
C:\Windows\system32\oobe\pnpibs.dll - Ok
C:\Windows\system32\oobe\setup.cfg - container
C:\Windows\system32\nl\Narrator.resources.dll - Ok
C:\Windows\system32\oobe\FirstUXRes.WIM - Ok
C:\Windows\system32\nl-NL\Licenses\eval\UltimateN\license.rtf - Ok
C:\Windows\system32\oobe\msoobeui.dll - container
C:\Windows\system32\oobe\msoobe.exe - Ok
C:\Windows\system32\oobe\setupsqm.exe - Ok
C:\Windows\system32\oobe\spprgrss.dll - Ok
C:\Windows\system32\oobe\wdsutil.dll - Ok
C:\Windows\system32\oobe\Info\oobe.xml - Ok
C:\Windows\system32\nl-NL\Licenses\eval\Ultimate\license.rtf - Ok
C:\Windows\system32\oobe\Info\Default\1031\OOBE.xml - Ok
C:\Windows\system32\oobe\windeploy.exe - Ok
C:\Windows\system32\oobe\Setup.exe - Ok
C:\Windows\system32\oobe\win32ui.dll - Ok
C:\Windows\system32\oobe\Info\Default\1033\OOBE.xml - Ok
>C:\Windows\system32\oobe\W32UIRes.dll is BINARYRES container
C:\Windows\system32\oobe\Info\Default\1036\OOBE.xml - Ok
C:\Windows\system32\oobe\W32UIRes.dll - container
C:\Windows\system32\oobe\winsetup.dll - Ok
C:\Windows\system32\oobe\Info\Default\1043\OOBE.xml - Ok
C:\Windows\system32\oobe\unbcl.dll - Ok
C:\Windows\system32\oobe\nl-NL\audit.exe.mui - Ok
C:\Windows\system32\oobe\nl-NL\oobeldr.exe.mui - Ok
C:\Windows\system32\oobe\nl-NL\msoobeui.dll.mui - Ok
C:\Windows\system32\oobe\nl-NL\OOBE_HELP_Change_Computer_Name.rtf - Ok
C:\Windows\system32\oobe\WinLGDep.dll - Ok
C:\Windows\system32\oobe\nl-NL\HELP_What_is_Activation.rtf - Ok
C:\Windows\system32\oobe\nl-NL\pnpibs.dll.mui - Ok
C:\Windows\system32\oobe\nl-NL\setup.exe.mui - Ok
C:\Windows\system32\oobe\nl-NL\OOBE_HELP_What_is_HomeGroup.rtf - Ok
C:\Windows\system32\oobe\nl-NL\windeploy.exe.mui - Ok
C:\Windows\system32\oobe\nl-NL\WinLGDep.dll.mui - Ok
C:\Windows\system32\oobe\nl-NL\OOBE_HELP_Opt_in_Details.rtf - Ok
>C:\Windows\system32\oobe\nl-NL\W32UIRes.dll.mui is BINARYRES container
C:\Windows\system32\oobe\nl-NL\OOBE_HELP_What_is_User_Account.rtf - Ok
C:\Windows\system32\oobe\nl-NL\W32UIRes.dll.mui - container
C:\Windows\system32\oobe\nl-NL\winsetup.dll.mui - Ok
C:\Windows\system32\pl-PL\cdosys.dll.mui - Ok
C:\Windows\system32\pl-PL\comctl32.dll.mui - Ok
C:\Windows\system32\pl-PL\comdlg32.dll.mui - Ok
C:\Windows\system32\pl-PL\DWrite.dll.mui - Ok
C:\Windows\system32\oobe\Info\Default\1036\eula.rtf - Ok
C:\Windows\system32\oobe\Info\Default\1043\eula.rtf - Ok
C:\Windows\system32\pl-PL\fms.dll.mui - Ok
C:\Windows\system32\oobe\Info\Default\1033\eula.rtf - Ok
C:\Windows\system32\pl-PL\mlang.dll.mui - Ok
C:\Windows\system32\pl-PL\msimsg.dll.mui - Ok
C:\Windows\system32\pl-PL\FntCache.dll.mui - Ok
C:\Windows\system32\pl-PL\WMPhoto.dll.mui - Ok
C:\Windows\system32\pl-PL\d2d1.dll.mui - Ok
C:\Windows\system32\pt-BR\cdosys.dll.mui - Ok
C:\Windows\system32\pl-PL\msprivs.dll.mui - Ok
C:\Windows\system32\pt-BR\comdlg32.dll.mui - Ok
C:\Windows\system32\pt-BR\comctl32.dll.mui - Ok
C:\Windows\system32\oobe\nl-NL\vofflps.rtf - Ok
C:\Windows\system32\pt-BR\DWrite.dll.mui - Ok
C:\Windows\system32\pt-BR\FntCache.dll.mui - Ok
C:\Windows\system32\pt-BR\fms.dll.mui - Ok
C:\Windows\system32\pt-BR\msimsg.dll.mui - Ok
C:\Windows\system32\pt-BR\mlang.dll.mui - Ok
C:\Windows\system32\pt-BR\WMPhoto.dll.mui - Ok
C:\Windows\system32\pt-BR\msprivs.dll.mui - Ok
C:\Windows\system32\pt-PT\cdosys.dll.mui - Ok
C:\Windows\system32\oobe\Info\Default\1031\eula.rtf - Ok
C:\Windows\system32\pt-PT\DWrite.dll.mui - Ok
C:\Windows\system32\pt-PT\FntCache.dll.mui - Ok
C:\Windows\system32\oobe\W32UIImg.dll - Ok
C:\Windows\system32\pt-PT\msprivs.dll.mui - Ok
C:\Windows\system32\ras\cis.scp - Ok
C:\Windows\system32\pt-PT\mlang.dll.mui - Ok
C:\Windows\system32\pt-PT\WMPhoto.dll.mui - Ok
C:\Windows\system32\nl\AuthFWSnapIn.Resources.dll - Ok
C:\Windows\system32\pt-PT\d2d1.dll.mui - Ok
C:\Windows\system32\restore\MachineGuid.txt - Ok
C:\Windows\system32\ras\switch.inf - Ok
C:\Windows\system32\pt-PT\fms.dll.mui - Ok
C:\Windows\system32\ras\pppmenu.scp - Ok
C:\Windows\system32\ro-RO\comctl32.dll.mui - Ok
C:\Windows\system32\pt-PT\comctl32.dll.mui - Ok
C:\Windows\system32\ras\pad.inf - Ok
C:\Windows\system32\pt-BR\d2d1.dll.mui - Ok
C:\Windows\system32\oobe\nl-NL\privacy.rtf - Ok
C:\Windows\system32\ru-RU\comdlg32.dll.mui - Ok
C:\Windows\system32\ro-RO\msimsg.dll.mui - Ok
C:\Windows\system32\ro-RO\comdlg32.dll.mui - Ok
C:\Windows\system32\ru-RU\cdosys.dll.mui - Ok
C:\Windows\system32\ro-RO\mlang.dll.mui - Ok
C:\Windows\system32\ru-RU\comctl32.dll.mui - Ok
C:\Windows\system32\ru-RU\DWrite.dll.mui - Ok
C:\Windows\system32\ru-RU\msprivs.dll.mui - Ok
C:\Windows\system32\ru-RU\WMPhoto.dll.mui - Ok
C:\Windows\system32\ru-RU\FntCache.dll.mui - Ok
C:\Windows\system32\ru-RU\mlang.dll.mui - Ok
C:\Windows\system32\ru-RU\d2d1.dll.mui - Ok
C:\Windows\system32\sk-SK\comdlg32.dll.mui - Ok
C:\Windows\system32\sk-SK\comctl32.dll.mui - Ok
C:\Windows\system32\ru-RU\msimsg.dll.mui - Ok
C:\Windows\system32\pt-PT\comdlg32.dll.mui - Ok
C:\Windows\system32\ro-RO\fms.dll.mui - Ok
C:\Windows\system32\sl-SI\comctl32.dll.mui - Ok
C:\Windows\system32\pt-PT\msimsg.dll.mui - Ok
C:\Windows\system32\slmgr\0413\slmgr.ini - Ok
C:\Windows\system32\spool\PRINTERS\FP00000.SHD - Ok
C:\Windows\system32\spool\PRINTERS\FP00001.SHD - Ok
C:\Windows\system32\ru-RU\fms.dll.mui - Ok
C:\Windows\system32\spool\PRINTERS\FP00002.SHD - Ok
C:\Windows\system32\spool\PRINTERS\FP00003.SHD - Ok
C:\Windows\system32\spool\PRINTERS\FP00004.SHD - Ok
C:\Windows\system32\spool\PRINTERS\FP00001.SPL - Ok
C:\Windows\system32\sl-SI\mlang.dll.mui - Ok
C:\Windows\system32\sl-SI\msimsg.dll.mui - Ok
C:\Windows\system32\sl-SI\comdlg32.dll.mui - Ok
C:\Windows\system32\spool\PRINTERS\FP00005.SHD - Ok
C:\Windows\system32\spool\PRINTERS\FP00007.SHD - Ok
C:\Windows\system32\sk-SK\msimsg.dll.mui - Ok
C:\Windows\system32\spool\PRINTERS\FP00008.SHD - Ok
C:\Windows\system32\sk-SK\mlang.dll.mui - Ok
C:\Windows\system32\spool\drivers\color\AdobeRGB1998.icc - Ok
C:\Windows\system32\spool\PRINTERS\FP00000.SPL - Ok
C:\Windows\system32\spool\PRINTERS\FP00002.SPL - Ok
C:\Windows\system32\spool\drivers\color\AppleRGB.icc - Ok
C:\Windows\system32\spool\drivers\color\BlackWhite.icc - Ok
C:\Windows\system32\spool\drivers\color\CIERGB.icc - Ok
C:\Windows\system32\spool\drivers\color\ColorMatchRGB.icc - Ok
C:\Windows\system32\sk-SK\fms.dll.mui - Ok
C:\Windows\system32\spool\drivers\color\D50.camp - Ok
C:\Windows\system32\spool\drivers\color\D65.camp - Ok
C:\Windows\system32\spool\drivers\color\DCDM_X'Y'Z'.icc - Ok
C:\Windows\system32\spool\drivers\color\DCI_P3.icc - Ok
C:\Windows\system32\sl-SI\fms.dll.mui - Ok
C:\Windows\system32\spool\PRINTERS\FP00008.SPL - Ok
C:\Windows\system32\spool\drivers\color\Graphics.gmmp - Ok
C:\Windows\system32\spool\PRINTERS\FP00004.SPL - Ok
C:\Windows\system32\spool\drivers\color\CNBJPR18.ICM - Ok
C:\Windows\system32\spool\drivers\color\CoatedGRACoL2006.icc - Ok
C:\Windows\system32\spool\PRINTERS\FP00003.SPL - Ok
C:\Windows\system32\spool\drivers\color\MediaSim.gmmp - Ok
C:\Windows\system32\spool\drivers\color\PAL_SECAM.icc - Ok
C:\Windows\system32\spool\drivers\color\Photo.gmmp - Ok
C:\Windows\system32\spool\drivers\color\Proofing.gmmp - Ok
C:\Windows\system32\spool\drivers\color\ProPhoto.icm - Ok
C:\Windows\system32\spool\drivers\color\EuroscaleCoated.icc - Ok
C:\Windows\system32\spool\drivers\color\JapanColor2003WebCoated.icc - Ok
C:\Windows\system32\spool\drivers\color\SMPTE-C.icc - Ok
C:\Windows\system32\spool\drivers\color\EuroscaleUncoated.icc - Ok
C:\Windows\system32\spool\drivers\color\sRGB Color Space Profile.icm - Ok
C:\Windows\system32\spool\drivers\color\JapanColor2001Uncoated.icc - Ok
C:\Windows\system32\spool\drivers\color\RSWOP.icm - Ok
C:\Windows\system32\spool\drivers\color\CoatedFOGRA39.icc - Ok
C:\Windows\system32\spool\drivers\color\USSheetfedCoated.icc - Ok
C:\Windows\system32\spool\drivers\color\VideoHD.icc - Ok
C:\Windows\system32\spool\drivers\color\VideoHD16-235.icc - Ok
C:\Windows\system32\spool\drivers\color\USWebUncoated.icc - Ok
C:\Windows\system32\spool\drivers\color\VideoNTSC.icc - Ok
C:\Windows\system32\spool\drivers\color\VideoNTSC16-235.icc - Ok
C:\Windows\system32\spool\drivers\color\VideoPAL.icc - Ok
C:\Windows\system32\spool\drivers\color\VideoPAL16-235.icc - Ok
C:\Windows\system32\spool\drivers\color\USSheetfedUncoated.icc - Ok
C:\Windows\system32\spool\drivers\color\USWebCoatedSWOP.icc - Ok
C:\Windows\system32\spool\drivers\color\UncoatedFOGRA29.icc - Ok
C:\Windows\system32\spool\drivers\color\WideGamutRGB.icc - Ok
C:\Windows\system32\spool\drivers\color\wsRGB.cdmp - Ok
C:\Windows\system32\spool\drivers\color\wscRGB.cdmp - Ok
C:\Windows\system32\spool\drivers\x64\SendToOneNote-PipelineConfig.xml - Ok
C:\Windows\system32\spool\drivers\x64\SendToOneNote.gpd - Ok
C:\Windows\system32\spool\drivers\x64\SendToOneNote.ini - Ok
C:\Windows\system32\spool\drivers\color\WebCoatedSWOP2006Grade3.icc - Ok
C:\Windows\system32\spool\drivers\color\WebCoatedFOGRA28.icc - Ok
C:\Windows\system32\spool\drivers\x64\SendToOneNoteFilter.gpd - Ok
C:\Windows\system32\spool\drivers\color\USNewsprintSNAP2007.icc - Ok
C:\Windows\system32\spool\drivers\x64\SendToOneNoteNames.gpd - Ok
C:\Windows\system32\spool\drivers\x64\stddtype.gdl - Ok
C:\Windows\system32\spool\drivers\x64\stdschem.gdl - Ok
C:\Windows\system32\spool\drivers\x64\stdschmx.gdl - Ok
C:\Windows\system32\spool\drivers\color\CoatedFOGRA27.icc - Ok
C:\Windows\system32\spool\drivers\x64\unidrv.hlp - Ok
C:\Windows\system32\spool\drivers\x64\stdnames.gpd - Ok
C:\Windows\system32\spool\drivers\x64\SendToOneNoteUI.dll - Ok
C:\Windows\system32\spool\drivers\x64\SendToOneNoteFilter.dll - Ok
C:\Windows\system32\spool\drivers\x64\3\ADGELP.INI - Ok
C:\Windows\system32\spool\drivers\x64\unidrv.dll - Ok
C:\Windows\system32\spool\drivers\x64\unidrvui.dll - Ok
C:\Windows\system32\spool\drivers\x64\3\ADPDF9.BPD - Ok
C:\Windows\system32\spool\PRINTERS\FP00007.SPL - Ok
C:\Windows\system32\spool\drivers\x64\3\AdobePDFUI.dll - Ok
C:\Windows\system32\spool\drivers\x64\3\AdobePdf.dll - Ok
C:\Windows\system32\spool\drivers\x64\3\CNB3000.BUD - Ok
C:\Windows\system32\spool\drivers\x64\3\ADREGP.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\ADPDF9.PPD - Ok
>C:\Windows\system32\spool\drivers\x64\3\CNB3000.DLL - packed by PESTUB
C:\Windows\system32\spool\drivers\x64\3\CNB3000.DLL - Ok
C:\Windows\system32\spool\drivers\color\JapanColor2002Newspaper.icc - Ok
C:\Windows\system32\spool\drivers\x64\3\CNBJ0760.TBL - Ok
C:\Windows\system32\spool\drivers\x64\3\CNBJ2.INI - Ok
C:\Windows\system32\spool\drivers\x64\mxdwdrv.dll - Ok
C:\Windows\system32\spool\drivers\x64\3\CNB3000.GPD - Ok
C:\Windows\system32\spool\drivers\x64\3\ADUIGP.DLL - Ok
C:\Windows\system32\spool\drivers\color\WebCoatedSWOP2006Grade5.icc - Ok
>C:\Windows\system32\spool\drivers\x64\3\CNBO59.DLL - packed by PESTUB
C:\Windows\system32\spool\drivers\x64\3\CNBO59.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\CNBJGRC2.GPD - Ok
C:\Windows\system32\spool\drivers\x64\3\CNBVM.GPD - Ok
C:\Windows\system32\spool\drivers\color\JapanColor2001Coated.icc - Ok
>C:\Windows\system32\spool\drivers\x64\3\CNBJDRV2.DLL - packed by PESTUB
C:\Windows\system32\spool\drivers\color\JapanWebCoated.icc - Ok
C:\Windows\system32\spool\drivers\x64\3\CNBJDRV2.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\HP3gvsf5.cfg - Ok
C:\Windows\system32\spool\drivers\x64\XpsSvcs.dll - Ok
C:\Windows\system32\spool\drivers\x64\3\HPBMIAPI.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\FXSDRV.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\HPBOID.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\HPBOIDPS.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\FXSWZRD.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\HPBMINI.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\HPEACLHN.HPI - Ok
C:\Windows\system32\spool\drivers\x64\3\FXSUI.DLL - Ok
>C:\Windows\system32\spool\drivers\x64\3\CNBJUI2.DLL - packed by PESTUB
C:\Windows\system32\spool\drivers\x64\3\HPf78kes.cfg - Ok
C:\Windows\system32\spool\drivers\x64\3\CNBPGR05.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\HPBPROPS.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\HPMCPCP6.CFG - Ok
C:\Windows\system32\spool\drivers\x64\3\hpmcpcp6.BUD - Ok
C:\Windows\system32\spool\drivers\x64\3\HPZ6CWN7.INI - Ok
C:\Windows\system32\spool\drivers\x64\3\hpmcpcp6.xml - Ok
C:\Windows\system32\spool\drivers\x64\3\HPZ6MWN7.GPD - Ok
C:\Windows\system32\spool\drivers\x64\3\FXSTIFF.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\HPZIDR12.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\HPBPRO.DLL - Ok
>C:\Windows\system32\spool\drivers\x64\3\hpmcpcp6.gpd is MAIL container
C:\Windows\system32\spool\drivers\x64\3\hpmcpcp6.gpd - mail
C:\Windows\system32\spool\drivers\x64\3\HPZIPM12.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\HPZINW12.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\HPZIPR12.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\HPZIPT12.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\HPZSCWN7.DTD - Ok
C:\Windows\system32\spool\drivers\x64\3\HPZISN12.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\HPZ6RWN7.DLL - Ok
C:\Windows\system32\spool\drivers\x64\unires.dll - Ok
C:\Windows\system32\spool\drivers\x64\3\HPZEVWN7.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\mxdwdrv.dll - Ok
C:\Windows\system32\spool\drivers\x64\3\FXSAPI.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\mxdwdui.BUD - Ok
C:\Windows\system32\spool\drivers\x64\3\mxdwdui.ini - Ok
C:\Windows\system32\spool\drivers\x64\3\mxdwdui.gpd - Ok
C:\Windows\system32\spool\drivers\x64\3\HPZUIWN7.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\mxdwdui.dll - Ok
C:\Windows\system32\spool\drivers\x64\3\HPZSMWN7.GPD - Ok
C:\Windows\system32\spool\drivers\x64\3\PCLXL.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\P6FONT.GPD - Ok
C:\Windows\system32\spool\drivers\x64\3\PJL.GPD - Ok
C:\Windows\system32\spool\drivers\x64\3\PSCRIPT.HLP - Ok
C:\Windows\system32\spool\drivers\x64\3\PCLXL.GPD - Ok
C:\Windows\system32\spool\drivers\x64\3\PSCRIPT.NTF - Ok
>C:\Windows\system32\spool\drivers\x64\3\HPCDMCLH.DLL - packed by PESTUB
C:\Windows\system32\spool\drivers\x64\3\P6DISP.GPD - Ok
C:\Windows\system32\spool\drivers\x64\3\PS_SCHM.GDL - Ok
C:\Windows\system32\spool\drivers\x64\3\SendToOneNote-PipelineConfig.xml - Ok
C:\Windows\system32\spool\drivers\x64\3\sendtoonenote.BUD - Ok
C:\Windows\system32\spool\drivers\x64\3\PS5UI.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\SendToOneNote.ini - Ok
C:\Windows\system32\spool\drivers\x64\3\sendtoonenote.gpd - Ok
C:\Windows\system32\spool\drivers\x64\3\SendToOneNoteFilter.gpd - Ok
C:\Windows\system32\spool\drivers\x64\3\PSCRPTFE.NTF - Ok
C:\Windows\system32\spool\drivers\x64\3\SendToOneNoteFilter.dll - Ok
C:\Windows\system32\spool\drivers\x64\3\SendToOneNoteUI.dll - Ok
C:\Windows\system32\spool\drivers\x64\3\SendToOneNoteNames.gpd - Ok
C:\Windows\system32\spool\drivers\x64\3\stddtype.gdl - Ok
C:\Windows\system32\spool\drivers\x64\3\stdschem.gdl - Ok
C:\Windows\system32\spool\drivers\x64\3\stdschmx.gdl - Ok
C:\Windows\system32\spool\drivers\x64\3\unidrv.hlp - Ok
C:\Windows\system32\spool\drivers\x64\3\stdnames.gpd - Ok
C:\Windows\system32\spool\PRINTERS\FP00005.SPL - Ok
C:\Windows\system32\spool\drivers\x64\3\PCL5ERES.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\mui\0413\PSCRIPT.HLP - Ok
C:\Windows\system32\spool\drivers\x64\3\mui\0413\TTYUI.HLP - Ok
C:\Windows\system32\spool\drivers\x64\3\mui\0413\UNIDRV.HLP - Ok
C:\Windows\system32\spool\drivers\x64\3\HPCDMCLH.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\CNBJUI2.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\BRCI06UI.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\BRCLUI05.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\brci14ui.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\brci08ui.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\BRCLUI06.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\BRPTUI2.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\unires.dll - Ok
C:\Windows\system32\spool\drivers\x64\3\HPZLSWN7.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR274.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR273.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\HPZSSWN7.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR276.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR281.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\brmzui13.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR280.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR284.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR283.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR282.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR285.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\PSCRIPT5.DLL - Ok
C:\Windows\system32\spool\drivers\x64\3\unidrvui.dll - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR286.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR289.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR290.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR288.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\XpsSvcs.dll - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR292.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR293.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR294.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR297.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR300.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR302.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR301.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR303.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR312.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR311.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR315.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR310.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR316.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR309.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR323.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR319.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR326.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR320.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\BRUUI23A.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR318.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR325.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR327.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR331.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR333.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR332.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR334.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR328.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR342.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR339.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR335.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBBR346.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBIC4_1.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBIC4_2.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBIC4_5.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBIC4_4.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBIC4_6.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBIC4_3.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBMR284.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBIC4_8.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBMR310.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBMR285.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBPC4_1.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBPC4_2.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBPCOMM.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_274.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBPV4.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_276.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_279.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBPV3.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBIC4_7.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_281.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_280.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_284.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_282.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_287.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_285.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_288.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_286.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_283.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_289.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_292.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_290.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_291.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\unidrv.dll - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_293.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_294.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_301.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_295.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_300.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_297.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_298.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_309.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_311.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_302.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_303.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_310.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_312.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_316.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_318.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_317.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_319.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_325.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_324.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_320.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_326.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_327.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_328.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_331.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_329.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_333.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_335.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_334.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_321.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_315.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_323.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_332.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_337.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_338.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_340.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_341.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_339.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_336.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNN0B007.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_346.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\EP7RES01.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\CNBP_342.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\FXUCU001.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hp6500at.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hp8000at.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hp6000at.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hp6500nt.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hp8500at.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hp6000nt.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\EP7UIP00.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\EP7RES00.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\FXSRES.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpb8500t.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hp8500gt.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpc4500t.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpc309at.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpc5500t.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpc5300t.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpfiew71.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpd7500t.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpD5400t.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpfevw73.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpc6300t.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpc4600t.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpfiew73.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpd2600t.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpfprw73.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\HPFIME50.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hp8500nt.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpf4400t.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\HPZ3Awn7.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpzprw71.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpzprw72.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\HPZPRwn7.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\HPZEVWN7.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpzlaw71.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\hpzevw72.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\HPZLSWN7.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\HPZLAwn7.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\HPZEVW71.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\HPZUIWN7.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\KO0C0001.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\lxkpclui.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\lxkpclrs.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\lxkpsui.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\LXKXLRES.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\LXKXLUI.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\OKDTERES.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\KYW7FR02.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\OKDTURES.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\kyw7fr04.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\kyw7fr03.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\OK9IBRES.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\KYW7FRES.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\PCL4RES.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\PCL5URES.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\PCLXL.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\HPZUIW71.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\PCL5ERES.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\PSCRIPT5.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\RIAUI17.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\RIARES7.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\PS5UI.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\tsprint.dll.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\SH_1_RES.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\TTYRES.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\SODPPUI2.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\RIAUI27.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\TTYUI.DLL.mui - Ok
C:\Windows\system32\spool\drivers\x64\3\HPZSTWN7.DLL - Ok
>C:\Windows\system32\spool\drivers\x64\PCC\prnms001.inf_amd64_neutral_9fe8503f82ce60fa.cab is CAB archive
C:\Windows\system32\spool\drivers\x64\PCC\prnms001.inf_amd64_neutral_9fe8503f82ce60fa.cab - Ok
C:\Windows\system32\spool\drivers\x64\PCC\prnms001.inf_amd64_neutral_9fe8503f82ce60fa.cab - archive
C:\Windows\system32\spool\drivers\x64\3\nl-NL\UNIRES.DLL.mui - Ok
>C:\Windows\system32\spool\drivers\x64\PCC\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24.cab is CAB archive
C:\Windows\system32\spool\drivers\x64\PCC\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24.cab - Ok
C:\Windows\system32\spool\drivers\x64\PCC\prnhp002.inf_amd64_neutral_04d05d1f6a90ea24.cab - archive
C:\Windows\system32\spool\drivers\x64\3\nl-NL\tsmxuui3.dll.mui - Ok
>C:\Windows\system32\spool\drivers\x64\PCC\adobepdf.inf_amd64_neutral_70cb20a3417216e2.cab is CAB archive
C:\Windows\system32\spool\drivers\x64\PCC\adobepdf.inf_amd64_neutral_70cb20a3417216e2.cab - Ok
C:\Windows\system32\spool\drivers\x64\PCC\adobepdf.inf_amd64_neutral_70cb20a3417216e2.cab - archive
>C:\Windows\system32\spool\drivers\x64\PCC\prnms002.inf_amd64_neutral_d439051ec90eeda4.cab is CAB archive
C:\Windows\system32\spool\drivers\x64\PCC\prnms002.inf_amd64_neutral_d439051ec90eeda4.cab - Ok
C:\Windows\system32\spool\drivers\x64\PCC\prnms002.inf_amd64_neutral_d439051ec90eeda4.cab - archive
>C:\Windows\system32\spool\drivers\x64\PCC\ntprint.inf_amd64_neutral_4616c3de1949be6d.cab is CAB archive
C:\Windows\system32\spool\drivers\x64\PCC\ntprint.inf_amd64_neutral_4616c3de1949be6d.cab - Ok
C:\Windows\system32\spool\drivers\x64\PCC\ntprint.inf_amd64_neutral_4616c3de1949be6d.cab - archive
>C:\Windows\system32\spool\drivers\x64\PCC\prnms002.inf_amd64_neutral_d834e48846616289.cab is CAB archive
C:\Windows\system32\spool\drivers\x64\PCC\prnms002.inf_amd64_neutral_d834e48846616289.cab - Ok
C:\Windows\system32\spool\drivers\x64\PCC\prnms002.inf_amd64_neutral_d834e48846616289.cab - archive
C:\Windows\system32\spool\tools\Microsoft XPS Document Writer\mxdwdui.ini - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\RIPSUI7.DLL.mui - Ok
C:\Windows\system32\spool\prtprocs\x64\HPZPPWN7.DLL - Ok
C:\Windows\system32\spool\prtprocs\x64\winprint.dll - Ok
C:\Windows\system32\spool\tools\Microsoft XPS Document Writer\prnms001.cat - Ok
C:\Windows\system32\spool\tools\Microsoft XPS Document Writer\prnms001.inf - Ok
C:\Windows\system32\spool\prtprocs\x64\nl-NL\LXKPTPRC.DLL.mui - Ok
C:\Windows\system32\spool\tools\Microsoft XPS Document Writer\mxdwdui.gpd - Ok
C:\Windows\system32\spp\plugin-manifests-signed\sppobjs-spp-plugin-manifest-signed.xrm-ms - Ok
C:\Windows\system32\spp\plugin-manifests-signed\sppwinob-spp-plugin-manifest-signed.xrm-ms - Ok
C:\Windows\system32\spp\tokens\channels\OCUR\Security-SPP-Component-SKU-OCUR-RETAIL1-ul-oob.xrm-ms - Ok
>C:\Windows\system32\spool\drivers\x64\PCC\prnca005.inf_amd64_neutral_179dd80b276be15d.cab is CAB archive
C:\Windows\system32\spool\drivers\x64\PCC\prnca005.inf_amd64_neutral_179dd80b276be15d.cab - Ok
C:\Windows\system32\spool\drivers\x64\PCC\prnca005.inf_amd64_neutral_179dd80b276be15d.cab - archive
C:\Windows\system32\spp\tokens\channels\OCUR\Security-SPP-Component-SKU-OCUR-RETAIL1-pl.xrm-ms - Ok
C:\Windows\system32\spp\tokens\identity\rac-generic-private.xrm-ms - Ok
C:\Windows\system32\spool\drivers\x64\3\nl-NL\UNIDRVUI.DLL.mui - Ok
C:\Windows\system32\spp\tokens\identity\spc-generic-private.xrm-ms - Ok
C:\Windows\system32\spp\tokens\channels\OCUR\Security-SPP-Component-SKU-OCUR-ul-oob.xrm-ms - Ok
C:\Windows\system32\spp\tokens\issuance\client-issuance-spc.xrm-ms - Ok
C:\Windows\system32\spp\tokens\issuance\client-issuance-rac.xrm-ms - Ok
C:\Windows\system32\spp\tokens\channels\OCUR\Security-SPP-Component-SKU-OCUR-pl.xrm-ms - Ok
C:\Windows\system32\spp\tokens\issuance\client-issuance-ul-oob.xrm-ms - Ok
C:\Windows\system32\spp\tokens\issuance\client-issuance-ul-oem.xrm-ms - Ok
C:\Windows\system32\spp\tokens\issuance\client-issuance-plugin-manifest.xrm-ms - Ok
C:\Windows\system32\spp\tokens\identity\rac-generic-public.xrm-ms - Ok
C:\Windows\system32\spp\tokens\issuance\client-issuance-ppd.xrm-ms - Ok
C:\Windows\system32\spp\tokens\identity\spc-generic-public.xrm-ms - Ok
C:\Windows\system32\spp\tokens\issuance\client-issuance-stil.xrm-ms - Ok
C:\Windows\system32\spp\tokens\issuance\client-issuance-pkc.xrm-ms - Ok
C:\Windows\system32\spp\tokens\channels\OCUR\Security-SPP-Component-SKU-OCUR-RETAIL1-ul-phn.xrm-ms - Ok
C:\Windows\system32\spp\tokens\channels\OCUR\Security-SPP-Component-SKU-OCUR-ul-phn.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\explorer-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\DNS-Client-license-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\ACLUIFileFolderTool-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\ChangeDesktopBackground-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\appid-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\DirectExperience-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\issuance\client-issuance-wgalic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\GroupPolicy-License-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\LSA-License-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\feclient-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\IASLicensing-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\issuance\client-issuance-ul-phn.xrm-ms - Ok
C:\Windows\system32\spp\tokens\issuance\client-issuance-ul.xrm-ms - Ok
C:\Windows\system32\spp\tokens\pkeyconfig\pkeyconfig.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Kernel-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Microsoft-Windows-DesktopWindowManager-Core-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Microsoft-Windows-Core-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Microsoft-Windows-InternetConnectionSharingConfig-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\MediaCenter-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Microsoft-Windows-NetworkBridge-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Microsoft-Windows-SensorsLicense-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Microsoft-Windows-QWAVE-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Microsoft-Windows-DOT11PREF-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Microsoft-Windows-Fax-Common-ppdlic.xrm-ms - Ok
C:\Windows\system32\spool\tools\Microsoft XPS Document Writer\mxdwdui.dll - Ok
C:\Windows\system32\spp\tokens\ppdlic\msac3enc-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Microsoft-Windows-IE-InternetExplorer-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\MicrosoftWindowsSafeDocsMain-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\msmpeg2enc-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\MobilePCMobilityCenter-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\msmpeg2adec-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\MCLicense-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\OMD-API-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Personalization-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\msmpeg2vdec-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\provsvc-license-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\SecureStartupFeature-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\RasBase-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\PeerToPeerBase-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Printing-Spooler-Core-Localspl-Licensing-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\PhotoMinFeature-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\parentalcontrols-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Printing-Spooler-Core-Spoolss-Licensing-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Security-SPP-UX-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Security-SPP-Component-SKU-OCUR-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Security-SPP-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\shell-homegroup-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Shell-InBoxGames-Hearts-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Security-SPP-Component-SKU-HomePremium-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Shell-InBoxGames-FreeCell-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Shell-InBoxGames-Solitaire-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Shell-InBoxGames-Minesweeper-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Microsoft-Windows-AuxiliaryDisplay-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Shell-InBoxGames-PurblePlace-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Shell-MultiplayerInboxGames-Spades-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Shell-MultiplayerInboxGames-Common-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Shell-PremiumInBoxGames-Chess-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Shell-MultiplayerInboxGames-Checkers-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\SLC-Component-SKU-OCUR-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Shell-InBoxGames-SpiderSolitaire-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\SMBServer-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\shell32-license-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\TabletPC-tabbtn-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\SnippingToolLicensing-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\TabletPC-UIHub-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Shell-MultiplayerInboxGames-Backgammon-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\TabletPCPlatformInput-core-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\TerminalServices-RemoteConnectionManager-UiEffects-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\VirtualPC-licensing-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\volmgrx-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\WindowsAnytimeUpgrade-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\Shell-InBoxGames-Shanghai-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\WMPPlayer-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\WorkstationService-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\WindowsSearchComponent-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\StickyNotesLicensing-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-NONSLP-pl.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-NONSLP1-pl.xrm-ms - Ok
C:\Windows\system32\spp\tokens\ppdlic\TerminalServices-RemoteConnectionManager-License-ppdlic.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-NONSLP-ul-oob.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-NONSLP-ul-phn.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-NONSLP3-pl.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-NONSLP2-ul-oob.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-NONSLP2-pl.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-NONSLP1-ul-phn.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-NONSLP1-ul-oob.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-NONSLP3-ul-oob.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-NONSLP3-ul-phn.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-NONSLP2-ul-phn.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-SLP-ul.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-SLP1-ul-oob.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-SLP-ul-oob.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-SLPCOA1-pl.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-SLPCOA-ul-oob.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-SLPCOA-ul-phn.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-SLPCOA-pl.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-SLPCOA1-ul-oob.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-SLPCOA1-ul-phn.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-SLPCOA2-pl.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-SLP1-ul.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-SLPCOA2-ul-phn.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-RETAIL1-pl.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-SLPCOA3-ul-oob.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-RETAIL1-ul-oob.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-RETAIL1-ul-phn.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-RETAIL2-ul-oob.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-RETAIL3-ul-oob.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-RETAIL3-pl.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-pl.xrm-ms - Ok
C:\Windows\system32\sppui\migip.dun - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-RETAIL2-ul-phn.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-SLPCOA2-ul-oob.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-ul-oob.xrm-ms - Ok
C:\Windows\system32\sppui\reg.isp - Ok
C:\Windows\system32\sppui\phone.inf - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-ul-phn.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-RETAIL3-ul-phn.xrm-ms - Ok
C:\Windows\system32\sr-Latn-CS\comctl32.dll.mui - Ok
C:\Windows\system32\sppui\migrate.obe - Ok
C:\Windows\system32\sr-Latn-CS\fms.dll.mui - Ok
C:\Windows\system32\sr-Latn-CS\mlang.dll.mui - Ok
C:\Windows\system32\sr-Latn-CS\comdlg32.dll.mui - Ok
C:\Windows\system32\spp\tokens\ppdlic\NetworkSecurity-ppdlic.xrm-ms - Ok
C:\Windows\system32\sv-SE\cdosys.dll.mui - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-SLPCOA3-pl.xrm-ms - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-OEM-SLPCOA3-ul-phn.xrm-ms - Ok
C:\Windows\system32\sv-SE\DWrite.dll.mui - Ok
C:\Windows\system32\sv-SE\fms.dll.mui - Ok
C:\Windows\system32\sv-SE\comctl32.dll.mui - Ok
C:\Windows\system32\sysprep\Sysprep_succeeded.tag - Ok
C:\Windows\system32\spp\tokens\skus\Security-SPP-Component-SKU-HomePremium\Security-SPP-Component-SKU-HomePremium-RETAIL2-pl.xrm-ms - Ok
C:\Windows\system32\sv-SE\msprivs.dll.mui - Ok
C:\Windows\system32\sysprep\Panther\diagerr.xml - Ok
C:\Windows\system32\sysprep\Panther\setuperr.log - Ok
C:\Windows\system32\sysprep\Panther\diagwrn.xml - Ok
C:\Windows\system32\sysprep\Panther\IE\diagerr.xml - Ok
C:\Windows\system32\sv-SE\comdlg32.dll.mui - Ok
C:\Windows\system32\sysprep\Panther\IE\setuperr.log - Ok
C:\Windows\system32\sysprep\Panther\IE\diagwrn.xml - Ok
C:\Windows\system32\sysprep\Panther\IE\setupact.log - Ok
C:\Windows\system32\sv-SE\msimsg.dll.mui - Ok
C:\Windows\system32\sysprep\sysprep.exe - Ok
C:\Windows\system32\sv-SE\mlang.dll.mui - Ok
C:\Windows\system32\sr-Latn-CS\msimsg.dll.mui - Ok
C:\Windows\system32\sv-SE\FntCache.dll.mui - Ok
C:\Windows\system32\th-TH\comdlg32.dll.mui - Ok
C:\Windows\system32\tr-TR\comctl32.dll.mui - Ok
C:\Windows\system32\th-TH\comctl32.dll.mui - Ok
C:\Windows\system32\th-TH\fms.dll.mui - Ok
C:\Windows\system32\tr-TR\cdosys.dll.mui - Ok
C:\Windows\system32\sv-SE\d2d1.dll.mui - Ok
C:\Windows\system32\th-TH\msimsg.dll.mui - Ok
C:\Windows\system32\tr-TR\comdlg32.dll.mui - Ok
C:\Windows\system32\tr-TR\FntCache.dll.mui - Ok
C:\Windows\system32\tr-TR\mlang.dll.mui - Ok
C:\Windows\system32\tr-TR\DWrite.dll.mui - Ok
C:\Windows\system32\sysprep\nl-NL\sysprep.exe.mui - Ok
C:\Windows\system32\tr-TR\d2d1.dll.mui - Ok
C:\Windows\system32\tr-TR\msimsg.dll.mui - Ok
C:\Windows\system32\uk-UA\mlang.dll.mui - Ok
C:\Windows\system32\uk-UA\comdlg32.dll.mui - Ok
C:\Windows\system32\uk-UA\comctl32.dll.mui - Ok
C:\Windows\system32\wbem\AuditRsop.mof - Ok
C:\Windows\system32\wbem\authfwcfg.mof - Ok
C:\Windows\system32\wbem\aaclient.mof - Ok
C:\Windows\system32\tr-TR\msprivs.dll.mui - Ok
C:\Windows\system32\uk-UA\fms.dll.mui - Ok
C:\Windows\system32\uk-UA\msimsg.dll.mui - Ok
C:\Windows\system32\sysprep\Panther\setupact.log - Ok
C:\Windows\system32\wbem\auxiliarydisplaycpl.mof - Ok
C:\Windows\system32\wbem\bcd.mof - Ok
C:\Windows\system32\wbem\auxiliarydisplayservices.mof - Ok
C:\Windows\system32\wbem\auxiliarydisplaydriverlib.mof - Ok
C:\Windows\system32\tr-TR\WMPhoto.dll.mui - Ok
C:\Windows\system32\wbem\cimdmtf.mof - Ok
C:\Windows\system32\wbem\BthMtpEnum.mof - Ok
C:\Windows\system32\wbem\auxiliarydisplayapi.mof - Ok
C:\Windows\system32\wbem\DevicePairingHandler.mof - Ok
C:\Windows\system32\wbem\cimwin32.mof - Ok
C:\Windows\system32\wbem\dimsjob.mof - Ok
C:\Windows\system32\wbem\dimsroam.mof - Ok
C:\Windows\system32\wbem\dsprov.mof - Ok
C:\Windows\system32\wbem\DShowRdpFilter.mof - Ok
C:\Windows\system32\wbem\cli.mof - Ok
C:\Windows\system32\wbem\drvinst.mof - Ok
C:\Windows\system32\sv-SE\WMPhoto.dll.mui - Ok
C:\Windows\system32\wbem\eaimeapi.mof - Ok
C:\Windows\system32\tr-TR\fms.dll.mui - Ok
C:\Windows\system32\wbem\dsprov.dll - Ok
C:\Windows\system32\wbem\fdPHost.mof - Ok
C:\Windows\system32\wbem\fdrespub.mof - Ok
C:\Windows\system32\wbem\filetrace.mof - Ok
C:\Windows\system32\wbem\fdSSDP.mof - Ok
C:\Windows\system32\wbem\fdWSD.mof - Ok
C:\Windows\system32\wbem\fdWNet.mof - Ok
C:\Windows\system32\wbem\firewallapi.mof - Ok
C:\Windows\system32\wbem\cliegaliases.mof - Ok
C:\Windows\system32\wbem\FunDisc.mof - Ok
C:\Windows\system32\th-TH\mlang.dll.mui - Ok
C:\Windows\system32\wbem\esscli.dll - Ok
C:\Windows\system32\wbem\dot3.mof - Ok
C:\Windows\system32\wbem\fastprox.dll - Ok
C:\Windows\system32\wbem\hnetcfg.mof - Ok
C:\Windows\system32\wbem\fwcfg.mof - Ok
C:\Windows\system32\wbem\interop.mof - Ok
C:\Windows\system32\wbem\IPBusEnum.mof - Ok
C:\Windows\system32\wbem\hbaapi.mof - Ok
C:\Windows\system32\wbem\IMAPIv2-LegacyShim.mof - Ok
C:\Windows\system32\wbem\IMAPIv2-FileSystemSupport.mof - Ok
C:\Windows\system32\wbem\ipsecsvc.mof - Ok
C:\Windows\system32\wbem\irmon.mof - Ok
C:\Windows\system32\wbem\iscsidsc.mof - Ok
C:\Windows\system32\wbem\irda.mof - Ok
