paint shop pro X2 start niet meer
Gast Italyfan
Hallo, ik heb het volgende probleem:
PSPX2 start niet meer op en ik krijg de volgende melding:
microsoft visual c++ runtime library
runtime error
Program : d:\program files\corel\c...
This application has requested the runtime to trminate it in an unusual way.
Please contact the application's support team for more information
het systeem draait met windows Xp, en het vreemde is dat psp wel opstart in veilige modus
Wie kan mij helpen, ik stuur alvast een logje mee.
Alvast bedankt voor wie me helpen kan.
Scan saved at 11:57:40, on 31/05/2009
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\Program Files\Common Files\BitDefender\BitDefender Update Service\livesrv.exe
D:\Program Files\BitDefender\BitDefender 2009\vsserv.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Google\Update\GoogleUpdate.exe
C:\WINDOWS\SOUNDMAN.EXE
D:\Program Files\Telemeter 3.0\telemeter3.exe
D:\Program Files\HP\HP Software Update\HPWuSchd2.exe
D:\Program Files\Adobe\Acrobat 7.0\Distillr\Acrotray.exe
D:\Program Files\Unlocker\UnlockerAssistant.exe
D:\Program Files\BitDefender\BitDefender 2009\bdagent.exe
C:\Program Files\ATI Technologies\ATI.ACE\cli.exe
C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
C:\Program Files\VIA\RAID\raid_tool.exe
D:\Program Files\SlySoft\AnyDVD\AnyDVD.exe
D:\Program Files\Java\jre6\bin\jqs.exe
D:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
C:\WINDOWS\system32\HPZipm12.exe
D:\Program Files\HP\Digital Imaging\bin\hpqimzone.exe
D:\Program Files\BitDefender\BitDefender 2009\seccenter.exe
D:\Program Files\HP\Digital Imaging\bin\hpqSTE08.exe
C:\WINDOWS\system32\SearchIndexer.exe
C:\Program Files\IncrediMail\bin\IMApp.exe
C:\WINDOWS\system32\wuauclt.exe
C:\WINDOWS\system32\SearchProtocolHost.exe
D:\download prog\Clean prog\HiJackThis\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = telenet.be/5/0/1/nl/thuis.html
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = Live Search
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = Live Search
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - D:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: Skype add-on (mastermind) - {22BF413B-C6D2-4d91-82A9-A0F997BA588C} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll
O2 - BHO: Adobe PDF Conversion Toolbar Helper - {AE7CD045-E861-484f-8273-0445EE161910} - D:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.3572\swg.dll
O2 - BHO: Google Dictionary Compression sdch - {C84D72FE-E17D-4195-BB24-76C02E2E7C4E} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_9993303B90FE6C1D.dll
O2 - BHO: Java Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - D:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - D:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - D:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll
O3 - Toolbar: BitDefender Toolbar - {381FFDE8-2394-4f90-B10D-FC6124A40F8C} - D:\Program Files\BitDefender\BitDefender 2009\IEToolbar.dll
O3 - Toolbar: &Google Toolbar - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll
O4 - HKLM\..\Run: [Corel File Shell Monitor] D:\Program Files\Corel\Corel Paint Shop Pro Photo X2\CorelIOMonitor.exe
O4 - HKLM\..\Run: [soundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [Telemeter 3.0] "d:\Program Files\Telemeter 3.0\telemeter3.exe"
O4 - HKLM\..\Run: [HP Software Update] D:\Program Files\HP\HP Software Update\HPWuSchd2.exe
O4 - HKLM\..\Run: [Acrobat Assistant 7.0] "D:\Program Files\Adobe\Acrobat 7.0\Distillr\Acrotray.exe"
O4 - HKLM\..\Run: [unlockerAssistant] "D:\Program Files\Unlocker\UnlockerAssistant.exe"
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [ATIPTA] C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
O4 - HKLM\..\Run: [bDAgent] "D:\Program Files\BitDefender\BitDefender 2009\bdagent.exe"
O4 - HKLM\..\Run: [bitDefender Antiphishing Helper] "D:\Program Files\BitDefender\BitDefender 2009\IEShow.exe"
O4 - HKLM\..\Run: [ATICCC] "C:\Program Files\ATI Technologies\ATI.ACE\cli.exe" runtime -Delay
O4 - HKLM\..\Run: [sunJavaUpdateSched] "D:\Program Files\Java\jre6\bin\jusched.exe"
O4 - HKLM\..\Run: [RaidTool] C:\Program Files\VIA\RAID\raid_tool.exe
O4 - HKLM\..\Run: [NeroCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [iTunesHelper] "D:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [Google Quick Search Box] "C:\Program Files\Google\Quick Search Box\qsb.exe" /autorun
O4 - HKLM\..\Run: [ElbyCheckAnyDVD] "d:\Program Files\SlySoft\AnyDVD\ElbyCheck.exe" /L AnyDVD
O4 - HKLM\..\Run: [AnyDVD] D:\Program Files\SlySoft\AnyDVD\AnyDVD.exe
O4 - HKCU\..\Run: [incrediMail] C:\Program Files\IncrediMail\bin\IncMail.exe /c
O4 - HKCU\..\Run: [skype] "C:\Program Files\Skype\Phone\Skype.exe" /nosplash /minimized
O4 - HKCU\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\MSN Messenger\MsnMsgr.Exe" /background
O4 - HKCU\..\Run: [mediacodec.exe] C:\DOCUME~1\nineke\LOCALS~1\Temp\mediacodec.exe
O4 - Global Startup: Adobe Acrobat Speed Launcher.lnk = ?
