C:\Program Files (x86)\AVG;fs
C:\ProgramData\Avg;fs
C:\Users\All Users\Avg;fs
C:\Users\computer\AppData\Local\Avg;fs
C:\Users\computer\AppData\Local\AvgSetupLog;fs
C:\Users\computer\AppData\Local\Packages\windows_ie_ac_001\AC\AVG Web TuneUp;fs
C:\Users\computer\AppData\Roaming\AVG;fs
C:\Windows\ServiceProfiles\LocalService\AppData\Local\Avg;fs
C:\Windows\System32\config\systemprofile\AppData\Local\Avg;fs
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\Avg;fs
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\AvgSetupLog;fs
C:\Windows\SysWOW64\config\systemprofile\AppData\Roaming\AVG;fs
C:\Program Files (x86)\Common Files\mcafee;fs
C:\ProgramData\McAfee;fs
C:\Users\All Users\McAfee;fs
C:\Users\computer\AppData\Local\Microsoft\Windows\INetCache\Virtualized\C\ProgramData\McAfee;fs
C:\Users\computer\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_www.avg.com_0.localstorage;f
C:\Users\computer\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_www.avg.com_0.localstorage-journal;f
C:\Users\computer\AppData\Local\Packages\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\AC\#!001\MicrosoftEdge\User\Default\DOMStore\L1802ICE\www.avg[1].xml;f
C:\Windows\ELAMBKUP\avgboota.sys;f
C:\Windows\Prefetch\AVGSETUPX.EXE-7568D0C5.pf;f
C:\Windows\Prefetch\AVGSETUPX.EXE-CC991EB8.pf;f
C:\Windows\Prefetch\AVGSETUPX.EXE-CEBB255C.pf;f
C:\Windows\Prefetch\AVGSETUPX.EXE-E96D18FD.pf;f
C:\Windows\Prefetch\AVG_AVC_STB_ALL_2015_LTST_501-33C3CDC2.pf;f
C:\Windows\Prefetch\AVG_REMOVER_STF_X64_2015_5501-AFE9C8C0.pf;f
AvgAMPS;s
C:\WINDOWS\system32\DRIVERS\avgidsha.sys;f
C:\WINDOWS\system32\DRIVERS\avgmfx64.sys;f
C:\WINDOWS\system32\DRIVERS\avgrkx64.sys;f
C:\WINDOWS\system32\DRIVERS\avguniva.sys;f
C:\WINDOWS\system32\DRIVERS\avgdiska.sys;f
C:\WINDOWS\system32\DRIVERS\avgwfpa.sys;f
C:\WINDOWS\system32\DRIVERS\avgboota.sys;f
C:\WINDOWS\system32\DRIVERS\avgloga.sys;f
C:\WINDOWS\system32\DRIVERS\avgldx64.sys;f
C:\Program Files(x86)\McAfee;fs
Zoek.exe logbestand plaatsen
De scan gedaan maar het gaf het volgende probleem dat ik een melding kreeg van automatich herstel ( wat niet lukte) en uiteindelijk bij geanvanceerde optie pc herstel met
behoud van mijn bestanden ...ik weet niet of dit de bedoeling was :questionmark:
Maar hier het log toegevoegd
zoek-results.txt
microsoft edge browser geeft nog steeds af en toe melding dat de pagina niet gevonden kan worden en dat de verbinding met outlook niet goed is.
Andere apparaten verder werken prima en is er geen probleem.
post-10399-0-31175800-1458495081_thumb.p
Bij mijn metwerkinstelllingen zag ik dat de  "vliegstand" was ingeschakeld :hmmmm: misschien dat daardoor de verbinding iedere keer wegviel?
In ieder geval werkt het nu een stuk beter ...maar wacht verder af .
Doe een registeropruiming met CCleaner.
start CCleaner op.
Klik in de linkse kolom op Registeren vervolgens op ‘Scan naar problemen”
Kies dan Herstel alle geselecteerde fouten”.
avg;a
mcafee;a
aangepast door kweezie wabbit
Sorry, dat was een klein foutje van mij.
De mail dient voornamelijk om je te melden dat er een nieuw bericht is in het topic.
Best enkel voortgaan op wat in het topic staat en niet op de mail.
  • Klik op Scan.
  • Klik vervolgens op Clean (Engelse versie)of Verwijderen (Nederlandse versie).
Voeg dit logje toe aan je volgend bericht.
Anders is het hier terug te vinden C:\\AdwCleaner\\AdwCleaner[C0].txt.