C:\Windows\system32\wbem\iscsiprf.mof - Ok
C:\Windows\system32\wbem\iscsihba.mof - Ok
C:\Windows\system32\wbem\l2gpstore.mof - Ok
C:\Windows\system32\wbem\krnlprov.mof - Ok
C:\Windows\system32\wbem\lltdio.mof - Ok
C:\Windows\system32\wbem\KrnlProv.dll - Ok
C:\Windows\system32\wbem\L2SecHC.mof - Ok
C:\Windows\system32\wbem\lltdsvc.mof - Ok
C:\Windows\system32\wbem\kerberos.mof - Ok
C:\Windows\system32\wbem\Microsoft-Windows-Remote-FileSystem.mof - Ok
C:\Windows\system32\wbem\iscsirem.mof - Ok
C:\Windows\system32\wbem\mmc.mof - Ok
C:\Windows\system32\wbem\mblctr.mof - Ok
C:\Windows\system32\wbem\MMFUtil.dll - Ok
C:\Windows\system32\wbem\msfeeds.mof - Ok
C:\Windows\system32\wbem\IMAPIv2-Base.mof - Ok
C:\Windows\system32\wbem\mofcomp.exe - Ok
C:\Windows\system32\wbem\mpsdrv.mof - Ok
C:\Windows\system32\wbem\mountmgr.mof - Ok
C:\Windows\system32\wbem\mpssvc.mof - Ok
C:\Windows\system32\wbem\msfeedsbs.mof - Ok
C:\Windows\system32\wbem\msi.mof - Ok
C:\Windows\system32\wbem\mofinstall.dll - Ok
C:\Windows\system32\wbem\msiscsi.mof - Ok
C:\Windows\system32\wbem\lsasrv.mof - Ok
C:\Windows\system32\wbem\mofd.dll - Ok
C:\Windows\system32\wbem\msv1_0.mof - Ok
C:\Windows\system32\wbem\NCProv.dll - Ok
C:\Windows\system32\wbem\NAPCLIENTSCHEMA.MOF - Ok
C:\Windows\system32\wbem\ndistrace.mof - Ok
C:\Windows\system32\wbem\NAPCLIENTPROV.MOF - Ok
C:\Windows\system32\wbem\mstsc.mof - Ok
C:\Windows\system32\wbem\mstscax.mof - Ok
C:\Windows\system32\wbem\mswmdm.mof - Ok
C:\Windows\system32\wbem\ncprov.mof - Ok
C:\Windows\system32\spool\drivers\x64\3\FXSRES.DLL - Ok
C:\Windows\system32\wbem\networkitemfactory.mof - Ok
C:\Windows\system32\wbem\nci.mof - Ok
C:\Windows\system32\wbem\ncsi.mof - Ok
C:\Windows\system32\wbem\networkmap.mof - Ok
C:\Windows\system32\wbem\netprofm.mof - Ok
C:\Windows\system32\wbem\ntfs.mof - Ok
C:\Windows\system32\wbem\newdev.mof - Ok
C:\Windows\system32\wbem\ntevt.dll - Ok
C:\Windows\system32\wbem\nshipsec.mof - Ok
C:\Windows\system32\wbem\nlsvc.mof - Ok
C:\Windows\system32\wbem\nlasvc.mof - Ok
C:\Windows\system32\wbem\PNPXAssoc.mof - Ok
C:\Windows\system32\wbem\pnpsetup.mof - Ok
C:\Windows\system32\wbem\polstore.mof - Ok
C:\Windows\system32\wbem\partmgr.mof - Ok
C:\Windows\system32\wbem\p2p-pnrp.mof - Ok
C:\Windows\system32\wbem\p2p-collab.mof - Ok
C:\Windows\system32\wbem\p2p-mesh.mof - Ok
C:\Windows\system32\wbem\powerpolicyprovider.mof - Ok
C:\Windows\system32\wbem\portabledeviceconnectapi.mof - Ok
C:\Windows\system32\wbem\onex.mof - Ok
C:\Windows\system32\wbem\portabledevicewiacompat.mof - Ok
C:\Windows\system32\wbem\portabledeviceclassextension.mof - Ok
C:\Windows\system32\wbem\portabledevicewmdrm.mof - Ok
C:\Windows\system32\wbem\msiprov.dll - Ok
C:\Windows\system32\wbem\powermeterprovider.mof - Ok
C:\Windows\system32\wbem\ppcRsopUserSchema.mof - Ok
C:\Windows\system32\wbem\portabledevicetypes.mof - Ok
C:\Windows\system32\wbem\rawxml.xsl - Ok
C:\Windows\system32\wbem\ppcRsopCompSchema.mof - Ok
C:\Windows\system32\wbem\PrintFilterPipelineSvc.mof - Ok
C:\Windows\system32\wbem\qmgr.mof - Ok
C:\Windows\system32\wbem\profileassociationprovider.mof - Ok
C:\Windows\system32\wbem\RacWmiProv.mof - Ok
C:\Windows\system32\wbem\portabledeviceapi.mof - Ok
C:\Windows\system32\wbem\rdpcore.mof - Ok
C:\Windows\system32\wbem\ntevt.mof - Ok
C:\Windows\system32\wbem\rdpencom.mof - Ok
C:\Windows\system32\wbem\regevent.mof - Ok
C:\Windows\system32\wbem\schannel.mof - Ok
C:\Windows\system32\wbem\scm.mof - Ok
C:\Windows\system32\wbem\rspndr.mof - Ok
C:\Windows\system32\wbem\rsop.mof - Ok
C:\Windows\system32\wbem\RacWmiProv.dll - Ok
C:\Windows\system32\wbem\SchedSvc.mof - Ok
C:\Windows\system32\wbem\scrcons.mof - Ok
C:\Windows\system32\wbem\scrcons.exe - Ok
C:\Windows\system32\wbem\sensorscpl.mof - Ok
C:\Windows\system32\wbem\SensorsClassExtension.mof - Ok
C:\Windows\system32\wbem\ServiceModel.mof.uninstall - Ok
C:\Windows\system32\wbem\secrcw32.mof - Ok
C:\Windows\system32\wbem\sdbus.mof - Ok
C:\Windows\system32\wbem\ServiceModel.mof - Ok
C:\Windows\system32\wbem\scersop.mof - Ok
C:\Windows\system32\wbem\ServiceModel35.mof.uninstall - Ok
C:\Windows\system32\wbem\services.mof - Ok
C:\Windows\system32\wbem\sppwmi.mof - Ok
C:\Windows\system32\wbem\setupapi.mof - Ok
C:\Windows\system32\wbem\repdrvfs.dll - Ok
C:\Windows\system32\wbem\SMTPCons.dll - Ok
C:\Windows\system32\wbem\ServiceModel35.mof - Ok
C:\Windows\system32\wbem\sr.mof - Ok
C:\Windows\system32\wbem\ServDeps.dll - Ok
C:\Windows\system32\wbem\system.mof - Ok
C:\Windows\system32\wbem\ssdpsrv.mof - Ok
C:\Windows\system32\wbem\sstpsvc.mof - Ok
C:\Windows\system32\wbem\textvaluelist.xsl - Ok
C:\Windows\system32\wbem\smtpcons.mof - Ok
C:\Windows\system32\wbem\subscrpt.mof - Ok
C:\Windows\system32\wbem\tsmf.mof - Ok
C:\Windows\system32\wbem\tcpip.mof - Ok
C:\Windows\system32\wbem\umb.mof - Ok
C:\Windows\system32\wbem\texttable.xsl - Ok
C:\Windows\system32\wbem\stdprov.dll - Ok
C:\Windows\system32\wbem\umbus.mof - Ok
C:\Windows\system32\wbem\tspkg.mof - Ok
C:\Windows\system32\wbem\umpass.mof - Ok
C:\Windows\system32\wbem\umpnpmgr.mof - Ok
C:\Windows\system32\wbem\unsecapp.exe - Ok
C:\Windows\system32\wbem\stortrace.mof - Ok
C:\Windows\system32\wbem\UserProfileWmiProvider.mof - Ok
C:\Windows\system32\wbem\vds.mof - Ok
C:\Windows\system32\wbem\vdswmi.dll - Ok
C:\Windows\system32\wbem\WBEMCons.mof - Ok
C:\Windows\system32\wbem\vss.mof - Ok
C:\Windows\system32\wbem\wbemcons.dll - Ok
C:\Windows\system32\wbem\wbemess.dll - Ok
C:\Windows\system32\wbem\wbemcore.dll - Ok
C:\Windows\system32\wbem\wbemprox.dll - Ok
C:\Windows\system32\wbem\vsswmi.dll - Ok
C:\Windows\system32\wbem\wbemsvc.dll - Ok
C:\Windows\system32\wbem\Wdf01000Uninstall.mof - Ok
C:\Windows\system32\wbem\wcncsvc.mof - Ok
C:\Windows\system32\wbem\wdigest.mof - Ok
C:\Windows\system32\wbem\WFP.MOF - Ok
C:\Windows\system32\wbem\wfs.mof - Ok
C:\Windows\system32\wbem\WFAPIGP.mof - Ok
C:\Windows\system32\wbem\Wdf01000.mof - Ok
C:\Windows\system32\wbem\WgxInstalledGame.mof - Ok
C:\Windows\system32\wbem\wbemdisp.tlb - Ok
C:\Windows\system32\wbem\Win32_EncryptableVolumeUninstall.mof - Ok
C:\Windows\system32\wbem\viewprov.dll - Ok
C:\Windows\system32\wbem\win32_printer.mof - Ok
C:\Windows\system32\wbem\whqlprov.mof - Ok
C:\Windows\system32\wbem\Win32_EncryptableVolume.dll - Ok
C:\Windows\system32\wbem\winlogon.mof - Ok
C:\Windows\system32\wbem\wininit.mof - Ok
C:\Windows\system32\wbem\wbemdisp.dll - Ok
C:\Windows\system32\wbem\Win32_Tpm.mof - Ok
C:\Windows\system32\wbem\cimwin32.dll - Ok
C:\Windows\system32\wbem\winipsec.mof - Ok
C:\Windows\system32\wbem\Win32_Tpm.dll - Ok
C:\Windows\system32\wbem\Winsat.mof - Ok
C:\Windows\system32\wbem\WinMgmtR.dll - Ok
C:\Windows\system32\wbem\wbemcntl.dll - Ok
C:\Windows\system32\wbem\samsrv.mof - Ok
C:\Windows\system32\wbem\WinsatUninstall.mof - Ok
C:\Windows\system32\wbem\WLanHC.mof - Ok
C:\Windows\system32\wbem\wmi.mof - Ok
C:\Windows\system32\wbem\WinMgmt.exe - Ok
C:\Windows\system32\wbem\WmiApRpl.dll - Ok
C:\Windows\system32\wbem\wbemtest.exe - Ok
C:\Windows\system32\wbem\WmiApSrv.exe - Ok
C:\Windows\system32\wbem\wmipcima.mof - Ok
C:\Windows\system32\wbem\win32_encryptablevolume.mof - Ok
C:\Windows\system32\wbem\WMICOOKR.dll - Ok
C:\Windows\system32\wbem\WmiDcPrv.dll - Ok
C:\Windows\system32\wbem\wlan.mof - Ok
C:\Windows\system32\wbem\WmiApRes.dll - Ok
C:\Windows\system32\wbem\wmipdfs.mof - Ok
C:\Windows\system32\wbem\wmipdskq.mof - Ok
C:\Windows\system32\wbem\wmipdfs.dll - Ok
C:\Windows\system32\wbem\wmipicmp.mof - Ok
C:\Windows\system32\wbem\WmiPerfInst.mof - Ok
C:\Windows\system32\wbem\WmiPerfClass.mof - Ok
C:\Windows\system32\wbem\WmiPerfInst.dll - Ok
C:\Windows\system32\wbem\wmipiprt.mof - Ok
C:\Windows\system32\wbem\WMIADAP.exe - Ok
C:\Windows\system32\wbem\wmipjobj.mof - Ok
C:\Windows\system32\wbem\WmiPerfClass.dll - Ok
C:\Windows\system32\wbem\wmipdskq.dll - Ok
C:\Windows\system32\wbem\WMIPICMP.dll - Ok
C:\Windows\system32\wbem\WMIPIPRT.dll - Ok
C:\Windows\system32\wbem\wmiprov.dll - Ok
C:\Windows\system32\wbem\WMIPJOBJ.dll - Ok
C:\Windows\system32\wbem\WMIPSESS.dll - Ok
C:\Windows\system32\wbem\wmipcima.dll - Ok
C:\Windows\system32\wbem\wmitimep.mof - Ok
C:\Windows\system32\wbem\WmiPrvSE.exe - Ok
C:\Windows\system32\wbem\wmitimep.dll - Ok
C:\Windows\system32\wbem\wmipsess.mof - Ok
C:\Windows\system32\wbem\WMI_Tracing.mof - Ok
C:\Windows\system32\wbem\wpc.mof - Ok
C:\Windows\system32\wbem\wmiutils.dll - Ok
C:\Windows\system32\wbem\wpdbusenum.mof - Ok
C:\Windows\system32\wbem\wpdcomp.mof - Ok
C:\Windows\system32\wbem\wmp.mof - Ok
C:\Windows\system32\wbem\wmpnetwk.mof - Ok
C:\Windows\system32\wbem\wpcuninst.mof - Ok
C:\Windows\system32\wbem\WMIsvc.dll - Ok
C:\Windows\system32\wbem\wpdshext.mof - Ok
C:\Windows\system32\wbem\wpdfs.mof - Ok
C:\Windows\system32\wbem\wpdmtp.mof - Ok
C:\Windows\system32\wbem\wscmisetup.mof - Ok
C:\Windows\system32\wbem\wpd_ci.mof - Ok
C:\Windows\system32\wbem\WSDApi.mof - Ok
C:\Windows\system32\wbem\WPDShServiceObj.mof - Ok
C:\Windows\system32\wbem\wpdsp.mof - Ok
C:\Windows\system32\wbem\WmiPrvSD.dll - Ok
C:\Windows\system32\wbem\wscenter.mof - Ok
C:\Windows\system32\wbem\xsl-mappings.xml - Ok
C:\Windows\system32\wbem\WMIC.exe - Ok
C:\Windows\system32\wbem\wzcdlg.mof - Ok
C:\Windows\system32\wbem\AutoRecover\14C5A2A3C41254184B007011E5565E5B.mof - Ok
C:\Windows\system32\wbem\wpdwcn.mof - Ok
C:\Windows\system32\wbem\AutoRecover\1BA88ACB624E02A260404A9D8F7BD8E5.mof - Ok
C:\Windows\system32\wbem\AutoRecover\26A5A04A346330E389400293E01228AC.mof - Ok
C:\Windows\system32\wbem\WUDFx.mof - Ok
C:\Windows\system32\wbem\AutoRecover\3FA3650B664BC96A8672EC85A7AE4225.mof - Ok
C:\Windows\system32\wbem\xwizards.mof - Ok
C:\Windows\system32\wbem\AutoRecover\451233ED13E097000776690B79D8D753.mof - Ok
C:\Windows\system32\wbem\AutoRecover\6792FDA793556851BD20EA3DD8BD4F6B.mof - Ok
C:\Windows\system32\wbem\AutoRecover\32C943873CC624333BD0BF2A77384240.mof - Ok
C:\Windows\system32\wbem\AutoRecover\20FFC2A784EB8ADEE52F4F770E9BD1F4.mof - Ok
C:\Windows\system32\wbem\AutoRecover\35D38E70DF68A084436B84B1B77C1393.mof - Ok
C:\Windows\system32\wbem\AutoRecover\779E080B33F322115205BB50F1E0B8D1.mof - Ok
C:\Windows\system32\wbem\WUDFxUninstall.mof - Ok
C:\Windows\system32\wbem\AutoRecover\542DC56D520FDDEDA279A0D2F398203D.mof - Ok
C:\Windows\system32\wbem\wpcsprov.mof - Ok
C:\Windows\system32\wbem\AutoRecover\716FDC254E211F547A560E1A71D0E6CA.mof - Ok
C:\Windows\system32\wbem\AutoRecover\9E721AD57D012C71CF681490F452F678.mof - Ok
C:\Windows\system32\wbem\Performance\WmiApRpl.ini - Ok
C:\Windows\system32\wbem\AutoRecover\BBF206490BAA431B592F9A13534F43F6.mof - Ok
C:\Windows\system32\wbem\Repository\MAPPING2.MAP - Ok
C:\Windows\system32\wbem\Performance\WmiApRpl.h - Ok
C:\Windows\system32\wbem\Repository\MAPPING1.MAP - Ok
C:\Windows\system32\wbem\AutoRecover\D361F8B496FD6DAF7BEEF497E09C0DC1.mof - Ok
C:\Windows\system32\wbem\en-US\msfeeds.mfl - Ok
C:\Windows\system32\wbem\Repository\MAPPING3.MAP - Ok
C:\Windows\system32\wbem\en-US\msfeedsbs.mfl - Ok
C:\Windows\system32\wbem\nl-NL\aaclient.mfl - Ok
C:\Windows\system32\wbem\nl-NL\auxiliarydisplaycpl.mfl - Ok
C:\Windows\system32\wbem\WsmAuto.mof - Ok
C:\Windows\system32\wbem\AutoRecover\6F8564A71977AE6B940705DCC4847A8D.mof - Ok
C:\Windows\system32\wbem\nl-NL\cli.mfl - Ok
C:\Windows\system32\wbem\nl-NL\cliegaliases.mfl - Ok
C:\Windows\system32\wbem\nl-NL\cimwin32.dll.mui - Ok
C:\Windows\system32\wbem\Repository\INDEX.BTR - Ok
C:\Windows\system32\wbem\nl-NL\csv.xsl - Ok
C:\Windows\system32\wbem\nl-NL\filetrace.mfl - Ok
C:\Windows\system32\wbem\nl-NL\dsprov.mfl - Ok
C:\Windows\system32\wbem\AutoRecover\E6195BA9E153534E5472835E2F29A5B0.mof - Ok
C:\Windows\system32\wbem\nl-NL\htable.xsl - Ok
C:\Windows\system32\wbem\nl-NL\hform.xsl - Ok
C:\Windows\system32\wbem\nl-NL\interop.mfl - Ok
C:\Windows\system32\wbem\nl-NL\cimwin32.mfl - Ok
C:\Windows\system32\wbem\nl-NL\irmon.mfl - Ok
C:\Windows\system32\wbem\nl-NL\iscsidsc.mfl - Ok
C:\Windows\system32\wbem\nl-NL\hbaapi.mfl - Ok
C:\Windows\system32\wbem\nl-NL\iscsiprf.mfl - Ok
C:\Windows\system32\wbem\nl-NL\KrnlProv.dll.mui - Ok
C:\Windows\system32\wbem\nl-NL\l2gpstore.mfl - Ok
C:\Windows\system32\wbem\AutoRecover\7C45C8B7490D3AD44A961494C7FBFAFD.mof - Ok
C:\Windows\system32\wbem\nl-NL\krnlprov.mfl - Ok
C:\Windows\system32\wbem\nl-NL\mof.xsl - Ok
C:\Windows\system32\wbem\nl-NL\msfeeds.mfl - Ok
C:\Windows\system32\wbem\AutoRecover\CF881EBD6F50B8BAA9BD57DC3DAC5CB2.mof - Ok
C:\Windows\system32\wbem\nl-NL\msfeedsbs.mfl - Ok
C:\Windows\system32\wbem\nl-NL\MMFUtil.dll.mui - Ok
C:\Windows\system32\wbem\nl-NL\cimdmtf.mfl - Ok
C:\Windows\system32\wbem\nl-NL\mstscax.mfl - Ok
C:\Windows\system32\wbem\nl-NL\mstsc.mfl - Ok
C:\Windows\system32\wbem\nl-NL\ncprov.mfl - Ok
C:\Windows\system32\wbem\nl-NL\msi.mfl - Ok
C:\Windows\system32\wbem\nl-NL\p2p-collab.mfl - Ok
C:\Windows\system32\wbem\nl-NL\p2p-mesh.mfl - Ok
C:\Windows\system32\wbem\nl-NL\ntevt.mfl - Ok
C:\Windows\system32\wbem\Repository\OBJECTS.DATA - Ok
C:\Windows\system32\wbem\nl-NL\powerpolicyprovider.mfl - Ok
C:\Windows\system32\wbem\nl-NL\powermeterprovider.mfl - Ok
C:\Windows\system32\wbem\nl-NL\rdpcore.mfl - Ok
C:\Windows\system32\wbem\nl-NL\profileassociationprovider.mfl - Ok
C:\Windows\system32\wbem\nl-NL\mofcomp.exe.mui - Ok
C:\Windows\system32\wbem\nl-NL\rdpencom.mfl - Ok
C:\Windows\system32\wbem\nl-NL\mofd.dll.mui - Ok
C:\Windows\system32\wbem\nl-NL\RacWmiProv.mfl - Ok
C:\Windows\system32\wbem\nl-NL\ntevt.dll.mui - Ok
C:\Windows\system32\wbem\nl-NL\secrcw32.mfl - Ok
C:\Windows\system32\wbem\nl-NL\NCProv.dll.mui - Ok
C:\Windows\system32\wbem\nl-NL\ScrCons.mfl - Ok
C:\Windows\system32\wbem\nl-NL\scrcons.exe.mui - Ok
C:\Windows\system32\wbem\nl-NL\rsop.mfl - Ok
C:\Windows\system32\wbem\nl-NL\sensorscpl.mfl - Ok
C:\Windows\system32\wbem\nl-NL\ServiceModel35.mfl - Ok
C:\Windows\system32\wbem\nl-NL\smtpcons.mfl - Ok
C:\Windows\system32\wbem\nl-NL\sr.mfl - Ok
C:\Windows\system32\wbem\nl-NL\sppwmi.mfl - Ok
C:\Windows\system32\wbem\nl-NL\ServiceModel.mfl - Ok
C:\Windows\system32\wbem\nl-NL\subscrpt.mfl - Ok
C:\Windows\system32\wbem\nl-NL\ServDeps.dll.mui - Ok
C:\Windows\system32\wbem\nl-NL\UserProfileWmiProvider.mfl - Ok
C:\Windows\system32\wbem\nl-NL\vds.mfl - Ok
C:\Windows\system32\wbem\nl-NL\vdswmi.dll.mui - Ok
C:\Windows\system32\wbem\nl-NL\vss.mfl - Ok
C:\Windows\system32\wbem\nl-NL\system.mfl - Ok
C:\Windows\system32\wbem\nl-NL\WbemCons.mfl - Ok
C:\Windows\system32\wbem\nl-NL\p2p-pnrp.mfl - Ok
C:\Windows\system32\wbem\nl-NL\wcncsvc.mfl - Ok
C:\Windows\system32\wbem\nl-NL\wbemcore.dll.mui - Ok
C:\Windows\system32\wbem\nl-NL\WgxInstalledGame.mfl - Ok
C:\Windows\system32\wbem\nl-NL\wfs.mfl - Ok
C:\Windows\system32\wbem\nl-NL\wbemcntl.dll.mui - Ok
C:\Windows\system32\wbem\nl-NL\win32_printer.mfl - Ok
C:\Windows\system32\wbem\nl-NL\vsswmi.dll.mui - Ok
C:\Windows\system32\wbem\nl-NL\regevent.mfl - Ok
C:\Windows\system32\wbem\nl-NL\wininit.mfl - Ok
C:\Windows\system32\wbem\nl-NL\whqlprov.mfl - Ok
C:\Windows\system32\wbem\nl-NL\win32_tpm.dll.mui - Ok
C:\Windows\system32\wbem\nl-NL\winlogon.mfl - Ok
C:\Windows\system32\wbem\nl-NL\wbemtest.exe.mui - Ok
C:\Windows\system32\wbem\nl-NL\wmi.mfl - Ok
C:\Windows\system32\wbem\nl-NL\WmiApSrv.exe.mui - Ok
C:\Windows\system32\wbem\nl-NL\wmipcima.mfl - Ok
C:\Windows\system32\wbem\nl-NL\WmiApRpl.dll.mui - Ok
C:\Windows\system32\wbem\nl-NL\wmipdfs.mfl - Ok
C:\Windows\system32\wbem\nl-NL\wmipdskq.mfl - Ok
C:\Windows\system32\wbem\nl-NL\WmiApRes.dll.mui - Ok
C:\Windows\system32\wbem\nl-NL\WmiPerfClass.dll.mui - Ok
C:\Windows\system32\wbem\nl-NL\WmiPerfInst.dll.mui - Ok
C:\Windows\system32\wbem\nl-NL\wmipiprt.mfl - Ok
C:\Windows\system32\wbem\nl-NL\wmipjobj.mfl - Ok
C:\Windows\system32\wbem\nl-NL\wmipsess.mfl - Ok
C:\Windows\system32\wbem\nl-NL\wmipicmp.mfl - Ok
C:\Windows\system32\wbem\nl-NL\wmitimep.mfl - Ok
C:\Windows\system32\wbem\nl-NL\wscenter.mfl - Ok
C:\Windows\system32\wbem\nl-NL\WinMgmtR.dll.mui - Ok
C:\Windows\system32\wbem\nl-NL\xml.xsl - Ok
C:\Windows\system32\wbem\Logs\wmiprov.log - Ok
C:\Windows\system32\wbem\nl-NL\wmpnetwk.mfl - Ok
C:\Windows\system32\wbem\nl-NL\WinMgmt.exe.mui - Ok
C:\Windows\system32\wbem\nl-NL\xwizards.mfl - Ok
C:\Windows\system32\wbem\nl-NL\WMIPICMP.dll.mui - Ok
C:\Windows\system32\wdi\BootPerformanceDiagnostics_SystemData.bin - Ok
C:\Windows\system32\wbem\nl-NL\WUDFx.mfl - Ok
C:\Windows\system32\wbem\nl-NL\wmiutils.dll.mui - Ok
C:\Windows\system32\wbem\xml\cim20.dtd - Ok
C:\Windows\system32\wbem\xml\wmi20.dtd - Ok
C:\Windows\system32\wbem\nl-NL\WMIsvc.dll.mui - Ok
C:\Windows\system32\wdi\LogFiles\WdiContextLog.etl.002 - Ok
C:\Windows\system32\wdi\perftrack\AltTab.ptxml - Ok
C:\Windows\system32\wbem\nl-NL\WMIC.exe.mui - Ok
C:\Windows\system32\wdi\perftrack\comdlg32.ptxml - Ok
C:\Windows\system32\wdi\perftrack\AppInfoEvents.ptxml - Ok
C:\Windows\system32\wbem\xml\wmi2xml.dll - Ok
C:\Windows\system32\wdi\perftrack\authui.ptxml - Ok
C:\Windows\system32\wdi\ShutdownPerformanceDiagnostics_SystemData.bin - Ok
C:\Windows\system32\wdi\LogFiles\ShutdownCKCL.etl - Ok
C:\Windows\system32\wdi\perftrack\DiagCpl.Events.ptxml - Ok
C:\Windows\system32\wdi\perftrack\DeviceUx.ptxml - Ok
C:\Windows\system32\wdi\LogFiles\BootCKCL.etl - Ok
C:\Windows\system32\wdi\perftrack\Core-Fundamentals-ClientPerformance-Perftrack.ptxml - Ok
C:\Windows\system32\wdi\perftrack\Display.ptxml - Ok
C:\Windows\system32\wbem\Logs\wmiprov.lo_ - Ok
C:\Windows\system32\wdi\perftrack\DXP-DeviceExperience.ptxml - Ok
C:\Windows\system32\wdi\perftrack\HealthCenterCPLInstrumentation.ptxml - Ok
C:\Windows\system32\wdi\perftrack\ETWInstrumentation.ptxml - Ok
C:\Windows\system32\wdi\perftrack\DriverFrameworks-UserMode.ptxml - Ok
C:\Windows\system32\wdi\perftrack\HealthCenterInstrumentation.ptxml - Ok
C:\Windows\system32\wdi\perftrack\ErrorReportingConsole.ptxml - Ok
C:\Windows\system32\wdi\perftrack\LDDMCore.ptxml - Ok
C:\Windows\system32\wdi\perftrack\Help-DataLayer.ptxml - Ok
C:\Windows\system32\wdi\LogFiles\WdiContextLog.etl.001 - Ok
C:\Windows\system32\wdi\perftrack\DisplaySwitch.ptxml - Ok
C:\Windows\system32\wdi\perftrack\msdt.events.ptxml - Ok
C:\Windows\system32\wdi\perftrack\Microsoft-Windows-VAN.ptxml - Ok
C:\Windows\system32\wdi\perftrack\Microsoft-Windows-WLANConnectionFlow.ptxml - Ok
C:\Windows\system32\wdi\perftrack\Microsoft-Windows-TabletPC-InputPanel-Events.ptxml - Ok
C:\Windows\system32\wdi\perftrack\Microsoft-Windows-NCSI.ptxml - Ok
C:\Windows\system32\wdi\perftrack\DhcpClientDll.ptxml - Ok
C:\Windows\system32\wdi\perftrack\NetworkConnectionsFolder.ptxml - Ok
C:\Windows\system32\wdi\perftrack\Microsoft-Windows-IE-HTMLRendering.ptxml - Ok
C:\Windows\system32\wdi\perftrack\powercpl.ptxml - Ok
C:\Windows\system32\wdi\LogFiles\WdiContextLog.etl.003 - Ok
C:\Windows\system32\wdi\perftrack\NlaSvc.ptxml - Ok
C:\Windows\system32\wdi\perftrack\prod_WMPPlayer.ptxml - Ok
C:\Windows\system32\wdi\perftrack\Services.ptxml - Ok
C:\Windows\system32\wdi\perftrack\NetworkDiagnosticsFramework.ptxml - Ok
C:\Windows\system32\wdi\perftrack\profsvc.ptxml - Ok
C:\Windows\system32\wdi\perftrack\StobjectInstrumentation.ptxml - Ok
C:\Windows\system32\wdi\perftrack\Spux.ptxml - Ok
C:\Windows\system32\wdi\perftrack\Sidebar.ptxml - Ok
C:\Windows\system32\wdi\perftrack\provsvc.ptxml - Ok
C:\Windows\system32\wdi\perftrack\prod_Audio-AudioCore.ptxml - Ok
C:\Windows\system32\wdi\perftrack\UIAutomationCore.ptxml - Ok
C:\Windows\system32\wdi\perftrack\taskmgr.events.ptxml - Ok
C:\Windows\system32\wdi\perftrack\NetworkProfile.ptxml - Ok
C:\Windows\system32\wdi\perftrack\Microsoft-Windows-Documents-Events.ptxml - Ok
C:\Windows\system32\wdi\perftrack\wdc.events.ptxml - Ok
C:\Windows\system32\wdi\perftrack\WinlogonEvents.ptxml - Ok
C:\Windows\system32\wdi\perftrack\WpdCoreInstrumentation.ptxml - Ok
C:\Windows\system32\wdi\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-3111613574-2524581245-2586426736-500_UserData.bin - Ok
C:\Windows\system32\wdi\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-1159550464-2611606491-1380218214-500_UserData.bin - Ok
C:\Windows\system32\wdi\perftrack\userplugplayetw.ptxml - Ok
C:\Windows\system32\wdi\perftrack\WinINet.ETW.ptxml - Ok
C:\Windows\system32\wdi\perftrack\themecpl.ptxml - Ok
C:\Windows\system32\wdi\perftrack\timedate.ptxml - Ok
C:\Windows\system32\wfp\wfpdiag.etl - Ok
C:\Windows\system32\wdi\perftrack\VolumeControl.ptxml - Ok
C:\Windows\system32\wdi\perftrack\ieframe.ptxml - Ok
C:\Windows\system32\winevt\Logs\Doctor Web.evtx - Ok
C:\Windows\system32\wdi\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\{c397ad01-b868-4d0e-b5a4-abb6c799c322}\snapshot.etl - Ok
C:\Windows\system32\winevt\Logs\HardwareEvents.evtx - Ok
C:\Windows\system32\wdi\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\{2861e9cf-8b0f-4546-824a-627c21566123}\snapshot.etl - Ok
C:\Windows\system32\winevt\Logs\Hewlett-Packard.evtx - Ok
C:\Windows\system32\winevt\Logs\HP Software Framework.evtx - Ok
C:\Windows\system32\wdi\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\{532e28d2-d3b3-4bd5-8223-fa9916341c6f}\snapshot.etl - Ok
C:\Windows\system32\winevt\Logs\Media Center.evtx - Ok
C:\Windows\system32\winevt\Logs\Key Management Service.evtx - Ok
C:\Windows\system32\winevt\Logs\ACEEventLog.evtx - Ok
C:\Windows\system32\winevt\Logs\Internet Explorer.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Application-Experience%4Program-Compatibility-Troubleshooter.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Audio%4CaptureMonitor.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Application-Experience%4Program-Compatibility-Assistant.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Application-Experience%4Problem-Steps-Recorder.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Audio%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Application-Experience%4Program-Telemetry.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-CodeIntegrity%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Application-Experience%4Program-Inventory.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Dhcpv6-Client%4Admin.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Diagnosis-Scheduled%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Dhcp-Client%4Admin.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Diagnosis-Scripted%4Admin.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Diagnosis-Scripted%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Diagnostics-Networking%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Diagnosis-ScriptedDiagnosticsProvider%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Diagnostics-Performance%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-DiskDiagnosticDataCollector%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Fault-Tolerant-Heap%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Diagnosis-DPS%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Application.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Help%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Bits-Client%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-HomeGroup Provider Service%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Kernel-EventTracing%4Admin.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-International%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Kernel-StoreMgr%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Kernel-WHEA%4Errors.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-DriverFrameworks-UserMode%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-LanguagePackSetup%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-MUI%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-MUI%4Admin.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-NCSI%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-NetworkAccessProtection%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-NetworkAccessProtection%4WHC.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-NetworkLocationWizard%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\DebugChannel.etl - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Authentication User Interface%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-NlaSvc%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-ParentalControls%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-PrintService%4Admin.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-ReliabilityAnalysisComponent%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-GroupPolicy%4Operational.evtx - Ok
C:\Windows\system32\wdi\perftrack\Wlansvc.ptxml - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-ReadyBoost%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Resource-Exhaustion-Detector%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Resource-Exhaustion-Resolver%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-RestartManager%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-TerminalServices-LocalSessionManager%4Admin.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-UAC-FileVirtualization%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Kernel-Power%4Thermal-Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Windows Defender%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Windows Defender%4WHC.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-WER-Diag%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-TerminalServices-LocalSessionManager%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Kernel-WHEA%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-WindowsSystemAssessmentTool%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-WindowsBackup%4ActionCenter.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Winlogon%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-NetworkProfile%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-WindowsUpdateClient%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Windows Firewall With Advanced Security%4ConnectionSecurity.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-WPD-MTPClassDriver%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-WPD-ClassInstaller%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Setup.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Windows Firewall With Advanced Security%4Firewall.evtx - Ok
C:\Windows\system32\winevt\Logs\Windows PowerShell.evtx - Ok
C:\Windows\system32\winevt\Logs\TuneUp.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-WLAN-AutoConfig%4Operational.evtx - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-User Profile Service%4Operational.evtx - Ok
C:\Windows\system32\winrm\0413\winrm.ini - Ok
C:\Windows\system32\wdi\perftrack\ShellCoreInstrumentation.ptxml - Ok
C:\Windows\system32\zh-CN\DWrite.dll.mui - Ok
C:\Windows\system32\zh-CN\FntCache.dll.mui - Ok
C:\Windows\system32\winevt\Logs\System.evtx - Ok
C:\Windows\system32\zh-CN\mlang.dll.mui - Ok
C:\Windows\system32\zh-CN\fms.dll.mui - Ok
C:\Windows\system32\zh-CN\msimsg.dll.mui - Ok
C:\Windows\system32\winevt\Logs\Microsoft-Windows-Known Folders API Service.evtx - Ok
C:\Windows\system32\zh-HK\comctl32.dll.mui - Ok
C:\Windows\system32\zh-HK\fms.dll.mui - Ok
C:\Windows\system32\zh-HK\comdlg32.dll.mui - Ok
C:\Windows\system32\zh-CN\comdlg32.dll.mui - Ok
C:\Windows\system32\zh-CN\comctl32.dll.mui - Ok
C:\Windows\system32\zh-HK\FntCache.dll.mui - Ok
C:\Windows\system32\zh-CN\WMPhoto.dll.mui - Ok
C:\Windows\system32\zh-HK\WMPhoto.dll.mui - Ok
C:\Windows\system32\zh-HK\d2d1.dll.mui - Ok
C:\Windows\system32\winevt\Logs\Security.evtx - Ok
C:\Windows\system32\zh-TW\comdlg32.dll.mui - Ok
C:\Windows\system32\zh-HK\mlang.dll.mui - Ok
C:\Windows\system32\zh-CN\msprivs.dll.mui - Ok
C:\Windows\system32\zh-TW\comctl32.dll.mui - Ok
C:\Windows\system32\zh-TW\fms.dll.mui - Ok
C:\Windows\system32\zh-TW\cdosys.dll.mui - Ok
C:\Windows\system32\zh-TW\WMPhoto.dll.mui - Ok
C:\Windows\system32\zh-TW\msprivs.dll.mui - Ok
C:\Windows\system32\zh-CN\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\12520850.cpx - Ok
C:\Windows\SysWOW64\12520437.cpx - Ok
C:\Windows\system32\zh-TW\msimsg.dll.mui - Ok
C:\Windows\system32\zh-HK\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\aaclient.dll - Ok
C:\Windows\system32\zh-TW\DWrite.dll.mui - Ok
C:\Windows\system32\zh-TW\FntCache.dll.mui - Ok
C:\Windows\SysWOW64\acledit.dll - Ok
C:\Windows\system32\zh-TW\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\aclui.dll - Ok
C:\Windows\system32\zh-TW\mlang.dll.mui - Ok
C:\Windows\SysWOW64\actxprxy.dll - Ok
C:\Windows\SysWOW64\ACCTRES.dll - Ok
C:\Windows\SysWOW64\AdapterTroubleshooter.exe - Ok
C:\Windows\SysWOW64\activeds.dll - Ok
C:\Windows\SysWOW64\adsldpc.dll - Ok
C:\Windows\SysWOW64\adsmsext.dll - Ok
C:\Windows\system32\zh-CN\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\adsldp.dll - Ok
C:\Windows\SysWOW64\ActionCenter.dll - Ok
C:\Windows\SysWOW64\aecache.dll - Ok
C:\Windows\SysWOW64\activeds.tlb - Ok
C:\Windows\SysWOW64\advpack.dll - Ok
C:\Windows\SysWOW64\adprovider.dll - Ok
C:\Windows\SysWOW64\advapi32.dll - Ok
C:\Windows\SysWOW64\aeevts.dll - Ok
C:\Windows\SysWOW64\acppage.dll - Ok
C:\Windows\SysWOW64\ActionCenterCPL.dll - Ok
C:\Windows\SysWOW64\AltTab.dll - Ok
C:\Windows\SysWOW64\amxread.dll - Ok
C:\Windows\SysWOW64\api-ms-win-core-datetime-l1-1-0.dll - Ok
>C:\Windows\SysWOW64\api-ms-win-core-console-l1-1-0.dll - packed by FLY-CODE
C:\Windows\SysWOW64\amdpcom32.dll - Ok
C:\Windows\SysWOW64\api-ms-win-core-console-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-core-delayload-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-core-fibers-l1-1-0.dll - Ok
C:\Windows\system32\winevt\Logs\OAlerts.evtx - Ok
>C:\Windows\SysWOW64\api-ms-win-core-file-l1-1-0.dll - packed by FLY-CODE
C:\Windows\SysWOW64\amcompat.tlb - Ok
C:\Windows\SysWOW64\api-ms-win-core-file-l1-1-0.dll - Ok
C:\Windows\SysWOW64\amstream.dll - Ok
C:\Windows\SysWOW64\api-ms-win-core-debug-l1-1-0.dll - Ok
>C:\Windows\SysWOW64\api-ms-win-core-localization-l1-1-0.dll - packed by FLY-CODE
C:\Windows\SysWOW64\api-ms-win-core-localization-l1-1-0.dll - Ok
>C:\Windows\SysWOW64\api-ms-win-core-errorhandling-l1-1-0.dll - packed by FLY-CODE
C:\Windows\SysWOW64\api-ms-win-core-errorhandling-l1-1-0.dll - Ok
>C:\Windows\SysWOW64\api-ms-win-core-localregistry-l1-1-0.dll - packed by FLY-CODE
>C:\Windows\SysWOW64\api-ms-win-core-io-l1-1-0.dll - packed by FLY-CODE
>C:\Windows\SysWOW64\api-ms-win-core-interlocked-l1-1-0.dll - packed by FLY-CODE
C:\Windows\SysWOW64\api-ms-win-core-handle-l1-1-0.dll - Ok
>C:\Windows\SysWOW64\api-ms-win-core-libraryloader-l1-1-0.dll - packed by FLY-CODE
C:\Windows\SysWOW64\api-ms-win-core-localregistry-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-core-io-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-core-interlocked-l1-1-0.dll - Ok
>C:\Windows\SysWOW64\api-ms-win-core-heap-l1-1-0.dll - packed by FLY-CODE
C:\Windows\SysWOW64\api-ms-win-core-libraryloader-l1-1-0.dll - Ok
>C:\Windows\SysWOW64\api-ms-win-core-memory-l1-1-0.dll - packed by FLY-CODE
>C:\Windows\SysWOW64\api-ms-win-core-namedpipe-l1-1-0.dll - packed by FLY-CODE
>C:\Windows\SysWOW64\api-ms-win-core-processenvironment-l1-1-0.dll - packed by FLY-CODE
>C:\Windows\SysWOW64\api-ms-win-core-misc-l1-1-0.dll - packed by FLY-CODE
C:\Windows\SysWOW64\api-ms-win-core-heap-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-core-processenvironment-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-core-misc-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-core-namedpipe-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-core-memory-l1-1-0.dll - Ok
C:\Windows\SysWOW64\adtschema.dll - Ok
>C:\Windows\SysWOW64\api-ms-win-core-threadpool-l1-1-0.dll - packed by FLY-CODE
>C:\Windows\SysWOW64\api-ms-win-core-string-l1-1-0.dll - packed by FLY-CODE
>C:\Windows\SysWOW64\api-ms-win-core-synch-l1-1-0.dll - packed by FLY-CODE
>C:\Windows\SysWOW64\api-ms-win-core-sysinfo-l1-1-0.dll - packed by FLY-CODE
C:\Windows\SysWOW64\api-ms-win-core-string-l1-1-0.dll - Ok
C:\Windows\SysWOW64\adsnt.dll - Ok
C:\Windows\SysWOW64\api-ms-win-core-threadpool-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-core-util-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-core-synch-l1-1-0.dll - Ok
>C:\Windows\SysWOW64\api-ms-win-core-processthreads-l1-1-0.dll - packed by FLY-CODE
C:\Windows\SysWOW64\api-ms-win-core-profile-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-downlevel-advapi32-l2-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-downlevel-normaliz-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-downlevel-advapi32-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-downlevel-shell32-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-downlevel-ole32-l1-1-0.dll - Ok
>C:\Windows\SysWOW64\api-ms-win-core-xstate-l1-1-0.dll - packed by FLY-CODE
C:\Windows\SysWOW64\api-ms-win-downlevel-shlwapi-l2-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-downlevel-user32-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-core-processthreads-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-core-rtlsupport-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-downlevel-shlwapi-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-downlevel-version-l1-1-0.dll - Ok
>C:\Windows\SysWOW64\api-ms-win-security-sddl-l1-1-0.dll - packed by FLY-CODE
>C:\Windows\SysWOW64\api-ms-win-security-base-l1-1-0.dll - packed by FLY-CODE
C:\Windows\SysWOW64\api-ms-win-core-sysinfo-l1-1-0.dll - Ok
>C:\Windows\SysWOW64\api-ms-win-security-lsalookup-l1-1-0.dll - packed by FLY-CODE
C:\Windows\SysWOW64\api-ms-win-core-xstate-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-service-core-l1-1-0.dll - Ok
>C:\Windows\SysWOW64\api-ms-win-service-management-l1-1-0.dll - packed by FLY-CODE
>C:\Windows\SysWOW64\api-ms-win-service-winsvc-l1-1-0.dll - packed by FLY-CODE
>C:\Windows\SysWOW64\api-ms-win-service-management-l2-1-0.dll - packed by FLY-CODE
C:\Windows\SysWOW64\api-ms-win-security-sddl-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-security-lsalookup-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-security-base-l1-1-0.dll - Ok
C:\Windows\SysWOW64\apisetschema.dll - Ok
C:\Windows\SysWOW64\AppLog.log - Ok
C:\Windows\SysWOW64\api-ms-win-service-winsvc-l1-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-service-management-l2-1-0.dll - Ok
C:\Windows\SysWOW64\api-ms-win-service-management-l1-1-0.dll - Ok
C:\Windows\SysWOW64\apilogen.dll - Ok
C:\Windows\SysWOW64\Apphlpdm.dll - Ok
C:\Windows\SysWOW64\asferror.dll - Ok
C:\Windows\SysWOW64\appidapi.dll - Ok
C:\Windows\SysWOW64\ARP.EXE - Ok
C:\Windows\SysWOW64\apphelp.dll - Ok
C:\Windows\SysWOW64\asycfilt.dll - Ok
C:\Windows\SysWOW64\accessibilitycpl.dll - Ok
C:\Windows\SysWOW64\apircl.dll - Ok
C:\Windows\SysWOW64\AtBroker.exe - Ok
C:\Windows\SysWOW64\at.exe - Ok
C:\Windows\SysWOW64\ati2edxx.dll - Ok
C:\Windows\SysWOW64\aticalcl.dll - Ok
C:\Windows\SysWOW64\aticalrt.dll - Ok
C:\Windows\SysWOW64\atigktxx.dll - Ok
C:\Windows\SysWOW64\apss.dll - Ok
C:\Windows\SysWOW64\atiadlxy.dll - Ok
C:\Windows\SysWOW64\atiglpxx.dll - Ok
C:\Windows\SysWOW64\atipblag.dat - Ok
C:\Windows\SysWOW64\atipblup.dat - Ok
C:\Windows\SysWOW64\atimpc32.dll - Ok
C:\Windows\SysWOW64\atiu9pag.dll - Ok
C:\Windows\SysWOW64\apds.dll - Ok
C:\Windows\SysWOW64\atiumdva.cap - Ok
C:\Windows\SysWOW64\appwiz.cpl - Ok
C:\Windows\SysWOW64\atiuxpag.dll - Ok
C:\Windows\SysWOW64\aticfx32.dll - Ok
C:\Windows\SysWOW64\atl.dll - Ok
C:\Windows\SysWOW64\atl71.dll - Ok
C:\Windows\SysWOW64\atipdlxx.dll - Ok
C:\Windows\SysWOW64\atmlib.dll - Ok
C:\Windows\SysWOW64\atl100.dll - Ok
C:\Windows\SysWOW64\audiodev.dll - Ok
C:\Windows\SysWOW64\attrib.exe - Ok
C:\Windows\SysWOW64\AudioSes.dll - Ok
C:\Windows\SysWOW64\auditpol.exe - Ok
C:\Windows\SysWOW64\AudioEng.dll - Ok
C:\Windows\SysWOW64\AUDIOKSE.dll - Ok
C:\Windows\SysWOW64\authfwcfg.dll - Ok
C:\Windows\SysWOW64\AuthFWWizFwk.dll - Ok
C:\Windows\SysWOW64\atiumdag.dll - Ok
C:\Windows\SysWOW64\atmfd.dll - Ok
C:\Windows\SysWOW64\authz.dll - Ok
C:\Windows\SysWOW64\AuthFWGP.dll - Ok
C:\Windows\SysWOW64\atiumdmv.dll - Ok
>C:\Windows\SysWOW64\authui.dll is ZLIB container
C:\Windows\SysWOW64\autochk.exe - Ok
C:\Windows\SysWOW64\authui.dll - container
C:\Windows\SysWOW64\AuxiliaryDisplayApi.dll - Ok
C:\Windows\SysWOW64\autoplay.dll - Ok
C:\Windows\SysWOW64\avifil32.dll - Ok
C:\Windows\SysWOW64\aticaldd.dll - Ok
C:\Windows\SysWOW64\avicap32.dll - Ok
C:\Windows\SysWOW64\avrt.dll - Ok
C:\Windows\SysWOW64\azman.msc - Ok
C:\Windows\SysWOW64\AzSqlExt.dll - Ok
C:\Windows\SysWOW64\autoconv.exe - Ok
C:\Windows\SysWOW64\AuxiliaryDisplayCpl.dll - Ok
C:\Windows\SysWOW64\autofmt.exe - Ok
C:\Windows\SysWOW64\bcrypt.dll - Ok
C:\Windows\SysWOW64\basecsp.dll - Ok
C:\Windows\SysWOW64\bdaplgin.ax - Ok
C:\Windows\SysWOW64\bidispl.dll - Ok
C:\Windows\SysWOW64\azroles.dll - Ok
C:\Windows\SysWOW64\bcryptprimitives.dll - Ok
C:\Windows\SysWOW64\BioCredProv.dll - Ok
C:\Windows\SysWOW64\bitsprx4.dll - Ok
C:\Windows\SysWOW64\bitsperf.dll - Ok
C:\Windows\SysWOW64\bitsprx3.dll - Ok
C:\Windows\SysWOW64\azroleui.dll - Ok
>C:\Windows\SysWOW64\bitsprx2.dll - packed by FLY-CODE
C:\Windows\SysWOW64\bitsadmin.exe - Ok
C:\Windows\SysWOW64\boot.sdi - Ok
C:\Windows\SysWOW64\bitsprx6.dll - Ok
C:\Windows\SysWOW64\bopomofo.uce - Ok
C:\Windows\SysWOW64\bitsprx5.dll - Ok
C:\Windows\SysWOW64\BOOTVID.DLL - Ok
C:\Windows\SysWOW64\browcli.dll - Ok
C:\Windows\SysWOW64\batmeter.dll - Ok
C:\Windows\SysWOW64\bitsprx2.dll - Ok
C:\Windows\SysWOW64\bootcfg.exe - Ok
C:\Windows\SysWOW64\browseui.dll - Ok
C:\Windows\SysWOW64\btpanui.dll - Ok
C:\Windows\SysWOW64\atiumdva.dll - Ok
C:\Windows\SysWOW64\BWUnpairElevated.dll - Ok
C:\Windows\SysWOW64\BWContextHandler.dll - Ok
C:\Windows\SysWOW64\bthudtask.exe - Ok
C:\Windows\SysWOW64\cabinet.dll - Ok
C:\Windows\SysWOW64\bthprops.cpl - Ok
C:\Windows\SysWOW64\cacls.exe - Ok
C:\Windows\SysWOW64\capisp.dll - Ok
C:\Windows\SysWOW64\cabview.dll - Ok
C:\Windows\SysWOW64\atidxx32.dll - Ok
C:\Windows\SysWOW64\capiprovider.dll - Ok
C:\Windows\SysWOW64\blackbox.dll - Ok
>C:\Windows\SysWOW64\cero.rs is ZLIB container
C:\Windows\SysWOW64\cca.dll - Ok
C:\Windows\SysWOW64\catsrvps.dll - Ok
C:\Windows\SysWOW64\cero.rs - container
C:\Windows\SysWOW64\certCredProvider.dll - Ok
C:\Windows\SysWOW64\catsrv.dll - Ok
C:\Windows\SysWOW64\certenc.dll - Ok
C:\Windows\SysWOW64\certcli.dll - Ok
C:\Windows\SysWOW64\catsrvut.dll - Ok
C:\Windows\SysWOW64\Bubbles.scr - Ok
C:\Windows\SysWOW64\certmgr.msc - Ok
C:\Windows\SysWOW64\CertEnrollCtrl.exe - Ok
C:\Windows\SysWOW64\CertEnrollUI.dll - Ok
>C:\Windows\SysWOW64\calc.exe is ZLIB container
C:\Windows\SysWOW64\cfgbkend.dll - Ok
C:\Windows\SysWOW64\certreq.exe - Ok
C:\Windows\SysWOW64\calc.exe - container
C:\Windows\SysWOW64\cfgmgr32.dll - Ok
C:\Windows\SysWOW64\cewmdm.dll - Ok
C:\Windows\SysWOW64\CertPolEng.dll - Ok
C:\Windows\SysWOW64\chcp.com - Ok
C:\Windows\SysWOW64\chkntfs.exe - Ok
C:\Windows\SysWOW64\amdocl.dll - Ok
C:\Windows\SysWOW64\chkdsk.exe - Ok
C:\Windows\SysWOW64\chajei.ime - Ok
>C:\Windows\SysWOW64\cdosys.dll is BINARYRES container
>>C:\Windows\SysWOW64\cdosys.dll\data001 is JS-HTML container
C:\Windows\SysWOW64\cdosys.dll - container
C:\Windows\SysWOW64\choice.exe - Ok
C:\Windows\SysWOW64\cic.dll - Ok
C:\Windows\SysWOW64\charmap.exe - Ok
C:\Windows\SysWOW64\CertEnroll.dll - Ok
C:\Windows\SysWOW64\CHxReadingStringIME.dll - Ok
C:\Windows\SysWOW64\AuthFWSnapin.dll - Ok
C:\Windows\SysWOW64\certmgr.dll - Ok
C:\Windows\SysWOW64\cintlgnt.ime - Ok
C:\Windows\SysWOW64\clb.dll - Ok
C:\Windows\SysWOW64\cipher.exe - Ok
C:\Windows\SysWOW64\clfsw32.dll - Ok
C:\Windows\SysWOW64\clbcatq.dll - Ok
C:\Windows\SysWOW64\cleanmgr.exe - Ok
C:\Windows\SysWOW64\clip.exe - Ok
C:\Windows\SysWOW64\cliconfg.rll - Ok
C:\Windows\SysWOW64\cliconfg.exe - Ok
C:\Windows\SysWOW64\cliconfg.dll - Ok
C:\Windows\SysWOW64\certutil.exe - Ok
C:\Windows\SysWOW64\chsbrkr.dll - Ok
C:\Windows\SysWOW64\cmdkey.exe - Ok
>C:\Windows\SysWOW64\cmcfg32.dll - packed by FLY-CODE
C:\Windows\SysWOW64\clusapi.dll - Ok
C:\Windows\SysWOW64\cmifw.dll - Ok
C:\Windows\SysWOW64\cmlua.dll - Ok
C:\Windows\SysWOW64\cmicryptinstall.dll - Ok
C:\Windows\SysWOW64\cmdl32.exe - Ok
C:\Windows\SysWOW64\cmstplua.dll - Ok
C:\Windows\SysWOW64\cmd.exe - Ok
C:\Windows\SysWOW64\cmcfg32.dll - Ok
C:\Windows\SysWOW64\cmutil.dll - Ok
C:\Windows\SysWOW64\cngaudit.dll - Ok
C:\Windows\SysWOW64\cmmon32.exe - Ok
C:\Windows\SysWOW64\cngprovider.dll - Ok
C:\Windows\SysWOW64\cmpbk32.dll - Ok
C:\Windows\SysWOW64\cmipnpinstall.dll - Ok
C:\Windows\SysWOW64\cnvfat.dll - Ok
C:\Windows\SysWOW64\cmdial32.dll - Ok
C:\Windows\SysWOW64\colbact.dll - Ok
C:\Windows\SysWOW64\colorcpl.exe - Ok
C:\Windows\SysWOW64\cmstp.exe - Ok
C:\Windows\SysWOW64\cob-au.rs - Ok
C:\Windows\SysWOW64\comexp.msc - Ok
C:\Windows\SysWOW64\comp.exe - Ok
C:\Windows\SysWOW64\compobj.dll - Ok
C:\Windows\SysWOW64\compmgmt.msc - Ok
C:\Windows\SysWOW64\compact.exe - Ok
C:\Windows\SysWOW64\comdlg32.dll - Ok
C:\Windows\SysWOW64\comcat.dll - Ok
C:\Windows\SysWOW64\comrepl.dll - Ok
C:\Windows\SysWOW64\COLORCNV.DLL - Ok
C:\Windows\SysWOW64\ComputerDefaults.exe - Ok
C:\Windows\SysWOW64\compstui.dll - Ok
C:\Windows\SysWOW64\colorui.dll - Ok
C:\Windows\SysWOW64\convert.exe - Ok
C:\Windows\SysWOW64\credssp.dll - Ok
C:\Windows\SysWOW64\comsnap.dll - Ok
C:\Windows\SysWOW64\console.dll - Ok
C:\Windows\SysWOW64\credwiz.exe - Ok
C:\Windows\SysWOW64\comuid.dll - Ok
C:\Windows\SysWOW64\chtbrkr.dll - Ok
C:\Windows\SysWOW64\credui.dll - Ok
C:\Windows\SysWOW64\comctl32.dll - Ok
C:\Windows\SysWOW64\cryptdlg.dll - Ok
C:\Windows\SysWOW64\cryptdll.dll - Ok
C:\Windows\SysWOW64\control.exe - Ok
C:\Windows\SysWOW64\CPFilters.dll - Ok
C:\Windows\SysWOW64\crtdll.dll - Ok
C:\Windows\SysWOW64\cryptext.dll - Ok
C:\Windows\SysWOW64\cryptnet.dll - Ok
C:\Windows\SysWOW64\cryptbase.dll - Ok
C:\Windows\SysWOW64\cryptsp.dll - Ok
C:\Windows\SysWOW64\cscdll.dll - Ok
C:\Windows\SysWOW64\cscapi.dll - Ok
C:\Windows\SysWOW64\cryptxml.dll - Ok
C:\Windows\SysWOW64\csrr.rs - Ok
C:\Windows\SysWOW64\crypt32.dll - Ok
C:\Windows\SysWOW64\cryptsvc.dll - Ok
C:\Windows\SysWOW64\C_037.NLS - Ok
C:\Windows\SysWOW64\C_10000.NLS - Ok
C:\Windows\SysWOW64\ctfmon.exe - Ok
>C:\Windows\SysWOW64\cryptui.dll - packed by FLY-CODE
C:\Windows\SysWOW64\comsvcs.dll - Ok
C:\Windows\SysWOW64\cscript.exe - Ok
C:\Windows\SysWOW64\C_10004.NLS - Ok
C:\Windows\SysWOW64\CSVer.dll - Ok
C:\Windows\SysWOW64\C_10003.NLS - Ok
C:\Windows\SysWOW64\C_10001.NLS - Ok
C:\Windows\SysWOW64\C_10006.NLS - Ok
C:\Windows\SysWOW64\ctl3d32.dll - Ok
C:\Windows\SysWOW64\C_10007.NLS - Ok
C:\Windows\SysWOW64\C_10005.NLS - Ok
C:\Windows\SysWOW64\C_10017.NLS - Ok
C:\Windows\SysWOW64\cttunesvr.exe - Ok
C:\Windows\SysWOW64\C_10008.NLS - Ok
C:\Windows\SysWOW64\C_10010.NLS - Ok
C:\Windows\SysWOW64\C_10021.NLS - Ok
C:\Windows\SysWOW64\C_10079.NLS - Ok
C:\Windows\SysWOW64\C_10081.NLS - Ok
C:\Windows\SysWOW64\C_10029.NLS - Ok
C:\Windows\SysWOW64\C_10082.NLS - Ok
C:\Windows\SysWOW64\C_1047.NLS - Ok
C:\Windows\SysWOW64\C_1141.NLS - Ok
C:\Windows\SysWOW64\C_1026.NLS - Ok
C:\Windows\SysWOW64\C_1140.NLS - Ok
C:\Windows\SysWOW64\C_1143.NLS - Ok
C:\Windows\SysWOW64\C_1142.NLS - Ok
C:\Windows\SysWOW64\C_1144.NLS - Ok
C:\Windows\SysWOW64\C_10002.NLS - Ok
C:\Windows\SysWOW64\C_1147.NLS - Ok
C:\Windows\SysWOW64\C_1146.NLS - Ok
C:\Windows\SysWOW64\C_1148.NLS - Ok
C:\Windows\SysWOW64\C_1145.NLS - Ok
C:\Windows\SysWOW64\C_1250.NLS - Ok
C:\Windows\SysWOW64\C_1252.NLS - Ok
C:\Windows\SysWOW64\C_1251.NLS - Ok
C:\Windows\SysWOW64\C_1254.NLS - Ok
C:\Windows\SysWOW64\C_1256.NLS - Ok
C:\Windows\SysWOW64\C_1255.NLS - Ok
C:\Windows\SysWOW64\C_1258.NLS - Ok
C:\Windows\SysWOW64\C_1149.NLS - Ok
C:\Windows\SysWOW64\C_1257.NLS - Ok
C:\Windows\SysWOW64\C_1253.NLS - Ok
C:\Windows\SysWOW64\C_1361.NLS - Ok
C:\Windows\SysWOW64\C_20000.NLS - Ok
C:\Windows\SysWOW64\C_20002.NLS - Ok
C:\Windows\SysWOW64\C_20001.NLS - Ok
C:\Windows\SysWOW64\C_20004.NLS - Ok
C:\Windows\SysWOW64\C_20003.NLS - Ok
C:\Windows\SysWOW64\C_20106.NLS - Ok
C:\Windows\SysWOW64\C_20105.NLS - Ok
C:\Windows\SysWOW64\C_20127.NLS - Ok
C:\Windows\SysWOW64\C_20108.NLS - Ok
C:\Windows\SysWOW64\C_20269.NLS - Ok
C:\Windows\SysWOW64\C_20107.NLS - Ok
C:\Windows\SysWOW64\C_20277.NLS - Ok
C:\Windows\SysWOW64\C_20278.NLS - Ok
C:\Windows\SysWOW64\C_20280.NLS - Ok
C:\Windows\SysWOW64\C_20273.NLS - Ok
C:\Windows\SysWOW64\C_20285.NLS - Ok
C:\Windows\SysWOW64\C_20297.NLS - Ok
C:\Windows\SysWOW64\C_20290.NLS - Ok
C:\Windows\SysWOW64\C_20005.NLS - Ok
C:\Windows\SysWOW64\C_20284.NLS - Ok
C:\Windows\SysWOW64\C_20420.NLS - Ok
C:\Windows\SysWOW64\C_20423.NLS - Ok
C:\Windows\SysWOW64\C_20424.NLS - Ok
C:\Windows\SysWOW64\C_20866.NLS - Ok
C:\Windows\SysWOW64\C_20871.NLS - Ok
C:\Windows\SysWOW64\C_20838.NLS - Ok
C:\Windows\SysWOW64\C_20880.NLS - Ok
C:\Windows\SysWOW64\C_20905.NLS - Ok
C:\Windows\SysWOW64\C_20924.NLS - Ok
C:\Windows\SysWOW64\cttune.exe - Ok
C:\Windows\SysWOW64\C_20833.NLS - Ok
C:\Windows\SysWOW64\connect.dll - Ok
C:\Windows\SysWOW64\C_21025.NLS - Ok
C:\Windows\SysWOW64\C_20932.NLS - Ok
C:\Windows\SysWOW64\C_21027.NLS - Ok
C:\Windows\SysWOW64\C_21866.NLS - Ok
C:\Windows\SysWOW64\C_20949.NLS - Ok
C:\Windows\SysWOW64\C_28594.NLS - Ok
C:\Windows\SysWOW64\C_28595.NLS - Ok
C:\Windows\SysWOW64\C_20936.NLS - Ok
C:\Windows\SysWOW64\C_28591.NLS - Ok
C:\Windows\SysWOW64\C_20261.NLS - Ok
C:\Windows\SysWOW64\C_28597.NLS - Ok
C:\Windows\SysWOW64\C_28592.NLS - Ok
C:\Windows\SysWOW64\C_28593.NLS - Ok
