Zoek.exe v5.0.0.0 Updated 28-December-2013
Tool run by Peter on ma 30-12-2013 at 21:46:45,50.
Microsoft Windows 7 Home Premium 6.1.7601 Service Pack 1 x86
Launched: C:\Users\Peter\AppData\Local\Temp\wz954c\zoek.exe [scan all users] [script inserted] [Checkboxes used]
==== System Restore Info ======================
30-12-2013 21:48:53 Zoek.exe System Restore Point Created Succesfully.
==== Reset Hosts File ======================
# Copyright © 1993-2006 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
# localhost name resolution is handle within DNS itself.
127.0.0.1 localhost
::1 localhost
==== Empty Folders Check ======================
C:\Program Files\Lavasoft deleted successfully
C:\Program Files\Common Files\PDF Architect deleted successfully
C:\ProgramData\Media Get LLC deleted successfully
C:\Users\Peter\AppData\Roaming\McAFee TechCheck deleted successfully
C:\Users\Peter\AppData\Roaming\SibCode deleted successfully
C:\Users\Peter\AppData\Local\WMTools Downloaded Files deleted successfully
==== FireFox Fix ======================
ProfilePath: C:\Users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default
user.js not found
---- Lines securedsearch removed from prefs.js ----
user_pref("keyword.URL", "- Lavasoft Secure Search Yahoo-Zoekresultaten="
---- FireFox user.js and prefs.js backups ----
prefs_30-12-2013_2157_.backup
==== Registry Fix Code ======================
Windows Registry Editor Version 5.00
[-HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\mobilegeni daemon]
[-HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Search Protection]
C:\Program Files\Mobogenie not found
C:\ProgramData\Search Protection not found
C:\Program Files\SecretSauce deleted
C:\!KillBox deleted
C:\ProgramData\{01BD4FC9-2F86-4706-A62E-774BB7E9D308} deleted
C:\Users\Peter\AppData\Local\genienext deleted
C:\Users\Peter\daemonprocess.txt deleted
C:\Users\Peter\.android deleted
C:\Program Files\ParetoLogic deleted
C:\Program Files\Common Files\ParetoLogic deleted
C:\Program Files\File Type Assistant deleted
C:\Users\Peter\AppData\Roaming\newnext.me deleted
C:\Users\Peter\AppData\Roaming\SecureSearch deleted
C:\Users\Peter\AppData\Roaming\ParetoLogic deleted
C:\Users\Peter\AppData\Roaming\DriverCure deleted
C:\ProgramData\whlb32g.dll deleted
C:\ProgramData\ParetoLogic deleted
C:\Users\Peter\AppData\Local\FileTypeAssistant deleted
C:\Users\Peter\AppData\Local\Programs deleted
C:\Users\Peter\AppData\Local\cache deleted
C:\Windows\system32\config\systemprofile\AppData\Local\FileTypeAssistant deleted
C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\ParetoLogic deleted
C:\Windows\tasks\ParetoLogic Registration3.job deleted
C:\Windows\tasks\ParetoLogic Update Version3 Startup Task.job deleted
C:\Windows\tasks\ParetoLogic Update Version3.job deleted
C:\Users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\firefox@secretsauce.biz.xpi deleted
"C:\Users\Peter\AppData\Roaming\Ditto\Ditto.db" not deleted
"C:\Users\Peter\AppData\Roaming\Ditto" not deleted
==== Files Recently Created / Modified ======================
====== C:\Windows ====
2013-12-28 20:24:07 84B4F61F59A421BD85D97B35D194B42B 86016 ----a-w- C:\Windows\unvise32.exe
2013-12-28 17:33:17 4D5FD79A075B9BD9ACEFD6FAA753318A 43152 ----a-w- C:\Windows\avastSS.scr
2013-12-28 03:17:47 01F88BD2623CCC352C4D0D89547B621F 268 ----a-w- C:\Windows\_delis32.ini
2013-12-28 03:17:42 2301304260456CAB0F9BF2083F6ADB56 327168 ----a-w- C:\Windows\IsUn0413.exe
2013-12-28 00:21:22 3D2141C11318F9DF5F68A5255B436217 740 ----a-w- C:\Windows\ODBC.INI
2013-12-27 21:12:04 D1E75542EC8D1B4851765A57AC63618E 1908 ----a-w- C:\Windows\diagerr.xml
2013-12-27 21:12:04 9BDF2180B28AC3E913446AAA557CF29F 2560 ----a-w- C:\Windows\diagwrn.xml
====== C:\Users\Peter\AppData\Local\Temp ====
2013-12-30 20:06:43 B4FEC4E889C49693E5A1568E021C2E11 3080088 ----a-w- C:\Users\Peter\AppData\Local\Temp\Update.exe
====== Java Cache =====
2013-12-28 11:13:35 C1BBA7F1278F193AB584FFF460DB5E2A 17878 ----a-w- C:\Users\Peter\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\12\eef218c-18e310e7
2013-12-28 11:13:25 415FC9732A3F4D89A0E01251CD66E136 646 ----a-w- C:\Users\Peter\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\17\49a00451-262342c9
2013-12-28 11:13:23 415FC9732A3F4D89A0E01251CD66E136 646 ----a-w- C:\Users\Peter\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\31\34e05d1f-7d9dce5d
2013-12-28 11:13:25 34FA8033B50A3F99D3AB8209C72C0ABA 6860 ----a-w- C:\Users\Peter\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\43\1ca2666b-311d84b2
2013-12-28 09:26:02 D41D8CD98F00B204E9800998ECF8427E 0 ----a-w- C:\Users\Peter\AppData\LocalLow\Sun\Java\Deployment\SystemCache\6.0\32\6c34baa0-388de102
====== C:\Windows\system32 =====
2013-12-29 18:38:50 18C48414627F5F1C57A8C7CA815E75BD 12288 ----a-w- C:\Windows\System32\TsUsbRedirectionGroupPolicyControl.exe
2013-12-29 18:38:49 D3A08BA0A5C9CA61A10A8EB81C176692 13312 ----a-w- C:\Windows\System32\TsUsbRedirectionGroupPolicyExtension.dll
2013-12-29 18:38:49 A86F5616EACB7155998011CEFFFB52F6 12800 ----a-w- C:\Windows\System32\RdpGroupPolicyExtension.dll
2013-12-29 18:38:48 E6446AB7A7E602CAFF51ACA3C68C1526 269312 ----a-w- C:\Windows\System32\aaclient.dll
2013-12-29 18:38:48 D3F64318307CEC05CBDE533D99976532 16896 ----a-w- C:\Windows\System32\wksprtPS.dll
2013-12-29 18:38:48 A9D4140B8B843D5719F7C3EED8C0F9FD 37376 ----a-w- C:\Windows\System32\tsgqec.dll
2013-12-29 18:38:48 3F853160DEE5B71B9AD2F1BAF2B1E55B 46592 ----a-w- C:\Windows\System32\MsRdpWebAccess.dll
2013-12-29 18:38:48 3228AB5F8652EAABFF3C5FC7FD0F603A 221184 ----a-w- C:\Windows\System32\rdpudd.dll
2013-12-29 18:38:48 321BE3A2C87206B0C85ECD4FA4EBBF54 56320 ----a-w- C:\Windows\System32\TSWbPrxy.exe
2013-12-29 18:38:48 235B7E30D5B48A3B769C00DA166F080B 32768 ----a-w- C:\Windows\System32\TsUsbGDCoInstaller.dll
2013-12-29 18:38:47 C551B35F71CA76C88112966238821105 317440 ----a-w- C:\Windows\System32\wksprt.exe
2013-12-29 18:38:47 AC3598BD1101BBC4365994BAB093BB62 2739712 ----a-w- C:\Windows\System32\rdpcorets.dll
2013-12-29 18:38:47 8999F18D38D55E34D356796507FFD639 192000 ----a-w- C:\Windows\System32\rdpendp_winip.dll
2013-12-29 18:38:47 40FF6C636380A87DE3A99F4E348BFDCB 1048064 ----a-w- C:\Windows\System32\mstsc.exe
2013-12-29 18:38:46 EF1689081813A60D4610FF429530BA36 4916224 ----a-w- C:\Windows\System32\mstscax.dll
2013-12-29 18:20:07 1B24EC543ADEA0AFB520B4F104134CBB 1002008 ----a-w- C:\Windows\System32\igxpun.exe
2013-12-29 17:50:10 98CEBCE699DB75E8CBEEF26BFDD86E97 88123800 ----a-w- C:\Windows\System32\MRT.exe
2013-12-29 17:48:51 FE47B7BC8EA320C2D9B5E5BF6E303765 73216 ----a-w- C:\Windows\System32\WUDFSvc.dll
2013-12-29 17:48:51 D689B2C2E69156D954C24810F4081C1E 38912 ----a-w- C:\Windows\System32\WUDFCoinstaller.dll
2013-12-29 17:48:51 D5CF1536137026ACDED95BF6CBF849F6 172032 ----a-w- C:\Windows\System32\WUDFPlatform.dll
2013-12-29 17:48:51 980B6A5F92B8DB235C4A26728C2BE732 196608 ----a-w- C:\Windows\System32\WUDFHost.exe
2013-12-29 17:48:50 A36F7A256E65D858A7039DB00ADEEBDD 613888 ----a-w- C:\Windows\System32\WUDFx.dll
2013-12-29 17:48:09 907281ED4AD35D41B29FFDC211EBAD80 5120 ----a-w- C:\Windows\System32\wmi.dll
2013-12-29 17:47:03 DA1919D896DBD5895E138932AE9E398B 293376 ----a-w- C:\Windows\System32\browserchoice.exe
2013-12-29 17:36:27 6C4B2E1A25841077084EB9F76FF6FFA7 11410432 ----a-w- C:\Windows\System32\wmp.dll
2013-12-29 17:36:26 02DF0628BE8B64B84D50FBE53549AA3B 12625408 ----a-w- C:\Windows\System32\wmploc.DLL
2013-12-29 17:34:11 8B285BDAB7735FDFB18E6F7122923B77 187392 ----a-w- C:\Windows\System32\UIAnimation.dll
2013-12-29 17:34:08 545F1BAAADD0BF1F4FE4586293FCA07D 417792 ----a-w- C:\Windows\System32\WMPhoto.dll
2013-12-29 17:34:07 C7A730AFB80B11F93EFC81B1D6F920D7 364544 ----a-w- C:\Windows\System32\XpsGdiConverter.dll
2013-12-29 17:34:07 B3170CCC779B682C3341873EA60CF084 1988096 ----a-w- C:\Windows\System32\d3d10warp.dll
2013-12-29 17:34:07 6A13B4F3B3F575F1E24B877B9359AABA 10752 ---ha-w- C:\Windows\System32\api-ms-win-downlevel-advapi32-l1-1-0.dll
2013-12-29 17:34:07 6951562DC4625EEFC6EACD52AD165866 9728 ---ha-w- C:\Windows\System32\api-ms-win-downlevel-shlwapi-l1-1-0.dll
2013-12-29 17:34:07 60F4AEFA103D421EA4A40E31409B4756 3072 ---ha-w- C:\Windows\System32\api-ms-win-downlevel-shell32-l1-1-0.dll
2013-12-29 17:34:07 589CBC4989F750E1DA35625AB481CF43 4096 ---ha-w- C:\Windows\System32\api-ms-win-downlevel-user32-l1-1-0.dll
2013-12-29 17:34:07 49ACA548B2423F1C67898E6AC719A9A6 3584 ---ha-w- C:\Windows\System32\api-ms-win-downlevel-advapi32-l2-1-0.dll
2013-12-29 17:34:07 3BE0D923AA45A4DBE091C2D84F0B4FE7 3072 ---ha-w- C:\Windows\System32\api-ms-win-downlevel-version-l1-1-0.dll
2013-12-29 17:34:07 2E33DFD10F28F86C3FC40EE123CC3904 2560 ---ha-w- C:\Windows\System32\api-ms-win-downlevel-normaliz-l1-1-0.dll
2013-12-29 17:34:07 1C60E09CA1C3A045BC4D367F67C915B7 5632 ---ha-w- C:\Windows\System32\api-ms-win-downlevel-ole32-l1-1-0.dll
2013-12-29 17:34:07 007863E45F25AA47A4C30D0930BBFD85 5632 ---ha-w- C:\Windows\System32\api-ms-win-downlevel-shlwapi-l2-1-0.dll
2013-12-29 17:34:06 FB3F036EF6A467F7AF46C821FF5D198D 220160 ----a-w- C:\Windows\System32\d3d10core.dll
2013-12-29 17:34:06 E12C4928B32ACE04610259647F072635 906240 ----a-w- C:\Windows\System32\FntCache.dll
2013-12-29 17:34:06 D4F264FE23F8953D840904418220C15E 293376 ----a-w- C:\Windows\System32\dxgi.dll
2013-12-29 17:34:06 D4212AB475A3B25EC4DF574536C3EDC5 249856 ----a-w- C:\Windows\System32\d3d10_1core.dll
2013-12-29 17:34:06 8504944851DF6175CC489A8F3328459E 1080832 ----a-w- C:\Windows\System32\d3d10.dll
2013-12-29 17:34:06 6A7B5A3EFCCDB53DA41CF6838056990F 1158144 ----a-w- C:\Windows\System32\XpsPrint.dll
2013-12-29 17:34:06 600A65F922CCDCBB2D11467914241556 2284544 ----a-w- C:\Windows\System32\msmpeg2vdec.dll
2013-12-29 17:34:06 4FF3EC04CD47DD62181894B71B004E40 604160 ----a-w- C:\Windows\System32\d3d10level9.dll
2013-12-29 17:34:06 3C1936A12C62254F914A01BBC6A8DC69 161792 ----a-w- C:\Windows\System32\d3d10_1.dll
2013-12-29 17:34:05 9FF8F684BACF326082E5562F7C104A79 3419136 ----a-w- C:\Windows\System32\d2d1.dll
2013-12-29 17:34:05 62A6EB5771580CAE445804389F3F7432 207872 ----a-w- C:\Windows\System32\WindowsCodecsExt.dll
2013-12-29 17:34:05 4277F5164DE9B7C665BB928B9145BEE0 1247744 ----a-w- C:\Windows\System32\DWrite.dll
2013-12-29 17:34:05 3BCECD87AB4E6743BFB45B352AD1A529 1230336 ----a-w- C:\Windows\System32\WindowsCodecs.dll
2013-12-29 17:25:12 FC415B303B1ECF80B5F130A1F7203D02 492544 ----a-w- C:\Windows\System32\win32spl.dll
2013-12-29 17:25:08 1153AC6E133AA849853DFD407B086B80 420064 ----a-w- C:\Windows\System32\locale.nls
2013-12-29 17:24:59 A6C29DB53ECA94FA8591C5388D604B82 2342400 ----a-w- C:\Windows\System32\msi.dll
2013-12-29 17:24:49 465DBF63A5049E4DB4BC5C12FFE781CB 1549312 ----a-w- C:\Windows\System32\tquery.dll
2013-12-29 17:24:49 0241CB16136B9A4939CA0395768AE286 1401344 ----a-w- C:\Windows\System32\mssrch.dll
2013-12-29 17:24:48 E1AC89F6C5252057E6062843E36A6701 164352 ----a-w- C:\Windows\System32\SearchProtocolHost.exe
2013-12-29 17:24:48 DB67C7C62038BDE813CB6486581A7611 337408 ----a-w- C:\Windows\System32\mssph.dll
2013-12-29 17:24:48 A6CD6B3F71E13E2E45B727FB8A47EA87 86528 ----a-w- C:\Windows\System32\SearchFilterHost.exe
2013-12-29 17:24:48 987323F0247D023AD1AE52195540ECE0 666624 ----a-w- C:\Windows\System32\mssvp.dll
2013-12-29 17:24:48 5BDF8B0B9A3EADE3A2A6F2ED8D44E36D 197120 ----a-w- C:\Windows\System32\mssphtb.dll
2013-12-29 17:24:48 2DC6285EC4F902BE08E7C5FA6D3FD017 59392 ----a-w- C:\Windows\System32\msscntrs.dll
2013-12-29 17:24:48 236F286E103FD44BD85FDD93097FD5DD 427520 ----a-w- C:\Windows\System32\SearchIndexer.exe
2013-12-29 17:24:47 6DE66FE7C526637E74CD066461C7C871 1505280 ----a-w- C:\Windows\System32\d3d11.dll
2013-12-29 17:24:46 786B9C958A4F217322C24C736263C51F 245760 ----a-w- C:\Windows\System32\OxpsConverter.exe
2013-12-29 17:24:44 33B26FA5DBEB69FFAB703EDCB4E6DE4A 514560 ----a-w- C:\Windows\System32\qdvd.dll
2013-12-29 17:24:42 58F67245D041FBE7AF88F4EAF79DF0FA 499712 ----a-w- C:\Windows\System32\iphlpsvc.dll
2013-12-29 17:24:42 5078492B9CAC9CB721698DB51F039035 175104 ----a-w- C:\Windows\System32\netcorehc.dll
2013-12-29 17:24:42 374071043F9E4231EE43BE2BB48DD36D 242176 ----a-w- C:\Windows\System32\nlasvc.dll
2013-12-29 17:24:42 140D9F911182357626165EA0BEB98C4F 156672 ----a-w- C:\Windows\System32\ncsi.dll
2013-12-29 17:24:41 50E0DD0A5B8D8BC353578F2F73926697 52224 ----a-w- C:\Windows\System32\nlaapi.dll
2013-12-29 17:24:41 23FC8068953C9BE2D63AE4EF1129112A 18944 ----a-w- C:\Windows\System32\netevent.dll
2013-12-29 17:24:34 E0B8C6B1EA1EF94747E966E9093FB968 1289096 ----a-w- C:\Windows\System32\ntdll.dll
2013-12-29 17:24:34 DE91DCC7BC55E940979097E98F743205 69632 ----a-w- C:\Windows\System32\smss.exe
2013-12-29 17:24:34 D67472125471784DE7147946EDA25FEB 640512 ----a-w- C:\Windows\System32\advapi32.dll
2013-12-29 17:24:34 813A7F5A2D6D366EB3FFB643B851BCE5 3914176 ----a-w- C:\Windows\System32\ntoskrnl.exe
2013-12-29 17:24:34 482C8CD985C727C7C78A5E9B320947F0 3969472 ----a-w- C:\Windows\System32\ntkrnlpa.exe
2013-12-29 17:24:34 401D25136E26B237D77DA1BF1198B3BD 619520 ----a-w- C:\Windows\System32\tdh.dll
2013-12-29 17:24:34 23AB7E36551C6BA5370EF7F05142F0EB 38912 ----a-w- C:\Windows\System32\csrsrv.dll
2013-12-29 17:24:33 E94C583CDE2348950155F2AF2876F34D 231424 ----a-w- C:\Windows\System32\mswsock.dll
2013-12-29 17:24:31 E2ED66FAF894F545EB083AC5F5763854 434688 ----a-w- C:\Windows\System32\scavengeui.dll
2013-12-29 17:24:27 45FBAFFA68CBC29AC2563985CEE72B9C 24576 ----a-w- C:\Windows\System32\cryptdlg.dll
2013-12-29 17:24:22 EE7CB55F77465CDAC4C80F587FF7C278 1796096 ----a-w- C:\Windows\System32\authui.dll
2013-12-29 17:24:21 E9BB0CD09DA17C71FD1B9954D75AEEF7 168960 ----a-w- C:\Windows\System32\credui.dll
2013-12-29 17:24:21 4BCC63ED1C3D15B2635A8AE2B854B3EB 152576 ----a-w- C:\Windows\System32\SmartcardCredentialProvider.dll
2013-12-29 17:24:15 866004E949EB3D02C3CAE0A553231A3A 400896 ----a-w- C:\Windows\System32\srcore.dll
2013-12-29 17:24:14 7E9917D5309A90E7576653BFE39F80D8 478720 ----a-w- C:\Windows\System32\timedate.cpl
2013-12-29 17:24:14 5D1BFF0FCE80F9E2E539F436710D4A79 31232 ----a-w- C:\Windows\System32\prevhost.exe
2013-12-29 17:24:13 B7230010D97787AF3D25E4C82F2B06B9 626688 ----a-w- C:\Windows\System32\usp10.dll
2013-12-29 17:24:10 EDF2A5E96BEC469DA3F64E9BDD386111 180224 ----a-w- C:\Windows\System32\xmllite.dll
2013-12-29 17:24:10 DA8AAF7E56F698608A89542131F74818 40960 ----a-w- C:\Windows\System32\wwanprotdim.dll
2013-12-29 17:24:10 3C5E51C05BE9B56EAFF4E388C3AB25E4 186368 ----a-w- C:\Windows\System32\wwansvc.dll
2013-12-29 17:24:09 AFA53BD631FB0509A91A99391209BB70 301568 ----a-w- C:\Windows\System32\msieftp.dll
2013-12-29 17:23:59 ED59143843560B5EDB543C2A48CB9E4B 45568 ----a-w- C:\Windows\System32\oflc-nz.rs
2013-12-29 17:23:59 A704E750245D5D4EE4A23E99A00F27D5 46592 ----a-w- C:\Windows\System32\fpb.rs
2013-12-29 17:23:59 A067A19A91C2AA0198F9BD01A5CEF5C6 21504 ----a-w- C:\Windows\System32\grb.rs
2013-12-29 17:23:59 9EDCFA23CC081E38C86CA309D0F7E3DC 30720 ----a-w- C:\Windows\System32\usk.rs
2013-12-29 17:23:59 9B7D7F4D1F79E8B7D727BE94B1630D59 44544 ----a-w- C:\Windows\System32\pegibbfc.rs
2013-12-29 17:23:59 6EC618588447B82EA8D88719EE46F725 43520 ----a-w- C:\Windows\System32\csrr.rs
2013-12-29 17:23:59 64E211E0FDFCE4D186DF58BB7D0503BC 2576384 ----a-w- C:\Windows\System32\gameux.dll
2013-12-29 17:23:59 5109C45498BC709C8A7E016D5FFCCAC2 20480 ----a-w- C:\Windows\System32\pegi.rs
2013-12-29 17:23:59 4F5C56DBF076D5BBB1D22B37BF281396 20480 ----a-w- C:\Windows\System32\pegi-pt.rs
2013-12-29 17:23:59 41CE7975CAD7BCF92538D2C452239523 40960 ----a-w- C:\Windows\System32\cob-au.rs
2013-12-29 17:23:59 27828AAA24AA46F11036954ADE355C1C 15360 ----a-w- C:\Windows\System32\djctq.rs
2013-12-29 17:23:58 DDD1C4AB9A9DAE6D4092C4C95E714650 51712 ----a-w- C:\Windows\System32\esrb.rs
2013-12-29 17:23:58 CBC69A055EF410CBD65593E4808B6DB4 23552 ----a-w- C:\Windows\System32\oflc.rs
2013-12-29 17:23:58 7752619457598CF057C4CC02A0867029 55296 ----a-w- C:\Windows\System32\cero.rs
2013-12-29 17:23:58 72035C97983745E742D71E9A8EF70BBB 20480 ----a-w- C:\Windows\System32\pegi-fi.rs
2013-12-29 17:23:58 43C9CF6825CEA58F1815B7C3DBBB385C 308736 ----a-w- C:\Windows\System32\Wpc.dll
2013-12-29 17:23:50 CADEFAC453040E370A1BDFF3973BE00D 164352 ----a-w- C:\Windows\System32\profsvc.dll
2013-12-29 17:23:50 75E8EBD7040CE238684333F97014762A 205824 ----a-w- C:\Windows\System32\WebClnt.dll
2013-12-29 17:23:49 EAF4712B706936C0B10D3B5319B37E81 81920 ----a-w- C:\Windows\System32\davclnt.dll
2013-12-29 17:23:02 EF6950D7B24AAF4E477065F5455DD4F8 1038848 ----a-w- C:\Windows\System32\lsasrv.dll
2013-12-29 17:23:02 D89077E2E1C88A29C57F21FAD28DAC45 15872 ----a-w- C:\Windows\System32\sspisrv.dll
2013-12-29 17:23:02 BD6B9BC84D004C6BEE89CF7BDB95E1FC 99840 ----a-w- C:\Windows\System32\sspicli.dll
2013-12-29 17:23:02 AD7FB087A238883D1618F29F7BBBD584 220160 ----a-w- C:\Windows\System32\ncrypt.dll
2013-12-29 17:23:02 AA6F6457116B559B76BC6A012CB4C293 247808 ----a-w- C:\Windows\System32\schannel.dll
2013-12-29 17:23:02 803B370865D907EA21DC0C2B6A8936B5 22016 ----a-w- C:\Windows\System32\lsass.exe
2013-12-29 17:23:02 372948BB5E41CE42341C4398DE572E56 22016 ----a-w- C:\Windows\System32\secur32.dll
2013-12-29 17:22:45 68EAAEDF0365168B804E8728368FA946 175104 ----a-w- C:\Windows\System32\wintrust.dll
2013-12-29 17:22:40 3B7C1A53047FF6ACEFD9BA6E281DEBB7 805376 ----a-w- C:\Windows\System32\cdosys.dll
2013-12-29 17:21:59 0D52559AEF4AA5EAC82F530617032283 903168 ----a-w- C:\Windows\System32\certutil.exe
2013-12-29 17:21:58 CC917AC4D3F8756FF13174980B474791 43008 ----a-w- C:\Windows\System32\certenc.dll
2013-12-29 17:21:46 813845D5C5D8325CA5E8B1F547016378 534528 ----a-w- C:\Windows\System32\EncDec.dll
2013-12-29 17:21:44 68DCA1777D7224A79A9DC3D47BED6D32 75776 ----a-w- C:\Windows\System32\psisrndr.ax
2013-12-29 17:21:44 00ADF21DE55AA97297FAC65E4F3A0256 465408 ----a-w- C:\Windows\System32\psisdecd.dll
2013-12-29 17:21:28 EF71BA5DF59034962B0C62314A71351A 193536 ----a-w- C:\Windows\System32\dhcpcore6.dll
2013-12-29 17:21:28 81F6C1AE23B1C493D9E996C3103915D7 44032 ----a-w- C:\Windows\System32\dhcpcsvc6.dll
2013-12-29 17:21:23 4EC2C3B15B9EC41AD0D6CD918D20376E 2048 ----a-w- C:\Windows\System32\tzres.dll
2013-12-29 17:21:19 5A043BDA3BFADD5B4C16F3BDE5EC4312 652800 ----a-w- C:\Windows\System32\rpcrt4.dll
2013-12-29 17:21:18 92FB57D9D865019D26346EB13E15CD75 642048 ----a-w- C:\Windows\System32\CPFilters.dll
2013-12-29 17:21:18 4D05D7A79E970398D8C687712E65A9B0 850944 ----a-w- C:\Windows\System32\sbe.dll
2013-12-29 17:21:18 246560C5B7995489F25BF9175F2B6380 199680 ----a-w- C:\Windows\System32\mpg2splt.ax
2013-12-29 17:21:16 B40420876B9288E0A1C8CCA8A84E5DC9 270336 ----a-w- C:\Windows\System32\dnsapi.dll
2013-12-29 17:21:16 ACBC1FB1950AC0C41944A6C8917032EF 28672 ----a-w- C:\Windows\System32\dnscacheugc.exe
2013-12-29 17:21:16 33EF4861F19A0736B11314AAD9AE28D0 132608 ----a-w- C:\Windows\System32\dnsrslvr.dll
2013-12-29 17:21:15 E7B9D5FF20FFDD4AAE2EF1D1B8C27A37 159232 ----a-w- C:\Windows\System32\imagehlp.dll
2013-12-29 17:21:15 09F65975C1C9793B923BB52A7FA83453 121856 ----a-w- C:\Windows\System32\wshom.ocx
2013-12-29 17:21:14 A3B1D1312602280839A4A2AFBDFD066E 163840 ----a-w- C:\Windows\System32\scrrun.dll
2013-12-29 17:21:14 A3A35EE79C64A640152B3113E6E254E2 126976 ----a-w- C:\Windows\System32\cscript.exe
2013-12-29 17:21:14 979D74799EA6C8B8167869A68DF5204A 141824 ----a-w- C:\Windows\System32\wscript.exe
2013-12-29 17:21:14 8E01332CC4B68BC6B5B7EFFE374442AA 233472 ----a-w- C:\Windows\System32\oleacc.dll
2013-12-29 17:21:14 6C765E82B57F2E66CE9C54AC238471D9 571904 ----a-w- C:\Windows\System32\oleaut32.dll
2013-12-29 17:21:12 310F6F492A3B4B1020ED9BF9CCBBE6B6 376832 ----a-w- C:\Windows\System32\dpnet.dll
2013-12-29 17:21:11 72910F1DEB838E6E08A9017BFB7D4F0B 41984 ----a-w- C:\Windows\System32\browcli.dll
2013-12-29 17:21:11 3DAA727B5B0A45039B0E1C9A211B8400 102912 ----a-w- C:\Windows\System32\browser.dll
2013-12-29 17:21:11 2FCA0D2C59A855C54BAFA22AA329DF0F 57344 ----a-w- C:\Windows\System32\netapi32.dll
2013-12-29 17:21:09 EAADD6E47ED2A7003ACE1793B98CF63F 1389568 ----a-w- C:\Windows\System32\msxml6.dll
2013-12-29 17:21:08 7B90C5F0A510852036822EE860CABF26 67072 ----a-w- C:\Windows\System32\packager.dll
