Download 52147fb3b2536-AdwCleaner_99_3_16x16x32.pngAdwCleaner by Xplode naar het bureaublad.
AdwCleaner uitvoeren
  • Dubbelklik op AdwCleaner.exe om de tool te starten.
  • Klik vervolgens op de knop Scan.
  • Wanneer de scan gereed is Klikt u vervolgens op de knop Clean.
  • Als dit gereed is wordt er gevraagd om de computer opnieuw op te starten, klik hier op OK.
  • Nadat de computer opnieuw is opgestart wordt het logbestand automatisch geopend.
  • Plaats dit logbestand in het volgende bericht.
  • Reacties 28
dwCleaner v3.017 - Report created 18/01/2014 at 23:44:53
# Updated 12/01/2014 by Xplode
# Operating System : Windows Vista Home Premium Service Pack 2 (32 bits)
# Username : Simon - LH-8T16PC5A3PEY
# Running from : C:\Users\Simon\Downloads\adwcleaner.exe
# Option : Clean
***** [ Services ] *****
***** [ Files / Folders ] *****
Folder Deleted : C:\ProgramData\VauudoIex
***** [ Shortcuts ] *****
***** [ Registry ] *****
Key Deleted : HKLM\SOFTWARE\Classes\bbylntlbr.bbylntlbrHlpr
Key Deleted : HKLM\SOFTWARE\Classes\bbylntlbr.bbylntlbrHlpr.1
Key Deleted : HKLM\SOFTWARE\Classes\driverscanner
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{AF175732-0D59-716D-F757-9F1492D808D9}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{DE9028D0-5FFA-4E69-94E3-89EE8741F468}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{DB507187-9746-458C-97DA-C458131EEDE7}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{13ABD093-D46F-40DF-A608-47E162EC799D}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{A7A6995D-6EE1-4FD1-A258-49395D5BF99C}
Key Deleted : HKCU\Software\Softonic
Key Deleted : HKCU\Software\Wajam
Key Deleted : HKCU\Software\AppDataLow\SProtector
Key Deleted : HKLM\Software\SP Global
Key Deleted : HKLM\Software\SProtector
Key Deleted : HKLM\Software\Uniblue
Key Deleted : HKLM\Software\Wajam
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache\{C670DCAE-E392-AA32-6F42-143C7FC4BDFD}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache\Vid-Saver
Key Deleted : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\0FF2AEFF45EEA0A48A4B33C1973B6094
Key Deleted : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\305B09CE8C53A214DB58887F62F25536
***** [ Browsers ] *****
-\\ Internet Explorer v9.0.8112.16526
-\\ Mozilla Firefox v26.0 (nl)
[ File : C:\Users\Simon\AppData\Roaming\Mozilla\Firefox\Profiles\extensions\prefs.js ]
[ File : C:\Users\Simon\AppData\Roaming\Mozilla\Firefox\Profiles\fzplg2hz.default-1389980085299\prefs.js ]
-\\ Google Chrome v
[ File : C:\Users\Simon\AppData\Local\Google\Chrome\User Data\Default\preferences ]
Deleted : homepage
Deleted : urls_to_restore_on_startup
AdwCleaner[R0].txt - [2447 octets] - [18/01/2014 23:41:05]
AdwCleaner[s0].txt - [2414 octets] - [18/01/2014 23:44:53]
########## EOF - C:\AdwCleaner\AdwCleaner[s0].txt - [2474 octets] ##########
net helaas weer dezelfde crash gehad IQRL_NOT_LESS_OR_EQUAL
zit er aan te twijfelen of mijn ram of grafische kaart mischien kapot is
aangepast door monis71
Dat je jouw probleem zo snel mogelijk wil opgelost zien kan ik best begrijpen.
Maar je moet wel rekening houden met het feit dat alle medewerkers hier vrijwilligers zijn en dat die dus andere leden hun problemen proberen oplossen in hun vrije tijd.
Dus kan het soms even duren voor je verder geholpen wordt.
Ik ben geen hardware expert maar ik kan je alvast doorgeven hoe je het Ram- geheugen kan testen, voer onderstaande uit:
Doe eens een geheugentest met Memtest86+
Alle informatie hierover vind je in deze handleiding.
Dat begrijp ik ook volkomen maar ik wil niet dat dit topic vergeten wordt. Het is me al een keer voorgekomen vandaar.