C:\Windows\SysWOW64\c_28603.nls - Ok
C:\Windows\SysWOW64\C_28605.NLS - Ok
C:\Windows\SysWOW64\C_28596.NLS - Ok
C:\Windows\SysWOW64\C_708.NLS - Ok
C:\Windows\SysWOW64\C_28598.NLS - Ok
C:\Windows\SysWOW64\C_500.NLS - Ok
C:\Windows\SysWOW64\C_720.NLS - Ok
C:\Windows\SysWOW64\C_28599.NLS - Ok
C:\Windows\SysWOW64\C_855.NLS - Ok
C:\Windows\SysWOW64\C_437.NLS - Ok
C:\Windows\SysWOW64\C_858.NLS - Ok
C:\Windows\SysWOW64\C_775.NLS - Ok
C:\Windows\SysWOW64\C_850.NLS - Ok
C:\Windows\SysWOW64\C_737.NLS - Ok
C:\Windows\SysWOW64\C_861.NLS - Ok
C:\Windows\SysWOW64\C_852.NLS - Ok
C:\Windows\SysWOW64\C_857.NLS - Ok
C:\Windows\SysWOW64\C_864.NLS - Ok
C:\Windows\SysWOW64\C_863.NLS - Ok
C:\Windows\SysWOW64\C_865.NLS - Ok
C:\Windows\SysWOW64\C_860.NLS - Ok
C:\Windows\SysWOW64\C_869.NLS - Ok
C:\Windows\SysWOW64\C_870.NLS - Ok
C:\Windows\SysWOW64\comres.dll - Ok
C:\Windows\SysWOW64\C_874.NLS - Ok
C:\Windows\SysWOW64\C_875.NLS - Ok
C:\Windows\SysWOW64\C_862.NLS - Ok
C:\Windows\SysWOW64\C_866.NLS - Ok
C:\Windows\SysWOW64\C_950.NLS - Ok
C:\Windows\SysWOW64\C_936.NLS - Ok
C:\Windows\SysWOW64\C_932.NLS - Ok
C:\Windows\SysWOW64\C_949.NLS - Ok
C:\Windows\SysWOW64\C_IS2022.DLL - Ok
C:\Windows\SysWOW64\C_ISCII.DLL - Ok
C:\Windows\SysWOW64\cryptui.dll - Ok
C:\Windows\SysWOW64\d3d8thk.dll - Ok
C:\Windows\SysWOW64\d3d10_1.dll - Ok
C:\Windows\SysWOW64\C_G18030.DLL - Ok
C:\Windows\SysWOW64\d3d10_1core.dll - Ok
C:\Windows\SysWOW64\d3d10core.dll - Ok
C:\Windows\SysWOW64\d3d11.dll - Ok
C:\Windows\SysWOW64\d3d10level9.dll - Ok
C:\Windows\SysWOW64\d3d10warp.dll - Ok
C:\Windows\SysWOW64\d3dim.dll - Ok
C:\Windows\SysWOW64\d3d10.dll - Ok
>C:\Windows\SysWOW64\d3dx10_41.dll - packed by PESTUB
C:\Windows\SysWOW64\d3dxof.dll - Ok
C:\Windows\SysWOW64\dataclen.dll - Ok
C:\Windows\SysWOW64\d3d8.dll - Ok
C:\Windows\SysWOW64\d2d1.dll - Ok
C:\Windows\SysWOW64\d3dramp.dll - Ok
C:\Windows\SysWOW64\davclnt.dll - Ok
C:\Windows\SysWOW64\davhlpr.dll - Ok
C:\Windows\SysWOW64\d3dx10_41.dll - Ok
C:\Windows\SysWOW64\d3dim700.dll - Ok
C:\Windows\SysWOW64\dbnmpntw.dll - Ok
C:\Windows\SysWOW64\d3dx10_42.dll - Ok
C:\Windows\SysWOW64\dbnetlib.dll - Ok
C:\Windows\SysWOW64\dciman32.dll - Ok
C:\Windows\SysWOW64\dbghelp.dll - Ok
C:\Windows\SysWOW64\dcomcnfg.exe - Ok
>C:\Windows\SysWOW64\DDACLSys.dll - packed by FLY-CODE
C:\Windows\SysWOW64\DDOIProxy.dll - Ok
C:\Windows\SysWOW64\ddodiag.exe - Ok
C:\Windows\SysWOW64\ddrawex.dll - Ok
C:\Windows\SysWOW64\DDACLSys.dll - Ok
C:\Windows\SysWOW64\d3d9.dll - Ok
C:\Windows\SysWOW64\deskadp.dll - Ok
C:\Windows\SysWOW64\ddraw.dll - Ok
>C:\Windows\SysWOW64\deskperf.dll - packed by FLY-CODE
C:\Windows\SysWOW64\deskmon.dll - Ok
>C:\Windows\SysWOW64\D3DCompiler_41.dll - packed by PESTUB
C:\Windows\SysWOW64\desk.cpl - Ok
C:\Windows\SysWOW64\devenum.dll - Ok
C:\Windows\SysWOW64\DeviceDisplayStatusManager.dll - Ok
C:\Windows\SysWOW64\atioglxx.dll - Ok
C:\Windows\SysWOW64\DeviceMetadataParsers.dll - Ok
C:\Windows\SysWOW64\deskperf.dll - Ok
C:\Windows\SysWOW64\defaultlocationcpl.dll - Ok
C:\Windows\SysWOW64\DevicePairingHandler.dll - Ok
C:\Windows\SysWOW64\DevicePairingProxy.dll - Ok
C:\Windows\SysWOW64\DeviceUxRes.dll - Ok
C:\Windows\SysWOW64\dccw.exe - Ok
C:\Windows\SysWOW64\DevicePairing.dll - Ok
C:\Windows\SysWOW64\DevicePairingWizard.exe - Ok
C:\Windows\SysWOW64\devobj.dll - Ok
C:\Windows\SysWOW64\devmgmt.msc - Ok
C:\Windows\SysWOW64\devrtl.dll - Ok
C:\Windows\SysWOW64\DevicePairingFolder.dll - Ok
C:\Windows\SysWOW64\DeviceCenter.dll - Ok
>C:\Windows\SysWOW64\dhcpcmonitor.dll - packed by FLY-CODE
C:\Windows\SysWOW64\devmgr.dll - Ok
C:\Windows\SysWOW64\DeviceProperties.exe - Ok
C:\Windows\SysWOW64\dfscli.dll - Ok
C:\Windows\SysWOW64\DfsShlEx.dll - Ok
C:\Windows\SysWOW64\dhcpcsvc.dll - Ok
C:\Windows\SysWOW64\dhcpcsvc6.dll - Ok
C:\Windows\SysWOW64\dhcpcmonitor.dll - Ok
>C:\Windows\SysWOW64\dfrgui.exe is ZLIB container
C:\Windows\SysWOW64\dbgeng.dll - Ok
C:\Windows\SysWOW64\dfrgui.exe - container
>C:\Windows\SysWOW64\d3dx9_32.dll - packed by PESTUB
C:\Windows\SysWOW64\DHCPQEC.DLL - Ok
C:\Windows\SysWOW64\dhcpcore6.dll - Ok
C:\Windows\SysWOW64\dialer.exe - Ok
C:\Windows\SysWOW64\dhcpcore.dll - Ok
C:\Windows\SysWOW64\dimsjob.dll - Ok
C:\Windows\SysWOW64\diantz.exe - Ok
C:\Windows\SysWOW64\dimsroam.dll - Ok
C:\Windows\SysWOW64\dhcpsapi.dll - Ok
C:\Windows\SysWOW64\diskcomp.com - Ok
C:\Windows\SysWOW64\D3DCompiler_41.dll - Ok
C:\Windows\SysWOW64\diskmgmt.msc - Ok
C:\Windows\SysWOW64\diskcopy.com - Ok
C:\Windows\SysWOW64\dinput.dll - Ok
C:\Windows\SysWOW64\dfshim.dll - Ok
C:\Windows\SysWOW64\dispex.dll - Ok
C:\Windows\SysWOW64\diskperf.exe - Ok
C:\Windows\SysWOW64\difxapi.dll - Ok
C:\Windows\SysWOW64\dinput8.dll - Ok
C:\Windows\SysWOW64\djctq.rs - Ok
C:\Windows\SysWOW64\Dism.exe - Ok
C:\Windows\SysWOW64\diskraid.exe - Ok
C:\Windows\SysWOW64\dmband.dll - Ok
C:\Windows\SysWOW64\dllhost.exe - Ok
C:\Windows\SysWOW64\DDORes.dll - Ok
C:\Windows\SysWOW64\dmdskres2.dll - Ok
C:\Windows\SysWOW64\dllhst3g.exe - Ok
C:\Windows\SysWOW64\diskpart.exe - Ok
C:\Windows\SysWOW64\dmcompos.dll - Ok
C:\Windows\SysWOW64\dmintf.dll - Ok
C:\Windows\SysWOW64\dmocx.dll - Ok
C:\Windows\SysWOW64\dmloader.dll - Ok
C:\Windows\SysWOW64\dmime.dll - Ok
C:\Windows\SysWOW64\dmdskmgr.dll - Ok
C:\Windows\SysWOW64\dmdlgs.dll - Ok
C:\Windows\SysWOW64\dmdskres.dll - Ok
C:\Windows\SysWOW64\diskcopy.dll - Ok
C:\Windows\SysWOW64\dmrc.dll - Ok
C:\Windows\SysWOW64\dmutil.dll - Ok
C:\Windows\SysWOW64\dmscript.dll - Ok
C:\Windows\SysWOW64\dmsynth.dll - Ok
C:\Windows\SysWOW64\DisplaySwitch.exe - Ok
C:\Windows\SysWOW64\dmusic.dll - Ok
C:\Windows\SysWOW64\d3dx9_32.dll - Ok
C:\Windows\SysWOW64\DOErrors.log - Ok
C:\Windows\SysWOW64\dmstyle.dll - Ok
C:\Windows\SysWOW64\dnssd.dll - Ok
C:\Windows\SysWOW64\dnsapi.dll - Ok
C:\Windows\SysWOW64\dmvdsitf.dll - Ok
C:\Windows\SysWOW64\dnscacheugc.exe - Ok
C:\Windows\SysWOW64\dnscmmc.dll - Ok
C:\Windows\SysWOW64\dns-sd.exe - Ok
C:\Windows\SysWOW64\dot3cfg.dll - Ok
C:\Windows\SysWOW64\Display.dll - Ok
C:\Windows\SysWOW64\doskey.exe - Ok
C:\Windows\SysWOW64\docprop.dll - Ok
C:\Windows\SysWOW64\dmview.ocx - Ok
C:\Windows\SysWOW64\dot3dlg.dll - Ok
C:\Windows\SysWOW64\dnssdX.dll - Ok
C:\Windows\SysWOW64\dot3gpclnt.dll - Ok
C:\Windows\SysWOW64\dot3hc.dll - Ok
C:\Windows\SysWOW64\dpnaddr.dll - Ok
C:\Windows\SysWOW64\dpapiprovider.dll - Ok
C:\Windows\SysWOW64\dot3msm.dll - Ok
C:\Windows\SysWOW64\dpapimig.exe - Ok
C:\Windows\SysWOW64\dot3api.dll - Ok
C:\Windows\SysWOW64\dpmodemx.dll - Ok
C:\Windows\SysWOW64\dpnhupnp.dll - Ok
C:\Windows\SysWOW64\DpiScaling.exe - Ok
C:\Windows\SysWOW64\dpnhpast.dll - Ok
C:\Windows\SysWOW64\dpnlobby.dll - Ok
C:\Windows\SysWOW64\dpnathlp.dll - Ok
C:\Windows\SysWOW64\dplaysvr.exe - Ok
C:\Windows\SysWOW64\dot3gpui.dll - Ok
C:\Windows\SysWOW64\dot3ui.dll - Ok
C:\Windows\SysWOW64\dpwsockx.dll - Ok
C:\Windows\SysWOW64\drprov.dll - Ok
C:\Windows\SysWOW64\drttransport.dll - Ok
C:\Windows\SysWOW64\dpnsvr.exe - Ok
C:\Windows\SysWOW64\driverquery.exe - Ok
C:\Windows\SysWOW64\drtprov.dll - Ok
C:\Windows\SysWOW64\dplayx.dll - Ok
C:\Windows\SysWOW64\dsauth.dll - Ok
C:\Windows\SysWOW64\ds32gt.dll - Ok
C:\Windows\SysWOW64\drt.dll - Ok
C:\Windows\SysWOW64\dskquota.dll - Ok
C:\Windows\SysWOW64\dpx.dll - Ok
>C:\Windows\SysWOW64\drvstore.dll - packed by BINARYRES
C:\Windows\SysWOW64\drvinst.exe - Ok
C:\Windows\SysWOW64\dpnet.dll - Ok
>>C:\Windows\SysWOW64\drvstore.dll - packed by MS COMPRESS
C:\Windows\SysWOW64\dsdmo.dll - Ok
C:\Windows\SysWOW64\dsrole.dll - Ok
C:\Windows\SysWOW64\drvstore.dll - Ok
C:\Windows\SysWOW64\dssec.dll - Ok
C:\Windows\SysWOW64\drmmgrtn.dll - Ok
C:\Windows\SysWOW64\DShowRdpFilter.dll - Ok
C:\Windows\SysWOW64\dswave.dll - Ok
C:\Windows\SysWOW64\dtsh.dll - Ok
C:\Windows\SysWOW64\dsquery.dll - Ok
C:\Windows\SysWOW64\dsound.dll - Ok
C:\Windows\SysWOW64\duser.dll - Ok
C:\Windows\SysWOW64\dssenh.dll - Ok
C:\Windows\SysWOW64\dvdplay.exe - Ok
C:\Windows\SysWOW64\dwmapi.dll - Ok
C:\Windows\SysWOW64\dskquoui.dll - Ok
C:\Windows\SysWOW64\dui70.dll - Ok
C:\Windows\SysWOW64\dvdupgrd.exe - Ok
C:\Windows\SysWOW64\dsprop.dll - Ok
C:\Windows\SysWOW64\dxmasf.dll - Ok
>C:\Windows\SysWOW64\drmv2clt.dll is BINARYRES container
>>C:\Windows\SysWOW64\drmv2clt.dll\data001 is JS-HTML container
C:\Windows\SysWOW64\drmv2clt.dll - container
C:\Windows\SysWOW64\dxgi.dll - Ok
C:\Windows\SysWOW64\dssec.dat - Ok
C:\Windows\SysWOW64\dxdiagn.dll - Ok
C:\Windows\SysWOW64\dxva2.dll - Ok
C:\Windows\SysWOW64\DWWIN.EXE - Ok
C:\Windows\SysWOW64\dsuiext.dll - Ok
C:\Windows\SysWOW64\dxtmsft.dll - Ok
C:\Windows\SysWOW64\dxdiag.exe - Ok
C:\Windows\SysWOW64\dxtrans.dll - Ok
C:\Windows\SysWOW64\eappgnui.dll - Ok
C:\Windows\SysWOW64\eappcfg.dll - Ok
C:\Windows\SysWOW64\eapp3hst.dll - Ok
C:\Windows\SysWOW64\eappprxy.dll - Ok
C:\Windows\SysWOW64\DWrite.dll - Ok
C:\Windows\SysWOW64\EAPQEC.DLL - Ok
C:\Windows\SysWOW64\dwmcore.dll - Ok
C:\Windows\SysWOW64\efsutil.dll - Ok
C:\Windows\SysWOW64\efsadu.dll - Ok
C:\Windows\SysWOW64\EhStorAPI.dll - Ok
C:\Windows\SysWOW64\DXPTaskRingtone.dll - Ok
C:\Windows\SysWOW64\efsui.exe - Ok
C:\Windows\SysWOW64\efscore.dll - Ok
C:\Windows\SysWOW64\ELSCore.dll - Ok
C:\Windows\SysWOW64\EhStorPwdMgr.dll - Ok
C:\Windows\SysWOW64\EhStorShell.dll - Ok
C:\Windows\SysWOW64\elsTrans.dll - Ok
C:\Windows\SysWOW64\eapphost.dll - Ok
C:\Windows\SysWOW64\elshyph.dll - Ok
C:\Windows\SysWOW64\EhStorAuthn.exe - Ok
C:\Windows\SysWOW64\encapi.dll - Ok
C:\Windows\SysWOW64\els.dll - Ok
>C:\Windows\SysWOW64\eventcls.dll - packed by FLY-CODE
C:\Windows\SysWOW64\eqossnap.dll - Ok
>C:\Windows\SysWOW64\EventViewer_EventDetails.xsl is JS-HTML container
>C:\Windows\SysWOW64\esrb.rs is ZLIB container
C:\Windows\SysWOW64\esentprf.dll - Ok
C:\Windows\SysWOW64\elslad.dll - Ok
C:\Windows\SysWOW64\esrb.rs - container
C:\Windows\SysWOW64\esentutl.exe - Ok
C:\Windows\SysWOW64\EventViewer_EventDetails.xsl - container
C:\Windows\SysWOW64\eventcreate.exe - Ok
C:\Windows\SysWOW64\eventcls.dll - Ok
C:\Windows\SysWOW64\eventvwr.msc - Ok
>C:\Windows\SysWOW64\eventvwr.exe - packed by FLY-CODE
C:\Windows\SysWOW64\es.dll - Ok
C:\Windows\SysWOW64\eudcedit.exe - Ok
C:\Windows\SysWOW64\ezdigsgn.dat - Ok
>C:\Windows\SysWOW64\expand.exe - packed by BINARYRES
>>C:\Windows\SysWOW64\expand.exe - packed by MS COMPRESS
C:\Windows\SysWOW64\expand.exe - Ok
C:\Windows\SysWOW64\extrac32.exe - Ok
C:\Windows\SysWOW64\evr.dll - Ok
C:\Windows\SysWOW64\DxpTaskSync.dll - Ok
C:\Windows\SysWOW64\eventvwr.exe - Ok
C:\Windows\SysWOW64\EncDec.dll - Ok
>C:\Windows\SysWOW64\ezFileImport7.dll is BINARYRES container
>>C:\Windows\SysWOW64\ezFileImport7.dll\data001 is JS-HTML container
C:\Windows\SysWOW64\ezFileImport7.dll - container
C:\Windows\SysWOW64\ezMAPIHelper.exe - Ok
C:\Windows\SysWOW64\ezLicPrompt7.dll - Ok
C:\Windows\SysWOW64\expsrv.dll - Ok
C:\Windows\SysWOW64\ezHints7.dll - Ok
C:\Windows\SysWOW64\ExplorerFrame.dll - Ok
C:\Windows\SysWOW64\ezRas7.dll - Ok
C:\Windows\SysWOW64\explorer.exe - Ok
>C:\Windows\SysWOW64\ezMDUninstall.exe is BINARYRES container
C:\Windows\SysWOW64\ezMDUninstall.exe - container
C:\Windows\SysWOW64\esent.dll - Ok
C:\Windows\SysWOW64\ezsidmv.dat - Ok
C:\Windows\SysWOW64\ezEMail7.dll - Ok
C:\Windows\SysWOW64\ezSetupMgr.exe - Ok
C:\Windows\SysWOW64\ezMenu7.dll - Ok
C:\Windows\SysWOW64\ezSubs7.dll - Ok
C:\Windows\SysWOW64\ezseng.exe - Ok
>C:\Windows\SysWOW64\ezBook7.dll is ZLIB container
>C:\Windows\SysWOW64\ezScore7.dll is BINARYRES container
>>C:\Windows\SysWOW64\ezScore7.dll\data002 is ZLIB container
C:\Windows\SysWOW64\ezUPBHook.dll - Ok
C:\Windows\SysWOW64\ezShellStart.exe - Ok
C:\Windows\SysWOW64\f3ahvoas.dll - Ok
C:\Windows\SysWOW64\ezScore7.dll - container
C:\Windows\SysWOW64\ezUninst.exe - Ok
C:\Windows\SysWOW64\ezsvc7x.dll - Ok
>C:\Windows\SysWOW64\ezShell7.dll is ZLIB container
C:\Windows\SysWOW64\fdBthProxy.dll - Ok
C:\Windows\SysWOW64\fc.exe - Ok
C:\Windows\SysWOW64\fdBth.dll - Ok
C:\Windows\SysWOW64\ezShell7.dll - container
C:\Windows\SysWOW64\Faultrep.dll - Ok
C:\Windows\SysWOW64\fdeploy.dll - Ok
>C:\Windows\SysWOW64\ezPrint7.dll is ZLIB container
C:\Windows\SysWOW64\fdProxy.dll - Ok
C:\Windows\SysWOW64\fdWNet.dll - Ok
C:\Windows\SysWOW64\fdPnp.dll - Ok
C:\Windows\SysWOW64\ezBook7.dll - container
C:\Windows\SysWOW64\ezSharedSvcHost.exe - Ok
>C:\Windows\SysWOW64\ezWizard7.dll is ZLIB container
C:\Windows\SysWOW64\fde.dll - Ok
C:\Windows\SysWOW64\fdWCN.dll - Ok
C:\Windows\SysWOW64\fdSSDP.dll - Ok
>C:\Windows\SysWOW64\ezUtils7.dll is ZLIB container
C:\Windows\SysWOW64\find.exe - Ok
C:\Windows\SysWOW64\fdWSD.dll - Ok
C:\Windows\SysWOW64\Firewall.cpl - Ok
C:\Windows\SysWOW64\ezPrint7.dll - container
C:\Windows\SysWOW64\feclient.dll - Ok
C:\Windows\SysWOW64\finger.exe - Ok
C:\Windows\SysWOW64\findnetprinters.dll - Ok
C:\Windows\SysWOW64\ezUtils7.dll - container
C:\Windows\SysWOW64\fltLib.dll - Ok
C:\Windows\SysWOW64\fixmapi.exe - Ok
C:\Windows\SysWOW64\findstr.exe - Ok
C:\Windows\SysWOW64\ezScrSvr.scr - Ok
C:\Windows\SysWOW64\fmifs.dll - Ok
C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl - Ok
C:\Windows\SysWOW64\ezWizard7.dll - container
C:\Windows\SysWOW64\FirewallAPI.dll - Ok
C:\Windows\SysWOW64\fltMC.exe - Ok
C:\Windows\SysWOW64\forfiles.exe - Ok
C:\Windows\SysWOW64\fpb.rs - Ok
C:\Windows\SysWOW64\fms.dll - Ok
C:\Windows\SysWOW64\format.com - Ok
C:\Windows\SysWOW64\filemgmt.dll - Ok
C:\Windows\SysWOW64\fontsub.dll - Ok
C:\Windows\SysWOW64\fphc.dll - Ok
C:\Windows\SysWOW64\fontview.exe - Ok
C:\Windows\SysWOW64\fsmgmt.msc - Ok
C:\Windows\SysWOW64\FirewallControlPanel.dll - Ok
C:\Windows\SysWOW64\fwcfg.dll - Ok
C:\Windows\SysWOW64\ftp.exe - Ok
C:\Windows\SysWOW64\fsutil.exe - Ok
C:\Windows\SysWOW64\framedyn.dll - Ok
C:\Windows\SysWOW64\FwRemoteSvr.dll - Ok
C:\Windows\SysWOW64\fthsvc.dll - Ok
C:\Windows\SysWOW64\FWPUCLNT.DLL - Ok
C:\Windows\SysWOW64\FXSCOM.dll - Ok
C:\Windows\SysWOW64\framedynos.dll - Ok
C:\Windows\SysWOW64\gb2312.uce - Ok
C:\Windows\SysWOW64\FXSEXT32.dll - Ok
C:\Windows\SysWOW64\FXSAPI.dll - Ok
C:\Windows\SysWOW64\g711codc.ax - Ok
C:\Windows\SysWOW64\fundisc.dll - Ok
>C:\Windows\SysWOW64\fontext.dll - packed by BINARYRES
>>C:\Windows\SysWOW64\fontext.dll - packed by MS COMPRESS
C:\Windows\SysWOW64\FXSXP32.dll - Ok
C:\Windows\SysWOW64\getmac.exe - Ok
C:\Windows\SysWOW64\gcdef.dll - Ok
C:\Windows\SysWOW64\fontext.dll - Ok
C:\Windows\SysWOW64\FXSCOMEX.dll - Ok
C:\Windows\SysWOW64\GEARAspi.dll - Ok
C:\Windows\SysWOW64\getuname.dll - Ok
C:\Windows\SysWOW64\gdi32.dll - Ok
C:\Windows\SysWOW64\gpapi.dll - Ok
C:\Windows\SysWOW64\gpprnext.dll - Ok
C:\Windows\SysWOW64\glmf32.dll - Ok
C:\Windows\SysWOW64\gptext.dll - Ok
C:\Windows\SysWOW64\grb.rs - Ok
>C:\Windows\SysWOW64\grpconv.exe - packed by FLY-CODE
C:\Windows\SysWOW64\glu32.dll - Ok
C:\Windows\SysWOW64\gpresult.exe - Ok
>C:\Windows\SysWOW64\gpupdate.exe - packed by FLY-CODE
C:\Windows\SysWOW64\hcproviders.dll - Ok
>C:\Windows\SysWOW64\hbaapi.dll - packed by FLY-CODE
C:\Windows\SysWOW64\hdwwiz.cpl - Ok
C:\Windows\SysWOW64\help.exe - Ok
C:\Windows\SysWOW64\grpconv.exe - Ok
C:\Windows\SysWOW64\FXSRESM.dll - Ok
C:\Windows\SysWOW64\gpupdate.exe - Ok
C:\Windows\SysWOW64\hbaapi.dll - Ok
C:\Windows\SysWOW64\HelpPaneProxy.dll - Ok
C:\Windows\SysWOW64\FlashPlayerApp.exe - Ok
C:\Windows\SysWOW64\hid.dll - Ok
C:\Windows\SysWOW64\hidphone.tsp - Ok
C:\Windows\SysWOW64\hdwwiz.exe - Ok
C:\Windows\SysWOW64\hh.exe - Ok
C:\Windows\SysWOW64\gpedit.dll - Ok
C:\Windows\SysWOW64\hlink.dll - Ok
C:\Windows\SysWOW64\hhsetup.dll - Ok
>C:\Windows\SysWOW64\hnetmon.dll - packed by FLY-CODE
C:\Windows\SysWOW64\hidserv.dll - Ok
C:\Windows\SysWOW64\HOSTNAME.EXE - Ok
C:\Windows\SysWOW64\ias.dll - Ok
C:\Windows\SysWOW64\httpapi.dll - Ok
C:\Windows\SysWOW64\hnetmon.dll - Ok
C:\Windows\SysWOW64\htui.dll - Ok
C:\Windows\SysWOW64\hnetcfg.dll - Ok
C:\Windows\SysWOW64\hgcpl.dll - Ok
C:\Windows\SysWOW64\iasdatastore.dll - Ok
C:\Windows\SysWOW64\hhctrl.ocx - Ok
C:\Windows\SysWOW64\iac25_32.ax - Ok
C:\Windows\SysWOW64\iasacct.dll - Ok
C:\Windows\SysWOW64\iasads.dll - Ok
C:\Windows\SysWOW64\iashlpr.dll - Ok
C:\Windows\SysWOW64\iaspolcy.dll - Ok
C:\Windows\SysWOW64\iasrecst.dll - Ok
C:\Windows\SysWOW64\html.iec - Ok
C:\Windows\SysWOW64\iassvcs.dll - Ok
C:\Windows\SysWOW64\iasnap.dll - Ok
C:\Windows\SysWOW64\icardres.dll - Ok
C:\Windows\SysWOW64\icacls.exe - Ok
>C:\Windows\SysWOW64\IasMigPlugin.dll is BINARYRES container
C:\Windows\SysWOW64\IasMigPlugin.dll - container
C:\Windows\SysWOW64\icmp.dll - Ok
C:\Windows\SysWOW64\iasrad.dll - Ok
C:\Windows\SysWOW64\icm32.dll - Ok
C:\Windows\SysWOW64\iccvid.dll - Ok
>C:\Windows\SysWOW64\icmui.dll - packed by FLY-CODE
C:\Windows\SysWOW64\icardie.dll - Ok
C:\Windows\SysWOW64\ideograf.uce - Ok
C:\Windows\SysWOW64\iassdo.dll - Ok
C:\Windows\SysWOW64\IconCodecService.dll - Ok
>C:\Windows\SysWOW64\icsunattend.exe - packed by FLY-CODE
C:\Windows\SysWOW64\icrav03.rat - Ok
C:\Windows\SysWOW64\iassam.dll - Ok
C:\Windows\SysWOW64\idndl.dll - Ok
C:\Windows\SysWOW64\icmui.dll - Ok
C:\Windows\SysWOW64\IDStore.dll - Ok
>C:\Windows\SysWOW64\icsigd.dll - packed by FLY-CODE
C:\Windows\SysWOW64\IEAdvpack.dll - Ok
C:\Windows\SysWOW64\icsunattend.exe - Ok
C:\Windows\SysWOW64\GameUXLegacyGDFs.dll - Ok
C:\Windows\SysWOW64\iedkcs32.dll - Ok
C:\Windows\SysWOW64\iernonce.dll - Ok
C:\Windows\SysWOW64\iesetup.dll - Ok
C:\Windows\SysWOW64\iepeers.dll - Ok
C:\Windows\SysWOW64\gameux.dll - Ok
C:\Windows\SysWOW64\icsigd.dll - Ok
C:\Windows\SysWOW64\ifmon.dll - Ok
C:\Windows\SysWOW64\iesysprep.dll - Ok
C:\Windows\SysWOW64\ieapfltr.dll - Ok
C:\Windows\SysWOW64\ifsutilx.dll - Ok
C:\Windows\SysWOW64\igcompkrng600.bin - Ok
C:\Windows\SysWOW64\ieUnatt.exe - Ok
C:\Windows\SysWOW64\iexpress.exe - Ok
C:\Windows\SysWOW64\ieuinit.inf - Ok
C:\Windows\SysWOW64\igfcg600m.bin - Ok
C:\Windows\SysWOW64\icardagt.exe - Ok
C:\Windows\SysWOW64\ifsutil.dll - Ok
C:\Windows\SysWOW64\iertutil.dll - Ok
C:\Windows\SysWOW64\igdde32.dll - Ok
C:\Windows\SysWOW64\ieui.dll - Ok
C:\Windows\SysWOW64\igfxcmrt32.dll - Ok
C:\Windows\SysWOW64\igkrng600.bin - Ok
C:\Windows\SysWOW64\igfxexps32.dll - Ok
C:\Windows\SysWOW64\ieapfltr.dat - Ok
>C:\Windows\SysWOW64\imaadp32.acm - packed by FLY-CODE
C:\Windows\SysWOW64\igfxdv32.dll - Ok
C:\Windows\SysWOW64\iglhcp32.dll - Ok
C:\Windows\SysWOW64\igdumdx32.dll - Ok
C:\Windows\SysWOW64\imaadp32.acm - Ok
C:\Windows\SysWOW64\imagehlp.dll - Ok
C:\Windows\SysWOW64\imgutil.dll - Ok
C:\Windows\SysWOW64\imapi.dll - Ok
>C:\Windows\SysWOW64\iglhsip32.dll - packed by FLY-CODE
C:\Windows\SysWOW64\imapi2.dll - Ok
C:\Windows\SysWOW64\ieframe.dll - Ok
C:\Windows\SysWOW64\imagesp1.dll - Ok
C:\Windows\SysWOW64\imm32.dll - Ok
C:\Windows\SysWOW64\imkr80.ime - Ok
C:\Windows\SysWOW64\inetmib1.dll - Ok
C:\Windows\SysWOW64\IMJP10K.DLL - Ok
C:\Windows\SysWOW64\INETRES.dll - Ok
C:\Windows\SysWOW64\inetcomm.dll - Ok
C:\Windows\SysWOW64\IMJP10.IME - Ok
C:\Windows\SysWOW64\igdumd32.dll - Ok
C:\Windows\SysWOW64\infocardapi.dll - Ok
C:\Windows\SysWOW64\InfDefaultInstall.exe - Ok
C:\Windows\SysWOW64\imapi2fs.dll - Ok
C:\Windows\SysWOW64\infocardcpl.cpl - Ok
C:\Windows\SysWOW64\instnm.exe - Ok
C:\Windows\SysWOW64\iologmsg.dll - Ok
C:\Windows\SysWOW64\IPBusEnumProxy.dll - Ok
C:\Windows\SysWOW64\iprop.dll - Ok
C:\Windows\SysWOW64\InkEd.dll - Ok
C:\Windows\SysWOW64\ipconfig.exe - Ok
C:\Windows\SysWOW64\iprtprio.dll - Ok
C:\Windows\SysWOW64\inseng.dll - Ok
C:\Windows\SysWOW64\IPHLPAPI.DLL - Ok
C:\Windows\SysWOW64\intl.cpl - Ok
C:\Windows\SysWOW64\iprtrmgr.dll - Ok
C:\Windows\SysWOW64\input.dll - Ok
C:\Windows\SysWOW64\iglhsip32.dll - Ok
>C:\Windows\SysWOW64\ir41_qc.dll - packed by FLY-CODE
>C:\Windows\SysWOW64\ir41_qcx.dll - packed by FLY-CODE
C:\Windows\SysWOW64\ir32_32.dll - Ok
C:\Windows\SysWOW64\inetcpl.cpl - Ok
C:\Windows\SysWOW64\ipsmsnap.dll - Ok
C:\Windows\SysWOW64\ipsecsnp.dll - Ok
C:\Windows\SysWOW64\ir50_qc.dll - Ok
C:\Windows\SysWOW64\ir50_qcx.dll - Ok
>C:\Windows\SysWOW64\irclass.dll - packed by FLY-CODE
C:\Windows\SysWOW64\ir41_32.ax - Ok
C:\Windows\SysWOW64\irclass.dll - Ok
>C:\Windows\SysWOW64\iscsicpl.exe - packed by FLY-CODE
>C:\Windows\SysWOW64\iscsicli.exe - packed by FLY-CODE
C:\Windows\SysWOW64\irprops.cpl - Ok
C:\Windows\SysWOW64\iscsidsc.dll - Ok
C:\Windows\SysWOW64\iscsied.dll - Ok
C:\Windows\SysWOW64\iscsicpl.dll - Ok
C:\Windows\SysWOW64\iscsium.dll - Ok
C:\Windows\SysWOW64\ir41_qc.dll - Ok
C:\Windows\SysWOW64\ir41_qcx.dll - Ok
C:\Windows\SysWOW64\ir50_32.dll - Ok
C:\Windows\SysWOW64\iscsiwmi.dll - Ok
>C:\Windows\SysWOW64\iyuv_32.dll - packed by FLY-CODE
C:\Windows\SysWOW64\iscsicpl.exe - Ok
C:\Windows\SysWOW64\iscsicli.exe - Ok
C:\Windows\SysWOW64\itss.dll - Ok
C:\Windows\SysWOW64\isoburn.exe - Ok
C:\Windows\SysWOW64\itircl.dll - Ok
C:\Windows\SysWOW64\iTVData.dll - Ok
C:\Windows\SysWOW64\jdns_sd.dll - Ok
C:\Windows\SysWOW64\ivfsrc.ax - Ok
C:\Windows\SysWOW64\iyuv_32.dll - Ok
C:\Windows\SysWOW64\jupdate-1.7.0_09-b05.log - Ok
C:\Windows\SysWOW64\jupdate-1.7.0_21-b11.log - Ok
C:\Windows\SysWOW64\jsproxy.dll - Ok
C:\Windows\SysWOW64\kanji_1.uce - Ok
C:\Windows\SysWOW64\java.exe - Ok
C:\Windows\SysWOW64\jupdate-1.7.0_45-b18.log - Ok
C:\Windows\SysWOW64\joy.cpl - Ok
C:\Windows\SysWOW64\kanji_2.uce - Ok
C:\Windows\SysWOW64\kbd101.DLL - Ok
C:\Windows\SysWOW64\kbd101b.DLL - Ok
C:\Windows\SysWOW64\kbd101c.DLL - Ok
C:\Windows\SysWOW64\kbd101a.DLL - Ok
C:\Windows\SysWOW64\javaw.exe - Ok
C:\Windows\SysWOW64\kbd106n.dll - Ok
C:\Windows\SysWOW64\kbd103.DLL - Ok
C:\Windows\SysWOW64\KBDA3.DLL - Ok
C:\Windows\SysWOW64\kbd106.dll - Ok
C:\Windows\SysWOW64\KBDAL.DLL - Ok
C:\Windows\SysWOW64\kbdax2.dll - Ok
C:\Windows\SysWOW64\KBDARME.DLL - Ok
C:\Windows\SysWOW64\KBDARMW.DLL - Ok
C:\Windows\SysWOW64\KBDAZE.DLL - Ok
C:\Windows\SysWOW64\javaws.exe - Ok
C:\Windows\SysWOW64\KBDBE.DLL - Ok
C:\Windows\SysWOW64\KBDA1.DLL - Ok
C:\Windows\SysWOW64\KBDAZEL.DLL - Ok
C:\Windows\SysWOW64\KBDBGPH.DLL - Ok
C:\Windows\SysWOW64\KBDBGPH1.DLL - Ok
C:\Windows\SysWOW64\jscript.dll - Ok
C:\Windows\SysWOW64\KBDBENE.DLL - Ok
C:\Windows\SysWOW64\KBDBHC.DLL - Ok
C:\Windows\SysWOW64\KBDBR.DLL - Ok
C:\Windows\SysWOW64\KBDBU.DLL - Ok
C:\Windows\SysWOW64\KBDBLR.DLL - Ok
C:\Windows\SysWOW64\KBDCAN.DLL - Ok
C:\Windows\SysWOW64\KBDBULG.DLL - Ok
C:\Windows\SysWOW64\KBDCZ.DLL - Ok
C:\Windows\SysWOW64\KBDCR.DLL - Ok
C:\Windows\SysWOW64\KBDBASH.DLL - Ok
C:\Windows\SysWOW64\KBDCZ1.DLL - Ok
C:\Windows\SysWOW64\KBDDA.DLL - Ok
C:\Windows\SysWOW64\KBDDIV2.DLL - Ok
C:\Windows\SysWOW64\KBDDIV1.DLL - Ok
C:\Windows\SysWOW64\KBDCZ2.DLL - Ok
C:\Windows\SysWOW64\KBDDV.DLL - Ok
C:\Windows\SysWOW64\KBDA2.DLL - Ok
C:\Windows\SysWOW64\KBDEST.DLL - Ok
C:\Windows\SysWOW64\KBDES.DLL - Ok
C:\Windows\SysWOW64\KBDFA.DLL - Ok
C:\Windows\SysWOW64\KBDFR.DLL - Ok
C:\Windows\SysWOW64\KBDFO.DLL - Ok
C:\Windows\SysWOW64\KBDGAE.DLL - Ok
C:\Windows\SysWOW64\KBDFI1.DLL - Ok
C:\Windows\SysWOW64\KBDGEO.DLL - Ok
C:\Windows\SysWOW64\KBDFI.DLL - Ok
C:\Windows\SysWOW64\KBDCA.DLL - Ok
C:\Windows\SysWOW64\KBDGR1.DLL - Ok
C:\Windows\SysWOW64\KBDGRLND.DLL - Ok
C:\Windows\SysWOW64\KBDHAU.DLL - Ok
C:\Windows\SysWOW64\kbdgeoqw.dll - Ok
C:\Windows\SysWOW64\kbdgeoer.dll - Ok
C:\Windows\SysWOW64\KBDGKL.DLL - Ok
C:\Windows\SysWOW64\KBDGR.DLL - Ok
C:\Windows\SysWOW64\KBDFC.DLL - Ok
C:\Windows\SysWOW64\KBDHEB.DLL - Ok
C:\Windows\SysWOW64\KBDHE319.DLL - Ok
C:\Windows\SysWOW64\KBDHE220.DLL - Ok
C:\Windows\SysWOW64\KBDHELA3.DLL - Ok
C:\Windows\SysWOW64\KBDHE.DLL - Ok
C:\Windows\SysWOW64\KBDHU1.DLL - Ok
C:\Windows\SysWOW64\KBDHU.DLL - Ok
C:\Windows\SysWOW64\KBDIBO.DLL - Ok
C:\Windows\SysWOW64\KBDIC.DLL - Ok
C:\Windows\SysWOW64\KBDINASA.DLL - Ok
C:\Windows\SysWOW64\KBDINDEV.DLL - Ok
C:\Windows\SysWOW64\KBDINBE2.DLL - Ok
C:\Windows\SysWOW64\KBDINBEN.DLL - Ok
C:\Windows\SysWOW64\kbdibm02.DLL - Ok
C:\Windows\SysWOW64\KBDHEPT.DLL - Ok
C:\Windows\SysWOW64\KBDINBE1.DLL - Ok
C:\Windows\SysWOW64\KBDINMAL.DLL - Ok
C:\Windows\SysWOW64\KBDINMAR.DLL - Ok
C:\Windows\SysWOW64\KBDINGUJ.DLL - Ok
C:\Windows\SysWOW64\KBDINPUN.DLL - Ok
C:\Windows\SysWOW64\KBDINTAM.DLL - Ok
C:\Windows\SysWOW64\KBDINKAN.DLL - Ok
C:\Windows\SysWOW64\KBDINHIN.DLL - Ok
C:\Windows\SysWOW64\KBDINUK2.DLL - Ok
C:\Windows\SysWOW64\KBDIR.DLL - Ok
C:\Windows\SysWOW64\KBDINTEL.DLL - Ok
C:\Windows\SysWOW64\KBDIT.DLL - Ok
C:\Windows\SysWOW64\KBDINORI.DLL - Ok
C:\Windows\SysWOW64\KBDIT142.DLL - Ok
C:\Windows\SysWOW64\KBDKAZ.DLL - Ok
C:\Windows\SysWOW64\KBDIULAT.DLL - Ok
C:\Windows\SysWOW64\KBDKYR.DLL - Ok
C:\Windows\SysWOW64\KBDJPN.DLL - Ok
C:\Windows\SysWOW64\KBDKHMR.DLL - Ok
C:\Windows\SysWOW64\KBDKOR.DLL - Ok
C:\Windows\SysWOW64\KBDLA.DLL - Ok
C:\Windows\SysWOW64\KBDLV1.DLL - Ok
C:\Windows\SysWOW64\KBDLV.DLL - Ok
C:\Windows\SysWOW64\KBDLT2.DLL - Ok
C:\Windows\SysWOW64\kbdlk41a.dll - Ok
C:\Windows\SysWOW64\KBDMAC.DLL - Ok
C:\Windows\SysWOW64\KBDMLT47.DLL - Ok
C:\Windows\SysWOW64\KBDHELA2.DLL - Ok
C:\Windows\SysWOW64\KBDMONMO.DLL - Ok
C:\Windows\SysWOW64\KBDMAORI.DLL - Ok
C:\Windows\SysWOW64\KBDMACST.DLL - Ok
C:\Windows\SysWOW64\KBDNE.DLL - Ok
C:\Windows\SysWOW64\kbdnec.DLL - Ok
C:\Windows\SysWOW64\KBDMON.DLL - Ok
C:\Windows\SysWOW64\KBDLT.DLL - Ok
C:\Windows\SysWOW64\kbdnecat.DLL - Ok
C:\Windows\SysWOW64\KBDMLT48.DLL - Ok
C:\Windows\SysWOW64\kbdnec95.DLL - Ok
C:\Windows\SysWOW64\KBDNO.DLL - Ok
C:\Windows\SysWOW64\KBDNO1.DLL - Ok
C:\Windows\SysWOW64\KBDNEPR.DLL - Ok
C:\Windows\SysWOW64\KBDNSO.DLL - Ok
C:\Windows\SysWOW64\KBDPL.DLL - Ok
C:\Windows\SysWOW64\KBDPL1.DLL - Ok
C:\Windows\SysWOW64\KBDPO.DLL - Ok
C:\Windows\SysWOW64\KBDLAO.DLL - Ok
C:\Windows\SysWOW64\KBDRO.DLL - Ok
C:\Windows\SysWOW64\KBDROPR.DLL - Ok
C:\Windows\SysWOW64\KBDRU1.DLL - Ok
C:\Windows\SysWOW64\kbdnecnt.DLL - Ok
C:\Windows\SysWOW64\KBDRU.DLL - Ok
C:\Windows\SysWOW64\KBDSL.DLL - Ok
C:\Windows\SysWOW64\KBDSF.DLL - Ok
C:\Windows\SysWOW64\KBDSL1.DLL - Ok
C:\Windows\SysWOW64\KBDSG.DLL - Ok
C:\Windows\SysWOW64\KBDSMSNO.DLL - Ok
C:\Windows\SysWOW64\KBDSMSFI.DLL - Ok
C:\Windows\SysWOW64\KBDSORS1.DLL - Ok
C:\Windows\SysWOW64\KBDPASH.DLL - Ok
C:\Windows\SysWOW64\KBDSP.DLL - Ok
C:\Windows\SysWOW64\KBDSW.DLL - Ok
C:\Windows\SysWOW64\KBDLT1.DLL - Ok
C:\Windows\SysWOW64\KBDSW09.DLL - Ok
C:\Windows\SysWOW64\KBDSYR1.DLL - Ok
C:\Windows\SysWOW64\KBDROST.DLL - Ok
C:\Windows\SysWOW64\KBDTAJIK.DLL - Ok
C:\Windows\SysWOW64\KBDSYR2.DLL - Ok
C:\Windows\SysWOW64\KBDTAT.DLL - Ok
C:\Windows\SysWOW64\KBDSORST.DLL - Ok
C:\Windows\SysWOW64\KBDTH3.DLL - Ok
C:\Windows\SysWOW64\KBDSN1.DLL - Ok
C:\Windows\SysWOW64\KBDTUF.DLL - Ok
C:\Windows\SysWOW64\KBDTH1.DLL - Ok
C:\Windows\SysWOW64\KBDTUQ.DLL - Ok
C:\Windows\SysWOW64\KBDUGHR1.DLL - Ok
C:\Windows\SysWOW64\KBDTURME.DLL - Ok
C:\Windows\SysWOW64\KBDUGHR.DLL - Ok
C:\Windows\SysWOW64\KBDUKX.DLL - Ok
C:\Windows\SysWOW64\KBDUR.DLL - Ok
C:\Windows\SysWOW64\KBDUK.DLL - Ok
C:\Windows\SysWOW64\KBDSOREX.DLL - Ok
C:\Windows\SysWOW64\KBDUS.DLL - Ok
C:\Windows\SysWOW64\KBDUSA.DLL - Ok
C:\Windows\SysWOW64\KBDUSL.DLL - Ok
C:\Windows\SysWOW64\KBDUR1.DLL - Ok
C:\Windows\SysWOW64\KBDVNTC.DLL - Ok
C:\Windows\SysWOW64\KBDUSX.DLL - Ok
C:\Windows\SysWOW64\KBDUZB.DLL - Ok
C:\Windows\SysWOW64\KBDUSR.DLL - Ok
C:\Windows\SysWOW64\KBDWOL.DLL - Ok
C:\Windows\SysWOW64\KBDTIPRC.DLL - Ok
C:\Windows\SysWOW64\KBDTH0.DLL - Ok
C:\Windows\SysWOW64\KBDYCC.DLL - Ok
C:\Windows\SysWOW64\KBDYCL.DLL - Ok
C:\Windows\SysWOW64\KBDYBA.DLL - Ok
C:\Windows\SysWOW64\KBDURDU.DLL - Ok
C:\Windows\SysWOW64\keyiso.dll - Ok
C:\Windows\SysWOW64\korean.uce - Ok
C:\Windows\SysWOW64\KBDYAK.DLL - Ok
C:\Windows\SysWOW64\korwbrkr.lex - Ok
C:\Windows\SysWOW64\keymgr.dll - Ok
C:\Windows\SysWOW64\korwbrkr.dll - Ok
C:\Windows\SysWOW64\ksuser.dll - Ok
C:\Windows\SysWOW64\ksproxy.ax - Ok
C:\Windows\SysWOW64\kmddsp.tsp - Ok
C:\Windows\SysWOW64\Kswdmcap.ax - Ok
C:\Windows\SysWOW64\ktmutil.exe - Ok
C:\Windows\SysWOW64\ksxbar.ax - Ok
C:\Windows\SysWOW64\kstvtune.ax - Ok
C:\Windows\SysWOW64\l2nacp.dll - Ok
C:\Windows\SysWOW64\l2gpstore.dll - Ok
C:\Windows\SysWOW64\L2SecHC.dll - Ok
C:\Windows\SysWOW64\l3codeca.acm - Ok
C:\Windows\SysWOW64\KernelBase.dll - Ok
C:\Windows\SysWOW64\ktmw32.dll - Ok
C:\Windows\SysWOW64\lcptr.tbl - Ok
C:\Windows\SysWOW64\KBDTH2.DLL - Ok
C:\Windows\SysWOW64\LAPRXY.DLL - Ok
C:\Windows\SysWOW64\lcphrase.tbl - Ok
C:\Windows\SysWOW64\linkinfo.dll - Ok
C:\Windows\SysWOW64\kernel32.dll - Ok
C:\Windows\SysWOW64\l3codecp.acm - Ok
C:\Windows\SysWOW64\kerberos.dll - Ok
>C:\Windows\SysWOW64\label.exe - packed by FLY-CODE
C:\Windows\SysWOW64\loadperf.dll - Ok
C:\Windows\SysWOW64\licmgr10.dll - Ok
C:\Windows\SysWOW64\locale.nls - Ok
C:\Windows\SysWOW64\locationnotificationsview.xml - Ok
C:\Windows\SysWOW64\log.txt - read error
C:\Windows\SysWOW64\label.exe - Ok
C:\Windows\SysWOW64\LIVESSP.DLL - Ok
C:\Windows\SysWOW64\LocationNotifications.exe - Ok
C:\Windows\SysWOW64\localsec.dll - Ok
C:\Windows\SysWOW64\license.rtf - Ok
C:\Windows\SysWOW64\lodctr.exe - Ok
C:\Windows\SysWOW64\LocationApi.dll - Ok
C:\Windows\SysWOW64\logoncli.dll - Ok
C:\Windows\SysWOW64\loghours.dll - Ok
C:\Windows\SysWOW64\lsmproxy.dll - Ok
C:\Windows\SysWOW64\l_intl.nls - Ok
C:\Windows\SysWOW64\luainstall.dll - Ok
C:\Windows\SysWOW64\lusrmgr.msc - Ok
C:\Windows\SysWOW64\lz32.dll - Ok
C:\Windows\SysWOW64\lpk.dll - Ok
C:\Windows\SysWOW64\logman.exe - Ok
C:\Windows\SysWOW64\mapisvc.inf - Ok
C:\Windows\SysWOW64\logagent.exe - Ok
>C:\Windows\SysWOW64\Magnify.exe is ZLIB container
C:\Windows\SysWOW64\Magnification.dll - Ok
C:\Windows\SysWOW64\mapi32.dll - Ok
C:\Windows\SysWOW64\mapistub.dll - Ok
C:\Windows\SysWOW64\Magnify.exe - container
C:\Windows\SysWOW64\mcbuilder.exe - Ok
C:\Windows\SysWOW64\mciqtz32.dll - Ok
C:\Windows\SysWOW64\mctres.dll - Ok
>C:\Windows\SysWOW64\mciseq.dll - packed by FLY-CODE
>C:\Windows\SysWOW64\MCEWMDRMNDBootstrap.dll - packed by FLY-CODE
C:\Windows\SysWOW64\mciwave.dll - Ok
C:\Windows\SysWOW64\mciavi32.dll - Ok
C:\Windows\SysWOW64\mcicda.dll - Ok
C:\Windows\SysWOW64\makecab.exe - Ok
C:\Windows\SysWOW64\main.cpl - Ok
C:\Windows\SysWOW64\mciseq.dll - Ok
>C:\Windows\SysWOW64\mdminst.dll - packed by FLY-CODE
C:\Windows\SysWOW64\mf3216.dll - Ok
C:\Windows\SysWOW64\mfAACEnc.dll - Ok
C:\Windows\SysWOW64\MediaMetadataHandler.dll - Ok
C:\Windows\SysWOW64\mfc100chs.dll - Ok
C:\Windows\SysWOW64\mfc100cht.dll - Ok
C:\Windows\SysWOW64\mfc100deu.dll - Ok
C:\Windows\SysWOW64\mfc100enu.dll - Ok
C:\Windows\SysWOW64\mfc100esn.dll - Ok
C:\Windows\SysWOW64\MCEWMDRMNDBootstrap.dll - Ok
C:\Windows\SysWOW64\mfc100fra.dll - Ok
C:\Windows\SysWOW64\mfc100jpn.dll - Ok
C:\Windows\SysWOW64\mfc100kor.dll - Ok
C:\Windows\SysWOW64\mfc100rus.dll - Ok
C:\Windows\SysWOW64\mdminst.dll - Ok
C:\Windows\SysWOW64\mfc100ita.dll - Ok
C:\Windows\SysWOW64\mf.dll - Ok
C:\Windows\SysWOW64\MFC71CHS.DLL - Ok
C:\Windows\SysWOW64\ig4icd32.dll - Ok
C:\Windows\SysWOW64\MFC71CHT.DLL - Ok
C:\Windows\SysWOW64\MFC71DEU.DLL - Ok
C:\Windows\SysWOW64\MFC71ENU.DLL - Ok
C:\Windows\SysWOW64\mfc40u.dll - Ok
C:\Windows\SysWOW64\MFC71ESP.DLL - Ok
C:\Windows\SysWOW64\MFC71FRA.DLL - Ok
C:\Windows\SysWOW64\igd10umd32.dll - Ok
C:\Windows\SysWOW64\MFC71ITA.DLL - Ok
C:\Windows\SysWOW64\MFC71JPN.DLL - Ok
C:\Windows\SysWOW64\MFC71KOR.DLL - Ok
C:\Windows\SysWOW64\mfc42.dll - Ok
C:\Windows\SysWOW64\mfc40.dll - Ok
C:\Windows\SysWOW64\mfcm100.dll - Ok
C:\Windows\SysWOW64\mfcsubs.dll - Ok
C:\Windows\SysWOW64\mfc71.dll - Ok
C:\Windows\SysWOW64\mfcm100u.dll - Ok
C:\Windows\SysWOW64\mferror.dll - Ok
C:\Windows\SysWOW64\mfmjpegdec.dll - Ok
>C:\Windows\SysWOW64\mfplat.dll - packed by FLY-CODE
C:\Windows\SysWOW64\mfdvdec.dll - Ok
C:\Windows\SysWOW64\mfc42u.dll - Ok
C:\Windows\SysWOW64\mfh264enc.dll - Ok
C:\Windows\SysWOW64\mfpmp.exe - Ok
C:\Windows\SysWOW64\MFPlay.dll - Ok
C:\Windows\SysWOW64\mfvdsp.dll - Ok
C:\Windows\SysWOW64\mfps.dll - Ok
C:\Windows\SysWOW64\mgmtapi.dll - Ok
C:\Windows\SysWOW64\mfreadwrite.dll - Ok
C:\Windows\SysWOW64\midimap.dll - Ok
C:\Windows\SysWOW64\migisol.dll - Ok
C:\Windows\SysWOW64\mimefilt.dll - Ok
C:\Windows\SysWOW64\MigAutoPlay.exe - Ok
C:\Windows\SysWOW64\MFWMAAEC.DLL - Ok
C:\Windows\SysWOW64\mfplat.dll - Ok
C:\Windows\SysWOW64\miguiresource.dll - Ok
C:\Windows\SysWOW64\mlfcache.dat - Ok
C:\Windows\SysWOW64\mlang.dat - Ok
C:\Windows\SysWOW64\mmcico.dll - Ok
C:\Windows\SysWOW64\mmci.dll - Ok
C:\Windows\SysWOW64\mfc71u.dll - Ok
>C:\Windows\SysWOW64\mfc100u.dll is ZLIB container
C:\Windows\SysWOW64\mlang.dll - Ok
C:\Windows\SysWOW64\mmcbase.dll - Ok
C:\Windows\SysWOW64\mfc100u.dll - container
C:\Windows\SysWOW64\mfds.dll - Ok
C:\Windows\SysWOW64\mmcshext.dll - Ok
C:\Windows\SysWOW64\mode.com - Ok
C:\Windows\SysWOW64\more.com - Ok
>C:\Windows\SysWOW64\mobsync.exe - packed by FLY-CODE
C:\Windows\SysWOW64\moricons.dll - Ok
C:\Windows\SysWOW64\MMDevAPI.dll - Ok
C:\Windows\SysWOW64\mountvol.exe - Ok
C:\Windows\SysWOW64\modemui.dll - Ok
C:\Windows\SysWOW64\MP3DMOD.DLL - Ok
C:\Windows\SysWOW64\mobsync.exe - Ok
C:\Windows\SysWOW64\Mpeg2Data.ax - Ok
C:\Windows\SysWOW64\mmsys.cpl - Ok
C:\Windows\SysWOW64\MP43DECD.DLL - Ok
C:\Windows\SysWOW64\MP4SDECD.DLL - Ok
C:\Windows\SysWOW64\mpg2splt.ax - Ok
>C:\Windows\SysWOW64\mfc100.dll is ZLIB container
C:\Windows\SysWOW64\mprdim.dll - Ok
C:\Windows\SysWOW64\MPG4DECD.DLL - Ok
C:\Windows\SysWOW64\mfc100.dll - container
C:\Windows\SysWOW64\mprddm.dll - Ok
C:\Windows\SysWOW64\mpr.dll - Ok
C:\Windows\SysWOW64\mprapi.dll - Ok
C:\Windows\SysWOW64\msacm32.drv - Ok
C:\Windows\SysWOW64\mprmsg.dll - Ok
C:\Windows\SysWOW64\MRINFO.EXE - Ok
C:\Windows\SysWOW64\msafd.dll - Ok
C:\Windows\SysWOW64\msaatext.dll - Ok
C:\Windows\SysWOW64\msasn1.dll - Ok
C:\Windows\SysWOW64\msadp32.acm - Ok
C:\Windows\SysWOW64\msaudite.dll - Ok
C:\Windows\SysWOW64\mscat32.dll - Ok
C:\Windows\SysWOW64\jscript9.dll - Ok
C:\Windows\SysWOW64\MSAC3ENC.DLL - Ok
C:\Windows\SysWOW64\mscpx32r.dLL - Ok
C:\Windows\SysWOW64\msacm32.dll - Ok
C:\Windows\SysWOW64\mmc.exe - Ok
C:\Windows\SysWOW64\mscories.dll - Ok
>C:\Windows\SysWOW64\mscpxl32.dLL - packed by FLY-CODE
C:\Windows\SysWOW64\mscorier.dll - Ok
C:\Windows\SysWOW64\msctfime.ime - Ok
C:\Windows\SysWOW64\msclmd.dll - Ok
C:\Windows\SysWOW64\mscandui.dll - Ok
C:\Windows\SysWOW64\mscms.dll - Ok
C:\Windows\SysWOW64\MsCtfMonitor.dll - Ok
C:\Windows\SysWOW64\mscoree.dll - Ok
C:\Windows\SysWOW64\msctfp.dll - Ok
C:\Windows\SysWOW64\msdatsrc.tlb - Ok
C:\Windows\SysWOW64\mscpxl32.dLL - Ok
C:\Windows\SysWOW64\msdart.dll - Ok
C:\Windows\SysWOW64\msdadiag.dll - Ok
C:\Windows\SysWOW64\msctfui.dll - Ok
C:\Windows\SysWOW64\msdmo.dll - Ok
C:\Windows\SysWOW64\msdelta.dll - Ok
C:\Windows\SysWOW64\msdrm.dll - Ok
C:\Windows\SysWOW64\msdxm.ocx - Ok
C:\Windows\SysWOW64\msdtcVSp1res.dll - Ok
C:\Windows\SysWOW64\msdxm.tlb - Ok
C:\Windows\SysWOW64\MSDvbNP.ax - Ok
C:\Windows\SysWOW64\msctf.dll - Ok
C:\Windows\SysWOW64\msfeedsbs.dll - Ok
C:\Windows\SysWOW64\mmcndmgr.dll - Ok
C:\Windows\SysWOW64\msdtcuiu.dll - Ok
C:\Windows\SysWOW64\msg711.acm - Ok
C:\Windows\SysWOW64\msdtcprx.dll - Ok
C:\Windows\SysWOW64\msfeedssync.exe - Ok
C:\Windows\SysWOW64\msexcl40.dll - Ok
C:\Windows\SysWOW64\msfeeds.dll - Ok
C:\Windows\SysWOW64\msgsm32.acm - Ok
C:\Windows\SysWOW64\msexch40.dll - Ok
C:\Windows\SysWOW64\mshtmler.dll - Ok
C:\Windows\SysWOW64\mshta.exe - Ok
C:\Windows\SysWOW64\msidle.dll - Ok
C:\Windows\SysWOW64\mshtmled.dll - Ok
C:\Windows\SysWOW64\msdt.exe - Ok
C:\Windows\SysWOW64\msidntld.dll - Ok
C:\Windows\SysWOW64\msident.dll - Ok
C:\Windows\SysWOW64\msidcrl30.dll - Ok
C:\Windows\SysWOW64\msiexec.exe - Ok
C:\Windows\SysWOW64\msimsg.dll - Ok
>C:\Windows\SysWOW64\msimg32.dll - packed by FLY-CODE
C:\Windows\SysWOW64\msiltcfg.dll - Ok
C:\Windows\SysWOW64\msimtf.dll - Ok
C:\Windows\SysWOW64\msimg32.dll - Ok
C:\Windows\SysWOW64\msihnd.dll - Ok
C:\Windows\SysWOW64\msieftp.dll - Ok
C:\Windows\SysWOW64\msisip.dll - Ok
C:\Windows\SysWOW64\msjint40.dll - Ok
C:\Windows\SysWOW64\msftedit.dll - Ok
C:\Windows\SysWOW64\msinfo32.exe - Ok
C:\Windows\SysWOW64\msjter40.dll - Ok
C:\Windows\SysWOW64\msjetoledb40.dll - Ok
C:\Windows\SysWOW64\msls31.dll - Ok
C:\Windows\SysWOW64\mshtmlmedia.dll - Ok
C:\Windows\SysWOW64\msi.dll - Ok
C:\Windows\SysWOW64\msjtes40.dll - Ok
C:\Windows\SysWOW64\msltus40.dll - Ok
C:\Windows\SysWOW64\msobjs.dll - Ok
C:\Windows\SysWOW64\mshtml.tlb - Ok
>C:\Windows\SysWOW64\msnetobj.dll - packed by FLY-CODE
C:\Windows\SysWOW64\msjava.dll - Ok
C:\Windows\SysWOW64\MSNP.ax - Ok
C:\Windows\SysWOW64\msoert2.dll - Ok
C:\Windows\SysWOW64\msorc32r.dll - Ok
C:\Windows\SysWOW64\msjet40.dll - Ok
C:\Windows\SysWOW64\MSMPEG2ENC.DLL - Ok
>C:\Windows\SysWOW64\mspatcha.dll - packed by FLY-CODE
C:\Windows\SysWOW64\msoeacct.dll - Ok
C:\Windows\SysWOW64\msorcl32.dll - Ok
C:\Windows\SysWOW64\MsraLegacy.tlb - Ok
C:\Windows\SysWOW64\msports.dll - Ok
C:\Windows\SysWOW64\mshtml.dll - Ok
C:\Windows\SysWOW64\mspatcha.dll - Ok
C:\Windows\SysWOW64\mspbde40.dll - Ok
C:\Windows\SysWOW64\msrating.dll - Ok
>C:\Windows\SysWOW64\MsRdpWebAccess.dll - packed by FLY-CODE
C:\Windows\SysWOW64\msmpeg2adec.dll - Ok
C:\Windows\SysWOW64\msra.exe - Ok
C:\Windows\SysWOW64\msrdc.dll - Ok
C:\Windows\SysWOW64\msrd2x40.dll - Ok
C:\Windows\SysWOW64\msrle32.dll - Ok
C:\Windows\SysWOW64\msrd3x40.dll - Ok
C:\Windows\SysWOW64\msscntrs.dll - Ok
C:\Windows\SysWOW64\MsRdpWebAccess.dll - Ok
C:\Windows\SysWOW64\msshooks.dll - Ok
C:\Windows\SysWOW64\msscript.ocx - Ok
C:\Windows\SysWOW64\mssip32.dll - Ok
C:\Windows\SysWOW64\mssign32.dll - Ok
C:\Windows\SysWOW64\mssha.dll - Ok
C:\Windows\SysWOW64\msshavmsg.dll - Ok
C:\Windows\SysWOW64\msnetobj.dll - Ok
C:\Windows\SysWOW64\msrepl40.dll - Ok
C:\Windows\SysWOW64\mssprxy.dll - Ok
C:\Windows\SysWOW64\mssitlb.dll - Ok
C:\Windows\SysWOW64\msswch.dll - Ok
C:\Windows\SysWOW64\mmres.dll - Ok
C:\Windows\SysWOW64\mssph.dll - Ok
C:\Windows\SysWOW64\mstask.dll - Ok
C:\Windows\SysWOW64\msmpeg2vdec.dll - Ok
C:\Windows\SysWOW64\mssphtb.dll - Ok
>C:\Windows\SysWOW64\msscp.dll - packed by FLY-CODE
C:\Windows\SysWOW64\msutb.dll - Ok
C:\Windows\SysWOW64\msv1_0.dll - Ok
C:\Windows\SysWOW64\msvcirt.dll - Ok
C:\Windows\SysWOW64\mssrch.dll - Ok
C:\Windows\SysWOW64\mstext40.dll - Ok
C:\Windows\SysWOW64\msvcp100.dll - Ok
C:\Windows\SysWOW64\msvbvm60.dll - Ok
C:\Windows\SysWOW64\mssvp.dll - Ok
C:\Windows\SysWOW64\msvcp60.dll - Ok
C:\Windows\SysWOW64\msvcrt40.dll - Ok
C:\Windows\SysWOW64\msvcr71.dll - Ok
C:\Windows\SysWOW64\msvcr100.dll - Ok
C:\Windows\SysWOW64\msvidc32.dll - Ok
C:\Windows\SysWOW64\msvcrt20.dll - Ok
C:\Windows\SysWOW64\mstsc.exe - Ok
C:\Windows\SysWOW64\msvcr100_clr0400.dll - Ok
C:\Windows\SysWOW64\msvcp71.dll - Ok
C:\Windows\SysWOW64\msvcrt.dll - Ok
C:\Windows\SysWOW64\msvfw32.dll - Ok
C:\Windows\SysWOW64\msxml3r.dll - Ok
C:\Windows\SysWOW64\mswsock.dll - Ok
C:\Windows\SysWOW64\msxml6r.dll - Ok
C:\Windows\SysWOW64\mswmdm.dll - Ok
C:\Windows\SysWOW64\msscp.dll - Ok
C:\Windows\SysWOW64\msxbde40.dll - Ok
C:\Windows\SysWOW64\msyuv.dll - Ok
C:\Windows\SysWOW64\mtxex.dll - Ok
C:\Windows\SysWOW64\mswdat10.dll - Ok
C:\Windows\SysWOW64\mswstr10.dll - Ok
C:\Windows\SysWOW64\mspaint.exe - Ok
C:\Windows\SysWOW64\mtxdm.dll - Ok
C:\Windows\SysWOW64\mtxlegih.dll - Ok
C:\Windows\SysWOW64\imageres.dll - Ok
C:\Windows\SysWOW64\mtstocom.exe - Ok
C:\Windows\SysWOW64\mtxoci.dll - Ok
C:\Windows\SysWOW64\muifontsetup.dll - Ok
C:\Windows\SysWOW64\MuiUnattend.exe - Ok
C:\Windows\SysWOW64\NAPCLCFG.MSC - Ok
C:\Windows\SysWOW64\mtxclu.dll - Ok
C:\Windows\SysWOW64\NAPCRYPT.DLL - Ok
C:\Windows\SysWOW64\MSVidCtl.dll - Ok
C:\Windows\SysWOW64\NAPHLPR.DLL - Ok
C:\Windows\SysWOW64\napdsnap.dll - Ok
C:\Windows\SysWOW64\mydocs.dll - Ok
C:\Windows\SysWOW64\napipsec.dll - Ok
C:\Windows\SysWOW64\mycomput.dll - Ok
C:\Windows\SysWOW64\NapiNSP.dll - Ok
C:\Windows\SysWOW64\NativeHooks.dll - Ok
C:\Windows\SysWOW64\NAPMONTR.DLL - Ok
C:\Windows\SysWOW64\Mystify.scr - Ok
C:\Windows\SysWOW64\NcdProp.dll - Ok
C:\Windows\SysWOW64\nci.dll - Ok
>C:\Windows\SysWOW64\ncryptui.dll - packed by FLY-CODE
C:\Windows\SysWOW64\nddeapi.dll - Ok
C:\Windows\SysWOW64\ncrypt.dll - Ok
C:\Windows\SysWOW64\ncpa.cpl - Ok
C:\Windows\SysWOW64\ncobjapi.dll - Ok
C:\Windows\SysWOW64\NdfEventView.xml - Ok
C:\Windows\SysWOW64\ndfetw.dll - Ok
>C:\Windows\SysWOW64\ndadmin.exe - packed by FLY-CODE
C:\Windows\SysWOW64\msxml3.dll - Ok
C:\Windows\SysWOW64\ncryptui.dll - Ok
C:\Windows\SysWOW64\ndiscapCfg.dll - Ok
C:\Windows\SysWOW64\NAPSTAT.EXE - Ok
C:\Windows\SysWOW64\ndfhcdiscovery.dll - Ok
C:\Windows\SysWOW64\ncsi.dll - Ok
C:\Windows\SysWOW64\ndproxystub.dll - Ok
C:\Windows\SysWOW64\ndishc.dll - Ok
C:\Windows\SysWOW64\ndfapi.dll - Ok
C:\Windows\SysWOW64\ndptsp.tsp - Ok
C:\Windows\SysWOW64\netapi32.dll - Ok
C:\Windows\SysWOW64\ndadmin.exe - Ok
C:\Windows\SysWOW64\netbtugc.exe - Ok
C:\Windows\SysWOW64\net.exe - Ok
C:\Windows\SysWOW64\netbios.dll - Ok
C:\Windows\SysWOW64\negoexts.dll - Ok
C:\Windows\SysWOW64\neth.dll - Ok
C:\Windows\SysWOW64\netevent.dll - Ok
C:\Windows\SysWOW64\netfxperf.dll - Ok
C:\Windows\SysWOW64\netiougc.exe - Ok
C:\Windows\SysWOW64\netcorehc.dll - Ok
C:\Windows\SysWOW64\net1.exe - Ok
C:\Windows\SysWOW64\netmsg.dll - Ok
C:\Windows\SysWOW64\netiohlp.dll - Ok
C:\Windows\SysWOW64\NaturalLanguage6.dll - Ok
C:\Windows\SysWOW64\netid.dll - Ok
C:\Windows\SysWOW64\netjoin.dll - Ok
C:\Windows\SysWOW64\Netplwiz.exe - Ok
C:\Windows\SysWOW64\netlogon.dll - Ok
C:\Windows\SysWOW64\netsh.exe - Ok
C:\Windows\SysWOW64\netplwiz.dll - Ok
C:\Windows\SysWOW64\netcfgx.dll - Ok
C:\Windows\SysWOW64\NETSTAT.EXE - Ok
>C:\Windows\SysWOW64\netutils.dll - packed by FLY-CODE
C:\Windows\SysWOW64\msxml6.dll - Ok
C:\Windows\SysWOW64\netprofm.dll - Ok
C:\Windows\SysWOW64\networkitemfactory.dll - Ok
C:\Windows\SysWOW64\netdiagfx.dll - Ok
C:\Windows\SysWOW64\netprof.dll - Ok
C:\Windows\SysWOW64\netutils.dll - Ok
C:\Windows\SysWOW64\nlaapi.dll - Ok
C:\Windows\SysWOW64\nlmsprep.dll - Ok
C:\Windows\SysWOW64\nlsbres.dll - Ok
C:\Windows\SysWOW64\netcenter.dll - Ok
C:\Windows\SysWOW64\nlhtml.dll - Ok
C:\Windows\SysWOW64\networkexplorer.dll - Ok
C:\Windows\SysWOW64\newdev.exe - Ok
C:\Windows\SysWOW64\newdev.dll - Ok
C:\Windows\SysWOW64\nlmgp.dll - Ok
C:\Windows\SysWOW64\mstscax.dll - Ok
C:\Windows\SysWOW64\NlsData0001.dll - Ok
C:\Windows\SysWOW64\NlsData0000.dll - Ok
C:\Windows\SysWOW64\NlsData0007.dll - Ok
C:\Windows\SysWOW64\NlsData0003.dll - Ok
C:\Windows\SysWOW64\NlsData000f.dll - Ok
C:\Windows\SysWOW64\NlsData0002.dll - Ok
C:\Windows\SysWOW64\NlsData000c.dll - Ok
C:\Windows\SysWOW64\NlsData000d.dll - Ok
C:\Windows\SysWOW64\networkmap.dll - Ok
C:\Windows\SysWOW64\netshell.dll - Ok
C:\Windows\SysWOW64\NlsData0018.dll - Ok
C:\Windows\SysWOW64\NlsData0009.dll - Ok
C:\Windows\SysWOW64\NlsData001a.dll - Ok
C:\Windows\SysWOW64\NlsData001b.dll - Ok
C:\Windows\SysWOW64\NlsData0011.dll - Ok
C:\Windows\SysWOW64\NlsData0022.dll - Ok
C:\Windows\SysWOW64\NlsData0021.dll - Ok
C:\Windows\SysWOW64\NlsData0020.dll - Ok
C:\Windows\SysWOW64\NlsData0026.dll - Ok
C:\Windows\SysWOW64\NlsData0027.dll - Ok
C:\Windows\SysWOW64\NlsData0010.dll - Ok
C:\Windows\SysWOW64\NlsData002a.dll - Ok
C:\Windows\SysWOW64\NlsData0024.dll - Ok
C:\Windows\SysWOW64\NlsData001d.dll - Ok
C:\Windows\SysWOW64\NlsData003e.dll - Ok
C:\Windows\SysWOW64\NlsData0046.dll - Ok
C:\Windows\SysWOW64\NlsData0047.dll - Ok
C:\Windows\SysWOW64\NlsData0019.dll - Ok
C:\Windows\SysWOW64\NlsData0045.dll - Ok
C:\Windows\SysWOW64\NlsData0049.dll - Ok
C:\Windows\SysWOW64\NlsData0039.dll - Ok
C:\Windows\SysWOW64\Nlsdl.dll - Ok
C:\Windows\SysWOW64\NlsData004a.dll - Ok
C:\Windows\SysWOW64\NlsData004b.dll - Ok
C:\Windows\SysWOW64\NlsData004e.dll - Ok
C:\Windows\SysWOW64\NlsData004c.dll - Ok
C:\Windows\SysWOW64\NlsData081a.dll - Ok
C:\Windows\SysWOW64\NlsData0c1a.dll - Ok
C:\Windows\SysWOW64\NlsData000a.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0003.dll - Ok
C:\Windows\SysWOW64\NlsData0416.dll - Ok
C:\Windows\SysWOW64\NlsData0414.dll - Ok
C:\Windows\SysWOW64\NlsLexicons000d.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0009.dll - Ok
C:\Windows\SysWOW64\NlsData0816.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0011.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0010.dll - Ok
C:\Windows\SysWOW64\NlsLexicons000f.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0018.dll - Ok
C:\Windows\SysWOW64\NlsLexicons000c.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0020.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0019.dll - Ok
C:\Windows\SysWOW64\NlsLexicons001a.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0021.dll - Ok
C:\Windows\SysWOW64\NlsData0013.dll - Ok
C:\Windows\SysWOW64\NlsLexicons002a.dll - Ok
C:\Windows\SysWOW64\NlsLexicons001b.dll - Ok
C:\Windows\SysWOW64\NlsLexicons000a.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0039.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0046.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0045.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0047.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0022.dll - Ok
C:\Windows\SysWOW64\NlsLexicons003e.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0049.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0026.dll - Ok
C:\Windows\SysWOW64\NlsLexicons004b.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0027.dll - Ok
C:\Windows\SysWOW64\NlsLexicons004e.dll - Ok
C:\Windows\SysWOW64\NlsLexicons001d.dll - Ok
C:\Windows\SysWOW64\NlsLexicons004a.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0414.dll - Ok
C:\Windows\SysWOW64\NOISE.CHS - Ok
C:\Windows\SysWOW64\NOISE.CHT - Ok
C:\Windows\SysWOW64\NOISE.DAT - Ok
C:\Windows\SysWOW64\noise.jpn - Ok
C:\Windows\SysWOW64\noise.kor - Ok
C:\Windows\SysWOW64\NOISE.THA - Ok
C:\Windows\SysWOW64\NlsLexicons004c.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0024.dll - Ok