2013-12-29 17:21:05 7D27E63B54DB093BB0D9E95F81094D75 34304 ----a-w- C:\Windows\System32\atmlib.dll
2013-12-29 17:21:05 5C6B44F9CAAC475B7B9EBBC29CB7F065 295424 ----a-w- C:\Windows\System32\atmfd.dll
2013-12-29 17:21:04 F632602316001D517F4EF3B53B9A6C33 26112 ----a-w- C:\Windows\System32\lpk.dll
2013-12-29 17:21:04 8CC4638FA7B5B921B9080CF962582C0B 70656 ----a-w- C:\Windows\System32\fontsub.dll
2013-12-29 17:21:04 2342EC9254F4C60CA98441BD65C89E12 10240 ----a-w- C:\Windows\System32\dciman32.dll
2013-12-29 17:21:03 A45CB10FC8C4DCA23F96FE4D334F64FE 2048 ----a-w- C:\Windows\System32\msxml3r.dll
2013-12-29 17:21:03 1CDEA9188899E76D4FFD54C9D512CCDB 1236992 ----a-w- C:\Windows\System32\msxml3.dll
2013-12-29 17:21:02 0805487A6036A9F9C4E7AF7FEF835529 1620992 ----a-w- C:\Windows\System32\WMVDECOD.DLL
2013-12-29 17:21:00 03F3B770DFBED6131653CEDA8CA780F0 442880 ----a-w- C:\Windows\System32\ntshrui.dll
2013-12-29 17:20:58 EC7BC28D207DA09E79B3E9FAF8B232CA 293376 ----a-w- C:\Windows\System32\umpnpmgr.dll
2013-12-29 17:20:58 2A01B40C8334A8124001CFAC256FCA83 102608 ----a-w- C:\Windows\System32\PresentationCFFRasterizerNative_v0300.dll
2013-12-29 17:20:57 ED27D1D75BF5E683AD3EDD9E3123520A 741376 ----a-w- C:\Windows\System32\inetcomm.dll
2013-12-29 17:20:50 75F5E1FE8D55CF8E577E0EC5F2290D3F 530432 ----a-w- C:\Windows\System32\comctl32.dll
2013-12-29 17:20:48 8ACB33EF85F9EA87D18FECEAD593A255 2349056 ----a-w- C:\Windows\System32\win32k.sys
2013-12-29 17:20:48 674EB817CF6E43B7DF3EC26E06E98D98 509440 ----a-w- C:\Windows\System32\qedit.dll
2013-12-29 17:20:46 0AE0C4955E1DE29CCDC9DA1B816FE5EE 1328128 ----a-w- C:\Windows\System32\quartz.dll
2013-12-29 17:20:45 BDA0B954A30498B5A7EDC6204CBA07ED 542208 ----a-w- C:\Windows\System32\kerberos.dll
2013-12-29 17:20:44 C245EBD6B1A5FB6E6BBE2A635032490F 191488 ----a-w- C:\Windows\System32\FXSCOVER.exe
2013-12-29 17:07:35 E2D83DAA6A229CFDAF129189A9245889 86016 ----a-w- C:\Windows\System32\odbccu32.dll
2013-12-29 17:07:35 66ABBF38123D3113BB55EBAFCF37AB92 122880 ----a-w- C:\Windows\System32\odbccp32.dll
2013-12-29 17:07:35 534BF06B2DEE965A1389A9312545AE03 81920 ----a-w- C:\Windows\System32\odbccr32.dll
2013-12-29 17:07:35 3FDB77D0BBEEB36AE35077ABC0BF80EC 319488 ----a-w- C:\Windows\System32\odbcjt32.dll
2013-12-29 17:07:34 EF37EDC20412A01DDD9A42E8D939A5A3 163840 ----a-w- C:\Windows\System32\odbctrac.dll
2013-12-29 17:07:31 FB19FC5951A88F3C523E35C2C98D23C0 314880 ----a-w- C:\Windows\System32\webio.dll
2013-12-29 17:07:15 5A775CAE7CCCAC581C05B8D2C92C0DF1 305152 ----a-w- C:\Windows\System32\gdi32.dll
2013-12-29 17:07:14 74AF6AA2E8B3180AADAE5FE8813CB1CD 769024 ----a-w- C:\Windows\System32\localspl.dll
2013-12-29 17:07:08 D23E615E0969AECC1134E372B0B295D1 78336 ----a-w- C:\Windows\System32\synceng.dll
2013-12-29 17:07:07 9DC80A8AAAAAC397BDAB3C67165A824E 690688 ----a-w- C:\Windows\System32\msvcrt.dll
2013-12-29 17:07:03 E02781D4871844DCD30DF1D69A650F78 12872704 ----a-w- C:\Windows\System32\shell32.dll
2013-12-29 17:07:03 2C4A87CA8C00E98EFDCFA2E8EC9A3503 180224 ----a-w- C:\Windows\System32\shdocvw.dll
2013-12-29 17:06:54 A5661C9330E5FCFCDD53EB03D5F04822 8192 ----a-w- C:\Windows\System32\rdrmemptylst.exe
2013-12-29 17:06:54 954AAF2028CD907B7F7ED40FFFD9D27F 58880 ----a-w- C:\Windows\System32\rdpwsx.dll
2013-12-29 17:06:54 58D2343C32DF596FB6132B54395DE5DB 129536 ----a-w- C:\Windows\System32\rdpcorekmts.dll
2013-12-29 17:06:41 F0D0E883EBBDC7615DC9EDEA0FFB2817 216576 ----a-w- C:\Windows\System32\FWPUCLNT.DLL
2013-12-29 17:06:41 CE2A48CD0D2B39FB77FA4797C6434E71 656896 ----a-w- C:\Windows\System32\nshwfp.dll
2013-12-29 17:06:41 B9C54120F46392100478F58F374E5709 679424 ----a-w- C:\Windows\System32\IKEEXT.DLL
2013-12-29 17:06:11 B0BC447C758FF055D53FC6831FDB0344 101720 ----a-w- C:\Windows\System32\consent.exe
2013-12-29 17:06:10 EACFDF31921F51C097629F1F3C9129B4 47104 ----a-w- C:\Windows\System32\appinfo.dll
2013-12-29 17:06:01 DC6612A9EE015A36BA2A27BC9CC12537 1137664 ----a-w- C:\Windows\System32\mfc42.dll
2013-12-29 17:06:01 24CAEDCD73B5B0E22226283B7B2468C7 1164288 ----a-w- C:\Windows\System32\mfc42u.dll
2013-12-29 17:05:58 2F0BC1FC6142DCB31C7D9804962A7011 9728 ----a-w- C:\Windows\System32\Wdfres.dll
2013-12-29 17:05:54 CC09E0C9A2D89C6E71D093DC8BD121B7 1168384 ----a-w- C:\Windows\System32\crypt32.dll
2013-12-29 17:05:54 7CA1BECEA5DE2643ADDAD32670E7A4C9 140288 ----a-w- C:\Windows\System32\cryptsvc.dll
2013-12-29 17:05:54 7B851A8018B1EA00A69707A390004884 103936 ----a-w- C:\Windows\System32\cryptnet.dll
2013-12-29 17:05:49 6933E2AFF444A7A95D5C67E98449163E 868352 ----a-w- C:\Windows\System32\kernel32.dll
2013-12-29 17:05:49 1E65CF7B26D02750544EFDD73C8118FA 293376 ----a-w- C:\Windows\System32\KernelBase.dll
2013-12-29 17:05:48 51BB04243DF6196C06E125898127E397 169984 ----a-w- C:\Windows\System32\winsrv.dll
2013-12-29 17:05:48 2DE16A63F71D10B42ACE01E759078600 271360 ----a-w- C:\Windows\System32\conhost.exe
2013-12-29 17:05:44 20104EA66332D24D7C65BBB087C56737 123904 ----a-w- C:\Windows\System32\poqexec.exe
2013-12-29 17:05:41 72E953215CADE1A726C04AAFDF6B463D 49152 ----a-w- C:\Windows\System32\taskhost.exe
2013-12-29 16:59:54 86F34E7288DA428E38E2D8C7E806A871 826880 ----a-w- C:\Windows\System32\rdpcore.dll
2013-12-28 18:51:32 EB4A8F35A70A887FE32F43A3AA7D4E9A 203976 ----a-w- C:\Windows\System32\RICHTX32.OCX
2013-12-28 18:51:32 D76F0EAB36F83A31D411AEAF70DA7396 140288 ----a-w- C:\Windows\System32\comdlg32.ocx
2013-12-28 18:51:32 06EE7BB3C681B9FA8AF4280A154EE133 244416 ----a-w- C:\Windows\System32\Msflxgrd.ocx
2013-12-28 17:33:19 A46118A8987612525FC548AE33222DE4 270240 ----a-w- C:\Windows\System32\aswBoot.exe
2013-12-28 11:56:51 34E573287E2E95D4F560FAC85B2DA24D 201872 ----a-w- C:\Windows\System32\rmoc3260.dll
2013-12-28 11:56:49 B74E422BC81236042529DC8A42A18423 5632 ----a-w- C:\Windows\System32\pndx5032.dll
2013-12-28 11:56:49 B4EB68502E52EBDC0B2C55EA3445284C 272896 ----a-w- C:\Windows\System32\pncrt.dll
2013-12-28 11:56:49 33833B3EDA1B07EBD367FA9B38B23E60 6656 ----a-w- C:\Windows\System32\pndx5016.dll
2013-12-28 11:56:46 86F1895AE8C5E8B17D99ECE768A70732 348160 ----a-w- C:\Windows\System32\msvcr71.dll
2013-12-28 11:56:46 561FA2ABB31DFA8FAB762145F81667C2 499712 ----a-w- C:\Windows\System32\msvcp71.dll
2013-12-28 10:34:39 5FEFD614BBD3FFA3712B172F70B1FDE2 24576 ----a-w- C:\Windows\System32\msxml3a.dll
2013-12-28 10:32:02 EB5F811C1F78005B3C147599A0CCCF51 608448 ----a-w- C:\Windows\System32\comctl32.ocx
2013-12-28 10:32:02 DC925B6D77BA9ECB532E2F6750BE943B 224016 ----a-w- C:\Windows\System32\tabctl32.ocx
2013-12-28 10:32:02 B006E26E122C67D4FC68DF1E1AECA458 991232 ----a-w- C:\Windows\System32\imageviewer2.ocx
2013-12-28 10:32:02 84637D0DDEF17005967A8E0856E99A75 1703936 ----a-w- C:\Windows\System32\gdiplus.dll
2013-12-28 10:32:02 51C9E8D775C6653ACF5D87BDB2EBD33E 200704 ----a-w- C:\Windows\System32\threed32.ocx
2013-12-28 10:32:02 503E3D39587A3F08799DB5DEFD540DDB 106496 ----a-w- C:\Windows\System32\mbprgbar.ocx
2013-12-28 10:32:02 1B63AF252CFEFF520871F0AE37C80C5E 164144 ----a-w- C:\Windows\System32\comct232.ocx
2013-12-28 10:32:01 385D15906D1BE4DE788D5CCB3732C24F 151552 ----a-w- C:\Windows\System32\ccrpfd6.ocx
2013-12-28 10:32:01 0DBFB6B62B040703D7E4C83D84788888 110592 ----a-w- C:\Windows\System32\ccrpbds6.dll
2013-12-28 09:18:01 F83865A3007357A5E498EB9E3BED273D 31744 ----a-w- C:\Windows\System32\iernonce.dll
2013-12-28 09:18:01 F0FEFB0B5D25A75D478A4317139D937E 353584 ----a-w- C:\Windows\System32\iedkcs32.dll
2013-12-28 09:18:01 EE9D715AF1B928982F417238B9914484 434176 ----a-w- C:\Windows\System32\ieapfltr.dll
2013-12-28 09:18:01 EE0AFCEE88098F754212F9069E80A766 86528 ----a-w- C:\Windows\System32\iesysprep.dll
2013-12-28 09:18:01 ED6F6FBBCDEC95483B7351E23F4FCDF6 110592 ----a-w- C:\Windows\System32\IEAdvpack.dll
2013-12-28 09:18:01 E8F37AF4D09972684D9EE1786901F540 176640 ----a-w- C:\Windows\System32\ieui.dll
2013-12-28 09:18:01 DB754FF5F6ADBA2A25EC1B6672D1C91E 163840 ----a-w- C:\Windows\System32\ieakui.dll
2013-12-28 09:18:01 CA493A92DA9880B6F1A89C3DBD54BA5B 223232 ----a-w- C:\Windows\System32\dxtrans.dll
2013-12-28 09:18:01 C89906FA43A58FD4CFC7EA06D885A597 12344320 ----a-w- C:\Windows\System32\mshtml.dll
2013-12-28 09:18:01 C2E35F6FCBD5B4DB2B52B32D1153EC04 2382848 ----a-w- C:\Windows\System32\mshtml.tlb
2013-12-28 09:18:01 C0B8B96D018849FD8CCF15FED84E8782 74240 ----a-w- C:\Windows\System32\ie4uinit.exe
2013-12-28 09:18:01 C05A60DB2ED385E9BB5CF7AE773A3D9B 717824 ----a-w- C:\Windows\System32\jscript.dll
2013-12-28 09:18:01 BDA52464C16707EAA513C8A2920ACE1F 231936 ----a-w- C:\Windows\System32\url.dll
2013-12-28 09:18:01 B787EE3F327ABAC1EC47313B3A673598 1796096 ----a-w- C:\Windows\System32\iertutil.dll
2013-12-28 09:18:01 B231416DD7569B5C16F2DD2D2D64BB5A 9739264 ----a-w- C:\Windows\System32\ieframe.dll
2013-12-28 09:18:01 ADB9477A9C95C79FDF5DC214225603B0 420864 ----a-w- C:\Windows\System32\vbscript.dll
2013-12-28 09:18:01 A0C6AFE2C9C74573F5C0776CDE1128B1 142848 ----a-w- C:\Windows\System32\ieUnatt.exe
2013-12-28 09:18:01 90A57CA422923286838AAC7DE2D41B92 118784 ----a-w- C:\Windows\System32\iepeers.dll
2013-12-28 09:18:01 83F5D4B41BB12CE146786E97F6AAD75E 3695416 ----a-w- C:\Windows\System32\ieapfltr.dat
2013-12-28 09:18:01 822E4743E61687933629AE3A8DECABC2 65024 ----a-w- C:\Windows\System32\jsproxy.dll
2013-12-28 09:18:01 802B0229D904E28C1EA9A5274AB457FC 74752 ----a-w- C:\Windows\System32\iesetup.dll
2013-12-28 09:18:01 7AC9B18F1BE210702DA5E586224B1571 66048 ----a-w- C:\Windows\System32\icardie.dll
2013-12-28 09:18:01 795202EFA9ED73F99C96235C1DC6A1AC 1806848 ----a-w- C:\Windows\System32\jscript9.dll
2013-12-28 09:18:01 76EB0222590D5DCD050CF862237F414A 63488 ----a-w- C:\Windows\System32\tdc.ocx
2013-12-28 09:18:01 76E987D8CF0683337CF165363B6FDFD9 48640 ----a-w- C:\Windows\System32\mshtmler.dll
2013-12-28 09:18:01 736D1B28224F9DF8008BE8B0DEDFC9EF 76800 ----a-w- C:\Windows\System32\SetIEInstalledDate.exe
2013-12-28 09:18:01 6B4701D3D9724812E8C3801E7BF87157 23552 ----a-w- C:\Windows\System32\licmgr10.dll
2013-12-28 09:18:01 6B036492120E65C0C367DC31D01088A1 74752 ----a-w- C:\Windows\System32\RegisterIEPKEYs.exe
2013-12-28 09:18:01 68563AC389F92EE79F1C714288BA1DCE 35840 ----a-w- C:\Windows\System32\imgutil.dll
2013-12-28 09:18:01 67BC2BA6F94D2D0C51213691FBFEEBB1 152064 ----a-w- C:\Windows\System32\wextract.exe
2013-12-28 09:18:01 60B4F624BB87A3B21D3EC68F38DA6B61 78848 ----a-w- C:\Windows\System32\inseng.dll
2013-12-28 09:18:01 5B37190F79F5D63C1033ED88C006080C 123392 ----a-w- C:\Windows\System32\occache.dll
2013-12-28 09:18:01 5AAFA41F2A09D68F43741EF13937650A 1105408 ----a-w- C:\Windows\System32\urlmon.dll
2013-12-28 09:18:01 51AF0A12CD86E22E1A027C38CC021AC6 150528 ----a-w- C:\Windows\System32\iexpress.exe
2013-12-28 09:18:01 5193DE33F3284C447E0D31DAFBF92570 203776 ----a-w- C:\Windows\System32\webcheck.dll
2013-12-28 09:18:01 4CC9DF09C3D915BA0A101A11DB684F26 1129472 ----a-w- C:\Windows\System32\wininet.dll
2013-12-28 09:18:01 4B80D1F847C0658977E1E8051A4DE002 41472 ----a-w- C:\Windows\System32\msfeedsbs.dll
2013-12-28 09:18:01 4B333D3CC96AE66BD754329FD2989EE2 72822 ----a-w- C:\Windows\System32\ieuinit.inf
2013-12-28 09:18:01 49729570B7FD369BBDEC16D7683324A0 227840 ----a-w- C:\Windows\System32\ieaksie.dll
2013-12-28 09:18:01 4312DEBDACBE338F0B90E7F08E7672BE 353792 ----a-w- C:\Windows\System32\dxtmsft.dll
2013-12-28 09:18:01 3F7A8BCF37433A69CEEDE1E6AEE79784 101888 ----a-w- C:\Windows\System32\admparse.dll
2013-12-28 09:18:01 36E4D129029784EE37A2C14393B6A4E8 607744 ----a-w- C:\Windows\System32\msfeeds.dll
2013-12-28 09:18:01 35AAE2E841AA1A949775168E119482C9 161792 ----a-w- C:\Windows\System32\msls31.dll
2013-12-28 09:18:01 2429485305BCCFB1014B19BFB512E8F9 73216 ----a-w- C:\Windows\System32\mshtmled.dll
2013-12-28 09:18:01 1E7094AFAD0C369DD6D400C7047E4AB2 130560 ----a-w- C:\Windows\System32\ieakeng.dll
2013-12-28 09:18:01 1D3EE28BA231CBB9600F5D102EAF4EA7 10752 ----a-w- C:\Windows\System32\msfeedssync.exe
2013-12-28 09:18:01 0B8FE658BD033EC8B1F6FBC305CC65E7 162304 ----a-w- C:\Windows\System32\msrating.dll
2013-12-28 09:18:01 09C9E7F477FB225FDB3B6DE8FED0AA9B 367104 ----a-w- C:\Windows\System32\html.iec
2013-12-28 09:18:01 06FDA396980A0157469A334E1BFEAF17 1427968 ----a-w- C:\Windows\System32\inetcpl.cpl
2013-12-28 09:18:01 061CBB1058A10C0875D18CAFF835AE97 11776 ----a-w- C:\Windows\System32\mshta.exe
2013-12-28 09:18:01 04A8B2F67825380BC0C7C46D56776133 54272 ----a-w- C:\Windows\System32\pngfilt.dll
2013-12-28 07:04:26 D329085A88A9019ED5700C0F04B3176E 137000 ----a-w- C:\Windows\System32\MSMAPI32.OCX
2013-12-28 07:04:26 AE47A8A5FE8193BB84FFCD338115D8EF 662288 ----a-w- C:\Windows\System32\MSCOMCT2.OCX
2013-12-28 07:04:26 5CA984BA87D2F268F8DC96A38E67ED34 95416 ----a-w- C:\Windows\System32\pdfcmon.dll
2013-12-28 07:04:24 6EC9A8DC8508D724E7456600B0CCB995 23552 ----a-w- C:\Windows\System32\MSMPIDE.DLL
2013-12-28 06:13:19 EDDD8E0A3E3E4536134FAC6D2629AEC9 826328 ----a-w- C:\Windows\System32\npDeployJava1.dll
2013-12-28 06:13:19 BEA043F03D49EB400A9C34C0C4F028D6 754648 ----a-w- C:\Windows\System32\deployJava1.dll
2013-12-28 06:13:19 1FF367432C2825787A3C6A2175FE60A0 244184 ----a-w- C:\Windows\System32\javaws.exe
2013-12-28 06:13:16 CA9398465C43495AED12879659FDC7CA 175064 ----a-w- C:\Windows\System32\javaw.exe
2013-12-28 06:13:16 47424A9CC9B334A2192FD30C9CB8C034 175064 ----a-w- C:\Windows\System32\java.exe
2013-12-28 00:21:20 322FD75A97DBA67FC8F97A9957F857F1 28040 ----a-w- C:\Windows\System32\mdimon.dll
2013-12-27 22:48:04 EBE768B199EB3E741AB64BE55CCF0F66 71048 ----a-w- C:\Windows\System32\FlashPlayerCPLApp.cpl
2013-12-27 22:48:04 52FA726F8D37412122EC4EF1DF09D80F 692616 ----a-w- C:\Windows\System32\FlashPlayerApp.exe
2013-12-27 21:54:08 FC3EC24FCE372C89423E015A2AC1A31E 1933848 ----a-w- C:\Windows\System32\wuaueng.dll
2013-12-27 21:54:08 BDC0C99E472176C8C2C853A68ADC5073 45080 ----a-w- C:\Windows\System32\wups2.dll
2013-12-27 21:54:08 2E0B0A051FFAA86E358465BB0880D453 53784 ----a-w- C:\Windows\System32\wuauclt.exe
2013-12-27 21:54:08 285C594C4913FA9DC7BB6BA3AD6F101A 2422272 ----a-w- C:\Windows\System32\wucltux.dll
2013-12-27 21:53:58 C480F0E968ECA0D80D0299D7F204E33B 88576 ----a-w- C:\Windows\System32\wudriver.dll
2013-12-27 21:53:58 3458EDA96E30FBD0477A2800D3FB1909 35864 ----a-w- C:\Windows\System32\wups.dll
2013-12-27 21:53:58 1A617835452EEE5060976C9B9F5FE635 577048 ----a-w- C:\Windows\System32\wuapi.dll
2013-12-27 21:53:52 98F94089E9C549E223AB05BE54BAB2ED 171904 ----a-w- C:\Windows\System32\wuwebv.dll
2013-12-27 21:53:52 069385484EA57B663D688894C88975C5 33792 ----a-w- C:\Windows\System32\wuapp.exe
2013-12-27 20:16:36 54502A2F8B141D8AE16ACC0F59D86421 230048 ------w- C:\Windows\System32\MpSigStub.exe
====== C:\Windows\system32\drivers =====
2013-12-29 20:28:57 0DB7527DB188C7D967A37BB51BBF3963 40776 ----a-w- C:\Windows\System32\drivers\mbamswissarmy.sys
2013-12-29 18:38:50 65375DF758CA1872AB7EBBBA457FD5E6 14848 ----a-w- C:\Windows\System32\drivers\rdpvideominiport.sys
2013-12-29 18:38:49 9CE253214ACAA5A7D323327D2055EFAA 49664 ----a-w- C:\Windows\System32\drivers\TsUsbFlt.sys
2013-12-29 18:38:49 57C527AF84748B5C2F5178C499C0B81F 27136 ----a-w- C:\Windows\System32\drivers\TsUsbGD.sys
2013-12-29 17:48:51 867C301E8B790040AE9CF6486E8041DF 155136 ----a-w- C:\Windows\System32\drivers\WUDFRd.sys
2013-12-29 17:48:51 06E6F32C8D0A3F66D956F57B43A2E070 66560 ----a-w- C:\Windows\System32\drivers\WUDFPf.sys
2013-12-29 17:48:50 933222B19FF3E7EA5F65517EA1F7D57E 3 ----a-w- C:\Windows\System32\drivers\MsftWdf_User_01_11_00_Inbox_Critical.Wdf
2013-12-29 17:48:09 7DAE5EBCC80E45D3253F4923DC424D05 19824 ----a-w- C:\Windows\System32\drivers\fs_rec.sys
2013-12-29 17:24:41 3EEBD3BD93DA46A26E89893C7AB2FF3B 35328 ----a-w- C:\Windows\System32\drivers\tcpipreg.sys
2013-12-29 17:24:33 F81BB7E487EDCEAB630A7EE66CF23913 338944 ----a-w- C:\Windows\System32\drivers\afd.sys
2013-12-29 17:24:33 CA59F7C570AF70BC174F477CFE2D9EE3 1294272 ----a-w- C:\Windows\System32\drivers\tcpip.sys
2013-12-29 17:24:16 ED80D303102A746D30C1684B387BCBF1 33280 ----a-w- C:\Windows\System32\drivers\RNDISMP.sys
2013-12-29 17:24:16 8C9C922D71F1CD4DEF73F186416B7896 712048 ----a-w- C:\Windows\System32\drivers\ndis.sys
2013-12-29 17:24:11 E306A24D9694C724FA2491278BF50FDB 196328 ----a-w- C:\Windows\System32\drivers\fvevol.sys
2013-12-29 17:23:49 DDCE686D76C2B4DB435A3AF5BD0E691D 133056 ----a-w- C:\Windows\System32\drivers\ataport.sys
2013-12-29 17:23:49 21F4B24ACFC79A483515BD986DD9043F 115712 ----a-w- C:\Windows\System32\drivers\mrxdav.sys
2013-12-29 17:23:02 F286830298323272260332D6ABC905C1 67520 ----a-w- C:\Windows\System32\drivers\ksecdd.sys
2013-12-29 17:23:02 D7C760D57B1656DD748B9E4AB6CB5A51 136640 ----a-w- C:\Windows\System32\drivers\ksecpkg.sys
2013-12-29 17:23:02 85449EEBE8F8EBD6481EFBF0F352B4EB 369848 ----a-w- C:\Windows\System32\drivers\cng.sys
2013-12-29 17:22:38 E4C2764065D66EA1D2D3EBC28FE99C46 311808 ----a-w- C:\Windows\System32\drivers\srv.sys
2013-12-29 17:22:38 BE6BD660CAA6F291AE06A718A4FA8ABC 114688 ----a-w- C:\Windows\System32\drivers\srvnet.sys
2013-12-29 17:22:38 03F0545BD8D4C77FA0AE1CEEDFCC71AB 310272 ----a-w- C:\Windows\System32\drivers\srv2.sys
2013-12-29 17:21:51 5E43D2B0EE64123D4880DFA6626DEFDE 1211752 ----a-w- C:\Windows\System32\drivers\ntfs.sys
2013-12-29 17:21:46 AAB149EE616952BB84308C28E75ED20D 187752 ----a-w- C:\Windows\System32\drivers\FWPKCLNT.SYS
2013-12-29 17:21:46 776FCEFE2CD27C442DF66D3F3535078D 240496 ----a-w- C:\Windows\System32\drivers\netio.sys
2013-12-29 17:21:31 FE8A57C8E04EDD3AA8ADD8F3C8F65297 15872 ----a-w- C:\Windows\System32\drivers\usb8023.sys
2013-12-29 17:21:04 B81F204D146000BE76651A50670A5E9E 96768 ----a-w- C:\Windows\System32\drivers\mrxsmb20.sys
2013-12-29 17:21:04 6D17A4791ACA19328C685D256349FEFC 223744 ----a-w- C:\Windows\System32\drivers\mrxsmb10.sys
2013-12-29 17:21:04 5D16C921E3671636C0EBA3BBAAC5FD25 123904 ----a-w- C:\Windows\System32\drivers\mrxsmb.sys
2013-12-29 17:20:55 F1B27299F547D452EDAEF01FC187CB91 25728 ----a-w- C:\Windows\System32\drivers\hidparse.sys
2013-12-29 17:20:55 50ABE682EBE752EAF62B18790D6D491C 55808 ----a-w- C:\Windows\System32\drivers\hidclass.sys
2013-12-29 17:20:54 E405328A0E38BF823E2361C413283F6D 218984 ----a-w- C:\Windows\System32\drivers\dxgmms1.sys
2013-12-29 17:20:54 71BC35067CABC02C9453AEAA42B2E43E 729024 ----a-w- C:\Windows\System32\drivers\dxgkrnl.sys
2013-12-29 17:20:52 F031683E6D1FEA157ABB2FF260B51E61 183808 ----a-w- C:\Windows\System32\drivers\rdpwd.sys
2013-12-29 17:20:50 D0F0D7A97C90FE72A79732812E65F822 27008 ----a-w- C:\Windows\System32\drivers\Diskdump.sys
2013-12-29 17:20:43 EB6137D696A9B4E9718AC6F8641CB4C9 177152 ----a-w- C:\Windows\System32\drivers\portcls.sys
2013-12-29 17:20:43 9842041E2F5ACE1E2F5FB4EF02053DC8 81408 ----a-w- C:\Windows\System32\drivers\drmk.sys
2013-12-29 17:06:39 3F34A1B4C5F6475F320C275E63AFCE9B 56176 ----a-w- C:\Windows\System32\drivers\partmgr.sys
2013-12-29 17:05:58 933222B19FF3E7EA5F65517EA1F7D57E 3 ----a-w- C:\Windows\System32\drivers\MsftWdf_Kernel_01011_Inbox_Critical.Wdf
2013-12-29 17:05:58 48704647CD2E9DAA2EB81BDE6D029EDB 47720 ----a-w- C:\Windows\System32\drivers\WdfLdr.sys
2013-12-29 17:05:58 25944D2CC49E0A6C581D02A74B7D6645 527064 ----a-w- C:\Windows\System32\drivers\Wdf01000.sys
2013-12-29 17:05:43 DE014425522610BEDCA3821BB8C0F1D5 146816 ----a-w- C:\Windows\System32\drivers\usbvideo.sys
2013-12-29 17:05:43 8F2DA3028D5FCBD1A060A3DE64CD6506 69632 ----a-w- C:\Windows\System32\drivers\bowser.sys
2013-12-29 17:05:43 2352AB5F9F8F097BF9D41D5A4718A041 86016 ----a-w- C:\Windows\System32\drivers\usbcir.sys
2013-12-29 17:05:38 B37B08F2E5EEB1A37E448E09BACE1101 31232 ----a-w- C:\Windows\System32\drivers\tssecsrv.sys
2013-12-29 16:59:54 2C2C5AFE7EE4F620D69C23C0617651A8 24576 ----a-w- C:\Windows\System32\drivers\tdtcp.sys
2013-12-28 17:37:28 37A6A39C1792BA961EE6172A0F3CA236 64168 ----a-w- C:\Windows\System32\drivers\aswstm.sys
2013-12-28 17:33:27 7BA7543EA7936A7ADA615F6DE7C95494 410528 ----a-w- C:\Windows\System32\drivers\aswSP.sys
2013-12-28 17:33:27 1B0662514A68C3A42E60D240C5ABEF28 180248 ----a-w- C:\Windows\System32\drivers\aswVmm.sys
2013-12-28 17:33:26 F385467DF95D0A73775CB3B076B8B969 49944 ----a-w- C:\Windows\System32\drivers\aswRvrt.sys
2013-12-28 17:33:25 6F1505608202BBD179095A6A150D103F 67824 ----a-w- C:\Windows\System32\drivers\aswMonFlt.sys
