autoclean;
  • Reset Hosts
  • Post nu de inhoud van het geopende logje in het volgende bericht.
Zoek.exe Version 4.0.0.5 Updated 30-November-2013
Tool run by willy on di 03/12/2013 at 17:33:51.19.
Microsoft Windows 7 Home Premium 6.1.7601 Service Pack 1 x64
Launched: F:\Docuwilly\Acer\probleem dec\zoek.exe [script inserted] [Checkboxes used]
==== Older Logs ======================
C:\zoek-results2013-12-03-090618.log 45121 bytes
==== Reset Hosts File ======================
# Copyright © 1993-2006 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
# localhost name resolution is handle within DNS itself.
127.0.0.1 localhost
::1 localhost
==== FireFox Fix ======================
ProfilePath: C:\Users\willy\AppData\Roaming\Mozilla\Firefox\Profiles\f6fjst1m.default
---- Lines browser.startup.page removed from prefs.js ----
user_pref("browser.startup.page", 3);
---- FireFox user.js and prefs.js backups ----
user_20130312_1740_.backup
prefs_20130312_1740_.backup
C:\ProgramData\{3C5CBD7B-3D1D-411E-96C2-513FFCA84D2D} deleted
==== Firefox Extensions Registry ======================
[HKEY_LOCAL_MACHINE\Software\Wow6432Node\Mozilla\Firefox\Extensions]
"wrc@avast.com"="C:\Program Files\AVAST Software\Avast\WebRep\FF" [03/12/2013 09:26]
==== Firefox Extensions ======================
- Free Download Manager plugin - C:\ProgramData\Free Download Manager\Firefox\Extensions\1.6.0
- avast Online Security - C:\Program Files\AVAST Software\Avast\WebRep\FF
- Undetermined - C:\Program Files (x86)\IObit Apps Toolbar\FF
- Free Download Manager plugin - %ProfilePath%\extensions\fdm_ffext@freedownloadmanager.org
- Advanced SystemCare Surfing Protection - %ProfilePath%\extensions\ascsurfingprotection@iobit.com
- British English Dictionary - %ProfilePath%\extensions\en-GB@dictionaries.addons.mozilla.org
- nzbdStatus - %ProfilePath%\extensions\sabnzbdstatus@dq5studios.com.xpi
AppDir: C:\Program Files (x86)\Mozilla Firefox
- Belgium eID - %AppDir%\extensions\belgiumeid@eid.belgium.be
- Default - %AppDir%\browser\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd}
==== Firefox Plugins ======================
Profilepath: C:\Users\willy\AppData\Roaming\Mozilla\Firefox\Profiles\f6fjst1m.default
4BF70B35B943BD73BD6E13EB7C1BA4B3 - C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_9_900_117.dll - Shockwave Flash
==== Chrome Look ======================
nfengeggddojhakldhlpjdlddgkkjkdd - C:\Program Files (x86)\IObit\Surfing Protection\BrowerProtect\ASC_GhromePlugin.crx[12/10/2013 13:04]
Advanced SystemCare Surfing Protection - willy - Default\Extensions\nfengeggddojhakldhlpjdlddgkkjkdd
Old Values:
"Start Page"="http://www.google.com/"
New Values:
"DefaultScope"="{6A1806CD-94D4-4689-BA73-E35EA1EA9990}"
{0633EE93-D776-472f-A0FF-E1416B8B2E3A} Bing Url="http://www.bing.com/search?q={searchTerms}&src=IE-SearchBox&FORM=IE8SRC"
{6A1806CD-94D4-4689-BA73-E35EA1EA9990} Google Url="http://www.google.com/search?q={searchTerms}&rls=com.microsoft:{language}&ie={inputEncoding}&oe={outputEncoding}&startIndex={startIndex?}&startPage={startPage}"
C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5 emptied successfully
C:\Users\willy\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5 emptied successfully
C:\Users\willy\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\Content.IE5 emptied successfully
C:\Windows\SysNative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5 emptied successfully
C:\Windows\sysWoW64\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5 emptied successfully
C:\Windows\serviceprofiles\networkservice\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5 emptied successfully
C:\Windows\serviceprofiles\Localservice\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5 emptied successfully
C:\Windows\sysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5 emptied successfully
C:\Users\willy\AppData\Local\Mozilla\Firefox\Profiles\f6fjst1m.default\Cache emptied successfully
C:\Users\willy\AppData\Local\Google\Chrome\User Data\Default\Cache emptied successfully
C:\Users\willy\AppData\Local\Temp successfully emptied
==== EOF on di 03/12/2013 at 17:45:17.00 ======================
Mensen, juicht: Iobit is weer bereikbaar. Het zou me wel benieuwen wat er fout was gelopen, zodat ik u met dit probleem niet meer onnodig hoef lastig te vallen. Alvast heel hartelijk dank voor uw hulp en expertise!
Naar alle waarschijnlijkheid zat IOBit bij de "dubieuze" websites in je HOSTS-bestand. Door het herstellen van het standaardbestand, zou deze blokkering opgeheven zijn.
Nu mag je nog de gebruikte tools en de restjes van die besmetting opruimen:
  • Remove disinfection tools
  • Purge System Restore
  • Reset system settings
Klik in de linkse kolom op “Cleaner”. Klik achtereenvolgens op ‘Analyseren’ en na de analyse op 'Schoonmaken'. Klik vervolgens in de linkse kolom op “Register” en klik op ‘Scan naar problemen”. Als er fouten gevonden worden klik je op ”Herstel geselecteerde problemen” en ”OK”. Dan krijg je de vraag om een back-up te maken. Klik op “JA”. Kies dan “Herstel alle geselecteerde fouten”.