C:\Windows\SysWOW64\npmproxy.dll - Ok
C:\Windows\SysWOW64\nshhttp.dll - Ok
C:\Windows\SysWOW64\nshipsec.dll - Ok
C:\Windows\SysWOW64\nshwfp.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0416.dll - Ok
C:\Windows\SysWOW64\nslookup.exe - Ok
C:\Windows\SysWOW64\NlsLexicons0816.dll - Ok
C:\Windows\SysWOW64\normaliz.dll - Ok
>C:\Windows\SysWOW64\nsi.dll - packed by FLY-CODE
C:\Windows\SysWOW64\nsi.dll - Ok
C:\Windows\SysWOW64\ntlanman.dll - Ok
C:\Windows\SysWOW64\ntdsapi.dll - Ok
C:\Windows\SysWOW64\notepad.exe - Ok
>C:\Windows\SysWOW64\ntlanui2.dll - packed by FLY-CODE
C:\Windows\SysWOW64\ntlanui2.dll - Ok
C:\Windows\SysWOW64\NlsLexicons081a.dll - Ok
C:\Windows\SysWOW64\ntprint.exe - Ok
C:\Windows\SysWOW64\ntmarta.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0c1a.dll - Ok
C:\Windows\SysWOW64\ntprint.dll - Ok
C:\Windows\SysWOW64\ntshrui.dll - Ok
C:\Windows\SysWOW64\occache.dll - Ok
C:\Windows\SysWOW64\NlsModels0011.dll - Ok
C:\Windows\SysWOW64\ocsetapi.dll - Ok
C:\Windows\SysWOW64\objsel.dll - Ok
C:\Windows\SysWOW64\odbcad32.exe - Ok
C:\Windows\SysWOW64\ocsetup.exe - Ok
C:\Windows\SysWOW64\odbc32gt.dll - Ok
C:\Windows\SysWOW64\ntvdm64.dll - Ok
C:\Windows\SysWOW64\odbcconf.rsp - Ok
C:\Windows\SysWOW64\odbcbcp.dll - Ok
C:\Windows\SysWOW64\odbcconf.dll - Ok
C:\Windows\SysWOW64\odbc32.dll - Ok
C:\Windows\SysWOW64\odbccr32.dll - Ok
C:\Windows\SysWOW64\odbccp32.dll - Ok
C:\Windows\SysWOW64\odbccu32.dll - Ok
C:\Windows\SysWOW64\odbcint.dll - Ok
C:\Windows\SysWOW64\odbcconf.exe - Ok
C:\Windows\SysWOW64\odbctrac.dll - Ok
C:\Windows\SysWOW64\odfox32.dll - Ok
C:\Windows\SysWOW64\oddbse32.dll - Ok
C:\Windows\SysWOW64\odbcjt32.dll - Ok
C:\Windows\SysWOW64\odtext32.dll - Ok
C:\Windows\SysWOW64\odpdx32.dll - Ok
C:\Windows\SysWOW64\odexl32.dll - Ok
>C:\Windows\SysWOW64\oflc.rs is ZLIB container
C:\Windows\SysWOW64\NlsLexicons0007.dll - Ok
C:\Windows\SysWOW64\Oemdspif.dll - Ok
C:\Windows\SysWOW64\ole2.dll - Ok
C:\Windows\SysWOW64\oflc.rs - container
C:\Windows\SysWOW64\odbcji32.dll - Ok
C:\Windows\SysWOW64\ole2nls.dll - Ok
C:\Windows\SysWOW64\offfilt.dll - Ok
C:\Windows\SysWOW64\oflc-nz.rs - Ok
C:\Windows\SysWOW64\oleaccrc.dll - Ok
C:\Windows\SysWOW64\ole2disp.dll - Ok
C:\Windows\SysWOW64\oleacchooks.dll - Ok
C:\Windows\SysWOW64\oledlg.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0002.dll - Ok
C:\Windows\SysWOW64\olecli32.dll - Ok
C:\Windows\SysWOW64\oleacc.dll - Ok
C:\Windows\SysWOW64\oleaut32.dll - Ok
C:\Windows\SysWOW64\olepro32.dll - Ok
C:\Windows\SysWOW64\ogldrv.dll - Ok
C:\Windows\SysWOW64\oleres.dll - Ok
C:\Windows\SysWOW64\oleprn.dll - Ok
C:\Windows\SysWOW64\olesvr32.dll - Ok
C:\Windows\SysWOW64\olethk32.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0001.dll - Ok
C:\Windows\SysWOW64\OpenCL.dll - Ok
C:\Windows\SysWOW64\onex.dll - Ok
>C:\Windows\SysWOW64\ole32.dll is BINARYRES container
C:\Windows\SysWOW64\opengl32.dll - Ok
C:\Windows\SysWOW64\ole32.dll - container
C:\Windows\SysWOW64\OnLineIDCpl.dll - Ok
C:\Windows\SysWOW64\openfiles.exe - Ok
C:\Windows\SysWOW64\osbaseln.dll - Ok
C:\Windows\SysWOW64\OVDecode.dll - Ok
C:\Windows\SysWOW64\osuninst.dll - Ok
C:\Windows\SysWOW64\OptionalFeatures.exe - Ok
C:\Windows\SysWOW64\p2pcollab.dll - Ok
C:\Windows\SysWOW64\p2pnetsh.dll - Ok
C:\Windows\SysWOW64\P2P.dll - Ok
C:\Windows\SysWOW64\P2PGraph.dll - Ok
C:\Windows\SysWOW64\NlsLexicons0013.dll - Ok
C:\Windows\SysWOW64\osk.exe - Ok
C:\Windows\SysWOW64\OobeFldr.dll - Ok
C:\Windows\SysWOW64\pcl.sep - Ok
C:\Windows\SysWOW64\panmap.dll - Ok
C:\Windows\SysWOW64\pcwum.dll - Ok
C:\Windows\SysWOW64\pautoenr.dll - Ok
C:\Windows\SysWOW64\pcaui.dll - Ok
C:\Windows\SysWOW64\pcaui.exe - Ok
>C:\Windows\SysWOW64\PATHPING.EXE - packed by FLY-CODE
C:\Windows\SysWOW64\pdh.dll - Ok
C:\Windows\SysWOW64\pdhui.dll - Ok
>C:\Windows\SysWOW64\pegi-fi.rs is ZLIB container
C:\Windows\SysWOW64\packager.dll - Ok
>C:\Windows\SysWOW64\pegi.rs is ZLIB container
C:\Windows\SysWOW64\PerfCenterCpl.ico - Ok
C:\Windows\SysWOW64\pegi.rs - container
C:\Windows\SysWOW64\onexui.dll - Ok
C:\Windows\SysWOW64\pegi-fi.rs - container
>C:\Windows\SysWOW64\pegi-pt.rs is ZLIB container
>C:\Windows\SysWOW64\pegibbfc.rs is ZLIB container
C:\Windows\SysWOW64\PATHPING.EXE - Ok
C:\Windows\SysWOW64\pegi-pt.rs - container
C:\Windows\SysWOW64\pegibbfc.rs - container
C:\Windows\SysWOW64\ntdll.dll - Ok
C:\Windows\SysWOW64\perfhost.exe - Ok
C:\Windows\SysWOW64\perfdisk.dll - Ok
C:\Windows\SysWOW64\perfctrs.dll - Ok
C:\Windows\SysWOW64\perfts.dll - Ok
C:\Windows\SysWOW64\perfnet.dll - Ok
C:\Windows\SysWOW64\perfos.dll - Ok
C:\Windows\SysWOW64\perfproc.dll - Ok
C:\Windows\SysWOW64\pid.dll - Ok
C:\Windows\SysWOW64\perfmon.msc - Ok
C:\Windows\SysWOW64\PerfCenterCPL.dll - Ok
C:\Windows\SysWOW64\phon.ime - Ok
C:\Windows\SysWOW64\PhotoMetadataHandler.dll - Ok
C:\Windows\SysWOW64\pifmgr.dll - Ok
>C:\Windows\SysWOW64\PING.EXE - packed by FLY-CODE
C:\Windows\SysWOW64\pintlgnt.ime - Ok
C:\Windows\SysWOW64\perfmon.exe - Ok
C:\Windows\SysWOW64\pku2u.dll - Ok
C:\Windows\SysWOW64\OpcServices.dll - Ok
C:\Windows\SysWOW64\pngfilt.dll - Ok
C:\Windows\SysWOW64\PING.EXE - Ok
C:\Windows\SysWOW64\photowiz.dll - Ok
C:\Windows\SysWOW64\PkgMgr.exe - Ok
>C:\Windows\SysWOW64\PhotoScreensaver.scr is ZLIB container
C:\Windows\SysWOW64\PlaySndSrv.dll - Ok
C:\Windows\SysWOW64\pnrpnsp.dll - Ok
C:\Windows\SysWOW64\polstore.dll - Ok
>C:\Windows\SysWOW64\pnpsetup.dll - packed by FLY-CODE
C:\Windows\SysWOW64\PortableDeviceConnectApi.dll - Ok
C:\Windows\SysWOW64\pnpsetup.dll - Ok
C:\Windows\SysWOW64\PortableDeviceClassExtension.dll - Ok
C:\Windows\SysWOW64\PhotoScreensaver.scr - container
C:\Windows\SysWOW64\poqexec.exe - Ok
C:\Windows\SysWOW64\PortableDeviceSyncProvider.dll - Ok
C:\Windows\SysWOW64\PortableDeviceApi.dll - Ok
>C:\Windows\SysWOW64\pidgenx.dll - packed by FLY-CODE
C:\Windows\SysWOW64\PortableDeviceWiaCompat.dll - Ok
C:\Windows\SysWOW64\PortableDeviceTypes.dll - Ok
C:\Windows\SysWOW64\pots.dll - Ok
C:\Windows\SysWOW64\powercfg.exe - Ok
C:\Windows\SysWOW64\PortableDeviceStatus.dll - Ok
C:\Windows\SysWOW64\powercfg.cpl - Ok
C:\Windows\SysWOW64\PortableDeviceWMDRM.dll - Ok
C:\Windows\SysWOW64\PresentationHostProxy.dll - Ok
C:\Windows\SysWOW64\powercpl.dll - Ok
C:\Windows\SysWOW64\PresentationCFFRasterizerNative_v0300.dll - Ok
C:\Windows\SysWOW64\prflbmsg.dll - Ok
C:\Windows\SysWOW64\prevhost.exe - Ok
>C:\Windows\SysWOW64\print.exe - packed by FLY-CODE
C:\Windows\SysWOW64\pla.dll - Ok
C:\Windows\SysWOW64\powrprof.dll - Ok
C:\Windows\SysWOW64\prncache.dll - Ok
C:\Windows\SysWOW64\printui.exe - Ok
C:\Windows\SysWOW64\print.exe - Ok
C:\Windows\SysWOW64\prnntfy.dll - Ok
C:\Windows\SysWOW64\pidgenx.dll - Ok
C:\Windows\SysWOW64\profapi.dll - Ok
C:\Windows\SysWOW64\pnidui.dll - Ok
C:\Windows\SysWOW64\printui.dll - Ok
C:\Windows\SysWOW64\prnfldr.dll - Ok
C:\Windows\SysWOW64\prntvpt.dll - Ok
C:\Windows\SysWOW64\pscript.sep - Ok
C:\Windows\SysWOW64\PresentationHost.exe - Ok
C:\Windows\SysWOW64\proquota.exe - Ok
C:\Windows\SysWOW64\psapi.dll - Ok
C:\Windows\SysWOW64\psbase.dll - Ok
C:\Windows\SysWOW64\PSHED.DLL - Ok
C:\Windows\SysWOW64\pstorec.dll - Ok
C:\Windows\SysWOW64\provsvc.dll - Ok
C:\Windows\SysWOW64\propsys.dll - Ok
C:\Windows\SysWOW64\psisrndr.ax - Ok
C:\Windows\SysWOW64\pstorsvc.dll - Ok
C:\Windows\SysWOW64\provthrd.dll - Ok
C:\Windows\SysWOW64\PresentationNative_v0300.dll - Ok
C:\Windows\SysWOW64\pwrshplugin.dll - Ok
C:\Windows\SysWOW64\puiapi.dll - Ok
C:\Windows\SysWOW64\QCLIPROV.DLL - Ok
C:\Windows\SysWOW64\qcap.dll - Ok
C:\Windows\SysWOW64\puiobj.dll - Ok
C:\Windows\SysWOW64\qdv.dll - Ok
C:\Windows\SysWOW64\psisdecd.dll - Ok
C:\Windows\SysWOW64\qmgrprxy.dll - Ok
C:\Windows\SysWOW64\QAGENT.DLL - Ok
C:\Windows\SysWOW64\QSVRMGMT.DLL - Ok
C:\Windows\SysWOW64\qasf.dll - Ok
C:\Windows\SysWOW64\qintlgnt.ime - Ok
C:\Windows\SysWOW64\QSHVHOST.DLL - Ok
C:\Windows\SysWOW64\qedit.dll - Ok
C:\Windows\SysWOW64\QUTIL.DLL - Ok
C:\Windows\SysWOW64\quick.ime - Ok
C:\Windows\SysWOW64\psr.exe - Ok
C:\Windows\SysWOW64\RacRules.xml - Ok
C:\Windows\SysWOW64\qdvd.dll - Ok
C:\Windows\SysWOW64\qwave.dll - Ok
C:\Windows\SysWOW64\rasadhlp.dll - Ok
>C:\Windows\SysWOW64\racpldlg.dll is ZLIB container
C:\Windows\SysWOW64\radardt.dll - Ok
C:\Windows\SysWOW64\radarrs.dll - Ok
C:\Windows\SysWOW64\rasautou.exe - Ok
C:\Windows\SysWOW64\racpldlg.dll - container
C:\Windows\SysWOW64\ntkrnlpa.exe - Ok
C:\Windows\SysWOW64\rasctrnm.h - Ok
C:\Windows\SysWOW64\qedwipes.dll - Ok
C:\Windows\SysWOW64\rasctrs.dll - Ok
C:\Windows\SysWOW64\rascfg.dll - Ok
C:\Windows\SysWOW64\rasdiag.dll - Ok
C:\Windows\SysWOW64\rasdial.exe - Ok
C:\Windows\SysWOW64\rasapi32.dll - Ok
C:\Windows\SysWOW64\raschap.dll - Ok
C:\Windows\SysWOW64\rasman.dll - Ok
C:\Windows\SysWOW64\ntoskrnl.exe - Ok
C:\Windows\SysWOW64\rasmontr.dll - Ok
C:\Windows\SysWOW64\Query.dll - Ok
C:\Windows\SysWOW64\raserver.exe - Ok
C:\Windows\SysWOW64\rasphone.exe - Ok
C:\Windows\SysWOW64\rasmxs.dll - Ok
C:\Windows\SysWOW64\quartz.dll - Ok
C:\Windows\SysWOW64\rasser.dll - Ok
C:\Windows\SysWOW64\rasplap.dll - Ok
C:\Windows\SysWOW64\rasdlg.dll - Ok
C:\Windows\SysWOW64\rasppp.dll - Ok
C:\Windows\SysWOW64\rdpd3d.dll - Ok
C:\Windows\SysWOW64\rastapi.dll - Ok
C:\Windows\SysWOW64\rdprefdrvapi.dll - Ok
C:\Windows\SysWOW64\RASMM.dll - Ok
C:\Windows\SysWOW64\rastls.dll - Ok
C:\Windows\SysWOW64\ReAgentc.exe - Ok
C:\Windows\SysWOW64\rdrleakdiag.exe - Ok
C:\Windows\SysWOW64\rasgcw.dll - Ok
C:\Windows\SysWOW64\recover.exe - Ok
C:\Windows\SysWOW64\rdpencom.dll - Ok
C:\Windows\SysWOW64\regapi.dll - Ok
C:\Windows\SysWOW64\RegCtrl.dll - Ok
C:\Windows\SysWOW64\regedt32.exe - Ok
C:\Windows\SysWOW64\reg.exe - Ok
C:\Windows\SysWOW64\ReAgent.dll - Ok
C:\Windows\SysWOW64\RacEngn.dll - Ok
C:\Windows\SysWOW64\regini.exe - Ok
C:\Windows\SysWOW64\rendezvousSession.tlb - Ok
>C:\Windows\SysWOW64\regsvr32.exe - packed by FLY-CODE
C:\Windows\SysWOW64\relog.exe - Ok
C:\Windows\SysWOW64\RegisterIEPKEYs.exe - Ok
C:\Windows\SysWOW64\RestartManagerUninstall.mof - Ok
C:\Windows\SysWOW64\RestartManager.mof - Ok
C:\Windows\SysWOW64\rekeywiz.exe - Ok
C:\Windows\SysWOW64\remotesp.tsp - Ok
C:\Windows\SysWOW64\replace.exe - Ok
C:\Windows\SysWOW64\remotepg.dll - Ok
C:\Windows\SysWOW64\resutils.dll - Ok
C:\Windows\SysWOW64\RESAMPLEDMO.DLL - Ok
C:\Windows\SysWOW64\riched32.dll - Ok
C:\Windows\SysWOW64\resmon.exe - Ok
C:\Windows\SysWOW64\rgb9rast.dll - Ok
C:\Windows\SysWOW64\regsvr32.exe - Ok
C:\Windows\SysWOW64\rnr20.dll - Ok
C:\Windows\SysWOW64\rdpcore.dll - Ok
C:\Windows\SysWOW64\RpcDiag.dll - Ok
C:\Windows\SysWOW64\RmClient.exe - Ok
>C:\Windows\SysWOW64\RMActivate_isv.exe - packed by FLY-CODE
C:\Windows\SysWOW64\Robocopy.exe - Ok
>C:\Windows\SysWOW64\RMActivate_ssp.exe - packed by FLY-CODE
C:\Windows\SysWOW64\rpchttp.dll - Ok
C:\Windows\SysWOW64\rpcnsh.dll - Ok
C:\Windows\SysWOW64\RPCNDFP.dll - Ok
>C:\Windows\SysWOW64\RMActivate_ssp_isv.exe - packed by FLY-CODE
C:\Windows\SysWOW64\RpcNs4.dll - Ok
C:\Windows\SysWOW64\RpcPing.exe - Ok
>C:\Windows\SysWOW64\ROUTE.EXE - packed by FLY-CODE
C:\Windows\SysWOW64\Ribbons.scr - Ok
C:\Windows\SysWOW64\RpcRtRemote.dll - Ok
>C:\Windows\SysWOW64\RMActivate.exe - packed by FLY-CODE
C:\Windows\SysWOW64\rshx32.dll - Ok
C:\Windows\SysWOW64\riched20.dll - Ok
C:\Windows\SysWOW64\rsaenh.dll - Ok
C:\Windows\SysWOW64\rrinstaller.exe - Ok
C:\Windows\SysWOW64\regedit.exe - Ok
C:\Windows\SysWOW64\rtffilt.dll - Ok
C:\Windows\SysWOW64\RMActivate_ssp.exe - Ok
C:\Windows\SysWOW64\RMActivate_isv.exe - Ok
C:\Windows\SysWOW64\RstrtMgr.dll - Ok
C:\Windows\SysWOW64\rpcrt4.dll - Ok
C:\Windows\SysWOW64\RMActivate_ssp_isv.exe - Ok
C:\Windows\SysWOW64\rtm.dll - Ok
>C:\Windows\SysWOW64\runas.exe - packed by FLY-CODE
C:\Windows\SysWOW64\rundll32.exe - Ok
C:\Windows\SysWOW64\SampleRes.dll - Ok
C:\Windows\SysWOW64\samlib.dll - Ok
C:\Windows\SysWOW64\RunLegacyCPLElevated.exe - Ok
C:\Windows\SysWOW64\ROUTE.EXE - Ok
C:\Windows\SysWOW64\sas.dll - Ok
C:\Windows\SysWOW64\samcli.dll - Ok
C:\Windows\SysWOW64\rtutils.dll - Ok
C:\Windows\SysWOW64\RMActivate.exe - Ok
C:\Windows\SysWOW64\runonce.exe - Ok
C:\Windows\SysWOW64\runas.exe - Ok
C:\Windows\SysWOW64\sberes.dll - Ok
C:\Windows\SysWOW64\scecli.dll - Ok
C:\Windows\SysWOW64\sbunattend.exe - Ok
C:\Windows\SysWOW64\SCardDlg.dll - Ok
C:\Windows\SysWOW64\sbeio.dll - Ok
C:\Windows\SysWOW64\schedcli.dll - Ok
C:\Windows\SysWOW64\rtl70.bpl - Ok
C:\Windows\SysWOW64\scansetting.dll - Ok
C:\Windows\SysWOW64\sc.exe - Ok
>C:\Windows\SysWOW64\scripto.dll is BINARYRES container
C:\Windows\SysWOW64\scripto.dll - container
C:\Windows\SysWOW64\scrnsave.scr - Ok
C:\Windows\SysWOW64\schannel.dll - Ok
C:\Windows\SysWOW64\scksp.dll - Ok
C:\Windows\SysWOW64\sdbinst.exe - Ok
C:\Windows\SysWOW64\scesrv.dll - Ok
C:\Windows\SysWOW64\scrobj.dll - Ok
C:\Windows\SysWOW64\sdiagnhost.exe - Ok
C:\Windows\SysWOW64\scrrun.dll - Ok
C:\Windows\SysWOW64\schtasks.exe - Ok
C:\Windows\SysWOW64\sdchange.exe - Ok
C:\Windows\SysWOW64\sdiageng.dll - Ok
C:\Windows\SysWOW64\SearchFilterHost.exe - Ok
C:\Windows\SysWOW64\sechost.dll - Ok
C:\Windows\SysWOW64\SecEdit.exe - Ok
C:\Windows\SysWOW64\sdiagprv.dll - Ok
>C:\Windows\SysWOW64\secinit.exe - packed by FLY-CODE
C:\Windows\SysWOW64\sdohlp.dll - Ok
C:\Windows\SysWOW64\secproc_ssp.dll - Ok
C:\Windows\SysWOW64\SearchProtocolHost.exe - Ok
>C:\Windows\SysWOW64\secur32.dll - packed by FLY-CODE
C:\Windows\SysWOW64\secproc_ssp_isv.dll - Ok
C:\Windows\SysWOW64\security.dll - Ok
C:\Windows\SysWOW64\Sens.dll - Ok
C:\Windows\SysWOW64\secinit.exe - Ok
C:\Windows\SysWOW64\SensApi.dll - Ok
C:\Windows\SysWOW64\sendmail.dll - Ok
>C:\Windows\SysWOW64\secproc_isv.dll - packed by FLY-CODE
>C:\Windows\SysWOW64\secproc.dll - packed by FLY-CODE
C:\Windows\SysWOW64\SearchIndexer.exe - Ok
C:\Windows\SysWOW64\sbe.dll - Ok
C:\Windows\SysWOW64\secur32.dll - Ok
C:\Windows\SysWOW64\serialui.dll - Ok
C:\Windows\SysWOW64\services.msc - Ok
C:\Windows\SysWOW64\serwvdrv.dll - Ok
C:\Windows\SysWOW64\SensorsApi.dll - Ok
C:\Windows\SysWOW64\setup16.exe - Ok
C:\Windows\SysWOW64\SessEnv.dll - Ok
C:\Windows\SysWOW64\SearchFolder.dll - Ok
C:\Windows\SysWOW64\setupcln.dll - Ok
C:\Windows\SysWOW64\SetIEInstalledDate.exe - Ok
C:\Windows\SysWOW64\sfc.dll - Ok
C:\Windows\SysWOW64\setx.exe - Ok
>C:\Windows\SysWOW64\setupSNK.exe - packed by FLY-CODE
C:\Windows\SysWOW64\sfc_os.dll - Ok
C:\Windows\SysWOW64\sethc.exe - Ok
C:\Windows\SysWOW64\sfc.exe - Ok
C:\Windows\SysWOW64\setupugc.exe - Ok
C:\Windows\SysWOW64\shacct.dll - Ok
C:\Windows\SysWOW64\shfolder.dll - Ok
C:\Windows\SysWOW64\ShiftJIS.uce - Ok
C:\Windows\SysWOW64\setupSNK.exe - Ok
C:\Windows\SysWOW64\shdocvw.dll - Ok
C:\Windows\SysWOW64\secproc.dll - Ok
C:\Windows\SysWOW64\shgina.dll - Ok
C:\Windows\SysWOW64\shimgvw.dll - Ok
C:\Windows\SysWOW64\shimeng.dll - Ok
C:\Windows\SysWOW64\shpafact.dll - Ok
C:\Windows\SysWOW64\shunimpl.dll - Ok
C:\Windows\SysWOW64\shlwapi.dll - Ok
C:\Windows\SysWOW64\shutdown.exe - Ok
C:\Windows\SysWOW64\shsetup.dll - Ok
C:\Windows\SysWOW64\setupapi.dll - Ok
C:\Windows\SysWOW64\simpdata.tlb - Ok
C:\Windows\SysWOW64\shellstyle.dll - Ok
C:\Windows\SysWOW64\sirenacm.dll - Ok
C:\Windows\SysWOW64\shsvcs.dll - Ok
C:\Windows\SysWOW64\signdrv.dll - Ok
C:\Windows\SysWOW64\shrpubw.exe - Ok
C:\Windows\SysWOW64\sisbkup.dll - Ok
C:\Windows\SysWOW64\slc.dll - Ok
C:\Windows\SysWOW64\SensorsCpl.dll - Ok
C:\Windows\SysWOW64\slcext.dll - Ok
C:\Windows\SysWOW64\SlotMaximizerAg.dll - Ok
C:\Windows\SysWOW64\shwebsvc.dll - Ok
C:\Windows\SysWOW64\SmartcardCredentialProvider.dll - Ok
C:\Windows\SysWOW64\SMBHelperClass.dll - Ok
C:\Windows\SysWOW64\snmpapi.dll - Ok
C:\Windows\SysWOW64\slwga.dll - Ok
C:\Windows\SysWOW64\secproc_isv.dll - Ok
C:\Windows\SysWOW64\softpub.dll - Ok
C:\Windows\SysWOW64\SortServer2003Compat.dll - Ok
C:\Windows\SysWOW64\spbcd.dll - Ok
C:\Windows\SysWOW64\SortWindows6Compat.dll - Ok
C:\Windows\SysWOW64\sort.exe - Ok
C:\Windows\SysWOW64\softkbd.dll - Ok
C:\Windows\SysWOW64\spnet.dll - Ok
>C:\Windows\SysWOW64\spfileq.dll - packed by BINARYRES
>>C:\Windows\SysWOW64\spfileq.dll - packed by MS COMPRESS
C:\Windows\SysWOW64\SndVolSSO.dll - Ok
C:\Windows\SysWOW64\spopk.dll - Ok
C:\Windows\SysWOW64\spfileq.dll - Ok
C:\Windows\SysWOW64\SPInf.dll - Ok
C:\Windows\SysWOW64\slmgr.vbs - Ok
C:\Windows\SysWOW64\SndVol.exe - Ok
C:\Windows\SysWOW64\sppc.dll - Ok
C:\Windows\SysWOW64\spp.dll - Ok
C:\Windows\SysWOW64\spwinsat.dll - Ok
C:\Windows\SysWOW64\spwizres.dll - Ok
C:\Windows\SysWOW64\sppinst.dll - Ok
C:\Windows\SysWOW64\sppwmi.dll - Ok
C:\Windows\SysWOW64\sppcomapi.dll - Ok
C:\Windows\SysWOW64\sppcommdlg.dll - Ok
C:\Windows\SysWOW64\sppcc.dll - Ok
C:\Windows\SysWOW64\spwizeng.dll - Ok
C:\Windows\SysWOW64\sqlsrv32.rll - Ok
C:\Windows\SysWOW64\sqlceoledb30.dll - Ok
C:\Windows\SysWOW64\spwmp.dll - Ok
C:\Windows\SysWOW64\sqlcese30.dll - Ok
C:\Windows\SysWOW64\sqlwid.dll - Ok
C:\Windows\SysWOW64\sqlunirl.dll - Ok
C:\Windows\SysWOW64\sqlwoa.dll - Ok
C:\Windows\SysWOW64\sqlceqp30.dll - Ok
C:\Windows\SysWOW64\srclient.dll - Ok
C:\Windows\SysWOW64\srchadmin.dll - Ok
>C:\Windows\SysWOW64\sppcext.dll - packed by FLY-CODE
C:\Windows\SysWOW64\sqmapi.dll - Ok
>C:\Windows\SysWOW64\srdelayed.exe - packed by FLY-CODE
C:\Windows\SysWOW64\sscore.dll - Ok
C:\Windows\SysWOW64\srhelper.dll - Ok
C:\Windows\SysWOW64\sqlsrv32.dll - Ok
C:\Windows\SysWOW64\srvcli.dll - Ok
C:\Windows\SysWOW64\ssdpapi.dll - Ok
C:\Windows\SysWOW64\sspicli.dll - Ok
C:\Windows\SysWOW64\srdelayed.exe - Ok
C:\Windows\SysWOW64\SSShim.dll - Ok
C:\Windows\SysWOW64\storage.dll - Ok
C:\Windows\SysWOW64\stdole32.tlb - Ok
C:\Windows\SysWOW64\stclient.dll - Ok
C:\Windows\SysWOW64\stdole2.tlb - Ok
C:\Windows\SysWOW64\SubRange.uce - Ok
C:\Windows\SysWOW64\StorageContextHandler.dll - Ok
C:\Windows\SysWOW64\sti.dll - Ok
C:\Windows\SysWOW64\Storprop.dll - Ok
>C:\Windows\SysWOW64\subst.exe - packed by FLY-CODE
C:\Windows\SysWOW64\stobject.dll - Ok
C:\Windows\SysWOW64\StructuredQuery.dll - Ok
C:\Windows\SysWOW64\ssText3d.scr - Ok
C:\Windows\SysWOW64\shell32.dll - Ok
C:\Windows\SysWOW64\svchost.exe - Ok
C:\Windows\SysWOW64\sxproxy.dll - Ok
C:\Windows\SysWOW64\sxshared.dll - Ok
C:\Windows\SysWOW64\subst.exe - Ok
C:\Windows\SysWOW64\synceng.dll - Ok
C:\Windows\SysWOW64\sxs.dll - Ok
C:\Windows\SysWOW64\sxsstore.dll - Ok
C:\Windows\SysWOW64\sxstrace.exe - Ok
C:\Windows\SysWOW64\SyncHostps.dll - Ok
C:\Windows\SysWOW64\sppcext.dll - Ok
C:\Windows\SysWOW64\SyncHost.exe - Ok
C:\Windows\SysWOW64\SyncInfrastructureps.dll - Ok
C:\Windows\SysWOW64\sud.dll - Ok
C:\Windows\SysWOW64\Syncreg.dll - Ok
C:\Windows\SysWOW64\SynTPEnhPS.dll - Ok
C:\Windows\SysWOW64\SynCOM.dll - Ok
C:\Windows\SysWOW64\SlotMaximizerBe.dll - Ok
C:\Windows\SysWOW64\sysprint.sep - Ok
C:\Windows\SysWOW64\sysprtj.sep - Ok
C:\Windows\SysWOW64\SynTPCOM.dll - Ok
C:\Windows\SysWOW64\SyncInfrastructure.dll - Ok
C:\Windows\SysWOW64\syssetup.dll - Ok
C:\Windows\SysWOW64\syskey.exe - Ok
C:\Windows\SysWOW64\syncui.dll - Ok
C:\Windows\SysWOW64\RtsPStorIcon.dll - Ok
C:\Windows\SysWOW64\systeminfo.exe - Ok
C:\Windows\SysWOW64\SystemPropertiesAdvanced.exe - Ok
C:\Windows\SysWOW64\SystemPropertiesComputerName.exe - Ok
C:\Windows\SysWOW64\sysdm.cpl - Ok
C:\Windows\SysWOW64\SystemPropertiesDataExecutionPrevention.exe - Ok
C:\Windows\SysWOW64\SynCtrl.dll - Ok
C:\Windows\SysWOW64\SystemPropertiesHardware.exe - Ok
C:\Windows\SysWOW64\SystemPropertiesProtection.exe - Ok
C:\Windows\SysWOW64\SystemPropertiesPerformance.exe - Ok
C:\Windows\SysWOW64\systray.exe - Ok
C:\Windows\SysWOW64\SystemPropertiesRemote.exe - Ok
C:\Windows\SysWOW64\sysmon.ocx - Ok
C:\Windows\SysWOW64\systemcpl.dll - Ok
C:\Windows\SysWOW64\t2embed.dll - Ok
C:\Windows\SysWOW64\tapiperf.dll - Ok
C:\Windows\SysWOW64\takeown.exe - Ok
C:\Windows\SysWOW64\TapiSysprep.dll - Ok
C:\Windows\SysWOW64\TapiMigPlugin.dll - Ok
C:\Windows\SysWOW64\TapiUnattend.exe - Ok
C:\Windows\SysWOW64\tapi32.dll - Ok
C:\Windows\SysWOW64\tapiui.dll - Ok
C:\Windows\SysWOW64\taskkill.exe - Ok
C:\Windows\SysWOW64\tasklist.exe - Ok
C:\Windows\SysWOW64\tapisrv.dll - Ok
C:\Windows\SysWOW64\tcpbidi.xml - Ok
C:\Windows\SysWOW64\TaskSchdPS.dll - Ok
C:\Windows\SysWOW64\SyncCenter.dll - Ok
C:\Windows\SysWOW64\taskcomp.dll - Ok
C:\Windows\SysWOW64\taskschd.msc - Ok
>C:\Windows\SysWOW64\tbs.dll - packed by FLY-CODE
C:\Windows\SysWOW64\tcmsetup.exe - Ok
C:\Windows\SysWOW64\tcpmonui.dll - Ok
C:\Windows\SysWOW64\taskeng.exe - Ok
C:\Windows\SysWOW64\TCPSVCS.EXE - Ok
C:\Windows\SysWOW64\tdc.ocx - Ok
C:\Windows\SysWOW64\tbs.dll - Ok
C:\Windows\SysWOW64\taskmgr.exe - Ok
C:\Windows\SysWOW64\telephon.cpl - Ok
C:\Windows\SysWOW64\ticrf.rat - Ok
C:\Windows\SysWOW64\thawbrkr.dll - Ok
C:\Windows\SysWOW64\thumbcache.dll - Ok
C:\Windows\SysWOW64\tcpipcfg.dll - Ok
C:\Windows\SysWOW64\TimeDateMUICallback.dll - Ok
C:\Windows\SysWOW64\taskschd.dll - Ok
C:\Windows\SysWOW64\termmgr.dll - Ok
C:\Windows\SysWOW64\spwizimg.dll - Ok
C:\Windows\SysWOW64\tpm.msc - Ok
C:\Windows\SysWOW64\tlscsp.dll - Ok
C:\Windows\SysWOW64\timeout.exe - Ok
C:\Windows\SysWOW64\tintlgnt.ime - Ok
C:\Windows\SysWOW64\tpmcompc.dll - Ok
>C:\Windows\SysWOW64\TRACERT.EXE - packed by FLY-CODE
C:\Windows\SysWOW64\tapi3.dll - Ok
C:\Windows\SysWOW64\tdh.dll - Ok
C:\Windows\SysWOW64\themeui.dll - Ok
C:\Windows\SysWOW64\traffic.dll - Ok
C:\Windows\SysWOW64\tsbyuv.dll - Ok
C:\Windows\SysWOW64\TRAPI.dll - Ok
C:\Windows\SysWOW64\TpmInit.exe - Ok
C:\Windows\SysWOW64\tree.com - Ok
C:\Windows\SysWOW64\tsgqec.dll - Ok
>C:\Windows\SysWOW64\timedate.cpl is ZLIB container
C:\Windows\SysWOW64\TRACERT.EXE - Ok
C:\Windows\SysWOW64\TSChannel.dll - Ok
C:\Windows\SysWOW64\tracerpt.exe - Ok
C:\Windows\SysWOW64\TSpkg.dll - Ok
C:\Windows\SysWOW64\TsWpfWrp.exe - Ok
C:\Windows\SysWOW64\typelib.dll - Ok
C:\Windows\SysWOW64\timedate.cpl - container
C:\Windows\SysWOW64\tvratings.dll - Ok
C:\Windows\SysWOW64\txfw32.dll - Ok
C:\Windows\SysWOW64\tsmf.dll - Ok
C:\Windows\SysWOW64\tzres.dll - Ok
C:\Windows\SysWOW64\txflog.dll - Ok
C:\Windows\SysWOW64\udhisapi.dll - Ok
C:\Windows\SysWOW64\typeperf.exe - Ok
C:\Windows\SysWOW64\TSTheme.exe - Ok
C:\Windows\SysWOW64\ucmhc.dll - Ok
C:\Windows\SysWOW64\twext.dll - Ok
C:\Windows\SysWOW64\ubpm.dll - Ok
C:\Windows\SysWOW64\themecpl.dll - Ok
C:\Windows\SysWOW64\uexfat.dll - Ok
C:\Windows\SysWOW64\tzutil.exe - Ok
C:\Windows\SysWOW64\ufat.dll - Ok
C:\Windows\SysWOW64\uicom.dll - Ok
>C:\Windows\SysWOW64\umdmxfrm.dll - packed by FLY-CODE
C:\Windows\SysWOW64\uniplat.dll - Ok
C:\Windows\SysWOW64\unimdmat.dll - Ok
C:\Windows\SysWOW64\UIAnimation.dll - Ok
C:\Windows\SysWOW64\ulib.dll - Ok
C:\Windows\SysWOW64\unlodctr.exe - Ok
C:\Windows\SysWOW64\TSWorkspace.dll - Ok
C:\Windows\SysWOW64\umdmxfrm.dll - Ok
C:\Windows\SysWOW64\tquery.dll - Ok
C:\Windows\SysWOW64\ureg.dll - Ok
C:\Windows\SysWOW64\UIAutomationCore.dll - Ok
C:\Windows\SysWOW64\unimdm.tsp - Ok
C:\Windows\SysWOW64\unregmp2.exe - Ok
C:\Windows\SysWOW64\upnpcont.exe - Ok
C:\Windows\SysWOW64\untfs.dll - Ok
>C:\Windows\SysWOW64\usbperf.dll - packed by FLY-CODE
C:\Windows\SysWOW64\usbceip.dll - Ok
C:\Windows\SysWOW64\upnp.dll - Ok
C:\Windows\SysWOW64\user.exe - Ok
C:\Windows\SysWOW64\url.dll - Ok
C:\Windows\SysWOW64\UserAccountControlSettings.dll - Ok
C:\Windows\SysWOW64\usbperf.dll - Ok
C:\Windows\SysWOW64\usbui.dll - Ok
C:\Windows\SysWOW64\UIRibbonRes.dll - Ok
C:\Windows\SysWOW64\userenv.dll - Ok
C:\Windows\SysWOW64\usk.rs - Ok
C:\Windows\SysWOW64\userinit.exe - Ok
C:\Windows\SysWOW64\UserAccountControlSettings.exe - Ok
C:\Windows\SysWOW64\utildll.dll - Ok
C:\Windows\SysWOW64\uxlibres.dll - Ok
C:\Windows\SysWOW64\uudf.dll - Ok
C:\Windows\SysWOW64\uxlib.dll - Ok
C:\Windows\SysWOW64\UXInit.dll - Ok
C:\Windows\SysWOW64\upnphost.dll - Ok
C:\Windows\SysWOW64\user32.dll - Ok
C:\Windows\SysWOW64\usercpl.dll - Ok
C:\Windows\SysWOW64\vaultcli.dll - Ok
C:\Windows\SysWOW64\uxtheme.dll - Ok
C:\Windows\SysWOW64\VBICodec.ax - Ok
C:\Windows\SysWOW64\vbajet32.dll - Ok
C:\Windows\SysWOW64\usp10.dll - Ok
C:\Windows\SysWOW64\vbisurf.ax - Ok
C:\Windows\SysWOW64\urlmon.dll - Ok
>C:\Windows\SysWOW64\vdmdbg.dll - packed by FLY-CODE
C:\Windows\SysWOW64\vclsmp70.bpl - Ok
C:\Windows\SysWOW64\vcomp100.dll - Ok
C:\Windows\SysWOW64\VAN.dll - Ok
C:\Windows\SysWOW64\vdmdbg.dll - Ok
C:\Windows\SysWOW64\vcljpg70.bpl - Ok
C:\Windows\SysWOW64\vds_ps.dll - Ok
C:\Windows\SysWOW64\vdsvd.dll - Ok
C:\Windows\SysWOW64\vdsbas.dll - Ok
C:\Windows\SysWOW64\verclsid.exe - Ok
C:\Windows\SysWOW64\vfpodbc.dll - Ok
C:\Windows\SysWOW64\vclx70.bpl - Ok
C:\Windows\SysWOW64\vbscript.dll - Ok
C:\Windows\SysWOW64\verifier.exe - Ok
C:\Windows\SysWOW64\vdsdyn.dll - Ok
C:\Windows\SysWOW64\Utilman.exe - Ok
C:\Windows\SysWOW64\vidcap.ax - Ok
C:\Windows\SysWOW64\Vault.dll - Ok
C:\Windows\SysWOW64\version.dll - Ok
C:\Windows\SysWOW64\vfwwdm32.dll - Ok
>C:\Windows\SysWOW64\virtdisk.dll - packed by FLY-CODE
C:\Windows\SysWOW64\vpnikeapi.dll - Ok
C:\Windows\SysWOW64\VIDRESZR.DLL - Ok
C:\Windows\SysWOW64\vss_ps.dll - Ok
C:\Windows\SysWOW64\vsstrace.dll - Ok
C:\Windows\SysWOW64\WABSyncProvider.dll - Ok
C:\Windows\SysWOW64\w32topl.dll - Ok
C:\Windows\SysWOW64\verifier.dll - Ok
C:\Windows\SysWOW64\virtdisk.dll - Ok
C:\Windows\SysWOW64\vssadmin.exe - Ok
C:\Windows\SysWOW64\waitfor.exe - Ok
C:\Windows\SysWOW64\w32tm.exe - Ok
C:\Windows\SysWOW64\WcnApi.dll - Ok
C:\Windows\SysWOW64\WcnEapPeerProxy.dll - Ok
C:\Windows\SysWOW64\WcnEapAuthProxy.dll - Ok
C:\Windows\SysWOW64\wavemsp.dll - Ok
C:\Windows\SysWOW64\WcsPlugInService.dll - Ok
C:\Windows\SysWOW64\wdi.dll - Ok
C:\Windows\SysWOW64\WEB.rs - Ok
C:\Windows\SysWOW64\wdmaud.drv - Ok
C:\Windows\SysWOW64\wdigest.dll - Ok
C:\Windows\SysWOW64\wbemcomn.dll - Ok
C:\Windows\SysWOW64\wcncsvc.dll - Ok
C:\Windows\SysWOW64\wdscore.dll - Ok
C:\Windows\SysWOW64\wecapi.dll - Ok
C:\Windows\SysWOW64\webcheck.dll - Ok
C:\Windows\SysWOW64\wecutil.exe - Ok
C:\Windows\SysWOW64\wcnwiz.dll - Ok
C:\Windows\SysWOW64\vssapi.dll - Ok
C:\Windows\SysWOW64\werdiagcontroller.dll - Ok
C:\Windows\SysWOW64\webio.dll - Ok
C:\Windows\SysWOW64\wer.dll - Ok
C:\Windows\SysWOW64\WebClnt.dll - Ok
C:\Windows\SysWOW64\WerFaultSecure.exe - Ok
C:\Windows\SysWOW64\wermgr.exe - Ok
C:\Windows\SysWOW64\werui.dll - Ok
C:\Windows\SysWOW64\WF.msc - Ok
C:\Windows\SysWOW64\vcl70.bpl - Ok
C:\Windows\SysWOW64\UIRibbon.dll - Ok
C:\Windows\SysWOW64\wevtapi.dll - Ok
C:\Windows\SysWOW64\webservices.dll - Ok
C:\Windows\SysWOW64\wfapigp.dll - Ok
C:\Windows\SysWOW64\whealogr.dll - Ok
C:\Windows\SysWOW64\whhelper.dll - Ok
C:\Windows\SysWOW64\wevtfwd.dll - Ok
C:\Windows\SysWOW64\WfHC.dll - Ok
C:\Windows\SysWOW64\where.exe - Ok
C:\Windows\SysWOW64\wevtutil.exe - Ok
C:\Windows\SysWOW64\whoami.exe - Ok
C:\Windows\SysWOW64\wiadss.dll - Ok
C:\Windows\SysWOW64\wextract.exe - Ok
C:\Windows\SysWOW64\wiascanprofiles.dll - Ok
>C:\Windows\SysWOW64\wiatrace.dll - packed by FLY-CODE
C:\Windows\SysWOW64\WerFault.exe - Ok
C:\Windows\SysWOW64\WiaExtensionHost64.dll - Ok
C:\Windows\SysWOW64\wdc.dll - Ok
C:\Windows\SysWOW64\wiaacmgr.exe - Ok
C:\Windows\SysWOW64\wiadefui.dll - Ok
C:\Windows\SysWOW64\wiavideo.dll - Ok
C:\Windows\SysWOW64\winbrand.dll - Ok
C:\Windows\SysWOW64\wiatrace.dll - Ok
C:\Windows\SysWOW64\wincredprovider.dll - Ok
C:\Windows\SysWOW64\wimgapi.dll - Ok
C:\Windows\SysWOW64\winbio.dll - Ok
C:\Windows\SysWOW64\wiashext.dll - Ok
C:\Windows\SysWOW64\WinFax.dll - Ok
C:\Windows\SysWOW64\wiaaut.dll - Ok
C:\Windows\SysWOW64\winrm.cmd - Ok
C:\Windows\SysWOW64\wimserv.exe - Ok
C:\Windows\SysWOW64\WindowsCodecsExt.dll - Ok
C:\Windows\SysWOW64\WindowsAccessBridge-32.dll - Ok
C:\Windows\SysWOW64\winrnr.dll - Ok
C:\Windows\SysWOW64\winipsec.dll - Ok
C:\Windows\SysWOW64\winhttp.dll - Ok
>C:\Windows\SysWOW64\winnsi.dll - packed by FLY-CODE
C:\Windows\SysWOW64\winmm.dll - Ok
C:\Windows\SysWOW64\winrsmgr.dll - Ok
C:\Windows\SysWOW64\winrssrv.dll - Ok
C:\Windows\SysWOW64\win32spl.dll - Ok
C:\Windows\SysWOW64\winrs.exe - Ok
C:\Windows\SysWOW64\winnsi.dll - Ok
C:\Windows\SysWOW64\winrshost.exe - Ok
>C:\Windows\SysWOW64\winshfhc.dll - packed by FLY-CODE
C:\Windows\SysWOW64\wininit.exe - Ok
C:\Windows\SysWOW64\WinSCard.dll - Ok
C:\Windows\SysWOW64\winsockhc.dll - Ok
C:\Windows\SysWOW64\WindowsCodecs.dll - Ok
C:\Windows\SysWOW64\WINSRPC.DLL - Ok
C:\Windows\SysWOW64\winrscmd.dll - Ok
C:\Windows\SysWOW64\winspool.drv - Ok
C:\Windows\SysWOW64\winsta.dll - Ok
C:\Windows\SysWOW64\winshfhc.dll - Ok
C:\Windows\SysWOW64\winusb.dll - Ok
C:\Windows\SysWOW64\WinSyncProviders.dll - Ok
C:\Windows\SysWOW64\WinSyncMetastore.dll - Ok
C:\Windows\SysWOW64\WinSync.dll - Ok
C:\Windows\SysWOW64\wkscli.dll - Ok
>C:\Windows\SysWOW64\wintrust.dll - packed by FLY-CODE
C:\Windows\SysWOW64\winrm.vbs - Ok
>C:\Windows\SysWOW64\wksprtPS.dll - packed by FLY-CODE
C:\Windows\SysWOW64\wlanapi.dll - Ok
C:\Windows\SysWOW64\winver.exe - Ok
C:\Windows\SysWOW64\wlancfg.dll - Ok
C:\Windows\SysWOW64\wlanext.exe - Ok
>C:\Windows\SysWOW64\WinSATAPI.dll is ZLIB container
C:\Windows\SysWOW64\wlanhlp.dll - Ok
C:\Windows\SysWOW64\wksprtPS.dll - Ok
C:\Windows\SysWOW64\wlaninst.dll - Ok
C:\Windows\SysWOW64\WinSATAPI.dll - container
C:\Windows\SysWOW64\wlanutil.dll - Ok
C:\Windows\SysWOW64\wlandlg.dll - Ok
C:\Windows\SysWOW64\wlangpui.dll - Ok
C:\Windows\SysWOW64\wlgpclnt.dll - Ok
C:\Windows\SysWOW64\Wldap32.dll - Ok
C:\Windows\SysWOW64\WlS0WndH.dll - Ok
C:\Windows\SysWOW64\WLanConn.dll - Ok
C:\Windows\SysWOW64\wintrust.dll - Ok
C:\Windows\SysWOW64\wlanmsm.dll - Ok
C:\Windows\SysWOW64\wmdmps.dll - Ok
C:\Windows\SysWOW64\wmcodecdspps.dll - Ok
C:\Windows\SysWOW64\wlansec.dll - Ok
C:\Windows\SysWOW64\wlanui.dll - Ok
C:\Windows\SysWOW64\wmdmlog.dll - Ok
C:\Windows\SysWOW64\wininet.dll - Ok
C:\Windows\SysWOW64\wmerror.dll - Ok
C:\Windows\SysWOW64\wmi.dll - Ok
C:\Windows\SysWOW64\WMASF.DLL - Ok
C:\Windows\SysWOW64\wmiprop.dll - Ok
C:\Windows\SysWOW64\WlanMM.dll - Ok
C:\Windows\SysWOW64\wmpcm.dll - Ok
C:\Windows\SysWOW64\wlanpref.dll - Ok
C:\Windows\SysWOW64\wmdrmnet.dll - Ok
C:\Windows\SysWOW64\WmpDui.dll - Ok
C:\Windows\SysWOW64\wmdrmdev.dll - Ok
C:\Windows\SysWOW64\wmidx.dll - Ok
C:\Windows\SysWOW64\wmpeffects.dll - Ok
C:\Windows\SysWOW64\wmpdxm.dll - Ok
C:\Windows\SysWOW64\wmpps.dll - Ok
C:\Windows\SysWOW64\wmdrmsdk.dll - Ok
C:\Windows\SysWOW64\wmpshell.dll - Ok
C:\Windows\SysWOW64\wmpsrcwp.dll - Ok
C:\Windows\SysWOW64\WMADMOD.DLL - Ok
C:\Windows\SysWOW64\WMADMOE.DLL - Ok
C:\Windows\SysWOW64\wmsgapi.dll - Ok
C:\Windows\SysWOW64\wmpmde.dll - Ok
C:\Windows\SysWOW64\WMPhoto.dll - Ok
C:\Windows\SysWOW64\WMNetMgr.dll - Ok
C:\Windows\SysWOW64\WMVSDECD.DLL - Ok
C:\Windows\SysWOW64\wmvdspa.dll - Ok
C:\Windows\SysWOW64\WMSPDMOD.DLL - Ok
C:\Windows\SysWOW64\Wpc.dll - Ok
C:\Windows\SysWOW64\wow32.dll - Ok
C:\Windows\SysWOW64\wowreg32.exe - Ok
C:\Windows\SysWOW64\wpcao.dll - Ok
C:\Windows\SysWOW64\WMVSENCD.DLL - Ok
C:\Windows\SysWOW64\wpcsvc.dll - Ok
C:\Windows\SysWOW64\WPDShextAutoplay.exe - Ok
C:\Windows\SysWOW64\WMSPDMOE.DLL - Ok
C:\Windows\SysWOW64\WPDShServiceObj.dll - Ok
C:\Windows\SysWOW64\WMPEncEn.dll - Ok
C:\Windows\SysWOW64\write.exe - Ok
C:\Windows\SysWOW64\ws2help.dll - Ok
C:\Windows\SysWOW64\wscinterop.dll - Ok
C:\Windows\SysWOW64\WMVDECOD.DLL - Ok
C:\Windows\SysWOW64\wscapi.dll - Ok
C:\Windows\SysWOW64\ws2_32.dll - Ok
C:\Windows\SysWOW64\wscmisetup.dll - Ok
C:\Windows\SysWOW64\wscproxystub.dll - Ok
C:\Windows\SysWOW64\WMVENCOD.DLL - Ok
C:\Windows\SysWOW64\wscisvif.dll - Ok
C:\Windows\SysWOW64\WMVXENCD.DLL - Ok
C:\Windows\SysWOW64\wpdwcn.dll - Ok
>C:\Windows\SysWOW64\wshbth.dll - packed by FLY-CODE
C:\Windows\SysWOW64\WSDApi.dll - Ok
C:\Windows\SysWOW64\wsdchngr.dll - Ok
C:\Windows\SysWOW64\WPDSp.dll - Ok
C:\Windows\SysWOW64\wscript.exe - Ok
C:\Windows\SysWOW64\wshbth.dll - Ok
C:\Windows\SysWOW64\wship6.dll - Ok
C:\Windows\SysWOW64\wshelper.dll - Ok
C:\Windows\SysWOW64\wshcon.dll - Ok
C:\Windows\SysWOW64\wshrm.dll - Ok
C:\Windows\SysWOW64\wshirda.dll - Ok
C:\Windows\SysWOW64\wsmanconfig_schema.xml - Ok
C:\Windows\SysWOW64\WSHTCPIP.DLL - Ok
C:\Windows\SysWOW64\wshext.dll - Ok
C:\Windows\SysWOW64\wsmplpxy.dll - Ok
C:\Windows\SysWOW64\wsmprovhost.exe - Ok
C:\Windows\SysWOW64\WsmAuto.dll - Ok
C:\Windows\SysWOW64\WsmPty.xsl - Ok
C:\Windows\SysWOW64\WSManMigrationPlugin.dll - Ok
C:\Windows\SysWOW64\WSManHTTPConfig.exe - Ok
C:\Windows\SysWOW64\WsmTxt.xsl - Ok
C:\Windows\SysWOW64\wshqos.dll - Ok
C:\Windows\SysWOW64\WsmRes.dll - Ok
C:\Windows\SysWOW64\wshom.ocx - Ok
C:\Windows\SysWOW64\WMVCORE.DLL - Ok
C:\Windows\SysWOW64\wsnmp32.dll - Ok
C:\Windows\SysWOW64\wsock32.dll - Ok
C:\Windows\SysWOW64\WsmWmiPl.dll - Ok
>C:\Windows\SysWOW64\wscui.cpl is ZLIB container
C:\Windows\SysWOW64\wsecedit.dll - Ok
C:\Windows\SysWOW64\WSTPager.ax - Ok
C:\Windows\SysWOW64\wups.dll - Ok
C:\Windows\SysWOW64\wtsapi32.dll - Ok
C:\Windows\SysWOW64\wudriver.dll - Ok
C:\Windows\SysWOW64\wscui.cpl - container
C:\Windows\SysWOW64\wuapp.exe - Ok
C:\Windows\SysWOW64\wpdshext.dll - Ok
C:\Windows\SysWOW64\wuwebv.dll - Ok
C:\Windows\SysWOW64\wwapi.dll - Ok
C:\Windows\SysWOW64\wzcdlg.dll - Ok
C:\Windows\SysWOW64\WWanAPI.dll - Ok
C:\Windows\SysWOW64\xcopy.exe - Ok
C:\Windows\SysWOW64\XAPOFX1_3.dll - Ok
C:\Windows\SysWOW64\xmlfilter.dll - Ok
C:\Windows\SysWOW64\WsmSvc.dll - Ok
C:\Windows\SysWOW64\xmlprovi.dll - Ok
C:\Windows\SysWOW64\XInput9_1_0.dll - Ok
C:\Windows\SysWOW64\wusa.exe - Ok
C:\Windows\SysWOW64\wvc.dll - Ok
C:\Windows\SysWOW64\wuapi.dll - Ok
C:\Windows\SysWOW64\xolehlp.dll - Ok
C:\Windows\SysWOW64\xpsrchvw.xml - Ok
C:\Windows\SysWOW64\XpsRasterService.dll - Ok
C:\Windows\SysWOW64\xwizard.dtd - Ok
C:\Windows\SysWOW64\XpsGdiConverter.dll - Ok
C:\Windows\SysWOW64\xmllite.dll - Ok
C:\Windows\SysWOW64\XAudio2_5.dll - Ok
C:\Windows\SysWOW64\xwreg.dll - Ok
C:\Windows\SysWOW64\xwizard.exe - Ok
C:\Windows\SysWOW64\XPSSHHDR.dll - Ok
C:\Windows\SysWOW64\xwizards.dll - Ok
C:\Windows\SysWOW64\Adobe\Director\M5if32.dll - Ok
C:\Windows\SysWOW64\Adobe\Director\M5drvr32.exe - Ok
C:\Windows\SysWOW64\xwtpdui.dll - Ok
C:\Windows\SysWOW64\xwtpw32.dll - Ok
C:\Windows\SysWOW64\XpsFilt.dll - Ok
C:\Windows\SysWOW64\zipfldr.dll - Ok
C:\Windows\SysWOW64\Adobe\Director\SwDir.dll - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\DynaPlayer.dll - Ok
C:\Windows\SysWOW64\xpssvcs.dll - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Control.dll - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\shockwave_Projector_Loader.dcr - Ok
C:\Windows\SysWOW64\XpsPrint.dll - Ok
C:\Windows\SysWOW64\Adobe\Director\SWDNLD.EXE - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\SwLogo.bmp - Ok
C:\Windows\SysWOW64\Adobe\Director\np32dsw.dll - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\SwMenu.dll - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\SwInit.exe - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Plugin.dll - Ok
>C:\Windows\SysWOW64\Adobe\Shockwave 11\uninstaller.exe - packed by FLY-CODE
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\AudioFilters.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Animated GIF Asset.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\BitmapFilters.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Proj.dll - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\CBrowser.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\AudioMixer.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\DirectSound.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Cursor Asset.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\DVD Asset.x32 - Ok
>C:\Windows\SysWOW64\xpsrchvw.exe - packed by FLY-CODE
C:\Windows\SysWOW64\Adobe\Shockwave 11\dirapi.dll - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\iml32.dll - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Font Asset.x32 - Ok
>>C:\Windows\SysWOW64\Adobe\Shockwave 11\uninstaller.exe is NSIS container
C:\Windows\SysWOW64\xpsservices.dll - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\uninstaller.exe - container
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\FLVAsset.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\INetURL.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Font Xtra.x32 - Ok
>C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\MacroMix.x32 - packed by FLY-CODE
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Mix Services.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\MPEG 3 Import Export.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\SwHelper_1161629.exe - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\MacroMix.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Netlingo.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Havok.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Multiusr.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Netfile.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\PNG Import Export.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\RealMedia Asset.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\F4VAsset.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\QT6Asset.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Sound Import Export.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Sound Control.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Speech.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Sun AU Import Export.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Targa Import Export.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Swastrm.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Swadcmpr.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\SWA Import Export.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Text Asset.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\MP4Asset.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Tiff Import Export.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Windows Media Asset.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\XMLParser.x32 - Ok
C:\Windows\SysWOW64\AdvancedInstallers\cmiadapter.dll - Ok
C:\Windows\SysWOW64\Dism\CompatProvider.dll - Ok
C:\Windows\SysWOW64\AdvancedInstallers\OEMHelpIns.dll - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\TextXtra.x32 - Ok
C:\Windows\SysWOW64\Dism\DismCorePS.dll - Ok
C:\Windows\SysWOW64\Dism\CbsProvider.dll - Ok
C:\Windows\SysWOW64\Dism\DismCore.dll - Ok
C:\Windows\SysWOW64\Dism\DismProv.dll - Ok
>C:\Windows\SysWOW64\Dism\DismHost.exe - packed by FLY-CODE
C:\Windows\SysWOW64\Dism\DmiProvider.dll - Ok
C:\Windows\SysWOW64\Dism\FolderProvider.dll - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Shockwave 3d Asset.x32 - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Dynamiks.x32 - Ok
>>C:\Windows\SysWOW64\xpsrchvw.exe is BINARYRES container
C:\Windows\SysWOW64\Dism\LogProvider.dll - Ok
C:\Windows\SysWOW64\xpsrchvw.exe - container
C:\Windows\SysWOW64\Dism\OSProvider.dll - Ok
C:\Windows\SysWOW64\Dism\IntlProvider.dll - Ok
C:\Windows\SysWOW64\Dism\nl-NL\CbsProvider.dll.mui - Ok
C:\Windows\SysWOW64\Dism\MsiProvider.dll - Ok
C:\Windows\SysWOW64\Dism\nl-NL\CompatProvider.dll.mui - Ok
C:\Windows\SysWOW64\Dism\nl-NL\DismCore.dll.mui - Ok
C:\Windows\SysWOW64\Dism\SmiProvider.dll - Ok
C:\Windows\SysWOW64\Dism\nl-NL\FolderProvider.dll.mui - Ok
C:\Windows\SysWOW64\Dism\DismHost.exe - Ok
C:\Windows\SysWOW64\Dism\UnattendProvider.dll - Ok
C:\Windows\SysWOW64\Dism\nl-NL\DismProv.dll.mui - Ok
C:\Windows\SysWOW64\Dism\nl-NL\DmiProvider.dll.mui - Ok
C:\Windows\SysWOW64\Dism\WimProvider.dll - Ok
C:\Windows\SysWOW64\Dism\nl-NL\LogProvider.dll.mui - Ok
C:\Windows\SysWOW64\Dism\nl-NL\TransmogProvider.dll.mui - Ok
C:\Windows\SysWOW64\Dism\nl-NL\SmiProvider.dll.mui - Ok
C:\Windows\SysWOW64\Dism\nl-NL\OSProvider.dll.mui - Ok
C:\Windows\SysWOW64\Dism\nl-NL\IntlProvider.dll.mui - Ok
C:\Windows\SysWOW64\DriverStore\nl-NL\netpgm.inf_loc - Ok
C:\Windows\SysWOW64\DriverStore\nl-NL\netserv.inf_loc - Ok
C:\Windows\SysWOW64\Dism\nl-NL\MsiProvider.dll.mui - Ok
C:\Windows\SysWOW64\Dism\nl-NL\WimProvider.dll.mui - Ok
C:\Windows\SysWOW64\Dism\TransmogProvider.dll - Ok
C:\Windows\SysWOW64\Dism\nl-NL\UnattendProvider.dll.mui - Ok
C:\Windows\SysWOW64\IME\IMEJP10\IMJPDCTP.DLL - Ok
C:\Windows\SysWOW64\IME\IMEJP10\IMJPDADM.EXE - Ok
C:\Windows\SysWOW64\IME\IMEJP10\IMJPCD.DLL - Ok
C:\Windows\SysWOW64\IME\IMEJP10\IMJPDSVR.EXE - Ok
C:\Windows\SysWOW64\IME\IMEJP10\imjppdmg.exe - Ok
C:\Windows\SysWOW64\IME\IMEJP10\IMJPAPI.DLL - Ok
C:\Windows\SysWOW64\IME\IMEJP10\IMJPMGR.EXE - Ok
C:\Windows\SysWOW64\IME\IMEJP10\IMJPUEX.EXE - Ok
C:\Windows\SysWOW64\Adobe\Shockwave 11\Xtras\Flash Asset.x32 - Ok
C:\Windows\SysWOW64\IME\IMEJP10\imjpuexc.exe - Ok
C:\Windows\SysWOW64\IME\IMEJP10\APPLETS\IMJPCLST.XML - Ok
C:\Windows\SysWOW64\IME\IMEJP10\IMJPDCT.EXE - Ok
C:\Windows\SysWOW64\IME\IMEJP10\imjpcus.dll - Ok
C:\Windows\SysWOW64\IME\IMEJP10\imjputyc.dll - Ok
C:\Windows\SysWOW64\IME\IMEJP10\APPLETS\IMJPCAC.DLL - Ok
C:\Windows\SysWOW64\IME\IMESC5\ImSCCfg.DLL - Ok
C:\Windows\SysWOW64\AdvancedInstallers\cmiv2.dll - Ok
C:\Windows\SysWOW64\IME\IMEJP10\APPLETS\IMJPKDIC.DLL - Ok
C:\Windows\SysWOW64\IME\IMEJP10\APPLETS\IMJPCLST.DLL - Ok
C:\Windows\SysWOW64\IME\IMEJP10\APPLETS\IMJPSKF.DLL - Ok
C:\Windows\SysWOW64\IME\IMESC5\PMIGRATE.dll - Ok
C:\Windows\SysWOW64\IME\IMESC5\IMSCPROP.exe - Ok
C:\Windows\SysWOW64\wmp.dll - Ok
C:\Windows\SysWOW64\IME\IMESC5\applets\PINTLCSA.dll - Ok
C:\Windows\SysWOW64\IME\IMETC10\IMTCCFG.DLL - Ok
>C:\Windows\SysWOW64\IME\IMESC5\IMSCTIP.dll - packed by BINARYRES
C:\Windows\SysWOW64\IME\IMEJP10\IMJPTIP.DLL - Ok
C:\Windows\SysWOW64\IME\IMESC5\IMSCTIP.dll - Ok
>C:\Windows\SysWOW64\IME\IMESC5\imscui.DLL - packed by BINARYRES
C:\Windows\SysWOW64\IME\IMETC10\applets\IMTCDIC.dll - Ok
C:\Windows\SysWOW64\IME\IMESC5\imscui.DLL - Ok
C:\Windows\SysWOW64\IME\IMESC5\ImSCCore.dll - Ok
C:\Windows\SysWOW64\IME\IMETC10\applets\IMTCCAC.dll - Ok
C:\Windows\SysWOW64\IME\IMETC10\applets\IMTCSKF.dll - Ok
C:\Windows\SysWOW64\IME\imekr8\imkrapi.dll - Ok
C:\Windows\SysWOW64\IME\IMETC10\IMTCCORE.DLL - Ok
C:\Windows\SysWOW64\IME\imekr8\imkrudt.dll - Ok
>C:\Windows\SysWOW64\IME\IMETC10\imtcui.DLL - packed by BINARYRES
C:\Windows\SysWOW64\IME\IMETC10\IMTCPROP.exe - Ok
>C:\Windows\SysWOW64\IME\IMETC10\IMTCTIP.dll - packed by BINARYRES
C:\Windows\SysWOW64\IME\IMETC10\imtcui.DLL - Ok
C:\Windows\SysWOW64\IME\IMETC10\IMTCTIP.dll - Ok
C:\Windows\SysWOW64\IME\imekr8\applets\imkrcac.dll - Ok
C:\Windows\SysWOW64\IME\imekr8\dicts\imkrhjd.dll - Ok
C:\Windows\SysWOW64\IME\imekr8\applets\imkrskf.dll - Ok
C:\Windows\SysWOW64\IME\shared\IMEAPIS.DLL - Ok
C:\Windows\SysWOW64\IME\imekr8\imkrtip.dll - Ok
C:\Windows\SysWOW64\IME\shared\IMEPADSM.DLL - Ok
C:\Windows\SysWOW64\IME\shared\imecfm.dll - Ok
C:\Windows\SysWOW64\IME\shared\imever.dll - Ok
C:\Windows\SysWOW64\IME\shared\res\padrs404.dll - Ok
C:\Windows\SysWOW64\IME\shared\IMJKAPI.DLL - Ok
C:\Windows\SysWOW64\IME\shared\IMCCPHR.exe - Ok
C:\Windows\SysWOW64\IME\shared\res\padrs411.dll - Ok
C:\Windows\SysWOW64\IME\shared\res\padrs412.dll - Ok
C:\Windows\SysWOW64\wmploc.DLL - Ok
C:\Windows\SysWOW64\IME\shared\IMEPADSV.EXE - Ok
C:\Windows\SysWOW64\IME\shared\res\padrs804.dll - Ok
C:\Windows\SysWOW64\IME\shared\IMETIP.DLL - Ok
C:\Windows\SysWOW64\InstallShield\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0005\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0003\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0006\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\_isdel.exe - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0007\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0009\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\000b\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\000a\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0008\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0010\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\000e\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0011\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setup.exe - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0012\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0013\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0014\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0019\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\001a\_setup.dll - Ok
C:\Windows\SysWOW64\IME\shared\MSCAND20.DLL - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0015\_setup.dll - Ok
>C:\Windows\SysWOW64\InstallShield\setupdir\001b\_setup.dll - packed by FLY-CODE
>C:\Windows\SysWOW64\InstallShield\setupdir\001d\_setup.dll - packed by FLY-CODE
>C:\Windows\SysWOW64\InstallShield\setupdir\001e\_setup.dll - packed by FLY-CODE
C:\Windows\SysWOW64\InstallShield\setupdir\001f\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0024\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\002d\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0404\_setup.dll - Ok
>C:\Windows\SysWOW64\InstallShield\setupdir\040c\_setup.dll - packed by FLY-CODE
C:\Windows\SysWOW64\InstallShield\setupdir\0021\_setup.dll - Ok
>C:\Windows\SysWOW64\InstallShield\setupdir\0804\_setup.dll - packed by FLY-CODE
>C:\Windows\SysWOW64\InstallShield\setupdir\0416\_setup.dll - packed by FLY-CODE
C:\Windows\SysWOW64\InstallShield\setupdir\0816\_setup.dll - Ok
>C:\Windows\SysWOW64\InstallShield\setupdir\0c0c\_setup.dll - packed by FLY-CODE
C:\Windows\SysWOW64\MUI\0413\mscorees.dll - Ok
C:\Windows\SysWOW64\Macromed\Flash\activex.vch - Ok
C:\Windows\SysWOW64\MUI\0409\mscorees.dll - Ok
C:\Windows\SysWOW64\Macromed\Flash\FlashAuthor.cfg - Ok
C:\Windows\SysWOW64\IME\IMEJP10\APPLETS\mshwjpnrIME.dll - Ok