2013-12-28 17:33:25 0F639D0526820BA7872C963813E0EB8D 775952 ----a-w- C:\Windows\System32\drivers\aswSnx.sys
2013-12-28 17:33:23 2206985EF126AB90F3D7F1A020589DC9 79720 ----a-w- C:\Windows\System32\drivers\aswRdr2.sys
2013-12-28 17:33:19 0EEFB7741B46099FE1AA124F57BEEE41 26136 ----a-w- C:\Windows\System32\drivers\aswKbd.sys
2013-12-28 11:31:04 B630D5631B8BEB259DEA049EBC4FC57B 48640 ----a-w- C:\Windows\System32\drivers\KSafeDISK.sys
2013-12-28 11:31:04 9026258E6FD965982CBB090569AD7042 27648 ----a-w- C:\Windows\System32\drivers\BTOWSFF.sys
2013-12-28 11:31:03 E12F2E9E0CF646FEBCB948EDDF76CAB4 45952 ----a-w- C:\Windows\System32\drivers\BTOWSVF.sys
2013-12-28 08:00:26 4470E3C1E0C3378E4CAB137893C12C3A 22856 ----a-w- C:\Windows\System32\drivers\mbam.sys
2013-12-28 03:08:27 9E26599599D178E71AFB5599E146031A 9200 ------w- C:\Windows\System32\drivers\cdralw2k.sys
2013-12-28 03:08:27 49452BFCEC22F36A7A9B9C2181BC3042 43872 ------w- C:\Windows\System32\drivers\PxHelp20.sys
2013-12-28 03:08:27 223DEA13C9D064BABC882B4727F6F905 9072 ------w- C:\Windows\System32\drivers\cdr4_xp.sys
2013-12-27 20:28:56 D41D8CD98F00B204E9800998ECF8427E 0 ---ha-w- C:\Windows\System32\drivers\Msft_User_WpdFs_01_09_00.Wdf
====== C:\Windows\Tasks ======
2013-12-30 19:42:07 67D5686A5803845EF63BFAA4DB6CFF99 386 ----a-w- C:\Windows\Tasks\RegCure Pro.job
2013-12-30 19:42:07 6497941A41DC1B5D92B9321D0C3935C7 3310 ----a-w- C:\Windows\system32\Tasks\RegCure Pro
2013-12-30 17:54:39 35C76D66D1529A3A136669FE67B89994 1042 ----a-w- C:\Windows\Tasks\GoogleUpdateTaskMachineUA.job
2013-12-30 17:54:39 1DD8D92DC752680BDC5E39BD30882325 4038 ----a-w- C:\Windows\system32\Tasks\GoogleUpdateTaskMachineUA
2013-12-30 17:54:38 9EE356692C3680E0892C1C2A07E0996A 1038 ----a-w- C:\Windows\Tasks\GoogleUpdateTaskMachineCore.job
2013-12-30 17:54:38 387DB545FAA708F2B0F0332B82A0F933 3786 ----a-w- C:\Windows\system32\Tasks\GoogleUpdateTaskMachineCore
2013-12-30 03:18:12 412A59A3B281DEC57E8C0C9A304301B1 3328 ----a-w- C:\Windows\system32\Tasks\RealPlayerRealUpgradeScheduledTaskS-1-5-21-3188537812-1931195976-3180334174-1000
2013-12-29 19:12:10 A4BD0EA72070B24B1DFB642B8FE7E675 3114 ----a-w- C:\Windows\system32\Tasks\{264E02C3-1C87-4815-AFC7-05D247CE7AD8}
2013-12-28 17:33:32 8ED68F5BC811DAF6F04FEE017DC68B13 4182 ----a-w- C:\Windows\system32\Tasks\avast! Emergency Update
2013-12-28 11:31:01 1C7208B6EA91B10F3FA31976CFCFFDB6 3290 ----a-w- C:\Windows\system32\Tasks\ToolwizCareFree
2013-12-28 07:44:34 EF0196850523E6E92161032694BB37D2 2990 ----a-w- C:\Windows\system32\Tasks\SlimCleaner Run
2013-12-28 06:18:07 ABB547263193069B755050A306A95CE7 3810 ----a-w- C:\Windows\system32\Tasks\DriverEasy Scheduled Scan
2013-12-28 06:18:07 7D46388CDCF171051D34EBF70F447B51 406 ----a-w- C:\Windows\Tasks\DriverEasy Scheduled Scan.job
2013-12-28 05:43:08 6301731B21CA9FADC42C2BDB2EA09773 3556 ----a-w- C:\Windows\system32\Tasks\ProgramRefresh-ATFST
2013-12-28 05:43:07 1819AD5041E19ADDAAA8FD13F7B5E046 3878 ----a-w- C:\Windows\system32\Tasks\ProgramUpdateCheck
2013-12-28 05:43:03 91ECC2BF13DEBE1B0DC031B552217759 3074 ----a-w- C:\Windows\system32\Tasks\FreeFileViewerUpdateChecker
2013-12-28 05:43:03 20109D69E36AC9BE3F5B39395897D5B2 378 ----a-w- C:\Windows\Tasks\FreeFileViewerUpdateChecker.job
====== C:\Windows\Temp ======
======= C:\Program Files =====
2013-12-30 17:54:36 -------- d-----w- C:\Program Files\Google
2013-12-30 00:14:39 -------- d-----w- C:\Program Files\Common Files\Skype
2013-12-30 00:14:39 -------- d-----r- C:\Program Files\Skype
2013-12-29 19:57:59 -------- d-----w- C:\Program Files\Registrar Registry Manager
2013-12-29 19:12:28 -------- d-----w- C:\Program Files\Windows Installer Clean Up
2013-12-29 19:12:13 -------- d-----w- C:\Program Files\MSECACHE
2013-12-29 00:48:35 -------- d-----w- C:\Program Files\Microsoft
2013-12-28 20:20:46 -------- d-----w- C:\Program Files\Movie Maker 2.6
2013-12-28 12:28:53 -------- d-----w- C:\Program Files\QuickTime
2013-12-28 12:28:33 -------- d-----w- C:\Program Files\Common Files\Apple
2013-12-28 12:28:25 -------- d-----w- C:\Program Files\Apple Software Update
2013-12-28 12:00:49 -------- d-----w- C:\Program Files\Flash Movie Player
2013-12-28 11:57:07 -------- d-----w- C:\Program Files\RealNetworks
2013-12-28 11:56:53 -------- d-----w- C:\Program Files\Common Files\xing shared
2013-12-28 11:56:45 -------- d-----w- C:\Program Files\Real
2013-12-28 11:54:44 -------- d-----w- C:\Program Files\VideoLAN
2013-12-28 11:30:59 -------- d-----w- C:\Program Files\ToolwizCareFree
2013-12-28 10:35:04 -------- d-----w- C:\Program Files\Common Files\AVSMedia
2013-12-28 10:32:01 -------- d-----w- C:\Program Files\PIXresizer
2013-12-28 09:14:46 -------- d-----w- C:\Program Files\eysy photo effects
2013-12-28 09:08:17 -------- d-----w- C:\Program Files\Picture Collage Maker Pro
2013-12-28 08:56:45 -------- d-----w- C:\Program Files\SUPERAntiSpyware
2013-12-28 08:12:41 -------- d-----w- C:\Program Files\Trend Micro
2013-12-28 07:44:34 -------- d-----w- C:\Program Files\SlimCleaner
2013-12-28 07:36:24 -------- d-----w- C:\Program Files\Speaking Clock
2013-12-28 07:12:05 -------- d-----w- C:\Program Files\PDF to Word Free
2013-12-28 07:04:24 -------- d-----w- C:\Program Files\PDFCreator
2013-12-28 06:52:46 -------- d-----w- C:\Program Files\photo filter
2013-12-28 06:51:48 -------- d-----w- C:\Program Files\Photo Effects Studio
2013-12-28 06:48:50 -------- d-----w- C:\Program Files\Noiseware Professional Edition
2013-12-28 06:46:54 -------- d-----w- C:\Program Files\FotoSketcher
2013-12-28 06:44:58 -------- d-----w- C:\Program Files\FastStone Photo Resizer
2013-12-28 06:43:21 -------- d-----w- C:\Program Files\Easy Graphic Converter
2013-12-28 06:37:41 -------- d-----w- C:\Program Files\Cool Timer
2013-12-28 06:29:41 -------- d-----w- C:\Program Files\Clipboard Magic
2013-12-28 06:18:05 -------- d-----w- C:\Program Files\Easeware
2013-12-28 06:13:23 -------- d-----w- C:\Program Files\Common Files\Java
2013-12-28 06:13:11 -------- d-----w- C:\Program Files\Java
2013-12-28 05:44:20 -------- d-----w- C:\Program Files\OpenOffice 4
2013-12-28 05:42:56 -------- d-----w- C:\Program Files\FreeFileViewer
2013-12-28 05:36:57 -------- d-----w- C:\Program Files\Nik Software
2013-12-28 05:28:17 -------- d-----w- C:\Program Files\Beauty Pilot2
2013-12-28 05:27:50 -------- d-----w- C:\Program Files\Beauty Pilot
2013-12-28 05:11:01 -------- d-----w- C:\Program Files\POP Peeper
2013-12-28 04:05:45 -------- d-----w- C:\Program Files\Imagenomic
2013-12-28 04:05:02 -------- d-----w- C:\Program Files\Common Files\InstallShield
2013-12-28 04:04:54 -------- d-----w- C:\Program Files\onOne Software
2013-12-28 04:04:53 -------- d--h--w- C:\Program Files\InstallShield Installation Information
2013-12-28 03:08:27 -------- d-----w- C:\Program Files\Common Files\PX Storage Engine
2013-12-28 00:20:55 -------- d-----w- C:\Program Files\Common Files\DESIGNER
2013-12-28 00:18:48 -------- d-----w- C:\Program Files\Microsoft.NET
2013-12-28 00:18:48 -------- d-----w- C:\Program Files\Microsoft Office
2013-12-27 23:56:29 -------- d-----w- C:\Program Files\WinZip
2013-12-27 23:19:10 -------- d-----w- C:\Program Files\Microsoft Windows 7 Upgrade Advisor
2013-12-27 22:56:46 -------- d-----w- C:\Program Files\Common Files\Adobe
2013-12-27 22:56:46 -------- d-----w- C:\Program Files\Adobe
2013-12-27 21:30:21 -------- d-----w- C:\Program Files\Ditto
2013-12-27 20:47:14 -------- d-----w- C:\Program Files\Microsoft Silverlight
======= C: =====
2013-12-30 20:01:43 1FDF72102C2A76E10B79104DEE4AAA8B 70 ----a-w- C:\0.bak
2013-12-28 07:04:28 86A18FE4837C9F31E1B3EDCB180AE519 1035 ----a-w- C:\0
2013-12-26 16:40:06 BD10AE2A72501C188C6278A7DFB66CEB 5096008 ----a-w- C:\setup.dll
====== C:\Users\Peter\AppData\Roaming ======
2013-12-30 20:27:12 -------- d-----w- C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Windows 7 USB DVD Download Tool
2013-12-30 17:59:58 -------- d-----w- C:\Windows\system32\config\systemprofile\AppData\Local\Google
2013-12-30 17:54:30 -------- d-----w- C:\Users\Peter\AppData\Local\Google
2013-12-30 17:54:18 -------- d-----w- C:\Users\Peter\AppData\Local\Deployment
2013-12-30 17:54:18 -------- d-----w- C:\Users\Peter\AppData\Local\Apps
2013-12-30 14:09:48 A0B3FDD4C95251DCC30B1C88C80F32E4 7597 ----a-w- C:\Users\Peter\AppData\Local\Resmon.ResmonCfg
2013-12-30 00:14:49 -------- d-----w- C:\Users\Peter\AppData\Roaming\Skype
2013-12-29 18:53:13 -------- d-----w- C:\Users\Peter\AppData\Roaming\LavasoftStatistics
2013-12-29 00:38:41 -------- d-----w- C:\Users\Peter\AppData\Roaming\kompozer.net
2013-12-29 00:38:41 -------- d-----w- C:\Users\Peter\AppData\Local\kompozer.net
2013-12-28 21:10:36 -------- d-----w- C:\Users\Peter\AppData\Roaming\Canneverbe Limited
2013-12-28 18:51:29 -------- d-----w- C:\Users\Peter\AppData\Roaming\TechCheck
2013-12-28 14:24:14 -------- d-----w- C:\Users\Peter\AppData\Roaming\Apple Computer
2013-12-28 14:22:48 -------- d-----w- C:\Users\Peter\AppData\Roaming\POP Peeper
2013-12-28 12:41:00 -------- d-----w- C:\Users\Peter\AppData\Local\Spotify
2013-12-28 12:40:48 -------- d-----w- C:\Users\Peter\AppData\Roaming\Spotify
2013-12-28 12:30:51 -------- d-----w- C:\Users\Peter\AppData\Local\Apple Computer
2013-12-28 12:28:26 -------- d-----w- C:\Users\Peter\AppData\Local\Apple
2013-12-28 12:28:13 -------- d-----w- C:\Users\Peter\AppData\Locallow\Apple Computer
2013-12-28 12:02:32 -------- d-----w- C:\Users\Peter\AppData\Roaming\vlc
2013-12-28 11:57:28 -------- d-----w- C:\Users\Peter\AppData\Roaming\RealNetworks
2013-12-28 11:56:34 -------- d-----w- C:\Users\Peter\AppData\Roaming\Real
2013-12-28 11:31:02 -------- d-----w- C:\Users\Peter\AppData\Local\ToolwizCareFree
2013-12-28 09:02:58 -------- d-----w- C:\Users\Peter\AppData\Local\SlimWare Utilities Inc
2013-12-28 08:56:55 -------- d-----w- C:\Users\Peter\AppData\Roaming\SUPERAntiSpyware.com
2013-12-28 08:41:21 -------- d-----w- C:\Users\Peter\AppData\Roaming\FreeFileViewer
2013-12-28 07:12:44 -------- d-----w- C:\Users\Peter\AppData\Locallow\Adobe
2013-12-28 07:06:25 -------- d-----w- C:\Users\Peter\AppData\Roaming\PDF Architect
2013-12-28 06:57:25 -------- d-----w- C:\Users\Peter\AppData\Roaming\PearlMountain
2013-12-28 06:44:01 -------- d-----w- C:\Users\Peter\AppData\Roaming\FastStone
2013-12-28 06:41:38 -------- d-----w- C:\Users\Peter\AppData\Local\Harmony_Hollow_Software
2013-12-28 06:41:18 -------- d-----w- C:\Users\Peter\AppData\Local\CTSounds
2013-12-28 06:29:48 -------- d-----w- C:\Users\Peter\AppData\Roaming\CyberMatrix
2013-12-28 06:28:39 -------- d-----w- C:\Users\Peter\AppData\Roaming\Convivea
2013-12-28 06:26:38 -------- d-----w- C:\Users\Peter\AppData\Roaming\AVS4YOU
2013-12-28 06:18:07 -------- d-----w- C:\Users\Peter\AppData\Roaming\Easeware
2013-12-28 06:13:04 -------- d-----w- C:\Users\Peter\AppData\Locallow\Sun
2013-12-28 05:48:06 -------- d-----w- C:\Users\Peter\AppData\Local\ElevatedDiagnostics
2013-12-28 05:45:04 -------- d-----w- C:\Users\Peter\AppData\Roaming\OpenOffice
2013-12-28 05:43:19 -------- d-----w- C:\Users\Peter\AppData\Local\FreeFileViewer
2013-12-28 05:31:18 -------- d-----w- C:\Users\Peter\AppData\Local\Nik Software
2013-12-28 05:29:22 -------- d-----w- C:\Users\Peter\AppData\Roaming\BeautyPilot
2013-12-28 05:18:41 -------- d-----w- C:\Windows\serviceprofiles\Localservice\AppData\Local\PnrpSqm
2013-12-28 05:17:01 -------- d-----w- C:\Windows\serviceprofiles\Localservice\AppData\Roaming\PeerNetworking
2013-12-28 01:02:55 -------- d-----w- C:\Users\Peter\AppData\Roaming\AVG
2013-12-28 00:15:30 -------- d-----w- C:\Users\Peter\AppData\Roaming\Google
2013-12-27 23:19:39 -------- d-----w- C:\Users\Peter\AppData\Local\Microsoft Corporation
2013-12-27 22:37:54 E5FA7CB272B7A5655CCDDE1538C8996B 69544 ----a-w- C:\Users\Peter\AppData\Local\GDIPFONTCACHEV1.DAT
2013-12-27 22:30:45 -------- d-----w- C:\Users\Peter\AppData\Roaming\Media Get LLC
2013-12-27 22:30:24 -------- d-----w- C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\MediaGet2
2013-12-27 22:30:24 -------- d-----w- C:\Users\Peter\AppData\Local\MediaGet2
2013-12-27 22:30:24 -------- d-----w- C:\Users\Peter\AppData\Local\Media Get LLC
2013-12-27 21:33:45 -------- d-----w- C:\Users\Peter\AppData\Roaming\Mozilla
2013-12-27 21:33:45 -------- d-----w- C:\Users\Peter\AppData\Local\Mozilla
2013-12-27 21:31:38 -------- d-----w- C:\Users\Peter\AppData\Roaming\Adobe
2013-12-27 21:31:17 -------- d-----w- C:\Users\Peter\AppData\Local\Adobe
2013-12-27 21:30:28 -------- d-----w- C:\Users\Peter\AppData\Roaming\Ditto
2013-12-27 21:00:02 -------- d-----w- C:\Users\Peter\AppData\Roaming\uTorrent
2013-12-27 20:25:42 -------- d-s---w- C:\Users\Peter\AppData\Locallow\Microsoft
2013-12-27 19:53:00 -------- d-----w- C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
2013-12-27 19:53:00 -------- d-----w- C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
2013-12-27 19:52:49 -------- d-----w- C:\Users\Peter\AppData\Roaming\Identities
2013-12-27 19:52:41 -------- d-----w- C:\Users\Peter\AppData\Local\VirtualStore
2013-12-27 19:52:40 -------- d-s---w- C:\Users\Peter\AppData\Roaming\Microsoft
2013-12-27 19:52:40 -------- d-----w- C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Maintenance
2013-12-27 19:52:40 -------- d-----w- C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Accessories
2013-12-27 19:52:40 -------- d-----w- C:\Users\Peter\AppData\Roaming\Media Center Programs
2013-12-27 19:52:40 -------- d-----w- C:\Users\Peter\AppData\Local\Temp
2013-12-27 19:52:40 -------- d-----w- C:\Users\Peter\AppData\Local\Microsoft
====== C:\Users\Peter ======
2013-12-30 20:27:12 E5BE07EBB0C9D0B1A49FD65C80049702 2506 ----a-w- C:\Users\teddy\Windows 7 USB DVD Download Tool.lnk
2013-12-30 20:04:28 43B138619B40DCB9F192046D009D7F67 4728144 ----a-w- C:\Users\teddy\pc clean\RegCurePro.exe
2013-12-30 18:53:11 63C3C419200755087C7496933C298F8F 5162600 ----a-w- C:\Users\Peter\Downloads\Repair-tool.exe
2013-12-30 17:54:50 -------- d-----w- C:\ProgramData\Google
2013-12-30 14:11:03 69CA82A7482A00D8EE063D2B97FC4338 781383 ----a-w- C:\Users\teddy\pc clean\RSIT.exe
2013-12-30 03:32:49 BF9A233DACF15065E254434BC9AAAA17 82 --sh--w- C:\Users\Peter\desktop.ini
2013-12-30 00:14:39 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Skype
2013-12-30 00:14:35 -------- d-----w- C:\ProgramData\Skype
2013-12-29 23:22:43 E5530C24F95262CD148A06A047B82802 24805592 ----a-w- C:\Users\teddy\virus\Windows-KB890830-V5.7.exe
2013-12-29 22:05:25 -------- d-----w- C:\Users\teddy\fims downloaden
2013-12-29 22:04:20 -------- d-----w- C:\Users\teddy\emails
2013-12-29 22:03:53 -------- d-----w- C:\Users\teddy\email web
2013-12-29 21:55:33 -------- d-----w- C:\Users\teddy\lettertypes
2013-12-29 20:04:02 D41D8CD98F00B204E9800998ECF8427E 0 ----a-w- C:\Users\Peter\DesktopAllerleiVolledige naam.doc
2013-12-29 19:58:00 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Registrar Registry Manager
2013-12-29 18:28:45 -------- d-----w- C:\ProgramData\Lavasoft
2013-12-29 18:22:57 32CABB7112E22422075279BAE1BF729B 92672 ----a-w- C:\Users\teddy\virus\KillBox.exe
2013-12-29 18:20:16 C8A6B75E72DF96DEC9B71498849B7590 532480 ----a-w- C:\Users\teddy\pc clean\cwshredder.exe
2013-12-28 21:13:04 32CBECF1C0B588EF3AB1C700F5BD7C8D 991232 ----a-w- C:\Users\teddy\players\Pirate-1006.exe
2013-12-28 21:10:43 -------- d-----w- C:\ProgramData\Canneverbe Limited
2013-12-28 20:28:21 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Auto FX Software
2013-12-28 20:24:01 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Auto FX DreamSuite
2013-12-28 17:33:57 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Avast
2013-12-28 12:29:01 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\QuickTime
2013-12-28 12:28:53 -------- d-----w- C:\ProgramData\Apple Computer
2013-12-28 12:28:25 -------- d-----w- C:\ProgramData\Apple
2013-12-28 12:12:45 -------- d-----w- C:\Users\Peter\l
2013-12-28 12:00:49 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Flash Movie Player
2013-12-28 11:57:05 -------- d-----w- C:\ProgramData\RealNetworks
2013-12-28 11:56:49 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\RealNetworks
2013-12-28 11:56:08 -------- d-----w- C:\ProgramData\Real
2013-12-28 11:54:53 -------- d-----w- C:\Users\teddy\players
2013-12-28 11:54:48 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN
2013-12-28 11:31:02 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ToolwizCareFree
2013-12-28 10:35:41 -------- d-----w- C:\ProgramData\AVS4YOU
2013-12-28 10:32:03 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PIXresizer
2013-12-28 09:08:46 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Picture Collage Maker Pro
2013-12-28 09:02:25 -------- d-----w- C:\ProgramData\Licenses
2013-12-28 09:02:24 -------- d---a-w- C:\ProgramData\TEMP
2013-12-28 08:56:50 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SUPERAntiSpyware
2013-12-28 08:56:45 -------- d-----w- C:\ProgramData\SUPERAntiSpyware.com
2013-12-28 08:16:04 -------- d-----w- C:\Users\teddy\handige links
2013-12-28 07:59:46 -------- d-----w- C:\Users\teddy\virus
2013-12-28 07:59:09 AF5C84446657B48C9B9B870C46438261 1233962 ----a-w- C:\Users\teddy\virus\adwcleaner(1).exe
2013-12-28 07:49:45 -------- d-----w- C:\Users\teddy\pc geluiden
2013-12-28 07:49:28 32CBECF1C0B588EF3AB1C700F5BD7C8D 991232 ----a-w- C:\Users\Peter\muziek\Pirate-1006.exe
2013-12-28 07:49:28 -------- d-----w- C:\Users\Peter\muziek
2013-12-28 07:47:55 F9B24EFADFC68005F6E21E4FC74DCD1B 837632 ----a-w- C:\Users\teddy\pc clean\RegClean.exe
2013-12-28 07:44:35 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SlimCleaner
2013-12-28 07:36:24 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Speaking Clock
2013-12-28 07:14:41 D41D8CD98F00B204E9800998ECF8427E 0 ----a-w- C:\Users\Peter\DesktopBartenders.doc
2013-12-28 07:12:06 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PDF to Word Free
2013-12-28 07:04:28 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PDFCreator
2013-12-28 06:57:25 -------- d-----w- C:\ProgramData\PearlMountain
2013-12-28 06:37:41 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Cool Timer
2013-12-28 06:18:35 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DriverEasy
2013-12-28 06:13:23 -------- d-----w- C:\ProgramData\Sun
2013-12-28 06:09:26 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Beauty Pilot
2013-12-28 05:44:35 -------- d-s---w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\OpenOffice 4.0.1
2013-12-28 05:43:00 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\FreeFileViewer
2013-12-28 05:36:59 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Snapseed
2013-12-28 04:42:00 -------- d-----r- C:\Users\teddy\pc clean
2013-12-28 04:05:45 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Imagenomic
2013-12-28 04:04:54 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\onOne Software
2013-12-28 01:01:58 -------- d-----w- C:\ProgramData\AVG
2013-12-28 01:01:51 -------- d--h--w- C:\ProgramData\Common Files
2013-12-28 01:00:14 -------- d-----w- C:\Users\Peter\Werkbalk
2013-12-28 01:00:13 139B5C6A20A709BDE181285394EE232E 45056 ----a-w- C:\Users\Peter\werbalken pc 2\IconConverter.exe
2013-12-28 01:00:13 -------- d-----w- C:\Users\Peter\werbalken pc 2
2013-12-28 00:35:48 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office Tools
2013-12-28 00:20:58 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office
2013-12-27 23:56:42 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinZip
2013-12-27 23:56:29 -------- d-----w- C:\ProgramData\WinZip
2013-12-27 23:51:46 5A13648A4CD5D157D002186C463441B2 842 ----a-w- C:\Users\Peter\Downloads.lnk
2013-12-27 22:56:35 -------- d-----w- C:\ProgramData\Adobe
2013-12-27 21:33:37 -------- d-----w- C:\ProgramData\Mozilla
2013-12-27 21:30:22 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ditto
2013-12-27 20:47:16 -------- d-----w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Silverlight
2013-12-27 19:53:00 -------- d-----r- C:\Users\Peter\Searches
2013-12-27 19:52:48 -------- d-----r- C:\Users\Peter\Contacts
2013-12-27 19:52:40 6FC234AD3752E1267B34FB12BCD6718B 20 --sh--w- C:\Users\Peter\ntuser.ini
2013-12-27 19:52:40 -------- d--h--w- C:\Users\Peter\AppData
