# AdwCleaner v3.018 - Report created 11/02/2014 at 13:15:26
# Updated 28/01/2014 by Xplode
# Operating System : Windows 7 Home Premium Service Pack 1 (64 bits)
# Username : ( - HPHPE330BE
# Running from : C:\Users\(\Downloads\adwcleaner.exe
# Option : Clean
***** [ Services ] *****
***** [ Files / Folders ] *****
***** [ Shortcuts ] *****
***** [ Registry ] *****
Key Deleted : HKLM\SOFTWARE\Classes\driverscanner
Key Deleted : HKCU\Software\IM
Key Deleted : HKCU\Software\ParetoLogic
Key Deleted : HKCU\Software\Softonic
Key Deleted : HKLM\Software\ParetoLogic
Key Deleted : HKLM\Software\Uniblue\DriverScanner
***** [ Browsers ] *****
-\\ Internet Explorer v11.0.9600.16428
-\\ Mozilla Firefox v27.0 (nl)
[ File : C:\Users\(\AppData\Roaming\Mozilla\Firefox\Profiles\18mq6zal.default-1370327011862\prefs.js ]
-\\ Google Chrome v
[ File : C:\Users\(\AppData\Local\Google\Chrome\User Data\Default\preferences ]
AdwCleaner[R0].txt - [1334 octets] - [11/02/2014 13:13:56]
AdwCleaner[s0].txt - [1144 octets] - [11/02/2014 13:15:26]
########## EOF - C:\AdwCleaner\AdwCleaner[s0].txt - [1204 octets] ##########
Prima zo ... dan mag je de gebruikte tools verwijderen en nog wat restjes opruimen :
  • Remove disinfection tools
  • Purge System Restore
  • Reset system settings