C:\Windows\SysWOW64\Macromed\Flash\flashplayer.xpt - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\001d\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\001b\_setup.dll - Ok
C:\Windows\SysWOW64\Macromed\Flash\FlashInstall.log - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\040c\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0416\_setup.dll - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\001e\_setup.dll - Ok
C:\Windows\SysWOW64\Macromed\Flash\mms.cfg - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0804\_setup.dll - Ok
C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerTrust\Adobe Illustrator CS5 FXG.cfg - Ok
C:\Windows\SysWOW64\Macromed\Flash\plugin.vch - Ok
C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerTrust\AdobeFireworksCS5.cfg - Ok
C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerTrust\AdobeXMPFileInfoCS5.cfg - Ok
C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe - Ok
C:\Windows\SysWOW64\NetworkList\Icons\StockIcons\bench_16.bin - Ok
C:\Windows\SysWOW64\InstallShield\setupdir\0c0c\_setup.dll - Ok
C:\Windows\SysWOW64\NetworkList\Icons\StockIcons\bench_24.bin - Ok
C:\Windows\SysWOW64\NetworkList\Icons\StockIcons\bench_32.bin - Ok
C:\Windows\SysWOW64\NetworkList\Icons\StockIcons\house_16.bin - Ok
C:\Windows\SysWOW64\NetworkList\Icons\StockIcons\house_24.bin - Ok
C:\Windows\SysWOW64\NetworkList\Icons\StockIcons\bench_48.bin - Ok
C:\Windows\SysWOW64\NetworkList\Icons\StockIcons\house_32.bin - Ok
C:\Windows\SysWOW64\NetworkList\Icons\StockIcons\office_16.bin - Ok
C:\Windows\SysWOW64\Msdtc\Trace\msdtcvtr.bat - Ok
C:\Windows\SysWOW64\NetworkList\Icons\StockIcons\office_32.bin - Ok
C:\Windows\SysWOW64\NetworkList\Icons\StockIcons\office_48.bin - Ok
C:\Windows\SysWOW64\NetworkList\Icons\StockIcons\house_48.bin - Ok
C:\Windows\SysWOW64\NetworkList\Icons\StockIcons\office_24.bin - Ok
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.dll - Ok
C:\Windows\SysWOW64\IME\IMETC10\applets\MSHWCHTRIME.dll - Ok
C:\Windows\SysWOW64\Msdtc\Trace\msdtctr.mof - Ok
C:\Windows\SysWOW64\Printing_Admin_Scripts\nl-NL\prndrvr.vbs - Ok
C:\Windows\SysWOW64\IME\imekr8\applets\mshwkorrIME.dll - Ok
C:\Windows\SysWOW64\Recovery\ReAgent.xml - Ok
C:\Windows\SysWOW64\Printing_Admin_Scripts\nl-NL\pubprn.vbs - Ok
C:\Windows\SysWOW64\Printing_Admin_Scripts\nl-NL\prnjobs.vbs - Ok
C:\Windows\SysWOW64\Printing_Admin_Scripts\nl-NL\prncnfg.vbs - Ok
C:\Windows\SysWOW64\Setup\cmmigr.dll - Ok
C:\Windows\SysWOW64\Setup\pbkmigr.dll - Ok
C:\Windows\SysWOW64\Setup\msdtcstp.dll - Ok
C:\Windows\SysWOW64\Printing_Admin_Scripts\nl-NL\prnmngr.vbs - Ok
C:\Windows\SysWOW64\Setup\tssysprep.dll - Ok
C:\Windows\SysWOW64\Printing_Admin_Scripts\nl-NL\prnqctl.vbs - Ok
C:\Windows\SysWOW64\Setup\RasMigPlugin.dll - Ok
C:\Windows\SysWOW64\Printing_Admin_Scripts\nl-NL\prnport.vbs - Ok
C:\Windows\SysWOW64\Speech\Engines\SR\nl-NL\srloc.dll.mui - Ok
C:\Windows\SysWOW64\Setup\comsetup.dll - Ok
C:\Windows\SysWOW64\Speech\Engines\SR\spsrx.dll - Ok
C:\Windows\SysWOW64\Speech\SpeechUX\nl-NL\sapi.cpl.mui - Ok
C:\Windows\SysWOW64\Speech\SpeechUX\SpeechUXPS.DLL - Ok
C:\Windows\SysWOW64\Speech\Engines\SR\srloc.dll - Ok
C:\Windows\SysWOW64\Speech\SpeechUX\sapi.cpl - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\Certificate.format.ps1xml - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\Diagnostics.Format.ps1xml - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\DotNetTypes.format.ps1xml - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\FileSystem.format.ps1xml - Ok
C:\Windows\SysWOW64\Wat\WatWeb.dll - Ok
C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_9_900_117.exe - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\getevent.types.ps1xml - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\PowerShellCore.format.ps1xml - Ok
>C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_117.ocx - packed by BINARYRES
>>C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_117.ocx is WISE container
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\PowerShellTrace.format.ps1xml - Ok
C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_9_900_117.ocx - container
C:\Windows\SysWOW64\Speech\Engines\SR\spsreng.dll - Ok
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_Plugin.exe - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\Help.format.ps1xml - Ok
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe - Ok
C:\Windows\SysWOW64\Wat\npWatWeb.dll - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\Registry.format.ps1xml - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\WSMan.Format.ps1xml - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\CompiledComposition.Microsoft.PowerShell.GPowerShell.dll - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\pwrshmsg.dll - Ok
C:\Windows\SysWOW64\WCN\nl-NL\Add_a_device_or_computer_to_a_network_usb.rtf - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\Modules\BitsTransfer\BitsTransfer.psd1 - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\Modules\BitsTransfer\BitsTransfer.Format.ps1xml - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\Examples\profile.ps1 - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\PSEvents.dll - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\Modules\BitsTransfer\nl-NL\about_BITS_Cmdlets.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\Modules\PSDiagnostics\PSDiagnostics.psm1 - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\Modules\PSDiagnostics\PSDiagnostics.psd1 - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\Modules\TroubleshootingPack\TroubleshootingPack.psd1 - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\Modules\BitsTransfer\nl-NL\Microsoft.BackgroundIntelligentTransfer.Management.dll-Help.xml - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\pwrshsip.dll - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Arithmetic_Operators.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_arrays.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\Modules\TroubleshootingPack\nl-NL\Microsoft.Windows.Diagnosis.TroubleshootingPack.dll-Help.xml - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Assignment_Operators.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_command_precedence.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_aliases.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\types.ps1xml - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Command_Syntax.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\powershell_ise.exe - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Comment_Based_Help.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Continue.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\powershell.exe - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Automatic_Variables.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_data_sections.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\pspluginwkr.dll - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Core_Commands.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Break.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_do.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_debuggers.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_escape_characters.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_environment_variables.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_CommonParameters.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_For.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_eventlogs.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Comparison_Operators.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Foreach.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_functions_advanced_parameters.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_execution_policies.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_functions_cmdletbindingattribute.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_format.ps1xml.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_History.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\Modules\BitsTransfer\Microsoft.BackgroundIntelligentTransfer.Management.Interop.dll - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_functions_advanced.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_hash_tables.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_jobs.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_join.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_functions.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Line_Editing.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_locations.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Language_Keywords.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_logical_operators.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_methods.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_modules.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_functions_advanced_methods.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_job_details.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Parsing.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_operators.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_pipelines.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Path_Syntax.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_preference_variables.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_objects.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_prompts.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_properties.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_providers.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_If.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_profiles.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Quoting_Rules.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\Modules\TroubleshootingPack\TroubleshootingPack.format.ps1xml - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Ref.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_regular_expressions.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Redirection.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_remote_jobs.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_remote_output.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_remote.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_remote_FAQ.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_parameters.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_remote_requirements.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_PSSnapins.help.txt - Ok
C:\Windows\SysWOW64\Speech\Common\sapi.dll - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Reserved_Words.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Return.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_scopes.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_pssessions.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_scripts.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_remote_troubleshooting.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_pssession_details.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Signing.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_split.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Switch.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Special_Characters.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Throw.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_trap.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_try_catch_finally.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Variables.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_wildcards.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_While.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_transactions.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Windows_PowerShell_2.0.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Session_Configurations.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_Windows_PowerShell_ISE.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_WMI_Cmdlets.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\ImportAllModules.psd1 - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\default.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_script_internationalization.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_requires.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\Microsoft.PowerShell.ConsoleHost.dll-Help.xml - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_script_blocks.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_type_operators.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\Microsoft.PowerShell.Security.dll-Help.xml - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_WS-Management_Cmdlets.help.txt - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\Microsoft.PowerShell.Commands.Diagnostics.dll-Help.xml - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\PSEvents.dll.mui - Ok
>C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_types.ps1xml.help.txt is JS-HTML container
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\Microsoft.PowerShell.Commands.Management.dll-Help.xml - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\powershell.exe.mui - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\pwrshmsg.dll.mui - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\powershell_ise.resources.dll - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\System.Management.Automation.dll-Help.xml - Ok
C:\Windows\SysWOW64\ar-SA\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\pspluginwkr.dll.mui - Ok
C:\Windows\SysWOW64\ar-SA\fms.dll.mui - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\Microsoft.PowerShell.Commands.Utility.dll-Help.xml - Ok
C:\Windows\SysWOW64\XPSViewer\nl-NL\XPSViewer.exe.mui - Ok
C:\Windows\SysWOW64\ar-SA\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\ar-SA\mlang.dll.mui - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\Microsoft.Wsman.Management.dll-Help.xml - Ok
C:\Windows\SysWOW64\ar-SA\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\ar-SA\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\ar-SA\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\bg-BG\mlang.dll.mui - Ok
C:\Windows\SysWOW64\WindowsPowerShell\v1.0\nl-NL\about_types.ps1xml.help.txt - container
C:\Windows\SysWOW64\bg-BG\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\com\comempty.dat - Ok
C:\Windows\SysWOW64\bg-BG\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\21253908F3CB05D51B1C2DA8B681A785 - Ok
C:\Windows\SysWOW64\com\nl-NL\MigRegDB.exe.mui - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\37C951188967C8EB88D99893D9D191FE - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\3C3948BE6E525B8A8CEE9FAC91C9E392_5BEB6C6453DB87D996BDBC5D90D34AE1 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\3C3948BE6E525B8A8CEE9FAC91C9E392_F22C244C26135E26EA130FBBB8E0B316 - Ok
C:\Windows\SysWOW64\com\mtsadmin.tlb - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\60E31627FDA0A46932B0E5948949F2A5 - Ok
>C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\57C8EDB95DF3F0AD4EE2DC2B8CFD4157 is CAB archive
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\57C8EDB95DF3F0AD4EE2DC2B8CFD4157 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\57C8EDB95DF3F0AD4EE2DC2B8CFD4157 - archive
C:\Windows\SysWOW64\com\nl-NL\comrepl.exe.mui - Ok
C:\Windows\SysWOW64\bg-BG\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\7396C420A8E1BC1DA97F1AF0D10BAD21 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\62B5AF9BE9ADC1085C3C56EC07A82BF6 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\7B8944BA8AD0EFDF0E01A43EF62BECD0_5442B1CAC753FE77C0664BB0A0BCD11E - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\7B8944BA8AD0EFDF0E01A43EF62BECD0_355DF12EAABE3F04A4C1AF592920E175 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\696F3DE637E6DE85B458996D49D759AD - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\8DFDF057024880D7A081AFBF6D26B92F - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\74BFD122C0875EC75DBE5C6DB4C59019 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\7B8944BA8AD0EFDF0E01A43EF62BECD0_8102C2D9BECD09FCBB2BC1857DCCAD50 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\91ECFED5143F7F4F4576655D8EFAB51C_7F1F89CBFAC5A5DFD2EF8ADBE044BC30 - Ok
C:\Windows\SysWOW64\bg-BG\fms.dll.mui - Ok
>C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\94308059B57B3142E455B38A6EB92015 is CAB archive
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\94308059B57B3142E455B38A6EB92015 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\94308059B57B3142E455B38A6EB92015 - archive
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\7B8944BA8AD0EFDF0E01A43EF62BECD0_AE80968B09655437A4C6DA8671FF8BB7 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\7D266D9E1E69FA1EEFB9699B009B34C8_0A9BFDD75B598C2110CBF610C078E6E6 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\944E5B697BC46FE14AB888AE8A1EBB99_5EA473A18C5D1F0523BE2B797DB81465 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\A8FABA189DB7D25FBA7CAC806625FD30 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\7B2238AACCEDC3F1FFE8E7EB5F575EC9 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\AFA2A5744430E65F42D3175FABFBE3E8 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\955CAB6FF6A24D5820D50B5BA1CF79C7_0D0504E280D4BC90041F089A5D901106 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\C8E7EC0C85688F4738F3BE49B104BA67 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\21253908F3CB05D51B1C2DA8B681A785 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\ACF244F1A10D4DBED0D88EBA0C43A9B5_4132122BE9640F5939DCD2C026D919BD - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\37C951188967C8EB88D99893D9D191FE - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\944E5B697BC46FE14AB888AE8A1EBB99_AA2B21CEE0784AD570684C75F99D78A8 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\57C8EDB95DF3F0AD4EE2DC2B8CFD4157 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\3C3948BE6E525B8A8CEE9FAC91C9E392_5BEB6C6453DB87D996BDBC5D90D34AE1 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\62B5AF9BE9ADC1085C3C56EC07A82BF6 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\A1377F7115F1F126A15360369B165211 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\7396C420A8E1BC1DA97F1AF0D10BAD21 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\74BFD122C0875EC75DBE5C6DB4C59019 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\7B2238AACCEDC3F1FFE8E7EB5F575EC9 - Ok
C:\Windows\SysWOW64\com\MigRegDB.exe - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\7B8944BA8AD0EFDF0E01A43EF62BECD0_355DF12EAABE3F04A4C1AF592920E175 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\7B8944BA8AD0EFDF0E01A43EF62BECD0_5442B1CAC753FE77C0664BB0A0BCD11E - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\7B8944BA8AD0EFDF0E01A43EF62BECD0_8102C2D9BECD09FCBB2BC1857DCCAD50 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\8DFDF057024880D7A081AFBF6D26B92F - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\Content\ACF244F1A10D4DBED0D88EBA0C43A9B5_A9C858C1E3D297A71D80B8E1560DA3B5 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\3C3948BE6E525B8A8CEE9FAC91C9E392_F22C244C26135E26EA130FBBB8E0B316 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\7D266D9E1E69FA1EEFB9699B009B34C8_0A9BFDD75B598C2110CBF610C078E6E6 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\91ECFED5143F7F4F4576655D8EFAB51C_7F1F89CBFAC5A5DFD2EF8ADBE044BC30 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\944E5B697BC46FE14AB888AE8A1EBB99_5EA473A18C5D1F0523BE2B797DB81465 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\955CAB6FF6A24D5820D50B5BA1CF79C7_0D0504E280D4BC90041F089A5D901106 - Ok
C:\Windows\SysWOW64\com\comadmin.dll - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\A1377F7115F1F126A15360369B165211 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\944E5B697BC46FE14AB888AE8A1EBB99_AA2B21CEE0784AD570684C75F99D78A8 - Ok
C:\Windows\SysWOW64\com\comrepl.exe - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\A8FABA189DB7D25FBA7CAC806625FD30 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\60E31627FDA0A46932B0E5948949F2A5 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\696F3DE637E6DE85B458996D49D759AD - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\ACF244F1A10D4DBED0D88EBA0C43A9B5_A9C858C1E3D297A71D80B8E1560DA3B5 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\94308059B57B3142E455B38A6EB92015 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\AFA2A5744430E65F42D3175FABFBE3E8 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\ESET\ESET Smart Security\Antispam\rkd - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\ACF244F1A10D4DBED0D88EBA0C43A9B5_4132122BE9640F5939DCD2C026D919BD - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\C8E7EC0C85688F4738F3BE49B104BA67 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\ESET\ESET Smart Security\Antispam\productid - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\LocalLow\Microsoft\CryptnetUrlCache\MetaData\7B8944BA8AD0EFDF0E01A43EF62BECD0_AE80968B09655437A4C6DA8671FF8BB7 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\ESET\ESET Smart Security\Antispam\sc2.bin - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\ESET\ESET Smart Security\Antispam\sc1.bin.full.2010.12.08.01.17.00 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\ESET\ESET Smart Security\Antispam\sc21.bin.full.2010.10.13.23.04.01 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\ESET\ESET Smart Security\Antispam\sc2.bin.full.2005.02.11.04.44.13 - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\ESET\ESET Smart Security\Quarantine\2F9FADE9109BEECE04DAC831CE0F3B9D2F245828.NDF - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\ESET\ESET Smart Security\Antispam\scdns.bin - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\ESET\ESET Smart Security\Quarantine\5B0CCA662149240D1FD4354BEAC1338E97E334EA.NDF - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\ESET\ESET Smart Security\Quarantine\E138B8E2071B96EF2C1FA1B95838D713C1186997.NDF - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\CrashDumps\ekrn.exe.3152.dmp - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\ESET\ESET Smart Security\Quarantine\INFO.NQI - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\ESET\ESET Smart Security\Quarantine\5B0CCA662149240D1FD4354BEAC1338E97E334EA.NQF - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\ESET\ESET Smart Security\Antispam\scrh.bin - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Internet Explorer\MSIMGSIZ.DAT - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\desktop.ini - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\counters.dat - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\CrashDumps\HPWMISVC.exe.2312.dmp - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\History\desktop.ini - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\desktop.ini - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\8TMFVPHI.txt - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat - Ok
C:\Windows\SysWOW64\config\systemprofile\Favorites\desktop.ini - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\ESET\ESET Smart Security\Quarantine\2F9FADE9109BEECE04DAC831CE0F3B9D2F245828.NQF - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\IETldCache\index.dat - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\ESET\ESET Smart Security\Quarantine\E138B8E2071B96EF2C1FA1B95838D713C1186997.NQF - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Roaming\Apple Computer\Logs\asl.103945_12Nov13.log - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Roaming\Apple Computer\Logs\asl.105859_13Nov13.log - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Roaming\Apple Computer\Logs\asl.091718_18Nov13.log - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Roaming\Apple Computer\Logs\asl.114853_08Nov13.log - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Roaming\Apple Computer\Logs\asl.042420_14Nov13.log - Ok
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\ESET\ESET Smart Security\Antispam\sc1.bin - Ok
C:\Windows\SysWOW64\cs-CZ\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\cs-CZ\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\cs-CZ\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\cs-CZ\fms.dll.mui - Ok
C:\Windows\SysWOW64\config\systemprofile\Favorites\HP Games.lnk - Ok
C:\Windows\SysWOW64\cs-CZ\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\da-DK\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\da-DK\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\da-DK\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\da-DK\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\da-DK\mlang.dll.mui - Ok
C:\Windows\SysWOW64\da-DK\fms.dll.mui - Ok
C:\Windows\SysWOW64\cs-CZ\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\cs-CZ\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\cs-CZ\mlang.dll.mui - Ok
C:\Windows\SysWOW64\da-DK\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\da-DK\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\cs-CZ\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\da-DK\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\da-DK\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\de-DE\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\cs-CZ\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\drivers\103C_HP_cNB_Pavilion dv7 Notebook PC_Y5335KV_0U_Q2CE2022D7F_EFU1010059BIS-B2A_4A_I1800_SHP_V10.56_BF.12_T111026_W73-1_L413_M8140_J750_7Intel_86A7_92.20_#120117_N_(B0M73EA#UUG)_XMOBILE_CN10_Z.MRK - Ok
C:\Windows\SysWOW64\de-DE\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\de-DE\mlang.dll.mui - Ok
C:\Windows\SysWOW64\drivers\gmreadme.txt - Ok
C:\Windows\SysWOW64\de-DE\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\de-DE\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\de-DE\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\de-DE\fms.dll.mui - Ok
C:\Windows\SysWOW64\de-DE\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\drivers\gm.dls - Ok
C:\Windows\SysWOW64\drivers\nl-NL\ndiscap.sys.mui - Ok
C:\Windows\SysWOW64\de-DE\msimsg.dll.mui - Ok
>C:\Windows\SysWOW64\drivers\wimmount.sys - packed by FLY-CODE
C:\Windows\SysWOW64\de-DE\UIAnimation.dll.mui - Ok
C:\Windows\SysWOW64\drivers\nl-NL\pacer.sys.mui - Ok
C:\Windows\SysWOW64\drivers\nl-NL\scfilter.sys.mui - Ok
C:\Windows\SysWOW64\drivers\nl-NL\qwavedrv.sys.mui - Ok
C:\Windows\SysWOW64\drivers\nl-NL\bfe.dll.mui - Ok
C:\Windows\SysWOW64\drivers\nl-NL\tcpip.sys.mui - Ok
C:\Windows\SysWOW64\el-GR\mlang.dll.mui - Ok
C:\Windows\SysWOW64\el-GR\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\el-GR\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\el-GR\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\el-GR\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\el-GR\fms.dll.mui - Ok
C:\Windows\SysWOW64\el-GR\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\de-DE\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\el-GR\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\el-GR\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\en-US\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\en-US\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\en-US\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\en-US\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\en-US\elshyph.dll.mui - Ok
C:\Windows\SysWOW64\en-US\fms.dll.mui - Ok
>C:\Windows\SysWOW64\en-US\icardie.dll.mui is BINARYRES container
C:\Windows\SysWOW64\en-US\html.iec.mui - Ok
C:\Windows\SysWOW64\en-US\IEAdvpack.dll.mui - Ok
C:\Windows\SysWOW64\en-US\iepeers.dll.mui - Ok
C:\Windows\SysWOW64\en-US\iedkcs32.dll.mui - Ok
C:\Windows\SysWOW64\en-US\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\en-US\dfshim.dll.mui - Ok
C:\Windows\SysWOW64\drivers\wimmount.sys - Ok
C:\Windows\SysWOW64\en-US\icardie.dll.mui - container
C:\Windows\SysWOW64\el-GR\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\en-US\licmgr10.dll.mui - Ok
C:\Windows\SysWOW64\en-US\iexpress.exe.mui - Ok
>C:\Windows\SysWOW64\en-US\iesetup.dll.mui is BINARYRES container
C:\Windows\SysWOW64\en-US\mlang.dll.mui - Ok
C:\Windows\SysWOW64\en-US\iernonce.dll.mui - Ok
C:\Windows\SysWOW64\en-US\msfeedsbs.dll.mui - Ok
C:\Windows\SysWOW64\en-US\ieunatt.exe.mui - Ok
C:\Windows\SysWOW64\en-US\iesetup.dll.mui - container
C:\Windows\SysWOW64\en-US\mshta.exe.mui - Ok
C:\Windows\SysWOW64\en-US\inetcpl.cpl.mui - Ok
C:\Windows\SysWOW64\en-US\mshtmlmedia.dll.mui - Ok
C:\Windows\SysWOW64\en-US\jscript9.dll.mui - Ok
C:\Windows\SysWOW64\en-US\jscript.dll.mui - Ok
C:\Windows\SysWOW64\en-US\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\en-US\ieui.dll.mui - Ok
C:\Windows\SysWOW64\en-US\inseng.dll.mui - Ok
C:\Windows\SysWOW64\en-US\UIAnimation.dll.mui - Ok
>C:\Windows\SysWOW64\en-US\mshtml.dll.mui is BINARYRES container
C:\Windows\SysWOW64\en-US\mshtmler.dll.mui - Ok
C:\Windows\SysWOW64\en-US\mshtml.dll.mui - container
C:\Windows\SysWOW64\en-US\msrating.dll.mui - Ok
C:\Windows\SysWOW64\en-US\urlmon.dll.mui - Ok
C:\Windows\SysWOW64\en-US\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\en-US\vbscript.dll.mui - Ok
C:\Windows\SysWOW64\en-US\webcheck.dll.mui - Ok
C:\Windows\SysWOW64\en-US\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\es-ES\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\en-US\wextract.exe.mui - Ok
C:\Windows\SysWOW64\en-US\occache.dll.mui - Ok
C:\Windows\SysWOW64\es-ES\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\en-US\wininet.dll.mui - Ok
C:\Windows\SysWOW64\es-ES\UIAnimation.dll.mui - Ok
C:\Windows\SysWOW64\es-ES\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\es-ES\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\es-ES\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\es-ES\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\es-ES\fms.dll.mui - Ok
C:\Windows\SysWOW64\et-EE\mlang.dll.mui - Ok
C:\Windows\SysWOW64\es-ES\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\es-ES\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\et-EE\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\et-EE\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\es-ES\mlang.dll.mui - Ok
C:\Windows\SysWOW64\fi-FI\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\fi-FI\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\fi-FI\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\et-EE\fms.dll.mui - Ok
C:\Windows\SysWOW64\fi-FI\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\fi-FI\fms.dll.mui - Ok
C:\Windows\SysWOW64\fi-FI\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\fi-FI\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\et-EE\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\fi-FI\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\fr-FR\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\fi-FI\mlang.dll.mui - Ok
C:\Windows\SysWOW64\fr-FR\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\fi-FI\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\fr-FR\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\fr-FR\fms.dll.mui - Ok
C:\Windows\SysWOW64\fr-FR\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\fr-FR\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\fr-FR\UIAnimation.dll.mui - Ok
C:\Windows\SysWOW64\fr-FR\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\fr-FR\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\he-IL\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\fr-FR\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\he-IL\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\fr-FR\mlang.dll.mui - Ok
C:\Windows\SysWOW64\he-IL\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\he-IL\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\he-IL\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\hr-HR\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\he-IL\fms.dll.mui - Ok
C:\Windows\SysWOW64\hr-HR\fms.dll.mui - Ok
C:\Windows\SysWOW64\hr-HR\mlang.dll.mui - Ok
C:\Windows\SysWOW64\he-IL\mlang.dll.mui - Ok
C:\Windows\SysWOW64\hr-HR\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\hr-HR\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\hu-HU\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\hu-HU\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\hu-HU\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\hu-HU\fms.dll.mui - Ok
C:\Windows\SysWOW64\icsxml\osinfo.xml - Ok
C:\Windows\SysWOW64\hu-HU\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\icsxml\cmnicfg.xml - Ok
C:\Windows\SysWOW64\icsxml\potscfg.xml - Ok
C:\Windows\SysWOW64\icsxml\ipcfg.xml - Ok
C:\Windows\SysWOW64\hu-HU\mlang.dll.mui - Ok
C:\Windows\SysWOW64\icsxml\pppcfg.xml - Ok
C:\Windows\SysWOW64\hu-HU\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\hu-HU\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\hu-HU\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\it-IT\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\it-IT\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\it-IT\UIAnimation.dll.mui - Ok
C:\Windows\SysWOW64\it-IT\mlang.dll.mui - Ok
C:\Windows\SysWOW64\it-IT\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\it-IT\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\it-IT\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\it-IT\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\it-IT\fms.dll.mui - Ok
C:\Windows\SysWOW64\it-IT\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\ja-JP\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\hu-HU\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\ja-JP\mlang.dll.mui - Ok
C:\Windows\SysWOW64\ja-JP\fms.dll.mui - Ok
C:\Windows\SysWOW64\ja-JP\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\ja-JP\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\ja-JP\UIAnimation.dll.mui - Ok
C:\Windows\SysWOW64\it-IT\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\ja-JP\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\ko-KR\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\ja-JP\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\ja-JP\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\ko-KR\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\ko-KR\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\ko-KR\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\ja-JP\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\ja-JP\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\ko-KR\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\ko-KR\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\ko-KR\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\ko-KR\mlang.dll.mui - Ok
C:\Windows\SysWOW64\ko-KR\fms.dll.mui - Ok
C:\Windows\SysWOW64\lt-LT\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\lv-LV\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\lt-LT\mlang.dll.mui - Ok
C:\Windows\SysWOW64\ko-KR\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\lt-LT\fms.dll.mui - Ok
C:\Windows\SysWOW64\manifeststore\advapi32.amx - Ok
C:\Windows\SysWOW64\manifeststore\gdi32.amx - Ok
C:\Windows\SysWOW64\manifeststore\kernel32.amx - Ok
C:\Windows\SysWOW64\manifeststore\kernelbase.amx - Ok
C:\Windows\SysWOW64\manifeststore\user32.amx - Ok
C:\Windows\SysWOW64\lt-LT\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\lt-LT\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\lv-LV\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\lv-LV\mlang.dll.mui - Ok
>C:\Windows\SysWOW64\migration\audmigplugin.dll - packed by FLY-CODE
C:\Windows\SysWOW64\lv-LV\msimsg.dll.mui - Ok
>C:\Windows\SysWOW64\migration\imjpmig.dll - packed by FLY-CODE
C:\Windows\SysWOW64\lv-LV\fms.dll.mui - Ok
C:\Windows\SysWOW64\migration\imscmig.dll - Ok
C:\Windows\SysWOW64\migration\gameuxmig.dll - Ok
C:\Windows\SysWOW64\migration\imtcmig.dll - Ok
C:\Windows\SysWOW64\migration\bthmigplugin.dll - Ok
C:\Windows\SysWOW64\migration\commig.dll - Ok
C:\Windows\SysWOW64\migration\IphlpsvcMigPlugin.dll - Ok
C:\Windows\SysWOW64\migration\imjpmig.dll - Ok
C:\Windows\SysWOW64\migration\imkrmig.dll - Ok
C:\Windows\SysWOW64\migration\CntrtextMig.dll - Ok
C:\Windows\SysWOW64\en-US\ieframe.dll.mui - Ok
C:\Windows\SysWOW64\migration\netiomig.dll - Ok
C:\Windows\SysWOW64\migration\audmigplugin.dll - Ok
C:\Windows\SysWOW64\migration\nlscoremig.dll - Ok
C:\Windows\SysWOW64\migration\SCGMigPlugin.dll - Ok
>C:\Windows\SysWOW64\migration\shmig.dll - packed by FLY-CODE
C:\Windows\SysWOW64\migration\msctfmig.dll - Ok
C:\Windows\SysWOW64\migration\TableTextServiceMig.dll - Ok
C:\Windows\SysWOW64\migration\modemmigplugin.dll - Ok
C:\Windows\SysWOW64\migration\WSMT\rras\dlmanifests\RasApi-DL.man - Ok
C:\Windows\SysWOW64\migration\PlaMig.dll - Ok
C:\Windows\SysWOW64\migration\WSMT\rras\dlmanifests\RasmanService-DL.man - Ok
C:\Windows\SysWOW64\migration\WSMT\rras\dlmanifests\RasServerOC-DL.man - Ok
C:\Windows\SysWOW64\migration\WSearchMigPlugin.dll - Ok
C:\Windows\SysWOW64\migration\SxsMigPlugin.dll - Ok
C:\Windows\SysWOW64\migration\WSMT\rras\replacementmanifests\RasApi-Repl.man - Ok
C:\Windows\SysWOW64\migration\WSMT\rras\replacementmanifests\RasBase-Rassstp-Repl.man - Ok
C:\Windows\SysWOW64\migration\WSMT\rras\dlmanifests\RasServerMigPlugin-DL.man - Ok
C:\Windows\SysWOW64\migration\WininetPlugin.dll - Ok
C:\Windows\SysWOW64\migration\WSMT\rras\replacementmanifests\RasmanService-Repl.man - Ok
C:\Windows\SysWOW64\migration\StorMigPlugin.dll - Ok
C:\Windows\SysWOW64\migration\WSMT\rras\replacementmanifests\RasRqs-Repl.man - Ok
C:\Windows\SysWOW64\migration\WSMT\rras\replacementmanifests\Rasppp-Repl.man - Ok
>C:\Windows\SysWOW64\migration\WSMT\rras\replacementmanifests\RasServer-Repl.man is JS-HTML container
C:\Windows\SysWOW64\migration\WSMT\rras\replacementmanifests\RasServer-Repl.man - container
C:\Windows\SysWOW64\migration\WSMT\rras\replacementmanifests\RasDdm-Repl.man - Ok
C:\Windows\SysWOW64\migration\nl-NL\ShMig.dll.mui - Ok
C:\Windows\SysWOW64\migration\WsUpgrade.dll - Ok
C:\Windows\SysWOW64\migration\nl-NL\SxsMigPlugin.dll.mui - Ok
C:\Windows\SysWOW64\migration\WSMT\rras\dlmanifests\Microsoft-Windows-RasServer-MigPlugin\RasMigPlugin-DL-Mig.dll - Ok
C:\Windows\SysWOW64\migration\WSMT\rras\replacementmanifests\RasBase-Repl.man - Ok
C:\Windows\SysWOW64\migration\nl-NL\WsUpgrade.dll.mui - Ok
C:\Windows\SysWOW64\migwiz\migfiles.dat - Ok
C:\Windows\SysWOW64\migration\WMIMigrationPlugin.dll - Ok
C:\Windows\SysWOW64\migration\WSMT\rras\replacementmanifests\Microsoft-Windows-RasApi-MigPlugin\pbkmigr-Mig.dll - Ok
C:\Windows\SysWOW64\migration\shmig.dll - Ok
C:\Windows\SysWOW64\migwiz\migres.dll - Ok
C:\Windows\SysWOW64\migration\WSMT\rras\replacementmanifests\Microsoft-Windows-RasServer-MigPlugin\RasMigPlugin-Mig.dll - Ok
C:\Windows\SysWOW64\migwiz\cmi2migxml.dll - Ok
>C:\Windows\SysWOW64\migwiz\MigApp.xml is JS-HTML container
C:\Windows\SysWOW64\migwiz\mighost.exe - Ok
C:\Windows\SysWOW64\migwiz\SFCN.dat - Ok
C:\Windows\SysWOW64\migwiz\MXEAgent.dll - Ok
C:\Windows\SysWOW64\migration\MediaPlayer-DLMigPlugin.dll - Ok
C:\Windows\SysWOW64\migwiz\SFLCID.dat - Ok
C:\Windows\SysWOW64\migwiz\csiagent.dll - Ok
C:\Windows\SysWOW64\migwiz\MigSys.dll - Ok
C:\Windows\SysWOW64\migwiz\MigSetup.exe - Ok
C:\Windows\SysWOW64\migwiz\SFPAT.inf - Ok
C:\Windows\SysWOW64\migwiz\SFPATW7.inf - Ok
C:\Windows\SysWOW64\migwiz\SFLISTXP.dat - Ok
C:\Windows\SysWOW64\migwiz\SFLISTW7.dat - Ok
C:\Windows\SysWOW64\migwiz\SFLISTLH.dat - Ok
C:\Windows\SysWOW64\migwiz\PostMigRes\Web\base_images\AppInstalled.gif - Ok
C:\Windows\SysWOW64\migwiz\migstore.dll - Ok
C:\Windows\SysWOW64\migwiz\PostMigRes\Web\base_images\ClickDownExpanded.gif - Ok
C:\Windows\SysWOW64\migwiz\PostMigRes\Web\base_images\ClickDownNormal.gif - Ok
C:\Windows\SysWOW64\migwiz\PostMigRes\Web\base_images\Documents.gif - Ok
C:\Windows\SysWOW64\migwiz\SFPATLH.inf - Ok
C:\Windows\SysWOW64\migwiz\PostMigRes\Web\base_images\Column.bmp - Ok
C:\Windows\SysWOW64\migwiz\SFPATXP.inf - Ok
C:\Windows\SysWOW64\migwiz\migwiz.exe - Ok
C:\Windows\SysWOW64\migwiz\PostMigRes\Web\base_images\Failure.gif - Ok
C:\Windows\SysWOW64\migwiz\PostMigRes\Web\base_images\System.gif - Ok
C:\Windows\SysWOW64\migwiz\PostMigRes\Web\base_images\Users.gif - Ok
C:\Windows\SysWOW64\migwiz\PostMigRes\Web\base_images\WindowsMovieMaker.bmp - Ok
C:\Windows\SysWOW64\migwiz\PostMigRes\Web\base_images\Programs.gif - Ok
C:\Windows\SysWOW64\migwiz\PostMigRes\Web\base_images\WindowsMail.bmp - Ok
C:\Windows\SysWOW64\migwiz\PostMigRes\Web\base_images\WindowsPhotoGallery.bmp - Ok
C:\Windows\SysWOW64\migwiz\PostMigRes\data\HardwareVendors.xml - Ok
C:\Windows\SysWOW64\migwiz\PostMigRes\Web\base_images\WindowsOutlookExpress.bmp - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\ActiveDirectory-WMIReplicationProvider-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\ActiveDirectory-WebServices-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\ADFS-FederationService-DL.man - Ok
>C:\Windows\SysWOW64\migwiz\PostMig.exe is BINARYRES container
C:\Windows\SysWOW64\migwiz\dlmanifests\ADFS-WebAgentClaims-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\adminui-dl.man - Ok
>>C:\Windows\SysWOW64\migwiz\PostMig.exe\data001 is JS-HTML container
C:\Windows\SysWOW64\migwiz\PostMig.exe - container
C:\Windows\SysWOW64\migwiz\dlmanifests\ADSI-LDAP-Provider-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\ADFS-WebAgentToken-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\ADSI-LDAP-Extensions-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\ADFS-FederationServiceProxy-DL.man - Ok
>C:\Windows\SysWOW64\migwiz\PostMigRes\Web\reportapi.js is JS-HTML container
C:\Windows\SysWOW64\migwiz\dlmanifests\ADSI-WinNT-Provider-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\ADSI-Router-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Application_Experience-Infrastructure-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\authui-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\CAPI2_certs-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\CoreOS-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\BITSExtensions-Server-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\BITSExtensions-Server-Console-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\AccessibilityCpl-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\CommandPrompt-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Credential-Manager-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\crypto_keys-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\DFSClient-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\DirectoryServices-Domain-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\DirectoryServices-ADAM-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\DFSN-ServerService-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\DirectoryServices-ISM-Smtp-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\dpapi_keys-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\DHCPServerMigPlugin-DL.man - Ok
C:\Windows\SysWOW64\migwiz\PostMigRes\Web\reportapi.js - container
C:\Windows\SysWOW64\migwiz\dlmanifests\ETW-core-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\DNS-Server-Service-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\DNS-Client-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\DRM-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\eudcedit-dl.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\feclient-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\evntagnt-dl.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Fonts-Type1-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\explorer-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\GPMC-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\EventCollector-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\gpmgmt-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\GroupPolicy-Admin-Gpedit-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\GroupPolicy-Admin-Gpedit-Snapin-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\frs-core-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\HTTP-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\GPBase-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\ieframe-dl.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\International-Core-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\IPSec-Svc-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\International-TimeZones-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\IasMigPlugin-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Eventlog-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\GroupPolicy-CSE-SoftwareInstallation-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\iSNS_Service-DL.man - Ok
C:\Windows\SysWOW64\migwiz\MigApp.xml - container
C:\Windows\SysWOW64\migwiz\dlmanifests\jetcore-DL.man - Ok