2013-12-27 19:52:40 -------- d-----r- C:\Users\Peter\Videos
2013-12-27 19:52:40 -------- d-----r- C:\Users\Peter\Saved Games
2013-12-27 19:52:40 -------- d-----r- C:\Users\Peter\Pictures
2013-12-27 19:52:40 -------- d-----r- C:\Users\Peter\Music
2013-12-27 19:52:40 -------- d-----r- C:\Users\Peter\Links
2013-12-27 19:52:40 -------- d-----r- C:\Users\Peter\Favorites
2013-12-27 19:52:40 -------- d-----r- C:\Users\Peter\Downloads
2013-12-27 19:52:40 -------- d-----r- C:\Users\Peter\Documents
2013-12-27 19:52:40 -------- d-----r- C:\Users\Peter\Desktop
====== C: exe-files ==
2013-12-30 20:27:12 644C74FC96FB068005ABDBD309263018 119808 ----a-r- C:\Users\Peter\AppData\Roaming\Microsoft\Installer\{CCF298AF-9CE1-4B26-B251-486E98A34789}\icons.exe
2013-12-30 20:11:10 3C2A9F3195CDDD8943971DC8A677EF25 294912 ----a-w- C:\Windows\Temp\bcdedit.exe
2013-12-30 19:40:46 AF911BE206423BF440EA9D4DF075A632 2721168 ----a-w- C:\Users\Peter\Downloads\W8x86x64 act NL\Windows7-USB-DVD-tool.exe
2013-12-30 18:00:03 CA0A340ABCF0C14A09691CBC90186AB4 51080 ----atw- C:\Program Files\Google\Update\1.3.22.3\GoogleUpdateBroker.exe
2013-12-30 18:00:03 C98E0215F7B65F0DDEE0591BD57EDFA6 847128 ----a-w- C:\Program Files\Google\Update\1.3.22.3\GoogleUpdateSetup.exe
2013-12-30 18:00:03 600B1A4BCC0823A96DC7B86F005ADBB8 51080 ----atw- C:\Program Files\Google\Update\1.3.22.3\GoogleUpdateOnDemand.exe
2013-12-30 17:59:59 9CCBA5E2489E603BB1578D1D541252A8 273800 ----atw- C:\Program Files\Google\Update\1.3.22.3\GoogleCrashHandler64.exe
2013-12-30 17:59:58 506708142BC63DABA64F2D3AD1DCD5BF 116648 ----atw- C:\Program Files\Google\Update\1.3.22.3\GoogleUpdate.exe
2013-12-30 17:59:58 465680BDE344CE4FF6646626AA3A9125 223112 ----atw- C:\Program Files\Google\Update\1.3.22.3\GoogleCrashHandler.exe
2013-12-30 17:59:55 C98E0215F7B65F0DDEE0591BD57EDFA6 847128 ----a-w- C:\Program Files\Google\Update\Download\{430FD4D0-B729-4F61-AA34-91526481799D}\1.3.22.3\GoogleUpdateSetup.exe
2013-12-30 17:54:58 5D61BE7DB55B026A5D61A3EED09D0EAD 39408 ----a-w- C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
2013-12-30 17:54:56 5D4BC124FAAE6730AC002CDB67BF1A1C 194032 ----a-w- C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
2013-12-30 17:54:54 9951192EACEAA79DCE5E77E785C1AA55 400464 ----a-w- C:\Program Files\Google\Google Toolbar\GoogleToolbarUser_64.exe
2013-12-30 17:54:54 1ACCA74287FE5D7449FBB2B9F0C83341 309328 ----a-w- C:\Program Files\Google\Google Toolbar\GoogleToolbarUser_32.exe
2013-12-30 17:54:52 9951192EACEAA79DCE5E77E785C1AA55 400464 ----a-w- C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarUser_64_C22F1A733501EA96.exe
2013-12-30 17:54:52 4BEAF576CB43358C4DB9F45AC7C09CDB 194032 ----a-w- C:\Program Files\Google\Google Toolbar\Component\GoogleUpdaterService_B33FC4DD36A473C6.exe
2013-12-30 17:54:52 4B78E9AE06F7C310E30EE2FA5B7EBC3C 1721296 ----a-w- C:\Program Files\Google\Google Toolbar\Component\SearchWithGoogleUpdate_C993F490EED40C1B.exe
2013-12-30 17:54:52 1F2AFAB903C0D48480561F3BBD4539C2 739640 ----a-w- C:\Program Files\Google\Google Toolbar\Component\GoogleUpdateSetup_5CC4B0F53D73AD88.exe
2013-12-30 17:54:52 1ACCA74287FE5D7449FBB2B9F0C83341 309328 ----a-w- C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarUser_32_D053C89A9DB0461F.exe
2013-12-30 17:54:51 228A4633D638F7EEA6400D5ED5274397 1071696 ----a-w- C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarManager_231F3FD17DB59CFD.exe
2013-12-30 17:54:49 107FE627D4FCAEEEA44048529AA8FAE9 5030880 ----a-w- C:\Program Files\Google\Update\Download\{F69EABDD-A4BB-4555-BE7E-1EA5F59BBA24}\0.0.0.0\googletoolbarinstaller_en_signed.exe
2013-12-30 17:54:36 506708142BC63DABA64F2D3AD1DCD5BF 116648 ----atw- C:\Program Files\Google\Update\GoogleUpdate.exe
2013-12-30 17:54:28 A6F8D4FBC12177A75AB4C06D059229B6 784664 ----a-w- C:\Users\Peter\AppData\Local\Apps\2.0\XWBJA1P0.C63\JW5V6M5E.QT5\inst...app_4fe91ede9f9bdca3_0001.0003_fc100576141c6894\GoogleUpdateSetup.exe
2013-12-30 17:54:28 A6F8D4FBC12177A75AB4C06D059229B6 784664 ----a-w- C:\Users\Peter\AppData\Local\Apps\2.0\XWBJA1P0.C63\JW5V6M5E.QT5\clic...exe_4fe91ede9f9bdca3_0001.0003_none_81523f7b64d98436\GoogleUpdateSetup.exe
2013-12-30 17:54:28 2D479A35439E0DFBDBF2FDB6DEE8D49B 10120 ------w- C:\Users\Peter\AppData\Local\Apps\2.0\XWBJA1P0.C63\JW5V6M5E.QT5\inst...app_4fe91ede9f9bdca3_0001.0003_fc100576141c6894\clickonce_bootstrap.exe
2013-12-30 14:11:32 9A2347903D6EDB84C10F288BC0578C1C 388608 ----a-w- C:\Program Files\Trend Micro\Peter.exe
2013-12-30 03:31:57 A692C144F6AE8763D783D7869A205C28 11467424 ----a-w- C:\Windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\DCOFQU9K\BingBarSetup-Partner[1].EXE
2013-12-30 03:31:57 A692C144F6AE8763D783D7869A205C28 11467424 ----a-w- C:\Program Files\Microsoft\BingBar\7.3.124.0oemBingBarSetup-Partner.EXE
2013-12-29 22:58:32 6F3705B2E59AC26FDA582BF5826F9D21 249768 ----a-w- C:\Windows\System32\Wat\WatUX.exe
2013-12-29 22:58:32 353A04C273EC58475D8633E75CCD5604 1343400 ----a-w- C:\Windows\System32\Wat\WatAdminSvc.exe
2013-12-29 19:58:00 C06773BB57A63B3E5F31E1D14F4DDCEB 1573792 ----a-w- C:\Program Files\Registrar Registry Manager\rrLoader.exe
2013-12-29 19:58:00 B1190488BD21F0DD9D408A1F0D09DA80 56224 ----a-w- C:\Program Files\Registrar Registry Manager\rrsec2k.exe
2013-12-29 19:57:59 DE77D7B65548F5595E30B2A11D421E39 722421 ----a-w- C:\Program Files\Registrar Registry Manager\unins000.exe
2013-12-29 19:57:59 7E214E53062974D403ACD0DAE9F58760 5690272 ----a-w- C:\Program Files\Registrar Registry Manager\rr.exe
2013-12-29 19:12:28 06F1872462FBA06615F683CDA1487B4F 3584 ----a-r- C:\Users\Peter\AppData\Roaming\Microsoft\Installer\{121634B0-2F4B-11D3-ADA3-00C04F52DD52}\Icon386ED4E3.exe
2013-12-29 19:12:13 8FF91F846A078660B415D84BBA98A003 79872 ----a-w- C:\Program Files\MSECACHE\WICU3\MsiZapA.exe
2013-12-29 19:12:13 27D4BCC325306B1415A89DE550528E04 94720 ----a-w- C:\Program Files\MSECACHE\WICU3\MsiZapU.exe
2013-12-29 19:12:13 06109701320FB25F00E004110676A6F2 40960 ----a-w- C:\Program Files\MSECACHE\WICU3\msicuu.exe
2013-12-29 18:38:50 18C48414627F5F1C57A8C7CA815E75BD 12288 ----a-w- C:\Windows\System32\TsUsbRedirectionGroupPolicyControl.exe
2013-12-29 18:38:48 321BE3A2C87206B0C85ECD4FA4EBBF54 56320 ----a-w- C:\Windows\System32\TSWbPrxy.exe
2013-12-29 18:38:47 C551B35F71CA76C88112966238821105 317440 ----a-w- C:\Windows\System32\wksprt.exe
2013-12-29 18:38:47 40FF6C636380A87DE3A99F4E348BFDCB 1048064 ----a-w- C:\Windows\System32\mstsc.exe
2013-12-29 18:20:07 1B24EC543ADEA0AFB520B4F104134CBB 1002008 ----a-w- C:\Windows\System32\igxpun.exe
2013-12-29 17:50:10 98CEBCE699DB75E8CBEEF26BFDD86E97 88123800 ----a-w- C:\Windows\System32\MRT.exe
2013-12-29 17:48:51 980B6A5F92B8DB235C4A26728C2BE732 196608 ----a-w- C:\Windows\System32\WUDFHost.exe
2013-12-29 17:47:03 DA1919D896DBD5895E138932AE9E398B 293376 ----a-w- C:\Windows\System32\browserchoice.exe
2013-12-29 17:36:25 9AED8E824CF5FAAB67957EDBC5512060 164864 ----a-w- C:\Program Files\Windows Media Player\wmplayer.exe
2013-12-29 17:21:23 1C45FE48852BF6C4909AA42053E87514 40448 ----a-w- C:\Windows\servicing\GC32\tzupd.exe
2013-12-29 17:10:39 A6EDB44BD5102DADED61A361E9312B15 627712 ----a-w- C:\Program Files\PDFCreator\PDFArchitect\PDFArchitect.exe
2013-12-28 20:24:07 84B4F61F59A421BD85D97B35D194B42B 86016 ----a-w- C:\Windows\unvise32.exe
2013-12-28 12:40:59 4CD1A2CA9A43B8B6112DA61EB8AA72CC 62464 ----a-w- C:\Users\Peter\AppData\Roaming\Spotify\SpotifyLauncher.exe
2013-12-28 12:40:59 4272BB1D2B577D5917DA0AD9954C4A97 5951488 ----a-w- C:\Users\Peter\AppData\Roaming\Spotify\spotify.exe
2013-12-28 12:40:58 61350395623EE95ADB3EEDB4E60F2601 610304 ----a-w- C:\Users\Peter\AppData\Roaming\Spotify\Data\SpotifyHelper.exe
2013-12-28 12:40:58 4860117DA2E6E9B300144902629B09AC 1168896 ----a-w- C:\Users\Peter\AppData\Roaming\Spotify\Data\SpotifyWebHelper.exe
2013-12-28 12:00:49 1B7847BF9F5BB48C324B096279621AF4 55425 ----a-w- C:\Program Files\Flash Movie Player\uninst.exe
2013-12-28 11:57:13 08A9EF527F9A9430511331C5F769D6A9 8704 ----a-w- C:\Program Files\Real\RealPlayer\fixrjb.exe
2013-12-28 11:57:11 777A428B75818F69D378BE3DA655B322 389712 ----a-w- C:\Program Files\Real\RealPlayer\realcleaner.exe
2013-12-28 11:56:58 9C7790D83AC6FA17594166C1C5EFA452 384088 ----a-w- C:\Program Files\Real\RealPlayer\realconverter.exe
2013-12-28 11:56:58 6F9D42211FDA48BF605FDAD2722E9910 355416 ----a-w- C:\Program Files\Real\RealPlayer\convert.exe
2013-12-28 11:56:53 F442CB88716CEC6D3EBFA162D30557C6 389712 ----a-w- C:\Program Files\Real\RealPlayer\realtrimmer.exe
2013-12-28 11:56:53 365785DBFA3E434447225E6A7B878BB1 136784 ----a-w- C:\Program Files\Real\RealPlayer\realshare.exe
2013-12-28 11:56:52 7D4DA2E9DC6007EDCC5196F1983418FA 38482016 ----a-w- C:\Program Files\Real\RealPlayer\Setup\setup.exe
2013-12-28 11:56:50 1DE2837CA85D6E5894E1D7B33B958D9E 30816 ----a-w- C:\Program Files\Real\RealPlayer\rndevicedbbuilder.exe
2013-12-28 11:56:49 F2938D4C70EB1750721AC3C5FF512D5D 9216 ----a-w- C:\Program Files\Real\RealPlayer\realjbox.exe
2013-12-28 11:56:49 641120ED35394672B965D1F6512AE2D8 17528 ----a-w- C:\Program Files\Real\RealPlayer\rphelperapp.exe
2013-12-28 11:56:49 447FC81330CD96CA26459DB2E86C3630 501328 ----a-w- C:\Program Files\Real\RealPlayer\realplay.exe
2013-12-28 11:56:48 F6158734F1E24C6C510155CF0D363911 295512 ----a-w- C:\Program Files\Real\RealPlayer\Update\realsched.exe
2013-12-28 11:56:48 875531C152C5F658196226C7FDB80480 186480 ----a-w- C:\Program Files\Real\RealPlayer\Update\upgrdhlp.exe
2013-12-28 11:56:48 743A7F2C704AAB87445EA763B405EA75 83072 ----a-w- C:\Program Files\Real\RealPlayer\Update\realonemessagecenter.exe
2013-12-28 11:56:48 6E8A9D3EF552ABF757ED6C4DB9DADB96 579208 ----a-w- C:\Program Files\Real\RealPlayer\Update\r1puninst.exe
2013-12-28 11:56:48 521CA4CFD59E2C3C77B38B4EFCF62451 68216 ----a-w- C:\Program Files\Real\RealPlayer\Update\rnxproc.exe
2013-12-28 11:54:50 F5F17DDD84E5AC1DB954470EF3065F8E 228217 ----a-w- C:\Program Files\VideoLAN\VLC\uninstall.exe
2013-12-28 11:31:00 3091476D67A18F4FCF2A7396DF49C0B6 7403280 ----a-w- C:\Program Files\ToolwizCareFree\UninstallToolwizCare.exe
2013-12-28 11:30:59 F3EFB821E45339F49C97C6DA7452A5FE 7545104 ----a-w- C:\Program Files\ToolwizCareFree\ToolwizTools.exe
2013-12-28 11:30:59 CC6FA1E1A87A9D120BBFA89087FC1BF1 5286160 ----a-w- C:\Program Files\ToolwizCareFree\ToolwizCares.exe
2013-12-28 11:15:37 606B7DD349DE9607E0C74939FE5C2EDB 88542 ----a-w- C:\Windows\System32\Adobe\Shockwave 12\uninstaller.exe
2013-12-28 10:32:01 9186BC2669CAA16BE6FA07213455E977 715038 ----a-w- C:\Program Files\PIXresizer\unins000.exe
2013-12-28 10:32:01 6F9579C1FF495753F1718985F44A0CF0 434176 ----a-w- C:\Program Files\PIXresizer\PIXresizer.exe
2013-12-28 09:18:01 8911702CC546B76FE8F9C61987C68C43 222720 ----a-w- C:\Program Files\Internet Explorer\ielowutil.exe
2013-12-28 09:18:01 825E01EEC25E744FBCFB92F07FF411EE 307200 ----a-w- C:\Program Files\Internet Explorer\iediagcmd.exe
2013-12-28 09:18:01 73C8D00A87332F2DF0A7CFF87CEE1A82 107008 ----a-w- C:\Program Files\Internet Explorer\iecleanup.exe
2013-12-28 09:18:01 512C7881C3F7836455ADC9EBF0A0B167 22016 ----a-w- C:\Program Files\Internet Explorer\ExtExport.exe
2013-12-28 09:18:01 43E6F2A7FB182F2D7CB0CE5B8F1005CF 757488 ----a-w- C:\Program Files\Internet Explorer\iexplore.exe
2013-12-28 09:18:01 3348D1B1D702E333CE99F7E0FD313460 468480 ----a-w- C:\Program Files\Internet Explorer\ieinstal.exe
2013-12-28 09:14:46 5BE3E7E2D1C175097E6E78BFEE0EF03F 190464 ----a-w- C:\Program Files\eysy photo effects\epe.exe
2013-12-28 09:08:17 E6E88ABAC59F97D336888335E0B2DDC5 1314755 ----a-w- C:\Program Files\Picture Collage Maker Pro\unins000.exe
2013-12-28 09:08:17 170C35AB431EB09FF17EC9DF20A254CA 5266264 ----a-w- C:\Program Files\Picture Collage Maker Pro\PictureCollageMakerPro.exe
2013-12-28 08:21:31 CCCE51A85D1BA455FC789EFF3A9CF97B 1613824 ----a-w- C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\POPPeeper.exe
2013-12-28 08:16:54 31438C1D7438599E53F5A8A5855FDBC1 38856244 ----a-w- C:\Users\Peter\Downloads\Foxit Advanced PDF Editor v4.1.5 Incl Crack [TorDigger]\File Extractor - Foxit Advanced PDF Editor v4.1.5 Incl Crack [TorDigger].exe
2013-12-28 07:36:24 45F3BBDEE0D858D12DBC5887AAAF371E 988160 ----a-w- C:\Program Files\Speaking Clock\spclock.exe
2013-12-28 07:36:24 2BC0FCA6F2C3505619AAE1A12CA69B00 695578 ----a-w- C:\Program Files\Speaking Clock\unins000.exe
2013-12-28 07:12:05 CFB60A58672DF113FCBF39E4F560DE06 720373 ----a-w- C:\Program Files\PDF to Word Free\unins000.exe
2013-12-28 07:12:05 0FD69ED0754AF43C41A9F1EC35B35FC3 6184448 ----a-w- C:\Program Files\PDF to Word Free\PDFtoWordFree.exe
2013-12-28 07:04:28 EE0381F4DBCEB66481D6E9000ACF7B96 162976 ----a-w- C:\Program Files\PDFCreator\Images2PDF\Images2PDFC.exe
2013-12-28 07:04:28 BA7ED01015E6A3326677D01642BC80E3 306856 ----a-w- C:\Program Files\PDFCreator\DeleteMonitorDll.exe
2013-12-28 07:04:28 4875CDECE9C259F78A64D71BE18C4B89 720032 ----a-w- C:\Program Files\PDFCreator\Images2PDF\Images2PDF.exe
2013-12-28 07:04:26 9580B76B54E62CDF2A19D142C39B1BFB 622592 ----a-w- C:\Program Files\PDFCreator\languages\TransTool.exe
2013-12-28 07:04:26 513225B0D601484CE06453D9D82400B2 3182592 ----a-w- C:\Program Files\PDFCreator\PDFCreator.exe
2013-12-28 07:04:24 1EA291DFE6D5258F5165606CCDD2F14A 719280 ----a-w- C:\Program Files\PDFCreator\unins000.exe
2013-12-28 06:52:46 F2E4CB21697892C7AE918E22177DEA99 2838016 ----a-w- C:\Program Files\photo filter\PhotoFiltre.exe
2013-12-28 06:51:48 E60265B2C6ACCC178A421296774B28D0 4021248 ----a-w- C:\Program Files\Photo Effects Studio\EStudio.exe
2013-12-28 06:51:48 40D0FC98677E11D91B39A1AB3CDBB78B 695578 ----a-w- C:\Program Files\Photo Effects Studio\unins000.exe
2013-12-28 06:49:37 F74D839DB0122194B95C7DDB9DF2566A 20480 ----a-w- C:\Users\Peter\Desktop\KompoZer\xpt_dump.exe
2013-12-28 06:49:37 D65200BB925BB687882D583EC6A67DD0 8704 ----a-w- C:\Users\Peter\Desktop\KompoZer\regxpcom.exe
2013-12-28 06:49:37 D637825574FA39AB015BE438BECD7EAF 40960 ----a-w- C:\Users\Peter\Desktop\KompoZer\shlibsign.exe
2013-12-28 06:49:37 CBDA7FE1E77BB14263741705D7660533 73728 ----a-w- C:\Users\Peter\Desktop\KompoZer\xpicleanup.exe
2013-12-28 06:49:37 9EDD3E768AEBA20AF9BB029A7B87BA44 1184617 ----a-w- C:\Users\Peter\Desktop\KompoZer\unins000.exe
2013-12-28 06:49:37 9C0A51C57057517D91442AAE42515498 4608 ----a-w- C:\Users\Peter\Desktop\KompoZer\mangle.exe
2013-12-28 06:49:37 99BC58975A874A3619DF2D16082921D2 135168 ----a-w- C:\Users\Peter\Desktop\KompoZer\updater.exe
2013-12-28 06:49:37 7EB8E665516921A0447AC86EE7EB1D5B 417792 ----a-w- C:\Users\Peter\Desktop\KompoZer\kompozer.exe
2013-12-28 06:49:37 7CCF8CC9F4A33C44A3DEE6D005A51F98 16896 ----a-w- C:\Users\Peter\Desktop\KompoZer\xpt_link.exe
2013-12-28 06:49:37 7597B36AB936B2D1975551912858A1DB 13824 ----a-w- C:\Users\Peter\Desktop\KompoZer\xpcshell.exe
2013-12-28 06:49:37 49B0839632E537E64E0DCB24E9059B9A 69632 ----a-w- C:\Users\Peter\Desktop\KompoZer\xpidl.exe
2013-12-28 06:48:50 183D2818EC66601A70923BBF237520B9 974848 ----a-w- C:\Program Files\Noiseware Professional Edition\NoisewarePro.exe
2013-12-28 06:46:54 8CF1CF6218D4DE8EB67E8DDEA95BC96D 1177453 ----a-w- C:\Program Files\FotoSketcher\unins000.exe
2013-12-28 06:46:54 46893070B52A533197B9DE2409D864B0 4995584 ----a-w- C:\Program Files\FotoSketcher\FotoSketcher.exe
2013-12-28 06:44:59 F6603E5F261CD9A8EA24B328104FDBF2 35572 ----a-w- C:\Program Files\FastStone Photo Resizer\uninst.exe
2013-12-28 06:44:58 5A40A0DB81385C4BC6E64AAEA307DEF8 1399296 ----a-w- C:\Program Files\FastStone Photo Resizer\FSResizer.exe
2013-12-28 06:43:21 EC4FFB70D5BD1DCD2C66D54FE63D155B 917504 ----a-w- C:\Program Files\Easy Graphic Converter\ImageConverter.exe
2013-12-28 06:43:21 511F1D92A73345258A5050A400D608E8 72748 ----a-w- C:\Program Files\Easy Graphic Converter\unins000.exe
2013-12-28 06:43:21 4DB1D4D1814CC199987F8BCA0709AFDC 231936 ----a-w- C:\Program Files\Easy Graphic Converter\option.exe
2013-12-28 06:37:41 FE5F2FF1788EE2D6826C5C27830CFA3D 3030528 ----a-w- C:\Program Files\Cool Timer\cooltimer.exe
2013-12-28 06:37:41 48198DE5419956F1C1E662DD9D8B06C0 715253 ----a-w- C:\Program Files\Cool Timer\unins000.exe
2013-12-28 06:29:41 F3916424AB488FF49BBB91C0196565BA 663552 ----a-w- C:\Program Files\Clipboard Magic\ClipboardMagic.exe
2013-12-28 06:29:41 E79F056339163A89ECBBA4399048FF7D 707880 ----a-w- C:\Program Files\Clipboard Magic\unins000.exe
2013-12-28 06:18:35 6B157ADB735413FA7E2A532C01FAD814 173376 ----a-w- C:\Program Files\Easeware\DriverEasy\x64\Easeware.DriverInstall.exe
2013-12-28 06:18:20 2FE53EE9FF0EDC993D62F3761BDA5115 2988960 ----a-w- C:\Users\Peter\AppData\Roaming\Easeware\DriverEasy\updates\4.6.3.3060\DriverEasy_Setup.exe
2013-12-28 06:18:05 C56EAF74C36F48AAAAA225FA98068303 12096 ----a-w- C:\Program Files\Easeware\DriverEasy\Easeware.CheckingDevice.exe
2013-12-28 06:18:05 8296B77A2CF1F8926E58988BCF0D51A3 38720 ----a-w- C:\Program Files\Easeware\DriverEasy\Easeware.CheckScheduledScan.exe
2013-12-28 06:18:05 4E69E72CFFD9B0B06CCEA4B6FDAD0526 2725696 ----a-w- C:\Program Files\Easeware\DriverEasy\DriverEasy.exe
2013-12-28 06:18:05 41D4623282D76173CC79BF6026829B1C 173888 ----a-w- C:\Program Files\Easeware\DriverEasy\Easeware.DriverInstall.exe
2013-12-28 06:18:05 267E6910E9FD81E5B174440D0535BA20 1160512 ----a-w- C:\Program Files\Easeware\DriverEasy\unins000.exe
2013-12-28 06:18:05 1EF1C1EDC4368D15C8A67C09C150B163 252736 ----a-w- C:\Program Files\Easeware\DriverEasy\UnRAR.exe
2013-12-28 06:18:05 175CE3B32F6BCA13152F1D384FCD2958 515392 ----a-w- C:\Program Files\Easeware\DriverEasy\Easeware.PatchInstall.exe
2013-12-28 06:13:12 FAE4F630AE2B5AECFD0E237A34E9FE63 14808 ----a-w- C:\Program Files\Java\jre8\bin\ktab.exe
2013-12-28 06:13:12 EA6F418FCCF2D243B7B117CA94ED6153 14808 ----a-w- C:\Program Files\Java\jre8\bin\rmiregistry.exe
2013-12-28 06:13:12 DD86DBE425D7CB2448576712A82CBF04 14808 ----a-w- C:\Program Files\Java\jre8\bin\klist.exe
2013-12-28 06:13:12 DA08133CC340598C3DFFAC06E12243DD 14808 ----a-w- C:\Program Files\Java\jre8\bin\policytool.exe
2013-12-28 06:13:12 D84F7E71519DCC5B37B8E3193CA12B73 14808 ----a-w- C:\Program Files\Java\jre8\bin\pack200.exe
2013-12-28 06:13:12 CC99A56073F2B752C13D43AE4604F3E8 14808 ----a-w- C:\Program Files\Java\jre8\bin\orbd.exe
2013-12-28 06:13:12 CA9398465C43495AED12879659FDC7CA 175064 ----a-w- C:\Program Files\Java\jre8\bin\javaw.exe
2013-12-28 06:13:12 C341A655448607010E58047DDE745657 14808 ----a-w- C:\Program Files\Java\jre8\bin\java-rmi.exe
2013-12-28 06:13:12 B78EBA7CEF132DB1716C618A0F174E0E 161752 ----a-w- C:\Program Files\Java\jre8\bin\jqs.exe
2013-12-28 06:13:12 A128B985B66DADA43D2BC01B02CE444A 36312 ----a-w- C:\Program Files\Java\jre8\bin\jp2launcher.exe
2013-12-28 06:13:12 981B919CBA3A960D4FB20936F8AADB04 14808 ----a-w- C:\Program Files\Java\jre8\bin\keytool.exe
2013-12-28 06:13:12 84175B299F336B41F3932DC2FC46049A 14808 ----a-w- C:\Program Files\Java\jre8\bin\servertool.exe
2013-12-28 06:13:12 81FE90943FD78BF3C3BFDFE37E9A0F85 155096 ----a-w- C:\Program Files\Java\jre8\bin\unpack200.exe
2013-12-28 06:13:12 72D8AA8708823C0F7282B5DAD973F39A 66008 ----a-w- C:\Program Files\Java\jre8\bin\javacpl.exe
2013-12-28 06:13:12 47424A9CC9B334A2192FD30C9CB8C034 175064 ----a-w- C:\Program Files\Java\jre8\bin\java.exe
2013-12-28 06:13:12 371FDD6B1784BE0A46626E9369992027 14808 ----a-w- C:\Program Files\Java\jre8\bin\rmid.exe
2013-12-28 06:13:12 1FF367432C2825787A3C6A2175FE60A0 244184 ----a-w- C:\Program Files\Java\jre8\bin\javaws.exe
2013-12-28 06:13:12 162DF218AA60C68695D04B874364C217 14808 ----a-w- C:\Program Files\Java\jre8\bin\kinit.exe
2013-12-28 06:13:12 10E00FD0219EBE52808EBC4E4E6E5DEF 47064 ----a-w- C:\Program Files\Java\jre8\bin\ssvagent.exe
2013-12-28 06:13:12 03F76381F1AD2CE69B2CEE43A91FC823 15320 ----a-w- C:\Program Files\Java\jre8\bin\tnameserv.exe
2013-12-28 05:42:57 45D04F1309C5D1DC172F139A89D90E66 1635512 ----a-w- C:\Program Files\FreeFileViewer\FFVCheckForUpdates.exe
2013-12-28 05:42:56 E927477AAFDA33E0B4E0409E0FD257AD 12353840 ----a-w- C:\Program Files\FreeFileViewer\FreeFileViewer.exe
2013-12-28 05:42:56 8DA0FC0EFA4AD3CE27727ECFE5A9B751 710008 ----a-w- C:\Program Files\FreeFileViewer\unins000.exe
2013-12-28 05:42:56 7781EC8047344A919AFE45175F0236C6 2831224 ----a-w- C:\Program Files\FreeFileViewer\FFVCFG.exe
