C:\Users\Nelleke\AppData\Roaming\Mozilla\Firefox\Profiles\fiejsl2o.default-1357987608005\extensions\feca4b87-3be4-43da-a1b1-137c24220968@jetpack.xpi;fs
C:\Users\Nelleke\AppData\Roaming\Mozilla\Firefox\Profiles\fiejsl2o.default-1357987608005\extensions\ffextension@weheartit.com.xpi;fs
C:\Users\Nelleke\AppData\Roaming\Mozilla\Firefox\Profiles\fiejsl2o.default-1357987608005\extensions\jid1-YcMV6ngYmQRA2w@jetpack.xpi;fs
C:\Program Files (x86)\IObit\Advanced SystemCare 8;fs
C:\Program Files (x86)\IObit;fs
IObit;z
IObit;a
autoclean;
Zoek.exe logbestand plaatsen
  • Reacties 62
C:\IObit;fs
C:\Program Files (x86)\Common Files\IObit;fs
C:\ProgramData\IObit;fs
C:\Users\All Users\IObit;fs
C:\Users\Nelleke\AppData\LocalLow\IObit;fs
C:\Windows\SysWOW64\config\systemprofile\AppData\Roaming\IObit;fs
[HKEY_LOCAL_MACHINE\SOFTWARE\ADSRemoval];r
"UninstallString"=-;r
"InstallLocation"=-;r
[-HKEY_LOCAL_MACHINE\SOFTWARE\IObit];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\IObit\Advanced SystemCare 6];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\IObit\Advanced SystemCare 7];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\IObit\Advanced SystemCare 8];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\IObit\Advanced SystemCare Ultimate];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\IObit\ASC];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\IObit\Driver Booster];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\IObit\IObit Malware Fighter];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\IObit\LiveUpdate];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\IObit\RealTimeProtector];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\IObit\Uninstaller 4];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\*\shellex\ContextMenuHandlers\IObit Malware Fighter];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\*\shellex\ContextMenuHandlers\IObitUnstaler];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\//\//\IObit Cloud Anti-Malwre];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Directory\shellex\ContextMenuHandlers\IObitUnstaler];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Folder\ShellEx\ContextMenuHandlers\IObitUnstaler];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\lnkfile\shellex\ContextMenuHandlers\IObit Malware Fighter];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\lnkfile\shellex\ContextMenuHandlers\IObitUnstaler];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{60AD0991-ECD4-49DC-B170-8B7E7C60F51B}\1.0\0\win64];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{60AD0991-ECD4-49DC-B170-8B7E7C60F51B}\1.0\HELPDIR];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{ACB9DC96-D7BB-430F-AE6B-97F0DFDEAFCC}\1.0\0\win64];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{ACB9DC96-D7BB-430F-AE6B-97F0DFDEAFCC}\1.0\HELPDIR];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{CFDD9042-CEFB-4B68-B956-90CB0E466B38}\1.0\0\win64];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{CFDD9042-CEFB-4B68-B956-90CB0E466B38}\1.0\HELPDIR];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\TypeLib\{60AD0991-ECD4-49DC-B170-8B7E7C60F51B}\1.0\0\win64];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\TypeLib\{60AD0991-ECD4-49DC-B170-8B7E7C60F51B}\1.0\HELPDIR];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\TypeLib\{ACB9DC96-D7BB-430F-AE6B-97F0DFDEAFCC}\1.0\0\win64];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\TypeLib\{ACB9DC96-D7BB-430F-AE6B-97F0DFDEAFCC}\1.0\HELPDIR];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\TypeLib\{CFDD9042-CEFB-4B68-B956-90CB0E466B38}\1.0\0\win64];r
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\TypeLib\{CFDD9042-CEFB-4B68-B956-90CB0E466B38}\1.0\HELPDIR];r
[HKEY_USERS\.DEFAULT\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Persisted];r
"C:\\ProgramData\\IObit\\ASCDownloader\\Smart Defrag.exe"=-;r
"C:\\ProgramData\\IObit\\ASCDownloader\\Driver Booster.exe"=-;r
[HKEY_USERS\S-1-5-18\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Persisted];r
Nog steeds wanneer ik bv op de site van de telegraaf ben...en een filmpje aanklik en de site een nieuwe pagina opent waar de filmpjes staan..komt het filmpje niet in beeld het blijft een leeg wit vak???
Dit is 1 van de verschijnselen de andere is het constant draaiende wieltje bij de muis :angry:
Dat draaiende wieltje wijst op een proces dat in de achtergrond loopt.
Klik nu op de hoofding van de kolom "processor" tot de processen die cpu verbruiken bovenaan staan.
Zo zie je welk proces het meeste van je cpu kracht vraagt.
Maak nu van je Taakbeheer een afbeelding en voeg dit toe als bijlage in je volgende bericht.
Hierop is niks te zien.
Een heel normale toestand met slechts 2% cpu-belasting.
Dan zullen we het ergens anders moeten zoeken.
Ga naar start, typ eventvwr.msc in het zoekvak en klik op OK.
Dubbelklik op windows logboeken.
Dubbelklik op het logboek voor systeem.
Bij geregistreerd selecteer je afgelopen 24 uur en klik op OK.
Klik in de rechterkolom bij acties op gefilterd logboek opslaan als... .
Doe nu hetzelfde voor het logboek toepassingen en noem het bestand AppLog.
Je kan nu beide bestanden (SysLog.evtx en AppLog.evtx) samen inpakken in 1 zip bestand en dit zip bestand als bijlage toevoegen aan een volgend bericht.
Goedemorgen Kweezie rabbit
Hoop dat ik het goed heb gedaan het logje is bijgevoegd.
Kan het er ook mee te maken hebben dat adobe flashplayer niet geupdate kan worden?
Krijg ook vaak een melding dat window verkenner niet werkt.
Icloud kan ik ook niet updaten.
Weet niet of dit relevant is ??
Groet en hartelijk dank voor je hulp...
Nelleke
Applog (2).zip
Syslog.zip
Ga naar Start -> Alle programma's -> Bureauaccessoires.
Typ nu mountvol > %userprofile%\desktop\mountvol.txt en druk enter.
Let op de spatie voor en na de >.
Je zou nu het bestandje mountvol.txt op je bureaublad moeten hebben.
Voeg dit bestandje als bijlage toe aan je volgend bericht.