C:\Windows\SysWOW64\migwiz\unbcl.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\jetexcel-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\jet2x3x-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\jetexchlotus-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\jettext-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\jetxbasepdx-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Ldap-Client-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\MediaServer-ASPAdmin-Migration-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\MediaServer-Multicast-Migration-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\MediaServer-Migration-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-Bits-Client-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Kerberos-Key-Distribution-Center-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-CertificateServices-CA-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-CertificateServices-CAManagement-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-CertificateServices-MSCEP-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-DFSR-Core-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-HtmlHelp-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-Dot3svc-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-ICM-Profiles-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-ASPNET-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IE-Feeds-Platform-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-ASP-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-BasicAuthentication-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IE-ESC-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-CGI-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-CustomLogging-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-DefaultDocument-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-DirectoryBrowsing-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-HttpCompressionStatic-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-FTPServer-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-HttpErrors-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-HttpCompressionDynamic-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-HttpTracing-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-HttpRedirect-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-HTTPLogging-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-DigestAuthentication-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-ClientCertificateMappingAuthentication-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-IISCertificateMappingAuthentication-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-ISAPIFilter-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-ISAPIExtensions-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-LegacyScripts-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-LegacySnapIn-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-ManagementConsole-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-ManagementService-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-ManagementScriptingTools-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-IPSecurity-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-LoggingLibraries-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-Metabase-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-RequestMonitor-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-ODBCLogging-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-ServerSideIncludes-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-RequestFiltering-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-NetFxExtensibility-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IE-ClientNetworkProtocolImplementation-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-WMICompatibility-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-WindowsAuthentication-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-StaticContent-Deployment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-URLAuthorization-Deployment-DL.man - Ok
>C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-Mail-DL.man is JS-HTML container
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-MediaPlayer-Migration-DL.man - Ok
>C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IE-InternetExplorer-DL.man is JS-HTML container
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-OfflineFiles-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-Mail-DL.man - container
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-StorageMigration-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IE-InternetExplorer-DL.man - container
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-NetworkBridge-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-NETFXCoreComp-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-Sxs-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-SharedAccess-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-TapiSetup-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-WAS-NetFxEnvironment-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-WAS-ConfigurationAPI-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft.Windows.COM.ComPlus.Setup.DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-WAS-ProcessModel-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-WCFCoreComp-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-WlanSvc-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft.Windows.COM.DTC.Setup-DL.man - Ok
>C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-WAB-DL.man is JS-HTML container
C:\Windows\SysWOW64\migwiz\dlmanifests\MigrationDisplayGroups-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-WAB-DL.man - container
C:\Windows\SysWOW64\migwiz\dlmanifests\mpr-dl.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\msmq-domain-ic-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\msmq-routing-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\msmq-triggers-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\msmq-http-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Mup-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Networking-MPSSVC-Svc-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Netlogon-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\MUISettings-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\ndis-dl.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\nfs-servercore-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\NetworkLoadBalancingFullServer-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\ntoskrnl-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\openportmapper-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\openrpc-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\partmgr-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\PeerToPeerGraphing-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\PeerToPeerAdmin-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\PeerToPeerGrouping-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\PeerToPeerPNRP-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\PeerToPeerIdManager-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\PerformanceCounterInfrastructure-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Printing-Spooler-Core-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Printing-Spooler-Networkclient-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\RasApi-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\PeerToPeerBase-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\nfs-clientcore-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\psync-dl.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\RasCMAK-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\RasmanService-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\RasServerOC-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\RasConnectionManager-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\RPC-HTTP-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\RPC-HTTP_Proxy-DL.man - Ok
>C:\Windows\SysWOW64\migwiz\dlmanifests\odbc32dll-DL.man is JS-HTML container
C:\Windows\SysWOW64\migwiz\dlmanifests\RPC-Local-DL.man - Ok
>C:\Windows\SysWOW64\migwiz\dlmanifests\msmq-messagingcoreservice-DL.man is JS-HTML container
C:\Windows\SysWOW64\migwiz\dlmanifests\RasServerMigPlugin-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\RPC-Remote-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Security-Digest-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\schannel-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\odbc32dll-DL.man - container
C:\Windows\SysWOW64\migwiz\dlmanifests\Security-Kerberos-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Security-NTLM-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\shmig-DL.man - Ok
>C:\Windows\SysWOW64\migwiz\dlmanifests\SchedSvc-DL.man is JS-HTML container
C:\Windows\SysWOW64\migwiz\dlmanifests\SimpleTCP-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\SchedSvc-DL.man - container
C:\Windows\SysWOW64\migwiz\dlmanifests\shell32-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Smtpsvc-Admin-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Smtpsvc-Service-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Smss-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Rights-Management-Client-v1-API-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\SmartCardSubsystem-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\snmp-dl.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\snis-dl.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\SpeechCommon-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\TabletPC-TabBtn-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\msmq-messagingcoreservice-DL.man - container
C:\Windows\SysWOW64\migwiz\dlmanifests\TabletPCInputPanel-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Telnet-client-dl.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\terminalservices-AppServer-Licensing-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\TerminalServices-Drivers-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\TCPIP-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\terminalservices-licenseserver-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\TerminalServices-LocalSessionManager-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\TabletPCJournal-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\TerminalServices-RDP-WinStationExtensions-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\TabletPCPlatformInput-core-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\TerminalServices-RemoteConnectionManager-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\TerminalServices-SessionDirectory-Client-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\TerminalServices-TerminalServicesClient-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\srm-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Telnet-Server-dl.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Unimodem-Config-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\sua-dl.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\UPnPControlPoint-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\UPnPSSDP-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\TextServicesFramework-Migration-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Vss-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Video-TVVideoControl-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\VirtualDiskService-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\UPnPDeviceHost-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\themeui-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Time-Service-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\wds-dl.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Web-Services-for-Management-Core-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\WebEnroll-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\WebDAVRedir-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\WebDAVRedir-MrxDAV-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\WindowsSearchEngine-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\win32k-settings-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\WMI-SNMP-Provider-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\WMI-Core-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\WirelessNetworking-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\winlogon-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\wsinfra-upgrade-dl.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\WSRM-Service-DL.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\BITSExtensions-Server\bitsmig.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-ADFS-DL\adfsmig.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-COM-ComPlus-Setup-DL\commig.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-Bluetooth-Config\BthMigPlugin.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-COM-DTC-Setup-DL\msdtcstp.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-ActiveDirectory-WebServices-DL\adwsmigrate.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-DirectoryServices-ADAM-DL\adammigrate.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-International-Core-DL\nlscoremig.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-NetworkBridge\bridgemigplugin.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-DHCPServerMigPlugin-DL\DhcpSrvMigPlugin.dll - Ok
>C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IasServer-MigPlugin\IasMigPlugin.dll is BINARYRES container
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-NDIS\ndismigplugin.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IasServer-MigPlugin\IasMigPlugin.dll - container
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-MediaPlayer-DRM-DL\drmmgrtn.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-NetworkLoadBalancing-Core\NlbMigPlugin.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-OfflineFiles-DL\CscMigDl.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-IIS-DL\iismig.dll - Ok
>C:\Windows\SysWOW64\migwiz\wet.dll is BINARYRES container
>C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-TextServicesFramework-Migration-DL\imjpmig.dll - packed by FLY-CODE
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-PerformanceCounterInfrastructure-DL\CntrtextMig.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-StorageMigration\StorMigPlugin.dll - Ok
>>C:\Windows\SysWOW64\migwiz\wet.dll\data001 is JS-HTML container
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-TapiSetup\TapiMigPlugin.dll - Ok
C:\Windows\SysWOW64\migwiz\wet.dll - container
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-TextServicesFramework-Migration-DL\imkrmig.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-RasConnectionManager\cmmigr.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-MediaPlayer\MediaPlayer-DLMigPlugin.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-Sxs\SxsMigPlugin.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-TextServicesFramework-Migration-DL\imtcmig.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-RasServer-MigPlugin\RasMigPlugin.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-TextServicesFramework-Migration-DL\imjpmig.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-TextServicesFramework-Migration-DL\TableTextServiceMig.dll - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-TextServicesFramework-Migration-DL\msctfmig.dll - Ok
C:\Windows\SysWOW64\migwiz\nl-NL\migwiz.exe.mui - Ok
>C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-shmig-DL\shmig.dll - packed by FLY-CODE
C:\Windows\SysWOW64\migwiz\dlmanifests\Networking-MPSSVC-Svc\icfupgd.dll - Ok
C:\Windows\SysWOW64\migwiz\nl-NL\migres.dll.mui - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-Unimodem-Config\ModemMigPlugin.dll - Ok
>C:\Windows\SysWOW64\migwiz\nl-NL\PostMig.exe.mui is BINARYRES container
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-TextServicesFramework-Migration-DL\imscmig.dll - Ok
C:\Windows\SysWOW64\migwiz\nl-NL\migsetup.exe.mui - Ok
>>C:\Windows\SysWOW64\migwiz\nl-NL\PostMig.exe.mui\data001 is JS-HTML container
C:\Windows\SysWOW64\migwiz\nl-NL\PostMig.exe.mui - container
C:\Windows\SysWOW64\migwiz\replacementmanifests\audiommecore-other-migration-replacement.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-WMI-Core\WMIMigrationPlugin.dll - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\activedirectory-webservices-replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\Application-Experience-Program-Compatibility-Assistant-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\eudcedit-replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\capi2_certs-repl.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\ExtensibleAuthenticationProtocolHostService-Rep.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\dhcpclientdll-repl.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\FailoverCluster-Core-WOW64-RM.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\Fonts-Type1-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\FunDisc-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\gameuxmig-Replacement.man - Ok
>C:\Windows\SysWOW64\migwiz\nl-NL\wet.dll.mui is BINARYRES container
C:\Windows\SysWOW64\migwiz\replacementmanifests\authui-migration-replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\iis-ftpextensibility-rm.man - Ok
>C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_9_900_117.dll - packed by BINARYRES
>>C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_9_900_117.dll is WISE container
C:\Windows\SysWOW64\migwiz\replacementmanifests\iis-powershellprovider-rm.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\iis-ftpsvc-rm.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\iis-sharedlibraries-rm.man - Ok
C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_9_900_117.dll - container
C:\Windows\SysWOW64\migwiz\replacementmanifests\IPv4IPv6CoexistenceMigration-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\ehome-reg-inf_repl.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\microsoft-hyper-v-client-migration-replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\iis-webdav-rm.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\International-core-replacement.man - Ok
>>C:\Windows\SysWOW64\migwiz\nl-NL\wet.dll.mui\data006 is JS-HTML container
C:\Windows\SysWOW64\migwiz\nl-NL\wet.dll.mui - container
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-msmq-messagingcoreservice\mqmigplugin.dll - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\Microsoft-Windows-NETFX35CDFComp-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\Microsoft-Windows-OfflineFiles-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\Microsoft-Windows-WCFCoreComp-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\nfs-admincore-repl.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\Microsoft.Windows.Servermanager-non_msil-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\ndis-repl.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\nfs-clientcore-repl.man - Ok
>C:\Windows\SysWOW64\migwiz\replacementmanifests\dhcpservermigplugin-rep.man is JS-HTML container
C:\Windows\SysWOW64\migwiz\replacementmanifests\Microsoft-Windows-SecureStartup-FilterDriver-Replacement.man - Ok
>C:\Windows\SysWOW64\migwiz\replacementmanifests\Microsoft-Windows-Fax-Service-Replacement.man is JS-HTML container
C:\Windows\SysWOW64\migwiz\replacementmanifests\mmsys-migration-replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\printing-localprinting-replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\Printing-ServerCore-WOW64-RM.man - Ok
C:\Windows\SysWOW64\migwiz\dlmanifests\Microsoft-Windows-shmig-DL\shmig.dll - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\dhcpservermigplugin-rep.man - container
C:\Windows\SysWOW64\migwiz\replacementmanifests\Microsoft-Windows-Fax-Service-Replacement.man - container
C:\Windows\SysWOW64\migwiz\replacementmanifests\nfs-servercore-repl.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\ServerCore-EA-IME-WOW64-RM.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\shmig-replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\RasmanService-Repl.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\servercore-wow64-rm.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\Microsoft-Windows-NETFXCoreComp-Repl.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\srm-service-reports-repl.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\srm-datascrndriver-repl.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\srm-service-repl.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\stickynotes-replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\srm-ui-repl.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\srm-quotadriver-repl.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\sounds-migration-replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\suaCore-WOW64-RM.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\sysdm-replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\SysMain-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\TabletPC-UIHub-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\Rasppp-Repl.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\tabletpcstickynotes-replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\TabletPCPlatformInput-core-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\Rights-Management-Client-v1-API-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\TCPIP-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\TerminalServices-AppServer-Licensing-replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\TerminalServices-RAPWebPart-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\TerminalServices-SBMgr-SnapIn-non_msil-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\TerminalServices-Manager-SnapIn-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\UsbMigPlugin-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\WCF-HTTP-Activation-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\WCF-NonHTTP-Activation-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\vsssystemprovider-replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\virtualdiskservice-repl.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\TerminalServices-LicenseServer-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\Windows-MarketTheme-MCTAdmin-Component-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\migcore.dll - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\WindowsSearchEngine-replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\WMI-Core-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\vssservice-repl.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\WSRM-Service-Replacement.man - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\Microsoft-Windows-GameUXMig\gameuxmig.dll - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\WindowsSearchEngine\WSearchMigPlugin.dll - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\Usb\usbmigplugin.dll - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\Microsoft-Windows-TerminalServices-AppServer-Licensing\tsmigplugin.dll - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\Microsoft-Windows-OfflineFiles-Core\CscMig.dll - Ok
>C:\Windows\SysWOW64\migwiz\replacementmanifests\Microsoft-Windows-IE-InternetExplorer-repl.man is JS-HTML container
C:\Windows\SysWOW64\migwiz\replacementmanifests\Microsoft-Windows-IE-InternetExplorer-repl.man - container
C:\Windows\SysWOW64\migwiz\replacementmanifests\microsoft-activedirectory-webservices\adwsmigrate.dll - Ok
>C:\Windows\SysWOW64\migwiz\replacementmanifests\microsoft-windows-audio-mmecore-other\audmigplugin.dll - packed by FLY-CODE
C:\Windows\SysWOW64\nb-NO\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\microsoft-international-core\nlscoremig.dll - Ok
C:\Windows\SysWOW64\nb-NO\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\nb-NO\comdlg32.dll.mui - Ok
>C:\Windows\SysWOW64\migwiz\replacementmanifests\microsoft-windows-shmig\shmig.dll - packed by FLY-CODE
C:\Windows\SysWOW64\migwiz\replacementmanifests\microsoft-windows-iis-rm\iismig.dll - Ok
C:\Windows\SysWOW64\nb-NO\fms.dll.mui - Ok
C:\Windows\SysWOW64\nb-NO\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\nb-NO\mlang.dll.mui - Ok
C:\Windows\SysWOW64\nb-NO\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\nb-NO\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\microsoft-windows-ndis\ndismigplugin.dll - Ok
C:\Windows\SysWOW64\nl-NL\aaclient.dll.mui - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\Microsoft-Windows-TerminalServices-LicenseServer\TlsRepPlugin.dll - Ok
C:\Windows\SysWOW64\nl-NL\acledit.dll.mui - Ok
C:\Windows\SysWOW64\nb-NO\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\accessibilitycpl.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\acppage.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\aclui.dll.mui - Ok
C:\Windows\SysWOW64\nb-NO\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ActionCenterCPL.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\AdapterTroubleshooter.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\adsmsext.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\activeds.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\acctres.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\adsldpc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ActionCenter.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\adsldp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\adprovider.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\adsnt.dll.mui - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\microsoft-windows-audio-mmecore-other\audmigplugin.dll - Ok
C:\Windows\SysWOW64\nl-NL\amstream.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\AltTab.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\aelupsvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\aeevts.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\apphelp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\advpack.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\apircl.dll.mui - Ok
C:\Windows\SysWOW64\migwiz\replacementmanifests\microsoft-windows-shmig\shmig.dll - Ok
C:\Windows\SysWOW64\nl-NL\appwiz.cpl.mui - Ok
C:\Windows\SysWOW64\nl-NL\apds.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\apilogen.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\appidapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\apss.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Apphlpdm.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\arp.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\attrib.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\audiodg.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\atl.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\AtBroker.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\AudioSrv.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\adtschema.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\at.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\AudioSes.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\audiodev.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\authfwgp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\auditpol.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\azman.msc - Ok
C:\Windows\SysWOW64\nl-NL\authfwcfg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\authui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\advapi32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\asferror.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\avicap32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\avifil32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\azroles.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\autoplay.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\azsqlext.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\autochk.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\basecsp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\batmeter.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\AuxiliaryDisplayCpl.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\azroleui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\BioCredProv.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\bitsadmin.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\BWUnpairElevated.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\bthudtask.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\btpanui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\bthprops.cpl.mui - Ok
C:\Windows\SysWOW64\nl-NL\bfe.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\BWContextHandler.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Bubbles.scr.mui - Ok
C:\Windows\SysWOW64\nl-NL\bootcfg.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\capisp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\capiprovider.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\certcredprovider.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\autoconv.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\certcli.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\cacls.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\CertEnrollCtrl.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\certenc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\certmgr.msc - Ok
C:\Windows\SysWOW64\nl-NL\CertEnrollUI.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\CertEnroll.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Autofmt.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\calc.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\CertPolEng.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\certreq.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\cero.rs.mui - Ok
C:\Windows\SysWOW64\nl-NL\cabview.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\charmap.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\certmgr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\certprop.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\chkdsk.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\cic.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\cewmdm.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\cipher.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\clb.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\cfgbkend.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\chkntfs.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\choice.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\cleanmgr.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\clip.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\cmdkey.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\cliconfg.rll.mui - Ok
C:\Windows\SysWOW64\nl-NL\cmmon32.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\cmcfg32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\cmstplua.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\clusapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\cmlua.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\cmdl32.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\cngprovider.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\cmstp.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\colorcpl.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\cob-au.rs.mui - Ok
C:\Windows\SysWOW64\nl-NL\cmd.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\comp.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\cmdial32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\colorui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\compact.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\compstui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ComputerDefaults.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\compmgmt.msc - Ok
C:\Windows\SysWOW64\nl-NL\cmutil.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\cpfilters.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\certutil.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\comexp.msc - Ok
C:\Windows\SysWOW64\nl-NL\cryptsvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\console.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\connect.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\cryptxml.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\credui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ctfmon.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\cryptext.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\cttunesvr.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\credwiz.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\crypt32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\csrss.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\csrsrv.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\cscript.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\dcomcnfg.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\DDACLSys.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\cryptdlg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ddraw.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\cryptui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dataclen.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\cttune.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\deskperf.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\CSRR.rs.mui - Ok
C:\Windows\SysWOW64\nl-NL\desk.cpl.mui - Ok
C:\Windows\SysWOW64\nl-NL\DDORes.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dccw.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\devenum.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\defaultlocationcpl.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\DevicePairingProxy.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\deskadp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\DevicePairingFolder.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\DeviceProperties.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\deskmon.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\DevicePairing.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\DeviceCenter.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\DfsShlEx.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dhcpcsvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\comres.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dhcpcore.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\DfrgUI.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\dhcpcsvc6.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dfshim.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\devmgr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\DeviceUxRes.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dimsjob.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\DHCPQEC.DLL.MUI - Ok
C:\Windows\SysWOW64\nl-NL\dhcpcmonitor.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\devmgmt.msc - Ok
C:\Windows\SysWOW64\nl-NL\dinput.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\diskmgmt.msc - Ok
C:\Windows\SysWOW64\nl-NL\dhcpcore6.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dialer.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\dimsroam.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\diskperf.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\djctq.rs.mui - Ok
C:\Windows\SysWOW64\nl-NL\diskcopy.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dmocx.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\DisplaySwitch.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\dmdskres2.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dmusic.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Display.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Dism.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\doskey.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\dmutil.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dot3dlg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dinput8.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\docprop.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dot3gpclnt.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dot3msm.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dot3api.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dnsapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dnscmmc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dhcpsapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\diskpart.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\dpapimig.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\dot3hc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\diskraid.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\dot3svc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dot3ui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dpapiprovider.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dot3gpui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\DpiScaling.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\dot3cfg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dmdskres.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dpnsvr.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\drvinst.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\drprov.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dpwsockx.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dpnet.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dplaysvr.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\DShowRdpFilter.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dskquoui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\driverquery.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\dskquota.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\drt.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dtsh.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dsuiext.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dui70.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dvdupgrd.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\dvdplay.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\dsound.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dpmodemx.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\duser.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dsquery.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dsprop.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\eappgnui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\DWWIN.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\dxdiagn.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\eappcfg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\EAPQEC.DLL.MUI - Ok
C:\Windows\SysWOW64\nl-NL\DXPTaskRingtone.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\EhStorShell.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\efscore.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\dxdiag.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\efsadu.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\DxpTaskSync.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\EhStorAPI.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\eapphost.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\erofflps.txt - Ok
C:\Windows\SysWOW64\nl-NL\elscore.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\encdec.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\EhStorPwdMgr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\els.dll.mui - Ok
>C:\Windows\SysWOW64\nl-NL\EventViewer_EventDetails.xsl is JS-HTML container
C:\Windows\SysWOW64\nl-NL\dssec.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\EhStorAuthn.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\esrb.rs.mui - Ok
C:\Windows\SysWOW64\nl-NL\eudcedit.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\ESENT.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\extrac32.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\evr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\eqossnap.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\expand.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\fc.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\EventViewer_EventDetails.xsl - container
C:\Windows\SysWOW64\nl-NL\eventvwr.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\explorer.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\eventvwr.msc - Ok
C:\Windows\SysWOW64\nl-NL\faultrep.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\findstr.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\EventCreate.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\explorerframe.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\finger.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\fltlib.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\FirewallControlPanel.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\fde.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\fltMC.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\forfiles.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\fontext.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\FirewallAPI.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\fpb.rs.mui - Ok
C:\Windows\SysWOW64\nl-NL\fms.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\fdeploy.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\find.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\fixmapi.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\fontview.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\fthsvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\FunDisc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ftp.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\fphc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\g711codc.ax.mui - Ok
C:\Windows\SysWOW64\nl-NL\filemgmt.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\gameux.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\fsutil.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\getmac.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\glu32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\GCDEF.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\fwcfg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\fsmgmt.msc - Ok
C:\Windows\SysWOW64\nl-NL\fwpuclnt.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\gpapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\gpprnext.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\gpresult.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\gptext.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\grpconv.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\FXSRESM.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\gpsvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\hdwwiz.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\grb.rs.mui - Ok
C:\Windows\SysWOW64\nl-NL\hh.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\hidphone.tsp.mui - Ok
C:\Windows\SysWOW64\nl-NL\hid.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\hcproviders.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\gpedit.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\gpupdate.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\hlink.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\hdwwiz.cpl.mui - Ok
C:\Windows\SysWOW64\nl-NL\hgcpl.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\hidserv.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\hhctrl.ocx.mui - Ok
C:\Windows\SysWOW64\nl-NL\hnetcfg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\iasacct.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\hnetmon.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\html.iec.mui - Ok
C:\Windows\SysWOW64\nl-NL\hostname.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\iasads.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\help.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\httpapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ias.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\iac25_32.ax.mui - Ok
C:\Windows\SysWOW64\nl-NL\iashlpr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\iasrad.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\htui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ICacls.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\icm32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\iassvcs.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\icsigd.dll.mui - Ok
>C:\Windows\SysWOW64\nl-NL\icardie.dll.mui is BINARYRES container
C:\Windows\SysWOW64\nl-NL\iassdo.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\IdListen.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\iccvid.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\icardie.dll.mui - container
C:\Windows\SysWOW64\nl-NL\iepeers.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ieui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ieunatt.exe.mui - Ok
>C:\Windows\SysWOW64\nl-NL\iesetup.dll.mui is BINARYRES container
C:\Windows\SysWOW64\nl-NL\IEAdvpack.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\iernonce.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\iesetup.dll.mui - container
C:\Windows\SysWOW64\nl-NL\iexpress.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\iedkcs32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ikeext.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\imagesp1.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\imageres.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\imapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\imaadp32.acm.mui - Ok