2013-12-28 05:28:17 2A27ECBFBD818CF2389B15615F9F8075 695642 ----a-w- C:\Program Files\Beauty Pilot2\unins000.exe
2013-12-28 05:28:17 166AD7B1C596D20FB10694FC41F7E750 685056 ----a-w- C:\Program Files\Beauty Pilot2\BeautyPilot.exe
2013-12-28 05:27:50 F917DB7052F8147B301AA6F00F7AEBE1 1293824 ----a-w- C:\Program Files\Beauty Pilot\BeautyPilot.exe
2013-12-28 05:27:50 4D5E5ADE0EE7A2942DE837723CFFE15A 77261 ----a-w- C:\Program Files\Beauty Pilot\unins000.exe
2013-12-28 05:13:05 CCCE51A85D1BA455FC789EFF3A9CF97B 1613824 ----a-w- C:\Users\Peter\Desktop\delen\POP Peeper\POPPeeper.exe
2013-12-28 05:13:05 68392A19E5D5A30CED983F15198C1AAB 46708 ----a-w- C:\Users\Peter\Desktop\delen\POP Peeper\Uninstall.exe
2013-12-28 05:12:59 7F1F1E05A30A027583FF3406F48A4690 640957 ----a-w- C:\Users\Peter\Desktop\delen\Clipboard Magic\unins000.exe
2013-12-28 05:12:58 031FCFF4E1602352A7DD500115E1D3FB 7619344 ----a-w- C:\Users\Peter\Desktop\delen\Setup_ToolwizCare.exe
2013-12-28 05:11:01 CCCE51A85D1BA455FC789EFF3A9CF97B 1613824 ----a-w- C:\Program Files\POP Peeper\POPPeeper.exe
2013-12-28 05:11:01 68392A19E5D5A30CED983F15198C1AAB 46708 ----a-w- C:\Program Files\POP Peeper\Uninstall.exe
2013-12-28 04:33:27 8682971643FF77E31F069D043B858179 69632 ----a-w- C:\Users\Peter\Downloads\Windows 7 Anytime Upgrade Keygen\Windows 7 Anytime Upgrade Keygen.exe
2013-12-28 04:05:08 BEF1E6A9B97045EC3F2B9CF34ACB6810 121064 ----a-w- C:\Program Files\InstallShield Installation Information\{235674B0-A35F-4811-8A8F-E8F42A919EA3}\setup.exe
2013-12-28 04:05:02 D186D961E211E4FD7F7C3A02A864CBE5 5632 ----a-w- C:\Program Files\Common Files\InstallShield\Professional\RunTime\11\00\Intel32\DotNetInstaller.exe
2013-12-28 04:04:54 8D699C26857440661FAD1AED839FFC79 393216 ----a-w- C:\Program Files\InstallShield Installation Information\{BE2ED609-7C07-4F6B-8E83-3800F8A133D6}\setup.exe
2013-12-28 03:21:35 F08B216C9C1B508C6B0C885F67EA54D1 1065077 ----a-w- C:\Program Files\Common Files\Adobe\Workflow\AdobeWorkgroupHelper.exe
2013-12-28 03:21:10 F48B6A552716034398C97E2B8C9B67C7 46325 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\ImageReady druppels\Onscherp masker.exe
2013-12-28 03:21:10 EFBA2B7A2FA2D807306E62E7FA88167A 127959 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\Photoshop druppels\Beperken tot 64 pixels.exe
2013-12-28 03:21:10 E9B9A082B315DD8894B30BCAA89C4EEE 46366 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\ImageReady druppels\JPEG maken (kwaliteit 60).exe
2013-12-28 03:21:10 E836A1E3AA33F7BB8616BC9125749270 128219 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\Photoshop druppels\Opslaan als Photoshop PDF.exe
2013-12-28 03:21:10 D38EBB027F12CA35CAB94B6022222FBF 128219 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\Photoshop druppels\Opslaan als JPEG Normaal.exe
2013-12-28 03:21:10 C36AC2B789D61A0F08055E892A28B376 48021 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\ImageReady druppels\Knop maken.exe
2013-12-28 03:21:10 BCCE0C013434C6C147204F0A93156694 46573 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\ImageReady druppels\GIF maken (64 kleuren).exe
2013-12-28 03:21:10 B1FDF59DBE05CD026BB85B65C75CB6FA 127937 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\Photoshop druppels\Condit modus wijzigen.exe
2013-12-28 03:21:10 AD569C4A6E384247C9BCC2083FB0BECD 46511 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\ImageReady druppels\GIF maken (32, geen raster).exe
2013-12-28 03:21:10 8C4901CEA8A026187BBBC78D3495F3D8 129514 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\Photoshop druppels\Knop maken.exe
2013-12-28 03:21:10 5AF6DC6E8AFDE532AA9518DC70117F0E 129003 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\Photoshop druppels\Oude foto.exe
2013-12-28 03:21:10 51A0C3B4316C9281C14811DE506D9F7D 46365 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\ImageReady druppels\JPEG maken (kwaliteit 30).exe
2013-12-28 03:21:10 4A3F249E996D7D8FCB9ED67BA4EBA23C 46366 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\ImageReady druppels\JPEG maken (kwaliteit 10).exe
2013-12-28 03:21:10 453ED1A6FF6F1EE2F55EA9C234BD7882 48445 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\ImageReady druppels\Opslaan in meer grootten.exe
2013-12-28 03:21:10 211A4BEAB5BEBBDF64E5140011D45407 128381 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\Photoshop druppels\Sepiatoon maken.exe
2013-12-28 03:21:10 102EAEBFB7192194A8E8CEE9BF0A4C4C 132548 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\Photoshop druppels\Slagschaduwkader.exe
2013-12-28 03:21:10 01594FD161AF135DE971F4429D14B7A8 127959 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\Photoshop druppels\Beperken tot 300 pixels.exe
2013-12-28 03:21:09 E2A8C7536578161B52898CBDCEE64DB1 46215 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\ImageReady druppels\Beperken tot 200x200 pixels.exe
2013-12-28 03:21:09 CC40123A9B0C8E13C697E6450F9CB65A 46575 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\ImageReady druppels\GIF maken (128 kleuren).exe
2013-12-28 03:21:09 9EBFCD9177499047AD800FA2CA4DDC8B 46646 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\ImageReady druppels\Beperken 350, Maken JPG 30.exe
2013-12-28 03:21:09 607329A4E981CC9CF4DDD8943B09E0E4 46215 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Voorbeelden\Druppels\ImageReady druppels\Beperken tot 64X64 pixels.exe
2013-12-28 03:20:51 5CD0CD0EC4DC5DF459B3AC016764F5AA 110592 ----a-w- C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
2013-12-28 03:20:39 BF988C1AB7C0FB7E9AA2844725007128 117248 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Required\Droplet Template.exe
2013-12-28 03:20:27 52E2BBFB1BB0B06AFDA1FAA185610FEB 15900672 ----a-w- C:\Program Files\Adobe\Photoshop 7.0\Photoshop.exe
2013-12-28 03:17:42 2301304260456CAB0F9BF2083F6ADB56 327168 ----a-w- C:\Windows\IsUn0413.exe
2013-12-28 03:08:27 D2767CB08B232CBE00665E369A2DD6C8 120568 ------w- C:\Program Files\Common Files\PX Storage Engine\pxcpyi64.exe
2013-12-28 03:08:27 94760C6B1343795E9B14BBDDC20F7051 72176 ------w- C:\Program Files\Common Files\PX Storage Engine\pxhpinst.exe
2013-12-28 03:08:27 834472C432A348CD36163F092274C186 118256 ------w- C:\Program Files\Common Files\PX Storage Engine\pxinsi64.exe
2013-12-28 03:08:27 6E22355EE8B0E3E1173552FFCDE3AEB1 66296 ------w- C:\Program Files\Common Files\PX Storage Engine\pxcpya64.exe
2013-12-28 03:08:27 450EC871793F2289F23972F637192264 65008 ------w- C:\Program Files\Common Files\PX Storage Engine\pxinsa64.exe
2013-12-28 01:11:57 00265ABBB558589A83DF1B6C8B941DE1 3092640 ----a-w- C:\Users\Peter\Desktop\Allerlei\van alles\flashplayer10_3r183_20_win.exe
2013-12-28 01:11:44 673179E0F6A3A887C6E93869AB7DA658 21832280 ----a-w- C:\Users\Peter\Desktop\Allerlei\Firefox Setup 21.0(1).exe
2013-12-28 00:27:33 FD634486006D1B13C51C3848E9C3F364 648608 ----a-w- C:\Program Files\Microsoft Office\Office10\MSTORDB.EXE
2013-12-28 00:27:33 963B0DE72B3C6DD3BD3054C93EB2BBC7 103840 ----a-w- C:\Program Files\Microsoft Office\Office10\MSTORE.EXE
2013-12-28 00:27:33 5BC65464354A9FD3BEAA28E18839734A 83360 ----a-w- C:\Program Files\Microsoft Office\Office10\OSA.EXE
2013-12-28 00:27:33 3DEEA1C5985B84CB91FC983C2B0BD98F 218528 ----a-w- C:\Program Files\Microsoft Office\Office10\PROFLWIZ.EXE
2013-12-28 00:27:32 5CA495CF5A4BB6CEED28B9484069EBB1 226720 ----a-w- C:\Program Files\Microsoft Office\Office10\MSOFFICE.EXE
2013-12-28 00:27:32 4CC64A0212B751D68A1D31A56D7D0DAE 856155 ----a-w- C:\Program Files\Microsoft Office\Office10\MCDLC.EXE
2013-12-28 00:27:32 279C76AA39EF0502BAC51ADABA26559C 2143648 ----a-w- C:\Program Files\Microsoft Office\Office10\GRAPH.EXE
2013-12-28 00:27:32 10A8C11043DEA8C29BD25C2F73C37FA2 66976 ----a-w- C:\Program Files\Microsoft Office\Office10\MSOHTMED.EXE
2013-12-27 22:45:11 A7569CDF60DB586EC255EF9FFE311498 1433200 ----a-w- C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Ditto.exe
2013-12-27 22:35:12 E08BEA6C78E35C75696AB6FE5ABF94A7 458752 ----a-w- C:\Users\Peter\AppData\Local\Media Get LLC\MediaGet2\openvpn\openvpn.exe
2013-12-27 22:35:12 D1B6303856C0BD48190CB0B4B1FA7F5F 77824 ----a-w- C:\Users\Peter\AppData\Local\Media Get LLC\MediaGet2\openvpn\tapinstall.exe
2013-12-27 22:30:35 DF6CCF632A1BDB8717D75B64DE84039F 94440 ----a-w- C:\Users\Peter\AppData\Local\MediaGet2\mediaget-admin-proxy.exe
2013-12-27 22:30:35 4BB18C657B11C17124D845DD2793C91B 11738856 ----a-w- C:\Users\Peter\AppData\Local\MediaGet2\mediaget.exe
2013-12-27 22:30:34 45B75BC1526A0E7CE70EDA841055CB4E 115432 ----a-w- C:\Users\Peter\AppData\Local\MediaGet2\mediaget-uninstaller.exe
2013-12-27 21:30:21 A7569CDF60DB586EC255EF9FFE311498 1433200 ----a-w- C:\Program Files\Ditto\Ditto.exe
2013-12-27 21:30:21 9E6CBE09CBE997B2F969A1CA7118F281 1177437 ----a-w- C:\Program Files\Ditto\unins000.exe
2013-12-27 21:04:56 C82A6D1E1CEB24A963C5CA20B574B78F 1340496 ----a-w- C:\Users\Peter\AppData\Roaming\uTorrent\updates\3.3.2_30446.exe
2013-12-27 21:04:55 C82A6D1E1CEB24A963C5CA20B574B78F 1340496 ----a-w- C:\Users\Peter\AppData\Roaming\uTorrent\uTorrent.exe
=== C: other files ==
2013-12-29 19:58:00 E073E3C1CE604304351B34B5176B84BE 25504 ----a-w- C:\Program Files\Registrar Registry Manager\rspRegMon64.sys
2013-12-29 19:58:00 0725EFC1F93DB38F250E99FA7D6EE78C 25632 ----a-w- C:\Program Files\Registrar Registry Manager\rspRegMon32.sys
2013-12-29 18:38:50 E951866BAC5A23403F62A349EDBB6EEB 24064 ----a-w- C:\Windows\System32\DriverStore\FileRepository\termmou.inf_x86_neutral_0e28c761f9ae155a\terminpt.sys
2013-12-29 18:38:50 E951866BAC5A23403F62A349EDBB6EEB 24064 ----a-w- C:\Windows\System32\DriverStore\FileRepository\termkbd.inf_x86_neutral_339f71420b21f4a1\terminpt.sys
2013-12-29 18:38:49 57C527AF84748B5C2F5178C499C0B81F 27136 ----a-w- C:\Windows\System32\DriverStore\FileRepository\tsgenericusbdriver.inf_x86_neutral_93ae7b205b7d38be\TsUsbGD.sys
2013-12-29 17:24:16 C44206971082446BA8E9A19A35D41424 30208 ----a-w- C:\Windows\System32\DriverStore\FileRepository\netrndis.inf_x86_neutral_0b46e86f0f566f5a\rndismp6.sys
2013-12-29 17:24:16 94617EC3A62336151C039E15A2945042 33280 ----a-w- C:\Windows\System32\DriverStore\FileRepository\netrndis.inf_x86_neutral_0b46e86f0f566f5a\rndismpx.sys
2013-12-29 17:23:49 DDCE686D76C2B4DB435A3AF5BD0E691D 133056 ----a-w- C:\Windows\System32\DriverStore\FileRepository\mshdc.inf_x86_neutral_a5025d31bee4647c\ataport.sys
2013-12-29 17:21:31 C44206971082446BA8E9A19A35D41424 30208 ----a-w- C:\Windows\System32\DriverStore\FileRepository\netrndis.inf_x86_neutral_1c5becb2deac08f0\rndismp6.sys
2013-12-29 17:21:31 BE444D443F424E3146534BA98978D68A 15872 ----a-w- C:\Windows\System32\DriverStore\FileRepository\netrndis.inf_x86_neutral_1c5becb2deac08f0\usb80236.sys
2013-12-29 17:21:31 AF77716205C97E902E6C5B78DECE2CCA 15872 ----a-w- C:\Windows\System32\DriverStore\FileRepository\netrndis.inf_x86_neutral_1c5becb2deac08f0\usb8023x.sys
2013-12-29 17:21:31 94617EC3A62336151C039E15A2945042 33280 ----a-w- C:\Windows\System32\DriverStore\FileRepository\netrndis.inf_x86_neutral_1c5becb2deac08f0\rndismpx.sys
2013-12-29 17:21:13 007C0C8D5B01D82ACEB70431D15083F6 28160 ----a-w- C:\Windows\System32\DriverStore\FileRepository\mdmcpq.inf_x86_neutral_1965855805a8e768\usbser.sys
2013-12-29 17:20:55 FC6B21DB4B5B398AB93DBE59CBF11036 36352 ----a-w- C:\Windows\System32\DriverStore\FileRepository\sti.inf_x86_neutral_24eb5587941b03fb\usbscan.sys
2013-12-29 17:20:55 F1B27299F547D452EDAEF01FC187CB91 25728 ----a-w- C:\Windows\System32\DriverStore\FileRepository\input.inf_x86_neutral_1436b88c77b8881d\hidparse.sys
2013-12-29 17:20:55 50ABE682EBE752EAF62B18790D6D491C 55808 ----a-w- C:\Windows\System32\DriverStore\FileRepository\input.inf_x86_neutral_1436b88c77b8881d\hidclass.sys
2013-12-29 17:20:48 8ACB33EF85F9EA87D18FECEAD593A255 2349056 ----a-w- C:\Windows\System32\win32k.sys
2013-12-29 17:20:43 EB6137D696A9B4E9718AC6F8641CB4C9 177152 ----a-w- C:\Windows\System32\DriverStore\FileRepository\wdmaudio.inf_x86_neutral_df2ea65e936720f7\portcls.sys
2013-12-29 17:20:43 9842041E2F5ACE1E2F5FB4EF02053DC8 81408 ----a-w- C:\Windows\System32\DriverStore\FileRepository\wdmaudio.inf_x86_neutral_df2ea65e936720f7\drmk.sys
2013-12-29 17:05:43 DE014425522610BEDCA3821BB8C0F1D5 146816 ----a-w- C:\Windows\System32\DriverStore\FileRepository\usbvideo.inf_x86_neutral_b63436395ec126b7\usbvideo.sys
2013-12-29 17:05:43 A1977C315BF5691DA99235AA4A6907AF 80896 ----a-w- C:\Windows\System32\DriverStore\FileRepository\wdma_usb.inf_x86_neutral_8583111d879ac65d\USBAUDIO.sys
2013-12-29 17:05:43 2352AB5F9F8F097BF9D41D5A4718A041 86016 ----a-w- C:\Windows\System32\DriverStore\FileRepository\usbcir.inf_x86_neutral_1a7503cad201feda\usbcir.sys
2013-12-29 16:21:01 6C669DC80D35A563E07AFF9D90E86B50 53101 ----a-w- C:\Users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\yesscript@userstyles.org.xpi
2013-12-29 01:13:10 24DD89B8F590D9350C8CD3398980676F 81983 ----a-w- C:\Users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\multirevenue@googlemail.com.xpi
2013-12-28 21:33:45 74E4914A3324043CBAE4A5D9F9B4E1BA 6153 ----a-w- C:\Users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\{a949831f-d9c0-45ae-8c60-91c2a86fbfb6}.xpi
2013-12-28 21:33:41 F26BB70CAA2BBFA562441EE7A6D6FB88 18609 ----a-w- C:\Users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\{b9bfaf1c-a63f-47cd-8b9a-29526ced9060}.xpi
2013-12-28 12:40:59 3879837360740D2BB17334F384024115 9204072 ----a-w- C:\Users\Peter\AppData\Roaming\Spotify\Data\apps.zip
2013-12-28 12:40:58 65D9E08F597DC2022FA8191BFAE93A5A 2708120 ----a-w- C:\Users\Peter\AppData\Roaming\Spotify\Data\resources.zip
2013-12-28 11:24:34 3FE51813290A0D7103B620E2813A8C0E 915554 ----a-w- C:\Users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\{d10d0bf8-f5b5-c8b4-a8b2-2b9879e08c5d}.xpi
2013-12-28 11:24:00 DC20D9BE4B74151D7EB74E4DE0772E72 39512 ----a-w- C:\Users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\{b1df372d-8b32-4c7d-b6b4-9c5b78cf6fb1}.xpi
2013-12-28 11:00:09 AB95CF719BCE5E3009D4DA8ABFC0905D 21645 ----a-w- C:\Users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\openinie@wittersworld.com.xpi
2013-12-28 10:46:32 68E9723F04EBDEEA4ED6EC11C97D67C6 223615 ----a-w- C:\Users\Peter\AppData\Roaming\Easeware\DriverEasy\drivers\2kmmyyh2.rm3\win_b57_32-15.6.0.10.zip
2013-12-28 10:45:16 1207AADC1508C63D4434190312661D29 139336 ----a-w- C:\Users\Peter\AppData\Roaming\Easeware\DriverEasy\drivers\vbayks4w.bh1\R144930.zip
2013-12-28 07:04:27 FE82CC07F21FCC4769FFAF71083FC3C7 1206 ----a-w- C:\Program Files\PDFCreator\Scripts\RunProgramAfterSaving\SayIt.vbs
2013-12-28 07:04:27 FA5429E1B5E5959BF92D66AEC52F8684 3357 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\GhostscriptDirect.vbs
2013-12-28 07:04:27 E239A0E745583C0C9F9083EB4A8C1F30 4155 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\ShowOptions.vbs
2013-12-28 07:04:27 D09021E66F07B0742608AA24F9CE6A46 1420 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\SaveOptionsToFile.vbs
2013-12-28 07:04:27 C703A331134B4A2136118704067C5C86 3138 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\Convert2PDFAndPrint.vbs
2013-12-28 07:04:27 A5E62495FE0ADD0BFB594163FE053E4C 2055 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\ConvertJPEG2PDF.vbs
2013-12-28 07:04:27 9F88B55A78B4F8A2C4844098EE5E4157 1284 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\TestEvents.vbs
2013-12-28 07:04:27 9E45772D6C39D762DC060DA80B66CA4D 1709 ----a-w- C:\Program Files\PDFCreator\Scripts\RunProgramAfterSaving\AddWatermarkToPDF.vbs
2013-12-28 07:04:27 994317D96FD5EB8187E8AFA25C73D119 4518 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\TestCompression1.vbs
2013-12-28 07:04:27 8EF68FDB3F993766E4A0DB59667E2355 2991 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\Convert2TXT.vbs
2013-12-28 07:04:27 8D2BF9546F4C3AE99699C316CB958F91 14324 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\CompareColorCompressionModes.vbs
2013-12-28 07:04:27 87F506076393456E8CEB09F0BC1A4778 3682 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\GUI.vbs
2013-12-28 07:04:27 876726C9C8CDEA7A8A5366D3AD0D9AE9 1862 ----a-w- C:\Program Files\PDFCreator\Scripts\RunProgramAfterSaving\SendMail.vbs
2013-12-28 07:04:27 802F702D9169B524650C3D3E8612A738 3002 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\Convert2PDF.vbs
2013-12-28 07:04:27 79C47C6CA12D847B3B6834AE6190F447 2529 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\URL2PDF.vbs
2013-12-28 07:04:27 7315AA8A59391AC2839FBE89D7E4191B 667 ----a-w- C:\Program Files\PDFCreator\Scripts\RunProgramBeforeSaving\PopUpMessage.vbs
2013-12-28 07:04:27 7315AA8A59391AC2839FBE89D7E4191B 667 ----a-w- C:\Program Files\PDFCreator\Scripts\RunProgramAfterSaving\PopUpMessage.vbs
2013-12-28 07:04:27 725F2CBDB92EA32E9C965B1A5F303845 16907 ----a-w- C:\Program Files\PDFCreator\Scripts\RunProgramBeforeSaving\AddBookmarks.vbs
2013-12-28 07:04:27 6C7E92B736DBA7A315B4EA63DC9AB9CB 2261 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\Testpage2PDF.vbs
2013-12-28 07:04:27 615D6343862CC55A9DBD65D9D6B870CA 1638 ----a-w- C:\Program Files\PDFCreator\Scripts\RunProgramAfterSaving\EncryptAES128.vbs
2013-12-28 07:04:27 53400371555164D6ECB1EB50A04C2648 3467 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\CombineJobs.vbs
2013-12-28 07:04:27 33ECE405DDE42607969FA443FCED16ED 1120 ----a-w- C:\Program Files\PDFCreator\Scripts\RunProgramAfterSaving\NetSend.vbs
2013-12-28 07:04:27 29B29E1D6B613A5645790376A0FB5F44 1878 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\PS2PDF.vbs
2013-12-28 07:04:27 282C00843805DDAE53C084A98EE079D6 2710 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\Testpage2PDFSendEmail.vbs
2013-12-28 07:04:27 228410D7E9AB331EE2B2E2C160F39D7F 1112 ----a-w- C:\Program Files\PDFCreator\Scripts\RunProgramAfterSaving\FTPUpload.vbs
2013-12-28 07:04:27 170CCE998953A670BC5709FCAC33E65C 1966 ----a-w- C:\Program Files\PDFCreator\Scripts\RunProgramAfterSaving\MSAgent.vbs
2013-12-28 07:04:27 0B1B4BD1260A3EC6FE67106EC0442CC9 4931 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\CombineAndAddBookmarks.vbs
2013-12-28 07:04:27 00E822D2DCA639441B9D641FFE2247FB 3025 ----a-w- C:\Program Files\PDFCreator\COM\Windows Scripting Host\VBScripts\Convert2TIFF.vbs
2013-12-28 07:04:26 FDF4B7FA98573492A62B6CCA14815FDE 143 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\gsdj.bat
2013-12-28 07:04:26 EB12B1B17BAE9ACDF5F730E8A8B8F482 586 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\ps2pdf.bat
2013-12-28 07:04:26 E73952C1808EAD40B09F9D840E607AD7 404 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\ps2pdf14.bat
2013-12-28 07:04:26 E58297722D0D22B3ECF9D75020681EB0 1131 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\ps2epsi.bat
2013-12-28 07:04:26 E35C2A861E7B51C8EE01DCAE82CAEA3C 528 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\ps2ps2.bat
2013-12-28 07:04:26 DD77E8B85DD9BBD39375B4D815585E68 395 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\ps2ascii.bat
2013-12-28 07:04:26 D3C17D58EDD85ACA947A0AC0091C5660 271 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\pf2afm.bat
2013-12-28 07:04:26 CFFD874A35D9D00EFB491B496D3E9ED2 138 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\lpr2.bat
2013-12-28 07:04:26 CF9072C32D56E2C7FE85DCA673C137CA 582 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\eps2eps.bat
2013-12-28 07:04:26 BCF7A957306F77B76859FD630037010F 71 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\gstt.bat
2013-12-28 07:04:26 BC46A12DC0921BDBAE711E0FAC153860 70 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\gst.bat
2013-12-28 07:04:26 B82F9935BFA11419EC6C363A29AE05E1 1460 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\ps2pdfxx.bat
2013-12-28 07:04:26 B39534F9E53A4FCC4F28CF99FCEDF6B1 144 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\gslj.bat
2013-12-28 07:04:26 AA00A6C11C781CC0A77BC45AA5E80BF4 404 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\ps2pdf13.bat
2013-12-28 07:04:26 A66ED14A1C9E5A6C6D01DB13F8671E45 141 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\gslp.bat
2013-12-28 07:04:26 A4F047184CC16140D2E45A2E5FED373D 256 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\pfbtopfa.bat
2013-12-28 07:04:26 A128F19C0DEDEBD0DE6AD344A4D0F01E 146 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\gsdj500.bat