O4 - Global Startup: HP Digital Imaging Monitor.lnk = D:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
O4 - Global Startup: HP Photosmart Premier Snelstart.lnk = D:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe
O4 - Global Startup: Windows Search.lnk = C:\Program Files\Windows Desktop Search\WindowsSearch.exe
O8 - Extra context menu item: Convert link target to Adobe PDF - res://D:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert link target to existing PDF - res://D:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert selected links to Adobe PDF - res://D:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
O8 - Extra context menu item: Convert selected links to existing PDF - res://D:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
O8 - Extra context menu item: Convert selection to Adobe PDF - res://D:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert selection to existing PDF - res://D:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert to Adobe PDF - res://D:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert to existing PDF - res://D:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: E&xporteren naar Microsoft Excel - res://D:\PROGRA~1\MICROS~1\Office12\EXCEL.EXE/3000
O9 - Extra button: Verzenden naar OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - D:\PROGRA~1\MICROS~1\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: Verz&enden naar OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - D:\PROGRA~1\MICROS~1\Office12\ONBttnIE.dll
O9 - Extra button: Skype - {77BF5300-1474-4EC7-9980-D32B190E9B07} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - D:\PROGRA~1\MICROS~1\Office12\REFIEBAR.DLL
O16 - DPF: {474F00F5-3853-492C-AC3A-476512BBC336} (UploadListView Class) - http://picasaweb.google.nl/s/v/43.10/uploader2.cab
O16 - DPF: {4F1E5B1A-2A80-42CA-8532-2D05CB959537} (MSN Photo Upload Tool) - MSN Groups Closure Notice
O16 - DPF: {BFF1950D-B1B4-4AE8-B842-B2CCF06D9A1B} (Zylom Games Player) - http://game09.zylom.com/activex/zylomgamesplayer.cab
O16 - DPF: {D71F9A27-723E-4B8B-B428-B725E47CBA3E} (Imikimi_activex_plugin Control) - http://imikimi.com/download/imikimi_plugin_0.5.1.cab
O18 - Filter: x-sdch - {B1759355-3EEC-4C1E-B0F1-B719FE26E377} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_9993303B90FE6C1D.dll
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Mobiel Apple apparaat (Apple Mobile Device) - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: BitDefender Arrakis Server (Arrakis3) - BitDefender S.R.L. Antivirus software - BitDefender - The future of security now! - C:\Program Files\Common Files\BitDefender\BitDefender Arrakis Server\bin\Arrakis3.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: ATI Smart - Unknown owner - C:\WINDOWS\system32\ati2sgag.exe
O23 - Service: Google Updateservice (gupdate1c993b036eac032) (gupdate1c993b036eac032) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - D:\Program Files\Java\jre6\bin\jqs.exe
O23 - Service: BitDefender Desktop Update Service (LIVESRV) - BitDefender SRL - C:\Program Files\Common Files\BitDefender\BitDefender Update Service\livesrv.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\system32\HPZipm12.exe
O23 - Service: Protexis Licensing V2 (PSI_SVC_2) - Protexis Inc. - C:\Program Files\Common Files\Protexis\License Service\PsiService_2.exe
O23 - Service: BitDefender Virus Shield (VSSERV) - BitDefender S. R. L. - D:\Program Files\BitDefender\BitDefender 2009\vsserv.exe
End of file - 12219 bytes
Gast Italyfan
Hebt je HP printer een tijdje?
Is die PSPX2 geinstalleerd voor HP of erna?
hi,
de HP en de psp zijn er al reeds een jaar.
heb wel en probleem gehad met de infectie mediacodec, maar deze is verwijdert.
de psp start wel op in veilige modus maar niet in de normale modus
hopelijk heb he hier wat aan
alvast bedankt
ps weet niet meer wat er eerst op stond
Gast Italyfan
Ik vermoed dat het om Zylom Games Player gaat.
Kijk eens met CRTL+ALT+DEL
Onderaan ziet u CPU verbruikt?
Op hoeveel % staat die?
hi,
varieert tusen de 15 en 20 %, blijkt normaal te zijn.
dit terwijl er 2 programma's open staan 'incredimail en psp 9'
zal iets anders zijn zeker?