C:\Windows\SysWOW64\nl-NL\ifmon.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\imapi2.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\icmui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\InfDefaultInstall.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\input.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\iologmsg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\intl.cpl.mui - Ok
C:\Windows\SysWOW64\nl-NL\ipconfig.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\iphlpapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\inseng.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\inetres.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\getuname.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\inetcpl.cpl.mui - Ok
C:\Windows\SysWOW64\nl-NL\iprtrmgr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ipsecsvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\imapi2fs.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ir32_32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\iphlpsvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ipnathlp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ipsecsnp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ir41_32.ax.mui - Ok
C:\Windows\SysWOW64\nl-NL\ir50_32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\IpsmSnap.dll.mui - Ok
>C:\Windows\SysWOW64\nl-NL\icardres.dll.mui is BINARYRES container
C:\Windows\SysWOW64\nl-NL\irclass.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\iscsicli.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\iscsicpl.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\irprops.cpl.mui - Ok
C:\Windows\SysWOW64\nl-NL\iscsiexe.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\iscsidsc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\iscsicpl.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\jscript.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\isoburn.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\iyuv_32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\jscript9.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\kerberos.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\keyiso.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\kmddsp.tsp.mui - Ok
C:\Windows\SysWOW64\nl-NL\joy.cpl.mui - Ok
C:\Windows\SysWOW64\nl-NL\ksproxy.ax.mui - Ok
C:\Windows\SysWOW64\nl-NL\ksxbar.ax.mui - Ok
C:\Windows\SysWOW64\nl-NL\ivfsrc.ax.mui - Ok
C:\Windows\SysWOW64\nl-NL\iasdatastore.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ktmutil.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\label.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\kswdmcap.ax.mui - Ok
C:\Windows\SysWOW64\nl-NL\l3codeca.acm.mui - Ok
C:\Windows\SysWOW64\nl-NL\kstvtune.ax.mui - Ok
C:\Windows\SysWOW64\nl-NL\l2nacp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\licmgr10.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\lmhsvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\listsvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\keymgr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\LocationNotifications.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\L2SecHC.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\logagent.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\KernelBase.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\lipeula.rtf - Ok
C:\Windows\SysWOW64\nl-NL\localsec.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\loadperf.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\loghours.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Magnification.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\logman.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\icardres.dll.mui - container
C:\Windows\SysWOW64\nl-NL\Magnify.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\mapi32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mcicda.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mciqtz32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mapistub.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\lodctr.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\lpeula.rtf - Ok
C:\Windows\SysWOW64\nl-NL\mciseq.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mciwave.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\main.cpl.mui - Ok
C:\Windows\SysWOW64\nl-NL\lusrmgr.msc - Ok
C:\Windows\SysWOW64\nl-NL\mf.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mciavi32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mfpmp.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\MFC42u.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\midimap.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mferror.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mdminst.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\MigAutoPlay.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\mfplat.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mctres.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\miguiresource.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mimefilt.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\MFReadWrite.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mmcshext.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mmci.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mmcbase.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\MFC40.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\MFC40u.dll.mui - Ok
>C:\Windows\SysWOW64\nl-NL\mmcndmgr.dll.mui is BINARYRES container
>>C:\Windows\SysWOW64\nl-NL\mmcndmgr.dll.mui\data001 is JS-HTML container
C:\Windows\SysWOW64\nl-NL\MFC42.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\MFPlay.dll.mui - Ok
>>C:\Windows\SysWOW64\nl-NL\mmcndmgr.dll.mui\data002 is JS-HTML container
C:\Windows\SysWOW64\nl-NL\mmres.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mountvol.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\modemui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mmcndmgr.dll.mui - container
C:\Windows\SysWOW64\nl-NL\mpr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mp4sdecd.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mprddm.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mprdim.dll.mui - Ok
>C:\Windows\SysWOW64\nl-NL\mmc.exe.mui is BINARYRES container
C:\Windows\SysWOW64\nl-NL\MMDevAPI.dll.mui - Ok
>>C:\Windows\SysWOW64\nl-NL\mmc.exe.mui\data001 is JS-HTML container
C:\Windows\SysWOW64\nl-NL\mrinfo.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\msadp32.acm.mui - Ok
>>C:\Windows\SysWOW64\nl-NL\mmc.exe.mui\data002 is JS-HTML container
C:\Windows\SysWOW64\nl-NL\mmsys.cpl.mui - Ok
C:\Windows\SysWOW64\nl-NL\mpssvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msacm32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msacm32.drv.mui - Ok
C:\Windows\SysWOW64\nl-NL\mprmsg.dll.mui - Ok
>>C:\Windows\SysWOW64\nl-NL\mmc.exe.mui\data003 is JS-HTML container
C:\Windows\SysWOW64\nl-NL\msaatext.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mscandui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ieframe.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msctf.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mscms.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mlang.dll.mui - Ok
>>C:\Windows\SysWOW64\nl-NL\mmc.exe.mui\data005 is JS-HTML container
C:\Windows\SysWOW64\nl-NL\MsCtfMonitor.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mscpxl32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msdtc.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\msdrm.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msctfui.dll.mui - Ok
>>C:\Windows\SysWOW64\nl-NL\mmc.exe.mui\data006 is JS-HTML container
C:\Windows\SysWOW64\nl-NL\msfeedsbs.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msaudite.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msdtcVSp1res.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msg711.acm.mui - Ok
C:\Windows\SysWOW64\nl-NL\msdt.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\msgsm32.acm.mui - Ok
>>C:\Windows\SysWOW64\nl-NL\mmc.exe.mui\data008 is JS-HTML container
C:\Windows\SysWOW64\nl-NL\mshtmlmedia.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mmc.exe.mui - container
C:\Windows\SysWOW64\nl-NL\mshta.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\msidntld.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mshtmler.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msimtf.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msident.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\kernel32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msieftp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msmpeg2enc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msoert2.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msorc32r.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msrle32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msobjs.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msiexec.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\msinfo32.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\mspaint.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\mssha.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msjint40.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msports.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msscript.ocx.mui - Ok
C:\Windows\SysWOW64\nl-NL\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mssign32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mssph.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mssphtb.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msrating.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mssrch.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msshavmsg.dll.mui - Ok
>C:\Windows\SysWOW64\nl-NL\mshtml.dll.mui is BINARYRES container
C:\Windows\SysWOW64\nl-NL\mshtml.dll.mui - container
C:\Windows\SysWOW64\nl-NL\msra.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\msutb.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msvidc32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mssvp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mswstr10.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msv1_0.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msvfw32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mstask.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mtstocom.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\MSWMDM.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mstsc.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\mswsock.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\napdsnap.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\napinsp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\napipsec.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mydocs.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mstscax.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\mycomput.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\NAPCLCFG.MSC - Ok
C:\Windows\SysWOW64\nl-NL\nci.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Mystify.scr.mui - Ok
C:\Windows\SysWOW64\nl-NL\MSVidCtl.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ncrypt.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ncpa.cpl.mui - Ok
C:\Windows\SysWOW64\nl-NL\ndadmin.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\ndptsp.tsp.mui - Ok
C:\Windows\SysWOW64\nl-NL\msxml3r.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\netbtugc.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\nddeapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\msxml6r.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\NAPSTAT.EXE.MUI - Ok
C:\Windows\SysWOW64\nl-NL\ndfapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\NcdProp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ncryptui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\NAPMONTR.DLL.MUI - Ok
C:\Windows\SysWOW64\nl-NL\ndishc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\netcfgx.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\netcorehc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\netiougc.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\netcenter.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\netid.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\neth.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Netplwiz.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\netlogon.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\netdiagfx.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\netplwiz.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\netprof.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\netprofm.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\netevent.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\NetworkItemFactory.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\netsh.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\NetworkExplorer.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\newdev.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\netiohlp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\netshell.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\NetworkMap.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\nlmgp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\nlhtml.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\netstat.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\newdev.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\nlasvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\notepad.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\netmsg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\nsisvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ntlanman.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ntlanui2.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ntprint.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\nshhttp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ntshrui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\nlsbres.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ntmarta.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\nshwfp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ntvdm64.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\nslookup.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\ntprint.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\odbcad32.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\oflc-nz.rs.mui - Ok
C:\Windows\SysWOW64\nl-NL\occache.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ole32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\objsel.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\nshipsec.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\offFilt.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\odbcji32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\olecli32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\odbcconf.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\ocsetup.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\ntdll.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\onexui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\oflc.rs.mui - Ok
C:\Windows\SysWOW64\nl-NL\OnLineIDCPL.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\odbcint.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\OptionalFeatures.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\osbaseln.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\oobefldr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\oleres.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\p2pcollab.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\openfiles.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\p2p.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\oleaccrc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\oledlg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\oleprn.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\onex.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\osk.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\pdhui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\pegi-fi.rs.mui - Ok
C:\Windows\SysWOW64\nl-NL\pcwum.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\pathping.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\pautoenr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\pdh.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\pcaui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\pegi.rs.mui - Ok
C:\Windows\SysWOW64\nl-NL\pegi-pt.rs.mui - Ok
C:\Windows\SysWOW64\nl-NL\perfhost.exe.mui - Ok
>C:\Windows\SysWOW64\nl-NL\perfmon.exe.mui is BINARYRES container
C:\Windows\SysWOW64\nl-NL\perfctrs.dll.mui - Ok
>>C:\Windows\SysWOW64\nl-NL\perfmon.exe.mui\data001 is JS-HTML container
C:\Windows\SysWOW64\nl-NL\perfproc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\perfos.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\perfmon.exe.mui - container
C:\Windows\SysWOW64\nl-NL\perfdisk.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\perfnet.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\PerfCenterCPL.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\packager.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\PhotoScreensaver.scr.mui - Ok
C:\Windows\SysWOW64\nl-NL\pegibbfc.rs.mui - Ok
C:\Windows\SysWOW64\nl-NL\pnidui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\p2pnetsh.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ping.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\pnrpnsp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\PortableDeviceApi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\poqexec.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\PlaySndSrv.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\pla.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\polstore.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\portabledevicestatus.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\pots.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\perfmon.msc - Ok
C:\Windows\SysWOW64\nl-NL\PortableDeviceSyncProvider.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\PresentationHost.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\powercfg.cpl.mui - Ok
C:\Windows\SysWOW64\nl-NL\print.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\printui.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\powrprof.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\psbase.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\proquota.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\powercfg.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\prnfldr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\photowiz.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\prnntfy.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\powercpl.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\provsvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\pwrshplugin.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\prflbmsg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\qasf.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\printui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\QAgent.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\QCLIPROV.DLL.MUI - Ok
C:\Windows\SysWOW64\nl-NL\pshed.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\puiobj.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\puiapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\qcap.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\qdvd.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\qedit.dll.mui - Ok
>C:\Windows\SysWOW64\nl-NL\psr.exe.mui is BINARYRES container
C:\Windows\SysWOW64\nl-NL\propsys.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Qutil.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\QAgentRT.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\QSVRMGMT.DLL.MUI - Ok
C:\Windows\SysWOW64\nl-NL\psr.exe.mui - container
C:\Windows\SysWOW64\nl-NL\qdv.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\racengn.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\QShvHost.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Query.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\rasautou.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\rascfg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\qwave.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\qmgr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\racpldlg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\radarrs.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\rasapi32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\quartz.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\radardt.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\rasauto.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\rasdial.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\raschap.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\rasdiag.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\rasctrs.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\rasmm.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\rasphone.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\raserver.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\recover.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\rasplap.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\rdrleakdiag.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\rasgcw.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\reagentc.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\reg.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\reagent.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\RestartManager.mfl - Ok
C:\Windows\SysWOW64\nl-NL\replace.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\rasdlg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\RestartManagerUninstall.mfl - Ok
C:\Windows\SysWOW64\nl-NL\RMActivate.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\rastls.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\regedit.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\regsvr32.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\remotepg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\rasmontr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\RmClient.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\RMActivate_ssp_isv.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\RMActivate_isv.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\relog.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\Ribbons.scr.mui - Ok
C:\Windows\SysWOW64\nl-NL\RMActivate_ssp.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\rpchttp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\RpcNs4.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\rrinstaller.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\rtffilt.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\rekeywiz.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\rpcrt4.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\rpcping.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\rshx32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Robocopy.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\RPCNDFP.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\RunLegacyCPLElevated.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\rstrtmgr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\rtm.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\runonce.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\SampleRes.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\sberes.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\route.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\rundll32.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\sccls.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\SCardDlg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\runas.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\rstrui.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\SCardSvr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\samsrv.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\sc.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\scansetting.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\rpcnsh.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\scecli.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\scrnsave.scr.mui - Ok
C:\Windows\SysWOW64\nl-NL\scksp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\sdchange.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\scesrv.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\schedsvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\scrobj.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\schtasks.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\scrrun.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\SearchIndexer.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\sdbinst.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\sdiagnhost.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\sens.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\secinit.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\secedit.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\sdohlp.dll.mui - Ok
>C:\Windows\SysWOW64\nl-NL\sdiageng.dll.mui is ZLIB container
C:\Windows\SysWOW64\nl-NL\sechost.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\sendmail.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\sdiagprv.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\serwvdrv.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\sessenv.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\SensorsCpl.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\setupSNK.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\services.msc - Ok
C:\Windows\SysWOW64\nl-NL\setupcln.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\setup16.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\sdiageng.dll.mui - container
C:\Windows\SysWOW64\nl-NL\setx.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\sethc.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\serialui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\sfc.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\shsvcs.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\shgina.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\shimgvw.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\setupapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\shlwapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\shutdown.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\slc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\searchfolder.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\slcext.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\SMBHelperClass.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\shrpubw.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\SmartcardCredentialProvider.dll.mui - Ok
>C:\Windows\SysWOW64\nl-NL\shwebsvc.dll.mui is BINARYRES container
C:\Windows\SysWOW64\nl-NL\softkbd.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\sndvolsso.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\smss.exe.mui - Ok
>>C:\Windows\SysWOW64\nl-NL\shwebsvc.dll.mui\data001 is JS-HTML container
>C:\Windows\SysWOW64\nl-NL\shellstyle.dll.mui is ZLIB container
>>C:\Windows\SysWOW64\nl-NL\shwebsvc.dll.mui\data002 is JS-HTML container
C:\Windows\SysWOW64\nl-NL\sppcc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\shwebsvc.dll.mui - container
C:\Windows\SysWOW64\nl-NL\sppcext.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\spp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\sndvol.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\sppc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\spwizres.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\srchadmin.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\sort.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\sppcomapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ssdpsrv.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\sscore.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\srvsvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\shdocvw.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\sppcommdlg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\stobject.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\sti.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\srcore.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\sud.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ssText3d.scr.mui - Ok
C:\Windows\SysWOW64\nl-NL\svchost.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\subst.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\StorageContextHandler.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\sqlsrv32.rll.mui - Ok
C:\Windows\SysWOW64\nl-NL\sxproxy.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Storprop.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\syncreg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\syskey.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\sxstrace.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\SyncCenter.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\systeminfo.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\syncui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\sysmon.ocx.mui - Ok
C:\Windows\SysWOW64\nl-NL\sxs.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\SyncInfrastructure.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\shellstyle.dll.mui - container
C:\Windows\SysWOW64\nl-NL\SystemPropertiesPerformance.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\SystemPropertiesHardware.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\SystemPropertiesRemote.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\SystemPropertiesProtection.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\SystemPropertiesAdvanced.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\SystemPropertiesComputerName.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\SystemPropertiesDataExecutionPrevention.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\sysdm.cpl.mui - Ok
C:\Windows\SysWOW64\nl-NL\tapi3.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\takeown.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\tapiui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\TaskEng.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\tapi32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\systemcpl.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\tbssvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\taskkill.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\taskschd.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\tapisrv.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\TCPMonUI.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\tcpipcfg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\shell32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\taskcomp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\tdh.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\tasklist.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\termsrv.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\taskmgr.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\themeui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\timedate.cpl.mui - Ok
C:\Windows\SysWOW64\nl-NL\tpmcompc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\thumbcache.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\telephon.cpl.mui - Ok
C:\Windows\SysWOW64\nl-NL\timeout.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\termmgr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\tsgqec.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\TSTheme.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\themecpl.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\taskschd.msc - Ok
C:\Windows\SysWOW64\nl-NL\tsmf.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\TpmInit.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\tracert.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\TSWorkspace.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\tvratings.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\tcmsetup.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\twext.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\typeperf.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\tpm.msc - Ok
C:\Windows\SysWOW64\nl-NL\tzres.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\UIAnimation.dll.mui - Ok
>C:\Windows\SysWOW64\nl-NL\tracerpt.exe.mui is BINARYRES container
C:\Windows\SysWOW64\nl-NL\tzutil.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\ubpm.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\uicom.dll.mui - Ok
>>C:\Windows\SysWOW64\nl-NL\tracerpt.exe.mui\data001 is JS-HTML container
C:\Windows\SysWOW64\nl-NL\UIAutomationCore.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ucmhc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\tquery.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\umpo.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ui0detect.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\tracerpt.exe.mui - container
C:\Windows\SysWOW64\nl-NL\UIRibbon.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\unimdm.tsp.mui - Ok
C:\Windows\SysWOW64\nl-NL\usbperf.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\unregmp2.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\usbceip.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\upnp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\unimdmat.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\UserAccountControlSettings.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\userinit.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\usbui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ulib.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\unlodctr.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\usk.rs.mui - Ok
C:\Windows\SysWOW64\nl-NL\Utilman.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\utildll.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\VaultCmd.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\urlmon.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\uxtheme.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\VaultCredProvider.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\vaultsvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\VaultSysUi.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\usercpl.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\vbscript.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\vds.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\upnphost.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\userenv.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\VAN.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\umpnpmgr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\vfwwdm32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\vdsbas.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\vdsutil.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\user32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\WABSyncProvider.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wavemsp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\vssadmin.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\Vault.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\waitfor.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\WcsPlugInService.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\vsstrace.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wcncsvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\verifier.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\webclnt.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\WEB.rs.mui - Ok
C:\Windows\SysWOW64\nl-NL\w32tm.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\vdsdyn.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\webio.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\vdsvd.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wcnwiz.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wecsvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wdmaud.drv.mui - Ok
C:\Windows\SysWOW64\nl-NL\WerFault.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\wevtfwd.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\WerFaultSecure.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\wdi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\webcheck.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wecutil.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\wevtutil.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\wevtapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\WF.msc - Ok
C:\Windows\SysWOW64\nl-NL\whealogr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wextract.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\webservices.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\where.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\WfHC.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\whoami.exe.mui - Ok
>C:\Windows\SysWOW64\nl-NL\wdc.dll.mui is BINARYRES container
C:\Windows\SysWOW64\nl-NL\wer.dll.mui - Ok
>>C:\Windows\SysWOW64\nl-NL\wdc.dll.mui\data001 is JS-HTML container
C:\Windows\SysWOW64\nl-NL\werui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wiaacmgr.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\wiavideo.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\whhelper.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wiaservc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wiascanprofiles.dll.mui - Ok
>>C:\Windows\SysWOW64\nl-NL\wdc.dll.mui\data002 is JS-HTML container
C:\Windows\SysWOW64\nl-NL\wdc.dll.mui - container
C:\Windows\SysWOW64\nl-NL\wimgapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wiadss.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\win32k.sys.mui - Ok
C:\Windows\SysWOW64\nl-NL\wiashext.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\winbio.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wincredprovider.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\win32spl.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wiaaut.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wiadefui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\WinSATAPI.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\winsockhc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\WinSync.rll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wininit.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\winsrv.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wininet.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\WinSyncMetastore.rll.mui - Ok
C:\Windows\SysWOW64\nl-NL\winmm.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\winspool.drv.mui - Ok
C:\Windows\SysWOW64\nl-NL\WinSyncProviders.rll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wlanext.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\WLanConn.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wlandlg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\winver.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\wlanmm.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wldap32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\WinSCard.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wlanapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\winhttp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wmidx.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wlanutil.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wlgpclnt.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wmiprop.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wlansvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wmpdui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Winrs.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\wlanpref.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wpcao.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wmpshell.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wpcsvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\WpdBusEnum.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wlangpui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Wpc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\WPDSp.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\WPDShextAutoplay.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\wlancfg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wpdshext.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wpdwcn.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wscript.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\wlanui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wshelper.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wscsvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wshext.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wshqos.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wshom.ocx.mui - Ok
C:\Windows\SysWOW64\nl-NL\wship6.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\ws2_32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wshtcpip.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wshrm.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\WsmSvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\XInput9_1_0.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wscui.cpl.mui - Ok
C:\Windows\SysWOW64\nl-NL\wvc.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wsock32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\xmlfilter.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\xpsfilt.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wzcdlg.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wuapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\xpsshhdr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wsdapi.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\xwtpw32.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\xwtpdui.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wsecedit.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\xwizards.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\xpsrchvw.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\xwizard.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\EnterpriseN\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\WsmRes.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\wmerror.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\Enterprise\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\wusa.exe.mui - Ok
C:\Windows\SysWOW64\nl-NL\zipfldr.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\EnterpriseE\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\HomeBasicN\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\HomePremiumE\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\HomeBasicE\license.rtf - Ok
>C:\Windows\SysWOW64\nl-NL\wmploc.DLL.mui is BINARYRES container
>>C:\Windows\SysWOW64\nl-NL\wmploc.DLL.mui\data001 is JS-HTML container
C:\Windows\SysWOW64\nl-NL\wmploc.DLL.mui - container
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\ProfessionalN\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\StarterE\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\Professional\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\HomeBasic\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\HomePremiumN\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\HomePremium\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\ProfessionalE\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\UltimateN\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\EnterpriseN\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\EnterpriseE\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\Starter\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\Ultimate\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\Enterprise\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\UltimateE\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\HomePremiumE\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\OEM\StarterN\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\HomeBasicN\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\ProfessionalE\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\HomeBasicE\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\UltimateE\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\StarterE\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\HomePremiumN\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\HomeBasic\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\Starter\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\UltimateN\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\EnterpriseN\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\HomeBasicE\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\Enterprise\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\Ultimate\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\HomePremium\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\ProfessionalN\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\HomeBasic\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\EnterpriseE\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\HomePremiumE\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\HomePremiumN\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\HomePremium\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\Professional\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\HomeBasicN\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\ProfessionalN\license.rtf - Ok