2013-12-28 07:04:26 94973BD32C37A479321FEA658C59916D 184 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\gssetgs32.bat
2013-12-28 07:04:26 94973BD32C37A479321FEA658C59916D 184 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\gssetgs.bat
2013-12-28 07:04:26 89ABF67457237ABBA1540A8C918BDD92 318 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\pdf2dsc.bat
2013-12-28 07:04:26 82A2806EA432236F246B022F310DEBF1 1521 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\pftogsf.bat
2013-12-28 07:04:26 72DD78C9F9C476DE6F277456CBF875F4 88 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\lp386r2.bat
2013-12-28 07:04:26 6FC26133FCAF67CBAD5D0F315D8B8149 92 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\gsnd.bat
2013-12-28 07:04:26 60575A02493E499946423A5CDFF1B07D 184 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\gssetgs64.bat
2013-12-28 07:04:26 5BC0A2090A05779D8AE6BFC6FA11717E 95 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\gsndt.bat
2013-12-28 07:04:26 5083568FE7F99A27106D38F15A1DE8DA 404 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\ps2pdf12.bat
2013-12-28 07:04:26 4AEE03647E3F453C76B47E65F82B7F94 145 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\lpgs.bat
2013-12-28 07:04:26 44DDCD1EE83B17FDEFA39E8F31DF1A81 141 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\wmakebat.bat
2013-12-28 07:04:26 0CB25A3A955DE32499E22268ADCD5D0A 126 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\font2c.bat
2013-12-28 07:04:26 09FE49F06BF6EFDB213F745E5C5920C2 141 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\gsbj.bat
2013-12-28 07:04:26 09863BD713D6594134265D864B4729FD 95 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\lp386.bat
2013-12-28 07:04:26 07FCB58D7BB449B4BC1125BA5B73D690 494 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\pdf2ps.bat
2013-12-28 07:04:26 025E7D6CD7027E0703D2F45641E1D0A2 501 ----a-w- C:\Program Files\PDFCreator\GS9.10\gs9.10\Lib\ps2ps.bat
2013-12-28 06:28:42 50C949DCB8AFFE2D310B9F38929C5AC0 69018 ----a-w- C:\Users\Peter\AppData\Roaming\Convivea\Bit_Che\2\scripts\BACKUP\temp-scripts.zip
2013-12-28 06:13:12 5183A48059D82A7445FDD0DC5310880F 18425 ----a-w- C:\Program Files\Java\jre8\lib\deploy\ffjcext.zip
2013-12-28 03:08:27 9E26599599D178E71AFB5599E146031A 9200 ------w- C:\Windows\System32\drivers\cdralw2k.sys
2013-12-28 03:08:27 49452BFCEC22F36A7A9B9C2181BC3042 43872 ------w- C:\Windows\System32\drivers\PxHelp20.sys
2013-12-28 03:08:27 223DEA13C9D064BABC882B4727F6F905 9072 ------w- C:\Windows\System32\drivers\cdr4_xp.sys
2013-12-28 01:22:23 177BCDEFB24F21B6A1D059CA6613EDC5 323038 ----a-w- C:\Users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\paulsaintuzb@gmail.com.xpi
2013-12-28 01:22:11 CFD0316EA9EFC49744E7CC0EA246FA74 343554 ----a-w- C:\Users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\artur.dubovoy@gmail.com.xpi
2013-12-28 01:11:45 0634ECCDAFC7BF43A2F02D9930AC3E70 3317099 ----a-w- C:\Users\Peter\Desktop\Allerlei\producten.zip
2013-12-27 22:35:12 98A1E6BC9F766B0B0A5BF00AF847EF20 26624 ----a-w- C:\Users\Peter\AppData\Local\Media Get LLC\MediaGet2\openvpn\driver\tap0901.sys
2013-12-27 22:25:46 456AA2B8DB2C84CBD06C6A22B7C789AC 73024 ----a-w- C:\Users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\YoutubeDownloader@PeterOlayev.com.xpi
[HKEY_USERS\S-1-5-19\Software\Microsoft\Windows\CurrentVersion\Run]
"Sidebar"="%ProgramFiles%\Windows\Sidebar.exe /autoRun"
[HKEY_USERS\S-1-5-20\Software\Microsoft\Windows\CurrentVersion\Run]
[HKEY_USERS\S-1-5-21-3188537812-1931195976-3180334174-1000\Software\Microsoft\Windows\CurrentVersion\Run]
"Ditto"="C:\Program Files\Ditto\Ditto.exe"
"POP Peeper"="C:\Program Files\POP Peeper\POPPeeper.exe -min"
"Speaking Clock Lite"="C:\Program Files\Speaking Clock\spclock.exe"
"swg"="C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe"
[HKEY_USERS\S-1-5-19\Software\Microsoft\Windows\CurrentVersion\RunOnce]
"mctadmin"="C:\Windows\System32\mctadmin.exe"
[HKEY_USERS\S-1-5-20\Software\Microsoft\Windows\CurrentVersion\RunOnce]
"APSDaemon"="C:\Program Files\Common Files\Apple\Apple Application Support\APSDaemon.exe"
"AvastUI.exe"="C:\Program Files\AVAST Software\Avast\AvastUI.exe /nogui"
"IgfxTray"="C:\Windows\system32\igfxtray.exe"
"HotKeysCmds"="C:\Windows\system32\hkcmd.exe"
"Persistence"="C:\Windows\system32\igfxpers.exe"
==== Startup Registry Disabled ======================
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\MSConfig\startupreg]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\MSConfig\startupreg\NextLive]
"key"="SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Run"
"item"="NextLive"
"hkey"="HKCU"
"command"="C:\\Windows\\system32\\rundll32.exe \"C:\\Users\\Peter\\AppData\\Roaming\\newnext.me\\nengine.dll\",EntryPoint -m l"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\MSConfig\startupreg\QuickTime Task]
"item"="QuickTime Task"
"hkey"="HKLM"
"command"="\"C:\\Program Files\\QuickTime\\QTTask.exe\" -atboottime"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\MSConfig\startupreg\SpybotSD TeaTimer]
"item"="SpybotSD TeaTimer"
"hkey"="HKCU"
"command"="C:\\Program Files\\Spybot - Search & Destroy\\TeaTimer.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\MSConfig\startupreg\SUPERAntiSpyware]
"item"="SUPERAntiSpyware"
"hkey"="HKCU"
"command"="C:\\Program Files\\SUPERAntiSpyware\\SUPERAntiSpyware.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\MSConfig\startupreg\TkBellExe]
"item"="TkBellExe"
"hkey"="HKLM"
"command"="\"C:\\Program Files\\Real\\RealPlayer\\Update\\realsched.exe\" -osboot"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\MSConfig\startupreg\ToolwizCareFree]
"item"="ToolwizCareFree"
"hkey"="HKCU"
"command"="\"C:\\Program Files\\ToolwizCareFree\\ToolwizCares.exe\" -autorun"
==== Startup Folders ======================
2013-12-28 06:30:14 1086 ----a-w- C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Clipboard Magic.lnk
2013-12-28 03:21:54 1323 ----a-w- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\Adobe Gamma Loader.lnk
C:\Windows\tasks\DriverEasy Scheduled Scan.job --a------ C:\Program Files\Easeware\DriverEasy\DriverEasy.exe [23-12-2013 02:16]
C:\Windows\tasks\FreeFileViewerUpdateChecker.job --a------ C:\Program Files\FreeFileViewer\FFVCheckForUpdates.exe [25-03-2013 18:24]
C:\Windows\tasks\GoogleUpdateTaskMachineCore.job --a------ C:\Program Files\Google\Update\GoogleUpdate.exe [30-12-2013 18:54]
C:\Windows\tasks\GoogleUpdateTaskMachineUA.job --a------ C:\Program Files\Google\Update\GoogleUpdate.exe [30-12-2013 18:54]
C:\Windows\tasks\RegCure Pro.job --a------ C:\Program Files\ParetoLogic\RegCure Pro\RegCurePro.exe []
==== Other Scheduled Tasks ======================
"C:\Windows\system32\tasks\CCleanerSkipUAC" ["C:\Program Files\CCleaner\CCleaner.exe"]
"C:\Windows\system32\tasks\DriverEasy Scheduled Scan" [C:\Program Files\Easeware\DriverEasy\DriverEasy.exe]
"C:\Windows\system32\tasks\FreeFileViewerUpdateChecker" [C:\Program Files\FreeFileViewer\FFVCheckForUpdates.exe]
"C:\Windows\system32\tasks\GoogleUpdateTaskMachineCore" [C:\Program Files\Google\Update\GoogleUpdate.exe]
"C:\Windows\system32\tasks\GoogleUpdateTaskMachineUA" [C:\Program Files\Google\Update\GoogleUpdate.exe]
"C:\Windows\system32\tasks\ProgramRefresh-ATFST" [C:\Program Files\File Type Assistant\tsasetup.exe]
"C:\Windows\system32\tasks\ProgramUpdateCheck" [C:\Program Files\File Type Assistant\TSAssist.exe]
"C:\Windows\system32\tasks\RealPlayerRealUpgradeLogonTaskS-1-5-21-3188537812-1931195976-3180334174-1000" [C:\Program Files\Real\RealUpgrade\RealUpgrade.exe]
"C:\Windows\system32\tasks\RealPlayerRealUpgradeScheduledTaskS-1-5-21-3188537812-1931195976-3180334174-1000" [C:\Program Files\Real\RealUpgrade\RealUpgrade.exe]
"C:\Windows\system32\tasks\RegCure Pro" [C:\Program Files\ParetoLogic\RegCure Pro\RegCurePro.exe]
"C:\Windows\system32\tasks\SlimCleaner Run" ["C:\Program Files\SlimCleaner\SlimCleaner.exe"]
"C:\Windows\system32\tasks\ToolwizCareFree" [C:\Program Files\ToolwizCareFree\ToolwizCares.exe]
==== Firefox Extensions Registry ======================
[HKEY_LOCAL_MACHINE\Software\Mozilla\Firefox\Extensions]
"wrc@avast.com"="C:\Program Files\AVAST Software\Avast\WebRep\FF" [28-12-2013 18:37]
==== Firefox Extensions ======================
ProfilePath: C:\Users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default
- avast Online Security - C:\Program Files\AVAST Software\Avast\WebRep\FF
- IE Tab - %ProfilePath%\extensions\coralietab@mozdev.org
- IE Tab 2 FF 3.6 - %ProfilePath%\extensions\{1BC9BA34-1EED-42ca-A505-6D2F1A935BBB}
- IE Tab - %ProfilePath%\extensions\{77b819fa-95ad-4f2c-ac7c-486b356188a9}
- PlainOldFavorites - %ProfilePath%\extensions\{7E7165E2-0767-448c-852F-5FA8714F2C37}
- DownloadHelper - %ProfilePath%\extensions\{b9db16a4-6edc-47ec-a1f4-b86292ed211d}
- Flash and Video Download - %ProfilePath%\extensions\{bee6eb20-01e0-ebd1-da83-080329fb9a3a}
- Flash Video Downloader - %ProfilePath%\extensions\artur.dubovoy@gmail.com.xpi
- betterFox - Make your browsing experience 15 faster. - %ProfilePath%\extensions\multirevenue@googlemail.com.xpi
- Open in IE - %ProfilePath%\extensions\openinie@wittersworld.com.xpi
- Youtube Downloader - Media Downloader - %ProfilePath%\extensions\paulsaintuzb@gmail.com.xpi
- YesScript - %ProfilePath%\extensions\yesscript@userstyles.org.xpi
- 1-Click YouTube Video Downloader - %ProfilePath%\extensions\YoutubeDownloader@PeterOlayev.com.xpi
- Download Tab - %ProfilePath%\extensions\{a949831f-d9c0-45ae-8c60-91c2a86fbfb6}.xpi
- FirefoxAdKiller - %ProfilePath%\extensions\{b1df372d-8b32-4c7d-b6b4-9c5b78cf6fb1}.xpi
- Download YouTube Videos as MP4 - %ProfilePath%\extensions\{b9bfaf1c-a63f-47cd-8b9a-29526ced9060}.xpi
- Adblock Plus - %ProfilePath%\extensions\{d10d0bf8-f5b5-c8b4-a8b2-2b9879e08c5d}.xpi
AppDir: C:\Program Files\Mozilla Firefox
- Default - %AppDir%\browser\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd}
==== Firefox Plugins ======================
Profilepath: C:\Users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default
C36444D7301A8C881FC7296B092609C7 - C:\Program Files\Google\Update\1.3.22.3\npGoogleUpdate3.dll - Google Update
86FD0445C7A92516FC0BA201C79B8E9E - C:\Program Files\QuickTime\Plugins\npqtplugin5.dll - QuickTime Plug-in 7.7.4
9FDABAD05A9623988750CCC10223BDB0 - C:\Program Files\QuickTime\Plugins\npqtplugin4.dll - QuickTime Plug-in 7.7.4
5E1D0432C765884434A7CCD4DBDC80AA - C:\Program Files\QuickTime\Plugins\npqtplugin3.dll - QuickTime Plug-in 7.7.4
3B293C235A80E7A5369E6AA28FEA50B1 - C:\Program Files\QuickTime\Plugins\npqtplugin2.dll - QuickTime Plug-in 7.7.4
A80BCBED52F7DD5FDBF346A985A4E4D5 - C:\Program Files\QuickTime\Plugins\npqtplugin.dll - QuickTime Plug-in 7.7.4
3A9E1940B4459CC97FDCBB24FCB69004 - C:\Program Files\Real\RealPlayer\Netscape6\nppl3260.dll - RealPlayer G2 LiveConnect-Enabled Plug-In (32-bit)
0FCEAA7D12B7B0BA825E5C770B1DCA48 - C:\Program Files\Real\RealPlayer\Netscape6\nprpplugin.dll - RealPlayer Download Plugin
1259CF312EBF086A0FA281DCDCA23701 - C:\Program Files\Java\jre8\bin\plugin2\npjp2.dll - Java Platform SE 8
EDDD8E0A3E3E4536134FAC6D2629AEC9 - C:\Windows\system32\npDeployJava1.dll - Java Deployment Toolkit 8.0.0.57
F891089A6AB9E12FEDEBCC5EC0F40D66 - C:\Windows\system32\Macromed\Flash\NPSWF32_11_9_900_170.dll - Shockwave Flash
CBFE3156904AB2D1A097F5E74A6C62F3 - C:\Program Files\VideoLAN\VLC\npvlc.dll - VLC Web Plugin
F3B0E300AFC94E1A775A2D935A7D384F - C:\Windows\system32\Adobe\Director\np32dsw_1207148.dll - Shockwave for Director / Shockwave for Director
BE501CBC29B2025A263D80D399F1797A - c:\Program Files\Microsoft Silverlight\5.1.20913.0\npctrl.dll - Silverlight Plug-In
BE126CB7049E89ED6F3038016668B502 - C:\ProgramData\RealNetworks\RealDownloader\BrowserPlugins\MozillaPlugins\nprndlchromebrowserrecordext.dll - RealNetworks RealDownloader Chrome Background Extension Plug-In (32-bit)
EAC427FEF96A13058C1ACD17C38966CF - C:\ProgramData\RealNetworks\RealDownloader\BrowserPlugins\MozillaPlugins\nprndlpepperflashvideoshim.dll - RealNetworks RealDownloader PepperFlashVideoShim Plug-In (32-bit)
96B3689320E9B16EDF38B7A5001C35F0 - C:\ProgramData\RealNetworks\RealDownloader\BrowserPlugins\MozillaPlugins\nprndlhtml5videoshim.dll - RealNetworks RealDownloader HTML5VideoShim Plug-In (32-bit)
F8CB60A5ACA5D73807ECBD9942A8BCB7 - C:\ProgramData\RealNetworks\RealDownloader\BrowserPlugins\npdlplugin.dll - RealDownloader Plugin
21FF3F07336CE4F8DF6AF1746BC26AAB - C:\Program Files\Adobe\Reader 11.0\Reader\browser\nppdf32.dll - Adobe Acrobat
E0BCE90537E4A41AF36D5BDD5963A09D - C:\Program Files\Adobe\Reader 11.0\Reader\AIR\nppdf32.dll - Adobe Acrobat
B27CCB1168B1960AEC6E9D3E0E0F0D2A - c:\Program Files\Microsoft Silverlight\5.1.20913.0\npctrlui.dll - Microsoft® Silverlight
15E298B5EC5B89C5994A59863969D9FF - C:\Windows\system32\npmproxy.dll - Microsoft® Windows® Operating System
==== Chrome Look ======================
idhngdhcfkoamngbedgpaokgjbnpdiji - C:\ProgramData\RealNetworks\RealDownloader\BrowserPlugins\Chrome\Ext\realdownloader.crx[14-08-2013 15:24]
Old Values:
"Start Page"="https://www.facebook.com/hobbyfotograaf"
New Values:
"DefaultScope"="{40D1FED9-E723-46AB-BD83-987E4026ED3F}"
{0633EE93-D776-472f-A0FF-E1416B8B2E3A} Bing Url="{searchTerms} - Bing"
{40D1FED9-E723-46AB-BD83-987E4026ED3F} Google Url="{searchTerms} - Google zoeken"
{6A1806CD-94D4-4689-BA73-E35EA1EA9990} Google Url="{searchTerms} - Google Search}"
==== shortcuts on Users Desktops ======================
C:\Users\Peter\Desktop\fotos.lnk - E:\
C:\Users\Peter\Desktop\mp3.lnk - J:\mp3
C:\Users\Peter\Desktop\nu.lnk - J:\nu
C:\Users\Peter\Desktop\Peter.lnk - C:\Users\Peter
C:\Users\Peter\Desktop\teddy.lnk - C:\Users\teddy
C:\Users\Peter\Desktop\delen\peter & cynthia - Raccourci.lnk - C:\Users\Peter\Desktop\delen\peter & cynthia
==== shortcuts in Users Start Menu ======================
C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Internet Explorer.lnk - C:\Program Files\Internet Explorer\iexplore.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\MediaGet.lnk - C:\Users\Peter\AppData\Local\MediaGet2\mediaget.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Spotify.lnk - C:\Users\Peter\AppData\Roaming\Spotify\spotify.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Windows Install Clean Up.lnk - C:\Users\Peter\AppData\Roaming\Microsoft\Installer\{121634B0-2F4B-11D3-ADA3-00C04F52DD52}\Icon386ED4E3.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Accessories\System Tools\Internet Explorer (No Add-ons).lnk - C:\Program Files\Internet Explorer\iexplore.exe -extoff
C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\HiJackThis\HiJackThis.lnk - C:\Users\Peter\AppData\Roaming\Microsoft\Installer\{45A66726-69BC-466B-A7A4-12FCBA4883D7}\HiJackThis.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\MediaGet2\MediaGet.lnk - C:\Users\Peter\AppData\Local\MediaGet2\mediaget.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\MediaGet2\Uninstall MediaGet.lnk - C:\Users\Peter\AppData\Local\MediaGet2\mediaget-uninstaller.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Clipboard Magic.lnk - C:\Program Files\Clipboard Magic\ClipboardMagic.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Windows 7 USB DVD Download Tool\Uninstall Windows 7 USB DVD Download Tool.lnk - C:\Windows\system32\msiexec.exe /x {CCF298AF-9CE1-4B26-B251-486E98A34789}
C:\Users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Windows 7 USB DVD Download Tool\Windows 7 USB DVD Download Tool.lnk - C:\Users\Peter\AppData\Local\Apps\Windows 7 USB DVD Download Tool\Windows7-USB-DVD-Download-Tool.exe
==== shortcuts in All Users Start Menu ======================
C:\ProgramData\Microsoft\Windows\Start Menu\FreeFileViewer.lnk - C:\Program Files\FreeFileViewer\FreeFileViewer.exe
C:\ProgramData\Microsoft\Windows\Start Menu\New Office Document.lnk - C:\Windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\misc.exe -n
C:\ProgramData\Microsoft\Windows\Start Menu\Open Office Document.lnk - C:\Windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\misc.exe -f
C:\ProgramData\Microsoft\Windows\Start Menu\WinZip.lnk - C:\Program Files\WinZip\WINZIP32.EXE
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Photoshop 7.0.lnk - C:\Program Files\Adobe\Photoshop 7.0\Photoshop.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Photoshop Lightroom 2.lnk - C:\Program Files\Adobe\Adobe Photoshop Lightroom 2\lightroom.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Reader XI.lnk - C:\Windows\Installer\{AC76BA86-7AD7-1043-7B44-AB0000000001}\SC_Reader.ico
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Apple Software Update.lnk - C:\Windows\Installer\{789A5B64-9DD9-4BA5-915A-F0FC0A1B7BFE}\AppleSoftwareUpdateIco.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Media Center.lnk - C:\Windows\ehome\ehshell.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mozilla Firefox.lnk - C:\Program Files\Mozilla Firefox\firefox.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows 7 Upgrade Advisor.lnk - C:\Program Files\Microsoft Windows 7 Upgrade Advisor\WindowsUpgradeAdvisor.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows DVD Maker.lnk - C:\Program Files\DVD Maker\DVDMaker.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Movie Maker 2.6.lnk - C:\Windows\Installer\{B3DAF54F-DB25-4586-9EF1-96D24BB14088}\MOVIEMK.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Math Input Panel.lnk - C:\Program Files\Common Files\Microsoft Shared\Ink\mip.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Mobility Center.lnk - C:\Windows\system32\mblctr.exe /open
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Remote Desktop Connection.lnk - C:\Windows\system32\mstsc.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Snipping Tool.lnk - C:\Windows\system32\SnippingTool.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Sticky Notes.lnk - C:\Windows\system32\StikyNot.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Tablet PC\ShapeCollector.lnk - C:\Program Files\Common Files\Microsoft Shared\Ink\ShapeCollector.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Tablet PC\TabTip.lnk - C:\Program Files\Common Files\Microsoft Shared\Ink\TabTip.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories\Tablet PC\Windows Journal.lnk - C:\Program Files\Windows Journal\Journal.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Auto FX DreamSuite\Remove DreamSuite.lnk - C:\Windows\unvise32.exe C:\PROGRA~1\ADOBE\PHOTOS~2.0\PLUG-INS\uninstal.log
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Auto FX Software\DreamSuite\Auto FX Website.lnk - C:\Program Files\Adobe\PHOTOSHOP 6.0\PLUG-INS\DreamSuite\html\English\Auto FX Website.url
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Auto FX Software\DreamSuite\Online Manual.lnk - C:\Program Files\Adobe\PHOTOSHOP 6.0\PLUG-INS\DreamSuite\html\English\Online Manual.url
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Auto FX Software\DreamSuite\Product Demos.lnk - C:\Program Files\Adobe\PHOTOSHOP 6.0\PLUG-INS\DreamSuite\html\English\Product Demos.url
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Auto FX Software\DreamSuite\Registration Page.lnk - C:\Program Files\Adobe\PHOTOSHOP 6.0\PLUG-INS\DreamSuite\html\English\Registration Page.url
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Auto FX Software\DreamSuite\Uninstall DreamSuite.lnk - C:\Windows\unvise32.exe C:\PROGRA~1\Adobe\PHOTOS~2.0\PLUG-INS\DREAMS~1\DREAMS~1.LOG
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Auto FX Software\DreamSuite\Updater Page.lnk - C:\Program Files\Adobe\PHOTOSHOP 6.0\PLUG-INS\DreamSuite\html\English\Updater Page.url
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Avast\avast Pro Antivirus.lnk -
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Avast\avast SafeZone.lnk -
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Beauty Pilot\Beauty Pilot.lnk - C:\Program Files\Beauty Pilot\BeautyPilot.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Beauty Pilot\Help.lnk - C:\Program Files\Beauty Pilot\BeautyPilot.chm