C:\Windows\SysWOW64\oobe\background.bmp - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\Professional\license.rtf - Ok
C:\Windows\SysWOW64\nl\AuthFWWizFwk.Resources.dll - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\UltimateE\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\StarterN\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\ProfessionalE\license.rtf - Ok
C:\Windows\SysWOW64\pl-PL\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\_Default\StarterN\license.rtf - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\StarterE\license.rtf - Ok
C:\Windows\SysWOW64\pl-PL\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\pl-PL\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\pl-PL\fms.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\UltimateN\license.rtf - Ok
C:\Windows\SysWOW64\pl-PL\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\pl-PL\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\pl-PL\mlang.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\Ultimate\license.rtf - Ok
C:\Windows\SysWOW64\pt-BR\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\pl-PL\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\pl-PL\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\nl-NL\Licenses\eval\Starter\license.rtf - Ok
C:\Windows\SysWOW64\pt-BR\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\pt-BR\fms.dll.mui - Ok
C:\Windows\SysWOW64\oobe\cmisetup.dll - Ok
C:\Windows\SysWOW64\pt-BR\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\pt-BR\mlang.dll.mui - Ok
C:\Windows\SysWOW64\pl-PL\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\pt-BR\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\pt-PT\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\pt-BR\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\pt-PT\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\pt-BR\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\pt-PT\fms.dll.mui - Ok
C:\Windows\SysWOW64\ras\cis.scp - Ok
C:\Windows\SysWOW64\pt-BR\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\pt-BR\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\pt-PT\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\pt-PT\mlang.dll.mui - Ok
C:\Windows\SysWOW64\ras\switch.inf - Ok
C:\Windows\SysWOW64\pt-PT\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\pt-PT\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\pt-PT\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\ras\pppmenu.scp - Ok
C:\Windows\SysWOW64\pt-PT\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\ras\pad.inf - Ok
C:\Windows\SysWOW64\ro-RO\mlang.dll.mui - Ok
C:\Windows\SysWOW64\ru-RU\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\ro-RO\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\pt-PT\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\ro-RO\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\ro-RO\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\ru-RU\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\ru-RU\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\ru-RU\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\ro-RO\fms.dll.mui - Ok
C:\Windows\SysWOW64\ru-RU\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\ru-RU\mlang.dll.mui - Ok
C:\Windows\SysWOW64\ru-RU\fms.dll.mui - Ok
C:\Windows\SysWOW64\ru-RU\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\sk-SK\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\sk-SK\mlang.dll.mui - Ok
C:\Windows\SysWOW64\sda\SDRTCPRM.dll - Ok
C:\Windows\SysWOW64\sk-SK\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\sk-SK\fms.dll.mui - Ok
C:\Windows\SysWOW64\ru-RU\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\ru-RU\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\slmgr\0413\slmgr.ini - Ok
C:\Windows\SysWOW64\sl-SI\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\spp\tokens\channels\OCUR\Security-SPP-Component-SKU-OCUR-RETAIL1-ul-oob.xrm-ms - Ok
C:\Windows\SysWOW64\sl-SI\mlang.dll.mui - Ok
C:\Windows\SysWOW64\spp\tokens\channels\OCUR\Security-SPP-Component-SKU-OCUR-ul-oob.xrm-ms - Ok
C:\Windows\SysWOW64\sl-SI\fms.dll.mui - Ok
C:\Windows\SysWOW64\spp\tokens\channels\OCUR\Security-SPP-Component-SKU-OCUR-RETAIL1-pl.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\channels\OCUR\Security-SPP-Component-SKU-OCUR-pl.xrm-ms - Ok
C:\Windows\SysWOW64\nl\AuthFWSnapIn.Resources.dll - Ok
C:\Windows\SysWOW64\sl-SI\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\sk-SK\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\sl-SI\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\spp\tokens\pkeyconfig\pkeyconfig.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\IASLicensing-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\Microsoft-Windows-Core-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\Microsoft-Windows-DOT11PREF-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\msmpeg2adec-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\msac3enc-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\LSA-License-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\GroupPolicy-License-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\feclient-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\ACLUIFileFolderTool-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\channels\OCUR\Security-SPP-Component-SKU-OCUR-ul-phn.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\provsvc-license-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\PhotoMinFeature-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\msmpeg2enc-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\Printing-Spooler-Core-Localspl-Licensing-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\Printing-Spooler-Core-Spoolss-Licensing-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\msmpeg2vdec-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\channels\OCUR\Security-SPP-Component-SKU-OCUR-RETAIL1-ul-phn.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\shell32-license-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\SLC-Component-SKU-OCUR-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\Security-SPP-Component-SKU-OCUR-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\sppui\reg.isp - Ok
C:\Windows\SysWOW64\sppui\migip.dun - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\TerminalServices-RemoteConnectionManager-UiEffects-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\WindowsSearchComponent-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\sppui\phone.inf - Ok
C:\Windows\SysWOW64\sppui\migrate.obe - Ok
C:\Windows\SysWOW64\sv-SE\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\sr-Latn-CS\fms.dll.mui - Ok
C:\Windows\SysWOW64\sr-Latn-CS\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\sr-Latn-CS\mlang.dll.mui - Ok
C:\Windows\SysWOW64\spp\tokens\ppdlic\TerminalServices-RemoteConnectionManager-License-ppdlic.xrm-ms - Ok
C:\Windows\SysWOW64\sv-SE\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\sv-SE\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\sr-Latn-CS\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\sr-Latn-CS\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\sv-SE\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\sv-SE\mlang.dll.mui - Ok
C:\Windows\SysWOW64\sv-SE\fms.dll.mui - Ok
C:\Windows\SysWOW64\th-TH\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\th-TH\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\th-TH\mlang.dll.mui - Ok
C:\Windows\SysWOW64\sv-SE\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\th-TH\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\th-TH\fms.dll.mui - Ok
C:\Windows\SysWOW64\tr-TR\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\sv-SE\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\tr-TR\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\tr-TR\mlang.dll.mui - Ok
C:\Windows\SysWOW64\tr-TR\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\uk-UA\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\tr-TR\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\uk-UA\mlang.dll.mui - Ok
C:\Windows\SysWOW64\sv-SE\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\tr-TR\fms.dll.mui - Ok
C:\Windows\SysWOW64\uk-UA\fms.dll.mui - Ok
C:\Windows\SysWOW64\uk-UA\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\uk-UA\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\tr-TR\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\tr-TR\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\tr-TR\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\wbem\auxiliarydisplaycpl.mof - Ok
C:\Windows\SysWOW64\wbem\DevicePairingHandler.mof - Ok
C:\Windows\SysWOW64\wbem\dimsjob.mof - Ok
C:\Windows\SysWOW64\tr-TR\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\wbem\cli.mof - Ok
C:\Windows\SysWOW64\wbem\authfwcfg.mof - Ok
C:\Windows\SysWOW64\sv-SE\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\wbem\aaclient.mof - Ok
C:\Windows\SysWOW64\wbem\auxiliarydisplayapi.mof - Ok
C:\Windows\SysWOW64\wbem\BthMtpEnum.mof - Ok
C:\Windows\SysWOW64\wbem\esscli.dll - Ok
C:\Windows\SysWOW64\wbem\dot3.mof - Ok
C:\Windows\SysWOW64\wbem\fdWSD.mof - Ok
C:\Windows\SysWOW64\wbem\FunDisc.mof - Ok
C:\Windows\SysWOW64\wbem\fdSSDP.mof - Ok
C:\Windows\SysWOW64\wbem\fdWNet.mof - Ok
C:\Windows\SysWOW64\wbem\dimsroam.mof - Ok
C:\Windows\SysWOW64\wbem\hbaapi.mof - Ok
C:\Windows\SysWOW64\wbem\iscsidsc.mof - Ok
C:\Windows\SysWOW64\wbem\firewallapi.mof - Ok
C:\Windows\SysWOW64\wbem\iscsiprf.mof - Ok
C:\Windows\SysWOW64\wbem\fastprox.dll - Ok
C:\Windows\SysWOW64\wbem\iscsihba.mof - Ok
C:\Windows\SysWOW64\wbem\eaimeapi.mof - Ok
C:\Windows\SysWOW64\wbem\DShowRdpFilter.mof - Ok
C:\Windows\SysWOW64\wbem\drvinst.mof - Ok
C:\Windows\SysWOW64\wbem\l2gpstore.mof - Ok
C:\Windows\SysWOW64\wbem\kerberos.mof - Ok
C:\Windows\SysWOW64\wbem\L2SecHC.mof - Ok
C:\Windows\SysWOW64\wbem\IMAPIv2-Base.mof - Ok
C:\Windows\SysWOW64\wbem\fwcfg.mof - Ok
C:\Windows\SysWOW64\wbem\IMAPIv2-LegacyShim.mof - Ok
C:\Windows\SysWOW64\wbem\ipsecsvc.mof - Ok
C:\Windows\SysWOW64\wbem\IMAPIv2-FileSystemSupport.mof - Ok
C:\Windows\SysWOW64\wbem\cliegaliases.mof - Ok
C:\Windows\SysWOW64\wbem\lsasrv.mof - Ok
C:\Windows\SysWOW64\wbem\msiscsi.mof - Ok
C:\Windows\SysWOW64\wbem\msv1_0.mof - Ok
C:\Windows\SysWOW64\wbem\mofcomp.exe - Ok
C:\Windows\SysWOW64\wbem\msfeedsbs.mof - Ok
C:\Windows\SysWOW64\wbem\msfeeds.mof - Ok
C:\Windows\SysWOW64\wbem\mpsdrv.mof - Ok
C:\Windows\SysWOW64\wbem\mpssvc.mof - Ok
C:\Windows\SysWOW64\wbem\mstsc.mof - Ok
C:\Windows\SysWOW64\wbem\mstscax.mof - Ok
C:\Windows\SysWOW64\wbem\mswmdm.mof - Ok
C:\Windows\SysWOW64\wbem\nci.mof - Ok
C:\Windows\SysWOW64\wbem\ncsi.mof - Ok
C:\Windows\SysWOW64\wbem\networkitemfactory.mof - Ok
C:\Windows\SysWOW64\wbem\netprofm.mof - Ok
C:\Windows\SysWOW64\wbem\networkmap.mof - Ok
C:\Windows\SysWOW64\wbem\newdev.mof - Ok
C:\Windows\SysWOW64\wbem\nshipsec.mof - Ok
C:\Windows\SysWOW64\wbem\p2p-collab.mof - Ok
C:\Windows\SysWOW64\wbem\pnpsetup.mof - Ok
C:\Windows\SysWOW64\wbem\iscsirem.mof - Ok
C:\Windows\SysWOW64\wbem\nlasvc.mof - Ok
C:\Windows\SysWOW64\wbem\p2p-mesh.mof - Ok
C:\Windows\SysWOW64\wbem\mmc.mof - Ok
C:\Windows\SysWOW64\wbem\nlsvc.mof - Ok
C:\Windows\SysWOW64\wbem\polstore.mof - Ok
C:\Windows\SysWOW64\wbem\p2p-pnrp.mof - Ok
C:\Windows\SysWOW64\wbem\ppcRsopCompSchema.mof - Ok
C:\Windows\SysWOW64\wbem\portabledevicewiacompat.mof - Ok
C:\Windows\SysWOW64\wbem\portabledeviceconnectapi.mof - Ok
C:\Windows\SysWOW64\wbem\portabledeviceclassextension.mof - Ok
C:\Windows\SysWOW64\wbem\portabledevicewmdrm.mof - Ok
C:\Windows\SysWOW64\wbem\ppcRsopUserSchema.mof - Ok
C:\Windows\SysWOW64\wbem\portabledevicetypes.mof - Ok
C:\Windows\SysWOW64\wbem\rawxml.xsl - Ok
C:\Windows\SysWOW64\wbem\RacWmiProv.mof - Ok
C:\Windows\SysWOW64\wbem\rdpcore.mof - Ok
C:\Windows\SysWOW64\wbem\qmgr.mof - Ok
C:\Windows\SysWOW64\wbem\schannel.mof - Ok
C:\Windows\SysWOW64\wbem\rdpencom.mof - Ok
C:\Windows\SysWOW64\wbem\sensorscpl.mof - Ok
C:\Windows\SysWOW64\wbem\SchedSvc.mof - Ok
C:\Windows\SysWOW64\wbem\ServiceModel.mof.uninstall - Ok
C:\Windows\SysWOW64\wbem\ServiceModel35.mof.uninstall - Ok
C:\Windows\SysWOW64\wbem\scersop.mof - Ok
C:\Windows\SysWOW64\wbem\ServiceModel35.mof - Ok
C:\Windows\SysWOW64\wbem\ssdpsrv.mof - Ok
C:\Windows\SysWOW64\wbem\setupapi.mof - Ok
C:\Windows\SysWOW64\wbem\onex.mof - Ok
C:\Windows\SysWOW64\wbem\portabledeviceapi.mof - Ok
C:\Windows\SysWOW64\wbem\regevent.mof - Ok
C:\Windows\SysWOW64\wbem\ServiceModel.mof - Ok
C:\Windows\SysWOW64\wbem\textvaluelist.xsl - Ok
C:\Windows\SysWOW64\wbem\vds.mof - Ok
C:\Windows\SysWOW64\wbem\tspkg.mof - Ok
C:\Windows\SysWOW64\wbem\texttable.xsl - Ok
C:\Windows\SysWOW64\wbem\mofd.dll - Ok
C:\Windows\SysWOW64\wbem\umpnpmgr.mof - Ok
C:\Windows\SysWOW64\wbem\tsmf.mof - Ok
C:\Windows\SysWOW64\wbem\tcpip.mof - Ok
C:\Windows\SysWOW64\wbem\RacWmiProv.dll - Ok
C:\Windows\SysWOW64\wbem\vss.mof - Ok
C:\Windows\SysWOW64\wbem\stdprov.dll - Ok
C:\Windows\SysWOW64\wbem\viewprov.dll - Ok
C:\Windows\SysWOW64\wbem\WFP.MOF - Ok
C:\Windows\SysWOW64\wbem\wbemprox.dll - Ok
C:\Windows\SysWOW64\wbem\wfs.mof - Ok
C:\Windows\SysWOW64\wbem\wdigest.mof - Ok
C:\Windows\SysWOW64\wbem\vdswmi.dll - Ok
C:\Windows\SysWOW64\wbem\WgxInstalledGame.mof - Ok
C:\Windows\SysWOW64\wbem\wbemdisp.tlb - Ok
C:\Windows\SysWOW64\wbem\WFAPIGP.mof - Ok
C:\Windows\SysWOW64\wbem\vsswmi.dll - Ok
C:\Windows\SysWOW64\wbem\wbemsvc.dll - Ok
C:\Windows\SysWOW64\wbem\whqlprov.mof - Ok
C:\Windows\SysWOW64\wbem\wininit.mof - Ok
C:\Windows\SysWOW64\wbem\winipsec.mof - Ok
C:\Windows\SysWOW64\wbem\WinsatUninstall.mof - Ok
C:\Windows\SysWOW64\wbem\Winsat.mof - Ok
C:\Windows\SysWOW64\wbem\wbemdisp.dll - Ok
C:\Windows\SysWOW64\wbem\Win32_Tpm.dll - Ok
C:\Windows\SysWOW64\wbem\WinMgmt.exe - Ok
C:\Windows\SysWOW64\wbem\WmiPerfClass.mof - Ok
C:\Windows\SysWOW64\wbem\wlan.mof - Ok
C:\Windows\SysWOW64\wbem\WmiApRpl.dll - Ok
C:\Windows\SysWOW64\wbem\WmiPerfInst.mof - Ok
C:\Windows\SysWOW64\wbem\wbemcntl.dll - Ok
C:\Windows\SysWOW64\wbem\wpc.mof - Ok
C:\Windows\SysWOW64\wbem\WMICOOKR.dll - Ok
C:\Windows\SysWOW64\wbem\WmiPerfInst.dll - Ok
C:\Windows\SysWOW64\wbem\WMIADAP.exe - Ok
C:\Windows\SysWOW64\wbem\wpcuninst.mof - Ok
C:\Windows\SysWOW64\wbem\wmp.mof - Ok
C:\Windows\SysWOW64\wbem\wpdbusenum.mof - Ok
C:\Windows\SysWOW64\wbem\WmiDcPrv.dll - Ok
C:\Windows\SysWOW64\wbem\WmiPerfClass.dll - Ok
C:\Windows\SysWOW64\wbem\wpdcomp.mof - Ok
C:\Windows\SysWOW64\wbem\wmiutils.dll - Ok
C:\Windows\SysWOW64\wbem\samsrv.mof - Ok
C:\Windows\SysWOW64\wbem\wpdmtp.mof - Ok
C:\Windows\SysWOW64\wbem\WPDShServiceObj.mof - Ok
C:\Windows\SysWOW64\wbem\wpdfs.mof - Ok
C:\Windows\SysWOW64\wbem\wscenter.mof - Ok
C:\Windows\SysWOW64\wbem\wscmisetup.mof - Ok
C:\Windows\SysWOW64\wbem\wpdshext.mof - Ok
C:\Windows\SysWOW64\wbem\wpdsp.mof - Ok
C:\Windows\SysWOW64\wbem\en-US\msfeeds.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\aaclient.mfl - Ok
C:\Windows\SysWOW64\wbem\xsl-mappings.xml - Ok
C:\Windows\SysWOW64\wbem\xwizards.mof - Ok
C:\Windows\SysWOW64\wbem\nl-NL\auxiliarydisplaycpl.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\cli.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\csv.xsl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\cliegaliases.mfl - Ok
C:\Windows\SysWOW64\wbem\WsmAuto.mof - Ok
C:\Windows\SysWOW64\wbem\en-US\msfeedsbs.mfl - Ok
C:\Windows\SysWOW64\wbem\wzcdlg.mof - Ok
C:\Windows\SysWOW64\wbem\nl-NL\hform.xsl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\l2gpstore.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\iscsidsc.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\htable.xsl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\iscsiprf.mfl - Ok
C:\Windows\SysWOW64\wbem\wpdwcn.mof - Ok
C:\Windows\SysWOW64\wbem\nl-NL\hbaapi.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\mof.xsl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\msfeeds.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\mstsc.mfl - Ok
C:\Windows\SysWOW64\wbem\wpcsprov.mof - Ok
C:\Windows\SysWOW64\wbem\nl-NL\msfeedsbs.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\MMFUtil.dll.mui - Ok
C:\Windows\SysWOW64\wbem\nl-NL\p2p-collab.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\p2p-mesh.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\p2p-pnrp.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\mstscax.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\RacWmiProv.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\regevent.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\rdpcore.mfl - Ok
C:\Windows\SysWOW64\wbem\WSDApi.mof - Ok
C:\Windows\SysWOW64\wbem\nl-NL\sensorscpl.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\rdpencom.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\vds.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\vss.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\ServiceModel.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\ServiceModel35.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\wcncsvc.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\WgxInstalledGame.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\whqlprov.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\wininit.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\vdswmi.dll.mui - Ok
C:\Windows\SysWOW64\wbem\nl-NL\ServDeps.dll.mui - Ok
C:\Windows\SysWOW64\wbem\nl-NL\wbemcore.dll.mui - Ok
C:\Windows\SysWOW64\wbem\nl-NL\mofcomp.exe.mui - Ok
C:\Windows\SysWOW64\wbem\WmiPrvSE.exe - Ok
C:\Windows\SysWOW64\wbem\WMIC.exe - Ok
C:\Windows\SysWOW64\wbem\nl-NL\win32_tpm.dll.mui - Ok
C:\Windows\SysWOW64\wbem\nl-NL\wbemcntl.dll.mui - Ok
C:\Windows\SysWOW64\wbem\nl-NL\WmiPerfClass.dll.mui - Ok
C:\Windows\SysWOW64\wbem\nl-NL\wscenter.mfl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\WmiApRpl.dll.mui - Ok
C:\Windows\SysWOW64\wbem\nl-NL\xml.xsl - Ok
C:\Windows\SysWOW64\wbem\nl-NL\xwizards.mfl - Ok
C:\Windows\SysWOW64\wdi\perftrack\AltTab.ptxml - Ok
C:\Windows\SysWOW64\wbem\xml\cim20.dtd - Ok
C:\Windows\SysWOW64\wdi\perftrack\comdlg32.ptxml - Ok
C:\Windows\SysWOW64\wbem\nl-NL\mofd.dll.mui - Ok
C:\Windows\SysWOW64\wbem\nl-NL\WmiPerfInst.dll.mui - Ok
C:\Windows\SysWOW64\wbem\nl-NL\wmiutils.dll.mui - Ok
C:\Windows\SysWOW64\wdi\perftrack\authui.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\DiagCpl.Events.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\DisplaySwitch.ptxml - Ok
C:\Windows\SysWOW64\wbem\nl-NL\vsswmi.dll.mui - Ok
C:\Windows\SysWOW64\wdi\perftrack\DeviceUx.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\HealthCenterCPLInstrumentation.ptxml - Ok
C:\Windows\SysWOW64\wbem\nl-NL\WinMgmt.exe.mui - Ok
C:\Windows\SysWOW64\wdi\perftrack\HealthCenterInstrumentation.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\Help-DataLayer.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\NetworkConnectionsFolder.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\DhcpClientDll.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\Microsoft-Windows-WLANConnectionFlow.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\prod_wow64_Audio-AudioCore.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\powercpl.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\themecpl.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\prod_wow64_wmpplayer.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\timedate.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\taskmgr.events.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\Display.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\VolumeControl.ptxml - Ok
C:\Windows\SysWOW64\wbem\xml\wmi20.dtd - Ok
C:\Windows\SysWOW64\wdi\perftrack\userplugplayetw.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\wdc.events.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\wow64_Microsoft-Windows-IE-HTMLRendering.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\wow64_networkprofile.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\wow64_microsoft-windows-van.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\NetworkDiagnosticsFramework.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\wow64_Spux.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\wow64_provsvc.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\wow64_UIAutomationCore.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\wow64_nlasvc.ptxml - Ok
C:\Windows\SysWOW64\wbem\nl-NL\WMIC.exe.mui - Ok
C:\Windows\SysWOW64\wbem\xml\wmi2xml.dll - Ok
C:\Windows\SysWOW64\winrm\0413\winrm.ini - Ok
C:\Windows\SysWOW64\wdi\perftrack\wow64_Sidebar.ptxml - Ok
C:\Windows\SysWOW64\wdi\perftrack\wow64_WinINet.ETW.ptxml - Ok
C:\Windows\SysWOW64\zh-CN\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\zh-CN\fms.dll.mui - Ok
C:\Windows\SysWOW64\zh-CN\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\zh-CN\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\zh-CN\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\zh-CN\mlang.dll.mui - Ok
C:\Windows\SysWOW64\zh-CN\msimsg.dll.mui - Ok
C:\Windows\SysWOW64\zh-CN\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\wdi\perftrack\wow64_ieframe.ptxml - Ok
C:\Windows\SysWOW64\zh-HK\mlang.dll.mui - Ok
C:\Windows\SysWOW64\zh-HK\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\zh-CN\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\zh-HK\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\zh-HK\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\zh-HK\fms.dll.mui - Ok
C:\Windows\SysWOW64\zh-CN\comdlg32.dll.mui - Ok
C:\Windows\SysWOW64\zh-HK\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\zh-HK\d2d1.dll.mui - Ok
C:\Users\Jan\Documents\Default.rdp - Ok
C:\Users\Jan\Documents\desktop.ini - Ok
C:\Windows\SysWOW64\wdi\perftrack\wow64_wlansvc.ptxml - Ok
C:\Windows\SysWOW64\zh-TW\WMPhoto.dll.mui - Ok
C:\Windows\SysWOW64\zh-TW\cdosys.dll.mui - Ok
C:\Windows\SysWOW64\zh-TW\comdlg32.dll.mui - Ok
C:\Users\Jan\Documents\Adobe\Premiere Pro\5.0\AMERequestDB - Ok
C:\Users\Jan\Documents\Add-in Express\adxregistrator.log - Ok
C:\Windows\SysWOW64\zh-TW\mlang.dll.mui - Ok
C:\Windows\SysWOW64\zh-TW\fms.dll.mui - Ok
C:\Windows\SysWOW64\zh-TW\comctl32.dll.mui - Ok
C:\Windows\SysWOW64\zh-TW\DWrite.dll.mui - Ok
C:\Windows\SysWOW64\zh-TW\msprivs.dll.mui - Ok
C:\Windows\SysWOW64\zh-TW\d2d1.dll.mui - Ok
C:\Windows\SysWOW64\zh-TW\msimsg.dll.mui - Ok
C:\Users\Jan\Documents\Adobe\Premiere Pro\5.0\Adobe Premiere Pro Auto-Save\Untitled-1.prproj - Ok
C:\Users\Jan\Documents\Mijn afbeeldingen - directory
C:\Users\Jan\Documents\Mijn muziek - directory
C:\Users\Jan\Documents\Mijn video's - directory
C:\Users\Jan\Documents\Adobe\Premiere Pro\5.0\Layouts\WorkspaceConfig.xml - Ok
C:\Users\Jan\Documents\Adobe\Premiere Pro\5.0\Styles\workingset.prsl - Ok
C:\Users\Jan\Documents\Adobe\Premiere Pro\5.0\Untitled.prproj - Ok
C:\Users\Jan\Documents\Adobe\Premiere Pro\5.0\acapella.prproj - Ok
C:\Users\Jan\Documents\Adobe\Premiere Pro\5.0\tango met ballen.prproj - Ok
>C:\Users\Jan\Documents\Outlook-bestanden\oude_mails_jan.pst is PST container
C:\Users\Jan\Documents\Outlook-bestanden\oude_mails_jan.pst - mail
C:\Users\Jan\Documents\Outlook-bestanden\~info@casinoeventsblankenberge.be.pst.tmp - Ok
C:\Users\Jan\Documents\Outlook-bestanden\~jan@witte-paard.be.pst.tmp - Ok
C:\Users\Jan\Documents\Outlook-bestanden\~jcoppe@containerquicklock.com.pst.tmp - Ok
C:\Users\Jan\Documents\Outlook-bestanden\~Outlook.pst.tmp - Ok
C:\Users\Jan\Documents\Youcam\CyberLink YouCam(Webcam).lnk - Ok
>C:\Users\Jan\Documents\Outlook-bestanden\Outlook.pst is PST container
C:\Users\Jan\Documents\Outlook-bestanden\Outlook.pst - mail
C:\Users\Jan\Documents\Adobe\Premiere Pro\5.0\Adobe Premiere Pro Auto-Save\Untitled-2.prproj - Ok
C:\Users\Jan\Documents\Youcam\EffectManualOrder\ManualOrder_Avatar.xml - Ok
C:\Users\Jan\Documents\Youcam\EffectManualOrder\ManualOrder_Distortion.xml - Ok
C:\Users\Jan\Documents\Youcam\EffectManualOrder\ManualOrder_Emotion.xml - Ok
C:\Users\Jan\Documents\Youcam\EffectManualOrder\ManualOrder_Filter.xml - Ok
C:\Users\Jan\Documents\Youcam\EffectManualOrder\ManualOrder_Frame.xml - Ok
C:\Users\Jan\Documents\Youcam\EffectManualOrder\ManualOrder_FunnyScene.xml - Ok
>C:\Users\Jan\Documents\Outlook-bestanden\jcoppe@containerquicklock.com.pst is PST container
>C:\Users\Jan\Documents\Outlook-bestanden\info@casinoeventsblankenberge.be.pst is PST container
C:\Users\Jan\Documents\Outlook-bestanden\jcoppe@containerquicklock.com.pst - mail
C:\Users\Jan\Documents\Youcam\EffectManualOrder\ManualOrder_Gadget.xml - Ok
C:\Users\Jan\Documents\Outlook-bestanden\info@casinoeventsblankenberge.be.pst - mail
C:\Windows\TEMP\fwtsqmfile00.sqm - Ok
C:\Users\Jan\Documents\Youcam\FileSharingTmp\ManualOrder_Sharing.xml - Ok
C:\Windows\TEMP\fwtsqmfile01.sqm - Ok
C:\Windows\TEMP\fwtsqmfile02.sqm - Ok
C:\Windows\TEMP\ACLM_GeneratedProxy.cs - Ok
C:\Windows\TEMP\fwtsqmfile03.sqm - Ok
C:\Users\Jan\Documents\Adobe\Premiere Pro\5.0\Adobe Premiere Pro Auto-Save\acapella-1.prproj - Ok
C:\Windows\TEMP\fwtsqmfile04.sqm - Ok
C:\Windows\TEMP\fwtsqmfile07.sqm - Ok
>C:\Users\Jan\Documents\Outlook-bestanden\jan@witte-paard.be.pst is PST container
C:\Users\Jan\Documents\Outlook-bestanden\jan@witte-paard.be.pst - mail
C:\Windows\TEMP\fwtsqmfile05.sqm - Ok
C:\Windows\TEMP\fwtsqmfile08.sqm - Ok
C:\Windows\TEMP\HealthCheckAC.xml - Ok
C:\Windows\TEMP\lpksetup-20131105-204001-0.log - Ok
C:\Windows\TEMP\lpksetup-20131104-193926-0.log - Ok
C:\Windows\TEMP\lpksetup-20131108-114920-0.log - Ok
C:\Windows\TEMP\lpksetup-20131113-105915-0.log - Ok
C:\Windows\TEMP\lpksetup-20131105-104548-0.log - Ok
C:\Windows\TEMP\fwtsqmfile06.sqm - Ok
C:\Windows\TEMP\lpksetup-20131106-111006-0.log - Ok
C:\Windows\TEMP\MpCmdRun.log - Ok
C:\Windows\TEMP\MpSigStub.log - Ok
C:\Windows\TEMP\lpksetup-20131114-042431-0.log - Ok
C:\Windows\TEMP\ACLM\CPSSMasterCatalog.ini - Ok
C:\Windows\TEMP\lpksetup-20131112-104002-0.log - Ok
C:\Users\Jan\AppData\Local\Temp\AdobeARM.log - Ok
C:\Windows\TEMP\lpksetup-20131118-091731-0.log - Ok
C:\Users\Jan\AppData\Local\Temp\chrome_installer.log - Ok
C:\Users\Jan\AppData\Local\Temp\CVR6542.tmp.cvr - Ok
C:\Users\Jan\AppData\Local\Temp\CVR69F8.tmp.cvr - Ok
C:\Users\Jan\AppData\Local\Temp\AdobeARM_NotLocked.log - Ok
C:\Users\Jan\AppData\Local\Temp\CVR7AF0.tmp.cvr - Ok
C:\Users\Jan\AppData\Local\Temp\CVR3AAE.tmp.cvr - Ok
C:\Users\Jan\AppData\Local\Temp\CVR8D47.tmp.cvr - Ok
C:\Users\Jan\AppData\Local\Temp\CVR9BF0.tmp.cvr - Ok
C:\Users\Jan\AppData\Local\Temp\CVRA0E.tmp.cvr - Ok
C:\Users\Jan\AppData\Local\Temp\CVRACA4.tmp.cvr - Ok
C:\Users\Jan\AppData\Local\Temp\CVRBCB9.tmp.cvr - Ok
C:\Users\Jan\AppData\Local\Temp\CVRB4A8.tmp.cvr - Ok
C:\Users\Jan\AppData\Local\Temp\CVR9D14.tmp.cvr - Ok
C:\Users\Jan\AppData\Local\Temp\CVR8C18.tmp.cvr - Ok
C:\Users\Jan\AppData\Local\Temp\CVR7601.tmp.cvr - Ok
C:\Windows\TEMP\ACLM\ACLMLog.txt - Ok
C:\Users\Jan\AppData\Local\Temp\CVRBF67.tmp.cvr - Ok
C:\Users\Jan\AppData\Local\Temp\CVRC0C1.tmp.cvr - Ok
C:\Users\Jan\AppData\Local\Temp\CVRDDE6.tmp.cvr - Ok
C:\Users\Jan\Documents\Adobe\Premiere Pro\5.0\Layouts\UserWorkspace2.xml - Ok
C:\Users\Jan\Documents\Adobe\Premiere Pro\5.0\ArchivedLayouts\UserWorkspace2.xml - Ok
C:\Users\Jan\AppData\Local\Temp\CVRC7E0.tmp.cvr - Ok
C:\Users\Jan\AppData\Local\Temp\DBTmp74801981977 - Ok
C:\Users\Jan\AppData\Local\Temp\CVRCC53.tmp.cvr - Ok
C:\Users\Jan\AppData\Local\Temp\DBTmp74801982148 - Ok
C:\Users\Jan\AppData\Local\Temp\CVRD1A8.tmp.cvr - Ok
C:\Users\Jan\AppData\Local\Temp\DBTmp74801984473 - Ok
C:\Users\Jan\AppData\Local\Temp\DBTmp74801997140 - Ok
C:\Users\Jan\AppData\Local\Temp\DBTmp74801997202 - Ok
C:\Users\Jan\AppData\Local\Temp\DBTmp74801982117 - Ok
C:\Users\Jan\AppData\Local\Temp\CVRE1BB.tmp.cvr - Ok
C:\Users\Jan\Documents\Adobe\Premiere Pro\5.0\Layouts\UserWorkspace1.xml - Ok
C:\Users\Jan\AppData\Local\Temp\jusched.log - Ok
C:\Users\Jan\AppData\Local\Temp\FXSAPIDebugLogFile.txt - Ok
C:\Users\Jan\AppData\Local\Temp\DBTmp74801984426 - Ok
C:\Users\Jan\AppData\Local\Temp\HPSAActionItems.xml - Ok
C:\Users\Jan\AppData\Local\Temp\wmplog00.sqm - Ok
C:\Users\Jan\AppData\Local\Temp\zoek-results.txt - Ok
C:\Users\Jan\AppData\Local\Temp\wmplog01.sqm - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\18r9txnt - Ok
C:\Users\Jan\AppData\Local\Temp\StructuredQuery.log - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\19geal5i - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\0lch1w3x - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\1itlhcio - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\1mlq3a6m - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\10alna6x - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\17497lq5 - Ok
C:\Users\Jan\AppData\Local\Temp\wmplog02.sqm - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\2htclfyx - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\2ls4jox3 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\1m2ssboz - Ok
C:\Users\Jan\AppData\Local\Temp\swtag.log - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\2pbls1lh - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\2bt1qxns - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\2u9e0uv5 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\2rsa25qx - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\3aq9o98s - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\3hab60y9 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\3vklbjkz - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\31hd3u9y - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\3swz6dzf - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\44advobu - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\47mj5ezr - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\3xgsw7rr - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\48jhiui3 - Ok
C:\Users\Jan\AppData\Local\Temp\PDApp.log - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\4wt8e2u2 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\4nxhsepv - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\551w7aah - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\59bqq06a - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\5401f5b2 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\4mtz3rb6 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\6o2dodve - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\78qfaurd - Ok
C:\Users\Jan\Documents\Adobe\Premiere Pro\5.0\Layouts\UserWorkspace3.xml - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\6e2qbftp - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\7devl6to - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\89bp5ogl - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\6zqxovs3 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\5eumhj1i - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\8mn8obww - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\96yohfv6 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\8gwa3lss - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\9bew6ay2 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ahl84mdx - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\aj7hnyq4 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\85pp2jme - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\alht7v5t - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\au9qthrd - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\bqmvflwd - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\b5rnrgrf - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\79lxjcki - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\bs9qh98d - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\7hlsbs2r - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\du2sdowj - Ok
>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm is CHM container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\dyf5y1xk - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\dwq2uamx - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\au16j9z2 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\eud3g03p - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\e7c499cx - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\es39ot1j - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ccbz0qxq - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\fouy57ig - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\f4geycli - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\f15bfkpf - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\gkqhcic9 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ft2kft7r - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\g398s016 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\g93rg8jc - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\euknowxg - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\gia9f7yc - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\g3n3yxqo - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\h3w8p2k1 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\gmzmdfka - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\hxrwx872 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\h94i1x1z - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\iwppk6g1 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\j55rzecm - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ic3pjl29 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\i7mis6nw - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\j8jfzfff - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\j81x2b97 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\jlvu2vjd - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\jn3eu9b9 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\k4bzbsif - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\jqhhpyyw - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\kf8758hl - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\kfxb9b1h - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\khvl4vct - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\kme42i93 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\kozaxv8o - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\lkmbhsep - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\l3xs27l0 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\lvmq4vjx - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\m6dg9zlu - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\mgqv6uvk - Ok
>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm is CHM container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\mmkypvyt - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\n1eyhu7o - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\nkwsmg0n - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\nod71e50 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\nsx85e16 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\o0ji0p0n - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\kzd896ys - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ogde4qqc - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\okhukz8m - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\oqwg4a9e - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\cureit70_en_popup_text.js is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\amt3.log - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\n8jji65i - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\psk1w021 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\pjbog3x9 - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_additionaloptions.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\of9w67qd - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_cli_parameters.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\q8ghzxp8 - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_cli_switches.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\r1ehovtp - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\r7f48618 - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_customscan.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_detectionmethods.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\cureit70_ja_popup_html.js is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_enfmode.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\mpchg1uj.exe - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_intro.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\rnbla4fw - Ok
>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ru.chm is CHM container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_legal.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_additionaloptions.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_quarantine.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\r2fnnj0c - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_cli_parameters.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\skpuw5v3 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\sty3t19f - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_quickscan.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_cli_switches.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\t06l261g - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_quickstart.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ozaf29oh - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\t1vi7kde - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_customscan.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\t56r391k - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_scan_set_1.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\t9e3aeb2 - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_detectionmethods.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\r0ixweti - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\tr5kqyd3 - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_scan_set_2.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\u2ui1xpe - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_enfmode.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ulf5ou8d - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\unc9f11j - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_intro.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_scan_set_3.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\v221tfhj - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_legal.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_scan_set_4.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_quarantine.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_scan_settings.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_setneutrules.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\v4j5eze1 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\tm4wdx0m - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_quickscan.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\rhrbiv6y - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_snip_scan_1.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\vcsqb3g1 - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ru.chm\cureit70_popup_text.js is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\vujqj4y2 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\vjkowfvd - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_statistics.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_quickstart.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\wfmiwzyh - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\wnwknlqw - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_sysreq.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\weptlclg - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_scan_set_1.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_techsupport.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\wp2c33bo - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_scan_set_2.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_testing.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\wzhuti7z - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_scan_set_3.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\dw_update.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ru.chm\dw_cli_switches.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_scan_set_4.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ws6um9bf - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm\helpman_topicinit.js is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_scan_settings.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_setneutrules.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_snip_scan_1.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\xrhqvwnc - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_statistics.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_sysreq.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\xnqdyc58 - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_techsupport.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\p3uy74tu - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_testing.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\uu5jqjkc - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\y7xw1ra8 - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ru.chm\dw_quickstart.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ygux6bbh - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\dw_update.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\z0v86t1d - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\zarjs90i.key - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\en.chm - container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ru.chm\dw_scan_set_2.htm is JS-HTML container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm\helpman_topicinit.js is JS-HTML container
>C:\Users\Jan\AppData\Local\Temp\CR_5CA3E.tmp\SETUP_PATCH.PACKED.7Z is 7-ZIP archive
C:\Users\Jan\AppData\Local\Temp\CR_5CA3E.tmp\SETUP_PATCH.PACKED.7Z - Ok
C:\Users\Jan\AppData\Local\Temp\CR_5CA3E.tmp\SETUP_PATCH.PACKED.7Z - archive
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ru.chm\dw_scan_set_3.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\HP Support Framework\HPSF_Config1.dll - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\xtpeoy13 - Ok
>C:\Users\Jan\AppData\Local\Temp\TCD8398.tmp\ThemePictureAlternatingAccent.glox is ZIP archive
C:\Users\Jan\AppData\Local\Temp\TCD8398.tmp\ThemePictureAlternatingAccent.glox - Ok
C:\Users\Jan\AppData\Local\Temp\TCD8398.tmp\ThemePictureAlternatingAccent.glox - archive
>C:\Users\Jan\AppData\Local\Temp\TCD8399.tmp\ThemePictureGrid.glox is ZIP archive
C:\Users\Jan\AppData\Local\Temp\TCD8399.tmp\ThemePictureGrid.glox - Ok
C:\Users\Jan\AppData\Local\Temp\TCD8399.tmp\ThemePictureGrid.glox - archive
C:\Users\Jan\AppData\Local\Temp\msohtmlclip1\01\clip_colorschememapping.xml - Ok
C:\Users\Jan\AppData\Local\Temp\Low\JavaDeployReg.log - Ok
>C:\Users\Jan\AppData\Local\Temp\msohtmlclip1\01\clip_themedata.thmx is ZIP archive
C:\Users\Jan\AppData\Local\Temp\msohtmlclip1\01\clip_themedata.thmx - Ok
C:\Users\Jan\AppData\Local\Temp\msohtmlclip1\01\clip_themedata.thmx - archive
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\yr4auuxs - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\yr5surx8 - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ja.chm - container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ru.chm\dw_testing.htm is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\znt3e8ol - Ok
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ru.chm\helpman_topicinit.js is JS-HTML container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\ru.chm - container
>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\9ucvgoxp.dll is BINARYRES container
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\9ucvgoxp.dll\data003 - packed by BINARYRES
>>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\9ucvgoxp.dll\data004 - packed by BINARYRES
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\9ucvgoxp.dll - container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\m01cbbgb.exe - Ok
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\xy949bb4.dll - Ok
>C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\i4yqhvm6.exe is BINARYRES container
C:\Users\Jan\AppData\Local\Temp\29A853E8-ED91999A-EF968FBA-F9FE4DB8\i4yqhvm6.exe - container
C:\Users\Jan\Documents\Youcam\WebcamDiskMemory.tmp - Ok
Total 46031718799 bytes in 23096 files scanned (24683 objects)
Total 23058 files (24640 objects) are clean
Total 1 file are suspicious
Total 39 files are raised error condition
Scan time is 00:07:59.291
Start curing
C:\Windows\system32\drivers\etc\hosts - cured, reboot required
Total 1 file are neutralized