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Beauty Pilot\Uninstall.lnk - C:\Program Files\Beauty Pilot\unins000.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CCleaner\CCleaner.lnk - C:\Program Files\CCleaner\CCleaner.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CCleaner\Uninstall CCleaner.lnk - C:\Program Files\CCleaner\uninst.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Cool Timer\Cool Timer Help.lnk - C:\Program Files\Cool Timer\ct.chm
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Cool Timer\Cool Timer.lnk - C:\Program Files\Cool Timer\cooltimer.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Cool Timer\Uninstall Cool Timer.lnk - C:\Program Files\Cool Timer\unins000.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ditto\Ditto Help.lnk - C:\Program Files\Ditto\Help\DittoGettingStarted.htm
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ditto\Ditto.lnk - C:\Program Files\Ditto\Ditto.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ditto\Uninstall.lnk - C:\Program Files\Ditto\unins000.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DriverEasy\DriverEasy.lnk - C:\Program Files\Easeware\DriverEasy\DriverEasy.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DriverEasy\Uninstall DriverEasy.lnk - C:\Program Files\Easeware\DriverEasy\unins000.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Flash Movie Player\Flash Movie Player website.lnk - C:\Program Files\Flash Movie Player\Flash Movie Player.url
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Flash Movie Player\Flash Movie Player.lnk - C:\Program Files\Flash Movie Player\fmp.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\FreeFileViewer\FreeFileViewer.lnk - C:\Program Files\FreeFileViewer\FreeFileViewer.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\FreeFileViewer\Uninstall.lnk - C:\Program Files\FreeFileViewer\unins000.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Games\Chess.lnk -
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Games\Internet Backgammon.lnk -
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Games\Internet Checkers.lnk -
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Games\Internet Spades.lnk -
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Games\Mahjong.lnk -
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Imagenomic\Portraiture Plug-in\License Agreement.lnk - C:\Program Files\Imagenomic\Portraiture Plug-in\EULA.html
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Imagenomic\Portraiture Plug-in\Modify Portraiture Plug-in Installation.lnk - C:\Program Files\Imagenomic\Portraiture Plug-in\PortraiturePluginInstaller.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Imagenomic\Portraiture Plug-in\Portraiture Plug-in User's Guide.lnk - C:\Program Files\Imagenomic\Portraiture Plug-in\PortraiturePluginUsersGuide.pdf
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Imagenomic\Portraiture Plug-in\Uninstall Portraiture Plug-in.lnk - C:\Windows\System32\msiexec.exe /x {8F378798-88D8-4FA1-AB74-F035542133A6}
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes' Anti-Malware\Malwarebytes Anti-Malware Help.lnk - C:\Program Files\Malwarebytes' Anti-Malware\mbam.chm
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes' Anti-Malware\Malwarebytes Anti-Malware.lnk - C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes' Anti-Malware\Verwijder Malwarebytes Anti-Malware.lnk - C:\Program Files\Malwarebytes' Anti-Malware\unins000.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes' Anti-Malware\Tools\Malwarebytes Anti-Malware Chameleon.lnk - C:\Program Files\Malwarebytes' Anti-Malware\Chameleon\chameleon.chm
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office\Microsoft Office Excel 2003.lnk - C:\Windows\Installer\{90110413-6000-11D3-8CFE-0150048383C9}\xlicons.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office\Microsoft Office Word 2003.lnk - C:\Windows\Installer\{90110413-6000-11D3-8CFE-0150048383C9}\wordicon.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office\Microsoft Office-hulpprogramma's\Digitaal Certificaat voor VBA-projecten.lnk - C:\Windows\Installer\{90110413-6000-11D3-8CFE-0150048383C9}\misc.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office\Microsoft Office-hulpprogramma's\Microsoft Mediagalerie.lnk - C:\Windows\Installer\{90110413-6000-11D3-8CFE-0150048383C9}\cagicon.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office\Microsoft Office-hulpprogramma's\Microsoft Office 2003-taalinstellingen.lnk - C:\Windows\Installer\{90110413-6000-11D3-8CFE-0150048383C9}\misc.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office\Microsoft Office-hulpprogramma's\Microsoft Office 2003-wizard Mijn instellingen opslaan.lnk - C:\Windows\Installer\{90110413-6000-11D3-8CFE-0150048383C9}\opwicon.exe /u
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office\Microsoft Office-hulpprogramma's\Microsoft Office Document Imaging.lnk - C:\Windows\Installer\{90110413-6000-11D3-8CFE-0150048383C9}\mspicons.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office\Microsoft Office-hulpprogramma's\Microsoft Office Document Scanning.lnk - C:\Windows\Installer\{90110413-6000-11D3-8CFE-0150048383C9}\mspicons.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office\Microsoft Office-hulpprogramma's\Microsoft Office Picture Manager.lnk - C:\Windows\Installer\{90110413-6000-11D3-8CFE-0150048383C9}\oisicon.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office\Microsoft Office-hulpprogramma's\Microsoft Office-toepassingsherstel.lnk - C:\Windows\Installer\{90110413-6000-11D3-8CFE-0150048383C9}\misc.exe -c
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office Tools\Activate Product.lnk - C:\Windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\misc.exe -z
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office Tools\Microsoft Office Application Recovery.lnk - C:\Windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\misc.exe -c
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office Tools\Microsoft Office Shortcut Bar.lnk - C:\Windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\misc.exe -o
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Silverlight\Microsoft Silverlight.lnk - C:\Program Files\Microsoft Silverlight\5.1.20913.0\Silverlight.Configuration.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\onOne Software\PhotoPresets with One-Click WOW\Read Me.lnk -
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\onOne Software\PhotoPresets Wow Effects for Lightroom\Read Me.lnk - C:\Program Files\onOne Software\PhotoPresets Wow Effects for Lightroom\ReadMe.txt
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\OpenOffice 4.0.1\OpenOffice Base.lnk - C:\Program Files\OpenOffice 4\program\sbase.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\OpenOffice 4.0.1\OpenOffice Calc.lnk - C:\Program Files\OpenOffice 4\program\scalc.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\OpenOffice 4.0.1\OpenOffice Draw.lnk - C:\Program Files\OpenOffice 4\program\sdraw.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\OpenOffice 4.0.1\OpenOffice Impress.lnk - C:\Program Files\OpenOffice 4\program\simpress.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\OpenOffice 4.0.1\OpenOffice Math.lnk - C:\Program Files\OpenOffice 4\program\smath.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\OpenOffice 4.0.1\OpenOffice Writer.lnk - C:\Program Files\OpenOffice 4\program\swriter.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\OpenOffice 4.0.1\OpenOffice.lnk - C:\Program Files\OpenOffice 4\program\soffice.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PDF to Word Free\PDF to Word Free.lnk - C:\Program Files\PDF to Word Free\PDFtoWordFree.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PDF to Word Free\Uninstall.lnk - C:\Program Files\PDF to Word Free\unins000.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PDFCreator\Doneer aan PDFCreator.lnk - C:\Program Files\PDFCreator\Doneer aan PDFCreator.url
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PDFCreator\Geschiedenis.lnk - C:\Program Files\PDFCreator\History.txt
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PDFCreator\PDFCreator Help.lnk - C:\Program Files\PDFCreator\PDFCreator_english.chm
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PDFCreator\PDFCreator op het Web.lnk - C:\Program Files\PDFCreator\PDFCreator.url
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PDFCreator\PDFCreator.lnk - C:\Program Files\PDFCreator\PDFCreator.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PDFCreator\Translation Tool.lnk - C:\Program Files\PDFCreator\languages\TransTool.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PDFCreator\Images2PDF\Images2PDF Console Application.lnk - C:\Windows\System32\cmd.exe /k "C:\Program Files\PDFCreator\Images2PDF\Images2PDFC.exe"
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PDFCreator\Images2PDF\Images2PDF.lnk - C:\Program Files\PDFCreator\Images2PDF\Images2PDF.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PDFCreator\Licenses\FairPlay License.lnk - C:\Program Files\PDFCreator\FairPlay License.txt
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PDFCreator\Licenses\GPL License.lnk - C:\Program Files\PDFCreator\GNU License.txt
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Picture Collage Maker Pro\Picture Collage Maker Pro.lnk - C:\Program Files\Picture Collage Maker Pro\PictureCollageMakerPro.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Picture Collage Maker Pro\Uninstall Picture Collage Maker Pro.lnk - C:\Program Files\Picture Collage Maker Pro\unins000.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PIXresizer\PIXresizer on the Web.lnk - C:\Program Files\PIXresizer\PIXresizer.url
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PIXresizer\PIXresizer readme.lnk - C:\Program Files\PIXresizer\readme.txt
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PIXresizer\PIXresizer.lnk - C:\Program Files\PIXresizer\PIXresizer.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PIXresizer\Uninstall PIXresizer.lnk - C:\Program Files\PIXresizer\unins000.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\QuickTime\Over QuickTime.lnk - C:\Windows\Installer\{B67BAFBA-4C9F-48FA-9496-933E3B255044}\RichText.ico
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\QuickTime\PictureViewer.lnk - C:\Windows\Installer\{B67BAFBA-4C9F-48FA-9496-933E3B255044}\PictureViewer.ico
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\QuickTime\QuickTime deïnstalleren.lnk -
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\QuickTime\QuickTime Player.lnk - C:\Windows\Installer\{B67BAFBA-4C9F-48FA-9496-933E3B255044}\QTPlayer.ico
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\RealNetworks\RealDownloader.lnk - C:\Windows\Installer\{C8E8D2E3-EF6A-4B1D-A09E-7B27EBE2F3CE}\recordingmanager.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\RealNetworks\RealPlayer Converter.lnk - C:\Program Files\Real\RealPlayer\realconverter.exe /launch:start_menu
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\RealNetworks\RealPlayer Trimmer.lnk - C:\Program Files\Real\RealPlayer\realtrimmer.exe /launch:start_menu
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\RealNetworks\RealPlayer.lnk - C:\Program Files\Real\RealPlayer\realplay.exe /launch:start_menu
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Registrar Registry Manager\Registrar Registry Manager Help.lnk - C:\Program Files\Registrar Registry Manager\rr.chm
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Registrar Registry Manager\Registrar Registry Manager.lnk - C:\Program Files\Registrar Registry Manager\rr.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Skype\Skype.lnk - C:\Program Files\Skype\Phone\Skype.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SlimCleaner\SlimCleaner.lnk - C:\Windows\Installer\{6B8D6199-EE44-4FD7-813A-6D8C62C9B384}\Icon.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Snapseed\Snapseed.lnk - C:\Windows\Installer\{34FAD416-D661-467E-B008-2FC32D6638B9}\Snapseed.ico
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Snapseed\Uninstall Snapseed.lnk - C:\Windows\System32\msiexec.exe /x {34FAD416-D661-467E-B008-2FC32D6638B9}
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Speaking Clock\Multilingual Speaking Clock.lnk - C:\Program Files\Speaking Clock\spclock.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Speaking Clock\Speaking Clock homepage.lnk - C:\Program Files\Speaking Clock\Speaking Clock.url
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Spybot - Search & Destroy\File Shredder.lnk - C:\Program Files\Spybot - Search & Destroy\SDShred.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Spybot - Search & Destroy\Spybot - Search & Destroy.lnk - C:\Program Files\Spybot - Search & Destroy\SpybotSD.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Spybot - Search & Destroy\Tutorial.lnk - C:\Program Files\Spybot - Search & Destroy\Help\English.chm
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Spybot - Search & Destroy\Uninstall Spybot-S&D.lnk - C:\Program Files\Spybot - Search & Destroy\unins000.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Spybot - Search & Destroy\Update Spybot-S&D.lnk - C:\Program Files\Spybot - Search & Destroy\SDUpdate.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\Adobe Gamma Loader.lnk - C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SUPERAntiSpyware\SUPERAntiSpyware Alternate Start.lnk - C:\Program Files\SUPERAntiSpyware\RUNSAS.EXE
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SUPERAntiSpyware\SUPERAntiSpyware Free Edition.lnk - C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SUPERAntiSpyware\SUPERAntiSpyware Help.lnk - C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.chm
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SUPERAntiSpyware\SUPERAntiSpyware Registration-Activation.lnk - C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe /register
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ToolwizCareFree\Toolwiz Care.lnk - C:\Program Files\ToolwizCareFree\ToolwizCares.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ToolwizCareFree\Uninstall.lnk - C:\Program Files\ToolwizCareFree\UninstallToolwizCare.exe /REMOVE
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN\Documentation.lnk - C:\Program Files\VideoLAN\VLC\Documentation.url
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN\Release Notes.lnk - C:\Program Files\VideoLAN\VLC\NEWS.txt
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN\VideoLAN Website.lnk - C:\Program Files\VideoLAN\VLC\VideoLAN Website.url
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN\VLC media player - reset preferences and cache files.lnk - C:\Program Files\VideoLAN\VLC\vlc.exe --reset-config --reset-plugins-cache vlc://quit
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN\VLC media player skinned.lnk - C:\Program Files\VideoLAN\VLC\vlc.exe -Iskins
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN\VLC media player.lnk - C:\Program Files\VideoLAN\VLC\vlc.exe
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinZip\Help Manual.lnk - C:\Windows\hh.exe C:\PROGRA~1\WinZip\winzip.chm
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinZip\WinZip 12.1.lnk - C:\Program Files\WinZip\WINZIP32.EXE
==== shortcuts in Quick Launch ======================
C:\Users\Default\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Shows Desktop.lnk -
C:\Users\Default\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Window Switcher.lnk -
C:\Users\Default User\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Shows Desktop.lnk -
C:\Users\Default User\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Window Switcher.lnk -
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Calculator.lnk - C:\Windows\system32\calc.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\ClipboardMagic - Snelkoppeling.lnk - C:\Program Files\Clipboard Magic\ClipboardMagic.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Configuratiescherm - Snelkoppeling.lnk -
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Cool Timer.lnk - C:\Program Files\Cool Timer\cooltimer.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Downloads.lnk - C:\Users\Peter\Downloads
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\FreeFileViewer.lnk - C:\Program Files\FreeFileViewer\FreeFileViewer.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Launch Internet Explorer Browser.lnk - C:\Program Files\Internet Explorer\iexplore.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\MSOFFICE - Snelkoppeling.lnk - C:\Program Files\Microsoft Office\Office10\MSOFFICE.EXE
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Multilingual Speaking Clock.lnk - C:\Program Files\Speaking Clock\spclock.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Notepad.lnk - C:\Windows\system32\notepad.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Shows Desktop.lnk -
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Skype.lnk - C:\Windows\Installer\{4E76FF7E-AEBA-4C87-B788-CD47E5425B9D}\SkypeIcon.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Snipping Tool.lnk - C:\Windows\system32\SnippingTool.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Spotify.lnk - C:\Users\Peter\AppData\Roaming\Spotify\spotify.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Spybot - Search & Destroy.lnk - C:\Program Files\Spybot - Search & Destroy\SpybotSD.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Window Switcher.lnk -
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\email web\Outlook Express.lnk -
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\ImplicitAppShortcuts\7e4dca80246863e3\pinned.lnk - C:\Windows\system32\control.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\StartMenu\CCleaner.lnk - C:\Program Files\CCleaner\CCleaner.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\StartMenu\SlimCleaner.lnk - C:\Windows\Installer\{6B8D6199-EE44-4FD7-813A-6D8C62C9B384}\Icon.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar\Internet Explorer.lnk - C:\Program Files\Internet Explorer\iexplore.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar\Mozilla Firefox.lnk - C:\Program Files\Mozilla Firefox\firefox.exe
C:\Users\Peter\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar\Windows Explorer.lnk - C:\Windows\explorer.exe
==== Deleting Registry Keys ======================
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\{B4092C6D-E886-4CB2-BA68-FE5A88D31DE6}_is1 deleted successfully
C:\Users\Peter\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\Content.IE5 emptied successfully
C:\Windows\serviceprofiles\networkservice\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5 emptied successfully
C:\Windows\serviceprofiles\Localservice\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5 emptied successfully
C:\Users\Peter\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat will be deleted at reboot
C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat will be deleted at reboot
C:\Users\Peter\AppData\Local\Mozilla\Firefox\Profiles\ck28b102.default\Cache emptied successfully
No Chrome User Data found
==== C:\zoek_backup content ======================
C:\zoek_backup (files=525 folders=64 59746659 bytes)
C:\Users\Default\AppData\Local\Temp emptied successfully
C:\Users\Default User\AppData\Local\Temp emptied successfully
C:\Windows\serviceprofiles\networkservice\AppData\Local\Temp emptied successfully
C:\Windows\serviceprofiles\Localservice\AppData\Local\Temp emptied successfully
C:\Users\Peter\AppData\Local\Temp will be emptied at reboot
C:\Windows\Temp will be emptied at reboot
C:\Users\Peter\AppData\Local\Temp successfully emptied
"C:\Users\Peter\AppData\Roaming\Ditto\Ditto.db" not found
"C:\Users\Peter\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat" not deleted
"C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat" not found
"C:\Users\Peter\AppData\Roaming\Ditto" not found
==== EOF on ma 30-12-2013 at 22:10:27,57 ======================
Klik op “Start”
Klik op "Advanced settings"
  • Remove found threats
  • Scan archives
Klik op “Start”
Gebruik Kladblok om het logje te openen. Dit logje vind je op de locatie C:\\Program Files\\Eset\\EsetOnlineScanner\\log.txt
Kopieer en plak de inhoud van dit logje in je volgende bericht.
ESETSmartInstaller@High as downloader log:
all ok
# version=8
# OnlineScannerApp.exe=1.0.0.1
# OnlineScanner.ocx=1.0.0.6920
# api_version=3.0.2
# EOSSerial=8fd4cb6c1f45554ea37f4efa5ebbcaf2
# engine=16478
# end=stopped
# remove_checked=false
# archives_checked=true
# unwanted_checked=true
# unsafe_checked=true
# antistealth_checked=true
# utc_time=2014-01-01 05:25:55
# local_time=2014-01-01 06:25:55 (+0100, Romance (standaardtijd))
# country="Netherlands"
# lang=1033
# osver=6.1.7601 NT Service Pack 1
# compatibility_mode=773 16777213 71 77 340974 348519 0 0
# compatibility_mode=5893 16776573 100 94 252629 140228346 0 0
# scanned=1627
# found=0
# cleaned=0
# scan_time=41
all ok
# version=8
# api_version=3.0.2
# engine=16478
# end=finished
# utc_time=2014-01-01 06:40:30
# local_time=2014-01-01 07:40:30 (+0100, Romance (standaardtijd))
# lang=1033
# compatibility_mode=773 16777213 71 77 349049 352994 0 0
# compatibility_mode=5893 16776573 100 94 260704 140232821 0 0
# scanned=98611
# found=0
# cleaned=0
# scan_time=3697
en ik deed ook een combofix scan
ComboFix 14-01-01.01 - Peter 01-01-2014 18:28:42.1.2 - x86
Microsoft Windows 7 Home Premium 6.1.7601.1.1252.31.1043.18.3062.1719 [GMT 1:00]
Gestart vanuit: c:\users\teddy\pc clean\ComboFix.exe
AV: avast! Antivirus *Disabled/Updated* {17AD7D40-BA12-9C46-7131-94903A54AD8B}
SP: avast! Antivirus *Disabled/Updated* {ACCC9CA4-9C28-93C8-4B81-AFE241D3E736}
SP: Windows Defender *Enabled/Updated* {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
* Nieuw herstelpunt werd aangemaakt
C:\0.bak
c:\windows\IsUn0413.exe
(((((((((((((((((((( Bestanden Gemaakt van 2013-12-01 to 2014-01-01 ))))))))))))))))))))))))))))))
2014-01-01 17:35 . 2014-01-01 17:35 -------- d-----w- c:\users\Default\AppData\Local\temp
2014-01-01 15:31 . 2014-01-01 15:31 -------- d-----w- c:\program files\ESET
2013-12-31 01:52 . 2013-12-31 01:52 190464 ----a-w- c:\program files\epe.exe
2013-12-30 22:11 . 2001-02-12 23:58 226720 ----a-w- c:\programdata\Microsoft\Windows\Start Menu\Programs\Startup\MSOFFICE.EXE
2013-12-30 21:45 . 2013-12-30 21:47 291 ----a-w- c:\programdata\trjibbnrj.reg
2013-12-30 20:46 . 2014-01-01 17:00 -------- d-----w- C:\zoek_backup
2013-12-30 17:54 . 2013-12-30 17:54 -------- d-----w- c:\program files\Google
2013-12-30 14:11 . 2013-12-30 14:11 -------- d-----w- C:\rsit
2013-12-30 00:14 . 2013-12-30 00:14 -------- d-----w- c:\program files\Common Files\Skype
2013-12-30 00:14 . 2013-12-30 00:14 -------- d-----r- c:\program files\Skype
2013-12-30 00:14 . 2013-12-30 00:14 -------- d-----w- c:\programdata\Skype
2013-12-29 22:58 . 2013-12-29 22:58 -------- d-----w- c:\windows\system32\Wat
2013-12-29 19:57 . 2013-12-29 19:58 -------- d-----w- c:\program files\Registrar Registry Manager
2013-12-29 19:12 . 2013-12-29 19:12 -------- d-----w- c:\program files\Windows Installer Clean Up
2013-12-29 19:12 . 2013-12-30 00:07 -------- d-----w- c:\program files\MSECACHE
2013-12-29 18:28 . 2013-12-29 18:28 -------- d-----w- c:\programdata\Lavasoft
2013-12-29 18:20 . 2013-12-29 18:20 -------- d-----w- c:\windows\system32\x64
2013-12-29 18:20 . 2009-09-23 18:30 1002008 ----a-w- c:\windows\system32\igxpun.exe
2013-12-29 18:13 . 2013-12-29 18:13 -------- d-----w- c:\windows\Migration
2013-12-29 17:50 . 2013-12-29 17:53 -------- d-----w- c:\windows\system32\MRT
2013-12-29 17:48 . 2012-07-26 03:21 196608 ----a-w- c:\windows\system32\WUDFHost.exe
2013-12-29 17:48 . 2012-07-26 03:20 73216 ----a-w- c:\windows\system32\WUDFSvc.dll
2013-12-29 17:48 . 2012-07-26 03:20 38912 ----a-w- c:\windows\system32\WUDFCoinstaller.dll
2013-12-29 17:48 . 2012-07-26 03:20 172032 ----a-w- c:\windows\system32\WUDFPlatform.dll
2013-12-29 17:48 . 2012-07-26 02:33 66560 ----a-w- c:\windows\system32\drivers\WUDFPf.sys
2013-12-29 17:48 . 2012-07-26 02:32 155136 ----a-w- c:\windows\system32\drivers\WUDFRd.sys
2013-12-29 17:48 . 2012-07-26 03:20 613888 ----a-w- c:\windows\system32\WUDFx.dll
2013-12-29 17:48 . 2012-03-01 05:46 19824 ----a-w- c:\windows\system32\drivers\fs_rec.sys
2013-12-29 17:48 . 2012-03-01 05:29 5120 ----a-w- c:\windows\system32\wmi.dll
2013-12-29 17:47 . 2010-02-11 07:10 293376 ----a-w- c:\windows\system32\browserchoice.exe
2013-12-29 17:36 . 2013-05-10 04:56 12625408 ----a-w- c:\windows\system32\wmploc.DLL
2013-12-29 17:36 . 2013-05-10 03:48 164864 ----a-w- c:\program files\Windows Media Player\wmplayer.exe
2013-12-29 17:25 . 2013-04-26 04:55 492544 ----a-w- c:\windows\system32\win32spl.dll
2013-12-29 17:23 . 2012-12-07 12:20 2576384 ----a-w- c:\windows\system32\gameux.dll
2013-12-29 17:22 . 2013-07-09 04:52 175104 ----a-w- c:\windows\system32\wintrust.dll
2013-12-29 17:22 . 2012-06-06 05:05 143360 ----a-w- c:\program files\Common Files\System\ado\msjro.dll
2013-12-29 17:22 . 2012-06-06 05:05 372736 ----a-w- c:\program files\Common Files\System\ado\msadox.dll
2013-12-29 17:22 . 2012-06-06 05:05 57344 ----a-w- c:\program files\Common Files\System\ado\msador15.dll
2013-12-29 17:22 . 2012-06-06 05:05 352256 ----a-w- c:\program files\Common Files\System\ado\msadomd.dll
2013-12-29 17:22 . 2012-06-06 05:05 212992 ----a-w- c:\program files\Common Files\System\msadc\msadco.dll
2013-12-29 17:22 . 2012-06-06 05:05 1019904 ----a-w- c:\program files\Common Files\System\ado\msado15.dll
2013-12-29 17:22 . 2012-06-06 05:03 805376 ----a-w- c:\windows\system32\cdosys.dll
2013-12-29 17:22 . 2011-04-29 02:46 311808 ----a-w- c:\windows\system32\drivers\srv.sys
2013-12-29 17:22 . 2011-04-29 02:46 310272 ----a-w- c:\windows\system32\drivers\srv2.sys
2013-12-29 17:22 . 2011-04-29 02:46 114688 ----a-w- c:\windows\system32\drivers\srvnet.sys
2013-12-29 17:20 . 2013-07-20 10:33 102608 ----a-w- c:\windows\system32\PresentationCFFRasterizerNative_v0300.dll
2013-12-29 17:07 . 2013-04-10 05:04 1221632 ----a-w- c:\program files\Windows Journal\NBDoc.DLL
2013-12-29 17:06 . 2012-04-26 04:45 58880 ----a-w- c:\windows\system32\rdpwsx.dll
2013-12-29 17:05 . 2013-06-25 22:56 527064 ----a-w- c:\windows\system32\drivers\Wdf01000.sys
2013-12-29 16:59 . 2012-02-17 05:34 826880 ----a-w- c:\windows\system32\rdpcore.dll
2013-12-29 16:59 . 2012-02-17 04:13 24576 ----a-w- c:\windows\system32\drivers\tdtcp.sys
2013-12-29 00:48 . 2013-12-29 00:48 -------- d-----w- c:\program files\Microsoft
2013-12-28 21:10 . 2013-12-28 21:10 -------- d-----w- c:\programdata\Canneverbe Limited
2013-12-28 20:24 . 1999-12-17 10:13 86016 ----a-w- c:\windows\unvise32.exe
2013-12-28 20:20 . 2013-12-28 20:20 -------- d-----w- c:\program files\Movie Maker 2.6
2013-12-28 18:51 . 2000-05-22 00:00 244416 ----a-w- c:\windows\system32\Msflxgrd.ocx
2013-12-28 18:51 . 2000-05-22 00:00 203976 ----a-w- c:\windows\system32\RICHTX32.OCX
2013-12-28 18:51 . 1999-05-07 00:00 140288 ----a-w- c:\windows\system32\comdlg32.ocx
2013-12-28 17:37 . 2013-12-28 17:37 64168 ----a-w- c:\windows\system32\drivers\aswstm.sys
2013-12-28 17:33 . 2013-12-28 17:37 410528 ----a-w- c:\windows\system32\drivers\aswSP.sys
2013-12-28 17:33 . 2013-12-28 17:37 180248 ----a-w- c:\windows\system32\drivers\aswVmm.sys
2013-12-28 17:33 . 2013-12-28 17:33 49944 ----a-w- c:\windows\system32\drivers\aswRvrt.sys
2013-12-28 17:33 . 2013-12-28 17:37 775952 ----a-w- c:\windows\system32\drivers\aswSnx.sys
2013-12-28 17:33 . 2013-12-28 17:37 67824 ----a-w- c:\windows\system32\drivers\aswMonFlt.sys
2013-12-28 17:33 . 2013-12-28 17:33 79720 ----a-w- c:\windows\system32\drivers\aswRdr2.sys
2013-12-28 17:33 . 2013-12-28 17:37 270240 ----a-w- c:\windows\system32\aswBoot.exe
2013-12-28 17:33 . 2013-12-28 17:33 26136 ----a-w- c:\windows\system32\drivers\aswKbd.sys
2013-12-28 17:33 . 2013-12-28 17:37 43152 ----a-w- c:\windows\avastSS.scr
2013-12-28 17:32 . 2013-12-28 17:32 -------- d-----w- c:\program files\AVAST Software
2013-12-28 12:29 . 2013-12-28 12:29 159744 ----a-w- c:\program files\Internet Explorer\Plugins\npqtplugin5.dll
2013-12-28 12:29 . 2013-12-28 12:29 159744 ----a-w- c:\program files\Internet Explorer\Plugins\npqtplugin4.dll
2013-12-28 12:29 . 2013-12-28 12:29 159744 ----a-w- c:\program files\Internet Explorer\Plugins\npqtplugin3.dll
2013-12-28 12:29 . 2013-12-28 12:29 159744 ----a-w- c:\program files\Internet Explorer\Plugins\npqtplugin2.dll
2013-12-28 12:29 . 2013-12-28 12:29 159744 ----a-w- c:\program files\Internet Explorer\Plugins\npqtplugin.dll
2013-12-28 12:28 . 2013-12-28 12:29 -------- d-----w- c:\program files\QuickTime
2013-12-28 12:28 . 2013-12-28 12:28 -------- d-----w- c:\programdata\Apple Computer
2013-12-28 12:28 . 2013-12-28 12:28 -------- d-----w- c:\program files\Common Files\Apple
2013-12-28 12:28 . 2013-12-28 12:28 -------- d-----w- c:\program files\Apple Software Update
2013-12-28 12:00 . 2013-12-28 12:00 -------- d-----w- c:\program files\Flash Movie Player
2013-12-28 11:56 . 2013-12-28 11:56 -------- d-----w- c:\program files\Common Files\xing shared
2013-12-28 11:56 . 2013-12-28 11:56 499712 ----a-w- c:\windows\system32\msvcp71.dll
2013-12-28 11:56 . 2013-12-28 11:56 348160 ----a-w- c:\windows\system32\msvcr71.dll
2013-12-28 11:56 . 2013-12-28 11:56 -------- d-----w- c:\program files\Real
2013-12-28 11:54 . 2013-12-28 11:54 -------- d-----w- c:\program files\VideoLAN
2013-12-28 11:31 . 2013-12-28 11:31 48640 ----a-w- c:\windows\system32\drivers\KSafeDISK.sys
2013-12-28 11:31 . 2013-12-28 11:31 27648 ----a-w- c:\windows\system32\drivers\BTOWSFF.sys
2013-12-28 11:31 . 2013-12-28 11:31 -------- d-----w- C:\TOOLWIZ
2013-12-28 11:31 . 2013-12-28 11:31 45952 ----a-w- c:\windows\system32\drivers\BTOWSVF.sys
2013-12-28 11:30 . 2013-12-28 11:31 -------- d-----w- c:\program files\ToolwizCareFree
2013-12-28 11:15 . 2013-12-28 11:15 -------- d-----w- c:\windows\system32\Adobe
2013-12-28 10:35 . 2013-12-28 10:35 -------- d-----w- c:\programdata\AVS4YOU
2013-12-28 10:35 . 2013-12-28 10:38 -------- d-----w- c:\program files\Common Files\AVSMedia
2013-12-28 10:34 . 2011-01-11 10:53 24576 ----a-w- c:\windows\system32\msxml3a.dll
2013-12-28 10:32 . 2007-04-15 00:05 991232 ----a-w- c:\windows\system32\imageviewer2.ocx
2013-12-28 10:32 . 2004-03-08 23:00 224016 ----a-w- c:\windows\system32\tabctl32.ocx
2013-12-28 10:32 . 2002-08-29 19:00 1703936 ----a-w- c:\windows\system32\gdiplus.dll
2013-12-28 10:32 . 2000-07-09 18:15 106496 ----a-w- c:\windows\system32\mbprgbar.ocx
2013-12-28 10:32 . 2000-05-22 00:00 608448 ----a-w- c:\windows\system32\comctl32.ocx
2013-12-28 10:32 . 1998-06-24 00:00 164144 ----a-w- c:\windows\system32\comct232.ocx
2013-12-28 10:32 . 1996-01-12 00:00 200704 ----a-w- c:\windows\system32\threed32.ocx
2013-12-28 10:32 . 2013-12-28 10:32 -------- d-----w- c:\program files\PIXresizer
2013-12-28 10:32 . 2000-05-01 23:02 110592 ----a-w- c:\windows\system32\ccrpbds6.dll
2013-12-28 10:32 . 1999-09-16 09:04 151552 ----a-w- c:\windows\system32\ccrpfd6.ocx
2013-12-28 09:14 . 2013-12-28 09:14 -------- d-----w- c:\program files\eysy photo effects
2013-12-28 09:08 . 2013-12-28 09:08 -------- d-----w- c:\program files\Picture Collage Maker Pro
2013-12-28 09:02 . 2013-12-28 09:02 -------- d-----w- c:\programdata\Licenses
2013-12-28 08:56 . 2013-12-28 08:56 -------- d-----w- c:\program files\SUPERAntiSpyware
2013-12-28 08:56 . 2013-12-28 08:56 -------- d-----w- c:\programdata\SUPERAntiSpyware.com
2013-12-28 08:12 . 2013-12-30 20:02 -------- d-----w- c:\program files\Trend Micro
2013-12-28 08:10 . 2013-12-30 00:50 -------- d-----w- c:\programdata\Spybot - Search & Destroy
2013-12-28 08:10 . 2013-12-28 08:10 -------- d-----w- c:\program files\Spybot - Search & Destroy
2013-12-28 08:07 . 2013-12-29 20:32 -------- d-----w- C:\AdwCleaner
2013-12-28 08:01 . 2013-12-28 17:31 -------- d-----w- c:\programdata\AVAST Software
2013-12-28 08:00 . 2013-12-28 08:00 -------- d-----w- c:\programdata\Malwarebytes
2013-12-28 08:00 . 2013-12-28 08:00 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2013-12-28 08:00 . 2013-04-04 13:50 22856 ----a-w- c:\windows\system32\drivers\mbam.sys
2013-12-28 07:44 . 2013-12-28 09:10 -------- d-----w- c:\program files\SlimCleaner
2013-12-28 07:36 . 2013-12-28 07:36 -------- d-----w- c:\program files\Speaking Clock
2013-12-28 07:12 . 2013-12-28 07:12 -------- d-----w- c:\program files\PDF to Word Free
2013-12-28 07:04 . 2013-04-09 13:13 95416 ----a-w- c:\windows\system32\pdfcmon.dll
2013-12-28 07:04 . 2012-05-05 09:54 662288 ----a-w- c:\windows\system32\MSCOMCT2.OCX
2013-12-28 07:04 . 2012-05-05 09:54 137000 ----a-w- c:\windows\system32\MSMAPI32.OCX
2013-12-28 07:04 . 2013-12-30 00:50 -------- d-----w- c:\program files\PDFCreator
2013-12-28 07:04 . 2012-05-05 09:54 23552 ----a-w- c:\windows\system32\MSMPIDE.DLL
REGEDIT4
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\00avast]
@="{472083B0-C522-11CF-8763-00608CC02F24}"
[HKEY_CLASSES_ROOT\CLSID\{472083B0-C522-11CF-8763-00608CC02F24}]
2013-12-28 17:37 259464 ----a-w- c:\program files\AVAST Software\Avast\ashShell.dll
"Ditto"="c:\program files\Ditto\Ditto.exe" [2012-11-08 1433200]
"POP Peeper"="c:\program files\POP Peeper\POPPeeper.exe" [2011-11-16 1613824]
"Speaking Clock Lite"="c:\program files\Speaking Clock\spclock.exe" [2008-11-09 988160]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2013-12-30 39408]
"APSDaemon"="c:\program files\Common Files\Apple\Apple Application Support\APSDaemon.exe" [2013-04-21 59720]
"AvastUI.exe"="c:\program files\AVAST Software\Avast\AvastUI.exe" [2013-12-28 3764024]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2009-09-23 141848]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2009-09-23 173592]
"Persistence"="c:\windows\system32\igfxpers.exe" [2009-09-23 150552]
c:\users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\
Clipboard Magic.lnk - c:\program files\Clipboard Magic\ClipboardMagic.exe [2013-12-28 663552]
Adobe Gamma Loader.lnk - c:\program files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe [2013-12-28 110592]
MSOFFICE.EXE [2001-2-13 226720]
"ConsentPromptBehaviorAdmin"= 5 (0x5)
[hkey_local_machine\software\microsoft\windows\currentversion\explorer\ShellExecuteHooks]
"{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA}"= "c:\program files\SUPERAntiSpyware\SASSEH.DLL" [2013-05-07 115440]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\drivers32]
"aux"=wdmaud.drv
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\!SASCORE]
[HKLM\~\startupfolder\C:^Users^Peter^AppData^Roaming^Microsoft^Windows^Start Menu^Programs^Startup^trjibbnrj.lnk]
path=c:\users\Peter\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\trjibbnrj.lnk
backup=c:\windows\pss\trjibbnrj.lnk.Startup
backupExtension=.Startup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\QuickTime Task]
2013-05-01 02:59 421888 ----a-w- c:\program files\QuickTime\QTTask.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SpybotSD TeaTimer]
2009-01-26 14:31 2144088 --sha-r- c:\program files\Spybot - Search & Destroy\TeaTimer.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SUPERAntiSpyware]
2013-12-19 23:52 5625624 ----a-w- c:\program files\SUPERAntiSpyware\SUPERAntiSpyware.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ToolwizCareFree]
2013-12-28 11:30 5286160 ----a-w- c:\program files\ToolwizCareFree\ToolwizCares.exe
R2 BBSvc;BingBar Service;c:\program files\Microsoft\BingBar\7.3.124.0\BBSvc.exe [2013-12-16 193696]
R2 SkypeUpdate;Skype Updater;c:\program files\Skype\Updater\Updater.exe [2013-10-23 172192]
R3 aswStm;aswStm;c:\windows\system32\drivers\aswStm.sys [2013-12-28 64168]
R3 RdpVideoMiniport;Remote Desktop Video Miniport Driver;c:\windows\system32\drivers\rdpvideominiport.sys [2012-08-23 14848]
R3 TsUsbFlt;TsUsbFlt;c:\windows\system32\drivers\tsusbflt.sys [2012-08-23 49664]
R3 TsUsbGD;Remote Desktop Generic USB Device;c:\windows\system32\drivers\TsUsbGD.sys [2012-08-23 27136]
R3 WatAdminSvc;Windows Activation Technologies-service;c:\windows\system32\Wat\WatAdminSvc.exe [2013-12-29 1343400]
S0 aswRvrt;avast! Revert; [x]
S0 aswVmm;avast! VM Monitor; [x]
S0 BTOWSVF;BTOWSVF;c:\windows\system32\Drivers\BTOWSVF.sys [2013-12-28 45952]
S0 KSafeDISK;KSafeDISK;c:\windows\system32\Drivers\KSafeDISK.sys [2013-12-28 48640]
S1 aswKbd;aswKbd;c:\windows\system32\drivers\aswKbd.sys [2013-12-28 26136]
S1 aswSnx;aswSnx;c:\windows\system32\drivers\aswSnx.sys [2013-12-28 775952]
S1 aswSP;aswSP;c:\windows\system32\drivers\aswSP.sys [2013-12-28 410528]
S1 BTOWSFF;BTOWSFF;c:\windows\system32\Drivers\BTOWSFF.sys [2013-12-28 27648]
S1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\SASDIFSV.SYS [2011-07-22 12880]
S1 SAS***IL;SAS***IL;c:\program files\SUPERAntiSpyware\SAS***IL.SYS [2011-07-12 67664]
S2 !SASCORE;SAS Core Service;c:\program files\SUPERAntiSpyware\SASCORE.EXE [2013-10-10 120088]
S2 aswMonFlt;aswMonFlt;c:\windows\system32\drivers\aswMonFlt.sys [2013-12-28 67824]
S2 RealNetworks Downloader Resolver Service;RealNetworks Downloader Resolver Service;c:\program files\RealNetworks\RealDownloader\rndlresolversvc.exe [2013-08-14 39056]
S3 BBUpdate;BBUpdate;c:\program files\Microsoft\BingBar\7.3.124.0\SeaPort.exe [2013-12-16 247968]
S3 netr28u;Stuurprogramma voor RT2870 USB draadloze LAN-kaart voor Vista;c:\windows\system32\DRIVERS\netr28u.sys [2009-07-13 657408]
2014-01-01 c:\windows\Tasks\DriverEasy Scheduled Scan.job
- c:\program files\Easeware\DriverEasy\DriverEasy.exe [2013-12-28 01:16]
2014-01-01 c:\windows\Tasks\FreeFileViewerUpdateChecker.job
- c:\program files\FreeFileViewer\FFVCheckForUpdates.exe [2013-12-28 17:24]
2014-01-01 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2013-12-30 17:54]
2014-01-01 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
uStart Page = https://www.facebook.com/hobbyfotograaf
IE: E&xporteren naar Microsoft Excel - c:\progra~1\MICROS~4\OFFICE11\EXCEL.EXE/3000
TCP: DhcpNameServer = 192.168.1.1
TCP: Interfaces\{5E3FC910-BFD1-4DC2-8A27-4C0D8FAAA46E}: NameServer = 208.67.222.222,208.67.222.220
FF - ProfilePath - c:\users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\
FF - ExtSQL: 2013-12-27 23:15; {7E7165E2-0767-448c-852F-5FA8714F2C37}; c:\users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\{7E7165E2-0767-448c-852F-5FA8714F2C37}
FF - ExtSQL: 2013-12-27 23:40; {bee6eb20-01e0-ebd1-da83-080329fb9a3a}; c:\users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\{bee6eb20-01e0-ebd1-da83-080329fb9a3a}
FF - ExtSQL: 2013-12-27 23:40; YoutubeDownloader@PeterOlayev.com; c:\users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\YoutubeDownloader@PeterOlayev.com.xpi
FF - ExtSQL: 2013-12-28 02:22; {b9db16a4-6edc-47ec-a1f4-b86292ed211d}; c:\users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\{b9db16a4-6edc-47ec-a1f4-b86292ed211d}
FF - ExtSQL: 2013-12-28 02:22; paulsaintuzb@gmail.com; c:\users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\paulsaintuzb@gmail.com.xpi
FF - ExtSQL: 2013-12-28 02:22; artur.dubovoy@gmail.com; c:\users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\artur.dubovoy@gmail.com.xpi
FF - ExtSQL: 2013-12-28 12:00; {77b819fa-95ad-4f2c-ac7c-486b356188a9}; c:\users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\{77b819fa-95ad-4f2c-ac7c-486b356188a9}
FF - ExtSQL: 2013-12-28 12:00; {1BC9BA34-1EED-42ca-A505-6D2F1A935BBB}; c:\users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\{1BC9BA34-1EED-42ca-A505-6D2F1A935BBB}
FF - ExtSQL: 2013-12-28 12:00; openinie@wittersworld.com; c:\users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\openinie@wittersworld.com.xpi
FF - ExtSQL: 2013-12-28 12:00; coralietab@mozdev.org; c:\users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\coralietab@mozdev.org
FF - ExtSQL: 2013-12-28 12:24; {d10d0bf8-f5b5-c8b4-a8b2-2b9879e08c5d}; c:\users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\{d10d0bf8-f5b5-c8b4-a8b2-2b9879e08c5d}.xpi
FF - ExtSQL: 2013-12-28 12:26; {b1df372d-8b32-4c7d-b6b4-9c5b78cf6fb1}; c:\users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\{b1df372d-8b32-4c7d-b6b4-9c5b78cf6fb1}.xpi
FF - ExtSQL: 2013-12-28 18:37; wrc@avast.com; c:\program files\AVAST Software\Avast\WebRep\FF
FF - ExtSQL: 2013-12-28 22:33; {b9bfaf1c-a63f-47cd-8b9a-29526ced9060}; c:\users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\{b9bfaf1c-a63f-47cd-8b9a-29526ced9060}.xpi
FF - ExtSQL: 2013-12-29 17:21; yesscript@userstyles.org; c:\users\Peter\AppData\Roaming\Mozilla\Firefox\Profiles\ck28b102.default\extensions\yesscript@userstyles.org.xpi
AddRemove-Adobe Photoshop 7.0 - c:\windows\ISUN0413.EXE
@Denied: (Full) (Everyone)
Voltooingstijd: 2014-01-01 18:36:34
ComboFix-quarantined-files.txt 2014-01-01 17:36
Pre-Run: 49.198.620.672 bytes beschikbaar
Post-Run: 48.972.238.848 bytes beschikbaar
- - End Of File - - 08947CF0F4E4E86910FB7D88123D3DD5
A36C5E4F47E84449FF07ED3517B43A31
ik zit met nog een foutje als ik met rechtermuis op een foto of video klik kon ik vroeger een standaard programma kiezen, of op het internet zoeken naar bijhorend programma, dit werkt niet meer ik krijg melding
Er is voor deze bewerking geen programma aan het opgegeven bestand gekoppeld
ik heb windows opnieuw geinstaleerd, alles werkt oke nu, alvast bedankt en happy 2014
- - - Updated - - -
maar heb nieuw probleem met delen
als ik een map wil delen krijg ik de volgende melding
u hebt geen toegang tot \\PETERKE-PC\SharedDocs. Neem contact op met je netwerk beheerderer om toegang te vragen.
netwerdetectie staat aan
bestand en printindelind staat aan
delen inschakelen... staat aan
paswoord nodig staat op neen
van mijn pc met windows xp kan ik delen
maar niet van mijn pc met windows 7
